[GRASS-SVN] r32743 - in grass/branches/develbranch_6: gui gui/icons gui/images gui/wxpython gui/wxpython/gui_modules lib/init
Wed Aug 13 12:08:14 EDT 2008
Author: martinl
Date: 2008-08-13 12:08:13 -0400 (Wed, 13 Aug 2008)
New Revision: 32743
Added:
   grass/branches/develbranch_6/gui/icons/grass.ico
   grass/branches/develbranch_6/gui/icons/grass_dialog.ico
   grass/branches/develbranch_6/gui/icons/grass_error.ico
   grass/branches/develbranch_6/gui/icons/grass_map.ico
   grass/branches/develbranch_6/gui/icons/grass_nviz.ico
   grass/branches/develbranch_6/gui/icons/grass_sql.ico
   grass/branches/develbranch_6/gui/images/
   grass/branches/develbranch_6/gui/images/Makefile
   grass/branches/develbranch_6/gui/images/gintro.gif
Removed:
   grass/branches/develbranch_6/lib/init/gintro.gif
   grass/branches/develbranch_6/lib/init/grass.ico
   grass/branches/develbranch_6/lib/init/grass_dialog.ico
   grass/branches/develbranch_6/lib/init/grass_error.ico
   grass/branches/develbranch_6/lib/init/grass_map.ico
   grass/branches/develbranch_6/lib/init/grass_nviz.ico
   grass/branches/develbranch_6/lib/init/grass_sql.ico
   grass/branches/develbranch_6/gui/Makefile
   grass/branches/develbranch_6/gui/icons/Makefile
   grass/branches/develbranch_6/gui/wxpython/gis_set.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
   grass/branches/develbranch_6/lib/init/Makefile
   grass/branches/develbranch_6/lib/init/gis_set.tcl
lib/init: ICO files moved to gui/icons, intro image to gui/images
Modified: grass/branches/develbranch_6/gui/Makefile
--- grass/branches/develbranch_6/gui/Makefile	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/Makefile	2008-08-13 16:08:13 UTC (rev 32743)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ..
-SUBDIRS = icons scripts xml tcltk wxpython
+SUBDIRS = icons images scripts xml tcltk wxpython
 include $(MODULE_TOPDIR)/include/Make/Platform.make
@@ -9,4 +9,3 @@
 default: parsubdirs
 clean: cleansubdirs
Modified: grass/branches/develbranch_6/gui/icons/Makefile
--- grass/branches/develbranch_6/gui/icons/Makefile	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/icons/Makefile	2008-08-13 16:08:13 UTC (rev 32743)
@@ -2,13 +2,14 @@
 include $(MODULE_TOPDIR)/include/Make/Dir.make
-default:
-	if [ ! -d $(GISBASE)/etc/gui ] ; then $(MKDIR) $(GISBASE)/etc/gui ; fi
-	if [ ! -d $(GISBASE)/etc/gui/icons ] ; then $(MKDIR) $(GISBASE)/etc/gui/icons ; fi
-	if [ ! -d $(GISBASE)/etc/gui/icons/grass ] ; then $(MKDIR) $(GISBASE)/etc/gui/icons/grass ; fi
-	if [ ! -d $(GISBASE)/etc/gui/icons/silk ] ; then $(MKDIR) $(GISBASE)/etc/gui/icons/silk ; fi
-	for icon in grass/*.gif ; do $(INSTALL_DATA) $$icon $(GISBASE)/etc/gui/icons/grass ; done
-	for icon in silk/*.png ; do $(INSTALL_DATA) $$icon $(GISBASE)/etc/gui/icons/silk ; done
+default: $(ICONS)
+	if [ ! -d $(ETC)/gui ] ; then $(MKDIR) $(ETC)/gui ; fi
+	if [ ! -d $(ETC)/gui/icons ] ; then $(MKDIR) $(ETC)/gui/icons ; fi
+	if [ ! -d $(ETC)/gui/icons/grass ] ; then $(MKDIR) $(ETC)/gui/icons/grass ; fi
+	if [ ! -d $(ETC)/gui/icons/silk ] ; then $(MKDIR) $(ETC)/gui/icons/silk ; fi
+	for icon in grass/*.gif ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons/grass ; done
+	for icon in silk/*.png ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons/silk ; done
+	for icon in *.ico ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons ; done
 	if [ ! -d $(GISBASE)/docs ] ; then $(MKDIR) $(GISBASE)/docs ; fi
 	if [ ! -d $(GISBASE)/docs/html ] ; then $(MKDIR) $(GISBASE)/docs/html ; fi
 	if [ ! -d $(GISBASE)/docs/html/icons ] ; then $(MKDIR) $(GISBASE)/docs/html/icons ; fi
@@ -16,3 +17,4 @@
 	if [ ! -d $(GISBASE)/docs/html/icons/silk ] ; then $(MKDIR) $(GISBASE)/docs/html/icons/silk ; fi
 	for icon in grass/*.gif ; do $(INSTALL_DATA) $$icon $(GISBASE)/docs/html/icons/grass ; done
 	for icon in silk/*.png ; do $(INSTALL_DATA) $$icon $(GISBASE)/docs/html/icons/silk ; done
Copied: grass/branches/develbranch_6/gui/icons/grass.ico (from rev 32736, grass/branches/develbranch_6/lib/init/grass.ico)
(Binary files differ)
Property changes on: grass/branches/develbranch_6/gui/icons/grass.ico
___________________________________________________________________
   + image/x-icon
Copied: grass/branches/develbranch_6/gui/icons/grass_dialog.ico (from rev 32736, grass/branches/develbranch_6/lib/init/grass_dialog.ico)
Property changes on: grass/branches/develbranch_6/gui/icons/grass_dialog.ico
   + application/octet-stream
Copied: grass/branches/develbranch_6/gui/icons/grass_error.ico (from rev 32736, grass/branches/develbranch_6/lib/init/grass_error.ico)
Property changes on: grass/branches/develbranch_6/gui/icons/grass_error.ico
   + image/x-icon
Copied: grass/branches/develbranch_6/gui/icons/grass_map.ico (from rev 32736, grass/branches/develbranch_6/lib/init/grass_map.ico)
Property changes on: grass/branches/develbranch_6/gui/icons/grass_map.ico
Copied: grass/branches/develbranch_6/gui/icons/grass_nviz.ico (from rev 32736, grass/branches/develbranch_6/lib/init/grass_nviz.ico)
Property changes on: grass/branches/develbranch_6/gui/icons/grass_nviz.ico
   + image/x-icon
Copied: grass/branches/develbranch_6/gui/icons/grass_sql.ico (from rev 32736, grass/branches/develbranch_6/lib/init/grass_sql.ico)
Property changes on: grass/branches/develbranch_6/gui/icons/grass_sql.ico
Added: grass/branches/develbranch_6/gui/images/Makefile
--- grass/branches/develbranch_6/gui/images/Makefile	                        (rev 0)
+++ grass/branches/develbranch_6/gui/images/Makefile	2008-08-13 16:08:13 UTC (rev 32743)
@@ -0,0 +1,9 @@
+MODULE_TOPDIR = ../..
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default:
+	if [ ! -d $(ETC)/gui/images ] ; then $(MKDIR) $(ETC)/gui/images ; fi
+	$(INSTALL_DATA) gintro.gif $(ETC)/gui/images/gintro.gif
Property changes on: grass/branches/develbranch_6/gui/images/Makefile
   + text/x-sh
   + Author Date Id
   + native
Copied: grass/branches/develbranch_6/gui/images/gintro.gif (from rev 32736, grass/branches/develbranch_6/lib/init/gintro.gif)
Property changes on: grass/branches/develbranch_6/gui/images/gintro.gif
   + image/gif
Modified: grass/branches/develbranch_6/gui/wxpython/gis_set.py
--- grass/branches/develbranch_6/gui/wxpython/gis_set.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gis_set.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -64,7 +64,7 @@
         # image
         try:
-            name = os.path.join(globalvar.ETCDIR, "gintro.gif")
+            name = os.path.join(globalvar.ETCDIR, "gui", "images", "gintro.gif")
             self.hbitmap = wx.StaticBitmap(self.panel, wx.ID_ANY,
                                            wx.Bitmap(name=name,
                                                      type=wx.BITMAP_TYPE_GIF))
@@ -170,7 +170,7 @@
     def _set_properties(self):
         """Set frame properties"""
         self.SetTitle(_("Welcome to GRASS GIS"))
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, "grass.ico"),
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, "grass.ico"),
                              wx.BITMAP_TYPE_ICO))
         self.lwelcome.SetForegroundColour(wx.Colour(35, 142, 35))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -390,7 +390,7 @@
         wx.Frame.__init__(self, parent, id, title, style=style)
         # icon
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
         self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -66,7 +66,7 @@
                                caption=self.title,
                                message=self.message,
                                style=wx.ICON_ERROR | wx.CENTRE)
-        dlg.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_error.ico'), wx.BITMAP_TYPE_ICO))
+        dlg.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_error.ico'), wx.BITMAP_TYPE_ICO))
         if self.parent:
             dlg.CentreOnParent()
         else:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -607,7 +607,7 @@
         wx.Frame.__init__(self, parent, id, title, size=(625, 300))
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
         # init variables
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -71,6 +71,7 @@
 # path to python scripts
 ETCDIR = os.path.join(os.getenv("GISBASE"), "etc")
+ETCICONDIR = os.path.join(os.getenv("GISBASE"), "etc", "gui", "icons")
 ETCWXDIR = os.path.join(ETCDIR, "wxpython")
 """Style definition for FlatNotebook pages"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -2422,7 +2422,7 @@
         self.SetClientSize(size)
         self.iconsize = (16, 16)
         # Fancy gui
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -588,7 +588,7 @@
         self.CreateStatusBar()
         # icon
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
         # menu
         #         menu = wx.Menu()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -1141,7 +1141,7 @@
         # icon
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_nviz.ico'), wx.BITMAP_TYPE_ICO))
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_nviz.ico'), wx.BITMAP_TYPE_ICO))
         # dialog body
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -84,7 +84,7 @@
         # Icon
         # Add toolbar
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -41,7 +41,7 @@
         wx.Frame.__init__(self, parent, id, title)
         self.SetTitle(_("GRASS SQL Builder: %s") % (qtype.upper()))
         # variables
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2008-08-13 16:08:13 UTC (rev 32743)
@@ -107,7 +107,7 @@
                           style=wx.DEFAULT_FRAME_STYLE)
         self.SetTitle(self.baseTitle)
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
         self._auimgr = wx.aui.AuiManager(self)
Modified: grass/branches/develbranch_6/lib/init/Makefile
--- grass/branches/develbranch_6/lib/init/Makefile	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/lib/init/Makefile	2008-08-13 16:08:13 UTC (rev 32743)
@@ -48,17 +48,9 @@
 	$(ETC)/gis_set.tcl \
 	$(ETC)/epsg_option.tcl \
 	$(ETC)/file_option.tcl \
-	$(ETC)/gintro.gif \
 	$(ETC)/grass-run.sh \
 	$(ETC)/grass-xterm-wrapper
-ICONS = $(ETC)/grass.ico \
-	$(ETC)/grass_map.ico \
-	$(ETC)/grass_dialog.ico \
-	$(ETC)/grass_sql.ico \
-	$(ETC)/grass_nviz.ico \
-	$(ETC)/grass_error.ico
 ifeq ($(findstring darwin,$(ARCH)),darwin)
 	FILES += \
 		$(ETC)/grass-xterm-mac \
@@ -72,7 +64,7 @@
 		$(ETC)/grass-run.bat
 endif
-default: $(FILES) $(ICONS)
+default: $(FILES)
 	$(INSTALL_DATA) variables.html $(GISBASE)/docs/html/variables.html
 	$(INSTALL_DATA) grass6.html $(GISBASE)/docs/html/grass6.html
@@ -163,14 +155,6 @@
 	$(MKDIR) $@
 	$(INSTALL_DATA) msgs/*.msg $@
-$(ETC)/gintro.gif: gintro.gif
-	rm -f $@
-	$(INSTALL_DATA) gintro.gif $@
-$(ICONS): grass.ico grass_map.ico grass_sql.ico grass_dialog.ico grass_nviz.ico grass_error.ico
-	rm -f $@
-	$(INSTALL_DATA) $< $@
 $(ETC)/gis_set.tcl: gis_set.tcl
 	rm -f $@
 	$(INSTALL) gis_set.tcl $(ETC)
Deleted: grass/branches/develbranch_6/lib/init/gintro.gif
Modified: grass/branches/develbranch_6/lib/init/gis_set.tcl
--- grass/branches/develbranch_6/lib/init/gis_set.tcl	2008-08-13 15:13:43 UTC (rev 32742)
+++ grass/branches/develbranch_6/lib/init/gis_set.tcl	2008-08-13 16:08:13 UTC (rev 32743)
@@ -187,7 +187,7 @@
     set titlefrm [frame .frame0.intro -borderwidth 2 ]
     set introimg  [label $titlefrm.img -image [image create photo -file \
-    	"$env(GISBASE)/etc/gintro.gif"]]
+    	"$env(GISBASE)/etc/gui/images/gintro.gif"]]
     set introtitle [text $titlefrm.msg -height 5 \
     	-relief flat -fg darkgreen \
     	-bg #dddddd \
Deleted: grass/branches/develbranch_6/lib/init/grass.ico
Deleted: grass/branches/develbranch_6/lib/init/grass_dialog.ico
Deleted: grass/branches/develbranch_6/lib/init/grass_error.ico
Deleted: grass/branches/develbranch_6/lib/init/grass_map.ico
Deleted: grass/branches/develbranch_6/lib/init/grass_nviz.ico
Deleted: grass/branches/develbranch_6/lib/init/grass_sql.ico
