[GRASS-SVN] r32755 - in grass/trunk: . include include/Make
svn_grass at osgeo.org
Thu Aug 14 04:15:13 EDT 2008
Author: glynn
Date: 2008-08-14 04:15:13 -0400 (Thu, 14 Aug 2008)
New Revision: 32755
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/Make/Platform.make.in
grass/trunk/include/config.h.in
Remove --with-glw switch
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-08-13 21:27:25 UTC (rev 32754)
+++ grass/trunk/configure 2008-08-14 08:15:13 UTC (rev 32755)
@@ -57,8 +57,6 @@
ac_help="$ac_help
--with-freetype support FreeType functionality (default: no)"
ac_help="$ac_help
- --with-glw support GLw functionality (default: no)"
-ac_help="$ac_help
--with-nls support NLS functionality (default: no)"
ac_help="$ac_help
--with-readline support Readline functionality (default: no)"
@@ -169,11 +167,6 @@
--with-freetype-libs=DIRS
FreeType library files are in DIRS"
ac_help="$ac_help
- --with-glw-includes=DIRS
- GLw include files are in DIRS"
-ac_help="$ac_help
- --with-glw-libs=DIRS GLw library files are in DIRS"
-ac_help="$ac_help
--with-proj-includes=DIRS
External PROJ.4 include files are in DIRS"
ac_help="$ac_help
@@ -722,7 +715,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:726: checking host system type" >&5
+echo "configure:719: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -745,7 +738,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:749: checking for $ac_word" >&5
+echo "configure:742: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -772,7 +765,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:776: checking for $ac_word" >&5
+echo "configure:769: checking for $ac_word" >&5
@@ -820,7 +813,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:824: checking for $ac_word" >&5
+echo "configure:817: checking for $ac_word" >&5
@@ -849,7 +842,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:853: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:846: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -860,12 +853,12 @@
cat > conftest.$ac_ext << EOF
-#line 864 "configure"
+#line 857 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -891,19 +884,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:895: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:888: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:900: checking whether we are using GNU C" >&5
+echo "configure:893: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:907: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -921,7 +914,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:925: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:918: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -950,10 +943,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:954: checking for Cygwin environment" >&5
+echo "configure:947: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 957 "configure"
+#line 950 "configure"
int main() {
@@ -964,7 +957,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:968: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -980,17 +973,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:984: checking for mingw32 environment" >&5
+echo "configure:977: checking for mingw32 environment" >&5
-#line 987 "configure"
+#line 980 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1008,7 +1001,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1012: checking for executable suffix" >&5
+echo "configure:1005: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1027,23 +1020,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1031: checking for full floating-point support" >&5
+echo "configure:1024: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1036: checking whether "cc -mieee" works" >&5
+echo "configure:1029: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1040 "configure"
+#line 1033 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1047: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1040: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1059,7 +1052,7 @@
else
-#line 1063 "configure"
+#line 1056 "configure"
#include <float.h>
@@ -1073,7 +1066,7 @@
EOF
-if { (eval echo configure:1077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1086,14 +1079,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1090: checking for full floating-point support with -mieee" >&5
+echo "configure:1083: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1097 "configure"
+#line 1090 "configure"
#include <float.h>
@@ -1107,7 +1100,7 @@
EOF
-if { (eval echo configure:1111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1144,7 +1137,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1148: checking for $ac_word" >&5
+echo "configure:1141: checking for $ac_word" >&5
case "$pwd" in
@@ -1182,7 +1175,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1186: checking for source directory" >&5
+echo "configure:1179: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1193,7 +1186,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1197: checking for build directory" >&5
+echo "configure:1190: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1278,7 +1271,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1282: checking for MacOSX App" >&5
+echo "configure:1275: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1301,7 +1294,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1305: checking how to build libraries" >&5
+echo "configure:1298: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1344,7 +1337,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1348: checking for $ac_word" >&5
+echo "configure:1341: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1369,7 +1362,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1373: checking how to run the C preprocessor" >&5
+echo "configure:1366: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1382,13 +1375,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1386 "configure"
+#line 1379 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1385: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1399,13 +1392,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1403 "configure"
+#line 1396 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1409: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1402: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1416,13 +1409,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1420 "configure"
+#line 1413 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1450,7 +1443,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1454: checking if 64bit support is requested" >&5
+echo "configure:1447: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1470,7 +1463,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1474: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1467: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1494,7 +1487,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1498: checking system version (for dynamic loading)" >&5
+echo "configure:1491: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1520,13 +1513,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1524: checking for dlopen in -ldl" >&5
+echo "configure:1517: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1530 "configure"
+#line 1523 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1537,7 +1530,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1584,7 +1577,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1588: checking for $ac_word" >&5
+echo "configure:1581: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1713,13 +1706,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1717: checking for gettimeofday in -lbsd" >&5
+echo "configure:1710: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1723 "configure"
+#line 1716 "configure"
@@ -1730,7 +1723,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1771,13 +1764,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1775: checking for inet_ntoa in -lbind" >&5
+echo "configure:1768: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1781 "configure"
+#line 1774 "configure"
@@ -1788,7 +1781,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1849,13 +1842,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1853: checking for shl_load in -ldld" >&5
+echo "configure:1846: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1859 "configure"
+#line 1852 "configure"
@@ -1866,7 +1859,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1931,13 +1924,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1935: checking for shl_load in -ldld" >&5
+echo "configure:1928: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1941 "configure"
+#line 1934 "configure"
@@ -1948,7 +1941,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2070,15 +2063,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2074: checking for dld.h" >&5
+echo "configure:2067: checking for dld.h" >&5
-#line 2077 "configure"
+#line 2070 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2082: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2138,15 +2131,15 @@
else
-echo "configure:2142: checking for dld.h" >&5
+echo "configure:2135: checking for dld.h" >&5
-#line 2145 "configure"
+#line 2138 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2143: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2243,9 +2236,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2247: checking for ELF" >&5
+echo "configure:2240: checking for ELF" >&5
-#line 2249 "configure"
+#line 2242 "configure"
#ifdef __ELF__
@@ -2275,15 +2268,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2279: checking for dlfcn.h" >&5
+echo "configure:2272: checking for dlfcn.h" >&5
-#line 2282 "configure"
+#line 2275 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2280: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2307,9 +2300,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2311: checking for ELF" >&5
+echo "configure:2304: checking for ELF" >&5
-#line 2313 "configure"
+#line 2306 "configure"
#ifdef __ELF__
@@ -2633,17 +2626,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2637: checking for ld accepts -Bexport flag" >&5
+echo "configure:2630: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2640 "configure"
+#line 2633 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -2942,16 +2935,6 @@
-# Check whether --with-glw or --without-glw was given.
-if test "${with_glw+set}" = set; then
- withval="$with_glw"
-else
- with_glw=no
-fi
# Check whether --with-nls or --without-nls was given.
if test "${with_nls+set}" = set; then
withval="$with_nls"
@@ -3319,23 +3302,6 @@
-# Check whether --with-glw-includes or --without-glw-includes was given.
-if test "${with_glw_includes+set}" = set; then
- withval="$with_glw_includes"
-fi
-# Check whether --with-glw-libs or --without-glw-libs was given.
-if test "${with_glw_libs+set}" = set; then
- withval="$with_glw_libs"
-fi
# Check whether --with-proj-includes or --without-proj-includes was given.
if test "${with_proj_includes+set}" = set; then
withval="$with_proj_includes"
@@ -3386,7 +3352,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3390: checking for additional include dirs" >&5
+echo "configure:3356: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3409,7 +3375,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3413: checking for additional library dirs" >&5
+echo "configure:3379: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3443,7 +3409,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3447: checking for a BSD compatible install" >&5
+echo "configure:3413: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3496,7 +3462,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3500: checking for $ac_word" >&5
+echo "configure:3466: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3527,13 +3493,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3531: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3497: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3537 "configure"
+#line 3503 "configure"
@@ -3544,7 +3510,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3569,7 +3535,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3573: checking for $ac_word" >&5
+echo "configure:3539: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3609,7 +3575,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3613: checking for $ac_word" >&5
+echo "configure:3579: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3640,7 +3606,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3644: checking for $ac_word" >&5
+echo "configure:3610: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3678,7 +3644,7 @@
-echo "configure:3682: checking for $ac_word" >&5
+echo "configure:3648: checking for $ac_word" >&5
@@ -3707,7 +3673,7 @@
-echo "configure:3711: checking for $ac_word" >&5
+echo "configure:3677: checking for $ac_word" >&5
@@ -3738,7 +3704,7 @@
-echo "configure:3742: checking for $ac_word" >&5
+echo "configure:3708: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3767,7 +3733,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3771: checking for $ac_word" >&5
+echo "configure:3737: checking for $ac_word" >&5
case "$PERL" in
@@ -3798,10 +3764,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3802: checking for ANSI C header files" >&5
+echo "configure:3768: checking for ANSI C header files" >&5
-#line 3805 "configure"
+#line 3771 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3809,7 +3775,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3813: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3826,7 +3792,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3830 "configure"
+#line 3796 "configure"
#include <string.h>
EOF
@@ -3844,7 +3810,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3848 "configure"
+#line 3814 "configure"
#include <stdlib.h>
EOF
@@ -3865,7 +3831,7 @@
else
-#line 3869 "configure"
+#line 3835 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3876,7 +3842,7 @@
exit (0); }
EOF
-if { (eval echo configure:3880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3903,15 +3869,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3907: checking for $ac_hdr" >&5
+echo "configure:3873: checking for $ac_hdr" >&5
-#line 3910 "configure"
+#line 3876 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3915: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3881: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3940,15 +3906,15 @@
do
-echo "configure:3944: checking for $ac_hdr" >&5
+echo "configure:3910: checking for $ac_hdr" >&5
-#line 3947 "configure"
+#line 3913 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3952: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3977,15 +3943,15 @@
do
-echo "configure:3981: checking for $ac_hdr" >&5
+echo "configure:3947: checking for $ac_hdr" >&5
-#line 3984 "configure"
+#line 3950 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3989: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3955: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4014,15 +3980,15 @@
do
-echo "configure:4018: checking for $ac_hdr" >&5
+echo "configure:3984: checking for $ac_hdr" >&5
-#line 4021 "configure"
+#line 3987 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4026: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3992: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4051,15 +4017,15 @@
do
-echo "configure:4055: checking for $ac_hdr" >&5
+echo "configure:4021: checking for $ac_hdr" >&5
-#line 4058 "configure"
+#line 4024 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4063: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4085,10 +4051,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4089: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4055: checking whether time.h and sys/time.h may both be included" >&5
-#line 4092 "configure"
+#line 4058 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4097,7 +4063,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4067: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4117,10 +4083,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4121: checking for off_t" >&5
+echo "configure:4087: checking for off_t" >&5
-#line 4124 "configure"
+#line 4090 "configure"
#if STDC_HEADERS
@@ -4147,10 +4113,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4151: checking for uid_t in sys/types.h" >&5
+echo "configure:4117: checking for uid_t in sys/types.h" >&5
-#line 4154 "configure"
+#line 4120 "configure"
EOF
@@ -4178,10 +4144,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4182: checking return type of signal handlers" >&5
+echo "configure:4148: checking return type of signal handlers" >&5
-#line 4185 "configure"
+#line 4151 "configure"
#include <signal.h>
@@ -4198,7 +4164,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4202: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4168: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4216,10 +4182,10 @@
-echo "configure:4220: checking for Cygwin environment" >&5
+echo "configure:4186: checking for Cygwin environment" >&5
-#line 4223 "configure"
+#line 4189 "configure"
int main() {
@@ -4230,7 +4196,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4234: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4200: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4248,10 +4214,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4252: checking for $ac_func" >&5
+echo "configure:4218: checking for $ac_func" >&5
-#line 4255 "configure"
+#line 4221 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4274,7 +4240,7 @@
; return 0; }
EOF
-if { (eval echo configure:4278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4300,10 +4266,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4304: checking for $ac_func" >&5
+echo "configure:4270: checking for $ac_func" >&5
-#line 4307 "configure"
+#line 4273 "configure"
@@ -4326,7 +4292,7 @@
; return 0; }
EOF
-if { (eval echo configure:4330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4352,10 +4318,10 @@
for ac_func in drand48
do
-echo "configure:4356: checking for $ac_func" >&5
+echo "configure:4322: checking for $ac_func" >&5
-#line 4359 "configure"
+#line 4325 "configure"
@@ -4378,7 +4344,7 @@
; return 0; }
EOF
-if { (eval echo configure:4382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4404,10 +4370,10 @@
for ac_func in putenv setenv
do
-echo "configure:4408: checking for $ac_func" >&5
+echo "configure:4374: checking for $ac_func" >&5
-#line 4411 "configure"
+#line 4377 "configure"
@@ -4430,7 +4396,7 @@
; return 0; }
EOF
-if { (eval echo configure:4434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4456,10 +4422,10 @@
for ac_func in nanosleep
do
-echo "configure:4460: checking for $ac_func" >&5
+echo "configure:4426: checking for $ac_func" >&5
-#line 4463 "configure"
+#line 4429 "configure"
@@ -4482,7 +4448,7 @@
; return 0; }
EOF
-if { (eval echo configure:4486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4507,13 +4473,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4511: checking whether setpgrp takes no argument" >&5
+echo "configure:4477: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4517 "configure"
+#line 4483 "configure"
#ifdef HAVE_UNISTD_H
@@ -4533,7 +4499,7 @@
EOF
-if { (eval echo configure:4537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4561,16 +4527,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4565: checking for long long int" >&5
+echo "configure:4531: checking for long long int" >&5
-#line 4567 "configure"
+#line 4533 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4574: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4540: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4590,7 +4556,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4594: checking for W11" >&5
+echo "configure:4560: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4618,7 +4584,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4622: checking for X" >&5
+echo "configure:4588: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4678,12 +4644,12 @@
# First, try using that file with no special directory specified.
-#line 4682 "configure"
+#line 4648 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4653: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4752,14 +4718,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4756 "configure"
+#line 4722 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4864,17 +4830,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4868: checking whether -R must be followed by a space" >&5
+echo "configure:4834: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4871 "configure"
+#line 4837 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4890,14 +4856,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4894 "configure"
+#line 4860 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4929,13 +4895,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4933: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4899: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4939 "configure"
+#line 4905 "configure"
@@ -4946,7 +4912,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4967,13 +4933,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4971: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4937: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4977 "configure"
+#line 4943 "configure"
@@ -4984,7 +4950,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5012,10 +4978,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5016: checking for gethostbyname" >&5
+echo "configure:4982: checking for gethostbyname" >&5
-#line 5019 "configure"
+#line 4985 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5038,7 +5004,7 @@
; return 0; }
EOF
-if { (eval echo configure:5042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5058,13 +5024,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5062: checking for gethostbyname in -lnsl" >&5
+echo "configure:5028: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5068 "configure"
+#line 5034 "configure"
@@ -5075,7 +5041,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5104,10 +5070,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5108: checking for connect" >&5
+echo "configure:5074: checking for connect" >&5
-#line 5111 "configure"
+#line 5077 "configure"
which can conflict with char connect(); below. */
@@ -5130,7 +5096,7 @@
; return 0; }
EOF
-if { (eval echo configure:5134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5150,13 +5116,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5154: checking for connect in -lsocket" >&5
+echo "configure:5120: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5160 "configure"
+#line 5126 "configure"
@@ -5167,7 +5133,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5190,10 +5156,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5194: checking for remove" >&5
+echo "configure:5160: checking for remove" >&5
-#line 5197 "configure"
+#line 5163 "configure"
which can conflict with char remove(); below. */
@@ -5216,7 +5182,7 @@
; return 0; }
EOF
-if { (eval echo configure:5220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5236,13 +5202,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5240: checking for remove in -lposix" >&5
+echo "configure:5206: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5246 "configure"
+#line 5212 "configure"
@@ -5253,7 +5219,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5276,10 +5242,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5280: checking for shmat" >&5
+echo "configure:5246: checking for shmat" >&5
-#line 5283 "configure"
+#line 5249 "configure"
which can conflict with char shmat(); below. */
@@ -5302,7 +5268,7 @@
; return 0; }
EOF
-if { (eval echo configure:5306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5322,13 +5288,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5326: checking for shmat in -lipc" >&5
+echo "configure:5292: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5332 "configure"
+#line 5298 "configure"
@@ -5339,7 +5305,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5371,13 +5337,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5375: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5341: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5381 "configure"
+#line 5347 "configure"
@@ -5388,7 +5354,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5428,12 +5394,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5432: checking for library containing cuserid" >&5
+echo "configure:5398: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5437 "configure"
+#line 5403 "configure"
@@ -5444,7 +5410,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5455,7 +5421,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5459 "configure"
+#line 5425 "configure"
@@ -5466,7 +5432,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5492,10 +5458,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5496: checking for xdrmem_create" >&5
+echo "configure:5462: checking for xdrmem_create" >&5
-#line 5499 "configure"
+#line 5465 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5518,7 +5484,7 @@
; return 0; }
EOF
-if { (eval echo configure:5522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5536,13 +5502,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5540: checking for xdrmem_create in -lsun" >&5
+echo "configure:5506: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5546 "configure"
+#line 5512 "configure"
@@ -5553,7 +5519,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5572,13 +5538,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5576: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5542: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5582 "configure"
+#line 5548 "configure"
@@ -5589,7 +5555,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5608,13 +5574,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5612: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5578: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 5618 "configure"
+#line 5584 "configure"
@@ -5625,7 +5591,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5644,13 +5610,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5648: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5614: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 5654 "configure"
+#line 5620 "configure"
@@ -5661,7 +5627,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5695,10 +5661,10 @@
for ac_func in asprintf
do
-echo "configure:5699: checking for $ac_func" >&5
+echo "configure:5665: checking for $ac_func" >&5
-#line 5702 "configure"
+#line 5668 "configure"
@@ -5721,7 +5687,7 @@
; return 0; }
EOF
-if { (eval echo configure:5725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5748,10 +5714,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5752: checking for atan" >&5
+echo "configure:5718: checking for atan" >&5
-#line 5755 "configure"
+#line 5721 "configure"
which can conflict with char atan(); below. */
@@ -5774,7 +5740,7 @@
; return 0; }
EOF
-if { (eval echo configure:5778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -5792,13 +5758,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5796: checking for atan in -lm" >&5
+echo "configure:5762: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 5802 "configure"
+#line 5768 "configure"
@@ -5809,7 +5775,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:5813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5836,10 +5802,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5840: checking for dlsym" >&5
+echo "configure:5806: checking for dlsym" >&5
-#line 5843 "configure"
+#line 5809 "configure"
which can conflict with char dlsym(); below. */
@@ -5862,7 +5828,7 @@
; return 0; }
EOF
-if { (eval echo configure:5866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -5880,13 +5846,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:5884: checking for dlsym in -ldl" >&5
+echo "configure:5850: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 5890 "configure"
+#line 5856 "configure"
@@ -5897,7 +5863,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5924,10 +5890,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:5928: checking for iconv" >&5
+echo "configure:5894: checking for iconv" >&5
-#line 5931 "configure"
+#line 5897 "configure"
which can conflict with char iconv(); below. */
@@ -5950,7 +5916,7 @@
; return 0; }
EOF
-if { (eval echo configure:5954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -5968,13 +5934,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:5972: checking for iconv in -liconv" >&5
+echo "configure:5938: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 5978 "configure"
+#line 5944 "configure"
@@ -5985,7 +5951,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:5989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6004,13 +5970,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6008: checking for iconv in -lgiconv" >&5
+echo "configure:5974: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6014 "configure"
+#line 5980 "configure"
@@ -6021,7 +5987,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6040,10 +6006,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6044: checking for libiconv" >&5
+echo "configure:6010: checking for libiconv" >&5
-#line 6047 "configure"
+#line 6013 "configure"
which can conflict with char libiconv(); below. */
@@ -6066,7 +6032,7 @@
; return 0; }
EOF
-if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6084,13 +6050,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6088: checking for libiconv in -liconv" >&5
+echo "configure:6054: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6094 "configure"
+#line 6060 "configure"
@@ -6101,7 +6067,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6120,13 +6086,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6124: checking for libiconv in -lgiconv" >&5
+echo "configure:6090: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6130 "configure"
+#line 6096 "configure"
@@ -6137,7 +6103,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6174,10 +6140,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6178: checking for socket" >&5
+echo "configure:6144: checking for socket" >&5
-#line 6181 "configure"
+#line 6147 "configure"
which can conflict with char socket(); below. */
@@ -6200,7 +6166,7 @@
; return 0; }
EOF
-if { (eval echo configure:6204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6218,13 +6184,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6222: checking for socket in -lsocket" >&5
+echo "configure:6188: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6228 "configure"
+#line 6194 "configure"
@@ -6235,7 +6201,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6283,7 +6249,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6287: checking for location of zlib includes" >&5
+echo "configure:6253: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6309,15 +6275,15 @@
do
-echo "configure:6313: checking for $ac_hdr" >&5
+echo "configure:6279: checking for $ac_hdr" >&5
-#line 6316 "configure"
+#line 6282 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6351,7 +6317,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6355: checking for location of zlib library" >&5
+echo "configure:6321: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6376,13 +6342,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6380: checking for deflate in -lz" >&5
+echo "configure:6346: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6386 "configure"
+#line 6352 "configure"
@@ -6393,7 +6359,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6441,7 +6407,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6445: checking for location of External PROJ.4 includes" >&5
+echo "configure:6411: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6467,15 +6433,15 @@
do
-echo "configure:6471: checking for $ac_hdr" >&5
+echo "configure:6437: checking for $ac_hdr" >&5
-#line 6474 "configure"
+#line 6440 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6445: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6512,7 +6478,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6516: checking External PROJ.4 version" >&5
+echo "configure:6482: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6520,7 +6486,7 @@
else
-#line 6524 "configure"
+#line 6490 "configure"
#include <stdio.h>
@@ -6532,7 +6498,7 @@
EOF
-if { (eval echo configure:6536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6557,7 +6523,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6561: checking for location of External PROJ.4 library" >&5
+echo "configure:6527: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6582,13 +6548,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6586: checking for pj_get_def in -lproj" >&5
+echo "configure:6552: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 6592 "configure"
+#line 6558 "configure"
@@ -6599,7 +6565,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6633,7 +6599,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6637: checking for location of External PROJ.4 data files" >&5
+echo "configure:6603: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6657,14 +6623,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6661: checking for epsg" >&5
+echo "configure:6627: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6668: checking for $PROJSHARE/epsg" >&5
+echo "configure:6634: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -6696,7 +6662,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:6700: checking for $ac_word" >&5
+echo "configure:6666: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -6736,7 +6702,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:6740: checking whether to use Readline" >&5
+echo "configure:6706: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -6757,7 +6723,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6761: checking for location of Readline includes" >&5
+echo "configure:6727: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6783,15 +6749,15 @@
do
-echo "configure:6787: checking for $ac_hdr" >&5
+echo "configure:6753: checking for $ac_hdr" >&5
-#line 6790 "configure"
+#line 6756 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6795: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6761: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6827,15 +6793,15 @@
do
-echo "configure:6831: checking for $ac_hdr" >&5
+echo "configure:6797: checking for $ac_hdr" >&5
-#line 6834 "configure"
+#line 6800 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6839: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6805: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6869,7 +6835,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6873: checking for location of Readline library" >&5
+echo "configure:6839: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6894,13 +6860,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6898: checking for readline in -lreadline" >&5
+echo "configure:6864: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6904 "configure"
+#line 6870 "configure"
@@ -6911,7 +6877,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6946,13 +6912,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6950: checking for add_history in -lhistory" >&5
+echo "configure:6916: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6956 "configure"
+#line 6922 "configure"
#include "confdefs.h"
@@ -6963,7 +6929,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7006,7 +6972,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7010: checking whether to use JPEG" >&5
+echo "configure:6976: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7026,7 +6992,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7030: checking for location of JPEG includes" >&5
+echo "configure:6996: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7052,15 +7018,15 @@
do
-echo "configure:7056: checking for $ac_hdr" >&5
+echo "configure:7022: checking for $ac_hdr" >&5
-#line 7059 "configure"
+#line 7025 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7030: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7094,7 +7060,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7098: checking for location of JPEG library" >&5
+echo "configure:7064: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7121,13 +7087,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7125: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7091: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7131 "configure"
+#line 7097 "configure"
@@ -7138,7 +7104,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7157,13 +7123,13 @@
-echo "configure:7161: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7127: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7167 "configure"
+#line 7133 "configure"
@@ -7174,7 +7140,7 @@
; return 0; }
EOF
-if { (eval echo configure:7178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7223,7 +7189,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7227: checking whether to use GDAL" >&5
+echo "configure:7193: checking whether to use GDAL" >&5
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
@@ -7236,7 +7202,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7240: checking for $ac_word" >&5
+echo "configure:7206: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7296,14 +7262,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7300 "configure"
+#line 7266 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -7312,14 +7278,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7316 "configure"
+#line 7282 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7347,7 +7313,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7351: checking whether to use TIFF" >&5
+echo "configure:7317: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7367,7 +7333,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7371: checking for location of TIFF includes" >&5
+echo "configure:7337: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7393,15 +7359,15 @@
do
-echo "configure:7397: checking for $ac_hdr" >&5
+echo "configure:7363: checking for $ac_hdr" >&5
-#line 7400 "configure"
+#line 7366 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7371: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7435,7 +7401,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7439: checking for location of TIFF library" >&5
+echo "configure:7405: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7466,13 +7432,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7470: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7436: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7476 "configure"
+#line 7442 "configure"
@@ -7483,7 +7449,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7502,13 +7468,13 @@
-echo "configure:7506: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7472: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7512 "configure"
+#line 7478 "configure"
@@ -7519,7 +7485,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7538,13 +7504,13 @@
-echo "configure:7542: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7508: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7548 "configure"
+#line 7514 "configure"
@@ -7555,7 +7521,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7574,13 +7540,13 @@
-echo "configure:7578: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7544: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7584 "configure"
+#line 7550 "configure"
@@ -7591,7 +7557,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7610,13 +7576,13 @@
-echo "configure:7614: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7580: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7620 "configure"
+#line 7586 "configure"
@@ -7627,7 +7593,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7646,13 +7612,13 @@
-echo "configure:7650: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7616: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7656 "configure"
+#line 7622 "configure"
@@ -7663,7 +7629,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7682,13 +7648,13 @@
-echo "configure:7686: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7652: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7692 "configure"
+#line 7658 "configure"
@@ -7699,7 +7665,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7718,13 +7684,13 @@
-echo "configure:7722: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7688: checking for TIFFOpen in -ltiff" >&5
ac_save_LIBS="$LIBS"
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7728 "configure"
+#line 7694 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7735,7 +7701,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7833,7 +7799,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7837: checking whether to use PNG" >&5
+echo "configure:7803: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7852,7 +7818,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7856: checking for location of PNG includes" >&5
+echo "configure:7822: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7878,15 +7844,15 @@
do
-echo "configure:7882: checking for $ac_hdr" >&5
+echo "configure:7848: checking for $ac_hdr" >&5
-#line 7885 "configure"
+#line 7851 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7920,7 +7886,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7924: checking for location of PNG library" >&5
+echo "configure:7890: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7945,13 +7911,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7949: checking for png_read_image in -lpng" >&5
+echo "configure:7915: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7955 "configure"
+#line 7921 "configure"
@@ -7962,7 +7928,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8004,7 +7970,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8008: checking whether to use Tcl/Tk" >&5
+echo "configure:7974: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8024,7 +7990,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8028: checking for location of Tcl/Tk includes" >&5
+echo "configure:7994: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8050,15 +8016,15 @@
do
-echo "configure:8054: checking for $ac_hdr" >&5
+echo "configure:8020: checking for $ac_hdr" >&5
-#line 8057 "configure"
+#line 8023 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8095,15 +8061,15 @@
do
-echo "configure:8099: checking for $ac_hdr" >&5
+echo "configure:8065: checking for $ac_hdr" >&5
-#line 8102 "configure"
+#line 8068 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8137,7 +8103,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8141: checking Tcl version" >&5
+echo "configure:8107: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8145,7 +8111,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8149 "configure"
+#line 8115 "configure"
#include <stdio.h>
@@ -8157,7 +8123,7 @@
EOF
-if { (eval echo configure:8161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8175,7 +8141,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8179: checking Tk version" >&5
+echo "configure:8145: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8183,7 +8149,7 @@
else
-#line 8187 "configure"
+#line 8153 "configure"
#include <stdio.h>
@@ -8195,7 +8161,7 @@
EOF
-if { (eval echo configure:8199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8224,7 +8190,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8228: checking for location of Tcl/Tk library" >&5
+echo "configure:8194: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8254,13 +8220,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8258: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8224: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8264 "configure"
+#line 8230 "configure"
@@ -8271,7 +8237,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8290,13 +8256,13 @@
-echo "configure:8294: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8260: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8300 "configure"
+#line 8266 "configure"
@@ -8307,7 +8273,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8334,13 +8300,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8338: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8304: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8344 "configure"
+#line 8310 "configure"
@@ -8351,7 +8317,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8370,13 +8336,13 @@
-echo "configure:8374: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8340: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8380 "configure"
+#line 8346 "configure"
@@ -8387,7 +8353,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8414,13 +8380,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8418: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8384: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8424 "configure"
+#line 8390 "configure"
@@ -8431,7 +8397,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8450,13 +8416,13 @@
-echo "configure:8454: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8420: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8460 "configure"
+#line 8426 "configure"
@@ -8467,7 +8433,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8545,13 +8511,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8549: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8515: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8555 "configure"
+#line 8521 "configure"
@@ -8562,7 +8528,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8581,13 +8547,13 @@
-echo "configure:8585: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8551: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8591 "configure"
+#line 8557 "configure"
@@ -8598,7 +8564,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8625,13 +8591,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8629: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8595: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 8635 "configure"
+#line 8601 "configure"
@@ -8642,7 +8608,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8661,13 +8627,13 @@
-echo "configure:8665: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8631: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8671 "configure"
+#line 8637 "configure"
@@ -8678,7 +8644,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8705,13 +8671,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8709: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8675: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 8715 "configure"
+#line 8681 "configure"
@@ -8722,7 +8688,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8741,13 +8707,13 @@
-echo "configure:8745: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:8711: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8751 "configure"
+#line 8717 "configure"
@@ -8758,7 +8724,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8850,7 +8816,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8854: checking whether to use PostgreSQL" >&5
+echo "configure:8820: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8877,7 +8843,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8881: checking for location of PostgreSQL includes" >&5
+echo "configure:8847: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8903,15 +8869,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8907: checking for $ac_hdr" >&5
+echo "configure:8873: checking for $ac_hdr" >&5
-#line 8910 "configure"
+#line 8876 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8915: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8881: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8949,7 +8915,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8953: checking for location of PostgreSQL library" >&5
+echo "configure:8919: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8978,13 +8944,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8982: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8948: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8988 "configure"
+#line 8954 "configure"
@@ -8995,7 +8961,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9014,13 +8980,13 @@
-echo "configure:9018: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8984: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9024 "configure"
+#line 8990 "configure"
@@ -9031,7 +8997,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9050,13 +9016,13 @@
-echo "configure:9054: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9020: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9060 "configure"
+#line 9026 "configure"
@@ -9067,7 +9033,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9086,13 +9052,13 @@
-echo "configure:9090: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9056: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9096 "configure"
+#line 9062 "configure"
@@ -9103,7 +9069,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9160,13 +9126,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9164: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9130: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9170 "configure"
+#line 9136 "configure"
@@ -9177,7 +9143,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9199,13 +9165,13 @@
-echo "configure:9203: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9169: checking for PQcmdTuples in -lpq" >&5
-#line 9209 "configure"
+#line 9175 "configure"
@@ -9216,7 +9182,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9259,7 +9225,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9263: checking whether to use MySQL" >&5
+echo "configure:9229: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9279,7 +9245,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9283: checking for location of MySQL includes" >&5
+echo "configure:9249: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9305,15 +9271,15 @@
do
-echo "configure:9309: checking for $ac_hdr" >&5
+echo "configure:9275: checking for $ac_hdr" >&5
-#line 9312 "configure"
+#line 9278 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9283: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9350,7 +9316,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9354: checking for location of MySQL library" >&5
+echo "configure:9320: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9381,13 +9347,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9385: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9351: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9391 "configure"
+#line 9357 "configure"
@@ -9398,7 +9364,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9417,13 +9383,13 @@
-echo "configure:9421: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9387: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9427 "configure"
+#line 9393 "configure"
@@ -9434,7 +9400,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9453,13 +9419,13 @@
-echo "configure:9457: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9423: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9463 "configure"
+#line 9429 "configure"
@@ -9470,7 +9436,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9489,13 +9455,13 @@
-echo "configure:9493: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9459: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9499 "configure"
+#line 9465 "configure"
@@ -9506,7 +9472,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9525,13 +9491,13 @@
-echo "configure:9529: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9495: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9535 "configure"
+#line 9501 "configure"
@@ -9542,7 +9508,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9561,13 +9527,13 @@
-echo "configure:9565: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9531: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9571 "configure"
+#line 9537 "configure"
@@ -9578,7 +9544,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9597,13 +9563,13 @@
-echo "configure:9601: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9567: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9607 "configure"
+#line 9573 "configure"
@@ -9614,7 +9580,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9633,13 +9599,13 @@
-echo "configure:9637: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9603: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9643 "configure"
+#line 9609 "configure"
@@ -9650,7 +9616,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9740,7 +9706,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9744: checking for $ac_word" >&5
+echo "configure:9710: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9781,10 +9747,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9785: checking for mysql_server_init" >&5
+echo "configure:9751: checking for mysql_server_init" >&5
-#line 9788 "configure"
+#line 9754 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9807,7 +9773,7 @@
; return 0; }
EOF
-if { (eval echo configure:9811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9845,7 +9811,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9849: checking whether to use SQLite" >&5
+echo "configure:9815: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9865,7 +9831,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9869: checking for location of SQLite includes" >&5
+echo "configure:9835: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9891,15 +9857,15 @@
do
-echo "configure:9895: checking for $ac_hdr" >&5
+echo "configure:9861: checking for $ac_hdr" >&5
-#line 9898 "configure"
+#line 9864 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9869: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9942,7 +9908,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9946: checking for location of SQLite library" >&5
+echo "configure:9912: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9969,13 +9935,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9973: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9939: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 9979 "configure"
+#line 9945 "configure"
@@ -9986,7 +9952,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10005,13 +9971,13 @@
-echo "configure:10009: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9975: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10015 "configure"
+#line 9981 "configure"
@@ -10022,7 +9988,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10075,7 +10041,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10079: checking whether to use FFMPEG" >&5
+echo "configure:10045: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10095,7 +10061,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10099: checking for location of FFMPEG includes" >&5
+echo "configure:10065: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10121,15 +10087,15 @@
do
-echo "configure:10125: checking for $ac_hdr" >&5
+echo "configure:10091: checking for $ac_hdr" >&5
-#line 10128 "configure"
+#line 10094 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10165,15 +10131,15 @@
do
-echo "configure:10169: checking for $ac_hdr" >&5
+echo "configure:10135: checking for $ac_hdr" >&5
-#line 10172 "configure"
+#line 10138 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10177: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10143: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10209,15 +10175,15 @@
do
-echo "configure:10213: checking for $ac_hdr" >&5
+echo "configure:10179: checking for $ac_hdr" >&5
-#line 10216 "configure"
+#line 10182 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10260,7 +10226,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10264: checking for location of FFMPEG library" >&5
+echo "configure:10230: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10287,13 +10253,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10291: checking for av_free in -lavutil" >&5
+echo "configure:10257: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10297 "configure"
+#line 10263 "configure"
@@ -10304,7 +10270,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10323,13 +10289,13 @@
-echo "configure:10327: checking for av_free in -lavutil" >&5
+echo "configure:10293: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10333 "configure"
+#line 10299 "configure"
@@ -10340,7 +10306,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10385,13 +10351,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10389: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10355: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10395 "configure"
+#line 10361 "configure"
@@ -10402,7 +10368,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10421,13 +10387,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10425: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10391: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10431 "configure"
+#line 10397 "configure"
@@ -10438,7 +10404,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10483,13 +10449,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10487: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10453: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10493 "configure"
+#line 10459 "configure"
@@ -10500,7 +10466,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10519,13 +10485,13 @@
-echo "configure:10523: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10489: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10529 "configure"
+#line 10495 "configure"
@@ -10536,7 +10502,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10596,7 +10562,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10600: checking whether to use OpenGL" >&5
+echo "configure:10566: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10630,7 +10596,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10634: checking for location of OpenGL includes" >&5
+echo "configure:10600: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10656,15 +10622,15 @@
do
-echo "configure:10660: checking for $ac_hdr" >&5
+echo "configure:10626: checking for $ac_hdr" >&5
-#line 10663 "configure"
+#line 10629 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10698,7 +10664,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10702: checking for location of OpenGL library" >&5
+echo "configure:10668: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10727,13 +10693,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10731: checking for glBegin in -lGL" >&5
+echo "configure:10697: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10737 "configure"
+#line 10703 "configure"
@@ -10744,7 +10710,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10763,13 +10729,13 @@
-echo "configure:10767: checking for glBegin in -lGL" >&5
+echo "configure:10733: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10773 "configure"
+#line 10739 "configure"
@@ -10780,7 +10746,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10799,13 +10765,13 @@
-echo "configure:10803: checking for glBegin in -lGL" >&5
+echo "configure:10769: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10809 "configure"
+#line 10775 "configure"
@@ -10816,7 +10782,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10835,13 +10801,13 @@
-echo "configure:10839: checking for glBegin in -lGL" >&5
+echo "configure:10805: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10845 "configure"
+#line 10811 "configure"
@@ -10852,7 +10818,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10914,13 +10880,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10918: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10884: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10924 "configure"
+#line 10890 "configure"
@@ -10931,7 +10897,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10950,13 +10916,13 @@
-echo "configure:10954: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10920: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10960 "configure"
+#line 10926 "configure"
@@ -10967,7 +10933,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:10971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11014,10 +10980,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11018: checking for glXCreatePbuffer" >&5
+echo "configure:10984: checking for glXCreatePbuffer" >&5
-#line 11021 "configure"
+#line 10987 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11040,7 +11006,7 @@
; return 0; }
EOF
-if { (eval echo configure:11044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11077,10 +11043,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11081: checking for glXCreateGLXPixmap" >&5
+echo "configure:11047: checking for glXCreateGLXPixmap" >&5
-#line 11084 "configure"
+#line 11050 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11103,7 +11069,7 @@
; return 0; }
EOF
-if { (eval echo configure:11107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11146,7 +11112,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11150: checking for location of OpenGL framework" >&5
+echo "configure:11116: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11170,15 +11136,15 @@
do
-echo "configure:11174: checking for $ac_hdr" >&5
+echo "configure:11140: checking for $ac_hdr" >&5
-#line 11177 "configure"
+#line 11143 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11182: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11214,10 +11180,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11218: checking for glBegin" >&5
+echo "configure:11184: checking for glBegin" >&5
-#line 11221 "configure"
+#line 11187 "configure"
which can conflict with char glBegin(); below. */
@@ -11240,7 +11206,7 @@
; return 0; }
EOF
-if { (eval echo configure:11244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11277,10 +11243,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11281: checking for gluBeginCurve" >&5
+echo "configure:11247: checking for gluBeginCurve" >&5
-#line 11284 "configure"
+#line 11250 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11303,7 +11269,7 @@
; return 0; }
EOF
-if { (eval echo configure:11307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11351,7 +11317,7 @@
-echo "configure:11355: checking for location of OpenGL includes" >&5
+echo "configure:11321: checking for location of OpenGL includes" >&5
@@ -11377,15 +11343,15 @@
do
-echo "configure:11381: checking for $ac_hdr" >&5
+echo "configure:11347: checking for $ac_hdr" >&5
-#line 11384 "configure"
+#line 11350 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11389: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11419,7 +11385,7 @@
-echo "configure:11423: checking for location of OpenGL library" >&5
+echo "configure:11389: checking for location of OpenGL library" >&5
@@ -11444,18 +11410,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11448: checking for OpenGL library" >&5
+echo "configure:11414: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11452 "configure"
+#line 11418 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11479,18 +11445,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11483: checking for GLU library" >&5
+echo "configure:11449: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11487 "configure"
+#line 11453 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11539,7 +11505,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11543: checking whether to use ODBC" >&5
+echo "configure:11509: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11558,7 +11524,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11562: checking for location of ODBC includes" >&5
+echo "configure:11528: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11584,15 +11550,15 @@
do
-echo "configure:11588: checking for $ac_hdr" >&5
+echo "configure:11554: checking for $ac_hdr" >&5
-#line 11591 "configure"
+#line 11557 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11626,7 +11592,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11630: checking for location of ODBC library" >&5
+echo "configure:11596: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11651,13 +11617,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11655: checking for SQLConnect in -lodbc" >&5
+echo "configure:11621: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11661 "configure"
+#line 11627 "configure"
@@ -11668,7 +11634,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11693,13 +11659,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11697: checking for SQLConnect in -liodbc" >&5
+echo "configure:11663: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11703 "configure"
+#line 11669 "configure"
@@ -11710,7 +11676,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11735,11 +11701,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11739: checking for ODBC library" >&5
+echo "configure:11705: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11743 "configure"
+#line 11709 "configure"
#include <windows.h>
#include <sql.h>
@@ -11747,7 +11713,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11796,7 +11762,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11800: checking whether to use FFTW" >&5
+echo "configure:11766: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11815,7 +11781,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11819: checking for location of FFTW includes" >&5
+echo "configure:11785: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11841,15 +11807,15 @@
do
-echo "configure:11845: checking for $ac_hdr" >&5
+echo "configure:11811: checking for $ac_hdr" >&5
-#line 11848 "configure"
+#line 11814 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11877,15 +11843,15 @@
do
-echo "configure:11881: checking for $ac_hdr" >&5
+echo "configure:11847: checking for $ac_hdr" >&5
-#line 11884 "configure"
+#line 11850 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11913,15 +11879,15 @@
do
-echo "configure:11917: checking for $ac_hdr" >&5
+echo "configure:11883: checking for $ac_hdr" >&5
-#line 11920 "configure"
+#line 11886 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11967,7 +11933,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11971: checking for location of FFTW library" >&5
+echo "configure:11937: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11992,13 +11958,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11996: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11962: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12002 "configure"
+#line 11968 "configure"
@@ -12009,7 +11975,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12034,13 +12000,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12038: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12004: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12044 "configure"
+#line 12010 "configure"
#include "confdefs.h"
@@ -12051,7 +12017,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12076,13 +12042,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12080: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12046: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12086 "configure"
+#line 12052 "configure"
@@ -12093,7 +12059,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12150,7 +12116,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12154: checking whether to use BLAS" >&5
+echo "configure:12120: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12171,7 +12137,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12175: checking for location of BLAS includes" >&5
+echo "configure:12141: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12191,7 +12157,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12195: checking for location of BLAS library" >&5
+echo "configure:12161: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12217,15 +12183,15 @@
do
-echo "configure:12221: checking for $ac_hdr" >&5
+echo "configure:12187: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12224 "configure"
+#line 12190 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12195: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12260,13 +12226,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12264: checking for dnrm2_ in -lblas" >&5
+echo "configure:12230: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12270 "configure"
+#line 12236 "configure"
@@ -12277,7 +12243,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12296,13 +12262,13 @@
-echo "configure:12300: checking for dnrm2_ in -lblas" >&5
+echo "configure:12266: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12306 "configure"
+#line 12272 "configure"
@@ -12313,7 +12279,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12357,13 +12323,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12361: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12327: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12367 "configure"
+#line 12333 "configure"
@@ -12374,7 +12340,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12389,13 +12355,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12393: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12359: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12399 "configure"
+#line 12365 "configure"
@@ -12406,7 +12372,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12421,13 +12387,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12425: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12391: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12431 "configure"
+#line 12397 "configure"
@@ -12438,7 +12404,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12483,16 +12449,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12487: checking for sgemm in $vlib_flags" >&5
+echo "configure:12453: checking for sgemm in $vlib_flags" >&5
-#line 12489 "configure"
+#line 12455 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12510,13 +12476,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12514: checking for sgemm_ in -lblas" >&5
+echo "configure:12480: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12520 "configure"
+#line 12486 "configure"
@@ -12527,7 +12493,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12542,13 +12508,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12546: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12512: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12552 "configure"
+#line 12518 "configure"
@@ -12559,7 +12525,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12574,13 +12540,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12578: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12544: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12584 "configure"
+#line 12550 "configure"
@@ -12591,7 +12557,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12625,13 +12591,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12629: checking for acosp in -lsunmath" >&5
+echo "configure:12595: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12635 "configure"
+#line 12601 "configure"
@@ -12642,7 +12608,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12657,13 +12623,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12661: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12627: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12667 "configure"
+#line 12633 "configure"
@@ -12674,7 +12640,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12704,13 +12670,13 @@
# Generic BLAS library
-echo "configure:12708: checking for sgemm_ in -lblas" >&5
+echo "configure:12674: checking for sgemm_ in -lblas" >&5
ac_save_LIBS="$LIBS"
LIBS="-lblas $LIBS"
-#line 12714 "configure"
+#line 12680 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12721,7 +12687,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12760,7 +12726,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12764: checking whether to use LAPACK" >&5
+echo "configure:12730: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12785,7 +12751,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12789: checking for location of LAPACK includes" >&5
+echo "configure:12755: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12805,7 +12771,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12809: checking for location of LAPACK library" >&5
+echo "configure:12775: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12831,15 +12797,15 @@
do
-echo "configure:12835: checking for $ac_hdr" >&5
+echo "configure:12801: checking for $ac_hdr" >&5
-#line 12838 "configure"
+#line 12804 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12871,10 +12837,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12875: checking for dsegv_" >&5
+echo "configure:12841: checking for dsegv_" >&5
-#line 12878 "configure"
+#line 12844 "configure"
which can conflict with char dsegv_(); below. */
@@ -12897,7 +12863,7 @@
; return 0; }
EOF
-if { (eval echo configure:12901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12924,13 +12890,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12928: checking for desgv_ in -llapack" >&5
+echo "configure:12894: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12934 "configure"
+#line 12900 "configure"
@@ -12941,7 +12907,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12973,13 +12939,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12977: checking for dgesv_ in -llapack" >&5
+echo "configure:12943: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 12983 "configure"
+#line 12949 "configure"
@@ -12990,7 +12956,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13009,13 +12975,13 @@
-echo "configure:13013: checking for dgesv_ in -llapack" >&5
+echo "configure:12979: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13019 "configure"
+#line 12985 "configure"
@@ -13026,7 +12992,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13082,7 +13048,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13086: checking whether to use Motif" >&5
+echo "configure:13052: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13101,7 +13067,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13105: checking for location of Motif includes" >&5
+echo "configure:13071: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13127,15 +13093,15 @@
do
-echo "configure:13131: checking for $ac_hdr" >&5
+echo "configure:13097: checking for $ac_hdr" >&5
-#line 13134 "configure"
+#line 13100 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13169,7 +13135,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13173: checking for location of Motif library" >&5
+echo "configure:13139: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13194,13 +13160,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13198: checking for XmStringCreate in -lXm" >&5
+echo "configure:13164: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13204 "configure"
+#line 13170 "configure"
@@ -13211,7 +13177,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13252,7 +13218,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13256: checking whether to use Cairo" >&5
+echo "configure:13222: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13278,15 +13244,15 @@
do
-echo "configure:13282: checking for $ac_hdr" >&5
+echo "configure:13248: checking for $ac_hdr" >&5
-#line 13285 "configure"
+#line 13251 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13256: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13326,10 +13292,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13330: checking for cairo_create" >&5
+echo "configure:13296: checking for cairo_create" >&5
-#line 13333 "configure"
+#line 13299 "configure"
which can conflict with char cairo_create(); below. */
@@ -13352,7 +13318,7 @@
; return 0; }
EOF
-if { (eval echo configure:13356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13389,665 +13355,11 @@
# Done checking Cairo
-# Enable GLw option
-echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13397: checking whether to use GLw" >&5
-echo "$ac_t"""$with_glw"" 1>&6
-case "$with_glw" in
- "no") USE_GLW= ;;
- "yes") USE_GLW="1" ;;
- *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
-esac
-OPENGLWINC=
-OPENGLWM=
-if test -n "$USE_GLW"; then
-# With GLw includes directory
-echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13416: checking for location of GLw includes" >&5
-case "$with_glw_includes" in
-y | ye | yes | n | no)
- { echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_glw_includes" 1>&6
-if test -n "$with_glw_includes" ; then
- for dir in $with_glw_includes; do
- if test -d "$dir"; then
- OPENGLWINC="$OPENGLWINC -I$dir"
- else
- { echo "configure: error: *** GLw includes directory $dir does not exist." 1>&2; exit 1; }
- fi
- done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$OPENGLWINC $XMINC $X_CFLAGS $OPENGLINC $CPPFLAGS"
-for ac_hdr in GL/GLwMDrawA.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13442: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 13445 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=yes"
-else
- echo "$ac_err" >&5
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
- cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
- echo "$ac_t""no" 1>&6
-CPPFLAGS=" $CPPFLAGS"
-for ac_hdr in X11/GLw/GLwMDrawA.h
-do
-echo "configure:13478: checking for $ac_hdr" >&5
-#line 13481 "configure"
-#include <$ac_hdr>
-EOF
-{ (eval echo configure:13486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
-EOF
-else
-{ echo "configure: error: *** Unable to locate GLwM includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-fi
-done
-# With GLw library directory
-echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13526: checking for location of GLw library" >&5
-case "$with_glw_libs" in
- { echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_glw_libs" 1>&6
-if test -n "$with_glw_libs"; then
- for dir in $with_glw_libs; do
- OPENGLWM="$OPENGLWM -L$dir"
- else
- { echo "configure: error: *** GLw library directory $dir does not exist." 1>&2; exit 1; }
- fi
- done
-fi
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$OPENGLWM $XMLIB $OPENGL_LIB_PATH $LDFLAGS"
-echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13551: checking for GLwCreateMDrawingArea in -lGLw" >&5
-ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13557 "configure"
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char GLwCreateMDrawingArea();
-int main() {
-GLwCreateMDrawingArea()
-; return 0; }
-EOF
-if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=yes"
-else
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
- OPENGLWM="$OPENGLWM -lGLw "
-else
-LDFLAGS=${ac_save_ldflags}
-echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13593: checking for GLwCreateM1DrawingArea in -lGLw" >&5
-ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13599 "configure"
-char GLwCreateM1DrawingArea();
-int main() {
-GLwCreateM1DrawingArea()
-; return 0; }
-EOF
-if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
-else
-echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13635: checking for GLwCreateM2DrawingArea in -lGLw" >&5
-ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13641 "configure"
-char GLwCreateM2DrawingArea();
-int main() {
-GLwCreateM2DrawingArea()
-; return 0; }
-EOF
-if { (eval echo configure:13652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
-else
-echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13677: checking for GLwCreateMDrawingArea in -lGLwM" >&5
-ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
-LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13683 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:13694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- OPENGLWM="$OPENGLWM -lGLwM "
-else
-echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13719: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
-ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13725 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:13736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
-else
-echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13761: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
-ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13767 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:13778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
-else
-echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:13805: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
-ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
-LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13811 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:13822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- OPENGLWM="$OPENGLWM -lMesaGLw "
-else
-echo "configure:13841: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
-LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13847 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:13858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- OPENGLWM="$OPENGLWM -lMesaGLw $OPENGLULIB"
-else
-echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:13885: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
-ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
-LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13891 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:13902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- OPENGLWM="$OPENGLWM -lMesaGLwM "
-else
-echo "configure:13921: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
-LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13927 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:13938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- OPENGLWM="$OPENGLWM -lMesaGLwM $OPENGLULIB"
-else
- { echo "configure: error: *** Unable to locate GLwM library." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
-fi
-fi
-fi
-fi
-fi
-fi # $USE_OPENGL && $USE_MOTIF
-# Done checking GLw
# Enable FreeType option
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14051: checking whether to use FreeType" >&5
+echo "configure:13363: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14066,7 +13378,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14070: checking for location of FreeType includes" >&5
+echo "configure:13382: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14092,15 +13404,15 @@
do
-echo "configure:14096: checking for $ac_hdr" >&5
+echo "configure:13408: checking for $ac_hdr" >&5
-#line 14099 "configure"
+#line 13411 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14134,7 +13446,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14138: checking for location of FreeType library" >&5
+echo "configure:13450: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14159,13 +13471,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14163: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13475: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14169 "configure"
+#line 13481 "configure"
@@ -14176,7 +13488,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14217,7 +13529,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14221: checking whether to use NLS" >&5
+echo "configure:13533: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14237,10 +13549,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14241: checking for gettext" >&5
+echo "configure:13553: checking for gettext" >&5
-#line 14244 "configure"
+#line 13556 "configure"
which can conflict with char gettext(); below. */
@@ -14263,7 +13575,7 @@
; return 0; }
EOF
-if { (eval echo configure:14267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14281,13 +13593,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14285: checking for gettext in -lintl" >&5
+echo "configure:13597: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14291 "configure"
+#line 13603 "configure"
@@ -14298,7 +13610,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14333,7 +13645,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14337: checking whether to use C++" >&5
+echo "configure:13649: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14349,7 +13661,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14353: checking for $ac_word" >&5
+echo "configure:13665: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14378,7 +13690,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14382: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13694: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14389,12 +13701,12 @@
cat > conftest.$ac_ext << EOF
-#line 14393 "configure"
+#line 13705 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14420,19 +13732,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14424: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13736: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14429: checking whether we are using GNU C++" >&5
+echo "configure:13741: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14450,7 +13762,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14454: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13766: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14491,7 +13803,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14495: checking whether to use openDWG" >&5
+echo "configure:13807: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14511,7 +13823,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14515: checking for location of openDGW includes" >&5
+echo "configure:13827: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14537,15 +13849,15 @@
do
-echo "configure:14541: checking for $ac_hdr" >&5
+echo "configure:13853: checking for $ac_hdr" >&5
-#line 14544 "configure"
+#line 13856 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13861: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14579,7 +13891,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14583: checking for location of openDWG library" >&5
+echo "configure:13895: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14626,7 +13938,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14630: checking for special C compiler options needed for large files" >&5
+echo "configure:13942: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14634,7 +13946,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14638 "configure"
+#line 13950 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14650,7 +13962,7 @@
; return 0; }
EOF
-if { (eval echo configure:14654: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13966: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -14659,7 +13971,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14663 "configure"
+#line 13975 "configure"
@@ -14675,7 +13987,7 @@
; return 0; }
EOF
-if { (eval echo configure:14679: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14695,11 +14007,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14699: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14011: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14703 "configure"
+#line 14015 "configure"
@@ -14715,14 +14027,14 @@
; return 0; }
EOF
-if { (eval echo configure:14719: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14031: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14726 "configure"
+#line 14038 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14740,7 +14052,7 @@
; return 0; }
EOF
-if { (eval echo configure:14744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14759,11 +14071,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14763: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14075: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14767 "configure"
+#line 14079 "configure"
@@ -14779,14 +14091,14 @@
; return 0; }
EOF
-if { (eval echo configure:14783: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14095: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14790 "configure"
+#line 14102 "configure"
#define _LARGE_FILES 1
@@ -14804,7 +14116,7 @@
; return 0; }
EOF
-if { (eval echo configure:14808: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14120: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14823,25 +14135,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14827: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14139: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14831 "configure"
+#line 14143 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14838: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14150: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14845 "configure"
+#line 14157 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14850,7 +14162,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14854: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14166: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14871,10 +14183,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14875: checking if system supports Large Files at all" >&5
+echo "configure:14187: checking if system supports Large Files at all" >&5
-#line 14878 "configure"
+#line 14190 "configure"
#include <stdio.h>
@@ -14906,7 +14218,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14910: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14222: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14935,7 +14247,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14939: checking whether to use Python" >&5
+echo "configure:14251: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -14955,7 +14267,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:14959: checking for $ac_word" >&5
+echo "configure:14271: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15000,15 +14312,15 @@
do
-echo "configure:15004: checking for $ac_hdr" >&5
+echo "configure:14316: checking for $ac_hdr" >&5
-#line 15007 "configure"
+#line 14319 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14324: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15048,7 +14360,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15052: checking for $ac_word" >&5
+echo "configure:14364: checking for $ac_word" >&5
case "$SWIG" in
@@ -15094,7 +14406,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15098: checking whether to use wxWidgets" >&5
+echo "configure:14410: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15114,7 +14426,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15118: checking for $ac_word" >&5
+echo "configure:14430: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15162,7 +14474,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15166: checking wxWidgets version" >&5
+echo "configure:14478: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15185,15 +14497,15 @@
do
-echo "configure:15189: checking for $ac_hdr" >&5
+echo "configure:14501: checking for $ac_hdr" >&5
-#line 15192 "configure"
+#line 14504 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15229,15 +14541,15 @@
do
-echo "configure:15233: checking for $ac_hdr" >&5
+echo "configure:14545: checking for $ac_hdr" >&5
-#line 15236 "configure"
+#line 14548 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14553: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15523,8 +14835,6 @@
s%@CAIROINC@%$CAIROINC%g
s%@CAIROLIB@%$CAIROLIB%g
s%@USE_CAIRO@%$USE_CAIRO%g
-s%@OPENGLWINC@%$OPENGLWINC%g
-s%@OPENGLWM@%$OPENGLWM%g
s%@FTINC@%$FTINC%g
s%@FTLIB@%$FTLIB%g
s%@INTLLIB@%$INTLLIB%g
@@ -15846,8 +15156,6 @@
echo " GDAL support: `if test -n "${USE_GDAL}" ; then echo yes ; else echo no ; fi`"
-echo " GLw support: `if test -n "${USE_GLW}" ; then echo yes ; else echo no ; fi`"
echo " JPEG support: `if test -n "${USE_JPEG}" ; then echo yes ; else echo no ; fi`"
echo " LAPACK support: `if test -n "${USE_LAPACK}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-08-13 21:27:25 UTC (rev 32754)
+++ grass/trunk/configure.in 2008-08-14 08:15:13 UTC (rev 32755)
@@ -192,7 +192,6 @@
LOC_ARG_WITH(motif, Motif, no)
LOC_ARG_WITH(cairo, Cairo, no)
LOC_ARG_WITH(freetype, FreeType, no)
-LOC_ARG_WITH(glw, GLw, no)
LOC_ARG_WITH(nls, NLS, no)
LOC_ARG_WITH(readline, Readline, no)
LOC_ARG_WITH(opendwg, openDWG, no)
@@ -267,9 +266,6 @@
LOC_ARG_WITH_INC(freetype, FreeType)
LOC_ARG_WITH_LIB(freetype, FreeType)
-LOC_ARG_WITH_INC(glw, GLw)
-LOC_ARG_WITH_LIB(glw, GLw)
LOC_ARG_WITH_INC(proj, External PROJ.4)
LOC_ARG_WITH_LIB(proj, External PROJ.4)
LOC_ARG_WITH_SHARE(proj, External PROJ.4)
@@ -1397,51 +1393,6 @@
-LOC_CHECK_USE(glw,GLw,USE_GLW)
-OPENGLWINC=
-OPENGLWM=
-LOC_CHECK_INC_PATH(glw,GLw,OPENGLWINC)
-LOC_CHECK_INCLUDES(GL/GLwMDrawA.h,GLwM,$OPENGLWINC $XMINC $X_CFLAGS $OPENGLINC,[
-LOC_CHECK_INCLUDES(X11/GLw/GLwMDrawA.h,GLwM,,)
-LOC_CHECK_LIB_PATH(glw,GLw,OPENGLWM)
-LOC_CHECK_LIBS(GLw, GLwCreateMDrawingArea, GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-LOC_CHECK_LIBS(GLw, GLwCreateM1DrawingArea,GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-LOC_CHECK_LIBS(GLw, GLwCreateM2DrawingArea,GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-LOC_CHECK_LIBS(GLwM, GLwCreateMDrawingArea, GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-LOC_CHECK_LIBS(GLwM, GLwCreateM1DrawingArea,GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-LOC_CHECK_LIBS(GLwM, GLwCreateM2DrawingArea,GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-LOC_CHECK_LIBS(MesaGLw, GLwCreateMDrawingArea, GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-LOC_CHECK_LIBS(MesaGLwM,GLwCreateMDrawingArea, GLwM,$OPENGLWM $XMLIB $OPENGL_LIB_PATH,OPENGLWM,$X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,[
-], $OPENGLULIB)
-], $OPENGLULIB)
-AC_SUBST(OPENGLWINC)
-AC_SUBST(OPENGLWM)
LOC_CHECK_USE(freetype,FreeType,USE_FREETYPE)
@@ -1729,7 +1680,6 @@
LOC_MSG_USE(FFTW support,USE_FFTW)
LOC_MSG_USE(FreeType support,USE_FREETYPE)
LOC_MSG_USE(GDAL support,USE_GDAL)
-LOC_MSG_USE(GLw support,USE_GLW)
LOC_MSG_USE(JPEG support,USE_JPEG)
LOC_MSG_USE(LAPACK support,USE_LAPACK)
LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2008-08-13 21:27:25 UTC (rev 32754)
+++ grass/trunk/include/Make/Platform.make.in 2008-08-14 08:15:13 UTC (rev 32755)
@@ -163,10 +163,8 @@
#openGL files for NVIZ/r3.showdspf
OPENGLINC = @OPENGLINC@
-OPENGLWINC = @OPENGLWINC@
OPENGLLIB = @OPENGLLIB@
OPENGLULIB = @OPENGLULIB@
-OPENGLWM = @OPENGLWM@
OPENGL_X11 = @OPENGL_X11@
OPENGL_AQUA = @OPENGL_AQUA@
OPENGL_WINDOWS = @OPENGL_WINDOWS@
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in 2008-08-13 21:27:25 UTC (rev 32754)
+++ grass/trunk/include/config.h.in 2008-08-14 08:15:13 UTC (rev 32755)
@@ -200,12 +200,6 @@
/* define if NLS requested */
#undef USE_NLS
-/* define if <GL/GLwMDrawA.h> exists */
-#undef HAVE_GL_GLWMDRAWA_H
-/* define if <X11/GLw/GLwMDrawA.h> exists */
-#undef HAVE_X11_GLW_GLWMDRAWA_H
/* define if TclTk exists */
#undef HAVE_TCLTK
