[GRASS-SVN] r32762 - grass-addons/gipe/i.eb.h_SEBAL01
svn_grass at osgeo.org
Thu Aug 14 07:06:27 EDT 2008
Author: ychemin
Date: 2008-08-14 07:06:26 -0400 (Thu, 14 Aug 2008)
New Revision: 32762
grass-addons/gipe/i.eb.h_SEBAL01/main.c
bug fix
Modified: grass-addons/gipe/i.eb.h_SEBAL01/main.c
--- grass-addons/gipe/i.eb.h_SEBAL01/main.c 2008-08-14 10:19:50 UTC (rev 32761)
+++ grass-addons/gipe/i.eb.h_SEBAL01/main.c 2008-08-14 11:06:26 UTC (rev 32762)
@@ -131,7 +131,7 @@
input_row_wet = G_define_option();
input_row_wet->key = "row_wet";
input_row_wet->type = TYPE_DOUBLE;
- input_row_wet->required = YES;
+ input_row_wet->required = NO;
input_row_wet->gisprompt = "old,value";
input_row_wet->description = _("Row value of the wet pixel");
input_row_wet->guisection = _("Parameters");
@@ -139,7 +139,7 @@
input_col_wet = G_define_option();
input_col_wet->key = "col_wet";
input_col_wet->type = TYPE_DOUBLE;
- input_col_wet->required = YES;
+ input_col_wet->required = NO;
input_col_wet->gisprompt = "old,value";
input_col_wet->description = _("Column value of the wet pixel");
input_col_wet->guisection = _("Parameters");
@@ -147,7 +147,7 @@
input_row_dry = G_define_option();
input_row_dry->key = "row_dry";
input_row_dry->type = TYPE_DOUBLE;
- input_row_dry->required = YES;
+ input_row_dry->required = NO;
input_row_dry->gisprompt = "old,value";
input_row_dry->description = _("Row value of the dry pixel");
input_row_dry->guisection = _("Parameters");
@@ -155,7 +155,7 @@
input_col_dry = G_define_option();
input_col_dry->key = "col_dry";
input_col_dry->type = TYPE_DOUBLE;
- input_col_dry->required = YES;
+ input_col_dry->required = NO;
input_col_dry->gisprompt = "old,value";
input_col_dry->description = _("Column value of the dry pixel");
input_col_dry->guisection = _("Parameters");
@@ -191,13 +191,18 @@
m_col_wet = atof(input_col_wet->answer);
m_row_dry = atof(input_row_dry->answer);
m_col_dry = atof(input_col_dry->answer);
+ if((!input_row_wet->answer||!input_col_wet->answer||
+ !input_row_dry->answer||!input_col_dry->answer)&&
+ !flag2->answer){
+ G_fatal_error(_("FATAL ERROR: either auto-mode either wet/dry pixels coordinates should be provided!"));
if(flag3->answer){
- G_message("Manual wet/dry pixels in image coordinates");
- G_message("Wet Pixel=> x:%f y:%f",m_col_wet,m_row_wet);
- G_message("Dry Pixel=> x:%f y:%f",m_col_dry,m_row_dry);
+ G_message(_("Manual wet/dry pixels in image coordinates"));
+ G_message(_("Wet Pixel=> x:%f y:%f"),m_col_wet,m_row_wet);
+ G_message(_("Dry Pixel=> x:%f y:%f"),m_col_dry,m_row_dry);
} else {
- G_message("Wet Pixel=> row:%.0f col:%.0f",m_row_wet,m_col_wet);
- G_message("Dry Pixel=> row:%.0f col:%.0f",m_row_dry,m_col_dry);
+ G_message(_("Wet Pixel=> row:%.0f col:%.0f"),m_row_wet,m_col_wet);
+ G_message(_("Dry Pixel=> row:%.0f col:%.0f"),m_row_dry,m_col_dry);
/* find maps in mapset */
mapset_Rn = G_find_cell2 (Rn, "");
