[GRASS-SVN] r32772 - in grass/trunk: db/db.login display/d.barscale
display/d.colorlist display/d.colors display/d.colortable
display/d.erase display/d.extract display/d.font
display/d.fontlist display/d.geodesic display/d.graph
display/d.grid display/d.his display/d.histogram
display/d.info display/d.labels display/d.legend
display/d.linegraph display/d.measure display/d.nviz
display/d.path display/d.profile display/d.rast
display/d.rast.arrow display/d.rast.num display/d.rgb
display/d.rhumbline display/d.text.new
display/d.thematic.area display/d.title display/d.vect
display/d.vect.chart display/d.what.rast display/d.what.vect
display/d.where display/d.zoom doc/raster/r.example
doc/vector/v.example general/g.access general/g.dirseps
general/g.filename general/g.findetc general/g.findfile
general/g.gisenv general/g.gui general/g.mapset
general/g.mapsets general/g.message general/g.mkfontcap
general/g.parser general/g.pnmcomp general/g.proj
general/g.region general/g.setproj general/g.tempfile
general/g.transform general/g.version gui/tcltk/gis.m
imagery/i.atcorr imagery/i.cca imagery/i.class
imagery/i.cluster imagery/i.fft imagery/i.gensig
imagery/i.gensigset imagery/i.group imagery/i.his.rgb
imagery/i.ifft imagery/i.maxlik imagery/i.ortho.photo/menu
imagery/i.ortho.photo/photo.2image
imagery/i.ortho.photo/photo.2target
imagery/i.ortho.photo/photo.camera imagery/i.ortho.photo/photo.init
imagery/i.ortho.photo/photo.rectify imagery/i.pca
imagery/i.points imagery/i.rectify imagery/i.rgb.his
imagery/i.smap/shapiro imagery/i.target imagery/i.vpoints
imagery/i.zc lib/cairodriver lib/db/sqlp lib/htmldriver
lib/pngdriver lib/psdriver misc/m.cogo ps/ps.map
raster/r.average raster/r.basins.fill raster/r.bitpattern
raster/r.buffer raster/r.carve raster/r.cats raster/r.circle
raster/r.clump raster/r.coin raster/r.colors
raster/r.composite raster/r.compress raster/r.contour
raster/r.cost raster/r.covar raster/r.cross raster/r.describe
raster/r.digit raster/r.distance raster/r.drain
raster/r.fill.dir raster/r.flow raster/r.grow.distance
raster/r.grow2 raster/r.gwflow raster/r.his raster/r.in.arc
raster/r.in.ascii raster/r.in.bin raster/r.in.gdal
raster/r.in.gridatb raster/r.in.mat raster/r.in.poly
raster/r.in.xyz raster/r.info raster/r.kappa raster/r.lake
raster/r.le/r.le.patch raster/r.le/r.le.pixel
raster/r.le/r.le.setup raster/r.le/r.le.trace raster/r.li
raster/r.li/r.li.cwed raster/r.li/r.li.daemon
raster/r.li/r.li.dominance raster/r.li/r.li.edgedensity
raster/r.li/r.li.mpa raster/r.li/r.li.mps
raster/r.li/r.li.padcv raster/r.li/r.li.padrange
raster/r.li/r.li.padsd raster/r.li/r.li.patchdensity
raster/r.li/r.li.patchnum raster/r.li/r.li.richness
raster/r.li/r.li.setup raster/r.li/r.li.shannon
raster/r.li/r.li.shape raster/r.li/r.li.simpson raster/r.los
raster/r.median raster/r.mfilter raster/r.mfilter.fp
raster/r.mode raster/r.neighbors raster/r.null
raster/r.out.arc raster/r.out.ascii raster/r.out.bin
raster/r.out.gdal raster/r.out.gridatb raster/r.out.mat
raster/r.out.mpeg raster/r.out.png raster/r.out.pov
raster/r.out.ppm raster/r.out.ppm3 raster/r.out.tiff
raster/r.out.vrml raster/r.out.vtk raster/r.param.scale
raster/r.patch raster/r.profile raster/r.proj
raster/r.proj.seg raster/r.quant raster/r.quantile
raster/r.random raster/r.random.cells raster/r.random.surface
raster/r.reclass raster/r.recode raster/r.region
raster/r.report raster/r.resamp.interp raster/r.resamp.rst
raster/r.resamp.stats raster/r.resample raster/r.rescale
raster/r.rescale.eq raster/r.series raster/r.slope.aspect
raster/r.statistics raster/r.stats raster/r.sum raster/r.sun
raster/r.sunmask raster/r.support raster/r.support.stats
raster/r.surf.area raster/r.surf.contour
raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.idw
raster/r.surf.idw2 raster/r.surf.random raster/r.terraflow
raster/r.texture raster/r.thin raster/r.timestamp
raster/r.to.rast3 raster/r.to.rast3elev raster/r.to.vect
raster/r.topidx raster/r.topmodel raster/r.transect
raster/r.volume raster/r.walk raster/r.water.outlet
raster/r.watershed/front raster/r.what raster/r.what.color
raster/simwe/r.sim.sediment raster/simwe/r.sim.water
raster/wildfire/r.ros raster/wildfire/r.spread
raster/wildfire/r.spreadpath raster3d/r3.cross.rast
raster3d/r3.gwflow raster3d/r3.in.ascii raster3d/r3.in.v5d
raster3d/r3.mkdspf raster3d/r3.out.ascii raster3d/r3.out.v5d
raster3d/r3.out.vtk raster3d/r3.showdspf raster3d/r3.stats
raster3d/r3.to.rast scripts/d.correlate
scripts/d.out.gpsdrive scripts/d.polar scripts/d.rast.edit
scripts/d.rast.leg scripts/d.shadedmap
scripts/d.vect.thematic scripts/db.dropcol
scripts/db.droptable scripts/db.in.ogr scripts/db.out.ogr
scripts/db.test scripts/g.manual scripts/g.mlist
scripts/g.mremove scripts/i.fusion.brovey
scripts/i.image.mosaic scripts/i.in.spotvgt
scripts/i.landsat.rgb scripts/i.oif scripts/i.spectral
scripts/i.tasscap scripts/m.proj scripts/r.blend
scripts/r.fillnulls scripts/r.in.aster scripts/r.in.srtm
scripts/r.in.wms scripts/r.mapcalculator scripts/r.mask
scripts/r.out.gdal scripts/r.out.xyz scripts/r.plane
scripts/r.reclass.area scripts/r.regression.line
scripts/r.shaded.relief scripts/r.tileset
scripts/r3.mapcalculator scripts/v.build.all
scripts/v.centroids scripts/v.convert.all scripts/v.db.addcol
scripts/v.db.addtable scripts/v.db.dropcol
scripts/v.db.droptable scripts/v.db.join
scripts/v.db.reconnect.all scripts/v.db.renamecol
scripts/v.db.univar scripts/v.db.update scripts/v.dissolve
scripts/v.in.e00 scripts/v.in.garmin scripts/v.in.geonames
scripts/v.in.gns scripts/v.in.gpsbabel scripts/v.in.mapgen
scripts/v.in.sites.all scripts/v.in.wfs scripts/v.rast.stats
scripts/v.report scripts/v.what.vect sites/s.in.ascii
sites/s.out.ascii vector/lidar/v.lidar.correction
vector/lidar/v.lidar.edgedetection
vector/lidar/v.lidar.growing vector/lidar/v.outlier
vector/lidar/v.surf.bspline vector/v.buffer vector/v.build
vector/v.build.polylines vector/v.category vector/v.class
vector/v.clean vector/v.convert vector/v.db.connect
vector/v.db.select vector/v.digit vector/v.distance
vector/v.drape vector/v.edit vector/v.external
vector/v.extract vector/v.extrude vector/v.generalize
vector/v.hull vector/v.in.ascii vector/v.in.db
vector/v.in.dwg vector/v.in.dxf vector/v.in.ogr
vector/v.in.region vector/v.in.sites vector/v.info
vector/v.kcv vector/v.kernel vector/v.label vector/v.label.sa
vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label
vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where
vector/v.mkgrid vector/v.neighbors vector/v.net
vector/v.net.alloc vector/v.net.iso vector/v.net.path
vector/v.net.salesman vector/v.net.steiner
vector/v.net.visibility vector/v.normal vector/v.out.ascii
vector/v.out.dxf vector/v.out.ogr vector/v.out.pov
vector/v.out.svg vector/v.out.vtk vector/v.overlay
vector/v.parallel vector/v.patch vector/v.perturb
vector/v.proj vector/v.qcount vector/v.random
vector/v.reclass vector/v.sample vector/v.segment
vector/v.select vector/v.split vector/v.support
vector/v.surf.idw vector/v.surf.rst vector/v.to.db
vector/v.to.points vector/v.to.rast vector/v.to.rast3
vector/v.transform vector/v.type vector/v.univar
vector/v.vol.rst vector/v.what vector/v.what.rast
visualization/nviz visualization/nviz/src
visualization/nviz2/cmd visualization/xganim
svn_grass at osgeo.org
Fri Aug 15 02:17:21 EDT 2008
Author: glynn
Date: 2008-08-15 02:16:42 -0400 (Fri, 15 Aug 2008)
New Revision: 32772
Added:
grass/trunk/db/db.login/db.login.html
grass/trunk/display/d.barscale/d.barscale.html
grass/trunk/display/d.colorlist/d.colorlist.html
grass/trunk/display/d.colors/d.colors.html
grass/trunk/display/d.colortable/d.colortable.html
grass/trunk/display/d.erase/d.erase.html
grass/trunk/display/d.extract/d.extract.html
grass/trunk/display/d.font/d.font.html
grass/trunk/display/d.fontlist/d.fontlist.html
grass/trunk/display/d.geodesic/d.geodesic.html
grass/trunk/display/d.graph/d.graph.html
grass/trunk/display/d.grid/d.grid.html
grass/trunk/display/d.his/d.his.html
grass/trunk/display/d.histogram/d.histogram.html
grass/trunk/display/d.info/d.info.html
grass/trunk/display/d.labels/d.labels.html
grass/trunk/display/d.legend/d.legend.html
grass/trunk/display/d.linegraph/d.linegraph.html
grass/trunk/display/d.measure/d.measure.html
grass/trunk/display/d.nviz/d.nviz.html
grass/trunk/display/d.path/d.path.html
grass/trunk/display/d.profile/d.profile.html
grass/trunk/display/d.rast.arrow/d.rast.arrow.html
grass/trunk/display/d.rast.num/d.rast.num.html
grass/trunk/display/d.rast/d.rast.html
grass/trunk/display/d.rgb/d.rgb.html
grass/trunk/display/d.rhumbline/d.rhumbline.html
grass/trunk/display/d.text.new/d.text.html
grass/trunk/display/d.thematic.area/d.thematic.area.html
grass/trunk/display/d.title/d.title.html
grass/trunk/display/d.vect.chart/d.vect.chart.html
grass/trunk/display/d.vect/d.vect.html
grass/trunk/display/d.what.rast/d.what.rast.html
grass/trunk/display/d.what.vect/d.what.vect.html
grass/trunk/display/d.where/d.where.html
grass/trunk/display/d.zoom/d.zoom.html
grass/trunk/doc/raster/r.example/r.example.html
grass/trunk/doc/vector/v.example/v.example.html
grass/trunk/general/g.access/g.access.html
grass/trunk/general/g.dirseps/g.dirseps.html
grass/trunk/general/g.filename/g.filename.html
grass/trunk/general/g.findetc/g.findetc.html
grass/trunk/general/g.findfile/g.findfile.html
grass/trunk/general/g.gisenv/g.gisenv.html
grass/trunk/general/g.gui/g.gui.html
grass/trunk/general/g.mapset/g.mapset.html
grass/trunk/general/g.mapsets/g.mapsets.html
grass/trunk/general/g.message/g.message.html
grass/trunk/general/g.mkfontcap/g.mkfontcap.html
grass/trunk/general/g.parser/g.parser.html
grass/trunk/general/g.pnmcomp/g.pnmcomp.html
grass/trunk/general/g.proj/g.proj.html
grass/trunk/general/g.region/g.region.html
grass/trunk/general/g.setproj/g.setproj.html
grass/trunk/general/g.tempfile/g.tempfile.html
grass/trunk/general/g.transform/g.transform.html
grass/trunk/general/g.version/g.version.html
grass/trunk/gui/tcltk/gis.m/gis.m.html
grass/trunk/imagery/i.atcorr/i.atcorr.html
grass/trunk/imagery/i.cca/i.cca.html
grass/trunk/imagery/i.class/i.class.html
grass/trunk/imagery/i.cluster/i.cluster.html
grass/trunk/imagery/i.fft/i.fft.html
grass/trunk/imagery/i.gensig/i.gensig.html
grass/trunk/imagery/i.gensigset/i.gensigset.html
grass/trunk/imagery/i.group/i.group.html
grass/trunk/imagery/i.his.rgb/i.his.rgb.html
grass/trunk/imagery/i.ifft/i.ifft.html
grass/trunk/imagery/i.maxlik/i.maxlik.html
grass/trunk/imagery/i.ortho.photo/menu/i.ortho.photo.html
grass/trunk/imagery/i.ortho.photo/photo.2image/photo.2image.html
grass/trunk/imagery/i.ortho.photo/photo.2target/photo.2target.html
grass/trunk/imagery/i.ortho.photo/photo.camera/photo.camera.html
grass/trunk/imagery/i.ortho.photo/photo.init/photo.init.html
grass/trunk/imagery/i.ortho.photo/photo.rectify/photo.rectify.html
grass/trunk/imagery/i.pca/i.pca.html
grass/trunk/imagery/i.points/i.points.html
grass/trunk/imagery/i.rectify/i.rectify.html
grass/trunk/imagery/i.rgb.his/i.rgb.his.html
grass/trunk/imagery/i.smap/shapiro/i.smap.html
grass/trunk/imagery/i.target/i.target.html
grass/trunk/imagery/i.vpoints/i.vpoints.html
grass/trunk/imagery/i.zc/i.zc.html
grass/trunk/lib/cairodriver/cairodriver.html
grass/trunk/lib/db/sqlp/sql.html
grass/trunk/lib/htmldriver/htmldriver.html
grass/trunk/lib/pngdriver/pngdriver.html
grass/trunk/lib/psdriver/psdriver.html
grass/trunk/misc/m.cogo/m.cogo.html
grass/trunk/ps/ps.map/ps.map.html
grass/trunk/raster/r.average/r.average.html
grass/trunk/raster/r.basins.fill/r.basins.fill.html
grass/trunk/raster/r.bitpattern/r.bitpattern.html
grass/trunk/raster/r.buffer/r.buffer.html
grass/trunk/raster/r.carve/r.carve.html
grass/trunk/raster/r.cats/r.category.html
grass/trunk/raster/r.circle/r.circle.html
grass/trunk/raster/r.clump/r.clump.html
grass/trunk/raster/r.coin/r.coin.html
grass/trunk/raster/r.colors/r.colors.html
grass/trunk/raster/r.composite/r.composite.html
grass/trunk/raster/r.compress/r.compress.html
grass/trunk/raster/r.contour/r.contour.html
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.covar/r.covar.html
grass/trunk/raster/r.cross/r.cross.html
grass/trunk/raster/r.describe/r.describe.html
grass/trunk/raster/r.digit/r.digit.html
grass/trunk/raster/r.distance/r.distance.html
grass/trunk/raster/r.drain/r.drain.html
grass/trunk/raster/r.fill.dir/r.fill.dir.html
grass/trunk/raster/r.flow/r.flow.html
grass/trunk/raster/r.grow.distance/r.grow.distance.html
grass/trunk/raster/r.grow2/r.grow.html
grass/trunk/raster/r.gwflow/r.gwflow.html
grass/trunk/raster/r.his/r.his.html
grass/trunk/raster/r.in.arc/r.in.arc.html
grass/trunk/raster/r.in.ascii/r.in.ascii.html
grass/trunk/raster/r.in.bin/r.in.bin.html
grass/trunk/raster/r.in.gdal/r.in.gdal.html
grass/trunk/raster/r.in.gridatb/r.in.gridatb.html
grass/trunk/raster/r.in.mat/r.in.mat.html
grass/trunk/raster/r.in.poly/r.in.poly.html
grass/trunk/raster/r.in.xyz/r.in.xyz.html
grass/trunk/raster/r.info/r.info.html
grass/trunk/raster/r.kappa/r.kappa.html
grass/trunk/raster/r.lake/r.lake.html
grass/trunk/raster/r.le/r.le.patch/r.le.patch.html
grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html
grass/trunk/raster/r.le/r.le.setup/r.le.setup.html
grass/trunk/raster/r.le/r.le.trace/r.le.trace.html
grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html
grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
grass/trunk/raster/r.li/r.li.html
grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
grass/trunk/raster/r.los/r.los.html
grass/trunk/raster/r.median/r.median.html
grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html
grass/trunk/raster/r.mfilter/r.mfilter.html
grass/trunk/raster/r.mode/r.mode.html
grass/trunk/raster/r.neighbors/r.neighbors.html
grass/trunk/raster/r.null/r.null.html
grass/trunk/raster/r.out.arc/r.out.arc.html
grass/trunk/raster/r.out.ascii/r.out.ascii.html
grass/trunk/raster/r.out.bin/r.out.bin.html
grass/trunk/raster/r.out.gdal/r.out.gdal.html
grass/trunk/raster/r.out.gridatb/r.out.gridatb.html
grass/trunk/raster/r.out.mat/r.out.mat.html
grass/trunk/raster/r.out.mpeg/r.out.mpeg.html
grass/trunk/raster/r.out.png/r.out.png.html
grass/trunk/raster/r.out.pov/r.out.pov.html
grass/trunk/raster/r.out.ppm/r.out.ppm.html
grass/trunk/raster/r.out.ppm3/r.out.ppm3.html
grass/trunk/raster/r.out.tiff/r.out.tiff.html
grass/trunk/raster/r.out.vrml/r.out.vrml.html
grass/trunk/raster/r.out.vtk/r.out.vtk.html
grass/trunk/raster/r.param.scale/r.param.scale.html
grass/trunk/raster/r.patch/r.patch.html
grass/trunk/raster/r.profile/r.profile.html
grass/trunk/raster/r.proj.seg/r.proj.html
grass/trunk/raster/r.proj/r.proj.html
grass/trunk/raster/r.quant/r.quant.html
grass/trunk/raster/r.quantile/r.quantile.html
grass/trunk/raster/r.random.cells/r.random.cells.html
grass/trunk/raster/r.random.surface/r.random.surface.html
grass/trunk/raster/r.random/r.random.html
grass/trunk/raster/r.reclass/r.reclass.html
grass/trunk/raster/r.recode/r.recode.html
grass/trunk/raster/r.region/r.region.html
grass/trunk/raster/r.report/r.report.html
grass/trunk/raster/r.resamp.interp/r.resamp.interp.html
grass/trunk/raster/r.resamp.rst/r.resamp.rst.html
grass/trunk/raster/r.resamp.stats/r.resamp.stats.html
grass/trunk/raster/r.resample/r.resample.html
grass/trunk/raster/r.rescale.eq/r.rescale.eq.html
grass/trunk/raster/r.rescale/r.rescale.html
grass/trunk/raster/r.series/r.series.html
grass/trunk/raster/r.slope.aspect/r.slope.aspect.html
grass/trunk/raster/r.statistics/r.statistics.html
grass/trunk/raster/r.stats/r.stats.html
grass/trunk/raster/r.sum/r.sum.html
grass/trunk/raster/r.sun/r.sun.html
grass/trunk/raster/r.sunmask/r.sunmask.html
grass/trunk/raster/r.support.stats/r.support.stats.html
grass/trunk/raster/r.support/r.support.html
grass/trunk/raster/r.surf.area/r.surf.area.html
grass/trunk/raster/r.surf.contour/r.surf.contour.html
grass/trunk/raster/r.surf.fractal/r.surf.fractal.html
grass/trunk/raster/r.surf.gauss/r.surf.gauss.html
grass/trunk/raster/r.surf.idw/r.surf.idw.html
grass/trunk/raster/r.surf.idw2/r.surf.idw2.html
grass/trunk/raster/r.surf.random/r.surf.random.html
grass/trunk/raster/r.terraflow/r.terraflow.html
grass/trunk/raster/r.texture/r.texture.html
grass/trunk/raster/r.thin/r.thin.html
grass/trunk/raster/r.timestamp/r.timestamp.html
grass/trunk/raster/r.to.rast3/r.to.rast3.html
grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html
grass/trunk/raster/r.to.vect/r.to.vect.html
grass/trunk/raster/r.topidx/r.topidx.html
grass/trunk/raster/r.topmodel/r.topmodel.html
grass/trunk/raster/r.transect/r.transect.html
grass/trunk/raster/r.volume/r.volume.html
grass/trunk/raster/r.walk/r.walk.html
grass/trunk/raster/r.water.outlet/r.water.outlet.html
grass/trunk/raster/r.watershed/front/r.watershed.html
grass/trunk/raster/r.what.color/r.what.color.html
grass/trunk/raster/r.what/r.what.html
grass/trunk/raster/simwe/r.sim.sediment/r.sim.sediment.html
grass/trunk/raster/simwe/r.sim.water/r.sim.water.html
grass/trunk/raster/wildfire/r.ros/r.ros.html
grass/trunk/raster/wildfire/r.spread/r.spread.html
grass/trunk/raster/wildfire/r.spreadpath/r.spreadpath.html
grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html
grass/trunk/raster3d/r3.gwflow/r3.gwflow.html
grass/trunk/raster3d/r3.in.ascii/r3.in.ascii.html
grass/trunk/raster3d/r3.in.v5d/r3.in.v5d.html
grass/trunk/raster3d/r3.mkdspf/r3.mkdspf.html
grass/trunk/raster3d/r3.out.ascii/r3.out.ascii.html
grass/trunk/raster3d/r3.out.v5d/r3.out.v5d.html
grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html
grass/trunk/raster3d/r3.showdspf/r3.showdspf.html
grass/trunk/raster3d/r3.stats/r3.stats.html
grass/trunk/raster3d/r3.to.rast/r3.to.rast.html
grass/trunk/scripts/d.correlate/d.correlate.html
grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html
grass/trunk/scripts/d.polar/d.polar.html
grass/trunk/scripts/d.rast.edit/d.rast.edit.html
grass/trunk/scripts/d.rast.leg/d.rast.leg.html
grass/trunk/scripts/d.shadedmap/d.shadedmap.html
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html
grass/trunk/scripts/db.dropcol/db.dropcol.html
grass/trunk/scripts/db.droptable/db.droptable.html
grass/trunk/scripts/db.in.ogr/db.in.ogr.html
grass/trunk/scripts/db.out.ogr/db.out.ogr.html
grass/trunk/scripts/db.test/db.test.html
grass/trunk/scripts/g.manual/g.manual.html
grass/trunk/scripts/g.mlist/g.mlist.html
grass/trunk/scripts/g.mremove/g.mremove.html
grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.html
grass/trunk/scripts/i.image.mosaic/i.image.mosaic.html
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.html
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.html
grass/trunk/scripts/i.oif/i.oif.html
grass/trunk/scripts/i.spectral/i.spectral.html
grass/trunk/scripts/i.tasscap/i.tasscap.html
grass/trunk/scripts/m.proj/m.proj.html
grass/trunk/scripts/r.blend/r.blend.html
grass/trunk/scripts/r.fillnulls/r.fillnulls.html
grass/trunk/scripts/r.in.aster/r.in.aster.html
grass/trunk/scripts/r.in.srtm/r.in.srtm.html
grass/trunk/scripts/r.in.wms/r.in.wms.html
grass/trunk/scripts/r.mapcalculator/r.mapcalculator.html
grass/trunk/scripts/r.mask/r.mask.html
grass/trunk/scripts/r.out.gdal/r.out.gdal.sh.html
grass/trunk/scripts/r.out.xyz/r.out.xyz.html
grass/trunk/scripts/r.plane/r.plane.html
grass/trunk/scripts/r.reclass.area/r.reclass.area.html
grass/trunk/scripts/r.regression.line/r.regression.line.html
grass/trunk/scripts/r.shaded.relief/r.shaded.relief.html
grass/trunk/scripts/r.tileset/r.tileset.html
grass/trunk/scripts/r3.mapcalculator/r3.mapcalculator.html
grass/trunk/scripts/v.build.all/v.build.all.html
grass/trunk/scripts/v.centroids/v.centroids.html
grass/trunk/scripts/v.convert.all/v.convert.all.html
grass/trunk/scripts/v.db.addcol/v.db.addcol.html
grass/trunk/scripts/v.db.addtable/v.db.addtable.html
grass/trunk/scripts/v.db.dropcol/v.db.dropcol.html
grass/trunk/scripts/v.db.droptable/v.db.droptable.html
grass/trunk/scripts/v.db.join/v.db.join.html
grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.html
grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html
grass/trunk/scripts/v.db.univar/v.db.univar.html
grass/trunk/scripts/v.db.update/v.db.update.html
grass/trunk/scripts/v.dissolve/v.dissolve.html
grass/trunk/scripts/v.in.e00/v.in.e00.html
grass/trunk/scripts/v.in.garmin/v.in.garmin.html
grass/trunk/scripts/v.in.geonames/v.in.geonames.html
grass/trunk/scripts/v.in.gns/v.in.gns.html
grass/trunk/scripts/v.in.gpsbabel/v.in.gpsbabel.html
grass/trunk/scripts/v.in.mapgen/v.in.mapgen.html
grass/trunk/scripts/v.in.sites.all/v.in.sites.all.html
grass/trunk/scripts/v.in.wfs/v.in.wfs.html
grass/trunk/scripts/v.rast.stats/v.rast.stats.html
grass/trunk/scripts/v.report/v.report.html
grass/trunk/scripts/v.what.vect/v.what.vect.html
grass/trunk/sites/s.in.ascii/s.in.ascii.html
grass/trunk/sites/s.out.ascii/s.out.ascii.html
grass/trunk/vector/lidar/v.lidar.correction/v.lidar.correction.html
grass/trunk/vector/lidar/v.lidar.edgedetection/v.lidar.edgedetection.html
grass/trunk/vector/lidar/v.lidar.growing/v.lidar.growing.html
grass/trunk/vector/lidar/v.outlier/v.outlier.html
grass/trunk/vector/lidar/v.surf.bspline/v.surf.bspline.html
grass/trunk/vector/v.buffer/v.buffer.html
grass/trunk/vector/v.build.polylines/v.build.polylines.html
grass/trunk/vector/v.build/v.build.html
grass/trunk/vector/v.category/v.category.html
grass/trunk/vector/v.class/v.class.html
grass/trunk/vector/v.clean/v.clean.html
grass/trunk/vector/v.convert/v.convert.html
grass/trunk/vector/v.db.connect/v.db.connect.html
grass/trunk/vector/v.db.select/v.db.select.html
grass/trunk/vector/v.digit/v.digit.html
grass/trunk/vector/v.distance/v.distance.html
grass/trunk/vector/v.drape/v.drape.html
grass/trunk/vector/v.edit/v.edit.html
grass/trunk/vector/v.external/v.external.html
grass/trunk/vector/v.extract/v.extract.html
grass/trunk/vector/v.extrude/v.extrude.html
grass/trunk/vector/v.generalize/v.generalize.html
grass/trunk/vector/v.hull/v.hull.html
grass/trunk/vector/v.in.ascii/v.in.ascii.html
grass/trunk/vector/v.in.db/v.in.db.html
grass/trunk/vector/v.in.dwg/v.in.dwg.html
grass/trunk/vector/v.in.dxf/v.in.dxf.html
grass/trunk/vector/v.in.ogr/v.in.ogr.html
grass/trunk/vector/v.in.region/v.in.region.html
grass/trunk/vector/v.in.sites/v.in.sites.html
grass/trunk/vector/v.info/v.info.html
grass/trunk/vector/v.kcv/v.kcv.html
grass/trunk/vector/v.kernel/v.kernel.html
grass/trunk/vector/v.label.sa/v.label.sa.html
grass/trunk/vector/v.label/v.label.html
grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html
grass/trunk/vector/v.lrs/v.lrs.label/v.lrs.label.html
grass/trunk/vector/v.lrs/v.lrs.segment/v.lrs.segment.html
grass/trunk/vector/v.lrs/v.lrs.where/v.lrs.where.html
grass/trunk/vector/v.mkgrid/v.mkgrid.html
grass/trunk/vector/v.neighbors/v.neighbors.html
grass/trunk/vector/v.net.alloc/v.net.alloc.html
grass/trunk/vector/v.net.iso/v.net.iso.html
grass/trunk/vector/v.net.path/v.net.path.html
grass/trunk/vector/v.net.salesman/v.net.salesman.html
grass/trunk/vector/v.net.steiner/v.net.steiner.html
grass/trunk/vector/v.net.visibility/v.net.visibility.html
grass/trunk/vector/v.net/v.net.html
grass/trunk/vector/v.normal/v.normal.html
grass/trunk/vector/v.out.ascii/v.out.ascii.html
grass/trunk/vector/v.out.dxf/v.out.dxf.html
grass/trunk/vector/v.out.ogr/v.out.ogr.html
grass/trunk/vector/v.out.pov/v.out.pov.html
grass/trunk/vector/v.out.svg/v.out.svg.html
grass/trunk/vector/v.out.vtk/v.out.vtk.html
grass/trunk/vector/v.overlay/v.overlay.html
grass/trunk/vector/v.parallel/v.parallel.html
grass/trunk/vector/v.patch/v.patch.html
grass/trunk/vector/v.perturb/v.perturb.html
grass/trunk/vector/v.proj/v.proj.html
grass/trunk/vector/v.qcount/v.qcount.html
grass/trunk/vector/v.random/v.random.html
grass/trunk/vector/v.reclass/v.reclass.html
grass/trunk/vector/v.sample/v.sample.html
grass/trunk/vector/v.segment/v.segment.html
grass/trunk/vector/v.select/v.select.html
grass/trunk/vector/v.split/v.split.html
grass/trunk/vector/v.support/v.support.html
grass/trunk/vector/v.surf.idw/v.surf.idw.html
grass/trunk/vector/v.surf.rst/v.surf.rst.html
grass/trunk/vector/v.to.db/v.to.db.html
grass/trunk/vector/v.to.points/v.to.points.html
grass/trunk/vector/v.to.rast/v.to.rast.html
grass/trunk/vector/v.to.rast3/v.to.rast3.html
grass/trunk/vector/v.transform/v.transform.html
grass/trunk/vector/v.type/v.type.html
grass/trunk/vector/v.univar/v.univar.html
grass/trunk/vector/v.vol.rst/v.vol.rst.html
grass/trunk/vector/v.what.rast/v.what.rast.html
grass/trunk/vector/v.what/v.what.html
grass/trunk/visualization/nviz/nviz.html
grass/trunk/visualization/nviz2/cmd/nviz_cmd.html
grass/trunk/visualization/xganim/xganim.html
Removed:
grass/trunk/db/db.login/description.html
grass/trunk/display/d.barscale/description.html
grass/trunk/display/d.colorlist/description.html
grass/trunk/display/d.colors/description.html
grass/trunk/display/d.colortable/description.html
grass/trunk/display/d.erase/description.html
grass/trunk/display/d.extract/description.html
grass/trunk/display/d.font/description.html
grass/trunk/display/d.fontlist/description.html
grass/trunk/display/d.geodesic/description.html
grass/trunk/display/d.graph/description.html
grass/trunk/display/d.grid/description.html
grass/trunk/display/d.his/description.html
grass/trunk/display/d.histogram/description.html
grass/trunk/display/d.info/description.html
grass/trunk/display/d.labels/description.html
grass/trunk/display/d.legend/description.html
grass/trunk/display/d.linegraph/description.html
grass/trunk/display/d.measure/description.html
grass/trunk/display/d.nviz/description.html
grass/trunk/display/d.path/description.html
grass/trunk/display/d.profile/description.html
grass/trunk/display/d.rast.arrow/description.html
grass/trunk/display/d.rast.num/description.html
grass/trunk/display/d.rast/description.html
grass/trunk/display/d.rgb/description.html
grass/trunk/display/d.rhumbline/description.html
grass/trunk/display/d.text.new/description.html
grass/trunk/display/d.thematic.area/description.html
grass/trunk/display/d.title/description.html
grass/trunk/display/d.vect.chart/description.html
grass/trunk/display/d.vect/description.html
grass/trunk/display/d.what.rast/description.html
grass/trunk/display/d.what.vect/description.html
grass/trunk/display/d.where/description.html
grass/trunk/display/d.zoom/description.html
grass/trunk/doc/raster/r.example/description.html
grass/trunk/doc/vector/v.example/description.html
grass/trunk/general/g.access/description.html
grass/trunk/general/g.dirseps/description.html
grass/trunk/general/g.filename/description.html
grass/trunk/general/g.findetc/description.html
grass/trunk/general/g.findfile/description.html
grass/trunk/general/g.gisenv/description.html
grass/trunk/general/g.gui/description.html
grass/trunk/general/g.mapset/description.html
grass/trunk/general/g.mapsets/description.html
grass/trunk/general/g.message/description.html
grass/trunk/general/g.mkfontcap/description.html
grass/trunk/general/g.parser/description.html
grass/trunk/general/g.pnmcomp/description.html
grass/trunk/general/g.proj/description.html
grass/trunk/general/g.region/description.html
grass/trunk/general/g.setproj/description.html
grass/trunk/general/g.tempfile/description.html
grass/trunk/general/g.transform/description.html
grass/trunk/general/g.version/description.html
grass/trunk/gui/tcltk/gis.m/description.html
grass/trunk/imagery/i.atcorr/description.html
grass/trunk/imagery/i.cca/description.html
grass/trunk/imagery/i.class/description.html
grass/trunk/imagery/i.cluster/description.html
grass/trunk/imagery/i.fft/description.html
grass/trunk/imagery/i.gensig/description.html
grass/trunk/imagery/i.gensigset/description.html
grass/trunk/imagery/i.group/description.html
grass/trunk/imagery/i.his.rgb/description.html
grass/trunk/imagery/i.ifft/description.html
grass/trunk/imagery/i.maxlik/description.html
grass/trunk/imagery/i.ortho.photo/menu/description.html
grass/trunk/imagery/i.ortho.photo/photo.2image/description.html
grass/trunk/imagery/i.ortho.photo/photo.2target/description.html
grass/trunk/imagery/i.ortho.photo/photo.camera/description.html
grass/trunk/imagery/i.ortho.photo/photo.init/description.html
grass/trunk/imagery/i.ortho.photo/photo.rectify/description.html
grass/trunk/imagery/i.pca/description.html
grass/trunk/imagery/i.points/description.html
grass/trunk/imagery/i.rectify/description.html
grass/trunk/imagery/i.rgb.his/description.html
grass/trunk/imagery/i.smap/shapiro/description.html
grass/trunk/imagery/i.target/description.html
grass/trunk/imagery/i.vpoints/description.html
grass/trunk/imagery/i.zc/description.html
grass/trunk/lib/cairodriver/description.html
grass/trunk/lib/db/sqlp/description.html
grass/trunk/lib/htmldriver/description.html
grass/trunk/lib/pngdriver/description.html
grass/trunk/lib/psdriver/description.html
grass/trunk/misc/m.cogo/description.html
grass/trunk/ps/ps.map/description.html
grass/trunk/raster/r.average/description.html
grass/trunk/raster/r.basins.fill/description.html
grass/trunk/raster/r.bitpattern/description.html
grass/trunk/raster/r.buffer/description.html
grass/trunk/raster/r.carve/description.html
grass/trunk/raster/r.cats/description.html
grass/trunk/raster/r.circle/description.html
grass/trunk/raster/r.clump/description.html
grass/trunk/raster/r.coin/description.html
grass/trunk/raster/r.colors/description.html
grass/trunk/raster/r.composite/description.html
grass/trunk/raster/r.compress/description.html
grass/trunk/raster/r.contour/description.html
grass/trunk/raster/r.cost/description.html
grass/trunk/raster/r.covar/description.html
grass/trunk/raster/r.cross/description.html
grass/trunk/raster/r.describe/description.html
grass/trunk/raster/r.digit/description.html
grass/trunk/raster/r.distance/description.html
grass/trunk/raster/r.drain/description.html
grass/trunk/raster/r.fill.dir/description.html
grass/trunk/raster/r.flow/description.html
grass/trunk/raster/r.grow.distance/description.html
grass/trunk/raster/r.grow2/description.html
grass/trunk/raster/r.gwflow/description.html
grass/trunk/raster/r.his/description.html
grass/trunk/raster/r.in.arc/description.html
grass/trunk/raster/r.in.ascii/description.html
grass/trunk/raster/r.in.bin/description.html
grass/trunk/raster/r.in.gdal/description.html
grass/trunk/raster/r.in.gridatb/description.html
grass/trunk/raster/r.in.mat/description.html
grass/trunk/raster/r.in.poly/description.html
grass/trunk/raster/r.in.xyz/description.html
grass/trunk/raster/r.info/description.html
grass/trunk/raster/r.kappa/description.html
grass/trunk/raster/r.lake/description.html
grass/trunk/raster/r.le/r.le.patch/description.html
grass/trunk/raster/r.le/r.le.pixel/description.html
grass/trunk/raster/r.le/r.le.setup/description.html
grass/trunk/raster/r.le/r.le.trace/description.html
grass/trunk/raster/r.li/description.html
grass/trunk/raster/r.li/r.li.cwed/description.html
grass/trunk/raster/r.li/r.li.daemon/description.html
grass/trunk/raster/r.li/r.li.dominance/description.html
grass/trunk/raster/r.li/r.li.edgedensity/description.html
grass/trunk/raster/r.li/r.li.mpa/description.html
grass/trunk/raster/r.li/r.li.mps/description.html
grass/trunk/raster/r.li/r.li.padcv/description.html
grass/trunk/raster/r.li/r.li.padrange/description.html
grass/trunk/raster/r.li/r.li.padsd/description.html
grass/trunk/raster/r.li/r.li.patchdensity/description.html
grass/trunk/raster/r.li/r.li.patchnum/description.html
grass/trunk/raster/r.li/r.li.richness/description.html
grass/trunk/raster/r.li/r.li.setup/description.html
grass/trunk/raster/r.li/r.li.shannon/description.html
grass/trunk/raster/r.li/r.li.shape/description.html
grass/trunk/raster/r.li/r.li.simpson/description.html
grass/trunk/raster/r.los/description.html
grass/trunk/raster/r.median/description.html
grass/trunk/raster/r.mfilter.fp/description.html
grass/trunk/raster/r.mfilter/description.html
grass/trunk/raster/r.mode/description.html
grass/trunk/raster/r.neighbors/description.html
grass/trunk/raster/r.null/description.html
grass/trunk/raster/r.out.arc/description.html
grass/trunk/raster/r.out.ascii/description.html
grass/trunk/raster/r.out.bin/description.html
grass/trunk/raster/r.out.gdal/description.html
grass/trunk/raster/r.out.gridatb/description.html
grass/trunk/raster/r.out.mat/description.html
grass/trunk/raster/r.out.mpeg/description.html
grass/trunk/raster/r.out.png/description.html
grass/trunk/raster/r.out.pov/description.html
grass/trunk/raster/r.out.ppm/description.html
grass/trunk/raster/r.out.ppm3/description.html
grass/trunk/raster/r.out.tiff/description.html
grass/trunk/raster/r.out.vrml/description.html
grass/trunk/raster/r.out.vtk/description.html
grass/trunk/raster/r.param.scale/description.html
grass/trunk/raster/r.patch/description.html
grass/trunk/raster/r.profile/description.html
grass/trunk/raster/r.proj.seg/description.html
grass/trunk/raster/r.proj/description.html
grass/trunk/raster/r.quant/description.html
grass/trunk/raster/r.quantile/description.html
grass/trunk/raster/r.random.cells/description.html
grass/trunk/raster/r.random.surface/description.html
grass/trunk/raster/r.random/description.html
grass/trunk/raster/r.reclass/description.html
grass/trunk/raster/r.recode/description.html
grass/trunk/raster/r.region/description.html
grass/trunk/raster/r.report/description.html
grass/trunk/raster/r.resamp.interp/description.html
grass/trunk/raster/r.resamp.rst/description.html
grass/trunk/raster/r.resamp.stats/description.html
grass/trunk/raster/r.resample/description.html
grass/trunk/raster/r.rescale.eq/description.html
grass/trunk/raster/r.rescale/description.html
grass/trunk/raster/r.series/description.html
grass/trunk/raster/r.slope.aspect/description.html
grass/trunk/raster/r.statistics/description.html
grass/trunk/raster/r.stats/description.html
grass/trunk/raster/r.sum/description.html
grass/trunk/raster/r.sun/description.html
grass/trunk/raster/r.sunmask/description.html
grass/trunk/raster/r.support.stats/description.html
grass/trunk/raster/r.support/description.html
grass/trunk/raster/r.surf.area/description.html
grass/trunk/raster/r.surf.contour/description.html
grass/trunk/raster/r.surf.fractal/description.html
grass/trunk/raster/r.surf.gauss/description.html
grass/trunk/raster/r.surf.idw/description.html
grass/trunk/raster/r.surf.idw2/description.html
grass/trunk/raster/r.surf.random/description.html
grass/trunk/raster/r.terraflow/description.html
grass/trunk/raster/r.texture/description.html
grass/trunk/raster/r.thin/description.html
grass/trunk/raster/r.timestamp/description.html
grass/trunk/raster/r.to.rast3/description.html
grass/trunk/raster/r.to.rast3elev/description.html
grass/trunk/raster/r.to.vect/description.html
grass/trunk/raster/r.topidx/description.html
grass/trunk/raster/r.topmodel/description.html
grass/trunk/raster/r.transect/description.html
grass/trunk/raster/r.volume/description.html
grass/trunk/raster/r.walk/description.html
grass/trunk/raster/r.water.outlet/description.html
grass/trunk/raster/r.watershed/front/description.html
grass/trunk/raster/r.what.color/description.html
grass/trunk/raster/r.what/description.html
grass/trunk/raster/simwe/r.sim.sediment/description.html
grass/trunk/raster/simwe/r.sim.water/description.html
grass/trunk/raster/wildfire/r.ros/description.html
grass/trunk/raster/wildfire/r.spread/description.html
grass/trunk/raster/wildfire/r.spreadpath/description.html
grass/trunk/raster3d/r3.cross.rast/description.html
grass/trunk/raster3d/r3.gwflow/description.html
grass/trunk/raster3d/r3.in.ascii/description.html
grass/trunk/raster3d/r3.in.v5d/description.html
grass/trunk/raster3d/r3.mkdspf/description.html
grass/trunk/raster3d/r3.out.ascii/description.html
grass/trunk/raster3d/r3.out.v5d/description.html
grass/trunk/raster3d/r3.out.vtk/description.html
grass/trunk/raster3d/r3.showdspf/description.html
grass/trunk/raster3d/r3.stats/description.html
grass/trunk/raster3d/r3.to.rast/description.html
grass/trunk/scripts/d.correlate/description.html
grass/trunk/scripts/d.out.gpsdrive/description.html
grass/trunk/scripts/d.polar/description.html
grass/trunk/scripts/d.rast.edit/description.html
grass/trunk/scripts/d.rast.leg/description.html
grass/trunk/scripts/d.shadedmap/description.html
grass/trunk/scripts/d.vect.thematic/description.html
grass/trunk/scripts/db.dropcol/description.html
grass/trunk/scripts/db.droptable/description.html
grass/trunk/scripts/db.in.ogr/description.html
grass/trunk/scripts/db.out.ogr/description.html
grass/trunk/scripts/db.test/description.html
grass/trunk/scripts/g.manual/description.html
grass/trunk/scripts/g.mlist/description.html
grass/trunk/scripts/g.mremove/description.html
grass/trunk/scripts/i.fusion.brovey/description.html
grass/trunk/scripts/i.image.mosaic/description.html
grass/trunk/scripts/i.in.spotvgt/description.html
grass/trunk/scripts/i.landsat.rgb/description.html
grass/trunk/scripts/i.oif/description.html
grass/trunk/scripts/i.spectral/description.html
grass/trunk/scripts/i.tasscap/description.html
grass/trunk/scripts/m.proj/description.html
grass/trunk/scripts/r.blend/description.html
grass/trunk/scripts/r.fillnulls/description.html
grass/trunk/scripts/r.in.aster/description.html
grass/trunk/scripts/r.in.srtm/description.html
grass/trunk/scripts/r.in.wms/description.html
grass/trunk/scripts/r.mapcalculator/description.html
grass/trunk/scripts/r.mask/description.html
grass/trunk/scripts/r.out.gdal/description.html
grass/trunk/scripts/r.out.xyz/description.html
grass/trunk/scripts/r.plane/description.html
grass/trunk/scripts/r.reclass.area/description.html
grass/trunk/scripts/r.regression.line/description.html
grass/trunk/scripts/r.shaded.relief/description.html
grass/trunk/scripts/r.tileset/description.html
grass/trunk/scripts/r3.mapcalculator/description.html
grass/trunk/scripts/v.build.all/description.html
grass/trunk/scripts/v.centroids/description.html
grass/trunk/scripts/v.convert.all/description.html
grass/trunk/scripts/v.db.addcol/description.html
grass/trunk/scripts/v.db.addtable/description.html
grass/trunk/scripts/v.db.dropcol/description.html
grass/trunk/scripts/v.db.droptable/description.html
grass/trunk/scripts/v.db.join/description.html
grass/trunk/scripts/v.db.reconnect.all/description.html
grass/trunk/scripts/v.db.renamecol/description.html
grass/trunk/scripts/v.db.univar/description.html
grass/trunk/scripts/v.db.update/description.html
grass/trunk/scripts/v.dissolve/description.html
grass/trunk/scripts/v.in.e00/description.html
grass/trunk/scripts/v.in.garmin/description.html
grass/trunk/scripts/v.in.geonames/description.html
grass/trunk/scripts/v.in.gns/description.html
grass/trunk/scripts/v.in.gpsbabel/description.html
grass/trunk/scripts/v.in.mapgen/description.html
grass/trunk/scripts/v.in.sites.all/description.html
grass/trunk/scripts/v.in.wfs/description.html
grass/trunk/scripts/v.rast.stats/description.html
grass/trunk/scripts/v.report/description.html
grass/trunk/scripts/v.what.vect/description.html
grass/trunk/sites/s.in.ascii/description.html
grass/trunk/sites/s.out.ascii/description.html
grass/trunk/vector/lidar/v.lidar.correction/description.html
grass/trunk/vector/lidar/v.lidar.edgedetection/description.html
grass/trunk/vector/lidar/v.lidar.growing/description.html
grass/trunk/vector/lidar/v.outlier/description.html
grass/trunk/vector/lidar/v.surf.bspline/description.html
grass/trunk/vector/v.buffer/description.html
grass/trunk/vector/v.build.polylines/description.html
grass/trunk/vector/v.build/description.html
grass/trunk/vector/v.category/description.html
grass/trunk/vector/v.class/description.html
grass/trunk/vector/v.clean/description.html
grass/trunk/vector/v.convert/description.html
grass/trunk/vector/v.db.connect/description.html
grass/trunk/vector/v.db.select/description.html
grass/trunk/vector/v.digit/description.html
grass/trunk/vector/v.distance/description.html
grass/trunk/vector/v.drape/description.html
grass/trunk/vector/v.edit/description.html
grass/trunk/vector/v.external/description.html
grass/trunk/vector/v.extract/description.html
grass/trunk/vector/v.extrude/description.html
grass/trunk/vector/v.generalize/description.html
grass/trunk/vector/v.hull/description.html
grass/trunk/vector/v.in.ascii/description.html
grass/trunk/vector/v.in.db/description.html
grass/trunk/vector/v.in.dwg/description.html
grass/trunk/vector/v.in.dxf/description.html
grass/trunk/vector/v.in.ogr/description.html
grass/trunk/vector/v.in.region/description.html
grass/trunk/vector/v.in.sites/description.html
grass/trunk/vector/v.info/description.html
grass/trunk/vector/v.kcv/description.html
grass/trunk/vector/v.kernel/description.html
grass/trunk/vector/v.label.sa/description.html
grass/trunk/vector/v.label/description.html
grass/trunk/vector/v.lrs/v.lrs.create/description.html
grass/trunk/vector/v.lrs/v.lrs.label/description.html
grass/trunk/vector/v.lrs/v.lrs.segment/description.html
grass/trunk/vector/v.lrs/v.lrs.where/description.html
grass/trunk/vector/v.mkgrid/description.html
grass/trunk/vector/v.neighbors/description.html
grass/trunk/vector/v.net.alloc/description.html
grass/trunk/vector/v.net.iso/description.html
grass/trunk/vector/v.net.path/description.html
grass/trunk/vector/v.net.salesman/description.html
grass/trunk/vector/v.net.steiner/description.html
grass/trunk/vector/v.net.visibility/description.html
grass/trunk/vector/v.net/description.html
grass/trunk/vector/v.normal/description.html
grass/trunk/vector/v.out.ascii/description.html
grass/trunk/vector/v.out.dxf/description.html
grass/trunk/vector/v.out.ogr/description.html
grass/trunk/vector/v.out.pov/description.html
grass/trunk/vector/v.out.svg/description.html
grass/trunk/vector/v.out.vtk/description.html
grass/trunk/vector/v.overlay/description.html
grass/trunk/vector/v.parallel/description.html
grass/trunk/vector/v.patch/description.html
grass/trunk/vector/v.perturb/description.html
grass/trunk/vector/v.proj/description.html
grass/trunk/vector/v.qcount/description.html
grass/trunk/vector/v.random/description.html
grass/trunk/vector/v.reclass/description.html
grass/trunk/vector/v.sample/description.html
grass/trunk/vector/v.segment/description.html
grass/trunk/vector/v.select/description.html
grass/trunk/vector/v.split/description.html
grass/trunk/vector/v.support/description.html
grass/trunk/vector/v.surf.idw/description.html
grass/trunk/vector/v.surf.rst/description.html
grass/trunk/vector/v.to.db/description.html
grass/trunk/vector/v.to.points/description.html
grass/trunk/vector/v.to.rast/description.html
grass/trunk/vector/v.to.rast3/description.html
grass/trunk/vector/v.transform/description.html
grass/trunk/vector/v.type/description.html
grass/trunk/vector/v.univar/description.html
grass/trunk/vector/v.vol.rst/description.html
grass/trunk/vector/v.what.rast/description.html
grass/trunk/vector/v.what/description.html
grass/trunk/visualization/nviz/description.html
grass/trunk/visualization/nviz/src/description.html
grass/trunk/visualization/nviz2/cmd/description.html
grass/trunk/visualization/xganim/description.html
grass/trunk/gui/tcltk/gis.m/Makefile
grass/trunk/imagery/i.ortho.photo/photo.2image/Makefile
grass/trunk/imagery/i.ortho.photo/photo.2target/Makefile
grass/trunk/imagery/i.ortho.photo/photo.camera/Makefile
grass/trunk/imagery/i.ortho.photo/photo.init/Makefile
grass/trunk/imagery/i.ortho.photo/photo.rectify/Makefile
grass/trunk/lib/cairodriver/Makefile
grass/trunk/lib/db/sqlp/Makefile
grass/trunk/lib/htmldriver/Makefile
grass/trunk/lib/pngdriver/Makefile
grass/trunk/lib/psdriver/Makefile
grass/trunk/raster/r.li/Makefile
grass/trunk/raster/r.li/r.li.daemon/Makefile
grass/trunk/visualization/nviz/Makefile
grass/trunk/visualization/nviz/src/Makefile
Rename description.html -> $(PGM).html
Copied: grass/trunk/db/db.login/db.login.html (from rev 32770, grass/trunk/db/db.login/description.html)
--- grass/trunk/db/db.login/db.login.html (rev 0)
+++ grass/trunk/db/db.login/db.login.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,46 @@
+<h2>DESCRIPTION</h2>
+<em>db.login</em> sets user/password for driver/database.
+<h2>NOTE</h2>
+This is only related to SQL database backends (PostgreSQL, MySQL etc).
+The passwords are stored in a hidden file in the user account ('home'
+directory) called <em>.grasslogin6</em>. Only the file owner
+can access this file.
+<h2>EXAMPLES</h2>
+Example 1: Username specified, password will be invisibly queried interactively:
+<div class="code"><pre>
+db.login user=bacava
+</pre></div>
+<P>
+Example 2: Username and password specified (note that the command
+lines history will store the password in this way):
+db.login user=bacava pass=secret
+</pre></div>
+<P>
+Example 3: Username and empty password specified (note that the command
+db.login user=bacava pass=""
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a HREF="db.connect.html">db.connect</a>,
+<a HREF="db.test.html">db.test</a>
+</em>
+<h2>AUTHOR</h2>
+Radim Blazek
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/db/db.login/description.html
--- grass/trunk/db/db.login/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/db/db.login/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,46 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>db.login</em> sets user/password for driver/database.
-<h2>NOTE</h2>
-This is only related to SQL database backends (PostgreSQL, MySQL etc).
-The passwords are stored in a hidden file in the user account ('home'
-directory) called <em>.grasslogin6</em>. Only the file owner
-can access this file.
-<h2>EXAMPLES</h2>
-Example 1: Username specified, password will be invisibly queried interactively:
-<div class="code"><pre>
-db.login user=bacava
-</pre></div>
-<P>
-Example 2: Username and password specified (note that the command
-lines history will store the password in this way):
-db.login user=bacava pass=secret
-</pre></div>
-<P>
-Example 3: Username and empty password specified (note that the command
-db.login user=bacava pass=""
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a HREF="db.connect.html">db.connect</a>,
-<a HREF="db.test.html">db.test</a>
-</em>
-<h2>AUTHOR</h2>
-Radim Blazek
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/display/d.barscale/d.barscale.html (from rev 32770, grass/trunk/display/d.barscale/description.html)
--- grass/trunk/display/d.barscale/d.barscale.html (rev 0)
+++ grass/trunk/display/d.barscale/d.barscale.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,33 @@
+<H2>DESCRIPTION</H2>
+<EM>d.barscale</EM> displays a barscale on the graphics monitor using either
+the mouse or given screen coordinates. It can draw the scale in a couple of
+styles or simply draw a north arrow.
+<h2>NOTE</h2>
+<EM>d.barscale</EM> will not work in Lat/Lon locations as the horizontal
+scale distance changes with latitude. Try <EM>d.grid</EM> instead.
+<p>The -l flag will always draw a north arrow <em>and</em> a line scale
+together; it is currently not possible to draw a line scale without a north
+arrow. Instead, the -s flag can be used to draw a barscale only.</p>
+<H2>SEE ALSO</H2>
+<EM>
+<A HREF="d.graph.html">d.graph</A><br>
+<A HREF="d.grid.html">d.grid</A><br>
+<A HREF="d.legend.html">d.legend</A><br>
+<A HREF="d.measure.html">d.measure</A><br>
+<A HREF="d.where.html">d.where</A><br>
+<A HREF="g.region.html">g.region</A><br>
+</EM>
+<H2>AUTHOR</H2>
+unknown.
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/display/d.barscale/description.html
--- grass/trunk/display/d.barscale/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.barscale/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,33 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>d.barscale</EM> displays a barscale on the graphics monitor using either
-the mouse or given screen coordinates. It can draw the scale in a couple of
-styles or simply draw a north arrow.
-<h2>NOTE</h2>
-<EM>d.barscale</EM> will not work in Lat/Lon locations as the horizontal
-scale distance changes with latitude. Try <EM>d.grid</EM> instead.
-<p>The -l flag will always draw a north arrow <em>and</em> a line scale
-together; it is currently not possible to draw a line scale without a north
-arrow. Instead, the -s flag can be used to draw a barscale only.</p>
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="d.graph.html">d.graph</A><br>
-<A HREF="d.grid.html">d.grid</A><br>
-<A HREF="d.legend.html">d.legend</A><br>
-<A HREF="d.measure.html">d.measure</A><br>
-<A HREF="d.where.html">d.where</A><br>
-<A HREF="g.region.html">g.region</A><br>
-</EM>
-<H2>AUTHOR</H2>
-unknown.
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/display/d.colorlist/d.colorlist.html (from rev 32770, grass/trunk/display/d.colorlist/description.html)
--- grass/trunk/display/d.colorlist/d.colorlist.html (rev 0)
+++ grass/trunk/display/d.colorlist/d.colorlist.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,15 @@
+<EM>d.colorlist</EM> report the available color names.
+The list contains all available display colors with a configurable
+separator (default is comma).
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.colors.html">d.colors</A>
+<H2>AUTHOR</H2>
+Andreas Lange
Deleted: grass/trunk/display/d.colorlist/description.html
--- grass/trunk/display/d.colorlist/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.colorlist/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,15 +0,0 @@
-<EM>d.colorlist</EM> report the available color names.
-The list contains all available display colors with a configurable
-separator (default is comma).
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.colors.html">d.colors</A>
-<H2>AUTHOR</H2>
-Andreas Lange
Copied: grass/trunk/display/d.colors/d.colors.html (from rev 32770, grass/trunk/display/d.colors/description.html)
--- grass/trunk/display/d.colors/d.colors.html (rev 0)
+++ grass/trunk/display/d.colors/d.colors.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,205 @@
+A color table file associates specific colors with the categories of a
+raster map layer. The user can change these map category color assignments
+(i.e., change the map's color table) interactively, by first displaying the
+raster map to the graphics monitor and then running the program
+<EM>d.colors</EM>.
+<P>
+Any color changes made using <EM>d.colors</EM> will not immediately be
+shown on the graphics display; however, any color changes saved will
+still alter the map's color table and will appear next time the raster
+map layer is redisplayed (see <EM><A HREF="d.colortable.html">d.colortable</A></EM>).
+<P>
+The user must first display the relevant raster map layer to the
+active frame on the graphics monitor (e.g., using
+<EM><A HREF="d.rast.html">d.rast</A></EM>) before running
+<EM>d.colors</EM>. The user can then either enter the name of the
+raster map layer whose color table is to be changed on the command
+line (e.g., by typing: <tt>d.colors map=soils</tt>), or type
+<tt>d.colors</tt> without program arguments. If the user simply types
+<tt>d.colors</tt> without program arguments on the command line,
+<EM>d.colors</EM> will ask the user to enter the name of an existing
+raster map layer using the standard GRASS interface.
+<P>
+In either case, the user is then presented with the <EM>d.colors</EM>
+command menu, shown below.
+<!-- This menu is the same as the category and color
+changing portion of the <EM><A HREF="d.display.html">d.display</A></EM>
+menu. -->
+The <EM>d.colors</EM> commands are listed beneath the Category
+Pointer Movement, Color Modification, Replotting Screen, and Quitting
+sections below. Commands are invoked by typing in the single-key response
+shown to the left below. (Longer descriptions of these commands appear to
+the right.) Results from invoking these commands will be reflected in the
+Category and Category Number sections of the <EM>d.colors</EM> screen. On
+the <EM>d.colors</EM> screen menu, commands appear in the right half of the
+screen, and the current status of categories appears in the left half of the
+screen.
+<PRE>
+CATEGORIES
+ 0 No Data
+ 1 (Category 1 description)
+ 2 (Category 2 description)
+CATEGORY NUMBER:
+ RED 0 0%
+ GREEN 0 0%
+ BLUE 0 0%
+Shift Incr: 10 3%
+CATEGORY POINTER MOVEMENT
+ D/d down (cats) Move pointer to next category
+ U/u up (cats) Move pointer to previous category
+COLOR MODIFICATIONS
+ R/r RED Increase/decrease RED intensity
+ G/g GREEN Increase/decrease GREEN intensity
+ B/b BLUE Increase/decrease BLUE intensity
+ I/i increment Increase/decrease increment
+ (of intensity shift)
+ h highlight Highlight current color
+ +/- shift colors Shift entire color table (up/down)
+ c save color Save color table
+ t toggle table Toggle to different color table
+REPLOTTING SCREEN
+ * Replot screen Replots the screen
+QUITTING
+ Q quit Quits program
+</PRE>
+Changing categories - The keys
+<B>"d, D, u,"</B>
+and
+<B>"U"</B>
+are used to move to a different category. The lower case letters move up,
+<B>u,</B>
+and down,
+<B>d,</B>
+the category list one category at a time. The upper case letters move 10
+categories at a time for fast movement. The cursor does wrap between the
+first and last categories. The current category is noted on the text screen
+with an arrow, and is indicated on the graphics screen by a box around the
+current color.
+<P>
+Changing colors - The color associated with the current category can be
+changed with the
+<B>"R, r, G, g, B,"</B>
+and
+<B>b</B>
+keys. The upper case letters increase the intensities of
+red
+<B>R,</B>
+green
+<B>G,</B>
+and blue
+<B>B</B>
+for the current category; the lower case letters decrease the intensities of
+these same colors for the current category. Video devices make all the
+colors of the spectrum by mixing red, green, and blue. For those
+accustomed to red, yellow, and blue being the primary colors, this can
+be confusing. For starters, yellow is made by mixing red and green. The
+intensities are listed on the text screen in as percentages.
+<P>
+Keys <B>I</B> and <B>i</B> increase and decrease the
+percentage change that each keystroke of one of the color
+keys (<EM>R, r, G, g, B, b</EM>) causes in its respective
+color. The increase increment is initially set to 10%.
+Thus, pressing the <EM>R</EM> key would will increase the
+red component of the current category by 10%.
+<P>
+Highlight - The
+<B>h</B>
+key toggles between the current category color and the current
+highlight color. This color is initially black but can be modified as
+above while in highlight mode. Blinking can be accomplished by repeatedly
+striking the
+<B>h</B>
+key. When changing to different categories using the movement keys as
+described above, while in highlight mode the category colors will be
+always left showing their actual colors. Only one category is highlighted
+at any one time.
+<P>
+Saving the current color table -
+Pressing the <B>c</B> key will save the current color table as you have
+modified it. This table will then be used next time you
+display or paint this raster map layer.
+<P>
+Color table toggle - Different types of color tables are suitable for
+different raster map layers.
+The key
+<B>t</B>
+flips between the following color tables: red, green, blue color ramp; gray
+scale; smooth changing color wave; random colors; and the saved color table.
+<P>
+Color table shift - The entire table is shifted up and down using the
+<B>+</B>
+and
+<B>-</B>
+keys.
+<P>
+Quitting the <EM>d.colors</EM> program - Pressing the
+<B>Q</B> key will cause you to quit the <EM>d.colors</EM>
+program. If colors have been modified but not saved,
+<EM>d.colors</EM> will ask:
+<PRE>
+ Colors changed
+ Save the changes? (y/n)
+</PRE>
+The user should type in <B>y</B> to save changes,
+or <B>n</B> to not save changes, before quitting the program.
+If the user types <B>n</B>, the program will ask:
+<PRE>
+ Quit anyway? (y/n)
+</PRE>
+<H2>NOTES</H2>
+<P>
+The map whose color table is to be altered with
+<EM>d.colors</EM> must already be on display in the active
+display frame on the graphics monitor before
+<EM>d.colors</EM> is run. This can be done using the
+command <em><A HREF="d.rast.html">d.rast</a> map=name</EM> (where <EM>name</EM> is a raster map
+layer whose color table the user wishes to alter).
+<P>
+Some color monitors may not support the full range of colors required
+to display all of the map's categories listed in the map's color table.
+However, regardless of whether the user can see the color changes he is
+effecting to a map's color table, any changes to a map's color table
+made with <EM>d.colors</EM> that are saved will appear in the map's color table.
+<H2>SEE ALSO</H2>
+<EM>
+<A HREF="d.colortable.html">d.colortable</A>,
+<A HREF="d.rast.html">d.rast</A>,
+<A HREF="r.colors.html">r.colors</A>
+</EM>
+<H2>AUTHOR</H2>
+James Westervelt, U.S. Army Construction Engineering
+Research Laboratory
+<p>
Deleted: grass/trunk/display/d.colors/description.html
--- grass/trunk/display/d.colors/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.colors/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,205 +0,0 @@
-A color table file associates specific colors with the categories of a
-raster map layer. The user can change these map category color assignments
-(i.e., change the map's color table) interactively, by first displaying the
-raster map to the graphics monitor and then running the program
-<EM>d.colors</EM>.
-<P>
-Any color changes made using <EM>d.colors</EM> will not immediately be
-shown on the graphics display; however, any color changes saved will
-still alter the map's color table and will appear next time the raster
-map layer is redisplayed (see <EM><A HREF="d.colortable.html">d.colortable</A></EM>).
-<P>
-The user must first display the relevant raster map layer to the
-active frame on the graphics monitor (e.g., using
-<EM><A HREF="d.rast.html">d.rast</A></EM>) before running
-<EM>d.colors</EM>. The user can then either enter the name of the
-raster map layer whose color table is to be changed on the command
-line (e.g., by typing: <tt>d.colors map=soils</tt>), or type
-<tt>d.colors</tt> without program arguments. If the user simply types
-<tt>d.colors</tt> without program arguments on the command line,
-<EM>d.colors</EM> will ask the user to enter the name of an existing
-raster map layer using the standard GRASS interface.
-<P>
-In either case, the user is then presented with the <EM>d.colors</EM>
-command menu, shown below.
-<!-- This menu is the same as the category and color
-changing portion of the <EM><A HREF="d.display.html">d.display</A></EM>
-menu. -->
-The <EM>d.colors</EM> commands are listed beneath the Category
-Pointer Movement, Color Modification, Replotting Screen, and Quitting
-sections below. Commands are invoked by typing in the single-key response
-shown to the left below. (Longer descriptions of these commands appear to
-the right.) Results from invoking these commands will be reflected in the
-Category and Category Number sections of the <EM>d.colors</EM> screen. On
-the <EM>d.colors</EM> screen menu, commands appear in the right half of the
-screen, and the current status of categories appears in the left half of the
-screen.
-<PRE>
-CATEGORIES
- 0 No Data
- 1 (Category 1 description)
- 2 (Category 2 description)
-CATEGORY NUMBER:
- RED 0 0%
- GREEN 0 0%
- BLUE 0 0%
-Shift Incr: 10 3%
-CATEGORY POINTER MOVEMENT
- D/d down (cats) Move pointer to next category
- U/u up (cats) Move pointer to previous category
-COLOR MODIFICATIONS
- R/r RED Increase/decrease RED intensity
- G/g GREEN Increase/decrease GREEN intensity
- B/b BLUE Increase/decrease BLUE intensity
- I/i increment Increase/decrease increment
- (of intensity shift)
- h highlight Highlight current color
- +/- shift colors Shift entire color table (up/down)
- c save color Save color table
- t toggle table Toggle to different color table
-REPLOTTING SCREEN
- * Replot screen Replots the screen
-QUITTING
- Q quit Quits program
-</PRE>
-Changing categories - The keys
-<B>"d, D, u,"</B>
-and
-<B>"U"</B>
-are used to move to a different category. The lower case letters move up,
-<B>u,</B>
-and down,
-<B>d,</B>
-the category list one category at a time. The upper case letters move 10
-categories at a time for fast movement. The cursor does wrap between the
-first and last categories. The current category is noted on the text screen
-with an arrow, and is indicated on the graphics screen by a box around the
-current color.
-<P>
-Changing colors - The color associated with the current category can be
-changed with the
-<B>"R, r, G, g, B,"</B>
-and
-<B>b</B>
-keys. The upper case letters increase the intensities of
-red
-<B>R,</B>
-green
-<B>G,</B>
-and blue
-<B>B</B>
-for the current category; the lower case letters decrease the intensities of
-these same colors for the current category. Video devices make all the
-colors of the spectrum by mixing red, green, and blue. For those
-accustomed to red, yellow, and blue being the primary colors, this can
-be confusing. For starters, yellow is made by mixing red and green. The
-intensities are listed on the text screen in as percentages.
-<P>
-Keys <B>I</B> and <B>i</B> increase and decrease the
-percentage change that each keystroke of one of the color
-keys (<EM>R, r, G, g, B, b</EM>) causes in its respective
-color. The increase increment is initially set to 10%.
-Thus, pressing the <EM>R</EM> key would will increase the
-red component of the current category by 10%.
-<P>
-Highlight - The
-<B>h</B>
-key toggles between the current category color and the current
-highlight color. This color is initially black but can be modified as
-above while in highlight mode. Blinking can be accomplished by repeatedly
-striking the
-<B>h</B>
-key. When changing to different categories using the movement keys as
-described above, while in highlight mode the category colors will be
-always left showing their actual colors. Only one category is highlighted
-at any one time.
-<P>
-Saving the current color table -
-Pressing the <B>c</B> key will save the current color table as you have
-modified it. This table will then be used next time you
-display or paint this raster map layer.
-<P>
-Color table toggle - Different types of color tables are suitable for
-different raster map layers.
-The key
-<B>t</B>
-flips between the following color tables: red, green, blue color ramp; gray
-scale; smooth changing color wave; random colors; and the saved color table.
-<P>
-Color table shift - The entire table is shifted up and down using the
-<B>+</B>
-and
-<B>-</B>
-keys.
-<P>
-Quitting the <EM>d.colors</EM> program - Pressing the
-<B>Q</B> key will cause you to quit the <EM>d.colors</EM>
-program. If colors have been modified but not saved,
-<EM>d.colors</EM> will ask:
-<PRE>
- Colors changed
- Save the changes? (y/n)
-</PRE>
-The user should type in <B>y</B> to save changes,
-or <B>n</B> to not save changes, before quitting the program.
-If the user types <B>n</B>, the program will ask:
-<PRE>
- Quit anyway? (y/n)
-</PRE>
-<H2>NOTES</H2>
-<P>
-The map whose color table is to be altered with
-<EM>d.colors</EM> must already be on display in the active
-display frame on the graphics monitor before
-<EM>d.colors</EM> is run. This can be done using the
-command <em><A HREF="d.rast.html">d.rast</a> map=name</EM> (where <EM>name</EM> is a raster map
-layer whose color table the user wishes to alter).
-<P>
-Some color monitors may not support the full range of colors required
-to display all of the map's categories listed in the map's color table.
-However, regardless of whether the user can see the color changes he is
-effecting to a map's color table, any changes to a map's color table
-made with <EM>d.colors</EM> that are saved will appear in the map's color table.
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="d.colortable.html">d.colortable</A>,
-<A HREF="d.rast.html">d.rast</A>,
-<A HREF="r.colors.html">r.colors</A>
-</EM>
-<H2>AUTHOR</H2>
-James Westervelt, U.S. Army Construction Engineering
-Research Laboratory
-<p>
Copied: grass/trunk/display/d.colortable/d.colortable.html (from rev 32770, grass/trunk/display/d.colortable/description.html)
--- grass/trunk/display/d.colortable/d.colortable.html (rev 0)
+++ grass/trunk/display/d.colortable/d.colortable.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,111 @@
+The GRASS program <EM>d.colortable</EM>
+is used to display the color table associated with a raster map layer in the
+active frame on the graphics monitor. The map <EM>name</EM> should be
+an available raster map layer in the user's current mapset search path
+and location.
+<P>
+<H3>Parameters:</H3>
+<DL>
+<DT><B>map=</B><EM>name</EM>
+<DD>Name of a raster map layer in the user's current mapset search path
+whose color table is to be displayed.
+<DT><B>color=</B><EM>name</EM>
+<DD>Color of the lines separating the colors of the color table.
+<BR>
+Options: red, orange, yellow, green, blue,
+indigo, violet, gray, white</B>, and black.
+<BR>
+Default: <EM>white</EM>
+<DT><B>lines=</B><EM>value</EM>
+<DD>Number of lines to appear in the color table.
+<BR>
+Options: 1 - 1000
+<DT><B>cols=</B><EM>value</EM>
+<DD>Number of columns to appear in the color table.
+<BR>
+Options: 1 - 1000
+If the <EM>value</B>s</EM> of both <EM>lines</EM> and <EM>cols</EM> are not specified by
+the user, <EM>d.colortable</EM>
+divides the active frame equally among the number of categories
+present in the named raster map layer. If one option is specified,
+the other is automatically set to accommodate all categories.
+If both are specified, as many categories as possible are displayed.
+</DL>
+<P>
+The user can specify all needed parameters on the command line using the
+form:
+<P>
+<DL>
+<DD>
+<B>d.colortable map=</B><EM>name</EM>
+[<B>color=</B><EM>name</EM>]
+[<B>lines=</B><EM>value</EM>]
+[<B>cols=</B><EM>value</EM>]
+</DL>
+<P>
+If the user specifies the name of a map on the command line but does not
+specify the values of other parameters, parameter default values will be used.
+Alternately, if the user types simply <B>d.colortable</B> on the command line
+without any program arguments, the program will prompt the user for parameter
+settings using the standard GRASS <A HREF="parser.html">parser</A> interface described in the manual
+entry for <EM><A HREF="parser.html">parser</A></B>.</EM>
+<H2>EXAMPLE</H2>
+The user running the command:
+<DL>
+<DD>
+<B>d.colortable map=</B><EM>soils</EM>
+[<B>color=</B><EM>red</EM>]
+[<B>lines=</B><EM>1</EM>]
+[<B>cols=</B><EM>3</EM>]
+</DL>
+would see the active graphics frame divided into three columns
+extending the full frame height. The lines dividing the color table
+associated with the <EM>soils</EM> map would be displayed in red.
+The user would see, at most, only three of the colors from the <EM>soils</EM>
+color table displayed in the active frame (because the user requested
+that this frame be divided into three sections).
+<H2>NOTES</H2>
+If the user wishes to display the entire color table associated with
+a map, the user should either stipulate a number of lines (rows) and
+columns (cols) sufficient to accommodate the number of categories
+in the map's color table, or fail to assign values to one or both of
+<EM>lines</EM> and/or <EM>cols</B>.</EM>
+If the user runs <EM>d.colortable</EM> using the default number of
+lines and columns (the full graphics frame), all categories from the
+map's color table will be displayed. However, if the user requests
+that the color table associated with a map which has 10 data categories
+be displayed in a graphics frame with only 3 lines (rows) and 2 columns
+(a total of six cells),
+only six of the ten map categories will be displayed.
+<P>
+The user should run the GRASS program
+<EM><A HREF="d.erase.html">d.erase</A></EM> between
+runs of <EM>d.colortable</EM> to avoid confusion.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.colors.html">d.colors</A></EM><br>
+<EM><A HREF="d.erase.html">d.erase</A></EM><br>
+<EM><A HREF="d.rast.html">d.rast</A></EM><br>
+<EM><A HREF="parser.html">parser</A></EM>
+<H2>AUTHOR</H2>
+James Westervelt, U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/display/d.colortable/description.html
--- grass/trunk/display/d.colortable/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.colortable/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,111 +0,0 @@
-The GRASS program <EM>d.colortable</EM>
-is used to display the color table associated with a raster map layer in the
-active frame on the graphics monitor. The map <EM>name</EM> should be
-an available raster map layer in the user's current mapset search path
-and location.
-<P>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>map=</B><EM>name</EM>
-<DD>Name of a raster map layer in the user's current mapset search path
-whose color table is to be displayed.
-<DT><B>color=</B><EM>name</EM>
-<DD>Color of the lines separating the colors of the color table.
-<BR>
-Options: red, orange, yellow, green, blue,
-indigo, violet, gray, white</B>, and black.
-<BR>
-Default: <EM>white</EM>
-<DT><B>lines=</B><EM>value</EM>
-<DD>Number of lines to appear in the color table.
-<BR>
-Options: 1 - 1000
-<DT><B>cols=</B><EM>value</EM>
-<DD>Number of columns to appear in the color table.
-<BR>
-Options: 1 - 1000
-If the <EM>value</B>s</EM> of both <EM>lines</EM> and <EM>cols</EM> are not specified by
-the user, <EM>d.colortable</EM>
-divides the active frame equally among the number of categories
-present in the named raster map layer. If one option is specified,
-the other is automatically set to accommodate all categories.
-If both are specified, as many categories as possible are displayed.
-</DL>
-<P>
-The user can specify all needed parameters on the command line using the
-form:
-<P>
-<DL>
-<DD>
-<B>d.colortable map=</B><EM>name</EM>
-[<B>color=</B><EM>name</EM>]
-[<B>lines=</B><EM>value</EM>]
-[<B>cols=</B><EM>value</EM>]
-</DL>
-<P>
-If the user specifies the name of a map on the command line but does not
-specify the values of other parameters, parameter default values will be used.
-Alternately, if the user types simply <B>d.colortable</B> on the command line
-without any program arguments, the program will prompt the user for parameter
-settings using the standard GRASS <A HREF="parser.html">parser</A> interface described in the manual
-entry for <EM><A HREF="parser.html">parser</A></B>.</EM>
-<H2>EXAMPLE</H2>
-The user running the command:
-<DL>
-<DD>
-<B>d.colortable map=</B><EM>soils</EM>
-[<B>color=</B><EM>red</EM>]
-[<B>lines=</B><EM>1</EM>]
-[<B>cols=</B><EM>3</EM>]
-</DL>
-would see the active graphics frame divided into three columns
-extending the full frame height. The lines dividing the color table
-associated with the <EM>soils</EM> map would be displayed in red.
-The user would see, at most, only three of the colors from the <EM>soils</EM>
-color table displayed in the active frame (because the user requested
-that this frame be divided into three sections).
-<H2>NOTES</H2>
-If the user wishes to display the entire color table associated with
-a map, the user should either stipulate a number of lines (rows) and
-columns (cols) sufficient to accommodate the number of categories
-in the map's color table, or fail to assign values to one or both of
-<EM>lines</EM> and/or <EM>cols</B>.</EM>
-If the user runs <EM>d.colortable</EM> using the default number of
-lines and columns (the full graphics frame), all categories from the
-map's color table will be displayed. However, if the user requests
-that the color table associated with a map which has 10 data categories
-be displayed in a graphics frame with only 3 lines (rows) and 2 columns
-(a total of six cells),
-only six of the ten map categories will be displayed.
-<P>
-The user should run the GRASS program
-<EM><A HREF="d.erase.html">d.erase</A></EM> between
-runs of <EM>d.colortable</EM> to avoid confusion.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.colors.html">d.colors</A></EM><br>
-<EM><A HREF="d.erase.html">d.erase</A></EM><br>
-<EM><A HREF="d.rast.html">d.rast</A></EM><br>
-<EM><A HREF="parser.html">parser</A></EM>
-<H2>AUTHOR</H2>
-James Westervelt, U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/display/d.erase/d.erase.html (from rev 32770, grass/trunk/display/d.erase/description.html)
--- grass/trunk/display/d.erase/d.erase.html (rev 0)
+++ grass/trunk/display/d.erase/d.erase.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,17 @@
+<em>d.erase</em> erases the contents of the active graphics frame, and replaces it with
+the color black (by default) or by whatever color is specified by the user.
+<em>d.erase</em> will not alter the assignment of the active frame.
+<h2>SEE ALSO</h2>
+<em><a HREF="d.mon.html">d.mon</a></em>
+<h2>AUTHOR</h2>
Deleted: grass/trunk/display/d.erase/description.html
--- grass/trunk/display/d.erase/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.erase/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,17 +0,0 @@
-<em>d.erase</em> erases the contents of the active graphics frame, and replaces it with
-the color black (by default) or by whatever color is specified by the user.
-<em>d.erase</em> will not alter the assignment of the active frame.
-<h2>SEE ALSO</h2>
-<em><a HREF="d.mon.html">d.mon</a></em>
-<h2>AUTHOR</h2>
Copied: grass/trunk/display/d.extract/d.extract.html (from rev 32770, grass/trunk/display/d.extract/description.html)
--- grass/trunk/display/d.extract/d.extract.html (rev 0)
+++ grass/trunk/display/d.extract/d.extract.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,25 @@
+<em>d.extract</em> allows a user to graphically select vector objects from
+an existing vector map and creates a new map containing only the selected
+objects.
+<h2>EXAMPLE</h2>
+<h3>Graphically extract roads from a roads map:</h3>
+d.mon x0
+d.vect roads
+d.extract input=roads output=interstate
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a HREF="v.extract.html">v.extract</a></em>
+<h2>AUTHOR</h2>
+Radim Blazek, Markus Neteler
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/display/d.extract/description.html
--- grass/trunk/display/d.extract/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.extract/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,25 +0,0 @@
-<em>d.extract</em> allows a user to graphically select vector objects from
-an existing vector map and creates a new map containing only the selected
-objects.
-<h2>EXAMPLE</h2>
-<h3>Graphically extract roads from a roads map:</h3>
-d.mon x0
-d.vect roads
-d.extract input=roads output=interstate
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a HREF="v.extract.html">v.extract</a></em>
-<h2>AUTHOR</h2>
-Radim Blazek, Markus Neteler
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/display/d.font/d.font.html (from rev 32770, grass/trunk/display/d.font/description.html)
--- grass/trunk/display/d.font/d.font.html (rev 0)
+++ grass/trunk/display/d.font/d.font.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,74 @@
+<EM>d.font</EM> allows the user to select use of a specific text font for
+display of text on the graphics monitor.
+The GRASS program
+<EM><A HREF="../html/show.fonts.sh.html">show.fonts.sh</A></EM>
+is a UNIX Bourne shell macro which
+names and displays the fonts that can be selected using <EM>d.font</EM>.
+If the user does not specify a font when using other GRASS programs
+that display text, the font type <EM>romans</EM> is used by default.
+<P>
+The user can run this program either non-interactively or interactively.
+If the user specifies a font type name on the command line the program will
+run non-interactively.
+Alternately, the user can simply type <B>d.font</B> on the command line;
+in this case, the program will prompt the user for a display
+text font type using the standard GRASS interface described in the
+manual entry for <EM><A HREF="parser.html">parser</A></EM>.
+<P>
+<B>Parameter:</B>
+<DL>
+<DT><B>font=</B><EM>name</EM>
+<DD>Name of a font type, from among the font types italicized below.
+<BR>
+Default: <EM>romans</EM>
+<BR>
+Options: (italized)
+<BR><EM>cyrilc</EM> Cyrillic
+<BR><EM>gothgbt</EM> Gothic Great Britain triplex
+<BR><EM>gothgrt</EM> Gothic German triplex
+<BR><EM>gothitt</EM> Gothic Italian triplex
+<BR><EM>greekc</EM> Greek complex
+<BR><EM>greekcs</EM> Greek complex script
+<BR><EM>greekp</EM> Greek plain
+<BR><EM>greeks</EM> Greek simplex
+<BR><EM>italicc</EM> Italian complex
+<BR><EM>italiccs</EM> Italian complex small
+<BR><EM>italict</EM> Italian triplex
+<BR><EM>romanc</EM> Roman complex
+<BR><EM>romancs</EM> Roman complex small
+<BR><EM>romand</EM> Roman duplex
+<BR><EM>romanp</EM> Roman plain
+<BR><EM>romans</EM> Roman simplex
+<BR><EM>romant</EM> Roman triplex
+<BR><EM>scriptc</EM> Script complex
+<BR><EM>scripts</EM> Script simplex
+</DL>
+<H2>NOTES</H2>
+The font type
+<EM>romans</EM>
+is the fastest font type to display to the graphics monitor.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.text.html">d.text</A></EM><br>
+<EM><A HREF="d.title.html">d.title</A></EM><br>
+<H2>AUTHOR</H2>
+<P>
+<EM>d.font</EM> uses the public domain version of the Hershey Fonts created
+by Dr. A.V. Hershey while working at the U.S. National Bureau of
+Standards.
Deleted: grass/trunk/display/d.font/description.html
--- grass/trunk/display/d.font/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.font/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,74 +0,0 @@
-<EM>d.font</EM> allows the user to select use of a specific text font for
-display of text on the graphics monitor.
-The GRASS program
-<EM><A HREF="../html/show.fonts.sh.html">show.fonts.sh</A></EM>
-is a UNIX Bourne shell macro which
-names and displays the fonts that can be selected using <EM>d.font</EM>.
-If the user does not specify a font when using other GRASS programs
-that display text, the font type <EM>romans</EM> is used by default.
-<P>
-The user can run this program either non-interactively or interactively.
-If the user specifies a font type name on the command line the program will
-run non-interactively.
-Alternately, the user can simply type <B>d.font</B> on the command line;
-in this case, the program will prompt the user for a display
-text font type using the standard GRASS interface described in the
-manual entry for <EM><A HREF="parser.html">parser</A></EM>.
-<P>
-<B>Parameter:</B>
-<DL>
-<DT><B>font=</B><EM>name</EM>
-<DD>Name of a font type, from among the font types italicized below.
-<BR>
-Default: <EM>romans</EM>
-<BR>
-Options: (italized)
-<BR><EM>cyrilc</EM> Cyrillic
-<BR><EM>gothgbt</EM> Gothic Great Britain triplex
-<BR><EM>gothgrt</EM> Gothic German triplex
-<BR><EM>gothitt</EM> Gothic Italian triplex
-<BR><EM>greekc</EM> Greek complex
-<BR><EM>greekcs</EM> Greek complex script
-<BR><EM>greekp</EM> Greek plain
-<BR><EM>greeks</EM> Greek simplex
-<BR><EM>italicc</EM> Italian complex
-<BR><EM>italiccs</EM> Italian complex small
-<BR><EM>italict</EM> Italian triplex
-<BR><EM>romanc</EM> Roman complex
-<BR><EM>romancs</EM> Roman complex small
-<BR><EM>romand</EM> Roman duplex
-<BR><EM>romanp</EM> Roman plain
-<BR><EM>romans</EM> Roman simplex
-<BR><EM>romant</EM> Roman triplex
-<BR><EM>scriptc</EM> Script complex
-<BR><EM>scripts</EM> Script simplex
-</DL>
-<H2>NOTES</H2>
-The font type
-<EM>romans</EM>
-is the fastest font type to display to the graphics monitor.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.text.html">d.text</A></EM><br>
-<EM><A HREF="d.title.html">d.title</A></EM><br>
-<H2>AUTHOR</H2>
-<P>
-<EM>d.font</EM> uses the public domain version of the Hershey Fonts created
-by Dr. A.V. Hershey while working at the U.S. National Bureau of
-Standards.
Copied: grass/trunk/display/d.fontlist/d.fontlist.html (from rev 32770, grass/trunk/display/d.fontlist/description.html)
--- grass/trunk/display/d.fontlist/d.fontlist.html (rev 0)
+++ grass/trunk/display/d.fontlist/d.fontlist.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,15 @@
+<EM>d.fontlist</EM> outputs a list of available fonts for use with
+GRASS display commands.
+<H2>SEE ALSO</H2>
+<H2>AUTHOR</H2>
+Glynn Clements
+<p><i>Last changed: $Date: 2008-06-28 00:01:20 +0100 (Sat, 28 Jun 2008) $</i>
Deleted: grass/trunk/display/d.fontlist/description.html
--- grass/trunk/display/d.fontlist/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.fontlist/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,15 +0,0 @@
-<EM>d.fontlist</EM> outputs a list of available fonts for use with
-GRASS display commands.
-<H2>SEE ALSO</H2>
-<H2>AUTHOR</H2>
-Glynn Clements
-<p><i>Last changed: $Date: 2008-06-28 00:01:20 +0100 (Sat, 28 Jun 2008) $</i>
Copied: grass/trunk/display/d.geodesic/d.geodesic.html (from rev 32770, grass/trunk/display/d.geodesic/description.html)
--- grass/trunk/display/d.geodesic/d.geodesic.html (rev 0)
+++ grass/trunk/display/d.geodesic/d.geodesic.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,42 @@
+<EM>d.geodesic</EM> displays a geodesic line in the active frame on the user's
+graphics monitor. This is also known as the great circle line and traces the
+shortest distance between two user-specified points on the curved surface of
+a longitude/latitude data set. The two coordinate locations named must fall
+within the boundaries of the user's current geographic region.
+<H2>OPTIONS</H2>
+This program can be run either interactively or non-interactively.
+If the user types <B>d.geodesic</B> on the command line and runs it without other program
+parameters, the mouse will be activated; the user is asked to use
+the mouse to indicate the starting and ending points of each geodesic line
+to be drawn. The default line color (black) and text color (red)
+will be used.
+<P>
+Alternately, the user can specify the starting and ending coordinates
+of the geodesic, line color, and text color on the command line,
+and run the program non-interactively.
+<P>
+Once the user indicates the starting and ending coordinates
+of the geodesic, the line and its length (in miles) are displayed to
+the user's graphics monitor. If the text color is set to <em>none</em>,
+the great circle distance is not displayed.
+<H2>NOTES</H2>
+This program works only with GRASS locations using a longitude/latitude
+coordinate system.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.rhumbline.html">d.rhumbline</A></EM>
+<H2>AUTHOR</H2>
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/display/d.geodesic/description.html
--- grass/trunk/display/d.geodesic/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.geodesic/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,42 +0,0 @@
-<EM>d.geodesic</EM> displays a geodesic line in the active frame on the user's
-graphics monitor. This is also known as the great circle line and traces the
-shortest distance between two user-specified points on the curved surface of
-a longitude/latitude data set. The two coordinate locations named must fall
-within the boundaries of the user's current geographic region.
-<H2>OPTIONS</H2>
-This program can be run either interactively or non-interactively.
-If the user types <B>d.geodesic</B> on the command line and runs it without other program
-parameters, the mouse will be activated; the user is asked to use
-the mouse to indicate the starting and ending points of each geodesic line
-to be drawn. The default line color (black) and text color (red)
-will be used.
-<P>
-Alternately, the user can specify the starting and ending coordinates
-of the geodesic, line color, and text color on the command line,
-and run the program non-interactively.
-<P>
-Once the user indicates the starting and ending coordinates
-of the geodesic, the line and its length (in miles) are displayed to
-the user's graphics monitor. If the text color is set to <em>none</em>,
-the great circle distance is not displayed.
-<H2>NOTES</H2>
-This program works only with GRASS locations using a longitude/latitude
-coordinate system.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.rhumbline.html">d.rhumbline</A></EM>
-<H2>AUTHOR</H2>
-Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/display/d.graph/d.graph.html (from rev 32770, grass/trunk/display/d.graph/description.html)
--- grass/trunk/display/d.graph/d.graph.html (rev 0)
+++ grass/trunk/display/d.graph/d.graph.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,246 @@
+<EM>d.graph</EM>
+draws graphics that are described either from standard input (default),
+or within a file (if an <b>input</b> file name is identified on the
+command line). If graphics commands are entered from standard input,
+a <EM>CTRL-d</EM> is used to signal the end of input to <EM>d.graph</EM>.
+Coordinates are given either as a percentage of frame height and width
+(default) or in geographic coordinates (with the <B>-m</B> flag).
+<P>
+The program can be run interactively or non-interactively.
+The user can run the program completely non-interactively
+by specifying the name of a graphics file containing the
+<EM>d.graph</EM> graphics commands. If run non-interactively the
+<EM>d.graph</EM> command is saved to the display's dedraw history.
+The user can also elect to run the program partially interactively,
+by specifying any/all of the parameters <EM>except</EM>
+the graphics file <B>input=</B><EM>name</EM> parameter on the command line.
+In this case, <EM>d.graph</EM> will expect the user to input <EM>d.graph</EM>
+graphics commands from standard input (i.e., the keyboard) and
+will (silently) prompt the user for these graphics commands.
+<P>
+Alternately, the user can simply type <B>d.graph</B> on the command line,
+and be prompted for the values of all parameters<!-- (the user can still
+input graphics commands from either an input file or standard input
+using this form)-->. In this case, the user is presented with the standard
+GRASS GUI interface.
+<P>
+The default coordinate system used is 0-100 percent of the active frame
+in x and similarly 0-100 in y,
+regardless of the graphics monitor display frame size and aspect.
+The (0,0) location is the lower left corner of the active graphics
+monitor display frame. All values may be floating point.
+If the <B>-m</B> flag is given, geographic coordinates will be used instead.
+<H2>COMMANDS</H2>
+<P>
+The graphics language is simple, and uses the following commands:
+<BR>
+<DD>[
+<a href="#comment">#</a> |
+<a href="#move">move</a> |
+<a href="#draw">draw</a> |
+<a href="#polygon">polygon</a> |
+<a href="#polyline">polyline</a> |
+<a href="#color">color</a> |
+<a href="#text">text</a> |
+<a href="#size">size</a> |
+<a href="#symbol">symbol</a> |
+<a href="#rotation">rotation</a> |
+<a href="#icon">icon</a> |
+<a href="#width">width</a>
+]</DD>
+<DL>
+<a name="comment"></a>
+<DT><B>#</B> <EM>comment</EM>
+<DD>A line of comment which is ignored in the processing.
+<a name="move"></a>
+<DT><B>move</B> <EM>xpos ypos</EM>
+<DD>The current location is updated to <EM>xpos ypos</EM>.
+Unless the <B>-m</B> flag is used,
+values are stated as a percent of the active display frame's
+horizontal (<EM>xpos</EM>) and vertical (<EM>ypos</EM>) size,
+and may be floating point values. Values are between 0-100.
+<B>Note.</B> A space must separate <EM>xpos</EM> and <EM>ypos</EM>.
+<a name="draw"></a>
+<DT><B>draw</B> <EM>xpos ypos</EM>
+<DD>A line is drawn in the current color from the current location to the new
+location <EM>xpos ypos</EM>, which then becomes the current location.
+<a name="polygon"></a>
+<DT><B>polygon</B>
+<BR> <EM> xpos ypos</EM>
+<BR> ...
+<DD>The coordinates appearing beneath the word <EM>polygon</EM>,
+one pair per line,
+circumscribe a polygon that is to be filled with the current color.
+<a name="polyline"></a>
+<DT><B>polyline</B>
+<BR> ...
+<DD>The coordinates appearing beneath the word <EM>polyline</EM>,
+one pair per line,
+circumscribe a polygon that is not to be filled with color.
+<a name="color"></a>
+<DT><B>color</B> <EM>color</EM>
+<DD>Sets the current color to that stated; subsequent graphics will be drawn
+in the stated color, until the current color is set to a different color.
+Options are <EM>red</EM>,
+<EM>orange</EM>,
+<EM>yellow</EM>,
+<EM>green</EM>,
+<EM>blue</EM>,
+<EM>indigo</EM>,
+<EM>violet</EM>,
+<EM>brown</EM>,
+<EM>magenta</EM>,
+<EM>gray</EM>,
+<EM>white</EM>,
+<EM>black</EM>,
+an R:G:B triplet (separated by colons),
+or the word "none" (draws in the default background color).
+<a name="text"></a>
+<DT><B>text</B> <EM>line-of-text</EM>
+<DD>The stated text is drawn at the current location using the current color,
+and the new current location is then positioned at the end of the text string.
+<a name="size"></a>
+<DT><B>size</B> <EM>xper yper</EM>
+<DD>Subsequent text will be drawn such that the text is
+<EM>xper</EM> percent of the graphics monitor display frame wide and
+<EM>yper</EM> percent of the frame high. By default, the text size is set to
+5 percent of the active frame's width and 5 percent of the frame's height.
+If only one value is given, then that value will be used for both x and y
+scaling.
+<BR>
+<B>Note.</B> A space must separate <EM>xper</EM> and <EM>yper</EM>.
+<a name="symbol"></a>
+<DT><B>symbol</B> <EM>type size xper yper [line_color [fill_color]]</EM>
+<DD>A symbol is drawn at the given size on the display monitor. The
+<EM>xper</EM> and <EM>yper</EM> options define the center of the icon and
+are given as a percentage of the display frame (<tt>0,0</tt> is lower left).
+The symbol can be any of those stored in <tt>$GISBASE/etc/symbol/</tt>
+(e.g. <i>basic/circle</i>) or stored in the user's mapset directory in the
+form <tt>$MAPSET/symbol/</tt><em>type/name</em>.
+The colors may be either a standard color name, an R:G:B triplet,
+or "none". If using an R:G:B triplet, each color value can range from 0-255.
+If not specified the default <EM>line_color</EM> is black and the default
+<EM>fill_color</EM> is grey.
+<a name="rotation"></a>
+<DT><B>rotation</B> <EM>angle</EM>
+<DD>Subsequent text and symbols will be drawn such that they are rotated
+<em>angle</em> degrees counter-clockwise from east.
+<a name="icon"></a>
+<DT><B>icon</B> <EM>type size x y</EM>
+<DD>Draws an icon of types <EM>o</EM>, <EM>x</EM>, or <EM>+</EM>
+with specified <EM>size</EM> (in %) at location <EM>x,y</EM>.
+Note: type <EM>o</EM> designates a square.
+<BR>
+<a name="width"></a>
+<DT><B>width</B> <EM>value</EM>
+<DD>Subsequent lines (including non-FreeType text) will be drawn with
+the given pixel thickness.
+<BR>The default value is 0.
+</DL>
+<H2>EXAMPLES</H2>
+For an example use of <EM>d.graph</EM>, examine the contents of the
+command file <EM><a href="grass_logo.txt">grass_logo.txt</a></EM>
+located in the <EM>d.graph</EM> source code directory. It will draw the
+CERL GRASS logo using the <EM>d.graph</EM> graphing commands stored in the file.
+Note that the coordinates in the <EM><a href="grass_logo.txt">grass_logo.txt</a></EM> file were
+taken directly off an image drawn by hand on graph paper.
+<!-- formerly names "grass.logo.sh" in GRASS 5 code. -->
+<P>
+A dynamic example can be found in the <em>d.polar</em> shell script.
+<h4>Draw a "star" symbol at a given map coordinate</h4>
+echo "symbol basic/star 20 2264417 5413182 black red" | d.graph -m
+</pre></div>
+<h4>Split the screen into quadrants:</h4>
+d.frame -s full_screen
+d.graph << EOF
+ color 80:80:120
+ polygon
+ 0 49.75
+ 0 50.25
+ 100 50.25
+ 100 49.75
+ polygon
+ 49.85 0
+ 50.15 0
+ 50.15 100
+ 49.85 100
+EOF
+</pre></div>
+<H2>NOTES</H2>
+<EM>d.graph</EM> remembers the last screen location (<EM>xpos ypos</EM>) to which
+the user moved, even after the user erases the display frame.
+If the user runs <EM>d.graph</EM> repeatedly, and wishes to start anew with
+the default (xpos ypos) screen location, the user should <EM>clear</EM> the
+display frame between runs of <EM>d.graph</EM>.
+<H2>LIMITATIONS</H2>
+There are no automated ways of generating graphic images. It is anticipated
+that GRASS user sites will write programs to convert output from a resident
+graphics editor into GRASS <EM>d.graph</EM> format.
+(e.g. EPS -> <em>d.graph</em>, perhaps with the help of a
+<a href="http://www.pstoedit.net/">pstoedit</a> plugin)
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.font.html">d.font</A></EM><br>
+<EM><A HREF="d.frame.html">d.frame</A></EM><br>
+<EM><A HREF="d.labels.html">d.labels</A></EM><br>
+<!-- <EM><A HREF="d.mapgraph.html">d.mapgraph</A></EM><br> superseded by -m -->
+<EM><A HREF="d.polar.html">d.polar</A></EM><br>
+<EM><A HREF="d.where.html">d.where</A></EM><br>
+<!-- <EM><A HREF="grass.logo.sh.html">grass.logo.sh</A></EM><br> -->
+<H2>AUTHOR</H2>
+<br><i>Last changed: $Date$</i>
Deleted: grass/trunk/display/d.graph/description.html
--- grass/trunk/display/d.graph/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.graph/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,246 +0,0 @@
-<EM>d.graph</EM>
-draws graphics that are described either from standard input (default),
-or within a file (if an <b>input</b> file name is identified on the
-command line). If graphics commands are entered from standard input,
-a <EM>CTRL-d</EM> is used to signal the end of input to <EM>d.graph</EM>.
-Coordinates are given either as a percentage of frame height and width
-(default) or in geographic coordinates (with the <B>-m</B> flag).
-<P>
-The program can be run interactively or non-interactively.
-The user can run the program completely non-interactively
-by specifying the name of a graphics file containing the
-<EM>d.graph</EM> graphics commands. If run non-interactively the
-<EM>d.graph</EM> command is saved to the display's dedraw history.
-The user can also elect to run the program partially interactively,
-by specifying any/all of the parameters <EM>except</EM>
-the graphics file <B>input=</B><EM>name</EM> parameter on the command line.
-In this case, <EM>d.graph</EM> will expect the user to input <EM>d.graph</EM>
-graphics commands from standard input (i.e., the keyboard) and
-will (silently) prompt the user for these graphics commands.
-<P>
-Alternately, the user can simply type <B>d.graph</B> on the command line,
-and be prompted for the values of all parameters<!-- (the user can still
-input graphics commands from either an input file or standard input
-using this form)-->. In this case, the user is presented with the standard
-GRASS GUI interface.
-<P>
-The default coordinate system used is 0-100 percent of the active frame
-in x and similarly 0-100 in y,
-regardless of the graphics monitor display frame size and aspect.
-The (0,0) location is the lower left corner of the active graphics
-monitor display frame. All values may be floating point.
-If the <B>-m</B> flag is given, geographic coordinates will be used instead.
-<H2>COMMANDS</H2>
-<P>
-The graphics language is simple, and uses the following commands:
-<BR>
-<DD>[
-<a href="#comment">#</a> |
-<a href="#move">move</a> |
-<a href="#draw">draw</a> |
-<a href="#polygon">polygon</a> |
-<a href="#polyline">polyline</a> |
-<a href="#color">color</a> |
-<a href="#text">text</a> |
-<a href="#size">size</a> |
-<a href="#symbol">symbol</a> |
-<a href="#rotation">rotation</a> |
-<a href="#icon">icon</a> |
-<a href="#width">width</a>
-]</DD>
-<DL>
-<a name="comment"></a>
-<DT><B>#</B> <EM>comment</EM>
-<DD>A line of comment which is ignored in the processing.
-<a name="move"></a>
-<DT><B>move</B> <EM>xpos ypos</EM>
-<DD>The current location is updated to <EM>xpos ypos</EM>.
-Unless the <B>-m</B> flag is used,
-values are stated as a percent of the active display frame's
-horizontal (<EM>xpos</EM>) and vertical (<EM>ypos</EM>) size,
-and may be floating point values. Values are between 0-100.
-<B>Note.</B> A space must separate <EM>xpos</EM> and <EM>ypos</EM>.
-<a name="draw"></a>
-<DT><B>draw</B> <EM>xpos ypos</EM>
-<DD>A line is drawn in the current color from the current location to the new
-location <EM>xpos ypos</EM>, which then becomes the current location.
-<a name="polygon"></a>
-<DT><B>polygon</B>
-<BR> <EM> xpos ypos</EM>
-<BR> ...
-<DD>The coordinates appearing beneath the word <EM>polygon</EM>,
-one pair per line,
-circumscribe a polygon that is to be filled with the current color.
-<a name="polyline"></a>
-<DT><B>polyline</B>
-<BR> ...
-<DD>The coordinates appearing beneath the word <EM>polyline</EM>,
-one pair per line,
-circumscribe a polygon that is not to be filled with color.
-<a name="color"></a>
-<DT><B>color</B> <EM>color</EM>
-<DD>Sets the current color to that stated; subsequent graphics will be drawn
-in the stated color, until the current color is set to a different color.
-Options are <EM>red</EM>,
-<EM>orange</EM>,
-<EM>yellow</EM>,
-<EM>green</EM>,
-<EM>blue</EM>,
-<EM>indigo</EM>,
-<EM>violet</EM>,
-<EM>brown</EM>,
-<EM>magenta</EM>,
-<EM>gray</EM>,
-<EM>white</EM>,
-<EM>black</EM>,
-an R:G:B triplet (separated by colons),
-or the word "none" (draws in the default background color).
-<a name="text"></a>
-<DT><B>text</B> <EM>line-of-text</EM>
-<DD>The stated text is drawn at the current location using the current color,
-and the new current location is then positioned at the end of the text string.
-<a name="size"></a>
-<DT><B>size</B> <EM>xper yper</EM>
-<DD>Subsequent text will be drawn such that the text is
-<EM>xper</EM> percent of the graphics monitor display frame wide and
-<EM>yper</EM> percent of the frame high. By default, the text size is set to
-5 percent of the active frame's width and 5 percent of the frame's height.
-If only one value is given, then that value will be used for both x and y
-scaling.
-<BR>
-<B>Note.</B> A space must separate <EM>xper</EM> and <EM>yper</EM>.
-<a name="symbol"></a>
-<DT><B>symbol</B> <EM>type size xper yper [line_color [fill_color]]</EM>
-<DD>A symbol is drawn at the given size on the display monitor. The
-<EM>xper</EM> and <EM>yper</EM> options define the center of the icon and
-are given as a percentage of the display frame (<tt>0,0</tt> is lower left).
-The symbol can be any of those stored in <tt>$GISBASE/etc/symbol/</tt>
-(e.g. <i>basic/circle</i>) or stored in the user's mapset directory in the
-form <tt>$MAPSET/symbol/</tt><em>type/name</em>.
-The colors may be either a standard color name, an R:G:B triplet,
-or "none". If using an R:G:B triplet, each color value can range from 0-255.
-If not specified the default <EM>line_color</EM> is black and the default
-<EM>fill_color</EM> is grey.
-<a name="rotation"></a>
-<DT><B>rotation</B> <EM>angle</EM>
-<DD>Subsequent text and symbols will be drawn such that they are rotated
-<em>angle</em> degrees counter-clockwise from east.
-<a name="icon"></a>
-<DT><B>icon</B> <EM>type size x y</EM>
-<DD>Draws an icon of types <EM>o</EM>, <EM>x</EM>, or <EM>+</EM>
-with specified <EM>size</EM> (in %) at location <EM>x,y</EM>.
-Note: type <EM>o</EM> designates a square.
-<BR>
-<a name="width"></a>
-<DT><B>width</B> <EM>value</EM>
-<DD>Subsequent lines (including non-FreeType text) will be drawn with
-the given pixel thickness.
-<BR>The default value is 0.
-</DL>
-<H2>EXAMPLES</H2>
-For an example use of <EM>d.graph</EM>, examine the contents of the
-command file <EM><a href="grass_logo.txt">grass_logo.txt</a></EM>
-located in the <EM>d.graph</EM> source code directory. It will draw the
-CERL GRASS logo using the <EM>d.graph</EM> graphing commands stored in the file.
-Note that the coordinates in the <EM><a href="grass_logo.txt">grass_logo.txt</a></EM> file were
-taken directly off an image drawn by hand on graph paper.
-<!-- formerly names "grass.logo.sh" in GRASS 5 code. -->
-<P>
-A dynamic example can be found in the <em>d.polar</em> shell script.
-<h4>Draw a "star" symbol at a given map coordinate</h4>
-echo "symbol basic/star 20 2264417 5413182 black red" | d.graph -m
-</pre></div>
-<h4>Split the screen into quadrants:</h4>
-d.frame -s full_screen
-d.graph << EOF
- color 80:80:120
- polygon
- 0 49.75
- 0 50.25
- 100 50.25
- 100 49.75
- polygon
- 49.85 0
- 50.15 0
- 50.15 100
- 49.85 100
-EOF
-</pre></div>
-<H2>NOTES</H2>
-<EM>d.graph</EM> remembers the last screen location (<EM>xpos ypos</EM>) to which
-the user moved, even after the user erases the display frame.
-If the user runs <EM>d.graph</EM> repeatedly, and wishes to start anew with
-the default (xpos ypos) screen location, the user should <EM>clear</EM> the
-display frame between runs of <EM>d.graph</EM>.
-<H2>LIMITATIONS</H2>
-There are no automated ways of generating graphic images. It is anticipated
-that GRASS user sites will write programs to convert output from a resident
-graphics editor into GRASS <EM>d.graph</EM> format.
-(e.g. EPS -> <em>d.graph</em>, perhaps with the help of a
-<a href="http://www.pstoedit.net/">pstoedit</a> plugin)
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.font.html">d.font</A></EM><br>
-<EM><A HREF="d.frame.html">d.frame</A></EM><br>
-<EM><A HREF="d.labels.html">d.labels</A></EM><br>
-<!-- <EM><A HREF="d.mapgraph.html">d.mapgraph</A></EM><br> superseded by -m -->
-<EM><A HREF="d.polar.html">d.polar</A></EM><br>
-<EM><A HREF="d.where.html">d.where</A></EM><br>
-<!-- <EM><A HREF="grass.logo.sh.html">grass.logo.sh</A></EM><br> -->
-<H2>AUTHOR</H2>
-<br><i>Last changed: $Date$</i>
Copied: grass/trunk/display/d.grid/d.grid.html (from rev 32770, grass/trunk/display/d.grid/description.html)
--- grass/trunk/display/d.grid/d.grid.html (rev 0)
+++ grass/trunk/display/d.grid/d.grid.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,87 @@
+<EM>d.grid</EM> overlays a grid of user-defined size and
+color in the active display frame on the graphics monitor.
+The grid can be created as a standard rectangular grid or
+a geographic grid. The grid will overlay, not overwrite,
+the contents of the active display frame.
+<P>
+<EM>d.grid</EM> can be run non-interactively or
+interactively. If the user specifies the grid
+<EM>size</EM> and (optionally) the grid <EM>color</EM> on
+the command line the program will run non-interactively; if
+no grid <EM>color</EM> is given the default will be used.
+Alternately, the user may simply type <B>d.grid</B> on the
+command line; in this case, the program will prompt the
+user for parameter values using the standard GRASS graphical
+user interface.
+<H2>NOTES</H2>
+<EM>d.grid</EM> will not erase grids already displayed in
+the active graphics display frame by previous invocations
+of <EM>d.grid</EM>; multiple invocations of <EM>d.grid</EM>
+will therefore result in the drawing of multiple grids
+inside the active graphics frame. (A command like
+<EM><A HREF="d.erase.html">d.erase</A></EM>, which erases the
+entire contents of the active display frame, must be run to
+erase previously drawn grids from the display frame.)
+<P>
+If the user provides a
+<EM>-g</EM> flag a geographic (projected) grid
+will be drawn. With the <EM>-g</EM> flag the <EM>size</EM>
+argument accepts both decimal degrees and colon separated
+ddd:mm:ss coordinates (eg. <tt>00:30:00</tt> for half of a degree).
+<p>
+A geographic grid cannot be drawn for a <EM>latitude/longitude</EM>
+or <EM>XY</EM> projection.
+<p>
+Colors may be standard named GRASS colors (red, green, aqua, etc.) or
+a numerical R:G:B triplet, where component values range from 0-255.<BR>
+<p>
+The grid drawing may be turned off by using the <em>-n</em> flag.<BR>
+The border drawing may be turned off by using the <em>-b</em> flag.<BR>
+The coordinate text may be turned off by using the <em>-t</em> flag.<BR>
+<H2>EXAMPLES</H2>
+To draw a red geographic grid with 30 minute grid spacing run
+either of the following:
+<PRE>
+ d.grid -g size=00:30:00 color=red
+</PRE>
+or
+<PRE>
+ d.grid -g size=0.5 color=255:0:0
+</PRE>
+To draw a blue standard rectangular grid at a 500 (meter) spacing run the following:
+<PRE>
+ d.grid size=500 color=blue
+</PRE>
+<BR>
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.barscale.html">d.barscale</A></EM><br>
+<EM><A HREF="d.legend.html">d.legend</A></EM><br>
+<EM><A HREF="d.geodesic.html">d.geodesic</A></EM><br>
+<EM><A HREF="d.rhumbline.html">d.rhumbline</A></EM><br>
+<H2>AUTHORS</H2>
+James Westervelt, U.S. Army Construction Engineering Research Laboratory<BR>
+Geogrid support: Bob Covill<BR>
+Border support: Markus Neteler<BR>
+Text and RGB support: Hamish Bowman<BR>
Deleted: grass/trunk/display/d.grid/description.html
--- grass/trunk/display/d.grid/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.grid/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,87 +0,0 @@
-<EM>d.grid</EM> overlays a grid of user-defined size and
-color in the active display frame on the graphics monitor.
-The grid can be created as a standard rectangular grid or
-a geographic grid. The grid will overlay, not overwrite,
-the contents of the active display frame.
-<P>
-<EM>d.grid</EM> can be run non-interactively or
-interactively. If the user specifies the grid
-<EM>size</EM> and (optionally) the grid <EM>color</EM> on
-the command line the program will run non-interactively; if
-no grid <EM>color</EM> is given the default will be used.
-Alternately, the user may simply type <B>d.grid</B> on the
-command line; in this case, the program will prompt the
-user for parameter values using the standard GRASS graphical
-user interface.
-<H2>NOTES</H2>
-<EM>d.grid</EM> will not erase grids already displayed in
-the active graphics display frame by previous invocations
-of <EM>d.grid</EM>; multiple invocations of <EM>d.grid</EM>
-will therefore result in the drawing of multiple grids
-inside the active graphics frame. (A command like
-<EM><A HREF="d.erase.html">d.erase</A></EM>, which erases the
-entire contents of the active display frame, must be run to
-erase previously drawn grids from the display frame.)
-<P>
-If the user provides a
-<EM>-g</EM> flag a geographic (projected) grid
-will be drawn. With the <EM>-g</EM> flag the <EM>size</EM>
-argument accepts both decimal degrees and colon separated
-ddd:mm:ss coordinates (eg. <tt>00:30:00</tt> for half of a degree).
-<p>
-A geographic grid cannot be drawn for a <EM>latitude/longitude</EM>
-or <EM>XY</EM> projection.
-<p>
-Colors may be standard named GRASS colors (red, green, aqua, etc.) or
-a numerical R:G:B triplet, where component values range from 0-255.<BR>
-<p>
-The grid drawing may be turned off by using the <em>-n</em> flag.<BR>
-The border drawing may be turned off by using the <em>-b</em> flag.<BR>
-The coordinate text may be turned off by using the <em>-t</em> flag.<BR>
-<H2>EXAMPLES</H2>
-To draw a red geographic grid with 30 minute grid spacing run
-either of the following:
-<PRE>
- d.grid -g size=00:30:00 color=red
-</PRE>
-or
-<PRE>
- d.grid -g size=0.5 color=255:0:0
-</PRE>
-To draw a blue standard rectangular grid at a 500 (meter) spacing run the following:
-<PRE>
- d.grid size=500 color=blue
-</PRE>
-<BR>
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.barscale.html">d.barscale</A></EM><br>
-<EM><A HREF="d.legend.html">d.legend</A></EM><br>
-<EM><A HREF="d.geodesic.html">d.geodesic</A></EM><br>
-<EM><A HREF="d.rhumbline.html">d.rhumbline</A></EM><br>
-<H2>AUTHORS</H2>
-James Westervelt, U.S. Army Construction Engineering Research Laboratory<BR>
-Geogrid support: Bob Covill<BR>
-Border support: Markus Neteler<BR>
-Text and RGB support: Hamish Bowman<BR>
Copied: grass/trunk/display/d.his/d.his.html (from rev 32770, grass/trunk/display/d.his/description.html)
--- grass/trunk/display/d.his/d.his.html (rev 0)
+++ grass/trunk/display/d.his/d.his.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,145 @@
+<H2>DESCRIPTION</H2>
+<EM>his</EM> stands for hue, intensity, and saturation.
+This program produces a raster map layer providing a
+visually pleasing combination of hue, intensity, and
+saturation values from two or three user-specified raster
+map layers.
+<P>
+The human brain automatically interprets the vast amount of
+visual information available according to basic rules.
+Color, or <EM>hue</EM>, is used to categorize objects.
+Shading, or <EM>intensity</EM>, is interpreted as
+three-dimensional texturing. Finally, the degree of
+haziness, or <EM>saturation</EM>, is associated with
+distance or depth. This program allows data from up to
+three raster map layers to be combined into an image which
+retains the original information in terms of <EM>hue</EM>,
+<EM>intensity</EM>, and <EM>saturation</EM>.
+<H2>OPTIONS</H2>
+This program can be run non-interactively or
+interactively. It will run non-interactively if the user
+specifies on the command line the name of a map containing
+hue values (<B>h_map</B>), and the name(s) of map(s)
+containing intensity values (<B>i_map</B>) and/or
+saturation values (<B>s_map</B>). The resulting image will
+be displayed in the active display frame on the graphics
+monitor.
+<P>
+Alternately, the user can run the program interactively by
+typing <B>d.his</B> without naming parameter values on the
+command line. In this case, the program will prompt the
+GUI interface.
+<P>
+While any raster map layer can be used to represent the hue
+information, map layers with a few very distinct colors
+work best. Only raster map layers representing
+continuously varying data like elevation, aspect, weights,
+intensities, or amounts can suitably be used to provide
+intensity and saturation information.
+<P>
+For example, a visually pleasing image can be
+made by using a watershed map for the <EM>hue</EM> factor,
+an aspect map for the <EM>intensity</EM> factor, and an
+elevation map for <EM>saturation</EM>. (The user may wish
+to leave out the elevation information for a first try.)
+Ideally, the resulting image should resemble the view from
+an aircraft looking at a terrain on a sunny day with a bit
+of haze in the valleys.
+<P>
+The <b>brighten</b> option does not truly represent a percentage,
+but calling it that makes the option easy to understand, and it
+sounds better than <i>Normalized Scaling Factor</i>.
+<H2>THE PROCESS</H2>
+Each map cell is processed individually. First, the working
+color is set to the color of the corresponding cell in the
+map layer chosen to represent <EM>HUE</EM>. Second, this
+color is multiplied by the <EM>red</EM> intensity of that
+cell in the <EM>INTENSITY</EM> map layer. This map layer
+should have an appropriate gray-scale color table
+associated with it. You can ensure this by using the color
+manipulation capabilities of
+<EM><A HREF="d.colors.html">d.colors</A></EM> or
+<EM><A HREF="r.colors.html">r.colors</A></EM>.
+Finally, the color is made somewhat gray-based on the
+<EM>red</EM> intensity of that cell in the
+<EM>SATURATION</EM> map layer. Again, this map layer
+should have a gray-scale color table associated with it.
+<H2>NOTES</H2>
+The name is misleading. The actual conversion used is
+<PRE>
+ <U>H</U>.i.s + <U>G</U>.(1-s)
+where
+ <U>H</U> is the R,G,B color from the hue map
+ i is the red value from the intensity map
+ s is the red value from the saturation map
+ <U>G</U> is 50% gray (R = G = B = 0.5)
+</PRE>
+<P>
+Either (but not both) of the intensity or the saturation
+map layers may be omitted. This means that it is possible
+to produce output images that represent combinations of
+<EM>his, hi,</EM> or <EM>hs</EM>.
+<P>
+Users wishing to store the result in new raster map layers
+instead of displaying it on the monitor should use the
+program <EM><A HREF="r.his.html">r.his</A></EM>.
+<H2>EXAMPLE</H2>
+<h4>Spearfish dataset</h4>
+<div class="code"><pre>
+ g.region rast=elevation.dem
+ r.shaded.relief map=elevation.dem shad=elev.shad_relf
+ d.mon x1
+ d.his h=elevation.dem i=elev.shad_relf brighten=50
+</pre></div>
+<BR>
+<H2>SEE ALSO</H2>
+<EM>
+<A HREF="d.colors.html">d.colors</A>,
+<A HREF="d.frame.html">d.frame</A>,
+<A HREF="d.rgb.html">d.rgb</A>,
+<A HREF="r.colors.html">r.colors</A>,
+<A HREF="r.his.html">r.his</A>,
+<A HREF="i.his.rgb.html">i.his.rgb</A>,
+<A HREF="i.rgb.his.html">i.rgb.his</A>,
+<A HREF="hsv.rgb.sh.html">hsv.rgb.sh</A>,
+<A HREF="rgb.hsv.sh.html">rgb.hsv.sh</A>
+</EM>
+<H2>AUTHOR</H2>
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/display/d.his/description.html
--- grass/trunk/display/d.his/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.his/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,145 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>his</EM> stands for hue, intensity, and saturation.
-This program produces a raster map layer providing a
-visually pleasing combination of hue, intensity, and
-saturation values from two or three user-specified raster
-map layers.
-<P>
-The human brain automatically interprets the vast amount of
-visual information available according to basic rules.
-Color, or <EM>hue</EM>, is used to categorize objects.
-Shading, or <EM>intensity</EM>, is interpreted as
-three-dimensional texturing. Finally, the degree of
-haziness, or <EM>saturation</EM>, is associated with
-distance or depth. This program allows data from up to
-three raster map layers to be combined into an image which
-retains the original information in terms of <EM>hue</EM>,
-<EM>intensity</EM>, and <EM>saturation</EM>.
-<H2>OPTIONS</H2>
-This program can be run non-interactively or
-interactively. It will run non-interactively if the user
-specifies on the command line the name of a map containing
-hue values (<B>h_map</B>), and the name(s) of map(s)
-containing intensity values (<B>i_map</B>) and/or
-saturation values (<B>s_map</B>). The resulting image will
-be displayed in the active display frame on the graphics
-monitor.
-<P>
-Alternately, the user can run the program interactively by
-typing <B>d.his</B> without naming parameter values on the
-command line. In this case, the program will prompt the
-GUI interface.
-<P>
-While any raster map layer can be used to represent the hue
-information, map layers with a few very distinct colors
-work best. Only raster map layers representing
-continuously varying data like elevation, aspect, weights,
-intensities, or amounts can suitably be used to provide
-intensity and saturation information.
-<P>
-For example, a visually pleasing image can be
-made by using a watershed map for the <EM>hue</EM> factor,
-an aspect map for the <EM>intensity</EM> factor, and an
-elevation map for <EM>saturation</EM>. (The user may wish
-to leave out the elevation information for a first try.)
-Ideally, the resulting image should resemble the view from
-an aircraft looking at a terrain on a sunny day with a bit
-of haze in the valleys.
-<P>
-The <b>brighten</b> option does not truly represent a percentage,
-but calling it that makes the option easy to understand, and it
-sounds better than <i>Normalized Scaling Factor</i>.
-<H2>THE PROCESS</H2>
-Each map cell is processed individually. First, the working
-color is set to the color of the corresponding cell in the
-map layer chosen to represent <EM>HUE</EM>. Second, this
-color is multiplied by the <EM>red</EM> intensity of that
-cell in the <EM>INTENSITY</EM> map layer. This map layer
-should have an appropriate gray-scale color table
-associated with it. You can ensure this by using the color
-manipulation capabilities of
-<EM><A HREF="d.colors.html">d.colors</A></EM> or
-<EM><A HREF="r.colors.html">r.colors</A></EM>.
-Finally, the color is made somewhat gray-based on the
-<EM>red</EM> intensity of that cell in the
-<EM>SATURATION</EM> map layer. Again, this map layer
-should have a gray-scale color table associated with it.
-<H2>NOTES</H2>
-The name is misleading. The actual conversion used is
-<PRE>
- <U>H</U>.i.s + <U>G</U>.(1-s)
-where
- <U>H</U> is the R,G,B color from the hue map
- i is the red value from the intensity map
- s is the red value from the saturation map
- <U>G</U> is 50% gray (R = G = B = 0.5)
-</PRE>
-<P>
-Either (but not both) of the intensity or the saturation
-map layers may be omitted. This means that it is possible
-to produce output images that represent combinations of
-<EM>his, hi,</EM> or <EM>hs</EM>.
-<P>
-Users wishing to store the result in new raster map layers
-instead of displaying it on the monitor should use the
-program <EM><A HREF="r.his.html">r.his</A></EM>.
-<H2>EXAMPLE</H2>
-<h4>Spearfish dataset</h4>
-<div class="code"><pre>
- g.region rast=elevation.dem
- r.shaded.relief map=elevation.dem shad=elev.shad_relf
- d.mon x1
- d.his h=elevation.dem i=elev.shad_relf brighten=50
-</pre></div>
-<BR>
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="d.colors.html">d.colors</A>,
-<A HREF="d.frame.html">d.frame</A>,
-<A HREF="d.rgb.html">d.rgb</A>,
-<A HREF="r.colors.html">r.colors</A>,
-<A HREF="r.his.html">r.his</A>,
-<A HREF="i.his.rgb.html">i.his.rgb</A>,
-<A HREF="i.rgb.his.html">i.rgb.his</A>,
-<A HREF="hsv.rgb.sh.html">hsv.rgb.sh</A>,
-<A HREF="rgb.hsv.sh.html">rgb.hsv.sh</A>
-</EM>
-<H2>AUTHOR</H2>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/display/d.histogram/d.histogram.html (from rev 32770, grass/trunk/display/d.histogram/description.html)
--- grass/trunk/display/d.histogram/d.histogram.html (rev 0)
+++ grass/trunk/display/d.histogram/d.histogram.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,40 @@
+<EM>d.histogram</EM> displays the category-value distribution for a
+user-specified raster map layer, in the form of a bar chart or a pie chart.
+The display will be displayed in the active display frame on the graphics
+monitor, using the colors in the raster map layer's color table. The
+program determines the raster map's category value distribution by counting
+cells.
+<H2>NOTES</H2>
+<EM>d.histogram</EM> respects the current geographic region settings
+and the current MASK (if one exists).
+<P>
+<EM>d.histogram</EM> uses the colors in the map's color look-up table
+(i.e., the map's <EM>colr</EM> or <EM>colr2</EM> file).
+<H2>SEE ALSO</H2>
+<em>
+<a href="d.colors.html">d.colors</a>,
+<a href="d.colortable.html">d.colortable</a>,
+<a href="d.frame.html">d.frame</a>,
+<a href="d.graph.html">d.graph</a>,
+<a href="d.linegraph.html">d.linegraph</a>,
+<a href="d.polar.html">d.polar</a>,
+<a href="g.region.html">g.region</a>,
+<a href="r.stats.html">r.stats</a>
+</em>
+<H2>AUTHOR</H2>
+Dave Johnson
+<BR> DBA Systems, Inc.
+<BR> 10560 Arrowhead Drive
+<BR> Fairfax, Virginia 22030
+<p>
Deleted: grass/trunk/display/d.histogram/description.html
--- grass/trunk/display/d.histogram/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.histogram/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,40 +0,0 @@
-<EM>d.histogram</EM> displays the category-value distribution for a
-user-specified raster map layer, in the form of a bar chart or a pie chart.
-The display will be displayed in the active display frame on the graphics
-monitor, using the colors in the raster map layer's color table. The
-program determines the raster map's category value distribution by counting
-cells.
-<H2>NOTES</H2>
-<EM>d.histogram</EM> respects the current geographic region settings
-and the current MASK (if one exists).
-<P>
-<EM>d.histogram</EM> uses the colors in the map's color look-up table
-(i.e., the map's <EM>colr</EM> or <EM>colr2</EM> file).
-<H2>SEE ALSO</H2>
-<em>
-<a href="d.colors.html">d.colors</a>,
-<a href="d.colortable.html">d.colortable</a>,
-<a href="d.frame.html">d.frame</a>,
-<a href="d.graph.html">d.graph</a>,
-<a href="d.linegraph.html">d.linegraph</a>,
-<a href="d.polar.html">d.polar</a>,
-<a href="g.region.html">g.region</a>,
-<a href="r.stats.html">r.stats</a>
-</em>
-<H2>AUTHOR</H2>
-Dave Johnson
-<BR> DBA Systems, Inc.
-<BR> 10560 Arrowhead Drive
-<BR> Fairfax, Virginia 22030
-<p>
Copied: grass/trunk/display/d.info/d.info.html (from rev 32770, grass/trunk/display/d.info/description.html)
--- grass/trunk/display/d.info/d.info.html (rev 0)
+++ grass/trunk/display/d.info/d.info.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,26 @@
+<h2>DESCRIPTION</h2>
+<em>d.info</em> displays information about the active display monitor.
+<H2>NOTES</H2>
+Units are screen pixels (except for <em>-g</em> flag where map units
+are used).<BR>
+Where two numbers are given the format is: width, height.<BR>
+Where four numbers are given the format is: left, right, top, bottom.
+<BR><BR>
+Note: GRASS display pixel coordinates are measured from the top left.
+<P>
+<BR>
+<h2>SEE ALSO</h2>
+<em><a HREF="d.frame.html">d.frame</a></em><br>
+<em><a HREF="d.vect.html">d.vect</a></em><br>
+<em><a HREF="d.rast.html">d.rast</a></em><br>
+<h2>AUTHOR</h2>
+Glynn Clements
Deleted: grass/trunk/display/d.info/description.html
--- grass/trunk/display/d.info/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.info/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,26 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>d.info</em> displays information about the active display monitor.
-<H2>NOTES</H2>
-Units are screen pixels (except for <em>-g</em> flag where map units
-are used).<BR>
-Where two numbers are given the format is: width, height.<BR>
-Where four numbers are given the format is: left, right, top, bottom.
-<BR><BR>
-Note: GRASS display pixel coordinates are measured from the top left.
-<P>
-<BR>
-<h2>SEE ALSO</h2>
-<em><a HREF="d.frame.html">d.frame</a></em><br>
-<em><a HREF="d.vect.html">d.vect</a></em><br>
-<em><a HREF="d.rast.html">d.rast</a></em><br>
-<h2>AUTHOR</h2>
-Glynn Clements
Copied: grass/trunk/display/d.labels/d.labels.html (from rev 32770, grass/trunk/display/d.labels/description.html)
--- grass/trunk/display/d.labels/d.labels.html (rev 0)
+++ grass/trunk/display/d.labels/d.labels.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,43 @@
+<EM>d.labels</EM> displays a <EM>paint</EM> label file in the
+active display frame on the graphics monitor. Each label has components
+which determine the text, the location of the text on the image, its
+size, and the background for the text. This file can be generated with
+the <EM><A HREF="v.label.html">v.label</A></EM> program or simply created
+by the user as an ASCII file (using a text editor) and placed in the
+appropriate directory under the user's current mapset and location
+(i.e. <tt>$MAPSET/paint/labels/</tt>).
+<H2>NOTES</H2>
+Some of the information stored in the label file is unused by
+<EM>d.labels</EM>.
+<!-- The unused information found in a label file is printed to standard
+output. -->
+This extra information is used by such programs as
+<EM><A HREF="ps.map.html">ps.map</A></EM>.
+<P>
+This module was formerly known as <em>d.paint.labels</em>.
+The the old version of <em>d.labels</em> from GRASS 5, which provided
+interactive placement and modification of paint labels, still needs to
+have its functionality merged into this module.
+<H2>SEE ALSO</H2>
+<EM><A HREF="ps.map.html">ps.map</A></EM><br>
+<EM><A HREF="v.label.html">v.label</A></EM>
+<BR>
+<H2>AUTHOR</H2>
+James Westervelt,
+U.S. Army Construction Engineering
+Research Laboratory
+<p>
Deleted: grass/trunk/display/d.labels/description.html
--- grass/trunk/display/d.labels/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.labels/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,43 +0,0 @@
-<EM>d.labels</EM> displays a <EM>paint</EM> label file in the
-active display frame on the graphics monitor. Each label has components
-which determine the text, the location of the text on the image, its
-size, and the background for the text. This file can be generated with
-the <EM><A HREF="v.label.html">v.label</A></EM> program or simply created
-by the user as an ASCII file (using a text editor) and placed in the
-appropriate directory under the user's current mapset and location
-(i.e. <tt>$MAPSET/paint/labels/</tt>).
-<H2>NOTES</H2>
-Some of the information stored in the label file is unused by
-<EM>d.labels</EM>.
-<!-- The unused information found in a label file is printed to standard
-output. -->
-This extra information is used by such programs as
-<EM><A HREF="ps.map.html">ps.map</A></EM>.
-<P>
-This module was formerly known as <em>d.paint.labels</em>.
-The the old version of <em>d.labels</em> from GRASS 5, which provided
-interactive placement and modification of paint labels, still needs to
-have its functionality merged into this module.
-<H2>SEE ALSO</H2>
-<EM><A HREF="ps.map.html">ps.map</A></EM><br>
-<EM><A HREF="v.label.html">v.label</A></EM>
-<BR>
-<H2>AUTHOR</H2>
-James Westervelt,
-U.S. Army Construction Engineering
-Research Laboratory
-<p>
Copied: grass/trunk/display/d.legend/d.legend.html (from rev 32770, grass/trunk/display/d.legend/description.html)
--- grass/trunk/display/d.legend/d.legend.html (rev 0)
+++ grass/trunk/display/d.legend/d.legend.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,117 @@
+<EM>d.legend</EM> displays a legend for a user-specified
+raster map layer in the active frame on the graphics
+monitor.
+<P>
+The user can run <EM>d.legend</EM> either non-interactively
+or interactively. If the user specifies the name of a
+raster <B>map</B> layer on the command line, the program
+will run non-interactively. Default legend text
+<B>color</B> and position will be used unless
+the user specifies other values on the command line.
+<P>
+Alternately, the user can simply type <B>d.legend</B> on the command line;
+in this case, the program will prompt the user for parameter values
+using the standard GRASS GUI interface.
+<H2>NOTES</H2>
+The legend's default size is based on the dimensions of the
+active frame, specifically its height. <EM>d.legend</EM> will only
+obscure those portions of the active frame that directly underlie the legend.
+<p>
+When using the mouse or <B>at</B> to size & place the legend, a user may
+create a horizontal legend by making the box wider than it is tall.
+<p>
+Raster maps based on floating point values will display smoothed, from greatest
+to smallest value, while categorial raster maps will display in order, from
+top to bottom. Horizontal legends will always be smoothed. If the box is defined
+with inverted y-values or an inverted <B>range</B>, the legend will automatically
+flip. If this is not the desired result, the <B>-f</B> flag may be used to flip
+it back.
+<p>
+If the user attempts to display a very long legend in a relatively short
+display frame, the legend may appear in unreadably small text, or even revert
+to a smooth gradient legend. Use the <B>lines</B>, <B>thin</B>, <B>use</B>, <B>range</B>,
+and/or <B>-n</B> options to reduce the number of categories to be displayed,
+or the <B>-s</B> flag to force a smooth gradient legend.
+<p>
+The <B>lines</B> option will display the first number of categories, as defined
+by <EM>value</EM>, contained in the raster map. When used with the <B>-n</B> flag,
+it takes on a new meaning: "up to category #". When used with both
+<B>thin</B> and the <B>-n</B> flag, its meaning becomes more obscure. When
+using <B>lines</B>, auto-scaled text similar to "4 of 16 categories" will be placed at
+the bottom of the legend.
+<p>
+The <B>thin</B> option sets the thinning factor. For raster maps with a 0th
+category, <B>thin=</B><EM>10</EM> gives cats [0,10,20,...]. For raster maps
+starting at category 1, <B>thin=</B><EM>10</EM> gives cats [1,11,21,...].
+<p>
+The <B>use</B> option lets the user create a legend made up of arbitrary category
+values. e.g. <B>use=</B><EM>1000,100,10,0,-10,-100,-1000</EM>
+<p>
+The <B>range</B> option lets the user define the minimum and maximum categories
+to be used in the legend. It may also be used to define the limits of a smooth
+gradient legend created from a raster containing floating point values. Note
+the color scale will remain faithful to the category values as defined with
+<EM><A HREF="r.colors.html">r.colors</A></EM>, and the <B>range</B> may be
+extended to the limits defined by the <EM><A HREF="r.colors.html">r.colors</A></EM>
+color map.
+<p>
+The flag <B>-n</B> is useful for categorial maps, as it suppresses the
+drawing of non-existing categories (otherwise the full range is shown).
+<p>
+Vertical legends produced with <EM>d.legend</EM> will place text labels to the
+right of the legend box, horizontal legends will place text below. This text
+will be auto-scaled to fit within the frame, reducing the size of the legend
+if necessary. Legends positioned with the mouse or with the <B>at</B> option
+will not auto-scale text, in order to provide more control to the user.
+Smaller text may be obtained in this case by reducing the
+height of the box. The <B>-c</B> and <B>-v</B> flags may be used to suppress the
+display of category numbers and labels respectively, or used together to
+suppress all text of categorial raster maps.
+<p>
+The text produced from floating-point raster maps will automatically create
+output with a meaningful number of significant digits. For very small values,
+numbers will be expressed in scientific notation, e.g. "1.7e-9".
+<p>
+Legends placed with the mouse are not saved to the display window's history
+for automatic redraw. By setting the Debug level to 1 (see
+<EM><A HREF="g.gisenv.html">g.gisenv</A></EM>) the corresponding <b>at</b>
+setting can be determined.
+<p>
+Note that old scripts which relied on setting <B>lines</B> greater than the
+number of categories to scale the legend may no longer produce the desired
+output, although the auto-scaling should still produce something that looks
+good in this case.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.barscale.html">d.barscale</A></EM><BR>
+<EM><A HREF="d.colors.html">d.colors</A></EM><BR>
+<EM><A HREF="d.colortable.html">d.colortable</A></EM><BR>
+<EM><A HREF="d.erase.html">d.erase</A></EM><BR>
+<EM><A HREF="d.font.html">d.font</A></EM><BR>
+<EM><A HREF="d.grid.html">d.grid</A></EM><BR>
+<EM><A HREF="d.rast.html">d.rast</A></EM><BR>
+<!-- <EM><A HREF="d.rast.labels.html">d.rast.labels</A></EM><BR> -->
+<EM><A HREF="d.rast.leg.html">d.rast.leg</A></EM><BR>
+<EM><A HREF="d.text.html">d.text</A></EM><BR>
+<EM><A HREF="d.vect.thematic.html">d.vect.thematic</A></EM><BR>
+<EM><A HREF="d.what.rast.html">d.what.rast</A></EM><BR>
+<EM><A HREF="g.gisenv.html">g.gisenv</A></EM><BR>
+<EM><A HREF="r.reclass.html">r.reclass</A></EM><BR>
+<H2>AUTHORS</H2>
+Bill Brown, U.S. Army Construction Engineering Research Laboratories
+<BR>Late 2002: Rewrite of much of the code. Hamish Bowman,
+ Otago University, New Zealand
+<BR>Additional improvements from various authors
Deleted: grass/trunk/display/d.legend/description.html
--- grass/trunk/display/d.legend/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.legend/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,117 +0,0 @@
-<EM>d.legend</EM> displays a legend for a user-specified
-raster map layer in the active frame on the graphics
-monitor.
-<P>
-The user can run <EM>d.legend</EM> either non-interactively
-or interactively. If the user specifies the name of a
-raster <B>map</B> layer on the command line, the program
-will run non-interactively. Default legend text
-<B>color</B> and position will be used unless
-the user specifies other values on the command line.
-<P>
-Alternately, the user can simply type <B>d.legend</B> on the command line;
-in this case, the program will prompt the user for parameter values
-using the standard GRASS GUI interface.
-<H2>NOTES</H2>
-The legend's default size is based on the dimensions of the
-active frame, specifically its height. <EM>d.legend</EM> will only
-obscure those portions of the active frame that directly underlie the legend.
-<p>
-When using the mouse or <B>at</B> to size & place the legend, a user may
-create a horizontal legend by making the box wider than it is tall.
-<p>
-Raster maps based on floating point values will display smoothed, from greatest
-to smallest value, while categorial raster maps will display in order, from
-top to bottom. Horizontal legends will always be smoothed. If the box is defined
-with inverted y-values or an inverted <B>range</B>, the legend will automatically
-flip. If this is not the desired result, the <B>-f</B> flag may be used to flip
-it back.
-<p>
-If the user attempts to display a very long legend in a relatively short
-display frame, the legend may appear in unreadably small text, or even revert
-to a smooth gradient legend. Use the <B>lines</B>, <B>thin</B>, <B>use</B>, <B>range</B>,
-and/or <B>-n</B> options to reduce the number of categories to be displayed,
-or the <B>-s</B> flag to force a smooth gradient legend.
-<p>
-The <B>lines</B> option will display the first number of categories, as defined
-by <EM>value</EM>, contained in the raster map. When used with the <B>-n</B> flag,
-it takes on a new meaning: "up to category #". When used with both
-<B>thin</B> and the <B>-n</B> flag, its meaning becomes more obscure. When
-using <B>lines</B>, auto-scaled text similar to "4 of 16 categories" will be placed at
-the bottom of the legend.
-<p>
-The <B>thin</B> option sets the thinning factor. For raster maps with a 0th
-category, <B>thin=</B><EM>10</EM> gives cats [0,10,20,...]. For raster maps
-starting at category 1, <B>thin=</B><EM>10</EM> gives cats [1,11,21,...].
-<p>
-The <B>use</B> option lets the user create a legend made up of arbitrary category
-values. e.g. <B>use=</B><EM>1000,100,10,0,-10,-100,-1000</EM>
-<p>
-The <B>range</B> option lets the user define the minimum and maximum categories
-to be used in the legend. It may also be used to define the limits of a smooth
-gradient legend created from a raster containing floating point values. Note
-the color scale will remain faithful to the category values as defined with
-<EM><A HREF="r.colors.html">r.colors</A></EM>, and the <B>range</B> may be
-extended to the limits defined by the <EM><A HREF="r.colors.html">r.colors</A></EM>
-color map.
-<p>
-The flag <B>-n</B> is useful for categorial maps, as it suppresses the
-drawing of non-existing categories (otherwise the full range is shown).
-<p>
-Vertical legends produced with <EM>d.legend</EM> will place text labels to the
-right of the legend box, horizontal legends will place text below. This text
-will be auto-scaled to fit within the frame, reducing the size of the legend
-if necessary. Legends positioned with the mouse or with the <B>at</B> option
-will not auto-scale text, in order to provide more control to the user.
-Smaller text may be obtained in this case by reducing the
-height of the box. The <B>-c</B> and <B>-v</B> flags may be used to suppress the
-display of category numbers and labels respectively, or used together to
-suppress all text of categorial raster maps.
-<p>
-The text produced from floating-point raster maps will automatically create
-output with a meaningful number of significant digits. For very small values,
-numbers will be expressed in scientific notation, e.g. "1.7e-9".
-<p>
-Legends placed with the mouse are not saved to the display window's history
-for automatic redraw. By setting the Debug level to 1 (see
-<EM><A HREF="g.gisenv.html">g.gisenv</A></EM>) the corresponding <b>at</b>
-setting can be determined.
-<p>
-Note that old scripts which relied on setting <B>lines</B> greater than the
-number of categories to scale the legend may no longer produce the desired
-output, although the auto-scaling should still produce something that looks
-good in this case.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.barscale.html">d.barscale</A></EM><BR>
-<EM><A HREF="d.colors.html">d.colors</A></EM><BR>
-<EM><A HREF="d.colortable.html">d.colortable</A></EM><BR>
-<EM><A HREF="d.erase.html">d.erase</A></EM><BR>
-<EM><A HREF="d.font.html">d.font</A></EM><BR>
-<EM><A HREF="d.grid.html">d.grid</A></EM><BR>
-<EM><A HREF="d.rast.html">d.rast</A></EM><BR>
-<!-- <EM><A HREF="d.rast.labels.html">d.rast.labels</A></EM><BR> -->
-<EM><A HREF="d.rast.leg.html">d.rast.leg</A></EM><BR>
-<EM><A HREF="d.text.html">d.text</A></EM><BR>
-<EM><A HREF="d.vect.thematic.html">d.vect.thematic</A></EM><BR>
-<EM><A HREF="d.what.rast.html">d.what.rast</A></EM><BR>
-<EM><A HREF="g.gisenv.html">g.gisenv</A></EM><BR>
-<EM><A HREF="r.reclass.html">r.reclass</A></EM><BR>
-<H2>AUTHORS</H2>
-Bill Brown, U.S. Army Construction Engineering Research Laboratories
-<BR>Late 2002: Rewrite of much of the code. Hamish Bowman,
- Otago University, New Zealand
-<BR>Additional improvements from various authors
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/display/d.linegraph/d.linegraph.html (from rev 32770, grass/trunk/display/d.linegraph/description.html)
--- grass/trunk/display/d.linegraph/d.linegraph.html (rev 0)
+++ grass/trunk/display/d.linegraph/d.linegraph.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,95 @@
+<EM>d.linegraph</EM> is a primitive program to draw simple x,y line graphs
+based on numerical data contained in separate files.
+<P>
+Data file format<BR>
+The X and Y data files for the graph are essentially a column of numbers in
+each file, with one input number per line. The program expects that each X
+value will have a corresponding Y value, therefore the number of lines in
+each data input file should be the same. Essentially, the X data becomes
+the X axis reference to which the Y data is plotted as a line. Therefore,
+the X data should be a monotonically increasing progression of numbers (i.e.
+"1,2,3,..."; "0, 10, 100, 1000,..."; "...-5,-1,0,1,5..."). If multiple Y
+data files are used, the Y axis scale will be based on the range of minimum
+and maximum values from all Y files, then all Y data given will be graphed
+according to that Y scale. Therefore, if multiple Y data inputs are used
+with dissimilar units, the graph produced comparing the two will be
+deceptive.
+<P>
+<DL>
+<DT><B>directoryname</B>
+<DD>Path to the directory where the input files are located. If this option
+is not used, the <EM>d.linegraph</EM> looks for files in the current directory.
+<DD>Example format: directory/usr/grass/data/graph
+<DT><B>ycoloroption[,option,...]]</B>
+<DD>Color to be used for drawing the lines in the graph. If multiple Y data
+files are used, an equal number of colors may be used to control the colors
+of the lines. Colors will be assigned to Y data in respect to the sequence
+of instantiation on the command line. Options are listed below. By
+default, a series of colors will be chosen by the program if none are
+provided upon invocation.
+<DD>Order of default colors: yellow, red, green, violet, blue, orange, gray,
+brown, magenta, white, indigo).
+<DT><B>titlecoloroption</B>
+<DD>The color to be used for titles, axis lines, tics, and scale numbers.
+<DD>Default: "white"
+<DD>Color options: red, orange, yellow, green, blue, indigo, violet,
+magenta, brown, gray, white, and black.
+<DT><B>xtitlevalue</B>
+<DD>Title to describe X data. Will be centered beneath the graph. Default
+is no title unless the need for a unit descriptor is computed by the program
+(i.e. X: title in hundreds). Also, see NOTES section (below) for a format
+caveat for multi-word titles.
+<DT><B>ytitlevalue</B>
+<DD>Title to describe Y data. Will be centered beneath the X data title.
+Default is no title unless the need for a unit descriptor is computed by
+the program (i.e. Y: ttiittllee in thousands). Also, see NOTES section
+(below) for a format caveat for multi-word titles. In the case of graphs
+with multiple lines, one may wish to use more specific title placement by
+using the <EM>d.text</EM> or <EM>v.label</EM> programs.
+<DT><B>titlevalue</B>
+<DD>Title to describe the graph. Will be centered over the top of graph.
+Default is no title. See NOTES section (below) for a format caveat for
+multi-word titles.
+</DL>
+<H2>NOTES</H2>
+Since the command line parser is not amiable to multiple word inputs, to
+input titles of more than one word, use the underscore character ("") to
+represent spaces (" ").
+<P>
+Example: "titleCensusdata1990" would be printed over the graph as "Census
+data 1990".
+<P>
+The way the program locates and labels tic marks is less than perfect: 1)
+although distances between Y tics is proportional to the value, they are
+not proportional on the X axis; 2) decimal values between -1 and 1 can be
+printed on the X axis, but not on Y. (With respect to the later, the input
+for Y values can all be multiplied by a factor of 10 before graphing).
+<P>
+It might be easier to use a 3rd party tool such as xgraph or GNUplot instead
+of <em>d.linegraph</em>.
+(You can make GNUplot output pretty by using its SVG or PostScript output
+driver and converting that back into a rasterized image in a paint program)
+<H2>SEE ALSO</H2>
+<EM>
+<A HREF="d.text.html">d.text</A>,
+<A HREF="v.label.html">v.label</A>
+</EM>
+<H2>AUTHOR</H2>
+Chris Rewerts, Agricultural Engineering, Purdue University
+<p>
Deleted: grass/trunk/display/d.linegraph/description.html
--- grass/trunk/display/d.linegraph/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.linegraph/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,95 +0,0 @@
-<EM>d.linegraph</EM> is a primitive program to draw simple x,y line graphs
-based on numerical data contained in separate files.
-<P>
-Data file format<BR>
-The X and Y data files for the graph are essentially a column of numbers in
-each file, with one input number per line. The program expects that each X
-value will have a corresponding Y value, therefore the number of lines in
-each data input file should be the same. Essentially, the X data becomes
-the X axis reference to which the Y data is plotted as a line. Therefore,
-the X data should be a monotonically increasing progression of numbers (i.e.
-"1,2,3,..."; "0, 10, 100, 1000,..."; "...-5,-1,0,1,5..."). If multiple Y
-data files are used, the Y axis scale will be based on the range of minimum
-and maximum values from all Y files, then all Y data given will be graphed
-according to that Y scale. Therefore, if multiple Y data inputs are used
-with dissimilar units, the graph produced comparing the two will be
-deceptive.
-<P>
-<DL>
-<DT><B>directoryname</B>
-<DD>Path to the directory where the input files are located. If this option
-is not used, the <EM>d.linegraph</EM> looks for files in the current directory.
-<DD>Example format: directory/usr/grass/data/graph
-<DT><B>ycoloroption[,option,...]]</B>
-<DD>Color to be used for drawing the lines in the graph. If multiple Y data
-files are used, an equal number of colors may be used to control the colors
-of the lines. Colors will be assigned to Y data in respect to the sequence
-of instantiation on the command line. Options are listed below. By
-default, a series of colors will be chosen by the program if none are
-provided upon invocation.
-<DD>Order of default colors: yellow, red, green, violet, blue, orange, gray,
-brown, magenta, white, indigo).
-<DT><B>titlecoloroption</B>
-<DD>The color to be used for titles, axis lines, tics, and scale numbers.
-<DD>Default: "white"
-<DD>Color options: red, orange, yellow, green, blue, indigo, violet,
-magenta, brown, gray, white, and black.
-<DT><B>xtitlevalue</B>
-<DD>Title to describe X data. Will be centered beneath the graph. Default
-is no title unless the need for a unit descriptor is computed by the program
-(i.e. X: title in hundreds). Also, see NOTES section (below) for a format
-caveat for multi-word titles.
-<DT><B>ytitlevalue</B>
-<DD>Title to describe Y data. Will be centered beneath the X data title.
-Default is no title unless the need for a unit descriptor is computed by
-the program (i.e. Y: ttiittllee in thousands). Also, see NOTES section
-(below) for a format caveat for multi-word titles. In the case of graphs
-with multiple lines, one may wish to use more specific title placement by
-using the <EM>d.text</EM> or <EM>v.label</EM> programs.
-<DT><B>titlevalue</B>
-<DD>Title to describe the graph. Will be centered over the top of graph.
-Default is no title. See NOTES section (below) for a format caveat for
-multi-word titles.
-</DL>
-<H2>NOTES</H2>
-Since the command line parser is not amiable to multiple word inputs, to
-input titles of more than one word, use the underscore character ("") to
-represent spaces (" ").
-<P>
-Example: "titleCensusdata1990" would be printed over the graph as "Census
-data 1990".
-<P>
-The way the program locates and labels tic marks is less than perfect: 1)
-although distances between Y tics is proportional to the value, they are
-not proportional on the X axis; 2) decimal values between -1 and 1 can be
-printed on the X axis, but not on Y. (With respect to the later, the input
-for Y values can all be multiplied by a factor of 10 before graphing).
-<P>
-It might be easier to use a 3rd party tool such as xgraph or GNUplot instead
-of <em>d.linegraph</em>.
-(You can make GNUplot output pretty by using its SVG or PostScript output
-driver and converting that back into a rasterized image in a paint program)
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="d.text.html">d.text</A>,
-<A HREF="v.label.html">v.label</A>
-</EM>
-<H2>AUTHOR</H2>
-Chris Rewerts, Agricultural Engineering, Purdue University
-<p>
Copied: grass/trunk/display/d.measure/d.measure.html (from rev 32770, grass/trunk/display/d.measure/description.html)
--- grass/trunk/display/d.measure/d.measure.html (rev 0)
+++ grass/trunk/display/d.measure/d.measure.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,62 @@
+<EM>d.measure</EM> provides the user with an interactive
+way to measure the lengths and areas of lines and polygons
+drawn by the user in the active frame on the graphics
+monitor. Lines and polygons are drawn using a pointing
+device (mouse). Each line segment is drawn in colors
+<b>c1</b> and <b>c2</b>. A mouse button menu indicates
+that the user can find out the geographic coordinates of
+the cursor location, draw line segments between
+user-specified vertices, and quit <EM>d.measure</EM>. Lines
+and polygons are defined by the series of vertices marked
+by the user. If more than two successive vertices are
+drawn, <EM>d.measure</EM> prints the area encompassed
+(<EM>d.measure</EM> will assume the area is closed even if
+the user has not joined the first and last vertices).
+<!-- (not [currently] true!) Line lengths are stated in the same units
+as those of the current LOCATION. In a XY-LOCATION, where no units are
+available, <EM>d.measure</EM> prints a warning and gives results without
+units. -->
+Areas can be stated in hectares, square miles, square meters and
+square kilometers.
+Lines and polygons drawn using <EM>d.measure</EM> will
+overlay (not overwrite) whatever display currently appears
+in the active frame on the graphics monitor. The user can,
+for example, run
+<EM><A HREF="d.rast.html">d.rast</A></EM> or
+<EM><A HREF="d.vect.html">d.vect</A></EM> prior to running
+<EM>d.measure</EM>, and use raster and/or vector maps as a backdrop.
+<H2>NOTES</H2>
+<EM>d.measure</EM> uses all segments drawn by the user when computing area.
+If the user draws an area within another area, the combined
+area of both regions will be output.
+<H2>TODO</H2>
+Output lengths in the same units as those of the current LOCATION as
+found in the <tt>PROJ_UNITS</tt> file (see <EM>g.proj</EM>).
+Volunteers are welcome for this task.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.graph.html">d.graph</A></EM><br>
+<EM><A HREF="d.rast.html">d.rast</A></EM><br>
+<EM><A HREF="d.vect.html">d.vect</A></EM><br>
+<EM><A HREF="g.proj.html">g.proj</A></EM>
+<H2>AUTHORS</H2>
+James Westervelt,
+<BR>
+Michael Shapiro, <BR>
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/display/d.measure/description.html
--- grass/trunk/display/d.measure/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.measure/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,62 +0,0 @@
-<EM>d.measure</EM> provides the user with an interactive
-way to measure the lengths and areas of lines and polygons
-drawn by the user in the active frame on the graphics
-monitor. Lines and polygons are drawn using a pointing
-device (mouse). Each line segment is drawn in colors
-<b>c1</b> and <b>c2</b>. A mouse button menu indicates
-that the user can find out the geographic coordinates of
-the cursor location, draw line segments between
-user-specified vertices, and quit <EM>d.measure</EM>. Lines
-and polygons are defined by the series of vertices marked
-by the user. If more than two successive vertices are
-drawn, <EM>d.measure</EM> prints the area encompassed
-(<EM>d.measure</EM> will assume the area is closed even if
-the user has not joined the first and last vertices).
-<!-- (not [currently] true!) Line lengths are stated in the same units
-as those of the current LOCATION. In a XY-LOCATION, where no units are
-available, <EM>d.measure</EM> prints a warning and gives results without
-units. -->
-Areas can be stated in hectares, square miles, square meters and
-square kilometers.
-Lines and polygons drawn using <EM>d.measure</EM> will
-overlay (not overwrite) whatever display currently appears
-in the active frame on the graphics monitor. The user can,
-for example, run
-<EM><A HREF="d.rast.html">d.rast</A></EM> or
-<EM><A HREF="d.vect.html">d.vect</A></EM> prior to running
-<EM>d.measure</EM>, and use raster and/or vector maps as a backdrop.
-<H2>NOTES</H2>
-<EM>d.measure</EM> uses all segments drawn by the user when computing area.
-If the user draws an area within another area, the combined
-area of both regions will be output.
-<H2>TODO</H2>
-Output lengths in the same units as those of the current LOCATION as
-found in the <tt>PROJ_UNITS</tt> file (see <EM>g.proj</EM>).
-Volunteers are welcome for this task.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.graph.html">d.graph</A></EM><br>
-<EM><A HREF="d.rast.html">d.rast</A></EM><br>
-<EM><A HREF="d.vect.html">d.vect</A></EM><br>
-<EM><A HREF="g.proj.html">g.proj</A></EM>
-<H2>AUTHORS</H2>
-James Westervelt,
-<BR>
-Michael Shapiro, <BR>
Copied: grass/trunk/display/d.nviz/d.nviz.html (from rev 32770, grass/trunk/display/d.nviz/description.html)
--- grass/trunk/display/d.nviz/d.nviz.html (rev 0)
+++ grass/trunk/display/d.nviz/d.nviz.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,144 @@
+The <EM>d.nviz</EM> program allows the user to easily create a script
+that can be run in NVIZ to fly through a terrain.
+The NVIZ flight path can be chosen interactively from the GRASS
+monitor (<EM>-i</EM>) or supplied on the command line as comma
+separated coordinates. The program optionally allows a KeyFrame
+file to created (after running the script). This KeyFrame file can
+be loaded into the <EM>Keyframe Animation</EM> panel for fine
+tuning or editing.
+<p>
+The script generated by <EM>d.nviz</EM> can be run from the NVIZ
+command line (nviz script=script_name) or after NVIZ is started by
+selecting <EM>Scripting->Play Script</EM>.
+<H2>OPTIONS</H2>
+<H3>Flags:</H3>
+<DL>
+<DT><B>-i</B>
+<DD>Intercative mode
+<DD>The user selects the camera path from the GRASS monitor by
+ clicking the left mouse button along the route. Click the
+ right mouse button to finish.
+<DT><B>-f</B>
+<DD>Full render
+<DD>The script will draw all loaded NVIZ data and save scene to PPM image.
+<DT><B>-c</B>
+<DD>Flay at constant elevation
+<DD>With this flag the camera will be set to an elevation given by the
+ <EM>ht=</EM> parameter. The default is to fly at <EM>ht=</EM>
+ above the topography (i.e. camera height = elevation + ht)
+<DT><B>-k</B>
+<DD>Output KeyFrame file
+<DD>Generate a KeyFrame file that can be loaded from the NVIZ
+ <EM>Keyframe Animation</EM> panel. The KeyFrame file is
+ automatically assigned the script name with a
+ <EM>.kanimator</EM> extension.
+<DT><B>-o</B>
+<DD>Render the animation in an off-screen context
+<DT><B>-e</B>
+<DD>Enable vector and sites drawing
+</DL>
+<H3>Parameters:</H3>
+<DL>
+<DT><B>input</B>
+<DD>The name of the GRASS raster map with elevation data.
+<DD>This should be the same file that will be loaded in NVIZ.
+<DT><B>output</B>
+<DD>The name of the NVIZ script to create.
+<DT><B>name</B>
+<DD>The prefix for output images if running in full render mode (<EM>-f</EM>).
+<DD>The defulat preifix is NVIZ (eg. NVIZ0000.ppm).
+<DT><B>dist</B>
+<DD>The distance of the camera behind the center of view.
+<DT><B>ht</B>
+<DD>The height of the camera above the center of view.
+<DD>If the the <EM>-c</EM> flag is set, the height represents the actual camera height.
+<DT><B>frames</B>
+<DD>The number of frames in the animation.
+<DT><B>start</B>
+<DD>The starting frame number (default = 0).
+<DD> This option may be useful in full render mode when creating an
+animation in sections. For example the user may wish to start at frame
+number 2000.
+<DT><B>route</B>
+<DD>The comma seperated geographic coordinates for keyframe locations.
+<DD>The interactive flag (<EM>-i</EM>) overrides this option.
+</DL>
+<H2>EXAMPLE</H2>
+To interactively create an NVIZ animation from raster elev.rast with
+500 frames and the camera set to 50 meters above and 250 meters behind
+the scene, run the following:
+d.nviz -ik input=elevation.dem output=nviz.script dist=2400 ht=1220 frames=1000
+</pre></div>
+In the above the example the user is prompted to select the route from the GRASS monitor.
+The output script, nviz.script, can then be run in NVIZ:
+nviz el=elevation.dem script=nviz.script
+</pre></div>
+<H2>NOTES / HINTS</H2>
+The user must select at least four key-frame locations (points)
+ otherwise an error is generated.
+<p>
+If the GRASS region is changed the <EM>d.nviz</EM> command must be re-run.
+<p>
+The current GRASS region and the user supplied paramters are included
+as a comment at the top of the output script. This information can be
+used to easily re-create the animation.
+<p>
+The camera position is calculated backwards from the supplied
+position(s). It is possible that the camera position will lie outside
+the current window, in which case a non-fatal error is generated
+(Error: selected point is outside region). This error can result in
+jerky movements during the animation. To correct this problem reduce
+the <EM>dist=</EM> parameter or increase the current region.
+<h3>Loading the script into NVIZ</h3>
+The user can run the script at arbitrary resolution. To re-run it at
+higher spatial resolution or different settings, the user first loads
+the surface and sets the resolution, lighting, etc. Then internally
+the script generated by <em>d.nviz</em> is run. Alternatively, the
+user can run nviz with a previuosly saved state and the
+<em>d.nviz</em> generated script:
+nviz state=saved.state script=nviz.script
+</pre></div>
+<h3>Keyframe animator script</h3>
+Running the script generated by d.nviz within NVIZ, a new script for
+kanimator (keyframe animator) is created. The kanimator panel offers
+fine tuning of the speed (frame rate) as well as editing individual
+frames or inserting new frames. This new kanimator script has to be
+loaded from the Kanimator panel in NVIZ. In the Kanimator panel there
+are Save and Load button which allow the user to save and re-load a
+kanimator script. Once loaded, the key frames will appear in the GUI
+and can then be edited there.
+<H2>SEE ALSO</H2>
+<EM><A HREF="nviz.html">nviz</A></EM>
+<H2>AUTHOR</H2>
+<A HREF=mailto:bcovill at tekmap.ns.ca>Bob Covill</A>
Deleted: grass/trunk/display/d.nviz/description.html
--- grass/trunk/display/d.nviz/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.nviz/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,144 +0,0 @@
-The <EM>d.nviz</EM> program allows the user to easily create a script
-that can be run in NVIZ to fly through a terrain.
-The NVIZ flight path can be chosen interactively from the GRASS
-monitor (<EM>-i</EM>) or supplied on the command line as comma
-separated coordinates. The program optionally allows a KeyFrame
-file to created (after running the script). This KeyFrame file can
-be loaded into the <EM>Keyframe Animation</EM> panel for fine
-tuning or editing.
-<p>
-The script generated by <EM>d.nviz</EM> can be run from the NVIZ
-command line (nviz script=script_name) or after NVIZ is started by
-selecting <EM>Scripting->Play Script</EM>.
-<H2>OPTIONS</H2>
-<H3>Flags:</H3>
-<DL>
-<DT><B>-i</B>
-<DD>Intercative mode
-<DD>The user selects the camera path from the GRASS monitor by
- clicking the left mouse button along the route. Click the
- right mouse button to finish.
-<DT><B>-f</B>
-<DD>Full render
-<DD>The script will draw all loaded NVIZ data and save scene to PPM image.
-<DT><B>-c</B>
-<DD>Flay at constant elevation
-<DD>With this flag the camera will be set to an elevation given by the
- <EM>ht=</EM> parameter. The default is to fly at <EM>ht=</EM>
- above the topography (i.e. camera height = elevation + ht)
-<DT><B>-k</B>
-<DD>Output KeyFrame file
-<DD>Generate a KeyFrame file that can be loaded from the NVIZ
- <EM>Keyframe Animation</EM> panel. The KeyFrame file is
- automatically assigned the script name with a
- <EM>.kanimator</EM> extension.
-<DT><B>-o</B>
-<DD>Render the animation in an off-screen context
-<DT><B>-e</B>
-<DD>Enable vector and sites drawing
-</DL>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>input</B>
-<DD>The name of the GRASS raster map with elevation data.
-<DD>This should be the same file that will be loaded in NVIZ.
-<DT><B>output</B>
-<DD>The name of the NVIZ script to create.
-<DT><B>name</B>
-<DD>The prefix for output images if running in full render mode (<EM>-f</EM>).
-<DD>The defulat preifix is NVIZ (eg. NVIZ0000.ppm).
-<DT><B>dist</B>
-<DD>The distance of the camera behind the center of view.
-<DT><B>ht</B>
-<DD>The height of the camera above the center of view.
-<DD>If the the <EM>-c</EM> flag is set, the height represents the actual camera height.
-<DT><B>frames</B>
-<DD>The number of frames in the animation.
-<DT><B>start</B>
-<DD>The starting frame number (default = 0).
-<DD> This option may be useful in full render mode when creating an
-animation in sections. For example the user may wish to start at frame
-number 2000.
-<DT><B>route</B>
-<DD>The comma seperated geographic coordinates for keyframe locations.
-<DD>The interactive flag (<EM>-i</EM>) overrides this option.
-</DL>
-<H2>EXAMPLE</H2>
-To interactively create an NVIZ animation from raster elev.rast with
-500 frames and the camera set to 50 meters above and 250 meters behind
-the scene, run the following:
-d.nviz -ik input=elevation.dem output=nviz.script dist=2400 ht=1220 frames=1000
-</pre></div>
-In the above the example the user is prompted to select the route from the GRASS monitor.
-The output script, nviz.script, can then be run in NVIZ:
-nviz el=elevation.dem script=nviz.script
-</pre></div>
-<H2>NOTES / HINTS</H2>
-The user must select at least four key-frame locations (points)
- otherwise an error is generated.
-<p>
-If the GRASS region is changed the <EM>d.nviz</EM> command must be re-run.
-<p>
-The current GRASS region and the user supplied paramters are included
-as a comment at the top of the output script. This information can be
-used to easily re-create the animation.
-<p>
-The camera position is calculated backwards from the supplied
-position(s). It is possible that the camera position will lie outside
-the current window, in which case a non-fatal error is generated
-(Error: selected point is outside region). This error can result in
-jerky movements during the animation. To correct this problem reduce
-the <EM>dist=</EM> parameter or increase the current region.
-<h3>Loading the script into NVIZ</h3>
-The user can run the script at arbitrary resolution. To re-run it at
-higher spatial resolution or different settings, the user first loads
-the surface and sets the resolution, lighting, etc. Then internally
-the script generated by <em>d.nviz</em> is run. Alternatively, the
-user can run nviz with a previuosly saved state and the
-<em>d.nviz</em> generated script:
-nviz state=saved.state script=nviz.script
-</pre></div>
-<h3>Keyframe animator script</h3>
-Running the script generated by d.nviz within NVIZ, a new script for
-kanimator (keyframe animator) is created. The kanimator panel offers
-fine tuning of the speed (frame rate) as well as editing individual
-frames or inserting new frames. This new kanimator script has to be
-loaded from the Kanimator panel in NVIZ. In the Kanimator panel there
-are Save and Load button which allow the user to save and re-load a
-kanimator script. Once loaded, the key frames will appear in the GUI
-and can then be edited there.
-<H2>SEE ALSO</H2>
-<EM><A HREF="nviz.html">nviz</A></EM>
-<H2>AUTHOR</H2>
-<A HREF=mailto:bcovill at tekmap.ns.ca>Bob Covill</A>
Copied: grass/trunk/display/d.path/d.path.html (from rev 32770, grass/trunk/display/d.path/description.html)
--- grass/trunk/display/d.path/d.path.html (rev 0)
+++ grass/trunk/display/d.path/d.path.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,43 @@
+<em>d.path</em> enables shortest path vector networking - based on DGLib
+(Directed Graph Library) vector network library
+(see <a href="http://grass.gdf-hannover.de/wiki/Vector_network_analysis">screenshot</a>).
+Costs may be either line lengths, or attributes saved in a database table.
+Supported are cost assignments for both arcs and nodes, and also different
+in both directions of a vector line. For areas cost will be calculated along
+boundary lines.
+<h2>NOTE</h2>
+The user needs to display a vector map before using d.path. The 'from' and 'to'
+points are entered by mouse into the map displayed in the GRASS monitor, or
+if the <b>coor</b> option is used they can be specified non-interactively.
+The actions bound to the mouse buttons are described in the terminal
+window when running the command.
+<P>
+To calculate shortest path non-interactively and save the path to a new vector
+map, use the <em>v.net.path</em> module.
+<h2>EXAMPLE</h2>
+# Spearfish
+d.vect roads
+d.path -b roads coor="601653.5,4922869.2","593330.8,4924096.6"
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a HREF="v.net.path.html">v.net.path</a>,
+<a HREF="http://grass.itc.it/dglib/">DGLib</a>
+</em>
+<h2>AUTHOR</h2>
+Radim Blazek, ITC-Irst, Trento, Italy
+<p>
Deleted: grass/trunk/display/d.path/description.html
--- grass/trunk/display/d.path/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.path/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,43 +0,0 @@
-<em>d.path</em> enables shortest path vector networking - based on DGLib
-(Directed Graph Library) vector network library
-(see <a href="http://grass.gdf-hannover.de/wiki/Vector_network_analysis">screenshot</a>).
-Costs may be either line lengths, or attributes saved in a database table.
-Supported are cost assignments for both arcs and nodes, and also different
-in both directions of a vector line. For areas cost will be calculated along
-boundary lines.
-<h2>NOTE</h2>
-The user needs to display a vector map before using d.path. The 'from' and 'to'
-points are entered by mouse into the map displayed in the GRASS monitor, or
-if the <b>coor</b> option is used they can be specified non-interactively.
-The actions bound to the mouse buttons are described in the terminal
-window when running the command.
-<P>
-To calculate shortest path non-interactively and save the path to a new vector
-map, use the <em>v.net.path</em> module.
-<h2>EXAMPLE</h2>
-# Spearfish
-d.vect roads
-d.path -b roads coor="601653.5,4922869.2","593330.8,4924096.6"
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a HREF="v.net.path.html">v.net.path</a>,
-<a HREF="http://grass.itc.it/dglib/">DGLib</a>
-</em>
-<h2>AUTHOR</h2>
-Radim Blazek, ITC-Irst, Trento, Italy
-<p>
Copied: grass/trunk/display/d.profile/d.profile.html (from rev 32770, grass/trunk/display/d.profile/description.html)
--- grass/trunk/display/d.profile/d.profile.html (rev 0)
+++ grass/trunk/display/d.profile/d.profile.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,194 @@
+This command works only interactively. It clears the entire
+graphics screen and provides a graphical interaction
+allowing the selection of transects for which profiles are
+then generated. Input parameters can be specified on the command line
+for quicker start-up.
+<H2>USER PROMPTS</H2>
+First, you will be presented with a prompt asking you to
+choose a raster map layer to be profiled. Then you will be
+prompted for an optional display raster. The optional display raster
+will be shown rather than the profiled raster. This is useful
+to be able to more easily see ground features, such as might be visible
+in an aerial photo or satellite image. Finally, you will
+be prompted for the name prefix for output file(s) containing the profile
+data. This is an optional feature.
+<P>
+After parameters are given, the raster layer will be
+displayed in the left half of the graphics monitor, and the
+right half will be divided into four
+frames. There will also be two frames along the top of the
+monitor: a mouse-button menu frame on the left, and a
+status frame on the right.
+<P>
+The mouse-button menu initially offers you three options:
+<DL>
+<DD>
+Mouse Buttons: <BR>
+Left: Where am I? <BR>
+Middle: Mark FIRST Point of Profile Line. <BR>
+Right: QUIT this. <BR>
+</DL>
+You may query the displayed raster map layer by indicating
+points with the left mouse-button. The coordinates and
+category value of each point that you indicate will be
+displayed on in the status frame. If you mark the first
+point of the profile line you will be presented with the
+following mouse-button menu:
+<DL>
+<DD>
+Middle: Mark SECOND Point of Profile Line. <BR>
+</DL>
+Once you mark the second point of the profile line, the
+profile line will be labeled (with a letter from A to D)
+and displayed in one of the four display frames on the
+right hand side of the screen. You will then be presented
+with a third mouse-button menu:
+<DL>
+<DD>
+Left: DO ANOTHER <BR>
+Middle: CLEAR DISPLAY <BR>
+</DL>
+If you would like to view another profile, click on the
+left mouse-button. If you would like to redisplay the
+raster map layer and clear out the four profile frames,
+click on the middle mouse-button. If you would like to
+quit, then click on the right button.
+<P>
+If you selected the <B>plotfile</B> option, you will have up to
+four files starting with the <EM>name</EM> and followed by a suffix
+of the plot letter <EM>A, B, C,</EM> or <EM>D</EM>. The plots that
+are written to these files reflect the last of each plot done with that
+letter (i.e. They will match what's in the display when you quit).
+<P>
+The format of the plot files is not geared toward any particular software,
+but should be easy to coax into a number of other programs. The first
+three lines contain some header information about the plot, each prefixed
+with a <TT>#</TT> sign to denote a comment. A fourth comment line describes
+the data that follows. It consists of the distance (always in meters),
+the cell value (in whatever units it is in), the easting in decimal format,
+and the northing in decimal format.
+The number of values will vary depending on the length of the profile, cell
+resolution and the slope angle of the profile line. Below is an example
+of a plotfile:
+<P>
+<TT>
+# Profile A of elev.ft at snows<BR>
+# From (702879.29679757, 4287317.55920185) to (702722.40973589, 4287061.72632285)<BR>
+# Stats: Count = 644, Min = 2424.658936, Max = 2513.246094<BR>
+# dist value east north<BR>
+0.000000 2513.246094 702879.102364 4287317.516912<BR>
+0.000000 2513.246094 702878.713496 4287317.118970<BR>
+0.556395 2513.246094 702878.324629 4287316.721029<BR>
+1.112790 2513.246094 702878.324629 4287316.323088<BR>
+...<P>
+</TT>
+<H2>NOTES</H2>
+You might notice the first two 'dist' values in the profile output above are
+both zero. This is due to the fact the cell resolution for this file is
+less than one meter, and so the function that calculates the distance
+considers the distance between the first cell and the second to be zero.
+You might also notice, the coordinates given in the header and displayed on
+screen are slightly different from the first and last coordinates given in
+the profile data output. This is because the profile data output finds the
+eastings and northings for the center of the cells while the coordinate
+transformations from mouse clicks might yield slightly different coordinates
+which still fall within the same cell boundaries. The difference should
+always be less than the distance between the center and any corner (not
+edge!) of the cell at the resolution of the profiled raster.
+<P>
+Only four output plotfiles can be made. Each time a new profile is run, the
+plotfile is immediately written to the file <EM>name</EM>.<EM>letter</EM>.
+One can take advantage of this fact to create an unlimited number of
+plotfiles simply by renaming the output files before running more profiles.
+This may not always be the case, but it is at the time of this writing.
+<P>
+Useful enhancements to <EM>d.profile</EM> would include:
+<OL>
+<LI>Adding an option to display profiles using category
+colors, like a bar-chart.
+<LI>Allowing profile lines to be defined by a series of
+points, not just two.
+<LI>Allowing profiles to be saved in a file, for later
+viewing by GRASS.
+<LI>Allowing the user to enter profile line points by
+typing coordinates.
+</OL>
+<H3>Perl Script to convert output to a site_list</H3>
+The script below will convert the <B>plotfile</B> output to the site_list format.
+It probably won't work 100% for lat/lon datasets.
+<P>
+<TT>
+<B>#! /usr/bin/perl -w</B><BR>
+# prof2sites.pl: converts the output of d.profile to a site_list
+<P>
+<B>my</B> (<EM>$dist</EM>, <EM>$elev</EM>, <EM>$east</EM>, <EM>$north</EM>);
+<P>
+<B>while</B> (<<B>STDIN</B>>)<BR>
+{<BR>
+ <B>if</B> (m/^#/)<BR>
+ {<BR>
+ <B>print</B> "<EM>$_</EM>";<BR>
+ }<BR>
+ <B>else</B><BR>
+ {<BR>
+ <B>chomp</B>;<BR>
+ (<EM>$dist</EM>, <EM>$elev</EM>, <EM>$east</EM>, <EM>$north</EM>) = <B>split</B> / /;<BR>
+ <B>print</B> "<EM>$east</EM>|<EM>$north</EM>|<EM>$elev</EM>|#1 \%<EM>$dist</EM> \@Profile\n";<BR>
+ }<BR>
+}<BR>
+</TT>
+<H2>BUGS</H2>
+None known.
+<H2>AUTHOR</H2>
+Dave Johnson
+<BR> DBA Systems, Inc. <BR>
+10560 Arrowhead Drive <BR>
+Fairfax, Virginia 22030
+<P>
+Modified by Eric G. Miller for profile output, support of
+floating point rasters, and optional display raster (02-Dec-2000).
Deleted: grass/trunk/display/d.profile/description.html
--- grass/trunk/display/d.profile/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.profile/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,194 +0,0 @@
-This command works only interactively. It clears the entire
-graphics screen and provides a graphical interaction
-allowing the selection of transects for which profiles are
-then generated. Input parameters can be specified on the command line
-for quicker start-up.
-<H2>USER PROMPTS</H2>
-First, you will be presented with a prompt asking you to
-choose a raster map layer to be profiled. Then you will be
-prompted for an optional display raster. The optional display raster
-will be shown rather than the profiled raster. This is useful
-to be able to more easily see ground features, such as might be visible
-in an aerial photo or satellite image. Finally, you will
-be prompted for the name prefix for output file(s) containing the profile
-data. This is an optional feature.
-<P>
-After parameters are given, the raster layer will be
-displayed in the left half of the graphics monitor, and the
-right half will be divided into four
-frames. There will also be two frames along the top of the
-monitor: a mouse-button menu frame on the left, and a
-status frame on the right.
-<P>
-The mouse-button menu initially offers you three options:
-<DL>
-<DD>
-Mouse Buttons: <BR>
-Left: Where am I? <BR>
-Middle: Mark FIRST Point of Profile Line. <BR>
-Right: QUIT this. <BR>
-</DL>
-You may query the displayed raster map layer by indicating
-points with the left mouse-button. The coordinates and
-category value of each point that you indicate will be
-displayed on in the status frame. If you mark the first
-point of the profile line you will be presented with the
-following mouse-button menu:
-<DL>
-<DD>
-Middle: Mark SECOND Point of Profile Line. <BR>
-</DL>
-Once you mark the second point of the profile line, the
-profile line will be labeled (with a letter from A to D)
-and displayed in one of the four display frames on the
-right hand side of the screen. You will then be presented
-with a third mouse-button menu:
-<DL>
-<DD>
-Left: DO ANOTHER <BR>
-Middle: CLEAR DISPLAY <BR>
-</DL>
-If you would like to view another profile, click on the
-left mouse-button. If you would like to redisplay the
-raster map layer and clear out the four profile frames,
-click on the middle mouse-button. If you would like to
-quit, then click on the right button.
-<P>
-If you selected the <B>plotfile</B> option, you will have up to
-four files starting with the <EM>name</EM> and followed by a suffix
-of the plot letter <EM>A, B, C,</EM> or <EM>D</EM>. The plots that
-are written to these files reflect the last of each plot done with that
-letter (i.e. They will match what's in the display when you quit).
-<P>
-The format of the plot files is not geared toward any particular software,
-but should be easy to coax into a number of other programs. The first
-three lines contain some header information about the plot, each prefixed
-with a <TT>#</TT> sign to denote a comment. A fourth comment line describes
-the data that follows. It consists of the distance (always in meters),
-the cell value (in whatever units it is in), the easting in decimal format,
-and the northing in decimal format.
-The number of values will vary depending on the length of the profile, cell
-resolution and the slope angle of the profile line. Below is an example
-of a plotfile:
-<P>
-<TT>
-# Profile A of elev.ft at snows<BR>
-# From (702879.29679757, 4287317.55920185) to (702722.40973589, 4287061.72632285)<BR>
-# Stats: Count = 644, Min = 2424.658936, Max = 2513.246094<BR>
-# dist value east north<BR>
-0.000000 2513.246094 702879.102364 4287317.516912<BR>
-0.000000 2513.246094 702878.713496 4287317.118970<BR>
-0.556395 2513.246094 702878.324629 4287316.721029<BR>
-1.112790 2513.246094 702878.324629 4287316.323088<BR>
-...<P>
-</TT>
-<H2>NOTES</H2>
-You might notice the first two 'dist' values in the profile output above are
-both zero. This is due to the fact the cell resolution for this file is
-less than one meter, and so the function that calculates the distance
-considers the distance between the first cell and the second to be zero.
-You might also notice, the coordinates given in the header and displayed on
-screen are slightly different from the first and last coordinates given in
-the profile data output. This is because the profile data output finds the
-eastings and northings for the center of the cells while the coordinate
-transformations from mouse clicks might yield slightly different coordinates
-which still fall within the same cell boundaries. The difference should
-always be less than the distance between the center and any corner (not
-edge!) of the cell at the resolution of the profiled raster.
-<P>
-Only four output plotfiles can be made. Each time a new profile is run, the
-plotfile is immediately written to the file <EM>name</EM>.<EM>letter</EM>.
-One can take advantage of this fact to create an unlimited number of
-plotfiles simply by renaming the output files before running more profiles.
-This may not always be the case, but it is at the time of this writing.
-<P>
-Useful enhancements to <EM>d.profile</EM> would include:
-<OL>
-<LI>Adding an option to display profiles using category
-colors, like a bar-chart.
-<LI>Allowing profile lines to be defined by a series of
-points, not just two.
-<LI>Allowing profiles to be saved in a file, for later
-viewing by GRASS.
-<LI>Allowing the user to enter profile line points by
-typing coordinates.
-</OL>
-<H3>Perl Script to convert output to a site_list</H3>
-The script below will convert the <B>plotfile</B> output to the site_list format.
-It probably won't work 100% for lat/lon datasets.
-<P>
-<TT>
-<B>#! /usr/bin/perl -w</B><BR>
-# prof2sites.pl: converts the output of d.profile to a site_list
-<P>
-<B>my</B> (<EM>$dist</EM>, <EM>$elev</EM>, <EM>$east</EM>, <EM>$north</EM>);
-<P>
-<B>while</B> (<<B>STDIN</B>>)<BR>
-{<BR>
- <B>if</B> (m/^#/)<BR>
- {<BR>
- <B>print</B> "<EM>$_</EM>";<BR>
- }<BR>
- <B>else</B><BR>
- {<BR>
- <B>chomp</B>;<BR>
- (<EM>$dist</EM>, <EM>$elev</EM>, <EM>$east</EM>, <EM>$north</EM>) = <B>split</B> / /;<BR>
- <B>print</B> "<EM>$east</EM>|<EM>$north</EM>|<EM>$elev</EM>|#1 \%<EM>$dist</EM> \@Profile\n";<BR>
- }<BR>
-}<BR>
-</TT>
-<H2>BUGS</H2>
-None known.
-<H2>AUTHOR</H2>
-Dave Johnson
-<BR> DBA Systems, Inc. <BR>
-10560 Arrowhead Drive <BR>
-Fairfax, Virginia 22030
-<P>
-Modified by Eric G. Miller for profile output, support of
-floating point rasters, and optional display raster (02-Dec-2000).
Copied: grass/trunk/display/d.rast/d.rast.html (from rev 32770, grass/trunk/display/d.rast/description.html)
--- grass/trunk/display/d.rast/d.rast.html (rev 0)
+++ grass/trunk/display/d.rast/d.rast.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,22 @@
+<em>d.rast</em> displays raster map layer(s) <em>name</em>
+in the active display frame on the graphics monitor.
+<h2>NOTES</h2>
+To overlay raster maps option (<b>-o</b>) may be used.
+<h2>SEE ALSO</h2>
+<em><a HREF="d.erase.html">d.erase</a></em><br>
+<em><a HREF="d.what.rast.html">d.what.rast</a></em><br>
+<h2>AUTHOR</h2>
+James Westervelt,
Deleted: grass/trunk/display/d.rast/description.html
--- grass/trunk/display/d.rast/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.rast/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,22 +0,0 @@
-<em>d.rast</em> displays raster map layer(s) <em>name</em>
-in the active display frame on the graphics monitor.
-<h2>NOTES</h2>
-To overlay raster maps option (<b>-o</b>) may be used.
-<h2>SEE ALSO</h2>
-<em><a HREF="d.erase.html">d.erase</a></em><br>
-<em><a HREF="d.what.rast.html">d.what.rast</a></em><br>
-<h2>AUTHOR</h2>
-James Westervelt,
Copied: grass/trunk/display/d.rast.arrow/d.rast.arrow.html (from rev 32770, grass/trunk/display/d.rast.arrow/description.html)
--- grass/trunk/display/d.rast.arrow/d.rast.arrow.html (rev 0)
+++ grass/trunk/display/d.rast.arrow/d.rast.arrow.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,95 @@
+<H2>DESCRIPTION</H2>
+<EM>d.rast.arrow</EM>
+is designed to help users better visualize surface water flow direction,
+as indicated in an aspect raster map layer. There are two ways to specify
+the aspect layer the program is to use. The first is to display the aspect
+map layer on the graphics monitor before running <EM>d.rast.arrow</EM>.
+The second method involves setting the <EM>map</EM> parameter
+to the name of the desired aspect map.
+This allows the arrows to be drawn over any other maps already displayed
+on the graphics monitor.
+<P>
+<EM>d.rast.arrow</EM> will draw an arrow over each displayed cell
+to indicate in which direction the cell slopes. If the aspect
+layer has a category value denoting locations of "unknown" aspect,
+<EM>d.rast.arrow</EM> draws a question mark over the displayed cells
+of that category.
+Cells containing null data will be marked with an "X".
+<p>
+If you specify the <em>magnitude_map</em> option, arrow lengths
+denoting magnitude will be extracted from the cell values of the specified
+map. In this case the tail of the arrow will be centered on the source cell.
+You may adjust the overall scale using the <em>scale</em> option.
+<em>d.rast.arrow</em> will ignore NULL and negative magnitudes, and will
+warn you if the debug level is set at 5 or higher. Be aware. If your application
+uses negative values for magnitude, you can use <em>r.mapcalc</em> to prepare
+the magnitude map to suit your needs (absolute value, inverted direction and
+so on).
+<p>
+<H2>NOTES</H2>
+By default, arrows are drawn at the size of a cell and cannot be seen if
+the raster map is relatively close in scale. You can use the <em>skip</em>
+option to draw arrows every n-th cell in both directions if you are working
+with relatively high resolutions. It may be useful to disable the grid in
+this case, which is accomplished by setting its color to "<tt>none</tt>".
+<P>
+For GRASS and Compass type aspect maps, the cell values of the aspect map
+will determine the corresponding direction in 360 degrees. ANSWERS type
+aspect maps will be plotted in multiples of 15 degrees, and AGNPS type
+aspect maps will be displayed in D8 representation, i.e. the eight multiples
+of 45 degrees.
+<P>
+GRASS aspect maps are measured using Cartesian conventions, i.e. in degrees
+counterclockwise from east. e.g.:
+<UL>
+<pre>
+90 North
+180 West
+270 South
+0,360 East</pre>
+</UL>
+<P>
+They can be created from a raster elevation map with <em>r.slope.aspect</em>.
+<P>
+Compass type aspect maps are measured in degrees clockwise from north.
+<P>
+This module uses oceanographic conventions, i.e. arrows point downslope or
+direction "to", as opposed to atmospheric conventions (direction "from").
+<H2>EXAMPLE</H2>
+Convert U,V velocity component maps into magnitide,direction maps for use
+with <em>d.rast.arrow</em>:
+<pre>
+ r.mapcalc 'magnitude = sqrt(U_map^2 + V_map^2)'
+ r.mapcalc 'direction = atan(U_map, V_map)'
+ d.rast.arrow map=direction type=grass magnitude_map=magnitude skip=3 grid=none
+</pre>
+<BR>
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.frame.html">d.frame</A></EM><BR>
+<EM><A HREF="d.rast.edit.html">d.rast.edit</A></EM><BR>
+<EM><A HREF="d.rast.num.html">d.rast.num</A></EM><BR>
+<EM><A HREF="g.region.html">g.region</A></EM><BR>
+<EM><A HREF="r.slope.aspect.html">r.slope.aspect</A></EM><BR>
+<BR>
+<H2>AUTHORS</H2>
+<u>Original author</u><BR>
+Chris Rewerts<BR>
+<em>Agricultural Engineering,<BR>
+Purdue University</em><BR><BR>
+<u>Magnitude and 360 arrow code</u><BR>
+Hamish Bowman<BR>
+<em>Department of Marine Science, <BR>
+University of Otago, New Zealand</em>
Deleted: grass/trunk/display/d.rast.arrow/description.html
--- grass/trunk/display/d.rast.arrow/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.rast.arrow/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,95 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>d.rast.arrow</EM>
-is designed to help users better visualize surface water flow direction,
-as indicated in an aspect raster map layer. There are two ways to specify
-the aspect layer the program is to use. The first is to display the aspect
-map layer on the graphics monitor before running <EM>d.rast.arrow</EM>.
-The second method involves setting the <EM>map</EM> parameter
-to the name of the desired aspect map.
-This allows the arrows to be drawn over any other maps already displayed
-on the graphics monitor.
-<P>
-<EM>d.rast.arrow</EM> will draw an arrow over each displayed cell
-to indicate in which direction the cell slopes. If the aspect
-layer has a category value denoting locations of "unknown" aspect,
-<EM>d.rast.arrow</EM> draws a question mark over the displayed cells
-of that category.
-Cells containing null data will be marked with an "X".
-<p>
-If you specify the <em>magnitude_map</em> option, arrow lengths
-denoting magnitude will be extracted from the cell values of the specified
-map. In this case the tail of the arrow will be centered on the source cell.
-You may adjust the overall scale using the <em>scale</em> option.
-<em>d.rast.arrow</em> will ignore NULL and negative magnitudes, and will
-warn you if the debug level is set at 5 or higher. Be aware. If your application
-uses negative values for magnitude, you can use <em>r.mapcalc</em> to prepare
-the magnitude map to suit your needs (absolute value, inverted direction and
-so on).
-<p>
-<H2>NOTES</H2>
-By default, arrows are drawn at the size of a cell and cannot be seen if
-the raster map is relatively close in scale. You can use the <em>skip</em>
-option to draw arrows every n-th cell in both directions if you are working
-with relatively high resolutions. It may be useful to disable the grid in
-this case, which is accomplished by setting its color to "<tt>none</tt>".
-<P>
-For GRASS and Compass type aspect maps, the cell values of the aspect map
-will determine the corresponding direction in 360 degrees. ANSWERS type
-aspect maps will be plotted in multiples of 15 degrees, and AGNPS type
-aspect maps will be displayed in D8 representation, i.e. the eight multiples
-of 45 degrees.
-<P>
-GRASS aspect maps are measured using Cartesian conventions, i.e. in degrees
-counterclockwise from east. e.g.:
-<UL>
-<pre>
-90 North
-180 West
-270 South
-0,360 East</pre>
-</UL>
-<P>
-They can be created from a raster elevation map with <em>r.slope.aspect</em>.
-<P>
-Compass type aspect maps are measured in degrees clockwise from north.
-<P>
-This module uses oceanographic conventions, i.e. arrows point downslope or
-direction "to", as opposed to atmospheric conventions (direction "from").
-<H2>EXAMPLE</H2>
-Convert U,V velocity component maps into magnitide,direction maps for use
-with <em>d.rast.arrow</em>:
-<pre>
- r.mapcalc 'magnitude = sqrt(U_map^2 + V_map^2)'
- r.mapcalc 'direction = atan(U_map, V_map)'
- d.rast.arrow map=direction type=grass magnitude_map=magnitude skip=3 grid=none
-</pre>
-<BR>
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.frame.html">d.frame</A></EM><BR>
-<EM><A HREF="d.rast.edit.html">d.rast.edit</A></EM><BR>
-<EM><A HREF="d.rast.num.html">d.rast.num</A></EM><BR>
-<EM><A HREF="g.region.html">g.region</A></EM><BR>
-<EM><A HREF="r.slope.aspect.html">r.slope.aspect</A></EM><BR>
-<BR>
-<H2>AUTHORS</H2>
-<u>Original author</u><BR>
-Chris Rewerts<BR>
-<em>Agricultural Engineering,<BR>
-Purdue University</em><BR><BR>
-<u>Magnitude and 360 arrow code</u><BR>
-Hamish Bowman<BR>
-<em>Department of Marine Science, <BR>
-University of Otago, New Zealand</em>
Copied: grass/trunk/display/d.rast.num/d.rast.num.html (from rev 32770, grass/trunk/display/d.rast.num/description.html)
--- grass/trunk/display/d.rast.num/d.rast.num.html (rev 0)
+++ grass/trunk/display/d.rast.num/d.rast.num.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,46 @@
+<EM>d.rast.num</EM>
+overlays cell category values onto a raster map layer displayed
+on the user's graphics monitor.
+Category values will be displayed in the text color given and scaled
+to fit within a single cell. A grid outlining each map cell will also
+be overlain in a user-specified color, unless it has been set to "none".
+<P>
+If no grid color is given the default will be used. If no map layer
+is specified, the program will use whatever raster map layer is
+currently displayed in the active frame on the graphics monitor.
+<P>
+If the <b>-f</b> flag is given the displayed number will take on the color
+of the base map in that cell.
+<H2>NOTES</H2>
+The user is advised to set the current region to a relatively
+small area (i.e., less than 100 rows by 100 columns);
+otherwise, the individual cells being displayed will be small
+and the category value associated with each will be difficult to see.
+No data cells are indicated with "Null".
+<H2>SEE ALSO</H2>
+<em><a href="d.frame.html">d.frame</a></em>,
+<em><a href="d.grid.html">d.grid</a></em>,
+<em><a href="d.rast.html">d.rast</a></em>,
+<em><a href="d.rast.arrow.html">d.rast.arrow</a></em>,
+<em><a href="d.rast.edit.html">d.rast.edit</a></em>,
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>
+<H2>AUTHORS</H2>
+Raghavan Srinivasan,
+and Chris Rewerts,<BR>
+Agricultural Engineering, Purdue University
Deleted: grass/trunk/display/d.rast.num/description.html
--- grass/trunk/display/d.rast.num/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.rast.num/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,46 +0,0 @@
-<EM>d.rast.num</EM>
-overlays cell category values onto a raster map layer displayed
-on the user's graphics monitor.
-Category values will be displayed in the text color given and scaled
-to fit within a single cell. A grid outlining each map cell will also
-be overlain in a user-specified color, unless it has been set to "none".
-<P>
-If no grid color is given the default will be used. If no map layer
-is specified, the program will use whatever raster map layer is
-currently displayed in the active frame on the graphics monitor.
-<P>
-If the <b>-f</b> flag is given the displayed number will take on the color
-of the base map in that cell.
-<H2>NOTES</H2>
-The user is advised to set the current region to a relatively
-small area (i.e., less than 100 rows by 100 columns);
-otherwise, the individual cells being displayed will be small
-and the category value associated with each will be difficult to see.
-No data cells are indicated with "Null".
-<H2>SEE ALSO</H2>
-<em><a href="d.frame.html">d.frame</a></em>,
-<em><a href="d.grid.html">d.grid</a></em>,
-<em><a href="d.rast.html">d.rast</a></em>,
-<em><a href="d.rast.arrow.html">d.rast.arrow</a></em>,
-<em><a href="d.rast.edit.html">d.rast.edit</a></em>,
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>
-<H2>AUTHORS</H2>
-Raghavan Srinivasan,
-and Chris Rewerts,<BR>
-Agricultural Engineering, Purdue University
Copied: grass/trunk/display/d.rgb/d.rgb.html (from rev 32770, grass/trunk/display/d.rgb/description.html)
--- grass/trunk/display/d.rgb/d.rgb.html (rev 0)
+++ grass/trunk/display/d.rgb/d.rgb.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,94 @@
+<EM>RGB</EM> stands for red, green, and blue. This program
+visually combines three raster map layers to form a color
+image. For each layer, the corresponding component from
+the layer's color table is used (e.g. for the red layer,
+the red component is used, and so on). In general, the
+layers should use a grey-scale color table.
+<H2>OPTIONS</H2>
+<H3>Flags:</H3>
+<DL>
+<DT><B>-o</B>
+<DD>Overlay the resulting raster map layer onto whatever is already
+displayed in the active graphics frame. Any no-data areas in any of
+the named raster maps will seem transparent, and reveal the underlying
+image previously displayed in the graphics frame. If the <B>-o</B>
+flag is set, only cells containing non-null values will be displayed
+from the <EM>overlaid</EM> raster map. All other areas (i.e., the
+portions of the overlaid map that contain null values) will leave the
+underlying display untouched.
+</DL>
+<DL>
+<DT><B>red=</B><EM>name</EM>
+<DD>Name of raster map layer to be used for RED component.
+<DT><B>green=</B><EM>name</EM>
+<DD>Name of raster map layer to be used for GREEN component.
+<DT><B>blue=</B><EM>name</EM>
+<DD>Name of raster map layer to be used for BLUE component.
+</DL>
+<H2>NOTES</H2>
+This is a new version of <B>d.rgb</B>, which sends the
+data to the graphics monitor in true-color RGB format.
+Unlike the previous version, it does not attempt to
+quantize the combined image into a fixed number of colors.
+Nor does it have an option to generate a composite layer.
+The image and raster map layers will not display properly
+if the graphics device does not have a reasonable sampling
+of the RGB color-space.
+<P>
+If color quality of satellite image color composites seems to appear poor,
+run <EM><a href="r.colors.html">r.colors</A></EM> on the selected satellite
+channels.<P>
+Example:
+<dl>
+<dd><B>r.info -r</B> <EM>image.1</EM><BR>
+<tt>min=0<BR>
+max=255</tt><BR>
+<dd><B>r.colors map=</B><EM>image.1</EM> <B>color=</B><EM>rules</EM>
+<< EOF<BR>
+0 black<BR>
+255 white<BR>
+EOF<BR>
+<dd><B>r.colors map=</B><EM>image.2</EM> <B>rast=</B><EM>image.1</EM>
+<dd><B>r.colors map=</B><EM>image.3</EM> <B>rast=</B><EM>image.1</EM>
+</dl>
+<EM>Note: Future GRASS versions may do this for you automatically.</EM>
+<BR><BR><BR>
+To write out the color composite to a R/G/B raster maps, use
+<EM><a href="r.composite.html">r.composite</A></EM>.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.colors.html">d.colors</A></EM><br>
+<EM><A HREF="d.colortable.html">d.colortable</A></EM><br>
+<EM><A HREF="d.his.html">d.his</A></EM><br>
+<EM><A HREF="r.blend.html">r.blend</A></EM><br>
+<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM><br>
+<EM><A HREF="r.colors.html">r.colors</A></EM><br>
+<EM><A HREF="r.composite.html">r.composite</A></EM>
+<H2>AUTHOR</H2>
+Glynn Clements
Deleted: grass/trunk/display/d.rgb/description.html
--- grass/trunk/display/d.rgb/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.rgb/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,94 +0,0 @@
-<EM>RGB</EM> stands for red, green, and blue. This program
-visually combines three raster map layers to form a color
-image. For each layer, the corresponding component from
-the layer's color table is used (e.g. for the red layer,
-the red component is used, and so on). In general, the
-layers should use a grey-scale color table.
-<H2>OPTIONS</H2>
-<H3>Flags:</H3>
-<DL>
-<DT><B>-o</B>
-<DD>Overlay the resulting raster map layer onto whatever is already
-displayed in the active graphics frame. Any no-data areas in any of
-the named raster maps will seem transparent, and reveal the underlying
-image previously displayed in the graphics frame. If the <B>-o</B>
-flag is set, only cells containing non-null values will be displayed
-from the <EM>overlaid</EM> raster map. All other areas (i.e., the
-portions of the overlaid map that contain null values) will leave the
-underlying display untouched.
-</DL>
-<DL>
-<DT><B>red=</B><EM>name</EM>
-<DD>Name of raster map layer to be used for RED component.
-<DT><B>green=</B><EM>name</EM>
-<DD>Name of raster map layer to be used for GREEN component.
-<DT><B>blue=</B><EM>name</EM>
-<DD>Name of raster map layer to be used for BLUE component.
-</DL>
-<H2>NOTES</H2>
-This is a new version of <B>d.rgb</B>, which sends the
-data to the graphics monitor in true-color RGB format.
-Unlike the previous version, it does not attempt to
-quantize the combined image into a fixed number of colors.
-Nor does it have an option to generate a composite layer.
-The image and raster map layers will not display properly
-if the graphics device does not have a reasonable sampling
-of the RGB color-space.
-<P>
-If color quality of satellite image color composites seems to appear poor,
-run <EM><a href="r.colors.html">r.colors</A></EM> on the selected satellite
-channels.<P>
-Example:
-<dl>
-<dd><B>r.info -r</B> <EM>image.1</EM><BR>
-<tt>min=0<BR>
-max=255</tt><BR>
-<dd><B>r.colors map=</B><EM>image.1</EM> <B>color=</B><EM>rules</EM>
-<< EOF<BR>
-0 black<BR>
-255 white<BR>
-EOF<BR>
-<dd><B>r.colors map=</B><EM>image.2</EM> <B>rast=</B><EM>image.1</EM>
-<dd><B>r.colors map=</B><EM>image.3</EM> <B>rast=</B><EM>image.1</EM>
-</dl>
-<EM>Note: Future GRASS versions may do this for you automatically.</EM>
-<BR><BR><BR>
-To write out the color composite to a R/G/B raster maps, use
-<EM><a href="r.composite.html">r.composite</A></EM>.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.colors.html">d.colors</A></EM><br>
-<EM><A HREF="d.colortable.html">d.colortable</A></EM><br>
-<EM><A HREF="d.his.html">d.his</A></EM><br>
-<EM><A HREF="r.blend.html">r.blend</A></EM><br>
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM><br>
-<EM><A HREF="r.colors.html">r.colors</A></EM><br>
-<EM><A HREF="r.composite.html">r.composite</A></EM>
-<H2>AUTHOR</H2>
-Glynn Clements
Copied: grass/trunk/display/d.rhumbline/d.rhumbline.html (from rev 32770, grass/trunk/display/d.rhumbline/description.html)
--- grass/trunk/display/d.rhumbline/d.rhumbline.html (rev 0)
+++ grass/trunk/display/d.rhumbline/d.rhumbline.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,51 @@
+A rhumbline (loxodrome) is a line following a constant angle of the
+compass (i.e., a line of constant direction). It crosses all meridians
+at the same angle, i.e. a path of constant bearing.
+ <!-- There are 32
+points on the compass (points are roughly 11 degrees 15
+minutes apart). --> <EM>d.rhumbline</EM> displays the
+rhumbline joining any two user-specified points in the
+active frame on the user's graphics monitor. The named
+coordinate locations must fall within the boundaries of the
+user's current geographic region.
+<P>
+The user can run this program either interactively or
+non-interactively. If the user simply types
+<B>d.rhumbline</B> on the command line and runs it without specifying
+parameter values, the mouse will be activated and the user
+will be asked to use the mouse to indicate the two
+endpoints of the rhumbline. The rhumbline is then drawn in
+the default color (black). <!-- The program also outputs the
+coordinate locations of the two endpoints on the user's
+terminal and the number associated with the mouse button
+depressed by the user in a format useful for input to other
+programs. -->
+<P>
+Alternately, the user can specify the starting and ending
+longitude/latitude coordinates of the rhumbline and
+(optionally) the color in which the rhumbline will be
+displayed; in this case, the program will run
+non-interactively.
+<H2>NOTES</H2>
+This program works only with longitude-latitude locations.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.geodesic.html">d.geodesic</A></EM>
+<H2>AUTHOR</H2>
+Michael Shapiro,
+U.S. Army Construction Engineering
+Research Laboratory
Deleted: grass/trunk/display/d.rhumbline/description.html
--- grass/trunk/display/d.rhumbline/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.rhumbline/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,51 +0,0 @@
-A rhumbline (loxodrome) is a line following a constant angle of the
-compass (i.e., a line of constant direction). It crosses all meridians
-at the same angle, i.e. a path of constant bearing.
- <!-- There are 32
-points on the compass (points are roughly 11 degrees 15
-minutes apart). --> <EM>d.rhumbline</EM> displays the
-rhumbline joining any two user-specified points in the
-active frame on the user's graphics monitor. The named
-coordinate locations must fall within the boundaries of the
-user's current geographic region.
-<P>
-The user can run this program either interactively or
-non-interactively. If the user simply types
-<B>d.rhumbline</B> on the command line and runs it without specifying
-parameter values, the mouse will be activated and the user
-will be asked to use the mouse to indicate the two
-endpoints of the rhumbline. The rhumbline is then drawn in
-the default color (black). <!-- The program also outputs the
-coordinate locations of the two endpoints on the user's
-terminal and the number associated with the mouse button
-depressed by the user in a format useful for input to other
-programs. -->
-<P>
-Alternately, the user can specify the starting and ending
-longitude/latitude coordinates of the rhumbline and
-(optionally) the color in which the rhumbline will be
-displayed; in this case, the program will run
-non-interactively.
-<H2>NOTES</H2>
-This program works only with longitude-latitude locations.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.geodesic.html">d.geodesic</A></EM>
-<H2>AUTHOR</H2>
-Michael Shapiro,
-U.S. Army Construction Engineering
-Research Laboratory
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/display/d.text.new/d.text.html (from rev 32770, grass/trunk/display/d.text.new/description.html)
--- grass/trunk/display/d.text.new/d.text.html (rev 0)
+++ grass/trunk/display/d.text.new/d.text.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,109 @@
+<EM>d.text</EM> draws text in the active display frame on
+the graphics monitor. Text can be provided through
+standard input or redirected from a file (using the UNIX
+redirection mechanism).
+In addition to the options provided on the command line,
+colors, text size, font type, rotation angle, and boldness can be adjusted
+with commands in the standard input (i.e., if the user
+invokes <EM>d.text</EM> without options on the command
+line, and then assigns values to these options on lines
+within the standard input).
+<H3>Commands:</H3>
+<DL>
+<DT><B>.C</B> <EM>color</EM>
+<DD>
+(where <EM>color</EM> is one of the available colors) causes text appearing on
+subsequent lines to be drawn in that color.
+<DT><B>.S </B> <EM>size</EM>
+<DD>
+(where <EM>size</EM> is a percentage within the range 0 to
+100) adjusts text size. Note that a size of 10 would allow
+10 lines to be drawn in the active display frame, 5 would
+allow the drawing of 20 lines, and 50 would allow the
+drawing of 2 lines.
+<P>
+<DT><B>.F</B> <EM>font</EM>
+<DD>
+(where <EM>font</EM> is one of the fonts known by the GRASS program
+<EM><A HREF="d.font.html">d.font</A></EM>) manipulates
+the font type. Available fonts are listed in the GRASS manual entry for
+<EM><A HREF="d.font.html">d.font</A></EM>.
+The default font type used (if unspecified by the user)
+is <EM>romans</EM>.
+<!-- Run the GRASS macro
+<EM><A HREF="show.fonts.sh.html">show.fonts.sh</A></EM>
+to see what these fonts look like. -->
+<DT><B>.R </B> <EM>rotation</EM>
+<DD>
+(where <EM>rotation</EM> is an angle in degrees, counter-clockwise)
+to rotate the text.
+<DT><B>.B 1</B>
+<DD>stipulates that following text be printed in <B>bold</B>.
+This command means <EM>bold on</EM>.
+<DT><B>.B 0</B>
+<DD> turns <EM>bold off</EM> of all text appearing on lines beneath
+ it. (<EM>Bold off</EM> is used by default, if unspecified by the user.)
+</DL>
+<H2>EXAMPLE</H2>
+The following command will print the short phrase "This is
+a test of d.text" in the active display frame using the
+color yellow, in bold, and using 4/100'ths (4%) of the
+active frame's vertical space per line:
+<P>
+<pre>
+ <B>d.text</B> << EOF
+ .C yellow
+ .S 4
+ .B 1
+ This is a test of d.text
+ EOF
+</pre>
+The user presses <EM>control-d</EM>
+(the "Ctrl" and "d" keys) to end input to <EM>d.text</EM> (equal to EOF).
+<H2>NOTES</H2>
+Note that the GRASS command
+<EM><A HREF="d.title.html">d.title</A></EM> creates map TITLEs in a format
+suitable for input to <EM>d.text</EM>.
+<P>
+<EM>d.text</EM> needs escape sequences that can be used
+within lines to change colors, boldness, and perhaps size.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.font.html">d.font</A></EM><br>
+<EM><A HREF="d.title.html">d.title</A></EM><br>
+<!-- <EM><A HREF="show.fonts.sh.html">show.fonts.sh</A></EM><br> -->
+<EM><A HREF="d.labels.html">d.labels</A></EM><br>
+<H2>AUTHOR</H2>
+James Westervelt,
+<P>
+Updates by Huidae Cho
Deleted: grass/trunk/display/d.text.new/description.html
--- grass/trunk/display/d.text.new/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.text.new/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,109 +0,0 @@
-<EM>d.text</EM> draws text in the active display frame on
-the graphics monitor. Text can be provided through
-standard input or redirected from a file (using the UNIX
-redirection mechanism).
-In addition to the options provided on the command line,
-colors, text size, font type, rotation angle, and boldness can be adjusted
-with commands in the standard input (i.e., if the user
-invokes <EM>d.text</EM> without options on the command
-line, and then assigns values to these options on lines
-within the standard input).
-<H3>Commands:</H3>
-<DL>
-<DT><B>.C</B> <EM>color</EM>
-<DD>
-(where <EM>color</EM> is one of the available colors) causes text appearing on
-subsequent lines to be drawn in that color.
-<DT><B>.S </B> <EM>size</EM>
-<DD>
-(where <EM>size</EM> is a percentage within the range 0 to
-100) adjusts text size. Note that a size of 10 would allow
-10 lines to be drawn in the active display frame, 5 would
-allow the drawing of 20 lines, and 50 would allow the
-drawing of 2 lines.
-<P>
-<DT><B>.F</B> <EM>font</EM>
-<DD>
-(where <EM>font</EM> is one of the fonts known by the GRASS program
-<EM><A HREF="d.font.html">d.font</A></EM>) manipulates
-the font type. Available fonts are listed in the GRASS manual entry for
-<EM><A HREF="d.font.html">d.font</A></EM>.
-The default font type used (if unspecified by the user)
-is <EM>romans</EM>.
-<!-- Run the GRASS macro
-<EM><A HREF="show.fonts.sh.html">show.fonts.sh</A></EM>
-to see what these fonts look like. -->
-<DT><B>.R </B> <EM>rotation</EM>
-<DD>
-(where <EM>rotation</EM> is an angle in degrees, counter-clockwise)
-to rotate the text.
-<DT><B>.B 1</B>
-<DD>stipulates that following text be printed in <B>bold</B>.
-This command means <EM>bold on</EM>.
-<DT><B>.B 0</B>
-<DD> turns <EM>bold off</EM> of all text appearing on lines beneath
- it. (<EM>Bold off</EM> is used by default, if unspecified by the user.)
-</DL>
-<H2>EXAMPLE</H2>
-The following command will print the short phrase "This is
-a test of d.text" in the active display frame using the
-color yellow, in bold, and using 4/100'ths (4%) of the
-active frame's vertical space per line:
-<P>
-<pre>
- <B>d.text</B> << EOF
- .C yellow
- .S 4
- .B 1
- This is a test of d.text
- EOF
-</pre>
-The user presses <EM>control-d</EM>
-(the "Ctrl" and "d" keys) to end input to <EM>d.text</EM> (equal to EOF).
-<H2>NOTES</H2>
-Note that the GRASS command
-<EM><A HREF="d.title.html">d.title</A></EM> creates map TITLEs in a format
-suitable for input to <EM>d.text</EM>.
-<P>
-<EM>d.text</EM> needs escape sequences that can be used
-within lines to change colors, boldness, and perhaps size.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.font.html">d.font</A></EM><br>
-<EM><A HREF="d.title.html">d.title</A></EM><br>
-<!-- <EM><A HREF="show.fonts.sh.html">show.fonts.sh</A></EM><br> -->
-<EM><A HREF="d.labels.html">d.labels</A></EM><br>
-<H2>AUTHOR</H2>
-James Westervelt,
-<P>
-Updates by Huidae Cho
Copied: grass/trunk/display/d.thematic.area/d.thematic.area.html (from rev 32770, grass/trunk/display/d.thematic.area/description.html)
--- grass/trunk/display/d.thematic.area/d.thematic.area.html (rev 0)
+++ grass/trunk/display/d.thematic.area/d.thematic.area.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,31 @@
+<em>d.thematic.area</em> draws thematic coropleth vector maps based on an attribute column or an expression involving several columns. It takes a list of class breaks (excluding the minimum and maximum values) and a list of colors to apply to the classes (has to be the number of class breaks + 1).
+Instead of a list of class breaks, the user can also chose a classification algorithm and a number of classes. See the v.class man page for more information on these different algorithms.
+The <em>-l</em> flag instructs the module to print legend information (class min | class max | number of observations in class | color) to standard output for futher use in graphical software. When combined with the <em>-e</em> flag, the legend information will be extended with some additional statistical information. If the <em>-n</em> flag is set, the module will only print the legend information without drawing the map. If the user gives a <em>legendfile</em>, the module will write d.graph instructions for painting a legend into that file.
+<H2>EXAMPLE</H2>
+<div class="code"><pre>
+d.thematic.area -l map=communes3 data=pop breaks=111393.250000,222785.500000,334177.750000 colors=255:0:0,0:255:0,0:0:255,0,0,0
+</pre></div>
+The following example uses a calculated attribute (density = pop/area) and the standard deviation algorithm to calculate class breaks for 5 classes:
+d.thematic.area -l map=communes2 data=pop/area algorithm=std nbclasses=5 colors=0:0:255,50:100:255,255:100:50,255:0:0,156:0:0
+</pre></div>
+<H2>SEE ALSO</H2>
+<EM><A HREF="v.class.html">v.class</A></EM>
+<EM><A HREF="d.vect.html">d.vect</A></EM>
+<EM><A HREF="d.graph.html">d.graph</A></EM>
+<EM><A HREF="v.univar.html">v.univar</A></EM>
+<H2>AUTHOR</H2>
+Moritz Lennert
Deleted: grass/trunk/display/d.thematic.area/description.html
--- grass/trunk/display/d.thematic.area/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.thematic.area/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,31 +0,0 @@
-<em>d.thematic.area</em> draws thematic coropleth vector maps based on an attribute column or an expression involving several columns. It takes a list of class breaks (excluding the minimum and maximum values) and a list of colors to apply to the classes (has to be the number of class breaks + 1).
-Instead of a list of class breaks, the user can also chose a classification algorithm and a number of classes. See the v.class man page for more information on these different algorithms.
-The <em>-l</em> flag instructs the module to print legend information (class min | class max | number of observations in class | color) to standard output for futher use in graphical software. When combined with the <em>-e</em> flag, the legend information will be extended with some additional statistical information. If the <em>-n</em> flag is set, the module will only print the legend information without drawing the map. If the user gives a <em>legendfile</em>, the module will write d.graph instructions for painting a legend into that file.
-<H2>EXAMPLE</H2>
-<div class="code"><pre>
-d.thematic.area -l map=communes3 data=pop breaks=111393.250000,222785.500000,334177.750000 colors=255:0:0,0:255:0,0:0:255,0,0,0
-</pre></div>
-The following example uses a calculated attribute (density = pop/area) and the standard deviation algorithm to calculate class breaks for 5 classes:
-d.thematic.area -l map=communes2 data=pop/area algorithm=std nbclasses=5 colors=0:0:255,50:100:255,255:100:50,255:0:0,156:0:0
-</pre></div>
-<H2>SEE ALSO</H2>
-<EM><A HREF="v.class.html">v.class</A></EM>
-<EM><A HREF="v.univar.html">v.univar</A></EM>
-<H2>AUTHOR</H2>
-Moritz Lennert
Copied: grass/trunk/display/d.title/d.title.html (from rev 32770, grass/trunk/display/d.title/description.html)
--- grass/trunk/display/d.title/d.title.html (rev 0)
+++ grass/trunk/display/d.title/d.title.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,62 @@
+<EM>d.title</EM> generates to standard output a string which can be used by
+<EM><A HREF="d.text.html">d.text</A></EM> to draw a TITLE for the raster map
+layer <EM>name</EM> in the active display frame on the graphics monitor.
+Output created by <EM>d.title</EM> can be redirected into a file, or piped
+directly into <EM><A HREF="d.text.html">d.text</A></EM> to display the map
+TITLE created by <EM>d.title</EM>. The map TITLE created will include the
+map layer's name, TITLE, MAPSET, LOCATION_NAME, geographic region boundary
+coordinates, and cell resolution.
+If the <b>-d</b> draw flag is used, then <EM>d.title</EM> will call
+<EM>d.text</EM> for you and the title will be automatically rendered
+to the display.
+<H2>NOTES</H2>
+The text created with
+will not necessarily fit within the
+active display frame on the graphics monitor;
+the user should choose a text size appropriate to this frame.
+<H2>EXAMPLES</H2>
+For example, a user wishing to create a suitable TITLE for the
+Spearfish, SD <EM>soils</EM> map layer and to display this TITLE in the
+active display frame on the graphics monitor might type the following:
+<DL>
+<DD> <B>d.title map=</B><EM>soils</EM> <B>color=</B><EM>red</EM> <B>size=</B><EM>5</EM> <B>> TITLE.file</B>
+<DD> <B><A HREF="d.text.html">d.text</A> < TITLE.file</B>
+</DL>
+Alternately, the user might pipe <EM>d.title</EM> output directly
+into <EM><A HREF="d.text.html">d.text</A>:</EM>
+<DL>
+<DD>
+<B>d.title map=</B><EM>soils</EM> <B>color=</B><EM>red</EM> <B>size=</B><EM>5</EM> |
+<A HREF="d.text.html">d.text</A>
+</DL>
+<P>
+A file created by <EM>d.title</EM> can be displayed
+with <EM><A HREF="d.text.html">d.text</A></EM>.
+Information contained in this file takes precedence over the
+<EM>color</EM> and <EM>size</EM> parameters for
+<EM><A HREF="d.text.html">d.text</A></EM>.
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.text.html">d.text</A></EM><br>
+<H2>AUTHOR</H2>
+James Westervelt,
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/display/d.title/description.html
--- grass/trunk/display/d.title/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.title/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,62 +0,0 @@
-<EM>d.title</EM> generates to standard output a string which can be used by
-<EM><A HREF="d.text.html">d.text</A></EM> to draw a TITLE for the raster map
-layer <EM>name</EM> in the active display frame on the graphics monitor.
-Output created by <EM>d.title</EM> can be redirected into a file, or piped
-directly into <EM><A HREF="d.text.html">d.text</A></EM> to display the map
-TITLE created by <EM>d.title</EM>. The map TITLE created will include the
-map layer's name, TITLE, MAPSET, LOCATION_NAME, geographic region boundary
-coordinates, and cell resolution.
-If the <b>-d</b> draw flag is used, then <EM>d.title</EM> will call
-<EM>d.text</EM> for you and the title will be automatically rendered
-to the display.
-<H2>NOTES</H2>
-The text created with
-will not necessarily fit within the
-active display frame on the graphics monitor;
-the user should choose a text size appropriate to this frame.
-<H2>EXAMPLES</H2>
-For example, a user wishing to create a suitable TITLE for the
-Spearfish, SD <EM>soils</EM> map layer and to display this TITLE in the
-active display frame on the graphics monitor might type the following:
-<DL>
-<DD> <B>d.title map=</B><EM>soils</EM> <B>color=</B><EM>red</EM> <B>size=</B><EM>5</EM> <B>> TITLE.file</B>
-<DD> <B><A HREF="d.text.html">d.text</A> < TITLE.file</B>
-</DL>
-Alternately, the user might pipe <EM>d.title</EM> output directly
-into <EM><A HREF="d.text.html">d.text</A>:</EM>
-<DL>
-<DD>
-<B>d.title map=</B><EM>soils</EM> <B>color=</B><EM>red</EM> <B>size=</B><EM>5</EM> |
-<A HREF="d.text.html">d.text</A>
-</DL>
-<P>
-A file created by <EM>d.title</EM> can be displayed
-with <EM><A HREF="d.text.html">d.text</A></EM>.
-Information contained in this file takes precedence over the
-<EM>color</EM> and <EM>size</EM> parameters for
-<EM><A HREF="d.text.html">d.text</A></EM>.
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.text.html">d.text</A></EM><br>
-<H2>AUTHOR</H2>
-James Westervelt,
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/display/d.vect/d.vect.html (from rev 32770, grass/trunk/display/d.vect/description.html)
--- grass/trunk/display/d.vect/d.vect.html (rev 0)
+++ grass/trunk/display/d.vect/d.vect.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,107 @@
+<h2>DESCRIPTION</h2>
+<em>d.vect</em> displays GRASS vector data in the active frame on the graphics
+monitor.
+<h2>NOTES</h2>
+<em>d.vect</em> can simply be used typing <tt><b>d.vect map=</b>vector_map</tt>.
+There are a large variety of optional parameters which allow the user to
+specify vector type, colors, data fields, SQL queries, label size and
+justification, etc.
+<P>
+By default <em>d.vect</em> fills in holes in polygons (islands).
+If you only want to show active areas limit the features with, e.g.,
+"<tt>d.vect cats=1-999999</tt>".
+<P>
+In order to display attributes in the map, <em>display=attr</em> must be
+specified in addition to the column name (<em>attrcol</em> parameter).
+<P>
+Colors may be specified in an attribute table column
+named 'GRASSRGB' (which is a <tt>varchar(11)</tt> column containing <tt>RRR:GGG:BBB</tt> values),
+see the flag <em>-a</em>.
+<P>
+A table for a vector map might look like this:
+echo "select * from testisola" | db.select
+cat|label|GRASSRGB
+0|no data|255:255:255
+90|FRASSILONGO|23:245:67
+104|LEVICO|23:145:67
+139|PERGINE VALSUGANA|223:45:237
+168|SANT'ORSOLA|223:45:67
+190|TENNA|123:45:67
+</pre></div>
+<P>
+To add the GRASSRGB color column, use <em>v.db.addcol</em>:
+v.db.addcol testisola col="GRASSRGB varchar(11)"
+</pre></div>
+<P>
+To add/change a color, use <em>v.db.update</em>:
+v.db.update testisola col=GRASSRGB val="123:45:237" where="cat=139"
+</pre></div>
+<P>
+A much simpler method of color coding is by using the <em>-c</em> flag which
+displays vector elements of like category number with a random color.
+<P>
+This module can use FreeType/TrueType fonts if they have already been selected with
+<em>d.font</em>.
+<h2>EXAMPLES</h2>
+Spearfish examples:
+# display roads with category numbers:
+d.vect roads display=shape,cat lcolor=green
+# display randomly colorized soils map with attributes
+d.vect -c soils disp=attr attrcol=label
+# display randomly colorized selected vectors from soils map
+d.vect -c soils where="label='VBF'" display=shape,attr attrcol=label
+</pre></div>
+<p>
+3D points, 3D lines and 3D polygons colorized according to z height:
+g.region rast=elevation.10m
+r.random elevation.10m n=5000 vector=random3d -d
+d.mon x0
+# display as black points
+d.vect random3d
+# display 3D points colorized according to z height
+d.vect -z random3d zcol=gyr
+# 3D contour lines
+r.contour elevation.10m out=contour20m step=20
+d.vect -z contour20m zcol=gyr
+# generate 3D triangles
+v.delaunay random3d out=random3d_del
+# display 3D polygons colorized according to z height
+d.vect -z random3d_del type=area zcol=gyr
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a HREF="d.erase.html">d.erase</a>,
+<a HREF="d.what.vect.html">d.what.vect</a>,
+<a HREF="d.rast.html">d.rast</a>,
+<a HREF="v.db.addcol.html">v.db.addcol</a>
+<a HREF="v.db.update.html">v.db.update</a><br>
+<a HREF="sql.html">GRASS SQL interface</a>
+</em>
+<h2>AUTHORS</h2>
+CERL<br>
+Radim Blazek, ITC-Irst, Trento, Italy<br>
+other GRASS developers
+<p><i>Last changed: $Date$</i><p>
Deleted: grass/trunk/display/d.vect/description.html
--- grass/trunk/display/d.vect/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.vect/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,107 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>d.vect</em> displays GRASS vector data in the active frame on the graphics
-monitor.
-<h2>NOTES</h2>
-<em>d.vect</em> can simply be used typing <tt><b>d.vect map=</b>vector_map</tt>.
-There are a large variety of optional parameters which allow the user to
-specify vector type, colors, data fields, SQL queries, label size and
-justification, etc.
-<P>
-By default <em>d.vect</em> fills in holes in polygons (islands).
-If you only want to show active areas limit the features with, e.g.,
-"<tt>d.vect cats=1-999999</tt>".
-<P>
-In order to display attributes in the map, <em>display=attr</em> must be
-specified in addition to the column name (<em>attrcol</em> parameter).
-<P>
-Colors may be specified in an attribute table column
-named 'GRASSRGB' (which is a <tt>varchar(11)</tt> column containing <tt>RRR:GGG:BBB</tt> values),
-see the flag <em>-a</em>.
-<P>
-A table for a vector map might look like this:
-echo "select * from testisola" | db.select
-cat|label|GRASSRGB
-0|no data|255:255:255
-90|FRASSILONGO|23:245:67
-104|LEVICO|23:145:67
-139|PERGINE VALSUGANA|223:45:237
-168|SANT'ORSOLA|223:45:67
-190|TENNA|123:45:67
-</pre></div>
-<P>
-To add the GRASSRGB color column, use <em>v.db.addcol</em>:
-v.db.addcol testisola col="GRASSRGB varchar(11)"
-</pre></div>
-<P>
-To add/change a color, use <em>v.db.update</em>:
-v.db.update testisola col=GRASSRGB val="123:45:237" where="cat=139"
-</pre></div>
-<P>
-A much simpler method of color coding is by using the <em>-c</em> flag which
-displays vector elements of like category number with a random color.
-<P>
-This module can use FreeType/TrueType fonts if they have already been selected with
-<em>d.font</em>.
-<h2>EXAMPLES</h2>
-Spearfish examples:
-# display roads with category numbers:
-d.vect roads display=shape,cat lcolor=green
-# display randomly colorized soils map with attributes
-d.vect -c soils disp=attr attrcol=label
-# display randomly colorized selected vectors from soils map
-d.vect -c soils where="label='VBF'" display=shape,attr attrcol=label
-</pre></div>
-<p>
-3D points, 3D lines and 3D polygons colorized according to z height:
-g.region rast=elevation.10m
-r.random elevation.10m n=5000 vector=random3d -d
-d.mon x0
-# display as black points
-d.vect random3d
-# display 3D points colorized according to z height
-d.vect -z random3d zcol=gyr
-# 3D contour lines
-r.contour elevation.10m out=contour20m step=20
-d.vect -z contour20m zcol=gyr
-# generate 3D triangles
-v.delaunay random3d out=random3d_del
-# display 3D polygons colorized according to z height
-d.vect -z random3d_del type=area zcol=gyr
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a HREF="d.erase.html">d.erase</a>,
-<a HREF="d.what.vect.html">d.what.vect</a>,
-<a HREF="d.rast.html">d.rast</a>,
-<a HREF="v.db.addcol.html">v.db.addcol</a>
-<a HREF="v.db.update.html">v.db.update</a><br>
-<a HREF="sql.html">GRASS SQL interface</a>
-</em>
-<h2>AUTHORS</h2>
-CERL<br>
-Radim Blazek, ITC-Irst, Trento, Italy<br>
-other GRASS developers
-<p><i>Last changed: $Date$</i><p>
Copied: grass/trunk/display/d.vect.chart/d.vect.chart.html (from rev 32770, grass/trunk/display/d.vect.chart/description.html)
--- grass/trunk/display/d.vect.chart/d.vect.chart.html (rev 0)
+++ grass/trunk/display/d.vect.chart/d.vect.chart.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,54 @@
+<em>d.vect.chart</em> displays charts for GRASS vector data in the active frame on the graphics
+monitor.
+<h2>NOTES</h2>
+The charts are positioned as follows:
+<ul>
+<li> vector points: on point position
+<li> vector lines: on line centers
+<li> vector areas: on area centroids
+</ul>
+Bar charts are placed with their lower edge starting from the y-coordinate of the feature being symbolized, and centered with respect to the x-coordinate. The <b>-c</b> flag can be used to center the bar chart in both x and y directions.
+<br><br>
+The 'sizecol' parameter is proportionate to the radius.
+<br><br>
+The optional <b>max_ref</b> parameter accepts a list of values that represent the maximum value for each column listed in the values for the parameter <b>columns</b>. These values are used to create a framed bar plot if <b>ctype</b> is <em>bar</em> (See Example 2).
+<h2>EXAMPLES</h2>
+<h3>Example 1</h3>
+d.vect.chart map=vectmap columns=cens51,cens61,cens71,cens81
+</pre></div>
+<h3>Example 2</h3>
+Create framed bar graphs of an erodibiliy index from the SPEARFISH dataset.
+r.to.vect -s -v in=erode.index out=erode_index feature=area
+v.extract in=erode_index out=erode_index_ctrds type=centroid
+d.rast aspect
+d.vect.chart map=erode_index_ctrds ctype=bar columns=cat \
+ size=10 max_ref=12 scale=1.5 colors=yellow
+d.vect erode_index_ctrds icon=basic/circle fcol=black col=black size=5
+</pre></div>
+Example screenshot (zoomed):<br>
+<img src="d.vect.chart_example.jpg" alt="d.vect.chart example">
+<h2>SEE ALSO</h2>
+<em><a HREF="d.erase.html">d.erase</a>,
+<a HREF="d.vect.html">d.vect</a>,
+<a href="d.vect.thematic.html">d.vect.thematic</a>,
+<a HREF="d.rast.html">d.rast</a></em>
+<h2>AUTHOR</h2>
Deleted: grass/trunk/display/d.vect.chart/description.html
--- grass/trunk/display/d.vect.chart/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.vect.chart/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,54 +0,0 @@
-<em>d.vect.chart</em> displays charts for GRASS vector data in the active frame on the graphics
-monitor.
-<h2>NOTES</h2>
-The charts are positioned as follows:
-<ul>
-<li> vector points: on point position
-<li> vector lines: on line centers
-<li> vector areas: on area centroids
-</ul>
-Bar charts are placed with their lower edge starting from the y-coordinate of the feature being symbolized, and centered with respect to the x-coordinate. The <b>-c</b> flag can be used to center the bar chart in both x and y directions.
-<br><br>
-The 'sizecol' parameter is proportionate to the radius.
-<br><br>
-The optional <b>max_ref</b> parameter accepts a list of values that represent the maximum value for each column listed in the values for the parameter <b>columns</b>. These values are used to create a framed bar plot if <b>ctype</b> is <em>bar</em> (See Example 2).
-<h2>EXAMPLES</h2>
-<h3>Example 1</h3>
-d.vect.chart map=vectmap columns=cens51,cens61,cens71,cens81
-</pre></div>
-<h3>Example 2</h3>
-Create framed bar graphs of an erodibiliy index from the SPEARFISH dataset.
-r.to.vect -s -v in=erode.index out=erode_index feature=area
-v.extract in=erode_index out=erode_index_ctrds type=centroid
-d.rast aspect
-d.vect.chart map=erode_index_ctrds ctype=bar columns=cat \
- size=10 max_ref=12 scale=1.5 colors=yellow
-d.vect erode_index_ctrds icon=basic/circle fcol=black col=black size=5
-</pre></div>
-Example screenshot (zoomed):<br>
-<img src="d.vect.chart_example.jpg" alt="d.vect.chart example">
-<h2>SEE ALSO</h2>
-<em><a HREF="d.erase.html">d.erase</a>,
-<a HREF="d.vect.html">d.vect</a>,
-<a href="d.vect.thematic.html">d.vect.thematic</a>,
-<a HREF="d.rast.html">d.rast</a></em>
-<h2>AUTHOR</h2>
Copied: grass/trunk/display/d.what.rast/d.what.rast.html (from rev 32770, grass/trunk/display/d.what.rast/description.html)
--- grass/trunk/display/d.what.rast/d.what.rast.html (rev 0)
+++ grass/trunk/display/d.what.rast/d.what.rast.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,160 @@
+<em>d.what.rast</em> outputs the category values and labels
+associated with cell(s) at user-specified location(s) on
+user-named raster map layer(s).
+<p>
+The program will query the contents of raster map layer(s)
+named by the user on the command line. These map layers
+must exist in the user's current mapset search path. If
+the user does not name any raster map layers on the command
+line, <em>d.what.rast</em> will query the category contents
+of whatever raster map layer is already displayed in the
+active frame on the graphics monitor.
+<p>
+The program activates the mouse, and expects the user to
+indicate the cell location(s) to be queried by depressing a
+mouse button over desired location(s) within the current
+geographic region in the active display frame on the
+graphic monitor.
+<h2>EXAMPLE</h2>
+It is helpful, but not necessary, to first display a map to
+be used for reference in the active display frame before
+running <em>d.what.rast</em>. For example, the user might
+type the following series of commands and receive the
+output below.
+<p>
+<dl>
+<dt><b>d.rast map=</b><em>soils</em>
+<p>
+<dd>To first display the <em>soils</em> map in the active frame.</dd>
+</dl>
+<p>
+<dl>
+<dt><b>d.what.rast map=</b><em>soils,aspect</em><br>
+<p>
+<dd>User then moves the mouse to desired location on the
+displayed <em>soils</em> map layer, and presses the left
+mouse button to query the category contents of the
+<em>soils</em> and <em>aspect</em> maps at this geographic
+location. The program then outputs the below information
+to the user's terminal.</dd>
+</dl>
+<pre>
+617112(E) 3732014(N)
+soils in PERMANENT (44)Nunn clay loam, NdC
+aspect in PERMANENT (20)15 degrees north of west
+</pre>
+<p>
+The first line of output gives the easting (E) and northing (N) coordinates
+of the geographic location at which the user clicked the mouse.
+Subsequent lines give the selected map(s) name and mapset, map category value
+(within parentheses), and map category label corresponding to this
+user-selected map location.
+<p>
+The query may be repeated as often as desired using the
+left mouse button. The right button on the mouse is used
+to quit the <em>d.what.rast</em> session.
+<p>
+Users can set the <b>-t</b> flag to obtain a terse output
+from <em>d.what.rast</em>. This is useful when the user
+wishes output to be parsed by another program (like
+<em>awk</em>). If the <b>-t</b> flag is set, users can also
+select the field separator used (with the
+<b>fs=</b><em>name</em> option), or elect to use the
+default <b>:</b> field separator. In this case, the
+command
+<p>
+<dl>
+<dt><b>d.what.rast -t map=</b><em>soils,aspect</em>
+<p>
+<dd> produces output in the form shown below. The first line of
+output gives the easting, northing, and the mouse button
+return value (see NOTES below). Each
+subsequent line gives the map name and its mapset, the
+category value, and category label of the point specified
+on the user-named raster map layers. The default output
+field separator, a colon, is used since none was specified
+on the command line.</dd>
+</dl>
+<pre>
+617112:3732014:1
+soils at PERMANENT:44:Nunn clay loam, NdC
+aspect at PERMANENT:20:15 degrees north of west
+</pre>
+<p>
+Users can also use this program inside of shell scripts
+that require as input a map category value and a mouse
+button depressed. Users can choose an option to run
+<em>d.what.rast</em> only once, and return only the map
+category value found and the number of the mouse button
+depressed.
+<h2>NOTES</h2></a>
+Mouse button return values are as follows: 0 indicates no
+button was pressed, 1 indicates that the left mouse button
+was pressed, 2 indicates the middle button was pressed, and
+3 indicates that the right mouse button was pressed.
+<p>
+<em>d.what.rast</em> will always print its output to the
+terminal screen. <em>d.what.rast</em> output can be
+redirected into a file; however, if it is, the output will
+go both to the screen and to the file. For example:
+<p>
+<dl>
+<dt><b>d.what.rast map=</b><em>soils,aspect</em><b> > what.out</b>
+<p>
+<dd>will both send <em>d.what.rast</em> output to the screen
+and capture its output in the file named
+<em>what.out</em>.</dd>
+</dl>
+<p>
+The maximum number of raster map layers that can be queried at one time is 15.
+<p>
+<em><a HREF="d.what.vect.html">d.what.vect</a></em>
+allows the user to interactively query the category
+contents of multiple vector map layers at user-specified
+locations.
+<h2>SEE ALSO</h2>
+<em><a HREF="d.rast.html">d.rast</a></em><br>
+<em><a HREF="d.what.vect.html">d.what.vect</a></em><br>
+<em><a HREF="g.region.html">g.region</a></em><br>
+<h2>AUTHOR</h2>
+Michael Shapiro,
Deleted: grass/trunk/display/d.what.rast/description.html
--- grass/trunk/display/d.what.rast/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.what.rast/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,160 +0,0 @@
-<em>d.what.rast</em> outputs the category values and labels
-associated with cell(s) at user-specified location(s) on
-user-named raster map layer(s).
-<p>
-The program will query the contents of raster map layer(s)
-named by the user on the command line. These map layers
-must exist in the user's current mapset search path. If
-the user does not name any raster map layers on the command
-line, <em>d.what.rast</em> will query the category contents
-of whatever raster map layer is already displayed in the
-active frame on the graphics monitor.
-<p>
-The program activates the mouse, and expects the user to
-indicate the cell location(s) to be queried by depressing a
-mouse button over desired location(s) within the current
-geographic region in the active display frame on the
-graphic monitor.
-<h2>EXAMPLE</h2>
-It is helpful, but not necessary, to first display a map to
-be used for reference in the active display frame before
-running <em>d.what.rast</em>. For example, the user might
-type the following series of commands and receive the
-output below.
-<p>
-<dl>
-<dt><b>d.rast map=</b><em>soils</em>
-<p>
-<dd>To first display the <em>soils</em> map in the active frame.</dd>
-</dl>
-<p>
-<dl>
-<dt><b>d.what.rast map=</b><em>soils,aspect</em><br>
-<p>
-<dd>User then moves the mouse to desired location on the
-displayed <em>soils</em> map layer, and presses the left
-mouse button to query the category contents of the
-<em>soils</em> and <em>aspect</em> maps at this geographic
-location. The program then outputs the below information
-to the user's terminal.</dd>
-</dl>
-<pre>
-617112(E) 3732014(N)
-soils in PERMANENT (44)Nunn clay loam, NdC
-aspect in PERMANENT (20)15 degrees north of west
-</pre>
-<p>
-The first line of output gives the easting (E) and northing (N) coordinates
-of the geographic location at which the user clicked the mouse.
-Subsequent lines give the selected map(s) name and mapset, map category value
-(within parentheses), and map category label corresponding to this
-user-selected map location.
-<p>
-The query may be repeated as often as desired using the
-left mouse button. The right button on the mouse is used
-to quit the <em>d.what.rast</em> session.
-<p>
-Users can set the <b>-t</b> flag to obtain a terse output
-from <em>d.what.rast</em>. This is useful when the user
-wishes output to be parsed by another program (like
-<em>awk</em>). If the <b>-t</b> flag is set, users can also
-select the field separator used (with the
-<b>fs=</b><em>name</em> option), or elect to use the
-default <b>:</b> field separator. In this case, the
-command
-<p>
-<dl>
-<dt><b>d.what.rast -t map=</b><em>soils,aspect</em>
-<p>
-<dd> produces output in the form shown below. The first line of
-output gives the easting, northing, and the mouse button
-return value (see NOTES below). Each
-subsequent line gives the map name and its mapset, the
-category value, and category label of the point specified
-on the user-named raster map layers. The default output
-field separator, a colon, is used since none was specified
-on the command line.</dd>
-</dl>
-<pre>
-617112:3732014:1
-soils at PERMANENT:44:Nunn clay loam, NdC
-aspect at PERMANENT:20:15 degrees north of west
-</pre>
-<p>
-Users can also use this program inside of shell scripts
-that require as input a map category value and a mouse
-button depressed. Users can choose an option to run
-<em>d.what.rast</em> only once, and return only the map
-category value found and the number of the mouse button
-depressed.
-<h2>NOTES</h2></a>
-Mouse button return values are as follows: 0 indicates no
-button was pressed, 1 indicates that the left mouse button
-was pressed, 2 indicates the middle button was pressed, and
-3 indicates that the right mouse button was pressed.
-<p>
-<em>d.what.rast</em> will always print its output to the
-terminal screen. <em>d.what.rast</em> output can be
-redirected into a file; however, if it is, the output will
-go both to the screen and to the file. For example:
-<p>
-<dl>
-<dt><b>d.what.rast map=</b><em>soils,aspect</em><b> > what.out</b>
-<p>
-<dd>will both send <em>d.what.rast</em> output to the screen
-and capture its output in the file named
-<em>what.out</em>.</dd>
-</dl>
-<p>
-The maximum number of raster map layers that can be queried at one time is 15.
-<p>
-<em><a HREF="d.what.vect.html">d.what.vect</a></em>
-allows the user to interactively query the category
-contents of multiple vector map layers at user-specified
-locations.
-<h2>SEE ALSO</h2>
-<em><a HREF="d.rast.html">d.rast</a></em><br>
-<em><a HREF="d.what.vect.html">d.what.vect</a></em><br>
-<em><a HREF="g.region.html">g.region</a></em><br>
-<h2>AUTHOR</h2>
-Michael Shapiro,
Copied: grass/trunk/display/d.what.vect/d.what.vect.html (from rev 32770, grass/trunk/display/d.what.vect/description.html)
--- grass/trunk/display/d.what.vect/d.what.vect.html (rev 0)
+++ grass/trunk/display/d.what.vect/d.what.vect.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,57 @@
+<em>d.what.vect</em>
+outputs the category value(s) associated with user-specified location(s)
+in user-specified vector map layer(s).
+<p>
+The program activates the mouse, and expects the user to indicate the
+location(s) to be queried by depressing a mouse button over desired location(s)
+within the current geographic region in the active display frame on the
+graphic monitor. Query results from map(s) are by default displayed in a new
+monitor, where label values can be added or changed. Using parameter <b>-x</b>
+informations will be displayed as plain text to terminal window.
+<h2>EXAMPLE</h2>
+A sample <em>d.what.vect</em> session is given below. Although it is not
+necessary that the user first displays a vector map to be queried in the
+active display frame, it is helpful to have a map displayed there for
+reference.
+<p>
+<b>d.vect map=</b><em>roads</em><p>
+Displays the <em>roads</em> vector map layer on the graphics monitor.
+<p>
+<b>d.what.vect map=</b><em>roads,geology</em><p>
+After typing this, the user moves the mouse to a desired location
+on the displayed <em>roads</em> map layer, and presses the left mouse
+button to query the category value of the <em>roads</em> and the
+<em>geology</em> vector map at this location.
+The program then outputs the category value of a line type corresponding
+to this user-selected map location, for the vector map queried by the user.
+<p>
+The query may be repeated as often as desired using the left mouse button. The
+middle mouse button toggles the flash color.
+The right button on the mouse is used to quit the <em>d.what.vect</em> session.
+<h2>SEE ALSO</h2>
+<em><a HREF="d.vect.html">d.vect</a></em><br>
+<h2>AUTHOR</h2>
+Jim Hinthorne,
+Central Washington University<br>
+Upgrades by Dennis Finch, National Park Service and Radim Blazek, ITC-Irst, Trento, Italy
Deleted: grass/trunk/display/d.what.vect/description.html
--- grass/trunk/display/d.what.vect/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.what.vect/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,57 +0,0 @@
-<em>d.what.vect</em>
-outputs the category value(s) associated with user-specified location(s)
-in user-specified vector map layer(s).
-<p>
-The program activates the mouse, and expects the user to indicate the
-location(s) to be queried by depressing a mouse button over desired location(s)
-within the current geographic region in the active display frame on the
-graphic monitor. Query results from map(s) are by default displayed in a new
-monitor, where label values can be added or changed. Using parameter <b>-x</b>
-informations will be displayed as plain text to terminal window.
-<h2>EXAMPLE</h2>
-A sample <em>d.what.vect</em> session is given below. Although it is not
-necessary that the user first displays a vector map to be queried in the
-active display frame, it is helpful to have a map displayed there for
-reference.
-<p>
-<b>d.vect map=</b><em>roads</em><p>
-Displays the <em>roads</em> vector map layer on the graphics monitor.
-<p>
-<b>d.what.vect map=</b><em>roads,geology</em><p>
-After typing this, the user moves the mouse to a desired location
-on the displayed <em>roads</em> map layer, and presses the left mouse
-button to query the category value of the <em>roads</em> and the
-<em>geology</em> vector map at this location.
-The program then outputs the category value of a line type corresponding
-to this user-selected map location, for the vector map queried by the user.
-<p>
-The query may be repeated as often as desired using the left mouse button. The
-middle mouse button toggles the flash color.
-The right button on the mouse is used to quit the <em>d.what.vect</em> session.
-<h2>SEE ALSO</h2>
-<em><a HREF="d.vect.html">d.vect</a></em><br>
-<em><a HREF="d.what.rast.html">d.what.rast</a></em><br>
-<h2>AUTHOR</h2>
-Jim Hinthorne,
-Central Washington University<br>
-Upgrades by Dennis Finch, National Park Service and Radim Blazek, ITC-Irst, Trento, Italy
Copied: grass/trunk/display/d.where/d.where.html (from rev 32770, grass/trunk/display/d.where/description.html)
--- grass/trunk/display/d.where/d.where.html (rev 0)
+++ grass/trunk/display/d.where/d.where.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,61 @@
+<H2>DESCRIPTION</H2>
+<EM>d.where</EM> is an <EM>interactive</EM> program that
+allows the user, using the pointing device (mouse), to
+identify the geographic coordinates associated with point
+locations within the current geographic region in the
+active display frame on the graphics monitor.
+<P>
+Each mouse click will output the easting and northing of the point
+currently located beneath the mouse pointer.
+A mouse-button menu is presented so the user knows which
+mouse buttons to use. The output is always printed to the
+terminal screen; if the output is redirected into a file,
+it will be written to the file as well.
+<P>
+Mouse buttons:
+<pre>
+ Left: where am i
+ Middle: draw to/from here
+ Right: quit this
+</pre>
+The left mouse button prints the coordinates at the selected point,
+the middle mouse button allows to query two points (they are connected by a
+line for convenience). By using the right mouse button the module is left.
+<H2>NOTES</H2>
+This program uses the current geographic region setting and active frame.
+It is not necessary, although useful, to have displayed a map in the current
+frame before running <EM>d.where</EM>. The <b>-d</b> flag allows the user to
+optionally output latitude/longitude coordinates pair(s) in decimal degree
+rather than DD:MM:SS format. The <b>-w</b> flag is only valid
+if a datum is defined for the current location.
+If the <b>-f</b> flag is given the x,y frame coordinates of the active display
+monitor will be returned (as a percentage, 0,0 is bottom left).
+<H2>SEE ALSO</H2>
+<EM><A HREF="d.what.rast.html">d.what.rast</A></EM><br>
+<EM><A HREF="d.what.vect.html">d.what.vect</A></EM><br>
+<EM><A HREF="g.region.html">g.region</A></EM><br>
+<EM><A HREF="v.what.rast.html">v.what.rast</A></EM><br>
+<EM><A HREF="v.what.vect.html">v.what.vect</A></EM>
+<H2>AUTHORS</H2>
+James Westervelt, <br>
+Michael Shapiro, <BR>
Deleted: grass/trunk/display/d.where/description.html
--- grass/trunk/display/d.where/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.where/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,61 +0,0 @@
-<EM>d.where</EM> is an <EM>interactive</EM> program that
-allows the user, using the pointing device (mouse), to
-identify the geographic coordinates associated with point
-locations within the current geographic region in the
-active display frame on the graphics monitor.
-<P>
-Each mouse click will output the easting and northing of the point
-currently located beneath the mouse pointer.
-A mouse-button menu is presented so the user knows which
-mouse buttons to use. The output is always printed to the
-terminal screen; if the output is redirected into a file,
-it will be written to the file as well.
-<P>
-Mouse buttons:
-<pre>
- Left: where am i
- Middle: draw to/from here
- Right: quit this
-</pre>
-The left mouse button prints the coordinates at the selected point,
-the middle mouse button allows to query two points (they are connected by a
-line for convenience). By using the right mouse button the module is left.
-<H2>NOTES</H2>
-This program uses the current geographic region setting and active frame.
-It is not necessary, although useful, to have displayed a map in the current
-frame before running <EM>d.where</EM>. The <b>-d</b> flag allows the user to
-optionally output latitude/longitude coordinates pair(s) in decimal degree
-rather than DD:MM:SS format. The <b>-w</b> flag is only valid
-if a datum is defined for the current location.
-If the <b>-f</b> flag is given the x,y frame coordinates of the active display
-monitor will be returned (as a percentage, 0,0 is bottom left).
-<H2>SEE ALSO</H2>
-<EM><A HREF="d.what.rast.html">d.what.rast</A></EM><br>
-<EM><A HREF="d.what.vect.html">d.what.vect</A></EM><br>
-<EM><A HREF="g.region.html">g.region</A></EM><br>
-<EM><A HREF="v.what.rast.html">v.what.rast</A></EM><br>
-<EM><A HREF="v.what.vect.html">v.what.vect</A></EM>
-<H2>AUTHORS</H2>
-James Westervelt, <br>
-Michael Shapiro, <BR>
Copied: grass/trunk/display/d.zoom/d.zoom.html (from rev 32770, grass/trunk/display/d.zoom/description.html)
--- grass/trunk/display/d.zoom/d.zoom.html (rev 0)
+++ grass/trunk/display/d.zoom/d.zoom.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,45 @@
+<em>d.zoom</em> allows the user to interactively adjust the settings
+of the current geographic region using a pointing device such as
+a mouse.
+Like <em><a HREF="g.region.html">g.region</a></em>,
+<em>d.zoom</em> re-defines the settings of the geographic
+region. However, <em>d.zoom</em> allows the user to change
+the current region settings interactively, by either
+outlining the new region perimeter with a mouse, unzoom
+or pan the region. The graphics display is updated by the module.
+<p>
+After the user types the command <b>d.zoom</b> a mouse-button menu will appear
+directing the user.
+<p>
+Additionally the region settings can be modified by
+running <em><a HREF="g.region.html">g.region</a></em>.
+<h2>NOTES</h2>
+Although it is not necessary that the user display a map in
+the active display frame before running <em>d.zoom</em>, it
+is helpful to do this for reference. Using parameter <b>-f</b> integrate a
+pan function, <b>-h </b> facilitates the use for handhelds.
+<h2>SEE ALSO</h2>
+<em><a HREF="d.erase.html">d.erase</a></em><br>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+<br>
+Improvements by Huidae Cho and Markus Neteler
Deleted: grass/trunk/display/d.zoom/description.html
--- grass/trunk/display/d.zoom/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/display/d.zoom/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,45 +0,0 @@
-<em>d.zoom</em> allows the user to interactively adjust the settings
-of the current geographic region using a pointing device such as
-a mouse.
-Like <em><a HREF="g.region.html">g.region</a></em>,
-<em>d.zoom</em> re-defines the settings of the geographic
-region. However, <em>d.zoom</em> allows the user to change
-the current region settings interactively, by either
-outlining the new region perimeter with a mouse, unzoom
-or pan the region. The graphics display is updated by the module.
-<p>
-After the user types the command <b>d.zoom</b> a mouse-button menu will appear
-directing the user.
-<p>
-Additionally the region settings can be modified by
-running <em><a HREF="g.region.html">g.region</a></em>.
-<h2>NOTES</h2>
-Although it is not necessary that the user display a map in
-the active display frame before running <em>d.zoom</em>, it
-is helpful to do this for reference. Using parameter <b>-f</b> integrate a
-pan function, <b>-h </b> facilitates the use for handhelds.
-<h2>SEE ALSO</h2>
-<em><a HREF="d.erase.html">d.erase</a></em><br>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-<br>
-Improvements by Huidae Cho and Markus Neteler
Deleted: grass/trunk/doc/raster/r.example/description.html
--- grass/trunk/doc/raster/r.example/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/doc/raster/r.example/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,18 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>r.example</EM> does practically do nothing, except
-for illustrating GRASS raster programming. It copies
-over an existing raster map to a new raster map.
-See the source code for details.
-<H2>SEE ALSO</H2>
-<EM><A HREF="r.stats.html">r.stats</A></EM><br>
-<EM><A HREF="http://grass.itc.it/devel/index.php#prog">GRASS Programmer's Manual</A></EM>
-<H2>AUTHOR</H2>
-GRASS Development Team
Copied: grass/trunk/doc/raster/r.example/r.example.html (from rev 32770, grass/trunk/doc/raster/r.example/description.html)
--- grass/trunk/doc/raster/r.example/r.example.html (rev 0)
+++ grass/trunk/doc/raster/r.example/r.example.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,18 @@
+<EM>r.example</EM> does practically do nothing, except
+for illustrating GRASS raster programming. It copies
+over an existing raster map to a new raster map.
+See the source code for details.
+<H2>SEE ALSO</H2>
+<EM><A HREF="r.stats.html">r.stats</A></EM><br>
+<EM><A HREF="http://grass.itc.it/devel/index.php#prog">GRASS Programmer's Manual</A></EM>
+<H2>AUTHOR</H2>
+GRASS Development Team
Deleted: grass/trunk/doc/vector/v.example/description.html
--- grass/trunk/doc/vector/v.example/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/doc/vector/v.example/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,21 +0,0 @@
-<em>v.example</em> is an example vector module that does something like
-labeling all vectors with value 1. A new map is written instead of updating
-the input map.
-<h2>EXAMPLE</h2>
-v.example input=map output=newmap
-</pre></div>
-<H2>SEE ALSO</H2>
-<h2>AUTHOR</h2>
-Radim Blazek, ITC-irst, Trento, Italy
Copied: grass/trunk/doc/vector/v.example/v.example.html (from rev 32770, grass/trunk/doc/vector/v.example/description.html)
--- grass/trunk/doc/vector/v.example/v.example.html (rev 0)
+++ grass/trunk/doc/vector/v.example/v.example.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,21 @@
+<em>v.example</em> is an example vector module that does something like
+labeling all vectors with value 1. A new map is written instead of updating
+the input map.
+<h2>EXAMPLE</h2>
+v.example input=map output=newmap
+</pre></div>
+<H2>SEE ALSO</H2>
+<h2>AUTHOR</h2>
+Radim Blazek, ITC-irst, Trento, Italy
Deleted: grass/trunk/general/g.access/description.html
--- grass/trunk/general/g.access/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.access/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,46 +0,0 @@
-This program allows the user to control access to the
-current mapset. Normally, any user can read data from any
-GRASS mapset. But sometimes it is desirable to prohibit
-access to certain sensitive data. The <EM>g.access</EM>
-command allows a user to restrict read and execute access
-to the current mapset (see UNIX <EM>chmod</EM> command).
-<EM>g.access</EM> will not modify write access to the
-current mapset.
-<P>
-The user may, for example, allow only users in the same
-UNIX group to read data files in the mapset, or restrict
-the mapset to personal use only.
-<H2>NOTES</H2>
-<P> Under GRASS, access to the mapset PERMANENT must be open to
-all users. This is because GRASS looks for the user's default geographic
-region definition settings and the location TITLE in files that are stored
-under the PERMANENT mapset directory. The <EM>g.access</EM> command,
-therefore, will not allow you to restrict access to the PERMANENT mapset.
-<P>
-The <EM><A HREF="g.mapsets.html">g.mapsets</A></EM> command isn't smart
-enough to tell if access to a specified mapset is restricted, and the user
-is therefore allowed to include the names of restricted mapsets in his
-search path. However, the data in a restricted mapset is still protected;
-any attempts to look for or use data in a restricted mapset will fail. The
-user will simply not see any data listed for a restricted mapset.
-<H2>SEE ALSO</H2>
-UNIX manual entries for <EM>chmod</EM> and <EM>group</EM>
-<BR>
-<EM><A HREF="g.mapsets.html">g.mapsets</A></EM>
-<H2>AUTHOR</H2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/general/g.access/g.access.html (from rev 32770, grass/trunk/general/g.access/description.html)
--- grass/trunk/general/g.access/g.access.html (rev 0)
+++ grass/trunk/general/g.access/g.access.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,46 @@
+This program allows the user to control access to the
+current mapset. Normally, any user can read data from any
+GRASS mapset. But sometimes it is desirable to prohibit
+access to certain sensitive data. The <EM>g.access</EM>
+command allows a user to restrict read and execute access
+to the current mapset (see UNIX <EM>chmod</EM> command).
+<EM>g.access</EM> will not modify write access to the
+current mapset.
+<P>
+The user may, for example, allow only users in the same
+UNIX group to read data files in the mapset, or restrict
+the mapset to personal use only.
+<H2>NOTES</H2>
+<P> Under GRASS, access to the mapset PERMANENT must be open to
+all users. This is because GRASS looks for the user's default geographic
+region definition settings and the location TITLE in files that are stored
+under the PERMANENT mapset directory. The <EM>g.access</EM> command,
+therefore, will not allow you to restrict access to the PERMANENT mapset.
+<P>
+The <EM><A HREF="g.mapsets.html">g.mapsets</A></EM> command isn't smart
+enough to tell if access to a specified mapset is restricted, and the user
+is therefore allowed to include the names of restricted mapsets in his
+search path. However, the data in a restricted mapset is still protected;
+any attempts to look for or use data in a restricted mapset will fail. The
+user will simply not see any data listed for a restricted mapset.
+<H2>SEE ALSO</H2>
+UNIX manual entries for <EM>chmod</EM> and <EM>group</EM>
+<BR>
+<EM><A HREF="g.mapsets.html">g.mapsets</A></EM>
+<H2>AUTHOR</H2>
+Michael Shapiro,
+U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/general/g.dirseps/description.html
--- grass/trunk/general/g.dirseps/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.dirseps/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,11 +0,0 @@
-<EM>g.dirseps</EM> is an internal tool only. It copies input string
-to stdout, changing directory separator characters as specified by flags.
-It is used for interoperability between Unix and MS-Windows pathnames.
-<H2>AUTHOR</H2>
-Paul Kelly
Copied: grass/trunk/general/g.dirseps/g.dirseps.html (from rev 32770, grass/trunk/general/g.dirseps/description.html)
--- grass/trunk/general/g.dirseps/g.dirseps.html (rev 0)
+++ grass/trunk/general/g.dirseps/g.dirseps.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,11 @@
+<EM>g.dirseps</EM> is an internal tool only. It copies input string
+to stdout, changing directory separator characters as specified by flags.
+It is used for interoperability between Unix and MS-Windows pathnames.
+<H2>AUTHOR</H2>
+Paul Kelly
Deleted: grass/trunk/general/g.filename/description.html
--- grass/trunk/general/g.filename/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.filename/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,93 +0,0 @@
-<em>g.filename</em> is designed for Bourne shell scripts that need to know
-the full file name, including it's path, for mapset elements, like raster,
-vector and site maps, region definitions and imagery groups.
-<p>
-The list of element names to search for is not fixed; any subdirectory of the
-mapset directory is a valid element name.
-<p>
-However, the user can find the list of standard GRASS element names in
-the file $GISBASE/etc/element_list. This is the file which
-g.remove/g.rename/g.copy use to determine which files need to be
-deleted/renamed/copied for a given entity type.
-<!-- unused
-<H2>OPTIONS</H2>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>element=</B><EM>name</EM>
-<DD>The name of a GRASS data base element (i.e., directory
-within the GRASS mapset location).
-<DT><B>mapset=</B><EM>name</EM>
-<DD>The name of a GRASS data base mapset. As a
-convenience, a single dot (.) can be used to designate the
-current mapset.
-<DT><B>file=</B><EM>name</EM>
-<DD>The name of a GRASS data base file.
-</DL>
-<H2>OUTPUT</H2>
-<EM>g.filename</EM>
-writes one line to standard output:
-<DL>
-<DD>
-file='<EM>full_file_pathname'</EM>
-</DL>
-The output is a <EM>/bin/sh</EM> command to set the
-variable specified by the file <EM>name</EM> to the full
-UNIX path name for the data base file. This variable may
-be set in the <EM>/bin/sh</EM> as follows:
-<DL>
-<DD>
-eval `g.filename element=<em>name</em> mapset=<em>name</em> file=<em>name</em>`
-</pre></div>
-</DL>
-<H2>NOTES</H2>
-This routine generates the filename, but does not care if the file (or mapset
-or element) exists or not. This feature allows shell scripts to create new data
-base files as well as use existing ones.
-<P>
-If the mapset is the current mapset, <EM>g.filename</EM>
-automatically creates the <EM>element</EM> specified if it
-doesn't already exist. This makes it easy to add new files
-to the data base without having to worry about the
-existence of the required data base directories. (This
-program will not create a new mapset, however, if that
-specified does not currently exist.)
-<P>
-The program exits with a 0 if everything is ok; it exits
-with a non-zero value if there is an error, in which case
-file=<EM>'full_file_pathname'</EM> is not output.
-<H2>SEE ALSO</H2>
-<EM><A HREF="g.ask.html">g.ask</A></EM><br>
-<EM><A HREF="g.findfile.html">g.findfile</A></EM><br>
-<EM><A HREF="g.gisenv.html">g.gisenv</A></EM><br>
-<EM><A HREF="parser.html">parser</A></EM>
-<H2>AUTHOR</H2>
-Michael Shapiro,
-U.S.Army Construction Engineering Research Laboratory
Copied: grass/trunk/general/g.filename/g.filename.html (from rev 32770, grass/trunk/general/g.filename/description.html)
--- grass/trunk/general/g.filename/g.filename.html (rev 0)
+++ grass/trunk/general/g.filename/g.filename.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,93 @@
+<em>g.filename</em> is designed for Bourne shell scripts that need to know
+the full file name, including it's path, for mapset elements, like raster,
+vector and site maps, region definitions and imagery groups.
+<p>
+The list of element names to search for is not fixed; any subdirectory of the
+mapset directory is a valid element name.
+<p>
+However, the user can find the list of standard GRASS element names in
+the file $GISBASE/etc/element_list. This is the file which
+g.remove/g.rename/g.copy use to determine which files need to be
+deleted/renamed/copied for a given entity type.
+<!-- unused
+<H2>OPTIONS</H2>
+<H3>Parameters:</H3>
+<DL>
+<DT><B>element=</B><EM>name</EM>
+<DD>The name of a GRASS data base element (i.e., directory
+within the GRASS mapset location).
+<DT><B>mapset=</B><EM>name</EM>
+<DD>The name of a GRASS data base mapset. As a
+convenience, a single dot (.) can be used to designate the
+current mapset.
+<DT><B>file=</B><EM>name</EM>
+<DD>The name of a GRASS data base file.
+</DL>
+<H2>OUTPUT</H2>
+<EM>g.filename</EM>
+writes one line to standard output:
+<DL>
+<DD>
+file='<EM>full_file_pathname'</EM>
+</DL>
+The output is a <EM>/bin/sh</EM> command to set the
+variable specified by the file <EM>name</EM> to the full
+UNIX path name for the data base file. This variable may
+be set in the <EM>/bin/sh</EM> as follows:
+<DL>
+<DD>
+eval `g.filename element=<em>name</em> mapset=<em>name</em> file=<em>name</em>`
+</pre></div>
+</DL>
+<H2>NOTES</H2>
+This routine generates the filename, but does not care if the file (or mapset
+or element) exists or not. This feature allows shell scripts to create new data
+base files as well as use existing ones.
+<P>
+If the mapset is the current mapset, <EM>g.filename</EM>
+automatically creates the <EM>element</EM> specified if it
+doesn't already exist. This makes it easy to add new files
+to the data base without having to worry about the
+existence of the required data base directories. (This
+program will not create a new mapset, however, if that
+specified does not currently exist.)
+<P>
+The program exits with a 0 if everything is ok; it exits
+with a non-zero value if there is an error, in which case
+file=<EM>'full_file_pathname'</EM> is not output.
+<H2>SEE ALSO</H2>
+<EM><A HREF="g.ask.html">g.ask</A></EM><br>
+<EM><A HREF="g.findfile.html">g.findfile</A></EM><br>
+<EM><A HREF="g.gisenv.html">g.gisenv</A></EM><br>
+<EM><A HREF="parser.html">parser</A></EM>
+<H2>AUTHOR</H2>
+Michael Shapiro,
+U.S.Army Construction Engineering Research Laboratory
Deleted: grass/trunk/general/g.findetc/description.html
--- grass/trunk/general/g.findetc/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.findetc/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,27 +0,0 @@
-<EM>g.findetc</EM> is designed for Bourne shell scripts that need to search
-for support data, programs and subfoldrs in any number of directories as
-specified in GRASS_ADDON_ETC, plus the GRASS application etc/ directory. This
-is designed for addon scripts that are installed outside the GRASS application
-directory, such as a user's home or a system addon directory.
-<p>
-<H2>OUTPUT</H2>
-<EM>g.findetc</EM> writes the full path to the file or directory to standard output
-<H2>SEE ALSO</H2>
-<EM><A HREF="g.filename.html">g.filename</A></EM><br>
-<EM><A HREF="g.mapsets.html">g.mapsets</A></EM><br>
-<H2>AUTHOR</H2>
-William Kyngesburye
Copied: grass/trunk/general/g.findetc/g.findetc.html (from rev 32770, grass/trunk/general/g.findetc/description.html)
--- grass/trunk/general/g.findetc/g.findetc.html (rev 0)
+++ grass/trunk/general/g.findetc/g.findetc.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,27 @@
+<EM>g.findetc</EM> is designed for Bourne shell scripts that need to search
+for support data, programs and subfoldrs in any number of directories as
+specified in GRASS_ADDON_ETC, plus the GRASS application etc/ directory. This
+is designed for addon scripts that are installed outside the GRASS application
+directory, such as a user's home or a system addon directory.
+<p>
+<H2>OUTPUT</H2>
+<EM>g.findetc</EM> writes the full path to the file or directory to standard output
+<H2>SEE ALSO</H2>
+<EM><A HREF="g.filename.html">g.filename</A></EM><br>
+<EM><A HREF="g.mapsets.html">g.mapsets</A></EM><br>
+<H2>AUTHOR</H2>
+William Kyngesburye
Deleted: grass/trunk/general/g.findfile/description.html
--- grass/trunk/general/g.findfile/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.findfile/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,108 +0,0 @@
-<EM>g.findfile</EM> is designed for Bourne shell scripts that need to search
-for mapset <em>elements</em>, including: raster, vector maps, region
-definitions and <em><a HREF="i.group.html">imagery</a></em> groups.
-<p>
-The list of <em>element</em> names to search for is not fixed; any
-subdirectory of the mapset directory is a valid <em>element</em> name.
-<p>
-However, the user can find the list of standard GRASS <em>element</em> names in
-<!-- unused
-<H2>OPTIONS</H2>
-<DL>
-<DD>The data base element (i.e., directory within a GRASS
-mapset) to be searched.
-<DD>The mapset in which to search for the specified file
-<EM>name</EM>. If not specified, all mapsets in the user's
-GRASS search path are searched. Otherwise, the specified
-mapset is searched. As a convenience, if specified as a
-single dot (.) only the current mapset is searched.
-<DD>The name of a GRASS data file (of the stated
-<EM>element</EM> type) for which to search.
-</DL>
-<H2>OUTPUT</H2>
-<EM>g.findfile</EM> writes four lines to standard output:
-name='<EM>file_name</EM>'
-mapset='<EM>mapset_name</EM>'
-file='<EM>unix_filename</EM>'
-fullname='<EM>grass_fullname</EM>'
-</pre></div>
-The output is <EM>/bin/sh</EM> commands to set the variable
-<EM>name</EM> to the GRASS data base file name,
-<EM>mapset</EM> to the mapset in which the file resides,
-and <EM>file</EM> to the full UNIX path name for the named
-file. These variables may be set in the <EM>/bin/sh</EM>
-as follows:
-eval `g.findfile element=name mapset=name file=name`
-</pre></div>
-<P>
-For example (raster map):
-eval `g.findfile element=cell file=mymap`
-</pre></div>
-<H2>NOTES</H2>
-If the specified file does not exist, the variables will be set as follows:
-name=
-mapset=
-fullname=
-file=
-</pre></div>
-The following is a way to test for this case:
-<div class="code">
-<PRE>
-if [ ! "$file" ]
-then
- exit
-fi
-</PRE>
-</DIV>
-Note that region files are searched as <em>element=windows</em>.
-<H2>SEE ALSO</H2>
-<H2>AUTHOR</H2>
-Michael Shapiro,
Copied: grass/trunk/general/g.findfile/g.findfile.html (from rev 32770, grass/trunk/general/g.findfile/description.html)
--- grass/trunk/general/g.findfile/g.findfile.html (rev 0)
+++ grass/trunk/general/g.findfile/g.findfile.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,108 @@
+<EM>g.findfile</EM> is designed for Bourne shell scripts that need to search
+for mapset <em>elements</em>, including: raster, vector maps, region
+definitions and <em><a HREF="i.group.html">imagery</a></em> groups.
+<p>
+The list of <em>element</em> names to search for is not fixed; any
+subdirectory of the mapset directory is a valid <em>element</em> name.
+<p>
+However, the user can find the list of standard GRASS <em>element</em> names in
+<!-- unused
+<H2>OPTIONS</H2>
+<DL>
+<DD>The data base element (i.e., directory within a GRASS
+mapset) to be searched.
+<DD>The mapset in which to search for the specified file
+<EM>name</EM>. If not specified, all mapsets in the user's
+GRASS search path are searched. Otherwise, the specified
+mapset is searched. As a convenience, if specified as a
+single dot (.) only the current mapset is searched.
+<DD>The name of a GRASS data file (of the stated
+<EM>element</EM> type) for which to search.
+</DL>
+<H2>OUTPUT</H2>
+<EM>g.findfile</EM> writes four lines to standard output:
+name='<EM>file_name</EM>'
+mapset='<EM>mapset_name</EM>'
+file='<EM>unix_filename</EM>'
+fullname='<EM>grass_fullname</EM>'
+</pre></div>
+The output is <EM>/bin/sh</EM> commands to set the variable
+<EM>name</EM> to the GRASS data base file name,
+<EM>mapset</EM> to the mapset in which the file resides,
+and <EM>file</EM> to the full UNIX path name for the named
+file. These variables may be set in the <EM>/bin/sh</EM>
+as follows:
+eval `g.findfile element=name mapset=name file=name`
+</pre></div>
+<P>
+For example (raster map):
+eval `g.findfile element=cell file=mymap`
+</pre></div>
+<H2>NOTES</H2>
+If the specified file does not exist, the variables will be set as follows:
+name=
+mapset=
+fullname=
+file=
+</pre></div>
+The following is a way to test for this case:
+<div class="code">
+<PRE>
+if [ ! "$file" ]
+then
+ exit
+fi
+</PRE>
+</DIV>
+Note that region files are searched as <em>element=windows</em>.
+<H2>SEE ALSO</H2>
+<H2>AUTHOR</H2>
+Michael Shapiro,
Deleted: grass/trunk/general/g.gisenv/description.html
--- grass/trunk/general/g.gisenv/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.gisenv/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,208 +0,0 @@
-When a user runs GRASS, certain variables are set
-specifying the GRASS data base, location, mapset,
-peripheral device drivers, etc., being used in the current
-GRASS session. These variable name settings are recognized
-as long as the user is running a GRASS session.
-<h2>OPTIONS</h2>
-No prompts are given to the user when running
-<em>g.gisenv</em>. If run without arguments,
-<em>g.gisenv</em> lists all of the user's current GRASS
-variable settings. Results are sent to standard output,
-and may look like this:
-GISDBASE=/usr/grass5/data
-LOCATION_NAME=spearfish
-MAPSET=PERMANENT
-</pre></div>
-In this example, the full path name of the user's current
-location (i.e., <kbd>$LOCATION_NAME</kbd>) is
-<kbd>/usr/grass5/data/spearfish</kbd>, and the full path
-name of the user's current mapset (i.e.,
-<kbd>$MAPSET</kbd>) is
-<kbd>/usr/grass5/data/spearfish/PERMANENT</kbd>.
-<p>
-If the user specifies a <em>variable_name</em> on the
-command line (e.g., <b>g.gisenv MAPSET</b>), only the value
-for that particular GRASS variable is output to standard
-output. Possible variable names depend on the user's
-system, see <a href=variables.html>variables list</a> for details.
-<p>
-While other variables may be associated with each GRASS session
-(e.g., DIGITIZER, PAINTER, DISPLAY, and other variables), those stated
-below are essential.
-<dl>
-<dt><em>GISDBASE</em>
-<dd>The <kbd>$GISDBASE</kbd> is a directory in which all
-users' GRASS data are stored. Within the
-<kbd>$GISDBASE</kbd>, data are segregated into
-subdirectories (called "locations") based on the map
-coordinate system used and the geographic extent of the
-data. Each "location" directory itself contains
-subdirectories called "mapsets"; each "mapset" stores "data
-base elements" -- the directories (e.g., the
-<kbd>cell</kbd>, <kbd>cellhd</kbd>, <kbd>dig</kbd>, etc.,
-directories) in which GRASS data files are actually
-stored.
-<dt><em>LOCATION_NAME</em>
-<dd>The user must choose to work with the data under a single
-GRASS location within any given GRASS session; this
-location is then called the <em>current GRASS
-location</em>, and is specified by the variable
-<kbd>$LOCATION_NAME</kbd>. The <kbd>$LOCATION_NAME</kbd>
-is the GRASS data base location whose data will be affected
-by any GRASS commands issued during the user's current
-GRASS session, and is a subdirectory of the current
-<kbd>$GISDBASE</kbd>. Each "location" directory can
-contain multiple "mapset" directories (including the
-special mapset <kbd>PERMANENT</kbd>). Maps stored under
-the same GRASS <kbd>LOCATION_NAME</kbd> (and/or within the
-same <kbd>MAPSET</kbd>) must use the same coordinate system
-and typically fall within the boundaries of the same
-geographic region (aka, "location").
-<dt><em>MAPSET</em>
-<dd>Each "mapset" contains a set of maps relevant to the
-<kbd>LOCATION_NAME</kbd> directory in which it appears.
-Each <kbd>LOCATION_NAME</kbd> can contain multiple
-mapsets. (Mapsets which fall under the same
-<kbd>LOCATION_NAME</kbd> all contain data geographically
-relevant to the <kbd>LOCATION_NAME</kbd>, and all store
-data in the same map coordinate system. Frequently, maps
-are placed into different mapsets to distinguish file
-ownership -- e.g., each user might have his own mapset,
-storing any maps that he has created and/or are relevant to
-his work.) During each GRASS session, the user must choose
-one mapset to be the <em>current mapset</em>; the current
-mapset setting is given by <kbd>$MAPSET</kbd>, and is a
-subdirectory of <kbd>$LOCATION_NAME</kbd>. During a single
-GRASS session, the user can use available data in any of
-the mapsets stored under the current
-<kbd>LOCATION_NAME</kbd> directory that are in the user's
-mapset search path and accessible by the user. However,
-within a single GRASS session, the user only has
-<em>write</em> access to data stored under the <em>current
-mapset</em> (specified by the variable
-<kbd>$MAPSET</kbd>).
-<p>
-Each "mapset" stores GRASS data base elements (i.e., the
-directories in which GRASS data files are stored). Any
-maps created or modified by the user in the current GRASS
-session will be stored here. The <kbd>MAPSET</kbd>
-directory <kbd>PERMANENT</kbd> is generally reserved for
-the set of maps that form the base set for all users
-working under each <kbd>LOCATION_NAME</kbd>.
-</dl>
-Once within a GRASS session, GRASS users have access only
-to the data under a single GRASS data base directory (the
-<em>current GRASS data base</em>, specified by the variable
-<kbd>$GISDBASE</kbd>), and to a single GRASS location
-directory (the <em>current location</em>, specified by the
-variable <kbd>$LOCATION_NAME</kbd>). Within a single
-session, the user may only <em>modify</em> the data in the
-<em>current mapset</em> (specified by the variable
-<kbd>$MAPSET</kbd>), but may <em>use</em> data available
-under other mapsets under the same
-<kbd>LOCATION_NAME</kbd>.
-<p>
-All of these names must be legal names on the user's
-current system. For UNIX users, names less than 14
-characters and containing no non-printing or space codes
-are permissible. Examples of permissible names include:
-<em>one</em>, <em>mymap</em>, <em>VeGe_map</em>, and
-<em>1_for_me</em>. The underscore character can safely be
-used in place of a blank for multiple-word names.
-<h2>NOTES</h2>
-The output from
-<em>g.gisenv</em>
-when invoked without arguments is directly usable by /bin/sh.
-The following command will cast each variable into the UNIX environment:
-<p>
-<div class="code"><pre>
-<b>eval `g.gisenv`</b>
-</pre></div>
-<p>
-This works only for <em>/bin/sh</em>. The format of the
-output is not compatible with other UNIX shells.
-<h3>GRASS Debugging:</h3>
-To print debugging messages, the variable DEBUG must be set to level equal or
-greater than 0:
-<P>
-<TT>g.gisenv set="DEBUG=3"</TT>
-</pre></div>
-<P>
-Levels: (recommended levels)
-<ul>
-<li> 0 - silence
-<li> 1 - message is printed once or few times per module
-<li> 3 - each row (raster) or line (vector)
-<li> 5 - each cell (raster) or point (vector)
-</ul>
-To disable debugging messages, DEBUG must be set back to 0:
-<P>
-<TT>g.gisenv set="DEBUG=0"</TT>
-</pre></div>
-<P>
-<h2>SEE ALSO</h2>
-<em><a HREF="g.access.html">g.access</a></em><br>
-<em><a HREF="g.ask.html">g.ask</a></em><br>
-<em><a HREF="g.filename.html">g.filename</a></em><br>
-<em><a HREF="g.findfile.html">g.findfile</a></em><br>
-<em><a HREF="g.mapsets.html">g.mapsets</a></em><br>
-<em><a href="variables.html">variables list</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
Copied: grass/trunk/general/g.gisenv/g.gisenv.html (from rev 32770, grass/trunk/general/g.gisenv/description.html)
--- grass/trunk/general/g.gisenv/g.gisenv.html (rev 0)
+++ grass/trunk/general/g.gisenv/g.gisenv.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,208 @@
+When a user runs GRASS, certain variables are set
+specifying the GRASS data base, location, mapset,
+peripheral device drivers, etc., being used in the current
+GRASS session. These variable name settings are recognized
+as long as the user is running a GRASS session.
+<h2>OPTIONS</h2>
+No prompts are given to the user when running
+<em>g.gisenv</em>. If run without arguments,
+<em>g.gisenv</em> lists all of the user's current GRASS
+variable settings. Results are sent to standard output,
+and may look like this:
+<div class="code"><pre>
+GISDBASE=/usr/grass5/data
+LOCATION_NAME=spearfish
+MAPSET=PERMANENT
+</pre></div>
+In this example, the full path name of the user's current
+location (i.e., <kbd>$LOCATION_NAME</kbd>) is
+<kbd>/usr/grass5/data/spearfish</kbd>, and the full path
+name of the user's current mapset (i.e.,
+<kbd>$MAPSET</kbd>) is
+<kbd>/usr/grass5/data/spearfish/PERMANENT</kbd>.
+<p>
+If the user specifies a <em>variable_name</em> on the
+command line (e.g., <b>g.gisenv MAPSET</b>), only the value
+for that particular GRASS variable is output to standard
+output. Possible variable names depend on the user's
+system, see <a href=variables.html>variables list</a> for details.
+<p>
+While other variables may be associated with each GRASS session
+(e.g., DIGITIZER, PAINTER, DISPLAY, and other variables), those stated
+below are essential.
+<dl>
+<dt><em>GISDBASE</em>
+<dd>The <kbd>$GISDBASE</kbd> is a directory in which all
+users' GRASS data are stored. Within the
+<kbd>$GISDBASE</kbd>, data are segregated into
+subdirectories (called "locations") based on the map
+coordinate system used and the geographic extent of the
+data. Each "location" directory itself contains
+subdirectories called "mapsets"; each "mapset" stores "data
+base elements" -- the directories (e.g., the
+<kbd>cell</kbd>, <kbd>cellhd</kbd>, <kbd>dig</kbd>, etc.,
+directories) in which GRASS data files are actually
+stored.
+<dt><em>LOCATION_NAME</em>
+<dd>The user must choose to work with the data under a single
+GRASS location within any given GRASS session; this
+location is then called the <em>current GRASS
+location</em>, and is specified by the variable
+<kbd>$LOCATION_NAME</kbd>. The <kbd>$LOCATION_NAME</kbd>
+is the GRASS data base location whose data will be affected
+by any GRASS commands issued during the user's current
+GRASS session, and is a subdirectory of the current
+<kbd>$GISDBASE</kbd>. Each "location" directory can
+contain multiple "mapset" directories (including the
+special mapset <kbd>PERMANENT</kbd>). Maps stored under
+the same GRASS <kbd>LOCATION_NAME</kbd> (and/or within the
+same <kbd>MAPSET</kbd>) must use the same coordinate system
+and typically fall within the boundaries of the same
+geographic region (aka, "location").
+<dt><em>MAPSET</em>
+<dd>Each "mapset" contains a set of maps relevant to the
+<kbd>LOCATION_NAME</kbd> directory in which it appears.
+Each <kbd>LOCATION_NAME</kbd> can contain multiple
+mapsets. (Mapsets which fall under the same
+<kbd>LOCATION_NAME</kbd> all contain data geographically
+relevant to the <kbd>LOCATION_NAME</kbd>, and all store
+data in the same map coordinate system. Frequently, maps
+are placed into different mapsets to distinguish file
+ownership -- e.g., each user might have his own mapset,
+storing any maps that he has created and/or are relevant to
+his work.) During each GRASS session, the user must choose
+one mapset to be the <em>current mapset</em>; the current
+mapset setting is given by <kbd>$MAPSET</kbd>, and is a
+subdirectory of <kbd>$LOCATION_NAME</kbd>. During a single
+GRASS session, the user can use available data in any of
+the mapsets stored under the current
+<kbd>LOCATION_NAME</kbd> directory that are in the user's
+mapset search path and accessible by the user. However,
+within a single GRASS session, the user only has
+<em>write</em> access to data stored under the <em>current
+mapset</em> (specified by the variable
+<kbd>$MAPSET</kbd>).
+<p>
+Each "mapset" stores GRASS data base elements (i.e., the
+directories in which GRASS data files are stored). Any
+maps created or modified by the user in the current GRASS
+session will be stored here. The <kbd>MAPSET</kbd>
+directory <kbd>PERMANENT</kbd> is generally reserved for
+the set of maps that form the base set for all users
+working under each <kbd>LOCATION_NAME</kbd>.
+</dl>
+Once within a GRASS session, GRASS users have access only
+to the data under a single GRASS data base directory (the
+<em>current GRASS data base</em>, specified by the variable
+<kbd>$GISDBASE</kbd>), and to a single GRASS location
+directory (the <em>current location</em>, specified by the
+variable <kbd>$LOCATION_NAME</kbd>). Within a single
+session, the user may only <em>modify</em> the data in the
+<em>current mapset</em> (specified by the variable
+<kbd>$MAPSET</kbd>), but may <em>use</em> data available
+under other mapsets under the same
+<kbd>LOCATION_NAME</kbd>.
+<p>
+All of these names must be legal names on the user's
+current system. For UNIX users, names less than 14
+characters and containing no non-printing or space codes
+are permissible. Examples of permissible names include:
+<em>one</em>, <em>mymap</em>, <em>VeGe_map</em>, and
+<em>1_for_me</em>. The underscore character can safely be
+used in place of a blank for multiple-word names.
+<h2>NOTES</h2>
+The output from
+<em>g.gisenv</em>
+when invoked without arguments is directly usable by /bin/sh.
+The following command will cast each variable into the UNIX environment:
+<p>
+<b>eval `g.gisenv`</b>
+</pre></div>
+<p>
+This works only for <em>/bin/sh</em>. The format of the
+output is not compatible with other UNIX shells.
+<h3>GRASS Debugging:</h3>
+To print debugging messages, the variable DEBUG must be set to level equal or
+greater than 0:
+<P>
+<TT>g.gisenv set="DEBUG=3"</TT>
+</pre></div>
+<P>
+Levels: (recommended levels)
+<ul>
+<li> 0 - silence
+<li> 1 - message is printed once or few times per module
+<li> 3 - each row (raster) or line (vector)
+<li> 5 - each cell (raster) or point (vector)
+</ul>
+To disable debugging messages, DEBUG must be set back to 0:
+<P>
+<TT>g.gisenv set="DEBUG=0"</TT>
+</pre></div>
+<P>
+<h2>SEE ALSO</h2>
+<em><a HREF="g.access.html">g.access</a></em><br>
+<em><a HREF="g.ask.html">g.ask</a></em><br>
+<em><a HREF="g.filename.html">g.filename</a></em><br>
+<em><a HREF="g.findfile.html">g.findfile</a></em><br>
+<em><a HREF="g.mapsets.html">g.mapsets</a></em><br>
+<em><a href="variables.html">variables list</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/general/g.gui/description.html
--- grass/trunk/general/g.gui/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.gui/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,53 +0,0 @@
-<h2>DESCRIPTION</h2>
-<p>
-This program allows user to start a selected graphical user interface (GUI)
-from the command line prompt.
-<p>
-Currently three different GUIs are supported:
-<ul>
-<li><b>tcltk</b> - Current Tcl/Tk based GUI aka the <em>gis.m</em>
- <a href="gis.m.html">GIS Manager</a></li>
-<li><b>oldtcltk</b> - Old Tcl/Tk based GUI aka the <em>d.m</em>
- <a href="d.m.html">Display Manager</a></li>
-<li><b>wxpython</b> - New wxPython based GUI aka
- <a href="wxGUI.html">wxGUI</a></li>
-</ul>
-If the <b>-u</b> update flag is given or the <em>g.gisenv</em>
-<tt>GRASS_GUI</tt> variable is missing, then the <tt>GRASS_GUI</tt>
-variable is permanently changed and the selected GUI will be used
-as the default UI from then on.
-<h2>NOTES</h2>
-Valid values for GRASS_GUI are <tt>text</tt>, <tt>tcltk</tt>,
-<tt>oldtcltk</tt>, and <tt>wxpython</tt>.
-<em>g.gisenv</em> variables are stored in the user's home directory
-in a hidden file called "<TT>.grassrc7</TT>". They are not shell environment
-variables and the "rc" file is not a classic UNIX run command file,
-it just contains persistent GRASS variables and is not executed.
-<h2>SEE ALSO</h2>
-<em>
-<a href="wxGUI.html">wxPython based new generation GUI</a>,
-<a href="http://grass.gdf-hannover.de/wiki/WxPython-based_GUI_for_GRASS">wxGUI wiki-page</a><br>
-<a href="gis.m.html">Tcl/Tk based GIS Manager (gis.m)</a>,<br>
-<a href="d.m.html">Tcl/Tk based Display Manager (d.m)</a>,<br><br>
-<a href="g.gisenv.html">g.gisenv</a>, <a href="variables.html">GRASS variables list</a>
-</em>
-<h2>AUTHORS</h2>
-Martin Landa, FBK-irst, Trento, Italy<BR>
-Hamish Bowman, Otago University, Dunedin, New Zealand (fine tuning)
-<p>
-<i>$Date$</i>
Copied: grass/trunk/general/g.gui/g.gui.html (from rev 32770, grass/trunk/general/g.gui/description.html)
--- grass/trunk/general/g.gui/g.gui.html (rev 0)
+++ grass/trunk/general/g.gui/g.gui.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,53 @@
+<h2>DESCRIPTION</h2>
+<p>
+This program allows user to start a selected graphical user interface (GUI)
+from the command line prompt.
+<p>
+Currently three different GUIs are supported:
+<ul>
+<li><b>tcltk</b> - Current Tcl/Tk based GUI aka the <em>gis.m</em>
+ <a href="gis.m.html">GIS Manager</a></li>
+<li><b>oldtcltk</b> - Old Tcl/Tk based GUI aka the <em>d.m</em>
+ <a href="d.m.html">Display Manager</a></li>
+<li><b>wxpython</b> - New wxPython based GUI aka
+ <a href="wxGUI.html">wxGUI</a></li>
+</ul>
+If the <b>-u</b> update flag is given or the <em>g.gisenv</em>
+<tt>GRASS_GUI</tt> variable is missing, then the <tt>GRASS_GUI</tt>
+variable is permanently changed and the selected GUI will be used
+as the default UI from then on.
+<h2>NOTES</h2>
+Valid values for GRASS_GUI are <tt>text</tt>, <tt>tcltk</tt>,
+<tt>oldtcltk</tt>, and <tt>wxpython</tt>.
+<em>g.gisenv</em> variables are stored in the user's home directory
+in a hidden file called "<TT>.grassrc7</TT>". They are not shell environment
+variables and the "rc" file is not a classic UNIX run command file,
+it just contains persistent GRASS variables and is not executed.
+<h2>SEE ALSO</h2>
+<em>
+<a href="wxGUI.html">wxPython based new generation GUI</a>,
+<a href="http://grass.gdf-hannover.de/wiki/WxPython-based_GUI_for_GRASS">wxGUI wiki-page</a><br>
+<a href="gis.m.html">Tcl/Tk based GIS Manager (gis.m)</a>,<br>
+<a href="d.m.html">Tcl/Tk based Display Manager (d.m)</a>,<br><br>
+<a href="g.gisenv.html">g.gisenv</a>, <a href="variables.html">GRASS variables list</a>
+</em>
+<h2>AUTHORS</h2>
+Martin Landa, FBK-irst, Trento, Italy<BR>
+Hamish Bowman, Otago University, Dunedin, New Zealand (fine tuning)
+<p>
+<i>$Date$</i>
Deleted: grass/trunk/general/g.mapset/description.html
--- grass/trunk/general/g.mapset/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.mapset/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,25 +0,0 @@
-<em>g.mapset</em> allows to change the current mapset
-<h2>NOTES</h2>
-The shell continues to use the history for the old mapset. To change this
-you can switch the history to the new settings by commands:<BR>
-<BR>
- history -w
- history -r /$GISDBASE/$LOCATION/$MAPSET/.bash_history
- HISTFILE=/$GISDBASE/$LOCATION/$MAPSET/.bash_history
-</pre></div><BR>
-<h2>SEE ALSO</h2>
-<em><a HREF="g.gisenv.html">g.gisenv</a></em><br>
-<h2>AUTHOR</h2>
-Radim Blazek
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/general/g.mapset/g.mapset.html (from rev 32770, grass/trunk/general/g.mapset/description.html)
--- grass/trunk/general/g.mapset/g.mapset.html (rev 0)
+++ grass/trunk/general/g.mapset/g.mapset.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,25 @@
+<em>g.mapset</em> allows to change the current mapset
+<h2>NOTES</h2>
+The shell continues to use the history for the old mapset. To change this
+you can switch the history to the new settings by commands:<BR>
+<BR>
+ history -w
+ history -r /$GISDBASE/$LOCATION/$MAPSET/.bash_history
+ HISTFILE=/$GISDBASE/$LOCATION/$MAPSET/.bash_history
+</pre></div><BR>
+<h2>SEE ALSO</h2>
+<em><a HREF="g.gisenv.html">g.gisenv</a></em><br>
+<h2>AUTHOR</h2>
+Radim Blazek
Deleted: grass/trunk/general/g.mapsets/description.html
--- grass/trunk/general/g.mapsets/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.mapsets/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,138 +0,0 @@
-For basic information about Grass <em>mapset</em>, <em>location</em>
-and <em>data base</em> refer to <a HREF="helptext.html">GRASS Quickstart</a>.
-<p>
-A <em>mapset</em> holds a distinct set of data layers,
-each relevant to the same (or a subset of the same) geographic region,
-and each drawn in the same map coordinate system.
-At the outset of every GRASS session, the user identifies a
-GRASS data base, location, and mapset that are to be the
-user's <em>current data base</em>, <em>current location</em>,
-and <em>current mapset</em> for the duration of the session;
-any maps created by the user during the session
-will be stored under the <em>current mapset</em> set at the session's outset.
-(see <em><a href="g.mapset.html">g.mapset</a></em> [without an "s"] and
- <em><a href="g.gisenv.html">g.gisenv</a></em> for changing the mapset
- with a session)
-<p>
-The user can add, modify, and delete data layers that exist
-under his <em>current mapset</em>. Although the user can
-also <em>access</em> (i.e., use) data that are stored under
-<em>other</em> mapsets in the same GRASS location using the
-<tt>mapname at mapsetname</tt> notation or mapset search path, the user
-can only make permanent changes (create or modify data)
-located in the <em>current mapset</em>. The user's
-<em>mapset search path</em> lists the order in which other
-mapsets in the same GRASS location can be searched and
-their data accessed by the user. The user can modify the
-listing and order in which these mapsets are accessed by
-modifying the mapset search path; this can be done using
-the <em>g.mapsets</em> command. This program allows the
-user to use other's relevant map data without altering the
-original data layer, and without taking up disk space with
-a copy of the original map. The <tt>mapname at mapsetname</tt>
-notation may be used irrespective of the mapset search path,
-i.e., any map found in another mapset with sufficient
-<em><a href="g.access.html">g.access</a></em> privileges may
-be called in such a manner.
-<p>
-<em>g.mapsets</em> shows the user available mapsets under
-the current GRASS location, lists mapsets to which the user
-currently has access, and lists the order in which
-accessible mapsets will be accessed by GRASS programs
-searching for data files. The user is then given the
-opportunity to add or delete mapset names from his search
-path, or modify the order in which mapsets will be
-accessed.
-<p>
-When the user specifies the name of a data base element file
-(e.g., a particular vector map, raster map,
-<a HREF="i.group.html">imagery</a> group file, etc.)
-to a GRASS program, the program searches for the named file
-under each of the mapsets listed in the user's mapset search path
-in the order listed there until the program finds a file
-of the given name. (Users can also specify a file by
-its mapset, to make explicit the mapset from which the file is to be
-drawn; e.g., the command:
-<b><a HREF="g.copy.html">g.copy</a> rast=</b><em>'soils.file at PERMANENT',my.soils</em>
-</pre></div>
-ensures that a new file named <em>my.soils</em> is to be a copy of
-the file <em>soils.file</em> from the mapset PERMANENT.)
-<p>
-It is common for a user to have the special mapset
-<b>PERMANENT</b> included in his mapset search path, as
-this mapset typically contains finished base maps relevant
-to many applications. Often, other mapsets which contain
-sets of interpreted map layers will be likewise included in
-the user's mapset search path. Suppose, for example, that
-the mapset <em>Soil_Maps</em> contains interpreted soils
-map layers to which the user wants access. The mapset
-<em>Soil_Maps</em> should then be included in the user's
-<em>search path</em> variable.
-<p>
-The <em>mapset search path</em> is saved as part of the
-current mapset. When the user works with that mapset in
-subsequent GRASS sessions, the previously saved mapset
-search path will be used (and will continue to be used
-until it is modified by the user with <em>g.mapsets</em>).
-<h2>NOTES</h2>
-<em>g.mapsets</em> sets the current <em>mapset search
-path</em> to the <em>mapsets</em> named on the command
-line. If <em>g.mapsets</em> is typed but no <em>mapset</em>
-names are specified by the user on the command line, the
-program will print the user's current mapset search path,
-list available mapsets, and prompt the user for a new
-mapset search path listing.
-<p>
-The <em>addmapset</em> parameter allows for extending an existing
-<em>mapset search path</em>.
-<p>
-Users can restrict others' access to their mapset files
-through use of the GRASS program
-<em><a HREF="g.access.html">g.access</a></em>.
-Mapsets to which access is restricted can still be listed
-in another's mapset search path; however, access to these
-mapsets will remain restricted.
-<h2>SEE ALSO</h2>
-<em>
- <a HREF="g.access.html">g.access</a>,
- <a HREF="g.copy.html">g.copy</a>,
- <a HREF="g.gisenv.html">g.gisenv</a>,
- <a HREF="g.list.html">g.list</a>,
- <a HREF="g.mapset.html">g.mapset</a>
-</em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-Research Laboratory
-<p>
-Greg Koerper,
-ManTech Environmental Technology, Inc.
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/general/g.mapsets/g.mapsets.html (from rev 32770, grass/trunk/general/g.mapsets/description.html)
--- grass/trunk/general/g.mapsets/g.mapsets.html (rev 0)
+++ grass/trunk/general/g.mapsets/g.mapsets.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,138 @@
+For basic information about Grass <em>mapset</em>, <em>location</em>
+and <em>data base</em> refer to <a HREF="helptext.html">GRASS Quickstart</a>.
+<p>
+A <em>mapset</em> holds a distinct set of data layers,
+each relevant to the same (or a subset of the same) geographic region,
+and each drawn in the same map coordinate system.
+At the outset of every GRASS session, the user identifies a
+GRASS data base, location, and mapset that are to be the
+user's <em>current data base</em>, <em>current location</em>,
+and <em>current mapset</em> for the duration of the session;
+any maps created by the user during the session
+will be stored under the <em>current mapset</em> set at the session's outset.
+(see <em><a href="g.mapset.html">g.mapset</a></em> [without an "s"] and
+ <em><a href="g.gisenv.html">g.gisenv</a></em> for changing the mapset
+ with a session)
+<p>
+The user can add, modify, and delete data layers that exist
+under his <em>current mapset</em>. Although the user can
+also <em>access</em> (i.e., use) data that are stored under
+<em>other</em> mapsets in the same GRASS location using the
+<tt>mapname at mapsetname</tt> notation or mapset search path, the user
+can only make permanent changes (create or modify data)
+located in the <em>current mapset</em>. The user's
+<em>mapset search path</em> lists the order in which other
+mapsets in the same GRASS location can be searched and
+their data accessed by the user. The user can modify the
+listing and order in which these mapsets are accessed by
+modifying the mapset search path; this can be done using
+the <em>g.mapsets</em> command. This program allows the
+user to use other's relevant map data without altering the
+original data layer, and without taking up disk space with
+a copy of the original map. The <tt>mapname at mapsetname</tt>
+notation may be used irrespective of the mapset search path,
+i.e., any map found in another mapset with sufficient
+<em><a href="g.access.html">g.access</a></em> privileges may
+be called in such a manner.
+<p>
+<em>g.mapsets</em> shows the user available mapsets under
+the current GRASS location, lists mapsets to which the user
+currently has access, and lists the order in which
+accessible mapsets will be accessed by GRASS programs
+searching for data files. The user is then given the
+opportunity to add or delete mapset names from his search
+path, or modify the order in which mapsets will be
+accessed.
+<p>
+When the user specifies the name of a data base element file
+(e.g., a particular vector map, raster map,
+<a HREF="i.group.html">imagery</a> group file, etc.)
+to a GRASS program, the program searches for the named file
+under each of the mapsets listed in the user's mapset search path
+in the order listed there until the program finds a file
+of the given name. (Users can also specify a file by
+its mapset, to make explicit the mapset from which the file is to be
+drawn; e.g., the command:
+<b><a HREF="g.copy.html">g.copy</a> rast=</b><em>'soils.file at PERMANENT',my.soils</em>
+</pre></div>
+ensures that a new file named <em>my.soils</em> is to be a copy of
+the file <em>soils.file</em> from the mapset PERMANENT.)
+<p>
+It is common for a user to have the special mapset
+<b>PERMANENT</b> included in his mapset search path, as
+this mapset typically contains finished base maps relevant
+to many applications. Often, other mapsets which contain
+sets of interpreted map layers will be likewise included in
+the user's mapset search path. Suppose, for example, that
+the mapset <em>Soil_Maps</em> contains interpreted soils
+map layers to which the user wants access. The mapset
+<em>Soil_Maps</em> should then be included in the user's
+<em>search path</em> variable.
+<p>
+The <em>mapset search path</em> is saved as part of the
+current mapset. When the user works with that mapset in
+subsequent GRASS sessions, the previously saved mapset
+search path will be used (and will continue to be used
+until it is modified by the user with <em>g.mapsets</em>).
+<h2>NOTES</h2>
+<em>g.mapsets</em> sets the current <em>mapset search
+path</em> to the <em>mapsets</em> named on the command
+line. If <em>g.mapsets</em> is typed but no <em>mapset</em>
+names are specified by the user on the command line, the
+program will print the user's current mapset search path,
+list available mapsets, and prompt the user for a new
+mapset search path listing.
+<p>
+The <em>addmapset</em> parameter allows for extending an existing
+<em>mapset search path</em>.
+<p>
+Users can restrict others' access to their mapset files
+through use of the GRASS program
+<em><a HREF="g.access.html">g.access</a></em>.
+Mapsets to which access is restricted can still be listed
+in another's mapset search path; however, access to these
+mapsets will remain restricted.
+<h2>SEE ALSO</h2>
+<em>
+ <a HREF="g.access.html">g.access</a>,
+ <a HREF="g.copy.html">g.copy</a>,
+ <a HREF="g.gisenv.html">g.gisenv</a>,
+ <a HREF="g.list.html">g.list</a>,
+ <a HREF="g.mapset.html">g.mapset</a>
+</em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+Research Laboratory
+<p>
+Greg Koerper,
+ManTech Environmental Technology, Inc.
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/general/g.message/description.html
--- grass/trunk/general/g.message/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.message/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,81 +0,0 @@
-<p>
-This program is to be used in shell/perl/python scripts, so the author does not
-need to use the <tt>echo</tt> program. The advantage of <em>g.message</em> is
-that it formats messages just like other GRASS modules do and that its
-functionality is influenced by the <tt>GRASS_VERBOSE</tt> and
-<tt>GRASS_MESSAGE_FORMAT</tt> environment variables.
-</p>
-<p>
-The program can be used for standard informative messages as well as warnings
-(<b>-w</b> flag) and fatal errors (<b>-e</b> flag). For debugging
-purposes, the <b>-d</b> flag will cause <em>g.message</em> to print a debugging
-message at the given level.
-</p>
-<h2>NOTES</h2>
-Messages containing "<tt>=</tt>" must use the full <b>message=</b> syntax so
-the parser doesn't get confused.
-<P>
-If you want a long message (mutli-line) to be dealt with as a single
-paragraph, use a single call to <em>g.message</em> with text split in the
-script using the backslash as the last character. (In shell scripts don't
-close the "quote")
-<P>
-A blank line may be obtained with: <tt>g.message ""</tt>
-<P>
-Redundant whitespace will be stripped away.
-<P>
-It's advisable to single quote the messages that are to be printed literally.
-It prevents a number of characters (most notably, space and the dollar sign
-'<tt>$</tt>') from being treated specifically by the Shell.
-<P>
-When it is necessary to include, for example, a variable's value as part of
-the message, the double quotes may be used, which do not deprive the
-dollar sign of its special variable-expansion powers.
-<P>
-While it is known that the interactive Bash instances may treat the
-exclamation mark '<tt>!</tt>' character specifically (making single quoting
-of it necessary), it shouldn't be the case for the non-interactive
-instances of Bash. None the less, to avoid context-based confusion later on
-you are enouraged to single-quote messages that do not require
-<tt>$VARIABLE</tt> expansion.
-<P>
-<h4>VERBOSITY LEVELS</h4>
-Controlled by the "<tt>GRASS_VERBOSE</tt>" environment variable. Typically this
-is set using the <tt>--quiet</tt> or <tt>--verbose</tt> command line options.
-<ul>
-<li>0 - only errors and warnings are printed
-<li>1 - progress messages are printed
-<li>2 - all module messages are printed
-<li>3 - additional verbose messages are printed
-</ul>
-<h4>DEBUG LEVELS</h4>
-Controlled by the "<tt>DEBUG</tt>" GRASS <i>gisenv</i> variable. (set with
-<em><a href="g.gisenv.html">g.gisenv</a></em>)
-<BR>
-Recommended levels:
-<ul>
-<li>1 - message is printed once or few times per module
-<li>3 - each row (raster) or line (vector)
-<li>5 - each cell (raster) or point (vector)
-</ul>
-<h2>SEE ALSO</h2>
-<em>
-<a href="variables.html">GRASS variables and environment variables</a>,<br>
-<a href="g.parser.html">g.parser</a>
-</em>
-<h2>AUTHOR</h2>
-Jachym Cepicky
-<p>
Copied: grass/trunk/general/g.message/g.message.html (from rev 32770, grass/trunk/general/g.message/description.html)
--- grass/trunk/general/g.message/g.message.html (rev 0)
+++ grass/trunk/general/g.message/g.message.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,81 @@
+<p>
+This program is to be used in shell/perl/python scripts, so the author does not
+need to use the <tt>echo</tt> program. The advantage of <em>g.message</em> is
+that it formats messages just like other GRASS modules do and that its
+functionality is influenced by the <tt>GRASS_VERBOSE</tt> and
+<tt>GRASS_MESSAGE_FORMAT</tt> environment variables.
+</p>
+<p>
+The program can be used for standard informative messages as well as warnings
+(<b>-w</b> flag) and fatal errors (<b>-e</b> flag). For debugging
+purposes, the <b>-d</b> flag will cause <em>g.message</em> to print a debugging
+message at the given level.
+</p>
+<h2>NOTES</h2>
+Messages containing "<tt>=</tt>" must use the full <b>message=</b> syntax so
+the parser doesn't get confused.
+<P>
+If you want a long message (mutli-line) to be dealt with as a single
+paragraph, use a single call to <em>g.message</em> with text split in the
+script using the backslash as the last character. (In shell scripts don't
+close the "quote")
+<P>
+A blank line may be obtained with: <tt>g.message ""</tt>
+<P>
+Redundant whitespace will be stripped away.
+<P>
+It's advisable to single quote the messages that are to be printed literally.
+It prevents a number of characters (most notably, space and the dollar sign
+'<tt>$</tt>') from being treated specifically by the Shell.
+<P>
+When it is necessary to include, for example, a variable's value as part of
+the message, the double quotes may be used, which do not deprive the
+dollar sign of its special variable-expansion powers.
+<P>
+While it is known that the interactive Bash instances may treat the
+exclamation mark '<tt>!</tt>' character specifically (making single quoting
+of it necessary), it shouldn't be the case for the non-interactive
+instances of Bash. None the less, to avoid context-based confusion later on
+you are enouraged to single-quote messages that do not require
+<tt>$VARIABLE</tt> expansion.
+<P>
+<h4>VERBOSITY LEVELS</h4>
+Controlled by the "<tt>GRASS_VERBOSE</tt>" environment variable. Typically this
+is set using the <tt>--quiet</tt> or <tt>--verbose</tt> command line options.
+<ul>
+<li>0 - only errors and warnings are printed
+<li>1 - progress messages are printed
+<li>2 - all module messages are printed
+<li>3 - additional verbose messages are printed
+</ul>
+<h4>DEBUG LEVELS</h4>
+Controlled by the "<tt>DEBUG</tt>" GRASS <i>gisenv</i> variable. (set with
+<em><a href="g.gisenv.html">g.gisenv</a></em>)
+<BR>
+Recommended levels:
+<ul>
+<li>1 - message is printed once or few times per module
+<li>3 - each row (raster) or line (vector)
+<li>5 - each cell (raster) or point (vector)
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="variables.html">GRASS variables and environment variables</a>,<br>
+<a href="g.parser.html">g.parser</a>
+</em>
+<h2>AUTHOR</h2>
+Jachym Cepicky
+<p>
Deleted: grass/trunk/general/g.mkfontcap/description.html
--- grass/trunk/general/g.mkfontcap/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.mkfontcap/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,56 +0,0 @@
-<p>
-<EM>g.mkfontcap</EM> is a utilty to generate a GRASS font configuration file
-("fontcap") containing details of the fonts available on the current system.
-If <a href="http://freetype.sourceforge.net/">Freetype</a> is not installed,
-the font list will be limited to the set of Hershey stroke fonts supplied
-with GRASS. With Freetype enabled however, the module will recursively scan
-all files within a predefined hierarchy to find Freetype-compatible scalable
-fonts. The list of directories scanned is currently:
- /usr/lib/X11/fonts
- /usr/share/X11/fonts
- /usr/share/fonts
- ${HOME}/Library/Fonts
- /Library/Fonts
- /System/Library/Fonts
- ${WINDIR}/Fonts
-</pre></div>
-These correspond to directories where fonts can be found on some common
-operating systems. Extra directories to search can easily by added using the
-<em>extradirs</em> parameter, which accepts a comma-separated list. An extra
-directory may optionally contain an environment variable <em>at the start</em>
-of the string, if enclosed in ${xxx} syntax (see examples above).</p>
-<p>The module will normally write to the standard fontcap file location,
-<tt>$GISBASE/etc/fontcap</tt>. If the environment variable
-<strong>GRASS_FONT_CAP</strong> is set, the output will instead be written
-to the file specified by that variable. This is useful if you don't have
-permission to modify <tt>$GISBASE/etc/fontcap</tt>: in this case you can
-use e.g.
-# use local file version instead of system copy
-GRASS_FONT_CAP=$HOME/.gfontcap
-export $GRASS_FONT_CAP
-g.mkfontcap
-</pre></div>
-to create a personal copy and then to make GRASS use that file
-instead of the system copy.
-</p>
-<p>The output list of fonts is sorted first by type (Stroke fonts first,
-followed by Freetype) and within each type by the short name of the font.</p>
-<H2>SEE ALSO</H2>
-<EM><a href="d.font.html">d.font</a></EM>
-<H2>AUTHOR</H2>
-Paul Kelly
Copied: grass/trunk/general/g.mkfontcap/g.mkfontcap.html (from rev 32770, grass/trunk/general/g.mkfontcap/description.html)
--- grass/trunk/general/g.mkfontcap/g.mkfontcap.html (rev 0)
+++ grass/trunk/general/g.mkfontcap/g.mkfontcap.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,56 @@
+<H2>DESCRIPTION</H2>
+<p>
+<EM>g.mkfontcap</EM> is a utilty to generate a GRASS font configuration file
+("fontcap") containing details of the fonts available on the current system.
+If <a href="http://freetype.sourceforge.net/">Freetype</a> is not installed,
+the font list will be limited to the set of Hershey stroke fonts supplied
+with GRASS. With Freetype enabled however, the module will recursively scan
+all files within a predefined hierarchy to find Freetype-compatible scalable
+fonts. The list of directories scanned is currently:
+ /usr/lib/X11/fonts
+ /usr/share/X11/fonts
+ /usr/share/fonts
+ ${HOME}/Library/Fonts
+ /Library/Fonts
+ /System/Library/Fonts
+ ${WINDIR}/Fonts
+</pre></div>
+These correspond to directories where fonts can be found on some common
+operating systems. Extra directories to search can easily by added using the
+<em>extradirs</em> parameter, which accepts a comma-separated list. An extra
+directory may optionally contain an environment variable <em>at the start</em>
+of the string, if enclosed in ${xxx} syntax (see examples above).</p>
+<p>The module will normally write to the standard fontcap file location,
+<tt>$GISBASE/etc/fontcap</tt>. If the environment variable
+<strong>GRASS_FONT_CAP</strong> is set, the output will instead be written
+to the file specified by that variable. This is useful if you don't have
+permission to modify <tt>$GISBASE/etc/fontcap</tt>: in this case you can
+use e.g.
+# use local file version instead of system copy
+GRASS_FONT_CAP=$HOME/.gfontcap
+export $GRASS_FONT_CAP
+g.mkfontcap
+</pre></div>
+to create a personal copy and then to make GRASS use that file
+instead of the system copy.
+</p>
+<p>The output list of fonts is sorted first by type (Stroke fonts first,
+followed by Freetype) and within each type by the short name of the font.</p>
+<H2>SEE ALSO</H2>
+<EM><a href="d.font.html">d.font</a></EM>
+<H2>AUTHOR</H2>
+Paul Kelly
Deleted: grass/trunk/general/g.parser/description.html
--- grass/trunk/general/g.parser/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.parser/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,416 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>g.parser</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>g.parser</b></em>
-<H2>DESCRIPTION</H2>
-The <em>g.parser</em> module provides full parser support for GRASS scripts,
-including an auto-generated GUI interface, help page template, and command
-line option checking. In this way a simple script can very quickly be made
-into a full-fledged GRASS module.
-<P>
-<H2>OPTIONS</H2>
-After parsing the arguments are stored in environment variables for use in your
-scripts. These variables are named "GIS_FLAG_<NAME>" for flags and
-"GIS_OPT_<NAME>" for options.
-The names of variables are converted to upper case. For example if an option
-with key <b>input</b> was defined in the script header, the value will be
-available in variable <b>GIS_OPT_INPUT</b> and the value of flag with key <b>f</b>
-will be available in variable <b>GIS_FLAG_F</b>.
-<P>
-For flags, the value will be "1" if the flag was given, and "0" otherwise.
-<P>
-Typical header definitions are as follows:
-#%Module
-#% description: g.parser test script
-#%End
-#%flag
-#% key: f
-#% description: A flag
-#%end
-#%option
-#% key: raster
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Raster input map
-#% required : yes
-#%end
-</pre></div>
-<H2>NOTES</H2>
-An option can be instructed to allow multiple inputs by adding the following line:
-<pre>#% multiple : yes</pre>
-While this will only directly change the <i>Usage</i> section of the help
-screen, the option's environmental string may be easily parsed from within
-a script. For example, individual comma separated identities for an option
-named "input" can be parsed with the following Bash shell code:
-<div class="code"><pre>IFS=,
-for opt in $GIS_OPT_INPUT ; do
- ... "$opt"
-done
-</pre></div>
-<P>
-A "<tt>guisection</tt>" field may be added to each option and flag to specify
-that the options should appear in multiple tabs in the auto-generated GUI.
-Any options without a <tt>guisection</tt> field go into the "Options" tab.
-For example:
-<pre>#% guisection: tabname</pre>
-would put that option in a tab named <i>tabname</i>.
-<P>
-A "<tt>key_desc</tt>" field may be added to each option to specify the text that
-appears in the module's usage help section. For example:
-<pre>#% key_desc: filename</pre>
-added to an <b>input</b> option would create the usage summary
-<tt>[input=filename]</tt>.
-<P>
-If a script is run with --o, G_parser() will set <tt>GRASS_OVERWRITE=1</tt>,
-which has the same effect as passing --o to every module which is run
-from the script.
-Similarly, passing --q or --v will set <tt>GRASS_VERBOSE</tt> to 0 or 3
-respectively, which has the same effect as passing --q or --v to every
-module which is run from the script.
-Rather than checking whether --o, --q or --v were used, you should be
-checking $GRASS_OVERWRITE and/or $GRASS_VERBOSE instead. If those
-variables are set, the script should behave the same way regardless of
-whether they were set by --o, --q or --v being passed to the script or
-set by other means.
-<H2>AUTOMATED SCRIPT CREATION</H2>
-The flag <em>--script</em> added to a GRASS command, generates shell output.
-To write out a <em>g.parser</em> boilerplate for easy prototyping of shell
-scripts, the flag <em>--script</em> can be added to any GRASS command. Example:
-v.in.db --script
-</pre></div>
-<H2>Help page template (HTML)</H2>
-The flag <em>--html-description</em> added to a GRASS command, generates a
-related help page template in HTML. Example:
-v.in.db --html-description
-</pre></div>
-<H2>GUI window parser (XML)</H2>
-The flag <em>--interface-description</em> added to a GRASS command, generates a
-related help page template in XML. Example:
-v.in.db --interface-description
-</pre></div>
-<H2>GUI window parser (TclTk)</H2>
-The flag <em>--tcltk</em> added to a GRASS command, generates a
-a XML description of the GUI interface. Example
-v.in.db --tcltk
-</pre></div>
-<H2>TRANSLATION</h2>
-<em>g.parser</em> provides some support for translating the options of scripts.
-If called with the -t switch before the script filename like this
-g.parser -t somescriptfile
-</pre></div>
-<em>g.parser</em> will print the text of the translatable options to
-<tt>stdout</tt>, one per line, and exit. This is for internal use within
-the build system to prepare GRASS scripts for translation.
-<H2>EXAMPLES</H2>
-<h3>Example code for SHELL</h3>
-#!/bin/sh
-# g.parser demo script for shell programing
-#%Module
-#%End
-#%flag
-#% key: f
-#%END
-#%option
-#% key: raster
-#% type: string
-#% required : yes
-#%end
-#%option
-#% key: vector
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Vector input map
-#% required : yes
-#%end
-#%option
-#% key: option1
-#% type: string
-#% description: An option
-#% required : no
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-#### add your code below ####
-echo ""
-if [ $GIS_FLAG_F -eq 1 ] ; then
- echo "Flag -f set"
-else
- echo "Flag -f not set"
-fi
-# test if parameter present:
-if [ -n "$GIS_OPT_OPTION1" ] ; then
- echo "Value of GIS_OPT_OPTION1: '$GIS_OPT_OPTION1'"
-fi
-echo "Value of GIS_OPT_RASTER: '$GIS_OPT_RASTER'"
-echo "Value of GIS_OPT_VECTOR: '$GIS_OPT_VECTOR'"
-</pre></div>
-<h3>Example code for Python</h3>
-#!/usr/bin/python
-# g.parser demo script for python programing
-#%Module
-#% description: g.parser test script (python)
-#%End
-#%flag
-#% key: f
-#%END
-#%option
-#% key: raster
-#% type: string
-#% required : yes
-#%end
-#%option
-#% key: vector
-#% type: string
-#% required : yes
-#%end
-#%option
-#% key: option1
-#% type: string
-#% required : no
-#%end
-import os
-import sys
-def main():
- #### add your code here ####
- print ""
- if ( os.getenv('GIS_FLAG_F') == "1" ):
- print "Flag -f set"
- else:
- print "Flag -f not set"
- # test if parameter present:
- if ( os.getenv("GIS_OPT_OPTION1") != "" ):
- print "Value of GIS_OPT_OPTION1: '%s'" % os.getenv('GIS_OPT_OPTION1')
- print "Value of GIS_OPT_RASTER: '%s'" % os.getenv('GIS_OPT_RASTER')
- print "Value of GIS_OPT_VECTOR: '%s'" % os.getenv('GIS_OPT_VECTOR')
- #### end of your code ####
- return
-if __name__ == "__main__":
- if !os.getenv("GISBASE"):
- print >> sys.stderr, "You must be in GRASS GIS to run this program."
- sys.exit(0)
- if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
- os.execvp("g.parser", [sys.argv[0]] + sys.argv)
- else:
- main();
-</pre></div>
-<P>
-The <tt>test.py</tt> script will provide following help text:
-<P>
-./test.py --help
-Description:
- g.parser test script (python)
-Usage:
- test.sh [-f] option=name
-Flags:
- -f a flag
-Parameters:
- option an option
-</pre></div>
-<h3>Example code for Perl</h3>
-#!/usr/bin/perl -w
-use strict;
-#%Module
-#% description: g.parser test script (perl)
-#% keywords: keyword1, keyword2
-#%End
-#%flag
-#% key: f
-#%END
-#%option
-#% key: raster
-#% type: string
-#% required : yes
-#%end
-#%option
-#% key: vector
-#% type: string
-#% required : yes
-#%end
-#%option
-#% key: option1
-#% type: string
-#% required : no
-#%end
-if ( !$ENV{'GISBASE'} ) {
- printf(STDERR "You must be in GRASS GIS to run this program.\n");
- exit 1;
-if( $ARGV[0] ne '@ARGS_PARSED@' ){
- my $arg = "";
- for (my $i=0; $i < @ARGV;$i++) {
- $arg .= " $ARGV[$i] ";
- system("$ENV{GISBASE}/bin/g.parser $0 $arg");
- exit;
-#### add your code here ####
-print "\n";
-if ( $ENV{'GIS_FLAG_F'} eq "1" ){
- print "Flag -f set\n"
-else {
- print "Flag -f not set\n"
-printf ("Value of GIS_OPT_option1: '%s'\n", $ENV{'GIS_OPT_OPTION1'});
-printf ("Value of GIS_OPT_raster: '%s'\n", $ENV{'GIS_OPT_RASTER'});
-printf ("Value of GIS_OPT_vect: '%s'\n", $ENV{'GIS_OPT_VECTOR'});
-#### end of your code ####
-</pre></div>
-<P>
-The <tt>test.pl</tt> script will provide following help text:
-<P>
-./test.pl --help
-Description:
- g.parser test script (perl)
-Usage:
-Flags:
- -f a flag
-Parameters:
- option an option
-</pre></div>
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="d.ask.html">d.ask</A>,
-<A HREF="d.menu.html">d.menu</A>,
-<A HREF="g.ask.html">g.ask</A>,
-<A HREF="g.filename.html">g.filename</A>,
-<A HREF="g.findfile.html">g.findfile</A>,
-<A HREF="g.tempfile.html">g.tempfile</A>,
-</EM>
-and the <tt>SUBMITTING_SCRIPTS</tt> file in the GRASS source code.
-<H2>AUTHOR</H2>
-Glynn Clements
-<p>
-</p>
-</body>
-</html>
Copied: grass/trunk/general/g.parser/g.parser.html (from rev 32770, grass/trunk/general/g.parser/description.html)
--- grass/trunk/general/g.parser/g.parser.html (rev 0)
+++ grass/trunk/general/g.parser/g.parser.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,416 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>g.parser</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<h2>NAME</h2>
+<em><b>g.parser</b></em>
+The <em>g.parser</em> module provides full parser support for GRASS scripts,
+including an auto-generated GUI interface, help page template, and command
+line option checking. In this way a simple script can very quickly be made
+into a full-fledged GRASS module.
+<P>
+<H2>OPTIONS</H2>
+After parsing the arguments are stored in environment variables for use in your
+scripts. These variables are named "GIS_FLAG_<NAME>" for flags and
+"GIS_OPT_<NAME>" for options.
+The names of variables are converted to upper case. For example if an option
+with key <b>input</b> was defined in the script header, the value will be
+available in variable <b>GIS_OPT_INPUT</b> and the value of flag with key <b>f</b>
+will be available in variable <b>GIS_FLAG_F</b>.
+<P>
+For flags, the value will be "1" if the flag was given, and "0" otherwise.
+<P>
+Typical header definitions are as follows:
+#%Module
+#% description: g.parser test script
+#%End
+#%flag
+#% key: f
+#% description: A flag
+#%end
+#%option
+#% key: raster
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Raster input map
+#% required : yes
+#%end
+</pre></div>
+<H2>NOTES</H2>
+An option can be instructed to allow multiple inputs by adding the following line:
+<pre>#% multiple : yes</pre>
+While this will only directly change the <i>Usage</i> section of the help
+screen, the option's environmental string may be easily parsed from within
+a script. For example, individual comma separated identities for an option
+named "input" can be parsed with the following Bash shell code:
+<div class="code"><pre>IFS=,
+for opt in $GIS_OPT_INPUT ; do
+ ... "$opt"
+done
+</pre></div>
+<P>
+A "<tt>guisection</tt>" field may be added to each option and flag to specify
+that the options should appear in multiple tabs in the auto-generated GUI.
+Any options without a <tt>guisection</tt> field go into the "Options" tab.
+For example:
+<pre>#% guisection: tabname</pre>
+would put that option in a tab named <i>tabname</i>.
+<P>
+A "<tt>key_desc</tt>" field may be added to each option to specify the text that
+appears in the module's usage help section. For example:
+<pre>#% key_desc: filename</pre>
+added to an <b>input</b> option would create the usage summary
+<tt>[input=filename]</tt>.
+<P>
+If a script is run with --o, G_parser() will set <tt>GRASS_OVERWRITE=1</tt>,
+which has the same effect as passing --o to every module which is run
+from the script.
+Similarly, passing --q or --v will set <tt>GRASS_VERBOSE</tt> to 0 or 3
+respectively, which has the same effect as passing --q or --v to every
+module which is run from the script.
+Rather than checking whether --o, --q or --v were used, you should be
+checking $GRASS_OVERWRITE and/or $GRASS_VERBOSE instead. If those
+variables are set, the script should behave the same way regardless of
+whether they were set by --o, --q or --v being passed to the script or
+set by other means.
+<H2>AUTOMATED SCRIPT CREATION</H2>
+The flag <em>--script</em> added to a GRASS command, generates shell output.
+To write out a <em>g.parser</em> boilerplate for easy prototyping of shell
+scripts, the flag <em>--script</em> can be added to any GRASS command. Example:
+v.in.db --script
+</pre></div>
+<H2>Help page template (HTML)</H2>
+The flag <em>--html-description</em> added to a GRASS command, generates a
+related help page template in HTML. Example:
+v.in.db --html-description
+</pre></div>
+<H2>GUI window parser (XML)</H2>
+The flag <em>--interface-description</em> added to a GRASS command, generates a
+related help page template in XML. Example:
+v.in.db --interface-description
+</pre></div>
+<H2>GUI window parser (TclTk)</H2>
+The flag <em>--tcltk</em> added to a GRASS command, generates a
+a XML description of the GUI interface. Example
+v.in.db --tcltk
+</pre></div>
+<H2>TRANSLATION</h2>
+<em>g.parser</em> provides some support for translating the options of scripts.
+If called with the -t switch before the script filename like this
+g.parser -t somescriptfile
+</pre></div>
+<em>g.parser</em> will print the text of the translatable options to
+<tt>stdout</tt>, one per line, and exit. This is for internal use within
+the build system to prepare GRASS scripts for translation.
+<H2>EXAMPLES</H2>
+<h3>Example code for SHELL</h3>
+#!/bin/sh
+# g.parser demo script for shell programing
+#%Module
+#%End
+#%flag
+#% key: f
+#%END
+#%option
+#% key: raster
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: vector
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Vector input map
+#% required : yes
+#%end
+#%option
+#% key: option1
+#% type: string
+#% description: An option
+#% required : no
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+#### add your code below ####
+echo ""
+if [ $GIS_FLAG_F -eq 1 ] ; then
+ echo "Flag -f set"
+else
+ echo "Flag -f not set"
+fi
+# test if parameter present:
+if [ -n "$GIS_OPT_OPTION1" ] ; then
+ echo "Value of GIS_OPT_OPTION1: '$GIS_OPT_OPTION1'"
+fi
+echo "Value of GIS_OPT_RASTER: '$GIS_OPT_RASTER'"
+echo "Value of GIS_OPT_VECTOR: '$GIS_OPT_VECTOR'"
+</pre></div>
+<h3>Example code for Python</h3>
+#!/usr/bin/python
+# g.parser demo script for python programing
+#%Module
+#% description: g.parser test script (python)
+#%End
+#%flag
+#% key: f
+#%END
+#%option
+#% key: raster
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: vector
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: option1
+#% type: string
+#% required : no
+#%end
+import os
+import sys
+def main():
+ #### add your code here ####
+ print ""
+ if ( os.getenv('GIS_FLAG_F') == "1" ):
+ print "Flag -f set"
+ else:
+ print "Flag -f not set"
+ # test if parameter present:
+ if ( os.getenv("GIS_OPT_OPTION1") != "" ):
+ print "Value of GIS_OPT_OPTION1: '%s'" % os.getenv('GIS_OPT_OPTION1')
+ print "Value of GIS_OPT_RASTER: '%s'" % os.getenv('GIS_OPT_RASTER')
+ print "Value of GIS_OPT_VECTOR: '%s'" % os.getenv('GIS_OPT_VECTOR')
+ #### end of your code ####
+ return
+if __name__ == "__main__":
+ if !os.getenv("GISBASE"):
+ print >> sys.stderr, "You must be in GRASS GIS to run this program."
+ sys.exit(0)
+ if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+ os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+ else:
+ main();
+</pre></div>
+<P>
+The <tt>test.py</tt> script will provide following help text:
+<P>
+./test.py --help
+Description:
+ g.parser test script (python)
+Usage:
+ test.sh [-f] option=name
+Flags:
+ -f a flag
+Parameters:
+ option an option
+</pre></div>
+<h3>Example code for Perl</h3>
+#!/usr/bin/perl -w
+use strict;
+#%Module
+#% description: g.parser test script (perl)
+#% keywords: keyword1, keyword2
+#%End
+#%flag
+#% key: f
+#%END
+#%option
+#% key: raster
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: vector
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: option1
+#% type: string
+#% required : no
+#%end
+if ( !$ENV{'GISBASE'} ) {
+ printf(STDERR "You must be in GRASS GIS to run this program.\n");
+ exit 1;
+if( $ARGV[0] ne '@ARGS_PARSED@' ){
+ my $arg = "";
+ for (my $i=0; $i < @ARGV;$i++) {
+ $arg .= " $ARGV[$i] ";
+ system("$ENV{GISBASE}/bin/g.parser $0 $arg");
+ exit;
+#### add your code here ####
+print "\n";
+if ( $ENV{'GIS_FLAG_F'} eq "1" ){
+ print "Flag -f set\n"
+else {
+ print "Flag -f not set\n"
+printf ("Value of GIS_OPT_option1: '%s'\n", $ENV{'GIS_OPT_OPTION1'});
+printf ("Value of GIS_OPT_raster: '%s'\n", $ENV{'GIS_OPT_RASTER'});
+printf ("Value of GIS_OPT_vect: '%s'\n", $ENV{'GIS_OPT_VECTOR'});
+#### end of your code ####
+</pre></div>
+<P>
+The <tt>test.pl</tt> script will provide following help text:
+<P>
+./test.pl --help
+Description:
+ g.parser test script (perl)
+Usage:
+Flags:
+ -f a flag
+Parameters:
+ option an option
+</pre></div>
+<H2>SEE ALSO</H2>
+<EM>
+<A HREF="d.ask.html">d.ask</A>,
+<A HREF="d.menu.html">d.menu</A>,
+<A HREF="g.ask.html">g.ask</A>,
+<A HREF="g.filename.html">g.filename</A>,
+<A HREF="g.findfile.html">g.findfile</A>,
+<A HREF="g.tempfile.html">g.tempfile</A>,
+</EM>
+and the <tt>SUBMITTING_SCRIPTS</tt> file in the GRASS source code.
+<H2>AUTHOR</H2>
+Glynn Clements
+<p>
+</p>
+</body>
+</html>
Deleted: grass/trunk/general/g.pnmcomp/description.html
--- grass/trunk/general/g.pnmcomp/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.pnmcomp/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,42 +0,0 @@
-(culled from the mailing list)
-<BR>
-<pre>
-Subject: Re: [GRASS5] Re: [GRASSLIST:10403] Transparency added
-Date: Sun, 19 Feb 2006 20:17:59 +0000
-g.pnmcomp isn't meant for end users. It's an internal tool for use by
-a Tcl/Tk GUI.
-In essence, g.pnmcomp generates a PPM image by overlaying a series of
-PPM/PGM pairs (PPM = RGB image, PGM = alpha channel).
-The intention is that d.* programs will emit PPM/PGM pairs (by way of
-the PNG-driver code being integrated into libraster). The GUI will
-manage a set of layers; each layer consists of the data necessary to
-generate a PPM/PGM pair.
-Whenever the layer "stack" changes (by adding, removing, hiding,
-showing or re-ordering layers), the GUI will render any layers for
-which it doesn't already have the PPM/PGM pair, then re-run g.pnmcomp
-to generate the final image (just redoing the composition is a lot
-faster than redrawing everything).
-A C/C++ GUI would either have g.pnmcomp's functionality (image
-composition) built-in, or would use the system's graphics API to
-perform composition (for translucent layers, you would need OpenGL or
-the Render extension, or something else which supports translucent
-rendering).
-Tk doesn't support transparent (masked) true-colour images (it does
-support transparent GIFs, but that's limited to 256 colours), and an
-image composition routine in Tcl would be unacceptably slow, hence
-the existence of g.pnmcomp.
-</pre>
-<H2>AUTHOR</H2>
-Glynn Clements
Copied: grass/trunk/general/g.pnmcomp/g.pnmcomp.html (from rev 32770, grass/trunk/general/g.pnmcomp/description.html)
--- grass/trunk/general/g.pnmcomp/g.pnmcomp.html (rev 0)
+++ grass/trunk/general/g.pnmcomp/g.pnmcomp.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,42 @@
+(culled from the mailing list)
+<BR>
+<pre>
+From: Glynn Clements
+Subject: Re: [GRASS5] Re: [GRASSLIST:10403] Transparency added
+Date: Sun, 19 Feb 2006 20:17:59 +0000
+g.pnmcomp isn't meant for end users. It's an internal tool for use by
+a Tcl/Tk GUI.
+In essence, g.pnmcomp generates a PPM image by overlaying a series of
+PPM/PGM pairs (PPM = RGB image, PGM = alpha channel).
+The intention is that d.* programs will emit PPM/PGM pairs (by way of
+the PNG-driver code being integrated into libraster). The GUI will
+manage a set of layers; each layer consists of the data necessary to
+generate a PPM/PGM pair.
+Whenever the layer "stack" changes (by adding, removing, hiding,
+showing or re-ordering layers), the GUI will render any layers for
+which it doesn't already have the PPM/PGM pair, then re-run g.pnmcomp
+to generate the final image (just redoing the composition is a lot
+faster than redrawing everything).
+A C/C++ GUI would either have g.pnmcomp's functionality (image
+composition) built-in, or would use the system's graphics API to
+perform composition (for translucent layers, you would need OpenGL or
+the Render extension, or something else which supports translucent
+rendering).
+Tk doesn't support transparent (masked) true-colour images (it does
+support transparent GIFs, but that's limited to 256 colours), and an
+image composition routine in Tcl would be unacceptably slow, hence
+the existence of g.pnmcomp.
+</pre>
+<H2>AUTHOR</H2>
+Glynn Clements
Deleted: grass/trunk/general/g.proj/description.html
--- grass/trunk/general/g.proj/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.proj/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,221 +0,0 @@
-<P><em>g.proj</em> provides a means of converting a co-ordinate system
-description (i.e. projection information) between various formats.
-It requires <A HREF="http://www.gdal.org/ogr/">OGR</A> to compile. The basic
-functionality of the module is to report the projection information for the
-current location, either in conventional GRASS (-p flag) or PROJ.4 (-j flag)
-format.</P>
-<P>Projection information may also be output in the Well-Known Text (WKT)
-format popularised
-by proprietary GIS. In addition, if one of the parameters <em>georef</em>,
-<em>wkt</em>, <em>proj4</em> or <em>epsg</em> is specified, rather than the
-projection information being read from the current location it is imported
-from an external source as follows:
-<dl>
-<dt>georef=<em>filename</em></dt>
-<dd><em>g.proj</em> attempts to invoke GDAL and OGR in turn to read a
-georeferenced file <em>filename</em>. The projection information will be
-read from this file. If the file is not georeferenced or cannot be read,
-XY (unprojected) will be used.</dd>
-<dt>wkt=<em>filename</em> or <em>-</em></dt>
-<dd>The file <em>filename</em> should contain a projection description in WKT
-format with or without line-breaks (e.g. a '.prj' file). If <em>-</em> is given
-for the filename, the WKT description will be read from stdin rather than a
-file.</dd>
-<dt>proj4=<em>description</em> or <em>-</em></dt>
-<dd><em>description</em> should be a projection description in
-<A HREF="http://remotesensing.org/proj/">PROJ.4</a> format, enclosed in
-quotation marks if there are any spaces. If <em>-</em> is given for
-<em>description</em>, the PROJ.4 description will be read from stdin rather
-than as a directly-supplied command-line parameter.</dd>
-<dt>epsg=<em>number</em></dt>
-<dd><em>number</em> should correspond to the index number of a valid
-co-ordinate system in the <a href="http://www.epsg.org/CurrentDB.html">EPSG
-database</a>. EPSG code support is based upon a local copy of the GDAL CSV
-co-ordinate system and datum information files, stored in the directory
-${GISBASE}/etc/ogr_csv. These can be updated if necessary to support future
-revisions of the EPSG database.</dd>
-</dl>
-</P>
-<P>The -p, -j, -w, etc. flags are all functional when importing projection
-information from an external source, meaning that <em>g.proj</em> can be
-used to convert between representations of the information. It is
-<strong>not</strong> required that either the input or output be in GRASS
-format.</P>
-<P>In addition however, if the -c flag is specified, <em>g.proj</em> will
-create new GRASS projection files (PROJ_INFO, PROJ_UNITS, WIND and
-DEFAULT_WIND) based on the imported information. If the <em>location</em>
-parameter is specified in addition to -c, then a new location will be created.
-Otherwise the projection information files in the current location will be
-overwritten. The program will warn before doing this only if command-line
-interactive mode (<em>-i</em> flag) is selected.</P>
-<P>The final mode of operation of g.proj is to report on the datum
-information and datum transformation parameters associated with the
-co-ordinate system. The -d flag will report a human-readable summary of
-this.</P>
-<H2>NOTES</H2>
-<P>If the input co-ordinate system contains a datum name but no
-transformation parameters, and there is more than one suitable parameter set
-available (according to the files datum.table and datumtransform.table in
-${GISBASE}/etc), g.proj will check the value of the <em>datumtrans</em>
-option and act according to the following:<br>
-<strong>-1:</strong> List available parameter sets in a GUI-parsable (but also
-human-readable) format and exit.<br>
-<strong>0 (default):</strong> Continue without specifying parameters - if
-used when creating a location, other GRASS modules will use the "default"
-(likely non-optimum) parameters for this datum if necessary in the future.<br>
-<strong>Any other number less than or equal to the number of parameter sets
-available for this datum:</strong> Choose this parameter set and add it to the
-co-ordinate system description.<br>
-If the module is being used from the command-line through an interactive
-terminal, the <em>-i</em> flag can be specified to enable interactive
-selection of the parameter set, and the value of <em>datumtrans</em> (if
-specified) is ignored.<br>
-If the <em>-t</em> flag is specified, the module will attempt to change the
-datum transformation parameters using one of the above two methods
-<strong>even if</strong> a valid parameter set is already specified in the
-input co-ordinate system.</P>
-<P>Output is simply based on the input projection information. g.proj does
-<strong>not</strong> attempt to verify that the co-ordinate system thus
-described matches an existing system in use in the world. In particular,
-this means there are no EPSG Authority codes in the WKT output.</P>
-<P>WKT format shows the false eastings and northings in the projected unit
-(e.g. meters, feet) but in PROJ format it should always be given in meters.</P>
-<P>The maximum size of input WKT or PROJ.4 projection descriptions is
-limited to 8000 bytes.</P>
-<H2>EXAMPLES</H2>
-Print the projection information for the current location:<br>
-g.proj -p
-</pre></div>
-<p>
-Create a '.prj' file in ESRI format corresponding to the current location:<br>
-g.proj -wef > irish_grid.prj
-</pre></div>
-<p>
-Read the projection information from a geotiff file and print it in PROJ.4
-format:<br>
-g.proj -jf georef=ASTER_DEM20020508161837.tif
-</pre></div>
-<p>
-Convert the PROJ.4 projection description contained in a text file to WKT
-format:<br>
-cat proj4.description | g.proj -w proj4=-
-</pre></div>
-<p>
-Create a new location with the co-ordinate system referred to by EPSG code
-4326 (Latitude-Longitude/WGS84), without explicitly specifiying datum
-transformation parameters:<br>
-g.proj -c epsg=4326 location=latlong
-</pre></div>
-<p>
-Create a new location with the co-ordinate system referred to by ESRI-EPSG code
-900913 (<a href="http://spatialreference.org/ref/user/6/">Google Mercator Projection</a>)<br>
-g.proj -c epsg=900913 loc=google
-</pre></div>
-<p>
-29900 (Irish Grid), selecting datum transformation parameter set no. 2:<br>
-g.proj -c epsg=29900 datumtrans=2 location=irish_grid
-</pre></div>
-<p>
-Create a new location with the same co-ordinate system as the current
-g.proj -c location=newloc
-</pre></div>
-<p>
-Interactively change/update the datum transformation parameters for the
-current location:<br>
-g.proj -itc
-</pre></div>
-<p>
-Create a new location with the co-ordinate system from a WKT definition
-stored in a text file:<br>
-g.proj -c wkt=irish_grid.prj location=irish_grid
-</pre></div>
-<p>
-Reproject external raster map to current GRASS projection (does not always make sense!)
-using the GDAL 'gdalwarp' tool. We recommend to use the ERDAS/Img format and not
-to use the ESRI style of WKT:<br>
-# example for 30x30 pixel resolution (enforce with -tr to avoid odd values)
-gdalwarp -of HFA -tr 30 30 -t_srs "`g.proj -wf`" aster.img aster_tmerc.img
-</pre></div>
-<p>
-Reproject external vector map to current GRASS projection
-using the OGR 'ogr2ogr' tool:<br>
-ogr2ogr -t_srs "`g.proj -wf`" polbnda_italy_GB_ovest.shp polbnda_italy_LL.shp
-</pre></div>
-<H2>REFERENCES</H2>
-<a href="http://proj.maptools.org">PROJ 4</a>: Projection/datum support library<br>
-<a href="http://www.gdal.org">GDAL raster library and toolset</a><br>
-<a href="http://www.gdal.org/ogr/">OGR vector library and toolset</a>
-<P>
-<B>Further reading</B>
-<ul>
-<li> <a href="http://www.asprs.org/resources/grids/">ASPRS Grids and Datum</a>
-<li> <a href="http://www.mapref.org">MapRef - The Collection of Map Projections and Reference Systems for Europe</a>
-<li> <a href="http://www.remotesensing.org/geotiff/proj_list/">Projections Transform List</a> (PROJ4)
-</ul>
-<H2>SEE ALSO</H2>
-<EM><a href="g.setproj.html">g.setproj</a></EM><BR>
-<EM><a href="r.in.gdal.html">r.in.gdal</a></EM><BR>
-<EM><a href="v.in.ogr.html">v.in.ogr</a></EM>
-<h2>AUTHOR</h2>
-Paul Kelly
Copied: grass/trunk/general/g.proj/g.proj.html (from rev 32770, grass/trunk/general/g.proj/description.html)
--- grass/trunk/general/g.proj/g.proj.html (rev 0)
+++ grass/trunk/general/g.proj/g.proj.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,221 @@
+<P><em>g.proj</em> provides a means of converting a co-ordinate system
+description (i.e. projection information) between various formats.
+It requires <A HREF="http://www.gdal.org/ogr/">OGR</A> to compile. The basic
+functionality of the module is to report the projection information for the
+current location, either in conventional GRASS (-p flag) or PROJ.4 (-j flag)
+format.</P>
+<P>Projection information may also be output in the Well-Known Text (WKT)
+format popularised
+by proprietary GIS. In addition, if one of the parameters <em>georef</em>,
+<em>wkt</em>, <em>proj4</em> or <em>epsg</em> is specified, rather than the
+projection information being read from the current location it is imported
+from an external source as follows:
+<dl>
+<dt>georef=<em>filename</em></dt>
+<dd><em>g.proj</em> attempts to invoke GDAL and OGR in turn to read a
+georeferenced file <em>filename</em>. The projection information will be
+read from this file. If the file is not georeferenced or cannot be read,
+XY (unprojected) will be used.</dd>
+<dt>wkt=<em>filename</em> or <em>-</em></dt>
+<dd>The file <em>filename</em> should contain a projection description in WKT
+format with or without line-breaks (e.g. a '.prj' file). If <em>-</em> is given
+for the filename, the WKT description will be read from stdin rather than a
+file.</dd>
+<dt>proj4=<em>description</em> or <em>-</em></dt>
+<dd><em>description</em> should be a projection description in
+<A HREF="http://remotesensing.org/proj/">PROJ.4</a> format, enclosed in
+quotation marks if there are any spaces. If <em>-</em> is given for
+<em>description</em>, the PROJ.4 description will be read from stdin rather
+than as a directly-supplied command-line parameter.</dd>
+<dt>epsg=<em>number</em></dt>
+<dd><em>number</em> should correspond to the index number of a valid
+co-ordinate system in the <a href="http://www.epsg.org/CurrentDB.html">EPSG
+database</a>. EPSG code support is based upon a local copy of the GDAL CSV
+co-ordinate system and datum information files, stored in the directory
+${GISBASE}/etc/ogr_csv. These can be updated if necessary to support future
+revisions of the EPSG database.</dd>
+</dl>
+</P>
+<P>The -p, -j, -w, etc. flags are all functional when importing projection
+information from an external source, meaning that <em>g.proj</em> can be
+used to convert between representations of the information. It is
+<strong>not</strong> required that either the input or output be in GRASS
+format.</P>
+<P>In addition however, if the -c flag is specified, <em>g.proj</em> will
+create new GRASS projection files (PROJ_INFO, PROJ_UNITS, WIND and
+DEFAULT_WIND) based on the imported information. If the <em>location</em>
+parameter is specified in addition to -c, then a new location will be created.
+Otherwise the projection information files in the current location will be
+overwritten. The program will warn before doing this only if command-line
+interactive mode (<em>-i</em> flag) is selected.</P>
+<P>The final mode of operation of g.proj is to report on the datum
+information and datum transformation parameters associated with the
+co-ordinate system. The -d flag will report a human-readable summary of
+this.</P>
+<H2>NOTES</H2>
+<P>If the input co-ordinate system contains a datum name but no
+transformation parameters, and there is more than one suitable parameter set
+available (according to the files datum.table and datumtransform.table in
+${GISBASE}/etc), g.proj will check the value of the <em>datumtrans</em>
+option and act according to the following:<br>
+<strong>-1:</strong> List available parameter sets in a GUI-parsable (but also
+human-readable) format and exit.<br>
+<strong>0 (default):</strong> Continue without specifying parameters - if
+used when creating a location, other GRASS modules will use the "default"
+(likely non-optimum) parameters for this datum if necessary in the future.<br>
+<strong>Any other number less than or equal to the number of parameter sets
+available for this datum:</strong> Choose this parameter set and add it to the
+co-ordinate system description.<br>
+If the module is being used from the command-line through an interactive
+terminal, the <em>-i</em> flag can be specified to enable interactive
+selection of the parameter set, and the value of <em>datumtrans</em> (if
+specified) is ignored.<br>
+If the <em>-t</em> flag is specified, the module will attempt to change the
+datum transformation parameters using one of the above two methods
+<strong>even if</strong> a valid parameter set is already specified in the
+input co-ordinate system.</P>
+<P>Output is simply based on the input projection information. g.proj does
+<strong>not</strong> attempt to verify that the co-ordinate system thus
+described matches an existing system in use in the world. In particular,
+this means there are no EPSG Authority codes in the WKT output.</P>
+<P>WKT format shows the false eastings and northings in the projected unit
+(e.g. meters, feet) but in PROJ format it should always be given in meters.</P>
+<P>The maximum size of input WKT or PROJ.4 projection descriptions is
+limited to 8000 bytes.</P>
+<H2>EXAMPLES</H2>
+Print the projection information for the current location:<br>
+g.proj -p
+</pre></div>
+<p>
+Create a '.prj' file in ESRI format corresponding to the current location:<br>
+g.proj -wef > irish_grid.prj
+</pre></div>
+<p>
+Read the projection information from a geotiff file and print it in PROJ.4
+format:<br>
+g.proj -jf georef=ASTER_DEM20020508161837.tif
+</pre></div>
+<p>
+Convert the PROJ.4 projection description contained in a text file to WKT
+format:<br>
+cat proj4.description | g.proj -w proj4=-
+</pre></div>
+<p>
+Create a new location with the co-ordinate system referred to by EPSG code
+4326 (Latitude-Longitude/WGS84), without explicitly specifiying datum
+transformation parameters:<br>
+g.proj -c epsg=4326 location=latlong
+</pre></div>
+<p>
+Create a new location with the co-ordinate system referred to by ESRI-EPSG code
+900913 (<a href="http://spatialreference.org/ref/user/6/">Google Mercator Projection</a>)<br>
+g.proj -c epsg=900913 loc=google
+</pre></div>
+<p>
+29900 (Irish Grid), selecting datum transformation parameter set no. 2:<br>
+g.proj -c epsg=29900 datumtrans=2 location=irish_grid
+</pre></div>
+<p>
+Create a new location with the same co-ordinate system as the current
+location:<br>
+g.proj -c location=newloc
+</pre></div>
+<p>
+Interactively change/update the datum transformation parameters for the
+current location:<br>
+g.proj -itc
+</pre></div>
+<p>
+Create a new location with the co-ordinate system from a WKT definition
+stored in a text file:<br>
+g.proj -c wkt=irish_grid.prj location=irish_grid
+</pre></div>
+<p>
+Reproject external raster map to current GRASS projection (does not always make sense!)
+using the GDAL 'gdalwarp' tool. We recommend to use the ERDAS/Img format and not
+to use the ESRI style of WKT:<br>
+# example for 30x30 pixel resolution (enforce with -tr to avoid odd values)
+gdalwarp -of HFA -tr 30 30 -t_srs "`g.proj -wf`" aster.img aster_tmerc.img
+</pre></div>
+<p>
+Reproject external vector map to current GRASS projection
+using the OGR 'ogr2ogr' tool:<br>
+ogr2ogr -t_srs "`g.proj -wf`" polbnda_italy_GB_ovest.shp polbnda_italy_LL.shp
+</pre></div>
+<H2>REFERENCES</H2>
+<a href="http://proj.maptools.org">PROJ 4</a>: Projection/datum support library<br>
+<a href="http://www.gdal.org">GDAL raster library and toolset</a><br>
+<a href="http://www.gdal.org/ogr/">OGR vector library and toolset</a>
+<P>
+<B>Further reading</B>
+<ul>
+<li> <a href="http://www.asprs.org/resources/grids/">ASPRS Grids and Datum</a>
+<li> <a href="http://www.mapref.org">MapRef - The Collection of Map Projections and Reference Systems for Europe</a>
+<li> <a href="http://www.remotesensing.org/geotiff/proj_list/">Projections Transform List</a> (PROJ4)
+</ul>
+<H2>SEE ALSO</H2>
+<EM><a href="g.setproj.html">g.setproj</a></EM><BR>
+<EM><a href="r.in.gdal.html">r.in.gdal</a></EM><BR>
+<EM><a href="v.in.ogr.html">v.in.ogr</a></EM>
+<h2>AUTHOR</h2>
+Paul Kelly
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/general/g.region/description.html
--- grass/trunk/general/g.region/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.region/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,497 +0,0 @@
-<h2>DESCRIPTION</h2>
-The <em>g.region</em> module allows the user to manage the
-settings of the current geographic region. These regional
-boundaries can be set by the user directly and/or set from
-a region definition file (stored under the
-<kbd>windows</kbd> directory in the user's current
-mapset). The user can create, modify, and store as many
-geographic region definitions as desired for any given
-mapset. However, only one of these geographic region
-definitions will be current at any given moment, for a
-specified mapset; i.e., GRASS programs that respect the
-geographic region settings will use the current geographic
-region settings.
-<h2>DEFINITIONS</h2>
-<dl>
-<dt><b>Region:</b>
-<dd>In GRASS, a <em>region</em> refers to a geographic area
-with some defined boundaries, based on a specific map
-coordinate system and map projection. Each region also has
-associated with it the specific east-west and north-south
-resolutions of its smallest units (rectangular units called
-"cells").
-<p>
-The region's boundaries are given as the northernmost,
-southernmost, easternmost, and westernmost points that
-define its extent (cell edges). The north and south boundaries
-are commonly called <em>northings</em>, while the east and west
-boundaries are called <em>eastings</em>.
-<p>
-The region's cell resolution defines the size of the
-smallest piece of data recognized (imported, analyzed,
-displayed, stored, etc.) by GRASS modules affected by the
-current region settings. The north-south and east-west cell
-resolutions need not be the same, thus allowing non-square
-data cells to exist.
-<P>
-Typically all raster and display modules are affected by the current
-region settings, but not vector modules.
-Some special modules diverge from this rule, for example raster import
-modules and <em>v.in.region</em>.
-<dt><b>Default Region:</b>
-<dd>Each GRASS LOCATION has a fixed
-geographic region, called the default geographic region
-(stored in the region file <kbd>DEFAULT_WIND</kbd> under
-the special mapset <kbd>PERMANENT</kbd>), that defines the
-extent of the data base. While this provides a starting
-point for defining new geographic regions, user-defined
-geographic regions need not fall within this geographic
-region. The current region can be reset to the default region
-with the <b>-d</b> flag. The default region is initially set
-when the location is first created and can be reset using the
-<b>-s</b> flag.
-<dt><b>Current Region:</b>
-<dd>Each mapset has a current geographic region. This
-region defines the geographic area in which all GRASS
-displays and raster analyses will be done. Raster data will be
-resampled, if necessary, to meet the cell resolutions of
-the current geographic region setting.
-<dt><b>Saved Regions:</b>
-<dd>Each GRASS MAPSET may contain any number of
-pre-defined, and named, geographic regions. These region
-definitions are stored in the user's current mapset
-location under the <kbd>windows</kbd> directory (also
-referred to as the user's saved region definitions).
-Any of these pre-defined geographic regions
-may be selected, by name, to become the current geographic
-region. Users may also access saved region definitions
-stored under other mapsets in the current location, if
-these mapsets are included in the user's mapset search
-path or the '@' operator is used (<tt>region_name at mapset</tt>).
-</dl>
-<h2>NOTES</h2>
-After all updates have been applied, the current region's
-southern and western boundaries are (silently) adjusted so
-that the north/south distance is a multiple of the
-north/south resolution and that the east/west distance is a
-multiple of the east/west resolution.
-<p>
-With the <b>-a</b> flag all four boundaries are adjusted
-to be even multiples of the resolution, aligning the region to the
-resolution supplied by the user. The default is to
-align the region resolution to match the region boundaries.
-<p>
-The <b>-m</b> flag will report the region resolution in meters. The
-resolution is calculated by averaging the resolution at the region
-boundaries. This resolution is calculated by dividing the geodesic
-distance in meters at the boundary by the number of rows or columns.
-For example the east / west resolution (ewres) is determined from an
-average of the geodesic distances at the North and South boundaries
-divided by the number of columns.
-<!-- add'l info. include?
-Print the region resolution in meters (from geodesic). With no other
-flags the default output format is shell stype (-g). The region resolution
-represents the center of the map. The resolutions are calculated at the four
-outside edges, then the two NS edges are averaged and the two EW edges are
-averaged, the results finally printed.
-<p>
-The <b>-p</b> (or <b>-g</b>) option is recognized
-last. This means that all changes are applied to the
-region settings before printing occurs.
-<P>
-The <b>-g</b> flag prints the current region settings in shell script style.
-This format can be given back to <em>g.region</em> on its command line.
-This may also be used to save region settings as shell environment variables
-with the UNIX eval command, "<tt>eval `g.region -g`</tt>".
-<h3>Additional parameter information:</h3>
-<dl>
-<dt><b>3dview=</b><em>name</em>
-<dd>Make current region settings same as those in the named
-3dview file, which holds the region that was current when
-the 3dview was saved.
-<dt><b>zoom=</b><em>name</em>
-<dd>Shrink current region settings to the smallest region
-encompassing all non-NULL data in the named raster map
-layer that fall inside the user's current region. In this
-way you can tightly zoom in on isolated clumps within a
-bigger map.
-<p>
-If the user also includes the <b>rast=</b><em>name</em>
-option on the command line, <b>zoom=</b><em>name</em> will
-set the current region settings to the smallest region
-encompassing all non-NULL data in the named <b>zoom</b> map
-that fall inside the region stated in the cell header for
-the named <b>raster</b> map.
-<dt><b>align=</b><em>name</em>
-<dd>Set the current resolution equal to that of the named
-raster map, and align the current region to a row and
-column edge in the named map. Alignment only moves the
-existing region edges outward to the edges of the next
-nearest cell in the named raster map - not to the named
-map's edges. To perform the latter function, use the
-<b>rast=</b><em>name</em> option.
-</dl>
-<h2>EXAMPLES</h2>
-<dl>
-<dt>
-g.region n=7360100 e=699000
-</pre></div>
-<dd> will reset the northing and easting for the current
-region, but leave the south edge, west edge, and the region
-cell resolutions unchanged.
-<p>
-<dt><div class="code"><pre>
-g.region n=51:36:05N e=10:10:05E s=51:29:55N w=9:59:55E res=0:00:01
-</pre></div>
-<dd> will reset the northing, easting, southing, westing and resolution
-for the current region, here in DMS latitude-longitude style
-(decimal degrees and degrees with decimal minutes can also be used).
-<p>
-g.region -dp s=698000
-</pre></div>
-<dd> will set the current region from the default region
-for the GRASS data base location, reset the south edge to
-698000, and then print the result.
-<p>
-g.region n=n+1000 w=w-500
-</pre></div>
-<dd> The n=<em>value</em> may also be specified as a
-function of its current value: n=n+<em>value</em>
-increases the current northing, while n=n-<em>value</em>
-decreases it. This is also true for s=<em>value</em>,
-e=<em>value</em>, and w=<em>value</em>. In this example
-the current region's northern boundary is extended by 1000
-units and the current region's western boundary is
-decreased by 500 units.
-<p>
-g.region n=s+1000 e=w+1000
-</pre></div>
-<dd> This form allows the user to set the region boundary
-values relative to one another. Here, the northern
-boundary coordinate is set equal to 1000 units larger than
-the southern boundary's coordinate value, and the eastern
-boundary's coordinate value is set equal to 1000 units
-larger than the western boundary's coordinate value. The
-corresponding forms s=n-<em>value</em> and
-<p>
-w=e-<em>value</em> may be used to set the values of the
-region's southern and western boundaries, relative to the
-northern and eastern boundary values.
-g.region rast=soils
-</pre></div>
-<dd> This form will make the current region settings
-exactly the same as those given in the cell header file for
-the raster map layer <em>soils</em>.
-<p>
-g.region rast=soils zoom=soils
-</pre></div>
-<dd> This form will first look up the cell header file for
-the raster map layer <em>soils</em>, use this as the
-current region setting, and then shrink the region down to
-the smallest region which still encompasses all non-NULL
-data in the map layer <em>soils</em>. Note that if the
-parameter <em>rast=soils</em> were not specified, the
-zoom would shrink to encompass all non-NULL data values in
-the soils map that were located within the <i>current region</i>
-settings.
-<p>
-g.region -up rast=soils
-</pre></div>
-<dd> The <b>-u</b> option suppresses the re-setting of the
-current region definition. This can be useful when it is
-desired to only extract region information. In this case,
-the cell header file for the soils map layer is printed
-without changing the current region settings.
-<p>
-g.region -up zoom=soils save=soils
-</pre></div>
-<dd> This will zoom into the smallest region which
-encompasses all non-NULL soils data values, and save the
-new region settings in a file to be called <em>soils</em>
-and stored under the <kbd>windows</kbd> directory in the
-user's current mapset. The current region settings are not
-changed.
-<p>
-g.region b=0 t=3000 tbres=200 res3=100
-g.region -p3
-</pre></div>
-<dd> This will define the 3D region for voxel computations.
-In this example a volume with bottom (0m) to top (3000m)
-at horizontal resolution (100m) and vertical resolution (200m)
-is defined.
-<p>
-g.region -p
-</pre></div>
-<dd> This will print the current region in the format:
-projection: 1 (UTM)
-zone: 13
-datum: nad27
-ellipsoid: clark66
-north: 4928000
-south: 4914000
-west: 590000
-east: 609000
-nsres: 20
-ewres: 20
-rows: 700
-cols: 950
-</pre></div>
-<p>
-g.region -p3
-</pre></div>
-<dd> This will print the current region and the 3D region (used for voxels)
-in the format:
-zone: 13
-datum: nad27
-ellipsoid: clark66
-north: 4928000
-south: 4914000
-west: 590000
-east: 609000
-top: 1.00000000
-bottom: 0.00000000
-nsres: 20
-nsres3: 20
-ewres: 20
-ewres3: 20
-tbres: 1
-rows: 700
-rows3: 700
-cols: 950
-cols3: 950
-depths: 1
-</pre></div>
-<p>
-g.region -g
-</pre></div>
-<dd> The <b>-g</b> option prints the region in the
-following script style (key=value) format:
-n=4928000
-s=4914000
-w=590000
-e=609000
-nsres=20
-ewres=20
-rows=700
-cols=950
-</pre></div>
-<p>
-g.region -bg
-</pre></div>
-<dd> The <b>-bg</b> option prints the region in the
-following script style (key=value) format plus the
-boundary box in latitude-longitude/WGS84:
-n=4928000
-s=4914000
-w=590000
-e=609000
-nsres=20
-ewres=20
-rows=700
-cols=950
-LL_W=-103.87080682
-LL_E=-103.62942884
-LL_N=44.50164277
-LL_S=44.37302019
-</pre></div>
-<p>
-g.region -l
-</pre></div>
-<dd> The <b>-l</b> option prints the region in the
-following format:
-long: -103.86789484 lat: 44.50165890 (north/west corner)
-long: -103.62895703 lat: 44.49904013 (north/east corner)
-long: -103.63190061 lat: 44.37303558 (south/east corner)
-long: -103.87032572 lat: 44.37564292 (south/west corner)
-rows: 700
-cols: 950
-Center longitude: 103:44:59.170374W [-103.74977]
-Center latitude: 44:26:14.439781N [44.43734]
-</pre></div>
-<p>
-g.region -pm
-</pre></div>
- (latitude-longitude location):
-projection: 3 (Latitude-Longitude)
-zone: 0
-ellipsoid: wgs84
-north: 90N
-south: 40N
-west: 20W
-east: 20E
-nsres: 928.73944902
-ewres: 352.74269109
-rows: 6000
-cols: 4800
-</pre></div>
-Note that the resolution is here reported in meters, not decimal degrees.
-</dl>
-<p>
-Usage example of <em>g.region</em> in a shell with external software:<br>
-<!-- why not 'v.in.ogr spatial=' ?? -->
-Extract spatial subset of external vector map 'soils.shp' to new external
-vector map 'soils_cut.shp' using the OGR 'ogr2ogr' tool:<br>
-eval `g.region -g`
-ogr2ogr -spat $w $s $e $n soils_cut.shp soils.shp
-</pre></div>
-This requires that the location/SHAPE file projection match.
-<p>
-Usage example of <em>g.proj</em> and <em>g.region</em> in a shell with external software:<br>
-Extract spatial subset of external raster map 'p016r035_7t20020524_z17_nn30.tif'
-to new external raster map'p016r035_7t20020524_nc_spm_wake_nn30.tif using the GDAL
-'gdalwarp' tool:<br>
-eval `g.region -g`
-gdalwarp -t_srs "`g.proj -wf`" -te $w $s $e $n \
- p016r035_7t20020524_z17_nn30.tif \
- p016r035_7t20020524_nc_spm_wake_nn30.tif
-</pre></div>
-Here the input raster map does not have to match the location
-projection since it is reprojected on the fly.
-<h2>SEE ALSO</h2>
-<em>
-<a HREF="d.zoom.html">d.zoom</a><br>
-<a HREF="g.access.html">g.access</a><br>
-<a HREF="g.mapsets.html">g.mapsets</a><br>
-<a HREF="g.proj.html">g.proj</a><BR>
-<a HREF="g.setproj.html">g.setproj</a><BR>
-environment variables: <a HREF="variables.html#internal">GRASS_REGION and WIND_OVERRIDE</a>
-</em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S.Army Construction Engineering
-Research Laboratory
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/general/g.region/g.region.html (from rev 32770, grass/trunk/general/g.region/description.html)
--- grass/trunk/general/g.region/g.region.html (rev 0)
+++ grass/trunk/general/g.region/g.region.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,497 @@
+<h2>DESCRIPTION</h2>
+The <em>g.region</em> module allows the user to manage the
+settings of the current geographic region. These regional
+boundaries can be set by the user directly and/or set from
+a region definition file (stored under the
+<kbd>windows</kbd> directory in the user's current
+mapset). The user can create, modify, and store as many
+geographic region definitions as desired for any given
+mapset. However, only one of these geographic region
+definitions will be current at any given moment, for a
+specified mapset; i.e., GRASS programs that respect the
+geographic region settings will use the current geographic
+region settings.
+<h2>DEFINITIONS</h2>
+<dl>
+<dt><b>Region:</b>
+<dd>In GRASS, a <em>region</em> refers to a geographic area
+with some defined boundaries, based on a specific map
+coordinate system and map projection. Each region also has
+associated with it the specific east-west and north-south
+resolutions of its smallest units (rectangular units called
+"cells").
+<p>
+The region's boundaries are given as the northernmost,
+southernmost, easternmost, and westernmost points that
+define its extent (cell edges). The north and south boundaries
+are commonly called <em>northings</em>, while the east and west
+boundaries are called <em>eastings</em>.
+<p>
+The region's cell resolution defines the size of the
+smallest piece of data recognized (imported, analyzed,
+displayed, stored, etc.) by GRASS modules affected by the
+current region settings. The north-south and east-west cell
+resolutions need not be the same, thus allowing non-square
+data cells to exist.
+<P>
+Typically all raster and display modules are affected by the current
+region settings, but not vector modules.
+Some special modules diverge from this rule, for example raster import
+modules and <em>v.in.region</em>.
+<dt><b>Default Region:</b>
+<dd>Each GRASS LOCATION has a fixed
+geographic region, called the default geographic region
+(stored in the region file <kbd>DEFAULT_WIND</kbd> under
+the special mapset <kbd>PERMANENT</kbd>), that defines the
+extent of the data base. While this provides a starting
+point for defining new geographic regions, user-defined
+geographic regions need not fall within this geographic
+region. The current region can be reset to the default region
+with the <b>-d</b> flag. The default region is initially set
+when the location is first created and can be reset using the
+<b>-s</b> flag.
+<dt><b>Current Region:</b>
+<dd>Each mapset has a current geographic region. This
+region defines the geographic area in which all GRASS
+displays and raster analyses will be done. Raster data will be
+resampled, if necessary, to meet the cell resolutions of
+the current geographic region setting.
+<dt><b>Saved Regions:</b>
+<dd>Each GRASS MAPSET may contain any number of
+pre-defined, and named, geographic regions. These region
+definitions are stored in the user's current mapset
+location under the <kbd>windows</kbd> directory (also
+referred to as the user's saved region definitions).
+Any of these pre-defined geographic regions
+may be selected, by name, to become the current geographic
+region. Users may also access saved region definitions
+stored under other mapsets in the current location, if
+these mapsets are included in the user's mapset search
+path or the '@' operator is used (<tt>region_name at mapset</tt>).
+</dl>
+<h2>NOTES</h2>
+After all updates have been applied, the current region's
+southern and western boundaries are (silently) adjusted so
+that the north/south distance is a multiple of the
+north/south resolution and that the east/west distance is a
+multiple of the east/west resolution.
+<p>
+With the <b>-a</b> flag all four boundaries are adjusted
+to be even multiples of the resolution, aligning the region to the
+resolution supplied by the user. The default is to
+align the region resolution to match the region boundaries.
+<p>
+The <b>-m</b> flag will report the region resolution in meters. The
+resolution is calculated by averaging the resolution at the region
+boundaries. This resolution is calculated by dividing the geodesic
+distance in meters at the boundary by the number of rows or columns.
+For example the east / west resolution (ewres) is determined from an
+average of the geodesic distances at the North and South boundaries
+divided by the number of columns.
+<!-- add'l info. include?
+Print the region resolution in meters (from geodesic). With no other
+flags the default output format is shell stype (-g). The region resolution
+represents the center of the map. The resolutions are calculated at the four
+outside edges, then the two NS edges are averaged and the two EW edges are
+averaged, the results finally printed.
+<p>
+The <b>-p</b> (or <b>-g</b>) option is recognized
+last. This means that all changes are applied to the
+region settings before printing occurs.
+<P>
+The <b>-g</b> flag prints the current region settings in shell script style.
+This format can be given back to <em>g.region</em> on its command line.
+This may also be used to save region settings as shell environment variables
+with the UNIX eval command, "<tt>eval `g.region -g`</tt>".
+<h3>Additional parameter information:</h3>
+<dl>
+<dt><b>3dview=</b><em>name</em>
+<dd>Make current region settings same as those in the named
+3dview file, which holds the region that was current when
+the 3dview was saved.
+<dt><b>zoom=</b><em>name</em>
+<dd>Shrink current region settings to the smallest region
+encompassing all non-NULL data in the named raster map
+layer that fall inside the user's current region. In this
+way you can tightly zoom in on isolated clumps within a
+bigger map.
+<p>
+If the user also includes the <b>rast=</b><em>name</em>
+option on the command line, <b>zoom=</b><em>name</em> will
+set the current region settings to the smallest region
+encompassing all non-NULL data in the named <b>zoom</b> map
+that fall inside the region stated in the cell header for
+the named <b>raster</b> map.
+<dt><b>align=</b><em>name</em>
+<dd>Set the current resolution equal to that of the named
+raster map, and align the current region to a row and
+column edge in the named map. Alignment only moves the
+existing region edges outward to the edges of the next
+nearest cell in the named raster map - not to the named
+map's edges. To perform the latter function, use the
+<b>rast=</b><em>name</em> option.
+</dl>
+<h2>EXAMPLES</h2>
+<dl>
+<dt>
+g.region n=7360100 e=699000
+</pre></div>
+<dd> will reset the northing and easting for the current
+region, but leave the south edge, west edge, and the region
+cell resolutions unchanged.
+<p>
+<dt><div class="code"><pre>
+g.region n=51:36:05N e=10:10:05E s=51:29:55N w=9:59:55E res=0:00:01
+</pre></div>
+<dd> will reset the northing, easting, southing, westing and resolution
+for the current region, here in DMS latitude-longitude style
+(decimal degrees and degrees with decimal minutes can also be used).
+<p>
+g.region -dp s=698000
+</pre></div>
+<dd> will set the current region from the default region
+for the GRASS data base location, reset the south edge to
+698000, and then print the result.
+<p>
+g.region n=n+1000 w=w-500
+</pre></div>
+<dd> The n=<em>value</em> may also be specified as a
+function of its current value: n=n+<em>value</em>
+increases the current northing, while n=n-<em>value</em>
+decreases it. This is also true for s=<em>value</em>,
+e=<em>value</em>, and w=<em>value</em>. In this example
+the current region's northern boundary is extended by 1000
+units and the current region's western boundary is
+decreased by 500 units.
+<p>
+g.region n=s+1000 e=w+1000
+</pre></div>
+<dd> This form allows the user to set the region boundary
+values relative to one another. Here, the northern
+boundary coordinate is set equal to 1000 units larger than
+the southern boundary's coordinate value, and the eastern
+boundary's coordinate value is set equal to 1000 units
+larger than the western boundary's coordinate value. The
+corresponding forms s=n-<em>value</em> and
+<p>
+w=e-<em>value</em> may be used to set the values of the
+region's southern and western boundaries, relative to the
+northern and eastern boundary values.
+g.region rast=soils
+</pre></div>
+<dd> This form will make the current region settings
+exactly the same as those given in the cell header file for
+the raster map layer <em>soils</em>.
+<p>
+g.region rast=soils zoom=soils
+</pre></div>
+<dd> This form will first look up the cell header file for
+the raster map layer <em>soils</em>, use this as the
+current region setting, and then shrink the region down to
+the smallest region which still encompasses all non-NULL
+data in the map layer <em>soils</em>. Note that if the
+parameter <em>rast=soils</em> were not specified, the
+zoom would shrink to encompass all non-NULL data values in
+the soils map that were located within the <i>current region</i>
+settings.
+<p>
+g.region -up rast=soils
+</pre></div>
+<dd> The <b>-u</b> option suppresses the re-setting of the
+current region definition. This can be useful when it is
+desired to only extract region information. In this case,
+the cell header file for the soils map layer is printed
+without changing the current region settings.
+<p>
+g.region -up zoom=soils save=soils
+</pre></div>
+<dd> This will zoom into the smallest region which
+encompasses all non-NULL soils data values, and save the
+new region settings in a file to be called <em>soils</em>
+and stored under the <kbd>windows</kbd> directory in the
+user's current mapset. The current region settings are not
+changed.
+<p>
+g.region b=0 t=3000 tbres=200 res3=100
+g.region -p3
+</pre></div>
+<dd> This will define the 3D region for voxel computations.
+In this example a volume with bottom (0m) to top (3000m)
+at horizontal resolution (100m) and vertical resolution (200m)
+is defined.
+<p>
+g.region -p
+</pre></div>
+<dd> This will print the current region in the format:
+projection: 1 (UTM)
+zone: 13
+datum: nad27
+ellipsoid: clark66
+north: 4928000
+south: 4914000
+west: 590000
+east: 609000
+nsres: 20
+ewres: 20
+rows: 700
+cols: 950
+</pre></div>
+<p>
+g.region -p3
+</pre></div>
+<dd> This will print the current region and the 3D region (used for voxels)
+in the format:
+zone: 13
+datum: nad27
+ellipsoid: clark66
+north: 4928000
+south: 4914000
+west: 590000
+east: 609000
+top: 1.00000000
+bottom: 0.00000000
+nsres: 20
+nsres3: 20
+ewres: 20
+ewres3: 20
+tbres: 1
+rows: 700
+rows3: 700
+cols: 950
+cols3: 950
+depths: 1
+</pre></div>
+<p>
+g.region -g
+</pre></div>
+<dd> The <b>-g</b> option prints the region in the
+following script style (key=value) format:
+n=4928000
+s=4914000
+w=590000
+e=609000
+nsres=20
+ewres=20
+rows=700
+cols=950
+</pre></div>
+<p>
+g.region -bg
+</pre></div>
+<dd> The <b>-bg</b> option prints the region in the
+following script style (key=value) format plus the
+boundary box in latitude-longitude/WGS84:
+n=4928000
+s=4914000
+w=590000
+e=609000
+nsres=20
+ewres=20
+rows=700
+cols=950
+LL_W=-103.87080682
+LL_E=-103.62942884
+LL_N=44.50164277
+LL_S=44.37302019
+</pre></div>
+<p>
+g.region -l
+</pre></div>
+<dd> The <b>-l</b> option prints the region in the
+following format:
+long: -103.86789484 lat: 44.50165890 (north/west corner)
+long: -103.62895703 lat: 44.49904013 (north/east corner)
+long: -103.63190061 lat: 44.37303558 (south/east corner)
+long: -103.87032572 lat: 44.37564292 (south/west corner)
+rows: 700
+cols: 950
+Center longitude: 103:44:59.170374W [-103.74977]
+Center latitude: 44:26:14.439781N [44.43734]
+</pre></div>
+<p>
+g.region -pm
+</pre></div>
+ (latitude-longitude location):
+projection: 3 (Latitude-Longitude)
+zone: 0
+ellipsoid: wgs84
+north: 90N
+south: 40N
+west: 20W
+east: 20E
+nsres: 928.73944902
+ewres: 352.74269109
+rows: 6000
+cols: 4800
+</pre></div>
+Note that the resolution is here reported in meters, not decimal degrees.
+</dl>
+<p>
+Usage example of <em>g.region</em> in a shell with external software:<br>
+<!-- why not 'v.in.ogr spatial=' ?? -->
+Extract spatial subset of external vector map 'soils.shp' to new external
+vector map 'soils_cut.shp' using the OGR 'ogr2ogr' tool:<br>
+eval `g.region -g`
+ogr2ogr -spat $w $s $e $n soils_cut.shp soils.shp
+</pre></div>
+This requires that the location/SHAPE file projection match.
+<p>
+Usage example of <em>g.proj</em> and <em>g.region</em> in a shell with external software:<br>
+Extract spatial subset of external raster map 'p016r035_7t20020524_z17_nn30.tif'
+to new external raster map'p016r035_7t20020524_nc_spm_wake_nn30.tif using the GDAL
+'gdalwarp' tool:<br>
+eval `g.region -g`
+gdalwarp -t_srs "`g.proj -wf`" -te $w $s $e $n \
+ p016r035_7t20020524_z17_nn30.tif \
+ p016r035_7t20020524_nc_spm_wake_nn30.tif
+</pre></div>
+Here the input raster map does not have to match the location
+projection since it is reprojected on the fly.
+<h2>SEE ALSO</h2>
+<em>
+<a HREF="d.zoom.html">d.zoom</a><br>
+<a HREF="g.access.html">g.access</a><br>
+<a HREF="g.mapsets.html">g.mapsets</a><br>
+<a HREF="g.proj.html">g.proj</a><BR>
+<a HREF="g.setproj.html">g.setproj</a><BR>
+environment variables: <a HREF="variables.html#internal">GRASS_REGION and WIND_OVERRIDE</a>
+</em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S.Army Construction Engineering
+Research Laboratory
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/general/g.setproj/description.html
--- grass/trunk/general/g.setproj/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.setproj/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,95 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>g.setproj</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<H2>NAME</H2>
-<EM><b>g.setproj</b></EM> - Allows the user to create the PROJ_INFO and the
-PROJ_UNITS files to record the projection information associated with a
-current location.
-<BR>
-<H2>SYNOPSIS</H2>
-<B>g.setproj</B>
-<H2>DESCRIPTION</H2>
-Allows a user to create a PROJ_INFO file in the PERMANENT mapset of the
-current location. PROJ_INFO file is used to record the projection information
-associated with the specified mapset.
-<H2>NOTES</H2>
-The user running <EM>g.setproj</EM> must own the PERMANENT
-mapset and it must be currently selected.
-It is highly recommended to run <EM>g.setproj</EM> after
-creating a new location so that conversion programs (such
-as <EM>v.proj</EM>) can be run.
-<P>The user will be prompted for the projection name.
-Most projections are supported. The
-<A HREF="http://proj.maptools.org/">PROJ.4</A> abbreviations for the names are
-used with two exceptions, viz. 'll', for latitude / longitude geographic
-co-ordinates, and 'stp', for the State Plane Co-ordinate system (used in the
-USA).</P>
-<P>After the projection name, the user will be asked for a geodetic datum. If
-no datum transformation support is needed, the question may be answered with no,
-and no datum will be specified in the PROJ_INFO file. If this is the case
-the user must specify the ellipsoid (model of the curvature of the earth) to
-be used, otherwise it is determined by the datum being used.</P>
-<P>If the datum or ellipsoid required are not
-listed within this program, the user/administrator may add the definition
-to the files datum.table, datumtransform.table and ellipse.table in the
-$GISBASE/etc/ directory.</P>
-<P>Depending on the projection selected, the user will then be prompted for
-the various other parameters required to define it.</P>
-<P>
-The projections of aea, lcc, merc, leae, leac, and
-tmerc will generate a request to the user for the prime meridian and standard
-parallel for the output map.
-<H2>SEE ALSO</H2>
-<EM><A HREF="g.proj.html">g.proj</A></EM>,
-<EM><A HREF="m.proj.html">m.proj</A></EM>,
-<EM><A HREF="r.proj.html">r.proj</A></EM>,
-<EM><A HREF="v.proj.html">v.proj</A></EM>,
-<EM><A HREF="http://proj.maptools.org">PROJ.4</A></EM>
-<P>
-<ul>
-<li> A guide to <a href="http://erg.usgs.gov/isb/pubs/MapProjections/projections.html">Map Projections</a> by USGS
-</ul>
-<H2>AUTHOR</H2>
-Irina Kosinovsky,
-U.S. Army Construction Engineering
-Research Laboratory<BR>
-Morten Hulden, morten at tor.ngb.se - rewrote module and added 121 projections <BR>
-Andreas Lange, andreas.lange at rhein-main.de - added prelimnary map datum support
-<p>
-</p>
-</body>
-</html>
Copied: grass/trunk/general/g.setproj/g.setproj.html (from rev 32770, grass/trunk/general/g.setproj/description.html)
--- grass/trunk/general/g.setproj/g.setproj.html (rev 0)
+++ grass/trunk/general/g.setproj/g.setproj.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,95 @@
+<html>
+<head>
+<title>g.setproj</title>
+</head>
+<H2>NAME</H2>
+<EM><b>g.setproj</b></EM> - Allows the user to create the PROJ_INFO and the
+PROJ_UNITS files to record the projection information associated with a
+current location.
+<BR>
+<H2>SYNOPSIS</H2>
+<B>g.setproj</B>
+<H2>DESCRIPTION</H2>
+Allows a user to create a PROJ_INFO file in the PERMANENT mapset of the
+current location. PROJ_INFO file is used to record the projection information
+associated with the specified mapset.
+<H2>NOTES</H2>
+The user running <EM>g.setproj</EM> must own the PERMANENT
+mapset and it must be currently selected.
+It is highly recommended to run <EM>g.setproj</EM> after
+creating a new location so that conversion programs (such
+as <EM>v.proj</EM>) can be run.
+<P>The user will be prompted for the projection name.
+Most projections are supported. The
+<A HREF="http://proj.maptools.org/">PROJ.4</A> abbreviations for the names are
+used with two exceptions, viz. 'll', for latitude / longitude geographic
+co-ordinates, and 'stp', for the State Plane Co-ordinate system (used in the
+USA).</P>
+<P>After the projection name, the user will be asked for a geodetic datum. If
+no datum transformation support is needed, the question may be answered with no,
+and no datum will be specified in the PROJ_INFO file. If this is the case
+the user must specify the ellipsoid (model of the curvature of the earth) to
+be used, otherwise it is determined by the datum being used.</P>
+<P>If the datum or ellipsoid required are not
+listed within this program, the user/administrator may add the definition
+to the files datum.table, datumtransform.table and ellipse.table in the
+$GISBASE/etc/ directory.</P>
+<P>Depending on the projection selected, the user will then be prompted for
+the various other parameters required to define it.</P>
+<P>
+The projections of aea, lcc, merc, leae, leac, and
+tmerc will generate a request to the user for the prime meridian and standard
+parallel for the output map.
+<H2>SEE ALSO</H2>
+<EM><A HREF="g.proj.html">g.proj</A></EM>,
+<EM><A HREF="m.proj.html">m.proj</A></EM>,
+<EM><A HREF="r.proj.html">r.proj</A></EM>,
+<EM><A HREF="v.proj.html">v.proj</A></EM>,
+<EM><A HREF="http://proj.maptools.org">PROJ.4</A></EM>
+<P>
+<ul>
+<li> A guide to <a href="http://erg.usgs.gov/isb/pubs/MapProjections/projections.html">Map Projections</a> by USGS
+</ul>
+<H2>AUTHOR</H2>
+Irina Kosinovsky,
+U.S. Army Construction Engineering
+Research Laboratory<BR>
+Morten Hulden, morten at tor.ngb.se - rewrote module and added 121 projections <BR>
+Andreas Lange, andreas.lange at rhein-main.de - added prelimnary map datum support
+<p>
+</p>
+</body>
+</html>
Deleted: grass/trunk/general/g.tempfile/description.html
--- grass/trunk/general/g.tempfile/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.tempfile/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,53 +0,0 @@
-<EM>g.tempfile</EM>
-is designed for shell scripts that need to use large temporary files.
-GRASS provides a mechanism for temporary files that does not depend on
-/tmp. GRASS temporary files are created in the data base with the assumption
-that there will be enough space under the data base for large files.
-GRASS periodically removes temporary files that have been left behind
-by programs that failed to remove them before terminating.
-<P>
-creates an unique file and prints the name. The user is required to provide
-a process-id which will be used as part of the name of the file.
-Most Unix shells provide a way to get the process id of the current shell.
-For /bin/sh and /bin/csh this is $$.
-It is recommended that $$ be specified as the process-id for
-<EM>g.tempfile</EM>.
-<H2>EXAMPLE</H2>
-For /bin/sh scripts the following syntax should be used:
-<div class="code"><PRE>
-temp1=`g.tempfile pid=$$`
-temp2=`g.tempfile pid=$$`
-</PRE></div>
-For /bin/csh scripts, the following can be used:
-set temp1=`g.tempfile pid=$$`
-set temp2=`g.tempfile pid=$$`
-</PRE></div>
-<H2>NOTES</H2>
-Each call to <EM>g.tempfile</EM>
-creates a different (i.e. unique) name.
-Although GRASS does eventually get around to removing
-tempfiles that have been left behind, the programmer should
-make every effort to remove these files. They often get
-large and take up disk space. If you write /bin/sh scripts,
-learn to use the /bin/sh <EM>trap</EM> command. If you
-write /bin/csh scripts, learn to use the /bin/csh
-<EM>onintr</EM> command.
-<H2>AUTHOR</H2>
-Michael Shapiro,
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/general/g.tempfile/g.tempfile.html (from rev 32770, grass/trunk/general/g.tempfile/description.html)
--- grass/trunk/general/g.tempfile/g.tempfile.html (rev 0)
+++ grass/trunk/general/g.tempfile/g.tempfile.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,53 @@
+<EM>g.tempfile</EM>
+is designed for shell scripts that need to use large temporary files.
+GRASS provides a mechanism for temporary files that does not depend on
+/tmp. GRASS temporary files are created in the data base with the assumption
+that there will be enough space under the data base for large files.
+GRASS periodically removes temporary files that have been left behind
+by programs that failed to remove them before terminating.
+<P>
+creates an unique file and prints the name. The user is required to provide
+a process-id which will be used as part of the name of the file.
+Most Unix shells provide a way to get the process id of the current shell.
+For /bin/sh and /bin/csh this is $$.
+It is recommended that $$ be specified as the process-id for
+<EM>g.tempfile</EM>.
+<H2>EXAMPLE</H2>
+For /bin/sh scripts the following syntax should be used:
+<div class="code"><PRE>
+temp1=`g.tempfile pid=$$`
+temp2=`g.tempfile pid=$$`
+</PRE></div>
+For /bin/csh scripts, the following can be used:
+set temp1=`g.tempfile pid=$$`
+set temp2=`g.tempfile pid=$$`
+</PRE></div>
+<H2>NOTES</H2>
+Each call to <EM>g.tempfile</EM>
+creates a different (i.e. unique) name.
+Although GRASS does eventually get around to removing
+tempfiles that have been left behind, the programmer should
+make every effort to remove these files. They often get
+large and take up disk space. If you write /bin/sh scripts,
+learn to use the /bin/sh <EM>trap</EM> command. If you
+write /bin/csh scripts, learn to use the /bin/csh
+<EM>onintr</EM> command.
+<H2>AUTHOR</H2>
+Michael Shapiro,
Deleted: grass/trunk/general/g.transform/description.html
--- grass/trunk/general/g.transform/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.transform/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,15 +0,0 @@
-<EM>g.transform</EM> is an utility to compute transformation
-based upon GCPs and output error measurements.
-<H2>SEE ALSO</H2>
-<EM><A HREF="i.rectify.html">i.rectify</A></EM>
-<H2>AUTHORS</H2>
-Brian J. Buckley<br>
-Glynn Clements
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/general/g.transform/g.transform.html (from rev 32770, grass/trunk/general/g.transform/description.html)
--- grass/trunk/general/g.transform/g.transform.html (rev 0)
+++ grass/trunk/general/g.transform/g.transform.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,15 @@
+<EM>g.transform</EM> is an utility to compute transformation
+based upon GCPs and output error measurements.
+<H2>SEE ALSO</H2>
+<EM><A HREF="i.rectify.html">i.rectify</A></EM>
+<H2>AUTHORS</H2>
+Brian J. Buckley<br>
+Glynn Clements
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/general/g.version/description.html
--- grass/trunk/general/g.version/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/general/g.version/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,18 +0,0 @@
-<EM>g.version</EM>
-prints to standard output the GRASS version number, date,
-the GRASS copyright and GRASS build information.
-<H2>NOTES</H2>
-This program requires no command line arguments; the user simply types
-<B>g.version</B> on the command line to see the version number and date
-of the GRASS software currently being run by the user.
-<H2>AUTHOR</H2>
-Michael Shapiro,
Copied: grass/trunk/general/g.version/g.version.html (from rev 32770, grass/trunk/general/g.version/description.html)
--- grass/trunk/general/g.version/g.version.html (rev 0)
+++ grass/trunk/general/g.version/g.version.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,18 @@
+<EM>g.version</EM>
+prints to standard output the GRASS version number, date,
+the GRASS copyright and GRASS build information.
+<H2>NOTES</H2>
+This program requires no command line arguments; the user simply types
+<B>g.version</B> on the command line to see the version number and date
+of the GRASS software currently being run by the user.
+<H2>AUTHOR</H2>
+Michael Shapiro,
Modified: grass/trunk/gui/tcltk/gis.m/Makefile
--- grass/trunk/gui/tcltk/gis.m/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/gui/tcltk/gis.m/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -4,20 +4,15 @@
include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script install_scripts myhtml
+default: script install_scripts
install_scripts:
if [ ! -d $(GISBASE)/etc/gm ] ; then $(MKDIR) $(GISBASE)/etc/gm; fi
- #$(INSTALL) description.html $(GISBASE)/docs/html/gis.m.html
for file in *.tcl ; do $(INSTALL) $$file $(GISBASE)/etc/gm/ ; done
for file in *.gif ; do $(INSTALL_DATA) $$file $(GISBASE)/etc/gm/ ; done
for file in docs/gm_*.html ; do $(INSTALL_DATA) $$file $(GISBASE)/docs/html/ ; done
for file in docs/gm_*.png ; do $(INSTALL_DATA) $$file $(GISBASE)/docs/html/ ; done
for file in docs/gm_*.jpg ; do $(INSTALL_DATA) $$file $(GISBASE)/docs/html/ ; done
-myhtml:
- $(MAKE) htmlscript PGM=gis.m
$(BIN)/$(PGM).bat: $(PGM).bat
$(INSTALL_DATA) $< $@
Deleted: grass/trunk/gui/tcltk/gis.m/description.html
--- grass/trunk/gui/tcltk/gis.m/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/gui/tcltk/gis.m/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,431 +0,0 @@
-The <b>GRASS GIS Manager</b>
-provides an interactive graphical interface to GRASS commands. By
-default, it is started automatically with each GRASS session. The GIS
-Manager can be quit by selecting the <em>'File->Exit</em><em>'</em>
-menu item. The GIS Manager can be restarted from the GRASS command line
-shell by typing "<i>gis.m</i>".<br>
-<br>
-The GIS Manager includes a set of pull-down menus for all GRASS GIS
-functions (analysis, file I/O, GIS configuration and management), two
-rows of buttons that manage display layers, an upper window in
-which layers to display are organized, and a lower
-window which contains options panels for layers in the layer tree.
-<br><br>
-<center>
-<img src="gm_gismgr.jpg" alt="GIS Manager window" height="551" width="480">
-</center>
-<br>
-<br>
-The top left button opens a new map display window. Each map display
-has a unique set of layers to display and region setting (zoom). Other
-buttons add layers of different types for display in the selected map
-display window. There are additional buttons for saving or opening
-group display file, starting XGANIM (display animator) display
-interfaces (requires motif), and digitizing.
-<i>Mouse-over help</i> is available for all buttons.
-<P>
-Map layers are listed in the window below the
-buttons. Layers can include raster and vector maps, text, map
-enhancements (scale and north arrow, and grids), and commands
-(where any GRASS command be written). Layers are displayed in as
-arranged in the layer tree: the bottom layer
-is displayed first and the top is displayed last, as if
-layers are a series of stacked overlays. Any layer can be
-renamed by double clicking on its name and typing a new name.
-<P>
-The check box to the left of each layer makes it active or inactive for
-display.
-Only active layers are displayed/redisplayed when the display button is
-pressed. Layers can be organized into groups; entire groups can be
-activated or deactivated for display. Groups can be saved to a file and
-opened in subsequent sessions, restoring all layers and their display
-options.
-<P>
-When a layer is selected with the mouse, its options are shown in the
-panel below the layer tree window. Help for each layer type can be
-accessed by pressing the GRASS button in the option panel.<br>
-<P>
-Each map display has a unique layer tree and region setting (zoom).
-Buttons on each map display manage the map in the display (zoom and
-pan), provide tools for query and distance measurement, and exporting
-or printing the display. The geographic coordinates under the cursor
-are displayed in the indicator window (lower right window frame). It is
-important to note that zooming in any display will have NO effect on
-the 'computational region' setting (set with g.region). Only by selecting
-the "Set current region to match display" item in the zoom menu (in the
-map display tool bar) will the current display extents be copied to
-the computational region extents.
-<br><br>
-<center>
-<img src="gm_mapdisp.jpg" alt="Map Display window" height="422" width="480">
-</center>
-<br><br>
-A separate console window shows all commands issued and all command
-output (upper window). GRASS commands (and any other unix/linux
-commands) can be run from the console (lower window).<br>
-<br>
-<center>
-<img src="gm_gronsole.png" alt="Output and command console window" height="231" width="480">
-</center>
-<br>
-<h2>GIS MANAGER BUTTON FUNCTIONS</h2>
-<img src="gm_gismgrtools.png" alt="GIS Manager Toolbar">
-<H3><u>Top Row</u></H3>
-<DL>
-<DT><img src="icons/grass/gui-startmon.gif"> Open new map display</DT>
-<DD>Opens a new map display and resets layer tree.</DD>
-<DT><img src="icons/grass/element-cell.gif"> Add raster layer</DT>
-<DD>Adds a raster map to the layer tree. Raster display options include:
-displaying a selected subset of raster cells, defined by their cat
-values; draping (or "fusing") a second map over the base map;
-and displaying legends for the base map and draped map.
-<i>See <a href="d.rast.html">d.rast</a> and <a href="d.his.html">d.his</a>
- (for draping/fusing).</i>
-</DD>
-<DT><img src="icons/grass/channel-rgb.gif"> Add RGB or HIS raster layer</DT>
-<DD>Combines and displays three raster maps defined as red, green, and blue
-channels; or combines and displays two or three raster maps defined as
-hue, intensity, and (optionally) saturation channels.
-<i>See <a href="d.rgb.html">d.rgb</a> and <a href="d.his.html">d.his</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.histogram.gif"> Add histogram layer</DT>
-<DD>Adds a layer to display histogram of a raster map or image.
-<i>See <a href="d.histogram.html">d.histogram</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.rast.num.gif"> Add cell values layer</DT>
-<DD>Adds map of raster cells with cell values printed inside.
-Only works when <10,000 cells are displayed.
-<i>See <a href="d.rast.num.html">d.rast.num</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.rast.arrow.gif"> Add raster arrows layer</DT>
-<DD>Adds map of raster cells with directional arrows drawn.
-Arrow direction and length are determined by separate aspect/directional map
-and (optional) slope/intensity map.
-<i>See <a href="d.rast.arrow.html">d.rast.arrow</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.legend.gif"> Add raster legend</DT>
-<DD>Adds a legend for a single raster map to the layer tree.
-Multiple options for formatting the legend are available.
-<i>See <a href="d.legend.html">d.legend</a>.</i>
-</DD>
-<DT><img src="icons/grass/element-vector.gif"> Add vector layer</DT>
-<DD>Adds a vector map to the layer tree. A large number of options are
-available for displaying the vector map, including: outline and fill
-color, icon type and size for points, line widths for all vector types,
-automatic labeling using an attribute column, querying cats or
-attributes to limit vectors displayed, and restricting vector display
-depending on region size.
-<i>See <a href="d.vect.html">d.vect</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.vect.thematic.gif"> Add thematic map layer
-(for all vector types)</DT>
-<DD>Adds layer for thematic display values from a numeric attribute column
-associated with a vector map. Options include: thematic display type
-(graduated colors or point sizes), methods for creating display
-intervals, SQL query of attribute column to limit vector objects to
-display, control of point icon types and sizes, control of thematic
-color schemes, creation of legend for thematic map, and saving the
-results of thematic mapping to a ps.map instructions file for later
-printing.
-<i>See <a href="d.vect.thematic.html">d.vect.thematic</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.vect.chart.gif"> Add thematic charts layer
-(for vector points)</DT>
-<DD>Adds layer in which pie or bar charts can be automatically created at
-vector point locations. Charts display values from selected columns in the
-associated attribute table. Options include: chart type, layer and
-attributes to chart, chart colors, and chart size (fixed or based on
-attribute column).
-<i>See <a href="d.vect.chart.html">d.vect.chart</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.labels.gif"> Add raster labels layer for vector
-objects (from existing labels file)</DT>
-<DD>Add raster text layer from a labels file for vector objects created with
-the <em><a href="v.label.html">v.label</a></em> module (accessed from button
-in options panel). A labels file can also be created with a text editor.
-<i>See <a href="d.labels.html">d.labels</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.text.gif"> Add text layer</DT>
-<DD>Adds layer to display a line of text using default GRASS font
-(selected with <em><a href="d.font.html">d.font</a></em>).
-Options include: text placement (screen coordinates); and text size,
-bolding, and color.
-<i>See <a href="d.text.html">d.text</a>.</i>
-</DD>
-<DT><img src="icons/grass/gui-maptext.gif"> Add PostScript labels layer for vector
-<DD>Add PostScript text layer from a labels file for vector objects created
-with the <em><a href="v.label.html">v.label</a></em> module (accessed from
-button in options panel). A labels file can also be created with a text editor.
-</DD>
-<DT><img src="icons/grass/gui-maplabels.gif"> Add PostScript text layer</DT>
-<DD>Adds layer to display a line of PostScript text. Options include: text
-placement by coordinates (geographic or screen); text
-alignment, font and line spacing; and text size, bolding, and color.
-</DL>
-<BR><BR>
-<H3><u>Bottom Row</u></H3>
-<DL>
-<DT><img src="icons/grass/module-d.barscale.gif"> Add scalebar and north arrow layer</DT>
-<DD>Adds layer to display a combined scalebar and north arrow. Options
-include scalebar placement (using screen coordinates or a mouse),
-scalebar format, and scalebar colors.
-<i>See <a href="d.barscale.html">d.barscale</a>.</i>
-</DD>
-<DT><img src="icons/grass/module-d.grid.gif"> Overlay grids and lines</DT>
-<DD>Adds layer to display regular grid (for all locations), or geodesic and
-rhumblines (for latitude/longitude locations only). Grid options
-include: grid and border colors, grid origin, and grid line spacing.
-Geodesic and rhumbline options include: line color, and xy coordinates
-(geographic) of line endpoints.
-<i>See <a href="d.grid.html">d.grid</a>, <a href="d.geodesic.html">d.geodesic</a>,
- and <a href="d.rhumbline.html">d.rhumbline</a>.</i>
-</DD>
-<DT><img src="icons/grass/gui-cmd.gif"> Add command layer</DT>
-<DD>Adds a layer in which a GRASS GIS command or command list can be entered.
-For a command list use the pipe symbol as "|" as separator.
-For example:
-<div class="code"><pre>
- d.rast soils | d.rast -o roads | d.vect streams col=blue
-</pre></div>
-Note that when an option of the command contains spaces, you need to
-escape them with the backslash ('\') character, for example:<BR>
-<tt>d.text text=Population\ density</tt>
-</DD>
-<DT><img src="icons/grass/gui-group.gif"> Add group</DT>
-<DD>Adds an empty layer group. Layers can then be added to the group.</DD>
-<DT><img src="icons/grass/edit-copy.gif"> Duplicate selected layer or group</DT>
-<DD>Adds a new layer that duplicates the selected layer.</DD>
-<DT><img src="icons/grass/edit-cut.gif"> Cut selected layer or group</DT>
-<DD>Deletes the selected group or layer.</DD>
-<DT><img src="icons/grass/file-new.gif"> Erase all layers and create a new group</DT>
-<DD>Removes all layers in the layer tree and creates a new, empty group to
-which new layers can be added.<br></DD>
-<DT><img src="icons/grass/file-open.gif"> Open an existing group file</DT>
-<DD>Opens an previously saved group file, containing a set of display
-layers and their option settings.</DD>
-<DT><img src="icons/grass/file-save.gif"> Save layers to group file</DT>
-<DD>Saves current set of layers and their options to a group file.</DD>
-<DT><img src="icons/grass/module-xganim.gif"> Animate raster map series</DT>
-<DD>Starts the interactive Animation Tool interface to display a series
-of raster maps as an animation.
-<i>See the <a href="gm_animate.html">Animation Tool help page</a></i>.
-</DD>
-<DT><img src="icons/grass/module-v.digit.gif"> Digitize raster or vector maps</DT>
-<DD>Starts the raster digitizing or vector digitizing module, depending on
-whether a raster or vector map is selected. Raster digitizing always
-creates a new map. Vector digitizing will either edit an existing map
-(if an existing vector map is selected in the layer tree) or create a
-new vector map (if the name of the new vector to be created is entered
-in the 'vector name' field of the options panel for a vector map
-layer).
-<i>See <a href="r.digit.html">r.digit</a> and <a href="v.digit.html">v.digit</a></i>.
-</DD>
-</DL>
-<BR><BR>
-<h2>MAP DISPLAY BUTTON FUNCTIONS</h2>
-<img src="gm_mapdisptools.png" alt="Map display toolbar">
-<DL>
-<DT><img src="icons/grass/gui-display.gif"> Display active layers (current region)</DT>
-<DD>Displays all active layers at current resolution and region extents for
-that map display window.</DD>
-<DT><img src="icons/grass/gui-zoom_current.gif"> Re-render and display all active
-layers and zoom to current region</DT>
-<DD>Resets the region to the resolution and extents to the values set with
-<em>g.region</em>; forces re-display and re-rendering all active layers.
-<i>See <a href="g.region.html">g.region</a>.</i></DD>
-<DT><img src="icons/grass/module-nviz.gif"> NVIZ</DT>
-<DD>Starts NVIZ, the <i>n</i>-dimensional visualization module and interactive
-graphical interface. All active raster and vector layers in the layer
-tree will be displayed in NVIZ.
-<i>See the <a href="nviz.html">nviz</a> manual.</i></DD>
-<DT><img src="icons/grass/module-d.nviz.gif"> Create fly through path for NVIZ</DT>
-<DD>Starts a GRASS module for interactive creation of a fly-through path to
-be animated in NVIZ.
-<i>See <a href="d.nviz.html">d.nviz</a></i>.</DD>
-<DT><img src="icons/grass/gui-erase.gif"> Erase to white</DT>
-<DD>Erases the currently selected monitor to a white background; also
-removes all frames.
-<i>See <a href="d.erase.html">d.erase</a> and
-<a href="d.frame.html">d.frame -e</a>.</i></DD>
-<DT><img src="icons/grass/gui-pointer.gif"> Arrow cursor</DT>
-<DD>Select arrow cursor for map display.</DD>
-<DT><img src="icons/grass/gui-zoom_in.gif"> Zoom in</DT>
-<DD>Interactive zooming with the mouse in the active display monitor.
-Drawing a box with the mouse (left button) and zoom-in cursor causes
-the display to zoom in so that the area defined by the box fills the
-display. The map resolution is not changed. Clicking with the zoom-in
-cursor causes the display to zoom in by 30%, centered on the point
-where the mouse is clicked. Zooming resets the display region extents
-(both size and location of area displayed). It does NOT affect the
-computational region for other GIS processes.
-<DT><img src="icons/grass/gui-zoom_out.gif"> Zoom out</DT>
-Drawing a box with the mouse (left button) and zoom-out cursor causes
-the display to zoom in so that the area displayed shrinks to fill the
-area defined by the box. The map resolution is not changed. Clicking
-with the zoom-out cursor causes the display to zoom out by 30%, centered
-on the point where the mouse is clicked. Zooming resets the display
-region extents (both size and location of area displayed). It does NOT
-affect the computational region for other GIS processes.
-<DT><img src="icons/grass/gui-pan.gif"> Pan</DT>
-<DD>Interactive selection of a new center of view in the active display
-monitor. Drag the pan cursor while pressing the left mouse button to pan.
-Panning changes the location of the region displayed but not the size of
-the area displayed or the resolution. Panning does NOT affect the
-<DT><img src="icons/grass/gui-zoom_back.gif"> Revert zoom</DT>
-<DD>Returns to the previous zoom. Up to 5 levels of zoom back are maintained.
-<DT><img src="icons/grass/gui-mapzoom.gif"> Zoom menu</DT>
-<DD>Automatic zoom settings menu. Zoom to match the extents of a selected
-map or to match the extents of a saved region; save the current extents
-to a named region file; zoom to match the computational region (set with
-<em>g.region</em>) or to match the default region; set computational region
-(the mapset's <tt>WIND</tt> file) to match the current display extents
-(does not change the resolution).
-<DT><img src="icons/grass/gui-query.gif"> Query tool (select a map first)</DT>
-<DD>Query selected raster (only the base map of a draped map will be
-queried), RGB raster map (all three map channels will be queried), or
-vector map using the mouse. A map must be selected before query.
-Vector charts and thematic vector maps cannot be queried. The
-results of the query will be displayed in the console window.
-<i>See <a href="r.what.html">r.what</a> and <a href="v.what.html">v.what</a></i>.
-</DD>
-<DT><img src="icons/grass/gui-measure.gif"> Distance measurement tool</DT>
-<DD>Interactive measurement of lengths defined with the mouse. The length
-of each segment and the cumulative length of all segments measuered is
-displayed in the console window. Lengths are measured in the current
-measurement unit.
-<i>See also <a href="d.measure.html">d.measure</a>.</i></DD>
-<DT><img src="icons/grass/gui-profile.gif"> Profile tool</DT>
-<DD>Interactively create profile of a raster map. Profile transect
-is drawn with the mouse in map display. The profile may be of the
-displayed map or a different map.<i>
-See the <a href="gm_profile.html">Profile Tool help page</a>.</i></DD>
-<DT><img src="icons/grass/file-print.gif"> Print map</DT>
-<DD>Prints map on the UNIX <i>lpr</i> printer or PostScript device;
-saves visible map display (including PostScript text and labels) to PDF
-or EPS file. Requires <tt>ghostscript</tt> for all output except EPS.</DD>
-<DT><img src="icons/grass/file-save.gif"> Export map display</DT>
-<DD>Exports visible map display to different raster graphic formats.
-Exported map does not include PostScript text or PostScript labels.</DD>
-<DT><img src="icons/grass/drawmode-strict.gif"> Strict draw mode</DT>
-<DD>Selects strict draw mode. In strict mode the aspect ratio and resolution
-from the last zoom are used when drawing the maps. The map will show only
-the area and resolution selected. It will not usually fill the screen.
-Strict mode only shows what is asked for.</DD>
-<DT><img src="icons/grass/drawmode-explore.gif"> Explore draw mode</DT>
-<DD>Selects explore draw mode. In explore mode the region from the last zoom
-is expanded to fill the entire screen. The resolution is adjusted to match
-the screen resolution. Explore mode shows as much as possible.</DD>
-</DL>
-<h2>CONFIGURATION</h2>
-<h3>Changing fonts</h3>
-Fonts used in <em>gis.m</em> can be changed as follows:
-<ul>
- <li>Runtime: edit file '<tt>$GISBASE/etc/gtcltk/options.tcl</tt>'</li>
- <li>Source code: edit file '<tt>lib/gtcltk/options.tcl</tt>' and recompile gtcltk</li>
-</ul>
-<h2>SEE ALSO</h2>
-The <em>gis.m</em> <a href="gm_animate.html">ANIMATION TOOL</a><br>
-The <em>gis.m</em> <a href="gm_georect.html">GEORECTIFY TOOL</a><br>
-The <em>gis.m</em> <a href="gm_profile.html">PROFILE TOOL</a><br>
-<P>
-<em><a href="g.gui.html">g.gui</a></em>: Starts the default GUI<BR>
-<a href="d.m.html"><em>d.m</em> GUI</a>: The old display manager GUI<BR>
-<a href="wxGUI.html">wxPython GUI</a>:
- The next generation GUI, currently under development<BR>
-<h2>AUTHORS</h2>
-Michael Barton, Arizona State University, Tempe, Arizona, USA<br>
-Cedric Shock, USA
-<p>
Copied: grass/trunk/gui/tcltk/gis.m/gis.m.html (from rev 32770, grass/trunk/gui/tcltk/gis.m/description.html)
--- grass/trunk/gui/tcltk/gis.m/gis.m.html (rev 0)
+++ grass/trunk/gui/tcltk/gis.m/gis.m.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,431 @@
+The <b>GRASS GIS Manager</b>
+provides an interactive graphical interface to GRASS commands. By
+default, it is started automatically with each GRASS session. The GIS
+Manager can be quit by selecting the <em>'File->Exit</em><em>'</em>
+menu item. The GIS Manager can be restarted from the GRASS command line
+shell by typing "<i>gis.m</i>".<br>
+<br>
+The GIS Manager includes a set of pull-down menus for all GRASS GIS
+functions (analysis, file I/O, GIS configuration and management), two
+rows of buttons that manage display layers, an upper window in
+which layers to display are organized, and a lower
+window which contains options panels for layers in the layer tree.
+<br><br>
+<center>
+<img src="gm_gismgr.jpg" alt="GIS Manager window" height="551" width="480">
+</center>
+<br>
+<br>
+The top left button opens a new map display window. Each map display
+has a unique set of layers to display and region setting (zoom). Other
+buttons add layers of different types for display in the selected map
+display window. There are additional buttons for saving or opening
+group display file, starting XGANIM (display animator) display
+interfaces (requires motif), and digitizing.
+<i>Mouse-over help</i> is available for all buttons.
+<P>
+Map layers are listed in the window below the
+buttons. Layers can include raster and vector maps, text, map
+enhancements (scale and north arrow, and grids), and commands
+(where any GRASS command be written). Layers are displayed in as
+arranged in the layer tree: the bottom layer
+is displayed first and the top is displayed last, as if
+layers are a series of stacked overlays. Any layer can be
+renamed by double clicking on its name and typing a new name.
+<P>
+The check box to the left of each layer makes it active or inactive for
+display.
+Only active layers are displayed/redisplayed when the display button is
+pressed. Layers can be organized into groups; entire groups can be
+activated or deactivated for display. Groups can be saved to a file and
+opened in subsequent sessions, restoring all layers and their display
+options.
+<P>
+When a layer is selected with the mouse, its options are shown in the
+panel below the layer tree window. Help for each layer type can be
+accessed by pressing the GRASS button in the option panel.<br>
+<P>
+Each map display has a unique layer tree and region setting (zoom).
+Buttons on each map display manage the map in the display (zoom and
+pan), provide tools for query and distance measurement, and exporting
+or printing the display. The geographic coordinates under the cursor
+are displayed in the indicator window (lower right window frame). It is
+important to note that zooming in any display will have NO effect on
+the 'computational region' setting (set with g.region). Only by selecting
+the "Set current region to match display" item in the zoom menu (in the
+map display tool bar) will the current display extents be copied to
+the computational region extents.
+<br><br>
+<center>
+<img src="gm_mapdisp.jpg" alt="Map Display window" height="422" width="480">
+</center>
+<br><br>
+A separate console window shows all commands issued and all command
+output (upper window). GRASS commands (and any other unix/linux
+commands) can be run from the console (lower window).<br>
+<br>
+<center>
+<img src="gm_gronsole.png" alt="Output and command console window" height="231" width="480">
+</center>
+<br>
+<h2>GIS MANAGER BUTTON FUNCTIONS</h2>
+<img src="gm_gismgrtools.png" alt="GIS Manager Toolbar">
+<H3><u>Top Row</u></H3>
+<DL>
+<DT><img src="icons/grass/gui-startmon.gif"> Open new map display</DT>
+<DD>Opens a new map display and resets layer tree.</DD>
+<DT><img src="icons/grass/element-cell.gif"> Add raster layer</DT>
+<DD>Adds a raster map to the layer tree. Raster display options include:
+displaying a selected subset of raster cells, defined by their cat
+values; draping (or "fusing") a second map over the base map;
+and displaying legends for the base map and draped map.
+<i>See <a href="d.rast.html">d.rast</a> and <a href="d.his.html">d.his</a>
+ (for draping/fusing).</i>
+</DD>
+<DT><img src="icons/grass/channel-rgb.gif"> Add RGB or HIS raster layer</DT>
+<DD>Combines and displays three raster maps defined as red, green, and blue
+channels; or combines and displays two or three raster maps defined as
+hue, intensity, and (optionally) saturation channels.
+<i>See <a href="d.rgb.html">d.rgb</a> and <a href="d.his.html">d.his</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.histogram.gif"> Add histogram layer</DT>
+<DD>Adds a layer to display histogram of a raster map or image.
+<i>See <a href="d.histogram.html">d.histogram</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.rast.num.gif"> Add cell values layer</DT>
+<DD>Adds map of raster cells with cell values printed inside.
+Only works when <10,000 cells are displayed.
+<i>See <a href="d.rast.num.html">d.rast.num</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.rast.arrow.gif"> Add raster arrows layer</DT>
+<DD>Adds map of raster cells with directional arrows drawn.
+Arrow direction and length are determined by separate aspect/directional map
+and (optional) slope/intensity map.
+<i>See <a href="d.rast.arrow.html">d.rast.arrow</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.legend.gif"> Add raster legend</DT>
+<DD>Adds a legend for a single raster map to the layer tree.
+Multiple options for formatting the legend are available.
+<i>See <a href="d.legend.html">d.legend</a>.</i>
+</DD>
+<DT><img src="icons/grass/element-vector.gif"> Add vector layer</DT>
+<DD>Adds a vector map to the layer tree. A large number of options are
+available for displaying the vector map, including: outline and fill
+color, icon type and size for points, line widths for all vector types,
+automatic labeling using an attribute column, querying cats or
+attributes to limit vectors displayed, and restricting vector display
+depending on region size.
+<i>See <a href="d.vect.html">d.vect</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.vect.thematic.gif"> Add thematic map layer
+(for all vector types)</DT>
+<DD>Adds layer for thematic display values from a numeric attribute column
+associated with a vector map. Options include: thematic display type
+(graduated colors or point sizes), methods for creating display
+intervals, SQL query of attribute column to limit vector objects to
+display, control of point icon types and sizes, control of thematic
+color schemes, creation of legend for thematic map, and saving the
+results of thematic mapping to a ps.map instructions file for later
+printing.
+<i>See <a href="d.vect.thematic.html">d.vect.thematic</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.vect.chart.gif"> Add thematic charts layer
+(for vector points)</DT>
+<DD>Adds layer in which pie or bar charts can be automatically created at
+vector point locations. Charts display values from selected columns in the
+associated attribute table. Options include: chart type, layer and
+attributes to chart, chart colors, and chart size (fixed or based on
+attribute column).
+<i>See <a href="d.vect.chart.html">d.vect.chart</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.labels.gif"> Add raster labels layer for vector
+objects (from existing labels file)</DT>
+<DD>Add raster text layer from a labels file for vector objects created with
+the <em><a href="v.label.html">v.label</a></em> module (accessed from button
+in options panel). A labels file can also be created with a text editor.
+<i>See <a href="d.labels.html">d.labels</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.text.gif"> Add text layer</DT>
+<DD>Adds layer to display a line of text using default GRASS font
+(selected with <em><a href="d.font.html">d.font</a></em>).
+Options include: text placement (screen coordinates); and text size,
+bolding, and color.
+<i>See <a href="d.text.html">d.text</a>.</i>
+</DD>
+<DT><img src="icons/grass/gui-maptext.gif"> Add PostScript labels layer for vector
+<DD>Add PostScript text layer from a labels file for vector objects created
+with the <em><a href="v.label.html">v.label</a></em> module (accessed from
+button in options panel). A labels file can also be created with a text editor.
+</DD>
+<DT><img src="icons/grass/gui-maplabels.gif"> Add PostScript text layer</DT>
+<DD>Adds layer to display a line of PostScript text. Options include: text
+placement by coordinates (geographic or screen); text
+alignment, font and line spacing; and text size, bolding, and color.
+</DL>
+<BR><BR>
+<H3><u>Bottom Row</u></H3>
+<DL>
+<DT><img src="icons/grass/module-d.barscale.gif"> Add scalebar and north arrow layer</DT>
+<DD>Adds layer to display a combined scalebar and north arrow. Options
+include scalebar placement (using screen coordinates or a mouse),
+scalebar format, and scalebar colors.
+<i>See <a href="d.barscale.html">d.barscale</a>.</i>
+</DD>
+<DT><img src="icons/grass/module-d.grid.gif"> Overlay grids and lines</DT>
+<DD>Adds layer to display regular grid (for all locations), or geodesic and
+rhumblines (for latitude/longitude locations only). Grid options
+include: grid and border colors, grid origin, and grid line spacing.
+Geodesic and rhumbline options include: line color, and xy coordinates
+(geographic) of line endpoints.
+<i>See <a href="d.grid.html">d.grid</a>, <a href="d.geodesic.html">d.geodesic</a>,
+ and <a href="d.rhumbline.html">d.rhumbline</a>.</i>
+</DD>
+<DT><img src="icons/grass/gui-cmd.gif"> Add command layer</DT>
+<DD>Adds a layer in which a GRASS GIS command or command list can be entered.
+For a command list use the pipe symbol as "|" as separator.
+For example:
+<div class="code"><pre>
+ d.rast soils | d.rast -o roads | d.vect streams col=blue
+</pre></div>
+Note that when an option of the command contains spaces, you need to
+escape them with the backslash ('\') character, for example:<BR>
+<tt>d.text text=Population\ density</tt>
+</DD>
+<DT><img src="icons/grass/gui-group.gif"> Add group</DT>
+<DD>Adds an empty layer group. Layers can then be added to the group.</DD>
+<DT><img src="icons/grass/edit-copy.gif"> Duplicate selected layer or group</DT>
+<DD>Adds a new layer that duplicates the selected layer.</DD>
+<DT><img src="icons/grass/edit-cut.gif"> Cut selected layer or group</DT>
+<DD>Deletes the selected group or layer.</DD>
+<DT><img src="icons/grass/file-new.gif"> Erase all layers and create a new group</DT>
+<DD>Removes all layers in the layer tree and creates a new, empty group to
+which new layers can be added.<br></DD>
+<DT><img src="icons/grass/file-open.gif"> Open an existing group file</DT>
+<DD>Opens an previously saved group file, containing a set of display
+layers and their option settings.</DD>
+<DT><img src="icons/grass/file-save.gif"> Save layers to group file</DT>
+<DD>Saves current set of layers and their options to a group file.</DD>
+<DT><img src="icons/grass/module-xganim.gif"> Animate raster map series</DT>
+<DD>Starts the interactive Animation Tool interface to display a series
+of raster maps as an animation.
+<i>See the <a href="gm_animate.html">Animation Tool help page</a></i>.
+</DD>
+<DT><img src="icons/grass/module-v.digit.gif"> Digitize raster or vector maps</DT>
+<DD>Starts the raster digitizing or vector digitizing module, depending on
+whether a raster or vector map is selected. Raster digitizing always
+creates a new map. Vector digitizing will either edit an existing map
+(if an existing vector map is selected in the layer tree) or create a
+new vector map (if the name of the new vector to be created is entered
+in the 'vector name' field of the options panel for a vector map
+layer).
+<i>See <a href="r.digit.html">r.digit</a> and <a href="v.digit.html">v.digit</a></i>.
+</DD>
+</DL>
+<BR><BR>
+<h2>MAP DISPLAY BUTTON FUNCTIONS</h2>
+<img src="gm_mapdisptools.png" alt="Map display toolbar">
+<DL>
+<DT><img src="icons/grass/gui-display.gif"> Display active layers (current region)</DT>
+<DD>Displays all active layers at current resolution and region extents for
+that map display window.</DD>
+<DT><img src="icons/grass/gui-zoom_current.gif"> Re-render and display all active
+layers and zoom to current region</DT>
+<DD>Resets the region to the resolution and extents to the values set with
+<em>g.region</em>; forces re-display and re-rendering all active layers.
+<i>See <a href="g.region.html">g.region</a>.</i></DD>
+<DT><img src="icons/grass/module-nviz.gif"> NVIZ</DT>
+<DD>Starts NVIZ, the <i>n</i>-dimensional visualization module and interactive
+graphical interface. All active raster and vector layers in the layer
+tree will be displayed in NVIZ.
+<i>See the <a href="nviz.html">nviz</a> manual.</i></DD>
+<DT><img src="icons/grass/module-d.nviz.gif"> Create fly through path for NVIZ</DT>
+<DD>Starts a GRASS module for interactive creation of a fly-through path to
+be animated in NVIZ.
+<i>See <a href="d.nviz.html">d.nviz</a></i>.</DD>
+<DT><img src="icons/grass/gui-erase.gif"> Erase to white</DT>
+<DD>Erases the currently selected monitor to a white background; also
+removes all frames.
+<i>See <a href="d.erase.html">d.erase</a> and
+<a href="d.frame.html">d.frame -e</a>.</i></DD>
+<DT><img src="icons/grass/gui-pointer.gif"> Arrow cursor</DT>
+<DD>Select arrow cursor for map display.</DD>
+<DT><img src="icons/grass/gui-zoom_in.gif"> Zoom in</DT>
+<DD>Interactive zooming with the mouse in the active display monitor.
+Drawing a box with the mouse (left button) and zoom-in cursor causes
+the display to zoom in so that the area defined by the box fills the
+display. The map resolution is not changed. Clicking with the zoom-in
+cursor causes the display to zoom in by 30%, centered on the point
+where the mouse is clicked. Zooming resets the display region extents
+(both size and location of area displayed). It does NOT affect the
+computational region for other GIS processes.
+<DT><img src="icons/grass/gui-zoom_out.gif"> Zoom out</DT>
+Drawing a box with the mouse (left button) and zoom-out cursor causes
+the display to zoom in so that the area displayed shrinks to fill the
+area defined by the box. The map resolution is not changed. Clicking
+with the zoom-out cursor causes the display to zoom out by 30%, centered
+on the point where the mouse is clicked. Zooming resets the display
+region extents (both size and location of area displayed). It does NOT
+affect the computational region for other GIS processes.
+<DT><img src="icons/grass/gui-pan.gif"> Pan</DT>
+<DD>Interactive selection of a new center of view in the active display
+monitor. Drag the pan cursor while pressing the left mouse button to pan.
+Panning changes the location of the region displayed but not the size of
+the area displayed or the resolution. Panning does NOT affect the
+<DT><img src="icons/grass/gui-zoom_back.gif"> Revert zoom</DT>
+<DD>Returns to the previous zoom. Up to 5 levels of zoom back are maintained.
+<DT><img src="icons/grass/gui-mapzoom.gif"> Zoom menu</DT>
+<DD>Automatic zoom settings menu. Zoom to match the extents of a selected
+map or to match the extents of a saved region; save the current extents
+to a named region file; zoom to match the computational region (set with
+<em>g.region</em>) or to match the default region; set computational region
+(the mapset's <tt>WIND</tt> file) to match the current display extents
+(does not change the resolution).
+<DT><img src="icons/grass/gui-query.gif"> Query tool (select a map first)</DT>
+<DD>Query selected raster (only the base map of a draped map will be
+queried), RGB raster map (all three map channels will be queried), or
+vector map using the mouse. A map must be selected before query.
+Vector charts and thematic vector maps cannot be queried. The
+results of the query will be displayed in the console window.
+<i>See <a href="r.what.html">r.what</a> and <a href="v.what.html">v.what</a></i>.
+</DD>
+<DT><img src="icons/grass/gui-measure.gif"> Distance measurement tool</DT>
+<DD>Interactive measurement of lengths defined with the mouse. The length
+of each segment and the cumulative length of all segments measuered is
+displayed in the console window. Lengths are measured in the current
+measurement unit.
+<i>See also <a href="d.measure.html">d.measure</a>.</i></DD>
+<DT><img src="icons/grass/gui-profile.gif"> Profile tool</DT>
+<DD>Interactively create profile of a raster map. Profile transect
+is drawn with the mouse in map display. The profile may be of the
+displayed map or a different map.<i>
+See the <a href="gm_profile.html">Profile Tool help page</a>.</i></DD>
+<DT><img src="icons/grass/file-print.gif"> Print map</DT>
+<DD>Prints map on the UNIX <i>lpr</i> printer or PostScript device;
+saves visible map display (including PostScript text and labels) to PDF
+or EPS file. Requires <tt>ghostscript</tt> for all output except EPS.</DD>
+<DT><img src="icons/grass/file-save.gif"> Export map display</DT>
+<DD>Exports visible map display to different raster graphic formats.
+Exported map does not include PostScript text or PostScript labels.</DD>
+<DT><img src="icons/grass/drawmode-strict.gif"> Strict draw mode</DT>
+<DD>Selects strict draw mode. In strict mode the aspect ratio and resolution
+from the last zoom are used when drawing the maps. The map will show only
+the area and resolution selected. It will not usually fill the screen.
+Strict mode only shows what is asked for.</DD>
+<DT><img src="icons/grass/drawmode-explore.gif"> Explore draw mode</DT>
+<DD>Selects explore draw mode. In explore mode the region from the last zoom
+is expanded to fill the entire screen. The resolution is adjusted to match
+the screen resolution. Explore mode shows as much as possible.</DD>
+</DL>
+<h2>CONFIGURATION</h2>
+<h3>Changing fonts</h3>
+Fonts used in <em>gis.m</em> can be changed as follows:
+<ul>
+ <li>Runtime: edit file '<tt>$GISBASE/etc/gtcltk/options.tcl</tt>'</li>
+ <li>Source code: edit file '<tt>lib/gtcltk/options.tcl</tt>' and recompile gtcltk</li>
+</ul>
+<h2>SEE ALSO</h2>
+The <em>gis.m</em> <a href="gm_animate.html">ANIMATION TOOL</a><br>
+The <em>gis.m</em> <a href="gm_georect.html">GEORECTIFY TOOL</a><br>
+The <em>gis.m</em> <a href="gm_profile.html">PROFILE TOOL</a><br>
+<P>
+<em><a href="g.gui.html">g.gui</a></em>: Starts the default GUI<BR>
+<a href="d.m.html"><em>d.m</em> GUI</a>: The old display manager GUI<BR>
+<a href="wxGUI.html">wxPython GUI</a>:
+ The next generation GUI, currently under development<BR>
+<h2>AUTHORS</h2>
+Michael Barton, Arizona State University, Tempe, Arizona, USA<br>
+Cedric Shock, USA
+<p>
Deleted: grass/trunk/imagery/i.atcorr/description.html
--- grass/trunk/imagery/i.atcorr/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.atcorr/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,523 +0,0 @@
-<h2>DESCRIPTION</h2>
-<b>i.atcorr</b> performs atmospheric correction on the input raster using the
-6S algorithm (Second Simulation of Satellite Signal in the Solar Spectrum). A
-detailed algorithm description is available at the
-<a href=http://modis-sr.ltdri.org/index.html>Land Surface Reflectance Science
-Computing Facility website</a> and Mauro A. Homem Antunes <a
-href="http://www.ltid.inpe.br/dsr/mauro/6s/download_6s.html">website about his
-6s version</a>.
-<p>
-Current region settings are ignored. The region is adjusted to cover the input
-raster before the atmospheric correction is performed. This should not affect
-the user's current region settings.
-<p>
-Because using a continuous elevation <em>ialt</em> or visibility <em>ivis</em>
-map makes execution time much longer, it is advised to use categorized maps
-instead, in conjuction with flag <em>-o</em>. This flag tells
-<b>i.atcorr</b> to try and speedup calculations. However, this option under
-certain conditions can make execution time longer.
-<p>
-If flag <em>-r</em> is used, the input data are treated as reflectance.
-Otherwise, the input data are treated as radiance values and are converted to
-reflectance at the <b>i.atcorr</b> runtime. The output data are always
-reflectance.
-<p>
-An example 6s parameters <em>icnd</em> file for <b>i.atcorr</b>:
-<p>
-8 - geometrical conditions=Landsat ETM+
-2 19 13.00 -47.410 -20.234 - month day hh.ddd longitude lattitude ("hh.ddd" is a decimal hour GMT)
-1 - atmospheric mode=tropical
-1 - aerosols model=continental
-15 - visibility [km] (aerosol model concentration)
--.600 - target at 600m above sea level
--1000 - sensor on board a satellite
-64 - 4th band of ETM+ Landsat 7
-</pre></div>
-<h2><font color="red">REMAINING DOCUMENTATION ISSUES</font></h2>
-1. Using the target elevation and visibility parameters in the <em>icnd</em>
-file overrides <em>ialt</em> and <em>ivis</em> input rasters. It is not clear
-what to do to force <b>i.atcorr</b> to use the rasters instead though.
-<p>
-2. The "example 6s parameters file" explains that "-.600" in line 6 means
-"target at 600 m ASL". However, in the section E of "6S CODE PARAMETER CHOICES"
-it reads: "xps <=0. means the target is at the sea level". This is contrary.
-<p>
-3. In section E, I'm not sure if the "-100< xpp <0" shouldn't actually be
-"-1000< xpp <0". ?
-<p>
-4. It is not explained what is the "iaer" parameter that section D refers to.
-<p>
-5. Section D's "Aerosol model concentration" title could use a better wording I
-suppose. The current one seems to mean "the concentration of the model of the
-aerosol". Should it be "Aerosol concentration model"?
-<p>
-6. It should be explained under what circumstances the use of categorized maps
-in conjuction with flag <em>-o</em> can slow down the calculations instead of
-speeding them up.
-<p>
-7. "This should not affect the user's current region settings" sounds ambigious.
-<p>
-<H2>6S CODE PARAMETER CHOICES</H2>
-<h3>A. Geometrical conditions:</h3>
-<table BORDERWIDTH="AUTO" CELLPADDING="3">
-<tr>
-<td>Code</td>
-<td>Description</td>
-<td>Details</td>
-</tr>
-<tr>
-<td>1</td>
-<td><b>meteosat</b> observation</td>
-<td>enter month,day,decimal hour (universal time-hh.ddd)
-<br>
-n. of column,n. of line.(full scale 5000*2500) </td>
-</tr>
-<tr>
-<td>2</td>
-<td><b>goes east </b>observation</td>
-<br>
-n. of column,n. of line.(full scale 17000*12000)c</td>
-</tr>
-<tr>
-<td>3</td>
-<td><b>goes west</b> observation</td>
-<br>
-n. of column,n. of line.(full scale 17000*12000)</td>
-</tr>
-<tr>
-<td>4</td>
-<td><b>avhrr</b> (PM noaa)</td>
-<br>
-n. of column(1-2048),xlonan,hna
-<br>
-give long.(xlonan) and overpass hour (hna) at
-<br>
-the ascendant node at equator</td>
-</tr>
-<tr>
-<td>5</td>
-<td><b>avhrr</b> (AM noaa)</td>
-<br>
-<br>
-<br>
-</tr>
-<tr>
-<td>6</td>
-<td><b>hrv</b> (spot)</td>
-<td>enter month,day,hh.ddd,long.,lat. *</td>
-</tr>
-<tr>
-<td>7</td>
-<td><b>tm</b> (landsat)</td>
-</tr>
-<tr>
-<td>8</td>
-<td><b>etm+</b> (landsat7)</td>
-</tr>
-</table>
-<blockquote>
-* NOTE: for hrv, tm and etm+ experiments, longitude and lattitude
-are the coordinates of the scene center. Lattitude must be >0 for northern
-hemisphere and <0 for southern. Longitude must be >0 for eastern hemisphere
-and <0 for western.
-</blockquote>
-<br><h3>B. Atmospheric model</h3>
-<tr>
-<td>Code</td>
-<td>Meaning</td>
-</tr>
-<tr>
-<td>0</td>
-<td>no gaseous absorption</td>
-</tr>
-<tr>
-<td>1</td>
-<td>tropical</td>
-</tr>
-<tr>
-<td>2</td>
-<td>midlatitude summer</td>
-</tr>
-<tr>
-<td>3</td>
-<td>midlatitude winter</td>
-</tr>
-<tr>
-<td>4</td>
-<td>subarctic summer</td>
-</tr>
-<tr>
-<td>5</td>
-<td>subarctic winter</td>
-</tr>
-<tr>
-<td>6</td>
-<td>us standard 62</td>
-</tr>
-<tr>
-<td>7</td>
-<td>Define your own atmospheric model as a set of the following 5 parameters
-per each measurement:<br>
-<br>altitude [km]
-<br>pressure [mb]
-<br>temperature [k]
-<br>h2o density [g/m3]
-<br>o3 density [g/m3]<br>
-<br>For example: there is one radiosonde measurement for each altitude of
-0-25km at a step of 1km, one measurment for each altitude of 25-50km at a step
-of 5km, and two single measurements for altitudes 70km and 100km. This makes 34
-measurments. In that case, there are 34*5 values to input.</td>
-</tr>
-<tr>
-<td>8</td>
-<td>Define your own atmospheric model providing values of the water vapor and
-ozone content:
-<br>
-<br>uw [g/cm2]
-<br>uo3 [cm-atm]
-<br>
-<br> The profile is taken from us62.</td>
-</tr>
-</table>
-<br><h3>C. Aerosols model</h3>
-<tr>
-<td>Code</td>
-<td>Meaning</td>
-<td>Details</td>
-</tr>
-<tr>
-<td>0</td>
-<td>no aerosols</td>
-<td></td>
-</tr>
-<tr>
-<td>1</td>
-<td>continental model</td>
-<td></td>
-</tr>
-<tr>
-<td>2</td>
-<td>maritime model</td>
-<td></td>
-</tr>
-<tr>
-<td>3</td>
-<td>urban model</td>
-<td></td>
-</tr>
-<tr>
-<td>4</td>
-<td>shettle model for background desert aerosol</td>
-<td></td>
-</tr>
-<tr>
-<td>5</td>
-<td>biomass burning</td>
-<td></td>
-</tr>
-<tr>
-<td>6</td>
-<td>stratospheric model</td>
-<td></td>
-</tr>
-<tr>
-<td>7</td>
-<td>define your own model</td>
-<td>Enter the volumic percentage of each component:
-<br>
-<br>c(1) = volumic % of dust-like
-<br>c(2) = volumic % of water-soluble
-<br>c(3) = volumic % of oceanic
-<br>c(4) = volumic % of soot
-<br>
-<br>All values between 0 and 1.</td>
-</tr>
-<tr>
-<td>8</td>
-<td>Size distribution function: Multimodal Log Normal (up to 4 modes).</td>
-</tr>
-<tr>
-<td>9</td>
-<td>Size distribution function: Modified gamma.</td>
-</tr>
-<tr>
-<td>10</td>
-<td>Size distribution function: Junge Power-Law.</td>
-</tr>
-<tr>
-<td>11</td>
-<td>Sun-photometer measurements, 50 values max, entered as:
-<br>
-<br>r and d V / d (logr)
-<br>
-<br>where r is the radius [micron], V is the volume, d V / d (logr) [cm3/cm2/micron].
-<br>
-<br>Followed by:
-<br>
-<br>nr and ni for each wavelength
-<br>
-<br>where nr and ni are respectively the real and imaginary part of the
-refractive index.</td>
-</tr>
-</table>
-<br><h3>D. Aerosol model concentration (visibility)</h3>
-<blockquote>If you have an estimate of the meteorological parameter visibility
-v, enter directly the value of v [km] (the aerosol optical depth will be
-computed from a standard aerosol profile).
-<p>If you have an estimate of aerosol optical depth, enter v=0 for the
-visibility and enter the aerosol optical depth at 550nm.
-<p>NOTE: if iaer=0, enter v=-1.</blockquote>
-<br><h3>E. Target altitude (xps), sensor platform (xpp)</h3>
-<blockquote>xps <=0 means the target is at the sea level.
-<br>xps >0 means you know the altitude of the target expressed
-in km, and you put that value as xps.
-<br>
-<br>xpp=-1000 means that the sensor is on board a satellite.
-<br>xpp=0 means that the sensor is at the ground level.
-<br>-100<xpp<0 means you know the altitude of the sensor
-expressed in kilometers; this altitude is <b>relative to the target</b>
-altitude.
-<p>For aircraft simulations only (xpp is neither 0 nor -1000):
-<blockquote>
-puw,po3 (water vapor content,ozone content between the aircraft and the surface)
-<br>taerp (the aerosol optical thickness at 550nm between the aircraft and the
-surface)
-<p>If these data are not available, enter negative values for all of them.
-puw,po3 will then be interpolated from the us62 standard profile according
-to the values at the ground level. taerp will be computed according to a 2km
-exponential profile for aerosol.</blockquote>
-</blockquote>
-<br><h3>F. Sensor band</h3>
-<p>There are two possibilities: either define your own spectral conditions
-(codes -2, -1, 0, or 1) or choose a code indicating the band of one of the
-pre-defined satellites.
-<p>Define your own spectral conditions:
-<p>
-<tr>
-<td>Code</td>
-<td>Meaning</td>
-</tr>
-<tr>
-<td>-2</td>
-<td>Enter wlinf, wlsup.
-<br>The filter function will be equal to 1 over the whole band (as iwave=0)
-but step by step output will be printed.</td>
-</tr>
-<tr>
-<td>-1</td>
-<td>Enter wl (monochr. cond, gaseous absorption is included).</td>
-</tr>
-<tr>
-<td>0</td>
-<br>The filter function will be equal to 1over the whole band.</td>
-</tr>
-<tr>
-<td>1</td>
-<td>Enter wlinf, wlsup and user's filter function s(lambda) by step of 0.0025
-micrometer.</td>
-</tr>
-</table>
-<p>Pre-defined satellite bands:
-<p>
-<tr><td>Code</td><td>Meaning</td></tr>
-<tr><td>2</td><td><b>meteosat</b> vis band (0.350-1.110)</td></tr>
-<tr><td>3</td><td><b>goes east</b> band vis (0.490-0.900)</td></tr>
-<tr><td>4</td><td>goes west band vis (0.490-0.900)</td></tr>
-<tr><td>5</td><td><b>avhrr (noaa6)</b> band 1 (0.550-0.750)</td></tr>
-<tr><td>6</td><td>avhrr (noaa6) band 2 (0.690-1.120)</td></tr>
-<tr><td>7</td><td><b>avhrr (noaa7)</b> band 1 (0.500-0.800)</td></tr>
-<tr><td>8</td><td>avhrr (noaa7) band 2 (0.640-1.170)</td></tr>
-<tr><td>9</td><td><b>avhrr (noaa8)</b> band 1 (0.540-1.010)</td></tr>
-<tr><td>10</td><td>avhrr (noaa8) band 2 (0.680-1.120)</td></tr>
-<tr><td>11</td><td><b>avhrr (noaa9)</b> band 1 (0.530-0.810)</td></tr>
-<tr><td>12</td><td>avhrr (noaa9) band 1 (0.680-1.170)</td></tr>
-<tr><td>13</td><td><b>avhrr (noaa10)</b> band 1 (0.530-0.780)</td></tr>
-<tr><td>14</td><td>avhrr (noaa10) band 2 (0.600-1.190)</td></tr>
-<tr><td>15</td><td><b>avhrr (noaa11)</b> band 1 (0.540-0.820)</td></tr>
-<tr><td>16</td><td>avhrr (noaa11) band 2 (0.600-1.120)</td></tr>
-<tr><td>17</td><td><b>hrv1 (spot1)</b> band 1 (0.470-0.650)</td></tr>
-<tr><td>18</td><td>hrv1 (spot1) band 2 (0.600-0.720)</td></tr>
-<tr><td>19</td><td>hrv1 (spot1) band 3 (0.730-0.930)</td></tr>
-<tr><td>20</td><td>hrv1 (spot1) band pan (0.470-0.790)</td></tr>
-<tr><td>21</td><td><b>hrv2 (spot1)</b> band 1 (0.470-0.650)</td></tr>
-<tr><td>22</td><td>hrv2 (spot1) band 2 (0.590-0.730)</td></tr>
-<tr><td>23</td><td>hrv2 (spot1) band 3 (0.740-0.940)</td></tr>
-<tr><td>24</td><td>hrv2 (spot1) band pan (0.470-0.790)</td></tr>
-<tr><td>25</td><td><b>tm (landsat5)</b> band 1 (0.430-0.560)</td></tr>
-<tr><td>26</td><td>tm (landsat5) band 2 (0.500-0.650)</td></tr>
-<tr><td>27</td><td>tm (landsat5) band 3 (0.580-0.740)</td></tr>
-<tr><td>28</td><td>tm (landsat5) band 4 (0.730-0.950)</td></tr>
-<tr><td>29</td><td>tm (landsat5) band 5 (1.5025-1.890)</td></tr>
-<tr><td>30</td><td>tm (landsat5) band 7 (1.950-2.410)</td></tr>
-<tr><td>31</td><td><b>mss (landsat5)</b> band 1 (0.475-0.640)</td></tr>
-<tr><td>32</td><td>mss (landsat5) band 2 (0.580-0.750)</td></tr>
-<tr><td>33</td><td>mss (landsat5) band 3 (0.655-0.855)</td></tr>
-<tr><td>34</td><td>mss (landsat5) band 4 (0.785-1.100)</td></tr>
-<tr><td>35</td><td><b>MAS (ER2)</b> band 1 (0.5025-0.5875)</td></tr>
-<tr><td>36</td><td>MAS (ER2) band 2 (0.6075-0.7000)</td></tr>
-<tr><td>37</td><td>MAS (ER2) band 3 (0.8300-0.9125)</td></tr>
-<tr><td>38</td><td>MAS (ER2) band 4 (0.9000-0.9975)</td></tr>
-<tr><td>39</td><td>MAS (ER2) band 5 (1.8200-1.9575)</td></tr>
-<tr><td>40</td><td>MAS (ER2) band 6 (2.0950-2.1925)</td></tr>
-<tr><td>41</td><td>MAS (ER2) band 7 (3.5800-3.8700)</td></tr>
-<tr><td>42</td><td><b>MODIS</b> band 1 (0.6100-0.6850)</td></tr>
-<tr><td>43</td><td>MODIS band 2 (0.8200-0.9025)</td></tr>
-<tr><td>44</td><td>MODIS band 3 (0.4500-0.4825)</td></tr>
-<tr><td>45</td><td>MODIS band 4 (0.5400-0.5700)</td></tr>
-<tr><td>46</td><td>MODIS band 5 (1.2150-1.2700)</td></tr>
-<tr><td>47</td><td>MODIS band 6 (1.6000-1.6650)</td></tr>
-<tr><td>48</td><td>MODIS band 7 (2.0575-2.1825)</td></tr>
-<tr><td>49</td><td><b>avhrr (noaa12)</b> band 1 (0.500-1.000)</td></tr>
-<tr><td>50</td><td>avhrr (noaa12) band 2 (0.650-1.120)</td></tr>
-<tr><td>51</td><td><b>avhrr (noaa14)</b> band 1 (0.500-1.110)</td></tr>
-<tr><td>52</td><td>avhrr (noaa14) band 2 (0.680-1.100)</td></tr>
-<tr><td>53</td><td><b>POLDER</b> band 1 (0.4125-0.4775)</td></tr>
-<tr><td>54</td><td>POLDER band 2 (non polar) (0.4100-0.5225)</td></tr>
-<tr><td>55</td><td>POLDER band 3 (non polar) (0.5325-0.5950)</td></tr>
-<tr><td>56</td><td>POLDER band 4 P1 (0.6300-0.7025)</td></tr>
-<tr><td>57</td><td>POLDER band 5 (non polar) (0.7450-0.7800)</td></tr>
-<tr><td>58</td><td>POLDER band 6 (non polar) (0.7000-0.8300)</td></tr>
-<tr><td>59</td><td>POLDER band 7 P1 (0.8100-0.9200)</td></tr>
-<tr><td>60</td><td>POLDER band 8 (non polar) (0.8650-0.9400)</td></tr>
-<tr><td>61</td><td><b>etm+ (landsat7)</b> band 1 (0.435-0.520)</td></tr>
-<tr><td>62</td><td>etm+ (landsat7) band 2 (0.506-0.621)</td></tr>
-<tr><td>63</td><td>etm+ (landsat7) band 3 (0.622-0.702)</td></tr>
-<tr><td>64</td><td>etm+ (landsat7) band 4 (0.751-0.911)</td></tr>
-<tr><td>65</td><td>etm+ (landsat7) band 5 (1.512-1.792)</td></tr>
-<tr><td>66</td><td>etm+ (landsat7) band 7 (2.020-2.380)</td></tr>
-<tr><td>67</td><td>etm+ (landsat7) band 8 (0.504-0.909)</td></tr>
-</table>
-<H2>AUTHORS</H2>
-<p><em>Original version of the program for GRASS 5:</em>
-<br>Christo Zietsman, 13422863(at)sun.ac.za
-<p><em>Code clean-up and port to GRASS 6.3, 15.12.2006:</em>
-<br>Yann Chemin, ychemin(at)gmail.com
-<h2>REFERENCES</h2>
-<p>Vermote, E.F., Tanre, D., Deuze, J.L., Herman, M., and Morcrette, J.J., 1997,
-Second simulation of the satellite signal in the solar spectrum, 6S: An
-overview., IEEE Trans. Geosc. and Remote Sens. 35(3):675-686.
-<p><a href="http://modis-sr.ltdri.org/6S_code/6S_code2_thinner_stuff/6S_ltdri_org_manual.html">6s manual</a> at the <a href="http://modis-sr.ltdri.org/6S_code/index.html">6s homepage</a> of the Land Surface Reflectance Science Computing Facility
-<p>Mauro A. Homem Antunes <a href="http://www.ltid.inpe.br/dsr/mauro/6s/download_6s.html">website about his 6s version</a>
Copied: grass/trunk/imagery/i.atcorr/i.atcorr.html (from rev 32770, grass/trunk/imagery/i.atcorr/description.html)
--- grass/trunk/imagery/i.atcorr/i.atcorr.html (rev 0)
+++ grass/trunk/imagery/i.atcorr/i.atcorr.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,523 @@
+<h2>DESCRIPTION</h2>
+<b>i.atcorr</b> performs atmospheric correction on the input raster using the
+6S algorithm (Second Simulation of Satellite Signal in the Solar Spectrum). A
+detailed algorithm description is available at the
+<a href=http://modis-sr.ltdri.org/index.html>Land Surface Reflectance Science
+Computing Facility website</a> and Mauro A. Homem Antunes <a
+href="http://www.ltid.inpe.br/dsr/mauro/6s/download_6s.html">website about his
+6s version</a>.
+<p>
+Current region settings are ignored. The region is adjusted to cover the input
+raster before the atmospheric correction is performed. This should not affect
+the user's current region settings.
+<p>
+Because using a continuous elevation <em>ialt</em> or visibility <em>ivis</em>
+map makes execution time much longer, it is advised to use categorized maps
+instead, in conjuction with flag <em>-o</em>. This flag tells
+<b>i.atcorr</b> to try and speedup calculations. However, this option under
+certain conditions can make execution time longer.
+<p>
+If flag <em>-r</em> is used, the input data are treated as reflectance.
+Otherwise, the input data are treated as radiance values and are converted to
+reflectance at the <b>i.atcorr</b> runtime. The output data are always
+reflectance.
+<p>
+An example 6s parameters <em>icnd</em> file for <b>i.atcorr</b>:
+<p>
+8 - geometrical conditions=Landsat ETM+
+2 19 13.00 -47.410 -20.234 - month day hh.ddd longitude lattitude ("hh.ddd" is a decimal hour GMT)
+1 - atmospheric mode=tropical
+1 - aerosols model=continental
+15 - visibility [km] (aerosol model concentration)
+-.600 - target at 600m above sea level
+-1000 - sensor on board a satellite
+64 - 4th band of ETM+ Landsat 7
+</pre></div>
+<h2><font color="red">REMAINING DOCUMENTATION ISSUES</font></h2>
+1. Using the target elevation and visibility parameters in the <em>icnd</em>
+file overrides <em>ialt</em> and <em>ivis</em> input rasters. It is not clear
+what to do to force <b>i.atcorr</b> to use the rasters instead though.
+<p>
+2. The "example 6s parameters file" explains that "-.600" in line 6 means
+"target at 600 m ASL". However, in the section E of "6S CODE PARAMETER CHOICES"
+it reads: "xps <=0. means the target is at the sea level". This is contrary.
+<p>
+3. In section E, I'm not sure if the "-100< xpp <0" shouldn't actually be
+"-1000< xpp <0". ?
+<p>
+4. It is not explained what is the "iaer" parameter that section D refers to.
+<p>
+5. Section D's "Aerosol model concentration" title could use a better wording I
+suppose. The current one seems to mean "the concentration of the model of the
+aerosol". Should it be "Aerosol concentration model"?
+<p>
+6. It should be explained under what circumstances the use of categorized maps
+in conjuction with flag <em>-o</em> can slow down the calculations instead of
+speeding them up.
+<p>
+7. "This should not affect the user's current region settings" sounds ambigious.
+<p>
+<H2>6S CODE PARAMETER CHOICES</H2>
+<h3>A. Geometrical conditions:</h3>
+<table BORDERWIDTH="AUTO" CELLPADDING="3">
+<tr>
+<td>Code</td>
+<td>Description</td>
+<td>Details</td>
+</tr>
+<tr>
+<td>1</td>
+<td><b>meteosat</b> observation</td>
+<td>enter month,day,decimal hour (universal time-hh.ddd)
+<br>
+n. of column,n. of line.(full scale 5000*2500) </td>
+</tr>
+<tr>
+<td>2</td>
+<td><b>goes east </b>observation</td>
+<br>
+n. of column,n. of line.(full scale 17000*12000)c</td>
+</tr>
+<tr>
+<td>3</td>
+<td><b>goes west</b> observation</td>
+<br>
+n. of column,n. of line.(full scale 17000*12000)</td>
+</tr>
+<tr>
+<td>4</td>
+<td><b>avhrr</b> (PM noaa)</td>
+<br>
+n. of column(1-2048),xlonan,hna
+<br>
+give long.(xlonan) and overpass hour (hna) at
+<br>
+the ascendant node at equator</td>
+</tr>
+<tr>
+<td>5</td>
+<td><b>avhrr</b> (AM noaa)</td>
+<br>
+<br>
+<br>
+</tr>
+<tr>
+<td>6</td>
+<td><b>hrv</b> (spot)</td>
+<td>enter month,day,hh.ddd,long.,lat. *</td>
+</tr>
+<tr>
+<td>7</td>
+<td><b>tm</b> (landsat)</td>
+</tr>
+<tr>
+<td>8</td>
+<td><b>etm+</b> (landsat7)</td>
+</tr>
+</table>
+<blockquote>
+* NOTE: for hrv, tm and etm+ experiments, longitude and lattitude
+are the coordinates of the scene center. Lattitude must be >0 for northern
+hemisphere and <0 for southern. Longitude must be >0 for eastern hemisphere
+and <0 for western.
+</blockquote>
+<br><h3>B. Atmospheric model</h3>
+<tr>
+<td>Code</td>
+<td>Meaning</td>
+</tr>
+<tr>
+<td>0</td>
+<td>no gaseous absorption</td>
+</tr>
+<tr>
+<td>1</td>
+<td>tropical</td>
+</tr>
+<tr>
+<td>2</td>
+<td>midlatitude summer</td>
+</tr>
+<tr>
+<td>3</td>
+<td>midlatitude winter</td>
+</tr>
+<tr>
+<td>4</td>
+<td>subarctic summer</td>
+</tr>
+<tr>
+<td>5</td>
+<td>subarctic winter</td>
+</tr>
+<tr>
+<td>6</td>
+<td>us standard 62</td>
+</tr>
+<tr>
+<td>7</td>
+<td>Define your own atmospheric model as a set of the following 5 parameters
+per each measurement:<br>
+<br>altitude [km]
+<br>pressure [mb]
+<br>temperature [k]
+<br>h2o density [g/m3]
+<br>o3 density [g/m3]<br>
+<br>For example: there is one radiosonde measurement for each altitude of
+0-25km at a step of 1km, one measurment for each altitude of 25-50km at a step
+of 5km, and two single measurements for altitudes 70km and 100km. This makes 34
+measurments. In that case, there are 34*5 values to input.</td>
+</tr>
+<tr>
+<td>8</td>
+<td>Define your own atmospheric model providing values of the water vapor and
+ozone content:
+<br>
+<br>uw [g/cm2]
+<br>uo3 [cm-atm]
+<br>
+<br> The profile is taken from us62.</td>
+</tr>
+</table>
+<br><h3>C. Aerosols model</h3>
+<tr>
+<td>Code</td>
+<td>Meaning</td>
+<td>Details</td>
+</tr>
+<tr>
+<td>0</td>
+<td>no aerosols</td>
+<td></td>
+</tr>
+<tr>
+<td>1</td>
+<td>continental model</td>
+<td></td>
+</tr>
+<tr>
+<td>2</td>
+<td>maritime model</td>
+<td></td>
+</tr>
+<tr>
+<td>3</td>
+<td>urban model</td>
+<td></td>
+</tr>
+<tr>
+<td>4</td>
+<td>shettle model for background desert aerosol</td>
+<td></td>
+</tr>
+<tr>
+<td>5</td>
+<td>biomass burning</td>
+<td></td>
+</tr>
+<tr>
+<td>6</td>
+<td>stratospheric model</td>
+<td></td>
+</tr>
+<tr>
+<td>7</td>
+<td>define your own model</td>
+<td>Enter the volumic percentage of each component:
+<br>
+<br>c(1) = volumic % of dust-like
+<br>c(2) = volumic % of water-soluble
+<br>c(3) = volumic % of oceanic
+<br>c(4) = volumic % of soot
+<br>
+<br>All values between 0 and 1.</td>
+</tr>
+<tr>
+<td>8</td>
+<td>Size distribution function: Multimodal Log Normal (up to 4 modes).</td>
+</tr>
+<tr>
+<td>9</td>
+<td>Size distribution function: Modified gamma.</td>
+</tr>
+<tr>
+<td>10</td>
+<td>Size distribution function: Junge Power-Law.</td>
+</tr>
+<tr>
+<td>11</td>
+<td>Sun-photometer measurements, 50 values max, entered as:
+<br>
+<br>r and d V / d (logr)
+<br>
+<br>where r is the radius [micron], V is the volume, d V / d (logr) [cm3/cm2/micron].
+<br>
+<br>Followed by:
+<br>
+<br>nr and ni for each wavelength
+<br>
+<br>where nr and ni are respectively the real and imaginary part of the
+refractive index.</td>
+</tr>
+</table>
+<br><h3>D. Aerosol model concentration (visibility)</h3>
+<blockquote>If you have an estimate of the meteorological parameter visibility
+v, enter directly the value of v [km] (the aerosol optical depth will be
+computed from a standard aerosol profile).
+<p>If you have an estimate of aerosol optical depth, enter v=0 for the
+visibility and enter the aerosol optical depth at 550nm.
+<p>NOTE: if iaer=0, enter v=-1.</blockquote>
+<br><h3>E. Target altitude (xps), sensor platform (xpp)</h3>
+<blockquote>xps <=0 means the target is at the sea level.
+<br>xps >0 means you know the altitude of the target expressed
+in km, and you put that value as xps.
+<br>
+<br>xpp=-1000 means that the sensor is on board a satellite.
+<br>xpp=0 means that the sensor is at the ground level.
+<br>-100<xpp<0 means you know the altitude of the sensor
+expressed in kilometers; this altitude is <b>relative to the target</b>
+altitude.
+<p>For aircraft simulations only (xpp is neither 0 nor -1000):
+<blockquote>
+puw,po3 (water vapor content,ozone content between the aircraft and the surface)
+<br>taerp (the aerosol optical thickness at 550nm between the aircraft and the
+surface)
+<p>If these data are not available, enter negative values for all of them.
+puw,po3 will then be interpolated from the us62 standard profile according
+to the values at the ground level. taerp will be computed according to a 2km
+exponential profile for aerosol.</blockquote>
+</blockquote>
+<br><h3>F. Sensor band</h3>
+<p>There are two possibilities: either define your own spectral conditions
+(codes -2, -1, 0, or 1) or choose a code indicating the band of one of the
+pre-defined satellites.
+<p>Define your own spectral conditions:
+<p>
+<tr>
+<td>Code</td>
+<td>Meaning</td>
+</tr>
+<tr>
+<td>-2</td>
+<td>Enter wlinf, wlsup.
+<br>The filter function will be equal to 1 over the whole band (as iwave=0)
+but step by step output will be printed.</td>
+</tr>
+<tr>
+<td>-1</td>
+<td>Enter wl (monochr. cond, gaseous absorption is included).</td>
+</tr>
+<tr>
+<td>0</td>
+<br>The filter function will be equal to 1over the whole band.</td>
+</tr>
+<tr>
+<td>1</td>
+<td>Enter wlinf, wlsup and user's filter function s(lambda) by step of 0.0025
+micrometer.</td>
+</tr>
+</table>
+<p>Pre-defined satellite bands:
+<p>
+<tr><td>Code</td><td>Meaning</td></tr>
+<tr><td>2</td><td><b>meteosat</b> vis band (0.350-1.110)</td></tr>
+<tr><td>3</td><td><b>goes east</b> band vis (0.490-0.900)</td></tr>
+<tr><td>4</td><td>goes west band vis (0.490-0.900)</td></tr>
+<tr><td>5</td><td><b>avhrr (noaa6)</b> band 1 (0.550-0.750)</td></tr>
+<tr><td>6</td><td>avhrr (noaa6) band 2 (0.690-1.120)</td></tr>
+<tr><td>7</td><td><b>avhrr (noaa7)</b> band 1 (0.500-0.800)</td></tr>
+<tr><td>8</td><td>avhrr (noaa7) band 2 (0.640-1.170)</td></tr>
+<tr><td>9</td><td><b>avhrr (noaa8)</b> band 1 (0.540-1.010)</td></tr>
+<tr><td>10</td><td>avhrr (noaa8) band 2 (0.680-1.120)</td></tr>
+<tr><td>11</td><td><b>avhrr (noaa9)</b> band 1 (0.530-0.810)</td></tr>
+<tr><td>12</td><td>avhrr (noaa9) band 1 (0.680-1.170)</td></tr>
+<tr><td>13</td><td><b>avhrr (noaa10)</b> band 1 (0.530-0.780)</td></tr>
+<tr><td>14</td><td>avhrr (noaa10) band 2 (0.600-1.190)</td></tr>
+<tr><td>15</td><td><b>avhrr (noaa11)</b> band 1 (0.540-0.820)</td></tr>
+<tr><td>16</td><td>avhrr (noaa11) band 2 (0.600-1.120)</td></tr>
+<tr><td>17</td><td><b>hrv1 (spot1)</b> band 1 (0.470-0.650)</td></tr>
+<tr><td>18</td><td>hrv1 (spot1) band 2 (0.600-0.720)</td></tr>
+<tr><td>19</td><td>hrv1 (spot1) band 3 (0.730-0.930)</td></tr>
+<tr><td>20</td><td>hrv1 (spot1) band pan (0.470-0.790)</td></tr>
+<tr><td>21</td><td><b>hrv2 (spot1)</b> band 1 (0.470-0.650)</td></tr>
+<tr><td>22</td><td>hrv2 (spot1) band 2 (0.590-0.730)</td></tr>
+<tr><td>23</td><td>hrv2 (spot1) band 3 (0.740-0.940)</td></tr>
+<tr><td>24</td><td>hrv2 (spot1) band pan (0.470-0.790)</td></tr>
+<tr><td>25</td><td><b>tm (landsat5)</b> band 1 (0.430-0.560)</td></tr>
+<tr><td>26</td><td>tm (landsat5) band 2 (0.500-0.650)</td></tr>
+<tr><td>27</td><td>tm (landsat5) band 3 (0.580-0.740)</td></tr>
+<tr><td>28</td><td>tm (landsat5) band 4 (0.730-0.950)</td></tr>
+<tr><td>29</td><td>tm (landsat5) band 5 (1.5025-1.890)</td></tr>
+<tr><td>30</td><td>tm (landsat5) band 7 (1.950-2.410)</td></tr>
+<tr><td>31</td><td><b>mss (landsat5)</b> band 1 (0.475-0.640)</td></tr>
+<tr><td>32</td><td>mss (landsat5) band 2 (0.580-0.750)</td></tr>
+<tr><td>33</td><td>mss (landsat5) band 3 (0.655-0.855)</td></tr>
+<tr><td>34</td><td>mss (landsat5) band 4 (0.785-1.100)</td></tr>
+<tr><td>35</td><td><b>MAS (ER2)</b> band 1 (0.5025-0.5875)</td></tr>
+<tr><td>36</td><td>MAS (ER2) band 2 (0.6075-0.7000)</td></tr>
+<tr><td>37</td><td>MAS (ER2) band 3 (0.8300-0.9125)</td></tr>
+<tr><td>38</td><td>MAS (ER2) band 4 (0.9000-0.9975)</td></tr>
+<tr><td>39</td><td>MAS (ER2) band 5 (1.8200-1.9575)</td></tr>
+<tr><td>40</td><td>MAS (ER2) band 6 (2.0950-2.1925)</td></tr>
+<tr><td>41</td><td>MAS (ER2) band 7 (3.5800-3.8700)</td></tr>
+<tr><td>42</td><td><b>MODIS</b> band 1 (0.6100-0.6850)</td></tr>
+<tr><td>43</td><td>MODIS band 2 (0.8200-0.9025)</td></tr>
+<tr><td>44</td><td>MODIS band 3 (0.4500-0.4825)</td></tr>
+<tr><td>45</td><td>MODIS band 4 (0.5400-0.5700)</td></tr>
+<tr><td>46</td><td>MODIS band 5 (1.2150-1.2700)</td></tr>
+<tr><td>47</td><td>MODIS band 6 (1.6000-1.6650)</td></tr>
+<tr><td>48</td><td>MODIS band 7 (2.0575-2.1825)</td></tr>
+<tr><td>49</td><td><b>avhrr (noaa12)</b> band 1 (0.500-1.000)</td></tr>
+<tr><td>50</td><td>avhrr (noaa12) band 2 (0.650-1.120)</td></tr>
+<tr><td>51</td><td><b>avhrr (noaa14)</b> band 1 (0.500-1.110)</td></tr>
+<tr><td>52</td><td>avhrr (noaa14) band 2 (0.680-1.100)</td></tr>
+<tr><td>53</td><td><b>POLDER</b> band 1 (0.4125-0.4775)</td></tr>
+<tr><td>54</td><td>POLDER band 2 (non polar) (0.4100-0.5225)</td></tr>
+<tr><td>55</td><td>POLDER band 3 (non polar) (0.5325-0.5950)</td></tr>
+<tr><td>56</td><td>POLDER band 4 P1 (0.6300-0.7025)</td></tr>
+<tr><td>57</td><td>POLDER band 5 (non polar) (0.7450-0.7800)</td></tr>
+<tr><td>58</td><td>POLDER band 6 (non polar) (0.7000-0.8300)</td></tr>
+<tr><td>59</td><td>POLDER band 7 P1 (0.8100-0.9200)</td></tr>
+<tr><td>60</td><td>POLDER band 8 (non polar) (0.8650-0.9400)</td></tr>
+<tr><td>61</td><td><b>etm+ (landsat7)</b> band 1 (0.435-0.520)</td></tr>
+<tr><td>62</td><td>etm+ (landsat7) band 2 (0.506-0.621)</td></tr>
+<tr><td>63</td><td>etm+ (landsat7) band 3 (0.622-0.702)</td></tr>
+<tr><td>64</td><td>etm+ (landsat7) band 4 (0.751-0.911)</td></tr>
+<tr><td>65</td><td>etm+ (landsat7) band 5 (1.512-1.792)</td></tr>
+<tr><td>66</td><td>etm+ (landsat7) band 7 (2.020-2.380)</td></tr>
+<tr><td>67</td><td>etm+ (landsat7) band 8 (0.504-0.909)</td></tr>
+</table>
+<H2>AUTHORS</H2>
+<p><em>Original version of the program for GRASS 5:</em>
+<br>Christo Zietsman, 13422863(at)sun.ac.za
+<p><em>Code clean-up and port to GRASS 6.3, 15.12.2006:</em>
+<br>Yann Chemin, ychemin(at)gmail.com
+<h2>REFERENCES</h2>
+<p>Vermote, E.F., Tanre, D., Deuze, J.L., Herman, M., and Morcrette, J.J., 1997,
+Second simulation of the satellite signal in the solar spectrum, 6S: An
+overview., IEEE Trans. Geosc. and Remote Sens. 35(3):675-686.
+<p><a href="http://modis-sr.ltdri.org/6S_code/6S_code2_thinner_stuff/6S_ltdri_org_manual.html">6s manual</a> at the <a href="http://modis-sr.ltdri.org/6S_code/index.html">6s homepage</a> of the Land Surface Reflectance Science Computing Facility
+<p>Mauro A. Homem Antunes <a href="http://www.ltid.inpe.br/dsr/mauro/6s/download_6s.html">website about his 6s version</a>
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/imagery/i.cca/description.html
--- grass/trunk/imagery/i.cca/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.cca/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,82 +0,0 @@
-<H2>DESCRIPTION</H2>
-<B>i.cca</B> is an image processing program that takes from two to eight
-(raster) band files and a signature file, and outputs the same number of
-raster band files transformed to provide maximum separability of the
-categories indicated by the signatures. This implementation of the
-canonical components transformation is based on the algorithm contained in
-the <a href=http://dbwww.essc.psu.edu/lasdoc/user/canal.html>LAS image
-processing system</a>. CCA is also known as "Canonical components
-transformation".
-<P>
-Typically the user will use the
-<EM><A HREF="i.class.html">i.class</A></EM>
-program to collect a set of signatures and then pass those
-signatures along with the raster band files to
-<EM>i.cca</EM>. The raster band file names are specified
-on the command line by giving the group and subgroup that
-were used to collect the signatures.
-<P>
-The output raster map names are built by appending a ".1",
-".2", etc. to the output raster map name specified on the
-command line.
-<H3>Parameters:</H3>
-<DL>
-<DT><B>group=</B><EM>name</EM>
-<DD>Name of the <A HREF="i.group.html">imagery</A> group
-to which the 2 to 8 raster band files used belong.
-<DT><B>subgroup=</B><EM>name</EM>
-subgroup to which the 2 to 8 raster band files used
-belong.
-<DT><B>signature=</B><EM>name</EM>
-<DD>Name of an ASCII file containing spectral signatures.
-<DT><B>output=</B><EM>name</EM>
-<DD>Output raster map prefix name. The output raster map
-layer names are built by appending a ".1", ".2", etc. onto
-the <EM>output</EM> name specified by the user.
-</DL>
-<H2>NOTES</H2>
-<EM>i.cca</EM> respects the current geographic region definition
-and the current mask setting while performing the transformation.
-<H2>SEE ALSO</H2>
-Schowengerdt, Robert A. <B>Techniques for Image Processing and
-Classification in Remote Sensing</B>, Academic Press, 1983.
-<P>
-<EM><A HREF="i.class.html">i.class</A></EM><br>
-<EM><A HREF="i.pca.html">i.pca</A></EM><br>
-<EM><A HREF="r.covar.html">r.covar</A></EM><br>
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>
-<H2>AUTHORS</H2>
-David Satnik, GIS Laboratory,
-Central Washington University
-<BR>
-Ali R. Vali,
-University of Texas
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.cca/i.cca.html (from rev 32770, grass/trunk/imagery/i.cca/description.html)
--- grass/trunk/imagery/i.cca/i.cca.html (rev 0)
+++ grass/trunk/imagery/i.cca/i.cca.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,82 @@
+<H2>DESCRIPTION</H2>
+<B>i.cca</B> is an image processing program that takes from two to eight
+(raster) band files and a signature file, and outputs the same number of
+raster band files transformed to provide maximum separability of the
+categories indicated by the signatures. This implementation of the
+canonical components transformation is based on the algorithm contained in
+the <a href=http://dbwww.essc.psu.edu/lasdoc/user/canal.html>LAS image
+processing system</a>. CCA is also known as "Canonical components
+transformation".
+<P>
+Typically the user will use the
+<EM><A HREF="i.class.html">i.class</A></EM>
+program to collect a set of signatures and then pass those
+signatures along with the raster band files to
+<EM>i.cca</EM>. The raster band file names are specified
+on the command line by giving the group and subgroup that
+were used to collect the signatures.
+<P>
+The output raster map names are built by appending a ".1",
+".2", etc. to the output raster map name specified on the
+command line.
+<H3>Parameters:</H3>
+<DL>
+<DT><B>group=</B><EM>name</EM>
+<DD>Name of the <A HREF="i.group.html">imagery</A> group
+to which the 2 to 8 raster band files used belong.
+<DT><B>subgroup=</B><EM>name</EM>
+subgroup to which the 2 to 8 raster band files used
+belong.
+<DT><B>signature=</B><EM>name</EM>
+<DD>Name of an ASCII file containing spectral signatures.
+<DT><B>output=</B><EM>name</EM>
+<DD>Output raster map prefix name. The output raster map
+layer names are built by appending a ".1", ".2", etc. onto
+the <EM>output</EM> name specified by the user.
+</DL>
+<H2>NOTES</H2>
+<EM>i.cca</EM> respects the current geographic region definition
+and the current mask setting while performing the transformation.
+<H2>SEE ALSO</H2>
+Schowengerdt, Robert A. <B>Techniques for Image Processing and
+Classification in Remote Sensing</B>, Academic Press, 1983.
+<P>
+<EM><A HREF="i.class.html">i.class</A></EM><br>
+<EM><A HREF="i.pca.html">i.pca</A></EM><br>
+<EM><A HREF="r.covar.html">r.covar</A></EM><br>
+<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>
+<H2>AUTHORS</H2>
+David Satnik, GIS Laboratory,
+Central Washington University
+<BR>
+Ali R. Vali,
+University of Texas
Deleted: grass/trunk/imagery/i.class/description.html
--- grass/trunk/imagery/i.class/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.class/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,432 +0,0 @@
-<EM>i.class</EM>
-performs the first pass in the GRASS two-pass supervised image
-classification process;
-the GRASS program
-<EM><A HREF="i.maxlik.html">i.maxlik</A></EM> executes the second pass.
-Both programs must be run to generate a classified map in GRASS
-raster format.
-<P>
-<EM>i.class</EM> is an interactive program that allows the user to outline
-a region on the screen and calculate the spectral signature based on the
-cells that are within that region. During this process the user will be
-shown a histogram of the region for each image band. The user can also
-display the cells of the image bands which fall within a user-specified
-number of standard deviations from the means in the spectral signature.
-By doing this, the user can see how much of the image
-is likely to be put into the class associated with the current signature.
-<P>
-The spectral signatures that result are composed of region means and
-covariance matrices. These region means and covariance matrices are used in
-the second pass (<EM><A HREF="i.maxlik.html">i.maxlik</A></EM>) to classify
-the image.
-<P>
-Alternatively, the spectral signatures generated by <EM>i.class</EM> can be
-used for seed means for the clusters in the
-<EM><A HREF="i.cluster.html">i.cluster</A></EM> program.
-<H2>USER INPUTS</H2>
-At the command line the user is asked to enter the name of the raster map
-to be displayed during the process of outlining regions.
-Typically, the user will want to enter the name of a color
-composite previously created by
-<EM><A HREF="r.composite.html">r.composite</A></EM>.
-However, the user can enter the name of any existing raster
-map. This leaves the potential for using a raster map not
-directly derived from the image as a backdrop on which the
-user can outline the classes of interest.
-<P>
-The first screen in the program <EM>i.class</EM> asks the user for the
-<A HREF="i.group.html">imagery</A> <EM>group</EM> and <EM>subgroup</EM>
-to be analyzed:
-<div class="code"><PRE>
- Please select the group and subgroup to be analyzed
-GROUP: spot_______ (list will show available groups)
-SUBGROUP: 123________ (list will show available subgroups)
- AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
- (OR <Ctrl-C> TO CANCEL)
-</PRE></div>
-<P>
-The <EM>group</EM> should contain the
-imagery bands that the user wishes
-to classify. The <EM>subgroup</EM> is a subset of this group.
-The user must create a group and a subgroup by running the GRASS program
-<EM><A HREF="i.group.html">i.group</A></EM>
-before running <EM>i.class</EM>. The subgroup should contain
-only the image bands that the user wishes to classify.
-Note that this subgroup must contain more than one band.
-<P>
-After the first screen, the program asks the user for the name of the
-resulting signature file. The signature file is both the output file for
-<EM>i.class</EM> and the required input file for the GRASS
-<EM><A HREF="i.maxlik.html">i.maxlik</A></EM> module.
-It contains the region means and covariance matrices that are used to
-classify an image in <EM><A HREF="i.maxlik.html">i.maxlik</A></EM>.
-The signature file will be saved in the
-<tt>$MAPSET/group/$GROUP/subgroup/$SUBGROUP/sig/</tt> directory.
-<P>
-After entering the resulting signature file name, the user
-is asked to enter the name of a seed signature file. This
-is optional. A "seed" signature file is a previously
-created signature file. Such a seed signature file may be
-the result of an earlier run of <EM>i.class</EM>. The seed
-signature file is copied into the new resulting signature
-file before any new signatures are added by
-<EM>i.class</EM>. In this way, you can collect the work
-from several sessions with <EM>i.class</EM> into one
-signature file.
-<P>
-At this point the <EM>i.class</EM> graphics screen will be
-drawn on the graphics monitor and the user will be directed
-to use the mouse. From this point on the user will
-primarily work with the mouse, selecting options from the
-menus and outlining regions on the screen. The only time
-that the user will need to return to the text terminal is
-to enter names for the signatures created.
-<H2>THE DISPLAY FRAMES</H2>
-The display frame layout that <EM>i.class</EM> uses is
-represented below for reference.
-| | Map Display Frame |
-| Histogram Display | |
-| Frame | |
-| | Zoom Display Frame |
-| Menu Frame |
-</PRE></div>
-<H2>THE MENUS</H2>
-All of the menus in the <EM>i.class</EM> program are
-displayed across the bottom of the graphics monitor in the
-Menu Frame. To select an option from one of these menus,
-simply place the cursor over your selection and press any
-button on the mouse. Each of the menus is discussed in the
-following paragraphs.
-<A NAME="commandmenu"></a>
-<H3>The Command Menu</H3>
-The Command Menu includes the following selections:
-<DL>
-<DT><EM>Zoom</EM>
-<DD>This command allows the user to outline a rectangular
-region in either the Map or Zoom Display Frames and the
-region is displayed, magnified, to fit in the Zoom Display
-Frame. A red rectangle is drawn in the Map Display Frame,
-indicating what area the Zoom Display Frame shows.
-<P>
-To outline the rectangular region simply use any mouse button to anchor
-the first corner of the border and then use any button to choose the
-other corner.
-<DT><EM>Define region</EM>
-<DD>This selection takes the user to the
-<A HREF="#regionmenu">Region Menu</A>.
-This menu includes the
-options that allow the user to outline a region of interest
-on the displayed raster map.
-<DT><EM>Redisplay map</EM>
-<DD>This selection takes the user to the Redisplay Menu.
-The
-<A HREF="#redisplaymenu">Redisplay Menu</A>
-allows the user to redraw map display
-frames.
-<DT><EM>Analyze region</EM>
-<DD>This selection starts the process of analyzing the
-currently defined region. A histogram of the defined
-region will be displayed for each band. On the histogram
-for each band, the mean, standard deviation, minimum cell
-value and maximum cell value are marked. The histograms
-are automatically scaled in an attempt to fit the data into
-the space available, but it is possible that all of the
-data will not fit. In this case, as much of the data as
-possible, centered around the mean, will be displayed.
-After the histograms are displayed, the user will be given
-the
-<A HREF="#signaturemenu">Signature Menu</A>.
-<DT><EM>Quit</EM>
-<DD>The user should make this selection
-to end the session with <EM>i.class</EM>.
-</DL>
-<A NAME="regionmenu"></a>
-<H3>The Region Menu</H3>
-The Region Menu contains the following selections:
-<DL>
-<DT><EM>Erase region</EM>
-<DD>This selection erases any currently defined
-region.
-<DT><EM>Draw region</EM>
-<DD>This selection allows the user to use the mouse to
-draw a region on either the Map or Zoom Display Frame. An
-explanation of which mouse buttons to use is displayed in the Menu
-Frame. The user does not need to try to complete the region boundary. The
-last line of the region will be added when the user selects the
-Complete region option on the Region Menu.
-<DT><EM>Restore last region</EM>
-<DD>This selection restores the last region
-that was drawn. After a region is completed, it will be saved to be
-restored later. Only one previous region is saved.
-<DT><EM>Complete region</EM>
-<DD>This selection completes the region that is
-currently being drawn. As noted above, it saves the complete
-region to be restored later, if needed. Once the user has made a
-complete region, it can be analyzed with the Analyze Region
-selection on the <A HREF="#commandmenu">Command Menu</A>.
-<DT><EM>Done</EM>
-<DD>Use this selection to return to the
-<A HREF="#commandmenu">Command Menu</A>.
-</DL>
-<A NAME="redisplaymenu"></a>
-<H3>The Redisplay Map Menu</H3>
-The Redisplay Map Menu has the following selections, which are useful
-to redraw the raster maps displayed in the Map and Zoom Display Frames.
-<DL>
-<DT><EM>Map geographic region</EM>
-<DD>This selection causes the raster map in the Map
-Display Frame to be redrawn.
-<DT><EM>Zoom region</EM>
-<DD>This selection causes the Zoom Display Frame to
-be redrawn.
-<DT><EM>Both</EM>
-<DD>This selection causes both the Map and Zoom Display
-Frames to be redrawn.
-<DT><EM>Cancel</EM>
-<DD>Use this selection if you do not want to redisplay
-either of the above regions. The user will be returned to the
-</DL>
-<A NAME="signaturemenu"></a>
-<H3>The Analyze Region Menu</H3>
-The Analyze Region Menu contains the Signature Menu, which
-allows the user to set the number of standard deviations
-and the display color, and then to display (as an overlay)
-the cells that match the signature within the number of
-standard deviations specified. Note that once the matching
-cells are displayed, the Map Display Frame must be
-redisplayed to see only the original raster map again. The
-following selections are available on the Signature Menu:
-<DL>
-<DT><EM>Set std dev's</EM>
-<DD>This selection allows the user to set the number of
-standard deviations from the mean for the maximum and
-minimum range. The maximum and minimum range is used when
-finding the cells that "match" the signature. The user is
-presented with a menu of typical choices and an "Other"
-option. If the "Other" option is selected, enter the
-number of standard deviations from the keyboard on the text
-terminal. Otherwise, the selected option will be used.
-When the number of standard deviations is set, the
-histograms for each band will be redrawn with the maximum
-and minimum range marked.
-<P>
-Note that the number in parentheses on this
-selection is the current number of standard deviations.
-<DT><EM>Set color</EM>
-<DD>This selection allows the user to set the color for the
-display of cells that "match" the current signature. The
-user is presented with a menu of color choices. The color
-selected will be used when the Display Matches Menu
-selection is made.
-<P>
-Note that the color in parentheses on this selection is the current
-color for display.
-<DT><EM>Display matches</EM>
-<DD>This selection displays the cells that "match" the
-current signature in the current color. A cell "matches"
-the current signature if the cell value in each band is
-between the minimum range and maximum range for that band
-defined by the number of standard deviations currently
-set.
-<DT><EM>Done</EM>
-<DD>When this selection is chosen, the user will be asked
-whether or not he/she would like to save the current
-signature. If the user answers with the "Yes" selection,
-he/she will be asked to enter a description for the
-resultant signature file on the text terminal keyboard.
-The saved signature file description will be used by <EM>
-<A HREF="i.maxlik.html">i.maxlik</A></EM> to name the
-category that is created from the current signature. After
-either a "No" answer or the signature description is
-entered, the user is returned to the Command Menu.
-</DL>
-<H2>NOTES</H2>
-<EM>i.class</EM> uses the current MASK to generate the
-overlay for cells that match a signature. As a result, if
-a MASK already exists it will be removed during the
-execution of this program.
-<P>
-The cell values in the image bands cannot fall outside of
-the range of 0 to 255. <EM>i.class</EM> will report an
-error if they do.
-<P>
-<EM>i.class</EM>, like some of the other
-<A HREF="imagery.html">imagery</A> programs, does not use the
-standard GRASS display frames. After running
-<EM>i.class</EM>, you will need to create a display frame
-(e.g., using
-<EM><A HREF="d.frame.html">d.frame</A></EM> or
-<EM><A HREF="d.erase.html">d.erase</A></EM>)
-before you can use most of the GRASS display (d.) commands.
-<P>
-must be run before <EM>i.class</EM> to create an
-<A HREF="i.group.html">imagery</A> group and a subgroup
-containing the image bands to be classified.
-<P>
-The user can perform a supervised image classification by
-running <EM>i.class</EM> followed by
-<EM><A HREF="i.maxlik.html">i.maxlik</A></EM>.
-The user can perform an unsupervised classification
-by running
-<EM><A HREF="i.cluster.html">i.cluster</A></EM> followed by
-<P>
-<EM>i.class</EM> is interactive and requires the user to be running
-a graphics display monitor (see <EM><A HREF="d.mon.html">d.mon</A></EM>)
-to run this program.
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<A HREF="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
-Processing manual</A></EM>
-<P>
-<EM><A HREF="d.frame.html">d.frame</A>,
-<A HREF="d.mon.html">d.mon</A>,
-<A HREF="g.region.html">g.region</A>,
-<A HREF="i.cca.html">i.cca</A>,
-<A HREF="i.cluster.html">i.cluster</A>,
-<A HREF="r.composite.html">r.composite</A>,
-<A HREF="i.group.html">i.group</A>,
-<A HREF="i.maxlik.html">i.maxlik</A>,
-<A HREF="r.mapcalc.html">r.mapcalc</A></EM>
-<H2>AUTHOR</H2>
-David Satnik,
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.class/i.class.html (from rev 32770, grass/trunk/imagery/i.class/description.html)
--- grass/trunk/imagery/i.class/i.class.html (rev 0)
+++ grass/trunk/imagery/i.class/i.class.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,432 @@
+<EM>i.class</EM>
+performs the first pass in the GRASS two-pass supervised image
+classification process;
+the GRASS program
+<EM><A HREF="i.maxlik.html">i.maxlik</A></EM> executes the second pass.
+Both programs must be run to generate a classified map in GRASS
+raster format.
+<P>
+<EM>i.class</EM> is an interactive program that allows the user to outline
+a region on the screen and calculate the spectral signature based on the
+cells that are within that region. During this process the user will be
+shown a histogram of the region for each image band. The user can also
+display the cells of the image bands which fall within a user-specified
+number of standard deviations from the means in the spectral signature.
+By doing this, the user can see how much of the image
+is likely to be put into the class associated with the current signature.
+<P>
+The spectral signatures that result are composed of region means and
+covariance matrices. These region means and covariance matrices are used in
+the second pass (<EM><A HREF="i.maxlik.html">i.maxlik</A></EM>) to classify
+the image.
+<P>
+Alternatively, the spectral signatures generated by <EM>i.class</EM> can be
+used for seed means for the clusters in the
+<EM><A HREF="i.cluster.html">i.cluster</A></EM> program.
+<H2>USER INPUTS</H2>
+At the command line the user is asked to enter the name of the raster map
+to be displayed during the process of outlining regions.
+Typically, the user will want to enter the name of a color
+composite previously created by
+<EM><A HREF="r.composite.html">r.composite</A></EM>.
+However, the user can enter the name of any existing raster
+map. This leaves the potential for using a raster map not
+directly derived from the image as a backdrop on which the
+user can outline the classes of interest.
+<P>
+The first screen in the program <EM>i.class</EM> asks the user for the
+<A HREF="i.group.html">imagery</A> <EM>group</EM> and <EM>subgroup</EM>
+to be analyzed:
+<div class="code"><PRE>
+LOCATION: location SUPERVISED CLASSIFIER MAPSET: demo
+ Please select the group and subgroup to be analyzed
+GROUP: spot_______ (list will show available groups)
+SUBGROUP: 123________ (list will show available subgroups)
+ AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
+ (OR <Ctrl-C> TO CANCEL)
+</PRE></div>
+<P>
+The <EM>group</EM> should contain the
+imagery bands that the user wishes
+to classify. The <EM>subgroup</EM> is a subset of this group.
+The user must create a group and a subgroup by running the GRASS program
+<EM><A HREF="i.group.html">i.group</A></EM>
+before running <EM>i.class</EM>. The subgroup should contain
+only the image bands that the user wishes to classify.
+Note that this subgroup must contain more than one band.
+<P>
+After the first screen, the program asks the user for the name of the
+resulting signature file. The signature file is both the output file for
+<EM>i.class</EM> and the required input file for the GRASS
+<EM><A HREF="i.maxlik.html">i.maxlik</A></EM> module.
+It contains the region means and covariance matrices that are used to
+classify an image in <EM><A HREF="i.maxlik.html">i.maxlik</A></EM>.
+The signature file will be saved in the
+<tt>$MAPSET/group/$GROUP/subgroup/$SUBGROUP/sig/</tt> directory.
+<P>
+After entering the resulting signature file name, the user
+is asked to enter the name of a seed signature file. This
+is optional. A "seed" signature file is a previously
+created signature file. Such a seed signature file may be
+the result of an earlier run of <EM>i.class</EM>. The seed
+signature file is copied into the new resulting signature
+file before any new signatures are added by
+<EM>i.class</EM>. In this way, you can collect the work
+from several sessions with <EM>i.class</EM> into one
+signature file.
+<P>
+At this point the <EM>i.class</EM> graphics screen will be
+drawn on the graphics monitor and the user will be directed
+to use the mouse. From this point on the user will
+primarily work with the mouse, selecting options from the
+menus and outlining regions on the screen. The only time
+that the user will need to return to the text terminal is
+to enter names for the signatures created.
+<H2>THE DISPLAY FRAMES</H2>
+The display frame layout that <EM>i.class</EM> uses is
+represented below for reference.
+| | Map Display Frame |
+| Histogram Display | |
+| Frame | |
+| | Zoom Display Frame |
+| Menu Frame |
+</PRE></div>
+<H2>THE MENUS</H2>
+All of the menus in the <EM>i.class</EM> program are
+displayed across the bottom of the graphics monitor in the
+Menu Frame. To select an option from one of these menus,
+simply place the cursor over your selection and press any
+button on the mouse. Each of the menus is discussed in the
+following paragraphs.
+<A NAME="commandmenu"></a>
+<H3>The Command Menu</H3>
+The Command Menu includes the following selections:
+<DL>
+<DT><EM>Zoom</EM>
+<DD>This command allows the user to outline a rectangular
+region in either the Map or Zoom Display Frames and the
+region is displayed, magnified, to fit in the Zoom Display
+Frame. A red rectangle is drawn in the Map Display Frame,
+indicating what area the Zoom Display Frame shows.
+<P>
+To outline the rectangular region simply use any mouse button to anchor
+the first corner of the border and then use any button to choose the
+other corner.
+<DT><EM>Define region</EM>
+<DD>This selection takes the user to the
+<A HREF="#regionmenu">Region Menu</A>.
+This menu includes the
+options that allow the user to outline a region of interest
+on the displayed raster map.
+<DT><EM>Redisplay map</EM>
+<DD>This selection takes the user to the Redisplay Menu.
+The
+<A HREF="#redisplaymenu">Redisplay Menu</A>
+allows the user to redraw map display
+frames.
+<DT><EM>Analyze region</EM>
+<DD>This selection starts the process of analyzing the
+currently defined region. A histogram of the defined
+region will be displayed for each band. On the histogram
+for each band, the mean, standard deviation, minimum cell
+value and maximum cell value are marked. The histograms
+are automatically scaled in an attempt to fit the data into
+the space available, but it is possible that all of the
+data will not fit. In this case, as much of the data as
+possible, centered around the mean, will be displayed.
+After the histograms are displayed, the user will be given
+the
+<A HREF="#signaturemenu">Signature Menu</A>.
+<DT><EM>Quit</EM>
+<DD>The user should make this selection
+to end the session with <EM>i.class</EM>.
+</DL>
+<A NAME="regionmenu"></a>
+<H3>The Region Menu</H3>
+The Region Menu contains the following selections:
+<DL>
+<DT><EM>Erase region</EM>
+<DD>This selection erases any currently defined
+region.
+<DT><EM>Draw region</EM>
+<DD>This selection allows the user to use the mouse to
+draw a region on either the Map or Zoom Display Frame. An
+explanation of which mouse buttons to use is displayed in the Menu
+Frame. The user does not need to try to complete the region boundary. The
+last line of the region will be added when the user selects the
+Complete region option on the Region Menu.
+<DT><EM>Restore last region</EM>
+<DD>This selection restores the last region
+that was drawn. After a region is completed, it will be saved to be
+restored later. Only one previous region is saved.
+<DT><EM>Complete region</EM>
+<DD>This selection completes the region that is
+currently being drawn. As noted above, it saves the complete
+region to be restored later, if needed. Once the user has made a
+complete region, it can be analyzed with the Analyze Region
+selection on the <A HREF="#commandmenu">Command Menu</A>.
+<DT><EM>Done</EM>
+<DD>Use this selection to return to the
+<A HREF="#commandmenu">Command Menu</A>.
+</DL>
+<A NAME="redisplaymenu"></a>
+<H3>The Redisplay Map Menu</H3>
+The Redisplay Map Menu has the following selections, which are useful
+to redraw the raster maps displayed in the Map and Zoom Display Frames.
+<DL>
+<DT><EM>Map geographic region</EM>
+<DD>This selection causes the raster map in the Map
+Display Frame to be redrawn.
+<DT><EM>Zoom region</EM>
+<DD>This selection causes the Zoom Display Frame to
+be redrawn.
+<DT><EM>Both</EM>
+<DD>This selection causes both the Map and Zoom Display
+Frames to be redrawn.
+<DT><EM>Cancel</EM>
+<DD>Use this selection if you do not want to redisplay
+either of the above regions. The user will be returned to the
+</DL>
+<A NAME="signaturemenu"></a>
+<H3>The Analyze Region Menu</H3>
+The Analyze Region Menu contains the Signature Menu, which
+allows the user to set the number of standard deviations
+and the display color, and then to display (as an overlay)
+the cells that match the signature within the number of
+standard deviations specified. Note that once the matching
+cells are displayed, the Map Display Frame must be
+redisplayed to see only the original raster map again. The
+following selections are available on the Signature Menu:
+<DL>
+<DT><EM>Set std dev's</EM>
+<DD>This selection allows the user to set the number of
+standard deviations from the mean for the maximum and
+minimum range. The maximum and minimum range is used when
+finding the cells that "match" the signature. The user is
+presented with a menu of typical choices and an "Other"
+option. If the "Other" option is selected, enter the
+number of standard deviations from the keyboard on the text
+terminal. Otherwise, the selected option will be used.
+When the number of standard deviations is set, the
+histograms for each band will be redrawn with the maximum
+and minimum range marked.
+<P>
+Note that the number in parentheses on this
+selection is the current number of standard deviations.
+<DT><EM>Set color</EM>
+<DD>This selection allows the user to set the color for the
+display of cells that "match" the current signature. The
+user is presented with a menu of color choices. The color
+selected will be used when the Display Matches Menu
+selection is made.
+<P>
+Note that the color in parentheses on this selection is the current
+color for display.
+<DT><EM>Display matches</EM>
+<DD>This selection displays the cells that "match" the
+current signature in the current color. A cell "matches"
+the current signature if the cell value in each band is
+between the minimum range and maximum range for that band
+defined by the number of standard deviations currently
+set.
+<DT><EM>Done</EM>
+<DD>When this selection is chosen, the user will be asked
+whether or not he/she would like to save the current
+signature. If the user answers with the "Yes" selection,
+he/she will be asked to enter a description for the
+resultant signature file on the text terminal keyboard.
+The saved signature file description will be used by <EM>
+<A HREF="i.maxlik.html">i.maxlik</A></EM> to name the
+category that is created from the current signature. After
+either a "No" answer or the signature description is
+entered, the user is returned to the Command Menu.
+</DL>
+<H2>NOTES</H2>
+<EM>i.class</EM> uses the current MASK to generate the
+overlay for cells that match a signature. As a result, if
+a MASK already exists it will be removed during the
+execution of this program.
+<P>
+The cell values in the image bands cannot fall outside of
+the range of 0 to 255. <EM>i.class</EM> will report an
+error if they do.
+<P>
+<EM>i.class</EM>, like some of the other
+<A HREF="imagery.html">imagery</A> programs, does not use the
+standard GRASS display frames. After running
+<EM>i.class</EM>, you will need to create a display frame
+(e.g., using
+<EM><A HREF="d.frame.html">d.frame</A></EM> or
+<EM><A HREF="d.erase.html">d.erase</A></EM>)
+before you can use most of the GRASS display (d.) commands.
+<P>
+must be run before <EM>i.class</EM> to create an
+<A HREF="i.group.html">imagery</A> group and a subgroup
+containing the image bands to be classified.
+<P>
+The user can perform a supervised image classification by
+running <EM>i.class</EM> followed by
+<EM><A HREF="i.maxlik.html">i.maxlik</A></EM>.
+The user can perform an unsupervised classification
+by running
+<EM><A HREF="i.cluster.html">i.cluster</A></EM> followed by
+<P>
+<EM>i.class</EM> is interactive and requires the user to be running
+a graphics display monitor (see <EM><A HREF="d.mon.html">d.mon</A></EM>)
+to run this program.
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<A HREF="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
+Processing manual</A></EM>
+<P>
+<EM><A HREF="d.frame.html">d.frame</A>,
+<A HREF="d.mon.html">d.mon</A>,
+<A HREF="g.region.html">g.region</A>,
+<A HREF="i.cca.html">i.cca</A>,
+<A HREF="i.cluster.html">i.cluster</A>,
+<A HREF="r.composite.html">r.composite</A>,
+<A HREF="i.group.html">i.group</A>,
+<A HREF="i.maxlik.html">i.maxlik</A>,
+<A HREF="r.mapcalc.html">r.mapcalc</A></EM>
+<H2>AUTHOR</H2>
+David Satnik,
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/imagery/i.cluster/description.html
--- grass/trunk/imagery/i.cluster/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.cluster/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,268 +0,0 @@
-<EM>i.cluster</EM>
-performs the first pass in the GRASS two-pass unsupervised
-classification of imagery, while the GRASS program <EM>
-<A HREF="i.maxlik.html">i.maxlik</A></EM> executes
-the second pass. Both programs must be run to complete the unsupervised
-classification.
-<P>
-<EM>i.cluster</EM> is a clustering algorithm that reads
-through the (raster) imagery data and builds pixel clusters
-based on the spectral reflectances of the pixels (see Figure).
-The pixel clusters are imagery categories that can be related
-to land cover types on the ground. The spectral
-distributions of the clusters (which will be the land cover
-spectral signatures) are influenced by six parameters set
-by the user. The first parameter set by the user is the
-initial number of clusters to be discriminated.
-<p>
-<center>
-<img src="landsat_cluster.png" border=1><BR>
-<table border=0 width=590>
-<tr><td><center>
-<i>Fig.: Land use/land cover clustering of LANDSAT scene (simplified)</i>
-</center></td></tr>
-</table>
-</center>
-<p>
-<EM>i.cluster</EM> starts by generating spectral signatures
-for this number of clusters and "attempts" to end up with
-this number of clusters during the clustering process. The
-resulting number of clusters and their spectral
-distributions, however, are also influenced by the range of
-the spectral values (category values) in the image files
-and the other parameters set by the user. These parameters
-are: the minimum cluster size, minimum cluster separation,
-the percent convergence, the maximum number of iterations,
-and the row and column sampling intervals.
-<P>
-The cluster spectral signatures that result are composed of
-cluster means and covariance matrices. These cluster means
-and covariance matrices are used in the second pass
-(<EM><A HREF="i.maxlik.html">i.maxlik</A></EM>) to
-classify the image. The clusters or spectral classes
-result can be related to land cover types on the ground.
-The user has to specify the name of group file, the name of subgroup
-file, the name of a file to contain result signatures, the
-initial number of clusters to be discriminated, and
-optionally other parameters (see below)
-where the <EM>group</EM> should contain the imagery files
-that the user wishes to classify. The <EM>subgroup</EM> is
-a subset of this group. The user must create a group and
-subgroup by running the GRASS program
-before running <EM>i.cluster</EM>. The subgroup should
-contain only the imagery band files that the user wishes to
-classify. Note that this subgroup must contain more than
-one band file. The purpose of the group and subgroup is to
-collect map layers for classification or analysis. The
-<EM>sigfile</EM> is the file to contain result signatures
-which can be used as input for
-The classes value is the initial number of clusters to be
-discriminated; any parameter values left unspecified are
-set to their default values.
-<H3>Flags:</H3>
-<DL>
-<DT><B>-q</B>
-<DD>Run quietly. Suppresses output of program
-percent-complete messages and the time elapsed from the
-beginning of the program. If this flag is not used, these
-messages are printed out.
-</DL>
-<DL>
-<DD>The name of the group file which contains the imagery
-files that the user wishes to classify.
-<DD>The name of the subset of the group specified in group
-option, which must contain only imagery band files and more
-than one band file. The user must create a group and a
-before
-running <EM>i.cluster</EM>.
-<DT><B>sigfile=</B><EM>name</EM>
-<DD>The name assigned to output signature file which
-contains signatures of classes and can be used as the input
-file for the GRASS program
-for an unsupervised classification.
-<DT><B>classes=</B><EM>value</EM>
-<DD>The number of clusters that will initially be
-identified in the clustering process before the iterations
-begin.
-<DT><B>seed=</B><EM>name</EM>
-<DD>The name of a seed signature file is optional. The seed
-signatures are signatures that contain cluster means and
-covariance matrices which were calculated prior to the
-current run of <EM>i.cluster</EM>. They may be acquired
-from a previously run of <EM>i.cluster</EM> or from a
-supervised classification signature training site section
-(e.g., using the signature file output by
-<EM><A HREF="i.class.html">i.class</A></EM>).
-The purpose of seed signatures is to optimize the cluster
-decision boundaries (means) for the number of clusters
-specified.
-<DT><B>sample=</B><EM>row_interval,col_interval</EM>
-<DD>These numbers are optional with default values based on
-the size of the data set such that the total pixels to be
-processed is approximately 10,000 (consider round up).
-<DT><B>iterations=</B><EM>value</EM>
-<DD>This parameter determines the maximum number of
-iterations which is greater than the number of iterations
-predicted to achieve the optimum percent convergence. The
-default value is 30. If the number of iterations reaches
-the maximum designated by the user; the user may want to
-rerun <EM>i.cluster</EM> with a higher number of iterations
-(see <A HREF="#reportfile"><EM>reportfile</EM></A>).
-<BR>
-Default: 30
-<A NAME="convergence"></a>
-<DT><B>convergence=</B><EM>value</EM>
-<DD>A high percent convergence is the point at which
-cluster means become stable during the iteration process.
-The default value is 98.0 percent. When clusters are being
-created, their means constantly change as pixels are
-assigned to them and the means are recalculated to include
-the new pixel. After all clusters have been created,
-<EM>i.cluster</EM> begins iterations that change cluster
-means by maximizing the distances between them. As these
-means shift, a higher and higher convergence is
-approached. Because means will never become totally
-static, a percent convergence and a maximum number of
-iterations are supplied to stop the iterative process. The
-percent convergence should be reached before the maximum
-number of iterations. If the maximum number of iterations
-is reached, it is probable that the desired percent
-convergence was not reached. The number of iterations is
-reported in the cluster statistics in the report file
-<BR>
-Default: 98.0
-<DT><B>separation=</B><EM>value</EM>
-<DD>This is the minimum separation below which clusters
-will be merged in the iteration process. The default value
-is 0.0. This is an image-specific number (a "magic" number)
-that depends on the image data being classified and the
-number of final clusters that are acceptable. Its
-determination requires experimentation. Note that as the
-minimum class (or cluster) separation is increased, the
-maximum number of iterations should also be increased to
-achieve this separation with a high percentage of
-convergence
-(see <A HREF="#convergence"><EM>convergence</EM></A>).
-<BR>
-Default: 0.0
-<DT><B>min_size=</B><EM>value</EM>
-<DD>This is the minimum number of pixels that will be used
-to define a cluster, and is therefore the minimum number of
-pixels for which means and covariance matrices will be
-calculated.
-<BR>
-Default: 17
-<A NAME="reportfile"></A>
-<DT><B>reportfile=</B><EM>name</EM>
-<DD>The reportfile is an optional parameter which contains
-the result, i.e., the statistics for each cluster. Also
-included are the resulting percent convergence for the
-clusters, the number of iterations that was required to
-achieve the convergence, and the separability matrix.
-</DL>
-<H2>NOTES</H2>
-Running in command line mode, <EM>i.cluster</EM> will
-overwrite the output signature file and reportfile (if
-required by the user) without prompting if the files
-existed.
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<P>
-<EM>
-<A HREF="i.class.html">i.class</A><br>
-<A HREF="i.group.html">i.group</A><br>
-<A HREF="i.gensig.html">i.gensig</A><br>
-</EM>
-<H2>AUTHORS</H2>
-Michael Shapiro,
-U.S.Army Construction Engineering
-Research Laboratory
-<BR>
-Tao Wen,
-University of Illinois at
-Urbana-Champaign,
-Illinois
-<p>
Copied: grass/trunk/imagery/i.cluster/i.cluster.html (from rev 32770, grass/trunk/imagery/i.cluster/description.html)
--- grass/trunk/imagery/i.cluster/i.cluster.html (rev 0)
+++ grass/trunk/imagery/i.cluster/i.cluster.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,268 @@
+<EM>i.cluster</EM>
+performs the first pass in the GRASS two-pass unsupervised
+classification of imagery, while the GRASS program <EM>
+<A HREF="i.maxlik.html">i.maxlik</A></EM> executes
+the second pass. Both programs must be run to complete the unsupervised
+classification.
+<P>
+<EM>i.cluster</EM> is a clustering algorithm that reads
+through the (raster) imagery data and builds pixel clusters
+based on the spectral reflectances of the pixels (see Figure).
+The pixel clusters are imagery categories that can be related
+to land cover types on the ground. The spectral
+distributions of the clusters (which will be the land cover
+spectral signatures) are influenced by six parameters set
+by the user. The first parameter set by the user is the
+initial number of clusters to be discriminated.
+<p>
+<center>
+<img src="landsat_cluster.png" border=1><BR>
+<table border=0 width=590>
+<tr><td><center>
+<i>Fig.: Land use/land cover clustering of LANDSAT scene (simplified)</i>
+</center></td></tr>
+</table>
+</center>
+<p>
+<EM>i.cluster</EM> starts by generating spectral signatures
+for this number of clusters and "attempts" to end up with
+this number of clusters during the clustering process. The
+resulting number of clusters and their spectral
+distributions, however, are also influenced by the range of
+the spectral values (category values) in the image files
+and the other parameters set by the user. These parameters
+are: the minimum cluster size, minimum cluster separation,
+the percent convergence, the maximum number of iterations,
+and the row and column sampling intervals.
+<P>
+The cluster spectral signatures that result are composed of
+cluster means and covariance matrices. These cluster means
+and covariance matrices are used in the second pass
+(<EM><A HREF="i.maxlik.html">i.maxlik</A></EM>) to
+classify the image. The clusters or spectral classes
+result can be related to land cover types on the ground.
+The user has to specify the name of group file, the name of subgroup
+file, the name of a file to contain result signatures, the
+initial number of clusters to be discriminated, and
+optionally other parameters (see below)
+where the <EM>group</EM> should contain the imagery files
+that the user wishes to classify. The <EM>subgroup</EM> is
+a subset of this group. The user must create a group and
+subgroup by running the GRASS program
+before running <EM>i.cluster</EM>. The subgroup should
+contain only the imagery band files that the user wishes to
+classify. Note that this subgroup must contain more than
+one band file. The purpose of the group and subgroup is to
+collect map layers for classification or analysis. The
+<EM>sigfile</EM> is the file to contain result signatures
+which can be used as input for
+The classes value is the initial number of clusters to be
+discriminated; any parameter values left unspecified are
+set to their default values.
+<H3>Flags:</H3>
+<DL>
+<DT><B>-q</B>
+<DD>Run quietly. Suppresses output of program
+percent-complete messages and the time elapsed from the
+beginning of the program. If this flag is not used, these
+messages are printed out.
+</DL>
+<DL>
+<DD>The name of the group file which contains the imagery
+files that the user wishes to classify.
+<DD>The name of the subset of the group specified in group
+option, which must contain only imagery band files and more
+than one band file. The user must create a group and a
+before
+running <EM>i.cluster</EM>.
+<DT><B>sigfile=</B><EM>name</EM>
+<DD>The name assigned to output signature file which
+contains signatures of classes and can be used as the input
+file for the GRASS program
+for an unsupervised classification.
+<DT><B>classes=</B><EM>value</EM>
+<DD>The number of clusters that will initially be
+identified in the clustering process before the iterations
+begin.
+<DT><B>seed=</B><EM>name</EM>
+<DD>The name of a seed signature file is optional. The seed
+signatures are signatures that contain cluster means and
+covariance matrices which were calculated prior to the
+current run of <EM>i.cluster</EM>. They may be acquired
+from a previously run of <EM>i.cluster</EM> or from a
+supervised classification signature training site section
+(e.g., using the signature file output by
+<EM><A HREF="i.class.html">i.class</A></EM>).
+The purpose of seed signatures is to optimize the cluster
+decision boundaries (means) for the number of clusters
+specified.
+<DT><B>sample=</B><EM>row_interval,col_interval</EM>
+<DD>These numbers are optional with default values based on
+the size of the data set such that the total pixels to be
+processed is approximately 10,000 (consider round up).
+<DT><B>iterations=</B><EM>value</EM>
+<DD>This parameter determines the maximum number of
+iterations which is greater than the number of iterations
+predicted to achieve the optimum percent convergence. The
+default value is 30. If the number of iterations reaches
+the maximum designated by the user; the user may want to
+rerun <EM>i.cluster</EM> with a higher number of iterations
+(see <A HREF="#reportfile"><EM>reportfile</EM></A>).
+<BR>
+Default: 30
+<A NAME="convergence"></a>
+<DT><B>convergence=</B><EM>value</EM>
+<DD>A high percent convergence is the point at which
+cluster means become stable during the iteration process.
+The default value is 98.0 percent. When clusters are being
+created, their means constantly change as pixels are
+assigned to them and the means are recalculated to include
+the new pixel. After all clusters have been created,
+<EM>i.cluster</EM> begins iterations that change cluster
+means by maximizing the distances between them. As these
+means shift, a higher and higher convergence is
+approached. Because means will never become totally
+static, a percent convergence and a maximum number of
+iterations are supplied to stop the iterative process. The
+percent convergence should be reached before the maximum
+number of iterations. If the maximum number of iterations
+is reached, it is probable that the desired percent
+convergence was not reached. The number of iterations is
+reported in the cluster statistics in the report file
+<BR>
+Default: 98.0
+<DT><B>separation=</B><EM>value</EM>
+<DD>This is the minimum separation below which clusters
+will be merged in the iteration process. The default value
+is 0.0. This is an image-specific number (a "magic" number)
+that depends on the image data being classified and the
+number of final clusters that are acceptable. Its
+determination requires experimentation. Note that as the
+minimum class (or cluster) separation is increased, the
+maximum number of iterations should also be increased to
+achieve this separation with a high percentage of
+convergence
+(see <A HREF="#convergence"><EM>convergence</EM></A>).
+<BR>
+Default: 0.0
+<DT><B>min_size=</B><EM>value</EM>
+<DD>This is the minimum number of pixels that will be used
+to define a cluster, and is therefore the minimum number of
+pixels for which means and covariance matrices will be
+calculated.
+<BR>
+Default: 17
+<A NAME="reportfile"></A>
+<DT><B>reportfile=</B><EM>name</EM>
+<DD>The reportfile is an optional parameter which contains
+the result, i.e., the statistics for each cluster. Also
+included are the resulting percent convergence for the
+clusters, the number of iterations that was required to
+achieve the convergence, and the separability matrix.
+</DL>
+<H2>NOTES</H2>
+Running in command line mode, <EM>i.cluster</EM> will
+overwrite the output signature file and reportfile (if
+required by the user) without prompting if the files
+existed.
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<P>
+<EM>
+<A HREF="i.class.html">i.class</A><br>
+<A HREF="i.group.html">i.group</A><br>
+<A HREF="i.gensig.html">i.gensig</A><br>
+</EM>
+<H2>AUTHORS</H2>
+Michael Shapiro,
+U.S.Army Construction Engineering
+Research Laboratory
+<BR>
+Tao Wen,
+University of Illinois at
+Urbana-Champaign,
+Illinois
+<p>
Deleted: grass/trunk/imagery/i.fft/description.html
--- grass/trunk/imagery/i.fft/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.fft/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,76 +0,0 @@
-<EM>i.fft</EM> is an image processing program based on the FFT algorithm
-given by Frigo et al. (1998), that processes a single input raster map layer
-(<B>input_image</B>) and constructs the real and imaginary Fourier
-components in frequency space.
-<H2>NOTES</H2>
-The real and imaginary components are stored as arrays of
-doubles in the <EM>cell_misc</EM> directory (for use in the
-inverse transform program,
-<EM><A HREF="i.ifft.html">i.ifft</A></EM>),
-and are also scaled and formatted into the
-<B>real_image</B> and <B>imaginary_image</B> raster map
-layers for inspection, masking, etc. In these raster map
-layers the low frequency components are in the center and
-the high frequency components are toward the edges. The
-<B>input_image</B> need not be square; before
-processing, the X and Y dimensions of the
-<B>input_image</B> are padded with zeroes to the next
-highest power of two in extent (i.e., 256 x 256 is
-processed at that size, but 200 x 400 is padded to 256 x
-512). The cell category values for viewing, etc., are
-calculated by taking the natural log of the actual values
-then rescaling to 255, or whatever optional range is given
-on the command line, as suggested by Richards (1986). A
-color table is assigned to the resultant map layer.
-<P>
-The current geographic region and mask settings are
-respected when reading the input file. The presence of a
-mask will, in general, make the resulting fast Fourier
-transform invalid, or at least difficult to interpret.
-<H2>SEE ALSO</H2>
-M. Frigo and S. G. Johnson (1998): "FFTW: An Adaptive Software Architecture
-for the FFT". See <a href=>www.FFTW.org</a>: FFTW is a C subroutine library
-for computing the Discrete Fourier Transform (DFT) in one or more
-dimensions, of both real and complex data, and of arbitrary input size.
-<P>
-<B>Remote Sensing Digital Image Analysis</B>,
-by John A. Richards,
-Springer-Verlag, 1986.
-<P>
-Personal communication,
-between progam author and Ali R. Vali,
-Space Research Center,
-<A HREF="http://www.utexas.edu">University of Texas</A>, Austin, 1990.
-<P>
-<EM><A HREF="i.cca.html">i.cca</A></EM><br>
-<EM><A HREF="i.ifft.html">i.ifft</A></EM><br>
-<H2>AUTHOR</H2>
-<br>
-Glynn Clements (FFTW support)
Copied: grass/trunk/imagery/i.fft/i.fft.html (from rev 32770, grass/trunk/imagery/i.fft/description.html)
--- grass/trunk/imagery/i.fft/i.fft.html (rev 0)
+++ grass/trunk/imagery/i.fft/i.fft.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,76 @@
+<EM>i.fft</EM> is an image processing program based on the FFT algorithm
+given by Frigo et al. (1998), that processes a single input raster map layer
+(<B>input_image</B>) and constructs the real and imaginary Fourier
+components in frequency space.
+<H2>NOTES</H2>
+The real and imaginary components are stored as arrays of
+doubles in the <EM>cell_misc</EM> directory (for use in the
+inverse transform program,
+<EM><A HREF="i.ifft.html">i.ifft</A></EM>),
+and are also scaled and formatted into the
+<B>real_image</B> and <B>imaginary_image</B> raster map
+layers for inspection, masking, etc. In these raster map
+layers the low frequency components are in the center and
+the high frequency components are toward the edges. The
+<B>input_image</B> need not be square; before
+processing, the X and Y dimensions of the
+<B>input_image</B> are padded with zeroes to the next
+highest power of two in extent (i.e., 256 x 256 is
+processed at that size, but 200 x 400 is padded to 256 x
+512). The cell category values for viewing, etc., are
+calculated by taking the natural log of the actual values
+then rescaling to 255, or whatever optional range is given
+on the command line, as suggested by Richards (1986). A
+color table is assigned to the resultant map layer.
+<P>
+The current geographic region and mask settings are
+respected when reading the input file. The presence of a
+mask will, in general, make the resulting fast Fourier
+transform invalid, or at least difficult to interpret.
+<H2>SEE ALSO</H2>
+M. Frigo and S. G. Johnson (1998): "FFTW: An Adaptive Software Architecture
+for the FFT". See <a href=>www.FFTW.org</a>: FFTW is a C subroutine library
+for computing the Discrete Fourier Transform (DFT) in one or more
+dimensions, of both real and complex data, and of arbitrary input size.
+<P>
+<B>Remote Sensing Digital Image Analysis</B>,
+by John A. Richards,
+Springer-Verlag, 1986.
+<P>
+Personal communication,
+between progam author and Ali R. Vali,
+Space Research Center,
+<A HREF="http://www.utexas.edu">University of Texas</A>, Austin, 1990.
+<P>
+<EM><A HREF="i.cca.html">i.cca</A></EM><br>
+<EM><A HREF="i.ifft.html">i.ifft</A></EM><br>
+<H2>AUTHOR</H2>
+<br>
+Glynn Clements (FFTW support)
Deleted: grass/trunk/imagery/i.gensig/description.html
--- grass/trunk/imagery/i.gensig/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.gensig/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,139 +0,0 @@
-<EM>i.gensig</EM>
-is a non-interactive method for generating input into
-It can be used as the first pass in the GRASS two-pass
-classification process (instead of
- or
-It reads a raster map layer, called the training map, which
-has some of the pixels or regions already classified.
-<EM>i.gensig</EM> will then extract spectral signatures
-from an image based on the classification of the pixels in
-the training map and make these signatures available to
-<P>
-The user would then execute the GRASS program
-to actually create the final classified map.
-<H2>OPTIONS</H2>
-<H3>Parameters</H3>
-<DL>
-<DT><B>trainingmap=</B><EM>name</EM>
-<DD>ground truth training map
-<P>
-This map must be prepared by the user in advance. Programs like
-<EM><A HREF="v.digit.html">v.digit</A></EM> or <EM>
-<A HREF="r.digit.html">r.digit</A></EM> can be
-used to define representative
-areas of the classes the user defines to be in the image.
-Of course other methods could be devised by the user for creating
-this training map - <EM>i.gensig</EM> makes no assumption about the origin
-of this map layer. It simply creates signatures for the classes defined
-in the training map for the image to be classified (the image is
-specified in other options - see below).
-<DD>imagery group
-<P>
-This is the name of the group that contains the band files
-which comprise the image to be analyzed. The <EM>
-<A HREF="i.group.html">i.group</A> </EM> command is
-used to construct groups of raster layers which comprise an
-image.
-<P>
-<A NAME="subgroup"><DT><B>subgroup=</B><EM>name</EM></A>
-<DD>subgroup containing image files
-<P>
-This names the subgroup within the group that selects a
-subset of the bands to be analyzed. The <EM>
-also used to prepare this subgroup. The subgroup mechanism
-allows the user to select a subset of all the band files
-that form an image.
-<DT><B>signaturefile=</B><EM>name</EM>
-<DD>resultant signature file
-<P>
-This is the resultant signature file (containing the means
-and covariance matrices) for each class in the training map
-that is associated with the band files in the subgroup
-select (see <A HREF="#subgroup">above</A>).
-</DL>
-<H2>INTERACTIVE MODE</H2>
-If none of the arguments are specified on the command line,
-<EM>i.gensig</EM>
-will interactively prompt for the names of these maps and files.
-<P>
-It should be noted that interactive mode here only means
-interactive prompting for maps and files.
-It does not mean visualization of the signatures that
-result from the process.
-<H2>SEE ALSO</H2>
-for creating groups and subgroups.
-<P>
-and
-<EM><A HREF="r.digit.html">r.digit</A></EM>
-for interactively creating the training map.
-<P>
-for unsupervised clustering as an alternative to
-<EM>i.gensig</EM> to create signatures.
-<P>
-for a graphic/interactive as an alternative to
-<H2>AUTHOR</H2>
-Michael Shapiro,
-U.S.Army Construction Engineering Research Laboratory
Copied: grass/trunk/imagery/i.gensig/i.gensig.html (from rev 32770, grass/trunk/imagery/i.gensig/description.html)
--- grass/trunk/imagery/i.gensig/i.gensig.html (rev 0)
+++ grass/trunk/imagery/i.gensig/i.gensig.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,139 @@
+<EM>i.gensig</EM>
+is a non-interactive method for generating input into
+It can be used as the first pass in the GRASS two-pass
+classification process (instead of
+ or
+It reads a raster map layer, called the training map, which
+has some of the pixels or regions already classified.
+<EM>i.gensig</EM> will then extract spectral signatures
+from an image based on the classification of the pixels in
+the training map and make these signatures available to
+<P>
+The user would then execute the GRASS program
+to actually create the final classified map.
+<H2>OPTIONS</H2>
+<H3>Parameters</H3>
+<DL>
+<DT><B>trainingmap=</B><EM>name</EM>
+<DD>ground truth training map
+<P>
+This map must be prepared by the user in advance. Programs like
+<EM><A HREF="v.digit.html">v.digit</A></EM> or <EM>
+<A HREF="r.digit.html">r.digit</A></EM> can be
+used to define representative
+areas of the classes the user defines to be in the image.
+Of course other methods could be devised by the user for creating
+this training map - <EM>i.gensig</EM> makes no assumption about the origin
+of this map layer. It simply creates signatures for the classes defined
+in the training map for the image to be classified (the image is
+specified in other options - see below).
+<DD>imagery group
+<P>
+This is the name of the group that contains the band files
+which comprise the image to be analyzed. The <EM>
+<A HREF="i.group.html">i.group</A> </EM> command is
+used to construct groups of raster layers which comprise an
+image.
+<P>
+<A NAME="subgroup"><DT><B>subgroup=</B><EM>name</EM></A>
+<DD>subgroup containing image files
+<P>
+This names the subgroup within the group that selects a
+subset of the bands to be analyzed. The <EM>
+also used to prepare this subgroup. The subgroup mechanism
+allows the user to select a subset of all the band files
+that form an image.
+<DT><B>signaturefile=</B><EM>name</EM>
+<DD>resultant signature file
+<P>
+This is the resultant signature file (containing the means
+and covariance matrices) for each class in the training map
+that is associated with the band files in the subgroup
+select (see <A HREF="#subgroup">above</A>).
+</DL>
+<H2>INTERACTIVE MODE</H2>
+If none of the arguments are specified on the command line,
+<EM>i.gensig</EM>
+will interactively prompt for the names of these maps and files.
+<P>
+It should be noted that interactive mode here only means
+interactive prompting for maps and files.
+It does not mean visualization of the signatures that
+result from the process.
+<H2>SEE ALSO</H2>
+for creating groups and subgroups.
+<P>
+and
+<EM><A HREF="r.digit.html">r.digit</A></EM>
+for interactively creating the training map.
+<P>
+for unsupervised clustering as an alternative to
+<EM>i.gensig</EM> to create signatures.
+<P>
+for a graphic/interactive as an alternative to
+<H2>AUTHOR</H2>
+Michael Shapiro,
+U.S.Army Construction Engineering Research Laboratory
Deleted: grass/trunk/imagery/i.gensigset/description.html
--- grass/trunk/imagery/i.gensigset/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.gensigset/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,264 +0,0 @@
-<EM>i.gensigset</EM>
-<EM><A HREF="i.smap.html">i.smap</A>.</EM>
-It is used as the first pass in the a two-pass
-classification process. It reads a raster map layer,
-called the training map, which has some of the pixels or
-regions already classified. <EM>i.gensigset</EM> will then
-extract spectral signatures from an image based on the
-classification of the pixels in the training map and make
-these signatures available to
-<P>
-The user would then execute the GRASS program <EM>
-<A HREF="i.smap.html">i.smap</A></EM> to create the
-final classified map.
-<H2>OPTIONS</H2>
-<DL>
-<P>
-This raster layer, supplied as input by the user, has some
-of its pixels already classified, and the rest (probably
-most) of the pixels unclassified. Classified means that
-the pixel has a non-zero value and unclassified means that
-the pixel has a zero value.
-<P>
-The user must use
-<EM><A HREF="r.digit.html">r.digit</A></EM>,
-a combination of
-and
-<EM><A HREF="v.to.rast.html">v.to.rast</A></EM>,
-or some other import/developement process (e.g.,
-<EM><A HREF="v.in.transects.html">v.in.transects</A>)</EM>
-to define the areas
-representative
-of the classes in the image.
-<P>
-At present, there is no fully-interactive tool specifically
-designed for producing this layer.
-<DD>imagery group
-<P>
-command is used to construct groups of raster layers which
-comprise an image.
-<P>
-<P>
-command is also used to prepare this subgroup. The
-subgroup mechanism allows the user to select a subset of
-all the band files that form an image.
-<P>
-selected.
-<P>
-<DT><B>maxsig=</B><EM>value</EM>
-<DD>maximum number of sub-signatures in any class
-<BR>
-default: 10
-<P>
-The spectral signatures which are produced by this program
-are "mixed" signatures (see <A HREF="#notes">NOTES</A>).
-Each signature contains one or more subsignatures
-(represeting subclasses). The algorithm in this program
-starts with a maximum number of subclasses and reduces this
-number to a minimal number of subclasses which are
-spectrally distinct. The user has the option to set this
-starting value with this option.
-</DL>
-<EM>i.gensigset</EM> will interactively prompt for the
-names of these maps and files.
-<P>
-interactive prompting for maps and files. It does not mean
-visualization of the signatures that result from the
-process.
-<P>
-<A NAME="notes"><H2>NOTES</H2></A>
-The algorithm in <EM>i.gensigset</EM> determines the
-parameters of a spectral class model known as a Gaussian
-mixture distribution. The parameters are estimated using
-multispectral image data and a training map which labels
-the class of a subset of the image pixels. The mixture
-class parameters are stored as a class signature which can
-be used for subsequent segmentation (i.e., classification)
-of the multispectral image.
-<P>
-The Gaussian mixture class is a useful model because it can
-be used to describe the behavior of an information class
-which contains pixels with a variety of distinct spectral
-characteristics. For example, forest, grasslands or urban
-areas are examples of information classes that a user may
-wish to separate in an image. However, each of these
-information classes may contain subclasses each with its
-own distinctive spectral characteristic. For example, a
-forest may contain a variety of different tree species each
-with its own spectral behavior.
-<P>
-The objective of mixture classes is to improve segmentation
-performance by modeling each information class as a
-probabilistic mixture with a variety of subclasses. The
-mixture class model also removes the need to perform an
-initial unsupervised segmentation for the purposes of
-identifying these subclasses. However, if misclassified
-samples are used in the training process, these erroneous
-samples may be grouped as a separate undesired subclass.
-Therefore, care should be taken to provided accurate
-training data.
-<P>
-This clustering algorithm estimates both the number of
-distinct subclasses in each class, and the spectral mean
-and covariance for each subclass. The number of subclasses
-is estimated using Rissanen's minimum description length
-(MDL) criteria
-[<A HREF="#rissanen83">1</A>].
-This criteria attempts to determine
-the number of subclasses which "best" describe the data.
-The approximate maximum likelihood estimates of the mean
-and covariance of the subclasses are computed using the
-expectation maximization (EM) algorithm
-[<A HREF="#dempster77">2</A>,<A HREF="#redner84">3</A>].
-<H2>REFERENCES</H2>
-<OL>
-<LI><A NAME="rissanen83">J. Rissanen,</A>
-"A Universal Prior for Integers and Estimation by Minimum
-Description Length,"
-<EM>Annals of Statistics,</EM>
-vol. 11, no. 2, pp. 417-431, 1983.
-<LI><A NAME="dempster77">A. Dempster, N. Laird and D. Rubin,</A>
-"Maximum Likelihood from Incomplete Data via the EM Algorithm,"
-<EM>J. Roy. Statist. Soc. B,</EM>
-vol. 39, no. 1, pp. 1-38, 1977.
-<LI><A NAME="redner84">E. Redner and H. Walker,</A>
-"Mixture Densities, Maximum Likelihood and the EM Algorithm,"
-<EM>SIAM Review,</EM>
-vol. 26, no. 2, April 1984.
-</OL>
-<H2>SEE ALSO</H2>
-<P>
-and
-<P>
-<EM><A HREF="i.smap.html">i.smap</A></EM>
-for creating a final classification layer from the signatures
-generated by <EM>i.gensigset.</EM>
-<H2>AUTHORS</H2>
-Charles Bouman,
-School of
-Electrical Engineering,
-Purdue University
-<BR>
-Michael Shapiro,
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.gensigset/i.gensigset.html (from rev 32770, grass/trunk/imagery/i.gensigset/description.html)
--- grass/trunk/imagery/i.gensigset/i.gensigset.html (rev 0)
+++ grass/trunk/imagery/i.gensigset/i.gensigset.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,264 @@
+<H2>DESCRIPTION</H2>
+<EM>i.gensigset</EM>
+<EM><A HREF="i.smap.html">i.smap</A>.</EM>
+It is used as the first pass in the a two-pass
+classification process. It reads a raster map layer,
+called the training map, which has some of the pixels or
+regions already classified. <EM>i.gensigset</EM> will then
+extract spectral signatures from an image based on the
+classification of the pixels in the training map and make
+these signatures available to
+<P>
+The user would then execute the GRASS program <EM>
+<A HREF="i.smap.html">i.smap</A></EM> to create the
+final classified map.
+<H2>OPTIONS</H2>
+<DL>
+<P>
+This raster layer, supplied as input by the user, has some
+of its pixels already classified, and the rest (probably
+most) of the pixels unclassified. Classified means that
+the pixel has a non-zero value and unclassified means that
+the pixel has a zero value.
+<P>
+The user must use
+<EM><A HREF="r.digit.html">r.digit</A></EM>,
+a combination of
+and
+<EM><A HREF="v.to.rast.html">v.to.rast</A></EM>,
+or some other import/developement process (e.g.,
+<EM><A HREF="v.in.transects.html">v.in.transects</A>)</EM>
+to define the areas
+representative
+of the classes in the image.
+<P>
+At present, there is no fully-interactive tool specifically
+designed for producing this layer.
+<DT><B>group=</B><EM>name</EM>
+<DD>imagery group
+<P>
+command is used to construct groups of raster layers which
+comprise an image.
+<P>
+<DT><B>subgroup=</B><EM>name</EM>
+<P>
+command is also used to prepare this subgroup. The
+subgroup mechanism allows the user to select a subset of
+all the band files that form an image.
+<P>
+selected.
+<P>
+<DT><B>maxsig=</B><EM>value</EM>
+<DD>maximum number of sub-signatures in any class
+<BR>
+default: 10
+<P>
+The spectral signatures which are produced by this program
+are "mixed" signatures (see <A HREF="#notes">NOTES</A>).
+Each signature contains one or more subsignatures
+(represeting subclasses). The algorithm in this program
+starts with a maximum number of subclasses and reduces this
+number to a minimal number of subclasses which are
+spectrally distinct. The user has the option to set this
+starting value with this option.
+</DL>
+<EM>i.gensigset</EM> will interactively prompt for the
+names of these maps and files.
+<P>
+interactive prompting for maps and files. It does not mean
+visualization of the signatures that result from the
+process.
+<P>
+<A NAME="notes"><H2>NOTES</H2></A>
+The algorithm in <EM>i.gensigset</EM> determines the
+parameters of a spectral class model known as a Gaussian
+mixture distribution. The parameters are estimated using
+multispectral image data and a training map which labels
+the class of a subset of the image pixels. The mixture
+class parameters are stored as a class signature which can
+be used for subsequent segmentation (i.e., classification)
+of the multispectral image.
+<P>
+The Gaussian mixture class is a useful model because it can
+be used to describe the behavior of an information class
+which contains pixels with a variety of distinct spectral
+characteristics. For example, forest, grasslands or urban
+areas are examples of information classes that a user may
+wish to separate in an image. However, each of these
+information classes may contain subclasses each with its
+own distinctive spectral characteristic. For example, a
+forest may contain a variety of different tree species each
+with its own spectral behavior.
+<P>
+The objective of mixture classes is to improve segmentation
+performance by modeling each information class as a
+probabilistic mixture with a variety of subclasses. The
+mixture class model also removes the need to perform an
+initial unsupervised segmentation for the purposes of
+identifying these subclasses. However, if misclassified
+samples are used in the training process, these erroneous
+samples may be grouped as a separate undesired subclass.
+Therefore, care should be taken to provided accurate
+training data.
+<P>
+This clustering algorithm estimates both the number of
+distinct subclasses in each class, and the spectral mean
+and covariance for each subclass. The number of subclasses
+is estimated using Rissanen's minimum description length
+(MDL) criteria
+[<A HREF="#rissanen83">1</A>].
+This criteria attempts to determine
+the number of subclasses which "best" describe the data.
+The approximate maximum likelihood estimates of the mean
+and covariance of the subclasses are computed using the
+expectation maximization (EM) algorithm
+[<A HREF="#dempster77">2</A>,<A HREF="#redner84">3</A>].
+<H2>REFERENCES</H2>
+<OL>
+<LI><A NAME="rissanen83">J. Rissanen,</A>
+"A Universal Prior for Integers and Estimation by Minimum
+Description Length,"
+<EM>Annals of Statistics,</EM>
+vol. 11, no. 2, pp. 417-431, 1983.
+<LI><A NAME="dempster77">A. Dempster, N. Laird and D. Rubin,</A>
+"Maximum Likelihood from Incomplete Data via the EM Algorithm,"
+<EM>J. Roy. Statist. Soc. B,</EM>
+vol. 39, no. 1, pp. 1-38, 1977.
+<LI><A NAME="redner84">E. Redner and H. Walker,</A>
+"Mixture Densities, Maximum Likelihood and the EM Algorithm,"
+<EM>SIAM Review,</EM>
+vol. 26, no. 2, April 1984.
+</OL>
+<H2>SEE ALSO</H2>
+<P>
+and
+<P>
+<EM><A HREF="i.smap.html">i.smap</A></EM>
+for creating a final classification layer from the signatures
+generated by <EM>i.gensigset.</EM>
+<H2>AUTHORS</H2>
+Charles Bouman,
+School of
+Electrical Engineering,
+Purdue University
+<BR>
+Michael Shapiro,
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/imagery/i.group/description.html
--- grass/trunk/imagery/i.group/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.group/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,51 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>i.group</EM> allows the user to collect raster map layers in an imagery
-group by assigning them to user-named subgroups or other groups. This
-enables the user to run analyses on any combination of the raster map layers
-in a group. The user creates the groups and subgroups and selects the
-raster map layers that are to reside in them. Imagery analysis programs like
-<EM><A HREF="i.points.html">i.points</A></EM>,
-<EM><a href="i.rectify.html">i.rectify</A></EM>, <EM>i.ortho.rectify</EM> and
-others ask the user for the name of an imagery group whose data are to be
-analyzed. Imagery analysis programs like
-<EM><a href="i.cluster.html">i.cluster</A></EM> and
-<EM><a href="i.maxlik.html">i.maxlik</A></EM> ask the user for the imagery group
-and imagery subgroup whose data are to be analyzed.
-<H2>NOTES</H2>
-The <EM>i.group</EM> options are only available for
-imagery map layers in the current LOCATION_NAME.
-<P>
-Subgroup names may not contain more than 12 characters.
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<P>
-<EM>
-<A HREF="i.cluster.html">i.cluster</A><br>
-<A HREF="i.maxlik.html">i.maxlik</A><br>
-<A HREF="i.points.html">i.points</A><br>
-<A HREF="i.rectify.html">i.rectify</A><br>
-<a HREF="i.ortho.photo.html">i.ortho.photo</A>
-</EM>
-<H2>AUTHOR</H2>
-Michael Shapiro,
-<br>
-Parser support: Bob Covill (Tekmap, Canada)
-<p>
Copied: grass/trunk/imagery/i.group/i.group.html (from rev 32770, grass/trunk/imagery/i.group/description.html)
--- grass/trunk/imagery/i.group/i.group.html (rev 0)
+++ grass/trunk/imagery/i.group/i.group.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,51 @@
+<EM>i.group</EM> allows the user to collect raster map layers in an imagery
+group by assigning them to user-named subgroups or other groups. This
+enables the user to run analyses on any combination of the raster map layers
+in a group. The user creates the groups and subgroups and selects the
+raster map layers that are to reside in them. Imagery analysis programs like
+<EM><A HREF="i.points.html">i.points</A></EM>,
+<EM><a href="i.rectify.html">i.rectify</A></EM>, <EM>i.ortho.rectify</EM> and
+others ask the user for the name of an imagery group whose data are to be
+analyzed. Imagery analysis programs like
+<EM><a href="i.cluster.html">i.cluster</A></EM> and
+<EM><a href="i.maxlik.html">i.maxlik</A></EM> ask the user for the imagery group
+and imagery subgroup whose data are to be analyzed.
+<H2>NOTES</H2>
+The <EM>i.group</EM> options are only available for
+imagery map layers in the current LOCATION_NAME.
+<P>
+Subgroup names may not contain more than 12 characters.
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<P>
+<EM>
+<A HREF="i.cluster.html">i.cluster</A><br>
+<A HREF="i.maxlik.html">i.maxlik</A><br>
+<A HREF="i.points.html">i.points</A><br>
+<A HREF="i.rectify.html">i.rectify</A><br>
+<a HREF="i.ortho.photo.html">i.ortho.photo</A>
+</EM>
+<H2>AUTHOR</H2>
+Michael Shapiro,
+<br>
+Parser support: Bob Covill (Tekmap, Canada)
+<p>
Deleted: grass/trunk/imagery/i.his.rgb/description.html
--- grass/trunk/imagery/i.his.rgb/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.his.rgb/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,47 +0,0 @@
-<EM>i.his.rgb</EM> is an image processing program that
-processes three input raster map layers as hue, intensity
-and saturation components and produces three output raster
-map layers representing the red, green and blue components
-of this data. The output raster map layers are created by
-a standard hue-intensity-saturation (his) to red-green-blue
-(rgb) color transformation. Each output raster map layer
-is given a linear gray scale color table. The current
-geographic region and mask settings are respected.
-<H2>NOTES</H2>
-It is not possible to process three bands with
-<EM>i.his.rgb</EM> and then exactly recover the original
-bands with
-<EM><A HREF="i.rgb.his.html">i.rgb.his</A></EM>.
-This is due to loss of precision because of integer
-computations and rounding. Tests have shown that more than
-70% of the original cell values will be reproduced exactly
-after transformation in both directions and that 99% will
-be within plus or minus 1. A few cell values may differ
-significantly from their original values.
-<H2>SEE ALSO</H2>
-<EM><A HREF="hsv.rgb.sh.html">hsv.rgb.sh</A></EM><br>
-<EM><A HREF="i.colors.html">i.colors</A></EM><br>
-<EM><A HREF="i.rgb.his.html">i.rgb.his</A></EM><br>
-<EM><A HREF="r.colors.html">r.colors</A></EM><br>
-<EM><A HREF="rgb.hsv.sh.html">rgb.hsv.sh</A></EM>
-<H2>AUTHOR</H2>
-David Satnik, GIS Laboratory,
-Central Washington University
-<P>
-with acknowledgements to Ali Vali, Univ. of Texas Space Research
-Center, for the core routine.
Copied: grass/trunk/imagery/i.his.rgb/i.his.rgb.html (from rev 32770, grass/trunk/imagery/i.his.rgb/description.html)
--- grass/trunk/imagery/i.his.rgb/i.his.rgb.html (rev 0)
+++ grass/trunk/imagery/i.his.rgb/i.his.rgb.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,47 @@
+<EM>i.his.rgb</EM> is an image processing program that
+processes three input raster map layers as hue, intensity
+and saturation components and produces three output raster
+map layers representing the red, green and blue components
+of this data. The output raster map layers are created by
+a standard hue-intensity-saturation (his) to red-green-blue
+(rgb) color transformation. Each output raster map layer
+is given a linear gray scale color table. The current
+geographic region and mask settings are respected.
+<H2>NOTES</H2>
+It is not possible to process three bands with
+<EM>i.his.rgb</EM> and then exactly recover the original
+bands with
+<EM><A HREF="i.rgb.his.html">i.rgb.his</A></EM>.
+This is due to loss of precision because of integer
+computations and rounding. Tests have shown that more than
+70% of the original cell values will be reproduced exactly
+after transformation in both directions and that 99% will
+be within plus or minus 1. A few cell values may differ
+significantly from their original values.
+<H2>SEE ALSO</H2>
+<EM><A HREF="hsv.rgb.sh.html">hsv.rgb.sh</A></EM><br>
+<EM><A HREF="i.colors.html">i.colors</A></EM><br>
+<EM><A HREF="i.rgb.his.html">i.rgb.his</A></EM><br>
+<EM><A HREF="r.colors.html">r.colors</A></EM><br>
+<EM><A HREF="rgb.hsv.sh.html">rgb.hsv.sh</A></EM>
+<H2>AUTHOR</H2>
+David Satnik, GIS Laboratory,
+Central Washington University
+<P>
+with acknowledgements to Ali Vali, Univ. of Texas Space Research
+Center, for the core routine.
Deleted: grass/trunk/imagery/i.ifft/description.html
--- grass/trunk/imagery/i.ifft/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ifft/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,73 +0,0 @@
-<EM>i.ifft</EM> is an image processing program based on the algorithm given
-by Frigo et al. (1998), that converts real and imaginary frequency space
-images (produced by
-<EM><A HREF="i.fft.html">i.fft</A></EM>) into a normal image.
-<H2>NOTES</H2>
-The current mask is respected when reading the real and
-imaginary component files; thus, creating a mask is a
-primary step for
-selecting the portion of the frequency space data to be included in the
-inverse transform. The GRASS program <EM>r.digit</EM> can be used to create
-masks while viewing the real or imaginary component image. Alternatively
-<em>r.circle</em> can be used to generate high-, low- and donut filters
-specifying the DC point as circle/ring center.
-When <EM>i.ifft</EM> is executed, it (automatically) uses the same GRASS
-region definition setting that was used during the original transformation
-done with <EM><A HREF="i.fft.html">i.fft</A></EM>.
-<P>
-The real and imaginary components are read from arrays of
-doubles in the <EM>cell_misc</EM> directory (produced by
-the forward transform program,
-<EM><A HREF="i.fft.html">i.fft</A></EM>),
-and the reconstructed image will preserve the cell value
-scaling of the original image processed by
-<EM><A HREF="i.fft.html">i.fft</A></EM>. No color
-table is assigned to the output map; one should be created
-before viewing the <EM>output_image</EM>.
-<H2>SEE ALSO</H2>
-<P>
-<P>
-between program author and Ali R. Vali, Space Research Center,
-University of Texas, Austin, 1990.
-<P>
-<EM><A HREF="i.cca.html">i.cca</A></EM>,
-<EM><A HREF="i.class.html">i.class</A></EM>,
-<EM><A HREF="i.fft.html">i.fft</A></EM>,
-<EM><A HREF="i.pca.html">i.pca</A></EM>,
-<EM><A HREF="r.circle.html">r.circle</A></EM>
-<H2>AUTHOR</H2>
-<br>
Copied: grass/trunk/imagery/i.ifft/i.ifft.html (from rev 32770, grass/trunk/imagery/i.ifft/description.html)
--- grass/trunk/imagery/i.ifft/i.ifft.html (rev 0)
+++ grass/trunk/imagery/i.ifft/i.ifft.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,73 @@
+<EM>i.ifft</EM> is an image processing program based on the algorithm given
+by Frigo et al. (1998), that converts real and imaginary frequency space
+images (produced by
+<EM><A HREF="i.fft.html">i.fft</A></EM>) into a normal image.
+<H2>NOTES</H2>
+The current mask is respected when reading the real and
+imaginary component files; thus, creating a mask is a
+primary step for
+selecting the portion of the frequency space data to be included in the
+inverse transform. The GRASS program <EM>r.digit</EM> can be used to create
+masks while viewing the real or imaginary component image. Alternatively
+<em>r.circle</em> can be used to generate high-, low- and donut filters
+specifying the DC point as circle/ring center.
+When <EM>i.ifft</EM> is executed, it (automatically) uses the same GRASS
+region definition setting that was used during the original transformation
+done with <EM><A HREF="i.fft.html">i.fft</A></EM>.
+<P>
+The real and imaginary components are read from arrays of
+doubles in the <EM>cell_misc</EM> directory (produced by
+the forward transform program,
+<EM><A HREF="i.fft.html">i.fft</A></EM>),
+and the reconstructed image will preserve the cell value
+scaling of the original image processed by
+<EM><A HREF="i.fft.html">i.fft</A></EM>. No color
+table is assigned to the output map; one should be created
+before viewing the <EM>output_image</EM>.
+<H2>SEE ALSO</H2>
+<P>
+<P>
+between program author and Ali R. Vali, Space Research Center,
+University of Texas, Austin, 1990.
+<P>
+<EM><A HREF="i.cca.html">i.cca</A></EM>,
+<EM><A HREF="i.class.html">i.class</A></EM>,
+<EM><A HREF="i.fft.html">i.fft</A></EM>,
+<EM><A HREF="i.pca.html">i.pca</A></EM>,
+<EM><A HREF="r.circle.html">r.circle</A></EM>
+<H2>AUTHOR</H2>
+<br>
Deleted: grass/trunk/imagery/i.maxlik/description.html
--- grass/trunk/imagery/i.maxlik/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.maxlik/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,187 +0,0 @@
-<EM>i.maxlik</EM> is a maximum-likelihood discriminant
-analysis classifier. It can be used to perform the second
-step in either an unsupervised or a supervised image
-classification.
-<P>
-Either image classification methods are performed in two
-steps. The first step in an unsupervised image
-classification is performed by
-<EM><A HREF="i.cluster.html">i.cluster</A></EM>; the
-first step in a supervised classification is executed by
-the GRASS program <EM>
-<A HREF="i.class.html">i.class</A></EM>. In both cases,
-the second step in the image classification procedure is
-performed by <EM>i.maxlik</EM>.
-<P>
-In an unsupervised classification, the maximum-likelihood
-classifier uses the cluster means and covariance matrices
-from the <EM><A HREF="i.cluster.html">i.cluster</A></EM>
-signature file to determine to which category (spectral
-class) each cell in the image has the highest probability
-of belonging. In a supervised image classification, the
-maximum-likelihood classifier uses the region means and
-covariance matrices from the spectral signature file
-generated by <EM>
-<A HREF="i.class.html">i.class</A></EM>, based on regions
-(groups of image pixels) chosen by the user, to determine
-to which category each cell in the image has the highest
-probability of belonging.
-<P>
-In either case, the raster map layer output by
-<EM>i.maxlik</EM> is a classified image in which each cell
-has been assigned to a spectral class (i.e., a category).
-The spectral classes (categories) can be related to
-specific land cover types on the ground.
-<P>
-The program will run non-interactively if the user
-specifies the names of raster map layers, i.e., group and
-subgroup names, seed signature file name, result
-classification file name, and any combination of
-non-required options in the command line, using the form
-<DL>
-<DD>
-<B>i.maxlik</B>[<B>-q</B>] <B>group=</B><EM>name</EM>
-<B>subgroup=</B><EM>name</EM>
-<B>sigfile=</B><EM>name</EM> <B>class=</B><EM>name</EM>
-[<B>reject=</B><EM>name</EM>]
-</DL>
-where each flag and options have the meanings stated below.
-<P>
-Alternatively, the user can simply type <EM>i.maxlik</EM>
-in the command line without program arguments. In this case
-the user will be prompted for the program parameter
-settings; the program will run foreground.
-<H2>OPTIONS</H2>
-<H3>Flags:</H3>
-<DL>
-<DT><B>-q</B>
-<DD>Run quietly, without printing program messages to standard output.
-</DL>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>group=</B><EM>name</EM>
-<DD>The <A HREF="i.group.html">imagery</A> group
-contains the subgroup to be classified.
-<DT><B>subgroup=</B><EM>name</EM>
-<DD>The subgroup contains image files, which were used to create
-the signature file
-in the program <EM><A HREF="i.cluster.html">i.cluster</A></EM>,
-<EM><A HREF="i.class.html">i.class</A></EM>, or
-<EM><A HREF="i.gensig.html">i.gensig</A></EM> to be classified.
-<DD>The name of the signatures to be used for the
-classification. The signature file contains the cluster and
-covariance matrices that were calculated by the GRASS
-program <EM><A HREF="i.cluster.html">i.cluster</A></EM>
-(or the region means and covariance matrices generated by
-<EM><A HREF="i.class.html">i.class</A></EM>, if the
-user runs a supervised classification). These spectral
-signatures are what determine the categories (classes) to
-which image pixels will be assigned during the
-<DT><B>class=</B><EM>name</EM>
-<DD>The name of a raster map holds the classification
-results. This new raster map layer will contain categories
-that can be related to land cover categories on the
-ground.
-<DT><B>reject=</B><EM>name</EM>
-<DD>The optional name of a raster map holds the reject
-threshold results. This is the result of a chi square test
-on each discriminant result at various threshold levels of
-confidence to determine at what confidence level each cell
-classified (categorized). It is the reject threshold map
-layer, and contains one calculated confidence level for
-each classified cell in the classified image. One of the
-possible uses for this map layer is as a mask, to identify
-cells in the classified image that have the lowest
-probability of being assigned to the correct class.
-</DL>
-<H2>NOTES</H2>
-The maximum-likelihood classifier assumes that the spectral
-signatures for each class (category) in each band file
-are normally distributed (i.e., Gaussian in nature).
-Algorithms, such as
-<EM><A HREF="i.cluster.html">i.cluster</A></EM>,
-or <EM><A HREF="i.gensig.html">i.gensig</A></EM>,
-however, can create signatures that are not valid
-distributed (more likely with
-<EM><A HREF="i.class.html">i.class</A>).</EM>
-If this occurs,
-<EM>i.maxlik</EM>
-will reject them and display a warning message.
-<P>
-This program runs interactively if the user types
-<EM>i.maxlik</EM> only. If the user types <EM>i.maxlik</EM>
-along with all required options, it will overwrite the
-classified raster map without prompting if this map
-existed.
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<A HREF="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
-Processing manual</A></EM>
-<P>
-<EM>
-</EM>
-<H2>AUTHORS</H2>
-Michael Shapiro,
-<BR>
-Tao Wen,
-University of Illinois at Urbana-Champaign,
-Illinois
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.maxlik/i.maxlik.html (from rev 32770, grass/trunk/imagery/i.maxlik/description.html)
--- grass/trunk/imagery/i.maxlik/i.maxlik.html (rev 0)
+++ grass/trunk/imagery/i.maxlik/i.maxlik.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,187 @@
+<EM>i.maxlik</EM> is a maximum-likelihood discriminant
+analysis classifier. It can be used to perform the second
+step in either an unsupervised or a supervised image
+classification.
+<P>
+Either image classification methods are performed in two
+steps. The first step in an unsupervised image
+classification is performed by
+<EM><A HREF="i.cluster.html">i.cluster</A></EM>; the
+first step in a supervised classification is executed by
+the GRASS program <EM>
+<A HREF="i.class.html">i.class</A></EM>. In both cases,
+the second step in the image classification procedure is
+performed by <EM>i.maxlik</EM>.
+<P>
+In an unsupervised classification, the maximum-likelihood
+classifier uses the cluster means and covariance matrices
+from the <EM><A HREF="i.cluster.html">i.cluster</A></EM>
+signature file to determine to which category (spectral
+class) each cell in the image has the highest probability
+of belonging. In a supervised image classification, the
+maximum-likelihood classifier uses the region means and
+covariance matrices from the spectral signature file
+generated by <EM>
+<A HREF="i.class.html">i.class</A></EM>, based on regions
+(groups of image pixels) chosen by the user, to determine
+to which category each cell in the image has the highest
+probability of belonging.
+<P>
+In either case, the raster map layer output by
+<EM>i.maxlik</EM> is a classified image in which each cell
+has been assigned to a spectral class (i.e., a category).
+The spectral classes (categories) can be related to
+specific land cover types on the ground.
+<P>
+The program will run non-interactively if the user
+specifies the names of raster map layers, i.e., group and
+subgroup names, seed signature file name, result
+classification file name, and any combination of
+non-required options in the command line, using the form
+<DL>
+<DD>
+<B>i.maxlik</B>[<B>-q</B>] <B>group=</B><EM>name</EM>
+<B>subgroup=</B><EM>name</EM>
+<B>sigfile=</B><EM>name</EM> <B>class=</B><EM>name</EM>
+[<B>reject=</B><EM>name</EM>]
+</DL>
+where each flag and options have the meanings stated below.
+<P>
+Alternatively, the user can simply type <EM>i.maxlik</EM>
+in the command line without program arguments. In this case
+the user will be prompted for the program parameter
+settings; the program will run foreground.
+<H2>OPTIONS</H2>
+<H3>Flags:</H3>
+<DL>
+<DT><B>-q</B>
+<DD>Run quietly, without printing program messages to standard output.
+</DL>
+<H3>Parameters:</H3>
+<DL>
+<DD>The <A HREF="i.group.html">imagery</A> group
+contains the subgroup to be classified.
+<DD>The subgroup contains image files, which were used to create
+the signature file
+in the program <EM><A HREF="i.cluster.html">i.cluster</A></EM>,
+<EM><A HREF="i.class.html">i.class</A></EM>, or
+<EM><A HREF="i.gensig.html">i.gensig</A></EM> to be classified.
+<DD>The name of the signatures to be used for the
+classification. The signature file contains the cluster and
+covariance matrices that were calculated by the GRASS
+program <EM><A HREF="i.cluster.html">i.cluster</A></EM>
+(or the region means and covariance matrices generated by
+<EM><A HREF="i.class.html">i.class</A></EM>, if the
+user runs a supervised classification). These spectral
+signatures are what determine the categories (classes) to
+which image pixels will be assigned during the
+<DT><B>class=</B><EM>name</EM>
+<DD>The name of a raster map holds the classification
+results. This new raster map layer will contain categories
+that can be related to land cover categories on the
+ground.
+<DT><B>reject=</B><EM>name</EM>
+<DD>The optional name of a raster map holds the reject
+threshold results. This is the result of a chi square test
+on each discriminant result at various threshold levels of
+confidence to determine at what confidence level each cell
+classified (categorized). It is the reject threshold map
+layer, and contains one calculated confidence level for
+each classified cell in the classified image. One of the
+possible uses for this map layer is as a mask, to identify
+cells in the classified image that have the lowest
+probability of being assigned to the correct class.
+</DL>
+<H2>NOTES</H2>
+The maximum-likelihood classifier assumes that the spectral
+signatures for each class (category) in each band file
+are normally distributed (i.e., Gaussian in nature).
+Algorithms, such as
+<EM><A HREF="i.cluster.html">i.cluster</A></EM>,
+or <EM><A HREF="i.gensig.html">i.gensig</A></EM>,
+however, can create signatures that are not valid
+distributed (more likely with
+<EM><A HREF="i.class.html">i.class</A>).</EM>
+If this occurs,
+<EM>i.maxlik</EM>
+will reject them and display a warning message.
+<P>
+This program runs interactively if the user types
+<EM>i.maxlik</EM> only. If the user types <EM>i.maxlik</EM>
+along with all required options, it will overwrite the
+classified raster map without prompting if this map
+existed.
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<A HREF="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
+Processing manual</A></EM>
+<P>
+<EM>
+</EM>
+<H2>AUTHORS</H2>
+Michael Shapiro,
+<BR>
+Tao Wen,
+University of Illinois at Urbana-Champaign,
+Illinois
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/imagery/i.ortho.photo/menu/description.html
--- grass/trunk/imagery/i.ortho.photo/menu/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/menu/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,201 +0,0 @@
-<EM>i.ortho.photo</EM>
-allows the user to ortho-rectify imagery group files.
-An imagery group consists of several scanned aerial photographs
-(raster maps) of a common area.
-Imagery groups can be created or modified using the
-GRASS Image Processing Program
-<EM><A HREF="i.group.html">i.group</A></EM>,
-or using the first menu option described below.
-<EM>i.ortho.photo</EM> guides the user through the steps required to
-ortho-rectify the raster maps in a single imagery group.
-<P>
-The first menu in <EM>i.ortho.photo</EM> provides the user with the following
-options:
-<DL>
-<DT>Initialization Options:
-<DD>
-1) Select/Modify imagery group <BR>
-2) Select/Modify imagery group target<BR>
-3) Select/Modify target elevation model <BR>
-4) Select/Modify imagery group camera <BR>
-<BR>
-<DT>Transformation Parameter Computation:
-<DD>
-5) Compute image-to-photo transformation parameters<BR>
-6) Initialize exposure station parameters<BR>
-7) Compute photo-to-target transformation parameters<BR>
-<BR>
-<DT>Ortho-rectification Option:
-<DD>
-8) Ortho-rectify imagery group raster maps
-<BR>
-<DT>RETURN to exit
-<DD>>
-</DL>
-To ortho-rectify aerial images the user has to follow the menu options step by
-step. Generally the user builds a target location containing a projected DEM
-and a map reference (topo sheet or other map). Another xy-location will
-contain the aerial photo. The entire rectification process is started within
-the xy-location. First the target to the projected location has to be set
-(i.target), then the image references (fiducial points) will be defined. After
-describing the camera parameters, reference points from aerial image to the
-topo sheet from the target location will be set. The local elevation will be
-taken from the target DEM. Finally the aerial image will be rectified.
-<p>
-The options to follow are described as follows:
-<DL>
-<DT><EM>1. Select/Modify imagery group</EM>
-<DD>The current imagery group is display at the top of the
-previous menu. You may select another (new or existing)
-imagery group for the ortho-rectification program using
-option (1). After choosing option (1) you will be prompted
-for the name of a new or existing imagery group. Option
-(1) using the GRASS Image Processing Program
-for creation or modification of imagery groups. For more
-information on imagery group creation or modification
-please the the GRASS manual page for
-<EM><A HREF="i.group.html">i.group</A></EM>.
-<DT><EM>2. Select/Modify imagery group target</EM>
-<DD>The target location and mapset may be selected or
-modified using option (2). After choosing option (2) you
-will be prompted for the names of the target location and
-mapset, where the ortho-rectified raster maps will
-reside. The target location is also the location from
-which the elevation model (raster map) will be selected --
-see option (3). Option (2) uses the GRASS Image Processing
-Program
-<EM><A HREF="i.target.html">i.target</A></EM>,
-for selection or
-modification of the imagery group target location and mapset.
-For more information on imagery group
-selection or modification please the the GRASS manual page for
-<EM><A HREF="i.target.html">i.target</A></EM>.
-<DT><EM>3. Select/Modify target elevation model</EM>
-<DD>Option (3) allows you to select the raster map from
-the target location to be used as the elevation model. The
-elevation model is required for both the computation of
-photo-to-target parameters (option 6) and for the
-ortho-rectification of the imagery group files (option 8).
-The raster map select for the elevation model should cover
-the entire area of the image group to be ortho-rectified.
-Currently, the elevation model raster map is expected to
-be in units of meters. DTED and DEM files are suitable for
-use as the elevation model in the ortho-rectification
-program. After selection option (3) you will be prompted
-for the name of the raster map in the target location that
-you want to use as the elevation model.
-<DT><EM>4. Select/Modify imagery group camera</EM>
-<DD>Using option (4) you may select or create an camera
-reference file that will be used with the current imagery
-group. A camera reference file contains information on the
-internal characteristics of the aerial camera, as well as
-the geometry of the fiducial or reseau marks. The most
-important characteristic of the camera is its focal
-length. Fiducial or reseau marks locations are required to
-compute the scanned image to photo-coordinate
-transformation parameter (option 5). For a more detailed
-description of option (4) please see the GRASS manual page
-for
-<EM><A HREF="photo.camera.html">photo.camera</A></EM>.
-<DT><EM>5. Compute image-to-photo transformation parameters</EM>
-<DD>The scanned image to photo-coordinate transformation
-parameters are computed using option (5). In this
-interactive option you associate scanned reference points
-(fiducials, reseau marks, etc.) with their known photo
-coordinates from the camera reference file. Complete
-documentation for this option is available under the manual
-entry
-<EM><A HREF="photo.2image.html">photo.2image</A></EM>.
-<DT><EM>6. Initialize exposure station parameters</EM>
-<DD>If option (6) is selected, initial camera exposure
-station parameters and initial variances may be selected or
-modified. Complete documentation for this option is
-available under the manual entry
-<EM><A HREF="photo.init.html">photo.init</A></EM>.
-<DT><EM>7. Compute photo-to-target transformation parameters</EM>
-<DD>The photo to target transformation parameters are
-compute using option (7). Here control points are marked on
-one or more imagery group files and associated with there
-known standard (e.g. UTM) and elevation coordinates. Complete
-entry
-<EM><A HREF="photo.2target.html">photo.2target</A></EM>.
-<DT><EM>8. Ortho-photo imagery group files</EM>
-<DD>Option (8) is used to perform the actual image
-ortho-rectification after all of the transformation
-parameters have been computed. Ortho-rectified raster
-files will be created in the target location for each
-selected imagery group file. You may select either the
-current window in the target location or the minimal
-bounding window for the ortho-rectified image. Complete
-entry
-<EM><A HREF="photo.rectify.html">photo.rectify</A></EM>.
-</DL>
-<H2>NOTES</H2>
-<EM>i.ortho.photo</EM> currently requires the elevation
-model to be in meters, and the target location to be a standard (e.g. UTM)
-coordinate system.
-<H2>SEE ALSO</H2>
-<EM><A HREF="photo.camera.html">photo.camera</A></EM>,
-<EM><A HREF="photo.2image.html">photo.2image</A></EM>,
-<EM><A HREF="photo.2target.html">photo.2target</A></EM>,
-<EM><A HREF="photo.init.html">photo.init</A></EM>,
-<H2>AUTHOR</H2>
-Mike Baba, DBA Systems, Inc.
-<P>
-Updated rectification and elevation map to FP 1/2002 Markus Neteler
-<p>
Copied: grass/trunk/imagery/i.ortho.photo/menu/i.ortho.photo.html (from rev 32770, grass/trunk/imagery/i.ortho.photo/menu/description.html)
--- grass/trunk/imagery/i.ortho.photo/menu/i.ortho.photo.html (rev 0)
+++ grass/trunk/imagery/i.ortho.photo/menu/i.ortho.photo.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,201 @@
+<EM>i.ortho.photo</EM>
+allows the user to ortho-rectify imagery group files.
+An imagery group consists of several scanned aerial photographs
+(raster maps) of a common area.
+Imagery groups can be created or modified using the
+GRASS Image Processing Program
+<EM><A HREF="i.group.html">i.group</A></EM>,
+or using the first menu option described below.
+<EM>i.ortho.photo</EM> guides the user through the steps required to
+ortho-rectify the raster maps in a single imagery group.
+<P>
+The first menu in <EM>i.ortho.photo</EM> provides the user with the following
+options:
+<DL>
+<DT>Initialization Options:
+<DD>
+1) Select/Modify imagery group <BR>
+2) Select/Modify imagery group target<BR>
+3) Select/Modify target elevation model <BR>
+4) Select/Modify imagery group camera <BR>
+<BR>
+<DT>Transformation Parameter Computation:
+<DD>
+5) Compute image-to-photo transformation parameters<BR>
+6) Initialize exposure station parameters<BR>
+7) Compute photo-to-target transformation parameters<BR>
+<BR>
+<DT>Ortho-rectification Option:
+<DD>
+8) Ortho-rectify imagery group raster maps
+<BR>
+<DT>RETURN to exit
+<DD>>
+</DL>
+To ortho-rectify aerial images the user has to follow the menu options step by
+step. Generally the user builds a target location containing a projected DEM
+and a map reference (topo sheet or other map). Another xy-location will
+contain the aerial photo. The entire rectification process is started within
+the xy-location. First the target to the projected location has to be set
+(i.target), then the image references (fiducial points) will be defined. After
+describing the camera parameters, reference points from aerial image to the
+topo sheet from the target location will be set. The local elevation will be
+taken from the target DEM. Finally the aerial image will be rectified.
+<p>
+The options to follow are described as follows:
+<DL>
+<DT><EM>1. Select/Modify imagery group</EM>
+<DD>The current imagery group is display at the top of the
+previous menu. You may select another (new or existing)
+imagery group for the ortho-rectification program using
+option (1). After choosing option (1) you will be prompted
+for the name of a new or existing imagery group. Option
+(1) using the GRASS Image Processing Program
+for creation or modification of imagery groups. For more
+information on imagery group creation or modification
+please the the GRASS manual page for
+<EM><A HREF="i.group.html">i.group</A></EM>.
+<DT><EM>2. Select/Modify imagery group target</EM>
+<DD>The target location and mapset may be selected or
+modified using option (2). After choosing option (2) you
+will be prompted for the names of the target location and
+mapset, where the ortho-rectified raster maps will
+reside. The target location is also the location from
+which the elevation model (raster map) will be selected --
+see option (3). Option (2) uses the GRASS Image Processing
+Program
+<EM><A HREF="i.target.html">i.target</A></EM>,
+for selection or
+modification of the imagery group target location and mapset.
+For more information on imagery group
+selection or modification please the the GRASS manual page for
+<EM><A HREF="i.target.html">i.target</A></EM>.
+<DT><EM>3. Select/Modify target elevation model</EM>
+<DD>Option (3) allows you to select the raster map from
+the target location to be used as the elevation model. The
+elevation model is required for both the computation of
+photo-to-target parameters (option 6) and for the
+ortho-rectification of the imagery group files (option 8).
+The raster map select for the elevation model should cover
+the entire area of the image group to be ortho-rectified.
+Currently, the elevation model raster map is expected to
+be in units of meters. DTED and DEM files are suitable for
+use as the elevation model in the ortho-rectification
+program. After selection option (3) you will be prompted
+for the name of the raster map in the target location that
+you want to use as the elevation model.
+<DT><EM>4. Select/Modify imagery group camera</EM>
+<DD>Using option (4) you may select or create an camera
+reference file that will be used with the current imagery
+group. A camera reference file contains information on the
+internal characteristics of the aerial camera, as well as
+the geometry of the fiducial or reseau marks. The most
+important characteristic of the camera is its focal
+length. Fiducial or reseau marks locations are required to
+compute the scanned image to photo-coordinate
+transformation parameter (option 5). For a more detailed
+description of option (4) please see the GRASS manual page
+for
+<EM><A HREF="photo.camera.html">photo.camera</A></EM>.
+<DT><EM>5. Compute image-to-photo transformation parameters</EM>
+<DD>The scanned image to photo-coordinate transformation
+parameters are computed using option (5). In this
+interactive option you associate scanned reference points
+(fiducials, reseau marks, etc.) with their known photo
+coordinates from the camera reference file. Complete
+documentation for this option is available under the manual
+entry
+<EM><A HREF="photo.2image.html">photo.2image</A></EM>.
+<DT><EM>6. Initialize exposure station parameters</EM>
+<DD>If option (6) is selected, initial camera exposure
+station parameters and initial variances may be selected or
+modified. Complete documentation for this option is
+available under the manual entry
+<EM><A HREF="photo.init.html">photo.init</A></EM>.
+<DT><EM>7. Compute photo-to-target transformation parameters</EM>
+<DD>The photo to target transformation parameters are
+compute using option (7). Here control points are marked on
+one or more imagery group files and associated with there
+known standard (e.g. UTM) and elevation coordinates. Complete
+entry
+<EM><A HREF="photo.2target.html">photo.2target</A></EM>.
+<DT><EM>8. Ortho-photo imagery group files</EM>
+<DD>Option (8) is used to perform the actual image
+ortho-rectification after all of the transformation
+parameters have been computed. Ortho-rectified raster
+files will be created in the target location for each
+selected imagery group file. You may select either the
+current window in the target location or the minimal
+bounding window for the ortho-rectified image. Complete
+entry
+<EM><A HREF="photo.rectify.html">photo.rectify</A></EM>.
+</DL>
+<H2>NOTES</H2>
+<EM>i.ortho.photo</EM> currently requires the elevation
+model to be in meters, and the target location to be a standard (e.g. UTM)
+coordinate system.
+<H2>SEE ALSO</H2>
+<EM><A HREF="photo.camera.html">photo.camera</A></EM>,
+<EM><A HREF="photo.2image.html">photo.2image</A></EM>,
+<EM><A HREF="photo.2target.html">photo.2target</A></EM>,
+<EM><A HREF="photo.init.html">photo.init</A></EM>,
+<H2>AUTHOR</H2>
+Mike Baba, DBA Systems, Inc.
+<P>
+Updated rectification and elevation map to FP 1/2002 Markus Neteler
+<p>
Modified: grass/trunk/imagery/i.ortho.photo/photo.2image/Makefile
--- grass/trunk/imagery/i.ortho.photo/photo.2image/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.2image/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -11,6 +11,6 @@
default: etc
-$(PGM).tmp.html: description.html
+$(PGM).tmp.html: $(PGM).html
$(INSTALL_DATA) $< $@
Deleted: grass/trunk/imagery/i.ortho.photo/photo.2image/description.html
--- grass/trunk/imagery/i.ortho.photo/photo.2image/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.2image/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,377 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>photo.2image</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>photo.2image</b></em>
-<EM>photo.2image</EM> is an imagery function that enables
-you to mark fiducial or reseau points on an image to be
-ortho-rectified and then computes the image-to-photo
-coordinate transformation parameters. The coordinates of
-the fiducials or reseau marks can be choosen for a camera
-reference file.
-<P>
-During the process of marking reference points with known
-photo coordinates, you may compute the RMS (root mean
-square) error for each reference point entered.
-<EM>photo.2image</EM> does this by calculating the
-transformation equation (the same one that is calculated by
-<EM><A HREF="i.points.html">i.points</A> </EM>),
-and then plugging these results into an equation for RMS
-error.
-<P>
-<EM>photo.2image</EM> offers a zoom option to locate
-precisely the fiducial or reseau point to be marked on an
-image.
-<P>
-To run <EM>photo.2image</EM>, a graphics monitor is
-required.
-<P>
-The procedure for marking fiducial or reseau points,
-entering known photo-coordinates, and analyzing the RMS
-error is described below.
-<P>
-The terminal screen displays this message:
-<P>
-<B>use mouse now...</B>
-<P>
-The graphics monitor displays the following screen:
-<PRE>
- |imagery | |
-</PRE>
-<P>
-A pop-down menu like that shown below will be superimposed on the
-left half of the screen:
-<P>
-<PRE>
- | Double click on raster map to be plotted |
- | Double click here to cancel |
- |Mapset imagery |
- |gs13.1 | gs21.1 |
- |gs14.1 | gs22.2 |
-</PRE>
-Any single file in the imagery group may be used on which to mark
-points, and you may mark points on more than one file
-in the imagery group to accumulate the suggested minimum number of
-4-8 fiducial or ressue points.
-The imagery file selected is displayed in the upper
-left quadrant of the screen.
-<P>
-<H2>CAMERA FILE</H2>
-The camera reference file may be viewed by placing the mouse
-cross hairs on the words CAMERA. The camera reference file
-will be displayed in the lower left quadrant of the display:
-<P>
-<PRE>
-|Camera Reference File |
-| CAMERA NAME : camera name |
-| CAMERA ID : L1234 |
-| CAMERA CFL : 153.021 mm. |
-| CAMERA XP : 0.050 mm. |
-| CAMERA XP : 0.056 mm. |
-| number of fid. 4 |
-|ID (X PHOTO) mm. (Y PHOTO) mm. |
-|_______________________________________________________________|
-|1 -105.023 110.123 |
-|2 107.987 109.834 |
-|3 110.965 -104.329 |
-|4 -103.932 -110.352 |
-</PRE>
-<P>
-The following menu is displayed at the bottom
-of the graphics display:
-<P>
-<B>
-<PRE>
-|Quit | Zoom | Plot Cell | Camera | Analyze | Input->KEYBOARD | CAMERA FILE |
-</PRE>
-</B>
-<P>
-<H2>ZOOM</H2>
-To magnify the displayed file, you must
-place the mouse cross hairs on the word ZOOM. The following menu
-will then be displayed at the bottom of the screen:
-<P>
-<B>
-<PRE>
-|Cancel | Box | Point ||Select type of ZOOM |
-</PRE>
-</B>
-<P>
-You have the option of identifying the zoom window either by using
-the mouse to make a box, or by using the mouse to mark the center
-of the desired window, and adjusting the magnification factor.
-The terminal screen will display a mouse button menu to guide you in
-identifying the window. The section of the image within the zoom window
-will be displayed in the upper right hand quadrant.
-<P>
-<H2>MARKING REFERENCE POINTS</H2>
-To mark the known reference points (fiducial marks, reseau marks, etc.)
-on the image, you must place the mouse cross hairs
-on the corresponding location on the image to be marked and press
-the left hand button on the mouse. A diamond shaped symbol will be marked
-on the image.
-<P>
-If you wish to use the camera reference file only as a
-comparative reference, then the keyboard can be chosen as
-the means to input photo coordinates corresponding to the marked
-reference points on the image. This is done by placing the mouse
-cross hairs on the word KEYBOARD and pressing the left
-button on the mouse.
-<P>
-The following menu is displayed on the graphics terminal:
-<P>
-<PRE>
-|Point 1 marked at IMAGE COORDINATES | |
-|east: 1023.77 | |
-|north: 506.56 | |
-|Enter PHOTO COORDINATES as x and y: |
-</PRE>
-</B>
-<P>
-You then enter the known (x,y) photo coordinates, relative
-to the perspective center, for the reference
-point marked on the image. If you
-do not wish to enter a coordinate, simply hit RETURN to continue;
-the marked reference point will disappear.
-<P>
-If you select the CAMERA FILE option, then reference points
-marked on the image will be associated with selected photo
-coordinates from the displayed camera reference file. In this option,
-when you mark a point on the image, the following menu is
-displayed on the graphics terminal:
-<P>
-<PRE>
-CANCEL Double click on the fiducial mark to be referenced
-</PRE>
-<P>
-If you would like to select the photo coordinates of a displayed
-reference mark, this can be accomplished by placing the mouse
-cross hairs on the reference point to be selected and pressing
-the left button on the mouse twice. After a reference point is selected
-from the display, you are prompted with "Look ok? (Y/N)".
-If you respond with no, the reference point is ignored.
-If you respond with yes, the following is displayed on the terminal:
-<P>
-<P>
-<PRE>
-|east: 1023.77 | |
-|north: 1065.41 | |
-|Point 1 referenced at PHOTO COORDINATES | |
-|X: -105.023 | |
-|Y: 110.122 | |
-| use mouse now... |
-</PRE>
-</B>
-<P>
-The photo coordinates and the corresponding image coordinates are
-automatically saved in the photo_points file associated with the imagery
-group.
-<P>
-<P>
-<H2>ANALYZE</H2>
-After a number of points have been marked (4 to 8), you can
-check the RMS error of the points marked on the image. This is done
-by placing the mouse cross hairs on the word ANALYZE at the bottom
-of the monitor. An error report resembling the one shown below
-is superimposed on the monitor:
-<P>
-<PRE>
-| error image photo |
-|# row col photo east north x y |
-|1 0.0 -0.9 1.0 1048.5 -144.8 -105.023 110.122 |
-|2 0.4 1.0 1.3 2153.1 -567.2 107.987 109.834 |
-|3 -1.2 -0.5 0.6 1452.8 -476.5 110.965 -104.329 |
-|4 1.1 0.5 1.3 1034.0 -109.2 -103.932 -110.352 |
-| overall rms error: 4.46 |
-</PRE>
-<P>
- The following menu then appears at the bottom of the monitor:
-<P>
-<PRE>
-|DONE | PRINT | FILE | Double click on point to be included/excluded |
-</PRE>
-</B>
-<P>
-The RMS error for the image is given under the column
-TITLEd "error" and subTITLEd "row" and "col". In the above
-report, point number 1 is 0.0 rows and -0.9 columns from
-the predicted location calculated from the transformation
-equation. The RMS error for the photo coordinates is
-listed under the heading "photo". This is the RMS error
-for the x and y coordinates of the photo coordinates but it
-is presented in the table using one general value. The
-overall RMS error is displayed at the bottom of the screen
-in milimeters. Points that create high RMS error are
-displayed in red on the monitor (represented here in
-italics).
-<P>
-The location of the point marked on the imagery group file
-is given under the heading "image" and the subheadings
-"east" and "north". The location of the point in the photo
-coordinates is given under the heading "photo" and the
-subheadings "x" and "y". If you would like to exclude or
-include a point, this can be accomplished by placing the
-mouse cross hairs on the point number to be included (if
-the point is absent) or excluded (if the point is
-displayed) and pressing the left button on the mouse
-twice. When a point is excluded, it is not afterwards
-included in the calculation of the RMS error, or included
-in the final transformation matrix. However, it can be
-retrieved within <EM>photo.2image</EM> at any time by
-double clicking with the mouse as described above.
-<P>
-<H2>QUIT</H2>
-To end the <EM>photo.2image</EM> program place the mouse cross hairs
-on the word QUIT; the marked reference points (including coordinates)
-will be saved.
-<P>
-<H2>NOTES</H2>
-A good rule of thumb is to mark at least 4 to 8 points which are
-evenly distributed over the perimeter of the imagery
-group file in order to obtain
-an accurate transformation equation for the rectification process.
-The RMS error may increase with more points added, but the
-transformation equation will be more accurate.
-<P>
-An RMS error of less than or equal to approximately one resolution
-unit (pixel) for the image being rectified is generally considered
-acceptable.
-<H2>SEE ALSO</H2>
-<EM><A HREF="i.ortho.photo.html">i.ortho.photo</A></EM>,
-<H2>AUTHOR</H2>
-</body>
-</html>
Copied: grass/trunk/imagery/i.ortho.photo/photo.2image/photo.2image.html (from rev 32770, grass/trunk/imagery/i.ortho.photo/photo.2image/description.html)
--- grass/trunk/imagery/i.ortho.photo/photo.2image/photo.2image.html (rev 0)
+++ grass/trunk/imagery/i.ortho.photo/photo.2image/photo.2image.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,377 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>photo.2image</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<h2>NAME</h2>
+<em><b>photo.2image</b></em>
+<EM>photo.2image</EM> is an imagery function that enables
+you to mark fiducial or reseau points on an image to be
+ortho-rectified and then computes the image-to-photo
+coordinate transformation parameters. The coordinates of
+the fiducials or reseau marks can be choosen for a camera
+reference file.
+<P>
+During the process of marking reference points with known
+photo coordinates, you may compute the RMS (root mean
+square) error for each reference point entered.
+<EM>photo.2image</EM> does this by calculating the
+transformation equation (the same one that is calculated by
+<EM><A HREF="i.points.html">i.points</A> </EM>),
+and then plugging these results into an equation for RMS
+error.
+<P>
+<EM>photo.2image</EM> offers a zoom option to locate
+precisely the fiducial or reseau point to be marked on an
+image.
+<P>
+To run <EM>photo.2image</EM>, a graphics monitor is
+required.
+<P>
+The procedure for marking fiducial or reseau points,
+entering known photo-coordinates, and analyzing the RMS
+error is described below.
+<P>
+The terminal screen displays this message:
+<P>
+<B>use mouse now...</B>
+<P>
+The graphics monitor displays the following screen:
+<PRE>
+ |imagery | |
+</PRE>
+<P>
+A pop-down menu like that shown below will be superimposed on the
+left half of the screen:
+<P>
+<PRE>
+ | Double click on raster map to be plotted |
+ | Double click here to cancel |
+ |Mapset imagery |
+ |gs13.1 | gs21.1 |
+ |gs14.1 | gs22.2 |
+</PRE>
+Any single file in the imagery group may be used on which to mark
+points, and you may mark points on more than one file
+in the imagery group to accumulate the suggested minimum number of
+4-8 fiducial or ressue points.
+The imagery file selected is displayed in the upper
+left quadrant of the screen.
+<P>
+<H2>CAMERA FILE</H2>
+The camera reference file may be viewed by placing the mouse
+cross hairs on the words CAMERA. The camera reference file
+will be displayed in the lower left quadrant of the display:
+<P>
+<PRE>
+|Camera Reference File |
+| CAMERA NAME : camera name |
+| CAMERA ID : L1234 |
+| CAMERA CFL : 153.021 mm. |
+| CAMERA XP : 0.050 mm. |
+| CAMERA XP : 0.056 mm. |
+| number of fid. 4 |
+|ID (X PHOTO) mm. (Y PHOTO) mm. |
+|_______________________________________________________________|
+|1 -105.023 110.123 |
+|2 107.987 109.834 |
+|3 110.965 -104.329 |
+|4 -103.932 -110.352 |
+</PRE>
+<P>
+The following menu is displayed at the bottom
+of the graphics display:
+<P>
+<B>
+<PRE>
+|Quit | Zoom | Plot Cell | Camera | Analyze | Input->KEYBOARD | CAMERA FILE |
+</PRE>
+</B>
+<P>
+<H2>ZOOM</H2>
+To magnify the displayed file, you must
+place the mouse cross hairs on the word ZOOM. The following menu
+will then be displayed at the bottom of the screen:
+<P>
+<B>
+<PRE>
+|Cancel | Box | Point ||Select type of ZOOM |
+</PRE>
+</B>
+<P>
+You have the option of identifying the zoom window either by using
+the mouse to make a box, or by using the mouse to mark the center
+of the desired window, and adjusting the magnification factor.
+The terminal screen will display a mouse button menu to guide you in
+identifying the window. The section of the image within the zoom window
+will be displayed in the upper right hand quadrant.
+<P>
+<H2>MARKING REFERENCE POINTS</H2>
+To mark the known reference points (fiducial marks, reseau marks, etc.)
+on the image, you must place the mouse cross hairs
+on the corresponding location on the image to be marked and press
+the left hand button on the mouse. A diamond shaped symbol will be marked
+on the image.
+<P>
+If you wish to use the camera reference file only as a
+comparative reference, then the keyboard can be chosen as
+the means to input photo coordinates corresponding to the marked
+reference points on the image. This is done by placing the mouse
+cross hairs on the word KEYBOARD and pressing the left
+button on the mouse.
+<P>
+The following menu is displayed on the graphics terminal:
+<P>
+<PRE>
+|Point 1 marked at IMAGE COORDINATES | |
+|east: 1023.77 | |
+|north: 506.56 | |
+|Enter PHOTO COORDINATES as x and y: |
+</PRE>
+</B>
+<P>
+You then enter the known (x,y) photo coordinates, relative
+to the perspective center, for the reference
+point marked on the image. If you
+do not wish to enter a coordinate, simply hit RETURN to continue;
+the marked reference point will disappear.
+<P>
+If you select the CAMERA FILE option, then reference points
+marked on the image will be associated with selected photo
+coordinates from the displayed camera reference file. In this option,
+when you mark a point on the image, the following menu is
+displayed on the graphics terminal:
+<P>
+<PRE>
+CANCEL Double click on the fiducial mark to be referenced
+</PRE>
+<P>
+If you would like to select the photo coordinates of a displayed
+reference mark, this can be accomplished by placing the mouse
+cross hairs on the reference point to be selected and pressing
+the left button on the mouse twice. After a reference point is selected
+from the display, you are prompted with "Look ok? (Y/N)".
+If you respond with no, the reference point is ignored.
+If you respond with yes, the following is displayed on the terminal:
+<P>
+<P>
+<PRE>
+|east: 1023.77 | |
+|north: 1065.41 | |
+|Point 1 referenced at PHOTO COORDINATES | |
+|X: -105.023 | |
+|Y: 110.122 | |
+| use mouse now... |
+</PRE>
+</B>
+<P>
+The photo coordinates and the corresponding image coordinates are
+automatically saved in the photo_points file associated with the imagery
+group.
+<P>
+<P>
+<H2>ANALYZE</H2>
+After a number of points have been marked (4 to 8), you can
+check the RMS error of the points marked on the image. This is done
+by placing the mouse cross hairs on the word ANALYZE at the bottom
+of the monitor. An error report resembling the one shown below
+is superimposed on the monitor:
+<P>
+<PRE>
+| error image photo |
+|# row col photo east north x y |
+|1 0.0 -0.9 1.0 1048.5 -144.8 -105.023 110.122 |
+|2 0.4 1.0 1.3 2153.1 -567.2 107.987 109.834 |
+|3 -1.2 -0.5 0.6 1452.8 -476.5 110.965 -104.329 |
+|4 1.1 0.5 1.3 1034.0 -109.2 -103.932 -110.352 |
+| overall rms error: 4.46 |
+</PRE>
+<P>
+ The following menu then appears at the bottom of the monitor:
+<P>
+<PRE>
+|DONE | PRINT | FILE | Double click on point to be included/excluded |
+</PRE>
+</B>
+<P>
+The RMS error for the image is given under the column
+TITLEd "error" and subTITLEd "row" and "col". In the above
+report, point number 1 is 0.0 rows and -0.9 columns from
+the predicted location calculated from the transformation
+equation. The RMS error for the photo coordinates is
+listed under the heading "photo". This is the RMS error
+for the x and y coordinates of the photo coordinates but it
+is presented in the table using one general value. The
+overall RMS error is displayed at the bottom of the screen
+in milimeters. Points that create high RMS error are
+displayed in red on the monitor (represented here in
+italics).
+<P>
+The location of the point marked on the imagery group file
+is given under the heading "image" and the subheadings
+"east" and "north". The location of the point in the photo
+coordinates is given under the heading "photo" and the
+subheadings "x" and "y". If you would like to exclude or
+include a point, this can be accomplished by placing the
+mouse cross hairs on the point number to be included (if
+the point is absent) or excluded (if the point is
+displayed) and pressing the left button on the mouse
+twice. When a point is excluded, it is not afterwards
+included in the calculation of the RMS error, or included
+in the final transformation matrix. However, it can be
+retrieved within <EM>photo.2image</EM> at any time by
+double clicking with the mouse as described above.
+<P>
+<H2>QUIT</H2>
+To end the <EM>photo.2image</EM> program place the mouse cross hairs
+on the word QUIT; the marked reference points (including coordinates)
+will be saved.
+<P>
+<H2>NOTES</H2>
+A good rule of thumb is to mark at least 4 to 8 points which are
+evenly distributed over the perimeter of the imagery
+group file in order to obtain
+an accurate transformation equation for the rectification process.
+The RMS error may increase with more points added, but the
+transformation equation will be more accurate.
+<P>
+An RMS error of less than or equal to approximately one resolution
+unit (pixel) for the image being rectified is generally considered
+acceptable.
+<H2>SEE ALSO</H2>
+<EM><A HREF="i.ortho.photo.html">i.ortho.photo</A></EM>,
+<H2>AUTHOR</H2>
+</body>
+</html>
Modified: grass/trunk/imagery/i.ortho.photo/photo.2target/Makefile
--- grass/trunk/imagery/i.ortho.photo/photo.2target/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.2target/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -10,6 +10,3 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
default: etc
-$(PGM).tmp.html: $(ETC)/$(PGM)$(EXE)
- $(call htmldesc,$(ETC)/$(PGM)$(EXE))
Deleted: grass/trunk/imagery/i.ortho.photo/photo.2target/description.html
--- grass/trunk/imagery/i.ortho.photo/photo.2target/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.2target/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,383 +0,0 @@
-<EM>photo.2target</EM>
-is an imagery function that enables you to
-mark control points on an image to be ortho-rectified
-and then input the coordinates of each point for calculation
-of rectification parameters.
-Rectification is the mapping of an image from one coordinate
-system to another. The geometry of an image extracted into
-a GRASS LOCATION having an x,y coordinate system is not
-planimetric. To create a planimetric image, that is, to
-convert the x,y coordinate system into a standard coordinate
-system (for example, the UTM coordinate system or the State
-Plane coordinate system), points from a map having the
-standard coordinates must be associated with the same points
-on the image to be rectified.
-The ortho-rectification parameters are computed in two
-phases. The first phase computes a transformation matrix between image
-(row,col) coordinates and photo (x,y) coordinates relative to the
-perspective center. The transformation matrix is computed
-explicitly in the option <EM>
-<A HREF="photo.2image.html">photo.2image</A>
-</EM>.
-The second phase, <EM>photo.2target</EM>, enables you
-to mark control points on the image
-and then input the standard coordinates
-(Easting,Northing, and elevation) to determine the
-parameters for a three dimensional projective transformation.
-<EM>
-<A HREF="photo.init.html">photo.init</A>
-</EM> may be run before
-running <EM>photo.2target</EM>
-to modify the initial camera exposure station parameters, and/or
-modify the standard deviation of these parameters.
-<EM>
-</EM> is not required but generally is helpful.
-<P>
-During the process of marking control points and entering standard
-coordinates, you may compute the RMS (root mean square)
-error for each control point entered. photo.2target does this by
-calculating the transformation equation, and then
-plugging these results into an equation for RMS error.
-<P>
-<EM>photo.2target</EM> offers a zoom option to locate precisely the point
-to be marked on an image. This program also offers you the option
-of acquiring standard coordinates for a marked point from a map
-layer in the target database, or from a digitizer.
-<P>
-To run <EM>photo.2target</EM>, a graphics monitor is required.
-<P>
-The procedure for marking points, entering coordinates, and calculating RMS
-<P>
-The terminal screen displays the following message:
-<P>
-<P>
-<P>
-<PRE>
-|imagery filename (mag) | target filename (mag) |
-|QUIT ZOOM PLOTCELL ANALYZE | |
-</PRE>
-<P>
-<P>
-<PRE>
- | Mapset PERMANENT |
- |gs13.1 | gs14.1 |
- |gs21.1 | gs22.2 |
-</PRE>
-<P>
-Any single file in the imagery group may be used to mark
-points, and you can mark points on more than one file
-in the imagery group to accumulate the 12 points suggested minimum.
-Any file in the imagery group can be rectified (using
-<EM>
-<A HREF="photo.rectify.html">photo.rectify</A>
-</EM>) based on the rectification parameters
-computed from these control points.
-<P>
-The imagery file you select is displayed in the upper
-<H2>ZOOM</H2>
-<P>
-<PRE>
- |Cancel | Box | Point ||Select type of ZOOM |
-</PRE>
-<P>
-You may identifying the zoom window either by using
-the mouse to make a box, or by using the mouse to mark the center of
-the window and entering a magnification factor.
-<P>
-It is also possible to start zoom by box with middle mouse button
-and pan by right mouse button.
-<P>
-<H2>MARKING POINTS</H2>
-To mark the points on the image that correspond to the points on a
-standard coordinate system map, you must place the mouse
-cross hairs on the corresponding location on the image to be marked
-and press the
-left hand button on the mouse. A diamond shaped symbol will be
-marked on the image. The terminal will display the following
-menu:
-<P>
-<PRE>
- |Point 1 marked at IMAGE COORDINATES | |
- |IMAGE X: 1023.77 | |
- |IMAGE Y: -164.41 | |
- |Enter CONTROL COORDINATES as east,north,elevation: |
-</PRE>
-<P>
-You then enter the easting, northing, and elevation for the point
-marked on the image. If you wish not to enter a
-coordinate, simply hit RETURN to return control
-to the mouse; the marked point then disappears.
-<P>
-Entered point can be canceled by right mouse button click.
-<P>
-<H2>PLOT CELL</H2>
-In addition to acquiring control points from a standard map,
-you have the option of acquiring the points from
-a cell-map in the target database. The database map is displayed by
-placing the mouse cross hairs on the words PLOT CELL. The
-following line is then displayed at the bottom of the monitor:
-<P>
-<PRE>
- |Cancel | Indicate which side should be plotted |
-</PRE>
-<P>
-Which side of the monitor is to be plotted
-is indicated by placing the mouse cross hairs on the
-half of the monitor screen that you would like to use,
-and pressing the left mouse button. The following pop-down
-menu will be superimposed on the half of the screen that was
-chosen:
-<P>
-<PRE>
-</PRE>
-<PRE>
- | Mapset user1 |
- |tm.rectified | |
- |tm.classified | |
- |elevation | geology |
- |slope | soils |
- |aspect | |
- |roads | |
- |streams | |
- |airfields | |
-</PRE>
-<P>
-After the map is displayed the following message appears at
-the bottom of the monitor:
-<P>
-<PRE>
- |input method -> | keyboard | screen |
-</PRE>
-<P>
-If you wish to use the plotted map only as a
-comparative reference, the keyboard can be chosen as
-the means to input coordinates corresponding to the marked
-control points. This is done by placing the mouse
-<P>
-If you select the SCREEN option, points marked on
-the image will automatically be associated with the
-coordinates from the corresponding points on the target
-database map, and a corresponding elevation from the cell-file
-selected for elevation data. In this option, when you mark a point
-on the image, the following menu is displayed on the
-terminal:
-<P>
-<PRE>
- |Point 5 marked at IMAGE COORDINATES | |
- |Control Point location | |
- |East: 679132.57 | |
- |North: 4351080.67 | |
- |Elevation: 1010.00 | |
- |use mouse now... |
-</PRE>
-<P>
-The coordinates for the target database map are automatically saved
-as the coordinates corresponding to the marked control point on the image.
-<H2>ANALYZE</H2>
-After a number of points have been marked (4 to 7), you can
-of the monitor. An error report resembling that shown below
-<P>
-<PRE>
-| error |
-|# east north target east north east north elev. |
-|1 0.0 -0.9 1.0 48.5 4.8 79132.5 351080.6 10.0 |
-|2 0.4 1.0 1.3 53.1 7.2 84314.7 399001.4 239.3 |
-|3 -1.2 -0.5 0.6 52.8 6.5 67841.4 457682.8 209.5 |
-|4 1.1 0.5 1.3 34.0 9.2 77573.8 352626.4 432.5 |
-|5 -2.7 14.0 14.2 48.6 -144.9 79132.6 351080.7 985.0 |
-</PRE>
-<P>
-<P>
-<PRE>
- |DONE | PRINT FILE | Double click on point to be included/excluded |
-</PRE>
-<P>
-The RMS error for the image is given under the column TITLEd "error"
-and subTITLEd "east" and "north". In the above report, point number 1
-is 0.0 and -0.9 meters (east and north)
-from the predicted location calculated from
-the transformation equation.
-The RMS error for the target map is listed under the heading "target".
-This is the RMS error for the east and north coordinates of the
-target map but it is presented in the table using one general value.
-The overall RMS error is displayed at the bottom of the screen in meters.
-Points that create high RMS error are displayed in red on the monitor
-(represented here in italics).
-<P>
-The image coordinates of the point marked on the
-imagery group file is given under the heading "image" and the
-subheadings "east" and "north". The location of the control point in the
-target database is given under the heading "control" and the
-subheadings "east","north", and "elev". If you would like to
-exclude or include a control point, this can be accomplished by placing
-the mouse cross hairs on the control point number to be included (if the
-point is absent) or excluded (if the point is displayed) and
-pressing the left button on the mouse twice.
-When a point is excluded, it is not afterwards included in the calculation
-of the RMS error, or included in the final rectification parameters.
-However, it can be retrieved within <EM>photo.2target</EM> at any time
-by double clicking with the mouse as described above.
-<H2>QUIT</H2>
-To end the <EM>photo.2target</EM> program place the mouse cross hairs
-on the word QUIT; the marked control points (including coordinates)
-will be saved.
-<H2>NOTES</H2>
-During the course of marking control points and computing
-the ortho-rectification parameters, a matrix inversion error may occur.
-This is caused by trying to invert a non-singular normal equation matrix.
-When this situation
-arises, the status of all previously selected control points are modified,
-the control points are excluded. Running
-<EM>
-</EM> for the selected imagery group with accurate
-camera exposure station parameters should remedy the situation.
-The excluded control points may again be included as described in the section
-ANALYZE.
-<P>
-<P>
-A good rule of thumb is to mark at least 12 to 15 points which are
-evenly distributed over the entire imagery group file in order to obtain
-an accurate transformation parameters for the rectification process.
-transformation parameters will be more accurate over the entire image.
-<P>
-acceptable.
-<H2>SEE ALSO</H2>
-<H2>AUTHOR</H2>
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.ortho.photo/photo.2target/photo.2target.html (from rev 32770, grass/trunk/imagery/i.ortho.photo/photo.2target/description.html)
--- grass/trunk/imagery/i.ortho.photo/photo.2target/photo.2target.html (rev 0)
+++ grass/trunk/imagery/i.ortho.photo/photo.2target/photo.2target.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,383 @@
+<H2>DESCRIPTION</H2>
+<EM>photo.2target</EM>
+is an imagery function that enables you to
+mark control points on an image to be ortho-rectified
+and then input the coordinates of each point for calculation
+of rectification parameters.
+Rectification is the mapping of an image from one coordinate
+system to another. The geometry of an image extracted into
+a GRASS LOCATION having an x,y coordinate system is not
+planimetric. To create a planimetric image, that is, to
+convert the x,y coordinate system into a standard coordinate
+system (for example, the UTM coordinate system or the State
+Plane coordinate system), points from a map having the
+standard coordinates must be associated with the same points
+on the image to be rectified.
+The ortho-rectification parameters are computed in two
+phases. The first phase computes a transformation matrix between image
+(row,col) coordinates and photo (x,y) coordinates relative to the
+perspective center. The transformation matrix is computed
+explicitly in the option <EM>
+<A HREF="photo.2image.html">photo.2image</A>
+</EM>.
+The second phase, <EM>photo.2target</EM>, enables you
+to mark control points on the image
+and then input the standard coordinates
+(Easting,Northing, and elevation) to determine the
+parameters for a three dimensional projective transformation.
+<EM>
+<A HREF="photo.init.html">photo.init</A>
+</EM> may be run before
+running <EM>photo.2target</EM>
+to modify the initial camera exposure station parameters, and/or
+modify the standard deviation of these parameters.
+<EM>
+</EM> is not required but generally is helpful.
+<P>
+During the process of marking control points and entering standard
+coordinates, you may compute the RMS (root mean square)
+error for each control point entered. photo.2target does this by
+calculating the transformation equation, and then
+plugging these results into an equation for RMS error.
+<P>
+<EM>photo.2target</EM> offers a zoom option to locate precisely the point
+to be marked on an image. This program also offers you the option
+of acquiring standard coordinates for a marked point from a map
+layer in the target database, or from a digitizer.
+<P>
+To run <EM>photo.2target</EM>, a graphics monitor is required.
+<P>
+The procedure for marking points, entering coordinates, and calculating RMS
+<P>
+The terminal screen displays the following message:
+<P>
+<P>
+<P>
+<PRE>
+|imagery filename (mag) | target filename (mag) |
+|QUIT ZOOM PLOTCELL ANALYZE | |
+</PRE>
+<P>
+<P>
+<PRE>
+ | Mapset PERMANENT |
+ |gs13.1 | gs14.1 |
+ |gs21.1 | gs22.2 |
+</PRE>
+<P>
+Any single file in the imagery group may be used to mark
+points, and you can mark points on more than one file
+in the imagery group to accumulate the 12 points suggested minimum.
+Any file in the imagery group can be rectified (using
+<EM>
+<A HREF="photo.rectify.html">photo.rectify</A>
+</EM>) based on the rectification parameters
+computed from these control points.
+<P>
+The imagery file you select is displayed in the upper
+<H2>ZOOM</H2>
+<P>
+<PRE>
+ |Cancel | Box | Point ||Select type of ZOOM |
+</PRE>
+<P>
+You may identifying the zoom window either by using
+the mouse to make a box, or by using the mouse to mark the center of
+the window and entering a magnification factor.
+<P>
+It is also possible to start zoom by box with middle mouse button
+and pan by right mouse button.
+<P>
+<H2>MARKING POINTS</H2>
+To mark the points on the image that correspond to the points on a
+standard coordinate system map, you must place the mouse
+cross hairs on the corresponding location on the image to be marked
+and press the
+left hand button on the mouse. A diamond shaped symbol will be
+marked on the image. The terminal will display the following
+menu:
+<P>
+<PRE>
+ |Point 1 marked at IMAGE COORDINATES | |
+ |IMAGE X: 1023.77 | |
+ |IMAGE Y: -164.41 | |
+ |Enter CONTROL COORDINATES as east,north,elevation: |
+</PRE>
+<P>
+You then enter the easting, northing, and elevation for the point
+marked on the image. If you wish not to enter a
+coordinate, simply hit RETURN to return control
+to the mouse; the marked point then disappears.
+<P>
+Entered point can be canceled by right mouse button click.
+<P>
+<H2>PLOT CELL</H2>
+In addition to acquiring control points from a standard map,
+you have the option of acquiring the points from
+a cell-map in the target database. The database map is displayed by
+placing the mouse cross hairs on the words PLOT CELL. The
+following line is then displayed at the bottom of the monitor:
+<P>
+<PRE>
+ |Cancel | Indicate which side should be plotted |
+</PRE>
+<P>
+Which side of the monitor is to be plotted
+is indicated by placing the mouse cross hairs on the
+half of the monitor screen that you would like to use,
+and pressing the left mouse button. The following pop-down
+menu will be superimposed on the half of the screen that was
+chosen:
+<P>
+<PRE>
+</PRE>
+<PRE>
+ | Mapset user1 |
+ |tm.rectified | |
+ |tm.classified | |
+ |elevation | geology |
+ |slope | soils |
+ |aspect | |
+ |roads | |
+ |streams | |
+ |airfields | |
+</PRE>
+<P>
+After the map is displayed the following message appears at
+the bottom of the monitor:
+<P>
+<PRE>
+ |input method -> | keyboard | screen |
+</PRE>
+<P>
+If you wish to use the plotted map only as a
+comparative reference, the keyboard can be chosen as
+the means to input coordinates corresponding to the marked
+control points. This is done by placing the mouse
+<P>
+If you select the SCREEN option, points marked on
+the image will automatically be associated with the
+coordinates from the corresponding points on the target
+database map, and a corresponding elevation from the cell-file
+selected for elevation data. In this option, when you mark a point
+on the image, the following menu is displayed on the
+terminal:
+<P>
+<PRE>
+ |Point 5 marked at IMAGE COORDINATES | |
+ |Control Point location | |
+ |East: 679132.57 | |
+ |North: 4351080.67 | |
+ |Elevation: 1010.00 | |
+ |use mouse now... |
+</PRE>
+<P>
+The coordinates for the target database map are automatically saved
+as the coordinates corresponding to the marked control point on the image.
+<H2>ANALYZE</H2>
+After a number of points have been marked (4 to 7), you can
+of the monitor. An error report resembling that shown below
+<P>
+<PRE>
+| error |
+|# east north target east north east north elev. |
+|1 0.0 -0.9 1.0 48.5 4.8 79132.5 351080.6 10.0 |
+|2 0.4 1.0 1.3 53.1 7.2 84314.7 399001.4 239.3 |
+|3 -1.2 -0.5 0.6 52.8 6.5 67841.4 457682.8 209.5 |
+|4 1.1 0.5 1.3 34.0 9.2 77573.8 352626.4 432.5 |
+|5 -2.7 14.0 14.2 48.6 -144.9 79132.6 351080.7 985.0 |
+</PRE>
+<P>
+<P>
+<PRE>
+ |DONE | PRINT FILE | Double click on point to be included/excluded |
+</PRE>
+<P>
+The RMS error for the image is given under the column TITLEd "error"
+and subTITLEd "east" and "north". In the above report, point number 1
+is 0.0 and -0.9 meters (east and north)
+from the predicted location calculated from
+the transformation equation.
+The RMS error for the target map is listed under the heading "target".
+This is the RMS error for the east and north coordinates of the
+target map but it is presented in the table using one general value.
+The overall RMS error is displayed at the bottom of the screen in meters.
+Points that create high RMS error are displayed in red on the monitor
+(represented here in italics).
+<P>
+The image coordinates of the point marked on the
+imagery group file is given under the heading "image" and the
+subheadings "east" and "north". The location of the control point in the
+target database is given under the heading "control" and the
+subheadings "east","north", and "elev". If you would like to
+exclude or include a control point, this can be accomplished by placing
+the mouse cross hairs on the control point number to be included (if the
+point is absent) or excluded (if the point is displayed) and
+pressing the left button on the mouse twice.
+When a point is excluded, it is not afterwards included in the calculation
+of the RMS error, or included in the final rectification parameters.
+However, it can be retrieved within <EM>photo.2target</EM> at any time
+by double clicking with the mouse as described above.
+<H2>QUIT</H2>
+To end the <EM>photo.2target</EM> program place the mouse cross hairs
+on the word QUIT; the marked control points (including coordinates)
+will be saved.
+<H2>NOTES</H2>
+During the course of marking control points and computing
+the ortho-rectification parameters, a matrix inversion error may occur.
+This is caused by trying to invert a non-singular normal equation matrix.
+When this situation
+arises, the status of all previously selected control points are modified,
+the control points are excluded. Running
+<EM>
+</EM> for the selected imagery group with accurate
+camera exposure station parameters should remedy the situation.
+The excluded control points may again be included as described in the section
+ANALYZE.
+<P>
+<P>
+A good rule of thumb is to mark at least 12 to 15 points which are
+evenly distributed over the entire imagery group file in order to obtain
+an accurate transformation parameters for the rectification process.
+transformation parameters will be more accurate over the entire image.
+<P>
+acceptable.
+<H2>SEE ALSO</H2>
+<H2>AUTHOR</H2>
+<p><i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.ortho.photo/photo.camera/Makefile
--- grass/trunk/imagery/i.ortho.photo/photo.camera/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.camera/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -11,7 +11,5 @@
default: etc
-htmletc:
- $(MKDIR) $(GISBASE)/docs/html
- $(INSTALL_DATA) description.html $(GISBASE)/docs/html/$(PGM).html
- $(INSTALL_DATA) *.png $(GISBASE)/docs/html/
+ $(INSTALL_DATA) $< $@
Deleted: grass/trunk/imagery/i.ortho.photo/photo.camera/description.html
--- grass/trunk/imagery/i.ortho.photo/photo.camera/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.camera/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,126 +0,0 @@
-<html>
-<head>
-<title></title>
-</head>
-<h2>NAME</h2>
-<em><b></b></em>
-<H2>DESCRIPTION</H2>
-<EM>photo.camera</EM> creates or modifies entries in a camera reference
-file. For ortho-photo rectification, a camera reference file is required for
-computation of scanned image to photo-coordinate transformation parameters.
-There are two coordinate systems: The image coordinate system (in pixels)
-and the photo coordinate system (in milli-meters). The inner orientation
-establishes a relation between the pixels and the image coordinates with
-help of fiducial marks.
-<P>
-The first prompt in the program will ask you for the name of
-the camera reference file to be created or modified. You may
-create a new camera reference file by entering a new name, or modify an
-existing camera reference file by entering the name of an existing camera file.
-<P>
-After entering the camera file name, following menu is displayed:
-<P>
-Please provide the following information
-<P>
-<PRE>
- CAMERA NAME: <EM>camera name</EM>______
- CAMERA IDENTIFICATION: <EM>identification</EM>___
- CALIBRATED FOCAL LENGTH mm.:_________________
- POINT OF SYMMETRY (X) mm.:_________________
- POINT OF SYMMETRY (Y) mm.:_________________
- MAXIMUM NUMBER OF FIDUCIALS:_________________
- AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
- (OR <Ctrl-C> TO CANCEL)
-</PRE>
-The camera name and identification describe the camera reference file.
-The calibrated focal length and the point of symmetry are used in computing
-the photo-to-target transformation parameters. These values should be entered
-from the camera calibration report (usually available from the photograph
-supplier).
-<p>
-<img src="photo.camera.png" alt="Sketch of aerial photo"><br>
-<i>This example is the camera Zeiss LMK9 265-002A belonging to the Hellenic
-Military Geographical Survey (HMGS) and calibrated in December 1985</i>
-<p>
-The photo coordinate system origin is the so-called calibrated principal
-point (PP, Principal Point of Symmetry) which is in the center of the image.
-The origin of the axes is at the intersection of the radii traced from the
-fiducial marks. In the ideal case of no deviations in the camera (see camera
-calibration certificate) the center is the origin and the values are 0 for
-both X and Y of Point of Symmetry. But usually the principal point does not
-fall on the intersection of the radii at the center of the picture. This
-excentricity is usually of the order of a few micrometers. <P>
-You are then asked to enter the X and Y photo coordinates of each fiducial
-as follows.
-These fiducials (or reseau) marks are index marks imaged on film which serve
-as reference photo coordinate system. The maximum number of fiducials will
-determine the number of fiducial or reseau coordinate pairs to be entered
-below. The origin is the center of the image (or the point of symmetry) and
-X and Y are left-right and up-down. The order is up to the user, but must be
-kept consistent throughout the rectification process.
-<P>
-On this screen you should enter the fiducial or
-reseau photo-coordinates as given in the camera calibration report. The X,
-and Y coordinates are in milli-meters from the principle point.
-<P>
-<PRE>
- Fid# FID ID X Y
- 1__ _____ 0.0___ 0.0___
- 2__ _____ 0.0___ 0.0___
- 3__ _____ 0.0___ 0.0___
- 4__ _____ 0.0___ 0.0___
- 5__ _____ 0.0___ 0.0___
- 6__ _____ 0.0___ 0.0___
- 7__ _____ 0.0___ 0.0___
- 8__ _____ 0.0___ 0.0___
- 9__ _____ 0.0___ 0.0___
- 10_ _____ 0.0___ 0.0___
- next: end__
-</PRE>
-The input display is repeated until the number of MAXIMUM FIDUCIALS
-is reached.
-<H2>SEE ALSO</H2>
-<H2>AUTHOR</H2>
-</body>
-</html>
Copied: grass/trunk/imagery/i.ortho.photo/photo.camera/photo.camera.html (from rev 32770, grass/trunk/imagery/i.ortho.photo/photo.camera/description.html)
--- grass/trunk/imagery/i.ortho.photo/photo.camera/photo.camera.html (rev 0)
+++ grass/trunk/imagery/i.ortho.photo/photo.camera/photo.camera.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,126 @@
+<html>
+<head>
+<title></title>
+</head>
+<h2>NAME</h2>
+<em><b></b></em>
+<EM>photo.camera</EM> creates or modifies entries in a camera reference
+file. For ortho-photo rectification, a camera reference file is required for
+computation of scanned image to photo-coordinate transformation parameters.
+There are two coordinate systems: The image coordinate system (in pixels)
+and the photo coordinate system (in milli-meters). The inner orientation
+establishes a relation between the pixels and the image coordinates with
+help of fiducial marks.
+<P>
+The first prompt in the program will ask you for the name of
+the camera reference file to be created or modified. You may
+create a new camera reference file by entering a new name, or modify an
+existing camera reference file by entering the name of an existing camera file.
+<P>
+After entering the camera file name, following menu is displayed:
+<P>
+Please provide the following information
+<P>
+<PRE>
+ CAMERA NAME: <EM>camera name</EM>______
+ CAMERA IDENTIFICATION: <EM>identification</EM>___
+ CALIBRATED FOCAL LENGTH mm.:_________________
+ POINT OF SYMMETRY (X) mm.:_________________
+ POINT OF SYMMETRY (Y) mm.:_________________
+ MAXIMUM NUMBER OF FIDUCIALS:_________________
+ AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
+ (OR <Ctrl-C> TO CANCEL)
+</PRE>
+The camera name and identification describe the camera reference file.
+The calibrated focal length and the point of symmetry are used in computing
+the photo-to-target transformation parameters. These values should be entered
+from the camera calibration report (usually available from the photograph
+supplier).
+<p>
+<img src="photo.camera.png" alt="Sketch of aerial photo"><br>
+<i>This example is the camera Zeiss LMK9 265-002A belonging to the Hellenic
+Military Geographical Survey (HMGS) and calibrated in December 1985</i>
+<p>
+The photo coordinate system origin is the so-called calibrated principal
+point (PP, Principal Point of Symmetry) which is in the center of the image.
+The origin of the axes is at the intersection of the radii traced from the
+fiducial marks. In the ideal case of no deviations in the camera (see camera
+calibration certificate) the center is the origin and the values are 0 for
+both X and Y of Point of Symmetry. But usually the principal point does not
+fall on the intersection of the radii at the center of the picture. This
+excentricity is usually of the order of a few micrometers. <P>
+You are then asked to enter the X and Y photo coordinates of each fiducial
+as follows.
+These fiducials (or reseau) marks are index marks imaged on film which serve
+as reference photo coordinate system. The maximum number of fiducials will
+determine the number of fiducial or reseau coordinate pairs to be entered
+below. The origin is the center of the image (or the point of symmetry) and
+X and Y are left-right and up-down. The order is up to the user, but must be
+kept consistent throughout the rectification process.
+<P>
+On this screen you should enter the fiducial or
+reseau photo-coordinates as given in the camera calibration report. The X,
+and Y coordinates are in milli-meters from the principle point.
+<P>
+<PRE>
+ Fid# FID ID X Y
+ 1__ _____ 0.0___ 0.0___
+ 2__ _____ 0.0___ 0.0___
+ 3__ _____ 0.0___ 0.0___
+ 4__ _____ 0.0___ 0.0___
+ 5__ _____ 0.0___ 0.0___
+ 6__ _____ 0.0___ 0.0___
+ 7__ _____ 0.0___ 0.0___
+ 8__ _____ 0.0___ 0.0___
+ 9__ _____ 0.0___ 0.0___
+ 10_ _____ 0.0___ 0.0___
+ next: end__
+</PRE>
+The input display is repeated until the number of MAXIMUM FIDUCIALS
+is reached.
+<H2>SEE ALSO</H2>
+<H2>AUTHOR</H2>
+</body>
+</html>
Modified: grass/trunk/imagery/i.ortho.photo/photo.init/Makefile
--- grass/trunk/imagery/i.ortho.photo/photo.init/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.init/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -11,6 +11,6 @@
default: etc
Deleted: grass/trunk/imagery/i.ortho.photo/photo.init/description.html
--- grass/trunk/imagery/i.ortho.photo/photo.init/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.init/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,127 +0,0 @@
-<html>
-<head>
-<title>photo.init</title>
-</head>
-<h2>NAME</h2>
-<em><b>photo.init</b></em>
-Aerial photographs may be either vertical or oblique. Vertical photographs
-can be truly vertical (nadir), or slightly tilted (less than 3 degree
-from the vertical). Usually aerial photos are tilted to some degree. We
-refer to the term <i>vertical photograph</i> up to a tilt of 3 degree.
-<br>
-Oblique aerial photographs are purposely taken with an
-angle between 3 and 90 degree from the nadir direction.
-<P>
-<b>The use of <EM>photo.init</EM> (menu 6) is only required when rectifying a
-tilted or oblique aerial photo.</b>
-<P>
-<EM>photo.init</EM> creates or modifies entries in a camera initial exposure
-station file for imagery group referenced by a sub-block. These entries
-include: the (XC,YC,ZC) standard (e.g. UTM) approximate coordinates of the camera exposure
-station; initial roll, pitch, and yaw angles (in degrees) of the cameras
-attitude; and the <EM>a priori</EM> standard deviations for these
-parameters. During the imagery program, photo.rectify, the initial camera
-exposure station file is used for computation of the ortho-rectification
-parameters. If no initial camera exposure station file exist, the default
-values are computed from the control points file created in <EM><A
-HREF="photo.2target.html">photo.2target</A></EM>.
-<P>
-The following menu is displayed:
-<PRE>
- Please provide the following information
- INITIAL XC: Meters __________
- INITIAL YC: Meters __________
- INITIAL ZC: Meters __________
- INITIAL omega (roll) degrees: __________
- INITIAL phi (pitch) degrees: __________
- INITIAL kappa (yaw) degrees: __________
- Standard Deviation XC: Meters __________
- Standard Deviation YC: Meters __________
- Standard Deviation ZC: Meters __________
- Std. Dev. omega (roll) degrees: __________
- Std. Dev. phi (pitch) degrees: __________
- Std. Dev. kappa (yaw) degrees: __________
- Use these values at run time? (1=yes, 0=no)
-</PRE>
-<P>
-The INITIAL values for (XC,YC,ZC) are expressed in standard (e.g. UTM) coordinates, and
-represent an approximation for the location of the camera at the time of
-exposure.
-<ul>
-<li> X: East aircraft position;
-<li> Y: North aircraft position;
-<li> Z: Flight altitude above sea level
-</ul>
-<P>
-The INITIAL values for (omega,phi,kappa) are expressed in degrees, and
-represent an approximation for the cameras attitude at the time of
-exposure.
-<ul>
-<li> Omega (roll): Raising or lowering of the wings (turning around the
- aircraft's axis);
-<li> Phi (pitch): Raising or lowering of the aircraft's front (turning
- around the wings' axis);
-<li> Kappa (yaw): Rotation needed to align the aerial photo to true north:
- needs to be denoted as +90 degree for clockwise turn and -90 degree for
- a counterclockwise turn.
-</ul>
-<P>
-The standard deviations for (XC,YC,ZC) are expressed in meters, and
-are used as <EM>a priori</EM> values for the standard deviations used in
-computation of the ortho rectification parameters.
-<P>
-The standard deviations for (omega,phi,kappa) are expressed in degrees, and
-<P>
-If <i>Use these values at run time? (1=yes, 0=no)</i> is set to 0, the
-values in this menu are not used.
-<H2>SEE ALSO</H2>
-<H2>AUTHOR</H2>
-</body>
-</html>
Copied: grass/trunk/imagery/i.ortho.photo/photo.init/photo.init.html (from rev 32770, grass/trunk/imagery/i.ortho.photo/photo.init/description.html)
--- grass/trunk/imagery/i.ortho.photo/photo.init/photo.init.html (rev 0)
+++ grass/trunk/imagery/i.ortho.photo/photo.init/photo.init.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,127 @@
+<html>
+<head>
+<title>photo.init</title>
+</head>
+<h2>NAME</h2>
+<em><b>photo.init</b></em>
+Aerial photographs may be either vertical or oblique. Vertical photographs
+can be truly vertical (nadir), or slightly tilted (less than 3 degree
+from the vertical). Usually aerial photos are tilted to some degree. We
+refer to the term <i>vertical photograph</i> up to a tilt of 3 degree.
+<br>
+Oblique aerial photographs are purposely taken with an
+angle between 3 and 90 degree from the nadir direction.
+<P>
+<b>The use of <EM>photo.init</EM> (menu 6) is only required when rectifying a
+tilted or oblique aerial photo.</b>
+<P>
+<EM>photo.init</EM> creates or modifies entries in a camera initial exposure
+station file for imagery group referenced by a sub-block. These entries
+include: the (XC,YC,ZC) standard (e.g. UTM) approximate coordinates of the camera exposure
+station; initial roll, pitch, and yaw angles (in degrees) of the cameras
+attitude; and the <EM>a priori</EM> standard deviations for these
+parameters. During the imagery program, photo.rectify, the initial camera
+exposure station file is used for computation of the ortho-rectification
+parameters. If no initial camera exposure station file exist, the default
+values are computed from the control points file created in <EM><A
+HREF="photo.2target.html">photo.2target</A></EM>.
+<P>
+The following menu is displayed:
+<PRE>
+ Please provide the following information
+ INITIAL XC: Meters __________
+ INITIAL YC: Meters __________
+ INITIAL ZC: Meters __________
+ INITIAL omega (roll) degrees: __________
+ INITIAL phi (pitch) degrees: __________
+ INITIAL kappa (yaw) degrees: __________
+ Standard Deviation XC: Meters __________
+ Standard Deviation YC: Meters __________
+ Standard Deviation ZC: Meters __________
+ Std. Dev. omega (roll) degrees: __________
+ Std. Dev. phi (pitch) degrees: __________
+ Std. Dev. kappa (yaw) degrees: __________
+ Use these values at run time? (1=yes, 0=no)
+</PRE>
+<P>
+The INITIAL values for (XC,YC,ZC) are expressed in standard (e.g. UTM) coordinates, and
+represent an approximation for the location of the camera at the time of
+exposure.
+<ul>
+<li> X: East aircraft position;
+<li> Y: North aircraft position;
+<li> Z: Flight altitude above sea level
+</ul>
+<P>
+The INITIAL values for (omega,phi,kappa) are expressed in degrees, and
+represent an approximation for the cameras attitude at the time of
+exposure.
+<ul>
+<li> Omega (roll): Raising or lowering of the wings (turning around the
+ aircraft's axis);
+<li> Phi (pitch): Raising or lowering of the aircraft's front (turning
+ around the wings' axis);
+<li> Kappa (yaw): Rotation needed to align the aerial photo to true north:
+ needs to be denoted as +90 degree for clockwise turn and -90 degree for
+ a counterclockwise turn.
+</ul>
+<P>
+The standard deviations for (XC,YC,ZC) are expressed in meters, and
+are used as <EM>a priori</EM> values for the standard deviations used in
+computation of the ortho rectification parameters.
+<P>
+The standard deviations for (omega,phi,kappa) are expressed in degrees, and
+<P>
+If <i>Use these values at run time? (1=yes, 0=no)</i> is set to 0, the
+values in this menu are not used.
+<H2>SEE ALSO</H2>
+<H2>AUTHOR</H2>
+</body>
+</html>
Modified: grass/trunk/imagery/i.ortho.photo/photo.rectify/Makefile
--- grass/trunk/imagery/i.ortho.photo/photo.rectify/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.rectify/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -13,6 +13,6 @@
default: etc
Deleted: grass/trunk/imagery/i.ortho.photo/photo.rectify/description.html
--- grass/trunk/imagery/i.ortho.photo/photo.rectify/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.ortho.photo/photo.rectify/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,88 +0,0 @@
-<html>
-<head>
-<title>photo.rectify</title>
-</head>
-<h2>NAME</h2>
-<em><b>photo.rectify</b></em>
-<EM>photo.rectify</EM> rectifies an image by using the image to photo
-coordinate transformation matrix created by <A HREF="photo.2image.html">photo.2image</A>
-and the rectification parameters created by <A HREF="photo.2target.html">photo.2target</A>.
-Rectification is the process by which the geometry of an image is made
-planimetric. This is accomplished by mapping an image from one coordinate
-system to another. In photo.rectify the parameters computed by
-<A HREF="photo.2image.html">photo.2image</A> and
-<A HREF="photo.2target.html">photo.2target</A> are used in equations to
-convert x,y image coordinates to standard map coordinates for each pixel in
-the image. The result is an image with a standard map coordinate system,
-compensated for relief distortions and photographic tilt. Upon completion of
-the program the rectified image is deposited in a previously targeted GRASS
-LOCATION.
-<P> You are asked to select the file(s) within the imagery group
-to be rectified:
-<P> Please select the file(s) to rectify by naming an
-output file <P> <PRE>
- gs13.1 in PERMANENT gs13.orect...
- gs14.1 in PERMANENT .............
- (enter list by any name to get a list of existing raster maps)
-</PRE>
-<P>
-<P>
-More than one file may be rectified at a time. Each file
-should have a unique output file name.
-<P>
-The next prompt asks you to select one of two windows:
-<P>
-<PRE>
- Please select one of the following options
- 1. Use the current window in the target location
- 2. Determine the smallest window which covers the image
-</PRE>
-<P>
-<EM>photo.rectify</EM> will only rectify that portion of the
-image that occurs within the chosen window. Only that portion will be
-relocated in the target database. It is therefore important to check the
-current window in the target LOCATION if choice number one is selected.
-<P>
-The process may take an hour or more depending on the size of the image,
-the speed of the computer, the number files, and the size and resolution
-of the selected window.
-<P>
-The rectified image will be located in the target LOCATION when the program
-is completed. The original unrectified files are not modified or removed.
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="i.ortho.photo.html">i.ortho.photo</A><br>
-<A HREF="photo.camera.html">photo.camera</A><br>
-<A HREF="photo.2image.html">photo.2image</A><br>
-<A HREF="photo.2target.html">photo.2target</A><br>
-</EM>
-<H2>AUTHOR</H2>
-Mike Baba, DBA Systems, Inc.<br>
-Updated rectification and elevation map to FP 1/2002 Markus Neteler
-</body>
-</html>
Copied: grass/trunk/imagery/i.ortho.photo/photo.rectify/photo.rectify.html (from rev 32770, grass/trunk/imagery/i.ortho.photo/photo.rectify/description.html)
--- grass/trunk/imagery/i.ortho.photo/photo.rectify/photo.rectify.html (rev 0)
+++ grass/trunk/imagery/i.ortho.photo/photo.rectify/photo.rectify.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,88 @@
+<html>
+<head>
+<title>photo.rectify</title>
+</head>
+<h2>NAME</h2>
+<em><b>photo.rectify</b></em>
+<EM>photo.rectify</EM> rectifies an image by using the image to photo
+coordinate transformation matrix created by <A HREF="photo.2image.html">photo.2image</A>
+and the rectification parameters created by <A HREF="photo.2target.html">photo.2target</A>.
+Rectification is the process by which the geometry of an image is made
+planimetric. This is accomplished by mapping an image from one coordinate
+system to another. In photo.rectify the parameters computed by
+<A HREF="photo.2image.html">photo.2image</A> and
+<A HREF="photo.2target.html">photo.2target</A> are used in equations to
+convert x,y image coordinates to standard map coordinates for each pixel in
+the image. The result is an image with a standard map coordinate system,
+compensated for relief distortions and photographic tilt. Upon completion of
+the program the rectified image is deposited in a previously targeted GRASS
+LOCATION.
+<P> You are asked to select the file(s) within the imagery group
+to be rectified:
+<P> Please select the file(s) to rectify by naming an
+output file <P> <PRE>
+ gs13.1 in PERMANENT gs13.orect...
+ gs14.1 in PERMANENT .............
+ (enter list by any name to get a list of existing raster maps)
+</PRE>
+<P>
+<P>
+More than one file may be rectified at a time. Each file
+should have a unique output file name.
+<P>
+The next prompt asks you to select one of two windows:
+<P>
+<PRE>
+ Please select one of the following options
+ 1. Use the current window in the target location
+ 2. Determine the smallest window which covers the image
+</PRE>
+<P>
+<EM>photo.rectify</EM> will only rectify that portion of the
+image that occurs within the chosen window. Only that portion will be
+relocated in the target database. It is therefore important to check the
+current window in the target LOCATION if choice number one is selected.
+<P>
+The process may take an hour or more depending on the size of the image,
+the speed of the computer, the number files, and the size and resolution
+of the selected window.
+<P>
+The rectified image will be located in the target LOCATION when the program
+is completed. The original unrectified files are not modified or removed.
+<H2>SEE ALSO</H2>
+<EM>
+<A HREF="i.ortho.photo.html">i.ortho.photo</A><br>
+<A HREF="photo.camera.html">photo.camera</A><br>
+<A HREF="photo.2image.html">photo.2image</A><br>
+<A HREF="photo.2target.html">photo.2target</A><br>
+</EM>
+<H2>AUTHOR</H2>
+Mike Baba, DBA Systems, Inc.<br>
+Updated rectification and elevation map to FP 1/2002 Markus Neteler
+</body>
+</html>
Deleted: grass/trunk/imagery/i.pca/description.html
--- grass/trunk/imagery/i.pca/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.pca/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,85 +0,0 @@
-<EM>i.pca</EM> is an image processing program based on the
-algorithm provided by Vali (1990), that processes n (2
->= n) input raster map layers and produces n output
-raster map layers containing the principal components of
-the input data in decreasing order of variance
-("contrast"). The output raster map layers are assigned
-names with .1, .2, ... .n suffixes. The current geographic
-region definition and mask settings are respected when
-reading the input raster map layers. When the rescale
-option is used, the output files are rescaled to fit the
-min,max range.
-<H2>OPTIONS</H2>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>input=</B><EM>name,name</EM>[<EM>,name,name</EM>,...]
-<DD>Name of two or more input raster map layers.
-<DT><B>output=</B><EM>name</EM>
-<DD>The output raster map layer name to which suffixes are
-added. Each output raster map layer is assigned this
-user-specified <EM>name</EM> with a numerical (.1, .2, ...
-.n) suffix.
-<DT><B>rescale=</B><EM>min,max</EM>
-<DD>The optional output category range. (Default: 0,255) If
-rescale=0,0, no rescaling is performed on output files.
-<DD>If output is rescaled, the output raster will be of type CELL. If
-the output is not rescaled, the output raster will be of type DCELL.
-</DL>
-<H2>NOTES</H2>
-Richards (1986) gives a good example of the application of principal
-components analysis (pca) to a time series of LANDSAT images of a burned
-region in Australia.
-<H2>SEE ALSO</H2>
-Richards, John A.,
-<B>Remote Sensing Digital Image Analysis</B>,
-Springer-Verlag, 1986.
-<P>
-Vali, Ali R.,
-Personal communication,
-Space Research Center,
-University of Texas, Austin, 1990.
-<P>
-<EM><A HREF="i.cca.html">i.cca</A></EM><br>
-<EM><A HREF="i.class.html">i.class</A></EM><br>
-<EM><A HREF="i.fft.html">i.fft</A></EM><br>
-<EM><A HREF="i.ifft.html">i.ifft</A></EM><br>
-<EM><A HREF="m.eigensystem.html">m.eigensystem</A></EM><br>
-<EM><A HREF="r.covar.html">r.covar</A></EM><br>
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>
-<H2>AUTHOR</H2>
-David Satnik, GIS Laboratory
-<p>
-Major modifications for GRASS 4.1 were made by <br>
-Olga Waupotitsch and
-Michael Shapiro,
-U.S.Army Construction Engineering
-Research Laboratory
-<p>
-Rewritten for GRASS 6.x and major modifications by <br>
-Brad Douglas
Copied: grass/trunk/imagery/i.pca/i.pca.html (from rev 32770, grass/trunk/imagery/i.pca/description.html)
--- grass/trunk/imagery/i.pca/i.pca.html (rev 0)
+++ grass/trunk/imagery/i.pca/i.pca.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,85 @@
+<EM>i.pca</EM> is an image processing program based on the
+algorithm provided by Vali (1990), that processes n (2
+>= n) input raster map layers and produces n output
+raster map layers containing the principal components of
+the input data in decreasing order of variance
+("contrast"). The output raster map layers are assigned
+names with .1, .2, ... .n suffixes. The current geographic
+region definition and mask settings are respected when
+reading the input raster map layers. When the rescale
+option is used, the output files are rescaled to fit the
+min,max range.
+<H2>OPTIONS</H2>
+<H3>Parameters:</H3>
+<DL>
+<DT><B>input=</B><EM>name,name</EM>[<EM>,name,name</EM>,...]
+<DD>Name of two or more input raster map layers.
+<DT><B>output=</B><EM>name</EM>
+<DD>The output raster map layer name to which suffixes are
+added. Each output raster map layer is assigned this
+user-specified <EM>name</EM> with a numerical (.1, .2, ...
+.n) suffix.
+<DT><B>rescale=</B><EM>min,max</EM>
+<DD>The optional output category range. (Default: 0,255) If
+rescale=0,0, no rescaling is performed on output files.
+<DD>If output is rescaled, the output raster will be of type CELL. If
+the output is not rescaled, the output raster will be of type DCELL.
+</DL>
+<H2>NOTES</H2>
+Richards (1986) gives a good example of the application of principal
+components analysis (pca) to a time series of LANDSAT images of a burned
+region in Australia.
+<H2>SEE ALSO</H2>
+Richards, John A.,
+<B>Remote Sensing Digital Image Analysis</B>,
+Springer-Verlag, 1986.
+<P>
+Vali, Ali R.,
+Personal communication,
+Space Research Center,
+University of Texas, Austin, 1990.
+<P>
+<EM><A HREF="i.cca.html">i.cca</A></EM><br>
+<EM><A HREF="i.class.html">i.class</A></EM><br>
+<EM><A HREF="i.fft.html">i.fft</A></EM><br>
+<EM><A HREF="i.ifft.html">i.ifft</A></EM><br>
+<EM><A HREF="m.eigensystem.html">m.eigensystem</A></EM><br>
+<EM><A HREF="r.covar.html">r.covar</A></EM><br>
+<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>
+<H2>AUTHOR</H2>
+David Satnik, GIS Laboratory
+<p>
+Major modifications for GRASS 4.1 were made by <br>
+Olga Waupotitsch and
+Michael Shapiro,
+U.S.Army Construction Engineering
+Research Laboratory
+<p>
+Rewritten for GRASS 6.x and major modifications by <br>
+Brad Douglas
Deleted: grass/trunk/imagery/i.points/description.html
--- grass/trunk/imagery/i.points/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.points/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,424 +0,0 @@
-<EM>i.points</EM> is an
-<A HREF="imagery.html">imagery</A> function that enables
-the user to mark points on a (raster) image to be rectified
-and then input the geographic coordinates of each point for
-calculation of a coordinate transformation matrix.
-<EM>i.points</EM> must be followed by use of the GRASS
-program <EM><A HREF="i.rectify.html">i.rectify</A></EM>, which
-rectifies the image using the transformation matrix
-coefficients calculated by <EM>i.points</EM>.
-<P>
-<EM>Rectification</EM> is the mapping (transformation) of
-an image from one coordinate system to another. The
-geometry of an image extracted into a GRASS LOCATION having
-an x,y coordinate system is not planimetric. To create a
-planimetric image, that is, to convert the x,y coordinate
-system into a standard coordinate system (for example, the
-UTM coordinate system or the State Plane coordinate
-system), points from a map having the standard coordinates
-must be associated with the same points on the image to be
-rectified. <EM>i.points</EM> enables the user to mark
-points on an image and input the standard coordinates for
-that point. <EM>i.points</EM> then calculates a least
-squares regression using the two coordinate systems (x,y
-and standard) for the marked points. A matrix containing
-transformation coefficients is the output file for
-<EM>i.points</EM>.
-<P>
-During the process of marking points and entering map
-coordinates, the user can compute the RMS (root mean
-square) error for each point entered. <EM>i.points</EM>
-does this by calculating the transformation equation (the
-same one that is calculated in the GRASS program <EM>
-<A HREF="i.rectify.html">i.rectify</A></EM>), and then
-<P>
-<EM>i.points</EM> offers a zoom option to locate precisely
-the point to be marked on an image. This program also
-offers the user the option of acquiring standard
-coordinates for a marked point from a map layer in the
-target data base.
-<P>
-<EM><A HREF="i.target.html">i.target</A></EM> must be
-run before running <EM>i.points</EM> to enable the PLOT
-RASTER option to be used and to identify a target data base
-LOCATION_NAME and MAPSET for the rectified image. To run
-<EM>i.points</EM>, a graphics monitor is required.
-<P>
-calculating RMS error is described below.
-<P>
-The first prompt in the program asks the user for the
-<A HREF="i.group.html">imagery group</A> to be
-registered. Note that if
-<EM><A HREF="i.target.html">i.target</A></EM> is not run
-before <EM>i.points</EM>, the <EM>i.points</EM> program
-will display the following error message:
-<PRE>
-ERROR: Target information for group [spot] missing
- Please run i.target for group [spot]
-</PRE>
-After entering the group to be registered the terminal screen
-displays the message:
-<PRE>
- Use mouse now...
-</PRE>
-The graphics monitor displays the following screen:
-<PRE>
- ______________________________________________________________
-| imagery filename (mag) | target filename (mag) |
-|_________________________________|___________________________|
-| QUIT ZOOM PLOT RASTER ANALYZE| |
-</PRE>
-A pop-down menu like that shown below will be superimposed on the
-left half of the screen:
-<PRE>
- | Double click on raster map layer|
- | to be plotted |
- | Double click here to cancel |
- |_________________________________|
- | Mapset demo |
- |___________________|
- | spotclass| spot.1|
- |__________|________|
- | composite| spot.2|
- | spot.3 | |
-</PRE>
-Any single raster map layer in the
-<A HREF="i.group.html">imagery group</A> may be used on
-which to mark points, and the user can mark points on more
-than one raster map layer in the
-<A HREF="i.group.html">imagery group</A> to accumulate the
-suggested minimum number of 12 points. Any raster map
-layer in the <A HREF="i.group.html">imagery group</A>
-can be rectified (using
-<EM><A HREF="i.rectify.html">i.rectify</A></EM>) based on the
-transformation matrix computed from these points.
-<P>
-The imagery file chosen by
-the user is displayed in the upper left quadrant of the
-screen.
-<H3>ZOOM</H3>
-To magnify the displayed file, the user must
-place the mouse cross hairs on the word ZOOM. The following menu
-will then be displayed at the bottom of the screen:
-<PRE>
- | Cancel| Box| Point| Select type of ZOOM|
- |_______|_____|_______|_____________________|
-</PRE>
-The user has the option of identifying the zoom region
-either by using the mouse to make a box, or by using the
-mouse to mark the two diagonal points of the desired
-region. The terminal screen will display a mouse button
-menu to guide the user in identifying the corner points of
-the region.
-<H3>MARKING POINTS</H3>
-points on a standard coordinate system map, the user must
-place the mouse cross hairs on the corresponding location
-on the image to be marked and press the left hand button on
-the mouse. A diamond shaped symbol will be marked on the
-image. The user's terminal will display the following
-menu:
-<PRE>
-| Point 1 marked on the image at| |
-| East: 1023.77 | |
-| North: -164.41 | |
-|__________________________________________________________|
-| Enter coordinates as east north: |
-</PRE>
-The user then enters the easting and northing (separated by
-a space) for the point marked on the image. If the user
-wishes not to enter a coordinate, he or she may simply hit
-RETURN to return control to the mouse; the marked point
-then disappears.
-<H3>PLOT RASTER</H3>
-In addition to acquiring reference points from a standard
-map, the user has the option of acquiring the reference
-points from a raster map layer in the target data base
-LOCATION_NAME. The data base raster map layer is displayed
-by placing the mouse cross hairs on the words PLOT RASTER.
-The following line is then displayed at the bottom of the
-graphics monitor:
-<PRE>
- | Cancel| Indicate which side should be plotted|
- |_______|_______________________________________|
-</PRE>
-Which side of the graphics monitor is to be plotted
-half of the graphics monitor screen that the user would like to use,
-menu will be superimposed on the half of the screen that was chosen:
-<PRE>
- | Double click on raster (cell) map layer|
- | to be plotted |
- |________________________________________|
- | Mapset demo |
- |_____________________________|
- | tm.rectified | |
- |______________|______________|
- | tm.classified| |
- | elevation | geology |
- | slope | soils |
- | aspect | |
- | roads | |
-</PRE>
-After the raster map layer is displayed the following message appears
-at the bottom of the graphics monitor:
-<PRE>
- | input method -->| keyboard| screen|
- |_________________|__________|________|
-</PRE>
-If the user wishes to use the plotted raster map layer only
-as a comparative reference, then the keyboard can be chosen
-as the means to input coordinates corresponding to the
-marked points on the image. This is done by placing the
-mouse cross hairs on the word KEYBOARD and pressing the
-left button on the mouse.
-<P>
-If the user selects the SCREEN option, then points marked
-on the image will automatically be associated with the
-data base map layer. In this option, when the user marks a
-point on the image, the following menu is displayed at the
-terminal:
-<PRE>
-___________________________________________________________
-| Point 5 marked on the image at| |
-| Point located at | |
-| East: 679132.57 | |
-| North: 4351080.67 | |
-| use mouse now... |
-</PRE>
-The user then uses the mouse to mark a corresponding point
-on the displayed image from the target data base. The
-coordinates for the target data base map layer are
-automatically saved as the coordinates corresponding to the
-marked point on the image.
-<H3>ANALYZE</H3>
-After a number of points have been marked (4 to 7), the
-user can check the RMS error of the points marked on the
-image. This is done by placing the mouse cross hairs on
-the word ANALYZE at the bottom of the graphics monitor. An
-error report resembling that shown below is superimposed on
-the graphics monitor:
-<PRE>
-______________________________________________________________________
-| error image target |
-|# row col target east north east north |
-|____________________________________________________________________|
-|1 0.0 -0.9 1.0 1048.5 -144.8 679132.5 4351080.6|
-|2 0.4 1.0 1.3 2153.1 -567.2 684314.7 4399001.4|
-|3 -1.2 -0.5 .6 1452.8 -476.5 567841.4 3457682.8|
-|4 1.1 0.5 1.3 1034.0 -109.2 677573.8 4352626.4|
-|5 -2.7 14.0 14.2 1048.6 -144.9 679132.6 4351080.7|
-| overall rms error: 4.46 |
-</PRE>
-The following menu then appears at the bottom of the graphics monitor:
-<PRE>
- ____________________________________________________________________
-| DONE| PRINT FILE| Double click on point to be included/excluded|
-|_____|____________|________________________________________________|
-</PRE>
-TITLEd "error" and subTITLEd "row" and "col". In the above
-report, point number 1 is 0.0 rows and -0.9 columns from
-the predicted location calculated from the transformation
-equation. The RMS error for the target raster map layer is
-listed under the heading "target". This is the RMS error
-for the east and north coordinates of the target map layer,
-but it is presented in the table using one general value.
-screen in meters. Points that create high RMS error are
-displayed in red on the graphics monitor (represented here
-in italics).
-<P>
-The location of the point marked on the
-<A HREF="i.group.html">imagery group</A> file is given
-under the heading "image" and the subheadings "east" and
-"north". The location of the point in the target data base
-is given under the heading "target" and the subheadings
-"east" and "north". If the user would like to exclude or
-include a point, this can be accomplished by placing the
-mouse cross hairs on the point number to be included (if
-the point is absent) or excluded (if the point is
-displayed) and pressing the left button on the mouse
-twice. When a point is excluded, it is not afterwards
-included in the calculation of the RMS error, or included
-in the final transformation matrix. However, it can be
-retrieved within <EM>i.points</EM> at any time by double
-clicking with the mouse as described above.
-<H3>QUIT</H3>
-To end the <EM>i.points</EM> program place the mouse cross
-hairs on the word QUIT; the marked points (including
-coordinates) will be saved.
-<H2>NOTES</H2>
-which are evenly distributed over the entire
-<A HREF="i.group.html">imagery group</A> file in order to
-obtain an accurate transformation equation for the
-rectification process. The RMS error may increase with
-more points added, but the transformation equation will be
-more accurate.
-<P>
-An RMS error of less than or equal to approximately one
-resolution unit (pixel or cell) for the image being
-rectified is generally considered acceptable.
-<P>
-In order to use a digitizer with <EM>i.points</EM>, at
-least one digitizer driver besides "none" (the on-screen
-digitizer) must be available in the digitcap file.
-<P>
-This program is interactive.
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<A HREF="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
-Processing manual</A></EM>
-<P>
-<EM>
-<A HREF="g.mapsets.html">g.mapsets</A><br>
-<A HREF="i.group.html">i.group</A><br>
-<A HREF="i.rectify.html">i.rectify</A><br>
-<A HREF="i.target.html">i.target</A><br>
-<A HREF="i.vpoints.html">i.vpoints</A>
-</EM><br>
-<em><a href="gm_georect.html">gis.m: GEORECTIFY TOOL</a></em>
-<H2>AUTHOR</H2>
-Michael Shapiro,
-U.S.Army Construction Engineering Research Laboratory
-<p>
-<i>Last changed: $Date$</i></p>
Copied: grass/trunk/imagery/i.points/i.points.html (from rev 32770, grass/trunk/imagery/i.points/description.html)
--- grass/trunk/imagery/i.points/i.points.html (rev 0)
+++ grass/trunk/imagery/i.points/i.points.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,424 @@
+<EM>i.points</EM> is an
+<A HREF="imagery.html">imagery</A> function that enables
+the user to mark points on a (raster) image to be rectified
+and then input the geographic coordinates of each point for
+calculation of a coordinate transformation matrix.
+<EM>i.points</EM> must be followed by use of the GRASS
+program <EM><A HREF="i.rectify.html">i.rectify</A></EM>, which
+rectifies the image using the transformation matrix
+coefficients calculated by <EM>i.points</EM>.
+<P>
+<EM>Rectification</EM> is the mapping (transformation) of
+an image from one coordinate system to another. The
+geometry of an image extracted into a GRASS LOCATION having
+an x,y coordinate system is not planimetric. To create a
+planimetric image, that is, to convert the x,y coordinate
+system into a standard coordinate system (for example, the
+UTM coordinate system or the State Plane coordinate
+system), points from a map having the standard coordinates
+must be associated with the same points on the image to be
+rectified. <EM>i.points</EM> enables the user to mark
+points on an image and input the standard coordinates for
+that point. <EM>i.points</EM> then calculates a least
+squares regression using the two coordinate systems (x,y
+and standard) for the marked points. A matrix containing
+transformation coefficients is the output file for
+<EM>i.points</EM>.
+<P>
+During the process of marking points and entering map
+coordinates, the user can compute the RMS (root mean
+square) error for each point entered. <EM>i.points</EM>
+does this by calculating the transformation equation (the
+same one that is calculated in the GRASS program <EM>
+<A HREF="i.rectify.html">i.rectify</A></EM>), and then
+<P>
+<EM>i.points</EM> offers a zoom option to locate precisely
+the point to be marked on an image. This program also
+offers the user the option of acquiring standard
+coordinates for a marked point from a map layer in the
+target data base.
+<P>
+<EM><A HREF="i.target.html">i.target</A></EM> must be
+run before running <EM>i.points</EM> to enable the PLOT
+RASTER option to be used and to identify a target data base
+LOCATION_NAME and MAPSET for the rectified image. To run
+<EM>i.points</EM>, a graphics monitor is required.
+<P>
+calculating RMS error is described below.
+<P>
+The first prompt in the program asks the user for the
+<A HREF="i.group.html">imagery group</A> to be
+registered. Note that if
+<EM><A HREF="i.target.html">i.target</A></EM> is not run
+before <EM>i.points</EM>, the <EM>i.points</EM> program
+will display the following error message:
+<PRE>
+ERROR: Target information for group [spot] missing
+ Please run i.target for group [spot]
+</PRE>
+After entering the group to be registered the terminal screen
+displays the message:
+<PRE>
+ Use mouse now...
+</PRE>
+The graphics monitor displays the following screen:
+<PRE>
+ ______________________________________________________________
+| imagery filename (mag) | target filename (mag) |
+|_________________________________|___________________________|
+| QUIT ZOOM PLOT RASTER ANALYZE| |
+</PRE>
+A pop-down menu like that shown below will be superimposed on the
+left half of the screen:
+<PRE>
+ | Double click on raster map layer|
+ | to be plotted |
+ | Double click here to cancel |
+ |_________________________________|
+ | Mapset demo |
+ |___________________|
+ | spotclass| spot.1|
+ |__________|________|
+ | composite| spot.2|
+ | spot.3 | |
+</PRE>
+Any single raster map layer in the
+<A HREF="i.group.html">imagery group</A> may be used on
+which to mark points, and the user can mark points on more
+than one raster map layer in the
+<A HREF="i.group.html">imagery group</A> to accumulate the
+suggested minimum number of 12 points. Any raster map
+layer in the <A HREF="i.group.html">imagery group</A>
+can be rectified (using
+<EM><A HREF="i.rectify.html">i.rectify</A></EM>) based on the
+transformation matrix computed from these points.
+<P>
+The imagery file chosen by
+the user is displayed in the upper left quadrant of the
+screen.
+<H3>ZOOM</H3>
+To magnify the displayed file, the user must
+place the mouse cross hairs on the word ZOOM. The following menu
+will then be displayed at the bottom of the screen:
+<PRE>
+ | Cancel| Box| Point| Select type of ZOOM|
+ |_______|_____|_______|_____________________|
+</PRE>
+The user has the option of identifying the zoom region
+either by using the mouse to make a box, or by using the
+mouse to mark the two diagonal points of the desired
+region. The terminal screen will display a mouse button
+menu to guide the user in identifying the corner points of
+the region.
+<H3>MARKING POINTS</H3>
+points on a standard coordinate system map, the user must
+place the mouse cross hairs on the corresponding location
+on the image to be marked and press the left hand button on
+the mouse. A diamond shaped symbol will be marked on the
+image. The user's terminal will display the following
+menu:
+<PRE>
+| Point 1 marked on the image at| |
+| East: 1023.77 | |
+| North: -164.41 | |
+|__________________________________________________________|
+| Enter coordinates as east north: |
+</PRE>
+The user then enters the easting and northing (separated by
+a space) for the point marked on the image. If the user
+wishes not to enter a coordinate, he or she may simply hit
+RETURN to return control to the mouse; the marked point
+then disappears.
+<H3>PLOT RASTER</H3>
+In addition to acquiring reference points from a standard
+map, the user has the option of acquiring the reference
+points from a raster map layer in the target data base
+LOCATION_NAME. The data base raster map layer is displayed
+by placing the mouse cross hairs on the words PLOT RASTER.
+The following line is then displayed at the bottom of the
+graphics monitor:
+<PRE>
+ | Cancel| Indicate which side should be plotted|
+ |_______|_______________________________________|
+</PRE>
+Which side of the graphics monitor is to be plotted
+half of the graphics monitor screen that the user would like to use,
+menu will be superimposed on the half of the screen that was chosen:
+<PRE>
+ | Double click on raster (cell) map layer|
+ | to be plotted |
+ |________________________________________|
+ | Mapset demo |
+ |_____________________________|
+ | tm.rectified | |
+ |______________|______________|
+ | tm.classified| |
+ | elevation | geology |
+ | slope | soils |
+ | aspect | |
+ | roads | |
+</PRE>
+After the raster map layer is displayed the following message appears
+at the bottom of the graphics monitor:
+<PRE>
+ | input method -->| keyboard| screen|
+ |_________________|__________|________|
+</PRE>
+If the user wishes to use the plotted raster map layer only
+as a comparative reference, then the keyboard can be chosen
+as the means to input coordinates corresponding to the
+marked points on the image. This is done by placing the
+mouse cross hairs on the word KEYBOARD and pressing the
+left button on the mouse.
+<P>
+If the user selects the SCREEN option, then points marked
+on the image will automatically be associated with the
+data base map layer. In this option, when the user marks a
+point on the image, the following menu is displayed at the
+terminal:
+<PRE>
+___________________________________________________________
+| Point 5 marked on the image at| |
+| Point located at | |
+| East: 679132.57 | |
+| North: 4351080.67 | |
+| use mouse now... |
+</PRE>
+The user then uses the mouse to mark a corresponding point
+on the displayed image from the target data base. The
+coordinates for the target data base map layer are
+automatically saved as the coordinates corresponding to the
+marked point on the image.
+<H3>ANALYZE</H3>
+After a number of points have been marked (4 to 7), the
+user can check the RMS error of the points marked on the
+image. This is done by placing the mouse cross hairs on
+the word ANALYZE at the bottom of the graphics monitor. An
+error report resembling that shown below is superimposed on
+the graphics monitor:
+<PRE>
+______________________________________________________________________
+| error image target |
+|# row col target east north east north |
+|____________________________________________________________________|
+|1 0.0 -0.9 1.0 1048.5 -144.8 679132.5 4351080.6|
+|2 0.4 1.0 1.3 2153.1 -567.2 684314.7 4399001.4|
+|3 -1.2 -0.5 .6 1452.8 -476.5 567841.4 3457682.8|
+|4 1.1 0.5 1.3 1034.0 -109.2 677573.8 4352626.4|
+|5 -2.7 14.0 14.2 1048.6 -144.9 679132.6 4351080.7|
+| overall rms error: 4.46 |
+</PRE>
+The following menu then appears at the bottom of the graphics monitor:
+<PRE>
+ ____________________________________________________________________
+| DONE| PRINT FILE| Double click on point to be included/excluded|
+|_____|____________|________________________________________________|
+</PRE>
+TITLEd "error" and subTITLEd "row" and "col". In the above
+report, point number 1 is 0.0 rows and -0.9 columns from
+the predicted location calculated from the transformation
+equation. The RMS error for the target raster map layer is
+listed under the heading "target". This is the RMS error
+for the east and north coordinates of the target map layer,
+but it is presented in the table using one general value.
+screen in meters. Points that create high RMS error are
+displayed in red on the graphics monitor (represented here
+in italics).
+<P>
+The location of the point marked on the
+<A HREF="i.group.html">imagery group</A> file is given
+under the heading "image" and the subheadings "east" and
+"north". The location of the point in the target data base
+is given under the heading "target" and the subheadings
+"east" and "north". If the user would like to exclude or
+include a point, this can be accomplished by placing the
+mouse cross hairs on the point number to be included (if
+the point is absent) or excluded (if the point is
+displayed) and pressing the left button on the mouse
+twice. When a point is excluded, it is not afterwards
+included in the calculation of the RMS error, or included
+in the final transformation matrix. However, it can be
+retrieved within <EM>i.points</EM> at any time by double
+clicking with the mouse as described above.
+<H3>QUIT</H3>
+To end the <EM>i.points</EM> program place the mouse cross
+hairs on the word QUIT; the marked points (including
+coordinates) will be saved.
+<H2>NOTES</H2>
+which are evenly distributed over the entire
+<A HREF="i.group.html">imagery group</A> file in order to
+obtain an accurate transformation equation for the
+rectification process. The RMS error may increase with
+more points added, but the transformation equation will be
+more accurate.
+<P>
+An RMS error of less than or equal to approximately one
+resolution unit (pixel or cell) for the image being
+rectified is generally considered acceptable.
+<P>
+In order to use a digitizer with <EM>i.points</EM>, at
+least one digitizer driver besides "none" (the on-screen
+digitizer) must be available in the digitcap file.
+<P>
+This program is interactive.
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<A HREF="http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf">Image
+Processing manual</A></EM>
+<P>
+<EM>
+<A HREF="g.mapsets.html">g.mapsets</A><br>
+<A HREF="i.group.html">i.group</A><br>
+<A HREF="i.rectify.html">i.rectify</A><br>
+<A HREF="i.target.html">i.target</A><br>
+<A HREF="i.vpoints.html">i.vpoints</A>
+</EM><br>
+<em><a href="gm_georect.html">gis.m: GEORECTIFY TOOL</a></em>
+<H2>AUTHOR</H2>
+Michael Shapiro,
+U.S.Army Construction Engineering Research Laboratory
+<p>
+<i>Last changed: $Date$</i></p>
Deleted: grass/trunk/imagery/i.rectify/description.html
--- grass/trunk/imagery/i.rectify/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.rectify/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,232 +0,0 @@
-<EM>i.rectify</EM> uses the control
-points identified in
-<EM><A HREF="i.points.html">i.points</A></EM>
-or
-<EM><A HREF="i.vpoints.html">i.vpoints</A></EM>
-to calculate a transformation matrix based on a first,
-second, or third order polynomial and then converts x,y
-cell coordinates to standard map coordinates for each pixel
-in the image. The result is a planimetric image with a
-transformed coordinate system (i.e., a different coordinate
-system than before it was rectified).
-<P>
-or
-must be run before <EM>i.rectify</EM>, and both programs
-are required to rectify an image. An image must be
-rectified before it can reside in a standard coordinate
-LOCATION, and therefore be analyzed with the other map
-layers in the standard coordinate LOCATION. Upon
-completion of <EM>i.rectify</EM>, the rectified image is
-deposited in the target standard coordinate LOCATION. This
-LOCATION is selected using
-<EM><A HREF="i.target.html">i.target</A></EM>.
-<H2>Program Prompts</H2>
-The first prompt in the program asks for the name of
-the group containing the files to be rectified.
-<PRE>
- Enter the group containing files to be rectified
- Enter 'list' for a list of existing imagery groups
- Enter 'list -f' for a verbose listing
- Hit RETURN to cancel request
-</PRE>
- This is the same imagery group that was selected in
-or
-and the group that contains the raster maps with the marked
-points and their associated map coordinates. You are then
-asked to select the raster map(s) within the group to be
-rectified:
-<PRE>
-Please select the file(s) to rectify by naming an output file
- spot1.1 in mapsetname .............
- spot1.2 in mapsetname .............
- spot1.3 in mapsetname .............
- spotclass1 in mapsetname spotrectify1.
- spotreject1 in mapsetname .............
-(enter list by any name to get a list of existing raster maps)
-AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
- (OR<Ctrl-C> TO CANCEL)
-</PRE>
-More than one raster map may be rectified at a time. Each
-cell file should be given a unique output file name.
-<P>
-Next, you are asked to select one of two windows regions:
-<PRE>
-</PRE>
-The <EM>i.rectify</EM> program will only rectify that
-portion of the image or raster map that occurs within the
-chosen window region, and only that portion of the cell
-file will be relocated in the target database. It is
-important therefore, to check the current mapset window in
-the target LOCATION if choice number one is selected.
-<P>
-If you are rectifying a file with plans to patch it to
-another file using the GRASS program <em>r.patch</em>,
-choose option number one, the current window in the target
-location. This window, however, must be the default window
-for the target LOCATION. When a file being rectified is
-smaller than the default window in which it is being
-rectified, zeros are added to the rectified file. Patching
-files of the same size that contain 0/non-zero data,
-eliminates the possibility of a no-data line the patched
-result. This is because, when the images are patched, the
-zeros in the image are "covered" with non-zero pixel
-values. When rectifying files that are going to be
-patched, rectify all of the files using the same default
-window.
-<P>
-Select the order of transformation desired with the <b>order</b> option:
-<PRE>
-Select order of transformation --> 1st Order 2nd Order 3rd Order
-</PRE>
-The program will immediately recalculate the RMSE and the
-number of points required.
-<h3>Linear affine transformation (1st order transformation)</h3>
-<DL>
- <DD> x' = ax + by +c
- <DD> y' = Ax + Bt +C
-</DL>
-The a,b,c,A,B,C are determined by least squares regression
-based on the control points entered. This transformation
-applies scaling, translation and rotation. It is NOT a
-general purpose rubber-sheeting, nor is it ortho-photo
-rectification using a DEM, not second order polynomial,
-etc. It can be used if (1) you have geometrically correct
-images, and (2) the terrain or camera distortion effect can
-be ignored.
-<H3>Polynomial Transformation Matrix (2nd, 3d order transformation)</H3>
-The ANALYZE function has been changed to support
-calculating the registration coefficients using a first,
-second, or third order transformation matrix. The number
-of control points required for a selected order of
-transformation (represented by n) is
-<DL>
-<DD>((n + 1) * (n + 2) / 2)
-</DL>
-or 3, 6, and 10 respectively. It is strongly recommended
-that one or more additional points be identified to allow
-for an overly- determined transformation calculation which
-will generate the Root Mean Square (RMS) error values for
-each included point. The RMS error values for all the
-included control points are immediately recalculated when
-the user selects a different transformation order from the
-menu bar. The polynomial equations are performed using a
-modified Gaussian elimination method.
-<H3>Program Execution</H3>
-Note: The rectified image or rectified raster maps will be
-located in the target LOCATION when the program is
-completed. The original unrectified files are not modified
-or removed.
-<P>
-Note: In interactive mode it is possible to define a new file name
-for the target images. This is (currently) not provided in command line
-mode.
-<h2>NOTES</h2>
-<EM>i.rectify</EM> uses nearest neighbor resampling during
-the transformation choosing the actual pixel that has its centre nearest to
-the point location in the image. Advantage of this method is that the pixel
-brightness of the image is kept as <EM>i.rectify</EM> rearranges the
-geometry of the image pixels.
-<P>
-If <em>i.rectify</em> starts normally but after some time the following text is seen:
-<br><tt>
-GIS ERROR: error while writing to temp file
-</tt><br>
-the user may try the flag <EM>-c</EM> (or the module needs more free space
-on the hard drive).
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<P>
-<EM>
-<A HREF="g.transform.html">g.transform</A>,
-<A HREF="r.proj.html">r.proj</A>,
-<A HREF="v.proj.html">v.proj</A>,
-<A HREF="i.group.html">i.group</A>,
-<A HREF="i.points.html">i.points</A>,
-<A HREF="i.vpoints.html">i.vpoints</A>,
-</EM><br>
-<H2>AUTHORS</H2>
-William R. Enslin,
-Michigan State University,
-Center for Remote Sensing
-<p>
-Modified for GRASS 5.0 by:<BR>
-Luca Palmeri (palmeri at ux1.unipd.it)<BR>
-Bill Hughes<BR>
-Pierre de Mouveaux (pmx at audiovu.com)
-<BR>
-CMD mode by Bob Covill
-<p>
Copied: grass/trunk/imagery/i.rectify/i.rectify.html (from rev 32770, grass/trunk/imagery/i.rectify/description.html)
--- grass/trunk/imagery/i.rectify/i.rectify.html (rev 0)
+++ grass/trunk/imagery/i.rectify/i.rectify.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,232 @@
+<H2>DESCRIPTION</H2>
+<EM>i.rectify</EM> uses the control
+points identified in
+<EM><A HREF="i.points.html">i.points</A></EM>
+or
+<EM><A HREF="i.vpoints.html">i.vpoints</A></EM>
+to calculate a transformation matrix based on a first,
+second, or third order polynomial and then converts x,y
+cell coordinates to standard map coordinates for each pixel
+in the image. The result is a planimetric image with a
+transformed coordinate system (i.e., a different coordinate
+system than before it was rectified).
+<P>
+or
+must be run before <EM>i.rectify</EM>, and both programs
+are required to rectify an image. An image must be
+rectified before it can reside in a standard coordinate
+LOCATION, and therefore be analyzed with the other map
+layers in the standard coordinate LOCATION. Upon
+completion of <EM>i.rectify</EM>, the rectified image is
+deposited in the target standard coordinate LOCATION. This
+LOCATION is selected using
+<EM><A HREF="i.target.html">i.target</A></EM>.
+<H2>Program Prompts</H2>
+The first prompt in the program asks for the name of
+the group containing the files to be rectified.
+<PRE>
+ Enter the group containing files to be rectified
+ Enter 'list' for a list of existing imagery groups
+ Enter 'list -f' for a verbose listing
+ Hit RETURN to cancel request
+</PRE>
+ This is the same imagery group that was selected in
+or
+and the group that contains the raster maps with the marked
+points and their associated map coordinates. You are then
+asked to select the raster map(s) within the group to be
+rectified:
+<PRE>
+Please select the file(s) to rectify by naming an output file
+ spot1.1 in mapsetname .............
+ spot1.2 in mapsetname .............
+ spot1.3 in mapsetname .............
+ spotclass1 in mapsetname spotrectify1.
+ spotreject1 in mapsetname .............
+(enter list by any name to get a list of existing raster maps)
+AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
+ (OR<Ctrl-C> TO CANCEL)
+</PRE>
+More than one raster map may be rectified at a time. Each
+cell file should be given a unique output file name.
+<P>
+Next, you are asked to select one of two windows regions:
+<PRE>
+</PRE>
+The <EM>i.rectify</EM> program will only rectify that
+portion of the image or raster map that occurs within the
+chosen window region, and only that portion of the cell
+file will be relocated in the target database. It is
+important therefore, to check the current mapset window in
+the target LOCATION if choice number one is selected.
+<P>
+If you are rectifying a file with plans to patch it to
+another file using the GRASS program <em>r.patch</em>,
+choose option number one, the current window in the target
+location. This window, however, must be the default window
+for the target LOCATION. When a file being rectified is
+smaller than the default window in which it is being
+rectified, zeros are added to the rectified file. Patching
+files of the same size that contain 0/non-zero data,
+eliminates the possibility of a no-data line the patched
+result. This is because, when the images are patched, the
+zeros in the image are "covered" with non-zero pixel
+values. When rectifying files that are going to be
+patched, rectify all of the files using the same default
+window.
+<P>
+Select the order of transformation desired with the <b>order</b> option:
+<PRE>
+Select order of transformation --> 1st Order 2nd Order 3rd Order
+</PRE>
+The program will immediately recalculate the RMSE and the
+number of points required.
+<h3>Linear affine transformation (1st order transformation)</h3>
+<DL>
+ <DD> x' = ax + by +c
+ <DD> y' = Ax + Bt +C
+</DL>
+The a,b,c,A,B,C are determined by least squares regression
+based on the control points entered. This transformation
+applies scaling, translation and rotation. It is NOT a
+general purpose rubber-sheeting, nor is it ortho-photo
+rectification using a DEM, not second order polynomial,
+etc. It can be used if (1) you have geometrically correct
+images, and (2) the terrain or camera distortion effect can
+be ignored.
+<H3>Polynomial Transformation Matrix (2nd, 3d order transformation)</H3>
+The ANALYZE function has been changed to support
+calculating the registration coefficients using a first,
+second, or third order transformation matrix. The number
+of control points required for a selected order of
+transformation (represented by n) is
+<DL>
+<DD>((n + 1) * (n + 2) / 2)
+</DL>
+or 3, 6, and 10 respectively. It is strongly recommended
+that one or more additional points be identified to allow
+for an overly- determined transformation calculation which
+will generate the Root Mean Square (RMS) error values for
+each included point. The RMS error values for all the
+included control points are immediately recalculated when
+the user selects a different transformation order from the
+menu bar. The polynomial equations are performed using a
+modified Gaussian elimination method.
+<H3>Program Execution</H3>
+Note: The rectified image or rectified raster maps will be
+located in the target LOCATION when the program is
+completed. The original unrectified files are not modified
+or removed.
+<P>
+Note: In interactive mode it is possible to define a new file name
+for the target images. This is (currently) not provided in command line
+mode.
+<h2>NOTES</h2>
+<EM>i.rectify</EM> uses nearest neighbor resampling during
+the transformation choosing the actual pixel that has its centre nearest to
+the point location in the image. Advantage of this method is that the pixel
+brightness of the image is kept as <EM>i.rectify</EM> rearranges the
+geometry of the image pixels.
+<P>
+If <em>i.rectify</em> starts normally but after some time the following text is seen:
+<br><tt>
+GIS ERROR: error while writing to temp file
+</tt><br>
+the user may try the flag <EM>-c</EM> (or the module needs more free space
+on the hard drive).
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<P>
+<EM>
+<A HREF="g.transform.html">g.transform</A>,
+<A HREF="r.proj.html">r.proj</A>,
+<A HREF="v.proj.html">v.proj</A>,
+<A HREF="i.group.html">i.group</A>,
+<A HREF="i.points.html">i.points</A>,
+<A HREF="i.vpoints.html">i.vpoints</A>,
+</EM><br>
+<H2>AUTHORS</H2>
+William R. Enslin,
+Michigan State University,
+Center for Remote Sensing
+<p>
+Modified for GRASS 5.0 by:<BR>
+Luca Palmeri (palmeri at ux1.unipd.it)<BR>
+Bill Hughes<BR>
+Pierre de Mouveaux (pmx at audiovu.com)
+<BR>
+CMD mode by Bob Covill
+<p>
Deleted: grass/trunk/imagery/i.rgb.his/description.html
--- grass/trunk/imagery/i.rgb.his/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.rgb.his/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,29 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>i.rgb.his</EM> is an image processing program that
-processes three input raster map layers as red, green, and
-blue components and produces three output raster map layers
-representing the hue, intensity, and saturation of the
-data. The output raster map layers are created by a
-standard red-green-blue (rgb) to hue-intensity-saturation
-(his) color transformation. Each output raster map layer
-is given a linear gray scale color table. The current
-geographic region definition and mask settings are
-respected.
-<H2>SEE ALSO</H2>
-<EM><A HREF="hsv.rgb.sh.html">hsv.rgb.sh</A></EM><br>
-<EM><A HREF="i.his.rgb.html">i.his.rgb</A></EM><br>
-<EM><A HREF="rgb.hsv.sh.html">rgb.hsv.sh</A></EM>
-<H2>AUTHOR</H2>
-David Satnik, GIS Laboratory,
-Central Washington University,
-<BR>
-with acknowledgements to Ali Vali, Space Research
-Center, for the core routine.
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/imagery/i.rgb.his/i.rgb.his.html (from rev 32770, grass/trunk/imagery/i.rgb.his/description.html)
--- grass/trunk/imagery/i.rgb.his/i.rgb.his.html (rev 0)
+++ grass/trunk/imagery/i.rgb.his/i.rgb.his.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,29 @@
+<EM>i.rgb.his</EM> is an image processing program that
+processes three input raster map layers as red, green, and
+blue components and produces three output raster map layers
+representing the hue, intensity, and saturation of the
+data. The output raster map layers are created by a
+standard red-green-blue (rgb) to hue-intensity-saturation
+(his) color transformation. Each output raster map layer
+is given a linear gray scale color table. The current
+geographic region definition and mask settings are
+respected.
+<H2>SEE ALSO</H2>
+<EM><A HREF="hsv.rgb.sh.html">hsv.rgb.sh</A></EM><br>
+<EM><A HREF="i.his.rgb.html">i.his.rgb</A></EM><br>
+<EM><A HREF="rgb.hsv.sh.html">rgb.hsv.sh</A></EM>
+<H2>AUTHOR</H2>
+David Satnik, GIS Laboratory,
+Central Washington University,
+<BR>
+with acknowledgements to Ali Vali, Space Research
+Center, for the core routine.
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/imagery/i.smap/shapiro/description.html
--- grass/trunk/imagery/i.smap/shapiro/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.smap/shapiro/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,198 +0,0 @@
-The <EM>i.smap</EM> program is used to segment
-multispectral images using a spectral class model known as
-a Gaussian mixture distribution. Since Gaussian mixture
-distributions include conventional multivariate Gaussian
-distributions, this program may also be used to segment
-multispectral images based on simple spectral mean and
-covariance parameters.
-<P>
-<EM>i.smap</EM> has two modes of operation. The first mode
-is the sequential maximum a posteriori (SMAP) mode
-[<A HREF="#ref1">1</A>,<A HREF="#ref2">2</A>]. The SMAP
-segmentation algorithm attempts to improve segmentation
-accuracy by segmenting the image into regions rather than
-segmenting each pixel separately
-(see <A HREF="#notes">NOTES</A>).
-<P>
-The second mode is the more conventional maximum likelihood (ML)
-classification which classifies each pixel separately,
-but requires somewhat less computation. This mode is selected with
-the <B>-m</B> flag (see <A HREF="#mflag.html">below</A>).
-<H2>OPTIONS</H2>
-<H3>Flags:</H3>
-<DL>
-<DT><B>-m</B></A>
-<DD>Use maximum likelihood estimation (instead of smap).
-Normal operation is to use SMAP estimation (see
-<A HREF="#notes">NOTES</A>).
-<DT><B>-q</B>
-<DD>Run quietly, without printing messages about program
-progress. Without this flag, messages will be printed (to
-stderr) as the program progresses.
-</DL>
-<DL>
-<DT><B>group=</B><EM>name</EM>
-<DD>imagery group<BR>
-The imagery group that defines the image to be classified.
-<DT><B>subgroup=</B><EM>name</EM>
-<DD>imagery subgroup<BR>
-The subgroup within the group specified that specifies the
-subset of the band files that are to be used as image data
-to be classified.
-<DT><B>signaturefile=</B><EM>name</EM>
-<DD>imagery signaturefile<BR>
-The signature file that contains the spectral signatures (i.e., the
-statistics) for the classes to be identified in the image.
-This signature file is produced by the program
-<EM><A HREF="i.gensigset.html">i.gensigset</A></EM>
-<DT><B>blocksize=</B><EM>value</EM>
-<DD>size of submatrix to process at one time<BR>
-default: 128<BR>
-This option specifies the size of the "window" to be used when
-reading the image data.
-<P>
-This program was written to be nice about memory usage
-without influencing the resultant classification. This
-option allows the user to control how much memory is used.
-More memory may mean faster (or slower) operation depending
-on how much real memory your machine has and how much
-virtual memory the program uses.
-<P>
-The size of the submatrix used in segmenting the image has
-a principle function of controlling memory usage; however,
-it also can have a subtle effect on the quality of the
-segmentation in the smap mode. The smoothing parameters
-for the smap segmentation are estimated separately for each
-submatrix. Therefore, if the image has regions with
-qualitatively different behavior, (e.g., natural woodlands
-and man-made agricultural fields) it may be useful to use a
-submatrix small enough so that different smoothing
-parameters may be used for each distinctive region of the
-image.
-<P>
-The submatrix size has no effect on the performance of the
-ML segmentation method.
-<DD>output raster map.<BR>
-The name of a raster map that will contain the
-classification results. This new raster map layer will
-contain categories that can be related to landcover
-categories on the ground.
-</DL>
-<H2>INTERACTIVE MODE</H2>
-If none of the arguments are specified on the command line,
-<EM>i.smap</EM> will interactively prompt for the names of
-the maps and files.
-<A NAME="notes"><H2>NOTES</H2></A>
-The SMAP algorithm exploits the fact that nearby pixels in
-an image are likely to have the same class. It works by
-segmenting the image at various scales or resolutions and
-using the coarse scale segmentations to guide the finer
-scale segmentations. In addition to reducing the number of
-misclassifications, the SMAP algorithm generally produces
-segmentations with larger connected regions of a fixed
-class which may be useful in some applications.
-<P>
-The amount of smoothing that is performed in the
-segmentation is dependent of the behavior of the data in
-the image. If the data suggests that the nearby pixels
-often change class, then the algorithm will adaptively
-reduce the amount of smoothing. This ensures that
-excessively large regions are not formed.
-<P>
-The module i.smap does not support MASKed or NULL cells. Therefore
-it might be necessary to create a copy of the classification results
-using e.g. r.mapcalc.
-<p>
-r.mapcalc MASKed_map=classification results
-<H2>REFERENCES</H2>
-<OL>
-<LI>C. Bouman and M. Shapiro,
-"Multispectral Image Segmentation using a Multiscale Image Model",
-<EM>Proc. of IEEE Int'l Conf. on Acoust., Speech and Sig. Proc.,</EM>
-pp. III-565 - III-568, San Francisco, California, March
-23-26, 1992.
-<LI>C. Bouman and M. Shapiro 1994,
-"A Multiscale Random Field
-Model for Bayesian Image Segmentation",
-<EM>IEEE Trans. on Image Processing., 3(2), 162-177"</EM>
-<LI>McCauley, J.D. and B.A. Engel 1995,
-"Comparison of Scene Segmentations: SMAP, ECHO and Maximum Likelyhood",
-<EM>IEEE Trans. on Geoscience and Remote Sensing, 33(6): 1313-1316.</EM>
-</OL>
-<H2>SEE ALSO</H2>
-<EM><A HREF="i.group.html">i.group</A></EM>
-for creating groups and subgroups
-<P>
-to copy classification result in order to cut out MASKed subareas
-<P>
-to generate the signature file required by this program
-<H2>AUTHORS</H2>
-<a href=http://dynamo.ecn.purdue.edu/~bouman/software/segmentation/>Charles Bouman,
-School of Electrical Engineering, Purdue University</a>
-<BR>
-Michael Shapiro,
Copied: grass/trunk/imagery/i.smap/shapiro/i.smap.html (from rev 32770, grass/trunk/imagery/i.smap/shapiro/description.html)
--- grass/trunk/imagery/i.smap/shapiro/i.smap.html (rev 0)
+++ grass/trunk/imagery/i.smap/shapiro/i.smap.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,198 @@
+The <EM>i.smap</EM> program is used to segment
+multispectral images using a spectral class model known as
+a Gaussian mixture distribution. Since Gaussian mixture
+distributions include conventional multivariate Gaussian
+distributions, this program may also be used to segment
+multispectral images based on simple spectral mean and
+covariance parameters.
+<P>
+<EM>i.smap</EM> has two modes of operation. The first mode
+is the sequential maximum a posteriori (SMAP) mode
+[<A HREF="#ref1">1</A>,<A HREF="#ref2">2</A>]. The SMAP
+segmentation algorithm attempts to improve segmentation
+accuracy by segmenting the image into regions rather than
+segmenting each pixel separately
+(see <A HREF="#notes">NOTES</A>).
+<P>
+The second mode is the more conventional maximum likelihood (ML)
+classification which classifies each pixel separately,
+but requires somewhat less computation. This mode is selected with
+the <B>-m</B> flag (see <A HREF="#mflag.html">below</A>).
+<H2>OPTIONS</H2>
+<H3>Flags:</H3>
+<DL>
+<DT><B>-m</B></A>
+<DD>Use maximum likelihood estimation (instead of smap).
+Normal operation is to use SMAP estimation (see
+<A HREF="#notes">NOTES</A>).
+<DT><B>-q</B>
+<DD>Run quietly, without printing messages about program
+progress. Without this flag, messages will be printed (to
+stderr) as the program progresses.
+</DL>
+<DL>
+<DT><B>group=</B><EM>name</EM>
+<DD>imagery group<BR>
+The imagery group that defines the image to be classified.
+<DT><B>subgroup=</B><EM>name</EM>
+<DD>imagery subgroup<BR>
+The subgroup within the group specified that specifies the
+subset of the band files that are to be used as image data
+to be classified.
+<DT><B>signaturefile=</B><EM>name</EM>
+<DD>imagery signaturefile<BR>
+The signature file that contains the spectral signatures (i.e., the
+statistics) for the classes to be identified in the image.
+This signature file is produced by the program
+<EM><A HREF="i.gensigset.html">i.gensigset</A></EM>
+<DT><B>blocksize=</B><EM>value</EM>
+<DD>size of submatrix to process at one time<BR>
+default: 128<BR>
+This option specifies the size of the "window" to be used when
+reading the image data.
+<P>
+This program was written to be nice about memory usage
+without influencing the resultant classification. This
+option allows the user to control how much memory is used.
+More memory may mean faster (or slower) operation depending
+on how much real memory your machine has and how much
+virtual memory the program uses.
+<P>
+The size of the submatrix used in segmenting the image has
+a principle function of controlling memory usage; however,
+it also can have a subtle effect on the quality of the
+segmentation in the smap mode. The smoothing parameters
+for the smap segmentation are estimated separately for each
+submatrix. Therefore, if the image has regions with
+qualitatively different behavior, (e.g., natural woodlands
+and man-made agricultural fields) it may be useful to use a
+submatrix small enough so that different smoothing
+parameters may be used for each distinctive region of the
+image.
+<P>
+The submatrix size has no effect on the performance of the
+ML segmentation method.
+<DD>output raster map.<BR>
+The name of a raster map that will contain the
+classification results. This new raster map layer will
+contain categories that can be related to landcover
+categories on the ground.
+</DL>
+<H2>INTERACTIVE MODE</H2>
+If none of the arguments are specified on the command line,
+<EM>i.smap</EM> will interactively prompt for the names of
+the maps and files.
+<A NAME="notes"><H2>NOTES</H2></A>
+The SMAP algorithm exploits the fact that nearby pixels in
+an image are likely to have the same class. It works by
+segmenting the image at various scales or resolutions and
+using the coarse scale segmentations to guide the finer
+scale segmentations. In addition to reducing the number of
+misclassifications, the SMAP algorithm generally produces
+segmentations with larger connected regions of a fixed
+class which may be useful in some applications.
+<P>
+The amount of smoothing that is performed in the
+segmentation is dependent of the behavior of the data in
+the image. If the data suggests that the nearby pixels
+often change class, then the algorithm will adaptively
+reduce the amount of smoothing. This ensures that
+excessively large regions are not formed.
+<P>
+The module i.smap does not support MASKed or NULL cells. Therefore
+it might be necessary to create a copy of the classification results
+using e.g. r.mapcalc.
+<p>
+r.mapcalc MASKed_map=classification results
+<H2>REFERENCES</H2>
+<OL>
+<LI>C. Bouman and M. Shapiro,
+"Multispectral Image Segmentation using a Multiscale Image Model",
+<EM>Proc. of IEEE Int'l Conf. on Acoust., Speech and Sig. Proc.,</EM>
+pp. III-565 - III-568, San Francisco, California, March
+23-26, 1992.
+<LI>C. Bouman and M. Shapiro 1994,
+"A Multiscale Random Field
+Model for Bayesian Image Segmentation",
+<EM>IEEE Trans. on Image Processing., 3(2), 162-177"</EM>
+<LI>McCauley, J.D. and B.A. Engel 1995,
+"Comparison of Scene Segmentations: SMAP, ECHO and Maximum Likelyhood",
+<EM>IEEE Trans. on Geoscience and Remote Sensing, 33(6): 1313-1316.</EM>
+</OL>
+<H2>SEE ALSO</H2>
+<EM><A HREF="i.group.html">i.group</A></EM>
+for creating groups and subgroups
+<P>
+to copy classification result in order to cut out MASKed subareas
+<P>
+to generate the signature file required by this program
+<H2>AUTHORS</H2>
+<a href=http://dynamo.ecn.purdue.edu/~bouman/software/segmentation/>Charles Bouman,
+School of Electrical Engineering, Purdue University</a>
+<BR>
+Michael Shapiro,
Deleted: grass/trunk/imagery/i.target/description.html
--- grass/trunk/imagery/i.target/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.target/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,52 +0,0 @@
-<EM>i.target</EM> targets an <A HREF="i.group.html">imagery
-group</a> to a GRASS data base location name and mapset.
-A location name and mapset are required for the
-<EM><A HREF="i.rectify.html">i.rectify</A></EM> imagery module, into which
-to write the rectified map just prior to completion of the program;
-<EM>i.target</EM> enables the user to specify this location.
-<EM>i.target</EM> must be run before
-<EM><A HREF="i.points.html">i.points</A></EM> and
-<EM><A HREF="i.rectify.html">i.rectify</A></EM>.
-<H2>NOTES</H2>
-<P>
-The module's first option asks for the name of the
-<A HREF="i.group.html">imagery group</A> that needs a target.
-The imagery group must be present in the user's current mapset.
-An <A HREF="i.group.html">imagery group</A> may be targeted to any GRASS
-location.
-<P>
-If a group name is given without setting options, the currently targeted
-group will be displayed.
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<P>
-<EM>
-<A HREF="i.group.html">i.group</A><BR>
-<A HREF="i.points.html">i.points</A><BR>
-<A HREF="i.vpoints.html">i.vpoints</A><BR>
-</EM><br>
-<H2>AUTHOR</H2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory<p>
-Parser support: Bob Covill
-<p>
Copied: grass/trunk/imagery/i.target/i.target.html (from rev 32770, grass/trunk/imagery/i.target/description.html)
--- grass/trunk/imagery/i.target/i.target.html (rev 0)
+++ grass/trunk/imagery/i.target/i.target.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,52 @@
+<EM>i.target</EM> targets an <A HREF="i.group.html">imagery
+group</a> to a GRASS data base location name and mapset.
+A location name and mapset are required for the
+<EM><A HREF="i.rectify.html">i.rectify</A></EM> imagery module, into which
+to write the rectified map just prior to completion of the program;
+<EM>i.target</EM> enables the user to specify this location.
+<EM>i.target</EM> must be run before
+<EM><A HREF="i.points.html">i.points</A></EM> and
+<EM><A HREF="i.rectify.html">i.rectify</A></EM>.
+<H2>NOTES</H2>
+<P>
+The module's first option asks for the name of the
+<A HREF="i.group.html">imagery group</A> that needs a target.
+The imagery group must be present in the user's current mapset.
+An <A HREF="i.group.html">imagery group</A> may be targeted to any GRASS
+location.
+<P>
+If a group name is given without setting options, the currently targeted
+group will be displayed.
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<P>
+<EM>
+<A HREF="i.group.html">i.group</A><BR>
+<A HREF="i.points.html">i.points</A><BR>
+<A HREF="i.vpoints.html">i.vpoints</A><BR>
+</EM><br>
+<H2>AUTHOR</H2>
+Michael Shapiro,
+U.S. Army Construction Engineering Research Laboratory<p>
+Parser support: Bob Covill
+<p>
Deleted: grass/trunk/imagery/i.vpoints/description.html
--- grass/trunk/imagery/i.vpoints/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.vpoints/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,342 +0,0 @@
-This program enables the user to identify coordinate pairs of points from a
-vector map or keyboard entry and corresponding points in an image to be
-rectified. The map coordinate values of each point are used to calculate a
-transformation matrix. The operator may then use the
-<EM><a href="i.rectify.html">i.rectify</A></EM> program to rectify the image using
-the transformation matrix coefficients calculated from the control point
-file created in <EM>i.vpoints</EM>. The
-<EM> <a href="i.rectify.html">i.rectify</A></EM> program performs a first, second or
-third order transformation of the image.
-<P>
-The first step is to display the unrectified image and
-corresponding vector map data. The operator would then
-mark corresponding control point locations on the image and
-map. To identify the precise location of a point to be
-marked, <EM>i.vpoints</EM> has a zoom option. In addition to
-marking control points on an image to be rectified and
-inputting their world coordinate values using the
-keyboard, <EM>i.vpoints</EM> has the option to simultaneously
-display vector map data available in the targeted database,
-and identify on the vector map the location of the
-corresponding marked points. When this option is chosen,
-the coordinate values are input automatically. Any GRASS
-map layer or vector map in the targeted database LOCATION
-can be displayed using <EM>i.vpoints</EM>. The <EM>i.vpoints</EM> program
-also has the capability of overlaying (i.e., warping) the
-vector data onto the raster image to visually check the
-accuracy of the registration based on the current set of
-active control points. During the process of marking
-points and entering map coordinates, the user can compute
-the RMS (root mean square) error for each point entered.
-The <EM>i.vpoints</EM> program does this by calculating a
-transformation equation (the same one that is calculated in
-the GRASS program
-2). Coefficients are
-computed for the equation. The coefficients are then used in the
-equation along with the x,y coordinates of the marked points. The
-results are plugged into an equation for RMS error. The
-interpretation of RMS error is described in the ANALYZE subsection.
-<P>
-The procedures for marking control points (registration
-points), displaying vector map layers, overlaying vector maps onto
-the raster image, and calculating RMS error are described in the
-following sections .
-<P>
-To enter the program (the <EM>i.vpoints</EM> program requires the use of a
-graphics monitor) type <EM>i.vpoints</EM>:
-<DL>
- <DD><B>i.vpoints</B>
-</DL>
-The first prompt in the program asks for the imagery group to
-be registered . . .
-<PRE>
- Enter imagery group to be registered
-</PRE>
-For example,
-<DL>
-<DD>><B>list</B>
-</DL>
-might produce the following response:
-<PRE>
- <list>
- Available groups
- test
- hit RETURN to continue -->
-</PRE>
-whereas,
-<DL>
-<DD>><B>list -f</B>
-</DL>
-<PRE>
- Available groups
- test
- photo in PERMANENT
- res2 in tifftest
-</PRE>
-The imagery group entered above should contain the files
-that you wish to rectify. After entering the group to be
-registered, the terminal screen displays the message:
-<PRE>
- >test
- <test>
- Use mouse now . . .
-</PRE>
-And the color graphics monitor displays the following
-screen:
-<P>
- Any single file in the imagery group may be used to mark
-points, and points can be marked on more than one file in the
-imagery group to accumulate the suggested minimum number of points
-(3 for a 1st order transformation, 6 for a 2nd order, and 10 for a
-3rd order). Any file in the imagery group can be subsequently
-rectified (using <EM><A HREF="i.rectify.html">i.rectify</A></EM>)
-based on the transformation matrix computed from these points.
-<P>
- The chosen file is displayed in the upper left quadrant of the
-monitor at a default magnification based on the extent of the
-current active window.
-<P>
-<B>RASTER IMAGE</B>
-<P>
- The raster image option on the menu at the bottom of the
-window allows the user to display any single file in the imagery
-group in the upper right quadrant of the window screen. The option
-provides the same file selection pick list as is presented when you
-first enter the <EM>i.vpoints</EM> program. When you select this option,
-the program will erase the data contained in all of the four
-quadrant windows and will reinitialize all program values.
-<P>
-<B>VECTOR MAPS</B>
-<P>
- The vector maps option on the menu at the bottom of the screen
-allows the user to display vector map data in the upper right
-quadrant of the screen. After selecting the vector map layer to
-display, a menu selection bar appears along the bottom on the
-screen. This pick list is used to select the line color (blue,
-gray, green, red, white, or yellow) for the selected vector data
-layer.
-<P>
-<B>Refresh</B>
-<P>
- The refresh option on the main menu allows the user to
-"refresh" or re-draw the displayed vector data. This function will
-erase all outlines showing the limits of previously zoomed areas.
-A "yes/no" roompt will appear:
-<PRE>
- Refresh Map ? NO YES
-</PRE>
-<P>
-<B>Zoom</B>
-<P>
- To enlarge a raster or vector image, place the mouse cross
-hairs on the word zoom on the main menu and press the left button.
-The following menu will be displayed at the bottom. of the screen:
-<PRE>
- CANCEL BOX POINT Select type of zoom
-</PRE>
-You have the option to identify the map extent of the zoom window
-using either the mouse to define a box, or the mouse to mark a
-center point from which to enlarge the image. The box option first
-prompts you to identify a starting corner for the zoom region and
-then allows you to define the area to be zoomed using a rubber band
-box. The prompts appear as follows...
-<PRE>
- CANCEL Mark the first corner of region
- CANCEL Define the region
-</PRE>
-After marking the first corner of the region to be enlarged, hold
-down the left button and move the mouse to change the size and
-shape of the rubber band box. After defining the area to be
-enlarged, press the right button to accept it.
-<P>
-The point method for enlarging an image will display a mouse menu
-to guide you in selecting the appropriate enlargement. To enlarge
-or reduce the magnification factor, place the cursor on the "+" or
-"-" box and press the left button on the mouse.
-<P>
-<P>
-You may zoom either the raster or the vector display.
-<P>
-Upon accepting the new region limits, the raster or vector data are
-redisplayed in either the lower left (raster) or lower right
-(vector) windows.
-<P>
-The extent of the zoomed area is outlined on the unzoomed image in
-the main window area.
-<P>
- While the main menu is displayed, you can mark
-corrosponding control points on the raster and vector
-images or enter map coordinates from the keyboard. If you
-are using coordinates taken from a reference map, circle
-these points and then use whatever means you have available
-to identify as precisely as possible the coordinate values
-for these points. Digitizing software is recommended,
-especially GRASS v.digit. Once you have
-determined the standard coordinates (for example, UTM's) of
-each circled point, you are ready to mark the points on the
-displayed image.
-<P>
- To mark the points on the image, that correspond to the points
-on the standard coordinate map, place the mouse cross hairs on the
-point on the image to be marked (you will probably have to ZOOM to
-find the exact spot) and press the left hand button on the mouse.
-A diamond shaped symbol will be marked on the image. The text
-monitor will display the following screen:
-<PRE>
- Point 1 marked on the image at
- East: 1023.77
- North: -164.41
- Enter coordinates as east north:
-</PRE>
-<B>Analyze</B>
-<P>
- After a number of points have been marked (a minimum of 4 for
-a 1st order transformation, 7 for a 2nd order, and 11 for a 3rd
-order), the RMS error of the points marked on the image can be
-checked. This is done by placing the cross hairs on the word
-ANALYZE on the main menu at the bottom of the monitor. The
-following error report is superimposed on the monitor:
-<PRE>
- error image target
- # col row target east north east north
- 1 -0.9 0.0 1.0 1048.5 -144.8 679132.5 4351080.6
- 2 1.0 0.4 1.3 2153.1 -567.2 684314.7 4399001.4
- Overall rms error 76.85
-</PRE>
- The RMS error for the image being rectified is recorded under
-the column "error" and subTITLEd "row' and "col". In the above
-report, the marked point number 1 is 0.0 rows and -0.9 columns from
-the predicted location calculated by the transformation equation.
- The RMS error for the target database map is recorded under
-the heading "error" and the subheading "target". This is the RMS
-error for the east and the north coordinate values of the target
-map, but it is represented in the table using one general value.
- The overall RMS error for the image is displayed at the bottom
-of the screen in meters. Points that generate a high RMS error are
-displayed in red on the monitor.
- The x,y coordinate values of the point marked on the image
-being rectified are recorded under the heading "image" and the
-subheadings "east" and "north".
- The standard coordinate values of the point in the target
-database are recorded under the heading "target" and the
- If the user would like to exclude or include a point, this can
-be accomplished by placing the mouse cross hairs on the point
-number to be included (if the point is absent) or excluded (if the
-point is displayed) and then pressing the left button on the mouse
-twice. When a point is excluded, it is not included in the
-calculation of the RMS error, or included in the final
-transformation matrix. However, it can be retrieved within
-<EM>i.vpoints</EM> at any time by double clicking with the mouse as
-described above.
-<P>
-The following menu appears at the bottom of the monitor:
-<PRE>
- DONE PRINT FILE OVERLAY DELETE ON Transformation -
--> 1st ORDER Double click on point to be DELETED
-</PRE>
-Selecting DELETE ON will toggle the option to DELETE OFF, the
-toggle option is used to allow the user to physically remove a
-control point from the POINTS file instead of just flagging it as
-an non-active reference point.
-<P>
-<B>Overlay</B>
-<P>
-Overlay allows the user to overlay the vector map(s) onto the
-raster image. Overlay can be used to warp (register) and display
-the selected vector map data on top of the raster image contained
-in the upper left window of the color screen. An inverse
-coordinate transformation is performed using the currently active
-order of transformation (i.e., first, second, or third).
-<PRE>
- Overlay vectors on raster image NO YES
-</PRE>
-By selecting the 1st ORDER option, the user may select the order of
-transformation desired:
-<PRE>
- Select order of transformation --> 1st Order 2nd Order 3rd Order
-</PRE>
-The program will immediately recalculate the RMSE and the number of
-points required.
-<P>
-<B>Quit</B>
-<P>
- To exit the <EM>i.vpoints</EM> program, place the mouse cross hairs on
-the word QUIT at the bottom of the monitor and all of the marked
-points (including coordinates) will be saved.
-<H2>SEE ALSO</H2>
-The GRASS 4 <em>
-<P>
-<EM>
-<A HREF="g.mapsets.html">g.mapsets</A><BR>
-<A HREF="i.rectify.html">i.rectify</A><BR>
-</EM><br>
-<H2>AUTHOR</H2>
-William R. Enslin, Michigan State University Center for Remote Sensing<br>
-Radim Blazek (update to GRASS 5.7)<BR>
-Hamish Bowman (finish GRASS 6 porting)
-<p>
Copied: grass/trunk/imagery/i.vpoints/i.vpoints.html (from rev 32770, grass/trunk/imagery/i.vpoints/description.html)
--- grass/trunk/imagery/i.vpoints/i.vpoints.html (rev 0)
+++ grass/trunk/imagery/i.vpoints/i.vpoints.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,342 @@
+This program enables the user to identify coordinate pairs of points from a
+vector map or keyboard entry and corresponding points in an image to be
+rectified. The map coordinate values of each point are used to calculate a
+transformation matrix. The operator may then use the
+<EM><a href="i.rectify.html">i.rectify</A></EM> program to rectify the image using
+the transformation matrix coefficients calculated from the control point
+file created in <EM>i.vpoints</EM>. The
+<EM> <a href="i.rectify.html">i.rectify</A></EM> program performs a first, second or
+third order transformation of the image.
+<P>
+The first step is to display the unrectified image and
+corresponding vector map data. The operator would then
+mark corresponding control point locations on the image and
+map. To identify the precise location of a point to be
+marked, <EM>i.vpoints</EM> has a zoom option. In addition to
+marking control points on an image to be rectified and
+inputting their world coordinate values using the
+keyboard, <EM>i.vpoints</EM> has the option to simultaneously
+display vector map data available in the targeted database,
+and identify on the vector map the location of the
+corresponding marked points. When this option is chosen,
+the coordinate values are input automatically. Any GRASS
+map layer or vector map in the targeted database LOCATION
+can be displayed using <EM>i.vpoints</EM>. The <EM>i.vpoints</EM> program
+also has the capability of overlaying (i.e., warping) the
+vector data onto the raster image to visually check the
+accuracy of the registration based on the current set of
+active control points. During the process of marking
+points and entering map coordinates, the user can compute
+the RMS (root mean square) error for each point entered.
+The <EM>i.vpoints</EM> program does this by calculating a
+transformation equation (the same one that is calculated in
+the GRASS program
+2). Coefficients are
+computed for the equation. The coefficients are then used in the
+equation along with the x,y coordinates of the marked points. The
+results are plugged into an equation for RMS error. The
+interpretation of RMS error is described in the ANALYZE subsection.
+<P>
+The procedures for marking control points (registration
+points), displaying vector map layers, overlaying vector maps onto
+the raster image, and calculating RMS error are described in the
+following sections .
+<P>
+To enter the program (the <EM>i.vpoints</EM> program requires the use of a
+graphics monitor) type <EM>i.vpoints</EM>:
+<DL>
+ <DD><B>i.vpoints</B>
+</DL>
+The first prompt in the program asks for the imagery group to
+be registered . . .
+<PRE>
+ Enter imagery group to be registered
+</PRE>
+For example,
+<DL>
+<DD>><B>list</B>
+</DL>
+might produce the following response:
+<PRE>
+ <list>
+ Available groups
+ test
+ hit RETURN to continue -->
+</PRE>
+whereas,
+<DL>
+<DD>><B>list -f</B>
+</DL>
+<PRE>
+ Available groups
+ test
+ photo in PERMANENT
+ res2 in tifftest
+</PRE>
+The imagery group entered above should contain the files
+that you wish to rectify. After entering the group to be
+registered, the terminal screen displays the message:
+<PRE>
+ >test
+ <test>
+ Use mouse now . . .
+</PRE>
+And the color graphics monitor displays the following
+screen:
+<P>
+ Any single file in the imagery group may be used to mark
+points, and points can be marked on more than one file in the
+imagery group to accumulate the suggested minimum number of points
+(3 for a 1st order transformation, 6 for a 2nd order, and 10 for a
+3rd order). Any file in the imagery group can be subsequently
+rectified (using <EM><A HREF="i.rectify.html">i.rectify</A></EM>)
+based on the transformation matrix computed from these points.
+<P>
+ The chosen file is displayed in the upper left quadrant of the
+monitor at a default magnification based on the extent of the
+current active window.
+<P>
+<B>RASTER IMAGE</B>
+<P>
+ The raster image option on the menu at the bottom of the
+window allows the user to display any single file in the imagery
+group in the upper right quadrant of the window screen. The option
+provides the same file selection pick list as is presented when you
+first enter the <EM>i.vpoints</EM> program. When you select this option,
+the program will erase the data contained in all of the four
+quadrant windows and will reinitialize all program values.
+<P>
+<B>VECTOR MAPS</B>
+<P>
+ The vector maps option on the menu at the bottom of the screen
+allows the user to display vector map data in the upper right
+quadrant of the screen. After selecting the vector map layer to
+display, a menu selection bar appears along the bottom on the
+screen. This pick list is used to select the line color (blue,
+gray, green, red, white, or yellow) for the selected vector data
+layer.
+<P>
+<B>Refresh</B>
+<P>
+ The refresh option on the main menu allows the user to
+"refresh" or re-draw the displayed vector data. This function will
+erase all outlines showing the limits of previously zoomed areas.
+A "yes/no" roompt will appear:
+<PRE>
+ Refresh Map ? NO YES
+</PRE>
+<P>
+<B>Zoom</B>
+<P>
+ To enlarge a raster or vector image, place the mouse cross
+hairs on the word zoom on the main menu and press the left button.
+The following menu will be displayed at the bottom. of the screen:
+<PRE>
+ CANCEL BOX POINT Select type of zoom
+</PRE>
+You have the option to identify the map extent of the zoom window
+using either the mouse to define a box, or the mouse to mark a
+center point from which to enlarge the image. The box option first
+prompts you to identify a starting corner for the zoom region and
+then allows you to define the area to be zoomed using a rubber band
+box. The prompts appear as follows...
+<PRE>
+ CANCEL Mark the first corner of region
+ CANCEL Define the region
+</PRE>
+After marking the first corner of the region to be enlarged, hold
+down the left button and move the mouse to change the size and
+shape of the rubber band box. After defining the area to be
+enlarged, press the right button to accept it.
+<P>
+The point method for enlarging an image will display a mouse menu
+to guide you in selecting the appropriate enlargement. To enlarge
+or reduce the magnification factor, place the cursor on the "+" or
+"-" box and press the left button on the mouse.
+<P>
+<P>
+You may zoom either the raster or the vector display.
+<P>
+Upon accepting the new region limits, the raster or vector data are
+redisplayed in either the lower left (raster) or lower right
+(vector) windows.
+<P>
+The extent of the zoomed area is outlined on the unzoomed image in
+the main window area.
+<P>
+ While the main menu is displayed, you can mark
+corrosponding control points on the raster and vector
+images or enter map coordinates from the keyboard. If you
+are using coordinates taken from a reference map, circle
+these points and then use whatever means you have available
+to identify as precisely as possible the coordinate values
+for these points. Digitizing software is recommended,
+especially GRASS v.digit. Once you have
+determined the standard coordinates (for example, UTM's) of
+each circled point, you are ready to mark the points on the
+displayed image.
+<P>
+ To mark the points on the image, that correspond to the points
+on the standard coordinate map, place the mouse cross hairs on the
+point on the image to be marked (you will probably have to ZOOM to
+find the exact spot) and press the left hand button on the mouse.
+A diamond shaped symbol will be marked on the image. The text
+monitor will display the following screen:
+<PRE>
+ Point 1 marked on the image at
+ East: 1023.77
+ North: -164.41
+ Enter coordinates as east north:
+</PRE>
+<B>Analyze</B>
+<P>
+ After a number of points have been marked (a minimum of 4 for
+a 1st order transformation, 7 for a 2nd order, and 11 for a 3rd
+order), the RMS error of the points marked on the image can be
+checked. This is done by placing the cross hairs on the word
+ANALYZE on the main menu at the bottom of the monitor. The
+following error report is superimposed on the monitor:
+<PRE>
+ error image target
+ # col row target east north east north
+ 1 -0.9 0.0 1.0 1048.5 -144.8 679132.5 4351080.6
+ 2 1.0 0.4 1.3 2153.1 -567.2 684314.7 4399001.4
+ Overall rms error 76.85
+</PRE>
+ The RMS error for the image being rectified is recorded under
+the column "error" and subTITLEd "row' and "col". In the above
+report, the marked point number 1 is 0.0 rows and -0.9 columns from
+the predicted location calculated by the transformation equation.
+ The RMS error for the target database map is recorded under
+the heading "error" and the subheading "target". This is the RMS
+error for the east and the north coordinate values of the target
+map, but it is represented in the table using one general value.
+ The overall RMS error for the image is displayed at the bottom
+of the screen in meters. Points that generate a high RMS error are
+displayed in red on the monitor.
+ The x,y coordinate values of the point marked on the image
+being rectified are recorded under the heading "image" and the
+subheadings "east" and "north".
+ The standard coordinate values of the point in the target
+database are recorded under the heading "target" and the
+ If the user would like to exclude or include a point, this can
+be accomplished by placing the mouse cross hairs on the point
+number to be included (if the point is absent) or excluded (if the
+point is displayed) and then pressing the left button on the mouse
+twice. When a point is excluded, it is not included in the
+calculation of the RMS error, or included in the final
+transformation matrix. However, it can be retrieved within
+<EM>i.vpoints</EM> at any time by double clicking with the mouse as
+described above.
+<P>
+The following menu appears at the bottom of the monitor:
+<PRE>
+ DONE PRINT FILE OVERLAY DELETE ON Transformation -
+-> 1st ORDER Double click on point to be DELETED
+</PRE>
+Selecting DELETE ON will toggle the option to DELETE OFF, the
+toggle option is used to allow the user to physically remove a
+control point from the POINTS file instead of just flagging it as
+an non-active reference point.
+<P>
+<B>Overlay</B>
+<P>
+Overlay allows the user to overlay the vector map(s) onto the
+raster image. Overlay can be used to warp (register) and display
+the selected vector map data on top of the raster image contained
+in the upper left window of the color screen. An inverse
+coordinate transformation is performed using the currently active
+order of transformation (i.e., first, second, or third).
+<PRE>
+ Overlay vectors on raster image NO YES
+</PRE>
+By selecting the 1st ORDER option, the user may select the order of
+transformation desired:
+<PRE>
+ Select order of transformation --> 1st Order 2nd Order 3rd Order
+</PRE>
+The program will immediately recalculate the RMSE and the number of
+points required.
+<P>
+<B>Quit</B>
+<P>
+ To exit the <EM>i.vpoints</EM> program, place the mouse cross hairs on
+the word QUIT at the bottom of the monitor and all of the marked
+points (including coordinates) will be saved.
+<H2>SEE ALSO</H2>
+The GRASS 4 <em>
+<P>
+<EM>
+<A HREF="g.mapsets.html">g.mapsets</A><BR>
+<A HREF="i.rectify.html">i.rectify</A><BR>
+</EM><br>
+<H2>AUTHOR</H2>
+William R. Enslin, Michigan State University Center for Remote Sensing<br>
+Radim Blazek (update to GRASS 5.7)<BR>
+Hamish Bowman (finish GRASS 6 porting)
+<p>
Deleted: grass/trunk/imagery/i.zc/description.html
--- grass/trunk/imagery/i.zc/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/imagery/i.zc/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,113 +0,0 @@
-<EM>i.zc</EM> is an image processing program used for edge
-detection. The raster map produced shows the location of
-"boundaries" on the input map. Boundaries tend to be found
-in regions of changing cell values and tend to run
-perpendicular to the direction of the slope. The algorithm
-used for edge detection is one of the "zero-crossing"
-algorithms and is discussed briefly below.
-<P>
-This program will be run interactively if the user types
-<B>i.zc</B> without program arguments on the command line.
-In this event, the program will prompt the user for
-parameter values using the standard interface described in
-the manual entry for <EM><A HREF="parser.html">parser</A></EM>.
-Alternately, the
-user can run the program non-interactively by specifying
-program parameter values on the command line.
-<H2>OPTIONS</H2>
-<H3>Parameters:</H3>
-<DL>
-<DT><B>input_map=</B><EM>name</EM>
-<DD>Name of input raster map layer.
-<DT><B>zc_map=</B><EM>name</EM>
-<DD>Name of raster map layer to be used for zero-crossing values.
-<DT><B>width=</B><EM>value</EM>
-<DD>This parameter determines the x-y extent of the
-Gaussian filter. The default value is 9; higher and lower
-values can be tested by the user. Increasing the width
-will result in finding "edges" representing more gradual
-changes in cell values.
-<BR>
-Default: 9
-<DT><B>threshold=</B><EM>value</EM>
-<DD>This parameter determines the "sensitivity" of the
-Gaussian filter. The default value is 10; higher and
-lower values can be tested by the user. Increasing the
-threshold value will result in fewer edges being found.
-<BR>
-Default: 10
-<DT><B>orientations=</B><EM>value</EM>
-<DD>This value is the number of azimuth directions the
-cells on the output raster map layer are categorized into
-(similar to the aspect raster map layer produced by the
-<EM><A HREF="r.slope.aspect.html">r.slope.aspect</A></EM>
-program). For example, a value of 16 would result in
-detected edges being categorized into one of 16 bins
-depending on the direction of the edge at that point.
-<BR>
-Default: 1
-</DL>
-The current region definition and mask settings are respected
-when reading the input map.
-<H2>NOTES</H2>
-The procedure to find the "edges" in the image is as follows:
-<OL>
-<LI> The Fourier transform of the image is taken,
-<LI> The Fourier transform of the Laplacian of a two-dimensional
-Gaussian function is used to filter the transformed image,
-<LI> The result is run through an inverse Fourier transform,
-<LI> The resulting image is traversed in search of places where the image
-changes from positive to negative or from negative to positive,
-<LI> Each cell in the map where the value crosses zero
-(with a change in value greater than the threshold value)
-is marked as an edge and an orientation is assigned to it.
-The resulting raster map layer is output.
-</OL>
-<H2>SEE ALSO</H2>
-<EM><A HREF="i.fft.html">i.fft</A></EM>,
-<EM><A HREF="i.ifft.html">i.ifft</A></EM>,
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>,
-<EM><A HREF="r.mfilter.html">r.mfilter</A></EM>,
-<H2>AUTHOR</H2>
Copied: grass/trunk/imagery/i.zc/i.zc.html (from rev 32770, grass/trunk/imagery/i.zc/description.html)
--- grass/trunk/imagery/i.zc/i.zc.html (rev 0)
+++ grass/trunk/imagery/i.zc/i.zc.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,113 @@
+<EM>i.zc</EM> is an image processing program used for edge
+detection. The raster map produced shows the location of
+"boundaries" on the input map. Boundaries tend to be found
+in regions of changing cell values and tend to run
+perpendicular to the direction of the slope. The algorithm
+used for edge detection is one of the "zero-crossing"
+algorithms and is discussed briefly below.
+<P>
+This program will be run interactively if the user types
+<B>i.zc</B> without program arguments on the command line.
+In this event, the program will prompt the user for
+parameter values using the standard interface described in
+the manual entry for <EM><A HREF="parser.html">parser</A></EM>.
+Alternately, the
+user can run the program non-interactively by specifying
+program parameter values on the command line.
+<H2>OPTIONS</H2>
+<H3>Parameters:</H3>
+<DL>
+<DT><B>input_map=</B><EM>name</EM>
+<DD>Name of input raster map layer.
+<DT><B>zc_map=</B><EM>name</EM>
+<DD>Name of raster map layer to be used for zero-crossing values.
+<DT><B>width=</B><EM>value</EM>
+<DD>This parameter determines the x-y extent of the
+Gaussian filter. The default value is 9; higher and lower
+values can be tested by the user. Increasing the width
+will result in finding "edges" representing more gradual
+changes in cell values.
+<BR>
+Default: 9
+<DT><B>threshold=</B><EM>value</EM>
+<DD>This parameter determines the "sensitivity" of the
+Gaussian filter. The default value is 10; higher and
+lower values can be tested by the user. Increasing the
+threshold value will result in fewer edges being found.
+<BR>
+Default: 10
+<DT><B>orientations=</B><EM>value</EM>
+<DD>This value is the number of azimuth directions the
+cells on the output raster map layer are categorized into
+(similar to the aspect raster map layer produced by the
+<EM><A HREF="r.slope.aspect.html">r.slope.aspect</A></EM>
+program). For example, a value of 16 would result in
+detected edges being categorized into one of 16 bins
+depending on the direction of the edge at that point.
+<BR>
+Default: 1
+</DL>
+The current region definition and mask settings are respected
+when reading the input map.
+<H2>NOTES</H2>
+The procedure to find the "edges" in the image is as follows:
+<OL>
+<LI> The Fourier transform of the image is taken,
+<LI> The Fourier transform of the Laplacian of a two-dimensional
+Gaussian function is used to filter the transformed image,
+<LI> The result is run through an inverse Fourier transform,
+<LI> The resulting image is traversed in search of places where the image
+changes from positive to negative or from negative to positive,
+<LI> Each cell in the map where the value crosses zero
+(with a change in value greater than the threshold value)
+is marked as an edge and an orientation is assigned to it.
+The resulting raster map layer is output.
+</OL>
+<H2>SEE ALSO</H2>
+<EM><A HREF="i.fft.html">i.fft</A></EM>,
+<EM><A HREF="i.ifft.html">i.ifft</A></EM>,
+<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>,
+<EM><A HREF="r.mfilter.html">r.mfilter</A></EM>,
+<H2>AUTHOR</H2>
Modified: grass/trunk/lib/cairodriver/Makefile
--- grass/trunk/lib/cairodriver/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/cairodriver/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -2,19 +2,17 @@
include $(MODULE_TOPDIR)/include/Make/Platform.make
-PACKAGE ="libcairodriver"
-DEFS=-DPACKAGE=\"$(PACKAGE)\"
-EXTRA_CFLAGS=-I../driver $(CAIROINC) $(PICFLAGS) $(DEFS)
+EXTRA_CFLAGS=-I../driver $(CAIROINC)
EXTRA_LIBS=$(DRIVERLIB) $(GISLIB) $(CAIROLIB)
# added constant to /include/Make/Grass.make.in
LIB_NAME = $(CAIRODRIVER_LIBNAME)
+PGM = cairodriver
include $(MODULE_TOPDIR)/include/Make/Lib.make
ifneq ($(USE_CAIRO),)
-default: lib
+default: lib htmldir
else
default:
endif
Copied: grass/trunk/lib/cairodriver/cairodriver.html (from rev 32770, grass/trunk/lib/cairodriver/description.html)
--- grass/trunk/lib/cairodriver/cairodriver.html (rev 0)
+++ grass/trunk/lib/cairodriver/cairodriver.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,174 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<HTML>
+<HEAD>
+ <TITLE>Cairo driver</TITLE>
+ <META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
+ <link rel="stylesheet" href="grassdocs.css" type="text/css">
+</HEAD>
+<BODY bgColor=white>
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<H2>NAME</H2>
+<EM><B>Cairo driver</B></EM> - driver for bitmap or vector output using
+the Cairo graphics library.
+<BR>
+<EM>(drivers)</EM>
+The Cairo driver generates PNG, BMP, PPM, PS, PDF or SVG images from GRASS
+display commands, using the
+<A HREF="http://www.cairographics.org/">Cairo graphics library</A>.
+The image format is selected from the extension of the output file.
+<P>
+It is started as 'pseudo' monitor (output to an image file) and when
+stopped, all output from previously used display commands are written to
+the output file.
+<H2>USAGE</H2>
+<H3>Environment variables</H3>
+Several environment variables affect the operation of the Cairo driver:
+<UL>
+ <LI><B>GRASS_WIDTH=xxx</B><BR>
+ the width of the image.
+ </LI><BR>
+ <LI><B>GRASS_HEIGHT=yyy</B><BR>
+ the height of the image.
+ </LI><BR>
+ <LI><B>GRASS_CAIROFILE=filename</B><BR>
+ the name and format of the resulting image file, default is
+ <tt>map.png</tt>.<BR>
+ The image format is determined from the file extension.<BR>
+ Supported bitmap formats:
+ <UL>
+ <LI><B>.png</B> - Portable Network Graphics (PNG)</LI>
+ <LI><B>.bmp</B> - Windows Bitmap (BMP)</LI>
+ <LI><B>.ppm</B> - Portable Pixmap (PPM)</LI>
+ </UL>
+ Supported vector formats:
+ <UL>
+ <LI><B>.pdf</B> - Portable Document Format (PDF)</LI>
+ <LI><B>.ps</B> - PostScript (PS)</LI>
+ <LI><B>.svg</B> - Scalable Vector Graphics (SVG)</LI>
+ </UL>
+ (Note: Some formats may not be available, depending on your platform and
+ the Cairo library that GRASS was built with.)
+ </LI><BR>
+ <LI><B>GRASS_BACKGROUNDCOLOR=RRGGBB</B><BR>
+ specifies the background color to use in RGB
+ notation (hex values). Default is <b>FFFFFF</b> (white).
+ </LI><BR>
+ <LI><B>GRASS_TRANSPARENT=[TRUE|FALSE]</B><BR>
+ sets transparent background on (TRUE) or off (FALSE, default).
+ </LI><BR>
+ <LI><B>GRASS_AUTO_WRITE=[TRUE|FALSE]</B><BR>
+ if set to <tt>TRUE</tt>, the image file will be written after each
+ operation (i.e. whenever a client disconnects), rather than
+ only being written out when the driver terminates.<BR>
+ (Note: This only applies to bitmap formats - vector formats
+ are always written directly to file).
+ </LI><BR>
+ <LI><B>GRASS_CAIRO_READ</B><BR>
+ if <tt>TRUE</tt>, the Cairo driver will initialize the image from
+ the contents of GRASS_CAIROFILE.<BR>
+ (Note: This is only supported for bitmap formats)
+ </LI><BR>
+ <LI><B>GRASS_CAIRO_MAPPED</B><BR>
+ if <tt>TRUE</tt>, the Cairo driver will map GRASS_CAIROFILE as its framebuffer,
+ rather than using memory. This only works with BMP files.
+ </LI>
+</UL>
+<H3>Examples</H3>
+Example using the driver directly (bash-syntax):
+<div class="code"><PRE>
+export GRASS_WIDTH=800
+export GRASS_HEIGHT=800
+d.mon start=cairo
+d.rast map=elevation.10m
+d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
+d.vect map=roads width=2
+d.mon stop=cairo
+</PRE></div>
+Example using <em><a href="d.out.file.html">d.out.file</a></em>:
+d.mon x0
+d.out.file -c sf_cairo format=png size=800,800
+</PRE></div>
+<P>
+A more complicated example using <em><a href="d.out.file.html">d.out.file</a></em>:
+r.shaded.relief map=elevation.dem
+r.watershed elev=elevation.dem basin=watershed.basin thresh=10000
+d.mon x1
+d.shadedmap rel=elevation.dem.shade drape=watershed.basin bright=30
+d.vect streams color=aqua fcolor=aqua type=area,line
+d.vect roads where="label ~ 'light-duty road'" color=grey
+d.vect roads where="label ~ 'unimproved'" color=orange
+d.vect roads where="label ~ 'secondary highway'" color=100:100:100 width=2
+d.vect roads where="label ~ 'primary highway'" color=50:50:50 width=2
+d.vect railroads col=red width=2
+d.vect roads where="label = 'interstate'" color=black width=3
+d.vect archsites icon=basic/star size=25 fcolor=yellow
+d.font Andale_Mono
+echo "Spearfish, SD" | d.text color=black at=28,53 -b
+d.out.file -c sf_cairo2 format=png
+</PRE></div>
+<H2>NOTES</H2>
+The driver is still in development. Enable it by specifying
+<CODE>--with-cairo</CODE> when configuring GRASS. This
+requires a reasonably recent version of the Cairo libraries
+and a working pkg-config.
+<P>
+Antialiasing is enabled by default for bitmap formats. There is
+currently no way of disabling this.
+<P>
+Cairo supports true vector format output whenever possible. However,
+if the selected format doesn't support a necessary feature, Cairo may
+fall back on rendering a bitmap representation of the image wrapped in
+the selected vector format.
+<P>
+Cairo driver output via <em><A HREF="d.out.file.html">d.out.file</A></em>
+is supported via the -c flag.</P>
+<h2>SEE ALSO</h2>
+<EM>
+<A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
+<A HREF="pngdriver.html">PNG driver</A>,
+<A HREF="psdriver.html">PostScript driver</A>,
+<A href="xdriver.html">XDRIVER</A>
+<BR>
+<A HREF="d.frame.html">d.frame</A>,
+<A href="d.mon.html">d.mon</A>,
+<A href="d.rast.html">d.rast</A>,
+<A href="d.vect.html">d.vect</A>
+<A href="d.out.file.html">d.out.file</A>
+</EM>
+<H2>AUTHOR</H2>
+Lars Ahlzen <<I>lars (at) ahlzen.com</I>><BR>
+and the GRASS Development Team.
Deleted: grass/trunk/lib/cairodriver/description.html
--- grass/trunk/lib/cairodriver/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/cairodriver/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,174 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
-<HTML>
-<HEAD>
- <TITLE>Cairo driver</TITLE>
- <META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
- <link rel="stylesheet" href="grassdocs.css" type="text/css">
-</HEAD>
-<BODY bgColor=white>
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<H2>NAME</H2>
-<EM><B>Cairo driver</B></EM> - driver for bitmap or vector output using
-the Cairo graphics library.
-<BR>
-<EM>(drivers)</EM>
-The Cairo driver generates PNG, BMP, PPM, PS, PDF or SVG images from GRASS
-display commands, using the
-<A HREF="http://www.cairographics.org/">Cairo graphics library</A>.
-The image format is selected from the extension of the output file.
-<P>
-It is started as 'pseudo' monitor (output to an image file) and when
-stopped, all output from previously used display commands are written to
-the output file.
-<H2>USAGE</H2>
-<H3>Environment variables</H3>
-Several environment variables affect the operation of the Cairo driver:
-<UL>
- <LI><B>GRASS_WIDTH=xxx</B><BR>
- the width of the image.
- </LI><BR>
- <LI><B>GRASS_HEIGHT=yyy</B><BR>
- the height of the image.
- </LI><BR>
- <LI><B>GRASS_CAIROFILE=filename</B><BR>
- the name and format of the resulting image file, default is
- <tt>map.png</tt>.<BR>
- The image format is determined from the file extension.<BR>
- Supported bitmap formats:
- <UL>
- <LI><B>.png</B> - Portable Network Graphics (PNG)</LI>
- <LI><B>.bmp</B> - Windows Bitmap (BMP)</LI>
- <LI><B>.ppm</B> - Portable Pixmap (PPM)</LI>
- </UL>
- Supported vector formats:
- <UL>
- <LI><B>.pdf</B> - Portable Document Format (PDF)</LI>
- <LI><B>.ps</B> - PostScript (PS)</LI>
- <LI><B>.svg</B> - Scalable Vector Graphics (SVG)</LI>
- </UL>
- (Note: Some formats may not be available, depending on your platform and
- the Cairo library that GRASS was built with.)
- </LI><BR>
- <LI><B>GRASS_BACKGROUNDCOLOR=RRGGBB</B><BR>
- specifies the background color to use in RGB
- notation (hex values). Default is <b>FFFFFF</b> (white).
- </LI><BR>
- <LI><B>GRASS_TRANSPARENT=[TRUE|FALSE]</B><BR>
- sets transparent background on (TRUE) or off (FALSE, default).
- </LI><BR>
- <LI><B>GRASS_AUTO_WRITE=[TRUE|FALSE]</B><BR>
- if set to <tt>TRUE</tt>, the image file will be written after each
- operation (i.e. whenever a client disconnects), rather than
- only being written out when the driver terminates.<BR>
- (Note: This only applies to bitmap formats - vector formats
- are always written directly to file).
- </LI><BR>
- <LI><B>GRASS_CAIRO_READ</B><BR>
- if <tt>TRUE</tt>, the Cairo driver will initialize the image from
- the contents of GRASS_CAIROFILE.<BR>
- (Note: This is only supported for bitmap formats)
- </LI><BR>
- <LI><B>GRASS_CAIRO_MAPPED</B><BR>
- if <tt>TRUE</tt>, the Cairo driver will map GRASS_CAIROFILE as its framebuffer,
- rather than using memory. This only works with BMP files.
- </LI>
-</UL>
-<H3>Examples</H3>
-Example using the driver directly (bash-syntax):
-<div class="code"><PRE>
-export GRASS_WIDTH=800
-export GRASS_HEIGHT=800
-d.mon start=cairo
-d.rast map=elevation.10m
-d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
-d.vect map=roads width=2
-d.mon stop=cairo
-</PRE></div>
-Example using <em><a href="d.out.file.html">d.out.file</a></em>:
-d.mon x0
-d.out.file -c sf_cairo format=png size=800,800
-</PRE></div>
-<P>
-A more complicated example using <em><a href="d.out.file.html">d.out.file</a></em>:
-r.shaded.relief map=elevation.dem
-r.watershed elev=elevation.dem basin=watershed.basin thresh=10000
-d.mon x1
-d.shadedmap rel=elevation.dem.shade drape=watershed.basin bright=30
-d.vect streams color=aqua fcolor=aqua type=area,line
-d.vect roads where="label ~ 'light-duty road'" color=grey
-d.vect roads where="label ~ 'unimproved'" color=orange
-d.vect roads where="label ~ 'secondary highway'" color=100:100:100 width=2
-d.vect roads where="label ~ 'primary highway'" color=50:50:50 width=2
-d.vect railroads col=red width=2
-d.vect roads where="label = 'interstate'" color=black width=3
-d.vect archsites icon=basic/star size=25 fcolor=yellow
-d.font Andale_Mono
-echo "Spearfish, SD" | d.text color=black at=28,53 -b
-d.out.file -c sf_cairo2 format=png
-</PRE></div>
-<H2>NOTES</H2>
-The driver is still in development. Enable it by specifying
-<CODE>--with-cairo</CODE> when configuring GRASS. This
-requires a reasonably recent version of the Cairo libraries
-and a working pkg-config.
-<P>
-Antialiasing is enabled by default for bitmap formats. There is
-currently no way of disabling this.
-<P>
-Cairo supports true vector format output whenever possible. However,
-if the selected format doesn't support a necessary feature, Cairo may
-fall back on rendering a bitmap representation of the image wrapped in
-the selected vector format.
-<P>
-Cairo driver output via <em><A HREF="d.out.file.html">d.out.file</A></em>
-is supported via the -c flag.</P>
-<h2>SEE ALSO</h2>
-<EM>
-<A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
-<A HREF="pngdriver.html">PNG driver</A>,
-<A HREF="psdriver.html">PostScript driver</A>,
-<A href="xdriver.html">XDRIVER</A>
-<BR>
-<A HREF="d.frame.html">d.frame</A>,
-<A href="d.mon.html">d.mon</A>,
-<A href="d.rast.html">d.rast</A>,
-<A href="d.vect.html">d.vect</A>
-<A href="d.out.file.html">d.out.file</A>
-</EM>
-<H2>AUTHOR</H2>
-Lars Ahlzen <<I>lars (at) ahlzen.com</I>><BR>
-and the GRASS Development Team.
Modified: grass/trunk/lib/db/sqlp/Makefile
--- grass/trunk/lib/db/sqlp/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/db/sqlp/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,6 +1,7 @@
MODULE_TOPDIR = ../../..
LIB_NAME = $(SQLP_LIBNAME)
+PGM = sql
LIB_OBJS = \
alloc.o \
@@ -14,9 +15,7 @@
-default: lib
- $(MKDIR) $(GISBASE)/docs/html
- $(INSTALL_DATA) description.html $(GISBASE)/docs/html/sql.html
y.tab.c y.tab.h: yac.y
$(YACC) -d -v yac.y
Deleted: grass/trunk/lib/db/sqlp/description.html
--- grass/trunk/lib/db/sqlp/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/db/sqlp/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,150 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>SQL support in GRASS GIS</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<!-- This file is lib/db/sqlp/description.html -->
-<body bgcolor="white">
-<H2>SQL support in GRASS GIS</H2>
-GRASS can use various RDBMS and embedded databases.
-SQL queries are directly passed to the underlying
-database system.
-The set of supported SQL commands depends on the RDMBS
-and driver selected.
-<H2>Drivers</H2>
-The list of available drivers can vary in various binary
-distributions of GRASS.
-<p>
-<table border=1 >
-<tr><td><a href="grass-dbf.html">dbf</a></td><td>DBF files. Data are stored in DBF files.</td>
-<td><a href="http://shapelib.maptools.org/dbf_api.html">http://shapelib.maptools.org/dbf_api.html</a></td></tr>
-<tr><td><a href="grass-sqlite.html">sqlite</a></td><td>SQLite embedded database.</td>
-<td><a href="http://sqlite.org/">http://sqlite.org/</a></td></tr>
-<tr><td><a href="grass-pg.html">pg</a></td><td>PostgreSQL RDBMS.</td>
-<td><a href="http://postgresql.org/">http://postgresql.org/</a></td></tr>
-<tr><td><a href="grass-mysql.html">mysql</a></td><td>MySQL RDBMS.</td>
-<td><a href="http://mysql.org/">http://mysql.org/</a></td></tr>
-<tr><td><a href="grass-mesql.html">mesql</a></td><td>MySQL embedded database.</td>
-<tr><td><a href="grass-odbc.html">odbc</a></td><td>UnixODBC. (PostgreSQL, Oracle, etc.)</td>
-<td><a href="http://www.unixodbc.org/">http://www.unixodbc.org/</a></td></tr>
-</table>
-<H2>NOTES</H2>
-<ul>
-<li> SQL does not support '.' (dots) in table names.
-<li> Supported table name characters are only:<br>
- [A-Za-z][A-Za-z0-9_]*
-<li> A table name must start with a character, not a number.
-<li> Text-string matching requires the text part to be 'single quoted'.
-When run from the command line multiple queries should be contained
-in "double quotes". e.g.<br>
-<div class="code"><pre>
-d.vect map where="individual='juvenile' and area='beach'"
-</pre></div>
-<li> An error message such as "dbmi: Protocol error" either indicates an invalid column name
- or an unsupported column type (then the GRASS SQL parser needs to be extended).
-<li> DBF column names are limited to 10 characters (DBF API definition)
-</ul>
-<h2>EXAMPLES</h2>
-Display all vector points except for LAMAR valley and <i>extensive trapping</i> (brackets are superfluous in this example):
-d.vect trapping_sites_points fcol=black icon=basic/diamond col=white size=13 \
- where="valley <> 'LAMAR' OR (valley = 'LAMAR' AND description = 'extensive trapping')"
-</pre></div>
-<p>
-Select all attributes from table where str1 column values are not 'No Name':
-echo "SELECT * FROM archsites WHERE str1 <> 'No Name'" | db.select
-</pre></div>
-<p>
-<p>Example of subquery expressions from a list (does not work for DBF driver):
-v.db.select mysites where="id IN ('P04', 'P05')"
-</pre></div>
-<p>Example of pattern matching:
-# match exactly number of characters (here: 2), does not work for DBF driver:
-v.db.select mysites where="id LIKE 'P__'"
-#define wildcard:
-v.db.select mysites where="id LIKE 'P%'"
-</pre></div>
-<p>Example of null handling:
-v.db.addcol map=roads col="nulltest int"
-v.db.update map=roads col=nulltest value=1 where="cat > 2"
-d.vect roads where="nulltest is null"
-v.db.update map=roads col=nulltest value=2 where="cat <= 2"
-</pre></div>
-<p>Examples of complex expressions in updates (using v.db.* modules):
-v.db.addcol map=roads col="exprtest double precision"
-v.db.update map=roads col=exprtest value=cat/nulltest
-v.db.update map=roads col=exprtest value=cat/nulltest+cat where=cat=1
-</pre></div>
-<p>Examples of complex expressions in updates (using db.* modules):
-echo "UPDATE roads SET exprtest=null"
-echo "UPDATE roads SET exprtest=cat/2" | db.execute
-echo "UPDATE roads SET exprtest=cat/2+cat/3" | db.execute
-echo "UPDATE roads SET exprtest=NULL WHERE cat>2" | db.execute
-echo "UPDATE roads SET exprtest=cat/3*(cat+1) WHERE exprtest IS NULL" | db.execute"
-</pre></div>
-<p>
-Instead of creating and updating new columns with an expression,
-you can use the expression directly in a command:
-d.vect roads where="(cat/3*(cat+1))>8"
-d.vect roads where="cat>exprtest"
-</pre></div>
-<h2>SEE ALSO</h2>
-<a href="databaseintro.html">Database management in GRASS GIS</a>,<BR>
-<a href="database.html">Help pages for database modules</a>,<BR>
-<a href=http://www.redhat.com/docs/manuals/database/RHDB-2.1-Manual/sql/sqlreference.html>SQL
- Guide and Reference</a> (Red Hat)
-<p><i>Last changed: $Date$</i></p>
-<HR>
-<BR><a href=index.html>Help Index</a>
-<P>© 2008 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
-</body>
-</html>
Copied: grass/trunk/lib/db/sqlp/sql.html (from rev 32770, grass/trunk/lib/db/sqlp/description.html)
--- grass/trunk/lib/db/sqlp/sql.html (rev 0)
+++ grass/trunk/lib/db/sqlp/sql.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,150 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>SQL support in GRASS GIS</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<!-- This file is lib/db/sqlp/description.html -->
+<body bgcolor="white">
+<H2>SQL support in GRASS GIS</H2>
+GRASS can use various RDBMS and embedded databases.
+SQL queries are directly passed to the underlying
+database system.
+The set of supported SQL commands depends on the RDMBS
+and driver selected.
+<H2>Drivers</H2>
+The list of available drivers can vary in various binary
+distributions of GRASS.
+<p>
+<table border=1 >
+<tr><td><a href="grass-dbf.html">dbf</a></td><td>DBF files. Data are stored in DBF files.</td>
+<td><a href="http://shapelib.maptools.org/dbf_api.html">http://shapelib.maptools.org/dbf_api.html</a></td></tr>
+<tr><td><a href="grass-sqlite.html">sqlite</a></td><td>SQLite embedded database.</td>
+<td><a href="http://sqlite.org/">http://sqlite.org/</a></td></tr>
+<tr><td><a href="grass-pg.html">pg</a></td><td>PostgreSQL RDBMS.</td>
+<td><a href="http://postgresql.org/">http://postgresql.org/</a></td></tr>
+<tr><td><a href="grass-mysql.html">mysql</a></td><td>MySQL RDBMS.</td>
+<td><a href="http://mysql.org/">http://mysql.org/</a></td></tr>
+<tr><td><a href="grass-mesql.html">mesql</a></td><td>MySQL embedded database.</td>
+<tr><td><a href="grass-odbc.html">odbc</a></td><td>UnixODBC. (PostgreSQL, Oracle, etc.)</td>
+<td><a href="http://www.unixodbc.org/">http://www.unixodbc.org/</a></td></tr>
+</table>
+<H2>NOTES</H2>
+<ul>
+<li> SQL does not support '.' (dots) in table names.
+<li> Supported table name characters are only:<br>
+ [A-Za-z][A-Za-z0-9_]*
+<li> A table name must start with a character, not a number.
+<li> Text-string matching requires the text part to be 'single quoted'.
+When run from the command line multiple queries should be contained
+in "double quotes". e.g.<br>
+<div class="code"><pre>
+d.vect map where="individual='juvenile' and area='beach'"
+</pre></div>
+<li> An error message such as "dbmi: Protocol error" either indicates an invalid column name
+ or an unsupported column type (then the GRASS SQL parser needs to be extended).
+<li> DBF column names are limited to 10 characters (DBF API definition)
+</ul>
+<h2>EXAMPLES</h2>
+Display all vector points except for LAMAR valley and <i>extensive trapping</i> (brackets are superfluous in this example):
+d.vect trapping_sites_points fcol=black icon=basic/diamond col=white size=13 \
+ where="valley <> 'LAMAR' OR (valley = 'LAMAR' AND description = 'extensive trapping')"
+</pre></div>
+<p>
+Select all attributes from table where str1 column values are not 'No Name':
+echo "SELECT * FROM archsites WHERE str1 <> 'No Name'" | db.select
+</pre></div>
+<p>
+<p>Example of subquery expressions from a list (does not work for DBF driver):
+v.db.select mysites where="id IN ('P04', 'P05')"
+</pre></div>
+<p>Example of pattern matching:
+# match exactly number of characters (here: 2), does not work for DBF driver:
+v.db.select mysites where="id LIKE 'P__'"
+#define wildcard:
+v.db.select mysites where="id LIKE 'P%'"
+</pre></div>
+<p>Example of null handling:
+v.db.addcol map=roads col="nulltest int"
+v.db.update map=roads col=nulltest value=1 where="cat > 2"
+d.vect roads where="nulltest is null"
+v.db.update map=roads col=nulltest value=2 where="cat <= 2"
+</pre></div>
+<p>Examples of complex expressions in updates (using v.db.* modules):
+v.db.addcol map=roads col="exprtest double precision"
+v.db.update map=roads col=exprtest value=cat/nulltest
+v.db.update map=roads col=exprtest value=cat/nulltest+cat where=cat=1
+</pre></div>
+<p>Examples of complex expressions in updates (using db.* modules):
+echo "UPDATE roads SET exprtest=null"
+echo "UPDATE roads SET exprtest=cat/2" | db.execute
+echo "UPDATE roads SET exprtest=cat/2+cat/3" | db.execute
+echo "UPDATE roads SET exprtest=NULL WHERE cat>2" | db.execute
+echo "UPDATE roads SET exprtest=cat/3*(cat+1) WHERE exprtest IS NULL" | db.execute"
+</pre></div>
+<p>
+Instead of creating and updating new columns with an expression,
+you can use the expression directly in a command:
+d.vect roads where="(cat/3*(cat+1))>8"
+d.vect roads where="cat>exprtest"
+</pre></div>
+<h2>SEE ALSO</h2>
+<a href="databaseintro.html">Database management in GRASS GIS</a>,<BR>
+<a href="database.html">Help pages for database modules</a>,<BR>
+<a href=http://www.redhat.com/docs/manuals/database/RHDB-2.1-Manual/sql/sqlreference.html>SQL
+ Guide and Reference</a> (Red Hat)
+<p><i>Last changed: $Date$</i></p>
+<HR>
+<BR><a href=index.html>Help Index</a>
+<P>© 2008 <a href="http://grass.osgeo.org">GRASS Development Team</a></P>
+</body>
+</html>
Modified: grass/trunk/lib/htmldriver/Makefile
--- grass/trunk/lib/htmldriver/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/htmldriver/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -2,13 +2,12 @@
-PACKAGE ="libhtmldriver"
-EXTRA_CFLAGS=-I../driver $(PICFLAGS) $(DEFS)
LIB_NAME = $(HTMLDRIVER_LIBNAME)
+PGM = htmldriver
-default: lib
Deleted: grass/trunk/lib/htmldriver/description.html
--- grass/trunk/lib/htmldriver/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/htmldriver/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,190 +0,0 @@
-<HTML>
-<HEAD>
- <TITLE>HTMLMAP driver</TITLE>
-</HEAD>
-<H2>NAME</H2>
-<EM><B>HTMLMAP driver</B></EM> - driver to create HTML image maps.
-<BR><EM>(drivers)</EM>
-<H2>DESCRIPTION</H2>
-The HTMLMAP driver allows the generation of HTML image maps
-for area vector data. HTML image maps are used in conjunction with images to
-provide unique URL targets for different portions of an image. The HTMLMAP
-driver can create both client-side image maps embedded into HTML files, or
-server-side image maps used by web server software.
-<P>
-Note that GRASS display commands that require the MOUSE will not work
-correctly (or at all!)
-<P>
-Polygons can at most have 100 vertices (this limit imposed by HTML image map
-formats, see <B>GRASS_HTMLMAXPOINTS</B> below.) The driver will attempt to
-trim polygons that have more that 100
-vertices by removing vertices with the least amount of angle to the next
-vertice. Also, any polygon that is entirely bounded by another polygon will be
-discarded.
-<P>
-Text written to the driver before polygons are used as the HREF tag for all
-subsequent polygons written. All polygons that exist in a vector map will have
-the same HREF tag.
-<P>
-The only GRASS display commands that should be used with this driver are:
-<UL>
- <LI><a href="d.text.html">d.text</A>
- - pass href information for resulting image maps.</LI>
- <LI><a href="d.vect.html">d.vect</A>
- - draw polygons from a vector map.</LI>
-</UL>
-<H2>USAGE</H2>
-<H3>Environment variables</H3>Several environment variables effect the operation
-of HTMLMAP.
-<UL>
- <LI><B>GRASS_WIDTH=xxx</B><BR>the width of the image map (default is
- 640).
- </LI><BR>
- <LI><B>GRASS_HEIGHT=yyy</B><BR>the height of the image map (default is
- 480).
- </LI><BR>
- <LI><B>GRASS_HTMLTYPE=type</B><BR>the type of image mape to create (default is
- CLIENT):
- <UL>
- <DD><TT><B>CLIENT</B></TT> Netscape/IE client-side image map.
- (NAME="map")<BR>
- <DD><TT><B>APACHE</B></TT> Apache/NCSA server-side image
- map.<BR>
- <DD><TT><B>RAW</B></TT> Raw url
- and polygon vertices ( <I>url x1 y1 x2 y2
- ..... </I>), suitable for conversion to CERN server format, or any other
- format with user supplied conversion program.</DD>
- </UL>
- </LI><BR>
- <LI><B>GRASS_HTMLFILE=filename</B><BR>
- specifies the resulting file to store
- the html image map, default is <tt>htmlmap</tt>. Files without absolute path
- names are written in the current directory where the driver was started.
- <BR>
- <em>Any existing file of the same name is overwritten without
- warning.</em>
- </LI><BR>
- <LI><B>GRASS_HTMLMINDIST=n</B><BR>specifies the minimum distance in pixels
- that a point must change from the previous point to keep in the list of
- vertices for a polygon. The default is <tt>2</tt>, which means that a
- point's x and y difference from the previous point must change by a number
- of pixels greater than this value. This parameter helps to eliminate
- closely spaced points.
- </LI><BR>
- <LI><B>GRASS_HTMLMINBBOX=n</B><BR>specifies the minimum bounding box
- dimensions to record a polygon as a clickable area.
- The default is <tt>2</tt>, which means that a polygon with a bounding box
- of less than this value is not included. This parameter helps to eliminate
- polygons than are a point or line.
- </LI><BR>
- <LI><B>GRASS_HTMLMAXPOINTS=n</B><BR>specifies the maximum number of
- vertices included in a polygon's clickable area.
- The default is <tt>99</tt>. Some browsers can only accomodate polygons of
- 100 vertices or less. The HTMLMAP driver automatically ensures that a
- polygon is closed by making the last point the same as the first
- point.</LI><BR>
-</UL>
-<H3>Typical usage</H3>
-<UL>
- <LI>Start up the driver
-<DIV class="code"><PRE>
-d.mon start=HTMLMAP
-</PRE></DIV>
- </LI>
- <LI>Display text strings (HREF's) and polygons
-echo "http://www.no-such-place.net/area51/" | d.text
-d.vect map=area51
-echo "http://www.roswell-nm.net/little/green/men.html" | d.text
-d.vect map=roswell
-</PRE></div>
- <LI>Stop the driver when all polygon have been displayed. This will cause a file
- named 'htmlmap' to be created in your current directory.
-d.mon stop=HTMLMAP
-</PRE></DIV>
- <LI>You will also want to create an image for your image map. Use the PNG
- driver and other utilities to create .gif or .jpg files.
- <i>The following example is somewhat out of date and refers to options
- available in GRASS 5.</i>
-# using previous GRASS_WIDTH & GRASS_HEIGHT
-d.mon start=PNG
-d.mon select=PNG
-d.rast map=terrain
-d.vect map=area51 fillcolor=white linecolor=blue
-d.vect map=roswell fillcolor=yellow linecolor=blue
-d.vect map=states color=green
-d.vect map=roads color=black
-d.mon stop=PNG
-<!-- ???? FIXME -->
-# make the region the same as the newly created cell for ppm export
-g.region save=saved.reg
-g.region raster=D_cell
-r.out.ppm -q input=D_cell output=alien.ppm
-# use the netpbm utilities to create a gif (quantize if needed)
-# assemble some html with the image and the image map
-echo '<html><body><img src="alien.gif" usemap="#map">' >alien.html
-cat htmlmap >>alien.html
-echo '</body></html>' >>alien.html
-# don't forget to reset your region
-g.region region=saved.reg
-# take a look and test it out
-netscape file:`pwd`/alien.html &
-</PRE></DIV>
- </LI>
-</UL>
-<H2>NOTES</H2>
-HTMLMAP was adapted from the CELL driver in GRASS 4.3.
-Point-in-polygon test code was lifted from Randolph Franklin's web page, see
-<UL>
- <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/">http://www.ecse.rpi.edu/Homepages/wrf/</A></LI>
- <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html">http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html</A></LI>
-</UL>
-<P>
-If you create an HTML file with two or more images and image maps, you will
-need to edit the map names. The HTMLMAP driver creates its map with the name
-<tt>map</tt>. A small sed script can easily change the map name:
-<PRE>
- sed -e 's/NAME="map"/NAME="foomap"/' < htmlmap > foomap.html
-</PRE>
-<H2>SEE ALSO</H2>
-<EM>
- <a href="displaydrivers.html">Display drivers</a>
- <br>
- <a href="pngdriver.html">PNG driver</A>,
- <a href="psdriver.html">PostScript driver</A>,
- <a href="xdriver.html">XDRIVER</A>
- <BR>
- <A href="d.mon.html">d.mon</A>,
- <a href="d.text.html">d.text</A>,
- <a href="d.vect.html">d.vect</A>
-</EM>
-<p>
-<i>Last changed: $Date: 2008-03-23 14:34:53 +0000 (Sun, 23 Mar 2008) $</i>
Copied: grass/trunk/lib/htmldriver/htmldriver.html (from rev 32770, grass/trunk/lib/htmldriver/description.html)
--- grass/trunk/lib/htmldriver/htmldriver.html (rev 0)
+++ grass/trunk/lib/htmldriver/htmldriver.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,190 @@
+<HTML>
+<HEAD>
+ <TITLE>HTMLMAP driver</TITLE>
+</HEAD>
+<H2>NAME</H2>
+<EM><B>HTMLMAP driver</B></EM> - driver to create HTML image maps.
+<BR><EM>(drivers)</EM>
+<H2>DESCRIPTION</H2>
+The HTMLMAP driver allows the generation of HTML image maps
+for area vector data. HTML image maps are used in conjunction with images to
+provide unique URL targets for different portions of an image. The HTMLMAP
+driver can create both client-side image maps embedded into HTML files, or
+server-side image maps used by web server software.
+<P>
+Note that GRASS display commands that require the MOUSE will not work
+correctly (or at all!)
+<P>
+Polygons can at most have 100 vertices (this limit imposed by HTML image map
+formats, see <B>GRASS_HTMLMAXPOINTS</B> below.) The driver will attempt to
+trim polygons that have more that 100
+vertices by removing vertices with the least amount of angle to the next
+vertice. Also, any polygon that is entirely bounded by another polygon will be
+discarded.
+<P>
+Text written to the driver before polygons are used as the HREF tag for all
+subsequent polygons written. All polygons that exist in a vector map will have
+the same HREF tag.
+<P>
+The only GRASS display commands that should be used with this driver are:
+<UL>
+ <LI><a href="d.text.html">d.text</A>
+ - pass href information for resulting image maps.</LI>
+ <LI><a href="d.vect.html">d.vect</A>
+ - draw polygons from a vector map.</LI>
+</UL>
+<H2>USAGE</H2>
+<H3>Environment variables</H3>Several environment variables effect the operation
+of HTMLMAP.
+<UL>
+ <LI><B>GRASS_WIDTH=xxx</B><BR>the width of the image map (default is
+ 640).
+ </LI><BR>
+ <LI><B>GRASS_HEIGHT=yyy</B><BR>the height of the image map (default is
+ 480).
+ </LI><BR>
+ <LI><B>GRASS_HTMLTYPE=type</B><BR>the type of image mape to create (default is
+ CLIENT):
+ <UL>
+ <DD><TT><B>CLIENT</B></TT> Netscape/IE client-side image map.
+ (NAME="map")<BR>
+ <DD><TT><B>APACHE</B></TT> Apache/NCSA server-side image
+ map.<BR>
+ <DD><TT><B>RAW</B></TT> Raw url
+ and polygon vertices ( <I>url x1 y1 x2 y2
+ ..... </I>), suitable for conversion to CERN server format, or any other
+ format with user supplied conversion program.</DD>
+ </UL>
+ </LI><BR>
+ <LI><B>GRASS_HTMLFILE=filename</B><BR>
+ specifies the resulting file to store
+ the html image map, default is <tt>htmlmap</tt>. Files without absolute path
+ names are written in the current directory where the driver was started.
+ <BR>
+ <em>Any existing file of the same name is overwritten without
+ warning.</em>
+ </LI><BR>
+ <LI><B>GRASS_HTMLMINDIST=n</B><BR>specifies the minimum distance in pixels
+ that a point must change from the previous point to keep in the list of
+ vertices for a polygon. The default is <tt>2</tt>, which means that a
+ point's x and y difference from the previous point must change by a number
+ of pixels greater than this value. This parameter helps to eliminate
+ closely spaced points.
+ </LI><BR>
+ <LI><B>GRASS_HTMLMINBBOX=n</B><BR>specifies the minimum bounding box
+ dimensions to record a polygon as a clickable area.
+ The default is <tt>2</tt>, which means that a polygon with a bounding box
+ of less than this value is not included. This parameter helps to eliminate
+ polygons than are a point or line.
+ </LI><BR>
+ <LI><B>GRASS_HTMLMAXPOINTS=n</B><BR>specifies the maximum number of
+ vertices included in a polygon's clickable area.
+ The default is <tt>99</tt>. Some browsers can only accomodate polygons of
+ 100 vertices or less. The HTMLMAP driver automatically ensures that a
+ polygon is closed by making the last point the same as the first
+ point.</LI><BR>
+</UL>
+<H3>Typical usage</H3>
+<UL>
+ <LI>Start up the driver
+<DIV class="code"><PRE>
+d.mon start=HTMLMAP
+</PRE></DIV>
+ </LI>
+ <LI>Display text strings (HREF's) and polygons
+echo "http://www.no-such-place.net/area51/" | d.text
+d.vect map=area51
+echo "http://www.roswell-nm.net/little/green/men.html" | d.text
+d.vect map=roswell
+</PRE></div>
+ <LI>Stop the driver when all polygon have been displayed. This will cause a file
+ named 'htmlmap' to be created in your current directory.
+d.mon stop=HTMLMAP
+</PRE></DIV>
+ <LI>You will also want to create an image for your image map. Use the PNG
+ driver and other utilities to create .gif or .jpg files.
+ <i>The following example is somewhat out of date and refers to options
+ available in GRASS 5.</i>
+# using previous GRASS_WIDTH & GRASS_HEIGHT
+d.mon start=PNG
+d.mon select=PNG
+d.rast map=terrain
+d.vect map=area51 fillcolor=white linecolor=blue
+d.vect map=roswell fillcolor=yellow linecolor=blue
+d.vect map=states color=green
+d.vect map=roads color=black
+d.mon stop=PNG
+<!-- ???? FIXME -->
+# make the region the same as the newly created cell for ppm export
+g.region save=saved.reg
+g.region raster=D_cell
+r.out.ppm -q input=D_cell output=alien.ppm
+# use the netpbm utilities to create a gif (quantize if needed)
+# assemble some html with the image and the image map
+echo '<html><body><img src="alien.gif" usemap="#map">' >alien.html
+cat htmlmap >>alien.html
+echo '</body></html>' >>alien.html
+# don't forget to reset your region
+g.region region=saved.reg
+# take a look and test it out
+netscape file:`pwd`/alien.html &
+</PRE></DIV>
+ </LI>
+</UL>
+<H2>NOTES</H2>
+HTMLMAP was adapted from the CELL driver in GRASS 4.3.
+Point-in-polygon test code was lifted from Randolph Franklin's web page, see
+<UL>
+ <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/">http://www.ecse.rpi.edu/Homepages/wrf/</A></LI>
+ <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html">http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html</A></LI>
+</UL>
+<P>
+If you create an HTML file with two or more images and image maps, you will
+need to edit the map names. The HTMLMAP driver creates its map with the name
+<tt>map</tt>. A small sed script can easily change the map name:
+<PRE>
+ sed -e 's/NAME="map"/NAME="foomap"/' < htmlmap > foomap.html
+</PRE>
+<H2>SEE ALSO</H2>
+<EM>
+ <a href="displaydrivers.html">Display drivers</a>
+ <br>
+ <a href="pngdriver.html">PNG driver</A>,
+ <a href="psdriver.html">PostScript driver</A>,
+ <a href="xdriver.html">XDRIVER</A>
+ <BR>
+ <A href="d.mon.html">d.mon</A>,
+ <a href="d.text.html">d.text</A>,
+ <a href="d.vect.html">d.vect</A>
+</EM>
+<p>
+<i>Last changed: $Date: 2008-03-23 14:34:53 +0000 (Sun, 23 Mar 2008) $</i>
Modified: grass/trunk/lib/pngdriver/Makefile
--- grass/trunk/lib/pngdriver/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/pngdriver/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -2,12 +2,11 @@
-PACKAGE ="libpngdriver"
-EXTRA_CFLAGS=$(GETHOSTNAME) $(ZLIBINCPATH) $(PNGINC) -I../driver $(PICFLAGS) $(DEFS)
+EXTRA_CFLAGS=$(GETHOSTNAME) $(ZLIBINCPATH) $(PNGINC) -I../driver
EXTRA_LIBS=$(DRIVERLIB) $(GISLIB) $(PNGLIB)
LIB_NAME = $(PNGDRIVER_LIBNAME)
+PGM = cairodriver
LIB_OBJS = \
Box.o \
@@ -37,4 +36,4 @@
-default: lib
Deleted: grass/trunk/lib/pngdriver/description.html
--- grass/trunk/lib/pngdriver/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/pngdriver/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,125 +0,0 @@
-<HTML>
-<HEAD>
- <TITLE>PNG driver</TITLE>
-</HEAD>
-<H2>NAME</H2>
-<EM><B> PNG driver</B></EM> - driver to create PNG and PPM images.
-The PNG driver generates PNG and PPM images from GRASS display commands.
-Per default PNG files are written with this driver. It is started as 'pseudo' monitor
-(image file instead) and when stopped, all output from previously used
-display commands are written to the PNG image file.
-<H2>USAGE</H2>
-Several environment variables effect the operation
-of the PNG driver.
-<UL>
- the width of the image map (default is 640).</LI><BR>
- the height of the image map (default is 480).</LI><BR>
- <LI><B>GRASS_PNGFILE=filename</B><BR>
- the filename to put the resulting image in, default is <tt>map.png</tt>.
- If you set GRASS_PNGFILE to a filename which ends in ".ppm", a PPM
- file will be created.<br><br>
- notation (hex values). Default is <b>000000</b> (black).<br><br>
- sets transparent background on (TRUE) or off (FALSE, default).</LI><BR>
- <LI><B>GRASS_TRUECOLOR=[TRUE|FALSE]</B><BR>
- sets true-color support</LI><BR>
- <LI><B>GRASS_PNG_COMPRESSION=[0|1|9]</B><BR>
- compression level of PNG files (0 = none, 1 = fastest, 9 = best, default is 6)</LI><BR>
- <LI><B>GRASS_PNG_AUTO_WRITE=[TRUE|FALSE]</B><BR>
- only being written out when the driver terminates.</LI><BR>
- <LI><B>GRASS_PNG_READ</B><BR>
- if <tt>TRUE</tt>, the PNG driver will initialize the image from
- the contents of GRASS_PNGFILE.</LI><BR>
- <LI><B>GRASS_PNG_MAPPED</B><BR>
- if <tt>TRUE</tt>, the PNG driver will map GRASS_PNGFILE as its framebuffer,
- rather than using memory. This only works with BMP files.</LI><BR>
- <LI><B>GRASS_RENDER_IMMEDIATE=[TRUE|FALSE]</B><BR>
- tells the raster library to use its built-in PNG driver rather
- than connecting to an external monitor process using sockets. If
- <tt>TRUE</tt>, there is no need to run <tt>d.mon start=PNG</tt>.
-</UL>
-<H3>Example</H3>
-<OL>
- <LI>Define driver settings (here: bash shell syntax)
-export GRASS_RENDER_IMMEDIATE=TRUE
-export GRASS_TRUECOLOR=TRUE
-</PRE></DIV>
- </LI>
-d.mon start=PNG
-</PRE></DIV>
- </LI>
- <LI>Display raster map and vector polygons
-d.rast <i>somerastermap</i>
-d.vect <i>somevectormap</i> color=red
-</PRE></DIV>
- </LI>
- <LI> Stop the driver subsequently. This will write a
- file named <tt>map.png</tt> to be created in your current directory:
-d.mon stop=PNG
-</PRE></DIV>
- </LI>
-</OL>
-<H2>NOTES</H2>
-The PNG driver uses the libpng (see the <a href="http://www.libpng.org/pub/png/">libpng</a>
-home page) and zlib (see the
-<a href="http://www.zlib.net">zlib</a> home page), all which needs to
-be installed for the PNG driver to work (it's worth it).
-<p>
-The resolution of the <i>PNG</i> raster map is defined by the map
-extents. Use <em>g.region -p</em> to get the number of rows and cols and
-use the environment variables to set the PNG size. If you would like a
-larger image, multiply both rows and cols by the same whole number to
-preserve the aspect ratio.
-<p>
-Further PNG file processing (e.g. quantization to 1 bit for monochrome images)
-can be done with 'pnmquant' of the <a href="http://netpbm.sourceforge.net/">netpbm</a> tools.
-<h2>SEE ALSO</h2>
-<EM>
- <br>
- <A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
- <A HREF="psdriver.html">PostScript driver</A>,
- <A href="xdriver.html">XDRIVER</A>
- <BR>
- <A HREF="d.frame.html">d.frame</A>,
- <A href="d.rast.html">d.rast</A>,
- <A href="d.vect.html">d.vect</A>
-</EM>
-<H2>AUTHOR</H2>
-Original version: Per Henrik Johansen <<I>phj (at) norgit.no</I>> <I><a href="http://www.norgit.no">NORGIT AS</a></I>
-<BR>
-Rewritten by: Glynn Clements, 2003
-<p>
Copied: grass/trunk/lib/pngdriver/pngdriver.html (from rev 32770, grass/trunk/lib/pngdriver/description.html)
--- grass/trunk/lib/pngdriver/pngdriver.html (rev 0)
+++ grass/trunk/lib/pngdriver/pngdriver.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,125 @@
+<HTML>
+<HEAD>
+ <TITLE>PNG driver</TITLE>
+</HEAD>
+<H2>NAME</H2>
+<EM><B> PNG driver</B></EM> - driver to create PNG and PPM images.
+The PNG driver generates PNG and PPM images from GRASS display commands.
+Per default PNG files are written with this driver. It is started as 'pseudo' monitor
+(image file instead) and when stopped, all output from previously used
+display commands are written to the PNG image file.
+<H2>USAGE</H2>
+Several environment variables effect the operation
+of the PNG driver.
+<UL>
+ the width of the image map (default is 640).</LI><BR>
+ the height of the image map (default is 480).</LI><BR>
+ <LI><B>GRASS_PNGFILE=filename</B><BR>
+ the filename to put the resulting image in, default is <tt>map.png</tt>.
+ If you set GRASS_PNGFILE to a filename which ends in ".ppm", a PPM
+ file will be created.<br><br>
+ notation (hex values). Default is <b>000000</b> (black).<br><br>
+ sets transparent background on (TRUE) or off (FALSE, default).</LI><BR>
+ <LI><B>GRASS_TRUECOLOR=[TRUE|FALSE]</B><BR>
+ sets true-color support</LI><BR>
+ <LI><B>GRASS_PNG_COMPRESSION=[0|1|9]</B><BR>
+ compression level of PNG files (0 = none, 1 = fastest, 9 = best, default is 6)</LI><BR>
+ <LI><B>GRASS_PNG_AUTO_WRITE=[TRUE|FALSE]</B><BR>
+ only being written out when the driver terminates.</LI><BR>
+ <LI><B>GRASS_PNG_READ</B><BR>
+ if <tt>TRUE</tt>, the PNG driver will initialize the image from
+ the contents of GRASS_PNGFILE.</LI><BR>
+ <LI><B>GRASS_PNG_MAPPED</B><BR>
+ if <tt>TRUE</tt>, the PNG driver will map GRASS_PNGFILE as its framebuffer,
+ rather than using memory. This only works with BMP files.</LI><BR>
+ <LI><B>GRASS_RENDER_IMMEDIATE=[TRUE|FALSE]</B><BR>
+ tells the raster library to use its built-in PNG driver rather
+ than connecting to an external monitor process using sockets. If
+ <tt>TRUE</tt>, there is no need to run <tt>d.mon start=PNG</tt>.
+</UL>
+<H3>Example</H3>
+<OL>
+ <LI>Define driver settings (here: bash shell syntax)
+export GRASS_RENDER_IMMEDIATE=TRUE
+export GRASS_TRUECOLOR=TRUE
+</PRE></DIV>
+ </LI>
+d.mon start=PNG
+</PRE></DIV>
+ </LI>
+ <LI>Display raster map and vector polygons
+d.rast <i>somerastermap</i>
+d.vect <i>somevectormap</i> color=red
+</PRE></DIV>
+ </LI>
+ <LI> Stop the driver subsequently. This will write a
+ file named <tt>map.png</tt> to be created in your current directory:
+d.mon stop=PNG
+</PRE></DIV>
+ </LI>
+</OL>
+<H2>NOTES</H2>
+The PNG driver uses the libpng (see the <a href="http://www.libpng.org/pub/png/">libpng</a>
+home page) and zlib (see the
+<a href="http://www.zlib.net">zlib</a> home page), all which needs to
+be installed for the PNG driver to work (it's worth it).
+<p>
+The resolution of the <i>PNG</i> raster map is defined by the map
+extents. Use <em>g.region -p</em> to get the number of rows and cols and
+use the environment variables to set the PNG size. If you would like a
+larger image, multiply both rows and cols by the same whole number to
+preserve the aspect ratio.
+<p>
+Further PNG file processing (e.g. quantization to 1 bit for monochrome images)
+can be done with 'pnmquant' of the <a href="http://netpbm.sourceforge.net/">netpbm</a> tools.
+<h2>SEE ALSO</h2>
+<EM>
+ <br>
+ <A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
+ <A HREF="psdriver.html">PostScript driver</A>,
+ <A href="xdriver.html">XDRIVER</A>
+ <BR>
+ <A HREF="d.frame.html">d.frame</A>,
+ <A href="d.rast.html">d.rast</A>,
+ <A href="d.vect.html">d.vect</A>
+</EM>
+<H2>AUTHOR</H2>
+Original version: Per Henrik Johansen <<I>phj (at) norgit.no</I>> <I><a href="http://www.norgit.no">NORGIT AS</a></I>
+<BR>
+Rewritten by: Glynn Clements, 2003
+<p>
Modified: grass/trunk/lib/psdriver/Makefile
--- grass/trunk/lib/psdriver/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/psdriver/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -2,16 +2,15 @@
-PACKAGE ="libpsdriver"
LIB_NAME = $(PSDRIVER_LIBNAME)
+PGM = psdriver
-default: lib $(ETC)/psdriver.ps
+default: lib htmldir $(ETC)/psdriver.ps
$(ETC)/psdriver.ps: psdriver.ps
$(INSTALL_DATA) $< $@
Deleted: grass/trunk/lib/psdriver/description.html
--- grass/trunk/lib/psdriver/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/lib/psdriver/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,109 +0,0 @@
-<HTML>
-<HEAD>
- <TITLE>PS driver</TITLE>
-</HEAD>
-<H2>NAME</H2>
-<EM><B> PS driver</B></EM> - driver to create PostScript files.
-The PS driver generates a PostScript file from GRASS display commands.
-The driver is started as 'pseudo' monitor (PS file instead) and when
-to the PostScript file.
-<H2>USAGE</H2>
-of the PS driver:
-<UL>
- <LI><B>GRASS_PSFILE</B><BR>
- name of output file. If it ends with ".eps" an EPS file
- will be created.</LI><BR>
- <LI><B>GRASS_PAPER</B><BR>
- sets the screen dimensions and margins to
- fit a standard paper size, see also GRASS_WIDTH, GRASS_HEIGHT.</LI><BR>
- <LI><B>GRASS_WIDTH</B><BR>
- defines the width of the screen, see also GRASS_HEIGHT</LI><BR>
- <LI><B>GRASS_HEIGHT</B><BR>
- defines the height of the screen, see also GRASS_WIDTH</LI><BR>
- <LI><B>GRASS_TRUECOLOR</B><BR>
- if <tt>TRUE</tt>, the PS driver generates color output, otherwise
- monochrome.</LI><BR>
- <LI><B>GRASS_LANDSCAPE</B><BR>
- if <tt>TRUE</tt>, the screen is rotated 90 degrees
- counter-clockwise so that a "landscape" screen fits better on
- "portrait" paper.</LI><BR>
- <LI><B>GRASS_PS_HEADER</B><BR>
- if <tt>FALSE</tt>, the output is appended to any existing file,
- and no prolog or setup sections are generated.</LI><BR>
- <LI><B>GRASS_PS_TRAILER</B><BR>
- if <tt>FALSE</tt>, no trailer section is generated.</LI>
-</UL>
-<H3>Example</H3>
-<OL>
-d.mon start=PS
-</PRE></DIV>
- </LI>
-d.vect map=<i>somevectormap</i> color=red
-</PRE></DIV>
- </LI>
- file named <tt>map.ps</tt> to be created in your current directory:
-d.mon stop=PS
-</PRE></DIV>
- </LI>
-</OL>
-<H2>NOTES</H2>
-The resolution of the <i>PS</i> raster map is defined by the map
-use the environment variables to set the PS size. If you would like a
-<P>
-GRASS_TRUECOLOR requires either PostScript level 2 or level 1 plus the
-colorimage and setrgbcolor operators (this is the case for colour printers
-which pre-date level 2 PostScript).
-<p>
-Only masked images (<tt>d.rast -o</tt>, <tt>d.rgb -o</tt>, <tt>d.his
--n</tt>) require PostScript level 3.
-<h2>SEE ALSO</h2>
-<EM>
- <br>
- <A HREF="pngdriver.html">PNG driver</A>,
- <BR>
- <A href="d.out.file.html">d.out.file</A>,
-</EM>
-<H2>AUTHOR</H2>
-Glynn Clements, 2007
-<p>
Copied: grass/trunk/lib/psdriver/psdriver.html (from rev 32770, grass/trunk/lib/psdriver/description.html)
--- grass/trunk/lib/psdriver/psdriver.html (rev 0)
+++ grass/trunk/lib/psdriver/psdriver.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,109 @@
+<HTML>
+<HEAD>
+ <TITLE>PS driver</TITLE>
+</HEAD>
+<H2>NAME</H2>
+<EM><B> PS driver</B></EM> - driver to create PostScript files.
+The PS driver generates a PostScript file from GRASS display commands.
+The driver is started as 'pseudo' monitor (PS file instead) and when
+to the PostScript file.
+<H2>USAGE</H2>
+of the PS driver:
+<UL>
+ <LI><B>GRASS_PSFILE</B><BR>
+ name of output file. If it ends with ".eps" an EPS file
+ will be created.</LI><BR>
+ <LI><B>GRASS_PAPER</B><BR>
+ sets the screen dimensions and margins to
+ fit a standard paper size, see also GRASS_WIDTH, GRASS_HEIGHT.</LI><BR>
+ <LI><B>GRASS_WIDTH</B><BR>
+ defines the width of the screen, see also GRASS_HEIGHT</LI><BR>
+ <LI><B>GRASS_HEIGHT</B><BR>
+ defines the height of the screen, see also GRASS_WIDTH</LI><BR>
+ <LI><B>GRASS_TRUECOLOR</B><BR>
+ if <tt>TRUE</tt>, the PS driver generates color output, otherwise
+ monochrome.</LI><BR>
+ <LI><B>GRASS_LANDSCAPE</B><BR>
+ if <tt>TRUE</tt>, the screen is rotated 90 degrees
+ counter-clockwise so that a "landscape" screen fits better on
+ "portrait" paper.</LI><BR>
+ <LI><B>GRASS_PS_HEADER</B><BR>
+ if <tt>FALSE</tt>, the output is appended to any existing file,
+ and no prolog or setup sections are generated.</LI><BR>
+ <LI><B>GRASS_PS_TRAILER</B><BR>
+ if <tt>FALSE</tt>, no trailer section is generated.</LI>
+</UL>
+<H3>Example</H3>
+<OL>
+d.mon start=PS
+</PRE></DIV>
+ </LI>
+d.vect map=<i>somevectormap</i> color=red
+</PRE></DIV>
+ </LI>
+ file named <tt>map.ps</tt> to be created in your current directory:
+d.mon stop=PS
+</PRE></DIV>
+ </LI>
+</OL>
+<H2>NOTES</H2>
+The resolution of the <i>PS</i> raster map is defined by the map
+use the environment variables to set the PS size. If you would like a
+<P>
+GRASS_TRUECOLOR requires either PostScript level 2 or level 1 plus the
+colorimage and setrgbcolor operators (this is the case for colour printers
+which pre-date level 2 PostScript).
+<p>
+Only masked images (<tt>d.rast -o</tt>, <tt>d.rgb -o</tt>, <tt>d.his
+-n</tt>) require PostScript level 3.
+<h2>SEE ALSO</h2>
+<EM>
+ <br>
+ <A HREF="pngdriver.html">PNG driver</A>,
+ <BR>
+ <A href="d.out.file.html">d.out.file</A>,
+</EM>
+<H2>AUTHOR</H2>
+Glynn Clements, 2007
+<p>
Deleted: grass/trunk/misc/m.cogo/description.html
--- grass/trunk/misc/m.cogo/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/misc/m.cogo/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,145 +0,0 @@
-<EM>m.cogo</EM> converts data points between bearing and distance
-and X,Y coordinates. Only simple bearing/distance or coordinate
-pairs are handled. It assumes a cartesian coordinate system.
-<P>
-Input can be entered via standard input (default) or from the file
-<B>input=</B><EM>name</EM>. Specifying the input as "-" also
-specifies standard input, and is useful for using the program in
-a pipeline. Output will be to standard output unless a file
-name other than "-" is specified. The input file must
-closely adhere to the following format, where up to a 10 character
-label is allowed but not required (see <B>-l</B> flag).
-<P>
-<B>Example COGO input:</B>
- P23 N 23:14:12 W 340
- P24 S 04:18:56 E 230
-</pre></div>
-<P>
-The first column may contain a label and you must use the <B>-l</B>
-flag so the program knows. This is followed by a space, and then
-either the character 'N' or 'S' to indicate whether the bearing is
-relative to the north or south directions. After another space,
-the angle begins in degrees, minutes, and seconds in
-"DDD:MM:SS.SSSS" format. Generally, the angle can be of the form
-<EM>digits + separator + digits + separator + digits [+ '.' + digits]</EM>.
-A space follows the angle, and is then followed by either the 'E' or 'W'
-characters. A space separates the bearing from the distance (which should
-be in appropriate linear units).
-<P>
-<B>Output of the above input:</B>
- -134.140211 312.420236 P23
- -116.832837 83.072345 P24
-</pre></div>
-<P>
-Unless specified with the <B>coord</B> option, calculations begin from (0,0).
-<P>
-For those unfamiliar with the notation for bearings: Picture yourself in the
-center of a circle. The first hemispere notation tell you whether you should
-face north or south. Then you read the angle and either turn that many
-degrees to the east or west, depending on the second hemisphere notation.
-Finally, you move <distance> units in that direction to get to the
-next station.
-</P>
-<EM>m.cogo</EM> can be run either non-interactively or
-interactively. The program will be run non-interactively
-if the user specifies any parameter or flag. Use "m.cogo -",
-to run the program in a pipeline. Without any flags or
-parameters, <EM>m.cogo</EM> will prompt for each value
-using the familiar GRASS parser interface.
-<P>
-<H2>NOTES</H2>
-This program is very simplistic, and will not handle deviations
-from the input format explained above. Currently, the
-program doesn't do anything particularly useful with
-the output. However, it is envisioned that this program
-will be extended to provide the capability to generate
-vector and/or sites layers.
-<H2>EXAMPLE</H2>
- m.cogo -l in=cogo.dat
-</pre></div>
-Where the <tt>cogo.dat</tt> input file looks like:
-# Sample COGO input file -- This defines an area.
-# <label> <bearing> <distance>
-P001 S 88:44:56 W 6.7195
-P002 N 33:34:15 W 2.25
-P003 N 23:23:50 W 31.4024
-P004 N 05:04:45 W 25.6981
-P005 N 18:07:25 E 22.2439
-P006 N 27:49:50 E 75.7317
-P007 N 22:56:50 E 87.4482
-P008 N 37:45:15 E 37.7835
-P009 N 46:04:30 E 11.5854
-P010 N 90:00:00 E 8.8201
-P011 N 90:00:00 E 164.1128
-P012 S 48:41:12 E 10.1311
-P013 S 00:25:50 W 255.7652
-P014 N 88:03:13 W 98.8567
-P015 S 88:44:56 W 146.2713
-P016 S 88:44:56 W 18.7164
-</pre></div>
-Round trip:
- m.cogo -l in=cogo.dat | m.cogo -rl in="-"
-</pre></div>
-Import as a vector points map:
- m.cogo -l in=cogo.dat | v.in.ascii out=cogo_points x=1 y=2 fs=space
-</pre></div>
-Shell script to import as a vector line map:
- m.cogo -l in=cogo.dat | tac | awk '
- BEGIN { FS=" " ; R=0 }
- $1~/\d*\.\d*/ { printf(" %.8f %.8f\n", $1, $2) ; ++R }
- END { printf("L %d\n", R) }' | tac | \
- v.in.ascii -n format=standard out=cogo_line
-</pre></div>
-Unclosed lines may be snapped with <em>v.clean</em>, converted to
-boundaries with <em>v.type</em>, and closed boundaries may be
-converted to areas with <em>v.centroids</em>.
-<H2>SEE ALSO</H2>
-<em>
-<a HREF="v.centroids.html">v.centroids</a>,
-<a HREF="v.clean.html">v.clean</a>,
-<a HREF="v.digit.html">v.digit</a>,
-<a HREF="v.in.ascii.html">v.in.ascii</a>,
-<a HREF="v.type.html">v.type</a>
-</em>
-<H2>AUTHOR</H2>
-Eric G. Miller
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/misc/m.cogo/m.cogo.html (from rev 32770, grass/trunk/misc/m.cogo/description.html)
--- grass/trunk/misc/m.cogo/m.cogo.html (rev 0)
+++ grass/trunk/misc/m.cogo/m.cogo.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,145 @@
+<EM>m.cogo</EM> converts data points between bearing and distance
+and X,Y coordinates. Only simple bearing/distance or coordinate
+pairs are handled. It assumes a cartesian coordinate system.
+<P>
+Input can be entered via standard input (default) or from the file
+<B>input=</B><EM>name</EM>. Specifying the input as "-" also
+specifies standard input, and is useful for using the program in
+a pipeline. Output will be to standard output unless a file
+name other than "-" is specified. The input file must
+closely adhere to the following format, where up to a 10 character
+label is allowed but not required (see <B>-l</B> flag).
+<P>
+<B>Example COGO input:</B>
+ P23 N 23:14:12 W 340
+ P24 S 04:18:56 E 230
+</pre></div>
+<P>
+The first column may contain a label and you must use the <B>-l</B>
+flag so the program knows. This is followed by a space, and then
+either the character 'N' or 'S' to indicate whether the bearing is
+relative to the north or south directions. After another space,
+the angle begins in degrees, minutes, and seconds in
+"DDD:MM:SS.SSSS" format. Generally, the angle can be of the form
+<EM>digits + separator + digits + separator + digits [+ '.' + digits]</EM>.
+A space follows the angle, and is then followed by either the 'E' or 'W'
+characters. A space separates the bearing from the distance (which should
+be in appropriate linear units).
+<P>
+<B>Output of the above input:</B>
+ -134.140211 312.420236 P23
+ -116.832837 83.072345 P24
+</pre></div>
+<P>
+Unless specified with the <B>coord</B> option, calculations begin from (0,0).
+<P>
+For those unfamiliar with the notation for bearings: Picture yourself in the
+center of a circle. The first hemispere notation tell you whether you should
+face north or south. Then you read the angle and either turn that many
+degrees to the east or west, depending on the second hemisphere notation.
+Finally, you move <distance> units in that direction to get to the
+next station.
+</P>
+<EM>m.cogo</EM> can be run either non-interactively or
+interactively. The program will be run non-interactively
+if the user specifies any parameter or flag. Use "m.cogo -",
+to run the program in a pipeline. Without any flags or
+parameters, <EM>m.cogo</EM> will prompt for each value
+using the familiar GRASS parser interface.
+<P>
+<H2>NOTES</H2>
+This program is very simplistic, and will not handle deviations
+from the input format explained above. Currently, the
+program doesn't do anything particularly useful with
+the output. However, it is envisioned that this program
+will be extended to provide the capability to generate
+vector and/or sites layers.
+<H2>EXAMPLE</H2>
+ m.cogo -l in=cogo.dat
+</pre></div>
+Where the <tt>cogo.dat</tt> input file looks like:
+# Sample COGO input file -- This defines an area.
+# <label> <bearing> <distance>
+P001 S 88:44:56 W 6.7195
+P002 N 33:34:15 W 2.25
+P003 N 23:23:50 W 31.4024
+P004 N 05:04:45 W 25.6981
+P005 N 18:07:25 E 22.2439
+P006 N 27:49:50 E 75.7317
+P007 N 22:56:50 E 87.4482
+P008 N 37:45:15 E 37.7835
+P009 N 46:04:30 E 11.5854
+P010 N 90:00:00 E 8.8201
+P011 N 90:00:00 E 164.1128
+P012 S 48:41:12 E 10.1311
+P013 S 00:25:50 W 255.7652
+P014 N 88:03:13 W 98.8567
+P015 S 88:44:56 W 146.2713
+P016 S 88:44:56 W 18.7164
+</pre></div>
+Round trip:
+ m.cogo -l in=cogo.dat | m.cogo -rl in="-"
+</pre></div>
+Import as a vector points map:
+ m.cogo -l in=cogo.dat | v.in.ascii out=cogo_points x=1 y=2 fs=space
+</pre></div>
+Shell script to import as a vector line map:
+ m.cogo -l in=cogo.dat | tac | awk '
+ BEGIN { FS=" " ; R=0 }
+ $1~/\d*\.\d*/ { printf(" %.8f %.8f\n", $1, $2) ; ++R }
+ END { printf("L %d\n", R) }' | tac | \
+ v.in.ascii -n format=standard out=cogo_line
+</pre></div>
+Unclosed lines may be snapped with <em>v.clean</em>, converted to
+boundaries with <em>v.type</em>, and closed boundaries may be
+converted to areas with <em>v.centroids</em>.
+<H2>SEE ALSO</H2>
+<em>
+<a HREF="v.centroids.html">v.centroids</a>,
+<a HREF="v.clean.html">v.clean</a>,
+<a HREF="v.digit.html">v.digit</a>,
+<a HREF="v.in.ascii.html">v.in.ascii</a>,
+<a HREF="v.type.html">v.type</a>
+</em>
+<H2>AUTHOR</H2>
+Eric G. Miller
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/ps/ps.map/description.html
--- grass/trunk/ps/ps.map/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/ps/ps.map/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,1606 +0,0 @@
-<EM>ps.map</EM> is a cartographic mapping program for producing high quality
-hardcopy maps in PostScript format. Output can include a raster map, any
-number of vector overlays, text labels, decorations, and other spatial data.
-<P>
-A file of mapping instructions that describes the various spatial and textual
-information to be printed must be prepared prior to running <EM>ps.map</EM>.
-<H2>NOTES</H2>
-<P>
-The order of commands is generally unimportant but may affect how some layers
-are drawn. For example to plot <B>vpoints</B> above <B>vareas</B> list the
-<B>vpoints</B> entry first. Raster maps are always drawn first, and only a
-single raster map (or 3 if part of a RGB group) may be used.
-<P>
-The hash character ('<tt>#</tt>') may be used at the beginning of a line
-to indicate that the line is a comment. Blank lines will also be ignored.
-<P>
-Be aware that some mapping instructions require the <i>end</i> command
-and some do not. Any instruction that allows subcommands will require
-it, any instruction that does not allow subcommands will not.
-<P>
-The resolution and extent of raster maps plotted with <EM>ps.map</EM> are
-controlled by the current region settings via the
-<a href="g.region.html">g.region</a> module. The output filesize is largely
-a function of the region resolution, so special care should be taken
-if working with large raster datasets. For example if the desired output is
-US-Letter sized paper at 300dpi, with 1" margins and the raster filling the
-entire page, the usable area on the page will be 6.5" x 9", which at 300
-dots/inch is equivalent to a region of 1950 columns x 2700 rows (see
-"<tt>g.region -p</tt>"). Any higher resolution settings will make the
-output file larger, but with a consumer printer you probably won't be able
-to resolve any better detail in the hardcopy.
-<P>
-The user can specify negative or greater than 100 percentage values for
-positioning several map decorations and embedded EPS-files, to move them
-outside the current map box region (for example to position a caption,
-barscale, or legend above or below the map box).
-<P>
-One "pixel" is 1/72 of an inch.
-<P>
-For users wanting to use special characters (such as accented characters) it
-is important to note that <em>ps.map</em> uses <tt>ISO-8859-1</tt> encoding.
-This means that your instructions file will have to be encoded in this
-encoding. If you normally work in a different encoding environment (such as
-<tt>UTF-8</tt>), you have to transform your file to the <tt>ISO-8859-1</tt>
-encoding, for example by using the <tt>iconv</tt> utility:
-</P>
-iconv -f UTF-8 -t ISO_8859-1 utf_file > iso_file
-</PRE></DIV>
-<P><P>
-<H2>MAPPING INSTRUCTIONS</H2>
-The mapping instructions allow the user to specify various spatial data
-to be plotted. These instructions are normally prepared in a regular
-text file using a system editor. Some instructions are single line
-instructions while others are multiple line. Multiple line instructions
-consist of the main instruction followed by a subsection of one or more
-additional instructions and are terminated with an <i>end</i> instruction.
-<P>
-<h3>Instruction keywords:</h3>
-<a href="#border">border</a> |
-<a href="#colortable">colortable</a> |
-<a href="#comments">comments</a> |
-<a href="#copies">copies</a> |
-<a href="#eps">eps</a> |
-<a href="#geogrid">geogrid</a> |
-<a href="#greyrast">greyrast</a> |
-<a href="#grid">grid</a> |
-<a href="#group">group</a> |
-<a href="#header">header</a> |
-<a href="#labels">labels</a> |
-<a href="#line">line</a> |
-<a href="#mapinfo">mapinfo</a> |
-<a href="#maploc">maploc</a> |
-<a href="#maskcolor">maskcolor</a> |
-<a href="#outline">outline</a> |
-<a href="#paper">paper</a> |
-<a href="#point">point</a> |
-<a href="#psfile">psfile</a> |
-<a href="#raster">raster</a> |
-<a href="#read">read</a> |
-<a href="#rectangle">rectangle</a> |
-<a href="#region">region</a> |
-<a href="#rgb">rgb</a> |
-<a href="#scale">scale</a> |
-<a href="#scalebar">scalebar</a> |
-<a href="#setcolor">setcolor</a> |
-<a href="#text">text</a> |
-<a href="#vareas">vareas</a> |
-<a href="#vlines">vlines</a> |
-<a href="#vpoints">vpoints</a> |
-<a href="#vlegend">vlegend</a> |
-<a href="#end">end</a>
-<h3>Common instructions</h3>
-Instructions that may be included in the subsection under several
-different main instructions are:
-<DL>
-<DT><B>where</B> <EM>x y</EM>
-<DD>The top left corner of the bounding box of the item to be plotted
-is located <EM>x</EM> inches from the left edge of the paper and
-<EM>y</EM> inches from the top edge of the paper. If <EM>x</EM> is less than
-or equal to zero, the default horizontal location is used. If <EM>y</EM>
-is less than or equal to zero, the default vertical location is used.
-<DT><B>font</B> <EM>font name</EM>
-<DD>The name of the PostScript font.
-Fonts present in all PostScript implementations are:
-<tt>
-Times-Roman,
-Times-Italic,
-Times-Bold,
-Times-BoldItalic,
-Helvetica,
-Helvetica-Oblique,
-Helvetica-Bold,
-Helvetica-BoldOblique,
-Courier,
-Courier-Oblique,
-Courier-Bold,
-and
-Courier-BoldOblique</tt>.
-<BR>
-The default is Helvetica.
-</DD>
-<DT><B>fontsize</B> <EM>font size</EM>
-<DD>The size of the PostScript font (in 1/72nds of an inch).
-The default is 10.
-</DD>
-<a name="NAMED_COLORS"></a>
-<DT><B>color</B> <EM>name</EM>
-<DD>The following colors names are accepted by <EM>ps.map</EM>:
-<tt>
-aqua,
-black,
-blue,
-brown,
-cyan,
-gray,
-grey,
-green,
-indigo,
-magenta,
-orange,
-purple,
-red,
-violet,
-white,
-yellow
-</tt>.
-<BR><BR>
-For vectors and some plotting commands you can also specify
-'<tt>none</tt>' or '<tt>R:G:B</tt>' (e.g '<tt>255:0:0</tt>').
-</DD>
-</DL>
-<P>
-<BR>
-<h3>Command usage</h3>
-<a name="border"></a>
-<H2>border</H2>
-Controls the border which is drawn around the map area.
-<PRE>
-USAGE: <B>border</B> [y|n]
- <B>color</B> color
- <B>width</B> #
- <B>end</B>
-</PRE>
-The <B>color</B> may be either a standard GRASS color, a R:G:B triplet,
-or "none". The width is specified in points, unless followed by an "i"
-in which case it is measured in inches.
-The default is a black border box of width 1 point.
-<P>
-The border can be turned off completely with the
-"<tt>border n</tt>" instruction. In this case
-the <B>end</B> command should not be given as the
-main command will be treated as a single line instruction.
-<P>
-This example would create a grey border 0.1" wide.
-<PRE>
-EXAMPLE:
- <B>border</B>
- <B>color</B> grey
- <B>width</B> 0.1i
- <B>end</B>
-</PRE>
-<P>
-<a name="colortable"></a>
-<H2>colortable</H2>
-Prints the color table for the raster map layer anywhere on the page.
-<PRE>
-USAGE: <B>colortable</B> [y|n]
- <B>where</B> x y
- <B>raster</B> raster map
- <B>range</B> minimum maximum
- <B>width</B> table width
- <B>height</B> table height (FP legend only)
- <B>cols</B> table columns
- <B>font</B> font name
- <B>fontsize</B> font size
- <B>color</B> text color
- <B>nodata</B> [Y|n]
- <B>tickbar</B> [y|N]
- <B>end</B>
-</PRE>
-The color table will display the colors for each raster map layer
-category value and the category label.
-If <B>raster</B> is omitted, the colortable defaults to a previously registered raster layer.
-The legend's <B>range</B> can be adjusted for floating point rasters, but if
-set beyond the extent of the map's range be sure that you have set up color
-rules with <em>r.colors</em> which cover this range.
-The default location for the colortable is immediately below any other
-map legend information, starting at the left margin.
-The default text color is black.
-Omitting the <B>colortable</B> instruction would result in
-no color table. For floating point legends <B>width</B> is width of color
-band only. <B>height</B> is used only for floating point legend.
-Adding the <B>nodata n</B> instruction will prevent the "no data" box
-from being drawn (category based legends only).
-Adding the <B>tickbar y</B> instruction will change the tick mark style
-so that ticks are drawn across the color table instead of protruding out
-to the right (floating point legends only).
-<P>
-<B>Note</B>: Be careful about asking for color tables for
-raster map layers which have many categories, such as elevation.
-This could result in the printing of an extremely long color table!
-<P>
-Another issue is that the color table only includes categories which
-have a label. If there are only a few categories, you can use
-r.support to manually add labels. If there are too many categories to
-do this, you could write a script to add dummy labels to the cats file<br>
-(<gisdbase>/<location>/<mapset>/cats/<mapname>).
-<P>
-If the colortable is turned off with a "<tt>colortable n</tt>"
-instruction the <B>end</B> command should not be given as the
-<P>
-This example would print a color table immediately below any other map legend
-information, starting at the left margin, with 4 columns:
-<PRE>
-EXAMPLE:
- <B>colortable</B> y
- <B>cols</B> 4
- <B>width</B> 4
- <B>end</B>
-</PRE>
-<P>
-<a name="comments"></a>
-<H2>comments</H2>
-Prints comments anywhere on the page.
-<PRE>
-USAGE: <B>comments</B> commentfile
- <B>where</B> x y
- <B>end</B>
-</PRE>
-The default location is immediately below the last item item printed,
-starting at the left margin. The default text color is black.
-<P>
-If you wish to use parentheses spanning multiple lines you will need to
-quote them with a backslash to prevent the PostScript interpreter from
-getting confused. e.g. '<B><TT>\(</TT></B>' and '<B><TT>\)</TT></B>'
-<P>
-This example prints in blue
-whatever is in the file <EM>veg.comments</EM> starting at
-1.5 inches from the left edge of the page and 7.25 inches from the top of
-the page, using a 15/72 inch Helvetica Bold font.
-<PRE>
-EXAMPLE:
- <B>raster</B> vegetation
- <B>comments</B> veg.comments
- <B>where</B> 1.5 7.25
- <B>font</B> Helvetica Bold
- <B>fontsize</B> 15
- <B>color</B> blue
- <B>end</B>
-</PRE>
-Presumably, the file
-<EM>veg.comments</EM>
-contain comments
-pertaining to the raster map layer <EM>vegetation</EM>,
-such as "This map was created by classifying a LANDSAT TM image".
-<P>
-<a name="copies"></a>
-<H2>copies</H2>
-Specifies the number of copies to be printed.
-<PRE>
-USAGE: <B>copies</B> n
-</PRE>
-Each page will be printed n times.
-<P>
-This instruction is identical to the <EM>copies</EM> command line parameter.
-<P>
-<a name="eps"></a>
-<H2>eps</H2>
-Places EPS (Encapsulated PostScript) pictures on the output map.
-<PRE>
-USAGE: <B>eps</B> east north
- <B>eps</B> x% y%
- <B>epsfile</B> EPS file
- <B>scale</B> #
- <B>rotate</B> #
- <B>masked</B> [y|n]
- <B>end</B>
-</PRE>
-The EPS picture location is entered in the main
-instruction line by giving either the map
-coordinates or by using percentages of the geographic region.
-The EPS picture will be <i>centered</i> at the given position.
-The user must specify full EPS file path <B>epsfile</B>.
-The user may also specify the <B>scale</B> of the icon
-(default is 1.0), the <B>rotate</B> i.e. rotation in degrees
-(default is 0)
-and whether the point is to be <B>masked</B>
-by the current mask.
-(See manual entry for <EM><A HREF="r.mask.html">r.mask</A></EM>
-for more information on the mask.)
-<P>
-This example would place a EPS file ./epsf/logo.eps
-at the point (E456000 N7890000). This picture would be
-rotated 20 degrees clockwise, 3 times bigger than
-in original file and would not be masked by the current mask.
-<PRE>
-EXAMPLE:
- <B>eps</B> 456000 7890000
- <B>epsfile</B> ./epsf/logo.eps
- <B>scale</B> 3
- <B>rotate</B> 20
- <B>masked</B> n
- <B>end</B>
-</PRE>
-Of course, multiple EPS pictures may be drawn with multiple
-<EM>eps</EM>
-instructions.
-<P>
-<a name="geogrid"></a>
-<H2>geogrid</H2>
-Overlays a geographic grid onto the output map.
-<PRE>
-USAGE: <B>geogrid</B> spacing unit
- <B>numbers</B> # [color]
- <B>width</B> #
- <B>end</B>
-</PRE>
-The <B>spacing</B> and spacing unit of the geographic grid is given
-on the main instruction line. The <B>spacing</B> unit is given as one of <B>d</B> for
-degrees, <B>m</B> for minutes, and <B>s</B> for seconds.
-The subsection instructions allow the user to specify
-the <B>color</B> of the geographic grid lines,
-whether coordinate <B>numbers</B> should appear
-on the geographic grid lines, the <B>width</B>
-of the lines (accepts decimal points [floating points]
-as well as integers), and
-if they should appear every grid line (1), every other grid line
-(2), etc., and what color the numbers should be. The defaults are
-black grid lines, unnumbered.
-<P>
-NOTE: The <B>geogrid</B> draws grid numbers on the east and south borders of the map.
-<P>
-This example would overlay a blue geographic grid with a spacing of 30 minutes
-onto the output map. Alternate grid
-lines would be numbered with yellow numbers.
-<PRE>
-EXAMPLE:
- <B>geogrid</B> 30 m
- <B>color</B> blue
- <B>numbers</B> 2 yellow
- <B>end</B>
-</PRE>
-<P>
-<a name="greyrast"></a>
-<H2>greyrast</H2>
-Selects a raster map layer for output in shades of grey.
-<PRE>
-USAGE: <B>greyrast</B> mapname
-</PRE>
-For each
-<EM>ps.map</EM>
-run, only one raster map layer can be requested (using either the
-<EM>greyrast</EM> or the <EM>raster</EM> instruction).
-<P>
-<a name="grid"></a>
-<H2>grid</H2>
-Overlays a coordinate grid onto the output map.
-<PRE>
-USAGE: <B>grid</B> spacing
- <B>cross</B> cross size
- <B>width</B> #
- <B>end</B>
-</PRE>
-The <B>spacing</B> of the grid is given (in the geographic coordinate
-system units) on the main instruction line. The subsection instructions
-allow the user to specify
-the <B>color</B> of the grid lines,
-on the grid lines, and if they
-should appear every grid line (1), every other grid line
-The <B>cross</B> argument draws grid intersection crosses instead of grid lines,
-with cross size given in geographic coordinate system units.
-The defaults are black grid lines, unnumbered.
-<P>
-This example would overlay a green grid with a spacing of 10000 meters
-(for a metered database, like UTM) onto the output map. Alternate grid
-lines would be numbered with red numbers.
-<PRE>
-EXAMPLE:
- <B>grid</B> 10000
- <B>color</B> green
- <B>numbers</B> 2 red
- <B>end</B>
-</PRE>
-<P>
-<a name="group"></a>
-<H2>group</H2>
-Selects an RGB imagery group for output.
-<PRE>
-USAGE: <B>group</B> <EM>groupname</EM>
-</PRE>
-This is similar to <EM>raster</EM>, except that it uses an imagery group
-instead of a raster map layer. The group must contain three raster map
-layers, comprising the red, green and blue bands of the image.
-<P>
-<a name="header"></a>
-<H2>header</H2>
-Prints the map header above the map.
-<PRE>
-USAGE: <B>header</B>
- <B>file</B> header file
- <B>end</B>
-</PRE>
-If the <EM>file</EM> sub-instruction is absent the header will consist
-of the map's title <!-- from hist file -->
-and the location's description.<!-- PERMANENT/MYNAME -->
-The text will be centered on the page above the map.
-<P>
-This example prints (in red) whatever is in the file <EM>soils.hdr</EM> above
-the map, using a 20/72 inch <tt>Courier</tt> font.
-<PRE>
-EXAMPLE:
- <B>header</B>
- <B>file</B> soils.hdr
- <B>font</B> Courier
- <B>fontsize</B> 20
- <B>color</B> red
- <B>end</B>
-</PRE>
-<P>
-<a name="labels"></a>
-<H2>labels</H2>
-Selects a labels file for output (see manual entry for
-<EM>
-<A HREF="v.label.html">v.label</A>
-).</EM>
-<PRE>
-USAGE: <B>labels</B> labelfile
- <B>end</B>
-</PRE>
-<P>
-NOTE: ps.map can read new option 'ROTATE:' from labels file, which
-specifies counter clockwise rotation in degrees.
-<P>
-This example would paint labels from the labels file called
-<EM>town.names</EM>. Presumably, these labels would indicate the names of
-towns on the map.
-<PRE>
-EXAMPLE:
- <B>labels</B> town.names
- <B>end</B>
-</PRE>
-<P>
-<a name="line"></a>
-<H2>line</H2>
-Draws lines on the output map.
-<PRE>
-USAGE: <B>line</B> east north east north
- <B>line</B> x% y% x% y%
- <B>width</B> #
- <B>end</B>
-</PRE>
-The beginning and ending points of the line are entered on the main
-instruction. These points can be defined either by map coordinates or
-by using percentages of the geographic region.
-The user may also specify line
-<B>color</B>,
-<B>width</B>
-in pixels (accepts decimal points [floating points] as well as integers),
-and if the line is to be <B>masked</B> by the current mask.
-</EM> for more information on the mask.)
-<P>
-This example would draw a yellow line from the point x=10% y=80%
-to the point x=30% y=70%. This line
-would be 2 pixels wide and would appear even if there is a mask.
-<PRE>
-EXAMPLE:
- <B>line</B> 10% 80% 30% 70%
- <B>color</B> yellow
- <B>width</B> 2
- <B>masked</B> n
- <B>end</B>
-</PRE>
-Of course, multiple lines may be drawn with multiple
-<EM>line</EM>
-instructions.
-<P>
-<a name="mapinfo"></a>
-<H2>mapinfo</H2>
-Prints the portion of the map legend containing the scale, grid and
-region information, on or below the map.
-<PRE>
-USAGE: <B>mapinfo</B>
- <B>where</B> x y
- <B>background</B> box color|none
- <B>border</B> color|none
- <B>end</B>
-</PRE>
-The default location is immediately below the map,
-starting at the left edge of the map.
-The default background box color is white.
-<P>
-<EM>border</EM> will draw a border around the legend using the specified color.
- (see <a href="#NAMED_COLORS">NAMED COLORS</a>)
-<P>
-This example prints (in brown) the scale, grid and region information
-immediately below the map and starting 1.5 inches from the left edge
-of the page, using a 12/72 inch <tt>Courier</tt> font.
-<PRE>
-EXAMPLE:
- <B>mapinfo</B>
- <B>where</B> 1.5 0
- <B>fontsize</B> 12
- <B>color</B> brown
- <B>end</B>
-</PRE>
-<P>
-<a name="maploc"></a>
-<H2>maploc</H2>
-Positions the map on the page.
-<PRE>
-USAGE: <B>maploc</B> x y [width height]
-</PRE>
-The upper left corner of the map will be positioned <EM>x</EM> inches from
-the left edge of the page and <EM>y</EM> inches from the top of the page.
-If <EM>width</EM> and <EM>height</EM> (in inches) are present, the map will be
-rescaled, if necessary, to fit.
-<P>
-This example positions the upper left corner of the map 2.0 inches from
-the left edge and 3.5 inches from the top edge of the map.
-<PRE>
-EXAMPLE:
- <B>maploc</B> 2.0 3.5
-</PRE>
-<P>
-<a name="maskcolor"></a>
-<H2>maskcolor</H2>
-Color to be used for mask.
-<PRE>
-USAGE: <B>maskcolor</B> color
-</PRE>
-<a name="outline"></a>
-<H2>outline</H2>
-Outlines the areas of a raster map layer with a specified color.
-<PRE>
-USAGE: <B>outline</B>
- <B>width</B> width of line in pixels
- <B>end</B>
-</PRE>
-Distinct areas of the raster map will be separated from each other visually
-by drawing a border (or outline) in the specified
-<B>color</B>
-(default: black). For
-<B>width</B>
-the program accepts decimal points [floating points] as well as integers.
-Note: it is
-important the user enter the instruction <B>end</B> even if a color is not
-chosen.
-(It is hoped that in the future the outline of a different raster map
-layer other than the one currently being painted may be placed on the map.)
-<P>
-This example would outline the category areas of the
-<EM>soils</EM>
-raster map layer
-in grey.
-<PRE>
-EXAMPLE:
- <B>raster</B> soils
- <B>outline</B>
- <B>color</B> grey
- <B>width</B> 2
- <B>end</B>
-</PRE>
-<P>
-<a name="paper"></a>
-<H2>paper</H2>
-Specifies paper size and margins.
-<PRE>
-USAGE: <B>paper</B> paper name
- <B>height</B> #
- <B>width</B> #
- <B>left</B> #
- <B>right</B> #
- <B>bottom</B> #
- <B>top</B> #
- <B>end</B>
-</PRE>
-<B>paper</B> may select predefined paper name
- (a4,a3,a2,a1,a0,us-legal,us-letter,us-tabloid).
- Default paper size is a4. The measures are defined in <em>inches</em>.
-<B>left</B>, <B>right</B>, <B>bottom</B> and <B>top</B> are paper margins.
-If the plot is rotated with the <b>-r</b> command line flag, measures
-are applied to the <em>rotated</em> page.
-<P>
-<PRE>
-EXAMPLE:
- <B>paper</B> a3
- <B>end</B>
-</PRE>
-<P>
-<PRE>
-EXAMPLE:
- <B>paper</B>
- <B>width</B> 10
- <B>height</B> 10
- <B>left</B> 2
- <B>right</B> 2
- <B>bottom</B> 2
- <B>top</B> 2
- <B>end</B>
-</PRE>
-<P>
-<a name="point"></a>
-<H2>point</H2>
-Places additional points or icons on the output map.
-<PRE>
-USAGE: <B>point</B> east north
- <B>point</B> x% y%
- <B>fcolor</B> color
- <B>symbol</B> symbol group/name
- <B>size</B> #
- <B>rotate</B> #
- <B>end</B>
-</PRE>
-The point location is entered in the main instruction line by giving either the map
-The user may also specify the point <B>color</B>,
-the <B>size</B> of symbol in points,
-the rotation angle (in degrees CCW),
-and whether the point is to be <B>masked</B> by the current mask.
-(See manual entry for <EM> <A HREF="r.mask.html">r.mask</A>
-<P>
-This example would place a purple diamond (from icon file
-<EM>diamond</EM>) at the point (E456000 N7890000). This diamond would be the
-the size of a 15 points and would not be masked by the current mask.
-<PRE>
-EXAMPLE:
- <B>point</B> 456000 7890000
- <B>fcolor</B> purple
- <B>color</B> black
- <B>symbol</B> basic/diamond
- <B>size</B> 15
- <B>masked</B> n
- <B>end</B>
-</PRE>
-Of course, multiple points may be drawn with multiple
-<EM>point</EM>
-instructions.
-<P>
-<a name="psfile"></a>
-<H2>psfile</H2>
-Copies a file containing PostScript commands into the output file.
-<P>
-<B>Note:</B>
-<EM>ps.map</EM>
-will not search for this file. The user must be in the
-correct directory or specify the full path on the <B>psfile</B> instruction.
-(Note to /bin/csh users: ~ won't work with this instruction).
-<PRE>
-USAGE: <B>psfile</B> filename
-</PRE>
-This example copies the file "logo.ps" into the output file.
-<PRE>
-EXAMPLE:
- <B>psfile</B> logo.ps
-</PRE>
-<P>
-<a name="raster"></a>
-<H2>raster</H2>
-Selects a raster map layer for output.
-<PRE>
-USAGE: <B>raster</B> mapname
-</PRE>
-For each <EM>ps.map</EM> run, only one raster map layer (or set
-of layers or imagery group; see below) can be requested. If no
-raster map layer is requested, a completely white map will be
-produced. It can be useful to select no raster map layer in
-order to provide a white background for vector maps.
-<P>
-Note that an imagery group selected with the <EM>group</EM>
-option, or a set of three raster layers selected with the
-<EM>rgb</EM> option, count as a raster map layer for the
-purposes of the preceding paragraph.
-<P>
-This example would paint a map of the raster map layer <EM>soils</EM>.
-<PRE>
-EXAMPLE:
-</PRE>
-<P>
-<a name="read"></a>
-<H2>read</H2>
-Provides <EM>ps.map</EM> with a previously prepared input stream.
-<PRE>
-USAGE: <B>read</B> previously prepared UNIX file
-</PRE>
-Mapping instructions can be placed into a file and read into
-<EM>ps.map.</EM>
-<P>
-<B>Note:</B>
-<EM>ps.map</EM>
-correct directory or specify the full path on the <B>read</B> instruction.
-<P>
-This example reads the UNIX file <EM>pmap.roads</EM> into <EM>ps.map</EM>.
-This file may contain all the <EM>ps.map</EM> instructions for placing
-the vector map layer <EM>roads</EM> onto the output map.
-<PRE>
-EXAMPLE:
- <B>read</B> pmap.roads
-</PRE>
-The user may have created this file because this vector map layer
-is particularly useful for many <EM>ps.map</EM>
-outputs. By using the <B>read</B> option, the user need not enter all the input
-for the <B>vector</B> instruction, but simply <B>read</B> the previously prepared
-file with the correct instructions.
-<P>
-<a name="rectangle"></a>
-<H2>rectangle</H2>
-Draws rectangle on the output map.
-<PRE>
-USAGE: <B>rectangle</B> east north east north
- <B>rectangle</B> x% y% x% y%
- <B>fcolor</B> fill color
- <B>width</B> #
- <B>end</B>
-</PRE>
-The two corners of the rectangle are entered on the main
-<B>color</B>, fill color <B>fcolor</B>, <B>width</B>
-and if the rectangle is to be <B>masked</B> by the current mask.
-<BR>
-Multiple rectangles may be drawn by using multiple <EM>rectangle</EM> instructions.
-<P>
-This example would draw a yellow rectangle filled by green from the point x=10% y=80%
-<PRE>
-EXAMPLE:
- <B>rectangle</B> 10% 80% 30% 70%
- <B>fcolor</B> green
- <B>width</B> 2
- <B>masked</B> n
- <B>end</B>
-</PRE>
-<P>
-<a name="region"></a>
-<H2>region</H2>
-Places the outline of a smaller geographic region
-on the output.
-<PRE>
-USAGE: <B>region</B> regionfile
- <B>width</B> #
- <B>end</B>
-</PRE>
-Geographic region settings are created and saved using <EM> the
-<A HREF="g.region.html">g.region</A></EM> module.
-The <EM>ps.map</EM> <EM>region</EM> option can be used to show an outline of
-a smaller region which was printed on a separate run of <EM>ps.map</EM>
-on other user-created maps.
-<P>
-The user can specify the <B>color</B>
-and the <B>width</B> in pixel units (accepts decimal points
-[floating points] as well as integers) of the outline.
-The default is a black border of one pixel width.
-<P>
-This example would place a white outline, 2 pixels wide, of the
-geographic region called <EM>fire.zones</EM> onto the output map.
-This geographic region would have been created and saved using
-<EM><A HREF="g.region.html">g.region</A></EM>.
-<PRE>
-EXAMPLE:
- <B>region</B> fire.zones
- <B>color</B> white
- <B>width</B> 2
- <B>end</B>
-</PRE>
-<P>
-<a name="rgb"></a>
-<H2>rgb</H2>
-Selects three raster map layers for output as an RGB color image.
-<PRE>
-USAGE: <B>rgb</B> <EM>red</EM> <EM>green</EM> <EM>blue</EM>
-</PRE>
-This is similar to <EM>raster</EM>, except that it uses three
-raster map layers instead of a single layer. The three layers
-are composed to form a color image, similar to <EM>d.rgb</EM>.
-<P>
-For each layer, only one of the components of the layer's color
-table is used: the red component for the red layer, and so on.
-This will give the desired result if all of the layers have a
-grey-scale color table, or if each layer's color table uses the
-hue appropriate to the layer.
-<P>
-<a name="scale"></a>
-<H2>scale</H2>
-Selects a scale for the output map.
-<PRE>
-USAGE: <B>scale</B> <EM>scale</EM>
-</PRE>
-The scale can be selected either as:
-<DL>
-<DT>
-<DD>a relative ratio, e.g. 1:25000;
-<DT>
-<DD>an absolute width of the printed map, e.g. 10 inches;
-<DT>
-<DD>the number of printed paper panels, e.g. 3 panels
-<EM>.I</EM>
-(at the present time, only 1 panel is supported);
-<DT>
-<DD>the number of miles per inch, e.g. 1 inch equals 4 miles.
-</DD>
-</DL>
-<P>
-This example would set the scale of the map to 1 unit = 25000
-units.
-<PRE>
-EXAMPLE:
- <B>scale</B> 1:25000
-</PRE>
-<P>
-This instruction is identical to the <EM>scale</EM> command line parameter.
-<BR>
-<em>NOTE: Using "scale" from the command line is depreciated and while
-still provided for compatibility reasons it will be removed in the future.
-Please use the "scale" mapping instruction instead.</em>
-<P>
-<a name="scalebar"></a>
-<H2>scalebar</H2>
-Draws a scalebar on the map.
-<PRE>
-USAGE: <B>scalebar</B> [f|s]
- <B>where</B> x y
- <B>length</B> scale length
- <B>height</B> scale height
- <B>segment</B> no. segments
- <B>numbers</B> #
- <B>background</B> [Y|n]
- <B>end</B>
-</PRE>
-Draw one of two types of scale bar.
-Fancy (f) draws alternating black and white scale boxes.
-Simple (s) draws a plain line scale. The default type is fancy.
-The subsection instructions allow the user to set <B>where</B> the scalebar
-is placed, the <B>length</B> of the scalebar (in geographic coordinate
-system units), the <B>height</B> of the scalebar in inches, and the number of
-<B>segments</B> (or tics for simple). The <B>number</B> of annotations
-numbers every n-th segment.
-The <B>background</B> command can turn off the background box for the text.
-<P>
-The scalebar <B>length</B> is the only required argument. The defaults are a
-fancy scalebar with 4 segments, each segment labeled, and a height of 0.1
-inches. The default location is 2 inches from the top of the page and
-halfway across.
-<P>
-NOTE: The scalebar is centered on the location given.
-<P>
-This example draws a simple scalebar 1000 meters (for a metered database, like UTM) long,
-with tics every 200 meters, labeled every second tic. The scalebar is drawn 5 inches from the top and 4 inches from the left and is 0.25 inches high.
-<PRE>
-EXAMPLE:
- <B>scalebar</B> s
- <B>where</B> 4 5
- <B>length</B> 1000
- <B>height</B> 0.25
- <B>segment</B> 5
- <B>numbers</B> 2
- <B>end</B>
-</PRE>
-<a name="setcolor"></a>
-<H2>setcolor</H2>
-Overrides the color assigned to one or more categories
-of the raster map layer.
-<PRE>
-USAGE: <B>setcolor</B> cat(s) color
-</PRE>
-This example would set the color for categories 2,5 and 8 of the raster
-map layer <EM>watersheds</EM> to white and category 10 to green.
-(<B>NOTE</B>: no spaces are inserted between the category values.)
-<PRE>
-EXAMPLE:
- <B>raster</B> watersheds
- <B>setcolor</B> 2,5,8 white
- <B>setcolor</B> 10 green
-</PRE>
-Of course,
-<EM>setcolor</EM>
-can be requested more than once to override the default color for additional
-categories. More than one category can be changed for each request by listing
-all the category values separated by commas (but with no spaces).
-<P>
-<a name="text"></a>
-<H2>text</H2>
-Places text on the map.
-<PRE>
-USAGE: <B>text</B> east north text
- <B>text</B> x% y% text
- <B>font</B> fontname
- <B>color</B> color|none
- <B>width</B> #
- <B>hcolor</B> color|none
- <B>hwidth</B> #
- <B>background</B> color|none
- <B>size</B> #
- <B>ref</B> reference point
- <B>rotate</B> degrees CCW
- <B>xoffset</B> #
- <B>yoffset</B> #
- <B>opaque</B> [y|n]
- <B>end</B>
-</PRE>
-The user specifies where the text will be placed by
-providing map coordinates or percentages of the geographic region.
-The text follows these coordinates on the same instruction line.
-More than one line of text can be specified by notating the end of a line with
-<B>\n</B>
-(e.g. USA<B>\n</B>CERL).
-<P>
-The user can then specify various text features:
-<P>
-<B>font:</B>
-the PostScript font. Common possibilities are listed at the start of this
-help page. The default is <tt>Helvetica</tt>.
-<P>
-<B>color</B>
-(see <a href="#NAMED_COLORS">NAMED COLORS</a>);
-<P>
-<B>width</B>
-of the lines used to draw the text to make thicker letters
-(accepts decimal points [floating points] as well as integers);
-<P>
-<B>size</B> and <B>fontsize.</B>
-<B>size</B> gives the vertical height of the letters in meters on the
-ground (text size will grow or shrink depending on the scale at which
-the map is painted). Alternatively <B>fontsize</B> can set the font
-size directly. If neither <B>size</B> or <B>fontsize</B> is given, a
-default font size of 10 will be used;
-<P>
-the highlight color (<B>hcolor</B>) and
-the width of the highlight color (<B>hwidth</B>);
-<P>
-the text-enclosing-box <B>background</B> color;
-the text box <B>border</B> color;
-<P>
-<B>ref.</B>
-This reference point specifies the text handle - what
-part of the text should be placed on the location specified by the map
-coordinates. Reference points can refer to:
-[lower|upper|center] [left|right|center] of the text to be printed; The default is center center, i.e the text is centered on the reference point.
-<P>
-<B>rotate</B>
-sets the text rotation angle, measured in degrees counter-clockwise.
-<P>
-<B>yoffset</B>,
-which provides finer placement of text by shifting the
-text a vertical distance in pixels from the specified north. The vertical
-offset will shift the location to the south if positive, north if negative;
-<P>
-<B>xoffset</B>,
-which shifts the text a horizontal distance in pixels from
-the specified east The horizontal offset will shift the location east if
-positive, west if negative;
-<P>
-<B>opaque</B>,
-whether or not the text should be <B>opaque</B> to vectors. Entering <B>no</B>
-to the opaque option will allow the user to see any vectors which go
-through the text's background box. Otherwise, they will end at the box's edge.
-<P>
-<BR>
-The following example would place the text <EM>SPEARFISH LAND COVER</EM>
-at the coordinates E650000 N7365000. The text would be a total of
-3 pixels wide (2 pixels of red text and 1 pixel black highlight), have a white
-background enclosed in a red box, and be 500 meters in size. The lower right
-corner of the text would be centered over the coordinates provided. All
-vectors on the map would stop at the border of this text.
-<PRE>
-EXAMPLE:
- <B>text</B> 650000 7365000 SPEARFISH LAND COVER
- <B>font</B> romand
- <B>color</B> red
- <B>width</B> 2
- <B>hcolor</B> black
- <B>hwidth</B> 1
- <B>background</B> white
- <B>border</B> red
- <B>size</B> 500
- <B>ref</B> lower left
- <B>opaque</B> y
- <B>end</B>
-</PRE>
-<P>
-<a name="vareas"></a>
-<H2>vareas</H2>
-Selects a vector map layer for output and plots areas.
-<PRE>
-USAGE: <B>vareas</B> vectormap
- <B>layer</B> # (layer number used with cats/where option)
- <B>cats</B> list of categories (e.g. 1,3,5-7)
- <B>where</B> SQL where statement
- <B>rgbcolumn</B> column
- <B>width</B> #
- <B>label</B> label to use in legend
- <B>lpos</B> position in legend
- <B>pat</B> pattern file
- <B>pwidth</B> #
- <B>scale</B> #
- <B>end</B>
-</PRE>
-The user can specify:
-<P>
-<B>color</B> - color of the vector lines or area boundaries;
-<P>
-<B>fcolor</B> - the area fill color;
-<P>
-<B>rgbcolumn</B> - name of color definition column used for the area fill color;
-<P>
-<B>width</B> - width of the vectors lines or area boundaries in pixels
-<P>
-<B>masked</B> - whether or not the raster map layer is to be masked
-by the current mask;
-(see manual entry <EM><A HREF="r.mask.html">r.mask</A></EM>
-for more information on the mask)
-<P>
-<B>cats</B> - which categories should be plotted (default is all);
-<P>
-<B>where</B> - select features using a SQL where statement.
-For example: <tt>vlastnik = 'Cimrman'</tt>;
-<P>
-<B>label</B> - for description in <a href="#vlegend">vlegend</a>.
-Default is: map(mapset);
-<P>
-<B>lpos</B> - position vector is plotted in legend. If lpos is
-0 then this vector is omitted in legend. If more vectors used the
-same lpos then their symbols in legend are merged and label for
-first vector is used.
-<P>
-<B>pat</B> - full path to pattern file. The pattern file contains header and
-simple PostScript commands. It is similar to EPS but more limited, meaning that
-while each pattern file is a true EPS file, most EPS files are not useful as pattern
-files because they contain restricted commands. Color and width of patterns are set
-by <B>fcolor</B> (red, green, ..., none, R:G:B) and <B>width</B> until overwritten
-in the pattern file.
-Pattern may be scaled with the <b>scale</b> command. Several standard hatching
-patterns are provided in <tt>$GISBASE/etc/paint/patterns/</tt>.
-Demonstrative images can be found on the
-<a href="http://grass.gdf-hannover.de/wiki/AreaFillPatterns">GRASS Wiki site</a>.
-You can also create your own custom pattern files in a text editor.
-Example of pattern file:
-<div class="code"><PRE>
-%!PS-Adobe-2.0 EPSF-1.2
-%%BoundingBox: 0 0 10 10
-newpath
-5 0 moveto
-5 10 lineto
-stroke
-</PRE></div>
-<P>
-<B>scale</B> - pattern scale
-<P>
-<B>pwidth</B> - pattern line width, width is used by pattern until the width is overwritten
-in pattern file.
-<P>
-<PRE>
-EXAMPLE:
- <B>vareas</B> forest
- <B>color</B> blue
- <B>width</B> 1
- <B>masked</B> y
- <B>cats</B> 2,5-7
- <B>end</B>
-</PRE>
-<P>
-<a name="vlines"></a>
-<H2>vlines</H2>
-Selects a vector map layer for output and plots lines.
-<PRE>
-USAGE: <B>vlines</B> vectormap
- <B>type</B> line and/or boundary
- <B>where</B> SQL where statement like: vlastnik = 'Cimrman'
- <B>width</B> #
- <B>cwidth</B> #
- <B>hwidth</B> #
- <B>offset</B> #
- <B>coffset</B> #
- <B>ref</B> left|right
- <B>style</B> 00001111
- <B>lpos</B> #
- <B>end</B>
-</PRE>
-<P>
-<B>type</B> - the default is lines only;
-<P>
-<P>
-<B>rgbcolumn</B> - name of color definition column used for the vector lines or area boundaries;
-<P>
-<P>
-<B>cwidth</B> - width of the vectors lines. If cwidth is used then
-width of line is equal to cwidth * category value and width is
-used in legend;
-<P>
-<B>hcolor</B> - the highlight color for the vector lines;
-<P>
-<B>hwidth</B> - the width of the highlight color in pixels;
-<P>
-<B>offset</B> (experimental) - offset for the vectors lines in pixels for plotting
-parallel lines in distance equal to offset (accepts positive or
-negative decimal points). Useful to print streets with several parallel lanes;
-<P>
-<B>coffset</B> (experimental) - offset for the vectors lines. If coffset is used then
-offset of line is equal to coffset * category value and offset is
-used in legend;
-<P>
-<B>ref</B> (experimental) - line justification.
-<P>
-for more information on the mask);
-<P>
-<B>style</B> - the line style allows the vectors
-to be dashed in different patterns. This is done by typing a
-series of numbers (0's and 1's) in a desired sequence or pattern.
-The first block of repeated zeros or ones represents "draw", the second
-block represents "blank".
-An even number of blocks will repeat the pattern, an odd number of blocks
-will alternate the pattern.
-The default is "solid";
-<P>
-<P>
-<P>
-<P>
-<PRE>
-EXAMPLE:
- <B>vlines</B> streams
- <B>color</B> blue
- <B>width</B> 2
- <B>hcolor</B> white
- <B>hwidth</B> 1
- <B>masked</B> y
- <B>cats</B> 2
- <B>label</B> Streams - category 2
- <B>end</B>
-</PRE>
-<P>
-<a name="vpoints"></a>
-<H2>vpoints</H2>
-Selects vector point data to be placed on the output map
-<PRE>
-USAGE: <B>vpoints</B> vectormap
- <B>type</B> point and/or centroid
- <B>layer</B> # (layer number used with cats/where/sizecol options)
- <B>width</B> #
- <B>eps</B> epsfile
- <B>size</B> #
- <B>sizecolumn</B> attribute column used for symbol sizing
- <B>scale</B> scaling factor for sizecolumn values
- <B>rotate</B> #
- <B>rotatecolumn</B> column
- <B>label</B> legend label
- <B>end</B>
-</PRE>
-The user may specify the
-the <B>color</B> of the sites (see section on <a href="#NAMED_COLORS">NAMED COLORS</a>);
-either the GRASS <B>symbol</B> or
-the <B>eps</B> Encapsulated Postscript file to be used to represent the presence of a site
-(if '<B>$</B>' is used in the EPS file path it will be replaced by category number);
-and <B>rotate</B> (in degrees) for counter-clockwise rotation.
-<BR>
-The size of the icon (number of times larger than the size it is in
-the icon file) is typically given by the <B>size</B> option. Alternatively
-the size of the symbol or EPS graphic can be taken from an attribute column
-by using the <B>sizecolumn</B> command. The value given by <B>sizecolumn</B> may be
-scaled by using the <B>scale</B> factor setting (default scaling is 1.0).
-In a similar manner symbol color can be read from <B>rgbcolumn</B>
-and the rotation angle read from <B>rotatecolumn</B>.
-<PRE>
-EXAMPLE:
- <B>vpoints</B> windmills
- <B>color</B> blue
- <B>symbol</B> mills/windmill
- <B>size</B> 10
- <B>end</B>
-</PRE>
-<P>
-<a name="vlegend"></a>
-<H2>vlegend</H2>
-vector information, on or below the map.
-<PRE>
-USAGE: <B>vlegend</B>
- <B>where</B> x y
- <B>width</B> width of color symbol
- <B>cols</B> number of columns to print
- <B>end</B>
-</PRE>
-The default location is immediately below the legend containing the
-scale, grid and region information, starting at the left edge of the map.
-If the <EM>where</EM> instruction is present and <EM>y</EM> is less than or
-equal to zero, the vector legend will be positioned immediately below
-the map, starting <EM>x</EM> inches from the left edge of the page.
-<P>
-<EM>width</EM> is the width in inches of the color symbol (for areas) in front of the
-legend text. The default is 1/24 * fontsize inches.
-<EM>cols</EM> is the number of columns to split the legend into. The default is one
-column. The maximum number of colums is 10, or equal to the number of legend entries
-if there are less than 10 entries.
-<P>
-<P>
-Alternatively, the user can create a custom legend by using the
-<a href="#rectangle">rectangle</a>, <a href="#point">point</a>, and
-<a href="#text">text</a> instructions.
-<P>
-This example prints the vector legend
-immediately below the map and starting 4.5 inches from the left edge
-of the page, using a 12/72 inch Helvetica font.
-<PRE>
-EXAMPLE:
- <B>vlegend</B>
- <B>where</B> 4.5 0
- <B>end</B>
-</PRE>
-<P>
-<a name="end"></a>
-<H2>end</H2>
-Terminates input and begin painting the map.
-<PRE>
-USAGE: <B>end</B>
-</PRE>
-<BR>
-<P>
-<H2>EXAMPLE ps.map INPUT FILE</H2>
-The following is an example of a <EM>ps.map</EM> script file. The file has been
-named <EM>spear.soils</EM>.
-This script file can be entered at the command line:
-<PRE>
- <B>ps.map input=</B><EM>spear.soils</EM> <B>output=</B><EM>soils.ps</EM>
-</PRE>
-<PRE>
-# this ps.map example draws a map of Spearfish, SD
-<B>raster</B> soils
-<B>outline</B>
- <B>width</B> 1
- <B>end</B>
-<B>comments</B> soil.cmt
- <B>where</B> 1 6
- <B>end</B>
-<B>colortable</B> y
- <B>where</B> 1 6.5
- <B>cols</B> 4
- <B>width</B> 4
- <B>end</B>
-<B>setcolor</B> 6,8,9 white
-<B>setcolor</B> 10 green
-<B>vlines</B> roads
- <B>width</B> 2
- <B>style</B> 0111
- <B>color</B> grey
- <B>masked</B> n
- <B>end</B>
-<B>vlegend</B>
- <B>fontsize</B> 8
- <B>end</B>
-<B>text</B> 30% 100% SPEARFISH SOILS MAP
- <B>color</B> red
- <B>width</B> 1
- <B>hwidth</B> 1
- <B>border</B> red
- <B>size</B> 500
- <B>end</B>
-<B>line</B> 606969.73 3423092.91 616969.73 3423092.91
- <B>width</B> 2
- <B>end</B>
-<B>point</B> 40% 60%
- <B>color</B> purple
- <B>size</B> 25
- <B>masked</B> n
- <B>end</B>
-<B>scale</B> 1:125000
-<B>scalebar</B> f
- <B>where</B> 4.5 6.5
- <B>length</B> 5000
- <B>height</B> 0.05
- <B>segment</B> 5
- <B>numbers</B> 5
- <B>end</B>
-<B>geogrid</B> 60 s
- <B>color</B> blue
- <B>end</B>
-<B>paper</B> a4
- <B>end</B>
-<B>end</B>
-</PRE>
-<P>
-More examples can be found on the
-<a href="http://grass.osgeo.org/wiki/Ps.map_scripts">GRASS Wiki</a>
-help site.
-<P>
-<H2>CHANGES BETWEEN VERSION 5.0.x/5.4.x and 6.0</H2>
-<UL>
-<LI>Devices and ps.select do not exist any more. Paper is defined by the
-<EM>paper</EM> instruction.</LI>
-<LI><EM>vpoints</EM> are used instead of <EM>sites</EM> (points are read from vector).</LI>
-<LI><EM>vector</EM> is substituted by <EM>vpoints</EM>, <EM>vlines</EM> and <EM>vareas</EM>.</LI>
-<LI>Symbols are used instead of icons (different format and directory).</LI>
-<LI>Map legend can be printed in columns.</LI>
-</UL>
-<H2>SEE ALSO</H2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="v.label.html">v.label</a>
-</em>
-<H2>AUTHOR</H2>
-Paul Carlson, USDA, SCS, NHQ-CGIS<BR>
-Modifications: Radim Blazek, Glynn Clements, Bob Covill, Hamish Bowman
-<p>
Copied: grass/trunk/ps/ps.map/ps.map.html (from rev 32770, grass/trunk/ps/ps.map/description.html)
--- grass/trunk/ps/ps.map/ps.map.html (rev 0)
+++ grass/trunk/ps/ps.map/ps.map.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,1606 @@
+<H2>DESCRIPTION</H2>
+<EM>ps.map</EM> is a cartographic mapping program for producing high quality
+hardcopy maps in PostScript format. Output can include a raster map, any
+number of vector overlays, text labels, decorations, and other spatial data.
+<P>
+A file of mapping instructions that describes the various spatial and textual
+information to be printed must be prepared prior to running <EM>ps.map</EM>.
+<H2>NOTES</H2>
+<P>
+The order of commands is generally unimportant but may affect how some layers
+are drawn. For example to plot <B>vpoints</B> above <B>vareas</B> list the
+<B>vpoints</B> entry first. Raster maps are always drawn first, and only a
+single raster map (or 3 if part of a RGB group) may be used.
+<P>
+The hash character ('<tt>#</tt>') may be used at the beginning of a line
+to indicate that the line is a comment. Blank lines will also be ignored.
+<P>
+Be aware that some mapping instructions require the <i>end</i> command
+and some do not. Any instruction that allows subcommands will require
+it, any instruction that does not allow subcommands will not.
+<P>
+The resolution and extent of raster maps plotted with <EM>ps.map</EM> are
+controlled by the current region settings via the
+<a href="g.region.html">g.region</a> module. The output filesize is largely
+a function of the region resolution, so special care should be taken
+if working with large raster datasets. For example if the desired output is
+US-Letter sized paper at 300dpi, with 1" margins and the raster filling the
+entire page, the usable area on the page will be 6.5" x 9", which at 300
+dots/inch is equivalent to a region of 1950 columns x 2700 rows (see
+"<tt>g.region -p</tt>"). Any higher resolution settings will make the
+output file larger, but with a consumer printer you probably won't be able
+to resolve any better detail in the hardcopy.
+<P>
+The user can specify negative or greater than 100 percentage values for
+positioning several map decorations and embedded EPS-files, to move them
+outside the current map box region (for example to position a caption,
+barscale, or legend above or below the map box).
+<P>
+One "pixel" is 1/72 of an inch.
+<P>
+For users wanting to use special characters (such as accented characters) it
+is important to note that <em>ps.map</em> uses <tt>ISO-8859-1</tt> encoding.
+This means that your instructions file will have to be encoded in this
+encoding. If you normally work in a different encoding environment (such as
+<tt>UTF-8</tt>), you have to transform your file to the <tt>ISO-8859-1</tt>
+encoding, for example by using the <tt>iconv</tt> utility:
+</P>
+<DIV class="code"><PRE>
+iconv -f UTF-8 -t ISO_8859-1 utf_file > iso_file
+</PRE></DIV>
+<P><P>
+<H2>MAPPING INSTRUCTIONS</H2>
+The mapping instructions allow the user to specify various spatial data
+to be plotted. These instructions are normally prepared in a regular
+text file using a system editor. Some instructions are single line
+instructions while others are multiple line. Multiple line instructions
+consist of the main instruction followed by a subsection of one or more
+additional instructions and are terminated with an <i>end</i> instruction.
+<P>
+<h3>Instruction keywords:</h3>
+<a href="#border">border</a> |
+<a href="#colortable">colortable</a> |
+<a href="#comments">comments</a> |
+<a href="#copies">copies</a> |
+<a href="#eps">eps</a> |
+<a href="#geogrid">geogrid</a> |
+<a href="#greyrast">greyrast</a> |
+<a href="#grid">grid</a> |
+<a href="#group">group</a> |
+<a href="#header">header</a> |
+<a href="#labels">labels</a> |
+<a href="#line">line</a> |
+<a href="#mapinfo">mapinfo</a> |
+<a href="#maploc">maploc</a> |
+<a href="#maskcolor">maskcolor</a> |
+<a href="#outline">outline</a> |
+<a href="#paper">paper</a> |
+<a href="#point">point</a> |
+<a href="#psfile">psfile</a> |
+<a href="#raster">raster</a> |
+<a href="#read">read</a> |
+<a href="#rectangle">rectangle</a> |
+<a href="#region">region</a> |
+<a href="#rgb">rgb</a> |
+<a href="#scale">scale</a> |
+<a href="#scalebar">scalebar</a> |
+<a href="#setcolor">setcolor</a> |
+<a href="#text">text</a> |
+<a href="#vareas">vareas</a> |
+<a href="#vlines">vlines</a> |
+<a href="#vpoints">vpoints</a> |
+<a href="#vlegend">vlegend</a> |
+<a href="#end">end</a>
+<h3>Common instructions</h3>
+Instructions that may be included in the subsection under several
+different main instructions are:
+<DL>
+<DT><B>where</B> <EM>x y</EM>
+<DD>The top left corner of the bounding box of the item to be plotted
+is located <EM>x</EM> inches from the left edge of the paper and
+<EM>y</EM> inches from the top edge of the paper. If <EM>x</EM> is less than
+or equal to zero, the default horizontal location is used. If <EM>y</EM>
+is less than or equal to zero, the default vertical location is used.
+<DT><B>font</B> <EM>font name</EM>
+<DD>The name of the PostScript font.
+Fonts present in all PostScript implementations are:
+<tt>
+Times-Roman,
+Times-Italic,
+Times-Bold,
+Times-BoldItalic,
+Helvetica,
+Helvetica-Oblique,
+Helvetica-Bold,
+Helvetica-BoldOblique,
+Courier,
+Courier-Oblique,
+Courier-Bold,
+and
+Courier-BoldOblique</tt>.
+<BR>
+The default is Helvetica.
+</DD>
+<DT><B>fontsize</B> <EM>font size</EM>
+<DD>The size of the PostScript font (in 1/72nds of an inch).
+The default is 10.
+</DD>
+<a name="NAMED_COLORS"></a>
+<DT><B>color</B> <EM>name</EM>
+<DD>The following colors names are accepted by <EM>ps.map</EM>:
+<tt>
+aqua,
+black,
+blue,
+brown,
+cyan,
+gray,
+grey,
+green,
+indigo,
+magenta,
+orange,
+purple,
+red,
+violet,
+white,
+yellow
+</tt>.
+<BR><BR>
+For vectors and some plotting commands you can also specify
+'<tt>none</tt>' or '<tt>R:G:B</tt>' (e.g '<tt>255:0:0</tt>').
+</DD>
+</DL>
+<P>
+<BR>
+<h3>Command usage</h3>
+<a name="border"></a>
+<H2>border</H2>
+Controls the border which is drawn around the map area.
+<PRE>
+USAGE: <B>border</B> [y|n]
+ <B>color</B> color
+ <B>width</B> #
+ <B>end</B>
+</PRE>
+The <B>color</B> may be either a standard GRASS color, a R:G:B triplet,
+or "none". The width is specified in points, unless followed by an "i"
+in which case it is measured in inches.
+The default is a black border box of width 1 point.
+<P>
+The border can be turned off completely with the
+"<tt>border n</tt>" instruction. In this case
+the <B>end</B> command should not be given as the
+main command will be treated as a single line instruction.
+<P>
+This example would create a grey border 0.1" wide.
+<PRE>
+EXAMPLE:
+ <B>border</B>
+ <B>color</B> grey
+ <B>width</B> 0.1i
+ <B>end</B>
+</PRE>
+<P>
+<a name="colortable"></a>
+<H2>colortable</H2>
+Prints the color table for the raster map layer anywhere on the page.
+<PRE>
+USAGE: <B>colortable</B> [y|n]
+ <B>where</B> x y
+ <B>raster</B> raster map
+ <B>range</B> minimum maximum
+ <B>width</B> table width
+ <B>height</B> table height (FP legend only)
+ <B>cols</B> table columns
+ <B>font</B> font name
+ <B>fontsize</B> font size
+ <B>color</B> text color
+ <B>nodata</B> [Y|n]
+ <B>tickbar</B> [y|N]
+ <B>end</B>
+</PRE>
+The color table will display the colors for each raster map layer
+category value and the category label.
+If <B>raster</B> is omitted, the colortable defaults to a previously registered raster layer.
+The legend's <B>range</B> can be adjusted for floating point rasters, but if
+set beyond the extent of the map's range be sure that you have set up color
+rules with <em>r.colors</em> which cover this range.
+The default location for the colortable is immediately below any other
+map legend information, starting at the left margin.
+The default text color is black.
+Omitting the <B>colortable</B> instruction would result in
+no color table. For floating point legends <B>width</B> is width of color
+band only. <B>height</B> is used only for floating point legend.
+Adding the <B>nodata n</B> instruction will prevent the "no data" box
+from being drawn (category based legends only).
+Adding the <B>tickbar y</B> instruction will change the tick mark style
+so that ticks are drawn across the color table instead of protruding out
+to the right (floating point legends only).
+<P>
+<B>Note</B>: Be careful about asking for color tables for
+raster map layers which have many categories, such as elevation.
+This could result in the printing of an extremely long color table!
+<P>
+Another issue is that the color table only includes categories which
+have a label. If there are only a few categories, you can use
+r.support to manually add labels. If there are too many categories to
+do this, you could write a script to add dummy labels to the cats file<br>
+(<gisdbase>/<location>/<mapset>/cats/<mapname>).
+<P>
+If the colortable is turned off with a "<tt>colortable n</tt>"
+instruction the <B>end</B> command should not be given as the
+<P>
+This example would print a color table immediately below any other map legend
+information, starting at the left margin, with 4 columns:
+<PRE>
+EXAMPLE:
+ <B>colortable</B> y
+ <B>cols</B> 4
+ <B>width</B> 4
+ <B>end</B>
+</PRE>
+<P>
+<a name="comments"></a>
+<H2>comments</H2>
+Prints comments anywhere on the page.
+<PRE>
+USAGE: <B>comments</B> commentfile
+ <B>where</B> x y
+ <B>end</B>
+</PRE>
+The default location is immediately below the last item item printed,
+starting at the left margin. The default text color is black.
+<P>
+If you wish to use parentheses spanning multiple lines you will need to
+quote them with a backslash to prevent the PostScript interpreter from
+getting confused. e.g. '<B><TT>\(</TT></B>' and '<B><TT>\)</TT></B>'
+<P>
+This example prints in blue
+whatever is in the file <EM>veg.comments</EM> starting at
+1.5 inches from the left edge of the page and 7.25 inches from the top of
+the page, using a 15/72 inch Helvetica Bold font.
+<PRE>
+EXAMPLE:
+ <B>raster</B> vegetation
+ <B>comments</B> veg.comments
+ <B>where</B> 1.5 7.25
+ <B>font</B> Helvetica Bold
+ <B>fontsize</B> 15
+ <B>color</B> blue
+ <B>end</B>
+</PRE>
+Presumably, the file
+<EM>veg.comments</EM>
+contain comments
+pertaining to the raster map layer <EM>vegetation</EM>,
+such as "This map was created by classifying a LANDSAT TM image".
+<P>
+<a name="copies"></a>
+<H2>copies</H2>
+Specifies the number of copies to be printed.
+<PRE>
+USAGE: <B>copies</B> n
+</PRE>
+Each page will be printed n times.
+<P>
+This instruction is identical to the <EM>copies</EM> command line parameter.
+<P>
+<a name="eps"></a>
+<H2>eps</H2>
+Places EPS (Encapsulated PostScript) pictures on the output map.
+<PRE>
+USAGE: <B>eps</B> east north
+ <B>eps</B> x% y%
+ <B>epsfile</B> EPS file
+ <B>scale</B> #
+ <B>rotate</B> #
+ <B>masked</B> [y|n]
+ <B>end</B>
+</PRE>
+The EPS picture location is entered in the main
+instruction line by giving either the map
+coordinates or by using percentages of the geographic region.
+The EPS picture will be <i>centered</i> at the given position.
+The user must specify full EPS file path <B>epsfile</B>.
+The user may also specify the <B>scale</B> of the icon
+(default is 1.0), the <B>rotate</B> i.e. rotation in degrees
+(default is 0)
+and whether the point is to be <B>masked</B>
+by the current mask.
+(See manual entry for <EM><A HREF="r.mask.html">r.mask</A></EM>
+for more information on the mask.)
+<P>
+This example would place a EPS file ./epsf/logo.eps
+at the point (E456000 N7890000). This picture would be
+rotated 20 degrees clockwise, 3 times bigger than
+in original file and would not be masked by the current mask.
+<PRE>
+EXAMPLE:
+ <B>eps</B> 456000 7890000
+ <B>epsfile</B> ./epsf/logo.eps
+ <B>scale</B> 3
+ <B>rotate</B> 20
+ <B>masked</B> n
+ <B>end</B>
+</PRE>
+Of course, multiple EPS pictures may be drawn with multiple
+<EM>eps</EM>
+instructions.
+<P>
+<a name="geogrid"></a>
+<H2>geogrid</H2>
+Overlays a geographic grid onto the output map.
+<PRE>
+USAGE: <B>geogrid</B> spacing unit
+ <B>numbers</B> # [color]
+ <B>width</B> #
+ <B>end</B>
+</PRE>
+The <B>spacing</B> and spacing unit of the geographic grid is given
+on the main instruction line. The <B>spacing</B> unit is given as one of <B>d</B> for
+degrees, <B>m</B> for minutes, and <B>s</B> for seconds.
+The subsection instructions allow the user to specify
+the <B>color</B> of the geographic grid lines,
+whether coordinate <B>numbers</B> should appear
+on the geographic grid lines, the <B>width</B>
+of the lines (accepts decimal points [floating points]
+as well as integers), and
+if they should appear every grid line (1), every other grid line
+(2), etc., and what color the numbers should be. The defaults are
+black grid lines, unnumbered.
+<P>
+NOTE: The <B>geogrid</B> draws grid numbers on the east and south borders of the map.
+<P>
+This example would overlay a blue geographic grid with a spacing of 30 minutes
+onto the output map. Alternate grid
+lines would be numbered with yellow numbers.
+<PRE>
+EXAMPLE:
+ <B>geogrid</B> 30 m
+ <B>color</B> blue
+ <B>numbers</B> 2 yellow
+ <B>end</B>
+</PRE>
+<P>
+<a name="greyrast"></a>
+<H2>greyrast</H2>
+Selects a raster map layer for output in shades of grey.
+<PRE>
+USAGE: <B>greyrast</B> mapname
+</PRE>
+For each
+<EM>ps.map</EM>
+run, only one raster map layer can be requested (using either the
+<EM>greyrast</EM> or the <EM>raster</EM> instruction).
+<P>
+<a name="grid"></a>
+<H2>grid</H2>
+Overlays a coordinate grid onto the output map.
+<PRE>
+USAGE: <B>grid</B> spacing
+ <B>cross</B> cross size
+ <B>width</B> #
+ <B>end</B>
+</PRE>
+The <B>spacing</B> of the grid is given (in the geographic coordinate
+system units) on the main instruction line. The subsection instructions
+allow the user to specify
+the <B>color</B> of the grid lines,
+on the grid lines, and if they
+should appear every grid line (1), every other grid line
+The <B>cross</B> argument draws grid intersection crosses instead of grid lines,
+with cross size given in geographic coordinate system units.
+The defaults are black grid lines, unnumbered.
+<P>
+This example would overlay a green grid with a spacing of 10000 meters
+(for a metered database, like UTM) onto the output map. Alternate grid
+lines would be numbered with red numbers.
+<PRE>
+EXAMPLE:
+ <B>grid</B> 10000
+ <B>color</B> green
+ <B>numbers</B> 2 red
+ <B>end</B>
+</PRE>
+<P>
+<a name="group"></a>
+<H2>group</H2>
+Selects an RGB imagery group for output.
+<PRE>
+USAGE: <B>group</B> <EM>groupname</EM>
+</PRE>
+This is similar to <EM>raster</EM>, except that it uses an imagery group
+instead of a raster map layer. The group must contain three raster map
+layers, comprising the red, green and blue bands of the image.
+<P>
+<a name="header"></a>
+<H2>header</H2>
+Prints the map header above the map.
+<PRE>
+USAGE: <B>header</B>
+ <B>file</B> header file
+ <B>end</B>
+</PRE>
+If the <EM>file</EM> sub-instruction is absent the header will consist
+of the map's title <!-- from hist file -->
+and the location's description.<!-- PERMANENT/MYNAME -->
+The text will be centered on the page above the map.
+<P>
+This example prints (in red) whatever is in the file <EM>soils.hdr</EM> above
+the map, using a 20/72 inch <tt>Courier</tt> font.
+<PRE>
+EXAMPLE:
+ <B>header</B>
+ <B>file</B> soils.hdr
+ <B>font</B> Courier
+ <B>fontsize</B> 20
+ <B>color</B> red
+ <B>end</B>
+</PRE>
+<P>
+<a name="labels"></a>
+<H2>labels</H2>
+Selects a labels file for output (see manual entry for
+<EM>
+<A HREF="v.label.html">v.label</A>
+).</EM>
+<PRE>
+USAGE: <B>labels</B> labelfile
+ <B>end</B>
+</PRE>
+<P>
+NOTE: ps.map can read new option 'ROTATE:' from labels file, which
+specifies counter clockwise rotation in degrees.
+<P>
+This example would paint labels from the labels file called
+<EM>town.names</EM>. Presumably, these labels would indicate the names of
+towns on the map.
+<PRE>
+EXAMPLE:
+ <B>labels</B> town.names
+ <B>end</B>
+</PRE>
+<P>
+<a name="line"></a>
+<H2>line</H2>
+Draws lines on the output map.
+<PRE>
+USAGE: <B>line</B> east north east north
+ <B>line</B> x% y% x% y%
+ <B>width</B> #
+ <B>end</B>
+</PRE>
+The beginning and ending points of the line are entered on the main
+instruction. These points can be defined either by map coordinates or
+by using percentages of the geographic region.
+The user may also specify line
+<B>color</B>,
+<B>width</B>
+in pixels (accepts decimal points [floating points] as well as integers),
+and if the line is to be <B>masked</B> by the current mask.
+</EM> for more information on the mask.)
+<P>
+This example would draw a yellow line from the point x=10% y=80%
+to the point x=30% y=70%. This line
+would be 2 pixels wide and would appear even if there is a mask.
+<PRE>
+EXAMPLE:
+ <B>line</B> 10% 80% 30% 70%
+ <B>color</B> yellow
+ <B>width</B> 2
+ <B>masked</B> n
+ <B>end</B>
+</PRE>
+Of course, multiple lines may be drawn with multiple
+<EM>line</EM>
+instructions.
+<P>
+<a name="mapinfo"></a>
+<H2>mapinfo</H2>
+Prints the portion of the map legend containing the scale, grid and
+region information, on or below the map.
+<PRE>
+USAGE: <B>mapinfo</B>
+ <B>where</B> x y
+ <B>background</B> box color|none
+ <B>border</B> color|none
+ <B>end</B>
+</PRE>
+The default location is immediately below the map,
+starting at the left edge of the map.
+The default background box color is white.
+<P>
+<EM>border</EM> will draw a border around the legend using the specified color.
+ (see <a href="#NAMED_COLORS">NAMED COLORS</a>)
+<P>
+This example prints (in brown) the scale, grid and region information
+immediately below the map and starting 1.5 inches from the left edge
+of the page, using a 12/72 inch <tt>Courier</tt> font.
+<PRE>
+EXAMPLE:
+ <B>mapinfo</B>
+ <B>where</B> 1.5 0
+ <B>fontsize</B> 12
+ <B>color</B> brown
+ <B>end</B>
+</PRE>
+<P>
+<a name="maploc"></a>
+<H2>maploc</H2>
+Positions the map on the page.
+<PRE>
+USAGE: <B>maploc</B> x y [width height]
+</PRE>
+The upper left corner of the map will be positioned <EM>x</EM> inches from
+the left edge of the page and <EM>y</EM> inches from the top of the page.
+If <EM>width</EM> and <EM>height</EM> (in inches) are present, the map will be
+rescaled, if necessary, to fit.
+<P>
+This example positions the upper left corner of the map 2.0 inches from
+the left edge and 3.5 inches from the top edge of the map.
+<PRE>
+EXAMPLE:
+ <B>maploc</B> 2.0 3.5
+</PRE>
+<P>
+<a name="maskcolor"></a>
+<H2>maskcolor</H2>
+Color to be used for mask.
+<PRE>
+USAGE: <B>maskcolor</B> color
+</PRE>
+<a name="outline"></a>
+<H2>outline</H2>
+Outlines the areas of a raster map layer with a specified color.
+<PRE>
+USAGE: <B>outline</B>
+ <B>width</B> width of line in pixels
+ <B>end</B>
+</PRE>
+Distinct areas of the raster map will be separated from each other visually
+by drawing a border (or outline) in the specified
+<B>color</B>
+(default: black). For
+<B>width</B>
+the program accepts decimal points [floating points] as well as integers.
+Note: it is
+important the user enter the instruction <B>end</B> even if a color is not
+chosen.
+(It is hoped that in the future the outline of a different raster map
+layer other than the one currently being painted may be placed on the map.)
+<P>
+This example would outline the category areas of the
+<EM>soils</EM>
+raster map layer
+in grey.
+<PRE>
+EXAMPLE:
+ <B>raster</B> soils
+ <B>outline</B>
+ <B>color</B> grey
+ <B>width</B> 2
+ <B>end</B>
+</PRE>
+<P>
+<a name="paper"></a>
+<H2>paper</H2>
+Specifies paper size and margins.
+<PRE>
+USAGE: <B>paper</B> paper name
+ <B>height</B> #
+ <B>width</B> #
+ <B>left</B> #
+ <B>right</B> #
+ <B>bottom</B> #
+ <B>top</B> #
+ <B>end</B>
+</PRE>
+<B>paper</B> may select predefined paper name
+ (a4,a3,a2,a1,a0,us-legal,us-letter,us-tabloid).
+ Default paper size is a4. The measures are defined in <em>inches</em>.
+<B>left</B>, <B>right</B>, <B>bottom</B> and <B>top</B> are paper margins.
+If the plot is rotated with the <b>-r</b> command line flag, measures
+are applied to the <em>rotated</em> page.
+<P>
+<PRE>
+EXAMPLE:
+ <B>paper</B> a3
+ <B>end</B>
+</PRE>
+<P>
+<PRE>
+EXAMPLE:
+ <B>paper</B>
+ <B>width</B> 10
+ <B>height</B> 10
+ <B>left</B> 2
+ <B>right</B> 2
+ <B>bottom</B> 2
+ <B>top</B> 2
+ <B>end</B>
+</PRE>
+<P>
+<a name="point"></a>
+<H2>point</H2>
+Places additional points or icons on the output map.
+<PRE>
+USAGE: <B>point</B> east north
+ <B>point</B> x% y%
+ <B>fcolor</B> color
+ <B>symbol</B> symbol group/name
+ <B>size</B> #
+ <B>rotate</B> #
+ <B>end</B>
+</PRE>
+The point location is entered in the main instruction line by giving either the map
+The user may also specify the point <B>color</B>,
+the <B>size</B> of symbol in points,
+the rotation angle (in degrees CCW),
+and whether the point is to be <B>masked</B> by the current mask.
+(See manual entry for <EM> <A HREF="r.mask.html">r.mask</A>
+<P>
+This example would place a purple diamond (from icon file
+<EM>diamond</EM>) at the point (E456000 N7890000). This diamond would be the
+the size of a 15 points and would not be masked by the current mask.
+<PRE>
+EXAMPLE:
+ <B>point</B> 456000 7890000
+ <B>fcolor</B> purple
+ <B>color</B> black
+ <B>symbol</B> basic/diamond
+ <B>size</B> 15
+ <B>masked</B> n
+ <B>end</B>
+</PRE>
+Of course, multiple points may be drawn with multiple
+<EM>point</EM>
+instructions.
+<P>
+<a name="psfile"></a>
+<H2>psfile</H2>
+Copies a file containing PostScript commands into the output file.
+<P>
+<B>Note:</B>
+<EM>ps.map</EM>
+will not search for this file. The user must be in the
+correct directory or specify the full path on the <B>psfile</B> instruction.
+(Note to /bin/csh users: ~ won't work with this instruction).
+<PRE>
+USAGE: <B>psfile</B> filename
+</PRE>
+This example copies the file "logo.ps" into the output file.
+<PRE>
+EXAMPLE:
+ <B>psfile</B> logo.ps
+</PRE>
+<P>
+<a name="raster"></a>
+<H2>raster</H2>
+Selects a raster map layer for output.
+<PRE>
+USAGE: <B>raster</B> mapname
+</PRE>
+For each <EM>ps.map</EM> run, only one raster map layer (or set
+of layers or imagery group; see below) can be requested. If no
+raster map layer is requested, a completely white map will be
+produced. It can be useful to select no raster map layer in
+order to provide a white background for vector maps.
+<P>
+Note that an imagery group selected with the <EM>group</EM>
+option, or a set of three raster layers selected with the
+<EM>rgb</EM> option, count as a raster map layer for the
+purposes of the preceding paragraph.
+<P>
+This example would paint a map of the raster map layer <EM>soils</EM>.
+<PRE>
+EXAMPLE:
+</PRE>
+<P>
+<a name="read"></a>
+<H2>read</H2>
+Provides <EM>ps.map</EM> with a previously prepared input stream.
+<PRE>
+USAGE: <B>read</B> previously prepared UNIX file
+</PRE>
+Mapping instructions can be placed into a file and read into
+<EM>ps.map.</EM>
+<P>
+<B>Note:</B>
+<EM>ps.map</EM>
+correct directory or specify the full path on the <B>read</B> instruction.
+<P>
+This example reads the UNIX file <EM>pmap.roads</EM> into <EM>ps.map</EM>.
+This file may contain all the <EM>ps.map</EM> instructions for placing
+the vector map layer <EM>roads</EM> onto the output map.
+<PRE>
+EXAMPLE:
+ <B>read</B> pmap.roads
+</PRE>
+The user may have created this file because this vector map layer
+is particularly useful for many <EM>ps.map</EM>
+outputs. By using the <B>read</B> option, the user need not enter all the input
+for the <B>vector</B> instruction, but simply <B>read</B> the previously prepared
+file with the correct instructions.
+<P>
+<a name="rectangle"></a>
+<H2>rectangle</H2>
+Draws rectangle on the output map.
+<PRE>
+USAGE: <B>rectangle</B> east north east north
+ <B>rectangle</B> x% y% x% y%
+ <B>fcolor</B> fill color
+ <B>width</B> #
+ <B>end</B>
+</PRE>
+The two corners of the rectangle are entered on the main
+<B>color</B>, fill color <B>fcolor</B>, <B>width</B>
+and if the rectangle is to be <B>masked</B> by the current mask.
+<BR>
+Multiple rectangles may be drawn by using multiple <EM>rectangle</EM> instructions.
+<P>
+This example would draw a yellow rectangle filled by green from the point x=10% y=80%
+<PRE>
+EXAMPLE:
+ <B>rectangle</B> 10% 80% 30% 70%
+ <B>fcolor</B> green
+ <B>width</B> 2
+ <B>masked</B> n
+ <B>end</B>
+</PRE>
+<P>
+<a name="region"></a>
+<H2>region</H2>
+Places the outline of a smaller geographic region
+on the output.
+<PRE>
+USAGE: <B>region</B> regionfile
+ <B>width</B> #
+ <B>end</B>
+</PRE>
+Geographic region settings are created and saved using <EM> the
+<A HREF="g.region.html">g.region</A></EM> module.
+The <EM>ps.map</EM> <EM>region</EM> option can be used to show an outline of
+a smaller region which was printed on a separate run of <EM>ps.map</EM>
+on other user-created maps.
+<P>
+The user can specify the <B>color</B>
+and the <B>width</B> in pixel units (accepts decimal points
+[floating points] as well as integers) of the outline.
+The default is a black border of one pixel width.
+<P>
+This example would place a white outline, 2 pixels wide, of the
+geographic region called <EM>fire.zones</EM> onto the output map.
+This geographic region would have been created and saved using
+<EM><A HREF="g.region.html">g.region</A></EM>.
+<PRE>
+EXAMPLE:
+ <B>region</B> fire.zones
+ <B>color</B> white
+ <B>width</B> 2
+ <B>end</B>
+</PRE>
+<P>
+<a name="rgb"></a>
+<H2>rgb</H2>
+Selects three raster map layers for output as an RGB color image.
+<PRE>
+USAGE: <B>rgb</B> <EM>red</EM> <EM>green</EM> <EM>blue</EM>
+</PRE>
+This is similar to <EM>raster</EM>, except that it uses three
+raster map layers instead of a single layer. The three layers
+are composed to form a color image, similar to <EM>d.rgb</EM>.
+<P>
+For each layer, only one of the components of the layer's color
+table is used: the red component for the red layer, and so on.
+This will give the desired result if all of the layers have a
+grey-scale color table, or if each layer's color table uses the
+hue appropriate to the layer.
+<P>
+<a name="scale"></a>
+<H2>scale</H2>
+Selects a scale for the output map.
+<PRE>
+USAGE: <B>scale</B> <EM>scale</EM>
+</PRE>
+The scale can be selected either as:
+<DL>
+<DT>
+<DD>a relative ratio, e.g. 1:25000;
+<DT>
+<DD>an absolute width of the printed map, e.g. 10 inches;
+<DT>
+<DD>the number of printed paper panels, e.g. 3 panels
+<EM>.I</EM>
+(at the present time, only 1 panel is supported);
+<DT>
+<DD>the number of miles per inch, e.g. 1 inch equals 4 miles.
+</DD>
+</DL>
+<P>
+This example would set the scale of the map to 1 unit = 25000
+units.
+<PRE>
+EXAMPLE:
+ <B>scale</B> 1:25000
+</PRE>
+<P>
+This instruction is identical to the <EM>scale</EM> command line parameter.
+<BR>
+<em>NOTE: Using "scale" from the command line is depreciated and while
+still provided for compatibility reasons it will be removed in the future.
+Please use the "scale" mapping instruction instead.</em>
+<P>
+<a name="scalebar"></a>
+<H2>scalebar</H2>
+Draws a scalebar on the map.
+<PRE>
+USAGE: <B>scalebar</B> [f|s]
+ <B>where</B> x y
+ <B>length</B> scale length
+ <B>height</B> scale height
+ <B>segment</B> no. segments
+ <B>numbers</B> #
+ <B>background</B> [Y|n]
+ <B>end</B>
+</PRE>
+Draw one of two types of scale bar.
+Fancy (f) draws alternating black and white scale boxes.
+Simple (s) draws a plain line scale. The default type is fancy.
+The subsection instructions allow the user to set <B>where</B> the scalebar
+is placed, the <B>length</B> of the scalebar (in geographic coordinate
+system units), the <B>height</B> of the scalebar in inches, and the number of
+<B>segments</B> (or tics for simple). The <B>number</B> of annotations
+numbers every n-th segment.
+The <B>background</B> command can turn off the background box for the text.
+<P>
+The scalebar <B>length</B> is the only required argument. The defaults are a
+fancy scalebar with 4 segments, each segment labeled, and a height of 0.1
+inches. The default location is 2 inches from the top of the page and
+halfway across.
+<P>
+NOTE: The scalebar is centered on the location given.
+<P>
+This example draws a simple scalebar 1000 meters (for a metered database, like UTM) long,
+with tics every 200 meters, labeled every second tic. The scalebar is drawn 5 inches from the top and 4 inches from the left and is 0.25 inches high.
+<PRE>
+EXAMPLE:
+ <B>scalebar</B> s
+ <B>where</B> 4 5
+ <B>length</B> 1000
+ <B>height</B> 0.25
+ <B>segment</B> 5
+ <B>numbers</B> 2
+ <B>end</B>
+</PRE>
+<a name="setcolor"></a>
+<H2>setcolor</H2>
+Overrides the color assigned to one or more categories
+of the raster map layer.
+<PRE>
+USAGE: <B>setcolor</B> cat(s) color
+</PRE>
+This example would set the color for categories 2,5 and 8 of the raster
+map layer <EM>watersheds</EM> to white and category 10 to green.
+(<B>NOTE</B>: no spaces are inserted between the category values.)
+<PRE>
+EXAMPLE:
+ <B>raster</B> watersheds
+ <B>setcolor</B> 2,5,8 white
+ <B>setcolor</B> 10 green
+</PRE>
+Of course,
+<EM>setcolor</EM>
+can be requested more than once to override the default color for additional
+categories. More than one category can be changed for each request by listing
+all the category values separated by commas (but with no spaces).
+<P>
+<a name="text"></a>
+<H2>text</H2>
+Places text on the map.
+<PRE>
+USAGE: <B>text</B> east north text
+ <B>text</B> x% y% text
+ <B>font</B> fontname
+ <B>color</B> color|none
+ <B>width</B> #
+ <B>hcolor</B> color|none
+ <B>hwidth</B> #
+ <B>background</B> color|none
+ <B>size</B> #
+ <B>ref</B> reference point
+ <B>rotate</B> degrees CCW
+ <B>xoffset</B> #
+ <B>yoffset</B> #
+ <B>opaque</B> [y|n]
+ <B>end</B>
+</PRE>
+The user specifies where the text will be placed by
+providing map coordinates or percentages of the geographic region.
+The text follows these coordinates on the same instruction line.
+More than one line of text can be specified by notating the end of a line with
+<B>\n</B>
+(e.g. USA<B>\n</B>CERL).
+<P>
+The user can then specify various text features:
+<P>
+<B>font:</B>
+the PostScript font. Common possibilities are listed at the start of this
+help page. The default is <tt>Helvetica</tt>.
+<P>
+<B>color</B>
+(see <a href="#NAMED_COLORS">NAMED COLORS</a>);
+<P>
+<B>width</B>
+of the lines used to draw the text to make thicker letters
+(accepts decimal points [floating points] as well as integers);
+<P>
+<B>size</B> and <B>fontsize.</B>
+<B>size</B> gives the vertical height of the letters in meters on the
+ground (text size will grow or shrink depending on the scale at which
+the map is painted). Alternatively <B>fontsize</B> can set the font
+size directly. If neither <B>size</B> or <B>fontsize</B> is given, a
+default font size of 10 will be used;
+<P>
+the highlight color (<B>hcolor</B>) and
+the width of the highlight color (<B>hwidth</B>);
+<P>
+the text-enclosing-box <B>background</B> color;
+the text box <B>border</B> color;
+<P>
+<B>ref.</B>
+This reference point specifies the text handle - what
+part of the text should be placed on the location specified by the map
+coordinates. Reference points can refer to:
+[lower|upper|center] [left|right|center] of the text to be printed; The default is center center, i.e the text is centered on the reference point.
+<P>
+<B>rotate</B>
+sets the text rotation angle, measured in degrees counter-clockwise.
+<P>
+<B>yoffset</B>,
+which provides finer placement of text by shifting the
+text a vertical distance in pixels from the specified north. The vertical
+offset will shift the location to the south if positive, north if negative;
+<P>
+<B>xoffset</B>,
+which shifts the text a horizontal distance in pixels from
+the specified east The horizontal offset will shift the location east if
+positive, west if negative;
+<P>
+<B>opaque</B>,
+whether or not the text should be <B>opaque</B> to vectors. Entering <B>no</B>
+to the opaque option will allow the user to see any vectors which go
+through the text's background box. Otherwise, they will end at the box's edge.
+<P>
+<BR>
+The following example would place the text <EM>SPEARFISH LAND COVER</EM>
+at the coordinates E650000 N7365000. The text would be a total of
+3 pixels wide (2 pixels of red text and 1 pixel black highlight), have a white
+background enclosed in a red box, and be 500 meters in size. The lower right
+corner of the text would be centered over the coordinates provided. All
+vectors on the map would stop at the border of this text.
+<PRE>
+EXAMPLE:
+ <B>text</B> 650000 7365000 SPEARFISH LAND COVER
+ <B>font</B> romand
+ <B>color</B> red
+ <B>width</B> 2
+ <B>hcolor</B> black
+ <B>hwidth</B> 1
+ <B>background</B> white
+ <B>border</B> red
+ <B>size</B> 500
+ <B>ref</B> lower left
+ <B>opaque</B> y
+ <B>end</B>
+</PRE>
+<P>
+<a name="vareas"></a>
+<H2>vareas</H2>
+Selects a vector map layer for output and plots areas.
+<PRE>
+USAGE: <B>vareas</B> vectormap
+ <B>layer</B> # (layer number used with cats/where option)
+ <B>cats</B> list of categories (e.g. 1,3,5-7)
+ <B>where</B> SQL where statement
+ <B>rgbcolumn</B> column
+ <B>width</B> #
+ <B>label</B> label to use in legend
+ <B>lpos</B> position in legend
+ <B>pat</B> pattern file
+ <B>pwidth</B> #
+ <B>scale</B> #
+ <B>end</B>
+</PRE>
+The user can specify:
+<P>
+<B>color</B> - color of the vector lines or area boundaries;
+<P>
+<B>fcolor</B> - the area fill color;
+<P>
+<B>rgbcolumn</B> - name of color definition column used for the area fill color;
+<P>
+<B>width</B> - width of the vectors lines or area boundaries in pixels
+<P>
+<B>masked</B> - whether or not the raster map layer is to be masked
+by the current mask;
+(see manual entry <EM><A HREF="r.mask.html">r.mask</A></EM>
+for more information on the mask)
+<P>
+<B>cats</B> - which categories should be plotted (default is all);
+<P>
+<B>where</B> - select features using a SQL where statement.
+For example: <tt>vlastnik = 'Cimrman'</tt>;
+<P>
+<B>label</B> - for description in <a href="#vlegend">vlegend</a>.
+Default is: map(mapset);
+<P>
+<B>lpos</B> - position vector is plotted in legend. If lpos is
+0 then this vector is omitted in legend. If more vectors used the
+same lpos then their symbols in legend are merged and label for
+first vector is used.
+<P>
+<B>pat</B> - full path to pattern file. The pattern file contains header and
+simple PostScript commands. It is similar to EPS but more limited, meaning that
+while each pattern file is a true EPS file, most EPS files are not useful as pattern
+files because they contain restricted commands. Color and width of patterns are set
+by <B>fcolor</B> (red, green, ..., none, R:G:B) and <B>width</B> until overwritten
+in the pattern file.
+Pattern may be scaled with the <b>scale</b> command. Several standard hatching
+patterns are provided in <tt>$GISBASE/etc/paint/patterns/</tt>.
+Demonstrative images can be found on the
+<a href="http://grass.gdf-hannover.de/wiki/AreaFillPatterns">GRASS Wiki site</a>.
+You can also create your own custom pattern files in a text editor.
+Example of pattern file:
+<div class="code"><PRE>
+%!PS-Adobe-2.0 EPSF-1.2
+%%BoundingBox: 0 0 10 10
+newpath
+5 0 moveto
+5 10 lineto
+stroke
+</PRE></div>
+<P>
+<B>scale</B> - pattern scale
+<P>
+<B>pwidth</B> - pattern line width, width is used by pattern until the width is overwritten
+in pattern file.
+<P>
+<PRE>
+EXAMPLE:
+ <B>vareas</B> forest
+ <B>color</B> blue
+ <B>width</B> 1
+ <B>masked</B> y
+ <B>cats</B> 2,5-7
+ <B>end</B>
+</PRE>
+<P>
+<a name="vlines"></a>
+<H2>vlines</H2>
+Selects a vector map layer for output and plots lines.
+<PRE>
+USAGE: <B>vlines</B> vectormap
+ <B>type</B> line and/or boundary
+ <B>where</B> SQL where statement like: vlastnik = 'Cimrman'
+ <B>width</B> #
+ <B>cwidth</B> #
+ <B>hwidth</B> #
+ <B>offset</B> #
+ <B>coffset</B> #
+ <B>ref</B> left|right
+ <B>style</B> 00001111
+ <B>lpos</B> #
+ <B>end</B>
+</PRE>
+<P>
+<B>type</B> - the default is lines only;
+<P>
+<P>
+<B>rgbcolumn</B> - name of color definition column used for the vector lines or area boundaries;
+<P>
+<P>
+<B>cwidth</B> - width of the vectors lines. If cwidth is used then
+width of line is equal to cwidth * category value and width is
+used in legend;
+<P>
+<B>hcolor</B> - the highlight color for the vector lines;
+<P>
+<B>hwidth</B> - the width of the highlight color in pixels;
+<P>
+<B>offset</B> (experimental) - offset for the vectors lines in pixels for plotting
+parallel lines in distance equal to offset (accepts positive or
+negative decimal points). Useful to print streets with several parallel lanes;
+<P>
+<B>coffset</B> (experimental) - offset for the vectors lines. If coffset is used then
+offset of line is equal to coffset * category value and offset is
+used in legend;
+<P>
+<B>ref</B> (experimental) - line justification.
+<P>
+for more information on the mask);
+<P>
+<B>style</B> - the line style allows the vectors
+to be dashed in different patterns. This is done by typing a
+series of numbers (0's and 1's) in a desired sequence or pattern.
+The first block of repeated zeros or ones represents "draw", the second
+block represents "blank".
+An even number of blocks will repeat the pattern, an odd number of blocks
+will alternate the pattern.
+The default is "solid";
+<P>
+<P>
+<P>
+<P>
+<PRE>
+EXAMPLE:
+ <B>vlines</B> streams
+ <B>color</B> blue
+ <B>width</B> 2
+ <B>hcolor</B> white
+ <B>hwidth</B> 1
+ <B>masked</B> y
+ <B>cats</B> 2
+ <B>label</B> Streams - category 2
+ <B>end</B>
+</PRE>
+<P>
+<a name="vpoints"></a>
+<H2>vpoints</H2>
+Selects vector point data to be placed on the output map
+<PRE>
+USAGE: <B>vpoints</B> vectormap
+ <B>type</B> point and/or centroid
+ <B>layer</B> # (layer number used with cats/where/sizecol options)
+ <B>width</B> #
+ <B>eps</B> epsfile
+ <B>size</B> #
+ <B>sizecolumn</B> attribute column used for symbol sizing
+ <B>scale</B> scaling factor for sizecolumn values
+ <B>rotate</B> #
+ <B>rotatecolumn</B> column
+ <B>label</B> legend label
+ <B>end</B>
+</PRE>
+The user may specify the
+the <B>color</B> of the sites (see section on <a href="#NAMED_COLORS">NAMED COLORS</a>);
+either the GRASS <B>symbol</B> or
+the <B>eps</B> Encapsulated Postscript file to be used to represent the presence of a site
+(if '<B>$</B>' is used in the EPS file path it will be replaced by category number);
+and <B>rotate</B> (in degrees) for counter-clockwise rotation.
+<BR>
+The size of the icon (number of times larger than the size it is in
+the icon file) is typically given by the <B>size</B> option. Alternatively
+the size of the symbol or EPS graphic can be taken from an attribute column
+by using the <B>sizecolumn</B> command. The value given by <B>sizecolumn</B> may be
+scaled by using the <B>scale</B> factor setting (default scaling is 1.0).
+In a similar manner symbol color can be read from <B>rgbcolumn</B>
+and the rotation angle read from <B>rotatecolumn</B>.
+<PRE>
+EXAMPLE:
+ <B>vpoints</B> windmills
+ <B>color</B> blue
+ <B>symbol</B> mills/windmill
+ <B>size</B> 10
+ <B>end</B>
+</PRE>
+<P>
+<a name="vlegend"></a>
+<H2>vlegend</H2>
+vector information, on or below the map.
+<PRE>
+USAGE: <B>vlegend</B>
+ <B>where</B> x y
+ <B>width</B> width of color symbol
+ <B>cols</B> number of columns to print
+ <B>end</B>
+</PRE>
+The default location is immediately below the legend containing the
+scale, grid and region information, starting at the left edge of the map.
+If the <EM>where</EM> instruction is present and <EM>y</EM> is less than or
+equal to zero, the vector legend will be positioned immediately below
+the map, starting <EM>x</EM> inches from the left edge of the page.
+<P>
+<EM>width</EM> is the width in inches of the color symbol (for areas) in front of the
+legend text. The default is 1/24 * fontsize inches.
+<EM>cols</EM> is the number of columns to split the legend into. The default is one
+column. The maximum number of colums is 10, or equal to the number of legend entries
+if there are less than 10 entries.
+<P>
+<P>
+Alternatively, the user can create a custom legend by using the
+<a href="#rectangle">rectangle</a>, <a href="#point">point</a>, and
+<a href="#text">text</a> instructions.
+<P>
+This example prints the vector legend
+immediately below the map and starting 4.5 inches from the left edge
+of the page, using a 12/72 inch Helvetica font.
+<PRE>
+EXAMPLE:
+ <B>vlegend</B>
+ <B>where</B> 4.5 0
+ <B>end</B>
+</PRE>
+<P>
+<a name="end"></a>
+<H2>end</H2>
+Terminates input and begin painting the map.
+<PRE>
+USAGE: <B>end</B>
+</PRE>
+<BR>
+<P>
+<H2>EXAMPLE ps.map INPUT FILE</H2>
+The following is an example of a <EM>ps.map</EM> script file. The file has been
+named <EM>spear.soils</EM>.
+This script file can be entered at the command line:
+<PRE>
+ <B>ps.map input=</B><EM>spear.soils</EM> <B>output=</B><EM>soils.ps</EM>
+</PRE>
+<PRE>
+# this ps.map example draws a map of Spearfish, SD
+<B>raster</B> soils
+<B>outline</B>
+ <B>width</B> 1
+ <B>end</B>
+<B>comments</B> soil.cmt
+ <B>where</B> 1 6
+ <B>end</B>
+<B>colortable</B> y
+ <B>where</B> 1 6.5
+ <B>cols</B> 4
+ <B>width</B> 4
+ <B>end</B>
+<B>setcolor</B> 6,8,9 white
+<B>setcolor</B> 10 green
+<B>vlines</B> roads
+ <B>width</B> 2
+ <B>style</B> 0111
+ <B>color</B> grey
+ <B>masked</B> n
+ <B>end</B>
+<B>vlegend</B>
+ <B>fontsize</B> 8
+ <B>end</B>
+<B>text</B> 30% 100% SPEARFISH SOILS MAP
+ <B>color</B> red
+ <B>width</B> 1
+ <B>hwidth</B> 1
+ <B>border</B> red
+ <B>size</B> 500
+ <B>end</B>
+<B>line</B> 606969.73 3423092.91 616969.73 3423092.91
+ <B>width</B> 2
+ <B>end</B>
+<B>point</B> 40% 60%
+ <B>color</B> purple
+ <B>size</B> 25
+ <B>masked</B> n
+ <B>end</B>
+<B>scale</B> 1:125000
+<B>scalebar</B> f
+ <B>where</B> 4.5 6.5
+ <B>length</B> 5000
+ <B>height</B> 0.05
+ <B>segment</B> 5
+ <B>numbers</B> 5
+ <B>end</B>
+<B>geogrid</B> 60 s
+ <B>color</B> blue
+ <B>end</B>
+<B>paper</B> a4
+ <B>end</B>
+<B>end</B>
+</PRE>
+<P>
+More examples can be found on the
+<a href="http://grass.osgeo.org/wiki/Ps.map_scripts">GRASS Wiki</a>
+help site.
+<P>
+<H2>CHANGES BETWEEN VERSION 5.0.x/5.4.x and 6.0</H2>
+<UL>
+<LI>Devices and ps.select do not exist any more. Paper is defined by the
+<EM>paper</EM> instruction.</LI>
+<LI><EM>vpoints</EM> are used instead of <EM>sites</EM> (points are read from vector).</LI>
+<LI><EM>vector</EM> is substituted by <EM>vpoints</EM>, <EM>vlines</EM> and <EM>vareas</EM>.</LI>
+<LI>Symbols are used instead of icons (different format and directory).</LI>
+<LI>Map legend can be printed in columns.</LI>
+</UL>
+<H2>SEE ALSO</H2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="v.label.html">v.label</a>
+</em>
+<H2>AUTHOR</H2>
+Paul Carlson, USDA, SCS, NHQ-CGIS<BR>
+Modifications: Radim Blazek, Glynn Clements, Bob Covill, Hamish Bowman
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.average/description.html
--- grass/trunk/raster/r.average/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.average/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,144 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.average</em> calculates the average value of data
-contained in a <em>cover</em> raster map layer for areas
-assigned the same category value in the user-specified
-<em>base</em> raster map layer. These averaged values are
-stored in the category labels file associated with a new
-<em>output</em> map layer.
-The values to be averaged are taken from a user-specified
-<em>cover</em> map. The <em>category values</em> for the
-<em>cover</em> map will be averaged, unless the <b>-c</b>
-flag is set. If the <b>-c</b> flag is set, the values that
-appear in the <em>category labels</em> file for the
-<em>cover</em> map will be averaged instead (see example
-below).
-<p>
-The <em>output</em> map is actually a <em>reclass</em> of the <em>base</em>
-map (see <em> <a href="r.reclass.html">r.reclass</a></em>), and will have
-exactly the same <em>category values</em> as the <em>base</em> map. The
-averaged values computed by <em>r.average</em> are stored in the
-<em>output</em> map's <em>category labels</em> file.
-The <b>base=</b> map is an existing raster map layer in the user's current
-mapset search path. For each group of cells assigned the same category
-value in the <em>base</em> map, the values assigned these cells in the
-<em>cover</em> map will be averaged.
-The <em>cover</em> map is an existing raster map layer containing the values
-(in the form of cell category values or cell category labels) to be averaged
-within each category of the <em>base</em> map.
-<h2>NOTES</h2>
-The <b>-c</b> option requires that the category label for
-each category in the <em>cover</em> map be a valid number,
-integer, or decimal. To be exact, if the first item in the
-label is numeric, then that value is used. Otherwise, zero
-is used. The following table covers all possible cases:
-<p>
-<pre>
- category value
- label used by -c
- ______________________
- .12 .12
- .80 KF .8
- no data 0
-</pre>
-<p>
-(This flag is very similar to the @ operator in
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-and the user is encouraged to read the manual entry for
-to see how it works there.)
-<p>
-The user should use the results of <em>r.average</em> with
-care. Since this utility assigns a value to each cell
-which is based on global information (i.e., information at
-spatial locations other than just the location of the cell
-itself), the resultant map layer is only valid if the
-geographic region and mask settings are the same as they
-were at the time that the result map was created.
-<p>
-Results are affected by the current region settings and mask.
-<h2>EXAMPLE</h2>
-Assume that
-<em>farms</em>
-is a map with 7 farms (i.e., 7 categories), and that
-<em>soils.Kfactor</em>
-is a map of soil K factor values with the following category file:
-<pre>
- cat cat
- value label
- 0 no soil data
- 1 .10
- 2 .15
- 3 .17
- 4 .20
- 5 .24
- 6 .28
- 7 .32
- 8 .37
- 9 .43
-</pre>
-Then
-<p>
-<dl>
-<dd>
-<b>r.average -c base=</b><em>farms</em>
-<b>cover=</b><em>soils.Kfactor</em> <b>output=</b><em>K.by.farm</em>
-</dl>
-will compute the average soil K factor for each farm, and store the result
-in the output map <em>K.by.farm</em>, which will be a reclass of
-<em>farms</em> with category labels as follows (example only):
-<pre>
- cat cat
- value label
- 1 .1023
- 2 .1532
- 3 .172
- 4 .3872
- 5 .003
- 6 .28
- 7 .2345
-</pre>
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.category.html">r.category</a></em>,
-<em><a href="r.clump.html">r.clump</a></em>,
-<em><a href="r.describe.html">r.describe</a></em>,
-<em><a href="r.mfilter.html">r.mfilter</a></em>,
-<em><a href="r.mode.html">r.mode</a></em>,
-<em><a href="r.neighbors.html">r.neighbors</a></em>,
-<em><a href="r.reclass.html">r.reclass</a></em>,
-<em><a href="r.statistics.html">r.statistics</a></em>,
-<em><a href="r.stats.html">r.stats</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.average/r.average.html (from rev 32770, grass/trunk/raster/r.average/description.html)
--- grass/trunk/raster/r.average/r.average.html (rev 0)
+++ grass/trunk/raster/r.average/r.average.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,144 @@
+<h2>DESCRIPTION</h2>
+<em>r.average</em> calculates the average value of data
+contained in a <em>cover</em> raster map layer for areas
+assigned the same category value in the user-specified
+<em>base</em> raster map layer. These averaged values are
+stored in the category labels file associated with a new
+<em>output</em> map layer.
+The values to be averaged are taken from a user-specified
+<em>cover</em> map. The <em>category values</em> for the
+<em>cover</em> map will be averaged, unless the <b>-c</b>
+flag is set. If the <b>-c</b> flag is set, the values that
+appear in the <em>category labels</em> file for the
+<em>cover</em> map will be averaged instead (see example
+below).
+<p>
+The <em>output</em> map is actually a <em>reclass</em> of the <em>base</em>
+map (see <em> <a href="r.reclass.html">r.reclass</a></em>), and will have
+exactly the same <em>category values</em> as the <em>base</em> map. The
+averaged values computed by <em>r.average</em> are stored in the
+<em>output</em> map's <em>category labels</em> file.
+The <b>base=</b> map is an existing raster map layer in the user's current
+mapset search path. For each group of cells assigned the same category
+value in the <em>base</em> map, the values assigned these cells in the
+<em>cover</em> map will be averaged.
+The <em>cover</em> map is an existing raster map layer containing the values
+(in the form of cell category values or cell category labels) to be averaged
+within each category of the <em>base</em> map.
+<h2>NOTES</h2>
+The <b>-c</b> option requires that the category label for
+each category in the <em>cover</em> map be a valid number,
+integer, or decimal. To be exact, if the first item in the
+label is numeric, then that value is used. Otherwise, zero
+is used. The following table covers all possible cases:
+<p>
+<pre>
+ category value
+ label used by -c
+ ______________________
+ .12 .12
+ .80 KF .8
+ no data 0
+</pre>
+<p>
+(This flag is very similar to the @ operator in
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+and the user is encouraged to read the manual entry for
+to see how it works there.)
+<p>
+The user should use the results of <em>r.average</em> with
+care. Since this utility assigns a value to each cell
+which is based on global information (i.e., information at
+spatial locations other than just the location of the cell
+itself), the resultant map layer is only valid if the
+geographic region and mask settings are the same as they
+were at the time that the result map was created.
+<p>
+Results are affected by the current region settings and mask.
+<h2>EXAMPLE</h2>
+Assume that
+<em>farms</em>
+is a map with 7 farms (i.e., 7 categories), and that
+<em>soils.Kfactor</em>
+is a map of soil K factor values with the following category file:
+<pre>
+ cat cat
+ value label
+ 0 no soil data
+ 1 .10
+ 2 .15
+ 3 .17
+ 4 .20
+ 5 .24
+ 6 .28
+ 7 .32
+ 8 .37
+ 9 .43
+</pre>
+Then
+<p>
+<dl>
+<dd>
+<b>r.average -c base=</b><em>farms</em>
+<b>cover=</b><em>soils.Kfactor</em> <b>output=</b><em>K.by.farm</em>
+</dl>
+will compute the average soil K factor for each farm, and store the result
+in the output map <em>K.by.farm</em>, which will be a reclass of
+<em>farms</em> with category labels as follows (example only):
+<pre>
+ cat cat
+ value label
+ 1 .1023
+ 2 .1532
+ 3 .172
+ 4 .3872
+ 5 .003
+ 6 .28
+ 7 .2345
+</pre>
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.category.html">r.category</a></em>,
+<em><a href="r.clump.html">r.clump</a></em>,
+<em><a href="r.describe.html">r.describe</a></em>,
+<em><a href="r.mfilter.html">r.mfilter</a></em>,
+<em><a href="r.mode.html">r.mode</a></em>,
+<em><a href="r.neighbors.html">r.neighbors</a></em>,
+<em><a href="r.reclass.html">r.reclass</a></em>,
+<em><a href="r.statistics.html">r.statistics</a></em>,
+<em><a href="r.stats.html">r.stats</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S. Army Construction Engineering Research Laboratory
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.basins.fill/description.html
--- grass/trunk/raster/r.basins.fill/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.basins.fill/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,55 +0,0 @@
-<em>r.basins.fill</em>
-generates a raster map layer depicting subbasins, based
-on input raster map layers for the coded stream network
-(where each channel segment has been "coded" with a unique category value)
-and for the ridges within a given watershed.
-The raster map layer depicting ridges should include
-the ridge which defines the perimeter of the watershed.
-The coded stream network can be generated
-as part of the
-<em><a href="r.watershed.html">r.watershed</a></em> program,
-but the map layer of ridges will need to be created by hand
-(for example, through digitizing done in <em><a href="v.digit.html">v.digit</a></em>).
-<p>
-The resulting output raster map layer will
-code the subbasins with category values matching
-those of the channel segments passing through them.
-A user-supplied number of passes through the data is
-made in an attempt to fill in these subbasins.
-If the resulting map layer from this program appears to
-have holes within a subbasin, the program should be
-rerun with a higher number of passes.
-<br><br>
-<h2>NOTES</h2>
-The current geographic region setting is ignored.
-Instead, the geographic region for the entire input stream's
-map layer is used.
-<h2>SEE ALSO</h2>
-See Appendix A of the <b>GRASS</b> <a
-href="http://grass.itc.it/gdp/raster/r.watershed.ps">Tutorial:
-r.watershed</a> for further details on the combined use of
-<em>r.basins.fill</em> and <em><a href="r.watershed.html">r.watershed</a></em>.
-<p>
-<em><a href="r.watershed.html">r.watershed</a></em>,
-<em><a href="v.digit.html">v.digit</a></em>
-<h2>AUTHORS</h2>
-Dale White,
-Dept. of Geography,
-Pennsylvania State University
-<br>
-Larry Band, Dept. of Geography, University of Toronto, Canada
Copied: grass/trunk/raster/r.basins.fill/r.basins.fill.html (from rev 32770, grass/trunk/raster/r.basins.fill/description.html)
--- grass/trunk/raster/r.basins.fill/r.basins.fill.html (rev 0)
+++ grass/trunk/raster/r.basins.fill/r.basins.fill.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,55 @@
+<em>r.basins.fill</em>
+generates a raster map layer depicting subbasins, based
+on input raster map layers for the coded stream network
+(where each channel segment has been "coded" with a unique category value)
+and for the ridges within a given watershed.
+The raster map layer depicting ridges should include
+the ridge which defines the perimeter of the watershed.
+The coded stream network can be generated
+as part of the
+<em><a href="r.watershed.html">r.watershed</a></em> program,
+but the map layer of ridges will need to be created by hand
+(for example, through digitizing done in <em><a href="v.digit.html">v.digit</a></em>).
+<p>
+The resulting output raster map layer will
+code the subbasins with category values matching
+those of the channel segments passing through them.
+A user-supplied number of passes through the data is
+made in an attempt to fill in these subbasins.
+If the resulting map layer from this program appears to
+have holes within a subbasin, the program should be
+rerun with a higher number of passes.
+<br><br>
+<h2>NOTES</h2>
+The current geographic region setting is ignored.
+Instead, the geographic region for the entire input stream's
+map layer is used.
+<h2>SEE ALSO</h2>
+See Appendix A of the <b>GRASS</b> <a
+href="http://grass.itc.it/gdp/raster/r.watershed.ps">Tutorial:
+r.watershed</a> for further details on the combined use of
+<em>r.basins.fill</em> and <em><a href="r.watershed.html">r.watershed</a></em>.
+<p>
+<em><a href="r.watershed.html">r.watershed</a></em>,
+<em><a href="v.digit.html">v.digit</a></em>
+<h2>AUTHORS</h2>
+Dale White,
+Dept. of Geography,
+Pennsylvania State University
+<br>
+Larry Band, Dept. of Geography, University of Toronto, Canada
Deleted: grass/trunk/raster/r.bitpattern/description.html
--- grass/trunk/raster/r.bitpattern/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.bitpattern/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,52 +0,0 @@
-<em>r.bitpattern</em> performs bit pattern comparisons.
-The module can be used to pixelwise verify a satellite image
-for low quality pixels if a Quality Control Bit Index map is
-provided (e.g. as for MODIS sensor maps).
-The functionality is two-fold:
-<ol>
-<li>define position: set bit(s) to 1 which shall match,
- then convert this position pattern to integer, set pattern=
- parameter with that integer value
-<li>define pattern *value* which should be in that position:
- first bit pattern of value, convert to integer, set
- patval= parameter
-</ol>
-If several bitpatterns have to be tested, the resulting maps
-can be used to exclude low quality pixel in the input satellite
-image using <em>r.mapcalc</em> (OR and NOT operators).
-<h2>EXAMPLE</h2>
-<ol>
-<pre>
- xx xx 1x xx
- binary: 1000 -> integer: 8 -> pattern=8
-</pre>
-<li>define value:
-<pre>
- Ex.: we want to check for 0 in that position
- xx xx 0x xx
- binary: 0000 -> integer: 0 -> patval=0
- if value can be arbitray (0/1), then assume 0 value
-</pre>
-</ol>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.mapcalc.html">r.mapcalc</a>
-</em>
-<h2>AUTHORS</h2>
-Radim Blazek, Markus Neteler
Copied: grass/trunk/raster/r.bitpattern/r.bitpattern.html (from rev 32770, grass/trunk/raster/r.bitpattern/description.html)
--- grass/trunk/raster/r.bitpattern/r.bitpattern.html (rev 0)
+++ grass/trunk/raster/r.bitpattern/r.bitpattern.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,52 @@
+<em>r.bitpattern</em> performs bit pattern comparisons.
+The module can be used to pixelwise verify a satellite image
+for low quality pixels if a Quality Control Bit Index map is
+provided (e.g. as for MODIS sensor maps).
+The functionality is two-fold:
+<ol>
+<li>define position: set bit(s) to 1 which shall match,
+ then convert this position pattern to integer, set pattern=
+ parameter with that integer value
+<li>define pattern *value* which should be in that position:
+ first bit pattern of value, convert to integer, set
+ patval= parameter
+</ol>
+If several bitpatterns have to be tested, the resulting maps
+can be used to exclude low quality pixel in the input satellite
+image using <em>r.mapcalc</em> (OR and NOT operators).
+<h2>EXAMPLE</h2>
+<ol>
+<pre>
+ xx xx 1x xx
+ binary: 1000 -> integer: 8 -> pattern=8
+</pre>
+<li>define value:
+<pre>
+ Ex.: we want to check for 0 in that position
+ xx xx 0x xx
+ binary: 0000 -> integer: 0 -> patval=0
+ if value can be arbitray (0/1), then assume 0 value
+</pre>
+</ol>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>
+</em>
+<h2>AUTHORS</h2>
+Radim Blazek, Markus Neteler
Deleted: grass/trunk/raster/r.buffer/description.html
--- grass/trunk/raster/r.buffer/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.buffer/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,117 +0,0 @@
-<em>r.buffer</em> creates a new raster map layer showing
-buffer (a.k.a. "distance" or "proximity") zones around all
-cells that contain non-NULL category values in an existing
-raster map layer. The distances of buffer zones from cells
-with non-zero category values are user-chosen. Suppose,
-for example, that you want to place buffer zones around
-roads. This program could create the raster map layer
-shown below on the right based on road information
-contained in the raster map layer shown on the left.
-<div class="code"><pre>
- 000000000000000000000000 222233333333333333444444
- 111000000000000000000000 111222222222223333333333
- 000111111111100000000000 222111111111122223333333
- 000000001000011100000000 332222221222211122222222
- 000000001000000011111111 333333321233222211111111
- 000000001000000000000000 433333321233333222222222
- 000000001000000000000000 444443321233333333333333
- 000000001000000000000000 444443321233443333333333
- 000000001000000000000000 444443321233444444444444
- Category 0: No roads
- Category 1: Road location
- Category 2: Buffer Zone 1 around roads
- Category 3: Buffer Zone 2 around roads
- Category 4: Buffer Zone 3 around roads
-</pre></div>
-<br>
-<h2>NOTES</h2>
-The user has the option of identifying up to 250 continuous zones.
-The zones are identified by specifying the upper limit of each desired zone
-(<em>r.buffer</em> assumes that <tt>0</tt> is the starting point).
-("Continuous" is used in the sense that each category
-zone's lower value is the previous zone's upper value. The
-first buffer zone always has distance <tt>0</tt> as its lower
-bound.) Buffer distances can be specified using one of five units with the <em>
-units</em> parameter: <em>meters, kilometers, feet, miles</em>, and <em>nautmiles</em>
-(nautical miles).
-<p>
-<!-- ??? is this the real method used or some ancient option ??? -->
-Distances from cells containing the user-specified category values
-are calculated using the "fromcell" method. This method locates each
-cell that contains a category value from which distances are to be
-calculated, and draws the requested distance rings around
-them. This method works very fast when there are few cells
-containing the category values of interest, but works
-slowly when there are numerous cells containing the
-category values of interest spread throughout the area.
-<p>
-<em>r.buffer</em> measures distances from center of cell to
-center of cell using Euclidean distance measure for
-planimetric locations (like UTM) and using ellipsoidal
-geodesic distance measure for latitude/longitude locations.
-<p>
-<em>r.buffer</em> calculates distance zones from all cells having non-NULL
-category values in the <em>input</em> map. If the user wishes to calculate
-distances from only selected <em>input</em> map layer
-category values, the user should run (for example)
-<em><a href="r.reclass.html">r.reclass</a></em> prior to
-<em>r.buffer</em>, to reclass all categories from which distance zones
-are not desired to be calculated into category NULL.
-<p>
-The <b>-z</b> flag can be used to ignore raster values of zero instead of NULL
-values in the input raster map.
-<p>
-<h2>EXAMPLE</h2>
-In the following example, the buffer zones would be (in the default units
-of meters): 0-100, 101-200, 201-300, 301-400 and 401-500.
-<br>
-<b>r.buffer input=</b>roads <b>output=</b>roads.buf <b>distances=</b>100,200,300,400,500
-</pre></div>
-Result:
-<b>r.category input=</b>roads.buf
- 1 distances calculated from these locations
- 2 0-100 meters
- 3 100-200 meters
- 4 200-300 meters
- 5 300-400 meters
- 6 400-500 meters
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a><br>
-<a href="r.cost.html">r.cost</a><br>
-<a href="r.mapcalc.html">r.mapcalc</a><br>
-<a href="r.reclass.html">r.reclass</a><br>
-<a href="v.buffer.html">v.buffer</a>
-</em>
-<h2>AUTHORS</h2>
-Michael Shapiro, U.S. Army Construction Engineering
-Research Laboratory
-<br>
-James Westervelt, U.S. Army Construction Engineering
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.buffer/r.buffer.html (from rev 32770, grass/trunk/raster/r.buffer/description.html)
--- grass/trunk/raster/r.buffer/r.buffer.html (rev 0)
+++ grass/trunk/raster/r.buffer/r.buffer.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,117 @@
+<em>r.buffer</em> creates a new raster map layer showing
+buffer (a.k.a. "distance" or "proximity") zones around all
+cells that contain non-NULL category values in an existing
+raster map layer. The distances of buffer zones from cells
+with non-zero category values are user-chosen. Suppose,
+for example, that you want to place buffer zones around
+roads. This program could create the raster map layer
+shown below on the right based on road information
+contained in the raster map layer shown on the left.
+<div class="code"><pre>
+ 000000000000000000000000 222233333333333333444444
+ 111000000000000000000000 111222222222223333333333
+ 000111111111100000000000 222111111111122223333333
+ 000000001000011100000000 332222221222211122222222
+ 000000001000000011111111 333333321233222211111111
+ 000000001000000000000000 433333321233333222222222
+ 000000001000000000000000 444443321233333333333333
+ 000000001000000000000000 444443321233443333333333
+ 000000001000000000000000 444443321233444444444444
+ Category 0: No roads
+ Category 1: Road location
+ Category 2: Buffer Zone 1 around roads
+ Category 3: Buffer Zone 2 around roads
+ Category 4: Buffer Zone 3 around roads
+</pre></div>
+<br>
+<h2>NOTES</h2>
+The user has the option of identifying up to 250 continuous zones.
+The zones are identified by specifying the upper limit of each desired zone
+(<em>r.buffer</em> assumes that <tt>0</tt> is the starting point).
+("Continuous" is used in the sense that each category
+zone's lower value is the previous zone's upper value. The
+first buffer zone always has distance <tt>0</tt> as its lower
+bound.) Buffer distances can be specified using one of five units with the <em>
+units</em> parameter: <em>meters, kilometers, feet, miles</em>, and <em>nautmiles</em>
+(nautical miles).
+<p>
+<!-- ??? is this the real method used or some ancient option ??? -->
+Distances from cells containing the user-specified category values
+are calculated using the "fromcell" method. This method locates each
+cell that contains a category value from which distances are to be
+calculated, and draws the requested distance rings around
+them. This method works very fast when there are few cells
+containing the category values of interest, but works
+slowly when there are numerous cells containing the
+category values of interest spread throughout the area.
+<p>
+<em>r.buffer</em> measures distances from center of cell to
+center of cell using Euclidean distance measure for
+planimetric locations (like UTM) and using ellipsoidal
+geodesic distance measure for latitude/longitude locations.
+<p>
+<em>r.buffer</em> calculates distance zones from all cells having non-NULL
+category values in the <em>input</em> map. If the user wishes to calculate
+distances from only selected <em>input</em> map layer
+category values, the user should run (for example)
+<em><a href="r.reclass.html">r.reclass</a></em> prior to
+<em>r.buffer</em>, to reclass all categories from which distance zones
+are not desired to be calculated into category NULL.
+<p>
+The <b>-z</b> flag can be used to ignore raster values of zero instead of NULL
+values in the input raster map.
+<p>
+<h2>EXAMPLE</h2>
+In the following example, the buffer zones would be (in the default units
+of meters): 0-100, 101-200, 201-300, 301-400 and 401-500.
+<br>
+<b>r.buffer input=</b>roads <b>output=</b>roads.buf <b>distances=</b>100,200,300,400,500
+</pre></div>
+Result:
+<b>r.category input=</b>roads.buf
+ 1 distances calculated from these locations
+ 2 0-100 meters
+ 3 100-200 meters
+ 4 200-300 meters
+ 5 300-400 meters
+ 6 400-500 meters
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a><br>
+<a href="r.cost.html">r.cost</a><br>
+<a href="r.mapcalc.html">r.mapcalc</a><br>
+<a href="r.reclass.html">r.reclass</a><br>
+<a href="v.buffer.html">v.buffer</a>
+</em>
+<h2>AUTHORS</h2>
+Michael Shapiro, U.S. Army Construction Engineering
+Research Laboratory
+<br>
+James Westervelt, U.S. Army Construction Engineering
+<p>
Deleted: grass/trunk/raster/r.carve/description.html
--- grass/trunk/raster/r.carve/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.carve/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,48 +0,0 @@
-<em>r.carve</em> accepts vector stream data as input, transforms them to
-raster, and subtracts a defaultdepth+additionaldepth from a DEM. If
-the given width is more than 1 cell, it will carve the stream with the
-given width. With the -n flag it should eliminate all flat cells within
-the stream, so when and if the water gets into the stream it will
-flow. The <em>points</em> option generates x,y,z for points which define the stream
-with the z-value of the bottom of the carved-in stream. These points
-can then be combined with contours to interpolate a new DEM with
-better representation of valleys.
-<h2>NOTE</h2>
-<em>r.carve</em> does not create a depressionless DEM because many
-depressions are in flat areas and not in the streams.
-<h2>EXAMPLE</h2>
-g.region rast=elevation.10m -p
-r.carve rast=elevation.10m vect=streams out=carve_dem width=20 depth=5
-</pre></div>
-<h2>BUGS</h2>
-<!-- Is this still the case as of Jan 11, 2008? - EP -->
-The module does not operate yet in latitude-longitude locations. It
-has not been thoroughly tested, so not all options may work properly -
-but this was the intention.
-<h2>REFERENCES</h2>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/reports/cerl99/rep99.html">Terrain
-modeling and Soil Erosion Simulations for Fort Hood and Fort Polk test
-areas</a>, by Helena Mitasova, Lubos Mitas, William M. Brown, Douglas
-M. Johnston, GMSL (Report for CERL 1999)
-<h2>SEE ALSO</h2>
-<em><a href="r.flow.html">r.flow</a></em>,
-<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
-<h2>AUTHOR</h2>
-Bill Brown (GMSL)<br>
-GRASS 6 update: Brad Douglas
Copied: grass/trunk/raster/r.carve/r.carve.html (from rev 32770, grass/trunk/raster/r.carve/description.html)
--- grass/trunk/raster/r.carve/r.carve.html (rev 0)
+++ grass/trunk/raster/r.carve/r.carve.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,48 @@
+<em>r.carve</em> accepts vector stream data as input, transforms them to
+raster, and subtracts a defaultdepth+additionaldepth from a DEM. If
+the given width is more than 1 cell, it will carve the stream with the
+given width. With the -n flag it should eliminate all flat cells within
+the stream, so when and if the water gets into the stream it will
+flow. The <em>points</em> option generates x,y,z for points which define the stream
+with the z-value of the bottom of the carved-in stream. These points
+can then be combined with contours to interpolate a new DEM with
+better representation of valleys.
+<h2>NOTE</h2>
+<em>r.carve</em> does not create a depressionless DEM because many
+depressions are in flat areas and not in the streams.
+<h2>EXAMPLE</h2>
+g.region rast=elevation.10m -p
+r.carve rast=elevation.10m vect=streams out=carve_dem width=20 depth=5
+</pre></div>
+<h2>BUGS</h2>
+<!-- Is this still the case as of Jan 11, 2008? - EP -->
+The module does not operate yet in latitude-longitude locations. It
+has not been thoroughly tested, so not all options may work properly -
+but this was the intention.
+<h2>REFERENCES</h2>
+<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/reports/cerl99/rep99.html">Terrain
+modeling and Soil Erosion Simulations for Fort Hood and Fort Polk test
+areas</a>, by Helena Mitasova, Lubos Mitas, William M. Brown, Douglas
+M. Johnston, GMSL (Report for CERL 1999)
+<h2>SEE ALSO</h2>
+<em><a href="r.flow.html">r.flow</a></em>,
+<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
+<h2>AUTHOR</h2>
+Bill Brown (GMSL)<br>
+GRASS 6 update: Brad Douglas
Deleted: grass/trunk/raster/r.cats/description.html
--- grass/trunk/raster/r.cats/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.cats/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,178 +0,0 @@
-<em>r.category</em> prints the category values and labels for the raster map
-layer specified by <b>map=</b><em>name</em> to standard output.
-<p>
-The user can specify all needed parameters on the command line, and run the
-program non-interactively. If the user does not specify any categories
-(e.g., using the optional <b>cats=</b><em>range</em>[,<em>range</em>,...]
-argument), then all the category values and labels for the named raster map
-layer that occur in the map are printed. The entire <em>map</em> is read
-using <em><a href="r.describe.html">r.describe</a></em>, to determine which
-categories occur in the <em>map</em>. If a listing of categories is
-specified, then the labels for those categories only are printed. The
-<em>cats</em> may be specified as single category values, or as ranges of
-values. The user may also (optionally) specify that a field separator other
-than a space or tab be used to separate the category value from its
-corresponding category label in the output, by using the
-<b>fs=</b><em>character</em>|<em>space</em>|<em>tab</em> option (see example
-below). If no field separator is specified by the user, a tab is used to
-separate these fields in the output, by default.
-<p>
-The output is sent to standard output in the form of one category per line,
-with the category value first on the line, then an ASCII TAB character (or
-whatever single character or space is specified using the <b>fs</b>
-parameter), then the label for the category.
-<h2>NOTES</h2>
-Any ASCII TAB characters which may be in the label are replaced by spaces.
-<p>
-The output from <em>r.category</em> can be redirected into a file, or piped into
-another program.
-<h3>Input from a file</h3>
-The <b>rules</b> option allows the user to assign category labels from values
-found in a file. The label can refer to a single category, range of
-categories, floating point value, or a range of floating point values.
-The format is given as follows.
-cat:Label
-val1:val2:Label
-</pre></div>
-If the filename is given as "-", the category labels are read from <tt>stdin</tt>
-<h3>Default and dynamic category labels</h3>
-Default and dynamic category labels can be created for categories that
-are not explicitly labeled.
-The coefficient line can be followed by explicit category labels
-which override the format label generation.
-<pre>
- 0:no data
- 2: .
- 5: . ## explicit category labels
- 7: .
-</pre>
-explicit labels can be also of the form:
-<pre>
- 5.5:5:9 label description
- or
- 15:30 label description
-</pre>
-<p>
-In the format line
-<ul>
-<li>$1 refers to the value num*5.0+1000 (ie, using the first 2 coefficients)
-<li>$2 refers to the value num*5.0+1005 (ie, using the last 2 coefficients)
-</ul>
- $1.2 will print $1 with 2 decimal places.
-<p>
-Also, the form $?xxx$yyy$ translates into yyy if the category is 1, xxx
-otherwise. The $yyy$ is optional. Thus
-<p>
- $1 meter$?s
-<p>
-will become: 1 meter (for category 1)<br>
- 2 meters (for category 2), etc.
-<p>
-format='Elevation: $1.2 to $2.2 feet' ## Format Statement
-coefficients="5.0,1000,5.0,1005" ## Coefficients
-<p>
-The format and coefficients above would be used to generate the
-following statement in creation of the format appropriate category
-string for category "num":
-<p>
- sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)
-<p>
-Note: while both the format and coefficent lines must be present
- a blank line for the format string will effectively suppress
- automatic label generation.
-Note: quant rules of Categories structures are heavily dependant
-on the fact that rules are stored in the same order they are entered.
-since i-th rule and i-th label are entered at the same time, we
-know that i-th rule maps fp range to i, thus we know for sure
-that cats.labels[i] corresponds to i-th quant rule
-<p>
-To use a "<tt>$</tt>" in the label without triggering the plural test,
-put "<tt>$$</tt>" in the format string.
-<p>
-Use 'single quotes' when using a "<tt>$</tt>" on the command line to
-avoid unwanted shell substitution.
-<h2>EXAMPLES</h2>
-<p>
-<dl>
-<dt><div class="code"><pre>
-r.category map=soils
-</pre></div>
-<dd>
-prints the values and labels associated with all of the categories in the
-<em>soils</em> raster map layer;
-r.category map=soils cats=10,12,15-20
-</pre></div>
-<dd>
-prints only the category values and labels for <em>soils</em> map layer
-categories <tt>10, 12</tt>, and <tt>15</tt> through <tt>20</tt>; and
-r.category map=soils cats=10,20 fs=':'
-</pre></div>
-<dd>
-prints the values and labels for <em>soils</em> map layer categories
-<tt>10</tt> and <tt>20</tt>, but uses "<tt>:</tt>" (instead of a tab)
-as the character separating the category values from the category
-values in the output.
-</dl>
-<dl>
-<dt>Example output:
-<dd>
-<p>
-10:Dumps, mine, Cc
-20:Kyle clay, KaA
-</pre></div>
-</dl>
-<h2>TODO</h2>
-Respect the <b>fs=</b> field separator setting for input rules.
-<h2>SEE ALSO</h2>
-UNIX Manual entries for <i>awk</i> and <i>sort</i>
-<p>
-<em><a href="r.coin.html">r.coin</a></em>,
-<em><a href="d.what.rast.html">d.what.rast</a></em>,
-<em><a href="r.support.html">r.support</a></em>
-<h2>AUTHORS</h2>
-Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
-Hamish Bowman, University of Otago, New Zealand (label creation options)
-<p>
Copied: grass/trunk/raster/r.cats/r.category.html (from rev 32770, grass/trunk/raster/r.cats/description.html)
--- grass/trunk/raster/r.cats/r.category.html (rev 0)
+++ grass/trunk/raster/r.cats/r.category.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,178 @@
+<em>r.category</em> prints the category values and labels for the raster map
+layer specified by <b>map=</b><em>name</em> to standard output.
+<p>
+The user can specify all needed parameters on the command line, and run the
+program non-interactively. If the user does not specify any categories
+(e.g., using the optional <b>cats=</b><em>range</em>[,<em>range</em>,...]
+argument), then all the category values and labels for the named raster map
+layer that occur in the map are printed. The entire <em>map</em> is read
+using <em><a href="r.describe.html">r.describe</a></em>, to determine which
+categories occur in the <em>map</em>. If a listing of categories is
+specified, then the labels for those categories only are printed. The
+<em>cats</em> may be specified as single category values, or as ranges of
+values. The user may also (optionally) specify that a field separator other
+than a space or tab be used to separate the category value from its
+corresponding category label in the output, by using the
+<b>fs=</b><em>character</em>|<em>space</em>|<em>tab</em> option (see example
+below). If no field separator is specified by the user, a tab is used to
+separate these fields in the output, by default.
+<p>
+The output is sent to standard output in the form of one category per line,
+with the category value first on the line, then an ASCII TAB character (or
+whatever single character or space is specified using the <b>fs</b>
+parameter), then the label for the category.
+<h2>NOTES</h2>
+Any ASCII TAB characters which may be in the label are replaced by spaces.
+<p>
+The output from <em>r.category</em> can be redirected into a file, or piped into
+another program.
+<h3>Input from a file</h3>
+The <b>rules</b> option allows the user to assign category labels from values
+found in a file. The label can refer to a single category, range of
+categories, floating point value, or a range of floating point values.
+The format is given as follows.
+cat:Label
+val1:val2:Label
+</pre></div>
+If the filename is given as "-", the category labels are read from <tt>stdin</tt>
+<h3>Default and dynamic category labels</h3>
+Default and dynamic category labels can be created for categories that
+are not explicitly labeled.
+The coefficient line can be followed by explicit category labels
+which override the format label generation.
+<pre>
+ 0:no data
+ 2: .
+ 5: . ## explicit category labels
+ 7: .
+</pre>
+explicit labels can be also of the form:
+<pre>
+ 5.5:5:9 label description
+ or
+ 15:30 label description
+</pre>
+<p>
+In the format line
+<ul>
+<li>$1 refers to the value num*5.0+1000 (ie, using the first 2 coefficients)
+<li>$2 refers to the value num*5.0+1005 (ie, using the last 2 coefficients)
+</ul>
+ $1.2 will print $1 with 2 decimal places.
+<p>
+Also, the form $?xxx$yyy$ translates into yyy if the category is 1, xxx
+otherwise. The $yyy$ is optional. Thus
+<p>
+ $1 meter$?s
+<p>
+will become: 1 meter (for category 1)<br>
+ 2 meters (for category 2), etc.
+<p>
+format='Elevation: $1.2 to $2.2 feet' ## Format Statement
+coefficients="5.0,1000,5.0,1005" ## Coefficients
+<p>
+The format and coefficients above would be used to generate the
+following statement in creation of the format appropriate category
+string for category "num":
+<p>
+ sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)
+<p>
+Note: while both the format and coefficent lines must be present
+ a blank line for the format string will effectively suppress
+ automatic label generation.
+Note: quant rules of Categories structures are heavily dependant
+on the fact that rules are stored in the same order they are entered.
+since i-th rule and i-th label are entered at the same time, we
+know that i-th rule maps fp range to i, thus we know for sure
+that cats.labels[i] corresponds to i-th quant rule
+<p>
+To use a "<tt>$</tt>" in the label without triggering the plural test,
+put "<tt>$$</tt>" in the format string.
+<p>
+Use 'single quotes' when using a "<tt>$</tt>" on the command line to
+avoid unwanted shell substitution.
+<h2>EXAMPLES</h2>
+<p>
+<dl>
+<dt><div class="code"><pre>
+r.category map=soils
+</pre></div>
+<dd>
+prints the values and labels associated with all of the categories in the
+<em>soils</em> raster map layer;
+r.category map=soils cats=10,12,15-20
+</pre></div>
+<dd>
+prints only the category values and labels for <em>soils</em> map layer
+categories <tt>10, 12</tt>, and <tt>15</tt> through <tt>20</tt>; and
+r.category map=soils cats=10,20 fs=':'
+</pre></div>
+<dd>
+prints the values and labels for <em>soils</em> map layer categories
+<tt>10</tt> and <tt>20</tt>, but uses "<tt>:</tt>" (instead of a tab)
+as the character separating the category values from the category
+values in the output.
+</dl>
+<dl>
+<dt>Example output:
+<dd>
+<p>
+10:Dumps, mine, Cc
+20:Kyle clay, KaA
+</pre></div>
+</dl>
+<h2>TODO</h2>
+Respect the <b>fs=</b> field separator setting for input rules.
+<h2>SEE ALSO</h2>
+UNIX Manual entries for <i>awk</i> and <i>sort</i>
+<p>
+<em><a href="r.coin.html">r.coin</a></em>,
+<em><a href="d.what.rast.html">d.what.rast</a></em>,
+<em><a href="r.support.html">r.support</a></em>
+<h2>AUTHORS</h2>
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
+Hamish Bowman, University of Otago, New Zealand (label creation options)
+<p>
Deleted: grass/trunk/raster/r.circle/description.html
--- grass/trunk/raster/r.circle/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.circle/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,56 +0,0 @@
-This module creates an output raster map centered on the <em>x,y</em> values specified
-with the <em>coordinate</em> parameter, out to the edge of the current region.
-The output cell values increase linearly from the specified center. The <em>min</em>
-and <em>max</em> parameters control the inner and outer output raster map radii, respectively.
-<p>
-The <em>mult</em> parameter can be used to multiply the output raster cells by a common factor.
-Note that this parameter does not affect the output raster position or size; only the z-values
-are changed with this parameter.
-<p>
-Binary-output raster maps (solid circles of one value) can be created
-with the <b>-b</b> flag. Raster maps so created can be used to create
-binary filters for use in <em>i.ifft</em> (inverse Fourier transformations;
-apply filter with <em>r.mask</em>).
-<h2>EXAMPLES</h2>
-Generate a raster circle at current map center with a radius of 300m and outwardly
-increasing raster values:
-<pre>
-EASTCENTER=`g.region -c | awk ' /center easting:/ { print $3 }'`
-NORTHCENTER=`g.region -c | awk ' /center northing:/ { print $3 }'`
-r.circle output=circle coordinate=${EASTCENTER},${NORTHCENTER} max=300
-</pre>
-Generate a binary raster ring around current map center with an inner radius
-of 500m and an outer radius of 1000m:
-<pre>
-r.circle -b output=circle coordinate=${EASTCENTER},${NORTHCENTER} min=500 max=1000
-</pre>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="g.remove.html">g.remove</a>,
-<a href="g.rename.html">g.rename</a>,
-<a href="i.fft.html">i.fft</a>,
-<a href="i.ifft.html">i.ifft</a>,
-<a href="r.mask">r.mask</a>
-</em>
-<h2>AUTHOR</h2>
-Bill Brown, U.S. Army Construction Engineering Research Laboratory<br>
-Additional flag/min/max parameter by Markus Neteler, University of Hannover
-<p>
Copied: grass/trunk/raster/r.circle/r.circle.html (from rev 32770, grass/trunk/raster/r.circle/description.html)
--- grass/trunk/raster/r.circle/r.circle.html (rev 0)
+++ grass/trunk/raster/r.circle/r.circle.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,56 @@
+This module creates an output raster map centered on the <em>x,y</em> values specified
+with the <em>coordinate</em> parameter, out to the edge of the current region.
+The output cell values increase linearly from the specified center. The <em>min</em>
+and <em>max</em> parameters control the inner and outer output raster map radii, respectively.
+<p>
+The <em>mult</em> parameter can be used to multiply the output raster cells by a common factor.
+Note that this parameter does not affect the output raster position or size; only the z-values
+are changed with this parameter.
+<p>
+Binary-output raster maps (solid circles of one value) can be created
+with the <b>-b</b> flag. Raster maps so created can be used to create
+binary filters for use in <em>i.ifft</em> (inverse Fourier transformations;
+apply filter with <em>r.mask</em>).
+<h2>EXAMPLES</h2>
+Generate a raster circle at current map center with a radius of 300m and outwardly
+increasing raster values:
+<pre>
+EASTCENTER=`g.region -c | awk ' /center easting:/ { print $3 }'`
+NORTHCENTER=`g.region -c | awk ' /center northing:/ { print $3 }'`
+r.circle output=circle coordinate=${EASTCENTER},${NORTHCENTER} max=300
+</pre>
+Generate a binary raster ring around current map center with an inner radius
+of 500m and an outer radius of 1000m:
+<pre>
+r.circle -b output=circle coordinate=${EASTCENTER},${NORTHCENTER} min=500 max=1000
+</pre>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.remove.html">g.remove</a>,
+<a href="g.rename.html">g.rename</a>,
+<a href="i.fft.html">i.fft</a>,
+<a href="i.ifft.html">i.ifft</a>,
+<a href="r.mask">r.mask</a>
+</em>
+<h2>AUTHOR</h2>
+Bill Brown, U.S. Army Construction Engineering Research Laboratory<br>
+Additional flag/min/max parameter by Markus Neteler, University of Hannover
+<p>
Deleted: grass/trunk/raster/r.clump/description.html
--- grass/trunk/raster/r.clump/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.clump/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,53 +0,0 @@
-<em>r.clump</em> finds all areas of contiguous cell category values in the
-input raster map layer <em>name.</em> It assigns a unique category value
-to each such area ("clump") in the resulting output raster map layer
-<em>name.</em>
-Category distinctions in the input raster map layer are preserved. This
-means that if distinct category values are adjacent, they will NOT be
-clumped together. (The user can run <em><A
-HREF="r.reclass.html">r.reclass</a></em> prior to <em>r.clump</em> to
-recategorize cells and reassign cell category values.)
-<h2>NOTES</h2>
-<em>r.clump</em> moves a 2x2 matrix over the input raster map layer.
-The lower right-hand corner of the matrix is grouped with the cells above it,
-or to the left of it (diagonal cells are not considered.)
-<p>
-<em>r.clump</em> works properly with raster map layers that
-contain only "fat" areas (more than a single cell in
-width). Linear elements (lines that are a single cell
-wide) may or may not be clumped together depending on the
-direction of the line - horizontal and vertical lines of
-cells are considered to be contiguous, but diagonal lines
-of cells are not considered to be contiguous and are broken
-up into separate clumps.
-<p>
-A random color table and other support files are
-generated for the <em>output</em> raster map layer.
-<h2>SEE ALSO</h2>
-<em><a href="r.average.html">r.average</a></em><br>
-<em><a href="r.buffer.html">r.buffer</a></em><br>
-<em><a href="r.grow.html">r.grow</a><br></em><br>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em><br>
-<em><a href="r.mfilter.html">r.mfilter</a></em><br>
-<em><a href="r.neighbors.html">r.neighbors</a></em><br>
-<em><a href="r.to.vect.html">r.to.vect</a></em><br>
-<em><a href="r.reclass.html">r.reclass</a></em><br>
-<em><a href="r.statistics.html">r.statistics</a></em><br>
-<h2>AUTHOR</h2>
Copied: grass/trunk/raster/r.clump/r.clump.html (from rev 32770, grass/trunk/raster/r.clump/description.html)
--- grass/trunk/raster/r.clump/r.clump.html (rev 0)
+++ grass/trunk/raster/r.clump/r.clump.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,53 @@
+<em>r.clump</em> finds all areas of contiguous cell category values in the
+input raster map layer <em>name.</em> It assigns a unique category value
+to each such area ("clump") in the resulting output raster map layer
+<em>name.</em>
+Category distinctions in the input raster map layer are preserved. This
+means that if distinct category values are adjacent, they will NOT be
+clumped together. (The user can run <em><A
+HREF="r.reclass.html">r.reclass</a></em> prior to <em>r.clump</em> to
+recategorize cells and reassign cell category values.)
+<h2>NOTES</h2>
+<em>r.clump</em> moves a 2x2 matrix over the input raster map layer.
+The lower right-hand corner of the matrix is grouped with the cells above it,
+or to the left of it (diagonal cells are not considered.)
+<p>
+<em>r.clump</em> works properly with raster map layers that
+contain only "fat" areas (more than a single cell in
+width). Linear elements (lines that are a single cell
+wide) may or may not be clumped together depending on the
+direction of the line - horizontal and vertical lines of
+cells are considered to be contiguous, but diagonal lines
+of cells are not considered to be contiguous and are broken
+up into separate clumps.
+<p>
+A random color table and other support files are
+generated for the <em>output</em> raster map layer.
+<h2>SEE ALSO</h2>
+<em><a href="r.average.html">r.average</a></em><br>
+<em><a href="r.buffer.html">r.buffer</a></em><br>
+<em><a href="r.grow.html">r.grow</a><br></em><br>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em><br>
+<em><a href="r.mfilter.html">r.mfilter</a></em><br>
+<em><a href="r.neighbors.html">r.neighbors</a></em><br>
+<em><a href="r.to.vect.html">r.to.vect</a></em><br>
+<em><a href="r.reclass.html">r.reclass</a></em><br>
+<em><a href="r.statistics.html">r.statistics</a></em><br>
+<h2>AUTHOR</h2>
Deleted: grass/trunk/raster/r.coin/description.html
--- grass/trunk/raster/r.coin/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.coin/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,204 +0,0 @@
-<em>r.coin</em> tabulates the mutual occurrence of two
-raster map layers' categories with respect to one another.
-This analysis program respects the current geographic
-region and mask settings.
-<p>
-<em>r.coin</em>
-tabulates the coincidence of category values among the two
-map layers and prepares the basic table from which the
-report is to be created. This tabulation is followed by an
-indication of how long the coincidence table will be. If
-the table is extremely long, the user may decide that
-viewing it is not so important after all, and may cancel
-the request at this point. Assuming the user continues,
-<em>r.coin</em> then allows the user to choose one of eight
-units of measure in which the report results can be given.
-These units are:
-<p>
-<dl>
-<dt><em>c</em> <dd>cells
-<dt><em>p</em> <dd>percent cover of region
-<dt><em>x</em> <dd>percent of <map name> category (column)
-<dt><em>y</em> <dd>percent of <map name> category (row)
-<dt><em>a</em> <dd>acres
-<dt><em>h</em> <dd>hectares
-<dt><em>k</em> <dd>square kilometers
-<dt><em>m</em> <dd>square miles
-</dl>
-<p>
-Note that three of these options give results as percentage
-values: "p" is based on the grand total number of cells;
-"x" is based on only column totals; and "y" is based on
-only row totals. Only one unit of measure can be selected
-per report output. Type in just one of the letters
-designating a unit of measure followed by a
-<RETURN>. The report will be printed to the screen
-for review. After reviewing the report on the screen, the
-user is given several options. The report may be saved to
-a file and/or sent to a printer. If printed, it may be
-printed with either 80 or 132 columns. Finally, the user
-is given the option to rerun the coincidence tabulation
-using a different unit of measurement.
-<p>
-<h2>NOTES</h2>
-It is <b>not</b> a good idea to run <em>r.coin</em> on a
-map layer which has a monstrous number of categories (e.g.,
-unreclassed elevation). Because <em>r.coin</em> reports
-information for each and every category, it is better to
-reclassify those categories (using <em>r.reclass</em>)
-into a more manageable number prior to running
-<em>r.coin</em> on the reclassed raster map layer.
-<p>
-<h2>EXAMPLE</h2>
-Below is a sample of tabular output produced by
-<em>r.coin</em>. Here, map output is stated in units of
-square miles. The report tabulates the coincidence of the
-Spearfish sample database's <em>owner</em> and
-<em>road</em> raster map layers' categories. The
-<em>owner</em> categories in this case refer to whether the
-land is in private hands (category 1) or is owned by the
-U.S. Forest Service (category 2). The <em>roads</em> map
-layer categories refer to various types of roads (with the
-exception of category value "0", which indicates "no data";
-i.e., map locations at which no roads exist).
-<em>r.coin</em> does not report category labels. The user
-should run
-<em><a href="r.report.html">r.report</a></em> or
-to obtain this information.
-<p>
-The body of the report is arranged in panels. The map layer
-with the most categories is arranged along the vertical
-axis of the table; the other, along the horizontal axis.
-Each panel has a maximum of 5 categories (9 if printed)
-across the top. In addition, the last two columns reflect a
-cross total of each column for each row. All of the
-categories of the map layer arranged along the vertical
-axis are included in each panel. There is a total at the
-bottom of each column representing the sum of all the rows
-in that column. A second total represents the sum of all
-the non-zero category rows. A cross total (Table Row Total)
-of all columns for each row appears in a separate panel.
-<p>
-Note how the following information may be obtained from the sample report.
-<p>
-In the Spearfish data base, in area not owned by the Forest Service, there
-are 50.63 square miles of land not used for roads. Roads make up 9.27 square
-miles of land in this area.
-<p>
-Of the total 102.70 square miles in Spearfish, 42.80
-square miles is owned by the Forest Service.
-<br>
-In total, there are 14.58 square miles of roads.
-<p>
-There are more category 2 roads outside Forest Service land
-(2.92 mi. sq.)
-than there are inside Forest land boundaries (0.72 mi. sq.).
-<p>
-Following is a sample report.
-<pre>
-| COINCIDENCE TABULATION REPORT |
-|Location: spearfish Mapset: PERMANENT Date: Wed Jun 1 |
-| Layer 1: owner -- Ownership |
-| Layer 2: roads -- Roads |
-| Mask: none |
-| Units: square miles |
-| Window: North: 4928000.00 |
-| West: 590000.00 East: 609000.00 |
-| South: 4914000.00 |
-Panel #1 of 1
-| | owner | Panel Row Total |
-| cat# | 1 | 2 | w cat 0 | w/o cat 0 |
-|r 0 | 50.63 | 37.49 | 88.12 | 88.12 |
-|o 1 | 1.53 | 0.68 | 2.21 | 2.21 |
-|a 2 | 2.92 | 0.72 | 3.64 | 3.64 |
-|d 3 | 3.97 | 2.57 | 6.54 | 6.54 |
-|s 4 | 0.65 | 1.36 | 2.00 | 2.00 |
-| 5 | 0.19 | 0.00 | 0.19 | 0.19 |
-|Total | | | | |
-|with 0 | 59.90 | 42.80 | 102.70 | 102.70 |
-|w/o 0 | 9.27 | 5.32 | 14.58 | 14.58 |
-| | Table Row Total |
-| cat# | w cat 0 | w/o cat 0 |
-|r 0 | 88.12 | 88.12 |
-|o 1 | 2.21 | 2.21 |
-|a 2 | 3.64 | 3.64 |
-|d 3 | 6.54 | 6.54 |
-|s 4 | 2.00 | 2.00 |
-| 5 | 0.19 | 0.19 |
-|Total | | |
-|with 0 | 102.70 | 102.70 |
-|w/o 0 | 14.58 | 14.58 |
-</pre>
-<p>
-<em>r.coin</em> calculates the coincidence of two raster
-map layers. Although <em>r.coin</em> allows the user to
-rerun the report using different units, it is not possible
-to simply rerun the report with different map layers. In
-order to choose new map layers, it is necessary to rerun
-<em>r.coin.</em>
-<h2>SEE ALSO</h2>
-<em>
-<!-- not ported to GRASS 6 <a href="m.ipf.html">m.ipf</a>, -->
-<a href="r.category.html">r.category</a>,
-<a href="r.describe.html">r.describe</a>,
-<a href="r.reclass.html">r.reclass</a>,
-<a href="r.report.html">r.report</a>,
-<a href="r.stats.html">r.stats</a>
-</em>
-<h2>AUTHORS</h2>
-Michael O'Shea,
-<br>
-Michael Shapiro, <br>
-<p>
Copied: grass/trunk/raster/r.coin/r.coin.html (from rev 32770, grass/trunk/raster/r.coin/description.html)
--- grass/trunk/raster/r.coin/r.coin.html (rev 0)
+++ grass/trunk/raster/r.coin/r.coin.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,204 @@
+<em>r.coin</em> tabulates the mutual occurrence of two
+raster map layers' categories with respect to one another.
+This analysis program respects the current geographic
+region and mask settings.
+<p>
+<em>r.coin</em>
+tabulates the coincidence of category values among the two
+map layers and prepares the basic table from which the
+report is to be created. This tabulation is followed by an
+indication of how long the coincidence table will be. If
+the table is extremely long, the user may decide that
+viewing it is not so important after all, and may cancel
+the request at this point. Assuming the user continues,
+<em>r.coin</em> then allows the user to choose one of eight
+units of measure in which the report results can be given.
+These units are:
+<p>
+<dl>
+<dt><em>c</em> <dd>cells
+<dt><em>p</em> <dd>percent cover of region
+<dt><em>x</em> <dd>percent of <map name> category (column)
+<dt><em>y</em> <dd>percent of <map name> category (row)
+<dt><em>a</em> <dd>acres
+<dt><em>h</em> <dd>hectares
+<dt><em>k</em> <dd>square kilometers
+<dt><em>m</em> <dd>square miles
+</dl>
+<p>
+Note that three of these options give results as percentage
+values: "p" is based on the grand total number of cells;
+"x" is based on only column totals; and "y" is based on
+only row totals. Only one unit of measure can be selected
+per report output. Type in just one of the letters
+designating a unit of measure followed by a
+<RETURN>. The report will be printed to the screen
+for review. After reviewing the report on the screen, the
+user is given several options. The report may be saved to
+a file and/or sent to a printer. If printed, it may be
+printed with either 80 or 132 columns. Finally, the user
+is given the option to rerun the coincidence tabulation
+using a different unit of measurement.
+<p>
+<h2>NOTES</h2>
+It is <b>not</b> a good idea to run <em>r.coin</em> on a
+map layer which has a monstrous number of categories (e.g.,
+unreclassed elevation). Because <em>r.coin</em> reports
+information for each and every category, it is better to
+reclassify those categories (using <em>r.reclass</em>)
+into a more manageable number prior to running
+<em>r.coin</em> on the reclassed raster map layer.
+<p>
+<h2>EXAMPLE</h2>
+Below is a sample of tabular output produced by
+<em>r.coin</em>. Here, map output is stated in units of
+square miles. The report tabulates the coincidence of the
+Spearfish sample database's <em>owner</em> and
+<em>road</em> raster map layers' categories. The
+<em>owner</em> categories in this case refer to whether the
+land is in private hands (category 1) or is owned by the
+U.S. Forest Service (category 2). The <em>roads</em> map
+layer categories refer to various types of roads (with the
+exception of category value "0", which indicates "no data";
+i.e., map locations at which no roads exist).
+<em>r.coin</em> does not report category labels. The user
+should run
+<em><a href="r.report.html">r.report</a></em> or
+to obtain this information.
+<p>
+The body of the report is arranged in panels. The map layer
+with the most categories is arranged along the vertical
+axis of the table; the other, along the horizontal axis.
+Each panel has a maximum of 5 categories (9 if printed)
+across the top. In addition, the last two columns reflect a
+cross total of each column for each row. All of the
+categories of the map layer arranged along the vertical
+axis are included in each panel. There is a total at the
+bottom of each column representing the sum of all the rows
+in that column. A second total represents the sum of all
+the non-zero category rows. A cross total (Table Row Total)
+of all columns for each row appears in a separate panel.
+<p>
+Note how the following information may be obtained from the sample report.
+<p>
+In the Spearfish data base, in area not owned by the Forest Service, there
+are 50.63 square miles of land not used for roads. Roads make up 9.27 square
+miles of land in this area.
+<p>
+Of the total 102.70 square miles in Spearfish, 42.80
+square miles is owned by the Forest Service.
+<br>
+In total, there are 14.58 square miles of roads.
+<p>
+There are more category 2 roads outside Forest Service land
+(2.92 mi. sq.)
+than there are inside Forest land boundaries (0.72 mi. sq.).
+<p>
+Following is a sample report.
+<pre>
+| COINCIDENCE TABULATION REPORT |
+|Location: spearfish Mapset: PERMANENT Date: Wed Jun 1 |
+| Layer 1: owner -- Ownership |
+| Layer 2: roads -- Roads |
+| Mask: none |
+| Units: square miles |
+| Window: North: 4928000.00 |
+| West: 590000.00 East: 609000.00 |
+| South: 4914000.00 |
+Panel #1 of 1
+| | owner | Panel Row Total |
+| cat# | 1 | 2 | w cat 0 | w/o cat 0 |
+|r 0 | 50.63 | 37.49 | 88.12 | 88.12 |
+|o 1 | 1.53 | 0.68 | 2.21 | 2.21 |
+|a 2 | 2.92 | 0.72 | 3.64 | 3.64 |
+|d 3 | 3.97 | 2.57 | 6.54 | 6.54 |
+|s 4 | 0.65 | 1.36 | 2.00 | 2.00 |
+| 5 | 0.19 | 0.00 | 0.19 | 0.19 |
+|Total | | | | |
+|with 0 | 59.90 | 42.80 | 102.70 | 102.70 |
+|w/o 0 | 9.27 | 5.32 | 14.58 | 14.58 |
+| | Table Row Total |
+| cat# | w cat 0 | w/o cat 0 |
+|r 0 | 88.12 | 88.12 |
+|o 1 | 2.21 | 2.21 |
+|a 2 | 3.64 | 3.64 |
+|d 3 | 6.54 | 6.54 |
+|s 4 | 2.00 | 2.00 |
+| 5 | 0.19 | 0.19 |
+|Total | | |
+|with 0 | 102.70 | 102.70 |
+|w/o 0 | 14.58 | 14.58 |
+</pre>
+<p>
+<em>r.coin</em> calculates the coincidence of two raster
+map layers. Although <em>r.coin</em> allows the user to
+rerun the report using different units, it is not possible
+to simply rerun the report with different map layers. In
+order to choose new map layers, it is necessary to rerun
+<em>r.coin.</em>
+<h2>SEE ALSO</h2>
+<em>
+<!-- not ported to GRASS 6 <a href="m.ipf.html">m.ipf</a>, -->
+<a href="r.category.html">r.category</a>,
+<a href="r.describe.html">r.describe</a>,
+<a href="r.reclass.html">r.reclass</a>,
+<a href="r.report.html">r.report</a>,
+<a href="r.stats.html">r.stats</a>
+</em>
+<h2>AUTHORS</h2>
+Michael O'Shea,
+<br>
+Michael Shapiro, <br>
+<p>
Deleted: grass/trunk/raster/r.colors/description.html
--- grass/trunk/raster/r.colors/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.colors/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,314 +0,0 @@
-<i>r.colors</i> allows the user to create and/or modify the color table for a
-raster map layer. The map layer (specified on the command line by
-<b>map=</b><i>name</i>) must exist in the user's current mapset search path.
-The color table specified by <b>color=</b><i>type</i> must be one of the
-following:
-<pre>
- color type description
- aspect (aspect oriented grey colors)
- aspectcolr (aspect oriented rainbow colors)
- bcyr (blue through cyan through yellow to red)
- bgyr (blue through green through yellow to red)
- byg (blue through yellow to green colors)
- byr (blue through yellow to red colors)
- curvature (for terrain curvatures (from v.surf.rst and r.slope.aspect curvature colors))
- differences (differences oriented colors)
- elevation (maps percentage ranges of raster values to elevation color ramp)
- etopo2 (rainbow color ramp for the ETOPO2 2-minute Worldwide Bathymetry/Topography dataset)
- evi (enhanced vegetative index colors)
- grey (grey scale)
- grey1.0 (grey scale for raster values between 0.0-1.0)
- grey255 (grey scale for raster values bewtween 0-255)
- grey.eq (histogram-equalized grey scale)
- grey.log (histogram logarithmic transformed grey scale)
- gyr (green through yellow to red colors)
- ndvi (Normalized Difference Vegetation Index colors)
- population (color table covering human population classification breaks)
- rainbow (rainbow color table)
- ramp (color ramp)
- random (random color table)
- rules (create new color table based on user-specified rules)
- ryb (red through yellow to blue colors)
- ryg (red through yellow to green colors)
- slope (r.slope.aspect-type slope colors for raster values 0-90)
- srtm (color palette for Shuttle Radar Topography Mission elevation values)
- terrain (global elevation color table covering -11000 to +8850m)
- wave (color wave)
-</pre>
-<p>
-The <b>rast</b> option allows user to specify a raster map <i>name</i> from which
-to copy the color map.
-<p>
-Extra color tables (aspect, aspectcolr, bcyr, bgyr, byg, byr, curvature, differences,
-elevation, etopo2, evi, grey, grey1.0, grey255, gyr, ndvi, population, rainbow, ramp, ryb, ryg, slope, srtm, terrain, wave) are stored in $GISBASE/etc/colors/.
-User-defined color tables can also be stored in this directory for access from the <em>color</em> parameter.
-<p>
-The <b>-e</b> flag equalizes the original raster's color table. It can preclude
-the need for <em>grey.eq</em> rule, when used as
-<b>-e color=</b><em>grey</em>. Note however, that this will not yield a color
-table identical to <em>color=grey.eq</em>, because <em>grey.eq</em> scales
-the fraction by 256 to get a grey level, while <b>-e</b> uses it to interpolate
-the original colour table. If the original colour table is a 0-255 grey scale,
-<b>-e</b> is effectively scaling the fraction by 255. Different algorithms are
-used. <b>-e</b> is designed to work with any color table, both the floating
-point and the integer raster maps.
-<p>
-The <b>-g</b> flag divides the raster's grey value range into 100
-logarithmically equal steps (where "step" is a rule with the same grey level
-for the start and end points). It can preclude the need for <em>grey.log</em>
-rule, when used as <b>-g color=</b><em>grey</em>. Note however, that this
-will not yield a color table identical to <em>color=grey.log</em>. Different
-algorithms are used. Unlike <b>color=</b><em>grey.log</em>, <b>-g</b> is
-designed to work with both floating point and integer rasters, without
-performance issues with large datasets, of any original color table. Logarithmic
-scaling doesn't work on negative values. In the case when the value range
-includes zero, there's no realistic solution.
-<p>
-The <b>-e</b> and <b>-g</b> flags are not mutually exclusive.
-<p>
-If the user specifies the <b>-w</b> flag, the current color table file for
-the input map will not be overwritten. This means that the color table is
-created only if the <i>map</i> does not already have a color table. If this
-option is not specified, the color table will be created if one does not
-exist, or modified if it does.
-<p>
-If the user sets the <b>-q</b> flag, <i>r.colors</i> will run quietly,
-Without printing numerous messages on its progress to standard output.
-<p>Color table types <i>aspect, grey, grey.eq</i> (histogram-equalized grey
-scale), <i>byg</i> (blue-yellow-green), <i>byr</i> (blue-yellow-red),
-<i>gyr</i> (green-yellow-red), <i>rainbow, ramp, ryg</i> (red-yellow-green),
-<i>random</i>, and <i>wave</i> are pre-defined color tables that
-<i>r.colors</i> knows how to create without any further input.
-<p>
-In general, tables which associate colors with percentages (aspect, bcyr, byg,
-byr, elevation, grey, gyr, rainbow, ramp, ryb, ryg and wave) can be applied to
-any data, while those which use absolute values (aspectcolr, curvature, etopo2,
-evi, ndvi, population, slope, srtm, and terrain) only make sense for data with
-certain ranges.
-One can get a rough idea of the applicability of a colour table by reading the
-corresponding rules file ($GISBASE/etc/colors/<name>).
-For example the <em>slope</em> rule is defined as:
-0 255:255:255
-2 255:255:0
-5 0:255:0
-10 0:255 255
-15 0:0:255
-30 255:0:255
-50 255:0:0
-90 0:0:0
-</pre></div>
-<p>
-This is designed for the slope map generated by r.slope.aspect, where the value
-is a slope angle between 0 and 90 degrees.
-<p>
-Similarly, the <em>aspectcolr</em> rule:
-0 white
-1 yellow
-90 green
-180 cyan
-270 red
-360 yellow
-</pre></div>
-<p>
-is designed for the aspect maps produced by r.slope.aspect, where the value is a
-heading between 0 and 360 degrees.
-<p>
-The <i>rules</i> color table type will cause <i>r.colors</i> to read color
-table specifications from standard input (stdin) and will build the color table
-accordingly.
-<p>
-Using color table type <i>rules</i>, there are <!--three-->two ways to build a color
-table: <!--by color list,--> by category values and by "percent" values.
-<!-- HB: this causes an error in current code, maybe easy to enable functionality from old code??
-<p>
-Building a customized color table by color list is the simplest of the three
-rules methods: just list the colors you wish to appear in the color table in the
-order that you wish them to appear. Use the standard GRASS color names: white,
-black, red, green, blue, yellow, magenta, cyan, aqua, grey, gray, orange, brown,
-purple, violet, and indigo.
-<p>
-For example, to create a color table for the raster map layer <i>elevation</i>
-that assigns greens to low map category values, browns to the next larger
-map category values, and yellows to the still larger map category values,
-one would type:
-<b>r.colors map=</b><i>elevation</i> <b>color=</b><i>rules</i>
-green
-brown
-yellow
-end
-</pre></div>
-<p>
-To build a color table by category values' indices, the user should determine
-the range of category values in the raster map layer with which the color table
-will be used. Specific category values will then be associated with specific
-colors. Note that a color does not have to be assigned for every valid category
-value because <i>r.colors</i> will interpolate a color ramp to fill in where
-color specification rules have been left out. The format of such a specification
-is as follows:
-category_value color_name
-end
-</pre></div>
-<p>
-Each category value must be valid for the raster map layer, category values must
-be in ascending order and only use standard GRASS color names (see above).
-<p>
-Colors can also be specified by color numbers each in the range 0-255. The
-format of a category value color table specification using color numbers instead
-of color names is as follows:
-category_value red_number:green_number:blue_number
-end
-</pre></div>
-<p>
-Specifying a color table by "percent" values allows one to treat a color table
-as if it were numbered from 0 to 100. The format of a "percent" value color
-table specification is the same as for a category value color specification,
-except that the category values are replaced by "percent" values, each from
-0-100, in ascending order. The format is as follows:
-percent_value% color_name
-end
-</pre></div>
-<p>
-Using "percent" value color table specification rules, colors can also
-be specified by color numbers each in the range 0-255. The format of a
-percent value color table specification using color numbers instead of
-color names is as follows:
-percent_value% red_number:green_number:blue_number
-end
-</pre></div>
-<p>
-Note that you can also mix these <!--three-->two methods of color table
-specification; for example:
-0 black
-10% yellow
-78 blue<!--\n magenta
-purple
-brown-->
-100% 0:255:230
-end
-</pre></div>
-<p>
-To set the NULL (no data) color, use the "nv" parameter:
-0 black
-10% yellow
-nv white
-end
-</pre></div>
-<h2>EXAMPLES</h2>
-The below example shows how you can specify colors for a three category map,
-assigning red to category 1, green to category 2, and blue to category 3. Start
-by using a text editor to create the following rules specification file (save it
-with the name <i>rules.file</i>):
-1 red
-2 green
-3 blue
-end
-</pre></div>
-<p>
-The color table can then by assigned to map <i>threecats</i> by the following
-GRASS command:
-cat rules.file | r.colors -i map=threecats
-</pre></div>
-<p><br>
-To create a natural looking LUT for true map layer <i>elevation</i>, use the
-following rules specification file. It will assign light green shades to the
-lower elevations (first 20% of the LUT), and then darker greens (next 15%, and
-next 20%) and light browns (next 20%) for middle elevations, and darker browns
-(next 15%) for higher elevations, and finally yellow for the highest peaks (last
-10% of LUT).
-0% 0:230:0
-20% 0:160:0
-35% 50:130:0
-55% 120:100:30
-75% 120:130:40
-90% 170:160:50
-100% 255:255:100
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="d.colors.html">d.colors</a>,
-<a href="d.colortable.html">d.colortable</a>,
-<a href="d.legend.html">d.legend</a>,
-<a href="r.support.html">r.support</a>
-</em>
-<p>
-<a href="http://colorbrewer.org">ColorBrewer</a> is an online tool designed to
-help people select good color schemes for maps and other graphics.
-<h2>AUTHORS</h2>
-Michael Shapiro and David Johnson
-<p>
Copied: grass/trunk/raster/r.colors/r.colors.html (from rev 32770, grass/trunk/raster/r.colors/description.html)
--- grass/trunk/raster/r.colors/r.colors.html (rev 0)
+++ grass/trunk/raster/r.colors/r.colors.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,314 @@
+<h2>DESCRIPTION</h2>
+<i>r.colors</i> allows the user to create and/or modify the color table for a
+raster map layer. The map layer (specified on the command line by
+<b>map=</b><i>name</i>) must exist in the user's current mapset search path.
+The color table specified by <b>color=</b><i>type</i> must be one of the
+following:
+<pre>
+ color type description
+ aspect (aspect oriented grey colors)
+ aspectcolr (aspect oriented rainbow colors)
+ bcyr (blue through cyan through yellow to red)
+ bgyr (blue through green through yellow to red)
+ byg (blue through yellow to green colors)
+ byr (blue through yellow to red colors)
+ curvature (for terrain curvatures (from v.surf.rst and r.slope.aspect curvature colors))
+ differences (differences oriented colors)
+ elevation (maps percentage ranges of raster values to elevation color ramp)
+ etopo2 (rainbow color ramp for the ETOPO2 2-minute Worldwide Bathymetry/Topography dataset)
+ evi (enhanced vegetative index colors)
+ grey (grey scale)
+ grey1.0 (grey scale for raster values between 0.0-1.0)
+ grey255 (grey scale for raster values bewtween 0-255)
+ grey.eq (histogram-equalized grey scale)
+ grey.log (histogram logarithmic transformed grey scale)
+ gyr (green through yellow to red colors)
+ ndvi (Normalized Difference Vegetation Index colors)
+ population (color table covering human population classification breaks)
+ rainbow (rainbow color table)
+ ramp (color ramp)
+ random (random color table)
+ rules (create new color table based on user-specified rules)
+ ryb (red through yellow to blue colors)
+ ryg (red through yellow to green colors)
+ slope (r.slope.aspect-type slope colors for raster values 0-90)
+ srtm (color palette for Shuttle Radar Topography Mission elevation values)
+ terrain (global elevation color table covering -11000 to +8850m)
+ wave (color wave)
+</pre>
+<p>
+The <b>rast</b> option allows user to specify a raster map <i>name</i> from which
+to copy the color map.
+<p>
+Extra color tables (aspect, aspectcolr, bcyr, bgyr, byg, byr, curvature, differences,
+elevation, etopo2, evi, grey, grey1.0, grey255, gyr, ndvi, population, rainbow, ramp, ryb, ryg, slope, srtm, terrain, wave) are stored in $GISBASE/etc/colors/.
+User-defined color tables can also be stored in this directory for access from the <em>color</em> parameter.
+<p>
+The <b>-e</b> flag equalizes the original raster's color table. It can preclude
+the need for <em>grey.eq</em> rule, when used as
+<b>-e color=</b><em>grey</em>. Note however, that this will not yield a color
+table identical to <em>color=grey.eq</em>, because <em>grey.eq</em> scales
+the fraction by 256 to get a grey level, while <b>-e</b> uses it to interpolate
+the original colour table. If the original colour table is a 0-255 grey scale,
+<b>-e</b> is effectively scaling the fraction by 255. Different algorithms are
+used. <b>-e</b> is designed to work with any color table, both the floating
+point and the integer raster maps.
+<p>
+The <b>-g</b> flag divides the raster's grey value range into 100
+logarithmically equal steps (where "step" is a rule with the same grey level
+for the start and end points). It can preclude the need for <em>grey.log</em>
+rule, when used as <b>-g color=</b><em>grey</em>. Note however, that this
+will not yield a color table identical to <em>color=grey.log</em>. Different
+algorithms are used. Unlike <b>color=</b><em>grey.log</em>, <b>-g</b> is
+designed to work with both floating point and integer rasters, without
+performance issues with large datasets, of any original color table. Logarithmic
+scaling doesn't work on negative values. In the case when the value range
+includes zero, there's no realistic solution.
+<p>
+The <b>-e</b> and <b>-g</b> flags are not mutually exclusive.
+<p>
+If the user specifies the <b>-w</b> flag, the current color table file for
+the input map will not be overwritten. This means that the color table is
+created only if the <i>map</i> does not already have a color table. If this
+option is not specified, the color table will be created if one does not
+exist, or modified if it does.
+<p>
+If the user sets the <b>-q</b> flag, <i>r.colors</i> will run quietly,
+Without printing numerous messages on its progress to standard output.
+<p>Color table types <i>aspect, grey, grey.eq</i> (histogram-equalized grey
+scale), <i>byg</i> (blue-yellow-green), <i>byr</i> (blue-yellow-red),
+<i>gyr</i> (green-yellow-red), <i>rainbow, ramp, ryg</i> (red-yellow-green),
+<i>random</i>, and <i>wave</i> are pre-defined color tables that
+<i>r.colors</i> knows how to create without any further input.
+<p>
+In general, tables which associate colors with percentages (aspect, bcyr, byg,
+byr, elevation, grey, gyr, rainbow, ramp, ryb, ryg and wave) can be applied to
+any data, while those which use absolute values (aspectcolr, curvature, etopo2,
+evi, ndvi, population, slope, srtm, and terrain) only make sense for data with
+certain ranges.
+One can get a rough idea of the applicability of a colour table by reading the
+corresponding rules file ($GISBASE/etc/colors/<name>).
+For example the <em>slope</em> rule is defined as:
+0 255:255:255
+2 255:255:0
+5 0:255:0
+10 0:255 255
+15 0:0:255
+30 255:0:255
+50 255:0:0
+90 0:0:0
+</pre></div>
+<p>
+This is designed for the slope map generated by r.slope.aspect, where the value
+is a slope angle between 0 and 90 degrees.
+<p>
+Similarly, the <em>aspectcolr</em> rule:
+0 white
+1 yellow
+90 green
+180 cyan
+270 red
+360 yellow
+</pre></div>
+<p>
+is designed for the aspect maps produced by r.slope.aspect, where the value is a
+heading between 0 and 360 degrees.
+<p>
+The <i>rules</i> color table type will cause <i>r.colors</i> to read color
+table specifications from standard input (stdin) and will build the color table
+accordingly.
+<p>
+Using color table type <i>rules</i>, there are <!--three-->two ways to build a color
+table: <!--by color list,--> by category values and by "percent" values.
+<!-- HB: this causes an error in current code, maybe easy to enable functionality from old code??
+<p>
+Building a customized color table by color list is the simplest of the three
+rules methods: just list the colors you wish to appear in the color table in the
+order that you wish them to appear. Use the standard GRASS color names: white,
+black, red, green, blue, yellow, magenta, cyan, aqua, grey, gray, orange, brown,
+purple, violet, and indigo.
+<p>
+For example, to create a color table for the raster map layer <i>elevation</i>
+that assigns greens to low map category values, browns to the next larger
+map category values, and yellows to the still larger map category values,
+one would type:
+<b>r.colors map=</b><i>elevation</i> <b>color=</b><i>rules</i>
+green
+brown
+yellow
+end
+</pre></div>
+<p>
+To build a color table by category values' indices, the user should determine
+the range of category values in the raster map layer with which the color table
+will be used. Specific category values will then be associated with specific
+colors. Note that a color does not have to be assigned for every valid category
+value because <i>r.colors</i> will interpolate a color ramp to fill in where
+color specification rules have been left out. The format of such a specification
+is as follows:
+category_value color_name
+end
+</pre></div>
+<p>
+Each category value must be valid for the raster map layer, category values must
+be in ascending order and only use standard GRASS color names (see above).
+<p>
+Colors can also be specified by color numbers each in the range 0-255. The
+format of a category value color table specification using color numbers instead
+of color names is as follows:
+category_value red_number:green_number:blue_number
+end
+</pre></div>
+<p>
+Specifying a color table by "percent" values allows one to treat a color table
+as if it were numbered from 0 to 100. The format of a "percent" value color
+table specification is the same as for a category value color specification,
+except that the category values are replaced by "percent" values, each from
+0-100, in ascending order. The format is as follows:
+percent_value% color_name
+end
+</pre></div>
+<p>
+Using "percent" value color table specification rules, colors can also
+be specified by color numbers each in the range 0-255. The format of a
+percent value color table specification using color numbers instead of
+color names is as follows:
+percent_value% red_number:green_number:blue_number
+end
+</pre></div>
+<p>
+Note that you can also mix these <!--three-->two methods of color table
+specification; for example:
+0 black
+10% yellow
+78 blue<!--\n magenta
+purple
+brown-->
+100% 0:255:230
+end
+</pre></div>
+<p>
+To set the NULL (no data) color, use the "nv" parameter:
+0 black
+10% yellow
+nv white
+end
+</pre></div>
+<h2>EXAMPLES</h2>
+The below example shows how you can specify colors for a three category map,
+assigning red to category 1, green to category 2, and blue to category 3. Start
+by using a text editor to create the following rules specification file (save it
+with the name <i>rules.file</i>):
+1 red
+2 green
+3 blue
+end
+</pre></div>
+<p>
+The color table can then by assigned to map <i>threecats</i> by the following
+GRASS command:
+cat rules.file | r.colors -i map=threecats
+</pre></div>
+<p><br>
+To create a natural looking LUT for true map layer <i>elevation</i>, use the
+following rules specification file. It will assign light green shades to the
+lower elevations (first 20% of the LUT), and then darker greens (next 15%, and
+next 20%) and light browns (next 20%) for middle elevations, and darker browns
+(next 15%) for higher elevations, and finally yellow for the highest peaks (last
+10% of LUT).
+0% 0:230:0
+20% 0:160:0
+35% 50:130:0
+55% 120:100:30
+75% 120:130:40
+90% 170:160:50
+100% 255:255:100
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="d.colors.html">d.colors</a>,
+<a href="d.colortable.html">d.colortable</a>,
+<a href="d.legend.html">d.legend</a>,
+<a href="r.support.html">r.support</a>
+</em>
+<p>
+<a href="http://colorbrewer.org">ColorBrewer</a> is an online tool designed to
+help people select good color schemes for maps and other graphics.
+<h2>AUTHORS</h2>
+Michael Shapiro and David Johnson
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.composite/description.html
--- grass/trunk/raster/r.composite/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.composite/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,45 +0,0 @@
-<h2>DESCRIPTION</h2>
-This program combines three raster maps to form a
-composite RGB map. For each input map layer, the corresponding
-component from the map's color table is used (e.g. for
-the red map, the red component is used, and so on). In
-general, the maps should use a gray-scale color table.
-<h2>NOTES</h2>
-The default number of intensity levels for each component is 32,
-resulting in a total of 32768 possible colors (equivalent to 15 bits
-per pixel). If significantly more levels than this are used, not only
-will <em>r.composite</em> take longer to run, but displaying the
-resulting layer with <em><a href="d.rast.html">d.rast</a></em> will
-also be significantly slower.
-<p>
-Floyd-Steinberg dithering is optionally used with the <b>-d</b> flag.
-<h2>EXAMPLE</h2>
-Creating a composite RGB raster using 32 color levels per layer, with dithering:
-<div class="code"><pre>
-r.composite -d red=elevation.r green=elevation.g blue=elevation.b output=elev.composite
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="d.rast.html">d.rast</a>,
-<a href="d.rgb.html">d.rgb</a>,
-<a href="r.blend.html">r.blend</a>,
-<a href="r.colors.html">r.colors</a>
-</em>
-<p>
-<em>
-<a href="http://en.wikipedia.org/wiki/Floyd-Steinberg_dithering">Wikipedia Entry: Floyd-Steinberg dithering</a>
-</em>
-<h2>AUTHOR</h2>
-Glynn Clements
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.composite/r.composite.html (from rev 32770, grass/trunk/raster/r.composite/description.html)
--- grass/trunk/raster/r.composite/r.composite.html (rev 0)
+++ grass/trunk/raster/r.composite/r.composite.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,45 @@
+This program combines three raster maps to form a
+composite RGB map. For each input map layer, the corresponding
+component from the map's color table is used (e.g. for
+the red map, the red component is used, and so on). In
+general, the maps should use a gray-scale color table.
+<h2>NOTES</h2>
+The default number of intensity levels for each component is 32,
+resulting in a total of 32768 possible colors (equivalent to 15 bits
+per pixel). If significantly more levels than this are used, not only
+will <em>r.composite</em> take longer to run, but displaying the
+resulting layer with <em><a href="d.rast.html">d.rast</a></em> will
+also be significantly slower.
+<p>
+Floyd-Steinberg dithering is optionally used with the <b>-d</b> flag.
+<h2>EXAMPLE</h2>
+Creating a composite RGB raster using 32 color levels per layer, with dithering:
+<div class="code"><pre>
+r.composite -d red=elevation.r green=elevation.g blue=elevation.b output=elev.composite
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="d.rast.html">d.rast</a>,
+<a href="d.rgb.html">d.rgb</a>,
+<a href="r.blend.html">r.blend</a>,
+<a href="r.colors.html">r.colors</a>
+</em>
+<p>
+<em>
+<a href="http://en.wikipedia.org/wiki/Floyd-Steinberg_dithering">Wikipedia Entry: Floyd-Steinberg dithering</a>
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.compress/description.html
--- grass/trunk/raster/r.compress/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.compress/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,148 +0,0 @@
-The GRASS program <em>r.compress</em> can be used to compress and decompress
-raster map layers.
-<p>
-During compression, this program reformats raster maps
-using a run-length-encoding (RLE) algorithm. Raster map
-layers which contain very little information (such as
-boundary, geology, soils and land use maps) can be greatly
-reduced in size. Some raster map layers are shrunk to
-roughly 1% of their original sizes. Raster map layers
-containing complex images such as elevation and photo or
-satellite images may increase slightly in size.
-<!-- The 'new compressed format' probably isn't new anymore as of 2008. - EP
-GRASS uses a new compressed format, -->
-All new raster maps are now automatically stored in compressed
-form (see FORMATS below). GRASS programs can read both compressed
-and regular (uncompressed) file formats. This allows the use
-of whichever raster data format consumes less space.
-<p>
-As an example, the Spearfish data base raster map layer
-<em>owner</em> was originally a size of 26600 bytes. After
-it was compressed, the raster map became only 1249 bytes
-(25351 bytes smaller).
-<p>
-Raster files may be decompressed to return them to their
-original format, using the <b>-u</b> flag of
-<em>r.compress</em>. If <em>r.compress</em> is asked to
-compress a raster map which is already compressed (or to
-decompress an already decompressed raster map), it simply informs
-the user the map is already (de)compressed and exits.
-<h2>NOTES</h2>
-<em>r.compress</em> can be run either non-interactively or
-interactively. In non-interactive use, the user must
-specify the name(s) of the raster map layer(s) to be
-compressed (or decompressed) on the command line, using the
-form <b>map=</b><em>name</em>[,<em>name</em>,...] (where
-each <em>name</em> is the name of a raster map layer to be
-compressed or decompressed). The default behavior is to
-compress the named map(s).
-<h3>FORMATS</h3>
-Conceptually, a raster data file consists of rows of cells,
-with each row containing the same number of cells. A cell
-consists of one or more bytes. The number of bytes per
-cell depends on the category values stored in the cell.
-Category values in the range 0-255 require 1 byte per cell,
-while category values in the range 256-65535 require 2
-bytes, and category values in the range above 65535 require
-3 (or more) bytes per cell.
-<p>
-The <b>decompressed</b> raster map format matches the
-conceptual format. For example, a raster map with 1 byte
-cells that is 100 rows with 200 cells per row, consists of
-20,000 bytes. Running the UNIX command <em>ls -l</em> on
-this file will show a size of 20,000. If the cells were 2
-byte cells, the file would require 40,000 bytes. The map
-layer category values start with the upper left corner cell
-followed by the other cells along the northern boundary.
-The byte following the last byte of that first row is the
-first cell of the second row of category values (moving
-from left to right). There are no end-of-row markers or
-other syncing codes in the raster map. A cell header file
-(<em>cellhd</em>) is used to define how this string of bytes
-is broken up into rows of category values.
-<p>
-The <b>compressed</b> format is not so simple, but is quite
-elegant in its design. It not only requires less disk space
-to store the raster data, but often can result in faster
-execution of graphic and analysis programs since there is
-less disk I/O. There are two compressed formats: the
-pre-version 3.0 format (which GRASS programs can read but
-no longer produce), and the version 3.0 format (which is
-automatically used when new raster map layers are
-created).
-<h4>PRE-3.0 FORMAT:</h4>
-First 3 bytes (chars) - These are a special code that identifies
-the raster data as compressed.
-<p>
-Address array (long) - array (size of the number of rows +
-1) of addresses pointing to the internal start of each row.
-Because each row may be a different size, this array is
-necessary to provide a mapping of the data.
-<p>
-Row by row, beginning at the northern edge of the data, a
-series of byte groups describes the data. The number of
-bytes in each group is the number of bytes per cell plus
-one. The first byte of each group gives a count (up to
-255) of the number of cells that contain the category
-values given by the remaining bytes of the group.
-<h4>POST-3.0 FORMAT:</h4>
-The 3 byte code is not used.
-Instead, a field in the cell header is used to indicate compressed format.
-<p>
-The address array is the same.
-<p>
-The RLE format is the same as the pre-3.0 RLE, except that
-each row of data is preceded by a single byte containing
-the number of bytes per cell for the row, and if
-run-length-encoding the row would not require less space
-than non-run-length-encoding, then the row is not encoded.
-<p>
-These improvements give better compression than the pre-3.0
-format in 99% of the raster data layers. The kinds of
-raster data layers which get bigger are those in which each
-row would be larger if compressed (e.g., imagery band
-files). But even in this case the raster data layer would
-only be larger by the size of the address array and the
-single byte preceding each row.
-<h2>SEE ALSO</h2>
-<h2>AUTHORS</h2>
-James Westervelt,<br>
-Michael Shapiro,<br>
-U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.compress/r.compress.html (from rev 32770, grass/trunk/raster/r.compress/description.html)
--- grass/trunk/raster/r.compress/r.compress.html (rev 0)
+++ grass/trunk/raster/r.compress/r.compress.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,148 @@
+The GRASS program <em>r.compress</em> can be used to compress and decompress
+raster map layers.
+<p>
+During compression, this program reformats raster maps
+using a run-length-encoding (RLE) algorithm. Raster map
+layers which contain very little information (such as
+boundary, geology, soils and land use maps) can be greatly
+reduced in size. Some raster map layers are shrunk to
+roughly 1% of their original sizes. Raster map layers
+containing complex images such as elevation and photo or
+satellite images may increase slightly in size.
+<!-- The 'new compressed format' probably isn't new anymore as of 2008. - EP
+GRASS uses a new compressed format, -->
+All new raster maps are now automatically stored in compressed
+form (see FORMATS below). GRASS programs can read both compressed
+and regular (uncompressed) file formats. This allows the use
+of whichever raster data format consumes less space.
+<p>
+As an example, the Spearfish data base raster map layer
+<em>owner</em> was originally a size of 26600 bytes. After
+it was compressed, the raster map became only 1249 bytes
+(25351 bytes smaller).
+<p>
+Raster files may be decompressed to return them to their
+original format, using the <b>-u</b> flag of
+<em>r.compress</em>. If <em>r.compress</em> is asked to
+compress a raster map which is already compressed (or to
+decompress an already decompressed raster map), it simply informs
+the user the map is already (de)compressed and exits.
+<h2>NOTES</h2>
+<em>r.compress</em> can be run either non-interactively or
+interactively. In non-interactive use, the user must
+specify the name(s) of the raster map layer(s) to be
+compressed (or decompressed) on the command line, using the
+form <b>map=</b><em>name</em>[,<em>name</em>,...] (where
+each <em>name</em> is the name of a raster map layer to be
+compressed or decompressed). The default behavior is to
+compress the named map(s).
+<h3>FORMATS</h3>
+Conceptually, a raster data file consists of rows of cells,
+with each row containing the same number of cells. A cell
+consists of one or more bytes. The number of bytes per
+cell depends on the category values stored in the cell.
+Category values in the range 0-255 require 1 byte per cell,
+while category values in the range 256-65535 require 2
+bytes, and category values in the range above 65535 require
+3 (or more) bytes per cell.
+<p>
+The <b>decompressed</b> raster map format matches the
+conceptual format. For example, a raster map with 1 byte
+cells that is 100 rows with 200 cells per row, consists of
+20,000 bytes. Running the UNIX command <em>ls -l</em> on
+this file will show a size of 20,000. If the cells were 2
+byte cells, the file would require 40,000 bytes. The map
+layer category values start with the upper left corner cell
+followed by the other cells along the northern boundary.
+The byte following the last byte of that first row is the
+first cell of the second row of category values (moving
+from left to right). There are no end-of-row markers or
+other syncing codes in the raster map. A cell header file
+(<em>cellhd</em>) is used to define how this string of bytes
+is broken up into rows of category values.
+<p>
+The <b>compressed</b> format is not so simple, but is quite
+elegant in its design. It not only requires less disk space
+to store the raster data, but often can result in faster
+execution of graphic and analysis programs since there is
+less disk I/O. There are two compressed formats: the
+pre-version 3.0 format (which GRASS programs can read but
+no longer produce), and the version 3.0 format (which is
+automatically used when new raster map layers are
+created).
+<h4>PRE-3.0 FORMAT:</h4>
+First 3 bytes (chars) - These are a special code that identifies
+the raster data as compressed.
+<p>
+Address array (long) - array (size of the number of rows +
+1) of addresses pointing to the internal start of each row.
+Because each row may be a different size, this array is
+necessary to provide a mapping of the data.
+<p>
+Row by row, beginning at the northern edge of the data, a
+series of byte groups describes the data. The number of
+bytes in each group is the number of bytes per cell plus
+one. The first byte of each group gives a count (up to
+255) of the number of cells that contain the category
+values given by the remaining bytes of the group.
+<h4>POST-3.0 FORMAT:</h4>
+The 3 byte code is not used.
+Instead, a field in the cell header is used to indicate compressed format.
+<p>
+The address array is the same.
+<p>
+The RLE format is the same as the pre-3.0 RLE, except that
+each row of data is preceded by a single byte containing
+the number of bytes per cell for the row, and if
+run-length-encoding the row would not require less space
+than non-run-length-encoding, then the row is not encoded.
+<p>
+These improvements give better compression than the pre-3.0
+format in 99% of the raster data layers. The kinds of
+raster data layers which get bigger are those in which each
+row would be larger if compressed (e.g., imagery band
+files). But even in this case the raster data layer would
+only be larger by the size of the address array and the
+single byte preceding each row.
+<h2>SEE ALSO</h2>
+<h2>AUTHORS</h2>
+James Westervelt,<br>
+Michael Shapiro,<br>
+U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.contour/description.html
--- grass/trunk/raster/r.contour/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.contour/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,36 +0,0 @@
-<em>r.contour</em> produces a GRASS binary vector map of specified contours from a GRASS raster map.
-Contours can be produced using a comma-separated list of values in <b>levels</b>, or at some regular increment using the <b>step</b> parameter, using <b>minlevel</b> and <b>maxlevel</b> as minimum and maximum contour values, respectively. If no <b>minlevel</b> or <b>maxlevel</b> is specified, the minimum and maximum cell values in the <b>input</b> raster map will be used.
-<h2>NOTES</h2>
-<em>r.contour</em> will either step through incremental contours or produce
-contours from a list of levels, not both. If both a list of levels and
-a step are specified, the list will be produced and the step will be ignored.
-<p>Zero is treated as a valid data value by <em>r.contour</em>.
-<p>If a contour level exactly matches a category value in the raster map,
-the contour line may backtrack on itself, causing illegal arcs to be produced
-in the output GRASS vector map.
-<p>The optional <b>cut</b> parameter allows the user to specify a minimum number of
-raster cells eligilble to be included in a contour line written to the <b>output</b>
-vector map. It acts like a filter, omitting spurs, single points, etc., making the output more generalized.
-<h2>EXAMPLE</h2>
-In the Spearfish location, produce a vector contour map from input raster <i>elevation.dem</i>
-with contour levels from 1000m to 2000m, 100m contour step, and a minimum of 200 input raster
-points contributing to the contour line:
-<div><pre class="code">
-r.contour input=elevation.dem output=elevation_dem_contours minlevel=1000 maxlevel=2000 step=100 cut=200
-</pre></div>
-<h2>AUTHORS</h2>
-Terry Baker, U.S. Army Construction Engineering Research Laboratory<br>
-3/2001: cut parameter and fixes by Andrea Aime (aaime at libero.it)
Copied: grass/trunk/raster/r.contour/r.contour.html (from rev 32770, grass/trunk/raster/r.contour/description.html)
--- grass/trunk/raster/r.contour/r.contour.html (rev 0)
+++ grass/trunk/raster/r.contour/r.contour.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,36 @@
+<em>r.contour</em> produces a GRASS binary vector map of specified contours from a GRASS raster map.
+Contours can be produced using a comma-separated list of values in <b>levels</b>, or at some regular increment using the <b>step</b> parameter, using <b>minlevel</b> and <b>maxlevel</b> as minimum and maximum contour values, respectively. If no <b>minlevel</b> or <b>maxlevel</b> is specified, the minimum and maximum cell values in the <b>input</b> raster map will be used.
+<h2>NOTES</h2>
+<em>r.contour</em> will either step through incremental contours or produce
+contours from a list of levels, not both. If both a list of levels and
+a step are specified, the list will be produced and the step will be ignored.
+<p>Zero is treated as a valid data value by <em>r.contour</em>.
+<p>If a contour level exactly matches a category value in the raster map,
+the contour line may backtrack on itself, causing illegal arcs to be produced
+in the output GRASS vector map.
+<p>The optional <b>cut</b> parameter allows the user to specify a minimum number of
+raster cells eligilble to be included in a contour line written to the <b>output</b>
+vector map. It acts like a filter, omitting spurs, single points, etc., making the output more generalized.
+<h2>EXAMPLE</h2>
+In the Spearfish location, produce a vector contour map from input raster <i>elevation.dem</i>
+with contour levels from 1000m to 2000m, 100m contour step, and a minimum of 200 input raster
+points contributing to the contour line:
+<div><pre class="code">
+r.contour input=elevation.dem output=elevation_dem_contours minlevel=1000 maxlevel=2000 step=100 cut=200
+</pre></div>
+<h2>AUTHORS</h2>
+Terry Baker, U.S. Army Construction Engineering Research Laboratory<br>
+3/2001: cut parameter and fixes by Andrea Aime (aaime at libero.it)
Deleted: grass/trunk/raster/r.cost/description.html
--- grass/trunk/raster/r.cost/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.cost/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,260 +0,0 @@
-<p><em>r.cost</em> determines the cumulative cost of moving to each
-cell on a <em>cost surface</em> (the <b>input</b> raster map) from
-other user-specified cell(s) whose locations are specified by their
-geographic coordinate(s). Each cell in the original cost surface map
-will contain a category value which represents the cost of traversing
-that cell. <em>r.cost</em> will produce an <b>output</b> raster map in
-which each cell contains the lowest total cost of traversing the
-space between each cell and the user-specified points. (Diagonal
-costs are multiplied by a factor that depends on the dimensions of
-the cell.) This program uses the current geographic region settings.
-The <b>output</b> map will be of the same data format as the <b>input</b>
-map, integer or floating point.</p>
-<h2>OPTIONS</h2>
-The <b>input</b> <em>name</em> is the name of a raster map whose category values
-represent the surface cost. The <b>output</b> <em>name</em> is the name of the
-resultant raster map of cumulative cost.
-<p>
-<em>r.cost</em> can be run with three different methods of identifying the
-starting point(s). One or more points (geographic coordinate pairs) can be
-provided as specified <b>coordinate</b>s on the command line, from a vector
-points file, or from a raster map.
-All non-NULL cells are considered to be starting points.
-Each <em>x,y</em> <b>coordinate</b> pair gives the geographic location of a
-point from which the transportation cost should be figured. As many points as
-desired can be entered by the user. These starting points can also be read
-from a vector points file through the <b>start_sites</b> option or from a
-raster map through the <b>start_rast</b> option.
-<p>
-<em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
-or one of the stop points given with <b>stop_coordinates</b> is reached.
-Alternatively, the stop points can be read from a vector points file with the
-<b>stop_sites</b> option. During execution, once the cumulative cost to all
-stopping points has been determined, processing stops.
-Both sites read from a vector points file and those given on the command line
-will be processed.
-<p>
-The null cells in the <b>input</b> map can be assigned a (positive floating
-point) cost with the <b>null_cost</b> option.
-<br>
-When input map null cells are given a cost with the <b>null_cost</b>
-option, the corresponding cells in the output map are no longer null
-cells. By using the <b>-n</b> flag, the null cells of the input map are
-retained as null cells in the output map.</p>
-<p>
-As <em>r.cost</em> can run for a very long time, it can be useful to
-use the <b>-v</b> verbose flag to track progress.
-<p>
-The Knight's move (<b>-k</b> flag) may be used to improve the accuracy of
-the output. In the diagram below, the center location (<tt>O</tt>) represents a
-grid cell from which cumulative distances are calculated. Those
-neighbors marked with an <tt>X</tt> are always considered for cumulative cost
-updates. With the <b>-k</b> option, the neighbors marked with a <tt>K</tt> are
-also considered.
-</p>
- . . . K . . K . . .
- . . K . X . X . X . K . .
- . . . X . O . X . . .
-</pre></div>
-<br>
-Knight's move example:
-<center>
-<img src=rcost_knightsmove.png border=1><br>
-<table border=0 width=590>
-<tr><td><center>
-<i>Flat cost surface without (left pane) and with the knight's move (right pane).
-The default is to grow the cost outwards in 8 directions.
-Using the knight's move grows it outwards in 16 directions.</i>
-</center></td></tr>
-</table>
-</center>
-<h2>NULL CELLS</h2>
-<p>By default null cells in the input raster map are excluded from
-the algorithm, and thus retained in the output map.
-<p>
-If one wants <b>r.cost</b> to transparently cross any region of null cells,
-the <b>null_cost</b>=<tt>0.0</tt> option should be used. Then null cells just
-propagate the adjacent costs. These cells can be retained as null cells in the
-output map by using the <b>-n</b> flag.
-<h2>NOTES</h2>
-<p>Sometimes, when the differences among integer cell category values in the
-<em>r.cost</em> cumulative cost surface output are small, this
-cumulative cost output cannot accurately be used as input to <em><a href="r.drain.html">r.drain</a></em>
-(<em><a href="r.drain.html">r.drain</a></em> will output bad
-results). This problem can be circumvented by making the differences
-between cell category values in the cumulative cost output bigger. It
-is recommended that, if the output from <em>r.cost</em> is to be used
-as input to <em><a href="r.drain.html">r.drain</a></em>, the user
-multiply the input cost surface map to <em>r.cost</em> by the value
-of the map's cell resolution, before running <em>r.cost</em>. This
-can be done using <em><a href="r.mapcalc.html">r.mapcalc</a></em>. The map
-resolution can be found using <em><a href="g.region.html">g.region</a></em>.
-This problem doesn't arise with floating point maps.
-<h4>Algorithm notes</h4>
-The fundamental approach to calculating minimum travel cost is as
-follows:<p> The user generates a raster map indicating the cost of
-traversing each cell in the north-south and east-west directions.
-This map, along with a set of starting points are submitted to
-<em>r.cost</em>. The starting points are put into a list cells from which
-costs to the adjacent cells are to be calculated. The cell on the
-list with the lowest cumulative cost is selected for computing costs to
-the neighboring cells. Costs are computed and those cells are put
-on the list and the originating cell is finalized. This process
-of selecting the lowest cumulative cost cell, computing costs to the
-neighbors, putting the neighbors on the list and removing the
-originating cell from the list continues until the list is empty.
-<p>
-The most time consuming aspect of this algorithm is the management of
-the list of cells for which cumulative costs have been at least
-initially computed. <em>r.cost</em> uses a binary tree with an linked list
-at each node in the tree for efficiently holding cells with identical
-cumulative costs.
-<p>
-<em>r.cost</em>, like most all GRASS raster programs, is also made to be run on
-maps larger that can fit in available computer memory. As the
-algorithm works through the dynamic list of cells it can move almost
-randomly around the entire area. <em>r.cost</em> divides the entire area
-into a number of pieces and swaps these pieces in and out of memory (to
-and from disk) as needed. This provides a virtual memory approach
-optimally designed for 2-D raster maps.
-The amount of map to hold in memory at one time can be controlled with the
-<b>percent_memory</b> option. For large maps this value will have to be set
-to a lower value.
-<h2>EXAMPLES</h2>
-<p>Consider the following example:
-</p>
- Input:
- COST SURFACE
- . 2 . 2 . 1 . 1 . 5 . 5 . 5 .
- . 2 . 2 . 8 . 8 . 5 . 2 . 1 .
- . 7 . 1 . 1 . 8 . 2 . 2 . 2 .
- . 8 . 7 . 8 . 8 . 8 . 8 . 5 .
- . . . . . . . . . . _____ . .
- . 8 . 8 . 1 . 1 . 5 | <b>3</b> | 9 .
- . . . . . . . . . . |___| . .
- . 8 . 1 . 1 . 2 . 5 . 3 . 9 .
-Output (using -k): Output (not using -k):
- CUMULATIVE COST SURFACE CUMULATIVE COST SURFACE
- . . . . . . . . . . . . . . . . . . . <b>* * * * *</b> . . . . . .
- . 21. 21. 20. 19. 17. 15. 14. . 22. 21<b>* 21* 20*</b> 17. 15. 14.
- . 20. 19. 22. 19. 15. 12. 11. . 20. 19. 22<b>* 20*</b> 15. 12. 11.
- . . . . . . . . . . . . . . . . . . . . . <b>* * * * *</b> . . . .
- . 22. 18. 17. 17. 12. 11. 9. . 22. 18. 17<b>* 18* 13*</b> 11. 9.
- . 21. 14. 13. 12. 8. 6. 6. . 21. 14. 13. 12. 8. 6. 6.
- . . . . . . . . . . _____. . . . . . . . . . . . . . . . .
- . 16. 13. 8. 7. 4 | <b>0</b> | 6. . 16. 13. 8. 7 . 4. 0. 6.
- . . . . . . . . . . |___|. . . . . . . . . . . . . . . . .
- . 14. 9. 8. 9. 6. 3. 8. . 14. 9. 8. 9 . 6. 3. 8.
-</pre></div>
-<p>
-<!-- ??? are "starting" and "ending" swapped in the following text ??? -->
-The user-provided ending location in the above example is the boxed <b>3</b>
-in the above input map. The costs in the output map represent the total
-cost of moving from each box ("cell") to one or more (here,
-only one) starting location(s). Cells surrounded by asterisks are
-those that are different between operations using and not using the
-Knight's move (<b>-k</b>) option.
-<h4>Output analysis</h4>
-The output map can be viewed, for example, as an elevation model in which
-the starting location(s) is/are the lowest point(s). Outputs from <em>r.cost</em>
-can be used as inputs to <em><a href="r.drain.html">r.drain</a></em>, in order
-to trace the least-cost path given by this model between any given cell
-and the <em>r.cost</em> starting location(s). The two programs, when
-used together, generate least-cost paths or corridors between any two
-map locations (cells).
-<h4>Shortest distance surfaces</h4>
-The <em>r.cost</em> module allows for computing the shortest distance
-of each pixel from raster lines, such as determining the shortest distances
-of households to the nearby road. For this cost surfaces with cost value 1 are
-used. The calculation is done with <em>r.cost</em> as follows
-(example for Spearfish region):
- g.region rast=roads -p
- r.mapcalc "area.one=1"
- r.cost -k input=area.one output=distance start_rast=roads
- d.rast distance
- d.rast.num distance
- #transform to metric distance from cell distance using the raster resolution:
- r.mapcalc "dist_meters=distance * (ewres()+nsres())/2."
- d.rast dist_meters
-</pre></div>
-<h2>BUGS</h2>
-The percentage done calculation reported in verbose mode is often not linear
-and ends well before 100%. This does not affect output.
-<h2>SEE ALSO</h2>
-<em><a href="r.drain.html">r.drain</a></em>,
-<em><a href="r.walk.html">r.walk</a></em>,
-<em><a href="r.in.ascii.html">r.in.ascii</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.out.ascii.html">r.out.ascii</a></em>
-<h2>AUTHOR</h2>
-Antony Awaida,<br>
-Intelligent Engineering<br>
-Systems Laboratory,<br>
-M.I.T.<br>
-<br>
-U.S.Army Construction Engineering Research Laboratory
-<p>Updated for Grass 5<br>
-Pierre de Mouveaux (pmx at audiovu.com)
-</p>
Copied: grass/trunk/raster/r.cost/r.cost.html (from rev 32770, grass/trunk/raster/r.cost/description.html)
--- grass/trunk/raster/r.cost/r.cost.html (rev 0)
+++ grass/trunk/raster/r.cost/r.cost.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,260 @@
+<p><em>r.cost</em> determines the cumulative cost of moving to each
+cell on a <em>cost surface</em> (the <b>input</b> raster map) from
+other user-specified cell(s) whose locations are specified by their
+geographic coordinate(s). Each cell in the original cost surface map
+will contain a category value which represents the cost of traversing
+that cell. <em>r.cost</em> will produce an <b>output</b> raster map in
+which each cell contains the lowest total cost of traversing the
+space between each cell and the user-specified points. (Diagonal
+costs are multiplied by a factor that depends on the dimensions of
+the cell.) This program uses the current geographic region settings.
+The <b>output</b> map will be of the same data format as the <b>input</b>
+map, integer or floating point.</p>
+<h2>OPTIONS</h2>
+The <b>input</b> <em>name</em> is the name of a raster map whose category values
+represent the surface cost. The <b>output</b> <em>name</em> is the name of the
+resultant raster map of cumulative cost.
+<p>
+<em>r.cost</em> can be run with three different methods of identifying the
+starting point(s). One or more points (geographic coordinate pairs) can be
+provided as specified <b>coordinate</b>s on the command line, from a vector
+points file, or from a raster map.
+All non-NULL cells are considered to be starting points.
+Each <em>x,y</em> <b>coordinate</b> pair gives the geographic location of a
+point from which the transportation cost should be figured. As many points as
+desired can be entered by the user. These starting points can also be read
+from a vector points file through the <b>start_sites</b> option or from a
+raster map through the <b>start_rast</b> option.
+<p>
+<em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
+or one of the stop points given with <b>stop_coordinates</b> is reached.
+Alternatively, the stop points can be read from a vector points file with the
+<b>stop_sites</b> option. During execution, once the cumulative cost to all
+stopping points has been determined, processing stops.
+Both sites read from a vector points file and those given on the command line
+will be processed.
+<p>
+The null cells in the <b>input</b> map can be assigned a (positive floating
+point) cost with the <b>null_cost</b> option.
+<br>
+When input map null cells are given a cost with the <b>null_cost</b>
+option, the corresponding cells in the output map are no longer null
+cells. By using the <b>-n</b> flag, the null cells of the input map are
+retained as null cells in the output map.</p>
+<p>
+As <em>r.cost</em> can run for a very long time, it can be useful to
+use the <b>-v</b> verbose flag to track progress.
+<p>
+The Knight's move (<b>-k</b> flag) may be used to improve the accuracy of
+the output. In the diagram below, the center location (<tt>O</tt>) represents a
+grid cell from which cumulative distances are calculated. Those
+neighbors marked with an <tt>X</tt> are always considered for cumulative cost
+updates. With the <b>-k</b> option, the neighbors marked with a <tt>K</tt> are
+also considered.
+</p>
+ . . . K . . K . . .
+ . . K . X . X . X . K . .
+ . . . X . O . X . . .
+</pre></div>
+<br>
+Knight's move example:
+<center>
+<img src=rcost_knightsmove.png border=1><br>
+<table border=0 width=590>
+<tr><td><center>
+<i>Flat cost surface without (left pane) and with the knight's move (right pane).
+The default is to grow the cost outwards in 8 directions.
+Using the knight's move grows it outwards in 16 directions.</i>
+</center></td></tr>
+</table>
+</center>
+<h2>NULL CELLS</h2>
+<p>By default null cells in the input raster map are excluded from
+the algorithm, and thus retained in the output map.
+<p>
+If one wants <b>r.cost</b> to transparently cross any region of null cells,
+the <b>null_cost</b>=<tt>0.0</tt> option should be used. Then null cells just
+propagate the adjacent costs. These cells can be retained as null cells in the
+output map by using the <b>-n</b> flag.
+<h2>NOTES</h2>
+<p>Sometimes, when the differences among integer cell category values in the
+<em>r.cost</em> cumulative cost surface output are small, this
+cumulative cost output cannot accurately be used as input to <em><a href="r.drain.html">r.drain</a></em>
+(<em><a href="r.drain.html">r.drain</a></em> will output bad
+results). This problem can be circumvented by making the differences
+between cell category values in the cumulative cost output bigger. It
+is recommended that, if the output from <em>r.cost</em> is to be used
+as input to <em><a href="r.drain.html">r.drain</a></em>, the user
+multiply the input cost surface map to <em>r.cost</em> by the value
+of the map's cell resolution, before running <em>r.cost</em>. This
+can be done using <em><a href="r.mapcalc.html">r.mapcalc</a></em>. The map
+resolution can be found using <em><a href="g.region.html">g.region</a></em>.
+This problem doesn't arise with floating point maps.
+<h4>Algorithm notes</h4>
+The fundamental approach to calculating minimum travel cost is as
+follows:<p> The user generates a raster map indicating the cost of
+traversing each cell in the north-south and east-west directions.
+This map, along with a set of starting points are submitted to
+<em>r.cost</em>. The starting points are put into a list cells from which
+costs to the adjacent cells are to be calculated. The cell on the
+list with the lowest cumulative cost is selected for computing costs to
+the neighboring cells. Costs are computed and those cells are put
+on the list and the originating cell is finalized. This process
+of selecting the lowest cumulative cost cell, computing costs to the
+neighbors, putting the neighbors on the list and removing the
+originating cell from the list continues until the list is empty.
+<p>
+The most time consuming aspect of this algorithm is the management of
+the list of cells for which cumulative costs have been at least
+initially computed. <em>r.cost</em> uses a binary tree with an linked list
+at each node in the tree for efficiently holding cells with identical
+cumulative costs.
+<p>
+<em>r.cost</em>, like most all GRASS raster programs, is also made to be run on
+maps larger that can fit in available computer memory. As the
+algorithm works through the dynamic list of cells it can move almost
+randomly around the entire area. <em>r.cost</em> divides the entire area
+into a number of pieces and swaps these pieces in and out of memory (to
+and from disk) as needed. This provides a virtual memory approach
+optimally designed for 2-D raster maps.
+The amount of map to hold in memory at one time can be controlled with the
+<b>percent_memory</b> option. For large maps this value will have to be set
+to a lower value.
+<h2>EXAMPLES</h2>
+<p>Consider the following example:
+</p>
+ Input:
+ COST SURFACE
+ . 2 . 2 . 1 . 1 . 5 . 5 . 5 .
+ . 2 . 2 . 8 . 8 . 5 . 2 . 1 .
+ . 7 . 1 . 1 . 8 . 2 . 2 . 2 .
+ . 8 . 7 . 8 . 8 . 8 . 8 . 5 .
+ . . . . . . . . . . _____ . .
+ . 8 . 8 . 1 . 1 . 5 | <b>3</b> | 9 .
+ . . . . . . . . . . |___| . .
+ . 8 . 1 . 1 . 2 . 5 . 3 . 9 .
+Output (using -k): Output (not using -k):
+ CUMULATIVE COST SURFACE CUMULATIVE COST SURFACE
+ . . . . . . . . . . . . . . . . . . . <b>* * * * *</b> . . . . . .
+ . 21. 21. 20. 19. 17. 15. 14. . 22. 21<b>* 21* 20*</b> 17. 15. 14.
+ . 20. 19. 22. 19. 15. 12. 11. . 20. 19. 22<b>* 20*</b> 15. 12. 11.
+ . . . . . . . . . . . . . . . . . . . . . <b>* * * * *</b> . . . .
+ . 22. 18. 17. 17. 12. 11. 9. . 22. 18. 17<b>* 18* 13*</b> 11. 9.
+ . 21. 14. 13. 12. 8. 6. 6. . 21. 14. 13. 12. 8. 6. 6.
+ . . . . . . . . . . _____. . . . . . . . . . . . . . . . .
+ . 16. 13. 8. 7. 4 | <b>0</b> | 6. . 16. 13. 8. 7 . 4. 0. 6.
+ . . . . . . . . . . |___|. . . . . . . . . . . . . . . . .
+ . 14. 9. 8. 9. 6. 3. 8. . 14. 9. 8. 9 . 6. 3. 8.
+</pre></div>
+<p>
+<!-- ??? are "starting" and "ending" swapped in the following text ??? -->
+The user-provided ending location in the above example is the boxed <b>3</b>
+in the above input map. The costs in the output map represent the total
+cost of moving from each box ("cell") to one or more (here,
+only one) starting location(s). Cells surrounded by asterisks are
+those that are different between operations using and not using the
+Knight's move (<b>-k</b>) option.
+<h4>Output analysis</h4>
+The output map can be viewed, for example, as an elevation model in which
+the starting location(s) is/are the lowest point(s). Outputs from <em>r.cost</em>
+can be used as inputs to <em><a href="r.drain.html">r.drain</a></em>, in order
+to trace the least-cost path given by this model between any given cell
+and the <em>r.cost</em> starting location(s). The two programs, when
+used together, generate least-cost paths or corridors between any two
+map locations (cells).
+<h4>Shortest distance surfaces</h4>
+The <em>r.cost</em> module allows for computing the shortest distance
+of each pixel from raster lines, such as determining the shortest distances
+of households to the nearby road. For this cost surfaces with cost value 1 are
+used. The calculation is done with <em>r.cost</em> as follows
+(example for Spearfish region):
+ g.region rast=roads -p
+ r.mapcalc "area.one=1"
+ r.cost -k input=area.one output=distance start_rast=roads
+ d.rast distance
+ d.rast.num distance
+ #transform to metric distance from cell distance using the raster resolution:
+ r.mapcalc "dist_meters=distance * (ewres()+nsres())/2."
+ d.rast dist_meters
+</pre></div>
+<h2>BUGS</h2>
+The percentage done calculation reported in verbose mode is often not linear
+and ends well before 100%. This does not affect output.
+<h2>SEE ALSO</h2>
+<em><a href="r.drain.html">r.drain</a></em>,
+<em><a href="r.walk.html">r.walk</a></em>,
+<em><a href="r.in.ascii.html">r.in.ascii</a></em>,
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a href="r.out.ascii.html">r.out.ascii</a></em>
+<h2>AUTHOR</h2>
+Antony Awaida,<br>
+Intelligent Engineering<br>
+Systems Laboratory,<br>
+M.I.T.<br>
+<br>
+U.S.Army Construction Engineering Research Laboratory
+<p>Updated for Grass 5<br>
+Pierre de Mouveaux (pmx at audiovu.com)
+</p>
Deleted: grass/trunk/raster/r.covar/description.html
--- grass/trunk/raster/r.covar/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.covar/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,96 +0,0 @@
-<em>r.covar</em> outputs a covariance/correlation matrix for user-specified
-raster map layer(s). The output can be printed, or saved by redirecting
-output into a file.
-<p>
-The output is an N x N symmetric covariance (correlation) matrix,
-where N is the number of raster map layers specified on the command line.
-<h2>NOTES</h2>
-This module can be used as the first step of a principle components
-transformation.
-The covariance matrix would be input into a system which determines
-eigen values and eigen vectors. An NxN covariance matrix would result in
-N real eigen values and N eigen vectors (each composed of N real numbers).
-<p>
-The module <em><a href="m.eigensystem.html">m.eigensystem</a></em> in
-src.contrib can be compiled and used to generate the eigen values and
-vectors.
-<h2>EXAMPLE</h2>
-For example,
-<dl>
-<dd>
-<b>r.covar</b> map=</b><em>layer.1</em>,<em>layer.2</em>,<em>layer.3</em>
-</dl>
-would produce a 3x3 matrix (values are example only):
-<pre>
- 1.000000 0.914922 0.889581
- 0.914922 1.000000 0.939452
- 0.889581 0.939452 1.000000
-</pre>
-In the above example, the eigen values and corresponding eigen vectors
-for the covariance matrix are:
-<pre>
-component eigen value eigen vector
- 1 1159.745202 < 0.691002 0.720528 0.480511 >
- 2 5.970541 < 0.711939 -0.635820 -0.070394 >
- 3 146.503197 < 0.226584 0.347470 -0.846873 >
-</pre>
-The component corresponding to each vector can be produced using
-as follows:
-<dl>
-<dd>
-<b>r.mapcalc</b> 'pc.1 = 0.691002*layer.1 + 0.720528*layer.2 + 0.480511*layer.3'
-<br>
-<b>r.mapcalc</b> 'pc.2 = 0.711939*layer.1 - 0.635820*layer.2 - 0.070394*layer.3'
-<br>
-<b>r.mapcalc</b> 'pc.3 = 0.226584*layer.1 + 0.347470*layer.2 - 0.846873*layer.3'
-</dl>
-Note that based on the relative sizes of the eigen values,
-<em>pc.1</em>
-will contain about 88% of the variance in the data set,
-<em>pc.2</em>
-will contain about 1% of the variance in the data set, and
-<em>pc.3</em>
-will contain about 11% of the variance in the data set.
-Also, note that the range of values produced in
-<em>pc.1</em>, <em>pc.2</em>, and <em>pc.3</em> will
-not (in general) be the same as those for
-<em>layer.1</em>, <em>layer.2</em>, and <em>layer.3</em>.
-It may be necessary to rescale
-<em>pc.1</em>, <em>pc.2</em> and <em>pc.3</em> to
-the desired range (e.g. 0-255).
-This can be done with <em><a href="r.rescale.html">r.rescale</a></em>.
-<h2>SEE ALSO</h2>
-<em><a href="i.pca.html">i.pca</a></em>,
-<em><a href="m.eigensystem.html">m.eigensystem</a></em>,
-<em><a href="r.rescale.html">r.rescale</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.covar/r.covar.html (from rev 32770, grass/trunk/raster/r.covar/description.html)
--- grass/trunk/raster/r.covar/r.covar.html (rev 0)
+++ grass/trunk/raster/r.covar/r.covar.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,96 @@
+<em>r.covar</em> outputs a covariance/correlation matrix for user-specified
+raster map layer(s). The output can be printed, or saved by redirecting
+output into a file.
+<p>
+The output is an N x N symmetric covariance (correlation) matrix,
+where N is the number of raster map layers specified on the command line.
+<h2>NOTES</h2>
+This module can be used as the first step of a principle components
+transformation.
+The covariance matrix would be input into a system which determines
+eigen values and eigen vectors. An NxN covariance matrix would result in
+N real eigen values and N eigen vectors (each composed of N real numbers).
+<p>
+The module <em><a href="m.eigensystem.html">m.eigensystem</a></em> in
+src.contrib can be compiled and used to generate the eigen values and
+vectors.
+<h2>EXAMPLE</h2>
+For example,
+<dl>
+<dd>
+<b>r.covar</b> map=</b><em>layer.1</em>,<em>layer.2</em>,<em>layer.3</em>
+</dl>
+would produce a 3x3 matrix (values are example only):
+<pre>
+ 1.000000 0.914922 0.889581
+ 0.914922 1.000000 0.939452
+ 0.889581 0.939452 1.000000
+</pre>
+In the above example, the eigen values and corresponding eigen vectors
+for the covariance matrix are:
+<pre>
+component eigen value eigen vector
+ 1 1159.745202 < 0.691002 0.720528 0.480511 >
+ 2 5.970541 < 0.711939 -0.635820 -0.070394 >
+ 3 146.503197 < 0.226584 0.347470 -0.846873 >
+</pre>
+The component corresponding to each vector can be produced using
+as follows:
+<dl>
+<dd>
+<b>r.mapcalc</b> 'pc.1 = 0.691002*layer.1 + 0.720528*layer.2 + 0.480511*layer.3'
+<br>
+<b>r.mapcalc</b> 'pc.2 = 0.711939*layer.1 - 0.635820*layer.2 - 0.070394*layer.3'
+<br>
+<b>r.mapcalc</b> 'pc.3 = 0.226584*layer.1 + 0.347470*layer.2 - 0.846873*layer.3'
+</dl>
+Note that based on the relative sizes of the eigen values,
+<em>pc.1</em>
+will contain about 88% of the variance in the data set,
+<em>pc.2</em>
+will contain about 1% of the variance in the data set, and
+<em>pc.3</em>
+will contain about 11% of the variance in the data set.
+Also, note that the range of values produced in
+<em>pc.1</em>, <em>pc.2</em>, and <em>pc.3</em> will
+not (in general) be the same as those for
+<em>layer.1</em>, <em>layer.2</em>, and <em>layer.3</em>.
+It may be necessary to rescale
+<em>pc.1</em>, <em>pc.2</em> and <em>pc.3</em> to
+the desired range (e.g. 0-255).
+This can be done with <em><a href="r.rescale.html">r.rescale</a></em>.
+<h2>SEE ALSO</h2>
+<em><a href="i.pca.html">i.pca</a></em>,
+<em><a href="m.eigensystem.html">m.eigensystem</a></em>,
+<em><a href="r.rescale.html">r.rescale</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.cross/description.html
--- grass/trunk/raster/r.cross/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.cross/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,109 +0,0 @@
-<em>r.cross</em> creates an <em>output</em> raster map layer representing
-all unique combinations of category values in the raster input layers
-(<b>input=</b><em>name,name,name</em>, ...). At least two, but not more than
-ten, <em>input</em> map layers must be specified. The user must also
-specify a name to be assigned to the <em>output</em> raster map layer
-created by <em>r.cross</em>.
-<h2>OPTIONS</h2>
-The program will be run non-interactively if the user specifies
-the names of between 2-10 raster map layers be used as <em>input</em>,
-and the name of a raster map layer to hold program <em>output</em>.
-<p>
-With the <b>-z</b> flag zero data values are not crossed.
-This means that if a zero category value occurs in any input data layer,
-the combination is assigned to category zero in the resulting map layer,
-even if other data layers contain non-zero data.
-In the example given above, use of the <b>-z</b> option
-would cause 3 categories to be generated instead of 5.
-<p>
-If the <b>-z</b> flag is not specified, then map layer combinations
-in which not all category values are zero will be assigned
-a unique category value in the resulting map layer.
-<p>
-Category values in the new <em>output</em> map layer will be the
-cross-product of the category values from these existing <em>input</em> map
-layers.
-<h2>EXAMPLE</h2>
-For example, suppose that, using two raster map layers,
-the following combinations occur:
- map1 map2
- ___________
- 0 1
- 0 2
- 1 1
- 1 2
- 2 4
-</pre></div>
-<em>r.cross</em> would produce a new raster map layer with 5 categories:
- map1 map2 output
- ____________________
- 0 1 1
- 0 2 2
- 1 1 3
- 1 2 4
- 2 4 5
-</pre></div>
-Note: The actual category value assigned to a particular combination
-in the <em>result</em> map layer is
-dependent on the order in which the combinations occur in the input map
-layer data and can be considered essentially random.
-The example given here is illustrative only.
-<h2>SUPPORT FILES</h2>
-The category file created for the <em>output</em> raster map
-layer describes the
-combinations of input map layer category values which generated
-each category.
-In the above example, the category labels would be:
- category category
- value label
- ______________________________
- 1 layer1(0) layer2(1)
- 2 layer1(0) layer2(2)
- 3 layer1(1) layer2(1)
- 4 layer1(1) layer2(2)
- 5 layer1(2) layer2(4)
-</pre></div>
-A random color table is also generated for the <em>output</em> map layer.
-<h2>NOTES</h2>
-When run non-interactively, <em>r.cross</em> will not protect existing
-files in the user's mapset. If the user specifies an <em>output</em>
-file name that already exists in his mapset, the existing file will
-be overwritten by the new <em>r.cross</em> output.
-<h2>SEE ALSO</h2>
-<em><a href="r.covar.html">r.covar</a></em>,
-<em><a href="r.stats.html">r.stats</a></em>
-<h2>AUTHOR</h2>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.cross/r.cross.html (from rev 32770, grass/trunk/raster/r.cross/description.html)
--- grass/trunk/raster/r.cross/r.cross.html (rev 0)
+++ grass/trunk/raster/r.cross/r.cross.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,109 @@
+<em>r.cross</em> creates an <em>output</em> raster map layer representing
+all unique combinations of category values in the raster input layers
+(<b>input=</b><em>name,name,name</em>, ...). At least two, but not more than
+ten, <em>input</em> map layers must be specified. The user must also
+specify a name to be assigned to the <em>output</em> raster map layer
+created by <em>r.cross</em>.
+<h2>OPTIONS</h2>
+The program will be run non-interactively if the user specifies
+the names of between 2-10 raster map layers be used as <em>input</em>,
+and the name of a raster map layer to hold program <em>output</em>.
+<p>
+With the <b>-z</b> flag zero data values are not crossed.
+This means that if a zero category value occurs in any input data layer,
+the combination is assigned to category zero in the resulting map layer,
+even if other data layers contain non-zero data.
+In the example given above, use of the <b>-z</b> option
+would cause 3 categories to be generated instead of 5.
+<p>
+If the <b>-z</b> flag is not specified, then map layer combinations
+in which not all category values are zero will be assigned
+a unique category value in the resulting map layer.
+<p>
+Category values in the new <em>output</em> map layer will be the
+cross-product of the category values from these existing <em>input</em> map
+layers.
+<h2>EXAMPLE</h2>
+For example, suppose that, using two raster map layers,
+the following combinations occur:
+ map1 map2
+ ___________
+ 0 1
+ 0 2
+ 1 1
+ 1 2
+ 2 4
+</pre></div>
+<em>r.cross</em> would produce a new raster map layer with 5 categories:
+ map1 map2 output
+ ____________________
+ 0 1 1
+ 0 2 2
+ 1 1 3
+ 1 2 4
+ 2 4 5
+</pre></div>
+Note: The actual category value assigned to a particular combination
+in the <em>result</em> map layer is
+dependent on the order in which the combinations occur in the input map
+layer data and can be considered essentially random.
+The example given here is illustrative only.
+<h2>SUPPORT FILES</h2>
+The category file created for the <em>output</em> raster map
+layer describes the
+combinations of input map layer category values which generated
+each category.
+In the above example, the category labels would be:
+ category category
+ value label
+ ______________________________
+ 1 layer1(0) layer2(1)
+ 2 layer1(0) layer2(2)
+ 3 layer1(1) layer2(1)
+ 4 layer1(1) layer2(2)
+ 5 layer1(2) layer2(4)
+</pre></div>
+A random color table is also generated for the <em>output</em> map layer.
+<h2>NOTES</h2>
+When run non-interactively, <em>r.cross</em> will not protect existing
+files in the user's mapset. If the user specifies an <em>output</em>
+file name that already exists in his mapset, the existing file will
+be overwritten by the new <em>r.cross</em> output.
+<h2>SEE ALSO</h2>
+<em><a href="r.covar.html">r.covar</a></em>,
+<em><a href="r.stats.html">r.stats</a></em>
+<h2>AUTHOR</h2>
+<p>
Deleted: grass/trunk/raster/r.describe/description.html
--- grass/trunk/raster/r.describe/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.describe/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,109 +0,0 @@
-<em><b>r.describe</b></em> prints a terse listing of category values found in
-a user-specified raster map layer.
-<p>
-<em><b>r.describe</b></em> ignores the current geographic region and mask, and
-reads the full extent of the input raster map. This functionality is useful if the
-user intends to <em>reclassify</em> or <em>rescale</em> the data,
-since these functions (<em><a href="r.reclass.html">r.reclass</a></em> and
-<em><a href="r.rescale.html">r.rescale</a></em>)
-also ignore the current <em>geographic region</em>
-and <em>mask</em>.
-<p>
-The <em><b>nv</b></em> parameter sets the string to be used to represent <tt>NULL</tt>
-values in the module output; the default is '*'.
-<p>
-The <em><b>nsteps</b></em> parameter sets the number of quantisation steps to divide into
-the input raster map.
-<h2>NOTES</h2>
-<h3>FLAGS</h3>
-If the user selects the <b>-r</b> flag, a range of category values found in
-the raster map layer will be printed. The range is divided into three groups:
-negative, positive, and zero. If negative values occur, the minimum and maximum
-negative values will be printed. If positive values occur, the minimum and maximum
-positive values will be printed. If zero occurs, this will be indicated. The range
-report will generally run faster than the full list (the default output).
-<p>
-The <b>-d</b> flag can be used to force <em>r.describe</em> to respect the current region
-extents when repoting raster map categories. The default behavior is to read the full
-extent of the input raster map.
-<p>
-If the <b>-1</b> flag is specified, the output appears with one category value/range per line.
-<p>
-The <b>-n</b> flag suppresses the reporting of <tt>NULL</tt> values.
-<h2>EXAMPLES</h2>
-The following examples are from the Spearfish60 sample Location:
-<p>
-# Print the full list of raster map categories:
-r.describe landcover.30m
-* 11 21-23 31 32 41-43 51 71 81-83 85 91 92
-</pre></div>
-<p>
-# Print the raster range only:
-r.describe -r landcover.30m
-11 thru 92
-</pre></div>
-# Print raster map category range, suppressing nulls:
-r.describe -n landcover.30m
-11 21-23 31 32 41-43 51 71 81-83 85 91 92
-</pre></div>
-<p>
-# Print raster map categories, one category per line:
-r.describe -1 geology
-1
-2
-3
-4
-5
-6
-7
-8
-9
-</pre></div>
-<p>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="r.mask.html">r.mask</a>,
-<a href="r.reclass.html">r.reclass</a>,
-<a href="r.report.html">r.report</a>,
-<a href="r.rescale.html">r.rescale</a>,
-<a href="r.stats.html">r.stats</a>,
-<a href="r.univar.html">r.univar</a>
-</em>
-<h2>AUTHOR</h2>
-<p>
Copied: grass/trunk/raster/r.describe/r.describe.html (from rev 32770, grass/trunk/raster/r.describe/description.html)
--- grass/trunk/raster/r.describe/r.describe.html (rev 0)
+++ grass/trunk/raster/r.describe/r.describe.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,109 @@
+<h2>DESCRIPTION</h2>
+<em><b>r.describe</b></em> prints a terse listing of category values found in
+a user-specified raster map layer.
+<p>
+<em><b>r.describe</b></em> ignores the current geographic region and mask, and
+reads the full extent of the input raster map. This functionality is useful if the
+user intends to <em>reclassify</em> or <em>rescale</em> the data,
+since these functions (<em><a href="r.reclass.html">r.reclass</a></em> and
+<em><a href="r.rescale.html">r.rescale</a></em>)
+also ignore the current <em>geographic region</em>
+and <em>mask</em>.
+<p>
+The <em><b>nv</b></em> parameter sets the string to be used to represent <tt>NULL</tt>
+values in the module output; the default is '*'.
+<p>
+The <em><b>nsteps</b></em> parameter sets the number of quantisation steps to divide into
+the input raster map.
+<h2>NOTES</h2>
+<h3>FLAGS</h3>
+If the user selects the <b>-r</b> flag, a range of category values found in
+the raster map layer will be printed. The range is divided into three groups:
+negative, positive, and zero. If negative values occur, the minimum and maximum
+negative values will be printed. If positive values occur, the minimum and maximum
+positive values will be printed. If zero occurs, this will be indicated. The range
+report will generally run faster than the full list (the default output).
+<p>
+The <b>-d</b> flag can be used to force <em>r.describe</em> to respect the current region
+extents when repoting raster map categories. The default behavior is to read the full
+extent of the input raster map.
+<p>
+If the <b>-1</b> flag is specified, the output appears with one category value/range per line.
+<p>
+The <b>-n</b> flag suppresses the reporting of <tt>NULL</tt> values.
+<h2>EXAMPLES</h2>
+The following examples are from the Spearfish60 sample Location:
+<p>
+# Print the full list of raster map categories:
+r.describe landcover.30m
+* 11 21-23 31 32 41-43 51 71 81-83 85 91 92
+</pre></div>
+<p>
+# Print the raster range only:
+r.describe -r landcover.30m
+11 thru 92
+</pre></div>
+# Print raster map category range, suppressing nulls:
+r.describe -n landcover.30m
+11 21-23 31 32 41-43 51 71 81-83 85 91 92
+</pre></div>
+<p>
+# Print raster map categories, one category per line:
+r.describe -1 geology
+1
+2
+3
+4
+5
+6
+7
+8
+9
+</pre></div>
+<p>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.mask.html">r.mask</a>,
+<a href="r.reclass.html">r.reclass</a>,
+<a href="r.report.html">r.report</a>,
+<a href="r.rescale.html">r.rescale</a>,
+<a href="r.stats.html">r.stats</a>,
+<a href="r.univar.html">r.univar</a>
+</em>
+<h2>AUTHOR</h2>
+<p>
Deleted: grass/trunk/raster/r.digit/description.html
--- grass/trunk/raster/r.digit/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.digit/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,78 +0,0 @@
-The GRASS tool <em>r.digit</em> provides the user with a
-way to draw lines, areas, and circles on a monitor screen,
-and to save these features in a raster map. Lines, areas,
-and circles are to be drawn using a pointing device
-(mouse). A mouse button menu indicates the consequences of
-pressing each mouse button. The user is requested to enter
-the category number associated with the line, area, or
-circle subsequently drawn by the user. Lines, areas, and
-circles are defined by the series of points marked by the
-user inside the map window. <em>r.digit</em> will close
-areas when the user has not. By drawing a series of such
-features, the user can repair maps, identify areas of
-interest, or simply draw graphics for advertisement. When
-drawing is completed, a raster map based on the user's
-instructions is generated. It is available for use as a
-mask, in analyses, and for display.
-<p>
-The <b>bgcmd</b> option is intended to be used with display (d.*) commands.
-If several display commands are to be used to render the background
-they should be separated with the semi-colon ';' character.
-When run from the command line, these display commands will generally
-need to be "quoted" as they will contain spaces (see examples).
-<p>
-Digitizing is done in a "polygon" method. Each area is
-circumscribed completely. Two or more overlapping areas and/or lines
-might define a single part of a map. Each part of the map,
-however, is assigned only the LAST area or line which
-covered it.
-<h3>THE PROCESS:</h3>
-<h4>Start a monitor and display a raster to help setup and zoom to area of interest</h4>
-d.mon x0
-</pre></div>
-<p>
-<h4>Digitizing an area based on a existing map; creating a new raster map</h4>
-r.digit out=name_of_new_raster_map bgcmd="d.rast map=name_of_raster"
-</pre></div>
-<ol>
-<li>Choose to define an area or line, exit, or quit.
-If you choose to finish (<tt>exit</tt>) a new map is then created.
-If you quit, the session exits with nothing created.
-<li>If you choose to make an area or line you must identify
-the category number for that area or line.
-<li>Using the mouse trace the line or circumscribe the area;
-or, finish (go to Step 1).
-</ol>
-<h2>SEE ALSO</h2>
-<em><a href="v.digit.html">v.digit</a></em>,
-<em><a href="d.graph.html">d.graph</a></em>,
-<em><a href="d.linegraph.html">d.linegraph</a></em>,
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.in.poly.html">r.in.poly</a></em>,
-<em><a href="r.to.vect.html">r.to.vect</a></em>,
-<em><a href="v.in.ascii.html">v.in.ascii</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro, U.S.Army Construction Engineering
-Research Laboratory
Copied: grass/trunk/raster/r.digit/r.digit.html (from rev 32770, grass/trunk/raster/r.digit/description.html)
--- grass/trunk/raster/r.digit/r.digit.html (rev 0)
+++ grass/trunk/raster/r.digit/r.digit.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,78 @@
+The GRASS tool <em>r.digit</em> provides the user with a
+way to draw lines, areas, and circles on a monitor screen,
+and to save these features in a raster map. Lines, areas,
+and circles are to be drawn using a pointing device
+(mouse). A mouse button menu indicates the consequences of
+pressing each mouse button. The user is requested to enter
+the category number associated with the line, area, or
+circle subsequently drawn by the user. Lines, areas, and
+circles are defined by the series of points marked by the
+user inside the map window. <em>r.digit</em> will close
+areas when the user has not. By drawing a series of such
+features, the user can repair maps, identify areas of
+interest, or simply draw graphics for advertisement. When
+drawing is completed, a raster map based on the user's
+instructions is generated. It is available for use as a
+mask, in analyses, and for display.
+<p>
+The <b>bgcmd</b> option is intended to be used with display (d.*) commands.
+If several display commands are to be used to render the background
+they should be separated with the semi-colon ';' character.
+When run from the command line, these display commands will generally
+need to be "quoted" as they will contain spaces (see examples).
+<p>
+Digitizing is done in a "polygon" method. Each area is
+circumscribed completely. Two or more overlapping areas and/or lines
+might define a single part of a map. Each part of the map,
+however, is assigned only the LAST area or line which
+covered it.
+<h3>THE PROCESS:</h3>
+<h4>Start a monitor and display a raster to help setup and zoom to area of interest</h4>
+d.mon x0
+</pre></div>
+<p>
+<h4>Digitizing an area based on a existing map; creating a new raster map</h4>
+r.digit out=name_of_new_raster_map bgcmd="d.rast map=name_of_raster"
+</pre></div>
+<ol>
+<li>Choose to define an area or line, exit, or quit.
+If you choose to finish (<tt>exit</tt>) a new map is then created.
+If you quit, the session exits with nothing created.
+<li>If you choose to make an area or line you must identify
+the category number for that area or line.
+<li>Using the mouse trace the line or circumscribe the area;
+or, finish (go to Step 1).
+</ol>
+<h2>SEE ALSO</h2>
+<em><a href="v.digit.html">v.digit</a></em>,
+<em><a href="d.graph.html">d.graph</a></em>,
+<em><a href="d.linegraph.html">d.linegraph</a></em>,
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.in.poly.html">r.in.poly</a></em>,
+<em><a href="r.to.vect.html">r.to.vect</a></em>,
+<em><a href="v.in.ascii.html">v.in.ascii</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S.Army Construction Engineering
+Research Laboratory
Deleted: grass/trunk/raster/r.distance/description.html
--- grass/trunk/raster/r.distance/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.distance/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,67 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.distance</em> locates the closest points between "objects" in two raster maps. An
-"object" is defined as all the grid cells that have the same category
-number, and closest means having the shortest "straight-line" distance.
-The cell centers are considered for the distance calculation (two
-adjacent grid cells have the distance between their cell centers).
-<p>
-The output is an ascii list, one line per pair of objects, in the following form:
-<div class="code"><pre>
-cat1:cat2:distance:east1:north1:east2:north2
-</pre></div>
-<dl>
-<dt><b>cat1</b>
-<dd>Category number from map1
-<dt><b>cat2</b>
-<dd>Category number from map2
-<dt><b>distance</b>
-<dd>The distance in meters between "cat1" and "cat2"
-<dt><b>east1,north1</b>
-<dd>The coordinates of the grid cell "cat1" which is closest to "cat2"
-<dt><b>east2,north2</b>
-<dd>The coordinates of the grid cell "cat2" which is closest to "cat1"
-</dl>
-<h3>Flags</h3>
-<b>-l</b>
-The -l flag outputs the category labels of the matched raster objects at the
-beginning of the line, if they exist.
-<p>
-<b>-o</b>
-The -o flag reports zero distance if the input rasters are overlapping.
-<p>
-<h2>NOTES</h2>
-The output format lends itself to filtering. For example, to "see" lines
-connecting each of the category pairs in two maps, filter the output using
-awk and then into <em>d.graph</em>:
-<p>
-<div class="code"><pre>r.distance maps=map1,map2 | \
-awk -F: '{print "move",$4,$5,"\ndraw",$6,$7}' | d.graph -m</pre></div>
-<p>
-To create a vector map of all the "map1" coordinates, filter the output into
-awk and then into <em>v.in.ascii</em>:
-<p>
-<br>awk -F: '{print $4,$5}' | v.in.ascii format=point output=name fs=space</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="r.buffer.html">r.buffer</a></em>,
-<em><a href="r.cost.html">r.cost</a></em>,
-<em><a href="v.distance.html">v.distance</a></em>
-<h2>AUTHOR</h2>
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/raster/r.distance/r.distance.html (from rev 32770, grass/trunk/raster/r.distance/description.html)
--- grass/trunk/raster/r.distance/r.distance.html (rev 0)
+++ grass/trunk/raster/r.distance/r.distance.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,67 @@
+<em>r.distance</em> locates the closest points between "objects" in two raster maps. An
+"object" is defined as all the grid cells that have the same category
+number, and closest means having the shortest "straight-line" distance.
+The cell centers are considered for the distance calculation (two
+adjacent grid cells have the distance between their cell centers).
+<p>
+The output is an ascii list, one line per pair of objects, in the following form:
+<div class="code"><pre>
+cat1:cat2:distance:east1:north1:east2:north2
+</pre></div>
+<dl>
+<dt><b>cat1</b>
+<dd>Category number from map1
+<dt><b>cat2</b>
+<dd>Category number from map2
+<dt><b>distance</b>
+<dd>The distance in meters between "cat1" and "cat2"
+<dt><b>east1,north1</b>
+<dd>The coordinates of the grid cell "cat1" which is closest to "cat2"
+<dt><b>east2,north2</b>
+<dd>The coordinates of the grid cell "cat2" which is closest to "cat1"
+</dl>
+<h3>Flags</h3>
+<b>-l</b>
+The -l flag outputs the category labels of the matched raster objects at the
+beginning of the line, if they exist.
+<p>
+<b>-o</b>
+The -o flag reports zero distance if the input rasters are overlapping.
+<p>
+<h2>NOTES</h2>
+The output format lends itself to filtering. For example, to "see" lines
+connecting each of the category pairs in two maps, filter the output using
+awk and then into <em>d.graph</em>:
+<p>
+<div class="code"><pre>r.distance maps=map1,map2 | \
+awk -F: '{print "move",$4,$5,"\ndraw",$6,$7}' | d.graph -m</pre></div>
+<p>
+To create a vector map of all the "map1" coordinates, filter the output into
+awk and then into <em>v.in.ascii</em>:
+<p>
+<br>awk -F: '{print $4,$5}' | v.in.ascii format=point output=name fs=space</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="r.buffer.html">r.buffer</a></em>,
+<em><a href="r.cost.html">r.cost</a></em>,
+<em><a href="v.distance.html">v.distance</a></em>
+<h2>AUTHOR</h2>
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/raster/r.drain/description.html
--- grass/trunk/raster/r.drain/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.drain/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,194 +0,0 @@
-<em>r.drain</em> traces a flow through a least-cost path in an elevation
-model. The <b>input</b> elevation surface (a raster map layer) might
-be a cumulative cost map generated by the
-<em><a href="r.cost.html">r.cost</a></em> program.
-The <b>output</b> result (also a raster map layer) will show one or more
-least-cost paths between each user-provided location(s) and the minima
-(low category values) in the <b>input</b> map. By default, the <b>output</b>
-will be an integer CELL map with <tt>1</tt> along the least cost path,
-and null cells elsewhere.
-<p>
-With the <b>-c</b> (<em>copy</em>) flag, the input map cell values are
-copied verbatim along the path. With the <b>-a</b> (<em>accumulate</em>)
-flag, the accumulated cell value from the starting point up to the current
-cell is written on output. With either the <b>-c</b> or the <b>-a</b> flags, the
-<b>output</b> map is created with the same cell type as the <b>input</b> map (integer,
-float or double).
-With the <b>-n</b> (<em>number</em>) flag, the cells are numbered consecutively from the
-starting point to the final point.
-The <b>-c</b>, <b>-a</b>, and <b>-n</b> flags are mutually incompatible.
-<p>
-The path is calculated by choosing the steeper "slope" between adjacent
-cells. The slope calculation accurately acounts for the variable scale in
-lat-lon projections.
-<p>
-The <b>coordinate</b> parameter consists of map E and N grid coordinates of
-a starting point. Each x,y pair is the easting and northing (respectively) of
-a starting point from which a least-cost corridor will be developed.
-The <b>vector_points</b> parameter can take multiple vector maps containing
-additional starting points.
-Up to 1024 starting points can be input from a combination of the
-<b>coordinate</b> and <b>vector_points</b> parameters.
-<h2>NOTES</h2>
-<em>r.drain</em> currently finds only the lowest point
-(the cell having the smallest category value) in the
-input file that can be reached through directly adjacent cells
-that are less than or equal in value to the cell reached immediately
-prior to it; therefore, it will not necessarily reach the lowest point
-in the input file. It currently finds <em>pits</em> in the data, rather
-than the lowest point in the entire input map. The <em>r.fill.dir</em>,
-<em>r.terraflow</em>, and <em>r.basins.fill</em> modules can be used to
-fill in subbasins prior to processing with <em>r.drain</em>.
-<p>
-<em>r.drain</em> will not give sane results at the region boundary. On outer rows
-and columns bordering the edge of the region, the flow direction is always directly out
-of the map. In this case, the user could try adjusting the region extents slightly with
-<em>g.region</em> to allow additional outlet paths for <em>r.drain</em>.
-<h2>EXAMPLES</h2>
-Consider the following example:
-Input: Output:
- ELEVATION SURFACE LEAST COST PATH
-. 20| 19| 17. 16. 17. 16. 16. . . 1 . 1 . 1 . . . .
-. . |___| . . . . . . . . . . . . . . . . . . . . . . . . .
-. 18. 18. 24. 18. 15. 12. 11. . . . . . 1 . . .
-. 22. 16. 16. 18. 10. 10. 10. . . . . . 1 . . .
-. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 1 . .
-. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 1 . .
-. 17. 9 . 8 . 7 . 8 . 6 .12 . . . . . . . . .
-</pre></div>
-<p>
-The user-provided starting location in the above example is
-the boxed <b>19</b> in the left-hand map. The path in the output
-shows the least-cost corridor for moving from the starting
-box to the lowest (smallest) possible point. This is the path a raindrop
-would take in this landscape.
-<p>
-With the <b>-c</b> <em>(copy)</em> flag, you get the following result:
-Input: Output:
-. 20| 19| 17. 16. 17. 16. 16. . . 19. 17. 16. . . .
-. 18. 18. 24. 18. 15. 12. 11. . . . . . 15. . .
-. 22. 16. 16. 18. 10. 10. 10. . . . . . 10. . .
-. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 8 . .
-. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 0 . .
-Note that the last <em>0</em> will not be put in the null values map.
-</pre></div>
-<p>
-With the <b>-a</b> <em>(accumulate)</em> flag, you get the following result:
-Input: Output:
-. 20| 19| 17. 16. 17. 16. 16. . . 19. 36. 52. . . .
-. 18. 18. 24. 18. 15. 12. 11. . . . . . 67. . .
-. 22. 16. 16. 18. 10. 10. 10. . . . . . 77. . .
-. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 85. .
-. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 85. .
-</pre></div>
-<p>
-With the <b>-n</b> <em>(number)</em> flag, you get the following result:
-Input: Output:
-. 20| 19| 17. 16. 17. 16. 16. . . 1 . 2 . 3 . . . .
-. 18. 18. 24. 18. 15. 12. 11. . . . . . 4 . . .
-. 22. 16. 16. 18. 10. 10. 10. . . . . . 5 . . .
-. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 6 . .
-. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 7 . .
-</pre></div>
-<p>
-<h2>BUGS</h2>
-<p>
-Sometimes, when the differences among integer cell category values in the
-<em><a href="r.cost.html">r.cost</a></em> cumulative cost surface output are
-small, this cumulative cost output cannot accurately be used as input to
-<em>r.drain</em> (<em>t.drain</em> will output bad results).
-This problem can be circumvented by making the differences
-is recommended that if the output from <em>r.cost</em> is to be used
-as input to <em>r.drain</em>, the user multiply the <em>r.cost</em>
-input cost surface map by the value of the map's cell resolution,
-before running <em>r.cost</em>. This can be done using
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>. The map resolution can be
-found using <em><a href="g.region.html">g.region</a></em>.
-<h2>SEE ALSO</h2>
-<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
-<em><a href="r.basins.fill.html">r.basins.fill</a></em>,
-<em><a href="r.terraflow.html">r.terraflow</a></em>,
-<h2>AUTHOR</h2>
-Completely rewritten by Roger S. Miller, 2001
-<p>
-July 2004 at WebValley 2004, error checking and vector points added by
-Matteo Franchi (Liceo Leonardo Da Vinci, Trento) and
-Roberto Flor (ITC-irst, Trento, Italy)
Copied: grass/trunk/raster/r.drain/r.drain.html (from rev 32770, grass/trunk/raster/r.drain/description.html)
--- grass/trunk/raster/r.drain/r.drain.html (rev 0)
+++ grass/trunk/raster/r.drain/r.drain.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,194 @@
+<em>r.drain</em> traces a flow through a least-cost path in an elevation
+model. The <b>input</b> elevation surface (a raster map layer) might
+be a cumulative cost map generated by the
+<em><a href="r.cost.html">r.cost</a></em> program.
+The <b>output</b> result (also a raster map layer) will show one or more
+least-cost paths between each user-provided location(s) and the minima
+(low category values) in the <b>input</b> map. By default, the <b>output</b>
+will be an integer CELL map with <tt>1</tt> along the least cost path,
+and null cells elsewhere.
+<p>
+With the <b>-c</b> (<em>copy</em>) flag, the input map cell values are
+copied verbatim along the path. With the <b>-a</b> (<em>accumulate</em>)
+flag, the accumulated cell value from the starting point up to the current
+cell is written on output. With either the <b>-c</b> or the <b>-a</b> flags, the
+<b>output</b> map is created with the same cell type as the <b>input</b> map (integer,
+float or double).
+With the <b>-n</b> (<em>number</em>) flag, the cells are numbered consecutively from the
+starting point to the final point.
+The <b>-c</b>, <b>-a</b>, and <b>-n</b> flags are mutually incompatible.
+<p>
+The path is calculated by choosing the steeper "slope" between adjacent
+cells. The slope calculation accurately acounts for the variable scale in
+lat-lon projections.
+<p>
+The <b>coordinate</b> parameter consists of map E and N grid coordinates of
+a starting point. Each x,y pair is the easting and northing (respectively) of
+a starting point from which a least-cost corridor will be developed.
+The <b>vector_points</b> parameter can take multiple vector maps containing
+additional starting points.
+Up to 1024 starting points can be input from a combination of the
+<b>coordinate</b> and <b>vector_points</b> parameters.
+<h2>NOTES</h2>
+<em>r.drain</em> currently finds only the lowest point
+(the cell having the smallest category value) in the
+input file that can be reached through directly adjacent cells
+that are less than or equal in value to the cell reached immediately
+prior to it; therefore, it will not necessarily reach the lowest point
+in the input file. It currently finds <em>pits</em> in the data, rather
+than the lowest point in the entire input map. The <em>r.fill.dir</em>,
+<em>r.terraflow</em>, and <em>r.basins.fill</em> modules can be used to
+fill in subbasins prior to processing with <em>r.drain</em>.
+<p>
+<em>r.drain</em> will not give sane results at the region boundary. On outer rows
+and columns bordering the edge of the region, the flow direction is always directly out
+of the map. In this case, the user could try adjusting the region extents slightly with
+<em>g.region</em> to allow additional outlet paths for <em>r.drain</em>.
+<h2>EXAMPLES</h2>
+Consider the following example:
+Input: Output:
+ ELEVATION SURFACE LEAST COST PATH
+. 20| 19| 17. 16. 17. 16. 16. . . 1 . 1 . 1 . . . .
+. . |___| . . . . . . . . . . . . . . . . . . . . . . . . .
+. 18. 18. 24. 18. 15. 12. 11. . . . . . 1 . . .
+. 22. 16. 16. 18. 10. 10. 10. . . . . . 1 . . .
+. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 1 . .
+. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 1 . .
+. 17. 9 . 8 . 7 . 8 . 6 .12 . . . . . . . . .
+</pre></div>
+<p>
+The user-provided starting location in the above example is
+the boxed <b>19</b> in the left-hand map. The path in the output
+shows the least-cost corridor for moving from the starting
+box to the lowest (smallest) possible point. This is the path a raindrop
+would take in this landscape.
+<p>
+With the <b>-c</b> <em>(copy)</em> flag, you get the following result:
+Input: Output:
+. 20| 19| 17. 16. 17. 16. 16. . . 19. 17. 16. . . .
+. 18. 18. 24. 18. 15. 12. 11. . . . . . 15. . .
+. 22. 16. 16. 18. 10. 10. 10. . . . . . 10. . .
+. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 8 . .
+. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 0 . .
+Note that the last <em>0</em> will not be put in the null values map.
+</pre></div>
+<p>
+With the <b>-a</b> <em>(accumulate)</em> flag, you get the following result:
+Input: Output:
+. 20| 19| 17. 16. 17. 16. 16. . . 19. 36. 52. . . .
+. 18. 18. 24. 18. 15. 12. 11. . . . . . 67. . .
+. 22. 16. 16. 18. 10. 10. 10. . . . . . 77. . .
+. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 85. .
+. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 85. .
+</pre></div>
+<p>
+With the <b>-n</b> <em>(number)</em> flag, you get the following result:
+Input: Output:
+. 20| 19| 17. 16. 17. 16. 16. . . 1 . 2 . 3 . . . .
+. 18. 18. 24. 18. 15. 12. 11. . . . . . 4 . . .
+. 22. 16. 16. 18. 10. 10. 10. . . . . . 5 . . .
+. 17. 15. 15. 15. 10. 8 . 8 . . . . . . . 6 . .
+. 24. 16. 8 . 7 . 8 . 0 .12 . . . . . . . 7 . .
+</pre></div>
+<p>
+<h2>BUGS</h2>
+<p>
+Sometimes, when the differences among integer cell category values in the
+<em><a href="r.cost.html">r.cost</a></em> cumulative cost surface output are
+small, this cumulative cost output cannot accurately be used as input to
+<em>r.drain</em> (<em>t.drain</em> will output bad results).
+This problem can be circumvented by making the differences
+is recommended that if the output from <em>r.cost</em> is to be used
+as input to <em>r.drain</em>, the user multiply the <em>r.cost</em>
+input cost surface map by the value of the map's cell resolution,
+before running <em>r.cost</em>. This can be done using
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>. The map resolution can be
+found using <em><a href="g.region.html">g.region</a></em>.
+<h2>SEE ALSO</h2>
+<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
+<em><a href="r.basins.fill.html">r.basins.fill</a></em>,
+<em><a href="r.terraflow.html">r.terraflow</a></em>,
+<h2>AUTHOR</h2>
+Completely rewritten by Roger S. Miller, 2001
+<p>
+July 2004 at WebValley 2004, error checking and vector points added by
+Matteo Franchi (Liceo Leonardo Da Vinci, Trento) and
+Roberto Flor (ITC-irst, Trento, Italy)
Deleted: grass/trunk/raster/r.fill.dir/description.html
--- grass/trunk/raster/r.fill.dir/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.fill.dir/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,106 +0,0 @@
-<em>r.fill.dir</em> filters and generates a depressionless
-elevation map and a flow direction map from a given raster elevation map.
-<h2>NOTES</h2>
-The <b>type</b> parameter is the type of format at which the user wishes to create
-the flow direction map. The <i>agnps</i> format gives category values from
-1-8, with 1 facing north and increasing values in the clockwise direction.
-The <i>answers</i> format gives category values from 0-360 degrees, with 0
-(360) facing east and values increasing in the counter clockwise direction
-at 45 degree increments. The <i>grass</i> format gives the same category
-values as the <em><a href="r.slope.aspect.html">r.slope.aspect</a></em>
-program.<p>
-The method adopted to filter the elevation map and rectify it is
-based on the paper titled "Software Tools to Extract Structure from Digital
-Elevation Data for Geographic Information System Analysis" by S.K. Jenson
-and J.O. Domingue (1988).
-<p>
-The procedure takes an elevation layer as input and initially fills all the
-depressions with one pass across the layer. Next, the flow direction
-algorithm tries to find a unique direction for each cell. If the watershed
-program detects areas with pothholes, it delineates this area from the rest
-of the area and once again the depressions are filled using the neighborhood
-technique used by the flow direction routine. The final output will be a
-depressionless elevation layer and a unique flow direction layer.
-<p>
-This (D8) flow algorithm performs as follows: At each raster cell the code
-determines the slope to each of the 8 surrounding cells and assigns the flow
-direction to the highest slope out of the cell. If there is more than one
-equal, non-zero slope then the code picks one direction based on preferences
-that are hard-coded into the program. If the highest slope is flat and in
-more than one direction then the code first tries to select an alternative
-based on flow directions in the adjacent cells. <em>r.fill.dir</em> iteratates that process,
-effectively propagating flow directions from areas where the directions are
-known into the area where the flow direction can't otherwise be resolved.
-<p>
-The flow direction map can be encoded in either ANSWERS (Beasley et.al,
-1982) or AGNPS (Young et.al, 1985) form, so that it can be readily used as
-input to these hydrologic models. The resulting depressionless elevation
-layer can further be manipulated for deriving slopes and other attributes
-required by the hydrologic models.
-<p>
-In case of local problems, those unfilled areas can be stored optionally.
-Each unfilled area in this maps is numbered. The <b>-f</b> flag
-instructs the program to fill single-cell pits but otherwise to just find
-the undrained areas and exit. With the <b>-f</b> flag set the program
-writes an elevation map with just single-cell pits filled, a direction map
-with unresolved problems and a map of the undrained areas that were found
-but not filled. This option was included because filling DEMs was often not
-the best way to solve a drainage problem. These options let the user get a
-partially-fixed elevation map, identify the remaining problems and fix the
-problems appropriately.
-<p>
-<em>r.fill.dir</em> is sensitive to the current window setting. Thus
-the program can be used to generate a flow direction map for any
-sub-area within the full map layer. Also, <em>r.fill.dir</em> is
-sensitive to any <em>mask</em> in effect.
-<p>
-In some cases it may be necessary to run r.fill.dir repeatedly (using output
-from one run as input to the next run) before all of problem areas are
-filled.
-<h2>EXAMPLE</h2>
-r.fill.dir input=ansi.elev elevation=ansi.fill.elev direction=ansi.asp
-</pre></div>
-<p>
-will create a depressionless (sinkless) elevation map ansi.fill.elev and a flow
-direction map ansi.asp for the type "grass".
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.fillnulls.html">r.fillnulls</a>,
-<a href="r.slope.aspect.html">r.slope.aspect</a></em>
-<p>
-Beasley, D.B. and L.F. Huggins. 1982. ANSWERS (areal nonpoint source watershed environmental response simulation): User's manual. U.S. EPA-905/9-82-001, Chicago, IL, 54 p.
-<p>
-Jenson, S.K., and J.O. Domingue. 1988. Extracting topographic structure from
-digital elevation model data for geographic information system analysis. Photogram. Engr. and Remote Sens. 54: 1593-1600.
-<p>
-Young, R.A., C.A. Onstad, D.D. Bosch and W.P. Anderson. 1985. Agricultural nonpoint surface pollution models (AGNPS) I and II model documentation. St. Paul: Minn. Pollution control Agency and Washington D.C., USDA-Agricultural Research
-Service.
-<p>
-<h2>AUTHOR</h2>
-Fortran version:
-Raghavan Srinivasan, Agricultural Engineering Department, Purdue
-University<br>
-Rewrite to C with enhancements:
-Roger S. Miller
Copied: grass/trunk/raster/r.fill.dir/r.fill.dir.html (from rev 32770, grass/trunk/raster/r.fill.dir/description.html)
--- grass/trunk/raster/r.fill.dir/r.fill.dir.html (rev 0)
+++ grass/trunk/raster/r.fill.dir/r.fill.dir.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,106 @@
+<em>r.fill.dir</em> filters and generates a depressionless
+elevation map and a flow direction map from a given raster elevation map.
+<h2>NOTES</h2>
+The <b>type</b> parameter is the type of format at which the user wishes to create
+the flow direction map. The <i>agnps</i> format gives category values from
+1-8, with 1 facing north and increasing values in the clockwise direction.
+The <i>answers</i> format gives category values from 0-360 degrees, with 0
+(360) facing east and values increasing in the counter clockwise direction
+at 45 degree increments. The <i>grass</i> format gives the same category
+values as the <em><a href="r.slope.aspect.html">r.slope.aspect</a></em>
+program.<p>
+The method adopted to filter the elevation map and rectify it is
+based on the paper titled "Software Tools to Extract Structure from Digital
+Elevation Data for Geographic Information System Analysis" by S.K. Jenson
+and J.O. Domingue (1988).
+<p>
+The procedure takes an elevation layer as input and initially fills all the
+depressions with one pass across the layer. Next, the flow direction
+algorithm tries to find a unique direction for each cell. If the watershed
+program detects areas with pothholes, it delineates this area from the rest
+of the area and once again the depressions are filled using the neighborhood
+technique used by the flow direction routine. The final output will be a
+depressionless elevation layer and a unique flow direction layer.
+<p>
+This (D8) flow algorithm performs as follows: At each raster cell the code
+determines the slope to each of the 8 surrounding cells and assigns the flow
+direction to the highest slope out of the cell. If there is more than one
+equal, non-zero slope then the code picks one direction based on preferences
+that are hard-coded into the program. If the highest slope is flat and in
+more than one direction then the code first tries to select an alternative
+based on flow directions in the adjacent cells. <em>r.fill.dir</em> iteratates that process,
+effectively propagating flow directions from areas where the directions are
+known into the area where the flow direction can't otherwise be resolved.
+<p>
+The flow direction map can be encoded in either ANSWERS (Beasley et.al,
+1982) or AGNPS (Young et.al, 1985) form, so that it can be readily used as
+input to these hydrologic models. The resulting depressionless elevation
+layer can further be manipulated for deriving slopes and other attributes
+required by the hydrologic models.
+<p>
+In case of local problems, those unfilled areas can be stored optionally.
+Each unfilled area in this maps is numbered. The <b>-f</b> flag
+instructs the program to fill single-cell pits but otherwise to just find
+the undrained areas and exit. With the <b>-f</b> flag set the program
+writes an elevation map with just single-cell pits filled, a direction map
+with unresolved problems and a map of the undrained areas that were found
+but not filled. This option was included because filling DEMs was often not
+the best way to solve a drainage problem. These options let the user get a
+partially-fixed elevation map, identify the remaining problems and fix the
+problems appropriately.
+<p>
+<em>r.fill.dir</em> is sensitive to the current window setting. Thus
+the program can be used to generate a flow direction map for any
+sub-area within the full map layer. Also, <em>r.fill.dir</em> is
+sensitive to any <em>mask</em> in effect.
+<p>
+In some cases it may be necessary to run r.fill.dir repeatedly (using output
+from one run as input to the next run) before all of problem areas are
+filled.
+<h2>EXAMPLE</h2>
+r.fill.dir input=ansi.elev elevation=ansi.fill.elev direction=ansi.asp
+</pre></div>
+<p>
+will create a depressionless (sinkless) elevation map ansi.fill.elev and a flow
+direction map ansi.asp for the type "grass".
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.fillnulls.html">r.fillnulls</a>,
+<a href="r.slope.aspect.html">r.slope.aspect</a></em>
+<p>
+Beasley, D.B. and L.F. Huggins. 1982. ANSWERS (areal nonpoint source watershed environmental response simulation): User's manual. U.S. EPA-905/9-82-001, Chicago, IL, 54 p.
+<p>
+Jenson, S.K., and J.O. Domingue. 1988. Extracting topographic structure from
+digital elevation model data for geographic information system analysis. Photogram. Engr. and Remote Sens. 54: 1593-1600.
+<p>
+Young, R.A., C.A. Onstad, D.D. Bosch and W.P. Anderson. 1985. Agricultural nonpoint surface pollution models (AGNPS) I and II model documentation. St. Paul: Minn. Pollution control Agency and Washington D.C., USDA-Agricultural Research
+Service.
+<p>
+<h2>AUTHOR</h2>
+Fortran version:
+Raghavan Srinivasan, Agricultural Engineering Department, Purdue
+University<br>
+Rewrite to C with enhancements:
+Roger S. Miller
Deleted: grass/trunk/raster/r.flow/description.html
--- grass/trunk/raster/r.flow/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.flow/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,193 +0,0 @@
-This program generates flowlines using a combined raster-vector
-approach (see <a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps">Mitasova and
-Hofierka 1993</a> and <a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/ijgis.html">Mitasova et
-al. 1995</a>) from an input elevation raster map <b>elevin</b>
-(integer or floating point), and optionally an input aspect raster map
-<b>aspin</b> and/or an input barrier raster map <b>barin</b>. There are
-three possible output maps which can be produced in any combination
-simultaneously: a vector map <b>flout</b> of flowlines, a raster map
-<b>lgout</b> of flowpath lengths, and a raster map <b>dsout</b> of flowline
-densities (which are equal upslope contributed areas per unit width, when
-multiplied by resolution).
-<p>
-Aspect used for input must follow the same rules as aspect computed
-in other GRASS programs (see <a href="v.surf.rst.html">v.surf.rst</a>
-or <a href="r.slope.aspect.html">r.slope.aspect</a>).
-<p>
-Flowline output is given in a vector map <b>flout</b>, (flowlines generated
-downhill). The line segments of flowline vectors have endpoints on edges
-of a grid formed by drawing imaginary lines through the centers of the
-cells in the elevation map. Flowlines are generated from each cell downhill
-by default; they can be generated uphill using the flag <b>-u</b>. A flowline
-stops if its next segment would reverse the direction of flow (from up
-to down or vice-versa), cross a barrier, or arrive at a cell with undefined
-elevation or aspect. Another option, <b>skip</b>=val, indicates that only
-the flowlines from every val-th cell are to be included in <b>flout</b>.
-The default <b>skip</b> is max(1, <rows in elevin>/50, <cols in elevin>/50).
-A high <b>skip</b> usually speeds up processing time and often improves
-the readability of a visualization of <b>flout</b>.
-<p>
-Flowpath length output is given in a raster map <b>lgout</b>. The value
-in each grid cell is the sum of the planar lengths of all segments of the
-flowline generated from that cell. If the flag <b>-3</b> is given, elevation
-is taken into account in calculating the length of each segment.
-<p>Flowline density downhill or uphill output is given in a raster map
-<b>dsout.</b> The value in each grid cell is the number of flowlines which
-pass through that grid cell, that means the number of flowlines from the
-entire map which have segment endpoints within that cell.
-With the <b>-m</b> flag less memory is used as aspect at each cell is computed
-on the fly. This option incurs a severe performance penalty. If this flag is given,
-the aspect input map (if any) will be ignored.
-<!-- doesn't exist
-<p><b>-M</b> Use a fixed size memory and utilize page-swapping to handle
-large input files. This option incurs a severe performance penalty but
-is the only way to handle arbitrarily-large data files. If this flag is
-given, the <b>-m</b> flag will be ignored.
-The <b>barin</b> parameter is a raster map name with non-zero
-values representing barriers as input.
-<h2>NOTES</h2>
-For best results, use input elevation maps with high precision units (e.g.,
-centimeters) so that flowlines do not terminate prematurely in flat areas.
-To prevent the creation of tiny flowline segments with imperceivable changes
-in elevation, an endpoint which would land very close to the center of
-a grid cell is quantized to the exact center of that cell. The maximum
-distance between the intercepts along each axis of a single diagonal segment
-and another segment of 1/2 degree different aspect is taken to be "very
-close" for that axis. Note that this distance (the so-called "quantization
-error") is about 1-2% of the resolution on maps with square cells.
-<p>The values in length maps computed using the <b>-u</b> flag represent
-the distances from each cell to an upland flat or singular point. Such
-distances are useful in water erosion modeling for computation of the LS
-factor in the standard form of USLE. Uphill flowlines merge on ridge lines;
-by redirecting the order of the flowline points in the output vector map,
-dispersed waterflow can be simulated. The density map can be used for the
-extraction of ridge lines.
-<p>Computing the flowlines downhill simulates the actual flow (also known
-as the raindrop method). These flowlines tend to merge in valleys; they
-can be used for localization of areas with waterflow accumulation and for
-the extraction of channels. The downslope flowline density multiplied by
-the resolution can be used as an approximation of the upslope contributing
-area per unit contour width. This area is a measure of potential water
-flux for the steady state conditions and can be used in the modeling of
-water erosion for the computation of the unit stream power based LS factor
-or sediment transport capacity.
-<p>The program has been designed for modeling erosion on hillslopes and
-has rather strict conditions for ending flowlines. It is therefore not
-very suitable for the extraction of stream networks or delineation of watersheds
-unless a DEM without pits or flat areas is available
-(<a href=r.fill.dir.html>r.fill.dir</a> can be used to fill pits).
-<p> To label the vector flowlines automatically, the user can use
-<a href=v.category.html>v.category</a> (add categories).
-<h3>Algorithm background</h3>
-<p>1. Construction of flow-lines (slope-lines): <em>r.flow</em> uses an original
-vector-grid algorithm which uses an infinite number of directions between
-0.0000... and 360.0000... and traces the flow as a line (vector) in the
-direction of gradient (rather than from cell to cell in one of the 8
-directions = D-infinity algorithm). They are traced in any direction using
-aspect (so there is no limitation to 8 directions here). The D8 algorithm
-produces zig-zag lines. The value in the outlet is very similar for both
-<em>r.flow</em> and <em>r.flowmd</em> (GRASS 5 only) algorithms (because it is
-essentially the watershed area), however the spatial distribution of flow,
-especially on hillslopes is quite different. It is still a 1D flow routing
-so the dispersal flow is not accurately described, but still better than D8.
-<p>2. Computation of contributing areas: <em>r.flow</em> uses a single flow
-algorithm, i.e. all flow is transported to a single cell downslope.
-<h3><b>Differences between <em>r.flow</em> and <em>r.flowmd</em></b></h3>
-<p>
-<ol>
-<li> <em>r.flow</em> has an option to compute slope and aspect internally thus making
-the program capable to process much larger data sets than <em>r.flowmd</em>. It has
-also 2 additional options for handling of large data sets but it is not
-known that they work properly.
-<li> the programs handle the special cases when the flowline passes exactly
-(or very close) through the grid vertices differently.
-<li> <em>r.flowmd</em> has the simplified multiple flow addition so the results are
-smoother.
-</ol>
-In conclusion, <em>r.flowmd</em> produces nicer results but is slower and it does not
-support as large data sets as <em>r.flow</em>.
-<h3>Diagnostics</h3>
-<p>"ERROR: r.flow: " input " file's resolution differs from current" region
-resolution
-<p>The resolutions of all input files and the current region must match.
-<p>"ERROR: r.flow: resolution too unbalanced (" val " x " val ")" The difference
-in length between the two axes of a grid cell is so great that quantization
-error is larger than one of the dimensions. Resample the map and try again.
-<h2>REFERENCES</h2>
-<p>Mitasova, H., L. Mitas, 1993, Interpolation by regularized spline with
-tension : I. Theory and implementation. Mathematical Geology 25, p. 641-655.
-(<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/papers/lmg.rev1.ps>online</a>)
-<p>Mitasova and Hofierka 1993 : Interpolation by Regularized Spline with
-Tension: II. Application to Terrain Modeling and Surface Geometry Analysis.
-Mathematical Geology 25(6), 657-669. (<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps>online</a>)
-<p>Mitasova, H., Mitas, L., Brown, W.M., Gerdes, D.P., Kosinovsky, I.,
-Baker, T., 1995: Modeling spatially and temporally distributed phenomena:
-New methods and tools for GRASS GIS. International Journal of Geographical
-Information Systems 9(4), 433-446.
-<p>Mitasova, H., J. Hofierka, M. Zlocha, L.R. Iverson, 1996, Modeling
-topographic potential for erosion and deposition using GIS. Int. Journal of
-Geographical Information Science, 10(5), 629-641. (reply to a comment to
-this paper appears in 1997 in Int. Journal of Geographical Information
-Science, Vol. 11, No. 6)
-<p>Mitasova, H.(1993): Surfaces and modeling. Grassclippings (winter and
-spring) p.18-19.
-<h2>SEE ALSO</h2>
-<a href="r.basins.fill.html">r.basins.fill</a>,
-<a href="r.drain.html">r.drain</a>,
-<a href="r.fill.dir.html">r.fill.dir</a>,
-<a href="r.water.outlet.html">r.water.outlet</a>,
-<a href="r.watershed.html">r.watershed</a>,
-<a href="v.category.html">v.category</a>,
-<a href="v.to.rast.html">v.to.rast</a>
-<h2>AUTHORS</h2>
-<p><i>Original version of program:</i>
-<br>Maros Zlocha and Jaroslav Hofierka, Comenius University, Bratislava,
-Slovakia,
-<p><i>The current version of the program (adapted for GRASS5.0)</i>:
-<br>Joshua Caplan, Mark Ruesink, Helena Mitasova, University of Illinois
-at Urbana-Champaign with support from USA CERL.<br>
-<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/>GMSL/University of Illinois at
-Urbana-Champaign</a>
Copied: grass/trunk/raster/r.flow/r.flow.html (from rev 32770, grass/trunk/raster/r.flow/description.html)
--- grass/trunk/raster/r.flow/r.flow.html (rev 0)
+++ grass/trunk/raster/r.flow/r.flow.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,193 @@
+This program generates flowlines using a combined raster-vector
+approach (see <a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps">Mitasova and
+Hofierka 1993</a> and <a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/ijgis.html">Mitasova et
+al. 1995</a>) from an input elevation raster map <b>elevin</b>
+(integer or floating point), and optionally an input aspect raster map
+<b>aspin</b> and/or an input barrier raster map <b>barin</b>. There are
+three possible output maps which can be produced in any combination
+simultaneously: a vector map <b>flout</b> of flowlines, a raster map
+<b>lgout</b> of flowpath lengths, and a raster map <b>dsout</b> of flowline
+densities (which are equal upslope contributed areas per unit width, when
+multiplied by resolution).
+<p>
+Aspect used for input must follow the same rules as aspect computed
+in other GRASS programs (see <a href="v.surf.rst.html">v.surf.rst</a>
+or <a href="r.slope.aspect.html">r.slope.aspect</a>).
+<p>
+Flowline output is given in a vector map <b>flout</b>, (flowlines generated
+downhill). The line segments of flowline vectors have endpoints on edges
+of a grid formed by drawing imaginary lines through the centers of the
+cells in the elevation map. Flowlines are generated from each cell downhill
+by default; they can be generated uphill using the flag <b>-u</b>. A flowline
+stops if its next segment would reverse the direction of flow (from up
+to down or vice-versa), cross a barrier, or arrive at a cell with undefined
+elevation or aspect. Another option, <b>skip</b>=val, indicates that only
+the flowlines from every val-th cell are to be included in <b>flout</b>.
+The default <b>skip</b> is max(1, <rows in elevin>/50, <cols in elevin>/50).
+A high <b>skip</b> usually speeds up processing time and often improves
+the readability of a visualization of <b>flout</b>.
+<p>
+Flowpath length output is given in a raster map <b>lgout</b>. The value
+in each grid cell is the sum of the planar lengths of all segments of the
+flowline generated from that cell. If the flag <b>-3</b> is given, elevation
+is taken into account in calculating the length of each segment.
+<p>Flowline density downhill or uphill output is given in a raster map
+<b>dsout.</b> The value in each grid cell is the number of flowlines which
+pass through that grid cell, that means the number of flowlines from the
+entire map which have segment endpoints within that cell.
+With the <b>-m</b> flag less memory is used as aspect at each cell is computed
+on the fly. This option incurs a severe performance penalty. If this flag is given,
+the aspect input map (if any) will be ignored.
+<!-- doesn't exist
+<p><b>-M</b> Use a fixed size memory and utilize page-swapping to handle
+large input files. This option incurs a severe performance penalty but
+is the only way to handle arbitrarily-large data files. If this flag is
+given, the <b>-m</b> flag will be ignored.
+The <b>barin</b> parameter is a raster map name with non-zero
+values representing barriers as input.
+<h2>NOTES</h2>
+For best results, use input elevation maps with high precision units (e.g.,
+centimeters) so that flowlines do not terminate prematurely in flat areas.
+To prevent the creation of tiny flowline segments with imperceivable changes
+in elevation, an endpoint which would land very close to the center of
+a grid cell is quantized to the exact center of that cell. The maximum
+distance between the intercepts along each axis of a single diagonal segment
+and another segment of 1/2 degree different aspect is taken to be "very
+close" for that axis. Note that this distance (the so-called "quantization
+error") is about 1-2% of the resolution on maps with square cells.
+<p>The values in length maps computed using the <b>-u</b> flag represent
+the distances from each cell to an upland flat or singular point. Such
+distances are useful in water erosion modeling for computation of the LS
+factor in the standard form of USLE. Uphill flowlines merge on ridge lines;
+by redirecting the order of the flowline points in the output vector map,
+dispersed waterflow can be simulated. The density map can be used for the
+extraction of ridge lines.
+<p>Computing the flowlines downhill simulates the actual flow (also known
+as the raindrop method). These flowlines tend to merge in valleys; they
+can be used for localization of areas with waterflow accumulation and for
+the extraction of channels. The downslope flowline density multiplied by
+the resolution can be used as an approximation of the upslope contributing
+area per unit contour width. This area is a measure of potential water
+flux for the steady state conditions and can be used in the modeling of
+water erosion for the computation of the unit stream power based LS factor
+or sediment transport capacity.
+<p>The program has been designed for modeling erosion on hillslopes and
+has rather strict conditions for ending flowlines. It is therefore not
+very suitable for the extraction of stream networks or delineation of watersheds
+unless a DEM without pits or flat areas is available
+(<a href=r.fill.dir.html>r.fill.dir</a> can be used to fill pits).
+<p> To label the vector flowlines automatically, the user can use
+<a href=v.category.html>v.category</a> (add categories).
+<h3>Algorithm background</h3>
+<p>1. Construction of flow-lines (slope-lines): <em>r.flow</em> uses an original
+vector-grid algorithm which uses an infinite number of directions between
+0.0000... and 360.0000... and traces the flow as a line (vector) in the
+direction of gradient (rather than from cell to cell in one of the 8
+directions = D-infinity algorithm). They are traced in any direction using
+aspect (so there is no limitation to 8 directions here). The D8 algorithm
+produces zig-zag lines. The value in the outlet is very similar for both
+<em>r.flow</em> and <em>r.flowmd</em> (GRASS 5 only) algorithms (because it is
+essentially the watershed area), however the spatial distribution of flow,
+especially on hillslopes is quite different. It is still a 1D flow routing
+so the dispersal flow is not accurately described, but still better than D8.
+<p>2. Computation of contributing areas: <em>r.flow</em> uses a single flow
+algorithm, i.e. all flow is transported to a single cell downslope.
+<h3><b>Differences between <em>r.flow</em> and <em>r.flowmd</em></b></h3>
+<p>
+<ol>
+<li> <em>r.flow</em> has an option to compute slope and aspect internally thus making
+the program capable to process much larger data sets than <em>r.flowmd</em>. It has
+also 2 additional options for handling of large data sets but it is not
+known that they work properly.
+<li> the programs handle the special cases when the flowline passes exactly
+(or very close) through the grid vertices differently.
+<li> <em>r.flowmd</em> has the simplified multiple flow addition so the results are
+smoother.
+</ol>
+In conclusion, <em>r.flowmd</em> produces nicer results but is slower and it does not
+support as large data sets as <em>r.flow</em>.
+<h3>Diagnostics</h3>
+<p>"ERROR: r.flow: " input " file's resolution differs from current" region
+resolution
+<p>The resolutions of all input files and the current region must match.
+<p>"ERROR: r.flow: resolution too unbalanced (" val " x " val ")" The difference
+in length between the two axes of a grid cell is so great that quantization
+error is larger than one of the dimensions. Resample the map and try again.
+<h2>REFERENCES</h2>
+<p>Mitasova, H., L. Mitas, 1993, Interpolation by regularized spline with
+tension : I. Theory and implementation. Mathematical Geology 25, p. 641-655.
+(<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/papers/lmg.rev1.ps>online</a>)
+<p>Mitasova and Hofierka 1993 : Interpolation by Regularized Spline with
+Tension: II. Application to Terrain Modeling and Surface Geometry Analysis.
+Mathematical Geology 25(6), 657-669. (<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps>online</a>)
+<p>Mitasova, H., Mitas, L., Brown, W.M., Gerdes, D.P., Kosinovsky, I.,
+Baker, T., 1995: Modeling spatially and temporally distributed phenomena:
+New methods and tools for GRASS GIS. International Journal of Geographical
+Information Systems 9(4), 433-446.
+<p>Mitasova, H., J. Hofierka, M. Zlocha, L.R. Iverson, 1996, Modeling
+topographic potential for erosion and deposition using GIS. Int. Journal of
+Geographical Information Science, 10(5), 629-641. (reply to a comment to
+this paper appears in 1997 in Int. Journal of Geographical Information
+Science, Vol. 11, No. 6)
+<p>Mitasova, H.(1993): Surfaces and modeling. Grassclippings (winter and
+spring) p.18-19.
+<h2>SEE ALSO</h2>
+<a href="r.basins.fill.html">r.basins.fill</a>,
+<a href="r.drain.html">r.drain</a>,
+<a href="r.fill.dir.html">r.fill.dir</a>,
+<a href="r.water.outlet.html">r.water.outlet</a>,
+<a href="r.watershed.html">r.watershed</a>,
+<a href="v.category.html">v.category</a>,
+<a href="v.to.rast.html">v.to.rast</a>
+<h2>AUTHORS</h2>
+<p><i>Original version of program:</i>
+<br>Maros Zlocha and Jaroslav Hofierka, Comenius University, Bratislava,
+Slovakia,
+<p><i>The current version of the program (adapted for GRASS5.0)</i>:
+<br>Joshua Caplan, Mark Ruesink, Helena Mitasova, University of Illinois
+at Urbana-Champaign with support from USA CERL.<br>
+<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/>GMSL/University of Illinois at
+Urbana-Champaign</a>
Deleted: grass/trunk/raster/r.grow.distance/description.html
--- grass/trunk/raster/r.grow.distance/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.grow.distance/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,69 +0,0 @@
-<em>r.grow.distance</em> generates a raster map representing the
-distance to the nearest non-null cell in the input map.
-<h2>NOTES</h2>
-The user has the option of specifying four different metrics which
-control the geometry in which grown cells are created, (controlled by
-the <b>metric</b> parameter): <i>Euclidean</i>, <i>Squared</i>,
-<i>Manhattan</i>, and <i>Maximum</i>.
-<p>
-The <i>Euclidean distance</i> or <i>Euclidean metric</i> is the "ordinary" distance
-between two points that one would measure with a ruler, which can be
-proven by repeated application of the Pythagorean theorem.
-The formula is given by:
-<div class="code"><pre>d(dx,dy) = sqrt(dx^2 + dy^2)</pre></div>
-Cells grown using this metric would form isolines of distance that are
-circular from a given point, with the distance given by the <b>radius</b>.
-<p>
-The <i>Squared</i> metric is the <i>Euclidean</i> distance squared,
-i.e. it simply omits the square-root calculation. This may be faster,
-and is sufficient if only relative values are required.
-<p>
-The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
-which the usual metric of Euclidean geometry is replaced by a new
-metric in which the distance between two points is the sum of the (absolute)
-differences of their coordinates. The name alludes to the grid layout of
-most streets on the island of Manhattan, which causes the shortest path a
-car could take between two points in the city to have length equal to the
-points' distance in taxicab geometry.
-<div class="code"><pre>d(dx,dy) = abs(dx) + abs(dy)</pre></div>
-where cells grown using this metric would form isolines of distance that are
-rhombus-shaped from a given point.
-<p>
-The <i>Maximum metric</i> is given by the formula
-<div class="code"><pre>d(dx,dy) = max(abs(dx),abs(dy))</pre></div>
-where the isolines of distance from a point are squares.
-<h2>SEE ALSO</h2>
-<em><a href="r.grow.html">r.grow</a></em><br>
-<em><a href="r.buffer.html">r.buffer</a></em><br>
-<em><a href="r.patch.html">r.patch</a></em>
-<p>
-<em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a><br>
-<em><a href="http://en.wikipedia.org/wiki/Manhattan_metric">Wikipedia Entry: Manhattan Metric</a>
-<h2>AUTHORS</h2>
-Glynn Clements
Copied: grass/trunk/raster/r.grow.distance/r.grow.distance.html (from rev 32770, grass/trunk/raster/r.grow.distance/description.html)
--- grass/trunk/raster/r.grow.distance/r.grow.distance.html (rev 0)
+++ grass/trunk/raster/r.grow.distance/r.grow.distance.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,69 @@
+<em>r.grow.distance</em> generates a raster map representing the
+distance to the nearest non-null cell in the input map.
+<h2>NOTES</h2>
+The user has the option of specifying four different metrics which
+control the geometry in which grown cells are created, (controlled by
+the <b>metric</b> parameter): <i>Euclidean</i>, <i>Squared</i>,
+<i>Manhattan</i>, and <i>Maximum</i>.
+<p>
+The <i>Euclidean distance</i> or <i>Euclidean metric</i> is the "ordinary" distance
+between two points that one would measure with a ruler, which can be
+proven by repeated application of the Pythagorean theorem.
+The formula is given by:
+<div class="code"><pre>d(dx,dy) = sqrt(dx^2 + dy^2)</pre></div>
+Cells grown using this metric would form isolines of distance that are
+circular from a given point, with the distance given by the <b>radius</b>.
+<p>
+The <i>Squared</i> metric is the <i>Euclidean</i> distance squared,
+i.e. it simply omits the square-root calculation. This may be faster,
+and is sufficient if only relative values are required.
+<p>
+The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
+which the usual metric of Euclidean geometry is replaced by a new
+metric in which the distance between two points is the sum of the (absolute)
+differences of their coordinates. The name alludes to the grid layout of
+most streets on the island of Manhattan, which causes the shortest path a
+car could take between two points in the city to have length equal to the
+points' distance in taxicab geometry.
+<div class="code"><pre>d(dx,dy) = abs(dx) + abs(dy)</pre></div>
+where cells grown using this metric would form isolines of distance that are
+rhombus-shaped from a given point.
+<p>
+The <i>Maximum metric</i> is given by the formula
+<div class="code"><pre>d(dx,dy) = max(abs(dx),abs(dy))</pre></div>
+where the isolines of distance from a point are squares.
+<h2>SEE ALSO</h2>
+<em><a href="r.grow.html">r.grow</a></em><br>
+<em><a href="r.buffer.html">r.buffer</a></em><br>
+<em><a href="r.patch.html">r.patch</a></em>
+<p>
+<em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a><br>
+<em><a href="http://en.wikipedia.org/wiki/Manhattan_metric">Wikipedia Entry: Manhattan Metric</a>
+<h2>AUTHORS</h2>
+Glynn Clements
Deleted: grass/trunk/raster/r.grow2/description.html
--- grass/trunk/raster/r.grow2/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.grow2/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,77 +0,0 @@
-<em>r.grow</em> adds cells around the perimeters of all areas
-in a user-specified raster map layer and stores the output in
-a new raster map layer. The user can use it to grow by one or
-more than one cell (by varying the size of the <b>radius</b>
-parameter), or like <em>r.buffer</em>, but with the
-option of preserving the original cells (similar to combining
-<em>r.buffer</em> and <em>r.patch</em>).
-<h2>NOTES</h2>
-The user has the option of specifying three different metrics which
-the <b>metric</b> parameter): <i>Euclidean</i>, <i>Manhattan</i>, and
-<i>Maximum</i>.
-<p>
-<p>
-<p>
-<p>
-If there are two cells which are equal candidates to grow into an empty space,
-<em>r.grow</em> will choose the northernmost candidate; if there are multiple
-candidates with the same northing, the westernmost is chosen.
-<h2>SEE ALSO</h2>
-<p>
-<h2>AUTHORS</h2>
-Marjorie Larson,
-U.S. Army Construction Engineering Research Laboratory
-<p>
-Glynn Clements
Copied: grass/trunk/raster/r.grow2/r.grow.html (from rev 32770, grass/trunk/raster/r.grow2/description.html)
--- grass/trunk/raster/r.grow2/r.grow.html (rev 0)
+++ grass/trunk/raster/r.grow2/r.grow.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,77 @@
+<h2>DESCRIPTION</h2>
+<em>r.grow</em> adds cells around the perimeters of all areas
+in a user-specified raster map layer and stores the output in
+a new raster map layer. The user can use it to grow by one or
+more than one cell (by varying the size of the <b>radius</b>
+parameter), or like <em>r.buffer</em>, but with the
+option of preserving the original cells (similar to combining
+<em>r.buffer</em> and <em>r.patch</em>).
+<h2>NOTES</h2>
+The user has the option of specifying three different metrics which
+the <b>metric</b> parameter): <i>Euclidean</i>, <i>Manhattan</i>, and
+<i>Maximum</i>.
+<p>
+<p>
+<p>
+<p>
+If there are two cells which are equal candidates to grow into an empty space,
+<em>r.grow</em> will choose the northernmost candidate; if there are multiple
+candidates with the same northing, the westernmost is chosen.
+<h2>SEE ALSO</h2>
+<p>
+<h2>AUTHORS</h2>
+Marjorie Larson,
+U.S. Army Construction Engineering Research Laboratory
+<p>
+Glynn Clements
Deleted: grass/trunk/raster/r.gwflow/description.html
--- grass/trunk/raster/r.gwflow/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.gwflow/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,120 +0,0 @@
-This numerical program calculates transient, confined and
-unconfined groundwater flow in two dimensions based on
-raster maps and the current region resolution.
-All initial and boundary conditions must be provided as
-raster maps.
-<p>
-<center>
-<img src=r_gwflow_concept.png border=0><br>
-<table border=0 width=700>
-<tr><td><center>
-<i>Workflow of r.gwflow</i>
-</center></td></tr>
-</table>
-</center>
-<p>
-<em>r.gwflow</em> calculates the piezometric head and optionally the
-filter velocity field, based on the hydraulic conductivity and the piezometric head.
-The vector components can be visualized with paraview if they are exported
-with <em>r.out.vtk</em>.
-<br>
-<br>
-The groundwater flow will always be calculated transient.
-If you want to calculate stady state, set the timestep
-to a large number (billions of seconds) or set the
-specific yield/ effective porosity raster maps to zero.
-<h2>NOTES</h2>
-The groundwater flow calculation is based on Darcy's law and a
-finite volume discretization. The solved groundwater flow partial
-differential equation is of the following form:
-<p>
-(dh/dt)*Ss = Kxx * (d^2h/dx^2) + Kyy * (d^2h/dy^2) + q
-<ul>
-<li>h -- the piezometric head im [m]</li>
-<li>dt -- the time step for transient calculation in [s]</li>
-<li>S -- the specific yield [1/m]</li>
-<li>Kxx -- the hydraulic conductivity tensor part in x direction in [m/s]</li>
-<li>Kyy -- the hydraulic conductivity tensor part in y direction in [m/s]</li>
-<li>q - inner source in meter per second [1/s]</li>
-</ul>
-<br>
-<br>
-Two different boundary conditions are implemented,
-the Dirichlet and Neumann conditions. By default the calculation area is surrounded by homogeneous Neumann boundary conditions.
-The calculation and boundary status of single cells must be set with a status map,
-the following states are supportet:
-<ul>
-<li>0 == inactive - the cell with status 0 will not be calculated, active cells will have a no flow boundary to this cell</li>
-<li>1 == active - this cell is used for groundwater floaw calculation, inner sources and recharge can be defined for those cells</li>
-<li>2 == Dirichlet - cells of this type will have a fixed piezometric head value which do not change over the time </li>
-</ul>
-<br>
-<br>
-The groundwater flow equation can be solved with several solvers.
-Two iterative solvers with sparse and quadratic matrices support are implemented.
-The conjugate gradients (cg) method and the biconjugate gradients-stabilized (bicgstab) method.
-Aditionally a direct Gauss solver and LU solver are available. Those direct solvers
-only work with normal quadratic matrices, so be careful using them with large maps
-(maps of size 10.000 cells will need more than one gigabyte of RAM).
-Always prefer a sparse matrix solver.
-<h2>EXAMPLE</h2>
-Use this small script to create a working
-groundwater flow area and data. Make sure you are not in a lat/lon projection.
-# set the region accordingly
-g.region res=25 res3=25 t=100 b=0 n=1000 s=0 w=0 e=1000
-#now create the input raster maps for confined and unconfined aquifers
-r.mapcalc "phead=if(row() == 1 , 50, 40)"
-r.mapcalc "status=if(row() == 1 , 2, 1)"
-r.mapcalc "well=if(row() == 20 && col() == 20 , -0.001, 0)"
-r.mapcalc "hydcond=0.00025"
-r.mapcalc "recharge=0"
-r.mapcalc "top_conf=20.0"
-r.mapcalc "top_unconf=70.0"
-r.mapcalc "bottom=0.0"
-r.mapcalc "null=0.0"
-r.mapcalc "poros=0.15"
-r.mapcalc "syield=0.0001"
-#confined groundwater flow with cg solver and sparse matrix
-r.gwflow --o -s solver=cg top=top_conf bottom=bottom phead=phead status=status \
-hc_x=hydcond hc_y=hydcond q=well s=syield r=recharge output=gwresult_conf \
-dt=8640000 type=confined velocity=gwresult_conf_velocity
-#unconfined groundwater flow with cg solver and sparse matrix
-r.gwflow --o -s solver=cg top=top_unconf bottom=bottom phead=phead \
-status=status hc_x=hydcond hc_y=hydcond q=well s=poros r=recharge \
-output=gwresult_unconf dt=8640000 type=unconfined velocity=gwresult_unconf_velocity
-# The data can be visulaized with paraview when exported with r.out.vtk
-r.out.vtk -p in=gwresult_conf,status vector=gwresult_conf_velocity_x,gwresult_conf_velocity_y,null out=/tmp/gwdata_conf2d.vtk
-r.out.vtk -p elevation=gwresult_unconf in=gwresult_unconf,status vector=gwresult_unconf_velocity_x,gwresult_unconf_velocity_y,null out=/tmp/gwdata_unconf2d.vtk
-#now load the data into paraview
-paraview --data=/tmp/gwdata_conf2d.vtk &
-paraview --data=/tmp/gwdata_unconf2d.vtk &
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="r3.gwflow.html">r3.gwflow</a></em><br>
-<em><a href="r.out.vtk.html">r.out.vtk</a></em><br>
-<h2>AUTHOR</h2>
-Soeren Gebbert
Copied: grass/trunk/raster/r.gwflow/r.gwflow.html (from rev 32770, grass/trunk/raster/r.gwflow/description.html)
--- grass/trunk/raster/r.gwflow/r.gwflow.html (rev 0)
+++ grass/trunk/raster/r.gwflow/r.gwflow.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,120 @@
+This numerical program calculates transient, confined and
+unconfined groundwater flow in two dimensions based on
+raster maps and the current region resolution.
+All initial and boundary conditions must be provided as
+raster maps.
+<p>
+<center>
+<img src=r_gwflow_concept.png border=0><br>
+<table border=0 width=700>
+<tr><td><center>
+<i>Workflow of r.gwflow</i>
+</center></td></tr>
+</table>
+</center>
+<p>
+<em>r.gwflow</em> calculates the piezometric head and optionally the
+filter velocity field, based on the hydraulic conductivity and the piezometric head.
+The vector components can be visualized with paraview if they are exported
+with <em>r.out.vtk</em>.
+<br>
+<br>
+The groundwater flow will always be calculated transient.
+If you want to calculate stady state, set the timestep
+to a large number (billions of seconds) or set the
+specific yield/ effective porosity raster maps to zero.
+<h2>NOTES</h2>
+The groundwater flow calculation is based on Darcy's law and a
+finite volume discretization. The solved groundwater flow partial
+differential equation is of the following form:
+<p>
+(dh/dt)*Ss = Kxx * (d^2h/dx^2) + Kyy * (d^2h/dy^2) + q
+<ul>
+<li>h -- the piezometric head im [m]</li>
+<li>dt -- the time step for transient calculation in [s]</li>
+<li>S -- the specific yield [1/m]</li>
+<li>Kxx -- the hydraulic conductivity tensor part in x direction in [m/s]</li>
+<li>Kyy -- the hydraulic conductivity tensor part in y direction in [m/s]</li>
+<li>q - inner source in meter per second [1/s]</li>
+</ul>
+<br>
+<br>
+Two different boundary conditions are implemented,
+the Dirichlet and Neumann conditions. By default the calculation area is surrounded by homogeneous Neumann boundary conditions.
+The calculation and boundary status of single cells must be set with a status map,
+the following states are supportet:
+<ul>
+<li>0 == inactive - the cell with status 0 will not be calculated, active cells will have a no flow boundary to this cell</li>
+<li>1 == active - this cell is used for groundwater floaw calculation, inner sources and recharge can be defined for those cells</li>
+<li>2 == Dirichlet - cells of this type will have a fixed piezometric head value which do not change over the time </li>
+</ul>
+<br>
+<br>
+The groundwater flow equation can be solved with several solvers.
+Two iterative solvers with sparse and quadratic matrices support are implemented.
+The conjugate gradients (cg) method and the biconjugate gradients-stabilized (bicgstab) method.
+Aditionally a direct Gauss solver and LU solver are available. Those direct solvers
+only work with normal quadratic matrices, so be careful using them with large maps
+(maps of size 10.000 cells will need more than one gigabyte of RAM).
+Always prefer a sparse matrix solver.
+<h2>EXAMPLE</h2>
+Use this small script to create a working
+groundwater flow area and data. Make sure you are not in a lat/lon projection.
+# set the region accordingly
+g.region res=25 res3=25 t=100 b=0 n=1000 s=0 w=0 e=1000
+#now create the input raster maps for confined and unconfined aquifers
+r.mapcalc "phead=if(row() == 1 , 50, 40)"
+r.mapcalc "status=if(row() == 1 , 2, 1)"
+r.mapcalc "well=if(row() == 20 && col() == 20 , -0.001, 0)"
+r.mapcalc "hydcond=0.00025"
+r.mapcalc "recharge=0"
+r.mapcalc "top_conf=20.0"
+r.mapcalc "top_unconf=70.0"
+r.mapcalc "bottom=0.0"
+r.mapcalc "null=0.0"
+r.mapcalc "poros=0.15"
+r.mapcalc "syield=0.0001"
+#confined groundwater flow with cg solver and sparse matrix
+r.gwflow --o -s solver=cg top=top_conf bottom=bottom phead=phead status=status \
+hc_x=hydcond hc_y=hydcond q=well s=syield r=recharge output=gwresult_conf \
+dt=8640000 type=confined velocity=gwresult_conf_velocity
+#unconfined groundwater flow with cg solver and sparse matrix
+r.gwflow --o -s solver=cg top=top_unconf bottom=bottom phead=phead \
+status=status hc_x=hydcond hc_y=hydcond q=well s=poros r=recharge \
+output=gwresult_unconf dt=8640000 type=unconfined velocity=gwresult_unconf_velocity
+# The data can be visulaized with paraview when exported with r.out.vtk
+r.out.vtk -p in=gwresult_conf,status vector=gwresult_conf_velocity_x,gwresult_conf_velocity_y,null out=/tmp/gwdata_conf2d.vtk
+r.out.vtk -p elevation=gwresult_unconf in=gwresult_unconf,status vector=gwresult_unconf_velocity_x,gwresult_unconf_velocity_y,null out=/tmp/gwdata_unconf2d.vtk
+#now load the data into paraview
+paraview --data=/tmp/gwdata_conf2d.vtk &
+paraview --data=/tmp/gwdata_unconf2d.vtk &
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="r3.gwflow.html">r3.gwflow</a></em><br>
+<em><a href="r.out.vtk.html">r.out.vtk</a></em><br>
+<h2>AUTHOR</h2>
+Soeren Gebbert
Deleted: grass/trunk/raster/r.his/description.html
--- grass/trunk/raster/r.his/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.his/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,126 +0,0 @@
-<h2>DESCRIPTION</h2>
-<i>his</i> stands for hue, intensity, and saturation.
-This program produces red, green and blue raster map layers
-providing a visually pleasing combination of hue,
-intensity, and saturation values from two or three
-user-specified raster map layers.
-<p>
-The human brain automatically interprets the vast amount of
-visual information available according to basic rules.
-Color, or <i>hue</i>, is used to categorize objects.
-Shading, or <i>intensity</i>, is interpreted as
-three-dimensional texturing. Finally, the degree of
-haziness, or <i>saturation</i>, is associated with
-distance or depth. This program allows data from up to
-three raster map layers to be combined into a color image
-(in the form of separate red, green and blue raster map
-layers) which retains the original information in terms of
-<i>hue</i>, <i>intensity</i>, and <i>saturation</i>.
-<p>
-While any raster map layer can be used to represent the hue
-information, map layers with a few very distinct colors
-work best. Only raster map layers representing
-continuously varying data like elevation, aspect, weights,
-intensities, or amounts can suitably be used to provide
-intensity and saturation information.
-<p>
-For example, a visually pleasing image can be made by using
-a watershed map for the <i>hue</i> factor, an aspect map
-for the <i>intensity</i> factor, and an elevation map for
-<i>saturation</i>. (The user may wish to leave out the
-elevation information for a first try.) Ideally, the
-resulting image should resemble the view from an aircraft
-looking at a terrain on a sunny day with a bit of haze in
-the valleys.
-<h3>The Process</h3>
-Each map cell is processed individually. First, the working
-color is set to the color of the corresponding cell in the
-map layer chosen to represent <i>HUE</i>. Second, this
-color is multiplied by the <i>red</i> intensity of that
-cell in the <i>INTENSITY</i> map layer. This map layer
-should have an appropriate gray-scale color table
-associated with it. You can ensure this by using the color
-manipulation capabilities of
-<em><a href="d.colors.html">d.colors</a></em> or
-<em><a href="r.colors.html">r.colors</a></em>.
-Finally, the color is made somewhat gray-based on the
-<i>red</i> intensity of that cell in the
-<i>SATURATION</i> map layer. Again, this map layer
-should have a gray-scale color table associated with it.
-<h2>NOTES</h2>
-The name is misleading. The actual conversion used is
-<pre>
- <u>H</u>.i.s + <u>G</u>.(1-s)
-where
- <u>H</u> is the R,G,B color from the hue map
- i is the red value from the intensity map
- s is the red value from the saturation map
- <u>G</u> is 50% gray (R = G = B = 0.5)
-</pre>
-<p>
-Either (but not both) of the intensity or the saturation
-map layers may be omitted. This means that it is possible
-to produce output images that represent combinations of
-<i>his, hi,</i> or <i>hs</i>.
-The separate <i>red</i>, <i>green</i> and <i>blue</i>
-maps can be displayed on the graphics monitor using
-<em><a href="d.rgb.html">d.rgb</a></em>, or combined into
-a composite RGB layer using
-<em><a href="r.composite.html">r.composite</a></em>.
-Users wishing to simply display an <i>his</i> composite
-image without actually generating any layers should use the
-program <em><a href="d.his.html">d.his</a></em>.
-<h2>EXAMPLE</h2>
-Recreate the following <em>d.his</em> command using <em>r.his</em>:
- r.shaded.relief map=elevation.dem shad=elev.shad_relf
- d.his h=elevation.dem i=elev.shad_relf brighten=50
-</pre></div>
- r.mapcalc 'elev.shad_relf_bright50 = #elev.shad_relf * 1.5'
- r.colors elev.shad_relf_bright50 color=grey255
- r.his h_map=elevation.dem i_map=elev.shad_relf_bright50 r_map=esr.r g_map=esr.g bmap=esr.b
- d.rgb red=esr.r green=esr.g blue=esr.b
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="d.his.html">d.his</a></em>,
-<em><a href="d.colors.html">d.colors</a></em>,
-<em><a href="d.colortable.html">d.colortable</a></em>,
-<em><a href="r.blend.html">r.blend</a></em>,
-<em><a href="r.colors.html">r.colors</a></em>,
-<em><a href="i.his.rgb.html">i.his.rgb</a></em>,
-<em><a href="i.rgb.his.html">i.rgb.his</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements (based upon <em><a href="d.his.html">d.his</a></em>)
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.his/r.his.html (from rev 32770, grass/trunk/raster/r.his/description.html)
--- grass/trunk/raster/r.his/r.his.html (rev 0)
+++ grass/trunk/raster/r.his/r.his.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,126 @@
+<i>his</i> stands for hue, intensity, and saturation.
+This program produces red, green and blue raster map layers
+providing a visually pleasing combination of hue,
+intensity, and saturation values from two or three
+user-specified raster map layers.
+<p>
+The human brain automatically interprets the vast amount of
+visual information available according to basic rules.
+Color, or <i>hue</i>, is used to categorize objects.
+Shading, or <i>intensity</i>, is interpreted as
+three-dimensional texturing. Finally, the degree of
+haziness, or <i>saturation</i>, is associated with
+distance or depth. This program allows data from up to
+three raster map layers to be combined into a color image
+(in the form of separate red, green and blue raster map
+layers) which retains the original information in terms of
+<i>hue</i>, <i>intensity</i>, and <i>saturation</i>.
+<p>
+While any raster map layer can be used to represent the hue
+information, map layers with a few very distinct colors
+work best. Only raster map layers representing
+continuously varying data like elevation, aspect, weights,
+intensities, or amounts can suitably be used to provide
+intensity and saturation information.
+<p>
+For example, a visually pleasing image can be made by using
+a watershed map for the <i>hue</i> factor, an aspect map
+for the <i>intensity</i> factor, and an elevation map for
+<i>saturation</i>. (The user may wish to leave out the
+elevation information for a first try.) Ideally, the
+resulting image should resemble the view from an aircraft
+looking at a terrain on a sunny day with a bit of haze in
+the valleys.
+<h3>The Process</h3>
+Each map cell is processed individually. First, the working
+color is set to the color of the corresponding cell in the
+map layer chosen to represent <i>HUE</i>. Second, this
+color is multiplied by the <i>red</i> intensity of that
+cell in the <i>INTENSITY</i> map layer. This map layer
+should have an appropriate gray-scale color table
+associated with it. You can ensure this by using the color
+manipulation capabilities of
+<em><a href="d.colors.html">d.colors</a></em> or
+<em><a href="r.colors.html">r.colors</a></em>.
+Finally, the color is made somewhat gray-based on the
+<i>red</i> intensity of that cell in the
+<i>SATURATION</i> map layer. Again, this map layer
+should have a gray-scale color table associated with it.
+<h2>NOTES</h2>
+The name is misleading. The actual conversion used is
+<pre>
+ <u>H</u>.i.s + <u>G</u>.(1-s)
+where
+ <u>H</u> is the R,G,B color from the hue map
+ i is the red value from the intensity map
+ s is the red value from the saturation map
+ <u>G</u> is 50% gray (R = G = B = 0.5)
+</pre>
+<p>
+Either (but not both) of the intensity or the saturation
+map layers may be omitted. This means that it is possible
+to produce output images that represent combinations of
+<i>his, hi,</i> or <i>hs</i>.
+The separate <i>red</i>, <i>green</i> and <i>blue</i>
+maps can be displayed on the graphics monitor using
+<em><a href="d.rgb.html">d.rgb</a></em>, or combined into
+a composite RGB layer using
+<em><a href="r.composite.html">r.composite</a></em>.
+Users wishing to simply display an <i>his</i> composite
+image without actually generating any layers should use the
+program <em><a href="d.his.html">d.his</a></em>.
+<h2>EXAMPLE</h2>
+Recreate the following <em>d.his</em> command using <em>r.his</em>:
+ r.shaded.relief map=elevation.dem shad=elev.shad_relf
+ d.his h=elevation.dem i=elev.shad_relf brighten=50
+</pre></div>
+ r.mapcalc 'elev.shad_relf_bright50 = #elev.shad_relf * 1.5'
+ r.colors elev.shad_relf_bright50 color=grey255
+ r.his h_map=elevation.dem i_map=elev.shad_relf_bright50 r_map=esr.r g_map=esr.g bmap=esr.b
+ d.rgb red=esr.r green=esr.g blue=esr.b
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="d.his.html">d.his</a></em>,
+<em><a href="d.colors.html">d.colors</a></em>,
+<em><a href="d.colortable.html">d.colortable</a></em>,
+<em><a href="r.blend.html">r.blend</a></em>,
+<em><a href="r.colors.html">r.colors</a></em>,
+<em><a href="i.his.rgb.html">i.his.rgb</a></em>,
+<em><a href="i.rgb.his.html">i.rgb.his</a></em>
+<h2>AUTHOR</h2>
+Glynn Clements (based upon <em><a href="d.his.html">d.his</a></em>)
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.in.arc/description.html
--- grass/trunk/raster/r.in.arc/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.arc/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,52 +0,0 @@
-<em>r.in.arc</em> allows a user to create a (binary) GRASS raster map layer
-from an ESRI ARC/INFO ascii GRID file with (optional) title.
-<p>
-The ARC/INFO ascii GRID file header has 6 lines (last line optional):
- ncols:
- nrows:
- xllcorner:
- yllcorner:
- cellsize:
- nodata_value:
-</pre></div>
-or alternatively (not supported by <em>r.in.arc</em>, but by
-<i><a href=r.in.gdal.html>r.in.gdal</a></i>, last line optional):
- ncols:
- nrows:
- xllcenter:
- yllcenter:
- cellsize:
- nodata_value:
-</pre></div>
-<h2>NOTES</h2>
-<em>r.in.arc</em> handles floating point cell values. The <b>mult</b>
-option allows the number of significant figures of a floating point cell
-to be increased before importing. Multiples of ten are the most functional
-multipliers.
-<h2>EXAMPLE</h2>
-To import a ARC/INFO ascii grid, applying a 10x multiplier during import, with title:
-r.in.arc input=elev_meters.asc output=elev_decimeters title="Elevation data converted to decimeters" mult=10
-</div></pre>
-<h2>SEE ALSO</h2>
-<i><a href="r.in.gdal.html">r.in.gdal</a></i>
-<i><a href="r.out.arc.html">r.out.arc</a></i>
-<h2>AUTHOR</h2>
-Unknown German author, updated by Bill Brown to floating point support.
Copied: grass/trunk/raster/r.in.arc/r.in.arc.html (from rev 32770, grass/trunk/raster/r.in.arc/description.html)
--- grass/trunk/raster/r.in.arc/r.in.arc.html (rev 0)
+++ grass/trunk/raster/r.in.arc/r.in.arc.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,52 @@
+<em>r.in.arc</em> allows a user to create a (binary) GRASS raster map layer
+from an ESRI ARC/INFO ascii GRID file with (optional) title.
+<p>
+The ARC/INFO ascii GRID file header has 6 lines (last line optional):
+ ncols:
+ nrows:
+ xllcorner:
+ yllcorner:
+ cellsize:
+ nodata_value:
+</pre></div>
+or alternatively (not supported by <em>r.in.arc</em>, but by
+<i><a href=r.in.gdal.html>r.in.gdal</a></i>, last line optional):
+ ncols:
+ nrows:
+ xllcenter:
+ yllcenter:
+ cellsize:
+ nodata_value:
+</pre></div>
+<h2>NOTES</h2>
+<em>r.in.arc</em> handles floating point cell values. The <b>mult</b>
+option allows the number of significant figures of a floating point cell
+to be increased before importing. Multiples of ten are the most functional
+multipliers.
+<h2>EXAMPLE</h2>
+To import a ARC/INFO ascii grid, applying a 10x multiplier during import, with title:
+r.in.arc input=elev_meters.asc output=elev_decimeters title="Elevation data converted to decimeters" mult=10
+</div></pre>
+<h2>SEE ALSO</h2>
+<i><a href="r.in.gdal.html">r.in.gdal</a></i>
+<i><a href="r.out.arc.html">r.out.arc</a></i>
+<h2>AUTHOR</h2>
+Unknown German author, updated by Bill Brown to floating point support.
Deleted: grass/trunk/raster/r.in.ascii/description.html
--- grass/trunk/raster/r.in.ascii/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.ascii/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,121 +0,0 @@
-<em>r.in.ascii</em> allows a user to create a (binary) GRASS raster map
-layer from an ASCII raster input file with (optional) TITLE.
-<p>
-The GRASS ASCII <b>input</b> file has a header section which describes
-the location and size of the data, followed by the data itself.
-<p>
-The header has 6 lines:
-north: xxxxxx.xx
-south: xxxxxx.xx
-east: xxxxxx.xx
-west: xxxxxx.xx
-rows: r
-cols: c
-</pre></div>
-The north, south, east, and west field values entered
-are the coordinates of the edges of the geographic region.
-The rows and cols field values entered describe the dimensions
-of the matrix of data to follow.
-The data which follows is <em>r</em> rows of <em>c</em> integers.
-<p>
-Optionally the following parameters can be defined in the header section:
-null: nn
-type: float
-multiplier: 2.
-</pre></div>
-<p>
-"null" defines a string or number to be converted to NULL value (no
-data).<br>
-"type" defines the data type (int, float double) and is not required.<br>
-"multiplier" is an optional parameter to multiply each cell value.
-<h2>NOTES</h2>
-The geographic coordinates north, south, east, and west
-describe the outer edges of the geographic region. They
-run along the edges of the cells at the edge of the
-geographic region and <em>not</em> through the center of the cells
-at the edges.
-The NW value occurs at the beginning of the first line of data, and the
-SW value occurs at the beginning of the last line of data.
-<p>
-The data (which follows the header section) must contain
-<tt>r</tt> <em>x</em> <tt>c</tt> values, but it is not necessary
-that all the data for a row be on one line. A row may be
-split over many lines.
-<p>
-<em>r.in.ascii</em> may import <i>integer</i>, <i>floating point</i>, or <i>double</i> cell
-types using the <b>-i</b>, <b>-f</b>, and <b>-d</b> flags, respectively.
-<p>
-The header information in ESRI Raster ASCII files differs from GRASS.
-To convert an Arc/Info (ArcView) ASCII grid file into GRASS, see
-<em><a href="r.in.arc.html">r.in.arc</a></em>.
-<p>
-SURFER (Golden Software) ASCII files may be imported by passing the <b>-s</b> flag.
-<h2>EXAMPLE</h2>
-The following is a sample <b>input</b> file to <em>r.in.ascii</em>:
-north: 4299000.00
-south: 4247000.00
-east: 528000.00
-west: 500000.00
-rows: 10
-cols: 15
-null: -9999
-1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.out.ascii.html">r.out.ascii</a>,
-<a href="r.in.arc.html">r.in.arc</a>,
-<a href="r.in.gdal.html">r.in.gdal</a>,
-<a href="r.out.arc.html">r.out.arc</a>,
-<a href="r.in.bin.html">r.in.bin</a>,
-<a href="r3.in.ascii.html">r3.in.ascii</a></em>,
-<a href="http://grass.itc.it/gdp/html_grass5/ascii_formats.html">GRASS ASCII formats</a>
-</em>
-<h2>AUTHOR</h2>
-Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
-Surfer support by Roger Miller
Copied: grass/trunk/raster/r.in.ascii/r.in.ascii.html (from rev 32770, grass/trunk/raster/r.in.ascii/description.html)
--- grass/trunk/raster/r.in.ascii/r.in.ascii.html (rev 0)
+++ grass/trunk/raster/r.in.ascii/r.in.ascii.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,121 @@
+<em>r.in.ascii</em> allows a user to create a (binary) GRASS raster map
+layer from an ASCII raster input file with (optional) TITLE.
+<p>
+The GRASS ASCII <b>input</b> file has a header section which describes
+the location and size of the data, followed by the data itself.
+<p>
+The header has 6 lines:
+north: xxxxxx.xx
+south: xxxxxx.xx
+east: xxxxxx.xx
+west: xxxxxx.xx
+rows: r
+cols: c
+</pre></div>
+The north, south, east, and west field values entered
+are the coordinates of the edges of the geographic region.
+The rows and cols field values entered describe the dimensions
+of the matrix of data to follow.
+The data which follows is <em>r</em> rows of <em>c</em> integers.
+<p>
+Optionally the following parameters can be defined in the header section:
+null: nn
+type: float
+multiplier: 2.
+</pre></div>
+<p>
+"null" defines a string or number to be converted to NULL value (no
+data).<br>
+"type" defines the data type (int, float double) and is not required.<br>
+"multiplier" is an optional parameter to multiply each cell value.
+<h2>NOTES</h2>
+The geographic coordinates north, south, east, and west
+describe the outer edges of the geographic region. They
+run along the edges of the cells at the edge of the
+geographic region and <em>not</em> through the center of the cells
+at the edges.
+The NW value occurs at the beginning of the first line of data, and the
+SW value occurs at the beginning of the last line of data.
+<p>
+The data (which follows the header section) must contain
+<tt>r</tt> <em>x</em> <tt>c</tt> values, but it is not necessary
+that all the data for a row be on one line. A row may be
+split over many lines.
+<p>
+<em>r.in.ascii</em> may import <i>integer</i>, <i>floating point</i>, or <i>double</i> cell
+types using the <b>-i</b>, <b>-f</b>, and <b>-d</b> flags, respectively.
+<p>
+The header information in ESRI Raster ASCII files differs from GRASS.
+To convert an Arc/Info (ArcView) ASCII grid file into GRASS, see
+<em><a href="r.in.arc.html">r.in.arc</a></em>.
+<p>
+SURFER (Golden Software) ASCII files may be imported by passing the <b>-s</b> flag.
+<h2>EXAMPLE</h2>
+The following is a sample <b>input</b> file to <em>r.in.ascii</em>:
+north: 4299000.00
+south: 4247000.00
+east: 528000.00
+west: 500000.00
+rows: 10
+cols: 15
+null: -9999
+1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.out.ascii.html">r.out.ascii</a>,
+<a href="r.in.arc.html">r.in.arc</a>,
+<a href="r.in.gdal.html">r.in.gdal</a>,
+<a href="r.out.arc.html">r.out.arc</a>,
+<a href="r.in.bin.html">r.in.bin</a>,
+<a href="r3.in.ascii.html">r3.in.ascii</a></em>,
+<a href="http://grass.itc.it/gdp/html_grass5/ascii_formats.html">GRASS ASCII formats</a>
+</em>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
+Surfer support by Roger Miller
Deleted: grass/trunk/raster/r.in.bin/description.html
--- grass/trunk/raster/r.in.bin/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.bin/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,134 +0,0 @@
-<em>r.in.bin</em> allows a user to create a (binary) GRASS raster map layer
-from a variety of binary raster data formats.
-<p>
-The <b> -s</b> flag is used for importing two's-complement signed data.
-<p>
-The <b> -h</b> flag is used to read region information from a Generic
-Mapping Tools (GMT) type binary header. It is compatible with GMT binary
-grid types 1 and 2.
-<p>
-of the matrix of data to follow. If input is a
-<a href=http://gmt.soest.hawaii.edu/>GMT</a> binary array
-(-h flag), the six dimension fields are obtained from the GMT header.
-If the bytes field is entered incorrectly an error will be generated
-suggesting a closer bytes value.
-<p>
-<em>r.in.bin</em> can be used to import numerous binary arrays including:
-ETOPO30, ETOPO-5, ETOPO-2, Globe DEM, BIL, AVHRR and GMT binary arrays (ID 1 & 2)
-<p>
-<h2>NOTES</h2>
-If optional parameters are not supplied, <b>r.in.bin</b> attempts
-to calculate them. For example if the rows and columns parameters are
-not entered, <b>r.in.bin</b> automatically calculates them by subtracting
-south from north and west from east. This will only produce correct
-results if the raster resolution equals 1. Also, if the north, south,
-east, and west parameters are not entered, <b>r.in.bin</b> assigns
-them from the rows and columns parameters. In the above AVHRR example,
-the raster would be assigned a north=128, south=0, east=128, west=0.
-<p>
-at the edges.
-<p>
-Eastern limit of geographic region (in projected coordinates must be east
-of the west parameter value, but in geographical coordinates will wrap
-around the globe; user errors can be detected by comparing the <em>ewres</em> and
-<em>nsres</em> values of the imported map layer carefully).
-<br>
-Western limit of geographic region (in projected coordinates must be west
-of the east parameter value, but in geographical coordinates will wrap
-<p>
-Notes on (non)signed data:<p>
-If you use the -s flag the highest bit is the sign bit. If this is 1 the
-data is negative, and the data interval is half of the unsigned (not
-exactly).
-<p>
-This flag is only used if <b>bytes=</b> 1. If <b>bytes=</b> is greater
-than 1 the flag is ignored.
-<h2>EXAMPLES</h2>
-<h3>GTOPO30 DEM</h3>
-The following is a sample call of <em>r.in.bin</em> to import
-<a href=http://edcdaac.usgs.gov/gtopo30/gtopo30.asp>GTOPO30 DEM</a>
-data:
-<p>
-r.in.bin -sb input=E020N90.DEM output=gtopo30 bytes=2 north=90 south=40
-east=60 west=20 r=6000 c=4800
-</pre></div>
-<p>
-(you can add "anull=-9999" if you want sea level to have a NULL value)
-<h3>GMT</h3>
-The following is a sample call of <em>r.in.bin</em> to import a GMT
-type 1 (float) binary array:
-<p>
-r.in.bin -hf input=sample.grd output=sample.grass
-</pre></div>
-<p>
-(-b could be used to swap bytes if required)
-<h3>AVHRR</h3>
-The following is a sample call of <em>r.in.bin</em> to import an AVHRR image:
-<p>
-r.in.bin in=p07_b6.dat out=avhrr c=128 r=128
-</pre></div>
-<h3>ETOPO2</h3>
-<a href=http://www.ngdc.noaa.gov/mgg/image/2minrelief.html>ETOPO2 DEM</a> data (here full data set):
-<p>
-r.in.bin ETOPO2.dos.bin out=ETOPO2min r=5400 c=10800 n=90 s=-90 w=-180 e=180 bytes=2
-r.colors ETOPO2min rules=terrain
-</pre></div>
-<h3>TOPEX/SRTM30 PLUS</h3>
-<a href="http://topex.ucsd.edu/WWW_html/srtm30_plus.html">SRTM30 PLUS</a> data:
-<p>
-r.in.bin -sb input=e020n40.Bathmetry.srtm output=e020n40_topex \
- bytes=2 north=40 south=-10 east=60 west=20 r=6000 c=4800
-r.colors e020n40_topex rules=etopo2
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.out.bin.html">r.out.bin</a>,
-<a href="r.in.ascii.html">r.in.ascii</a>,
-<a href="r.out.gdal.html">r.out.gdal</a>,
-<a href="r.in.srtm.html">r.in.srtm</a>
-</em>
-<h2>AUTHORS</h2>
-Jacques Bouchard, France (bouchard at onera.fr)<br>
-Bob Covill, Canada (bcovill at tekmap.ns.ca)<br>
-Man page: Zsolt Felker (felker at c160.pki.matav.hu)
Copied: grass/trunk/raster/r.in.bin/r.in.bin.html (from rev 32770, grass/trunk/raster/r.in.bin/description.html)
--- grass/trunk/raster/r.in.bin/r.in.bin.html (rev 0)
+++ grass/trunk/raster/r.in.bin/r.in.bin.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,134 @@
+<em>r.in.bin</em> allows a user to create a (binary) GRASS raster map layer
+from a variety of binary raster data formats.
+<p>
+The <b> -s</b> flag is used for importing two's-complement signed data.
+<p>
+The <b> -h</b> flag is used to read region information from a Generic
+Mapping Tools (GMT) type binary header. It is compatible with GMT binary
+grid types 1 and 2.
+<p>
+of the matrix of data to follow. If input is a
+<a href=http://gmt.soest.hawaii.edu/>GMT</a> binary array
+(-h flag), the six dimension fields are obtained from the GMT header.
+If the bytes field is entered incorrectly an error will be generated
+suggesting a closer bytes value.
+<p>
+<em>r.in.bin</em> can be used to import numerous binary arrays including:
+ETOPO30, ETOPO-5, ETOPO-2, Globe DEM, BIL, AVHRR and GMT binary arrays (ID 1 & 2)
+<p>
+<h2>NOTES</h2>
+If optional parameters are not supplied, <b>r.in.bin</b> attempts
+to calculate them. For example if the rows and columns parameters are
+not entered, <b>r.in.bin</b> automatically calculates them by subtracting
+south from north and west from east. This will only produce correct
+results if the raster resolution equals 1. Also, if the north, south,
+east, and west parameters are not entered, <b>r.in.bin</b> assigns
+them from the rows and columns parameters. In the above AVHRR example,
+the raster would be assigned a north=128, south=0, east=128, west=0.
+<p>
+at the edges.
+<p>
+Eastern limit of geographic region (in projected coordinates must be east
+of the west parameter value, but in geographical coordinates will wrap
+around the globe; user errors can be detected by comparing the <em>ewres</em> and
+<em>nsres</em> values of the imported map layer carefully).
+<br>
+Western limit of geographic region (in projected coordinates must be west
+of the east parameter value, but in geographical coordinates will wrap
+<p>
+Notes on (non)signed data:<p>
+If you use the -s flag the highest bit is the sign bit. If this is 1 the
+data is negative, and the data interval is half of the unsigned (not
+exactly).
+<p>
+This flag is only used if <b>bytes=</b> 1. If <b>bytes=</b> is greater
+than 1 the flag is ignored.
+<h2>EXAMPLES</h2>
+<h3>GTOPO30 DEM</h3>
+The following is a sample call of <em>r.in.bin</em> to import
+<a href=http://edcdaac.usgs.gov/gtopo30/gtopo30.asp>GTOPO30 DEM</a>
+data:
+<p>
+r.in.bin -sb input=E020N90.DEM output=gtopo30 bytes=2 north=90 south=40
+east=60 west=20 r=6000 c=4800
+</pre></div>
+<p>
+(you can add "anull=-9999" if you want sea level to have a NULL value)
+<h3>GMT</h3>
+The following is a sample call of <em>r.in.bin</em> to import a GMT
+type 1 (float) binary array:
+<p>
+r.in.bin -hf input=sample.grd output=sample.grass
+</pre></div>
+<p>
+(-b could be used to swap bytes if required)
+<h3>AVHRR</h3>
+The following is a sample call of <em>r.in.bin</em> to import an AVHRR image:
+<p>
+r.in.bin in=p07_b6.dat out=avhrr c=128 r=128
+</pre></div>
+<h3>ETOPO2</h3>
+<a href=http://www.ngdc.noaa.gov/mgg/image/2minrelief.html>ETOPO2 DEM</a> data (here full data set):
+<p>
+r.in.bin ETOPO2.dos.bin out=ETOPO2min r=5400 c=10800 n=90 s=-90 w=-180 e=180 bytes=2
+r.colors ETOPO2min rules=terrain
+</pre></div>
+<h3>TOPEX/SRTM30 PLUS</h3>
+<a href="http://topex.ucsd.edu/WWW_html/srtm30_plus.html">SRTM30 PLUS</a> data:
+<p>
+r.in.bin -sb input=e020n40.Bathmetry.srtm output=e020n40_topex \
+ bytes=2 north=40 south=-10 east=60 west=20 r=6000 c=4800
+r.colors e020n40_topex rules=etopo2
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.out.bin.html">r.out.bin</a>,
+<a href="r.in.ascii.html">r.in.ascii</a>,
+<a href="r.out.gdal.html">r.out.gdal</a>,
+<a href="r.in.srtm.html">r.in.srtm</a>
+</em>
+<h2>AUTHORS</h2>
+Jacques Bouchard, France (bouchard at onera.fr)<br>
+Bob Covill, Canada (bcovill at tekmap.ns.ca)<br>
+Man page: Zsolt Felker (felker at c160.pki.matav.hu)
Deleted: grass/trunk/raster/r.in.gdal/description.html
--- grass/trunk/raster/r.in.gdal/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.gdal/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,260 +0,0 @@
-<em>r.in.gdal</em> allows a user to create a (binary) GRASS raster map layer,
-or imagery group, from any GDAL supported raster map format, with an optional
-title. The imported file may also be optionally used to create a new location.
-<!--<h2>OPTIONS</h2>
-Extended explanations:
-<h3>Flags:</h3>
-<dt><b>-e</b>
-<dd>Extend the DEFAULT_WIND in PERMANENT mapset to include the region of
-the new map layer. Old resolution is preserved, but the region, and rows/cols
-are updated. This will fail if the user doesn't have write access to the
-PERMANENT mapset.
-</dl>-->
-<h3>GDAL supported raster formats</h3>
-Full details on GDAL supported formats are available at:<p>
-<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a><p>
-Selected formats of more than 80 supported formats:
-Long Format Name Code Creation Georeferencing Maximum File Size
-Arc/Info ASCII Grid AAIGrid Yes Yes No limits
-Arc/Info Binary Grid AIG No Yes --
-AIRSAR Polarimetric AIRSAR No No --
-Microsoft Windows Device Independent Bitmap (.bmp) BMP Yes Yes 4GiB
-BSB Nautical Chart Format (.kap) BSB No Yes --
-VTP Binary Terrain Format (.bt) BT Yes Yes --
-CEOS (Spot for instance) CEOS No No --
-First Generation USGS DOQ (.doq) DOQ1 No Yes --
-New Labelled USGS DOQ (.doq) DOQ2 No Yes --
-Data (.dt0, .dt1) DTED No Yes --
-ERMapper Compressed Wavelets (.ecw) ECW Yes Yes
-ESRI .hdr Labelled EHdr No Yes --
-ENVI .hdr Labelled Raster ENVI Yes Yes No limits
-Envisat Image Product (.n1) Envisat No No --
-EOSAT FAST Format FAST No Yes --
-FITS (.fits) FITS Yes No
-Graphics Interchange Format (.gif) GIF Yes No 2GB
-Arc/Info Binary Grid (.adf) GIO Yes Yes
-GRASS Rasters GRASS No Yes --
-TIFF / GeoTIFF (.tif) GTiff Yes Yes 4GiB
-Hierarchical Data Format Release 4 (HDF4) HDF4 Yes Yes 2GiB
-Erdas Imagine (.img) HFA Yes Yes No limits
-Atlantis MFF2e HKV Yes Yes No limits
-Image Display and Analysis (WinDisp) IDA Yes Yes 2GB
-ILWIS Raster Map (.mpr,.mpl) ILWIS Yes Yes --
-Japanese DEM (.mem) JDEM No Yes --
-JPEG JFIF (.jpg) JPEG Yes Yes 4GiB (max dimentions 65500x65500)
-JPEG2000 (.jp2, .j2k) JPEG2000 Yes Yes 2GiB
-JPEG2000 (.jp2, .j2k) JP2KAK Yes Yes No limits
-NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B No Yes --
-Erdas 7.x .LAN and .GIS LAN No Yes 2GB
-In Memory Raster MEM Yes Yes 2GiB
-Atlantis MFF MFF Yes Yes No limits
-Multi-resolution Seamless Image Database MrSID No Yes --
-NDF NLAPS Data Format No Yes No limits
-NITF NITF Yes Yes
-NetCDF netCDF Yes Yes 2GB
-OGDI Bridge OGDI No Yes --
-PCI .aux Labelled PAux Yes No No limits
-PCI Geomatics Database File PCIDSK Yes Yes No limits
-Portable Network Graphics (.png) PNG Yes No
-PCRaster (.map) PCRaster Yes No
-Netpbm (.ppm,.pgm) PNM Yes No No limits
-RadarSat2 XML (product.xml) RS2 No Yes 4GB
-USGS SDTS DEM (*CATD.DDF) SDTS No Yes --
-SAR CEOS SAR_CEOS No Yes --
-USGS ASCII DEM (.dem) USGSDEM No Yes --
-X11 Pixmap (.xpm) XPM Yes No
-</pre></div>
-<h3>Location Creation</h3>
-<em>r.in.gdal</em> attempts to preserve projection information when importing
-datasets if the source format includes projection information, and if
-the GDAL driver supports it. If the projection of the source dataset does
-not match the projection of the current location <em>r.in.gdal</em> will
-report an error message (<tt>Projection of dataset does not appear to
-match current location</tt>) and then report the PROJ_INFO parameters of
-the source dataset.
-<p>
-If the user wishes to ignore the difference between the apparent coordinate
-system of the source data and the current location, they may pass the
-<b>-o</b> flag to override the projection check.
-<p>
-If the user wishes to import the data with the full projection definition,
-it is possible to have r.in.gdal automatically create a new location based
-on the projection and extents of the file being read. This is accomplished
-by passing the name to be used for the new location via the <b>location</b>
-parameter. Upon completion of the command, a new location will have been
-created (with only a PERMANENT mapset), and the raster will have been
-imported with the indicated <b>output</b> name into the PERMANENT mapset.
-<p>
-Support for GCPs: In case the image contains GCPs they are written to a
-POINTS file within an imagery group. They can directly be used for
-<a href=i.rectify.html>i.rectify</a>. The <b>target</b> option allows to
-automatically re-project the GCPs from their own projection into another
-projection read from the PROJ_INFO file of the location name
-<b>target</b>.
-<h2>NOTES</h2>
-Planned improvements to <em>r.in.gdal</em> in the future include support for
-reporting everything known about a dataset if the <b>output</b> parameter is not set.
-<p>
-The <em>r.in.gdal</em> comand does support the following features, as long as
-the underlying format driver supports it:
-<p>
-<dl>
-<dt> Color Table
-<dd> Bands with associated colortables will have the color tables transferred.
-Note that if the source has no colormap, r.in.gdal in GRASS 5.0 will emit
-no colormap. Use r.colors map=... color=grey to assign a greyscale colormap.
-In a future version of GRASS r.in.gdal will likely be upgraded to automatically
-emit greyscale colormaps.
-<br>
-<dt> Data Types
-<dd> Most GDAL data types are supported. Float32 and Float64 type bands
-are translated as GRASS floating point cells (but not double precision ...
-this could be added if needed), and most other types are translated as
-GRASS integer cells. This includes 16bit integer data sources. Complex
-(some SAR signal data formats) data bands are translated to two floating
-point cell layers (*.real and *.imaginary).<br>
-<dt> Georeferencing
-<dd> If the dataset has affine georeferencing information, this will be used
-to set the north, south, east and west edges. Rotational coefficients will
-be ignored, resulting in incorrect positioning for rotated datasets.<br>
-<dt> Projection
-<dd> The datasets projection will be used to compare to the current location
-or to define a new location. Internally GDAL represents projections in
-OpenGIS Well Known Text format. A large subset of the total set of GRASS
-projections are supported.<br>
-<dt> Null Values
-<dd> Raster bands for which a null value is recognised by GDAL will have
-the null pixels transformed into GRASS style nulls during import. Many
-generic formats (and formats poorly supported by GDAL) do not have a way
-of recognising null pixels in which case r.null should be used after the
-import.<br>
-<dt> GCPs
-<dd> Datasets that have Ground Control Points will have them imported as
-a POINTS file associated with the imagery group. Datasets with only one
-band that would otherwise have been translated as a simple raster map
-will also have an associated imagery group if there are ground control points.
-The coordinate system of the ground control points is reported by r.in.gdal
-but not preserved. It is up to the user to ensure that the location
-established with i.target has a compatible coordinate system before using
-the points with i.rectify.<br>
-</dl>
-<h3>Error Messages</h3>
-<i>"ERROR: Input map is rotated - cannot import."</i><br>
-In this case the image must be first externally rotated, applying the rotation info stored in
-the metadata field of the raster image file. For example, the
-<a href="http://www.gdal.org/gdal_utilities.html">gdalwarp</a> software can be used
-to transform the map to North-up (note, there are several gdalwarp parameters to select the
-resampling algorithm):
-gdalwarp rotated.tif northup.tif
-</pre></div>
-<p>
-<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
-You need to create a location whose projection matches the data you
-wish to import. Try using <b>location</b> parameter to create a new location based
-upon the projection information in the file. If desired, you can then re-project
-it to another location with <em>r.proj</em>.
-<h2>EXAMPLES</h2>
-To avoid that the GTOPO30 data are read incorrectly, you can add a new line
-"PIXELTYPE SIGNEDINT" in the .HDR to force interpretation of the file as
-signed rather than unsigned integers. Then the .DEM file can be imported.
-Finally, e.g. the 'terrain' color table can be assigned to the imported map
-with <em>r.colors</em>.
-<h3>GLOBE DEM</h3>
-To import <a href="http://www.ngdc.noaa.gov/seg/topo/gltiles.shtml">GLOBE DEM tiles</a>
-(approx 1km resolution, better than GTOPO30 DEM data), the user has to download
-additionally the related <a href="ftp://ftp.ngdc.noaa.gov/GLOBE_DEM/data/elev/esri/hdr/">HDR file(s)</a>.
-Finally, e.g. the 'terrain' color table can be assigned to the imported map with <em>r.colors</em>.
-<h3>Worldclim.org</h3>
-To import <a href="http://www.worldclim.org">Worldclim</a> data, the following
-line has to be added to each .hdr file:
-PIXELTYPE SIGNEDINT
-</pre></div>
-<h3>HDF</h3>
-The import of HDF bands requires the specification of the individual bands
-as seen by GDAL:
-# Example MODIS FPAR
-gdalinfo MOD15A2.A2003153.h18v04.004.2003171141042.hdf
-Subdatasets:
- SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"MOD15A2.A2003153.h18v04.004.2003171141042.hdf":MOD_Grid_MOD15A2:Fpar_1km
- SUBDATASET_1_DESC=[1200x1200] Fpar_1km MOD_Grid_MOD15A2 (8-bit unsigned integer)
- SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"MOD15A2.A2003153.h18v04.004.2003171141042.hdf":MOD_Grid_MOD15A2:Lai_1km
- SUBDATASET_2_DESC=[1200x1200] Lai_1km MOD_Grid_MOD15A2 (8-bit unsigned integer)
-# import of first band, here FPAR 1km:
-r.in.gdal HDF4_EOS:EOS_GRID:"MOD15A2.A2003153.h18v04.004.2003171141042.hdf":MOD_Grid_MOD15A2:Fpar_1km \
- out=fpar_1km_2003_06_02
-# ... likewise for other HDF bands in the file.
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.colors.html">r.colors</a>,
-<a href="r.null.html">r.null</a>
-</em>
-<h2>REFERENCES</h2>
-GDAL Pages: <a href="http://www.gdal.org">http://www.gdal.org/</a><br>
-<h2>AUTHOR</h2>
-<a href="http://home.gdal.org/warmerda/">Frank Warmerdam</a> (<a href="mailto:warmerdam AT pobox dot com">email</a>).
-<p><i>Last changed: $Date$</i>I
Copied: grass/trunk/raster/r.in.gdal/r.in.gdal.html (from rev 32770, grass/trunk/raster/r.in.gdal/description.html)
--- grass/trunk/raster/r.in.gdal/r.in.gdal.html (rev 0)
+++ grass/trunk/raster/r.in.gdal/r.in.gdal.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,260 @@
+<em>r.in.gdal</em> allows a user to create a (binary) GRASS raster map layer,
+or imagery group, from any GDAL supported raster map format, with an optional
+title. The imported file may also be optionally used to create a new location.
+<!--<h2>OPTIONS</h2>
+Extended explanations:
+<h3>Flags:</h3>
+<dt><b>-e</b>
+<dd>Extend the DEFAULT_WIND in PERMANENT mapset to include the region of
+the new map layer. Old resolution is preserved, but the region, and rows/cols
+are updated. This will fail if the user doesn't have write access to the
+PERMANENT mapset.
+</dl>-->
+<h3>GDAL supported raster formats</h3>
+Full details on GDAL supported formats are available at:<p>
+<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a><p>
+Selected formats of more than 80 supported formats:
+Long Format Name Code Creation Georeferencing Maximum File Size
+Arc/Info ASCII Grid AAIGrid Yes Yes No limits
+Arc/Info Binary Grid AIG No Yes --
+AIRSAR Polarimetric AIRSAR No No --
+Microsoft Windows Device Independent Bitmap (.bmp) BMP Yes Yes 4GiB
+BSB Nautical Chart Format (.kap) BSB No Yes --
+VTP Binary Terrain Format (.bt) BT Yes Yes --
+CEOS (Spot for instance) CEOS No No --
+First Generation USGS DOQ (.doq) DOQ1 No Yes --
+New Labelled USGS DOQ (.doq) DOQ2 No Yes --
+Data (.dt0, .dt1) DTED No Yes --
+ERMapper Compressed Wavelets (.ecw) ECW Yes Yes
+ESRI .hdr Labelled EHdr No Yes --
+ENVI .hdr Labelled Raster ENVI Yes Yes No limits
+Envisat Image Product (.n1) Envisat No No --
+EOSAT FAST Format FAST No Yes --
+FITS (.fits) FITS Yes No
+Graphics Interchange Format (.gif) GIF Yes No 2GB
+Arc/Info Binary Grid (.adf) GIO Yes Yes
+GRASS Rasters GRASS No Yes --
+TIFF / GeoTIFF (.tif) GTiff Yes Yes 4GiB
+Hierarchical Data Format Release 4 (HDF4) HDF4 Yes Yes 2GiB
+Erdas Imagine (.img) HFA Yes Yes No limits
+Atlantis MFF2e HKV Yes Yes No limits
+Image Display and Analysis (WinDisp) IDA Yes Yes 2GB
+ILWIS Raster Map (.mpr,.mpl) ILWIS Yes Yes --
+Japanese DEM (.mem) JDEM No Yes --
+JPEG JFIF (.jpg) JPEG Yes Yes 4GiB (max dimentions 65500x65500)
+JPEG2000 (.jp2, .j2k) JPEG2000 Yes Yes 2GiB
+JPEG2000 (.jp2, .j2k) JP2KAK Yes Yes No limits
+NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B No Yes --
+Erdas 7.x .LAN and .GIS LAN No Yes 2GB
+In Memory Raster MEM Yes Yes 2GiB
+Atlantis MFF MFF Yes Yes No limits
+Multi-resolution Seamless Image Database MrSID No Yes --
+NDF NLAPS Data Format No Yes No limits
+NITF NITF Yes Yes
+NetCDF netCDF Yes Yes 2GB
+OGDI Bridge OGDI No Yes --
+PCI .aux Labelled PAux Yes No No limits
+PCI Geomatics Database File PCIDSK Yes Yes No limits
+Portable Network Graphics (.png) PNG Yes No
+PCRaster (.map) PCRaster Yes No
+Netpbm (.ppm,.pgm) PNM Yes No No limits
+RadarSat2 XML (product.xml) RS2 No Yes 4GB
+USGS SDTS DEM (*CATD.DDF) SDTS No Yes --
+SAR CEOS SAR_CEOS No Yes --
+USGS ASCII DEM (.dem) USGSDEM No Yes --
+X11 Pixmap (.xpm) XPM Yes No
+</pre></div>
+<h3>Location Creation</h3>
+<em>r.in.gdal</em> attempts to preserve projection information when importing
+datasets if the source format includes projection information, and if
+the GDAL driver supports it. If the projection of the source dataset does
+not match the projection of the current location <em>r.in.gdal</em> will
+report an error message (<tt>Projection of dataset does not appear to
+match current location</tt>) and then report the PROJ_INFO parameters of
+the source dataset.
+<p>
+If the user wishes to ignore the difference between the apparent coordinate
+system of the source data and the current location, they may pass the
+<b>-o</b> flag to override the projection check.
+<p>
+If the user wishes to import the data with the full projection definition,
+it is possible to have r.in.gdal automatically create a new location based
+on the projection and extents of the file being read. This is accomplished
+by passing the name to be used for the new location via the <b>location</b>
+parameter. Upon completion of the command, a new location will have been
+created (with only a PERMANENT mapset), and the raster will have been
+imported with the indicated <b>output</b> name into the PERMANENT mapset.
+<p>
+Support for GCPs: In case the image contains GCPs they are written to a
+POINTS file within an imagery group. They can directly be used for
+<a href=i.rectify.html>i.rectify</a>. The <b>target</b> option allows to
+automatically re-project the GCPs from their own projection into another
+projection read from the PROJ_INFO file of the location name
+<b>target</b>.
+<h2>NOTES</h2>
+Planned improvements to <em>r.in.gdal</em> in the future include support for
+reporting everything known about a dataset if the <b>output</b> parameter is not set.
+<p>
+The <em>r.in.gdal</em> comand does support the following features, as long as
+the underlying format driver supports it:
+<p>
+<dl>
+<dt> Color Table
+<dd> Bands with associated colortables will have the color tables transferred.
+Note that if the source has no colormap, r.in.gdal in GRASS 5.0 will emit
+no colormap. Use r.colors map=... color=grey to assign a greyscale colormap.
+In a future version of GRASS r.in.gdal will likely be upgraded to automatically
+emit greyscale colormaps.
+<br>
+<dt> Data Types
+<dd> Most GDAL data types are supported. Float32 and Float64 type bands
+are translated as GRASS floating point cells (but not double precision ...
+this could be added if needed), and most other types are translated as
+GRASS integer cells. This includes 16bit integer data sources. Complex
+(some SAR signal data formats) data bands are translated to two floating
+point cell layers (*.real and *.imaginary).<br>
+<dt> Georeferencing
+<dd> If the dataset has affine georeferencing information, this will be used
+to set the north, south, east and west edges. Rotational coefficients will
+be ignored, resulting in incorrect positioning for rotated datasets.<br>
+<dt> Projection
+<dd> The datasets projection will be used to compare to the current location
+or to define a new location. Internally GDAL represents projections in
+OpenGIS Well Known Text format. A large subset of the total set of GRASS
+projections are supported.<br>
+<dt> Null Values
+<dd> Raster bands for which a null value is recognised by GDAL will have
+the null pixels transformed into GRASS style nulls during import. Many
+generic formats (and formats poorly supported by GDAL) do not have a way
+of recognising null pixels in which case r.null should be used after the
+import.<br>
+<dt> GCPs
+<dd> Datasets that have Ground Control Points will have them imported as
+a POINTS file associated with the imagery group. Datasets with only one
+band that would otherwise have been translated as a simple raster map
+will also have an associated imagery group if there are ground control points.
+The coordinate system of the ground control points is reported by r.in.gdal
+but not preserved. It is up to the user to ensure that the location
+established with i.target has a compatible coordinate system before using
+the points with i.rectify.<br>
+</dl>
+<h3>Error Messages</h3>
+<i>"ERROR: Input map is rotated - cannot import."</i><br>
+In this case the image must be first externally rotated, applying the rotation info stored in
+the metadata field of the raster image file. For example, the
+<a href="http://www.gdal.org/gdal_utilities.html">gdalwarp</a> software can be used
+to transform the map to North-up (note, there are several gdalwarp parameters to select the
+resampling algorithm):
+gdalwarp rotated.tif northup.tif
+</pre></div>
+<p>
+<i>"ERROR: Projection of dataset does not appear to match the current location."</i><br>
+You need to create a location whose projection matches the data you
+wish to import. Try using <b>location</b> parameter to create a new location based
+upon the projection information in the file. If desired, you can then re-project
+it to another location with <em>r.proj</em>.
+<h2>EXAMPLES</h2>
+To avoid that the GTOPO30 data are read incorrectly, you can add a new line
+"PIXELTYPE SIGNEDINT" in the .HDR to force interpretation of the file as
+signed rather than unsigned integers. Then the .DEM file can be imported.
+Finally, e.g. the 'terrain' color table can be assigned to the imported map
+with <em>r.colors</em>.
+<h3>GLOBE DEM</h3>
+To import <a href="http://www.ngdc.noaa.gov/seg/topo/gltiles.shtml">GLOBE DEM tiles</a>
+(approx 1km resolution, better than GTOPO30 DEM data), the user has to download
+additionally the related <a href="ftp://ftp.ngdc.noaa.gov/GLOBE_DEM/data/elev/esri/hdr/">HDR file(s)</a>.
+Finally, e.g. the 'terrain' color table can be assigned to the imported map with <em>r.colors</em>.
+<h3>Worldclim.org</h3>
+To import <a href="http://www.worldclim.org">Worldclim</a> data, the following
+line has to be added to each .hdr file:
+PIXELTYPE SIGNEDINT
+</pre></div>
+<h3>HDF</h3>
+The import of HDF bands requires the specification of the individual bands
+as seen by GDAL:
+# Example MODIS FPAR
+gdalinfo MOD15A2.A2003153.h18v04.004.2003171141042.hdf
+Subdatasets:
+ SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"MOD15A2.A2003153.h18v04.004.2003171141042.hdf":MOD_Grid_MOD15A2:Fpar_1km
+ SUBDATASET_1_DESC=[1200x1200] Fpar_1km MOD_Grid_MOD15A2 (8-bit unsigned integer)
+ SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"MOD15A2.A2003153.h18v04.004.2003171141042.hdf":MOD_Grid_MOD15A2:Lai_1km
+ SUBDATASET_2_DESC=[1200x1200] Lai_1km MOD_Grid_MOD15A2 (8-bit unsigned integer)
+# import of first band, here FPAR 1km:
+r.in.gdal HDF4_EOS:EOS_GRID:"MOD15A2.A2003153.h18v04.004.2003171141042.hdf":MOD_Grid_MOD15A2:Fpar_1km \
+ out=fpar_1km_2003_06_02
+# ... likewise for other HDF bands in the file.
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.colors.html">r.colors</a>,
+<a href="r.null.html">r.null</a>
+</em>
+<h2>REFERENCES</h2>
+GDAL Pages: <a href="http://www.gdal.org">http://www.gdal.org/</a><br>
+<h2>AUTHOR</h2>
+<a href="http://home.gdal.org/warmerda/">Frank Warmerdam</a> (<a href="mailto:warmerdam AT pobox dot com">email</a>).
+<p><i>Last changed: $Date$</i>I
Deleted: grass/trunk/raster/r.in.gridatb/description.html
--- grass/trunk/raster/r.in.gridatb/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.gridatb/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,16 +0,0 @@
-<em>r.in.gridatb</em> imports GRIDATB.FOR map file (TOPMODEL) into GRASS
-raster map.
-<h2>SEE ALSO</h2>
-<em><a href="r.topmodel.html">r.topmodel</a>,</em>
-<em><a href="r.out.gridatb.html">r.out.gridatb</a></em>
-<h2>AUTHOR</h2>
-Huidae Cho based on code from Keith Beven
Copied: grass/trunk/raster/r.in.gridatb/r.in.gridatb.html (from rev 32770, grass/trunk/raster/r.in.gridatb/description.html)
--- grass/trunk/raster/r.in.gridatb/r.in.gridatb.html (rev 0)
+++ grass/trunk/raster/r.in.gridatb/r.in.gridatb.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,16 @@
+<em>r.in.gridatb</em> imports GRIDATB.FOR map file (TOPMODEL) into GRASS
+raster map.
+<h2>SEE ALSO</h2>
+<em><a href="r.topmodel.html">r.topmodel</a>,</em>
+<em><a href="r.out.gridatb.html">r.out.gridatb</a></em>
+<h2>AUTHOR</h2>
+Huidae Cho based on code from Keith Beven
Deleted: grass/trunk/raster/r.in.mat/description.html
--- grass/trunk/raster/r.in.mat/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.mat/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,135 +0,0 @@
-<em>r.in.mat</em> will import a GRASS raster map from a Version 4 MAT-File
-which was created with Matlab or Octave.
-Attributes such as map title and bounds will also be imported if they exist.
-<br>
-<br>
-Specifically, the following array variables will be read:<br>
-<ul>
- <li><b> map_data</b>
- <li><b> map_name</b>
- <li><b> map_title</b>
- <li><b> map_northern_edge</b>
- <li><b> map_southern_edge</b>
- <li><b> map_eastern_edge</b>
- <li><b> map_western_edge</b>
-</ul>
-Any other variables in the MAT-file will be simply skipped over.<br>
-<br>
-The '<b>map_name</b>' variable is optional, if it exists, and is valid, the
-new map will be thus named. If it doesn't exist or a name is specified with
-the <b>output=</b> option, the raster map's name will be set to
-"<tt>MatFile</tt>" or the name specified respectively.
-(maximum 64 characters; normal GRASS naming rules apply)
-<br>
-<br>
-The '<b>map_title</b>' variable is optional, the map's title is set if it
-exists.
-<br>
-<br>
-The '<b>map_northern_edge</b>' and like variables are mandatory unless the
-user is importing to a "XY" non-georeferenced location
-(e.g. imagery data). Latitude and longitude values should be in decimal form.
-<h2>NOTES</h2>
-<em>r.in.mat</em> imports a Version 4 MAT-File. These files can be
-successfully created with more modern versions of Matlab and Octave
-(see "EXAMPLES" below).<br><br>
-Everything should be Endian safe, so the file to be imported can be simply
-copied between different system architectures without binary translation
-(caveat: see "TODO" below).<br><br>
-As there is no IEEE value for <tt>NaN</tt> in integer arrays, GRASS's null
-value may be used to represent it within these maps. Usually Matlab will save
-any integer based matrix with <tt>NaN</tt> values as a double-precision
-floating point array, so this usually isn't an issue. To save space, once the
-map is loaded into GRASS you can convert it back to an integer map with the
-following command:
-<div class="code"><pre>
-r.mapcalc int_map="int(MATFile_map)"
-</pre></div>
-<tt>NaN</tt> values in either floating point or double-precision floating point
-matrices should translate into null values as expected.<br><br>
-<em>r.in.mat</em> must load the entire map array into memory before writing,
-therefore it might have problems with <i>huge</i> arrays.
-(a 3000x4000 DCELL map uses about 100mb RAM)<br><br>
-GRASS defines its map bounds at the outer-edge of the bounding cells, not at
-the coordinates of their centroids. Thus, the following Matlab commands may
-be used to determine and check the map's resolution information will be correct:
- [rows cols] = size(map_data)
- x_range = map_eastern_edge - map_western_edge
- y_range = map_northern_edge - map_southern_edge
- ns_res = y_range/rows
- ew_res = x_range/cols
-</pre></div>
-<br>
-Remember Matlab arrays are referenced as <tt>(row,column)</tt>,
-i.e. <tt>(y,x)</tt>.
-<br><br>
-In addition, <em>r.in.mat</em> and <em>r.out.mat</em> make for a nice
-binary container format for transferring georeferenced maps around,
-even if you don't use Matlab or Octave.
-<h2>EXAMPLES</h2>
-In Matlab, save with:
-save filename.mat map_* -v4
-</pre></div>
-In Octave, save with:
-save -mat4-binary filename.mat map_*
-</pre></div>
-<br>
-<h2>TODO</h2>
-Robust support for mixed-Endian importation.
-<i>(This is a work in progress, please help by reporting any failures to the
-<a href="http://trac.osgeo.org/grass/">
-GRASS bug tracking system</a></i>; you will need to login with an OSGeo Userid)
-<br>
-Add support for importing map history, category information, color map, etc.
-if they exist.
-<br>
-Option to import a version 5 MAT-File, with map and support information
-stored in a single structured array.
-<h2>BUGS</h2>
-If you encounter any problems, please contact the GRASS Development Team.
-<h2>SEE ALSO</h2>
-<i>
-<a href="r.out.mat.html">r.out.mat</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.null.html">r.null</a>.<p>
-The <a href="http://www.octave.org">Octave</a> project
-</i>
-<h2>AUTHOR</h2>
-Hamish Bowman<br> <i>
-Department of Marine Science<br>
-University of Otago<br>
-New Zealand</i><br>
-<br>
Copied: grass/trunk/raster/r.in.mat/r.in.mat.html (from rev 32770, grass/trunk/raster/r.in.mat/description.html)
--- grass/trunk/raster/r.in.mat/r.in.mat.html (rev 0)
+++ grass/trunk/raster/r.in.mat/r.in.mat.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,135 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.mat</em> will import a GRASS raster map from a Version 4 MAT-File
+which was created with Matlab or Octave.
+Attributes such as map title and bounds will also be imported if they exist.
+<br>
+<br>
+Specifically, the following array variables will be read:<br>
+<ul>
+ <li><b> map_data</b>
+ <li><b> map_name</b>
+ <li><b> map_title</b>
+ <li><b> map_northern_edge</b>
+ <li><b> map_southern_edge</b>
+ <li><b> map_eastern_edge</b>
+ <li><b> map_western_edge</b>
+</ul>
+Any other variables in the MAT-file will be simply skipped over.<br>
+<br>
+The '<b>map_name</b>' variable is optional, if it exists, and is valid, the
+new map will be thus named. If it doesn't exist or a name is specified with
+the <b>output=</b> option, the raster map's name will be set to
+"<tt>MatFile</tt>" or the name specified respectively.
+(maximum 64 characters; normal GRASS naming rules apply)
+<br>
+<br>
+The '<b>map_title</b>' variable is optional, the map's title is set if it
+exists.
+<br>
+<br>
+The '<b>map_northern_edge</b>' and like variables are mandatory unless the
+user is importing to a "XY" non-georeferenced location
+(e.g. imagery data). Latitude and longitude values should be in decimal form.
+<h2>NOTES</h2>
+<em>r.in.mat</em> imports a Version 4 MAT-File. These files can be
+successfully created with more modern versions of Matlab and Octave
+(see "EXAMPLES" below).<br><br>
+Everything should be Endian safe, so the file to be imported can be simply
+copied between different system architectures without binary translation
+(caveat: see "TODO" below).<br><br>
+As there is no IEEE value for <tt>NaN</tt> in integer arrays, GRASS's null
+value may be used to represent it within these maps. Usually Matlab will save
+any integer based matrix with <tt>NaN</tt> values as a double-precision
+floating point array, so this usually isn't an issue. To save space, once the
+map is loaded into GRASS you can convert it back to an integer map with the
+following command:
+<div class="code"><pre>
+r.mapcalc int_map="int(MATFile_map)"
+</pre></div>
+<tt>NaN</tt> values in either floating point or double-precision floating point
+matrices should translate into null values as expected.<br><br>
+<em>r.in.mat</em> must load the entire map array into memory before writing,
+therefore it might have problems with <i>huge</i> arrays.
+(a 3000x4000 DCELL map uses about 100mb RAM)<br><br>
+GRASS defines its map bounds at the outer-edge of the bounding cells, not at
+the coordinates of their centroids. Thus, the following Matlab commands may
+be used to determine and check the map's resolution information will be correct:
+ [rows cols] = size(map_data)
+ x_range = map_eastern_edge - map_western_edge
+ y_range = map_northern_edge - map_southern_edge
+ ns_res = y_range/rows
+ ew_res = x_range/cols
+</pre></div>
+<br>
+Remember Matlab arrays are referenced as <tt>(row,column)</tt>,
+i.e. <tt>(y,x)</tt>.
+<br><br>
+In addition, <em>r.in.mat</em> and <em>r.out.mat</em> make for a nice
+binary container format for transferring georeferenced maps around,
+even if you don't use Matlab or Octave.
+<h2>EXAMPLES</h2>
+In Matlab, save with:
+save filename.mat map_* -v4
+</pre></div>
+In Octave, save with:
+save -mat4-binary filename.mat map_*
+</pre></div>
+<br>
+<h2>TODO</h2>
+Robust support for mixed-Endian importation.
+<i>(This is a work in progress, please help by reporting any failures to the
+<a href="http://trac.osgeo.org/grass/">
+GRASS bug tracking system</a></i>; you will need to login with an OSGeo Userid)
+<br>
+Add support for importing map history, category information, color map, etc.
+if they exist.
+<br>
+Option to import a version 5 MAT-File, with map and support information
+stored in a single structured array.
+<h2>BUGS</h2>
+If you encounter any problems, please contact the GRASS Development Team.
+<h2>SEE ALSO</h2>
+<i>
+<a href="r.out.mat.html">r.out.mat</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.null.html">r.null</a>.<p>
+The <a href="http://www.octave.org">Octave</a> project
+</i>
+<h2>AUTHOR</h2>
+Hamish Bowman<br> <i>
+Department of Marine Science<br>
+University of Otago<br>
+New Zealand</i><br>
+<br>
Deleted: grass/trunk/raster/r.in.poly/description.html
--- grass/trunk/raster/r.in.poly/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.poly/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,116 +0,0 @@
-<em>r.in.poly</em> allows the creation of GRASS binary
-raster maps from ASCII files in the current directory
-containing polygon, linear, and point features.
-<p>
-The <b>input</b> file is an ASCII text file containing the
-polygon, linear, and point feature definitions.
-The format of this file is described in the
-<a href="#format.html"><i>INPUT FORMAT</i></a> section below.
-<p>
-The number of raster <b>rows</b> to hold in memory is per default 4096.
-This parameter allows users with less memory (or more) on their
-system to control how much memory <em>r.in.poly</em> uses.
-Usually the default value is fine.
-<h2>NOTES</h2>
-<p>
-The data will be imported using the current region settings to set the
-new raster map's bounds and resolution. Any features falling outside
-the current region will be cropped. The region settings are contolled
-with the <em>g.region</em> module.
-<p>
-The format is a simplified version of the standard GRASS vector ASCII
-format used by <em>v.in.ascii</em>.
-<p>
-Polygons are filled, i.e. they define an area.
-<A NAME="format.html"></a>
-<h3>Input Format</h3>
-The input format for the <b>input</b> file consists of
-sections describing either polygonal areas, linear features, or
-point features. The basic format is:
-A <for polygonal areas>
- easting northing
-= cat# label
-L <for linear features>
- easting northing
-= cat# label
-P <for single cell point features>
- easting northing
-= cat# label
-</pre></div>
-The <tt>A</tt> signals the beginning of a filled polygon.
-It must appear in the first column.
-The <tt>L</tt> signals the beginning of a linear feature.
-It also must appear in the first column.
-The <tt>P</tt> signals the beginning of a single cell point feature.
-Again, it must appear in the first column.
-The coordinates of the vertices of the polygon, or the coordinates defining
-the linear or point feature follow and must have a space in the first
-column and at least one space between the <em>easting</em> and the
-<em>northing.</em> To give meaning to the features, the
-"<tt>=</tt>" indicates that the feature currently being
-processed has category value <em>cat#</em> (which must be
-an integer) and a <em>label</em> (which may be more than
-one word, or which may be omitted).
-<h2>EXAMPLE</h2>
-An area described by four points:
-A
- 591316.80 4926455.50
- 591410.25 4926482.40
- 591434.60 4926393.60
- 591341.20 4926368.70
-= 42 stadium
-</pre></div>
-<h2>SEE ALSO</h2>
-<i>
-<a href="r.digit.html">r.digit</a></i> (for interactive on-screen polygon/line digitizing for raster maps)<br>
-<i><a href="r.colors.html">r.colors</a></i> (for raster map color table creation)<br>
-<i><a href="d.rast.edit.html">d.rast.edit</a><br>
-<a href="g.region.html">g.region</a><br>
-<a href="r.in.xyz.html">r.in.xyz</a><br>
-<a href="r.patch.html">r.patch</a><br>
-<a href="v.in.ascii.html">v.in.ascii</a><br>
-<a href="v.digit.html">v.digit</a><br>
-</i>
-<h2>AUTHOR</h2>
-Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.in.poly/r.in.poly.html (from rev 32770, grass/trunk/raster/r.in.poly/description.html)
--- grass/trunk/raster/r.in.poly/r.in.poly.html (rev 0)
+++ grass/trunk/raster/r.in.poly/r.in.poly.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,116 @@
+<em>r.in.poly</em> allows the creation of GRASS binary
+raster maps from ASCII files in the current directory
+containing polygon, linear, and point features.
+<p>
+The <b>input</b> file is an ASCII text file containing the
+polygon, linear, and point feature definitions.
+The format of this file is described in the
+<a href="#format.html"><i>INPUT FORMAT</i></a> section below.
+<p>
+The number of raster <b>rows</b> to hold in memory is per default 4096.
+This parameter allows users with less memory (or more) on their
+system to control how much memory <em>r.in.poly</em> uses.
+Usually the default value is fine.
+<h2>NOTES</h2>
+<p>
+The data will be imported using the current region settings to set the
+new raster map's bounds and resolution. Any features falling outside
+the current region will be cropped. The region settings are contolled
+with the <em>g.region</em> module.
+<p>
+The format is a simplified version of the standard GRASS vector ASCII
+format used by <em>v.in.ascii</em>.
+<p>
+Polygons are filled, i.e. they define an area.
+<A NAME="format.html"></a>
+<h3>Input Format</h3>
+The input format for the <b>input</b> file consists of
+sections describing either polygonal areas, linear features, or
+point features. The basic format is:
+A <for polygonal areas>
+ easting northing
+= cat# label
+L <for linear features>
+ easting northing
+= cat# label
+P <for single cell point features>
+ easting northing
+= cat# label
+</pre></div>
+The <tt>A</tt> signals the beginning of a filled polygon.
+It must appear in the first column.
+The <tt>L</tt> signals the beginning of a linear feature.
+It also must appear in the first column.
+The <tt>P</tt> signals the beginning of a single cell point feature.
+Again, it must appear in the first column.
+The coordinates of the vertices of the polygon, or the coordinates defining
+the linear or point feature follow and must have a space in the first
+column and at least one space between the <em>easting</em> and the
+<em>northing.</em> To give meaning to the features, the
+"<tt>=</tt>" indicates that the feature currently being
+processed has category value <em>cat#</em> (which must be
+an integer) and a <em>label</em> (which may be more than
+one word, or which may be omitted).
+<h2>EXAMPLE</h2>
+An area described by four points:
+A
+ 591316.80 4926455.50
+ 591410.25 4926482.40
+ 591434.60 4926393.60
+ 591341.20 4926368.70
+= 42 stadium
+</pre></div>
+<h2>SEE ALSO</h2>
+<i>
+<a href="r.digit.html">r.digit</a></i> (for interactive on-screen polygon/line digitizing for raster maps)<br>
+<i><a href="r.colors.html">r.colors</a></i> (for raster map color table creation)<br>
+<i><a href="d.rast.edit.html">d.rast.edit</a><br>
+<a href="g.region.html">g.region</a><br>
+<a href="r.in.xyz.html">r.in.xyz</a><br>
+<a href="r.patch.html">r.patch</a><br>
+<a href="v.in.ascii.html">v.in.ascii</a><br>
+<a href="v.digit.html">v.digit</a><br>
+</i>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.in.xyz/description.html
--- grass/trunk/raster/r.in.xyz/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.in.xyz/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,244 +0,0 @@
-<h2>DESCRIPTION</h2>
-The <em>r.in.xyz</em> module will load and bin ungridded x,y,z ASCII data
-into a new raster map. The user may choose from a variety of statistical
-methods in creating the new raster.
-<p>
-<em>r.in.xyz</em> is designed for processing massive point cloud datasets,
-for example raw LIDAR or sidescan sonar swath data. It has been tested with
-datasets as large as 1.5 billion points.
-<p>
-Available statistics for populating the raster are:<br>
-<ul>
-<table>
-<tr><td><em>n</em></td> <td>number of points in cell</td></tr>
-<tr><td><em>min</em></td> <td>minimum value of points in cell</td></tr>
-<tr><td><em>max</em></td> <td>maximum value of points in cell</td></tr>
-<tr><td><em>range</em></td> <td>range of points in cell</td></tr>
-<tr><td><em>sum</em></td> <td>sum of points in cell</td></tr>
-<tr><td><em>mean</em></td> <td>average value of points in cell</td></tr>
-<tr><td><em>stddev</em></td> <td>standard deviation of points in cell</td></tr>
-<tr><td><em>variance</em></td> <td>variance of points in cell</td></tr>
-<tr><td><em>coeff_var</em></td><td>coefficient of variance of points in cell</td></tr>
-<tr><td><em>median</em></td> <td>median value of points in cell</td></tr>
-<tr valign="baseline"><td><em>percentile</em> </td>
- <td>p<sup><i>th</i></sup> percentile of points in cell</td></tr>
-<tr><td><em>skewness</em></td> <td>skewness of points in cell</td></tr>
-<tr><td><em>trimmean</em></td> <td>trimmed mean of points in cell</td></tr>
-</table><br>
-<li><em>Variance</em> and derivatives use the biased estimator (n). [subject to change]
-<li><em>Coefficient of variance</em> is given in percentage and defined as
-<tt>(stddev/mean)*100</tt>.
-</ul>
-<br>
-<h2>NOTES</h2>
-<h4>Memory use</h4>
-While the <b>input</b> file can be arbitrarily large, <em>r.in.xyz</em>
-will use a large amount of system memory for large raster regions (10000x10000).
-If the module refuses to start complaining that there isn't enough memory,
-use the <b>percent</b> parameter to run the module in several passes.
-In addition using a less precise map format (<tt>CELL</tt> [integer] or
-<tt>FCELL</tt> [floating point]) will use less memory than a <tt>DCELL</tt>
-[double precision floating point] <b>output</b> map. Methods such as <em>n,
-min, max, sum</em> will also use less memory, while <em>stddev, variance,
-and coeff_var</em> will use more.
-The aggregate functions <em>median, percentile, skewness</em> and
-<em>trimmed mean</em> will also use more memory.
-<p>
-The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
-preserving data precision and limiting system resource consumption.
-If reading data from a <tt>stdin</tt> stream, the program can only run using
-a single pass.
-<h4>Setting region bounds and resolution</h4>
-You can use the <b>-s</b> scan flag to find the extent of the input data
-(and thus point density) before performing the full import. Use
-<em>g.region</em> to adjust the region bounds to match. The <b>-g</b> shell
-style flag prints the extent suitable as parameters for <em>g.region</em>.
-A suitable resolution can be found by dividing the number of input points
-by the area covered. e.g.
- wc -l inputfile.txt
- g.region -p
- # points_per_cell = n_points / (rows * cols)
- g.region -e
- # UTM location:
- # points_per_sq_m = n_points / (ns_extent * ew_extent)
- # Lat/Lon location:
- # points_per_sq_m = n_points / (ns_extent * ew_extent*cos(lat) * (1852*60)^2)
-</pre></div>
-<p>
-If you only intend to interpolate the data with <em>r.to.vect</em> and
-<em>v.surf.rst</em>, then there is little point to setting the region
-resolution so fine that you only catch one data point per cell -- you might
-as well use "<tt>v.in.ascii -zbt</tt>" directly.
-<h4>Filtering</h4>
-Points falling outside the current region will be skipped. This includes
-points falling <em>exactly</em> on the southern region bound.
-(to capture those adjust the region with "<tt>g.region s=s-0.000001</tt>";
-see <em>g.region</em>)
-<p>
-Blank lines and comment lines starting with the hash symbol (<tt>#</tt>)
-will be skipped.
-<p>
-The <b>zrange</b> parameter may be used for filtering the input data by
-vertical extent. Example uses might include preparing multiple raster
-sections to be combined into a 3D raster array with <em>r.to.rast3</em>, or
-for filtering outliers on relatively flat terrain.
-<p>
-In varied terrain the user may find that <em>min</em> maps make for a good
-noise filter as most LIDAR noise is from premature hits. The <em>min</em> map
-may also be useful to find the underlying topography in a forested or urban
-environment if the cells are over sampled.
-<p>
-The user can use a combination of <em>r.in.xyz</em> <b>output</b> maps to create
-custom filters. e.g. use <em>r.mapcalc</em> to create a <tt>mean-(2*stddev)</tt>
-map. [In this example the user may want to include a lower bound filter in
-<em>r.mapcalc</em> to remove highly variable points (small <em>n</em>) or run
-<em>r.neighbors</em> to smooth the stddev map before further use.]
-<h4>Reprojection</h4>
-If the raster map is to be reprojected, it may be more appropriate to reproject
-the input points with <em>m.proj</em> or <em>cs2cs</em> before running
-<em>r.in.xyz</em>.
-<h4>Interpolation into a DEM</h4>
-The vector engine's topographic abilities introduce a finite memory overhead
-per vector point which will typically limit a vector map to approximately
-3 million points (~ 1750^2 cells). If you want more, use the <em>r.to.vect</em>
-<b>-b</b> flag to skip building topology. Without topology, however, all
-you'll be able to do with the vector map is display with <em>d.vect</em> and
-interpolate with <em>v.surf.rst</em>.
-Run <em>r.univar</em> on your raster map to check the number of non-NULL cells
-and adjust bounds and/or resolution as needed before proceeding.
-<p>
-Typical commands to create a DEM using a regularized spline fit:
- r.univar lidar_min
- r.to.vect -z feature=point in=lidar_min out=lidar_min_pt
- v.surf.rst layer=0 in=lidar_min_pt elev=lidar_min.rst
-</pre></div>
-<br>
-<h2>EXAMPLE</h2>
-Import the <a href="http://mpa.itc.it/grasstutor/data_menu2nd.phtml">Jockey's
-Ridge, NC, LIDAR dataset</a>, and process into a clean DEM:
- # scan and set region bounds
- r.in.xyz -s fs=, in=lidaratm2.txt out=test
- g.region n=35.969493 s=35.949693 e=-75.620999 w=-75.639999
- g.region res=0:00:00.075 -a
- # create "n" map containing count of points per cell for checking density
- r.in.xyz in=lidaratm2.txt out=lidar_n fs=, method=n zrange=-2,50
- # check point density [rho = n_sum / (rows*cols)]
- r.univar lidar_n | grep sum
- # create "min" map (elevation filtered for premature hits)
- r.in.xyz in=lidaratm2.txt out=lidar_min fs=, method=min zrange=-2,50
- # zoom to area of interest
- g.region n=35:57:56.25N s=35:57:13.575N w=75:38:23.7W e=75:37:15.675W
- # check number of non-null cells (try and keep under a few million)
- r.univar lidar_min | grep '^n:'
- # convert to points
- # interpolate using a regularized spline fit
- # set color scale to something interesting
- r.colors lidar_min.rst rule=bcyr -n -e
- # prepare a 1:1:1 scaled version for NVIZ visualization (for lat/lon input)
- r.mapcalc "lidar_min.rst_scaled = lidar_min.rst / (1852*60)"
- r.colors lidar_min.rst_scaled rule=bcyr -n -e
-</pre></div>
-<br>
-<h2>TODO</h2>
-<ul>
-<li> Support for multiple map output from a single run.<br>
- <tt>method=string[,string,...] output=name[,name,...]</tt>
-</ul>
-<h2>BUGS</h2>
-<ul>
-<li> <em>n</em> map sum can be ever-so-slightly more than `<tt>wc -l</tt>`
- with e.g. <tt>percent=10</tt> or less.
- <br>Cause unknown.
-<li> <em>n</em> map <tt>percent=100</tt> and <tt>percent=xx</tt> maps
- differ slightly (point will fall above/below the segmentation line)
- <br>Investigate with "<tt>r.mapcalc diff=bin_n.100 - bin_n.33</tt>" etc.
-<li> "<tt>nan</tt>" can leak into <em>coeff_var</em> maps.
- <br>Cause unknown. Possible work-around: "<tt>r.null setnull=nan</tt>"
-<!-- Another method: r.mapcalc 'No_nan = if(map == map, map, null() )' -->
-</ul>
-If you encounter any problems (or solutions!) please contact the GRASS
-Development Team.
-<h2>SEE ALSO</h2>
-<i>
-<a href="m.proj.html">m.proj</a><br>
-<a href="r.fillnulls.html">r.fillnulls</a><br>
-<a href="r.in.ascii.html">r.in.ascii</a><br>
-<a href="r.mapcalc.html">r.mapcalc</a><br>
-<a href="r.neighbors.html">r.neighbors</a><br>
-<a href="r.out.xyz.html">r.out.xyz</a><br>
-<a href="r.to.rast3.html">r.to.rast3</a><br>
-<a href="r.to.vect.html">r.to.vect</a><br>
-<a href="r.univar.html">r.univar</a><br>
-<a href="r.univar.sh.html">r.univar.sh</a><br>
-<a href="v.out.ascii.html">v.out.ascii</a><br>
-<a href="v.surf.rst.html">v.surf.rst</a>
-</i>
-<h2>AUTHORS</h2>
-<br>
-Extended by Volker Wichmann to support the aggregate functions
-<i>median, percentile, skewness</i> and <i>trimmed mean</i>.
-<br>
-<p>
-<i>Last changed: $Date$</i></p>
Copied: grass/trunk/raster/r.in.xyz/r.in.xyz.html (from rev 32770, grass/trunk/raster/r.in.xyz/description.html)
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html (rev 0)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,244 @@
+The <em>r.in.xyz</em> module will load and bin ungridded x,y,z ASCII data
+into a new raster map. The user may choose from a variety of statistical
+methods in creating the new raster.
+<p>
+<em>r.in.xyz</em> is designed for processing massive point cloud datasets,
+for example raw LIDAR or sidescan sonar swath data. It has been tested with
+datasets as large as 1.5 billion points.
+<p>
+Available statistics for populating the raster are:<br>
+<ul>
+<table>
+<tr><td><em>n</em></td> <td>number of points in cell</td></tr>
+<tr><td><em>min</em></td> <td>minimum value of points in cell</td></tr>
+<tr><td><em>max</em></td> <td>maximum value of points in cell</td></tr>
+<tr><td><em>range</em></td> <td>range of points in cell</td></tr>
+<tr><td><em>sum</em></td> <td>sum of points in cell</td></tr>
+<tr><td><em>mean</em></td> <td>average value of points in cell</td></tr>
+<tr><td><em>stddev</em></td> <td>standard deviation of points in cell</td></tr>
+<tr><td><em>variance</em></td> <td>variance of points in cell</td></tr>
+<tr><td><em>coeff_var</em></td><td>coefficient of variance of points in cell</td></tr>
+<tr><td><em>median</em></td> <td>median value of points in cell</td></tr>
+<tr valign="baseline"><td><em>percentile</em> </td>
+ <td>p<sup><i>th</i></sup> percentile of points in cell</td></tr>
+<tr><td><em>skewness</em></td> <td>skewness of points in cell</td></tr>
+<tr><td><em>trimmean</em></td> <td>trimmed mean of points in cell</td></tr>
+</table><br>
+<li><em>Variance</em> and derivatives use the biased estimator (n). [subject to change]
+<li><em>Coefficient of variance</em> is given in percentage and defined as
+<tt>(stddev/mean)*100</tt>.
+</ul>
+<br>
+<h2>NOTES</h2>
+<h4>Memory use</h4>
+While the <b>input</b> file can be arbitrarily large, <em>r.in.xyz</em>
+will use a large amount of system memory for large raster regions (10000x10000).
+If the module refuses to start complaining that there isn't enough memory,
+use the <b>percent</b> parameter to run the module in several passes.
+In addition using a less precise map format (<tt>CELL</tt> [integer] or
+<tt>FCELL</tt> [floating point]) will use less memory than a <tt>DCELL</tt>
+[double precision floating point] <b>output</b> map. Methods such as <em>n,
+min, max, sum</em> will also use less memory, while <em>stddev, variance,
+and coeff_var</em> will use more.
+The aggregate functions <em>median, percentile, skewness</em> and
+<em>trimmed mean</em> will also use more memory.
+<p>
+The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
+preserving data precision and limiting system resource consumption.
+If reading data from a <tt>stdin</tt> stream, the program can only run using
+a single pass.
+<h4>Setting region bounds and resolution</h4>
+You can use the <b>-s</b> scan flag to find the extent of the input data
+(and thus point density) before performing the full import. Use
+<em>g.region</em> to adjust the region bounds to match. The <b>-g</b> shell
+style flag prints the extent suitable as parameters for <em>g.region</em>.
+A suitable resolution can be found by dividing the number of input points
+by the area covered. e.g.
+ wc -l inputfile.txt
+ g.region -p
+ # points_per_cell = n_points / (rows * cols)
+ g.region -e
+ # UTM location:
+ # points_per_sq_m = n_points / (ns_extent * ew_extent)
+ # Lat/Lon location:
+ # points_per_sq_m = n_points / (ns_extent * ew_extent*cos(lat) * (1852*60)^2)
+</pre></div>
+<p>
+If you only intend to interpolate the data with <em>r.to.vect</em> and
+<em>v.surf.rst</em>, then there is little point to setting the region
+resolution so fine that you only catch one data point per cell -- you might
+as well use "<tt>v.in.ascii -zbt</tt>" directly.
+<h4>Filtering</h4>
+Points falling outside the current region will be skipped. This includes
+points falling <em>exactly</em> on the southern region bound.
+(to capture those adjust the region with "<tt>g.region s=s-0.000001</tt>";
+see <em>g.region</em>)
+<p>
+Blank lines and comment lines starting with the hash symbol (<tt>#</tt>)
+will be skipped.
+<p>
+The <b>zrange</b> parameter may be used for filtering the input data by
+vertical extent. Example uses might include preparing multiple raster
+sections to be combined into a 3D raster array with <em>r.to.rast3</em>, or
+for filtering outliers on relatively flat terrain.
+<p>
+In varied terrain the user may find that <em>min</em> maps make for a good
+noise filter as most LIDAR noise is from premature hits. The <em>min</em> map
+may also be useful to find the underlying topography in a forested or urban
+environment if the cells are over sampled.
+<p>
+The user can use a combination of <em>r.in.xyz</em> <b>output</b> maps to create
+custom filters. e.g. use <em>r.mapcalc</em> to create a <tt>mean-(2*stddev)</tt>
+map. [In this example the user may want to include a lower bound filter in
+<em>r.mapcalc</em> to remove highly variable points (small <em>n</em>) or run
+<em>r.neighbors</em> to smooth the stddev map before further use.]
+<h4>Reprojection</h4>
+If the raster map is to be reprojected, it may be more appropriate to reproject
+the input points with <em>m.proj</em> or <em>cs2cs</em> before running
+<em>r.in.xyz</em>.
+<h4>Interpolation into a DEM</h4>
+The vector engine's topographic abilities introduce a finite memory overhead
+per vector point which will typically limit a vector map to approximately
+3 million points (~ 1750^2 cells). If you want more, use the <em>r.to.vect</em>
+<b>-b</b> flag to skip building topology. Without topology, however, all
+you'll be able to do with the vector map is display with <em>d.vect</em> and
+interpolate with <em>v.surf.rst</em>.
+Run <em>r.univar</em> on your raster map to check the number of non-NULL cells
+and adjust bounds and/or resolution as needed before proceeding.
+<p>
+Typical commands to create a DEM using a regularized spline fit:
+ r.univar lidar_min
+ r.to.vect -z feature=point in=lidar_min out=lidar_min_pt
+ v.surf.rst layer=0 in=lidar_min_pt elev=lidar_min.rst
+</pre></div>
+<br>
+<h2>EXAMPLE</h2>
+Import the <a href="http://mpa.itc.it/grasstutor/data_menu2nd.phtml">Jockey's
+Ridge, NC, LIDAR dataset</a>, and process into a clean DEM:
+ # scan and set region bounds
+ r.in.xyz -s fs=, in=lidaratm2.txt out=test
+ g.region n=35.969493 s=35.949693 e=-75.620999 w=-75.639999
+ g.region res=0:00:00.075 -a
+ # create "n" map containing count of points per cell for checking density
+ r.in.xyz in=lidaratm2.txt out=lidar_n fs=, method=n zrange=-2,50
+ # check point density [rho = n_sum / (rows*cols)]
+ r.univar lidar_n | grep sum
+ # create "min" map (elevation filtered for premature hits)
+ r.in.xyz in=lidaratm2.txt out=lidar_min fs=, method=min zrange=-2,50
+ # zoom to area of interest
+ g.region n=35:57:56.25N s=35:57:13.575N w=75:38:23.7W e=75:37:15.675W
+ # check number of non-null cells (try and keep under a few million)
+ r.univar lidar_min | grep '^n:'
+ # convert to points
+ # interpolate using a regularized spline fit
+ # set color scale to something interesting
+ r.colors lidar_min.rst rule=bcyr -n -e
+ # prepare a 1:1:1 scaled version for NVIZ visualization (for lat/lon input)
+ r.mapcalc "lidar_min.rst_scaled = lidar_min.rst / (1852*60)"
+ r.colors lidar_min.rst_scaled rule=bcyr -n -e
+</pre></div>
+<br>
+<h2>TODO</h2>
+<ul>
+<li> Support for multiple map output from a single run.<br>
+ <tt>method=string[,string,...] output=name[,name,...]</tt>
+</ul>
+<h2>BUGS</h2>
+<ul>
+<li> <em>n</em> map sum can be ever-so-slightly more than `<tt>wc -l</tt>`
+ with e.g. <tt>percent=10</tt> or less.
+ <br>Cause unknown.
+<li> <em>n</em> map <tt>percent=100</tt> and <tt>percent=xx</tt> maps
+ differ slightly (point will fall above/below the segmentation line)
+ <br>Investigate with "<tt>r.mapcalc diff=bin_n.100 - bin_n.33</tt>" etc.
+<li> "<tt>nan</tt>" can leak into <em>coeff_var</em> maps.
+ <br>Cause unknown. Possible work-around: "<tt>r.null setnull=nan</tt>"
+<!-- Another method: r.mapcalc 'No_nan = if(map == map, map, null() )' -->
+</ul>
+If you encounter any problems (or solutions!) please contact the GRASS
+Development Team.
+<h2>SEE ALSO</h2>
+<i>
+<a href="m.proj.html">m.proj</a><br>
+<a href="r.fillnulls.html">r.fillnulls</a><br>
+<a href="r.in.ascii.html">r.in.ascii</a><br>
+<a href="r.mapcalc.html">r.mapcalc</a><br>
+<a href="r.neighbors.html">r.neighbors</a><br>
+<a href="r.out.xyz.html">r.out.xyz</a><br>
+<a href="r.to.rast3.html">r.to.rast3</a><br>
+<a href="r.to.vect.html">r.to.vect</a><br>
+<a href="r.univar.html">r.univar</a><br>
+<a href="r.univar.sh.html">r.univar.sh</a><br>
+<a href="v.out.ascii.html">v.out.ascii</a><br>
+<a href="v.surf.rst.html">v.surf.rst</a>
+</i>
+<h2>AUTHORS</h2>
+<br>
+Extended by Volker Wichmann to support the aggregate functions
+<i>median, percentile, skewness</i> and <i>trimmed mean</i>.
+<br>
+<p>
+<i>Last changed: $Date$</i></p>
Deleted: grass/trunk/raster/r.info/description.html
--- grass/trunk/raster/r.info/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.info/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,113 +0,0 @@
-<em>r.info</em> reports some basic information about a
-user-specified raster map layer. This map layer must exist
-in the user's current mapset search path. Information
-about the map's boundaries, resolution, projection, data
-type, category number, data base location and mapset,
-the timestamp and history are put into a table and written to standard
-output. The types of information listed can also be found
-in the <i>cats</i>, <i>cellhd</i>, and <i>hist</i>
-directories under the mapset in which the named map is
-stored.
-<p>
-The user can save the tabular output to a file
-by using the UNIX redirection mechanism (>); for example, the user
-might save a report on the <em>soils</em> map layer in a file called
-<em>soil.rpt</em> by typing:
-r.info map=soils > soil.rpt
-</pre></div>
-<h2>NOTES</h2>
-On large maps, the total number of cells in the map may not be displayed
-with an accurate number. This is only cosmetic.
-<p>
-Some standards (ISO-C90) and compilers do not support the 'long long' type
-as a 64-bit type. In the case that GRASS was built with such a compiler,
-an accuracy message may be displayed in the output of <em>r.info</em>
-after Total Cells:
-<p>
-<h2>EXAMPLES</h2>
-Below is a full report produced by <em>r.info</em> for the raster map
-<i>slope</i> in the Spearfish sample data base:
- | Layer: slope Date: Mon Nov 5 10:55:57 2001 |
- | Mapset: PERMANENT Login of Creator: neteler |
- | DataBase: /home/neteler/grassdaten |
- | Title: slope in degrees ( slope ) |
- | Timestamp: 20 Mar 1984 10:30 -0600 / 21 Mar 2020 10:30 -0600 |
- | Type of Map: raster Number of Categories: 255 |
- | Data Type: FCELL |
- | Rows: 477 |
- | Columns: 634 |
- | Total Cells: 302418 |
- | Projection: UTM (zone 13) |
- | N: 4928010 S: 4913700 Res: 30 |
- | E: 609000 W: 589980 Res: 30 |
- | Range of data: min = 0.000000 max = 52.520164 |
- | Data Source: |
- | raster elevation file elevation.dem |
- | Data Description: |
- | generated by r.slope.aspect |
- | Comments: |
- | slope map elev = elevation.dem |
- | zfactor = 1.00 format = degrees |
- | min_slp_allowed = 0.000000 |
-</pre></div>
-Alternatively, the output from <em>r.info</em> may be confined to a more terse
-subset of the available information by passing various flags to the module:
-r.info -rst slope
-min=0.000000
-max=52.520164
-nsres=30
-ewres=30
-datatype=FCELL
-r.info -g slope
-north=4928030
-south=4913690
-east=609000
-west=589980
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="g.mapsets.html">g.mapsets</a>,</em>
-<em><a href="r.coin.html">r.coin</a>,</em>
-<em><a href="r.describe.html">r.describe</a>,</em>
-<em><a href="r.report.html">r.report</a>,</em>
-<em><a href="r.stats.html">r.stats</a>,</em>
-<em><a href="r.support.html">r.support</a>,</em>
-<em><a href="r.univar.html">r.univar</a>,</em>
-<em><a href="r.what.html">r.what</a></em>
-<h2>AUTHOR</h2>
-Michael O'Shea,
-<a href="http://www.cecer.army.mil/">U.S. Army Construction Engineering Research Laboratory</a>
Copied: grass/trunk/raster/r.info/r.info.html (from rev 32770, grass/trunk/raster/r.info/description.html)
--- grass/trunk/raster/r.info/r.info.html (rev 0)
+++ grass/trunk/raster/r.info/r.info.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,113 @@
+<em>r.info</em> reports some basic information about a
+user-specified raster map layer. This map layer must exist
+in the user's current mapset search path. Information
+about the map's boundaries, resolution, projection, data
+type, category number, data base location and mapset,
+the timestamp and history are put into a table and written to standard
+output. The types of information listed can also be found
+in the <i>cats</i>, <i>cellhd</i>, and <i>hist</i>
+directories under the mapset in which the named map is
+stored.
+<p>
+The user can save the tabular output to a file
+by using the UNIX redirection mechanism (>); for example, the user
+might save a report on the <em>soils</em> map layer in a file called
+<em>soil.rpt</em> by typing:
+r.info map=soils > soil.rpt
+</pre></div>
+<h2>NOTES</h2>
+On large maps, the total number of cells in the map may not be displayed
+with an accurate number. This is only cosmetic.
+<p>
+Some standards (ISO-C90) and compilers do not support the 'long long' type
+as a 64-bit type. In the case that GRASS was built with such a compiler,
+an accuracy message may be displayed in the output of <em>r.info</em>
+after Total Cells:
+<p>
+<h2>EXAMPLES</h2>
+Below is a full report produced by <em>r.info</em> for the raster map
+<i>slope</i> in the Spearfish sample data base:
+ | Layer: slope Date: Mon Nov 5 10:55:57 2001 |
+ | Mapset: PERMANENT Login of Creator: neteler |
+ | Location: spearfish60 |
+ | DataBase: /home/neteler/grassdaten |
+ | Title: slope in degrees ( slope ) |
+ | Timestamp: 20 Mar 1984 10:30 -0600 / 21 Mar 2020 10:30 -0600 |
+ | Type of Map: raster Number of Categories: 255 |
+ | Data Type: FCELL |
+ | Rows: 477 |
+ | Columns: 634 |
+ | Total Cells: 302418 |
+ | Projection: UTM (zone 13) |
+ | N: 4928010 S: 4913700 Res: 30 |
+ | E: 609000 W: 589980 Res: 30 |
+ | Range of data: min = 0.000000 max = 52.520164 |
+ | Data Source: |
+ | raster elevation file elevation.dem |
+ | Data Description: |
+ | generated by r.slope.aspect |
+ | Comments: |
+ | slope map elev = elevation.dem |
+ | zfactor = 1.00 format = degrees |
+ | min_slp_allowed = 0.000000 |
+</pre></div>
+Alternatively, the output from <em>r.info</em> may be confined to a more terse
+subset of the available information by passing various flags to the module:
+r.info -rst slope
+min=0.000000
+max=52.520164
+nsres=30
+ewres=30
+datatype=FCELL
+r.info -g slope
+north=4928030
+south=4913690
+east=609000
+west=589980
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="g.mapsets.html">g.mapsets</a>,</em>
+<em><a href="r.coin.html">r.coin</a>,</em>
+<em><a href="r.describe.html">r.describe</a>,</em>
+<em><a href="r.report.html">r.report</a>,</em>
+<em><a href="r.stats.html">r.stats</a>,</em>
+<em><a href="r.support.html">r.support</a>,</em>
+<em><a href="r.univar.html">r.univar</a>,</em>
+<em><a href="r.what.html">r.what</a></em>
+<h2>AUTHOR</h2>
+Michael O'Shea,
+<a href="http://www.cecer.army.mil/">U.S. Army Construction Engineering Research Laboratory</a>
Deleted: grass/trunk/raster/r.kappa/description.html
--- grass/trunk/raster/r.kappa/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.kappa/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,66 +0,0 @@
-<em>r.kappa</em> tabulates the error matrix of classification result by
-crossing classified map layer with respect to reference map layer. Both
-overall <em>kappa</em> (accompanied by its <em>variance</em>) and
-conditional <em>kappa</em> values are calculated. This analysis program
-respects the current geographic region and mask settings.
-<p>
-<em>r.kappa</em> calculates the error matrix of the
-two map layers and prepares the table from which the report
-is to be created. <em>kappa</em> values for overall and
-each classes are computed along with their variances. Also
-percent of commission and ommission error, total correct
-classified result by pixel counts, total area in pixel
-counts and percentage of overall correctly classified
-pixels are tabulated.
-<p>
-The report will be write to an output file which is in
-plain text format and named by user at prompt of running
-the program.
-<p>
-The body of the report is arranged in panels. The
-classified result map layer categories is arranged along
-the vertical axis of the table, while the reference map
-layer categories along the horizontal axis. Each panel has
-a maximum of 5 categories (9 if wide format) across the
-top. In addition, the last column of the last panel
-reflects a cross total of each column for each row. All of
-the categories of the map layer arranged along the vertical
-axis, i.e., the reference map layer, are included in each
-panel. There is a total at the bottom of each column
-representing the sum of all the rows in that column.
-<h2>NOTES</h2>
-It is recommended to reclassify categories of classified
-result map layer into a more manageable number before
-running <em>r.kappa</em> on the classified raster map
-layer. Because <em>r.kappa</em> calculates and then reports
-information for each and every category.
-<p>
-<em>NA</em>'s in output file mean non-applicable in case
-<em>MASK</em> exists.
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<!--<em><a href="m.ipf.html">m.ipf</a></em>,-->
-<em><a href="r.category.html">r.category</a></em>,
-<em><a href="r.mask.html">r.mask</a></em>,
-<em><a href="r.reclass.html">r.reclass</a></em>,
-<em><a href="r.report.html">r.report</a></em>,
-<em><a href="r.stats.html">r.stats</a></em>
-<h2>AUTHOR</h2>
-Tao Wen, University of Illinois at Urbana-Champaign, Illinois
Copied: grass/trunk/raster/r.kappa/r.kappa.html (from rev 32770, grass/trunk/raster/r.kappa/description.html)
--- grass/trunk/raster/r.kappa/r.kappa.html (rev 0)
+++ grass/trunk/raster/r.kappa/r.kappa.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,66 @@
+<em>r.kappa</em> tabulates the error matrix of classification result by
+crossing classified map layer with respect to reference map layer. Both
+overall <em>kappa</em> (accompanied by its <em>variance</em>) and
+conditional <em>kappa</em> values are calculated. This analysis program
+respects the current geographic region and mask settings.
+<p>
+<em>r.kappa</em> calculates the error matrix of the
+two map layers and prepares the table from which the report
+is to be created. <em>kappa</em> values for overall and
+each classes are computed along with their variances. Also
+percent of commission and ommission error, total correct
+classified result by pixel counts, total area in pixel
+counts and percentage of overall correctly classified
+pixels are tabulated.
+<p>
+The report will be write to an output file which is in
+plain text format and named by user at prompt of running
+the program.
+<p>
+The body of the report is arranged in panels. The
+classified result map layer categories is arranged along
+the vertical axis of the table, while the reference map
+layer categories along the horizontal axis. Each panel has
+a maximum of 5 categories (9 if wide format) across the
+top. In addition, the last column of the last panel
+reflects a cross total of each column for each row. All of
+the categories of the map layer arranged along the vertical
+axis, i.e., the reference map layer, are included in each
+panel. There is a total at the bottom of each column
+representing the sum of all the rows in that column.
+<h2>NOTES</h2>
+It is recommended to reclassify categories of classified
+result map layer into a more manageable number before
+running <em>r.kappa</em> on the classified raster map
+layer. Because <em>r.kappa</em> calculates and then reports
+information for each and every category.
+<p>
+<em>NA</em>'s in output file mean non-applicable in case
+<em>MASK</em> exists.
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>,
+<!--<em><a href="m.ipf.html">m.ipf</a></em>,-->
+<em><a href="r.category.html">r.category</a></em>,
+<em><a href="r.mask.html">r.mask</a></em>,
+<em><a href="r.reclass.html">r.reclass</a></em>,
+<em><a href="r.report.html">r.report</a></em>,
+<em><a href="r.stats.html">r.stats</a></em>
+<h2>AUTHOR</h2>
+Tao Wen, University of Illinois at Urbana-Champaign, Illinois
Deleted: grass/trunk/raster/r.lake/description.html
--- grass/trunk/raster/r.lake/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.lake/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,90 +0,0 @@
-<p>The module fills a lake to a target water level from a given start point. The user
-can think of it as <em>r.grow</em> with additional checks for elevation. The resulting
-raster map contains cells with values representing lake depth and NULL for all other
-cells beyond the lake.</p>
-<p>This module uses a 3x3 moving window approach to find all cells that
-match three criteria and to define the lake:
-<ul>
- <li>cells are below the specified elevation (i.e., water level);</li>
- <li>cells are connected with an initial cell (seed or E,N value);</li>
- <li>cells are not NULL or masked.</li>
-</ul>
-</p>
-<p>The water level must be in DEM units.</p>
-<h2>NOTES</h2>
-The seed (starting) point can be a raster map with at least one
-cell value greater than zero, or a seed point can be specified as an E,
-N coordinate pair. If the seed is specified as a coordinate pair, an additional
-check is done to make sure that the target water level is above the level of
-the DEM. When a raster map is used as a seed, however, no such checks are done.
-Specifying a target water level below surface represented by DEM will result in an
-empty map. Note: a raster lake map created in a previous run can also be used
-as a seed map for a new run to simulate rising water levels.</p>
-<p>
-The module will create a new map (<b>lake=foo</b>) or can be set to replace
-the input (<b>seed=bar</b>) map if the <b>-o</b> flag is used. The user can use
-<b>-o</b> flag to create animations of rising water level without
-producing a separate map for each frame. An initial seed map must be created
-to start the sequence, and will be overwritten during subsequent runs with resulting
-water levels maps (i.e., a single file serves for both input and output).</p>
-<p>
-Negative output (the <b>-n</b> flag) is useful for visualisations in NVIZ.
-It equals the mapcalc's expression <em>"negative = 0 - positive"</em>.</p>
-<h3>MAPCALC EQUIVALENT - FOR GRASS HACKERS</h3>
-This module was initially created as a script using
-<em>r.mapcalc</em>. This had some limitations - it was slow and no
-checks where done to find out required iteration count. The shell script
-code (using <em>r.mapcalc</em>) used in the original script is shown below:
-${seedmap} = if( ${dem}, \
-if( if( isnull(${seedmap}),0,${seedmap}>0), ${wlevel}-${dem}, \
- if( \
- if(isnull(${seedmap}[-1,0]),0, ${seedmap}[-1,0]>0 && ${wlevel}>${dem}) ||\
- if(isnull(${seedmap}[-1,1]),0, ${seedmap}[-1,1]>0 && ${wlevel}>${dem}) ||\
- if(isnull(${seedmap}[0,1]), 0, ${seedmap}[0,1]>0 && ${wlevel}>${dem}) ||\
- if(isnull(${seedmap}[1,1]), 0, ${seedmap}[1,1]>0 && ${wlevel}>${dem}) ||\
- if(isnull(${seedmap}[1,0]), 0, ${seedmap}[1,0]>0 && ${wlevel}>${dem}) ||\
- if(isnull(${seedmap}[1,-1]),0, ${seedmap}[1,-1]>0 && ${wlevel}>${dem}) ||\
- if(isnull(${seedmap}[0,-1]),0, ${seedmap}[0,-1]>0 && ${wlevel}>${dem}) ||\
- if(isnull(${seedmap}[-1,-1]),0, ${seedmap}[-1,-1]>0 && ${wlevel}>${dem}),\
- ${wlevel}-${dem}, null() )))
-</pre></div>
-The ${seedmap} variable is replaced by seed map names, ${dem} with DEM map name, and
-${wlevel} with target water level. To get single water level, this code block is
-called with same level numerous times (in a loop) as the lake grows by single cells
-during single run.</p>
-<h2>BUGS/KNOWN ISSUES</h2>
-<ul>
- <li>The entire map is loaded into RAM.</li>
- <li>The module is NOT large file safe. (due to the previous point)</li>
- <li>A completely negative seed map will not work! At least one cell must have
- a value >0. Output from <em>r.lake -n</em> can NOT be used as input in the next run.</li>
-</ul>
-<h2>SEE ALSO</h2>
-<em><a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.grow.html">r.grow</a>,
-<a href="r.plane.html">r.plane</a></em>
-<h2>AUTHOR</h2>
-Maris Nartiss (maris.nartiss gmail.com)
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/raster/r.lake/r.lake.html (from rev 32770, grass/trunk/raster/r.lake/description.html)
--- grass/trunk/raster/r.lake/r.lake.html (rev 0)
+++ grass/trunk/raster/r.lake/r.lake.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,90 @@
+<p>The module fills a lake to a target water level from a given start point. The user
+can think of it as <em>r.grow</em> with additional checks for elevation. The resulting
+raster map contains cells with values representing lake depth and NULL for all other
+cells beyond the lake.</p>
+<p>This module uses a 3x3 moving window approach to find all cells that
+match three criteria and to define the lake:
+<ul>
+ <li>cells are below the specified elevation (i.e., water level);</li>
+ <li>cells are connected with an initial cell (seed or E,N value);</li>
+ <li>cells are not NULL or masked.</li>
+</ul>
+</p>
+<p>The water level must be in DEM units.</p>
+<h2>NOTES</h2>
+The seed (starting) point can be a raster map with at least one
+cell value greater than zero, or a seed point can be specified as an E,
+N coordinate pair. If the seed is specified as a coordinate pair, an additional
+check is done to make sure that the target water level is above the level of
+the DEM. When a raster map is used as a seed, however, no such checks are done.
+Specifying a target water level below surface represented by DEM will result in an
+empty map. Note: a raster lake map created in a previous run can also be used
+as a seed map for a new run to simulate rising water levels.</p>
+<p>
+The module will create a new map (<b>lake=foo</b>) or can be set to replace
+the input (<b>seed=bar</b>) map if the <b>-o</b> flag is used. The user can use
+<b>-o</b> flag to create animations of rising water level without
+producing a separate map for each frame. An initial seed map must be created
+to start the sequence, and will be overwritten during subsequent runs with resulting
+water levels maps (i.e., a single file serves for both input and output).</p>
+<p>
+Negative output (the <b>-n</b> flag) is useful for visualisations in NVIZ.
+It equals the mapcalc's expression <em>"negative = 0 - positive"</em>.</p>
+<h3>MAPCALC EQUIVALENT - FOR GRASS HACKERS</h3>
+This module was initially created as a script using
+<em>r.mapcalc</em>. This had some limitations - it was slow and no
+checks where done to find out required iteration count. The shell script
+code (using <em>r.mapcalc</em>) used in the original script is shown below:
+${seedmap} = if( ${dem}, \
+if( if( isnull(${seedmap}),0,${seedmap}>0), ${wlevel}-${dem}, \
+ if( \
+ if(isnull(${seedmap}[-1,0]),0, ${seedmap}[-1,0]>0 && ${wlevel}>${dem}) ||\
+ if(isnull(${seedmap}[-1,1]),0, ${seedmap}[-1,1]>0 && ${wlevel}>${dem}) ||\
+ if(isnull(${seedmap}[0,1]), 0, ${seedmap}[0,1]>0 && ${wlevel}>${dem}) ||\
+ if(isnull(${seedmap}[1,1]), 0, ${seedmap}[1,1]>0 && ${wlevel}>${dem}) ||\
+ if(isnull(${seedmap}[1,0]), 0, ${seedmap}[1,0]>0 && ${wlevel}>${dem}) ||\
+ if(isnull(${seedmap}[1,-1]),0, ${seedmap}[1,-1]>0 && ${wlevel}>${dem}) ||\
+ if(isnull(${seedmap}[0,-1]),0, ${seedmap}[0,-1]>0 && ${wlevel}>${dem}) ||\
+ if(isnull(${seedmap}[-1,-1]),0, ${seedmap}[-1,-1]>0 && ${wlevel}>${dem}),\
+ ${wlevel}-${dem}, null() )))
+</pre></div>
+The ${seedmap} variable is replaced by seed map names, ${dem} with DEM map name, and
+${wlevel} with target water level. To get single water level, this code block is
+called with same level numerous times (in a loop) as the lake grows by single cells
+during single run.</p>
+<h2>BUGS/KNOWN ISSUES</h2>
+<ul>
+ <li>The entire map is loaded into RAM.</li>
+ <li>The module is NOT large file safe. (due to the previous point)</li>
+ <li>A completely negative seed map will not work! At least one cell must have
+ a value >0. Output from <em>r.lake -n</em> can NOT be used as input in the next run.</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em><a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.grow.html">r.grow</a>,
+<a href="r.plane.html">r.plane</a></em>
+<h2>AUTHOR</h2>
+Maris Nartiss (maris.nartiss gmail.com)
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/raster/r.le/r.le.patch/description.html
--- grass/trunk/raster/r.le/r.le.patch/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.le/r.le.patch/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,40 +0,0 @@
-The <em>r.le.patch</em> module calculates attribute, patch size, core
-(interior) size, shape, fractal dimension, and perimeter measures for sets
-of patches in a landscape.
-<h2>NOTES</h2>
-Full instructions can be found in the <b>r.le manual</b> (see "REFERENCES"
-section below) and the <em><a href="r.le.setup.html">r.le.setup</a></em>
-help page.
-<h2>REFERENCES</h2>
-Baker, W.L. and Y. Cai. 1992. The r.le programs for multiscale analysis of
-landscape structure using the GRASS geographical information system.
-Landscape Ecology 7(4):291-302.
-<p>
-The <A href="http://grass.itc.it/gdp/landscape/r_le_manual5.pdf"><i>r.le</i>
-manual: Quantitative analysis of landscape structures</a> (GRASS 5; 2001)
-<h2>SEE ALSO</h2>
-<em>
-<!-- <a href="r.le.dist.html">r.le.dist</a>,
-<a href="r.le.null.html">r.le.null</a>, -->
-<a href="r.le.pixel.html">r.le.pixel</a>,
-<!-- <a href="r.le.rename.html">r.le.rename</a>, -->
-<a href="r.le.setup.html">r.le.setup</a>,
-<a href="r.le.trace.html">r.le.trace</a></em>
-<h2>AUTHOR</h2>
-William L. Baker Department of Geography and Recreation University of
-Wyoming Laramie, Wyoming 82071 U.S.A.
-<p>
Copied: grass/trunk/raster/r.le/r.le.patch/r.le.patch.html (from rev 32770, grass/trunk/raster/r.le/r.le.patch/description.html)
--- grass/trunk/raster/r.le/r.le.patch/r.le.patch.html (rev 0)
+++ grass/trunk/raster/r.le/r.le.patch/r.le.patch.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,40 @@
+The <em>r.le.patch</em> module calculates attribute, patch size, core
+(interior) size, shape, fractal dimension, and perimeter measures for sets
+of patches in a landscape.
+<h2>NOTES</h2>
+Full instructions can be found in the <b>r.le manual</b> (see "REFERENCES"
+section below) and the <em><a href="r.le.setup.html">r.le.setup</a></em>
+help page.
+Baker, W.L. and Y. Cai. 1992. The r.le programs for multiscale analysis of
+landscape structure using the GRASS geographical information system.
+Landscape Ecology 7(4):291-302.
+<p>
+The <A href="http://grass.itc.it/gdp/landscape/r_le_manual5.pdf"><i>r.le</i>
+manual: Quantitative analysis of landscape structures</a> (GRASS 5; 2001)
+<h2>SEE ALSO</h2>
+<em>
+<!-- <a href="r.le.dist.html">r.le.dist</a>,
+<a href="r.le.null.html">r.le.null</a>, -->
+<a href="r.le.pixel.html">r.le.pixel</a>,
+<!-- <a href="r.le.rename.html">r.le.rename</a>, -->
+<a href="r.le.setup.html">r.le.setup</a>,
+<a href="r.le.trace.html">r.le.trace</a></em>
+<h2>AUTHOR</h2>
+William L. Baker Department of Geography and Recreation University of
+Wyoming Laramie, Wyoming 82071 U.S.A.
+<p>
Deleted: grass/trunk/raster/r.le/r.le.pixel/description.html
--- grass/trunk/raster/r.le/r.le.pixel/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.le/r.le.pixel/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,39 +0,0 @@
-The <em>r.le.pixel</em> module contains a set of measures for attributes,
-diversity, texture, juxtaposition, and edge.
-<h2>NOTES</h2>
-help page.
-<p>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.le.patch.html">r.le.patch</a>,
-<h2>AUTHOR</h2>
-<p>
Copied: grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html (from rev 32770, grass/trunk/raster/r.le/r.le.pixel/description.html)
--- grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html (rev 0)
+++ grass/trunk/raster/r.le/r.le.pixel/r.le.pixel.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,39 @@
+The <em>r.le.pixel</em> module contains a set of measures for attributes,
+diversity, texture, juxtaposition, and edge.
+<h2>NOTES</h2>
+help page.
+<p>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.le.patch.html">r.le.patch</a>,
+<h2>AUTHOR</h2>
+<p>
Deleted: grass/trunk/raster/r.le/r.le.setup/description.html
--- grass/trunk/raster/r.le/r.le.setup/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.le/r.le.setup/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,472 +0,0 @@
-<em>r.le.setup</em> program is used to set
-up the sampling and analysis framework that will be used by the other
-<em>r.le</em> programs.
-<h2>NOTES</h2>
-<i>Full instructions can be found in the <b>r.le manual</b> (see "REFERENCES"
-section below).</i>
-<p>
-The first menu allows the user to define a rectangular sampling frame,
-select how sampling will be done (regions, sampling units, moving window),
-setup the limits for groups and classes, and change the color table.
-Use the left mouse button to make your choice.
-<p>
-Information about the structure of the landscape is obtained by overlaying
-a set of sampling areas on top of a specified part (the sampling frame of
-a map layer, and then calculating specific structural measures for the part
-of the map layer that corresponds to the area in each sampling area.
-<p>
-To setup a <em><b>sampling frame</b></em> click on SAMPLING FRAME in the
-main menu. The program will ask "Will the sampling frame (total area
-within which sampling units are distributed) be the whole map? (y/n) [y]"
-Just hit a carriage return to accept the default, which is to use the
-whole map. You do not need to setup a sampling frame if you want to use
-the whole map, as this is the default. To setup a different sampling
-frame type "n" in response to this question. Then use the mouse and a
-rubber band box to outline a rectangular sampling frame on screen.
-This box will be moved to the nearest row and column of the map.
-You will be asked last whether you want to "Refresh the screen before
-choosing more setup?" If you don't like the sampling frame you just setup,
-answer yes to this question, then click on SAMPLING FRAME again to redo
-this part of the setup. This sampling frame will be used in all subsequent
-setup procedures unless you change it. You can change it at any time by
-simply clicking on SAMPLING FRAME again.
-<p>
-A <em><b>sampling area</b></em> may be one of four things. First, it is
-possible to treat the entire map layer as the one (and only) sampling area.
-Second, if the map layer can be divided into meaningful geographical regions,
-then it is possible to treat the regions themselves as sampling areas.
-The third option is that the sampling areas may be sampling units of
-fixed shape and size (also called scale) that are placed within the map
-layer as a whole. The fourth and final option is that the sampling area
-may be moved systematically across the map as a moving window.
-<p>
-If regions are to be used as the sampling areas , then the user can use
-<em>r.le.setup</em> to draw regions or any existing map of regions can
-simply be used directly. To draw regions and create a new regions map
-in <em>r.le.setup</em> select "REGIONS" from the first <em>r.le.setup</em>
-menu, and the user is asked to do the following:
-<dl>
-<pre>
-1. "ENTER THE NEW REGION MAP NAME:". Only a new raster map name is
-acceptable. The user can type LIST to find out the existing raster map
-names in this location and mapset.
-2. "PLEASE OUTLINE REGION # 1". The user should move the mouse cursor
-into the graphic monitor window and use the mouse buttons as instructed:
-Left button: where am I.to display the current coordinates of the cursor.
-Middle button: Mark start (next) point. to enter a vertex of the region
-boundary.
-Right button: Finish region-connect to 1st point to close the region
-boundary by setting the last vertex to be equal to the first one.
-3. A "REGION OPTIONS:" menu is displayed and the user should use the mouse
-to select one of
- the options:<br>
-"DRAW MORE": repeat the above process and setup another region.
-"START OVER": abandon the previous setup and start all over again.
-"DONE-SAVE": save the regions outlined so far and exit this procedure.
-"QUIT-NO SAVE": quit the procedure without saving the regions.
-</pre>
-</dl>
-Once the "DONE-SAVE" option is selected, the new raster map of the sampling
-regions is generated. It is displayed on the monitor window for several
-seconds, the monitor window is refreshed, the main menu is displayed again,
-and the program is ready for other setup work. Note that you cannot draw
-regions in areas outside the mask, if a mask is present (see <em>r.mask</em>
-command).
-<p>
-The user can also use the GRASS <em>r.digit</em> or <em>v.digit</em>
-programs to digitize circular or polygonal regions and to create a
-sampling regions map without using <em>r.le.setup</em>. Or, as mention
-above, an existing raster map can be used as a regions map.
-<p>
-If sampling units are to be used as the sampling areas (Fig. 2), then
-choose "SAMPLING UNITS" from the first <em>r.le.setup</em> menu.
-The program checks the <em>r.le.para</em> subdirectory for an existing
-"units" file from a previous setup session and allows the user to rename
-this file (to save it) before proceeding. The r.le.setup program will
-otherwise overwrite the "units" file. Then the following choice is
-displayed followed by a series of other choices:
-<dl>
-<dd>
-<pre>
- Which do you want to do?
- (1) Use the keyboard to enter sampling unit parameters
- (2) Draw the sampling units with the mouse
- Enter 1 or 2:
-</pre>
-</dl>
-When sampling units are defined using the keyboard, the user inputs the
-shape and size (scale) of the sampling units by specifying dimensions
-in pixels using the keyboard. When sampling units are drawn with the
-mouse, the user clicks the mouse to define the sampling units in the
-GRASS monitor window, and then actually places the sampling units for
-each scale onto the map. By placing the units with the mouse the user
-can directly determine the method of sampling unit distribution as well
-as the shape, size, and number of sampling units.
-<p>
-If the choice is made to define sampling units using the keyboard, the
-following series of questions must be answered:
-<dl>
-<dd>
-<pre>
- How many different SCALES do you want (1-15)?
-</pre>
-</dl>
-The user is asked to specify the number of scales that will be used.
-The <em>r.le</em> programs allow the user to simultaneously sample the
-same map with the same measures using sampling areas of different sizes.
-Currently there can be between 1 and 15 scales that can be sampled
-simultaneously. Substantial output can be produced if many scales are used.
-<p>
-Sampling units must be placed spatially into the landscape. There are
-five options for doing this :
-<p>
-<em>Random nonoverlapping</em><br>
-Sampling units are placed in the landscape by randomly choosing numbers
-that specify the location of the upper left corner of each sampling unit,
-subject to the constraint that successive sampling units not overlap other
-sampling units or the edge of the landscape, and that they must be entirely
-within the area defined by the mask (see <em>r.mask</em> command) if one
-exists.
-<p>
-<em>Systematic contiguous</em><br>
-Sampling units are placed side by side across the rows. The user will
-be able to enter a row and column to indicate where the upper left corner
-of the systematic contiguous framework should be placed. Rows are numbered
-from the top down beginning with row 1 of the sampling frame. Columns are
-numbered from left to right, beginning with column 1 of the sampling frame.
-A random starting location can be obtained by using a standard random
-number table to choose the starting row and column. The <em>r.le.setup</em>
-program does not avoid placing the set of sampling units over areas
-outside the mask. The user will have to make sure that sampling units do
-not extend outside the mask by choosing a particular starting row and
-column or by drawing a sampling frame before placing the set of sampling
-units.
-<p>
-<em>Systematic noncontiguous</em><br>
-The user must specify the starting row and column as in #2 above and the
-amount of spacing (in pixels) between sampling units. Horizontal and
-vertical spacing are identical. Sampling units are again placed side by
-side (but spaced) across the rows. As in #2 the program does not avoid
-placing sampling units outside the masked area; the user will have to
-position the set of units to avoid areas outside the mask.
-<p>
-<em>Stratified random</em><br>
-The strata are rectangular areas within which single sampling units
-are randomly located. The user must first specify the starting row
-and column as in #2 above. Then the user must specify the number of
-strata in the horizontal and vertical directions. As in #2 the program
-does not avoid placing sampling units outside the masked area; the user
-will have to position the set of units to avoid areas outside the mask.
-<p>
-<em>Centered over sites</em><br>
-The user must specify the name of a sitefile containing point locations.
-A single sampling unit is placed with its center over each site in the site
-file. This is a useful approach for determining the landscape structure
-around points, such as around the location of wildlife observations.
-<p>
-The user is prompted to enter a ratio that defines the shape of the
-sampling units. Sampling units may have any rectangular shape,
-including square as a special case of rectangular. Rectangular shapes
-are specified by entering the ratio of columns/rows (horizontal
-dimension/vertical dimension) as a real number. For example, to obtain
-a sampling unit 10 columns wide by 4 rows long specify the ratio as 2.5
-(10/4).
-<dl>
-<dd>
-<pre>
- Recommended maximum SIZE is m in x cell total area. <br>
- What size (in cells) for each sampling unit of scale n?
-</pre>
-</dl>
-The user is then given the recommended maximum possible size for a
-sampling unit (in pixels) and asked to input the size of sampling units
-at each scale. Sampling units can be of any size, but the maximum size
-is the size of the landscape as a whole. All the sampling units, that
-make up a single sampling scale, are the same size. After specifying
-the size, the program determines the nearest actual number of rows and
-columns, and hence size, that is closest to the requested size, given
-the shape requested earlier.
-<dl>
-<dd>
-<pre>
- The nearest size is x cells wide X y cells high = xy cells
- Is this size OK? (y/n) [y]
- Maximum NUMBER of units in scale n is p?
- What NUMBER of sampling units do you want to try to use?
-</pre>
-</dl>
-The maximum number of units that can be placed over the map, given the
-shape and size of the units, is then given. The user can then choose
-the number of sampling units to be used in the map layer. It may not
-always be possible to choose the maximum number, depending upon the
-shape of the sampling units. In the case of systematic contiguous and
-noncontiguous, the program will indicate how many units will fit across
-the columns and down the rows. The user can then specify a particular
-layout (e.g., 6 units could be placed as 2 rows of 3 per row or as 3
-rows of 2 per row).
-<dl>
-<dd>
-<pre>
- Is this set of sampling units OK? (y/n) [y]
-</pre>
-</dl>
-Finally, the set of sampling units is displayed on the screen (e.g., Fig. 1)
-and the user is asked whether it is acceptable. If the answer is no, then
-the user is asked if the screen should be refreshed before redisplaying
-the menu for "Methods of sampling unit distribution" so that the user can
-try the sampling unit setup again.
-<p>
-The choice is made to define sampling units using the mouse, then the
-following menu for use with the mouse is displayed:
-<dl>
-<dd>
-<pre>
- Outline the standard sampling unit of scale n.
- Left button: Check unit size
- Middle button: Move cursor
- Right button: Lower right corner of unit here
-</pre>
-</dl>
-The user can then use the mouse and the rubber band box to outline the
-standard sampling unit. Once it has been outlined, the number of columns
-and rows in the unit, the ratio of width/length and the size of the unit,
-in cells, will be displayed. After this first unit is outlined, then a
-new menu is displayed:
-<dl>
-<dd>
-<pre>
- Outline more sampling units of scale n?
- Left button: Exit
- Middle button: Check unit position
- Right button: Lower right corner of next unit here
-</pre>
-</dl>
-The user can then place more units identical to the standard unit by
-simply clicking the right mouse button where the lower right corner of
-the unit should be placed. The rest of the rubber band box can be
-ignored while placing additional units. The program is set up so that
-units cannot be placed so they overlap one another, so they overlap the
-area outside the mask, or so they overlap the edge of the sampling frame.
-Warning messages are issued for all three of these errors and a sampling
-unit is simply not placed.
-<p>
-Using this procedure a rectangular "window" or single sampling area is
-moved systematically across the map to produce a new map (Fig. 2,3).
-This sampling procedure can only be used with the measures that produce
-a single value or with a single class or group when measures produce
-distributions of values (Table 1). The first class or group specified
-when defining class or group limits (section 2.3.2.) is used if
-distributional measures are chosen with the moving window sampling
-method. In this case, the user should manually edit the
-<em>r.le.para/recl_tb</em> file so that the desired group is listed as
-the first group in this file.
-<p>
-Sampling begins with the upper left corner of the window placed over
-the upper left corner of the sampling frame. It is strongly recommended
-that the user read the section on the GRASS mask (section 2.2.2) prior
-to setting up the moving window, as this mask can be used to speed up
-the moving window operation. The value of the chosen measure is
-calculated for the window area. This value is assigned to the location
-on the new map layer corresponding to the center pixel in the window if
-the window has odd (e.g. 3 X 3) dimensions. The value is assigned to
-the location on the new map layer corresponding to the first pixel below
-and to the right of the center if the window has even dimensions
-(e.g. 6 X 10). If this pixel has the value "0," which means "no data" in
-GRASS, then this pixel is skipped and a value of "0" is assigned to the
-corresponding location in the new map. The window is then moved to the
-right (across the row) by one pixel, and the process is repeated.
-At the end of the row, the window is moved down one pixel, and then back
-across the row. This option produces a new map layer, whose dimensions
-are smaller by approximately (m-1)/2 rows and columns, where m is the
-number of rows or columns in the window.
-<p>
-If the "MOVE-WINDOW" option in the main menu is selected, first the
-program checks for an existing "move_wind" file, in the r.le.para
-subdirectory, containing moving window specifications from a previous
-session. The user is given the option to avoid overwriting this file
-by entering a new file name for the old "move_wind" file. Users should
-be aware that moving window analyses are very slow, because a large
-number of sampling units are, in effect, used. See the appendix on
-"Time needed to complete analyses with the r.le programs" for some
-ideas about how moving window size and sampling frame area affect
-the needed time to complete the analyses.
-<p>
-The <em>r.le</em> programs <em>r.le.dist</em> and <em>r.le.patch</em>
-allow the attribute categories in the input map to be reclassed into
-several attribute groups, and reports the analysis results by each of
-these attribute groups. It is necessary to setup group limits for
-all measures that say "by gp" when typing "<em>r.le.dist help</em>"
-or "<em>r.le.patch help</em>" at the GRASS prompt. The same reclassing
-can be done with the measurement indices (e.g., size), except that each
-"cohort" (class) of the reclassed indices is called an index class
-instead of a group. It is also necessary to setup class limits for
-all measures that say "by class" when typing "<em>r.le.dist help</em>"
-<p>
-Group/class limits are setup by choosing "GROUP/CLASS LIMITS" from the
-main menu upon starting <em>r.le.setup</em>, or you can create the files
-manually using a text editor. The program checks for existing group/class
-limit files in subdirectory <em>r.le.para</em> and allows the user to
-rename these files prior to continuing. If the files are not renamed
-the program will overwrite them. The files are named recl_tb (attribute
-group limits), size (size class limits), shape_PA (shape index class
-limits for perimeter/area index), shape_CPA (shape index class limits
-for corrected perimeter/area index), shape_RCC (shape index class limits
-for related circumscribing circle index), and from_to (for the
-<em>r.le.dist</em> program distance methods m7-m9).
-<p>
-Attribute groups and index classes are defined in a different way.
-In the <em>r.le</em> programs attribute groups are defined as in the
-following example:
-<dl>
-<dd>
-<pre>
- 1, 3, 5, 7, 9 <b>thru</b> 21 = 1 (comment)
- 31 <b>thru</b> 50 = 2 (comment)
- <b>end</b>
-</pre>
-</dl>
-In this example, the existing categories 1, 3, 5, 7, {9, 10, ... 20, 21}
-are included in the new group 1, while {31, 32, 33, ..., 49, 50} are
-included in the new group 2. The characters in bold are the "key words"
-that are required in the definition. Each line is called one "reclass rule".
-<p>
-The GRASS reclass convention is adopted here with a little modification
-(see "<em>r.reclass</em>" command in the GRASS User's Manual).
-The difference is that r.le only allows one rule for each group while the
-GRASS <em>r.reclass</em> command allows more than one. The definition of
-"from" and "to" groups is simply the extension of the GRASS reclass rule.
-The advantage of using the GRASS reclass convention is that the user can
-generate a permanent reclassed map, using GRASS programs, directly from the
-<em>r.le</em> setup results.
-<p>
-The <em>r.le</em> measurement index classes are defined by the lower
-limits of the classes, as in the following example:
-<dl>
-<dd>
-<pre>
- 0.0, 10.0, 50.0, 200.0, <b>-999</b>
-</pre>
-</dl>
-This means:
-<dl>
-<dd>
-<pre>
- if v >= 0.0 and v < 10.0 then v belongs to index class 1;
- if v >= 10.0 and v < 50.0 then v belongs to index class 2;
- if v >= 50.0 and v < 200.0 then v belongs to index class 3;
- if v >= 200.0 then v belongs to index class 4;
-</pre>
-</dl>
-where v is the calculated index value and <b>-999</b> marks the end of
-the index class definition. The measurement index can be the size index,
-one of the three shape indices, or one of the three distance indices.
-The program is currently designed to allow no more than 25 attribute
-groups, 25 size classes, 25 shape index classes, and 25 distance index
-classes. As an alternative, the user may want to permanently group
-certain attributes prior to entering the <em>r.le</em> programs.
-For example, the user may want to group attributes 1-10, in a map whose
-attributes are ages, into a single attribute representing young patches.
-The user can do this using the GRASS <em>r.reclass</em> and
-<em>r.resample</em> commands, which will create a new map layer that can
-then be analyzed directly (without setting up group limits) with the
-<p>
-<h2>SEE ALSO</h2>
-<em>
-<h2>AUTHOR</h2>
-<p>
Copied: grass/trunk/raster/r.le/r.le.setup/r.le.setup.html (from rev 32770, grass/trunk/raster/r.le/r.le.setup/description.html)
--- grass/trunk/raster/r.le/r.le.setup/r.le.setup.html (rev 0)
+++ grass/trunk/raster/r.le/r.le.setup/r.le.setup.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,472 @@
+<h2>DESCRIPTION</h2>
+<em>r.le.setup</em> program is used to set
+up the sampling and analysis framework that will be used by the other
+<em>r.le</em> programs.
+<h2>NOTES</h2>
+<i>Full instructions can be found in the <b>r.le manual</b> (see "REFERENCES"
+section below).</i>
+<p>
+The first menu allows the user to define a rectangular sampling frame,
+select how sampling will be done (regions, sampling units, moving window),
+setup the limits for groups and classes, and change the color table.
+Use the left mouse button to make your choice.
+<p>
+Information about the structure of the landscape is obtained by overlaying
+a set of sampling areas on top of a specified part (the sampling frame of
+a map layer, and then calculating specific structural measures for the part
+of the map layer that corresponds to the area in each sampling area.
+<p>
+To setup a <em><b>sampling frame</b></em> click on SAMPLING FRAME in the
+main menu. The program will ask "Will the sampling frame (total area
+within which sampling units are distributed) be the whole map? (y/n) [y]"
+Just hit a carriage return to accept the default, which is to use the
+whole map. You do not need to setup a sampling frame if you want to use
+the whole map, as this is the default. To setup a different sampling
+frame type "n" in response to this question. Then use the mouse and a
+rubber band box to outline a rectangular sampling frame on screen.
+This box will be moved to the nearest row and column of the map.
+You will be asked last whether you want to "Refresh the screen before
+choosing more setup?" If you don't like the sampling frame you just setup,
+answer yes to this question, then click on SAMPLING FRAME again to redo
+this part of the setup. This sampling frame will be used in all subsequent
+setup procedures unless you change it. You can change it at any time by
+simply clicking on SAMPLING FRAME again.
+<p>
+A <em><b>sampling area</b></em> may be one of four things. First, it is
+possible to treat the entire map layer as the one (and only) sampling area.
+Second, if the map layer can be divided into meaningful geographical regions,
+then it is possible to treat the regions themselves as sampling areas.
+The third option is that the sampling areas may be sampling units of
+fixed shape and size (also called scale) that are placed within the map
+layer as a whole. The fourth and final option is that the sampling area
+may be moved systematically across the map as a moving window.
+<p>
+If regions are to be used as the sampling areas , then the user can use
+<em>r.le.setup</em> to draw regions or any existing map of regions can
+simply be used directly. To draw regions and create a new regions map
+in <em>r.le.setup</em> select "REGIONS" from the first <em>r.le.setup</em>
+menu, and the user is asked to do the following:
+<dl>
+<pre>
+1. "ENTER THE NEW REGION MAP NAME:". Only a new raster map name is
+acceptable. The user can type LIST to find out the existing raster map
+names in this location and mapset.
+2. "PLEASE OUTLINE REGION # 1". The user should move the mouse cursor
+into the graphic monitor window and use the mouse buttons as instructed:
+Left button: where am I.to display the current coordinates of the cursor.
+Middle button: Mark start (next) point. to enter a vertex of the region
+boundary.
+Right button: Finish region-connect to 1st point to close the region
+boundary by setting the last vertex to be equal to the first one.
+3. A "REGION OPTIONS:" menu is displayed and the user should use the mouse
+to select one of
+ the options:<br>
+"DRAW MORE": repeat the above process and setup another region.
+"START OVER": abandon the previous setup and start all over again.
+"DONE-SAVE": save the regions outlined so far and exit this procedure.
+"QUIT-NO SAVE": quit the procedure without saving the regions.
+</pre>
+</dl>
+Once the "DONE-SAVE" option is selected, the new raster map of the sampling
+regions is generated. It is displayed on the monitor window for several
+seconds, the monitor window is refreshed, the main menu is displayed again,
+and the program is ready for other setup work. Note that you cannot draw
+regions in areas outside the mask, if a mask is present (see <em>r.mask</em>
+command).
+<p>
+The user can also use the GRASS <em>r.digit</em> or <em>v.digit</em>
+programs to digitize circular or polygonal regions and to create a
+sampling regions map without using <em>r.le.setup</em>. Or, as mention
+above, an existing raster map can be used as a regions map.
+<p>
+If sampling units are to be used as the sampling areas (Fig. 2), then
+choose "SAMPLING UNITS" from the first <em>r.le.setup</em> menu.
+The program checks the <em>r.le.para</em> subdirectory for an existing
+"units" file from a previous setup session and allows the user to rename
+this file (to save it) before proceeding. The r.le.setup program will
+otherwise overwrite the "units" file. Then the following choice is
+displayed followed by a series of other choices:
+<dl>
+<dd>
+<pre>
+ Which do you want to do?
+ (1) Use the keyboard to enter sampling unit parameters
+ (2) Draw the sampling units with the mouse
+ Enter 1 or 2:
+</pre>
+</dl>
+When sampling units are defined using the keyboard, the user inputs the
+shape and size (scale) of the sampling units by specifying dimensions
+in pixels using the keyboard. When sampling units are drawn with the
+mouse, the user clicks the mouse to define the sampling units in the
+GRASS monitor window, and then actually places the sampling units for
+each scale onto the map. By placing the units with the mouse the user
+can directly determine the method of sampling unit distribution as well
+as the shape, size, and number of sampling units.
+<p>
+If the choice is made to define sampling units using the keyboard, the
+following series of questions must be answered:
+<dl>
+<dd>
+<pre>
+ How many different SCALES do you want (1-15)?
+</pre>
+</dl>
+The user is asked to specify the number of scales that will be used.
+The <em>r.le</em> programs allow the user to simultaneously sample the
+same map with the same measures using sampling areas of different sizes.
+Currently there can be between 1 and 15 scales that can be sampled
+simultaneously. Substantial output can be produced if many scales are used.
+<p>
+Sampling units must be placed spatially into the landscape. There are
+five options for doing this :
+<p>
+<em>Random nonoverlapping</em><br>
+Sampling units are placed in the landscape by randomly choosing numbers
+that specify the location of the upper left corner of each sampling unit,
+subject to the constraint that successive sampling units not overlap other
+sampling units or the edge of the landscape, and that they must be entirely
+within the area defined by the mask (see <em>r.mask</em> command) if one
+exists.
+<p>
+<em>Systematic contiguous</em><br>
+Sampling units are placed side by side across the rows. The user will
+be able to enter a row and column to indicate where the upper left corner
+of the systematic contiguous framework should be placed. Rows are numbered
+from the top down beginning with row 1 of the sampling frame. Columns are
+numbered from left to right, beginning with column 1 of the sampling frame.
+A random starting location can be obtained by using a standard random
+number table to choose the starting row and column. The <em>r.le.setup</em>
+program does not avoid placing the set of sampling units over areas
+outside the mask. The user will have to make sure that sampling units do
+not extend outside the mask by choosing a particular starting row and
+column or by drawing a sampling frame before placing the set of sampling
+units.
+<p>
+<em>Systematic noncontiguous</em><br>
+The user must specify the starting row and column as in #2 above and the
+amount of spacing (in pixels) between sampling units. Horizontal and
+vertical spacing are identical. Sampling units are again placed side by
+side (but spaced) across the rows. As in #2 the program does not avoid
+placing sampling units outside the masked area; the user will have to
+position the set of units to avoid areas outside the mask.
+<p>
+<em>Stratified random</em><br>
+The strata are rectangular areas within which single sampling units
+are randomly located. The user must first specify the starting row
+and column as in #2 above. Then the user must specify the number of
+strata in the horizontal and vertical directions. As in #2 the program
+does not avoid placing sampling units outside the masked area; the user
+will have to position the set of units to avoid areas outside the mask.
+<p>
+<em>Centered over sites</em><br>
+The user must specify the name of a sitefile containing point locations.
+A single sampling unit is placed with its center over each site in the site
+file. This is a useful approach for determining the landscape structure
+around points, such as around the location of wildlife observations.
+<p>
+The user is prompted to enter a ratio that defines the shape of the
+sampling units. Sampling units may have any rectangular shape,
+including square as a special case of rectangular. Rectangular shapes
+are specified by entering the ratio of columns/rows (horizontal
+dimension/vertical dimension) as a real number. For example, to obtain
+a sampling unit 10 columns wide by 4 rows long specify the ratio as 2.5
+(10/4).
+<dl>
+<dd>
+<pre>
+ Recommended maximum SIZE is m in x cell total area. <br>
+ What size (in cells) for each sampling unit of scale n?
+</pre>
+</dl>
+The user is then given the recommended maximum possible size for a
+sampling unit (in pixels) and asked to input the size of sampling units
+at each scale. Sampling units can be of any size, but the maximum size
+is the size of the landscape as a whole. All the sampling units, that
+make up a single sampling scale, are the same size. After specifying
+the size, the program determines the nearest actual number of rows and
+columns, and hence size, that is closest to the requested size, given
+the shape requested earlier.
+<dl>
+<dd>
+<pre>
+ The nearest size is x cells wide X y cells high = xy cells
+ Is this size OK? (y/n) [y]
+ Maximum NUMBER of units in scale n is p?
+ What NUMBER of sampling units do you want to try to use?
+</pre>
+</dl>
+The maximum number of units that can be placed over the map, given the
+shape and size of the units, is then given. The user can then choose
+the number of sampling units to be used in the map layer. It may not
+always be possible to choose the maximum number, depending upon the
+shape of the sampling units. In the case of systematic contiguous and
+noncontiguous, the program will indicate how many units will fit across
+the columns and down the rows. The user can then specify a particular
+layout (e.g., 6 units could be placed as 2 rows of 3 per row or as 3
+rows of 2 per row).
+<dl>
+<dd>
+<pre>
+ Is this set of sampling units OK? (y/n) [y]
+</pre>
+</dl>
+Finally, the set of sampling units is displayed on the screen (e.g., Fig. 1)
+and the user is asked whether it is acceptable. If the answer is no, then
+the user is asked if the screen should be refreshed before redisplaying
+the menu for "Methods of sampling unit distribution" so that the user can
+try the sampling unit setup again.
+<p>
+The choice is made to define sampling units using the mouse, then the
+following menu for use with the mouse is displayed:
+<dl>
+<dd>
+<pre>
+ Outline the standard sampling unit of scale n.
+ Left button: Check unit size
+ Middle button: Move cursor
+ Right button: Lower right corner of unit here
+</pre>
+</dl>
+The user can then use the mouse and the rubber band box to outline the
+standard sampling unit. Once it has been outlined, the number of columns
+and rows in the unit, the ratio of width/length and the size of the unit,
+in cells, will be displayed. After this first unit is outlined, then a
+new menu is displayed:
+<dl>
+<dd>
+<pre>
+ Outline more sampling units of scale n?
+ Left button: Exit
+ Middle button: Check unit position
+ Right button: Lower right corner of next unit here
+</pre>
+</dl>
+The user can then place more units identical to the standard unit by
+simply clicking the right mouse button where the lower right corner of
+the unit should be placed. The rest of the rubber band box can be
+ignored while placing additional units. The program is set up so that
+units cannot be placed so they overlap one another, so they overlap the
+area outside the mask, or so they overlap the edge of the sampling frame.
+Warning messages are issued for all three of these errors and a sampling
+unit is simply not placed.
+<p>
+Using this procedure a rectangular "window" or single sampling area is
+moved systematically across the map to produce a new map (Fig. 2,3).
+This sampling procedure can only be used with the measures that produce
+a single value or with a single class or group when measures produce
+distributions of values (Table 1). The first class or group specified
+when defining class or group limits (section 2.3.2.) is used if
+distributional measures are chosen with the moving window sampling
+method. In this case, the user should manually edit the
+<em>r.le.para/recl_tb</em> file so that the desired group is listed as
+the first group in this file.
+<p>
+Sampling begins with the upper left corner of the window placed over
+the upper left corner of the sampling frame. It is strongly recommended
+that the user read the section on the GRASS mask (section 2.2.2) prior
+to setting up the moving window, as this mask can be used to speed up
+the moving window operation. The value of the chosen measure is
+calculated for the window area. This value is assigned to the location
+on the new map layer corresponding to the center pixel in the window if
+the window has odd (e.g. 3 X 3) dimensions. The value is assigned to
+the location on the new map layer corresponding to the first pixel below
+and to the right of the center if the window has even dimensions
+(e.g. 6 X 10). If this pixel has the value "0," which means "no data" in
+GRASS, then this pixel is skipped and a value of "0" is assigned to the
+corresponding location in the new map. The window is then moved to the
+right (across the row) by one pixel, and the process is repeated.
+At the end of the row, the window is moved down one pixel, and then back
+across the row. This option produces a new map layer, whose dimensions
+are smaller by approximately (m-1)/2 rows and columns, where m is the
+number of rows or columns in the window.
+<p>
+If the "MOVE-WINDOW" option in the main menu is selected, first the
+program checks for an existing "move_wind" file, in the r.le.para
+subdirectory, containing moving window specifications from a previous
+session. The user is given the option to avoid overwriting this file
+by entering a new file name for the old "move_wind" file. Users should
+be aware that moving window analyses are very slow, because a large
+number of sampling units are, in effect, used. See the appendix on
+"Time needed to complete analyses with the r.le programs" for some
+ideas about how moving window size and sampling frame area affect
+the needed time to complete the analyses.
+<p>
+The <em>r.le</em> programs <em>r.le.dist</em> and <em>r.le.patch</em>
+allow the attribute categories in the input map to be reclassed into
+several attribute groups, and reports the analysis results by each of
+these attribute groups. It is necessary to setup group limits for
+all measures that say "by gp" when typing "<em>r.le.dist help</em>"
+or "<em>r.le.patch help</em>" at the GRASS prompt. The same reclassing
+can be done with the measurement indices (e.g., size), except that each
+"cohort" (class) of the reclassed indices is called an index class
+instead of a group. It is also necessary to setup class limits for
+all measures that say "by class" when typing "<em>r.le.dist help</em>"
+<p>
+Group/class limits are setup by choosing "GROUP/CLASS LIMITS" from the
+main menu upon starting <em>r.le.setup</em>, or you can create the files
+manually using a text editor. The program checks for existing group/class
+limit files in subdirectory <em>r.le.para</em> and allows the user to
+rename these files prior to continuing. If the files are not renamed
+the program will overwrite them. The files are named recl_tb (attribute
+group limits), size (size class limits), shape_PA (shape index class
+limits for perimeter/area index), shape_CPA (shape index class limits
+for corrected perimeter/area index), shape_RCC (shape index class limits
+for related circumscribing circle index), and from_to (for the
+<em>r.le.dist</em> program distance methods m7-m9).
+<p>
+Attribute groups and index classes are defined in a different way.
+In the <em>r.le</em> programs attribute groups are defined as in the
+following example:
+<dl>
+<dd>
+<pre>
+ 1, 3, 5, 7, 9 <b>thru</b> 21 = 1 (comment)
+ 31 <b>thru</b> 50 = 2 (comment)
+ <b>end</b>
+</pre>
+</dl>
+In this example, the existing categories 1, 3, 5, 7, {9, 10, ... 20, 21}
+are included in the new group 1, while {31, 32, 33, ..., 49, 50} are
+included in the new group 2. The characters in bold are the "key words"
+that are required in the definition. Each line is called one "reclass rule".
+<p>
+The GRASS reclass convention is adopted here with a little modification
+(see "<em>r.reclass</em>" command in the GRASS User's Manual).
+The difference is that r.le only allows one rule for each group while the
+GRASS <em>r.reclass</em> command allows more than one. The definition of
+"from" and "to" groups is simply the extension of the GRASS reclass rule.
+The advantage of using the GRASS reclass convention is that the user can
+generate a permanent reclassed map, using GRASS programs, directly from the
+<em>r.le</em> setup results.
+<p>
+The <em>r.le</em> measurement index classes are defined by the lower
+limits of the classes, as in the following example:
+<dl>
+<dd>
+<pre>
+ 0.0, 10.0, 50.0, 200.0, <b>-999</b>
+</pre>
+</dl>
+This means:
+<dl>
+<dd>
+<pre>
+ if v >= 0.0 and v < 10.0 then v belongs to index class 1;
+ if v >= 10.0 and v < 50.0 then v belongs to index class 2;
+ if v >= 50.0 and v < 200.0 then v belongs to index class 3;
+ if v >= 200.0 then v belongs to index class 4;
+</pre>
+</dl>
+where v is the calculated index value and <b>-999</b> marks the end of
+the index class definition. The measurement index can be the size index,
+one of the three shape indices, or one of the three distance indices.
+The program is currently designed to allow no more than 25 attribute
+groups, 25 size classes, 25 shape index classes, and 25 distance index
+classes. As an alternative, the user may want to permanently group
+certain attributes prior to entering the <em>r.le</em> programs.
+For example, the user may want to group attributes 1-10, in a map whose
+attributes are ages, into a single attribute representing young patches.
+The user can do this using the GRASS <em>r.reclass</em> and
+<em>r.resample</em> commands, which will create a new map layer that can
+then be analyzed directly (without setting up group limits) with the
+<h2>REFERENCES</h2>
+<p>
+<h2>SEE ALSO</h2>
+<em>
+<h2>AUTHOR</h2>
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.le/r.le.trace/description.html
--- grass/trunk/raster/r.le/r.le.trace/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.le/r.le.trace/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,43 +0,0 @@
-<h2>DESCRIPTION</h2>
-The <em>r.le.trace</em> module can be used to display the boundary of each
-<b>r.le</b> patch and show how the boundary is traced, display the attribute,
-size, perimeter, and shape indices for each patch, and save the data in an
-output file.
-<h2>NOTES</h2>
-help page.
-<p>
-<h2>SEE ALSO</h2>
-<em>
-<!--<a href="r.le.dist.html">r.le.dist</a>,
-</em>
-<h2>AUTHOR</h2>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.le/r.le.trace/r.le.trace.html (from rev 32770, grass/trunk/raster/r.le/r.le.trace/description.html)
--- grass/trunk/raster/r.le/r.le.trace/r.le.trace.html (rev 0)
+++ grass/trunk/raster/r.le/r.le.trace/r.le.trace.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,43 @@
+The <em>r.le.trace</em> module can be used to display the boundary of each
+<b>r.le</b> patch and show how the boundary is traced, display the attribute,
+size, perimeter, and shape indices for each patch, and save the data in an
+output file.
+<h2>NOTES</h2>
+help page.
+<p>
+<h2>SEE ALSO</h2>
+<em>
+<!--<a href="r.le.dist.html">r.le.dist</a>,
+</em>
+<h2>AUTHOR</h2>
+<p>
Modified: grass/trunk/raster/r.li/Makefile
--- grass/trunk/raster/r.li/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -23,8 +23,7 @@
include $(MODULE_TOPDIR)/include/Make/Dir.make
-default: parsubdirs
- $(INSTALL_DATA) description.html $(GISBASE)/docs/html/r.li.html
+default: parsubdirs htmldir
clean: cleansubdirs
Deleted: grass/trunk/raster/r.li/description.html
--- grass/trunk/raster/r.li/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,186 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>r.li</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>r.li</b></em> - package overview
-<h2>KEYWORDS</h2>
-raster, landscape structure analysis, overview, landscape metrics, landscape pattern, landscape analysis
-The <em>r.li</em> suite is a toolset for multiscale analysis of landscape structure.
-It aims at replacing the <em>r.le</em> suite of modules through a client-server,
-multiprocess implementation. External software for quantitative measures of landscape
-structure is for example FRAGSTATS (McGarigal and Marks 1995).
-<p>
-The <em>r.li</em> suite offers a set of patch and diversity indices.
-It supports analysis of landscapes composed of a mosaic of
-patches, but, more generally, the modules work with any two-dimensional
-raster map whose cell values are integer (e.g., 1, 2) or floating point
-(e.g., 1.1, 3.2) values. The <em>r.li.setup</em> module has options for
-controlling the shape, size, number, and distribution of sampling
-areas used to collect information about the landscape structure.
-Sampling area shapes can be the entire map or a moving
-window of square, rectangular or with circular shape. The size of
-sampling areas can be changed, so that the landscape can be analyzed
-at a variety of spatial scales simultaneously. Sampling areas may be
-distributed across the landscape in a random, systematic, or
-stratified-random manner, or as a moving window.
-<p>
-The <em>r.li</em> modules can calculate a number of measures that produce
-single values as output (e.g. mean patch size in the sampling area),
-as well as measures that produce a distribution of values as output
-(e.g. frequency distribution of patch sizes in the sampling area). The
-results are stored as raster maps.
-<p>
-The general procedure to calculate an index from a raster map is two-fold:
-<ol>
-<li>run <em>r.li.setup</em>: create a configuration file selecting the parts of
- raster to analyze.
-<li>run <em>r.li.'index'</em> (e.g., <em>r.li.patchdensity</em>) for calculate the selected
- index using on the areas selected on configuration file.
-</ol>
-<h2>NOTE</h2>
-Also the <em>r.li.daemon</em> has a main function and it can be run, but it is only a
-template for development of new indices.
-<!-- mhh ??: -->
-The function itself has no meaning, it can be used only for debug.
-<h2>EXAMPLE</h2>
-To calculate a patch density index on a whole 'geology' raster map in the
-Spearfish region, using a 5x5 moving window, follow this procedure:
-<ol>
-<li> CREATE A NEW CONFIGURATION FILE
- <ol>
- <li> run
-<div class="code"><pre>
- r.li.setup
-</pre></div>
- <li> The main <em>r.li.setup</em> window is displayed, click on "New"
- <li> Now it is displayed the new configuration window,
- enter the configuration file name (e.g., "my_conf", do not use absolute paths)
- and the name of raster map (e.g., "geology").
- The other fields are not needed for this configuration.
- <li> Click on "Setup sampling frame", select "Whole maplayer" and click "OK"
- <li> Click on "Setup sampling areas", select "Moving window" and click "OK"
- <li> Click on "Use keyboard to enter moving window dimension"
- <li> Select "Rectangle" and enter 5 on "heigth" and "width" fields
- <li> Click on "Save settings"
- <li> Close <em>r.li.setup</em> window
- </ol>
-<li> CALCULATE PATCHDENSITY INDEX
-<ol>
- <li> set region settings to geology raster map:
- g.region rast=geology -p
-</pre></div>
- <li> run <em>r.li.patchdensity</em>:
- r.li.patchdensity map=geology conf=my_conf out=patchdens
-</pre></div>
- </ol>
-</ol>
-The resulting patch density is stored in "patchdens" raster map.
-You can verify the result for example with contour lines:
-r.contour in=patchdens out=patchdens step=5
-d.rast patchdens
-d.vect -c patchdens
-</pre></div>
-Note that if you want to run another index with the same area
-configuration, you don't have to create another configuration file.
-You can also use the same area configuration file on another map. The
-program rescale it automatically. For instance if you have selected a
-5x5 sample area on 100x100 raster map, and you use the same
-configuration file on a 200x200 raster map, then the sample area is
-10x10.
-<h2>SEE ALSO</h2>
-<b>Core modules</b>:
-<ul>
- <li> <a href="r.li.daemon.html">r.li.daemon</a>: job launch daemon</li>
- <li> <a href="r.li.setup.html">r.li.setup</a>: Configuration editor for r.li.'index'</li>
-</ul>
-<b>Patch indices</b>:
-<ul>
-<li>Indices based on patch number:
-<ul>
- <li> <a href="r.li.patchdensity.html">r.li.patchdensity</a>: Calculates patch density index on a raster map, using a 4 neighbour algorithm</li>
- <li> <a href="r.li.patchnum.html">r.li.patchnum</a>: Calculates patch number index on a raster map, using a 4 neighbour algorithm</li>
-</ul>
-<li>Indices based on patch dimension:
-<ul>
- <li> <a href="r.li.mps.html">r.li.mps</a>: Calculates mean patch size index on a raster map, using a 4 neighbour algorithm</li>
- <li> <a href="r.li.padcv.html">r.li.padcv</a>: Calculates coefficient of variation of patch area on a raster map</li>
- <li> <a href="r.li.padrange.html">r.li.padrange</a>: Calculates range of patch area size on a raster map</li>
- <li> <a href="r.li.padsd.html">r.li.padsd</a>: Calculates standard deviation of patch area a raster map</li>
-</ul>
-<li>Indices based on patch shape:
-<ul>
- <li> <a href="r.li.shape.html">r.li.shape</a>: Calculates shape index on a raster map</li>
-</ul>
-<li>Indices based on patch edge: <!-- border? -->
-<ul>
- <li> <a href="r.li.edgedensity.html">r.li.edgedensity</a>: Calculates edge density index on a raster map, using a 4 neighbour algorithm</li>
-</ul>
-<li>Indices based on patch attributes:
-<ul>
- <li> <a href="r.li.cwed.html">r.li.cwed</a>: Calculates contrast Weighted Edge Density index on a raster map</li>
- <li> <a href="r.li.mpa.html">r.li.mpa</a>: Calculates mean pixel attribute index on a raster map</li>
-</ul>
-</ul>
-<b>Diversity indices</b>:
-<ul>
- <li> <a href="r.li.dominance.html">r.li.dominance</a>: Calculates dominance's diversity index on a raster map</li>
- <li> <a href="r.li.richness.html">r.li.richness</a>: Calculates dominance's diversity index on a raster map</li>
- <li> <a href="r.li.shannon.html">r.li.shannon</a>: Calculates Shannon's diversity index on a raster map</li>
- <li> <a href="r.li.simpson.html">r.li.simpson</a>: Calculates Simpson's diversity index on a raster map</li>
-</ul>
-<h2>ADDING NEW INDICES</h2>
-New indices can be defined and implemented by any C programmer, without having to
-deal with all basic functions (IO etc.). The computing architecture and the functions
-are clearly separated, thus allowing an easy expandability. Every index is defined
-separately, placed in a directory along with its Makefile for compiling it and a file
-description.html which describes the index including a simple example of use.
-McGarigal, K., and B. J. Marks. 1995. FRAGSTATS: spatial pattern
-analysis program for quantifying landscape structure. USDA For. Serv.
-Gen. Tech. Rep. PNW-351 (<a href="http://www.fs.fed.us/pnw/pubs/gtr_351.pdf">PDF</a>).
-<h2>AUTHORS</h2>
-<a href="mailto:porta at cli.di.unipi.it">Claudio Porta</a> and
-<a href="mailto:spano at cli.di.unipi.it">Lucio Davide Spano</a>, students of Computer Science
-University of Pisa (Italy). <br>
-Commission from Faunalia Pontedera (PI)<br>
-<hr>
-<p><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a>
-</body>
-</html>
Deleted: grass/trunk/raster/r.li/r.li.cwed/description.html
--- grass/trunk/raster/r.li/r.li.cwed/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.cwed/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,70 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>r.li.cwed</EM> (contrast weighted edge density) calculates the edge density
-between patch types specified:
-<P><img src="rlicwed_formula.png"> </P>
-<P>with:
-<ul>
-<li> <B>k</B>: attribute<BR>
-<li> <B>m</B>: number of non-null attributes in the sampling area<BR>
-<li> <B>e<small><small>ik</small></small></B>: total length of edge in landscape between patch types i and k<BR>
-<li><B> d<small><small>ik</small></small></B>: dissimilarity (edge contrast weight) between patch types i and k<BR>
-<li> <B>Area</B>: total landscape area<BR>
-</ul><BR>
-The input file have a row for each couple of patch type that we want to
-consider in the calculation. Each row must to have this syntax:<BR>
-<small>patchType1,patchType2,dissimilarityBetweenPatchType1andPatchType2</small><BR>
-<H2>EXAMPLES</H2>
-To calculate mean pixel attribute index on map my_map, using
-my_conf configuration file and saving results in
-my_out file run:<BR>
-r.li.cwed map=my_map conf=my_conf path=my_file output=my_out
-</pre></div>
-<BR>Example of input file:<BR>
-12,16,0.65<BR>
-44,123,0.32<BR>
-56,12,0.54<BR>
-23,66,0.99<BR>
-<H2>NOTES</H2>
-Do not use absolute path names for output files. They are raster if
-moving window disposition was selected, otherwise they are in
-~/.r.li/output folder.
-<BR>
-If the raster is full of null value it is considered to have 0 patch and CWED=0.
-If Area is 0 r.li.cwed returns -1. This is possible
-only if the map is masked.<BR>
-If you want to have null values instead run <BR>
-r.null setnull=-1 map=my_map
-</pre></div>
-after index calculation.<BR>
-<BR>
-<H2>REFERENCES</H2>
-Gen. Tech. Rep. PNW-351.
-<H2>SEE ALSO</H2>
-<EM><A HREF="r.li.html">r.li</A></EM> package overview <BR>
-<EM><A HREF="r.li.daemon.html">r.li.daemon</A></EM><BR>
-<EM><A HREF="r.li.setup.html">r.li.setup</A></EM>
-<H2>AUTHORS</H2>
-Serena Pallecchi student of Computer Science University of Pisa (Italy).<BR>
-Commission from Faunalia Pontedera (PI), Italy (www.faunalia.it)
-<H2>BUGS</H2>
-Please send bugs reports to
-<a href="mailto:pallecch at cli.di.unipi.it">pallecch at cli.di.unipi.it</a><BR>
Copied: grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html (from rev 32770, grass/trunk/raster/r.li/r.li.cwed/description.html)
--- grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,70 @@
+<H2>DESCRIPTION</H2>
+<EM>r.li.cwed</EM> (contrast weighted edge density) calculates the edge density
+between patch types specified:
+<P><img src="rlicwed_formula.png"> </P>
+<P>with:
+<ul>
+<li> <B>k</B>: attribute<BR>
+<li> <B>m</B>: number of non-null attributes in the sampling area<BR>
+<li> <B>e<small><small>ik</small></small></B>: total length of edge in landscape between patch types i and k<BR>
+<li><B> d<small><small>ik</small></small></B>: dissimilarity (edge contrast weight) between patch types i and k<BR>
+<li> <B>Area</B>: total landscape area<BR>
+</ul><BR>
+The input file have a row for each couple of patch type that we want to
+consider in the calculation. Each row must to have this syntax:<BR>
+<small>patchType1,patchType2,dissimilarityBetweenPatchType1andPatchType2</small><BR>
+<H2>EXAMPLES</H2>
+To calculate mean pixel attribute index on map my_map, using
+my_conf configuration file and saving results in
+my_out file run:<BR>
+<div class="code"><pre>
+r.li.cwed map=my_map conf=my_conf path=my_file output=my_out
+</pre></div>
+<BR>Example of input file:<BR>
+12,16,0.65<BR>
+44,123,0.32<BR>
+56,12,0.54<BR>
+23,66,0.99<BR>
+<H2>NOTES</H2>
+Do not use absolute path names for output files. They are raster if
+moving window disposition was selected, otherwise they are in
+~/.r.li/output folder.
+<BR>
+If the raster is full of null value it is considered to have 0 patch and CWED=0.
+If Area is 0 r.li.cwed returns -1. This is possible
+only if the map is masked.<BR>
+If you want to have null values instead run <BR>
+r.null setnull=-1 map=my_map
+</pre></div>
+after index calculation.<BR>
+<BR>
+<H2>REFERENCES</H2>
+McGarigal, K., and B. J. Marks. 1995. FRAGSTATS: spatial pattern
+analysis program for quantifying landscape structure. USDA For. Serv.
+Gen. Tech. Rep. PNW-351.
+<H2>SEE ALSO</H2>
+<EM><A HREF="r.li.html">r.li</A></EM> package overview <BR>
+<EM><A HREF="r.li.daemon.html">r.li.daemon</A></EM><BR>
+<EM><A HREF="r.li.setup.html">r.li.setup</A></EM>
+<H2>AUTHORS</H2>
+Serena Pallecchi student of Computer Science University of Pisa (Italy).<BR>
+Commission from Faunalia Pontedera (PI), Italy (www.faunalia.it)
+<H2>BUGS</H2>
+Please send bugs reports to
+<a href="mailto:pallecch at cli.di.unipi.it">pallecch at cli.di.unipi.it</a><BR>
Modified: grass/trunk/raster/r.li/r.li.daemon/Makefile
--- grass/trunk/raster/r.li/r.li.daemon/Makefile 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.daemon/Makefile 2008-08-15 06:16:42 UTC (rev 32772)
@@ -3,10 +3,10 @@
EXTRA_LIBS=$(GISLIB)
LIB_NAME = grass_rli
+PGM = r.li.daemon
DEPENDENCIES = $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Lib.make
-default: lib
- $(INSTALL_DATA) description.html $(GISBASE)/docs/html/r.li.daemon.html
+default: lib htmldir
Deleted: grass/trunk/raster/r.li/r.li.daemon/description.html
--- grass/trunk/raster/r.li/r.li.daemon/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.daemon/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,95 +0,0 @@
-<html>
-<head>
-</head>
-<EM>r.li.daemon</EM> provides a support for landscape index calculation on raster
-maps. It hides the managment of areas, defined using <a href="r.li.setup.html">r.li.setup</a>
-command. It do not have to be used like a standalone program, but its functions are
-a library used by all <em>r.li.[index]</em> commands.<br>
-This description is a tutorial for new index definition. <br><br>
-The developer has only to focus on a unique area, like in mathematical definitions, and
-has to write a C implementation of it.<br>
-The areas are defined using a <em>struct</em> called <b>area_des</b> and it members are
-explained in the source code (doxygen) documentation.
-<p>
-To write a new index only two steps are needed:
-<ol>
- <li>
- Define a function and insert its declaration on file <b>index.h</b> in <em>r.li.daemon</em>
- folder, which contains all index declarations. This function must be of this kind:
- <br><div class="code"><pre>
- int index(int fd, char ** par, area_des ad, double * result)
- </pre></div><br>
- where: <ul>
- <li><i>fd</i> is the raster map descriptor
- <li><i>par</i> is a matrix for special parameter (like argv in main)
- <li><i>ad</i> is the area descriptor
- <li><i>result</i> is where to put the index calculation result
- </ul>
- This function has to return 1 on success and 0 otherwise. <br><br>
- <li>
- Create a main for command line arguments parsing, and call the function
- int calculateIndex(char * file, int f(int, char** area_des, double *), char **parameters, char *raster, char *output);
- </pre></div><br>
- from the <i>r.li</i> library, for starting raster analysis.<br>
- It follows the meaning of parameters:
- <ul>
- <li><i>file</i> name of configuration file created using <a href="r.li.setup.html">r.li.setup</a>
- <li><i>f</i> pointer to index function defined above
- <li><i>parameters</i> pointer to index special parameters
- <li><i>raster</i> name of raster to use
- <li><i>output</i> output file name
- </ul>
-</ol>
-Compile it using a changed Makefile based on the file for <em>r.li.patchdensity</em>.
-<H2>NOTES</H2>
-Using GRASS library function to access raster rows can slow down moving windows
-execution. It is recommended to use
-<br><div class="code"><pre>
-RLI_get_cell_row(int, int, area_des)
-RLI_get_fcell_row(int, int, area_des)
-RLI_get_dcell_row(int, int, area_des)
-</pre></div><br>
-to use an ad hoc build memory managment developed to speed up the system.
-The documentation is in doxygen files.
-<H2>SEE ALSO</H2>
-<EM><A HREF="http://grass.itc.it/gdp/landscape/r_le_manual5.pdf">old r.le manual</A></EM><BR>
-<EM><A HREF="r.li.patchdensity.html">r.li.patchdensity</A></EM>,
-<H2>AUTHORS</H2>
-Claudio Porta and Lucio Davide Spano, students of Computer Science
-University of Pisa (Italy).<br>
-Rebuild of r.le.setup from William L. Baker
-This program is free software under the GPL (>=v2)
-Read the COPYING file that comes with GRASS for details.
-<H2>BUGS</h2>
-Pleas send bugs reports to
-<a href="mailto:spano at cli.di.unipi.it">spano at cli.di.unipi.it</a>,
-<a href="mailto:porta at cli.di.unipi.it">porta at cli.di.unipi.it</a><br>
-<BR>
-<p><i>Last changed: $Date$</i>
-<HR>
-<P><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a>
-</body>
-</html>
Copied: grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html (from rev 32770, grass/trunk/raster/r.li/r.li.daemon/description.html)
--- grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,95 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>r.li</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<EM>r.li.daemon</EM> provides a support for landscape index calculation on raster
+maps. It hides the managment of areas, defined using <a href="r.li.setup.html">r.li.setup</a>
+command. It do not have to be used like a standalone program, but its functions are
+a library used by all <em>r.li.[index]</em> commands.<br>
+This description is a tutorial for new index definition. <br><br>
+The developer has only to focus on a unique area, like in mathematical definitions, and
+has to write a C implementation of it.<br>
+The areas are defined using a <em>struct</em> called <b>area_des</b> and it members are
+explained in the source code (doxygen) documentation.
+<p>
+To write a new index only two steps are needed:
+<ol>
+ <li>
+ Define a function and insert its declaration on file <b>index.h</b> in <em>r.li.daemon</em>
+ folder, which contains all index declarations. This function must be of this kind:
+ <br><div class="code"><pre>
+ int index(int fd, char ** par, area_des ad, double * result)
+ </pre></div><br>
+ where: <ul>
+ <li><i>fd</i> is the raster map descriptor
+ <li><i>par</i> is a matrix for special parameter (like argv in main)
+ <li><i>ad</i> is the area descriptor
+ <li><i>result</i> is where to put the index calculation result
+ </ul>
+ This function has to return 1 on success and 0 otherwise. <br><br>
+ <li>
+ Create a main for command line arguments parsing, and call the function
+ int calculateIndex(char * file, int f(int, char** area_des, double *), char **parameters, char *raster, char *output);
+ </pre></div><br>
+ from the <i>r.li</i> library, for starting raster analysis.<br>
+ It follows the meaning of parameters:
+ <ul>
+ <li><i>file</i> name of configuration file created using <a href="r.li.setup.html">r.li.setup</a>
+ <li><i>f</i> pointer to index function defined above
+ <li><i>parameters</i> pointer to index special parameters
+ <li><i>raster</i> name of raster to use
+ <li><i>output</i> output file name
+ </ul>
+</ol>
+Compile it using a changed Makefile based on the file for <em>r.li.patchdensity</em>.
+<H2>NOTES</H2>
+Using GRASS library function to access raster rows can slow down moving windows
+execution. It is recommended to use
+<br><div class="code"><pre>
+RLI_get_cell_row(int, int, area_des)
+RLI_get_fcell_row(int, int, area_des)
+RLI_get_dcell_row(int, int, area_des)
+</pre></div><br>
+to use an ad hoc build memory managment developed to speed up the system.
+The documentation is in doxygen files.
+<H2>SEE ALSO</H2>
+<EM><A HREF="http://grass.itc.it/gdp/landscape/r_le_manual5.pdf">old r.le manual</A></EM><BR>
+<EM><A HREF="r.li.patchdensity.html">r.li.patchdensity</A></EM>,
+<H2>AUTHORS</H2>
+Claudio Porta and Lucio Davide Spano, students of Computer Science
+University of Pisa (Italy).<br>
+Commission from Faunalia Pontedera (PI)<br>
+Rebuild of r.le.setup from William L. Baker
+This program is free software under the GPL (>=v2)
+Read the COPYING file that comes with GRASS for details.
+<H2>BUGS</h2>
+Pleas send bugs reports to
+<a href="mailto:spano at cli.di.unipi.it">spano at cli.di.unipi.it</a>,
+<a href="mailto:porta at cli.di.unipi.it">porta at cli.di.unipi.it</a><br>
+<BR>
+<p><i>Last changed: $Date$</i>
+<HR>
+<P><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a>
+</body>
+</html>
Deleted: grass/trunk/raster/r.li/r.li.dominance/description.html
--- grass/trunk/raster/r.li/r.li.dominance/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.dominance/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,48 +0,0 @@
-<em>r.li.dominance</em>
-calculates the "dominance's diversity index" as:<br>
-<img src="rliDominance_formula.png"> <br>
-with: <br>
-<ul>
- <li><b>m</b>: number of different patch type<br> </li>
- <li><b>i</b>: patch type<br></li>
- <li><b>p<small><small>i</small></small></b>: proportion of the landscape occupied by patch type i<br></li>
-</ul>
-<h2>EXAMPLES</h2>
-To calculate dominance's diversity index on map my_map, using
-my_conf configuration file and saving results in my_out file run:<br>
-r.li.dominance map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-~/.r.li/output folder. <br>
-If input raster is full of null values r.li.dominance returns -1.<br>
-If you want to have null values instead run <br>
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.li.html">r.li</a>
-<a href="r.le.html">r.le</a>
-</em>
-<h2>AUTHORS</h2>
-Serena Pallecchi student of Computer Science University of Pisa (Italy).<br>
-<h2>BUGS</h2>
-<a href="mailto:pallecch at cli.di.unipi.it">pallecch at cli.di.unipi.it</a><br>
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html (from rev 32770, grass/trunk/raster/r.li/r.li.dominance/description.html)
--- grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,48 @@
+<em>r.li.dominance</em>
+calculates the "dominance's diversity index" as:<br>
+<img src="rliDominance_formula.png"> <br>
+with: <br>
+<ul>
+ <li><b>m</b>: number of different patch type<br> </li>
+ <li><b>i</b>: patch type<br></li>
+ <li><b>p<small><small>i</small></small></b>: proportion of the landscape occupied by patch type i<br></li>
+</ul>
+<h2>EXAMPLES</h2>
+To calculate dominance's diversity index on map my_map, using
+my_conf configuration file and saving results in my_out file run:<br>
+r.li.dominance map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+~/.r.li/output folder. <br>
+If input raster is full of null values r.li.dominance returns -1.<br>
+If you want to have null values instead run <br>
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.li.html">r.li</a>
+<a href="r.le.html">r.le</a>
+</em>
+<h2>AUTHORS</h2>
+Serena Pallecchi student of Computer Science University of Pisa (Italy).<br>
+<h2>BUGS</h2>
+<a href="mailto:pallecch at cli.di.unipi.it">pallecch at cli.di.unipi.it</a><br>
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/raster/r.li/r.li.edgedensity/description.html
--- grass/trunk/raster/r.li/r.li.edgedensity/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.edgedensity/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,63 +0,0 @@
-<em>r.li.edgedensity </em>calculates:<br>
-<br>
-<ul>
- <li> the density of all the edge of patch i<br></li>
- <img alt="" src="rliEdgeDensity_formula1.png"><br>
- or<br><br>
- <li> the density of all the edge in the sampling area if i isn't specified<br></li>
- <img alt="" src="rliEdgeDensity_formula2.png"><br></ul>
-<p>with:</p>
-<ul>
- <li><b>k</b>: patch type<br></li>
- <li><b>m</b>: number of patch type<br> </li>
- <li><b>n</b>: number of edge segment of patch type k</li>
- <li><b>e<small><small>ik </small></small></b>:total length of edge in landscape involving patch type k</li>
- <li> <B>Area</B>: total landscape area<BR>
-</ul>
-<h2>REFERENCES</h2>
-<h2>EXAMPLES</h2>
-To calculate edge density index on map my_map, using
-my_out file run:<br>
-<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <br><br>
-To calculate edge density index of patch_type 34, using
-my_conf configuration file and on map my_map, saving results in my_out
-file run:<br>
-<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <B>patch_type=</B>34
-<br>
-<h2>NOTES</h2>
-<br>
-If input raster is full of null values r.li.edgedensity consider to have 0
-patch.<br>
-If area is 0 r.li.edgedensity returns -1; this is possible only if input
-raster is masked.
-<B>r.null setnull=-1 map=</B>my_map <br>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html (from rev 32770, grass/trunk/raster/r.li/r.li.edgedensity/description.html)
--- grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,63 @@
+<em>r.li.edgedensity </em>calculates:<br>
+<br>
+<ul>
+ <li> the density of all the edge of patch i<br></li>
+ <img alt="" src="rliEdgeDensity_formula1.png"><br>
+ or<br><br>
+ <li> the density of all the edge in the sampling area if i isn't specified<br></li>
+ <img alt="" src="rliEdgeDensity_formula2.png"><br></ul>
+<p>with:</p>
+<ul>
+ <li><b>k</b>: patch type<br></li>
+ <li><b>m</b>: number of patch type<br> </li>
+ <li><b>n</b>: number of edge segment of patch type k</li>
+ <li><b>e<small><small>ik </small></small></b>:total length of edge in landscape involving patch type k</li>
+ <li> <B>Area</B>: total landscape area<BR>
+</ul>
+<h2>EXAMPLES</h2>
+To calculate edge density index on map my_map, using
+my_out file run:<br>
+<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <br><br>
+To calculate edge density index of patch_type 34, using
+my_conf configuration file and on map my_map, saving results in my_out
+file run:<br>
+<B>r.li.edgedensity map=</B>my_map <B>conf=</B>my_conf <B>output=</B>my_out <B>patch_type=</B>34
+<br>
+<h2>NOTES</h2>
+<br>
+If input raster is full of null values r.li.edgedensity consider to have 0
+patch.<br>
+If area is 0 r.li.edgedensity returns -1; this is possible only if input
+raster is masked.
+<B>r.null setnull=-1 map=</B>my_map <br>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.html (from rev 32770, grass/trunk/raster/r.li/description.html)
--- grass/trunk/raster/r.li/r.li.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,186 @@
+<html>
+<head>
+</head>
+<h2>NAME</h2>
+<em><b>r.li</b></em> - package overview
+<h2>KEYWORDS</h2>
+raster, landscape structure analysis, overview, landscape metrics, landscape pattern, landscape analysis
+The <em>r.li</em> suite is a toolset for multiscale analysis of landscape structure.
+It aims at replacing the <em>r.le</em> suite of modules through a client-server,
+multiprocess implementation. External software for quantitative measures of landscape
+structure is for example FRAGSTATS (McGarigal and Marks 1995).
+<p>
+The <em>r.li</em> suite offers a set of patch and diversity indices.
+It supports analysis of landscapes composed of a mosaic of
+patches, but, more generally, the modules work with any two-dimensional
+raster map whose cell values are integer (e.g., 1, 2) or floating point
+(e.g., 1.1, 3.2) values. The <em>r.li.setup</em> module has options for
+controlling the shape, size, number, and distribution of sampling
+areas used to collect information about the landscape structure.
+Sampling area shapes can be the entire map or a moving
+window of square, rectangular or with circular shape. The size of
+sampling areas can be changed, so that the landscape can be analyzed
+at a variety of spatial scales simultaneously. Sampling areas may be
+distributed across the landscape in a random, systematic, or
+stratified-random manner, or as a moving window.
+<p>
+The <em>r.li</em> modules can calculate a number of measures that produce
+single values as output (e.g. mean patch size in the sampling area),
+as well as measures that produce a distribution of values as output
+(e.g. frequency distribution of patch sizes in the sampling area). The
+results are stored as raster maps.
+<p>
+The general procedure to calculate an index from a raster map is two-fold:
+<ol>
+<li>run <em>r.li.setup</em>: create a configuration file selecting the parts of
+ raster to analyze.
+<li>run <em>r.li.'index'</em> (e.g., <em>r.li.patchdensity</em>) for calculate the selected
+ index using on the areas selected on configuration file.
+</ol>
+<h2>NOTE</h2>
+Also the <em>r.li.daemon</em> has a main function and it can be run, but it is only a
+template for development of new indices.
+<!-- mhh ??: -->
+The function itself has no meaning, it can be used only for debug.
+<h2>EXAMPLE</h2>
+To calculate a patch density index on a whole 'geology' raster map in the
+Spearfish region, using a 5x5 moving window, follow this procedure:
+<ol>
+<li> CREATE A NEW CONFIGURATION FILE
+ <ol>
+ <li> run
+ r.li.setup
+</pre></div>
+ <li> The main <em>r.li.setup</em> window is displayed, click on "New"
+ <li> Now it is displayed the new configuration window,
+ enter the configuration file name (e.g., "my_conf", do not use absolute paths)
+ and the name of raster map (e.g., "geology").
+ The other fields are not needed for this configuration.
+ <li> Click on "Setup sampling frame", select "Whole maplayer" and click "OK"
+ <li> Click on "Setup sampling areas", select "Moving window" and click "OK"
+ <li> Click on "Use keyboard to enter moving window dimension"
+ <li> Select "Rectangle" and enter 5 on "heigth" and "width" fields
+ <li> Click on "Save settings"
+ <li> Close <em>r.li.setup</em> window
+ </ol>
+<li> CALCULATE PATCHDENSITY INDEX
+<ol>
+ <li> set region settings to geology raster map:
+ g.region rast=geology -p
+</pre></div>
+ <li> run <em>r.li.patchdensity</em>:
+ r.li.patchdensity map=geology conf=my_conf out=patchdens
+</pre></div>
+ </ol>
+</ol>
+The resulting patch density is stored in "patchdens" raster map.
+You can verify the result for example with contour lines:
+r.contour in=patchdens out=patchdens step=5
+d.rast patchdens
+d.vect -c patchdens
+</pre></div>
+Note that if you want to run another index with the same area
+configuration, you don't have to create another configuration file.
+You can also use the same area configuration file on another map. The
+program rescale it automatically. For instance if you have selected a
+5x5 sample area on 100x100 raster map, and you use the same
+configuration file on a 200x200 raster map, then the sample area is
+10x10.
+<h2>SEE ALSO</h2>
+<b>Core modules</b>:
+<ul>
+ <li> <a href="r.li.daemon.html">r.li.daemon</a>: job launch daemon</li>
+ <li> <a href="r.li.setup.html">r.li.setup</a>: Configuration editor for r.li.'index'</li>
+</ul>
+<b>Patch indices</b>:
+<ul>
+<li>Indices based on patch number:
+<ul>
+ <li> <a href="r.li.patchdensity.html">r.li.patchdensity</a>: Calculates patch density index on a raster map, using a 4 neighbour algorithm</li>
+ <li> <a href="r.li.patchnum.html">r.li.patchnum</a>: Calculates patch number index on a raster map, using a 4 neighbour algorithm</li>
+</ul>
+<li>Indices based on patch dimension:
+<ul>
+ <li> <a href="r.li.mps.html">r.li.mps</a>: Calculates mean patch size index on a raster map, using a 4 neighbour algorithm</li>
+ <li> <a href="r.li.padcv.html">r.li.padcv</a>: Calculates coefficient of variation of patch area on a raster map</li>
+ <li> <a href="r.li.padrange.html">r.li.padrange</a>: Calculates range of patch area size on a raster map</li>
+ <li> <a href="r.li.padsd.html">r.li.padsd</a>: Calculates standard deviation of patch area a raster map</li>
+</ul>
+<li>Indices based on patch shape:
+<ul>
+ <li> <a href="r.li.shape.html">r.li.shape</a>: Calculates shape index on a raster map</li>
+</ul>
+<li>Indices based on patch edge: <!-- border? -->
+<ul>
+ <li> <a href="r.li.edgedensity.html">r.li.edgedensity</a>: Calculates edge density index on a raster map, using a 4 neighbour algorithm</li>
+</ul>
+<li>Indices based on patch attributes:
+<ul>
+ <li> <a href="r.li.cwed.html">r.li.cwed</a>: Calculates contrast Weighted Edge Density index on a raster map</li>
+ <li> <a href="r.li.mpa.html">r.li.mpa</a>: Calculates mean pixel attribute index on a raster map</li>
+</ul>
+</ul>
+<b>Diversity indices</b>:
+<ul>
+ <li> <a href="r.li.dominance.html">r.li.dominance</a>: Calculates dominance's diversity index on a raster map</li>
+ <li> <a href="r.li.richness.html">r.li.richness</a>: Calculates dominance's diversity index on a raster map</li>
+ <li> <a href="r.li.shannon.html">r.li.shannon</a>: Calculates Shannon's diversity index on a raster map</li>
+ <li> <a href="r.li.simpson.html">r.li.simpson</a>: Calculates Simpson's diversity index on a raster map</li>
+</ul>
+<h2>ADDING NEW INDICES</h2>
+New indices can be defined and implemented by any C programmer, without having to
+deal with all basic functions (IO etc.). The computing architecture and the functions
+are clearly separated, thus allowing an easy expandability. Every index is defined
+separately, placed in a directory along with its Makefile for compiling it and a file
+description.html which describes the index including a simple example of use.
+Gen. Tech. Rep. PNW-351 (<a href="http://www.fs.fed.us/pnw/pubs/gtr_351.pdf">PDF</a>).
+<h2>AUTHORS</h2>
+<a href="mailto:porta at cli.di.unipi.it">Claudio Porta</a> and
+<a href="mailto:spano at cli.di.unipi.it">Lucio Davide Spano</a>, students of Computer Science
+University of Pisa (Italy). <br>
+<hr>
+<p><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a>
+</body>
+</html>
Deleted: grass/trunk/raster/r.li/r.li.mpa/description.html
--- grass/trunk/raster/r.li/r.li.mpa/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.mpa/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,56 +0,0 @@
-<em>r.li.mpa</em>
-(mean pixel attribute) calculates the average value of the attribute of all the non-null
-cells in the sampling area as:<br>
-<img src="rlimpa_formula.png"> <br>
-with:<br>
-<ul>
- <li><b>i</b>: attribute<br></li>
- <li><b>m</b>: number of non-null attributes in the sampling area </li>
- <li><b>w<small><small>i</small></small></b>: number of cells of attribute i</li>
- <li><b>size</b>: size of sampling area (in cells)<br>
- </li>
-</ul>
-<h2>EXAMPLES</h2>
-r.li.mpa map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-~/.r.li/output folder.<br>
-If input raster is full of null values r.li.mpa consider to
-have 0 patch.<br>
-If area is 0 r.li.mpa returns -1; it is possible only if the
-raster is masked <br>
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html (from rev 32770, grass/trunk/raster/r.li/r.li.mpa/description.html)
--- grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,56 @@
+<em>r.li.mpa</em>
+(mean pixel attribute) calculates the average value of the attribute of all the non-null
+cells in the sampling area as:<br>
+<img src="rlimpa_formula.png"> <br>
+with:<br>
+<ul>
+ <li><b>i</b>: attribute<br></li>
+ <li><b>m</b>: number of non-null attributes in the sampling area </li>
+ <li><b>w<small><small>i</small></small></b>: number of cells of attribute i</li>
+ <li><b>size</b>: size of sampling area (in cells)<br>
+ </li>
+</ul>
+<h2>EXAMPLES</h2>
+r.li.mpa map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+~/.r.li/output folder.<br>
+If input raster is full of null values r.li.mpa consider to
+have 0 patch.<br>
+If area is 0 r.li.mpa returns -1; it is possible only if the
+raster is masked <br>
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.mps/description.html
--- grass/trunk/raster/r.li/r.li.mps/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.mps/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,54 +0,0 @@
-<em>r.li.mps</em>
-(mean patch size) calculates the mean size of the patches in the sampling area as:<br>
-<img src="rlimps_formula.png"><br>
-with:
-<ul>
- <li><b>A</b>:sampling area size without null cells</li>
- <li><b>Npatch</b>: number of patches<br>
- </li>
-</ul>
-<h2>EXAMPLES</h2>
-To calculate mean path size index on map my_map, using
-r.li.mps map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-<br>
-If input raster is full of null values r.li.mps returns 0.<br>
-r.null setnull=0 map=my_map
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.mps/r.li.mps.html (from rev 32770, grass/trunk/raster/r.li/r.li.mps/description.html)
--- grass/trunk/raster/r.li/r.li.mps/r.li.mps.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.mps/r.li.mps.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,54 @@
+<em>r.li.mps</em>
+(mean patch size) calculates the mean size of the patches in the sampling area as:<br>
+<img src="rlimps_formula.png"><br>
+with:
+<ul>
+ <li><b>A</b>:sampling area size without null cells</li>
+ <li><b>Npatch</b>: number of patches<br>
+ </li>
+</ul>
+<h2>EXAMPLES</h2>
+To calculate mean path size index on map my_map, using
+r.li.mps map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+<br>
+If input raster is full of null values r.li.mps returns 0.<br>
+r.null setnull=0 map=my_map
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.padcv/description.html
--- grass/trunk/raster/r.li/r.li.padcv/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.padcv/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,60 +0,0 @@
-<em>r.li.padcv</em>
- (patch area distribution coefficient of variation) calculates
-as:<br>
-<img src="rlipadcv_formula1.png"> <br>
-with:<br>
-<ul>
- <li><b>SD</b>: standard deviation of patch area size <br></li>
- <img src="rlipadcv_formula2.png"> <br>
- <li><b>MPS</b>: mean patch area size<br></li>
- <li><b>a<small><small>i</small></small></b>: area of patch i<br></li>
- <li><b>N<small>patch</small></b>: number of patch<br></li>
- </li>
-</ul>
-<h2>EXAMPLES</h2>
-r.li.padcv map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-If input raster is not full of null values r.li.padcv returns a value >=0 that is PADcv. <br>
-If input raster is full of null values r.li.padcv returns -1. <br>
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html (from rev 32770, grass/trunk/raster/r.li/r.li.padcv/description.html)
--- grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,60 @@
+<h2>DESCRIPTION</h2>
+<em>r.li.padcv</em>
+ (patch area distribution coefficient of variation) calculates
+as:<br>
+<img src="rlipadcv_formula1.png"> <br>
+with:<br>
+<ul>
+ <li><b>SD</b>: standard deviation of patch area size <br></li>
+ <img src="rlipadcv_formula2.png"> <br>
+ <li><b>MPS</b>: mean patch area size<br></li>
+ <li><b>a<small><small>i</small></small></b>: area of patch i<br></li>
+ <li><b>N<small>patch</small></b>: number of patch<br></li>
+ </li>
+</ul>
+<h2>EXAMPLES</h2>
+r.li.padcv map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+If input raster is not full of null values r.li.padcv returns a value >=0 that is PADcv. <br>
+If input raster is full of null values r.li.padcv returns -1. <br>
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.padrange/description.html
--- grass/trunk/raster/r.li/r.li.padrange/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.padrange/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,57 +0,0 @@
-<em>r.li.padrange</em>
- (patch area distribution range) calculates
-as:<br>
-<img src="rlipadrange_formula.png"> <br>
-with:<br>
-<ul>
- <li><b>a<small><small>max</small></small></b>: max patch area size<br></li>
- <li><b>a<small><small>min</small></small></b>: min patch area size<br></li>
- </li>
-</ul>
-<h2>EXAMPLES</h2>
-To calculate range of patch area size, using
-r.li.padrange map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-If input raster is not full of null values r.li.padrange returns a
-value >=0 that is PADcv. <br>
-If input raster is full of null values r.li.padrange returns -1. <br>
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html (from rev 32770, grass/trunk/raster/r.li/r.li.padrange/description.html)
--- grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,57 @@
+<em>r.li.padrange</em>
+ (patch area distribution range) calculates
+as:<br>
+<img src="rlipadrange_formula.png"> <br>
+with:<br>
+<ul>
+ <li><b>a<small><small>max</small></small></b>: max patch area size<br></li>
+ <li><b>a<small><small>min</small></small></b>: min patch area size<br></li>
+ </li>
+</ul>
+<h2>EXAMPLES</h2>
+To calculate range of patch area size, using
+r.li.padrange map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+If input raster is not full of null values r.li.padrange returns a
+value >=0 that is PADcv. <br>
+If input raster is full of null values r.li.padrange returns -1. <br>
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.padsd/description.html
--- grass/trunk/raster/r.li/r.li.padsd/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.padsd/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,52 +0,0 @@
-<em>r.li.padsd</em> (patch area distribution standard deviation) calculates as:<br>
-<img src="rlipadsd_formula.png"> <br>
-with:<br>
-<ul>
- </li>
-</ul>
-<h2>EXAMPLES</h2>
-r.li.padsd map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-If input raster is not full of null values r.li.padsd returns a value >=0 that is PADsd. <br>
-If input raster is full of null values r.li.padsd returns -1. <br>
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html (from rev 32770, grass/trunk/raster/r.li/r.li.padsd/description.html)
--- grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,52 @@
+<em>r.li.padsd</em> (patch area distribution standard deviation) calculates as:<br>
+<img src="rlipadsd_formula.png"> <br>
+with:<br>
+<ul>
+ </li>
+</ul>
+<h2>EXAMPLES</h2>
+r.li.padsd map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+If input raster is not full of null values r.li.padsd returns a value >=0 that is PADsd. <br>
+If input raster is full of null values r.li.padsd returns -1. <br>
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.patchdensity/description.html
--- grass/trunk/raster/r.li/r.li.patchdensity/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.patchdensity/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,64 +0,0 @@
-<EM>r.li.patchdensity</EM> is a patch index for <em>r.li</em> suite.
-It calculates the function:
-f(sample_area) = (Patch_Number/Area) * 1000000
-</pre></div>
-that is 1000000 by number of patch for area unit.
-This index is calculated using a 4 neighbour algorithm.
-<H2>EXAMPLES</H2>
-To calculate patch density index on map <em>my_map</em>, using <em>my_conf</em>
-configuration file (previously defined with <em>r.li.setup</em>) and saving
-results in the raster map <em>my_out</em>, run:
-r.li.patchdensity map=my_map conf=my_conf out=my_out
-</pre></div>
-<p>
-Example for Spearfish forest areas:
-g.region rast=landcover.30m -p
-# extract forested areas:
-r.category landcover.30m
-r.mapcalc "forests=if(landcover.30m >= 41 && landcover.30m <=43,1,null())"
-# patch density (7x7 moving window defined in r.li.setup):
-r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
-d.rast.leg forests_p_dens7
-r.to.vect forests out=forests feature=area
-d.vect forests type=boundary
-</pre></div>
-<H2>NOTES</H2>
-A map of NULL values is considered to have zero patches. <br>
-r.null setnull=0 map=my_out
-<pre></div>
-after index calculation.<br>
-<!-- next ??????: -->
-If raster area is 0, <em>r.li.patchdensity</em> returns -1. This is only possible
-if the raster is masked.
-<H2>SEE ALSO</H2>
-<H2>AUTHORS</H2>
-Commission from Faunalia Pontedera (PI) (www.faunalia.it)<br>
-<H2>BUGS</h2>
-<a href="mailto:porta at cli.di.unipi.it">porta at cli.di.unipi.it</a><BR>
-<p><i>Last changed: $Date$</i<pre>
Copied: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html (from rev 32770, grass/trunk/raster/r.li/r.li.patchdensity/description.html)
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,64 @@
+<EM>r.li.patchdensity</EM> is a patch index for <em>r.li</em> suite.
+It calculates the function:
+f(sample_area) = (Patch_Number/Area) * 1000000
+</pre></div>
+that is 1000000 by number of patch for area unit.
+This index is calculated using a 4 neighbour algorithm.
+<H2>EXAMPLES</H2>
+To calculate patch density index on map <em>my_map</em>, using <em>my_conf</em>
+configuration file (previously defined with <em>r.li.setup</em>) and saving
+results in the raster map <em>my_out</em>, run:
+r.li.patchdensity map=my_map conf=my_conf out=my_out
+</pre></div>
+<p>
+Example for Spearfish forest areas:
+g.region rast=landcover.30m -p
+# extract forested areas:
+r.category landcover.30m
+r.mapcalc "forests=if(landcover.30m >= 41 && landcover.30m <=43,1,null())"
+# patch density (7x7 moving window defined in r.li.setup):
+r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
+d.rast.leg forests_p_dens7
+r.to.vect forests out=forests feature=area
+d.vect forests type=boundary
+</pre></div>
+<H2>NOTES</H2>
+A map of NULL values is considered to have zero patches. <br>
+r.null setnull=0 map=my_out
+<pre></div>
+after index calculation.<br>
+<!-- next ??????: -->
+If raster area is 0, <em>r.li.patchdensity</em> returns -1. This is only possible
+if the raster is masked.
+<H2>SEE ALSO</H2>
+<H2>AUTHORS</H2>
+Commission from Faunalia Pontedera (PI) (www.faunalia.it)<br>
+<H2>BUGS</h2>
+<a href="mailto:porta at cli.di.unipi.it">porta at cli.di.unipi.it</a><BR>
+<p><i>Last changed: $Date$</i<pre>
Deleted: grass/trunk/raster/r.li/r.li.patchnum/description.html
--- grass/trunk/raster/r.li/r.li.patchnum/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.patchnum/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,40 +0,0 @@
-<EM>r.li.patchnum</EM> is a patch index for r.li program.<br>
-It calculates the function <br>
-<I> f(sample_area)= Patch_Number </I><br>
-This index is calculated using a 4 neighbour algorithm<br>
-<H2>EXAMPLES</H2>
-To calculate patch number index on map my_map, using
-<em>my_conf</em> configuration file and saving results in
-my_out file run:
-r.li.patchnumber map=my_map conf=my_conf out=my_out
-</pre></div>
-<H2>NOTES</H2>
-An that is full of null values is considered to have zero patch. <br>
-</pre></div>
-<H2>SEE ALSO</H2>
-<H2>AUTHORS</H2>
-<H2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html (from rev 32770, grass/trunk/raster/r.li/r.li.patchnum/description.html)
--- grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,40 @@
+<EM>r.li.patchnum</EM> is a patch index for r.li program.<br>
+It calculates the function <br>
+<I> f(sample_area)= Patch_Number </I><br>
+This index is calculated using a 4 neighbour algorithm<br>
+<H2>EXAMPLES</H2>
+To calculate patch number index on map my_map, using
+<em>my_conf</em> configuration file and saving results in
+my_out file run:
+r.li.patchnumber map=my_map conf=my_conf out=my_out
+</pre></div>
+<H2>NOTES</H2>
+An that is full of null values is considered to have zero patch. <br>
+</pre></div>
+<H2>SEE ALSO</H2>
+<H2>AUTHORS</H2>
+<H2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.richness/description.html
--- grass/trunk/raster/r.li/r.li.richness/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.richness/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,45 +0,0 @@
-<em>r.li.richness</em> calculates the "richness's diversity index" as:<br>
-<img src="rliRichness_formula.png"> <br>
-with: <br>
-<ul>
-</ul>
-<h2>EXAMPLES</h2>
-To calculate richness's diversity index on map my_map, using
-r.li.richness map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-If input raster is full of null values r.li.richness returns -1.<br>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.richness/r.li.richness.html (from rev 32770, grass/trunk/raster/r.li/r.li.richness/description.html)
--- grass/trunk/raster/r.li/r.li.richness/r.li.richness.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.richness/r.li.richness.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,45 @@
+<em>r.li.richness</em> calculates the "richness's diversity index" as:<br>
+<img src="rliRichness_formula.png"> <br>
+with: <br>
+<ul>
+</ul>
+<h2>EXAMPLES</h2>
+To calculate richness's diversity index on map my_map, using
+r.li.richness map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+If input raster is full of null values r.li.richness returns -1.<br>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.setup/description.html
--- grass/trunk/raster/r.li/r.li.setup/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.setup/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,158 +0,0 @@
-<EM>r.li.setup</EM> creates and shows configuration files for the
-others r.li programs. For a general introduction, see
-<a href="r.li.html">r.li</a>.
-<br>
-The configurations are raster map independent,
-it means that you can use a file created on a raster map for analyze any
-other you have. <br>
-The program is completly interactive and uses a GUI to help you
-in your choices.
-<h3>Analysis methods</h3>
-Definition of region for analysis:
-<ul>
-<li> Whole maplayer: entire map (current region),
-<li> Keyboard setting: based on keyboard selection for region definition,
-<li> Draw the sampling frame: based on interactive region selection via mouse.
-</ul>
-Definition of creation of sampling area:
-<ul>
-<li> Whole maplayer: use entire area selected above,
-<li> Regions: select one to many subareas via mouse,
-<li> Sample units: automated selection of sampling area (for details see below)
-<ul>
- <li> Random nonoverlapping,
- <li> Systematic contiguous,
- <li> Systematic noncontiguous,
- <li> Stratified random,
- <li> Centered over sites (vector points).
-</ul>
-<li> Moving window: rectagular or circular with size
-<li> Select areas from the overlayed vector map (for details see below)
-</ul>
-<img src="sampleAreas.jpg" alt="Sampling area definition">
-<h3>Usage details</h3>
-The startup window shows your configuration files, you can:
-<ol>
-<li><em><b>Load a file</b></em>: the configuration is printed using
-rectangles with differents colors (green for the raster map,
-red for the sample
-frame and blue for the sample areas), and other notes (disposition of
-sample areas etc).
-The configuration file is saved in <tt>~/.r.li/history/my_conf</tt>.
-<!-- NOT REALLY CLEAR: -->
-Configuration output files are raster if moving window disposition was
-selected, otherwise they are in ~/.r.li/output folder.
-<br>
-All dimension are percentage of raster rows or columns.
-<li><em><b>Create a new file:</b></em> this create a new configuration
-file in an interactive way, in three steps
- <ol>
- <li> Choose file name and maps to use for setting:
- <ul>
- <li> <em>Configuration file name </em>(required): the name
- of new configuration file
- <li> <em>Raster map name</em> (required): the name of raster
- map to use for setting
- <li> <em>Vector map to overlay</em> (optional): name of a vector
- map to overlay in setting
- <li> <em>Site file to overlay</em> (optional): name of vector map
- of points type to overlay in setting
- </ul>
- <li> Set the sampling frame. The sample frame is a rectangular area
- which contains all the areas to analyze. It can be defined in three
- ways:
- <ul>
- <li><em>Whole map layer</em>: the sample frame is the whole map
- <li><em>Keyboard setting</em>: the user enters the coordinates in
- cells of upper left corner of sampling frame and its length in
- rows and columns</em>
- <li><em>Draw the sample frame</em>: the user draws the sample frame
- on map using mouse.
- </ul>
- <li> Set the sample areas. The sample areas are simply the areas to
- analyze. They can be defined in five ways (see the picture below):
- <ul>
- <li><em>Whole map layer</em>: the sample area is the whole sample
- frame
- <li><em>Regions</em>: the user enters the number of areas and then
- draws them using mouse.
- <li><em>Sample units</em>: they are areas of rectangular or circular
- shape. The user can define them using keyboard or mouse.
- <ul>
- <li>keyboard: the user define the shape of sample unists and
- their disposition:
- <ul>
- <li><em>Random non overlapping</em>: the user specifies
- the number of sample units and they are placed in a
- random way at runtime. It is guaranted that the
- areas do not intersect themselfs.
- <li><em>Systematic contiguous</em>: the defined sample
- is placed covering the sample frame, side by side
- across rows.
- <li><em>Systematic non contiguous</em>: the same as above,
- but here ever rectangle is spaced from another by
- a specified number of cells
- <li><em>Stratified random</em>: the sample frame is
- divided in n strats of rows and m strats of columns
- (n and m are given by user), then the specified
- number of sample areas are placed in a random way,
- one for every m*n areas defined by strats.
- <li><em>Centered over sites</em>: the sample areas
- are placed into sample frame centering them on points
- in site file.
- </ul>
- <li>mouse: the user chooses the shape and then draws the
- specified number of sample areas on map.
- </ul>
- <li><em>Moving Window:</em> the user defines a rectangular or
- circular area, it is moved over all the raster increasing only
- of a cell for every move(in columns if possible, if not in rows).
- It produces a new raster containing the result of all analysis.
- <li><em>Select areas from the overlayed vector map</em>:
- the sample areas are defined by the vector map selected above.
- For every cat in vector map, the procedure prompts the
- user if he wants to include it as sample area.
- The resulting configuration file can be used only with the
- specified raster map, and the procedure can be used only if
- whole map layer is selected as sampling frame.
- </ol>
-<li><em><b>Remove a file</b></em> the selected file is deleted from the
-available configuration files.
-<li><em><b>Help</b></em>: open this help text.
-<li><em><b>Close</b></em> module window.
-</ol>
-<H2>NOTES</H2>
-Configuration files are raster map independent because areas are saved using
-relative coordinates.
-<H2>SEE ALSO</H2>
-old r.le manual</A></EM><BR>
-<EM><A HREF="r.li.daemon.html">r.li.daemon</A></EM>,
-<H2>AUTHORS</H2>
-Claudio Porta & Lucio Davide Spano, students of Computer Science
-<H2>BUGS</h2>
-<a href="mailto:cavallini at faunalia.it">cavallini at faunalia.it</a>
Copied: grass/trunk/raster/r.li/r.li.setup/r.li.setup.html (from rev 32770, grass/trunk/raster/r.li/r.li.setup/description.html)
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,158 @@
+<EM>r.li.setup</EM> creates and shows configuration files for the
+others r.li programs. For a general introduction, see
+<a href="r.li.html">r.li</a>.
+<br>
+The configurations are raster map independent,
+it means that you can use a file created on a raster map for analyze any
+other you have. <br>
+The program is completly interactive and uses a GUI to help you
+in your choices.
+<h3>Analysis methods</h3>
+Definition of region for analysis:
+<ul>
+<li> Whole maplayer: entire map (current region),
+<li> Keyboard setting: based on keyboard selection for region definition,
+<li> Draw the sampling frame: based on interactive region selection via mouse.
+</ul>
+Definition of creation of sampling area:
+<ul>
+<li> Whole maplayer: use entire area selected above,
+<li> Regions: select one to many subareas via mouse,
+<li> Sample units: automated selection of sampling area (for details see below)
+<ul>
+ <li> Random nonoverlapping,
+ <li> Systematic contiguous,
+ <li> Systematic noncontiguous,
+ <li> Stratified random,
+ <li> Centered over sites (vector points).
+</ul>
+<li> Moving window: rectagular or circular with size
+<li> Select areas from the overlayed vector map (for details see below)
+</ul>
+<img src="sampleAreas.jpg" alt="Sampling area definition">
+<h3>Usage details</h3>
+The startup window shows your configuration files, you can:
+<ol>
+<li><em><b>Load a file</b></em>: the configuration is printed using
+rectangles with differents colors (green for the raster map,
+red for the sample
+frame and blue for the sample areas), and other notes (disposition of
+sample areas etc).
+The configuration file is saved in <tt>~/.r.li/history/my_conf</tt>.
+<!-- NOT REALLY CLEAR: -->
+Configuration output files are raster if moving window disposition was
+selected, otherwise they are in ~/.r.li/output folder.
+<br>
+All dimension are percentage of raster rows or columns.
+<li><em><b>Create a new file:</b></em> this create a new configuration
+file in an interactive way, in three steps
+ <ol>
+ <li> Choose file name and maps to use for setting:
+ <ul>
+ <li> <em>Configuration file name </em>(required): the name
+ of new configuration file
+ <li> <em>Raster map name</em> (required): the name of raster
+ map to use for setting
+ <li> <em>Vector map to overlay</em> (optional): name of a vector
+ map to overlay in setting
+ <li> <em>Site file to overlay</em> (optional): name of vector map
+ of points type to overlay in setting
+ </ul>
+ <li> Set the sampling frame. The sample frame is a rectangular area
+ which contains all the areas to analyze. It can be defined in three
+ ways:
+ <ul>
+ <li><em>Whole map layer</em>: the sample frame is the whole map
+ <li><em>Keyboard setting</em>: the user enters the coordinates in
+ cells of upper left corner of sampling frame and its length in
+ rows and columns</em>
+ <li><em>Draw the sample frame</em>: the user draws the sample frame
+ on map using mouse.
+ </ul>
+ <li> Set the sample areas. The sample areas are simply the areas to
+ analyze. They can be defined in five ways (see the picture below):
+ <ul>
+ <li><em>Whole map layer</em>: the sample area is the whole sample
+ frame
+ <li><em>Regions</em>: the user enters the number of areas and then
+ draws them using mouse.
+ <li><em>Sample units</em>: they are areas of rectangular or circular
+ shape. The user can define them using keyboard or mouse.
+ <ul>
+ <li>keyboard: the user define the shape of sample unists and
+ their disposition:
+ <ul>
+ <li><em>Random non overlapping</em>: the user specifies
+ the number of sample units and they are placed in a
+ random way at runtime. It is guaranted that the
+ areas do not intersect themselfs.
+ <li><em>Systematic contiguous</em>: the defined sample
+ is placed covering the sample frame, side by side
+ across rows.
+ <li><em>Systematic non contiguous</em>: the same as above,
+ but here ever rectangle is spaced from another by
+ a specified number of cells
+ <li><em>Stratified random</em>: the sample frame is
+ divided in n strats of rows and m strats of columns
+ (n and m are given by user), then the specified
+ number of sample areas are placed in a random way,
+ one for every m*n areas defined by strats.
+ <li><em>Centered over sites</em>: the sample areas
+ are placed into sample frame centering them on points
+ in site file.
+ </ul>
+ <li>mouse: the user chooses the shape and then draws the
+ specified number of sample areas on map.
+ </ul>
+ <li><em>Moving Window:</em> the user defines a rectangular or
+ circular area, it is moved over all the raster increasing only
+ of a cell for every move(in columns if possible, if not in rows).
+ It produces a new raster containing the result of all analysis.
+ <li><em>Select areas from the overlayed vector map</em>:
+ the sample areas are defined by the vector map selected above.
+ For every cat in vector map, the procedure prompts the
+ user if he wants to include it as sample area.
+ The resulting configuration file can be used only with the
+ specified raster map, and the procedure can be used only if
+ whole map layer is selected as sampling frame.
+ </ol>
+<li><em><b>Remove a file</b></em> the selected file is deleted from the
+available configuration files.
+<li><em><b>Help</b></em>: open this help text.
+<li><em><b>Close</b></em> module window.
+</ol>
+<H2>NOTES</H2>
+Configuration files are raster map independent because areas are saved using
+relative coordinates.
+<H2>SEE ALSO</H2>
+old r.le manual</A></EM><BR>
+<EM><A HREF="r.li.daemon.html">r.li.daemon</A></EM>,
+<H2>AUTHORS</H2>
+Claudio Porta & Lucio Davide Spano, students of Computer Science
+<H2>BUGS</h2>
+<a href="mailto:cavallini at faunalia.it">cavallini at faunalia.it</a>
Deleted: grass/trunk/raster/r.li/r.li.shannon/description.html
--- grass/trunk/raster/r.li/r.li.shannon/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.shannon/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,50 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.li.shannon</em>
-calculates the "shannon's diversity index" as: <br>
-<img src="rliShannon_formula.png"><br>
-with:<br>
-<ul>
- <li><b>m</b>: number of patch type<br></li>
-</ul>
-<h2>EXAMPLES</h2>
-To calculate shannon's diversity index on map my_map, using
-<div class="code"><pre>
-r.li.shannon map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-If input raster is full of null values r.li.shannon returns -1. <br>
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html (from rev 32770, grass/trunk/raster/r.li/r.li.shannon/description.html)
--- grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,50 @@
+<em>r.li.shannon</em>
+calculates the "shannon's diversity index" as: <br>
+<img src="rliShannon_formula.png"><br>
+with:<br>
+<ul>
+ <li><b>m</b>: number of patch type<br></li>
+</ul>
+<h2>REFERENCES</h2>
+<h2>EXAMPLES</h2>
+To calculate shannon's diversity index on map my_map, using
+r.li.shannon map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+If input raster is full of null values r.li.shannon returns -1. <br>
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.li/r.li.shape/description.html
--- grass/trunk/raster/r.li/r.li.shape/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.shape/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,30 +0,0 @@
-<EM>r.li.shape</EM> is a patch index for r.li program.<br>
-<I> f(sample_area)= Area </I><br>
-<H2>EXAMPLES</H2>
-To calculate area index on map my_map, using
-my_out file run:
-r.li.shape map=my_map conf=my_conf out=my_out
-</pre></div>
-<H2>SEE ALSO</H2>
-<H2>AUTHORS</H2>
-<H2>BUGS</h2>
-<BR>
Copied: grass/trunk/raster/r.li/r.li.shape/r.li.shape.html (from rev 32770, grass/trunk/raster/r.li/r.li.shape/description.html)
--- grass/trunk/raster/r.li/r.li.shape/r.li.shape.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.shape/r.li.shape.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,30 @@
+<EM>r.li.shape</EM> is a patch index for r.li program.<br>
+<I> f(sample_area)= Area </I><br>
+<H2>EXAMPLES</H2>
+To calculate area index on map my_map, using
+my_out file run:
+r.li.shape map=my_map conf=my_conf out=my_out
+</pre></div>
+<H2>SEE ALSO</H2>
+<H2>AUTHORS</H2>
+<H2>BUGS</h2>
+<BR>
Deleted: grass/trunk/raster/r.li/r.li.simpson/description.html
--- grass/trunk/raster/r.li/r.li.simpson/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.li/r.li.simpson/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,53 +0,0 @@
-<em>r.li.simpson</em>
-calculates the "simpson's diversity index" as:<br>
-<img src="rliSimpson_formula.png"> <br>
-with: <br>
-<ul>
- <li><b>i</b>: patch type<br> </li>
- <li><b>p<small><small>i</small></small></b>: proportion of the landscape occupied by patch type i<br> </li>
-</ul>
-<h2>EXAMPLES</h2>
-To calculate simpson's diversity index on map my_map, using
-r.li.simpson map=my_map conf=my_conf output=my_out
-</pre></div>
-<h2>NOTES</h2>
-If input raster is full of null values r.li.simpson returns -1.<br>
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<h2>AUTHORS</h2>
-<h2>BUGS</h2>
Copied: grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html (from rev 32770, grass/trunk/raster/r.li/r.li.simpson/description.html)
--- grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html (rev 0)
+++ grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,53 @@
+<em>r.li.simpson</em>
+calculates the "simpson's diversity index" as:<br>
+<img src="rliSimpson_formula.png"> <br>
+with: <br>
+<ul>
+ <li><b>i</b>: patch type<br> </li>
+ <li><b>p<small><small>i</small></small></b>: proportion of the landscape occupied by patch type i<br> </li>
+</ul>
+<h2>EXAMPLES</h2>
+To calculate simpson's diversity index on map my_map, using
+r.li.simpson map=my_map conf=my_conf output=my_out
+</pre></div>
+<h2>NOTES</h2>
+If input raster is full of null values r.li.simpson returns -1.<br>
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<h2>AUTHORS</h2>
+<h2>BUGS</h2>
Deleted: grass/trunk/raster/r.los/description.html
--- grass/trunk/raster/r.los/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.los/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,95 +0,0 @@
-<em>r.los</em> generates a raster output map in which the cells that are
-visible from a user-specified observer position are marked with the
-vertical angle (in degrees) required to see those cells (viewshed).
-A value of 0 is directly below the specified viewing position,
-90 is due horizontal, and 180 is directly above the observer.
-The angle to the cell containing the viewing position is undefined
-and set to 180.
-<p>
-To run <em>r.los</em>, the user must specify at least
-an <b>input</b> map name, <b>output</b> map name, and the geographic
-<b>coordinate</b>s of the user's viewing location;
-any remaining parameters whose values are unspecified
-will be set to their default values (see below).
-<p>
-The <b>patt_map</b> is the name of a binary (1/0) raster map layer in which
-cells within the areas of interest are assigned the category value '1', and
-all other cells are assigned the category value '0' or NULL. If this parameter is
-omitted, the analysis will be performed for the whole area within a certain
-distance of the viewing point inside the geographic region boundaries.
-<br>
-Default: assign all cells that are within the <b>max_dist</b> and within
-the user's current geographic region boundaries a value of 1.
-<p>
-The <b>obs_elev</b> parameter defines the height of the observer (in
-meters) above the viewing point's elevation.
-<p>
-The <b>max_dist</b> parameter is the maximum distance (in meters) from the
-viewing point inside of which the line of sight analysis will be performed.
-The cells outside this distance range are assigned a NULL value.
-<h2>NOTES</h2>
-For accurate results, the program must be run with the resolution of the
-geographic region set equal to the resolution of the data
-(see <em><a href="g.region.html">g.region</a></em>).
-<p>
-The time to complete the calculation increases dramatically with the region size.
-Try to keep the columns and rows under 1000.
-<p>
-It is advisable to use a 'pattern layer' which identifies
-the areas of interest in which the line of sight analysis
-is required. Such a measure will reduce the time taken by
-the program to run.
-<p>
-The curvature of the Earth is not taken into account for these calculations.
-However, for interest's sake, a handy calculation for distance to the true horizon
-is approximated by <i>d = sqrt(13*h)</i> where <i>h</i> is the height of the observer
-in meters (above sea level) and <i>d</i> is the distance to the horizon in km.
-This may be useful for setting the <b>max_dist</b> value.
-<h2>EXAMPLE</h2>
-Spearfish example - calculation of viewshed from 50m tower
-on top of a mountain:
-r.los elevation.dem out=los coord=598869,4916642 obs_elev=50 max_dist=10000
-r.colors -e los color=bgyr
-d.shadedmap relief=aspect drape=los bright=10
-echo "symbol extra/target 25 598869 4916642 red" | d.graph -m
-</pre></div>
-<h2>TODO</h2>
-Rewrite using ideas from <em>r.cva</em> and a method which scales better
-to large regions.<br>A suggested method is detailed in:<br>
-Izraelevitz, David (USACE).<br>
-'A Fast Algorithm for Approximate Viewshed Computation'<br>
-<i>Photogrammetric Engineering & Remote Sensing</i>, July 2003
-<!-- http://article.gmane.org/gmane.comp.gis.grass.devel/1781
- Post by Paul Kelly 2003-08-13 to grass-dev,
- "Re: [bug #2061] (grass) r.los needs FP update" -->
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>
-<h2>AUTHOR</h2>
-Kewan Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.los/r.los.html (from rev 32770, grass/trunk/raster/r.los/description.html)
--- grass/trunk/raster/r.los/r.los.html (rev 0)
+++ grass/trunk/raster/r.los/r.los.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,95 @@
+<em>r.los</em> generates a raster output map in which the cells that are
+visible from a user-specified observer position are marked with the
+vertical angle (in degrees) required to see those cells (viewshed).
+A value of 0 is directly below the specified viewing position,
+90 is due horizontal, and 180 is directly above the observer.
+The angle to the cell containing the viewing position is undefined
+and set to 180.
+<p>
+To run <em>r.los</em>, the user must specify at least
+an <b>input</b> map name, <b>output</b> map name, and the geographic
+<b>coordinate</b>s of the user's viewing location;
+any remaining parameters whose values are unspecified
+will be set to their default values (see below).
+<p>
+The <b>patt_map</b> is the name of a binary (1/0) raster map layer in which
+cells within the areas of interest are assigned the category value '1', and
+all other cells are assigned the category value '0' or NULL. If this parameter is
+omitted, the analysis will be performed for the whole area within a certain
+distance of the viewing point inside the geographic region boundaries.
+<br>
+Default: assign all cells that are within the <b>max_dist</b> and within
+the user's current geographic region boundaries a value of 1.
+<p>
+The <b>obs_elev</b> parameter defines the height of the observer (in
+meters) above the viewing point's elevation.
+<p>
+The <b>max_dist</b> parameter is the maximum distance (in meters) from the
+viewing point inside of which the line of sight analysis will be performed.
+The cells outside this distance range are assigned a NULL value.
+<h2>NOTES</h2>
+For accurate results, the program must be run with the resolution of the
+geographic region set equal to the resolution of the data
+(see <em><a href="g.region.html">g.region</a></em>).
+<p>
+The time to complete the calculation increases dramatically with the region size.
+Try to keep the columns and rows under 1000.
+<p>
+It is advisable to use a 'pattern layer' which identifies
+the areas of interest in which the line of sight analysis
+is required. Such a measure will reduce the time taken by
+the program to run.
+<p>
+The curvature of the Earth is not taken into account for these calculations.
+However, for interest's sake, a handy calculation for distance to the true horizon
+is approximated by <i>d = sqrt(13*h)</i> where <i>h</i> is the height of the observer
+in meters (above sea level) and <i>d</i> is the distance to the horizon in km.
+This may be useful for setting the <b>max_dist</b> value.
+<h2>EXAMPLE</h2>
+Spearfish example - calculation of viewshed from 50m tower
+on top of a mountain:
+<div class="code"><pre>
+r.los elevation.dem out=los coord=598869,4916642 obs_elev=50 max_dist=10000
+r.colors -e los color=bgyr
+d.shadedmap relief=aspect drape=los bright=10
+echo "symbol extra/target 25 598869 4916642 red" | d.graph -m
+</pre></div>
+<h2>TODO</h2>
+Rewrite using ideas from <em>r.cva</em> and a method which scales better
+to large regions.<br>A suggested method is detailed in:<br>
+Izraelevitz, David (USACE).<br>
+'A Fast Algorithm for Approximate Viewshed Computation'<br>
+<i>Photogrammetric Engineering & Remote Sensing</i>, July 2003
+<!-- http://article.gmane.org/gmane.comp.gis.grass.devel/1781
+ Post by Paul Kelly 2003-08-13 to grass-dev,
+ "Re: [bug #2061] (grass) r.los needs FP update" -->
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>
+<h2>AUTHOR</h2>
+Kewan Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.median/description.html
--- grass/trunk/raster/r.median/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.median/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,68 +0,0 @@
-<em>r.median</em> calculates the median category of data
-contained in a <b>cover</b> raster map layer for areas
-assigned the same category value in the user-specified
-<b>base</b> raster map layer. These median values are
-stored in the new <b>output</b> map layer.
-<p>
-The <b>output</b> map is actually a <em>reclass</em> of the <b>base</b> map.
-The <b>base</b> map is an existing raster map layer in the user's current
-mapset search path. For each group of cells assigned the
-same category value in the <b>base</b> map, the median of
-the values assigned these cells in the <b>cover</b> map
-will be computed.
-<p>
-The <b>cover</b> map is an existing raster map layer containing the values
-to be used to compute the median within each category of the <b>base</b> map.
-<h2>NOTES</h2>
-The user should use the results of <em>r.median</em> with
-care. Since this utility assigns a value to each cell
-which is based on global information (i.e., information at
-spatial locations other than just the location of the cell
-itself), the resultant map layer is only valid if the
-geographic region and mask settings are the same as they
-were at the time that the result map was created.
-<p>
-Results are affected by the current region settings and mask.
-<h2>EXAMPLE</h2>
-Median K-factor (erosion) for Spearfish fields:
-g.region rast=fields -p
-r.median base=fields cover=soils.Kfactor output=K.by.farm.median
-r.univar K.by.farm.median
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.average.html">r.average</a></em>,
-<em><a href="r.category.html">r.category</a></em>,
-<em><a href="r.clump.html">r.clump</a></em>,
-<em><a href="r.describe.html">r.describe</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.mfilter.html">r.mfilter</a></em>,
-<em><a href="r.mode.html">r.mode</a></em>,
-<em><a href="r.neighbors.html">r.neighbors</a></em>,
-<em><a href="r.reclass.html">r.reclass</a></em>,
-<em><a href="r.statistics.html">r.statistics</a></em>,
-<em><a href="r.stats.html">r.stats</a></em>,
-<em><a href="r.univar.html">r.univar</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S.Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.median/r.median.html (from rev 32770, grass/trunk/raster/r.median/description.html)
--- grass/trunk/raster/r.median/r.median.html (rev 0)
+++ grass/trunk/raster/r.median/r.median.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,68 @@
+<em>r.median</em> calculates the median category of data
+contained in a <b>cover</b> raster map layer for areas
+assigned the same category value in the user-specified
+<b>base</b> raster map layer. These median values are
+stored in the new <b>output</b> map layer.
+<p>
+The <b>output</b> map is actually a <em>reclass</em> of the <b>base</b> map.
+The <b>base</b> map is an existing raster map layer in the user's current
+mapset search path. For each group of cells assigned the
+same category value in the <b>base</b> map, the median of
+the values assigned these cells in the <b>cover</b> map
+will be computed.
+<p>
+The <b>cover</b> map is an existing raster map layer containing the values
+to be used to compute the median within each category of the <b>base</b> map.
+<h2>NOTES</h2>
+The user should use the results of <em>r.median</em> with
+care. Since this utility assigns a value to each cell
+which is based on global information (i.e., information at
+spatial locations other than just the location of the cell
+itself), the resultant map layer is only valid if the
+geographic region and mask settings are the same as they
+were at the time that the result map was created.
+<p>
+Results are affected by the current region settings and mask.
+<h2>EXAMPLE</h2>
+Median K-factor (erosion) for Spearfish fields:
+g.region rast=fields -p
+r.median base=fields cover=soils.Kfactor output=K.by.farm.median
+r.univar K.by.farm.median
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.average.html">r.average</a></em>,
+<em><a href="r.category.html">r.category</a></em>,
+<em><a href="r.clump.html">r.clump</a></em>,
+<em><a href="r.describe.html">r.describe</a></em>,
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a href="r.mfilter.html">r.mfilter</a></em>,
+<em><a href="r.mode.html">r.mode</a></em>,
+<em><a href="r.neighbors.html">r.neighbors</a></em>,
+<em><a href="r.reclass.html">r.reclass</a></em>,
+<em><a href="r.statistics.html">r.statistics</a></em>,
+<em><a href="r.stats.html">r.stats</a></em>,
+<em><a href="r.univar.html">r.univar</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S.Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.mfilter/description.html
--- grass/trunk/raster/r.mfilter/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.mfilter/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,156 +0,0 @@
-<em>r.mfilter</em> filters the raster <em>input</em> to produce the
-raster <em>output</em> according to the matrix <em>filter</em> designed
-by the user (see <em>FILTERS</em> below).
-The filter is applied <em>repeat</em> times (default <em>value</em> is 1).
-The <em>output</em> raster map layer can be given a <em>TITLE</em> if desired.
-(This TITLE should be put in quotes if it contains more than one word.)
-With <b>-z</b> flag the filter is applied only to zero category values in
-the input raster map layer. The non-zero category values are not changed.
-Note that if there is more than one filter step, this rule is applied to the
-intermediate raster map layer -- only zero category values which result from
-the first filter will be changed. In most cases this will NOT be the
-desired result. Hence -z should be used only with single step filters.
-<p>
-The <b>filter</b> parameter defines the name of an existing, user-created
-UNIX ASCII file whose contents is a matrix defining the way in which the
-<em>input</em> file will be filtered. The format of this file is described
-below, under FILTERS.
-<p>
-The <b>repeat</b> parameter defines the number of times the <em>filter</em>
-is to be applied to the <em>input</em> data.
-<h2>FILTERS</h2>
-The <em>filter</em> file is a normal UNIX ASCII file designed by the user.
-It has the following format:
-<pre>
- TITLE TITLE
- MATRIX n
- n lines of n integers
- DIVISOR d
- TYPE S/P
-</pre>
-<dt>TITLE
-<dd>A one-line TITLE for the filter.
-If a TITLE was not specified on the command line, it can be specified here.
-This TITLE would be used to construct a TITLE for the resulting raster map
-layer. It should be a one-line description of the filter.
-<dt>MATRIX
-<dd>The matrix (n x n) follows on the next n lines. <em>n</em> must be
-an odd integer greater than or equal to 3.
-The matrix itself consists of n rows of n integers.
-The integers must be separated from each other by at least 1 blank.
-<dt>DIVISOR
-<dd>The filter divisor is <em>d</em>. If not specified, the default is 1.
-If the divisor is zero (0), then the divisor is dependent on the
-category values in the neighborhood
-(see HOW THE FILTER WORKS below).
-<dt>TYPE
-<dd>The filter type. <em>S</em> means sequential, while <em>P</em> mean parallel.
-If not specified, the default is S.
-<p>
-Sequential filtering happens in place. As the filter is applied to the
-raster map layer, the category values that were changed in neighboring
-cells affect the resulting category value of the current
-cell being filtered.
-<p>
-Parallel filtering happens in such a way that the original raster
-map layer category values are used to produce the new category value.
-<p>
-More than one filter may be specified in the filter file.
-The additional filter(s) are described just like the first.
-For example, the following describes two filters:
-</p>
-</dd>
-<h2>EXAMPLE FILTER FILE</h2>
-<pre>
- TITLE 3x3 average, non-zero data only, followed by 5x5 average
- MATRIX 3
- 1 1 1
- 1 1 1
- 1 1 1
- DIVISOR 0
- TYPE P
- MATRIX 5
- 1 1 1 1 1
- 1 1 1 1 1
- 1 1 1 1 1
- 1 1 1 1 1
- 1 1 1 1 1
- DIVISOR 25
- TYPE P
-</pre>
-<h2>HOW THE FILTER WORKS</h2>
-The filter process produces a new category value for each cell
-in the input raster map layer by multiplying the category values of the
-cells in the n x n neighborhood around the center cell
-by the corresponding matrix value and adding them together.
-If a divisor is specified, the sum is divided by this divisor,
-rounding to the nearest integer.
-(If a zero divisor was specified, then
-the divisor is computed for each cell as the sum of the MATRIX
-values where the corresponding input cell is non-zero.)
-<p>
-If more than one filter step is specified, either because the
-repeat value was greater than one or because the filter file
-contained more than one matrix, these steps are performed
-sequentially. This means that first one filter is applied to
-the entire input raster map layer to produce an intermediate result;
-then the next filter is applied to the intermediate result to
-produce another intermediate result; and so on, until the
-final filter is applied. Then the output cell is written.
-<h2>NOTES</h2>
-If the resolution of the geographic region does not agree with the
-resolution of the raster map layer, unintended resampling of the original
-data may occur. The user should be sure that the geographic region
-is set properly.
-<h2>SEE ALSO</h2>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-<p>
Copied: grass/trunk/raster/r.mfilter/r.mfilter.html (from rev 32770, grass/trunk/raster/r.mfilter/description.html)
--- grass/trunk/raster/r.mfilter/r.mfilter.html (rev 0)
+++ grass/trunk/raster/r.mfilter/r.mfilter.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,156 @@
+<em>r.mfilter</em> filters the raster <em>input</em> to produce the
+raster <em>output</em> according to the matrix <em>filter</em> designed
+by the user (see <em>FILTERS</em> below).
+The filter is applied <em>repeat</em> times (default <em>value</em> is 1).
+The <em>output</em> raster map layer can be given a <em>TITLE</em> if desired.
+(This TITLE should be put in quotes if it contains more than one word.)
+With <b>-z</b> flag the filter is applied only to zero category values in
+the input raster map layer. The non-zero category values are not changed.
+Note that if there is more than one filter step, this rule is applied to the
+intermediate raster map layer -- only zero category values which result from
+the first filter will be changed. In most cases this will NOT be the
+desired result. Hence -z should be used only with single step filters.
+<p>
+The <b>filter</b> parameter defines the name of an existing, user-created
+UNIX ASCII file whose contents is a matrix defining the way in which the
+<em>input</em> file will be filtered. The format of this file is described
+below, under FILTERS.
+<p>
+The <b>repeat</b> parameter defines the number of times the <em>filter</em>
+is to be applied to the <em>input</em> data.
+<h2>FILTERS</h2>
+The <em>filter</em> file is a normal UNIX ASCII file designed by the user.
+It has the following format:
+<pre>
+ TITLE TITLE
+ MATRIX n
+ n lines of n integers
+ DIVISOR d
+ TYPE S/P
+</pre>
+<dt>TITLE
+<dd>A one-line TITLE for the filter.
+If a TITLE was not specified on the command line, it can be specified here.
+This TITLE would be used to construct a TITLE for the resulting raster map
+layer. It should be a one-line description of the filter.
+<dt>MATRIX
+<dd>The matrix (n x n) follows on the next n lines. <em>n</em> must be
+an odd integer greater than or equal to 3.
+The matrix itself consists of n rows of n integers.
+The integers must be separated from each other by at least 1 blank.
+<dt>DIVISOR
+<dd>The filter divisor is <em>d</em>. If not specified, the default is 1.
+If the divisor is zero (0), then the divisor is dependent on the
+category values in the neighborhood
+(see HOW THE FILTER WORKS below).
+<dt>TYPE
+<dd>The filter type. <em>S</em> means sequential, while <em>P</em> mean parallel.
+If not specified, the default is S.
+<p>
+Sequential filtering happens in place. As the filter is applied to the
+raster map layer, the category values that were changed in neighboring
+cells affect the resulting category value of the current
+cell being filtered.
+<p>
+Parallel filtering happens in such a way that the original raster
+map layer category values are used to produce the new category value.
+<p>
+More than one filter may be specified in the filter file.
+The additional filter(s) are described just like the first.
+For example, the following describes two filters:
+</p>
+</dd>
+<h2>EXAMPLE FILTER FILE</h2>
+<pre>
+ TITLE 3x3 average, non-zero data only, followed by 5x5 average
+ MATRIX 3
+ 1 1 1
+ 1 1 1
+ 1 1 1
+ DIVISOR 0
+ TYPE P
+ MATRIX 5
+ 1 1 1 1 1
+ 1 1 1 1 1
+ 1 1 1 1 1
+ 1 1 1 1 1
+ 1 1 1 1 1
+ DIVISOR 25
+ TYPE P
+</pre>
+<h2>HOW THE FILTER WORKS</h2>
+The filter process produces a new category value for each cell
+in the input raster map layer by multiplying the category values of the
+cells in the n x n neighborhood around the center cell
+by the corresponding matrix value and adding them together.
+If a divisor is specified, the sum is divided by this divisor,
+rounding to the nearest integer.
+(If a zero divisor was specified, then
+the divisor is computed for each cell as the sum of the MATRIX
+values where the corresponding input cell is non-zero.)
+<p>
+If more than one filter step is specified, either because the
+repeat value was greater than one or because the filter file
+contained more than one matrix, these steps are performed
+sequentially. This means that first one filter is applied to
+the entire input raster map layer to produce an intermediate result;
+then the next filter is applied to the intermediate result to
+produce another intermediate result; and so on, until the
+final filter is applied. Then the output cell is written.
+<h2>NOTES</h2>
+If the resolution of the geographic region does not agree with the
+resolution of the raster map layer, unintended resampling of the original
+data may occur. The user should be sure that the geographic region
+is set properly.
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+<p>
Deleted: grass/trunk/raster/r.mfilter.fp/description.html
--- grass/trunk/raster/r.mfilter.fp/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.mfilter.fp/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,157 +0,0 @@
-<em>r.mfilter.fp</em> filters the raster <em>input</em> to produce the
-With <b>-z</b> flag the filter is applied only to null values in
-the input raster map layer. The non-null category values are not changed.
-intermediate raster map layer -- only null category values which result from
-<p>
-<p>
-<h2>FILTERS</h2>
-<pre>
- TITLE TITLE
- MATRIX n
- n lines of n values
- DIVISOR d
- TYPE S/P
-</pre>
-<dt>TITLE
-<dt>MATRIX
-The matrix itself consists of n rows of n values.
-The values must be separated from each other by at least 1 blank.
-<dt>DIVISOR
-<dt>TYPE
-<p>
-<p>
-<p>
-</p>
-</dd>
-<pre>
- TITLE 3x3 average, non-null data only, followed by 5x5 average
- MATRIX 3
- 1 1 1
- 1 1 1
- 1 1 1
- DIVISOR 0
- TYPE P
- MATRIX 5
- 1 1 1 1 1
- 1 1 1 1 1
- 1 1 1 1 1
- 1 1 1 1 1
- 1 1 1 1 1
- DIVISOR 25
- TYPE P
-</pre>
-If a divisor is specified, the sum is divided by this divisor.
-values where the corresponding input cell is non-null.)
-<p>
-<h2>NOTES</h2>
-is set properly.
-<h2>SEE ALSO</h2>
-<h2>AUTHOR</h2>
-Glynn Clements.
-Based upon r.mfilter, by Michael Shapiro,
-<p>
Copied: grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html (from rev 32770, grass/trunk/raster/r.mfilter.fp/description.html)
--- grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html (rev 0)
+++ grass/trunk/raster/r.mfilter.fp/r.mfilter.fp.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,157 @@
+<em>r.mfilter.fp</em> filters the raster <em>input</em> to produce the
+With <b>-z</b> flag the filter is applied only to null values in
+the input raster map layer. The non-null category values are not changed.
+intermediate raster map layer -- only null category values which result from
+<p>
+<p>
+<h2>FILTERS</h2>
+<pre>
+ TITLE TITLE
+ MATRIX n
+ n lines of n values
+ DIVISOR d
+ TYPE S/P
+</pre>
+<dt>TITLE
+<dt>MATRIX
+The matrix itself consists of n rows of n values.
+The values must be separated from each other by at least 1 blank.
+<dt>DIVISOR
+<dt>TYPE
+<p>
+<p>
+<p>
+</p>
+</dd>
+<pre>
+ TITLE 3x3 average, non-null data only, followed by 5x5 average
+ MATRIX 3
+ 1 1 1
+ 1 1 1
+ 1 1 1
+ DIVISOR 0
+ TYPE P
+ MATRIX 5
+ 1 1 1 1 1
+ 1 1 1 1 1
+ 1 1 1 1 1
+ 1 1 1 1 1
+ 1 1 1 1 1
+ DIVISOR 25
+ TYPE P
+</pre>
+If a divisor is specified, the sum is divided by this divisor.
+values where the corresponding input cell is non-null.)
+<p>
+<h2>NOTES</h2>
+is set properly.
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Glynn Clements.
+Based upon r.mfilter, by Michael Shapiro,
+<p>
Deleted: grass/trunk/raster/r.mode/description.html
--- grass/trunk/raster/r.mode/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.mode/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,67 +0,0 @@
-<em>r.mode</em> calculates the most frequently occurring value (i. e., mode)
-of data contained in a <em>cover</em> raster map layer for areas assigned
-the same category value in the user-specified <em>base</em> raster map
-layer. These modes are stored in the new <em>output</em> map layer.
-<p>
-The <em>output</em> map is actually a <em>reclass</em> of the <em>base</em>
-map.
-<p>
-The <b>base</b> parameter defines an existing raster map layer in the user's
-current mapset search path. For each group of cells assigned the same
-category value in the <em>base</em> map, the mode of the values assigned
-these cells in the <em>cover</em> map will be computed.
-<p>
-The <b>cover</b> parameter defines an existing raster map layer containing
-the values to be used to compute the mode within each category of the
-<em>base</em> map.
-<h2>NOTES</h2>
-The user should use the results of <em>r.mode</em> with care.
-Since this utility assigns a value to each
-cell which is based on global information (i.e., information at spatial
-locations other than just the location of the cell itself), the resultant
-map layer is only valid if the geographic region and mask settings are
-the same as they were at the time that the result map was created.
-<p>
-<h2>EXAMPLE</h2>
-Mode of K-factor (erosion) for Spearfish fields:
-r.mode base=fields cover=soils.Kfactor output=K.by.farm.mode
-r.univar K.by.farm.mode
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="r.median.html">r.median</a></em>,
-<h2>AUTHOR</h2>
-Michael Shapiro,
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.mode/r.mode.html (from rev 32770, grass/trunk/raster/r.mode/description.html)
--- grass/trunk/raster/r.mode/r.mode.html (rev 0)
+++ grass/trunk/raster/r.mode/r.mode.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,67 @@
+<em>r.mode</em> calculates the most frequently occurring value (i. e., mode)
+of data contained in a <em>cover</em> raster map layer for areas assigned
+the same category value in the user-specified <em>base</em> raster map
+layer. These modes are stored in the new <em>output</em> map layer.
+<p>
+The <em>output</em> map is actually a <em>reclass</em> of the <em>base</em>
+map.
+<p>
+The <b>base</b> parameter defines an existing raster map layer in the user's
+current mapset search path. For each group of cells assigned the same
+category value in the <em>base</em> map, the mode of the values assigned
+these cells in the <em>cover</em> map will be computed.
+<p>
+The <b>cover</b> parameter defines an existing raster map layer containing
+the values to be used to compute the mode within each category of the
+<em>base</em> map.
+<h2>NOTES</h2>
+The user should use the results of <em>r.mode</em> with care.
+Since this utility assigns a value to each
+cell which is based on global information (i.e., information at spatial
+locations other than just the location of the cell itself), the resultant
+map layer is only valid if the geographic region and mask settings are
+the same as they were at the time that the result map was created.
+<p>
+<h2>EXAMPLE</h2>
+Mode of K-factor (erosion) for Spearfish fields:
+r.mode base=fields cover=soils.Kfactor output=K.by.farm.mode
+r.univar K.by.farm.mode
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="r.median.html">r.median</a></em>,
+<h2>AUTHOR</h2>
+Michael Shapiro,
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.neighbors/description.html
--- grass/trunk/raster/r.neighbors/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.neighbors/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,291 +0,0 @@
-<em><b>r.neighbors</b></em> looks at each cell in a raster input
-file, and examines the values assigned to the
-cells in some user-defined "neighborhood" around it. It
-outputs a new raster map layer in which each cell is
-assigned a value that is some (user-specified)
-function of the values in that cell's neighborhood. For
-example, each cell in the output layer might be assigned a
-value equal to the average of the values
-appearing in its 3 x 3 cell "neighborhood" in the input
-layer.
-<p>
-The program will be run non-interactively if the user
-specifies program arguments (see OPTIONS) on the command
-line. Alternately, the user can simply type
-<em><b>r.neighbors</b></em> on the command line, without program
-arguments. In this case, the user will be prompted for
-flag settings and parameter values.
-<h3>OPTIONS</h3>
-The user must specify the names of the raster map layers to
-be used for <b>input</b> and <b>output</b>, the
-<b>method</b> used to analyze neighborhood
-values (i.e., the neighborhood function or operation to be
-performed), and the <b>size</b> of the neighborhood.
-Optionally, the user can also specify the <b>TITLE</b> to
-be assigned to the raster map layer <b>output</b>, elect
-to not align the resolution of the output with that of the
-input (the <b>-a</b> option), run <em><b>r.neighbors</b></em> with
-a custom matrix weights with the <em>weight</em> option, and
-elect to run <em><b>r.neighbors</b></em> quietly (the <b>-q</b> option).
-These options are described further below.
-<p>
-<em>Neighborhood Operation Methods:</em>
-The <b>neighborhood</b> operators determine what new
-value a center cell in a neighborhood will have after examining
-values inside its neighboring cells.
-Each cell in a raster map layer becomes the center cell of a neighborhood
-as the neighborhood window moves from cell to cell throughout the map layer.
-<em><b>r.neighbors</b></em> can perform the following operations:
-<p>
-<dl>
-<dt><b>average</b>
-<dd>The average value within the neighborhood.
-In the following example, the result would be:
-<br>
-(7*4 + 6 + 5 + 4*3)/9 = 5.66
-<br>
-The result is rounded to the nearest integer (in this case 6).
-<dt><b>median</b>
-<dd>The value found half-way through a list of the
-neighborhood's values,
-when these are ranged in numerical order.
-<dt><b>mode</b>
-<dd>The most frequently occurring value in the neighborhood.
-<dt><b>minimum</b>
-<dd>The minimum value within the neighborhood.
-<dt><b>maximum</b>
-<dd>The maximum value within the neighborhood.
-<pre>
- Raw Data Operation New Data
- | 7 | 7 | 5 | | | | |
- |----|----|----| average |----|----|----|
- | 4 | 7 | 4 |--------->| | 6 | |
- | 7 | 6 | 4 | | | | |
-</pre>
-<dt><b>stddev</b>
-<dd>The statistical standard deviation of values
-within the neighborhood (rounded to the nearest integer).
-<dt><b>sum</b>
-<dd>The sum of values within the neighborhood.
-<dt><b>variance</b>
-<dd>The statistical variance of values
-<dt><b>diversity</b>
-<dd>The number of different values within the neighborhood.
-In the above example, the diversity is 4.
-<dt><b>interspersion</b>
-<dd>The percentage of cells containing values which differ from the values
-assigned to the center cell in the neighborhood, plus 1.
-In the above example, the interspersion is:
-<br>
-5/8 * 100 + 1 = 63.5
-<br>
-The result is rounded to the nearest integer (in this case 64).
-</dl>
-<p>
-<br>
-<em>Neighborhood Size:</em>
-<dd>The neighborhood <b>size</b> specifies which cells surrounding any given
-cell fall into the neighborhood for that cell.
-The <b>size</b> must be an odd integer.
-For example,
-<pre>
- _ _ _
- |_|_|_|
- 3 x 3 neighborhood ---> |_|_|_|
- |_|_|_|
-</pre>
-</dd>
-<p>
-<em>Matrix weights:</em>
-<dd>A custom matrix can be used if none of the neighborhood operation
-methods are desirable by using the <b>weight</b>. This option must
-be used in conjunction with the <b>size</b> option to specify the
-matrix size. The weights desired are to be entered into a text file.
-For example, to calculate the focal mean with a matrix <b>size</b> of
-3,
-<pre>
-r.neigbors in=input.map out=output.map size=3 weight=weights.txt
-</pre>
-The contents of the weight.txt file:
-<pre>
-3 3 3
-1 4 8
-9 5 3
-</pre>
-This corresponds to the following 3x3 matrix:
-<pre>
- |3|3|3|
- |1|4|8|
- |9|5|3|
-</pre>
-<p>
-<h3>FLAGS</h3>
-<dt><b>-a</b>
-<dd>If specified, <em><b>r.neighbors</b></em> will not align the output
-raster map layer with that of the input raster map layer.
-The <em><b>r.neighbors</b></em> program works in the current geographic region.
-It is recommended, but not required, that the resolution
-of the geographic region be the same as that of the raster map layer.
-By default, if unspecified,
-<em><b>r.neighbors</b></em> will align these geographic region settings.
-<p>
-<dt><b>-c</b>
-<dd>
-This flag will use a circular neighborhood for the moving analysis window,
-centered on the current cell.
-<p>
-The exact masks for the first few neighborhood sizes are as follows:
-3x3 . X . 5x5 . . X . . 7x7 . . . X . . .
- X O X . X X X . . X X X X X .
- . X . X X O X X . X X X X X .
- . X X X . X X X O X X X
- . . X . . . X X X X X .
- . X X X X X .
- . . . X . . .
-9x9 . . . . X . . . . 11x11 . . . . . X . . . . .
- . . X X X X X . . . . X X X X X X X . .
- . X X X X X X X . . X X X X X X X X X .
- X X X X O X X X X . X X X X X X X X X .
- . X X X X X X X . X X X X X O X X X X X
- . . X X X X X . . . X X X X X X X X X .
- . . . . X . . . . . X X X X X X X X X .
- . . X X X X X X X . .
- . . . . . X . . . . .
-</pre></div>
-<p>
-<dt><b>-q</b>
-<dd>If specified, <em><b>r.neighbors</b></em> will run relatively quietly
-(i.e., without printing to standard output notes on the program's progress).
-If unspecified, the program will print messages to standard output by default.
-</dd>
-<h2>NOTES</h2>
-with the current mask, if any. It is recommended, but not required,
-that the resolution of the geographic region be the same as that
-of the raster map layer. By default, <em><b>r.neighbors</b></em> will align
-these geographic region settings. However, the user can elect to keep
-original input and output resolutions which are not aligned by specifying
-this (e.g., using the <b>-a</b> option).
-<p>
-The <b>-c</b> flag and the <b>weights</b> parameter are mutually exclusive.
-Any use of the two together will produce an error. Differently-shaped neighborhood
-analysis windows may be achieved by using the <b>weight=</b> parameter to specify
-a weights file where all values are equal (for <b>method</b>=sum, the sum of the
-weights should be 1). The user can also vary the weights at the edge of the
-neighborhood according to the proportion of the cell that lies inside the neighborhood circle,
-effectively anti-aliasing the analysis mask.
-<p>
-For aggregates where a weighted calculation isn't meaningful
-(specifically: minimum, maximum, diversity and interspersion), the
-weights are used to create a binary mask, where zero causes the cell
-to be ignored and any non-zero value causes the cell to be used.
-<p>
-<em><b>r.neighbors</b></em> copies the GRASS <em>color</em> files associated with
-the input raster map layer for those output map layers that are based
-on the neighborhood average, median, mode, minimum, and maximum.
-Because standard deviation, variance, diversity, and interspersion are indices,
-rather than direct correspondents to input values,
-no <em>color</em> files are copied for these map layers.
-(The user should note that although the <em>color</em> file is copied
-for <em>average</em> neighborhood function output,
-whether or not the color file makes sense for the output
-will be dependent on the input data values.)
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em><br>
-<em><a href="r.clump.html">r.clump</a></em><br>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em><br>
-<em><a href="r.mfilter.html">r.mfilter</a></em><br>
-<em><a href="r.statistics.html">r.statistics</a></em><br>
-<em><a href="r.support.html">r.support</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
Copied: grass/trunk/raster/r.neighbors/r.neighbors.html (from rev 32770, grass/trunk/raster/r.neighbors/description.html)
--- grass/trunk/raster/r.neighbors/r.neighbors.html (rev 0)
+++ grass/trunk/raster/r.neighbors/r.neighbors.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,291 @@
+<h2>DESCRIPTION</h2>
+<em><b>r.neighbors</b></em> looks at each cell in a raster input
+file, and examines the values assigned to the
+cells in some user-defined "neighborhood" around it. It
+outputs a new raster map layer in which each cell is
+assigned a value that is some (user-specified)
+function of the values in that cell's neighborhood. For
+example, each cell in the output layer might be assigned a
+value equal to the average of the values
+appearing in its 3 x 3 cell "neighborhood" in the input
+layer.
+<p>
+The program will be run non-interactively if the user
+specifies program arguments (see OPTIONS) on the command
+line. Alternately, the user can simply type
+<em><b>r.neighbors</b></em> on the command line, without program
+arguments. In this case, the user will be prompted for
+flag settings and parameter values.
+<h3>OPTIONS</h3>
+The user must specify the names of the raster map layers to
+be used for <b>input</b> and <b>output</b>, the
+<b>method</b> used to analyze neighborhood
+values (i.e., the neighborhood function or operation to be
+performed), and the <b>size</b> of the neighborhood.
+Optionally, the user can also specify the <b>TITLE</b> to
+be assigned to the raster map layer <b>output</b>, elect
+to not align the resolution of the output with that of the
+input (the <b>-a</b> option), run <em><b>r.neighbors</b></em> with
+a custom matrix weights with the <em>weight</em> option, and
+elect to run <em><b>r.neighbors</b></em> quietly (the <b>-q</b> option).
+These options are described further below.
+<p>
+<em>Neighborhood Operation Methods:</em>
+The <b>neighborhood</b> operators determine what new
+value a center cell in a neighborhood will have after examining
+values inside its neighboring cells.
+Each cell in a raster map layer becomes the center cell of a neighborhood
+as the neighborhood window moves from cell to cell throughout the map layer.
+<em><b>r.neighbors</b></em> can perform the following operations:
+<p>
+<dl>
+<dt><b>average</b>
+<dd>The average value within the neighborhood.
+In the following example, the result would be:
+<br>
+(7*4 + 6 + 5 + 4*3)/9 = 5.66
+<br>
+The result is rounded to the nearest integer (in this case 6).
+<dt><b>median</b>
+<dd>The value found half-way through a list of the
+neighborhood's values,
+when these are ranged in numerical order.
+<dt><b>mode</b>
+<dd>The most frequently occurring value in the neighborhood.
+<dt><b>minimum</b>
+<dd>The minimum value within the neighborhood.
+<dt><b>maximum</b>
+<dd>The maximum value within the neighborhood.
+<pre>
+ Raw Data Operation New Data
+ | 7 | 7 | 5 | | | | |
+ |----|----|----| average |----|----|----|
+ | 4 | 7 | 4 |--------->| | 6 | |
+ | 7 | 6 | 4 | | | | |
+</pre>
+<dt><b>stddev</b>
+<dd>The statistical standard deviation of values
+within the neighborhood (rounded to the nearest integer).
+<dt><b>sum</b>
+<dd>The sum of values within the neighborhood.
+<dt><b>variance</b>
+<dd>The statistical variance of values
+<dt><b>diversity</b>
+<dd>The number of different values within the neighborhood.
+In the above example, the diversity is 4.
+<dt><b>interspersion</b>
+<dd>The percentage of cells containing values which differ from the values
+assigned to the center cell in the neighborhood, plus 1.
+In the above example, the interspersion is:
+<br>
+5/8 * 100 + 1 = 63.5
+<br>
+The result is rounded to the nearest integer (in this case 64).
+</dl>
+<p>
+<br>
+<em>Neighborhood Size:</em>
+<dd>The neighborhood <b>size</b> specifies which cells surrounding any given
+cell fall into the neighborhood for that cell.
+The <b>size</b> must be an odd integer.
+For example,
+<pre>
+ _ _ _
+ |_|_|_|
+ 3 x 3 neighborhood ---> |_|_|_|
+ |_|_|_|
+</pre>
+</dd>
+<p>
+<em>Matrix weights:</em>
+<dd>A custom matrix can be used if none of the neighborhood operation
+methods are desirable by using the <b>weight</b>. This option must
+be used in conjunction with the <b>size</b> option to specify the
+matrix size. The weights desired are to be entered into a text file.
+For example, to calculate the focal mean with a matrix <b>size</b> of
+3,
+<pre>
+r.neigbors in=input.map out=output.map size=3 weight=weights.txt
+</pre>
+The contents of the weight.txt file:
+<pre>
+3 3 3
+1 4 8
+9 5 3
+</pre>
+This corresponds to the following 3x3 matrix:
+<pre>
+ |3|3|3|
+ |1|4|8|
+ |9|5|3|
+</pre>
+<p>
+<h3>FLAGS</h3>
+<dt><b>-a</b>
+<dd>If specified, <em><b>r.neighbors</b></em> will not align the output
+raster map layer with that of the input raster map layer.
+The <em><b>r.neighbors</b></em> program works in the current geographic region.
+It is recommended, but not required, that the resolution
+of the geographic region be the same as that of the raster map layer.
+By default, if unspecified,
+<em><b>r.neighbors</b></em> will align these geographic region settings.
+<p>
+<dt><b>-c</b>
+<dd>
+This flag will use a circular neighborhood for the moving analysis window,
+centered on the current cell.
+<p>
+The exact masks for the first few neighborhood sizes are as follows:
+3x3 . X . 5x5 . . X . . 7x7 . . . X . . .
+ X O X . X X X . . X X X X X .
+ . X . X X O X X . X X X X X .
+ . X X X . X X X O X X X
+ . . X . . . X X X X X .
+ . X X X X X .
+ . . . X . . .
+9x9 . . . . X . . . . 11x11 . . . . . X . . . . .
+ . . X X X X X . . . . X X X X X X X . .
+ . X X X X X X X . . X X X X X X X X X .
+ X X X X O X X X X . X X X X X X X X X .
+ . X X X X X X X . X X X X X O X X X X X
+ . . X X X X X . . . X X X X X X X X X .
+ . . . . X . . . . . X X X X X X X X X .
+ . . X X X X X X X . .
+ . . . . . X . . . . .
+</pre></div>
+<p>
+<dt><b>-q</b>
+<dd>If specified, <em><b>r.neighbors</b></em> will run relatively quietly
+(i.e., without printing to standard output notes on the program's progress).
+If unspecified, the program will print messages to standard output by default.
+</dd>
+<h2>NOTES</h2>
+with the current mask, if any. It is recommended, but not required,
+that the resolution of the geographic region be the same as that
+of the raster map layer. By default, <em><b>r.neighbors</b></em> will align
+these geographic region settings. However, the user can elect to keep
+original input and output resolutions which are not aligned by specifying
+this (e.g., using the <b>-a</b> option).
+<p>
+The <b>-c</b> flag and the <b>weights</b> parameter are mutually exclusive.
+Any use of the two together will produce an error. Differently-shaped neighborhood
+analysis windows may be achieved by using the <b>weight=</b> parameter to specify
+a weights file where all values are equal (for <b>method</b>=sum, the sum of the
+weights should be 1). The user can also vary the weights at the edge of the
+neighborhood according to the proportion of the cell that lies inside the neighborhood circle,
+effectively anti-aliasing the analysis mask.
+<p>
+For aggregates where a weighted calculation isn't meaningful
+(specifically: minimum, maximum, diversity and interspersion), the
+weights are used to create a binary mask, where zero causes the cell
+to be ignored and any non-zero value causes the cell to be used.
+<p>
+<em><b>r.neighbors</b></em> copies the GRASS <em>color</em> files associated with
+the input raster map layer for those output map layers that are based
+on the neighborhood average, median, mode, minimum, and maximum.
+Because standard deviation, variance, diversity, and interspersion are indices,
+rather than direct correspondents to input values,
+no <em>color</em> files are copied for these map layers.
+(The user should note that although the <em>color</em> file is copied
+for <em>average</em> neighborhood function output,
+whether or not the color file makes sense for the output
+will be dependent on the input data values.)
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em><br>
+<em><a href="r.clump.html">r.clump</a></em><br>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em><br>
+<em><a href="r.mfilter.html">r.mfilter</a></em><br>
+<em><a href="r.statistics.html">r.statistics</a></em><br>
+<em><a href="r.support.html">r.support</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
Deleted: grass/trunk/raster/r.null/description.html
--- grass/trunk/raster/r.null/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.null/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,63 +0,0 @@
-The function of <em>r.null</em> is to explicitly create the NULL-value
-bitmap file. The intended usage is to fix "old" maps that don't have a
-NULL-value bitmap file (i.e. to indicate if zero is valid value or is to be
-converted to NULL). The module does not work with reclassified maps.
-<p>
-The design is flexible. Ranges of values can be set to NULL and/or the NULL
-value can be eliminated and replace with a specified value.
-<p>
-The <b>setnull</b> parameter is used to specify values in the ranges to
-be set to NULL. A range is either a single value (e.g., 5.3), or a pair of
-values (e.g., 4.76-34.56). Existing NULL-values are left NULL, unless the
-null argument is requested.
-<p>
-The <b>null</b> parameter eliminates the NULL value and replaces it with
-value. This argument is applied only to existing NULL values, and not to the
-NULLs created by the setnull argument.
-<h2>EXAMPLES</h2>
-Set specific values of a classified map to NULL:<br>
-r.null map=landcover.30m setnull=21,22
-</pre></div>
-Set NULL-values of a map to a specific value:<br>
-r.null map=fields null=99
-</pre></div>
-<h2>NOTES</h2>
-Note that value is restricted to integer if the map is an integer map.
-<p>
-<em>r.null</em> and reclassified maps:<br>
-The problem is, if r.null was run on the reclass raster it would alter the
-original and any other reclass rasters of the original. Therefore r.null
-doesn't allow to recode reclassified maps (products of r.reclass).
-<br>
-So, the way to recode such a map is: The user makes a raster out of the
-reclass that isn't a reclass by copying it:<br>
-r.mapcalc newmap = reclass
-</pre></div>
-<h2>SEE ALSO</h2>
-and
-<em><a href="r.quant.html">r.quant</a></em>
-<h2>AUTHOR</h2>
Copied: grass/trunk/raster/r.null/r.null.html (from rev 32770, grass/trunk/raster/r.null/description.html)
--- grass/trunk/raster/r.null/r.null.html (rev 0)
+++ grass/trunk/raster/r.null/r.null.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,63 @@
+The function of <em>r.null</em> is to explicitly create the NULL-value
+bitmap file. The intended usage is to fix "old" maps that don't have a
+NULL-value bitmap file (i.e. to indicate if zero is valid value or is to be
+converted to NULL). The module does not work with reclassified maps.
+<p>
+The design is flexible. Ranges of values can be set to NULL and/or the NULL
+value can be eliminated and replace with a specified value.
+<p>
+The <b>setnull</b> parameter is used to specify values in the ranges to
+be set to NULL. A range is either a single value (e.g., 5.3), or a pair of
+values (e.g., 4.76-34.56). Existing NULL-values are left NULL, unless the
+null argument is requested.
+<p>
+The <b>null</b> parameter eliminates the NULL value and replaces it with
+value. This argument is applied only to existing NULL values, and not to the
+NULLs created by the setnull argument.
+<h2>EXAMPLES</h2>
+Set specific values of a classified map to NULL:<br>
+r.null map=landcover.30m setnull=21,22
+</pre></div>
+Set NULL-values of a map to a specific value:<br>
+r.null map=fields null=99
+</pre></div>
+<h2>NOTES</h2>
+Note that value is restricted to integer if the map is an integer map.
+<p>
+<em>r.null</em> and reclassified maps:<br>
+The problem is, if r.null was run on the reclass raster it would alter the
+original and any other reclass rasters of the original. Therefore r.null
+doesn't allow to recode reclassified maps (products of r.reclass).
+<br>
+So, the way to recode such a map is: The user makes a raster out of the
+reclass that isn't a reclass by copying it:<br>
+r.mapcalc newmap = reclass
+</pre></div>
+<h2>SEE ALSO</h2>
+and
+<em><a href="r.quant.html">r.quant</a></em>
+<h2>AUTHOR</h2>
Deleted: grass/trunk/raster/r.out.arc/description.html
--- grass/trunk/raster/r.out.arc/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.arc/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,59 +0,0 @@
-<em>r.out.arc</em> converts a user-specified raster map layer
-(<b>input=</b><em>name</em>) into an ESRI ARC-GRID ascii file
-(<b>output=</b><em>name</em>) suitable for export to other computer systems.
-The dp=<em>value</em> option (where <em>value</em> is a number of the user's
-choice) can be used to request that numbers after decimal points are
-limited. However, to use this, the user should know the maximum number of
-digits that will occur in the output file. The user can find the maximum
-number of digits occurring in the output file by running <em>r.out.arc</em>
-without the <b>dp=</b><em>value</em> option.
-<p>
-The GRASS program <em><a href="r.in.arc.html">r.in.arc</a></em> can be used
-to perform the reverse function, converting an ESRI ARC-GRID ascii file in
-suitable format to GRASS raster map format. The order of cell values in
-file is from lower left to upper right (reverse to GRASS).
-<h2>NOTES</h2>
-The output from <em>r.out.arc</em> may also be placed into a file
-by using the UNIX redirection mechanism; e.g.:
-r.out.arc input=soils output=- > out.grd
-</pre></div>
-The output file <em>out.grd</em> can then be copied
-onto a CDROM or floppy disk for export purposes.
-<p><br>
-An Arc ASCII grid can be loaded into ArcGIS 8.3 though ArcToolbox.<br>
-Use the "Import to Raster" -> "ASCII to Grid" tool to create a binary grid
-which can be selected using ArcCatalog. The spatial analyst extension may
-need to be installed and activated within Arc.
-<p>
-In ArcGIS 9.0 the import tool can be found at:<br>
-ArcMap -> Toolbox -> Conversion Tools -> To Raster -> ASCII to Raster
-<p>
-A GeoTIFF created with <em><a href="r.out.gdal.html">r.out.gdal</a></em> is
-sometimes a better solution for transferring raster maps to other GIS software.
-<p>
-<h2>SEE ALSO</h2>
-<em><a href="r.in.arc.html">r.in.arc</a></em><br>
-<em><a href="r.out.gdal.html">r.out.gdal</a></em><br>
-<h2>AUTHOR</h2>
-Markus Neteler, University of Hannover, Germany, <br>
-based on r.out.ascii written by <br>
-Michael Shapiro,
Copied: grass/trunk/raster/r.out.arc/r.out.arc.html (from rev 32770, grass/trunk/raster/r.out.arc/description.html)
--- grass/trunk/raster/r.out.arc/r.out.arc.html (rev 0)
+++ grass/trunk/raster/r.out.arc/r.out.arc.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,59 @@
+<em>r.out.arc</em> converts a user-specified raster map layer
+(<b>input=</b><em>name</em>) into an ESRI ARC-GRID ascii file
+(<b>output=</b><em>name</em>) suitable for export to other computer systems.
+The dp=<em>value</em> option (where <em>value</em> is a number of the user's
+choice) can be used to request that numbers after decimal points are
+limited. However, to use this, the user should know the maximum number of
+digits that will occur in the output file. The user can find the maximum
+number of digits occurring in the output file by running <em>r.out.arc</em>
+without the <b>dp=</b><em>value</em> option.
+<p>
+The GRASS program <em><a href="r.in.arc.html">r.in.arc</a></em> can be used
+to perform the reverse function, converting an ESRI ARC-GRID ascii file in
+suitable format to GRASS raster map format. The order of cell values in
+file is from lower left to upper right (reverse to GRASS).
+<h2>NOTES</h2>
+The output from <em>r.out.arc</em> may also be placed into a file
+by using the UNIX redirection mechanism; e.g.:
+r.out.arc input=soils output=- > out.grd
+</pre></div>
+The output file <em>out.grd</em> can then be copied
+onto a CDROM or floppy disk for export purposes.
+<p><br>
+An Arc ASCII grid can be loaded into ArcGIS 8.3 though ArcToolbox.<br>
+Use the "Import to Raster" -> "ASCII to Grid" tool to create a binary grid
+which can be selected using ArcCatalog. The spatial analyst extension may
+need to be installed and activated within Arc.
+<p>
+In ArcGIS 9.0 the import tool can be found at:<br>
+ArcMap -> Toolbox -> Conversion Tools -> To Raster -> ASCII to Raster
+<p>
+A GeoTIFF created with <em><a href="r.out.gdal.html">r.out.gdal</a></em> is
+sometimes a better solution for transferring raster maps to other GIS software.
+<p>
+<h2>SEE ALSO</h2>
+<em><a href="r.in.arc.html">r.in.arc</a></em><br>
+<em><a href="r.out.gdal.html">r.out.gdal</a></em><br>
+<h2>AUTHOR</h2>
+Markus Neteler, University of Hannover, Germany, <br>
+based on r.out.ascii written by <br>
+Michael Shapiro,
Deleted: grass/trunk/raster/r.out.ascii/description.html
--- grass/trunk/raster/r.out.ascii/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.ascii/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,63 +0,0 @@
-<em>r.out.ascii</em> converts a user-specified raster map layer
-(<b>input=</b><em>name</em>) into an ASCII grid in a text file
-other computer systems.
-<p>
-The GRASS program <em><a href="r.in.ascii.html">r.in.ascii</a></em> can be
-used to perform the reverse function, converting an ASCII file in suitable
-format to GRASS raster map format.
-<p>
-<!--With <b>-s</b> flag SURFER .grd ASCII GRID instead of GRASS ASCII GRID is
-written (with reverted row order, different header).
-<p>
-With <b>-m</b> flag MODFLOW (USGS) free-format array instead of GRASS ASCII
-GRID is written.-->
-<p>
-To write a SURFER .grd ASCII GRID file (with reverted row order and different
-header) use the <em>-s</em> flag:
-r.out.ascii -s input=inname output=outname.grd [dp=value]
-</pre></div>
-NULL data are coded to "1.70141e+038" for SURFER ASCII GRID files (ignoring
-the <em>null=</em> parameter).
-<h2>NOTES</h2>
-The output from <em>r.out.ascii</em> may be placed into a file by using the
-UNIX redirection mechanism; e.g.:
-r.out.ascii input=soils output=- > out.file
-</pre></div>
-The output file out.file can then be printed or copied onto a CDROM
-or floppy disk for export purposes.
-<p>
-To export the raster values as x,y,z values of cell centers (one per line)
-use the <em><a href="r.out.xyz.html">r.out.xyz</a></em> module.
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.in.ascii.html">r.in.ascii</a>,
-<a href="r.in.arc.html">r.in.arc</a>,
-<a href="r.out.bin.html">r.out.bin</a>,
-<a href="r.out.gdal.html">r.out.gdal</a>,
-<a href="r.out.xyz.html">r.out.xyz</a>
-</em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory
-<p>
-Surfer support by Markus Neteler
-<p>
Copied: grass/trunk/raster/r.out.ascii/r.out.ascii.html (from rev 32770, grass/trunk/raster/r.out.ascii/description.html)
--- grass/trunk/raster/r.out.ascii/r.out.ascii.html (rev 0)
+++ grass/trunk/raster/r.out.ascii/r.out.ascii.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,63 @@
+<em>r.out.ascii</em> converts a user-specified raster map layer
+(<b>input=</b><em>name</em>) into an ASCII grid in a text file
+other computer systems.
+<p>
+The GRASS program <em><a href="r.in.ascii.html">r.in.ascii</a></em> can be
+used to perform the reverse function, converting an ASCII file in suitable
+format to GRASS raster map format.
+<p>
+<!--With <b>-s</b> flag SURFER .grd ASCII GRID instead of GRASS ASCII GRID is
+written (with reverted row order, different header).
+<p>
+With <b>-m</b> flag MODFLOW (USGS) free-format array instead of GRASS ASCII
+GRID is written.-->
+<p>
+To write a SURFER .grd ASCII GRID file (with reverted row order and different
+header) use the <em>-s</em> flag:
+r.out.ascii -s input=inname output=outname.grd [dp=value]
+</pre></div>
+NULL data are coded to "1.70141e+038" for SURFER ASCII GRID files (ignoring
+the <em>null=</em> parameter).
+<h2>NOTES</h2>
+The output from <em>r.out.ascii</em> may be placed into a file by using the
+UNIX redirection mechanism; e.g.:
+r.out.ascii input=soils output=- > out.file
+</pre></div>
+The output file out.file can then be printed or copied onto a CDROM
+or floppy disk for export purposes.
+<p>
+To export the raster values as x,y,z values of cell centers (one per line)
+use the <em><a href="r.out.xyz.html">r.out.xyz</a></em> module.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.in.ascii.html">r.in.ascii</a>,
+<a href="r.in.arc.html">r.in.arc</a>,
+<a href="r.out.bin.html">r.out.bin</a>,
+<a href="r.out.gdal.html">r.out.gdal</a>,
+<a href="r.out.xyz.html">r.out.xyz</a>
+</em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S. Army Construction Engineering Research Laboratory
+<p>
+Surfer support by Markus Neteler
+<p>
Deleted: grass/trunk/raster/r.out.bin/description.html
--- grass/trunk/raster/r.out.bin/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.bin/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,43 +0,0 @@
-<h2>DESCRIPTION</h2>
-The <em>r.out.bin</em> program exports a GRASS raster map to a binary array
-file. Optionally, output can be sent to standard output (stdout) for direct
-input (pipe) into other applications. Data is exported according to the
-original GRASS raster type (e.g. float). If the "-i" flag is specified, an
-integer array is output. The region parameters are printed to stderr.
-<h2>NOTES</h2>
-With the -h flag, data can be directly used by
-<a href=http://gmt.soest.hawaii.edu/>GMT</a> as Grid Format 1 (float) or
-2 (short). For example:
-<div class="code"><pre>
-r.out.bin -h input=grass.raster output=new.grd
-grdinfo new.grd=1 (if float)
-</pre></div>
-<p>
-Exported data can be piped directly into the GMT program xyz2grd.
-r.out.bin input=grass.raster output=- | xyz2grd -R.... -ZTLf -
-</pre></div>
-The example uses the GMT program xyz2grd with the -ZTLf flag indicating that
-a float array was output.
-<h2>SEE ALSO</h2>
-<em><a href="r.in.bin.html">r.in.bin</a>,
-<a href="r.out.ascii.html">r.out.ascii</a>
-<a href="r.out.arc.html">r.out.arc</a></em>
-<h2>AUTHOR</h2>
-This program is derived from <em><a href="r.out.ascii.html">r.out.ascii</a></em>
-with a few modifications. <br>
-Author: <a href=mailto:bcovill at tekmap.ns.ca>Bob Covill</a>
Copied: grass/trunk/raster/r.out.bin/r.out.bin.html (from rev 32770, grass/trunk/raster/r.out.bin/description.html)
--- grass/trunk/raster/r.out.bin/r.out.bin.html (rev 0)
+++ grass/trunk/raster/r.out.bin/r.out.bin.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,43 @@
+The <em>r.out.bin</em> program exports a GRASS raster map to a binary array
+file. Optionally, output can be sent to standard output (stdout) for direct
+input (pipe) into other applications. Data is exported according to the
+original GRASS raster type (e.g. float). If the "-i" flag is specified, an
+integer array is output. The region parameters are printed to stderr.
+<h2>NOTES</h2>
+With the -h flag, data can be directly used by
+<a href=http://gmt.soest.hawaii.edu/>GMT</a> as Grid Format 1 (float) or
+2 (short). For example:
+r.out.bin -h input=grass.raster output=new.grd
+grdinfo new.grd=1 (if float)
+</pre></div>
+<p>
+Exported data can be piped directly into the GMT program xyz2grd.
+r.out.bin input=grass.raster output=- | xyz2grd -R.... -ZTLf -
+</pre></div>
+The example uses the GMT program xyz2grd with the -ZTLf flag indicating that
+a float array was output.
+<h2>SEE ALSO</h2>
+<em><a href="r.in.bin.html">r.in.bin</a>,
+<a href="r.out.ascii.html">r.out.ascii</a>
+<a href="r.out.arc.html">r.out.arc</a></em>
+<h2>AUTHOR</h2>
+This program is derived from <em><a href="r.out.ascii.html">r.out.ascii</a></em>
+with a few modifications. <br>
+Author: <a href=mailto:bcovill at tekmap.ns.ca>Bob Covill</a>
Deleted: grass/trunk/raster/r.out.gdal/description.html
--- grass/trunk/raster/r.out.gdal/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.gdal/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,140 +0,0 @@
-<em>r.out.gdal</em> allows a user to export a GRASS raster map layer
-into any GDAL supported raster map format.
-For possible <em>metaopt</em> parameters see the 'supported formats' pages
-of GDAL.
-The <em>createopt</em> may be used to create TFW or World files ("TFW=YES",
-"WORLDFILE=ON").
-<p>
-<em>r.out.gdal</em> also supports the export of multiband rasters through
-a group (created e.g. with <em>i.group</em>), when the group's name is entered
-as input.
-<h2>SUPPORTED RASTER FORMATS</h2>
-The set of <a href="http://www.gdal.org/formats_list.html">supported
-raster formats</a> written by <em>r.out.gdal</em> depends on the
-local GDAL installation. Available may be (incomplete list):<p>
-<pre>
- AAIGrid: Arc/Info ASCII Grid
- BMP: MS Windows Device Independent Bitmap
- BSB: Maptech BSB Nautical Charts
- DTED: DTED Elevation Raster
- ELAS: ELAS
- ENVI: ENVI .hdr Labelled
- FIT: FIT Image
- GIF: Graphics Interchange Format (.gif)
- GTiff: GeoTIFF
- HDF4Image: HDF4 Dataset
- HFA: Erdas Imagine Images (.img)
- JPEG2000: JPEG-2000 part 1 (ISO/IEC 15444-1)
- JPEG: JPEG JFIF
- MEM: In Memory Raster
- MFF2: Atlantis MFF2 (HKV) Raster
- MFF: Atlantis MFF Raster
- NITF: National Imagery Transmission Format
- PAux: PCI .aux Labelled
- PCIDSK: PCIDSK Database File
- PNG: Portable Network Graphics
- PNM: Portable Pixmap Format (netpbm)
- VRT: Virtual Raster
- XPM: X11 PixMap Format
-</pre>
-<h2>NOTES</h2>
-When writing out GeoTIFF format for users of ESRI software or ImageMagick,
-the band interleaving should be switched to pixel interleaving using
-<em>createopt="INTERLEAVE=PIXEL"</em>.
-<p>
-To specify multiple options use a comma separated list
-(<em>createopt="TFW=YES,COMPRESS=DEFLATE"</em>).
-<p>
-Out of the GDAL data types, the closest match for GRASS CELL, FCELL and DCELL
-rasters are respectively Int32, Float32 and Float64. These are not exact
-equivalents, but they will preserve the max possible data range and number of
-decimal places for each respective GRASS raster data type. Please keep in mind, that
-not all CELL rasters will require Int32 - e.g., 0-255 CELL raster are covered
-by the Byte <em>type</em> as well. Moreover, some GDAL-supported formats do not
-support all the data types possible in GDAL and GRASS. Use
-<em><a href="r.info">r.info</a></em> to check the data type and range for your
-GRASS raster, refer to specific format documentation
-(<a href="http://www.gdal.org/">GDAL website</a>, format vendor's docs) and
-e.g. the Wikipedia article
-<em><a href="http://en.wikipedia.org/wiki/C_syntax#Typical_boundaries_of_primitive_integral_types">Typical boundaries of primitive integral types</a></em>
-for details.
-<h2>EXAMPLES</h2>
-<h4>Export the integer raster roads map to GeoTIFF format:</h4>
-r.out.gdal input=roads output=roads.tif type=UInt16
-</pre></div>
-<p>
-<h4>Export a DCELL raster map in GeoTIFF format suitable for ESRI software:</h4>
-r.out.gdal in=elevation.10m out=ned_elev10m.tif type=Float64 createopt="INTERLEAVE=PIXEL,TFW=YES"
-</pre></div>
-<p>
-<h4>Export the floating point raster elevation map to ERDAS/IMG format:</h4>
-r.out.gdal input=elevation.10m output=elev_dem10.img format=HFA type=Float32
-</pre></div>
-<h4>Export group of image maps as multi-band file</h4>
-g.list group
-i.group group=tm7 subgroup=tm7 input=tm7_10,tm7_20,tm7_30,tm7_40,tm7_50,tm7_60,tm7_70
-i.group -l tm7
-r.out.gdal tm7 type=UInt16 out=lsat_multiband.tif
-gdalinfo lsat_multiband.tif
-</pre></div>
-<h2>GDAL RELATED ERROR MESSAGES</h2>
-<ul>
-<li> "ERROR 6: SetColorInterpretation() not supported for this dataset.": This <i>may</i>
- indicate that the color table was not written properly. But usually it will be
- correct and the message can be ignored.</li>
-<li> "ERROR 6: SetNoDataValue() not supported for this dataset.": The selected output format
- does not support "no data". It is recommended to use a different output format.</li>
-<li> "Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.": The color table metadata
- are too large. It is recommended to use a different output format.</li>
-</ul>
-<h2>SEE ALSO</h2>
-The <a href="http://www.gdal.org/formats_list.html">GDAL supported formats</a>
-page.
-<br>
-<em>
-<a href="r.out.ascii.html">r.out.ascii</a>,
-<a href="r.out.arc.html">r.out.arc</a>,
-<a href="r.out.mat.html">r.out.mat</a>,
-<a href="r.out.png.html">r.out.png</a>,
-<a href="r.out.ppm.html">r.out.ppm</a>,
-<a href="r.out.tiff.html">r.out.tiff</a>
-<br>
-<a href="r.out.gdal.sh.html">r.out.gdal.sh</a></em>
- (old shell script version using <tt>gdal_translate</tt>)
-<h2>REFERENCES</h2>
-GDAL Pages: <a href="http://www.gdal.org">http://www.gdal.org</a>
-<h2>AUTHOR</h2>
-Vytautas Vebra (oliver4grass at gmail.com)
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.out.gdal/r.out.gdal.html (from rev 32770, grass/trunk/raster/r.out.gdal/description.html)
--- grass/trunk/raster/r.out.gdal/r.out.gdal.html (rev 0)
+++ grass/trunk/raster/r.out.gdal/r.out.gdal.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,140 @@
+<em>r.out.gdal</em> allows a user to export a GRASS raster map layer
+into any GDAL supported raster map format.
+For possible <em>metaopt</em> parameters see the 'supported formats' pages
+of GDAL.
+The <em>createopt</em> may be used to create TFW or World files ("TFW=YES",
+"WORLDFILE=ON").
+<p>
+<em>r.out.gdal</em> also supports the export of multiband rasters through
+a group (created e.g. with <em>i.group</em>), when the group's name is entered
+as input.
+<h2>SUPPORTED RASTER FORMATS</h2>
+The set of <a href="http://www.gdal.org/formats_list.html">supported
+raster formats</a> written by <em>r.out.gdal</em> depends on the
+local GDAL installation. Available may be (incomplete list):<p>
+<pre>
+ AAIGrid: Arc/Info ASCII Grid
+ BMP: MS Windows Device Independent Bitmap
+ BSB: Maptech BSB Nautical Charts
+ DTED: DTED Elevation Raster
+ ELAS: ELAS
+ ENVI: ENVI .hdr Labelled
+ FIT: FIT Image
+ GIF: Graphics Interchange Format (.gif)
+ GTiff: GeoTIFF
+ HDF4Image: HDF4 Dataset
+ HFA: Erdas Imagine Images (.img)
+ JPEG2000: JPEG-2000 part 1 (ISO/IEC 15444-1)
+ JPEG: JPEG JFIF
+ MEM: In Memory Raster
+ MFF2: Atlantis MFF2 (HKV) Raster
+ MFF: Atlantis MFF Raster
+ NITF: National Imagery Transmission Format
+ PAux: PCI .aux Labelled
+ PCIDSK: PCIDSK Database File
+ PNG: Portable Network Graphics
+ PNM: Portable Pixmap Format (netpbm)
+ VRT: Virtual Raster
+ XPM: X11 PixMap Format
+</pre>
+<h2>NOTES</h2>
+When writing out GeoTIFF format for users of ESRI software or ImageMagick,
+the band interleaving should be switched to pixel interleaving using
+<em>createopt="INTERLEAVE=PIXEL"</em>.
+<p>
+To specify multiple options use a comma separated list
+(<em>createopt="TFW=YES,COMPRESS=DEFLATE"</em>).
+<p>
+Out of the GDAL data types, the closest match for GRASS CELL, FCELL and DCELL
+rasters are respectively Int32, Float32 and Float64. These are not exact
+equivalents, but they will preserve the max possible data range and number of
+decimal places for each respective GRASS raster data type. Please keep in mind, that
+not all CELL rasters will require Int32 - e.g., 0-255 CELL raster are covered
+by the Byte <em>type</em> as well. Moreover, some GDAL-supported formats do not
+support all the data types possible in GDAL and GRASS. Use
+<em><a href="r.info">r.info</a></em> to check the data type and range for your
+GRASS raster, refer to specific format documentation
+(<a href="http://www.gdal.org/">GDAL website</a>, format vendor's docs) and
+e.g. the Wikipedia article
+<em><a href="http://en.wikipedia.org/wiki/C_syntax#Typical_boundaries_of_primitive_integral_types">Typical boundaries of primitive integral types</a></em>
+for details.
+<h2>EXAMPLES</h2>
+<h4>Export the integer raster roads map to GeoTIFF format:</h4>
+<div class="code"><pre>
+r.out.gdal input=roads output=roads.tif type=UInt16
+</pre></div>
+<p>
+<h4>Export a DCELL raster map in GeoTIFF format suitable for ESRI software:</h4>
+r.out.gdal in=elevation.10m out=ned_elev10m.tif type=Float64 createopt="INTERLEAVE=PIXEL,TFW=YES"
+</pre></div>
+<p>
+<h4>Export the floating point raster elevation map to ERDAS/IMG format:</h4>
+r.out.gdal input=elevation.10m output=elev_dem10.img format=HFA type=Float32
+</pre></div>
+<h4>Export group of image maps as multi-band file</h4>
+g.list group
+i.group group=tm7 subgroup=tm7 input=tm7_10,tm7_20,tm7_30,tm7_40,tm7_50,tm7_60,tm7_70
+i.group -l tm7
+r.out.gdal tm7 type=UInt16 out=lsat_multiband.tif
+gdalinfo lsat_multiband.tif
+</pre></div>
+<h2>GDAL RELATED ERROR MESSAGES</h2>
+<ul>
+<li> "ERROR 6: SetColorInterpretation() not supported for this dataset.": This <i>may</i>
+ indicate that the color table was not written properly. But usually it will be
+ correct and the message can be ignored.</li>
+<li> "ERROR 6: SetNoDataValue() not supported for this dataset.": The selected output format
+ does not support "no data". It is recommended to use a different output format.</li>
+<li> "Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.": The color table metadata
+ are too large. It is recommended to use a different output format.</li>
+</ul>
+<h2>SEE ALSO</h2>
+The <a href="http://www.gdal.org/formats_list.html">GDAL supported formats</a>
+page.
+<br>
+<em>
+<a href="r.out.ascii.html">r.out.ascii</a>,
+<a href="r.out.arc.html">r.out.arc</a>,
+<a href="r.out.mat.html">r.out.mat</a>,
+<a href="r.out.png.html">r.out.png</a>,
+<a href="r.out.ppm.html">r.out.ppm</a>,
+<a href="r.out.tiff.html">r.out.tiff</a>
+<br>
+<a href="r.out.gdal.sh.html">r.out.gdal.sh</a></em>
+ (old shell script version using <tt>gdal_translate</tt>)
+<h2>REFERENCES</h2>
+GDAL Pages: <a href="http://www.gdal.org">http://www.gdal.org</a>
+<h2>AUTHOR</h2>
+Vytautas Vebra (oliver4grass at gmail.com)
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.out.gridatb/description.html
--- grass/trunk/raster/r.out.gridatb/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.gridatb/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,16 +0,0 @@
-<em>r.out.gridatb</em> exports a GRASS raster map to GRIDATB.FOR map file
-(TOPMODEL)
-<h2>SEE ALSO</h2>
-<em><a href="r.topmodel.html">r.topmodel</a>,</em>
-<em><a href="r.in.gridatb.html">r.in.gridatb</a></em>
-<h2>AUTHOR</h2>
-Huidae Cho based on code from Keith Beven
Copied: grass/trunk/raster/r.out.gridatb/r.out.gridatb.html (from rev 32770, grass/trunk/raster/r.out.gridatb/description.html)
--- grass/trunk/raster/r.out.gridatb/r.out.gridatb.html (rev 0)
+++ grass/trunk/raster/r.out.gridatb/r.out.gridatb.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,16 @@
+<em>r.out.gridatb</em> exports a GRASS raster map to GRIDATB.FOR map file
+(TOPMODEL)
+<h2>SEE ALSO</h2>
+<em><a href="r.topmodel.html">r.topmodel</a>,</em>
+<em><a href="r.in.gridatb.html">r.in.gridatb</a></em>
+<h2>AUTHOR</h2>
+Huidae Cho based on code from Keith Beven
Deleted: grass/trunk/raster/r.out.mat/description.html
--- grass/trunk/raster/r.out.mat/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.mat/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,99 +0,0 @@
-<em>r.out.mat</em> will export a GRASS raster map to a MAT-File which can
-be loaded into Matlab or Octave for plotting or further analysis.
-Attributes such as map title and bounds will also be exported into
-additional array variables.<br>
-<br>
-Specifically, the following array variables are created:<br>
-<ul>
- <li><b> map_data</b>
- <li><b> map_name</b>
- <li><b> map_title</b> (if it exists)
- <li><b> map_northern_edge</b>
- <li><b> map_southern_edge</b>
- <li><b> map_eastern_edge</b>
- <li><b> map_western_edge</b>
-</ul>
-<br>
-In addition, <em>r.out.mat</em> makes for a nice binary container format
-for transferring georeferenced maps around, even if you don't use Matlab
-or Octave.
-<h2>NOTES</h2>
-<em>r.out.mat</em> exports a Version 4 MAT-File. These files should
-successfully load into more modern versions of Matlab and Octave
-without any problems.<br><br>
-Everything should be Endian safe, so the resultant file can be simply
-copied between different system architectures without binary translation.
-<br><br>
-As there is no IEEE value for <tt>NaN</tt> for integer maps, GRASS's null
-value is used to represent it within these maps. You'll have to do something
-like this to clean them once the map is loaded into Matlab:
-<pre> map_data(find(map_data < -1e9)) = NaN;</pre>
-Null values in maps containing either floating point or double-precision
-floating point data should translate into <tt>NaN</tt> values as expected.
-<br><br>
-<em>r.out.mat</em> must load the entire map into memory before writing,
-therefore it might have problems with <i>huge</i> maps.
-(a 3000x4000 DCELL map uses about 100mb RAM)<br><br>
-GRASS defines its map bounds at the outer-edge of the bounding cells, not at
-the coordinates of their centroids. Thus, the following Matlab commands may
-be used to determine the map's resolution information:
- [rows cols] = size(map_data)
- x_range = map_eastern_edge - map_western_edge
- y_range = map_northern_edge - map_southern_edge
- ns_res = y_range/rows
- ew_res = x_range/cols
-</pre></div>
-<br>
-<h2>EXAMPLE</h2>
-In Matlab, plot with either:
-imagesc(map_data), axis equal, axis tight, colorbar
-</pre></div>
-or
-contourf(map_data, 24), axis ij, axis equal, axis tight, colorbar
-</pre></div>
-<br>
-<h2>TODO</h2>
-Add support for exporting map history, category information, color map, etc.
-<br>
-Option to export as a version 5 MAT-File, with map and support information
-stored in a single structured array.
-<h2>SEE ALSO</h2>
-<i>
-<a href="r.in.mat.html">r.in.mat</a><br>
-<a href="r.out.ascii.html">r.out.ascii</a>, <a href="r.out.bin.html">r.out.bin</a><br>
-<a href="r.null.html">r.null</a><br>
-The <a href="http://www.octave.org">Octave</a> project
-</i>
-<h2>AUTHOR</h2>
-Hamish Bowman<br> <i>
-Department of Marine Science<br>
-University of Otago<br>
-New Zealand</i><br>
-<br>
Copied: grass/trunk/raster/r.out.mat/r.out.mat.html (from rev 32770, grass/trunk/raster/r.out.mat/description.html)
--- grass/trunk/raster/r.out.mat/r.out.mat.html (rev 0)
+++ grass/trunk/raster/r.out.mat/r.out.mat.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,99 @@
+<em>r.out.mat</em> will export a GRASS raster map to a MAT-File which can
+be loaded into Matlab or Octave for plotting or further analysis.
+Attributes such as map title and bounds will also be exported into
+additional array variables.<br>
+<br>
+Specifically, the following array variables are created:<br>
+<ul>
+ <li><b> map_data</b>
+ <li><b> map_name</b>
+ <li><b> map_title</b> (if it exists)
+ <li><b> map_northern_edge</b>
+ <li><b> map_southern_edge</b>
+ <li><b> map_eastern_edge</b>
+ <li><b> map_western_edge</b>
+</ul>
+<br>
+In addition, <em>r.out.mat</em> makes for a nice binary container format
+for transferring georeferenced maps around, even if you don't use Matlab
+or Octave.
+<h2>NOTES</h2>
+<em>r.out.mat</em> exports a Version 4 MAT-File. These files should
+successfully load into more modern versions of Matlab and Octave
+without any problems.<br><br>
+Everything should be Endian safe, so the resultant file can be simply
+copied between different system architectures without binary translation.
+<br><br>
+As there is no IEEE value for <tt>NaN</tt> for integer maps, GRASS's null
+value is used to represent it within these maps. You'll have to do something
+like this to clean them once the map is loaded into Matlab:
+<pre> map_data(find(map_data < -1e9)) = NaN;</pre>
+Null values in maps containing either floating point or double-precision
+floating point data should translate into <tt>NaN</tt> values as expected.
+<br><br>
+<em>r.out.mat</em> must load the entire map into memory before writing,
+therefore it might have problems with <i>huge</i> maps.
+(a 3000x4000 DCELL map uses about 100mb RAM)<br><br>
+GRASS defines its map bounds at the outer-edge of the bounding cells, not at
+the coordinates of their centroids. Thus, the following Matlab commands may
+be used to determine the map's resolution information:
+ [rows cols] = size(map_data)
+ x_range = map_eastern_edge - map_western_edge
+ y_range = map_northern_edge - map_southern_edge
+ ns_res = y_range/rows
+ ew_res = x_range/cols
+</pre></div>
+<br>
+<h2>EXAMPLE</h2>
+In Matlab, plot with either:
+imagesc(map_data), axis equal, axis tight, colorbar
+</pre></div>
+or
+contourf(map_data, 24), axis ij, axis equal, axis tight, colorbar
+</pre></div>
+<br>
+<h2>TODO</h2>
+Add support for exporting map history, category information, color map, etc.
+<br>
+Option to export as a version 5 MAT-File, with map and support information
+stored in a single structured array.
+<h2>SEE ALSO</h2>
+<i>
+<a href="r.in.mat.html">r.in.mat</a><br>
+<a href="r.out.ascii.html">r.out.ascii</a>, <a href="r.out.bin.html">r.out.bin</a><br>
+<a href="r.null.html">r.null</a><br>
+The <a href="http://www.octave.org">Octave</a> project
+</i>
+<h2>AUTHOR</h2>
+Hamish Bowman<br> <i>
+Department of Marine Science<br>
+University of Otago<br>
+New Zealand</i><br>
+<br>
Deleted: grass/trunk/raster/r.out.mpeg/description.html
--- grass/trunk/raster/r.out.mpeg/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.mpeg/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,104 +0,0 @@
-<em>r.out.mpeg</em> is a tool for combining a series of GRASS raster maps
-into a single MPEG-1 (Motion Pictures Expert Group) format file. MPEG-1 is
-a "lossy" video compression format, so the quality of each resulting frame
-of the animation will be much diminished from the original raster image.
-The resulting output file may then be viewed using your favorite mpeg-format
-viewing program.
-MPEG-2 and MPEG-4 provide much better quality animations.
-<p>
-The user may define up to four "views", or sub-windows, to animate
-simultaneously. e.g., View 1 could be rainfall, View 2 flooded areas, View
-3 damage to bridges or levees, View 4 other economic damage, all animated as
-a time series. A black border 2 pixels wide is drawn around each view. There
-is an arbitrary limit of 400 files per view (400 animation frames).
-Temporary files are created in the conversion process, so lack of adequate
-tmp space could also limit the number of frames you are able to convert.
-<!-- flag to keep these to feed into another more modern encoder? -->
-<p>
-The environment variable GMPEG_SIZE is checked for a value to use as the
-dimension, in pixels, of the longest dimension of the animation image. If
-GMPEG_SIZE is not set, the animation size defaults to the rows & columns
-in the current GRASS region, scaling if necessary to a default minimum size
-of 200 and maximum of 500. These size defaults are overridden when using
-the -c flag (see below). The resolution of the current GRASS region is
-maintained, independent of image size. Playback programs have to decode the
-compressed data "on-the-fly", therefore smaller dimensioned animations will
-provide higher frame rates and smoother animations.
-<p>
-UNIX - style wild cards may be used with the command line version in place
-of a raster map name, but wild cards must be quoted.
-<h2>Example:</h2>
-r.out.mpeg view1="rain[1-9]","rain1[0-2]" view2="temp*"
-</pre></div>
-<p>
-If the number of files differs for each view, the view with the fewest files
-will determine the number of frames in the animation.
-<p>
-With <b>-c</b> flag the module converts "on the fly", uses less disk space
-by using <em>r.out.ppm</em> with stdout option to convert frames as needed
-instead of converting all frames to ppm before encoding. Only use when
-encoding a single view. Use of this option also overrides any size
-defaults, using the <b>CURRENTLY DEFINED GRASS REGION for the output size</b>.
-So be careful to set region to a reasonable size prior to encoding.
-<p>
-A quality value of <em>qual=1</em> will yield higher quality images, but
-with less compression (larger MPEG file size). Compression ratios will vary
-depending on the number of frames in the animation, but an MPEG produced
-using <em>qual=5</em> will usually be about 60% the size of the MPEG
-produced using <em>qual=1</em>.
-<h2>BUGS</h2>
-MPEG images must be 16-pixel aligned for successful compression, so if the
-rows & columns of the calculated image size (scaled, with borders added)
-are not evenly divisible by 16, a few rows/columns will be cut off the
-bottom & right sides of the image. The MPEG format is optimized to
-recognize image MOTION, so abrupt changes from one frame to another will
-cause a "noisy" encoding.
-<h2>NOTES</h2>
-This program requires the program <em>mpeg_encode</em> (aka <em>ppmtompeg</em>):
-<p>
-MPEG-1 Video Software Encoder<br>
-(Version 1.3; March 14, 1994)
-<p>
-Lawrence A. Rowe, Kevin Gong, Ketan Patel, and Dan Wallach Computer Science
-Division-EECS, <dd>Univ. of Calif. at Berkeley</dd>
-<p>
-Available from Berkeley:
-<a href="http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_encode.html">http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_encode.html</a>
-<br>or as part of the netpbm package (<em>ppmtompeg</em>):
-<a href="http://netpbm.sourceforge.net">http://netpbm.sourceforge.net</a>
-<p>
-Playback may be done with many viewers; <em>mpeg_encode</em>'s official companion
-is <em>mpeg_play</em> available from Berkeley at
-<a href="ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/">ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/</a>
-or a precompiled Debian package from
-<a href="http://packages.debian.org/ucbmpeg-play">http://packages.debian.org/ucbmpeg-play</a>
-(includes maintained source code).
-<p>
-Use of the <em>-c</em> flag requires the <em>r.out.ppm</em> GRASS module
-with the <em>stdout</em> option.
-<h2>SEE ALSO</h2>
-<em><a href="r.out.ppm.html">r.out.ppm</a></em>
-<br>
-<h2>AUTHOR</h2>
-Bill Brown,
-U.S. Army Construction Engineering Research Laboratories
Copied: grass/trunk/raster/r.out.mpeg/r.out.mpeg.html (from rev 32770, grass/trunk/raster/r.out.mpeg/description.html)
--- grass/trunk/raster/r.out.mpeg/r.out.mpeg.html (rev 0)
+++ grass/trunk/raster/r.out.mpeg/r.out.mpeg.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,104 @@
+<em>r.out.mpeg</em> is a tool for combining a series of GRASS raster maps
+into a single MPEG-1 (Motion Pictures Expert Group) format file. MPEG-1 is
+a "lossy" video compression format, so the quality of each resulting frame
+of the animation will be much diminished from the original raster image.
+The resulting output file may then be viewed using your favorite mpeg-format
+viewing program.
+MPEG-2 and MPEG-4 provide much better quality animations.
+<p>
+The user may define up to four "views", or sub-windows, to animate
+simultaneously. e.g., View 1 could be rainfall, View 2 flooded areas, View
+3 damage to bridges or levees, View 4 other economic damage, all animated as
+a time series. A black border 2 pixels wide is drawn around each view. There
+is an arbitrary limit of 400 files per view (400 animation frames).
+Temporary files are created in the conversion process, so lack of adequate
+tmp space could also limit the number of frames you are able to convert.
+<!-- flag to keep these to feed into another more modern encoder? -->
+<p>
+The environment variable GMPEG_SIZE is checked for a value to use as the
+dimension, in pixels, of the longest dimension of the animation image. If
+GMPEG_SIZE is not set, the animation size defaults to the rows & columns
+in the current GRASS region, scaling if necessary to a default minimum size
+of 200 and maximum of 500. These size defaults are overridden when using
+the -c flag (see below). The resolution of the current GRASS region is
+maintained, independent of image size. Playback programs have to decode the
+compressed data "on-the-fly", therefore smaller dimensioned animations will
+provide higher frame rates and smoother animations.
+<p>
+UNIX - style wild cards may be used with the command line version in place
+of a raster map name, but wild cards must be quoted.
+<h2>Example:</h2>
+r.out.mpeg view1="rain[1-9]","rain1[0-2]" view2="temp*"
+</pre></div>
+<p>
+If the number of files differs for each view, the view with the fewest files
+will determine the number of frames in the animation.
+<p>
+With <b>-c</b> flag the module converts "on the fly", uses less disk space
+by using <em>r.out.ppm</em> with stdout option to convert frames as needed
+instead of converting all frames to ppm before encoding. Only use when
+encoding a single view. Use of this option also overrides any size
+defaults, using the <b>CURRENTLY DEFINED GRASS REGION for the output size</b>.
+So be careful to set region to a reasonable size prior to encoding.
+<p>
+A quality value of <em>qual=1</em> will yield higher quality images, but
+with less compression (larger MPEG file size). Compression ratios will vary
+depending on the number of frames in the animation, but an MPEG produced
+using <em>qual=5</em> will usually be about 60% the size of the MPEG
+produced using <em>qual=1</em>.
+<h2>BUGS</h2>
+MPEG images must be 16-pixel aligned for successful compression, so if the
+rows & columns of the calculated image size (scaled, with borders added)
+are not evenly divisible by 16, a few rows/columns will be cut off the
+bottom & right sides of the image. The MPEG format is optimized to
+recognize image MOTION, so abrupt changes from one frame to another will
+cause a "noisy" encoding.
+<h2>NOTES</h2>
+This program requires the program <em>mpeg_encode</em> (aka <em>ppmtompeg</em>):
+<p>
+MPEG-1 Video Software Encoder<br>
+(Version 1.3; March 14, 1994)
+<p>
+Lawrence A. Rowe, Kevin Gong, Ketan Patel, and Dan Wallach Computer Science
+Division-EECS, <dd>Univ. of Calif. at Berkeley</dd>
+<p>
+Available from Berkeley:
+<a href="http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_encode.html">http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_encode.html</a>
+<br>or as part of the netpbm package (<em>ppmtompeg</em>):
+<a href="http://netpbm.sourceforge.net">http://netpbm.sourceforge.net</a>
+<p>
+Playback may be done with many viewers; <em>mpeg_encode</em>'s official companion
+is <em>mpeg_play</em> available from Berkeley at
+<a href="ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/">ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/</a>
+or a precompiled Debian package from
+<a href="http://packages.debian.org/ucbmpeg-play">http://packages.debian.org/ucbmpeg-play</a>
+(includes maintained source code).
+<p>
+Use of the <em>-c</em> flag requires the <em>r.out.ppm</em> GRASS module
+with the <em>stdout</em> option.
+<h2>SEE ALSO</h2>
+<em><a href="r.out.ppm.html">r.out.ppm</a></em>
+<br>
+<h2>AUTHOR</h2>
+Bill Brown,
+U.S. Army Construction Engineering Research Laboratories
Deleted: grass/trunk/raster/r.out.png/description.html
--- grass/trunk/raster/r.out.png/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.png/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,16 +0,0 @@
-<em>r.out.png</em> exports a GRASS raster map as non-georeferenced PNG image
-format
-<h2>SEE ALSO</h2>
-<em><a href="r.out.tiff.html">r.out.tiff</a>,</em>
-<em><a href="r.out.ascii.html">r.out.ascii</a></em>
-<h2>AUTHOR</h2>
-Alex Shevlakov
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.out.png/r.out.png.html (from rev 32770, grass/trunk/raster/r.out.png/description.html)
--- grass/trunk/raster/r.out.png/r.out.png.html (rev 0)
+++ grass/trunk/raster/r.out.png/r.out.png.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,16 @@
+<em>r.out.png</em> exports a GRASS raster map as non-georeferenced PNG image
+format
+<h2>SEE ALSO</h2>
+<em><a href="r.out.tiff.html">r.out.tiff</a>,</em>
+<em><a href="r.out.ascii.html">r.out.ascii</a></em>
+<h2>AUTHOR</h2>
+Alex Shevlakov
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.out.pov/description.html
--- grass/trunk/raster/r.out.pov/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.pov/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,64 +0,0 @@
-r.out.pov converts a user-specified raster map layer (map==name) into a
-height-field file for POVray (tga==name). The hftype==value option (where
-value is either 0 or 1) specifies the height-field type. When the user
-enters 0 the output will be actual heights. If entered 1 the cell-values
-will be normalized. If hftype is 0 (actual heights) the bias==value can
-be used to add or substract a value from heights. Use scale==value to scale
-your heights by value. The GRASS program r.out.pov can be used to create
-height- field files for Persistence of Vision (POV) raytracer. POV can
-use a height-field defined in Targa (.TGA) image file format where the
-RGB pixel values are 24 bits (3 bytes). A 16 bit unsigned integer height-field
-value is assigned as follows: RED = high byte, GREEN = low byte, BLUE =
-empty.
-<h2>EXAMPLE</h2>
-An example Povray script file may look like this:
-<p>
-#include "shapes.inc"
-#include "colors.inc"
-#include "textures.inc"
-#declare Scale = 7;
-light_source { <40000, Scale*3000, 5000> color MainLight }
-camera {
- location < 23000, Scale*2000, 0>
- angle 90
- look_at < 23000, Scale*1400, 5000>
-height_field {
- tga "dem.lr.tga"
- smooth
- water_level 0.11 // 726 / 6553.6 = 0.111
- texture {
- pigment {
- image_map { // image is always projected from -z, with front facing +z, top to +Y
- ppm "map.lr.ppm"
- once
- rotate x*90 // align map to height_field
- finish {
- ambient 0.2 // Very dark shadows
- diffuse 0.8 // Whiten the whites
- phong 0.2 // shiny
- phong_size 100.0 // with tight highlights
- specular 0.5
- roughness 0.05
- scale < 14500, Scale*6553.6, 13000 >
- translate <18300, 0, 1100>
-</pre></div>
-<h2>AUTHOR</h2>
-Klaus D. Meyer, GEUM.tec GbR, eMail: <i>GEUM.tec at geum.de</i>
Copied: grass/trunk/raster/r.out.pov/r.out.pov.html (from rev 32770, grass/trunk/raster/r.out.pov/description.html)
--- grass/trunk/raster/r.out.pov/r.out.pov.html (rev 0)
+++ grass/trunk/raster/r.out.pov/r.out.pov.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,64 @@
+r.out.pov converts a user-specified raster map layer (map==name) into a
+height-field file for POVray (tga==name). The hftype==value option (where
+value is either 0 or 1) specifies the height-field type. When the user
+enters 0 the output will be actual heights. If entered 1 the cell-values
+will be normalized. If hftype is 0 (actual heights) the bias==value can
+be used to add or substract a value from heights. Use scale==value to scale
+your heights by value. The GRASS program r.out.pov can be used to create
+height- field files for Persistence of Vision (POV) raytracer. POV can
+use a height-field defined in Targa (.TGA) image file format where the
+RGB pixel values are 24 bits (3 bytes). A 16 bit unsigned integer height-field
+value is assigned as follows: RED = high byte, GREEN = low byte, BLUE =
+empty.
+<h2>EXAMPLE</h2>
+An example Povray script file may look like this:
+<p>
+#include "shapes.inc"
+#include "colors.inc"
+#include "textures.inc"
+#declare Scale = 7;
+light_source { <40000, Scale*3000, 5000> color MainLight }
+camera {
+ location < 23000, Scale*2000, 0>
+ angle 90
+ look_at < 23000, Scale*1400, 5000>
+height_field {
+ tga "dem.lr.tga"
+ smooth
+ water_level 0.11 // 726 / 6553.6 = 0.111
+ texture {
+ pigment {
+ image_map { // image is always projected from -z, with front facing +z, top to +Y
+ ppm "map.lr.ppm"
+ once
+ rotate x*90 // align map to height_field
+ finish {
+ ambient 0.2 // Very dark shadows
+ diffuse 0.8 // Whiten the whites
+ phong 0.2 // shiny
+ phong_size 100.0 // with tight highlights
+ specular 0.5
+ roughness 0.05
+ scale < 14500, Scale*6553.6, 13000 >
+ translate <18300, 0, 1100>
+</pre></div>
+<h2>AUTHOR</h2>
+Klaus D. Meyer, GEUM.tec GbR, eMail: <i>GEUM.tec at geum.de</i>
Deleted: grass/trunk/raster/r.out.ppm/description.html
--- grass/trunk/raster/r.out.ppm/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.ppm/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,61 +0,0 @@
-<em>r.out.ppm</em> converts a GRASS raster map into a PPM image
-at the pixel resolution of the CURRENTLY DEFINED REGION.
-To get the resolution and region settings of the raster map, run:<p>
-g.region -p rast=[mapname]
-</pre></div>
-<p>
-before running <em>r.out.ppm</em>.<p>
-By default the PPM file created is 24-bit color, rawbits storage.
-You can use the <b>-G</b> flag to force <em>r.out.ppm</em> to
-output an 8-bit greyscale instead.
-The greyscale conversion uses the NTSC conversion:<p>
-Y = .30*Red + .59*Green + .11*Blue
-</pre></div>
-<p>
-One pixel is written for each cell value, so if <tt>ew_res</tt> and
-<tt>ns_res</tt> differ, the aspect ratio of the resulting image will be off.
-<h2>NOTES</h2>
-A few ppm file comments are written: the name of the GRASS
-raster map, resolution, etc. Although these are perfectly legal,
-I've found one PD image utility that chokes on them, so if you need
-a commentless PPM file, use '<tt>out=- > outfile.ppm</tt>'. (When sending
-output to stdout, no comments are written.)
-<h2>HINTS</h2>
-You can create a PNG image with NULL values represented by a transparent
-background by using the <a href="pngdriver.html">PNG driver</a> with
-<a href="variables.html">GRASS_TRANSPARENT</a> set to TRUE.
-Alternatively, you can use the <em>pnmtopng</em> program from
-<a href="http://netpbm.sourceforge.net">netpbm</a> to do this:
-r.out.ppm raster
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="d.out.png.html">d.out.png</a></em><br>
-<em><a href="r.out.ascii.html">r.out.ascii</a></em><br>
-<em><a href="r.out.mpeg.html">r.out.mpeg</a></em><br>
-<em><a href="r.out.png.html">r.out.png</a></em><br>
-<em><a href="r.out.ppm3.html">r.out.ppm3</a></em><br>
-<em><a href="r.out.tiff.html">r.out.tiff</a></em>
-<h2>AUTHOR</h2>
-Bill Brown, UIUC
Copied: grass/trunk/raster/r.out.ppm/r.out.ppm.html (from rev 32770, grass/trunk/raster/r.out.ppm/description.html)
--- grass/trunk/raster/r.out.ppm/r.out.ppm.html (rev 0)
+++ grass/trunk/raster/r.out.ppm/r.out.ppm.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,61 @@
+<em>r.out.ppm</em> converts a GRASS raster map into a PPM image
+at the pixel resolution of the CURRENTLY DEFINED REGION.
+To get the resolution and region settings of the raster map, run:<p>
+g.region -p rast=[mapname]
+</pre></div>
+<p>
+before running <em>r.out.ppm</em>.<p>
+By default the PPM file created is 24-bit color, rawbits storage.
+You can use the <b>-G</b> flag to force <em>r.out.ppm</em> to
+output an 8-bit greyscale instead.
+The greyscale conversion uses the NTSC conversion:<p>
+Y = .30*Red + .59*Green + .11*Blue
+</pre></div>
+<p>
+One pixel is written for each cell value, so if <tt>ew_res</tt> and
+<tt>ns_res</tt> differ, the aspect ratio of the resulting image will be off.
+<h2>NOTES</h2>
+A few ppm file comments are written: the name of the GRASS
+raster map, resolution, etc. Although these are perfectly legal,
+I've found one PD image utility that chokes on them, so if you need
+a commentless PPM file, use '<tt>out=- > outfile.ppm</tt>'. (When sending
+output to stdout, no comments are written.)
+<h2>HINTS</h2>
+You can create a PNG image with NULL values represented by a transparent
+background by using the <a href="pngdriver.html">PNG driver</a> with
+<a href="variables.html">GRASS_TRANSPARENT</a> set to TRUE.
+Alternatively, you can use the <em>pnmtopng</em> program from
+<a href="http://netpbm.sourceforge.net">netpbm</a> to do this:
+r.out.ppm raster
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="d.out.png.html">d.out.png</a></em><br>
+<em><a href="r.out.ascii.html">r.out.ascii</a></em><br>
+<em><a href="r.out.mpeg.html">r.out.mpeg</a></em><br>
+<em><a href="r.out.png.html">r.out.png</a></em><br>
+<em><a href="r.out.ppm3.html">r.out.ppm3</a></em><br>
+<em><a href="r.out.tiff.html">r.out.tiff</a></em>
+<h2>AUTHOR</h2>
+Bill Brown, UIUC
Deleted: grass/trunk/raster/r.out.ppm3/description.html
--- grass/trunk/raster/r.out.ppm3/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.ppm3/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,36 +0,0 @@
-<b>r.out.ppm3</b> converts 3 GRASS raster layers (R,G,B) to a PPM
-image file, using the current region.
-<p>
-This program converts a GRASS raster map to a PPM image file
-using the the current region settings.
-<p>
-To get the full area and resolutin of the raster map, run:
-g.region rast=[mapname]
-</pre></div>
-<p>before running <em>r.out.ppm3</em>.</p>
-<h2>NOTES</h2>
-One pixel is written for each cell value, so if ew_res and ns_res
-differ, the aspect ratio of the resulting image will be off.
-<h2>SEE ALSO</h2>
-<em><a href="r.out.ppm.html">r.out.ppm</a>,</em>
-<em><a href="r.in.gdal.html">r.in.gdal</a>,</em>
-<em><a href="d.rgb.html">d.rgb</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements <glynn.clements at virgin.net><br>
-Based upon <em>r.out.ppm</em> and <em>d.rgb</em>.
Copied: grass/trunk/raster/r.out.ppm3/r.out.ppm3.html (from rev 32770, grass/trunk/raster/r.out.ppm3/description.html)
--- grass/trunk/raster/r.out.ppm3/r.out.ppm3.html (rev 0)
+++ grass/trunk/raster/r.out.ppm3/r.out.ppm3.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,36 @@
+<h2>DESCRIPTION</h2>
+<b>r.out.ppm3</b> converts 3 GRASS raster layers (R,G,B) to a PPM
+image file, using the current region.
+<p>
+This program converts a GRASS raster map to a PPM image file
+using the the current region settings.
+<p>
+To get the full area and resolutin of the raster map, run:
+g.region rast=[mapname]
+</pre></div>
+<p>before running <em>r.out.ppm3</em>.</p>
+<h2>NOTES</h2>
+One pixel is written for each cell value, so if ew_res and ns_res
+differ, the aspect ratio of the resulting image will be off.
+<h2>SEE ALSO</h2>
+<em><a href="r.out.ppm.html">r.out.ppm</a>,</em>
+<em><a href="r.in.gdal.html">r.in.gdal</a>,</em>
+<em><a href="d.rgb.html">d.rgb</a></em>
+<h2>AUTHOR</h2>
+Glynn Clements <glynn.clements at virgin.net><br>
+Based upon <em>r.out.ppm</em> and <em>d.rgb</em>.
Deleted: grass/trunk/raster/r.out.tiff/description.html
--- grass/trunk/raster/r.out.tiff/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.tiff/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,45 +0,0 @@
-<p>This program converts a GRASS raster map to a TIFF raster map. Output may
-be 8 or 24 bit (TrueColor). Optionally, a TIFF World file compatible with
-ESRI's and other's products may be output.</p>
-<p>
-The program prompts the user for the name of a GRASS raster map, an output
-TIFF file, whether an 8 or 24 bit format is desired, and whether or not to
-create a TIFF world file. Currently only uncompressed, packpit, or deflate
-TIFF files are written. These output formats are known to be compatible
-with r.in.tiff.</p>
-<p>
-The output filename will always have the suffix <code>.tif</code>, and the Tiff World
-file (if requested) <code>.tfw</code>. Any <code>.tif</code> or
-<code>.tiff</code> suffix (case insensitive) specified in the output filename
-will be discarded.</p>
-<p>
-When writing with "-l" option, tiles are written at 128x128 pixels. For
-programs that can utilize tiles, it can help speed up some drawing
-operations.</p>
-<p>
-The user may adjust region and resolution before export using
-<a href="g.region.html">g.region</a>.</p>
-<p>
-A better choice to export GRASS raster data might be
-<a href="r.out.gdal.html">r.out.gdal</a>.
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a>,</em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-<p>
-GRASS 5.0 team
Copied: grass/trunk/raster/r.out.tiff/r.out.tiff.html (from rev 32770, grass/trunk/raster/r.out.tiff/description.html)
--- grass/trunk/raster/r.out.tiff/r.out.tiff.html (rev 0)
+++ grass/trunk/raster/r.out.tiff/r.out.tiff.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,45 @@
+<p>This program converts a GRASS raster map to a TIFF raster map. Output may
+be 8 or 24 bit (TrueColor). Optionally, a TIFF World file compatible with
+ESRI's and other's products may be output.</p>
+<p>
+The program prompts the user for the name of a GRASS raster map, an output
+TIFF file, whether an 8 or 24 bit format is desired, and whether or not to
+create a TIFF world file. Currently only uncompressed, packpit, or deflate
+TIFF files are written. These output formats are known to be compatible
+with r.in.tiff.</p>
+<p>
+The output filename will always have the suffix <code>.tif</code>, and the Tiff World
+file (if requested) <code>.tfw</code>. Any <code>.tif</code> or
+<code>.tiff</code> suffix (case insensitive) specified in the output filename
+will be discarded.</p>
+<p>
+When writing with "-l" option, tiles are written at 128x128 pixels. For
+programs that can utilize tiles, it can help speed up some drawing
+operations.</p>
+<p>
+The user may adjust region and resolution before export using
+<a href="g.region.html">g.region</a>.</p>
+<p>
+A better choice to export GRASS raster data might be
+<a href="r.out.gdal.html">r.out.gdal</a>.
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a>,</em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+<p>
+GRASS 5.0 team
Deleted: grass/trunk/raster/r.out.vrml/description.html
--- grass/trunk/raster/r.out.vrml/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.vrml/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,69 +0,0 @@
-This module exports a GRASS raster map to the Virtual Reality Modeling
-Language (VRML) format for 3D visualization.
-<p>
-This version only outputs raster maps in VRML 1.0 format.
-The newer VRML 2.0 format will be more efficient for geographic
-applications, as it introduces an "ElevationGrid" node so that
-only the elevation points will have to be written instead
-of the whole geometry. The vast majority of VRML viewers
-currently only support VRML 1.0.
-If the extension "wrl" (world) is not present in the he
-<em>output</em> parameter, it will be added.
-<h2>WARNING</h2>
-VRML is not well suited for large geometrys which can result from even
-a small geographic region. Most viewers seem to bog down with more
-than 12,000 polygons, depending on your hardware & specific
-viewer. Each grid cell results in two polygons, so a reasonable size
-region would be something less than about 75x75. For improved
-performance and smaller file size, leave off a color map. Since VRML
-is ascii text, gzip works very well to significantly compress file
-size.<p>
-<h2>NOTE</h2>
-This is a preliminary release of "<em>r.out.vrml</em>".
-For further information about VRML and available viewers for various platforms, see:<p>
-<a href="http://www.w3.org/MarkUp/VRML/">VRML Virtual Reality Modeling Language</a>
-<h2>BUGS:</h2>
-Currently the region is transformed to a unit size, so real geographic
-location is lost. Side effects when working in a lat-lon location are
-that besides general distortion due to projection, a very small
-exaggeration factor (on order of .001) must be used to compensate for
-vertical units expected to be the same as map units.
-<h2>TODO</h2>
-Update to the more modern <a href="http://www.geovrml.org">GeoVRML format</a>,
-or probably better the next generation
- <a href="http://www.web3d.org">X3D format</a>.
-See also the <a href="http://www.xj3d.org">Xj3D project</a>.
-<p>
-Future plans for this module are to allow draping of sites objects and
-vector maps and using the new sites format available in floating
-point GRASS to embed WWW links into site objects. It will also be
-upgraded to support VRML 2.0 and will allow entering multiple preset
-"views" using the existing GRASS 3d_view file format.<p>
-Other possible additions:
-<ul>
- <li> Allow animation of elevation, color, or sites based on
- user interaction.
- <li> Degradation of the raster to produce TINs for improved
- performance.
-</ul>
-<h2>AUTHOR</h2>
- Bill Brown, US Army Construction Engineering Research Laboratory
-<p>
Copied: grass/trunk/raster/r.out.vrml/r.out.vrml.html (from rev 32770, grass/trunk/raster/r.out.vrml/description.html)
--- grass/trunk/raster/r.out.vrml/r.out.vrml.html (rev 0)
+++ grass/trunk/raster/r.out.vrml/r.out.vrml.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,69 @@
+This module exports a GRASS raster map to the Virtual Reality Modeling
+Language (VRML) format for 3D visualization.
+<p>
+This version only outputs raster maps in VRML 1.0 format.
+The newer VRML 2.0 format will be more efficient for geographic
+applications, as it introduces an "ElevationGrid" node so that
+only the elevation points will have to be written instead
+of the whole geometry. The vast majority of VRML viewers
+currently only support VRML 1.0.
+If the extension "wrl" (world) is not present in the he
+<em>output</em> parameter, it will be added.
+<h2>WARNING</h2>
+VRML is not well suited for large geometrys which can result from even
+a small geographic region. Most viewers seem to bog down with more
+than 12,000 polygons, depending on your hardware & specific
+viewer. Each grid cell results in two polygons, so a reasonable size
+region would be something less than about 75x75. For improved
+performance and smaller file size, leave off a color map. Since VRML
+is ascii text, gzip works very well to significantly compress file
+size.<p>
+<h2>NOTE</h2>
+This is a preliminary release of "<em>r.out.vrml</em>".
+For further information about VRML and available viewers for various platforms, see:<p>
+<a href="http://www.w3.org/MarkUp/VRML/">VRML Virtual Reality Modeling Language</a>
+<h2>BUGS:</h2>
+Currently the region is transformed to a unit size, so real geographic
+location is lost. Side effects when working in a lat-lon location are
+that besides general distortion due to projection, a very small
+exaggeration factor (on order of .001) must be used to compensate for
+vertical units expected to be the same as map units.
+<h2>TODO</h2>
+Update to the more modern <a href="http://www.geovrml.org">GeoVRML format</a>,
+or probably better the next generation
+ <a href="http://www.web3d.org">X3D format</a>.
+See also the <a href="http://www.xj3d.org">Xj3D project</a>.
+<p>
+Future plans for this module are to allow draping of sites objects and
+vector maps and using the new sites format available in floating
+point GRASS to embed WWW links into site objects. It will also be
+upgraded to support VRML 2.0 and will allow entering multiple preset
+"views" using the existing GRASS 3d_view file format.<p>
+Other possible additions:
+<ul>
+ <li> Allow animation of elevation, color, or sites based on
+ user interaction.
+ <li> Degradation of the raster to produce TINs for improved
+ performance.
+</ul>
+<h2>AUTHOR</h2>
+ Bill Brown, US Army Construction Engineering Research Laboratory
+<p>
Deleted: grass/trunk/raster/r.out.vtk/description.html
--- grass/trunk/raster/r.out.vtk/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.out.vtk/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,124 +0,0 @@
-Outputs <i>Raster</i> maps in <i>VTK-ASCII</i> format. <i>Map's</i> are
-valid Raster map's in the current mapset. <i>output</i> is the name of
-an VTK-ASCII file which will be written in the current working directory.
-If <i>output</i> is not specified then <b>stdout</b> is used.
-The module is sensitive to region settings (set with g.region).
-<br>
-<br>
-Elevation, scaling, point/celldata, vector and RGB Data are supported.
-If the map is in LL projection, the elevation values will automatically scaled to
-degrees. It is supposed that the elevation values are provided in meters.
-If the elevation values are in a different unit than meters, use
-the scale parameter to convert the units.
-<br>
-<br>
-If no elevation map is given, the user can set the hight of the map by one value.
-Point or cell data are available. Also scaling is supported for this elevation value.
-The elevation value must be provided in meters.
-<br>
-<br>
-The RGB input requires three raster maps: red, green, blue - in this order.
-The maps must have values between 0 and 255, otherwise you will get lots of warnings
-and the values are set to 0.
-More than one RGB dataset (3 maps) is not supported.
-<br>
-<br>
-The vector input requires three raster maps: x, y, z -- defining the vector coordinates - in this order.
-More than one vector dataset (3 maps) is not supported.
-<h2>NOTES</h2>
-This filter generates:
-<ul>
-<li><i>structured points</i> with <i>celldata</i> or <i>pointdata</i> if no elevationfile is given</li>
-<li><i>structured grid</i> (not recommendet) with <i>pointdata</i> if an elevationfile is given</li>
-<li><i>polydataset</i> with <i>pointdata</i> if an elevationfile is given (default)</li>
-</ul>
-and puts this in a simple VTK-ASCII file. Nor XML or
-binary output are supported. It is possible to choose more then one raster map
-to be written to the VTK-ASCII file. Each cell-/pointdata is named like the raster map it represents.
-You can visualize this file with the
-<em><a href="http://www.vtk.org">VTK Toolkit</a></em>,
-<em><a href="http://www.paraview.org">Paraview</a></em> and
-<em><a href="http://mayavi.sourceforge.net">MayaVi</a></em> which are based on VTK.
-If you have a raster map with partly no data, use the threshold filter in paraview to
-visualize the valid data. Just filter all data which is greater/lesser than the
-choosen null value in the VTK-ASCII file.
-<br>
-If elevation map is choosen, a polygonal grid is created with <i>quads</i>,
-but the user can choose also <i>triangle strips</i> or <i>vertices</i>.
-These dataformats a documented at <em><a href="http://www.vtk.org">VTK Toolkit</a></em>.
-<br>
-<br>
-If the "-c" flag is used and the data should be visualised together with other data exported via *.out.vtk
-modules, be sure the "-c" flag was also set in these modules.
-But this will only work with data from the SAME location
-(The reference point for the coordinates transformation is based on the center point of the default region).
-<br>
-<br>
-<h3>Difference between point- and celldata</h3>
-r.out.vtk can export raster cells with different representations.
-<ul>
- <li>
- <i>pointdata</i> -- the cells/values are represented by the center of the cell.
- Instead of cells, points are created. Each point can hold different values,
- but the user can only visualize one value at a time. These points can
- be connected in different ways.
- </li>
- <li>
- <i>celldata</i> -- is only provided if no elevation map is given.
- The cells are created with the same hight and width as in GRASS. Each cell
- can hold different values, but the user can only visualize one value at a time.
- </li>
-</ul>
-<h2>EXAMPLE</h2>
-<h3>Simple Spearfish example</h3>
-#set a nice region
-g.region -d
-g.region n=4926970 s=4914857 w=591583 e=607793 res=50
-#export the data
-r.out.vtk input=elevation.10m,slope,aspect elevation=elevation.10m output=/tmp/out.vtk
-# visualize in paraview or other VTK viewer:
-paraview --data=/tmp/out.vtk
-</pre></div>
-<h3>Spearfish example with RGB data</h3>
-#set the region
-g.region -d
-#we are using r.in.onearth (available from the grass addon wiki) to create rgb data
-#get some satellite images with r.in.onearth
-r.in.onearth -l output=Sat tmband=Red
-r.in.onearth -l output=Sat tmband=IR1
-r.in.onearth -l output=Sat tmband=IR2
-#export the data
-r.out.vtk rgbmaps=SatLandsatTM_IR1,SatLandsatTM_IR2,SatLandsatTM_Red elevation=elevation.10m output=/tmp/out.vtk
-</pre></div>
-<br>
-<h2>SEE ALSO</h2>
-<em><a href="r3.out.vtk.html">r3.out.vtk</a></em><br>
-<em><a href="g.region.html">g.region</a></em><br>
-<h2>AUTHORS</h2>
-Soeren Gebbert
Copied: grass/trunk/raster/r.out.vtk/r.out.vtk.html (from rev 32770, grass/trunk/raster/r.out.vtk/description.html)
--- grass/trunk/raster/r.out.vtk/r.out.vtk.html (rev 0)
+++ grass/trunk/raster/r.out.vtk/r.out.vtk.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,124 @@
+Outputs <i>Raster</i> maps in <i>VTK-ASCII</i> format. <i>Map's</i> are
+valid Raster map's in the current mapset. <i>output</i> is the name of
+an VTK-ASCII file which will be written in the current working directory.
+If <i>output</i> is not specified then <b>stdout</b> is used.
+The module is sensitive to region settings (set with g.region).
+<br>
+<br>
+Elevation, scaling, point/celldata, vector and RGB Data are supported.
+If the map is in LL projection, the elevation values will automatically scaled to
+degrees. It is supposed that the elevation values are provided in meters.
+If the elevation values are in a different unit than meters, use
+the scale parameter to convert the units.
+<br>
+<br>
+If no elevation map is given, the user can set the hight of the map by one value.
+Point or cell data are available. Also scaling is supported for this elevation value.
+The elevation value must be provided in meters.
+<br>
+<br>
+The RGB input requires three raster maps: red, green, blue - in this order.
+The maps must have values between 0 and 255, otherwise you will get lots of warnings
+and the values are set to 0.
+More than one RGB dataset (3 maps) is not supported.
+<br>
+<br>
+The vector input requires three raster maps: x, y, z -- defining the vector coordinates - in this order.
+More than one vector dataset (3 maps) is not supported.
+<h2>NOTES</h2>
+This filter generates:
+<ul>
+<li><i>structured points</i> with <i>celldata</i> or <i>pointdata</i> if no elevationfile is given</li>
+<li><i>structured grid</i> (not recommendet) with <i>pointdata</i> if an elevationfile is given</li>
+<li><i>polydataset</i> with <i>pointdata</i> if an elevationfile is given (default)</li>
+</ul>
+and puts this in a simple VTK-ASCII file. Nor XML or
+binary output are supported. It is possible to choose more then one raster map
+to be written to the VTK-ASCII file. Each cell-/pointdata is named like the raster map it represents.
+You can visualize this file with the
+<em><a href="http://www.vtk.org">VTK Toolkit</a></em>,
+<em><a href="http://www.paraview.org">Paraview</a></em> and
+<em><a href="http://mayavi.sourceforge.net">MayaVi</a></em> which are based on VTK.
+If you have a raster map with partly no data, use the threshold filter in paraview to
+visualize the valid data. Just filter all data which is greater/lesser than the
+choosen null value in the VTK-ASCII file.
+<br>
+If elevation map is choosen, a polygonal grid is created with <i>quads</i>,
+but the user can choose also <i>triangle strips</i> or <i>vertices</i>.
+These dataformats a documented at <em><a href="http://www.vtk.org">VTK Toolkit</a></em>.
+<br>
+<br>
+If the "-c" flag is used and the data should be visualised together with other data exported via *.out.vtk
+modules, be sure the "-c" flag was also set in these modules.
+But this will only work with data from the SAME location
+(The reference point for the coordinates transformation is based on the center point of the default region).
+<br>
+<br>
+<h3>Difference between point- and celldata</h3>
+r.out.vtk can export raster cells with different representations.
+<ul>
+ <li>
+ <i>pointdata</i> -- the cells/values are represented by the center of the cell.
+ Instead of cells, points are created. Each point can hold different values,
+ but the user can only visualize one value at a time. These points can
+ be connected in different ways.
+ </li>
+ <li>
+ <i>celldata</i> -- is only provided if no elevation map is given.
+ The cells are created with the same hight and width as in GRASS. Each cell
+ can hold different values, but the user can only visualize one value at a time.
+ </li>
+</ul>
+<h2>EXAMPLE</h2>
+<h3>Simple Spearfish example</h3>
+#set a nice region
+g.region -d
+g.region n=4926970 s=4914857 w=591583 e=607793 res=50
+#export the data
+r.out.vtk input=elevation.10m,slope,aspect elevation=elevation.10m output=/tmp/out.vtk
+# visualize in paraview or other VTK viewer:
+paraview --data=/tmp/out.vtk
+</pre></div>
+<h3>Spearfish example with RGB data</h3>
+#set the region
+g.region -d
+#we are using r.in.onearth (available from the grass addon wiki) to create rgb data
+#get some satellite images with r.in.onearth
+r.in.onearth -l output=Sat tmband=Red
+r.in.onearth -l output=Sat tmband=IR1
+r.in.onearth -l output=Sat tmband=IR2
+#export the data
+r.out.vtk rgbmaps=SatLandsatTM_IR1,SatLandsatTM_IR2,SatLandsatTM_Red elevation=elevation.10m output=/tmp/out.vtk
+</pre></div>
+<br>
+<h2>SEE ALSO</h2>
+<em><a href="r3.out.vtk.html">r3.out.vtk</a></em><br>
+<em><a href="g.region.html">g.region</a></em><br>
+<h2>AUTHORS</h2>
+Soeren Gebbert
Deleted: grass/trunk/raster/r.param.scale/description.html
--- grass/trunk/raster/r.param.scale/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.param.scale/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,110 +0,0 @@
-<b>r.param.scale</b> extracts terrain parameters from a DEM. Uses a
-multi-scale approach by fitting a bivariate quadratic polynomial to a given
-window size using least squares.
-<p>
-The module calculates the following parameters (terminology is from Wood,
-1996 with related terminology used in other GRASS modules listed in
-brackets):
-<ul>
-<li>
-<i>elev</i>: Generalised elevation value (for resampling purposes at different
-scale)</li>
-<li>
-<i>slope</i>: Magnitude of maximum gradient (steepest slope angle)</li>
-<li>
-<i>aspect</i>: Direction of maximum gradient (steepest slope direction=flow direction)</li>
-<li>
-<i>profc</i> or profile curvature (curvature intersecting with the plane
-defined by <i>Z</i> axis and maximum gradient direction). Positive values
-describe convex profile curvature, negative values concave profile
-curvature.</li>
-<li>
-<i>planc</i> or plan curvature (horizontal curvature, intersecting with
-the <i>XY</i> plane)</li>
-<li>
-<i>longc</i> or longitudinal curvature (profile curvature intersecting
-with the plane defined by the surface normal and maximum gradient direction)</li>
-<li>
-<i>crosc</i> or cross-sectional curvature (tangential curvature intersecting
-with the plane defined by the surface normal and a tangent to the contour
-- perpendicular to maximum gradient direction)</li>
-<li>
-<i>maxic</i> or maximum curvature (can be in any direction)</li>
-<li>
-<i>minic</i> or minimum curvature (in direction perpendicular to the direction
-of of maximum curvature)</li>
-<li>
-<i>meanc</i> or mean curvature (average of maximum and minimum curvatures).</li>
-<li>
-<i>feature</i>: Morphometric features: peaks, ridges, passes, channels, pits and planes</li>
-</ul>
-<h2>NOTES</h2>
-In <i>r.param.scale</i> the direction of maximum gradient (considered
-downslope) is stored as (West is 0 degree, East is +/- 180 degree):
-<ul>
-<li>
-0..+180 degree from West to North to East</li>
-<li>
-0..-180 degree from West to South to East</li>
-</ul>
-Note that the aspect map is calculated differently from
-<a href="r.slope.aspect.html">r.slope.aspect</a>.
-<h2>Still to do</h2>
-Fix bug when `constrain through central cell' option selected. Create color
-tables for all output files (presently only on features).
-<h2>EXAMPLE</h2>
-The next commands will create a morphology map of the Spearfish region:
-<div class="code"><pre>
-g.region rast=elevation.10m -p
-r.param.scale in=elevation.10m output=morphology param=feature
-</pre></div>
-<h2>SEE ALSO</h2>
-<!-- not ported to GRASS 6 due to non-GPLness of numerical recipes.
-<i><a href="d.param.scale.html">d.param.scale</a></i>
-<p>Java Code in
-<a href="http://www.geog.le.ac.uk/jwo/research/LandSerf">LandSerf</a>
-that implements the same procedure
-<h2>REFERENCE</h2>
-Wood, J. (1996): The Geomorphological characterisation of Digital Elevation
-Models. Diss., Department of Geography, University of Leicester, U.K.
-<br>online at:
-<br><a href="http://www.soi.city.ac.uk/~jwo/phd/">http://www.soi.city.ac.uk/~jwo/phd/</a>
-<h2>AUTHOR</h2>
-<address>
-<a href="MAILTO:jwo at le.ac.uk">jwo at le.ac.uk</a>
-- <a href="http://www.geog.le.ac.uk/assist/index.html">ASSIST's home</a></address>
-<p>Update to FP 3/2002: L. Potrich, M. Neteler, S. Menegon (ITC-irst)
Copied: grass/trunk/raster/r.param.scale/r.param.scale.html (from rev 32770, grass/trunk/raster/r.param.scale/description.html)
--- grass/trunk/raster/r.param.scale/r.param.scale.html (rev 0)
+++ grass/trunk/raster/r.param.scale/r.param.scale.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,110 @@
+<b>r.param.scale</b> extracts terrain parameters from a DEM. Uses a
+multi-scale approach by fitting a bivariate quadratic polynomial to a given
+window size using least squares.
+<p>
+The module calculates the following parameters (terminology is from Wood,
+1996 with related terminology used in other GRASS modules listed in
+brackets):
+<ul>
+<li>
+<i>elev</i>: Generalised elevation value (for resampling purposes at different
+scale)</li>
+<li>
+<i>slope</i>: Magnitude of maximum gradient (steepest slope angle)</li>
+<li>
+<i>aspect</i>: Direction of maximum gradient (steepest slope direction=flow direction)</li>
+<li>
+<i>profc</i> or profile curvature (curvature intersecting with the plane
+defined by <i>Z</i> axis and maximum gradient direction). Positive values
+describe convex profile curvature, negative values concave profile
+curvature.</li>
+<li>
+<i>planc</i> or plan curvature (horizontal curvature, intersecting with
+the <i>XY</i> plane)</li>
+<li>
+<i>longc</i> or longitudinal curvature (profile curvature intersecting
+with the plane defined by the surface normal and maximum gradient direction)</li>
+<li>
+<i>crosc</i> or cross-sectional curvature (tangential curvature intersecting
+with the plane defined by the surface normal and a tangent to the contour
+- perpendicular to maximum gradient direction)</li>
+<li>
+<i>maxic</i> or maximum curvature (can be in any direction)</li>
+<li>
+<i>minic</i> or minimum curvature (in direction perpendicular to the direction
+of of maximum curvature)</li>
+<li>
+<i>meanc</i> or mean curvature (average of maximum and minimum curvatures).</li>
+<li>
+<i>feature</i>: Morphometric features: peaks, ridges, passes, channels, pits and planes</li>
+</ul>
+<h2>NOTES</h2>
+In <i>r.param.scale</i> the direction of maximum gradient (considered
+downslope) is stored as (West is 0 degree, East is +/- 180 degree):
+<ul>
+<li>
+0..+180 degree from West to North to East</li>
+<li>
+0..-180 degree from West to South to East</li>
+</ul>
+Note that the aspect map is calculated differently from
+<a href="r.slope.aspect.html">r.slope.aspect</a>.
+<h2>Still to do</h2>
+Fix bug when `constrain through central cell' option selected. Create color
+tables for all output files (presently only on features).
+<h2>EXAMPLE</h2>
+The next commands will create a morphology map of the Spearfish region:
+g.region rast=elevation.10m -p
+r.param.scale in=elevation.10m output=morphology param=feature
+</pre></div>
+<h2>SEE ALSO</h2>
+<!-- not ported to GRASS 6 due to non-GPLness of numerical recipes.
+<i><a href="d.param.scale.html">d.param.scale</a></i>
+<p>Java Code in
+<a href="http://www.geog.le.ac.uk/jwo/research/LandSerf">LandSerf</a>
+that implements the same procedure
+<h2>REFERENCE</h2>
+Wood, J. (1996): The Geomorphological characterisation of Digital Elevation
+Models. Diss., Department of Geography, University of Leicester, U.K.
+<br>online at:
+<br><a href="http://www.soi.city.ac.uk/~jwo/phd/">http://www.soi.city.ac.uk/~jwo/phd/</a>
+<h2>AUTHOR</h2>
+<address>
+<a href="MAILTO:jwo at le.ac.uk">jwo at le.ac.uk</a>
+- <a href="http://www.geog.le.ac.uk/assist/index.html">ASSIST's home</a></address>
+<p>Update to FP 3/2002: L. Potrich, M. Neteler, S. Menegon (ITC-irst)
Deleted: grass/trunk/raster/r.patch/description.html
--- grass/trunk/raster/r.patch/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.patch/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,115 +0,0 @@
-<h2>DESCRIPTION</h2>
-The GRASS program <em>r.patch</em> allows the user to build a new
-raster map the size and resolution of the current region by assigning
-known data values from input raster maps to the cells in this region.
-This is done by filling in "no data" cells, those that do not yet
-contain data, contain NULL data, or, optionally contain 0 data,
-with the data from the first input map.
-Once this is done the remaining holes are filled in by the next input map,
-and so on.
-This program
-is useful for making a composite raster map layer from two or more adjacent
-map layers, for filling in "holes" in a raster map layer's data (e.g., in
-digital elevation data), or for updating an older map layer with more recent
-data. The current geographic region definition and mask settings are
-respected.
-<p>
-The first <em>name</em> listed in the string
-<b>input=</b><em>name</em>,<em>name</em>,<em>name</em>, ... is the name of
-the first map whose data values will be used to fill in "no data" cells
-in the current region. The second through 200 (max) input <em>name</em>
-maps will be used, in order, to supply data values for for the remaining
-"no data" cells.
-<h2>EXAMPLE</h2>
-Below, the raster map layer on the far left is <b>patched</b>
-with the middle (<em>patching</em>) raster map layer,
-to produce the <em>composite</em> raster map layer on the right.
-<pre>
- 1 1 1 0 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 1 2 2 0 0
- 1 1 0 2 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 2 2 2 0 0
- 3 3 3 3 2 2 0 0 0 0 0 0 0 0 0 0 3 3 3 3 2 2 0 0
- 3 3 3 3 0 0 0 0 4 4 4 4 4 4 4 4 3 3 3 3 4 4 4 4
- 3 3 3 0 0 0 0 0 4 4 4 4 4 4 4 4 3 3 3 4 4 4 4 4
- 0 0 0 0 0 0 0 0 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
-</pre>
-Switching the <em>patched</em> and the <em>patching</em> raster map layers
-produces the following results:
-<pre>
- 0 0 1 1 0 0 0 0 1 1 1 0 2 2 0 0 1 1 1 1 2 2 0 0
- 0 0 1 1 0 0 0 0 1 1 0 2 2 2 0 0 1 1 1 1 2 2 0 0
- 0 0 0 0 0 0 0 0 3 3 3 3 2 2 0 0 3 3 3 3 2 2 0 0
- 4 4 4 4 4 4 4 4 3 3 3 3 0 0 0 0 4 4 4 4 4 4 4 4
- 4 4 4 4 4 4 4 4 3 3 3 0 0 0 0 0 4 4 4 4 4 4 4 4
- 4 4 4 4 4 4 4 4 0 0 0 0 0 0 0 0 4 4 4 4 4 4 4 4
-</pre>
-<h2>NOTES</h2>
-Frequently, this program is used to patch together adjacent map layers which
-have been digitized separately. The program
-<em><a href="v.mkgrid.html">v.mkgrid</a></em> can be used to make adjacent
-maps align neatly.
-<p>
-The user should check the current geographic region settings before running
-<em>r.patch</em>, to ensure that the region boundaries encompass all
-of the data desired to be included in the composite map and to ensure that the
-region resolution is the resolution of the desired data. To set the
-geographic region settings to one or several raster maps, the <em>g.region</em>
-program can be used:
-g.region rast=map1[,map2[,...]]
-</pre></div>
-<p>
-Use of <em>r.patch</em> is generally followed by use of the GRASS programs
-<em><a href="g.remove.html">g.remove</a></em> and
-<em><a href="g.rename.html">g.rename</a></em>;
-<em>g.remove</em> is used to remove the original (un-patched) raster map
-layers, while <em>g.rename</em> is used to then assign to the newly-created
-composite (patched) raster map layer the name of the original raster map
-layer.
-<p>
-<em>r.patch</em> creates support files for the patched, composite output map.
-<h2>EXAMPLE</h2>
-Create a list of maps matching a pattern, extend the region to include them
-all, and patch them together to create a mosaic. Overlapping maps will be
-used in the order listed.
-MAPS=`g.mlist type=rast sep=, pat="map_*"`
-g.region rast=$MAPS
-r.patch in=$MAPS out=mosaic
-</pre></div>
-<br>
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="g.remove.html">g.remove</a></em>,
-<em><a href="g.rename.html">g.rename</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.support.html">r.support</a></em>,
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory
-<br>
--z flag by Huidae Cho
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/raster/r.patch/r.patch.html (from rev 32770, grass/trunk/raster/r.patch/description.html)
--- grass/trunk/raster/r.patch/r.patch.html (rev 0)
+++ grass/trunk/raster/r.patch/r.patch.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,115 @@
+The GRASS program <em>r.patch</em> allows the user to build a new
+raster map the size and resolution of the current region by assigning
+known data values from input raster maps to the cells in this region.
+This is done by filling in "no data" cells, those that do not yet
+contain data, contain NULL data, or, optionally contain 0 data,
+with the data from the first input map.
+Once this is done the remaining holes are filled in by the next input map,
+and so on.
+This program
+is useful for making a composite raster map layer from two or more adjacent
+map layers, for filling in "holes" in a raster map layer's data (e.g., in
+digital elevation data), or for updating an older map layer with more recent
+data. The current geographic region definition and mask settings are
+respected.
+<p>
+The first <em>name</em> listed in the string
+<b>input=</b><em>name</em>,<em>name</em>,<em>name</em>, ... is the name of
+the first map whose data values will be used to fill in "no data" cells
+in the current region. The second through 200 (max) input <em>name</em>
+maps will be used, in order, to supply data values for for the remaining
+"no data" cells.
+<h2>EXAMPLE</h2>
+Below, the raster map layer on the far left is <b>patched</b>
+with the middle (<em>patching</em>) raster map layer,
+to produce the <em>composite</em> raster map layer on the right.
+<pre>
+ 1 1 1 0 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 1 2 2 0 0
+ 1 1 0 2 2 2 0 0 0 0 1 1 0 0 0 0 1 1 1 2 2 2 0 0
+ 3 3 3 3 2 2 0 0 0 0 0 0 0 0 0 0 3 3 3 3 2 2 0 0
+ 3 3 3 3 0 0 0 0 4 4 4 4 4 4 4 4 3 3 3 3 4 4 4 4
+ 3 3 3 0 0 0 0 0 4 4 4 4 4 4 4 4 3 3 3 4 4 4 4 4
+ 0 0 0 0 0 0 0 0 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
+</pre>
+Switching the <em>patched</em> and the <em>patching</em> raster map layers
+produces the following results:
+<pre>
+ 0 0 1 1 0 0 0 0 1 1 1 0 2 2 0 0 1 1 1 1 2 2 0 0
+ 0 0 1 1 0 0 0 0 1 1 0 2 2 2 0 0 1 1 1 1 2 2 0 0
+ 0 0 0 0 0 0 0 0 3 3 3 3 2 2 0 0 3 3 3 3 2 2 0 0
+ 4 4 4 4 4 4 4 4 3 3 3 3 0 0 0 0 4 4 4 4 4 4 4 4
+ 4 4 4 4 4 4 4 4 3 3 3 0 0 0 0 0 4 4 4 4 4 4 4 4
+ 4 4 4 4 4 4 4 4 0 0 0 0 0 0 0 0 4 4 4 4 4 4 4 4
+</pre>
+<h2>NOTES</h2>
+Frequently, this program is used to patch together adjacent map layers which
+have been digitized separately. The program
+<em><a href="v.mkgrid.html">v.mkgrid</a></em> can be used to make adjacent
+maps align neatly.
+<p>
+The user should check the current geographic region settings before running
+<em>r.patch</em>, to ensure that the region boundaries encompass all
+of the data desired to be included in the composite map and to ensure that the
+region resolution is the resolution of the desired data. To set the
+geographic region settings to one or several raster maps, the <em>g.region</em>
+program can be used:
+<div class="code"><pre>
+g.region rast=map1[,map2[,...]]
+</pre></div>
+<p>
+Use of <em>r.patch</em> is generally followed by use of the GRASS programs
+<em><a href="g.remove.html">g.remove</a></em> and
+<em><a href="g.rename.html">g.rename</a></em>;
+<em>g.remove</em> is used to remove the original (un-patched) raster map
+layers, while <em>g.rename</em> is used to then assign to the newly-created
+composite (patched) raster map layer the name of the original raster map
+layer.
+<p>
+<em>r.patch</em> creates support files for the patched, composite output map.
+<h2>EXAMPLE</h2>
+Create a list of maps matching a pattern, extend the region to include them
+all, and patch them together to create a mosaic. Overlapping maps will be
+used in the order listed.
+MAPS=`g.mlist type=rast sep=, pat="map_*"`
+g.region rast=$MAPS
+r.patch in=$MAPS out=mosaic
+</pre></div>
+<br>
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="g.remove.html">g.remove</a></em>,
+<em><a href="g.rename.html">g.rename</a></em>,
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a href="r.support.html">r.support</a></em>,
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S. Army Construction Engineering Research Laboratory
+<br>
+-z flag by Huidae Cho
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/raster/r.profile/description.html
--- grass/trunk/raster/r.profile/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.profile/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,146 +0,0 @@
-This program outputs two or four column (with <b>-g</b>) data to stdout or
-an ASCII file. The default two column output consists of cumulative profile
-length (in meters) and raster value. The optional four column output consists
-of easting, northing, cumlative profile length (m), and raster value. Profile
-end or "turning" points can be set manually with the <b>profile</b>
-argument or selected interactively from the GRASS monitor by setting the
-<b>-i</b> flag. The profile resolution, or distance between profile
-points, is obtained from the current region resolution, or can be manually
-set with the <b>res</b> argument.
-<p>
-The <b>-i</b> flag allows the user for selecting the profile from the GRASS
-monitor by clicking the left mouse button along the profile; clicking the
-right mouse button ends the profile.
-<p>
-The <b>profile</b> parameter can be set to comma separated geographic
-coordinates for profile line endpoints. The interactive flag (<b>-i</b>)
-overrides this option. Alternatively the coordinate pairs can be piped
-from stdin, one comma separated pair per line.
-<p>
-The <b>res</b> parameter sets the distance between each profile point
-(resolution). The resolution must be provided in GRASS database units (i.e.
-decimal degrees for Lat Long databases and meters for UTM). By default
-<em>r.profile</em> uses the resolution of the current GRASS region.
-<p>
-The <b>null</b> parameter can optionally be set to change the character
-string representing null values.
-<h2>OUTPUT FORMAT</h2>
-The multi column output from <em>r.profile</em> is intended for easy use in
-other programs. The output can be piped (|) directly into other programs or
-saved to a file for later use. Output with geographic coordinates (<em>-g</em>)
-is compatible with <em><a href="v.in.ascii.html">v.in.ascii</a></em> and can
-be piped direcly into this program.
-r.profile -ig input=elev.rast | v.in.ascii output=elev.profile fs=space
-</pre></div>
-The 2 column output is compatible with most plotting programs.
-<p>
-The optional RGB output provides the associated GRASS colour value for
-each profile point.
-<h2>EXAMPLES</h2>
-<b>Example 1</b><br>
-Extract a profile with coordinates provided on the command line:
-r.profile input=elev.rast output=profile.pts profile=562517,7779433,562984,7779533,563875,7779800
-</pre></div>
-This will extract a profile along the track defined by the three coordinate
-pairs.
-<p><br>
-<b>Example 2</b><br>
-Extract a profile by interactively selecting the profile route from the GRASS
-monitor:
-r.profile -i input=elev.rast output=profile.pts
-</pre></div>
-Use the left mouse button to select the profile route in the GRASS monitor. Use the
-right mouse button to end the profile.
-<p><br>
-<b>Example 3</b><br>
-Extract a profile with coordinates provided from standard input or an external file:
-<p>
-First create a points file with <em><a href="d.where.html">d.where</a></em>
-d.where > saved.points
-</pre></div>
-Then pipe the points file into r.profile
-cat saved.points | r.profile input=elev.rast output=profile.pts
-</pre></div>
-The advantage of this method is that the same profile points can be piped into
-different GRASS rasters by changing the input parameter.
-<p>
-With this method the coordinates must be given as space or tab seperated easting
-and northing. Labels after these values are ignored.
-<p>
-Another example using d.where:
-d.where | r.profile elevation.dem
-</pre></div>
-<p><br>
-<b>Example 4</b><br>
-Pipe coordinates into r.profile
-r.profile elevation.dem res=1000 << EOF
- 591243,4926344
- 592509,4922156
- 594100,4920793
- 599910,4919365
- 602929,4919235
- 604844,4918391
- 606468,4917190
- 607766,4915664
-EOF
-</pre></div>
-<h2>NOTES</h2>
-The profile resolution is measured exactly from the supplied end or
-"turning" point along the profile. The end of a profile segment will be an
-exact multiple of the profile resolution and will therefore not always match
-the end point coordinates entered for the segmanet.
-<p>
-To extract the numbers in scripts, following parameters can be used:
-r.profile input=dgm12.5 profile=3570631,5763556 2>/dev/null
-</pre></div>
-This filters out the everything except the numbers.
-<h2>SEE ALSO</h2>
-<em><a href="v.in.ascii.html">v.in.ascii</a></em>,
-<em><a href="d.where.html">d.where</a></em>,
-<em><a href="d.profile.html">d.profile</a></em>,
-<em><a href="r.what.html">r.what</a></em>,
-<em><a href="r.transect.html">r.transect</a></em>,
-<em><a href="gm_profile.html">gis.m: PROFILE TOOL</a></em>
-<h2>AUTHOR</h2>
-<a href=mailto:bcovill at tekmap.ns.ca>Bob Covill</a>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.profile/r.profile.html (from rev 32770, grass/trunk/raster/r.profile/description.html)
--- grass/trunk/raster/r.profile/r.profile.html (rev 0)
+++ grass/trunk/raster/r.profile/r.profile.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,146 @@
+This program outputs two or four column (with <b>-g</b>) data to stdout or
+an ASCII file. The default two column output consists of cumulative profile
+length (in meters) and raster value. The optional four column output consists
+of easting, northing, cumlative profile length (m), and raster value. Profile
+end or "turning" points can be set manually with the <b>profile</b>
+argument or selected interactively from the GRASS monitor by setting the
+<b>-i</b> flag. The profile resolution, or distance between profile
+points, is obtained from the current region resolution, or can be manually
+set with the <b>res</b> argument.
+<p>
+The <b>-i</b> flag allows the user for selecting the profile from the GRASS
+monitor by clicking the left mouse button along the profile; clicking the
+right mouse button ends the profile.
+<p>
+The <b>profile</b> parameter can be set to comma separated geographic
+coordinates for profile line endpoints. The interactive flag (<b>-i</b>)
+overrides this option. Alternatively the coordinate pairs can be piped
+from stdin, one comma separated pair per line.
+<p>
+The <b>res</b> parameter sets the distance between each profile point
+(resolution). The resolution must be provided in GRASS database units (i.e.
+decimal degrees for Lat Long databases and meters for UTM). By default
+<em>r.profile</em> uses the resolution of the current GRASS region.
+<p>
+The <b>null</b> parameter can optionally be set to change the character
+string representing null values.
+<h2>OUTPUT FORMAT</h2>
+The multi column output from <em>r.profile</em> is intended for easy use in
+other programs. The output can be piped (|) directly into other programs or
+saved to a file for later use. Output with geographic coordinates (<em>-g</em>)
+is compatible with <em><a href="v.in.ascii.html">v.in.ascii</a></em> and can
+be piped direcly into this program.
+r.profile -ig input=elev.rast | v.in.ascii output=elev.profile fs=space
+</pre></div>
+The 2 column output is compatible with most plotting programs.
+<p>
+The optional RGB output provides the associated GRASS colour value for
+each profile point.
+<h2>EXAMPLES</h2>
+<b>Example 1</b><br>
+Extract a profile with coordinates provided on the command line:
+r.profile input=elev.rast output=profile.pts profile=562517,7779433,562984,7779533,563875,7779800
+</pre></div>
+This will extract a profile along the track defined by the three coordinate
+pairs.
+<p><br>
+<b>Example 2</b><br>
+Extract a profile by interactively selecting the profile route from the GRASS
+monitor:
+r.profile -i input=elev.rast output=profile.pts
+</pre></div>
+Use the left mouse button to select the profile route in the GRASS monitor. Use the
+right mouse button to end the profile.
+<p><br>
+<b>Example 3</b><br>
+Extract a profile with coordinates provided from standard input or an external file:
+<p>
+First create a points file with <em><a href="d.where.html">d.where</a></em>
+d.where > saved.points
+</pre></div>
+Then pipe the points file into r.profile
+cat saved.points | r.profile input=elev.rast output=profile.pts
+</pre></div>
+The advantage of this method is that the same profile points can be piped into
+different GRASS rasters by changing the input parameter.
+<p>
+With this method the coordinates must be given as space or tab seperated easting
+and northing. Labels after these values are ignored.
+<p>
+Another example using d.where:
+d.where | r.profile elevation.dem
+</pre></div>
+<p><br>
+<b>Example 4</b><br>
+Pipe coordinates into r.profile
+r.profile elevation.dem res=1000 << EOF
+ 591243,4926344
+ 592509,4922156
+ 594100,4920793
+ 599910,4919365
+ 602929,4919235
+ 604844,4918391
+ 606468,4917190
+ 607766,4915664
+EOF
+</pre></div>
+<h2>NOTES</h2>
+The profile resolution is measured exactly from the supplied end or
+"turning" point along the profile. The end of a profile segment will be an
+exact multiple of the profile resolution and will therefore not always match
+the end point coordinates entered for the segmanet.
+<p>
+To extract the numbers in scripts, following parameters can be used:
+r.profile input=dgm12.5 profile=3570631,5763556 2>/dev/null
+</pre></div>
+This filters out the everything except the numbers.
+<h2>SEE ALSO</h2>
+<em><a href="v.in.ascii.html">v.in.ascii</a></em>,
+<em><a href="d.where.html">d.where</a></em>,
+<em><a href="d.profile.html">d.profile</a></em>,
+<em><a href="r.what.html">r.what</a></em>,
+<em><a href="r.transect.html">r.transect</a></em>,
+<em><a href="gm_profile.html">gis.m: PROFILE TOOL</a></em>
+<h2>AUTHOR</h2>
+<a href=mailto:bcovill at tekmap.ns.ca>Bob Covill</a>
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.proj/description.html
--- grass/trunk/raster/r.proj/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.proj/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,197 +0,0 @@
-<em>r.proj</em> projects a raster map in a specified mapset of a
-specified location from the projection of the input location to a raster map
-in the current location. The projection information is taken from the
-current PROJ_INFO files, as set with <i><a href="g.setproj.html">g.setproj</a>
-</i> and viewed with <i><a href="g.proj.html">g.proj</a></i>.
-<h4>Introduction</h4>
-<h5>Map projections</h5>
-Map projections are a method of representing information from a
-curved surface (usually a spheroid) in two dimensions, typically to allow
-indexing through cartesian coordinates. There are a wide variety of
-projections, with common ones divided into a number of classes, including
-cylindrical and pseudo-cylindrical, conic and pseudo-conic, and azimuthal
-methods, each of which may be conformal, equal-area, or neither.
-<p>
-The particular projection chosen depends on the purpose of the project,
-and the size, shape and location of the area of interest. For example,
-normal cylindrical projections are good for maps which are of greater extent
-east-west than north-south and in equatorial regions, while conic
-projections are better in mid-latitudes; transverse cylindrical projections
-are used for maps which are of greater extent north-south than east-west;
-azimuthal projections are used for polar regions. Oblique versions of any
-of these may also be used. Conformal projections preserve angular
-relationships, and better preserve arc-length, while equal-area projections
-are more appropriate for statistical studies and work in which the amount of
-material is important.
-<p>
-Projections are defined by precise mathematical relations, so the method
-of projecting coordinates from a geographic reference frame
-(latitude-longitude) into a projected cartesian reference frame (eg metres)
-is governed by these equations. Inverse projections can also be achieved.
-The public-domain Unix software package <i>PROJ</i> [1] has been designed to
-perform these transformations, and the user's manual contains a detailed
-description of over 100 useful projections. This also includes a
-programmers library of the projection methods to support other software
-development.
-<p>
-Thus, converting a vector map - in which objects are located
-with arbitrary spatial precision - from one projection into another is
-usually accomplished by a simple two-step process: first the location of
-all the points in the map are converted from the source through an inverse
-projection into latitude-longitude, and then through a forward projection
-into the target. (Of course the procedure will be one-step if either the
-source or target is in geographic coordinates.)
-<p>
-Converting a raster map, or image, between different projections,
-however, involves additional considerations.
-A raster may be considered to represent a sampling of a
-process at a regular, ordered set of locations. The set of locations that
-lie at the intersections of a cartesian grid in one projection will not, in
-general, coincide with the sample points in another projection. Thus, the
-conversion of raster maps involves an interpolation step in which the values
-of points at intermediate locations relative to the source grid are
-estimated.
-<h5>Projecting vector maps within the GRASS GIS</h5>
-<!-- move this into v.proj.html !! -->
-GIS data capture, import and transfer often requires a projection
-step, since the source or client will frequently be in a different
-projection to the working projection.
-<p>
-In some cases it is convenient to do the conversion outside the package,
-prior to import or after export, using software such as <i>PROJ.4</i>'s
-<i><a href="http://proj.maptools.org/">cs2cs</a></i> [1]. This is an easy
-method for converting an ASCII file containing a list of coordinate points,
-since there is no topology to be preserved and <i>cs2cs</i> can be used to
-process simple lists using a one-line command.
-<p>
-The format of files containg vector maps with <b>lines</b> and <b>arcs</b> is
-generally more complex, as parts of the data stored in the files will describe
-topology, and not just coordinates. In GRASS GIS the
-<i><a href="v.proj.html">v.proj</a></i> module is provided to reproject
-vector maps, transferring topology and attributes as well as node coordinates.
-This program uses the projection definition and parameters which are stored in
-the PROJ_INFO and PROJ_UNITS files in the PERMANENT mapset directory for every
-GRASS location.
-<br><br>
-<h4>Design of r.proj</h4>
-As discussed briefly above, the fundamental step in re-projecting a
-raster is resampling the source grid at locations corresponding to the
-intersections of a grid in the target projection. The basic procedure for
-accomplishing this, therefore, is as follows:
-<p>
-<em>r.proj</em> converts a map to a new geographic projection. It reads a
-map from a different location, projects it and write it out to the current
-location.
-<br>
-The projected data is resampled with one of three different methods:
-nearest neighbor, bilinear and cubic convolution.
-<p>
-The <em>method=nearest</em>, which performs a nearest neighbor assignment,
-is the fastest of the three resampling methods. It is primarily used for
-categorical data such as a land use classification, since it will not change
-the values of the data cells. The <em>method=bilinear</em> determines the new
-value of the cell based on a weighted distance average of the 4 surrounding
-cells in the input map. The <em>method=cubic</em> determines the new value of
-the cell based on a weighted distance average of the 16 surrounding cells in
-the input map.
-<p>
-The bilinear and cubic interpolation methods are most appropriate for
-continuous data and cause some smoothing. Both options should not be used
-with categorical data, since the cell values will be altered.
-<p>
-If nearest neighbor assignment is used, the output map has the same raster
-format as the input map. If any of the both interpolations is used, the
-output map is written as floating point.
-<p>
-Note that, following normal GRASS conventions, the coverage and
-resolution of the resulting grid is set by the current region settings,
-which may be adjusted using <i>g.region</i>. The target raster will be
-relatively unbiased for all cases if its grid has a similar resolution to
-the source, so that the resampling/interpolation step is only a local
-operation. If the resolution is changed significantly, then the behaviour
-of the generalisation or refinement will depend on the model of the process
-being represented. This will be very different for categorical versus
-numerical data. Note that three methods for the local interpolation step
-are provided.
-<p>
-<em>r.proj</em> supports general datum transformations, making use of the
-<em>PROJ.4</em> co-ordinate system translation library.
-</p>
-<h2>NOTES</h2>
-To avoid excessive time consumption when reprojecting a map the region and
-resolution of the target location should be set appropriately beforehand.
-A simple way to do this is to generate a vector "box" map of the region in
-the source location using <em><a href="v.in.region.html">v.in.region</a></em>.
-This "box" map is then reprojected into the target location with
-<em><a href="v.proj.html">v.proj</a></em>.
-Next the region in the target location is set to the extent of the new vector
-map with <em><a href="g.region.html">g.region</a></em> along with the desired
-raster resolution (<em>g.region -m</em> can be used in Latitude/Longitude
-locations to measure the geodetic length of a pixel).
-<em>r.proj</em> is then run for the raster map the user wants to reproject.
-In this case a little preparation goes a long way.
-<p>
-When reprojecting whole-world maps the user should disable map-trimming with
-the <em>-n</em> flag. Trimming is not useful here because the module has the
-whole map in memory anyway. Besides that, world "edges" are hard (or
-impossible) to find in projections other than latitude-longitude so results
-may be odd with trimming.
-<h2>REFERENCES</h2>
-[1] Evenden, G.I. (1990) <a href="http://proj.maptools.org/">Cartographic projection procedures for
-the UNIX environment - a user's manual.</a> USGS Open-File Report 90-284 (OF90-284.pdf)
-See also there: Interim Report and 2nd Interim Report on Release 4, Evenden 1994).
-<p>
-Richards, John A. (1993), Remote Sensing Digital Image Analysis,
-Springer-Verlag, Berlin, 2nd edition.
-<p>
-<a href=http://proj.maptools.org/>PROJ.4</a>: Projection/datum support library.
-<p>
-<b>Further reading</b>
-<ul>
-<li> <a href="http://www.asprs.org/resources/grids/">ASPRS Grids and Datum</a>
-<li> <a href="http://www.remotesensing.org/geotiff/proj_list/">Projections Transform List</a> (PROJ.4)
-<li> <a href="http://www.mapref.org">MapRef - The Collection of Map Projections and Reference Systems for Europe</a>
-<li> <a href="http://crs.bkg.bund.de/crs-eu/">Information and Service System for European Coordinate Reference Systems - CRS</a>
-</ul>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="g.proj.html">g.proj</a>,
-<a href="g.setproj.html">g.setproj</a>,
-<a href="i.rectify.html">i.rectify</a>,
-<a href="r.support.html">r.support</a>,
-<a href="r.stats.html">r.stats</a>,
-<a href="v.proj.html">v.proj</a>,
-<a href="v.in.region.html">v.in.region</a>
-</em>
-<p>
-The 'gdalwarp' and 'gdal_translate' utilities are available from the
-<a href="http://www.gdal.org">GDAL</a> project.
-<h2>AUTHORS</h2>
-Martin Schroeder, University of Heidelberg, Germany<p>
-Man page text from S.J.D. Cox, AGCRC, CSIRO Exploration & Mining, Nedlands, WA
-<p>
-Updated by <a href="mailto:morten at ngb.se">Morten Hulden</a>
-<p>
-Datum tranformation support and cleanup by Paul Kelly
Copied: grass/trunk/raster/r.proj/r.proj.html (from rev 32770, grass/trunk/raster/r.proj/description.html)
--- grass/trunk/raster/r.proj/r.proj.html (rev 0)
+++ grass/trunk/raster/r.proj/r.proj.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,197 @@
+<em>r.proj</em> projects a raster map in a specified mapset of a
+specified location from the projection of the input location to a raster map
+in the current location. The projection information is taken from the
+current PROJ_INFO files, as set with <i><a href="g.setproj.html">g.setproj</a>
+</i> and viewed with <i><a href="g.proj.html">g.proj</a></i>.
+<h4>Introduction</h4>
+<h5>Map projections</h5>
+Map projections are a method of representing information from a
+curved surface (usually a spheroid) in two dimensions, typically to allow
+indexing through cartesian coordinates. There are a wide variety of
+projections, with common ones divided into a number of classes, including
+cylindrical and pseudo-cylindrical, conic and pseudo-conic, and azimuthal
+methods, each of which may be conformal, equal-area, or neither.
+<p>
+The particular projection chosen depends on the purpose of the project,
+and the size, shape and location of the area of interest. For example,
+normal cylindrical projections are good for maps which are of greater extent
+east-west than north-south and in equatorial regions, while conic
+projections are better in mid-latitudes; transverse cylindrical projections
+are used for maps which are of greater extent north-south than east-west;
+azimuthal projections are used for polar regions. Oblique versions of any
+of these may also be used. Conformal projections preserve angular
+relationships, and better preserve arc-length, while equal-area projections
+are more appropriate for statistical studies and work in which the amount of
+material is important.
+<p>
+Projections are defined by precise mathematical relations, so the method
+of projecting coordinates from a geographic reference frame
+(latitude-longitude) into a projected cartesian reference frame (eg metres)
+is governed by these equations. Inverse projections can also be achieved.
+The public-domain Unix software package <i>PROJ</i> [1] has been designed to
+perform these transformations, and the user's manual contains a detailed
+description of over 100 useful projections. This also includes a
+programmers library of the projection methods to support other software
+development.
+<p>
+Thus, converting a vector map - in which objects are located
+with arbitrary spatial precision - from one projection into another is
+usually accomplished by a simple two-step process: first the location of
+all the points in the map are converted from the source through an inverse
+projection into latitude-longitude, and then through a forward projection
+into the target. (Of course the procedure will be one-step if either the
+source or target is in geographic coordinates.)
+<p>
+Converting a raster map, or image, between different projections,
+however, involves additional considerations.
+A raster may be considered to represent a sampling of a
+process at a regular, ordered set of locations. The set of locations that
+lie at the intersections of a cartesian grid in one projection will not, in
+general, coincide with the sample points in another projection. Thus, the
+conversion of raster maps involves an interpolation step in which the values
+of points at intermediate locations relative to the source grid are
+estimated.
+<h5>Projecting vector maps within the GRASS GIS</h5>
+<!-- move this into v.proj.html !! -->
+GIS data capture, import and transfer often requires a projection
+step, since the source or client will frequently be in a different
+projection to the working projection.
+<p>
+In some cases it is convenient to do the conversion outside the package,
+prior to import or after export, using software such as <i>PROJ.4</i>'s
+<i><a href="http://proj.maptools.org/">cs2cs</a></i> [1]. This is an easy
+method for converting an ASCII file containing a list of coordinate points,
+since there is no topology to be preserved and <i>cs2cs</i> can be used to
+process simple lists using a one-line command.
+<p>
+The format of files containg vector maps with <b>lines</b> and <b>arcs</b> is
+generally more complex, as parts of the data stored in the files will describe
+topology, and not just coordinates. In GRASS GIS the
+<i><a href="v.proj.html">v.proj</a></i> module is provided to reproject
+vector maps, transferring topology and attributes as well as node coordinates.
+This program uses the projection definition and parameters which are stored in
+the PROJ_INFO and PROJ_UNITS files in the PERMANENT mapset directory for every
+GRASS location.
+<br><br>
+<h4>Design of r.proj</h4>
+As discussed briefly above, the fundamental step in re-projecting a
+raster is resampling the source grid at locations corresponding to the
+intersections of a grid in the target projection. The basic procedure for
+accomplishing this, therefore, is as follows:
+<p>
+<em>r.proj</em> converts a map to a new geographic projection. It reads a
+map from a different location, projects it and write it out to the current
+location.
+<br>
+The projected data is resampled with one of three different methods:
+nearest neighbor, bilinear and cubic convolution.
+<p>
+The <em>method=nearest</em>, which performs a nearest neighbor assignment,
+is the fastest of the three resampling methods. It is primarily used for
+categorical data such as a land use classification, since it will not change
+the values of the data cells. The <em>method=bilinear</em> determines the new
+value of the cell based on a weighted distance average of the 4 surrounding
+cells in the input map. The <em>method=cubic</em> determines the new value of
+the cell based on a weighted distance average of the 16 surrounding cells in
+the input map.
+<p>
+The bilinear and cubic interpolation methods are most appropriate for
+continuous data and cause some smoothing. Both options should not be used
+with categorical data, since the cell values will be altered.
+<p>
+If nearest neighbor assignment is used, the output map has the same raster
+format as the input map. If any of the both interpolations is used, the
+output map is written as floating point.
+<p>
+Note that, following normal GRASS conventions, the coverage and
+resolution of the resulting grid is set by the current region settings,
+which may be adjusted using <i>g.region</i>. The target raster will be
+relatively unbiased for all cases if its grid has a similar resolution to
+the source, so that the resampling/interpolation step is only a local
+operation. If the resolution is changed significantly, then the behaviour
+of the generalisation or refinement will depend on the model of the process
+being represented. This will be very different for categorical versus
+numerical data. Note that three methods for the local interpolation step
+are provided.
+<p>
+<em>r.proj</em> supports general datum transformations, making use of the
+<em>PROJ.4</em> co-ordinate system translation library.
+</p>
+<h2>NOTES</h2>
+To avoid excessive time consumption when reprojecting a map the region and
+resolution of the target location should be set appropriately beforehand.
+A simple way to do this is to generate a vector "box" map of the region in
+the source location using <em><a href="v.in.region.html">v.in.region</a></em>.
+This "box" map is then reprojected into the target location with
+<em><a href="v.proj.html">v.proj</a></em>.
+Next the region in the target location is set to the extent of the new vector
+map with <em><a href="g.region.html">g.region</a></em> along with the desired
+raster resolution (<em>g.region -m</em> can be used in Latitude/Longitude
+locations to measure the geodetic length of a pixel).
+<em>r.proj</em> is then run for the raster map the user wants to reproject.
+In this case a little preparation goes a long way.
+<p>
+When reprojecting whole-world maps the user should disable map-trimming with
+the <em>-n</em> flag. Trimming is not useful here because the module has the
+whole map in memory anyway. Besides that, world "edges" are hard (or
+impossible) to find in projections other than latitude-longitude so results
+may be odd with trimming.
+<h2>REFERENCES</h2>
+[1] Evenden, G.I. (1990) <a href="http://proj.maptools.org/">Cartographic projection procedures for
+the UNIX environment - a user's manual.</a> USGS Open-File Report 90-284 (OF90-284.pdf)
+See also there: Interim Report and 2nd Interim Report on Release 4, Evenden 1994).
+<p>
+Richards, John A. (1993), Remote Sensing Digital Image Analysis,
+Springer-Verlag, Berlin, 2nd edition.
+<p>
+<a href=http://proj.maptools.org/>PROJ.4</a>: Projection/datum support library.
+<p>
+<b>Further reading</b>
+<ul>
+<li> <a href="http://www.asprs.org/resources/grids/">ASPRS Grids and Datum</a>
+<li> <a href="http://www.remotesensing.org/geotiff/proj_list/">Projections Transform List</a> (PROJ.4)
+<li> <a href="http://www.mapref.org">MapRef - The Collection of Map Projections and Reference Systems for Europe</a>
+<li> <a href="http://crs.bkg.bund.de/crs-eu/">Information and Service System for European Coordinate Reference Systems - CRS</a>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="g.proj.html">g.proj</a>,
+<a href="g.setproj.html">g.setproj</a>,
+<a href="i.rectify.html">i.rectify</a>,
+<a href="r.support.html">r.support</a>,
+<a href="r.stats.html">r.stats</a>,
+<a href="v.proj.html">v.proj</a>,
+<a href="v.in.region.html">v.in.region</a>
+</em>
+<p>
+The 'gdalwarp' and 'gdal_translate' utilities are available from the
+<a href="http://www.gdal.org">GDAL</a> project.
+<h2>AUTHORS</h2>
+Martin Schroeder, University of Heidelberg, Germany<p>
+Man page text from S.J.D. Cox, AGCRC, CSIRO Exploration & Mining, Nedlands, WA
+<p>
+Updated by <a href="mailto:morten at ngb.se">Morten Hulden</a>
+<p>
+Datum tranformation support and cleanup by Paul Kelly
Deleted: grass/trunk/raster/r.proj.seg/description.html
--- grass/trunk/raster/r.proj.seg/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.proj.seg/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,197 +0,0 @@
-<p>
-<p>
-development.
-<p>
-<p>
-estimated.
-<p>
-<p>
-The format of files containing vector maps with <b>lines</b> and <b>arcs</b> is
-GRASS location.
-<br><br>
-<p>
-location.
-<br>
-<p>
-The <em>method=nearest</em> method, which performs a nearest neighbor assignment,
-the values of the data cells. The <em>method=bilinear</em> method determines the new
-cells in the input map. The <em>method=cubic</em> method determines the new value of
-the input map.
-<p>
-<p>
-<p>
-are provided.
-<p>
-</p>
-<h2>NOTES</h2>
-<p>
-<p>
-<p>
-<p>
-<ul>
-</ul>
-<h2>SEE ALSO</h2>
-<em>
-</em>
-<p>
-<h2>AUTHORS</h2>
-<p>
-<p>
Copied: grass/trunk/raster/r.proj.seg/r.proj.html (from rev 32770, grass/trunk/raster/r.proj.seg/description.html)
--- grass/trunk/raster/r.proj.seg/r.proj.html (rev 0)
+++ grass/trunk/raster/r.proj.seg/r.proj.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,197 @@
+<h2>DESCRIPTION</h2>
+<p>
+<p>
+development.
+<p>
+<p>
+estimated.
+<p>
+<p>
+The format of files containing vector maps with <b>lines</b> and <b>arcs</b> is
+GRASS location.
+<br><br>
+<p>
+location.
+<br>
+<p>
+The <em>method=nearest</em> method, which performs a nearest neighbor assignment,
+the values of the data cells. The <em>method=bilinear</em> method determines the new
+cells in the input map. The <em>method=cubic</em> method determines the new value of
+the input map.
+<p>
+<p>
+<p>
+are provided.
+<p>
+</p>
+<h2>NOTES</h2>
+<p>
+<p>
+<p>
+<p>
+<ul>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+</em>
+<p>
+<h2>AUTHORS</h2>
+<p>
+<p>
Deleted: grass/trunk/raster/r.quant/description.html
--- grass/trunk/raster/r.quant/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.quant/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,36 +0,0 @@
-<em>r.quant</em> produces the quantization file for a floating-point map.
-<p>
-The <em>map</em> parameter defines the map for which the rules be to be
-created. If more than one map is specified, then this implies that the
-floating-point range is the miniumum and maximum of all the maps together,
-unless either basemap=map or fprange=min,max is specified.
-<h2> Quant rules </h2>
-The quant rules have to be entered interactively.
-<p>
-If rules is specified, the input has the form: <p>
- value1:value2:cat1:[cat2] <p>
-where value1 and value2 are floating point values and cat1 cand cat2 are
-integers. If cat2 is missing, it is taken to be equal to cat1. All values
-can be "*" which means infinity.
-<h2>NOTE</h2>
-It is an error for both basemap and fprange to be specified.
-<h2>SEE ALSO</h2>
-<em><a href="r.null.html">r.null</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro, Olga Waupotitsch,
-U.S.Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.quant/r.quant.html (from rev 32770, grass/trunk/raster/r.quant/description.html)
--- grass/trunk/raster/r.quant/r.quant.html (rev 0)
+++ grass/trunk/raster/r.quant/r.quant.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,36 @@
+<em>r.quant</em> produces the quantization file for a floating-point map.
+<p>
+The <em>map</em> parameter defines the map for which the rules be to be
+created. If more than one map is specified, then this implies that the
+floating-point range is the miniumum and maximum of all the maps together,
+unless either basemap=map or fprange=min,max is specified.
+<h2> Quant rules </h2>
+The quant rules have to be entered interactively.
+<p>
+If rules is specified, the input has the form: <p>
+ value1:value2:cat1:[cat2] <p>
+where value1 and value2 are floating point values and cat1 cand cat2 are
+integers. If cat2 is missing, it is taken to be equal to cat1. All values
+can be "*" which means infinity.
+<h2>NOTE</h2>
+It is an error for both basemap and fprange to be specified.
+<h2>SEE ALSO</h2>
+<em><a href="r.null.html">r.null</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro, Olga Waupotitsch,
+U.S.Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.quantile/description.html
--- grass/trunk/raster/r.quantile/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.quantile/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,17 +0,0 @@
-<em>r.quantile</em> computes quantiles in a manner suitable for use with large amounts of data.
-It is using two passes.
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.quant.html">r.quant</a>
-</em>
-<h2>AUTHOR</h2>
-Glynn Clements <glynn gclements.plus.com>
-<p>
-<i>Last changed: $Date: 2007-04-06 21:49:26 +0200 (Fri, 06 Apr 2007) $</i>
Copied: grass/trunk/raster/r.quantile/r.quantile.html (from rev 32770, grass/trunk/raster/r.quantile/description.html)
--- grass/trunk/raster/r.quantile/r.quantile.html (rev 0)
+++ grass/trunk/raster/r.quantile/r.quantile.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,17 @@
+<em>r.quantile</em> computes quantiles in a manner suitable for use with large amounts of data.
+It is using two passes.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.quant.html">r.quant</a>
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements <glynn gclements.plus.com>
+<p>
+<i>Last changed: $Date: 2007-04-06 21:49:26 +0200 (Fri, 06 Apr 2007) $</i>
Deleted: grass/trunk/raster/r.random/description.html
--- grass/trunk/raster/r.random/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.random/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,127 +0,0 @@
-<p>
-The program <em>r.random</em> allows the user to create a
-raster map layer and/or a vector points map containing
-coordinates of points whose locations have been randomly
-determined. The program locates these randomly generated
-vector points (sites) within the current geographic region and mask (if
-any), on non-NULL category value data areas within a
-user-specified raster map layer. If the user sets the
-<b>-z</b> flag, points will be randomly generated across all
-cells (even those with NULL values).
-<p>
-The category values and
-corresponding category names already associated with the
-random point locations in the <em>input</em> map layer are
-assigned to these points in the <em>raster_output</em> map
-layer. If the <b>-z</b> is specified, then a unique entry
-is made for the value used where the <em>input</em> was NULL.
-This value is at least 1 less than the smallest value in the
-<em>input</em> raster and is given a medium gray color.
-<h2>NOTES</h2>
-<p>
-If a <em>cover</em> raster map is specified and the <em>cover</em> map
-contains NULL (no data) values, these points are suppressed in the
-resulting <em>vector_output</em> or <em>raster_output</em> map.
-<p>
-The <em>vector_output</em> file created by <em>r.random</em>
-contains vector points that represent the <em>center points</em> of the
-randomly generated cells. A <em>value</em> attribute contains the cell value
-of the <em>input</em> raster (or the assigned value
-when <b>-z</b> is used). <br>
-If a <em>cover</em> map is additionally specified, a second
-column <em>covervalue</em> is populated with raster values from
-the <em>cover</em> map.
-<p>
-The user may specify the quantity of random locations to be
-generated either as a <em>positive integer</em> (e.g., 10),
-or as a <em>percentage of the raster map layer's cells</em>
-(e.g., 10%, or 3.05%). The number of cells considered for
-the percentage reflects whether or not the <b>-z</b> flag
-was given. Options are 0-100; percentages less than
-one percent may be stated as decimals.
-<p>
-Flag <b>-i</b> prints the raster map's name and location,
-the total number of cells under the current region settings, and
-the number of NULL valued cells under the current region settings.
-Then module exits without doing anything. Useful for deciding on the number
-of sites to have <em>r.random</em> create.
-<b>WARNING:</b> this feature may be removed in future. Use
-<a href="g.region.html">g.region</a> and
-<a href="r.report.html">r.report</a>
-instead.
-g.region -p
-r.report map=inputmap units=c null=* nsteps=1
-</pre></div>
-<p>
-To create random vector point locations within some, but not all,
-non-zero categories of the input raster map layer,
-the user must first create a reclassified raster map layer
-of the original raster map layer (e.g., using the GRASS
-program <em><a href="r.reclass.html">r.reclass</a></em>)
-that contains only the desired categories,
-and then use the reclassed raster map layer as input to <em>r.random</em>.
-<h2>EXAMPLES</h2>
-<p>
-Random vector elevation points sampled from elevation map in the
-Spearfish region, result stored in 2D vector map:
-r.random elevation.10m vector_output=elevrand n=100
-v.db.select elevrand
-v.univar elevrand col=value type=point
-</pre></div>
-<p>
-Spearfish region with collocated values sampled from landuse map,
-result stored in 3D vector map:
-r.random -d elevation.10m cover=landcover.30m vector_output=luserand3d n=100
-# data output (value: elevation, covervalue: landuse class):
-v.db.select luserand3d
-cat|value|covervalue
-1|1151.406616|81
-2|1172.121216|71
-3|1183.219604|71
-</pre></div>
-<h2>BUGS</h2>
-It's not possible to use the <b>-i</b> flag and not also specify the <b>n</b>
-parameter.
-<h2>SEE ALSO</h2>
-<em><a href="r.reclass.html">r.reclass</a></em><br>
-<em><a href="v.random.html">v.random</a></em><br>
-<h2>AUTHOR</h2>
-Dr. James Hinthorne,
-GIS Laboratory,
-Central Washington University
-<p>
-Modified for GRASS 5.0 by Eric G. Miller
-<p>
-Cover map support by Markus Neteler, 2007
-<p>
Copied: grass/trunk/raster/r.random/r.random.html (from rev 32770, grass/trunk/raster/r.random/description.html)
--- grass/trunk/raster/r.random/r.random.html (rev 0)
+++ grass/trunk/raster/r.random/r.random.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,127 @@
+<p>
+The program <em>r.random</em> allows the user to create a
+raster map layer and/or a vector points map containing
+coordinates of points whose locations have been randomly
+determined. The program locates these randomly generated
+vector points (sites) within the current geographic region and mask (if
+any), on non-NULL category value data areas within a
+user-specified raster map layer. If the user sets the
+<b>-z</b> flag, points will be randomly generated across all
+cells (even those with NULL values).
+<p>
+The category values and
+corresponding category names already associated with the
+random point locations in the <em>input</em> map layer are
+assigned to these points in the <em>raster_output</em> map
+layer. If the <b>-z</b> is specified, then a unique entry
+is made for the value used where the <em>input</em> was NULL.
+This value is at least 1 less than the smallest value in the
+<em>input</em> raster and is given a medium gray color.
+<h2>NOTES</h2>
+<p>
+If a <em>cover</em> raster map is specified and the <em>cover</em> map
+contains NULL (no data) values, these points are suppressed in the
+resulting <em>vector_output</em> or <em>raster_output</em> map.
+<p>
+The <em>vector_output</em> file created by <em>r.random</em>
+contains vector points that represent the <em>center points</em> of the
+randomly generated cells. A <em>value</em> attribute contains the cell value
+of the <em>input</em> raster (or the assigned value
+when <b>-z</b> is used). <br>
+If a <em>cover</em> map is additionally specified, a second
+column <em>covervalue</em> is populated with raster values from
+the <em>cover</em> map.
+<p>
+The user may specify the quantity of random locations to be
+generated either as a <em>positive integer</em> (e.g., 10),
+or as a <em>percentage of the raster map layer's cells</em>
+(e.g., 10%, or 3.05%). The number of cells considered for
+the percentage reflects whether or not the <b>-z</b> flag
+was given. Options are 0-100; percentages less than
+one percent may be stated as decimals.
+<p>
+Flag <b>-i</b> prints the raster map's name and location,
+the total number of cells under the current region settings, and
+the number of NULL valued cells under the current region settings.
+Then module exits without doing anything. Useful for deciding on the number
+of sites to have <em>r.random</em> create.
+<b>WARNING:</b> this feature may be removed in future. Use
+<a href="g.region.html">g.region</a> and
+<a href="r.report.html">r.report</a>
+instead.
+g.region -p
+r.report map=inputmap units=c null=* nsteps=1
+</pre></div>
+<p>
+To create random vector point locations within some, but not all,
+non-zero categories of the input raster map layer,
+the user must first create a reclassified raster map layer
+of the original raster map layer (e.g., using the GRASS
+program <em><a href="r.reclass.html">r.reclass</a></em>)
+that contains only the desired categories,
+and then use the reclassed raster map layer as input to <em>r.random</em>.
+<h2>EXAMPLES</h2>
+<p>
+Random vector elevation points sampled from elevation map in the
+Spearfish region, result stored in 2D vector map:
+r.random elevation.10m vector_output=elevrand n=100
+v.db.select elevrand
+v.univar elevrand col=value type=point
+</pre></div>
+<p>
+Spearfish region with collocated values sampled from landuse map,
+result stored in 3D vector map:
+r.random -d elevation.10m cover=landcover.30m vector_output=luserand3d n=100
+# data output (value: elevation, covervalue: landuse class):
+v.db.select luserand3d
+cat|value|covervalue
+1|1151.406616|81
+2|1172.121216|71
+3|1183.219604|71
+</pre></div>
+<h2>BUGS</h2>
+It's not possible to use the <b>-i</b> flag and not also specify the <b>n</b>
+parameter.
+<h2>SEE ALSO</h2>
+<em><a href="r.reclass.html">r.reclass</a></em><br>
+<em><a href="v.random.html">v.random</a></em><br>
+<h2>AUTHOR</h2>
+Dr. James Hinthorne,
+GIS Laboratory,
+Central Washington University
+<p>
+Modified for GRASS 5.0 by Eric G. Miller
+<p>
+Cover map support by Markus Neteler, 2007
+<p>
Deleted: grass/trunk/raster/r.random.cells/description.html
--- grass/trunk/raster/r.random.cells/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.random.cells/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,79 +0,0 @@
-<em>r.random.cells</em> generates a random sets of cells that are at
-least <var>distance</var> apart. The cells are numbered from 1 to the
-numbers of cells generated. Random cells will not be generated in areas
-masked off.
-<h2>PARAMETERS</h2>
-<b>output </b> Output map: Random cells. Each random cell has a unique
-non-zero cell value ranging from 1 to the number of cells generated. The
-heuristic for this algorithm is to randomly pick cells until there are no
-cells outside of the chosen cell's buffer of radius <b>distance</b>.
-<p>
-<b>distance</b> Input value(s) [default 0.0]: <b>distance</b> determines the
-minimum distance the centers of the random cells will be apart.
-<p>
-<b>seed</b> Input value [default: random]: Specifies the random seed that
-<em>r.random.cells</em> will use to generate the cells. If the random seed
-is not given,<em> r.random.cells</em> will get a seed from the process ID
-number.
-<h2>NOTES</h2>
-The original purpose for this program was to generate independent random
-samples of cells in a study area. The <b>distance</b> value is the amount of
-spatial autocorrelation for the map being studied. The amount of spatial
-autocorrelation can be determined by using <em>r.2Dcorrelogram</em> with
-<em>r.2Dto1D</em>, or <em>r.1Dcorrelogram</em>. With <b>distance</b> set to
-zero, the <b>output</b> map will number each non-masked cell from 1 to the
-number of non-masked cells in the study region.
-Random Field Software for GRASS by Chuck Ehlschlaeger<p>
-<p>As part of my dissertation, I put together several programs that help
-GRASS (4.1 and beyond) develop uncertainty models of spatial data. I hope
-you find it useful and dependable. The following papers might clarify their
-use: </p>
-<p>"<a href="http://www.wiu.edu/users/cre111/older/CGFinal/paper.htm">Visualizing Spatial Data
-Uncertainty Using Animation (final draft)</a>," by Charles R.
-Ehlschlaeger, Ashton M. Shortridge, and Michael F. Goodchild. Submitted to
-Computers in GeoSciences in September, 1996, accepted October, 1996 for
-publication in June, 1997. </p>
-<p>"<a href="http://www.wiu.edu/users/cre111/older/SDH96/paper.html">Modeling Uncertainty in Elevation Data for
-Geographical Analysis</a>", by Charles R. Ehlschlaeger, and Ashton M.
-Shortridge. Proceedings of the 7th International Symposium on Spatial Data
-Handling, Delft, Netherlands, August 1996. </p>
-<p>"<a href="http://www.wiu.edu/users/cre111/older/acm/paper.html">Dealing with Uncertainty in
-Categorical Coverage Maps: Defining, Visualizing, and Managing Data
-Errors</a>", by Charles Ehlschlaeger and Michael Goodchild.
-Proceedings, Workshop on Geographic Information Systems at the Conference on
-Information and Knowledge Management, Gaithersburg MD, 1994. </p>
-<p>"<a href="http://www.wiu.edu/users/cre111/older/gislis/gislis.html">Uncertainty in Spatial Data:
-Defining, Visualizing, and Managing Data Errors</a>", by Charles
-Ehlschlaeger and Michael Goodchild. Proceedings, GIS/LIS'94, pp. 246-253,
-Phoenix AZ, 1994. </p>
-<h2>SEE ALSO</h2>
-<em>
-r.1Dcorrelogram,
-r.2Dcorrelogram,
-r.2Dto1D,
-<a href="r.random.surface.html">r.random.surface</a>,
-r.random.model,
-<a href="r.random.html">r.random</a>
-</em>
-<h2>AUTHOR</h2>
-<p>Charles Ehlschlaeger; National Center for Geographic Information and
-Analysis, University of California, Santa Barbara.
Copied: grass/trunk/raster/r.random.cells/r.random.cells.html (from rev 32770, grass/trunk/raster/r.random.cells/description.html)
--- grass/trunk/raster/r.random.cells/r.random.cells.html (rev 0)
+++ grass/trunk/raster/r.random.cells/r.random.cells.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,79 @@
+<em>r.random.cells</em> generates a random sets of cells that are at
+least <var>distance</var> apart. The cells are numbered from 1 to the
+numbers of cells generated. Random cells will not be generated in areas
+masked off.
+<h2>PARAMETERS</h2>
+<b>output </b> Output map: Random cells. Each random cell has a unique
+non-zero cell value ranging from 1 to the number of cells generated. The
+heuristic for this algorithm is to randomly pick cells until there are no
+cells outside of the chosen cell's buffer of radius <b>distance</b>.
+<p>
+<b>distance</b> Input value(s) [default 0.0]: <b>distance</b> determines the
+minimum distance the centers of the random cells will be apart.
+<p>
+<b>seed</b> Input value [default: random]: Specifies the random seed that
+<em>r.random.cells</em> will use to generate the cells. If the random seed
+is not given,<em> r.random.cells</em> will get a seed from the process ID
+number.
+<h2>NOTES</h2>
+The original purpose for this program was to generate independent random
+samples of cells in a study area. The <b>distance</b> value is the amount of
+spatial autocorrelation for the map being studied. The amount of spatial
+autocorrelation can be determined by using <em>r.2Dcorrelogram</em> with
+<em>r.2Dto1D</em>, or <em>r.1Dcorrelogram</em>. With <b>distance</b> set to
+zero, the <b>output</b> map will number each non-masked cell from 1 to the
+number of non-masked cells in the study region.
+Random Field Software for GRASS by Chuck Ehlschlaeger<p>
+<p>As part of my dissertation, I put together several programs that help
+GRASS (4.1 and beyond) develop uncertainty models of spatial data. I hope
+you find it useful and dependable. The following papers might clarify their
+use: </p>
+<p>"<a href="http://www.wiu.edu/users/cre111/older/CGFinal/paper.htm">Visualizing Spatial Data
+Uncertainty Using Animation (final draft)</a>," by Charles R.
+Ehlschlaeger, Ashton M. Shortridge, and Michael F. Goodchild. Submitted to
+Computers in GeoSciences in September, 1996, accepted October, 1996 for
+publication in June, 1997. </p>
+<p>"<a href="http://www.wiu.edu/users/cre111/older/SDH96/paper.html">Modeling Uncertainty in Elevation Data for
+Geographical Analysis</a>", by Charles R. Ehlschlaeger, and Ashton M.
+Shortridge. Proceedings of the 7th International Symposium on Spatial Data
+Handling, Delft, Netherlands, August 1996. </p>
+<p>"<a href="http://www.wiu.edu/users/cre111/older/acm/paper.html">Dealing with Uncertainty in
+Categorical Coverage Maps: Defining, Visualizing, and Managing Data
+Errors</a>", by Charles Ehlschlaeger and Michael Goodchild.
+Proceedings, Workshop on Geographic Information Systems at the Conference on
+Information and Knowledge Management, Gaithersburg MD, 1994. </p>
+<p>"<a href="http://www.wiu.edu/users/cre111/older/gislis/gislis.html">Uncertainty in Spatial Data:
+Defining, Visualizing, and Managing Data Errors</a>", by Charles
+Ehlschlaeger and Michael Goodchild. Proceedings, GIS/LIS'94, pp. 246-253,
+Phoenix AZ, 1994. </p>
+<h2>SEE ALSO</h2>
+<em>
+r.1Dcorrelogram,
+r.2Dcorrelogram,
+r.2Dto1D,
+<a href="r.random.surface.html">r.random.surface</a>,
+r.random.model,
+<a href="r.random.html">r.random</a>
+</em>
+<h2>AUTHOR</h2>
+<p>Charles Ehlschlaeger; National Center for Geographic Information and
+Analysis, University of California, Santa Barbara.
Deleted: grass/trunk/raster/r.random.surface/description.html
--- grass/trunk/raster/r.random.surface/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.random.surface/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,174 +0,0 @@
-<em>r.random.surface</em> generates a spatially dependent random surface.
-The random surface is composed of values representing the deviation from the
-mean of the initial random values driving the algorithm. The initial random
-values are independent Gaussian random deviates with a mean of 0 and
-standard deviation of 1. The initial values are spread over each output map
-using filter(s) of diameter distance. The influence of each random value on
-nearby cells is determined by a distance decay function based on exponent.
-If multiple filters are passed over the output maps, each filter is given a
-weight based on the weight inputs. The resulting random surface can have
-"any" mean and variance, but the theoretical mean of an infinitely
-large map is 0.0 and a variance of 1.0. Description of the algorithm is in
-the <b>NOTES</b> section.
-<p>
-The random surface generated are composed of floating point numbers, and
-saved in the category description files of the output map(s). Cell values
-are uniformly or normally distributed between 1 and high values inclusive
-(determined by whether the <em>-u</em> flag is used). The category names
-indicate the average floating point value and the range of floating point
-values that each cell value represents.
-<p>
-<em>r.random.surface's</em> original goal is to generate random fields for
-spatial error modeling. A procedure to use <em>r.random.surface</em> in
-spatial error modeling is given in the <b>NOTES</b> section.
-<h3>Parameters:</h3>
-<dl>
-<dt><b>output</b>
-<dd>Output map(s): Random surface(s). The cell values are a random
-distribution between the low and high values inclusive. The category values
-of the output map(s) are in the form "#.# #.# to #.#" where each
-#.# is a floating point number. The first number is the average of the
-random values the cell value represents. The other two numbers are the range
-of random values for that cell value. The "average" mean value of
-generated <tt>output</tt> map(s) is 0. The "average"
-variance of map(s) generated is 1. The random values represent the standard
-deviation from the mean of that random surface.
-<dt><b>distance</b>
-<dd>Input value(s) [default 0.0]: distance determines the spatial dependence
-of the output map(s). The distance value indicates the minimum distance at
-which two map cells have no relationship to each other. A distance value of
-0.0 indicates that there is no spatial dependence (i.e., adjacent cell
-values have no relationship to each other). As the distance value increases,
-adjacent cell values will have values closer to each other. But the range
-and distribution of cell values over the output map(s) will remain the same.
-Visually, the clumps of lower and higher values gets larger as distance
-increases. If multiple values are given, each output map will have multiple
-filters, one for each set of distance, exponent, and weight values.
-<dt><b>exponent</b>
-<dd>Input value(s) [default 1.0]: exponent determines the distance decay
-exponent for a particular filter. The exponent value(s) have the property of
-determining the "texture" of the random surface. Texture will
-decrease as the exponent value(s) get closer to 1.0. Normally, exponent will
-be 1.0 or less. If there are no exponent values given, each filter will be
-given an exponent value of 1.0. If there is at least one exponent value
-given, there must be one exponent value for each distance value.
-<dt><b>flat</b>
-<dd>Input value(s) [default 0.0]: flat determines the distance at which the
-filter
-<dt><b>weight</b>
-<dd>Input value(s) [default 1.0]: weight determines the relative importance
-of each filter. For example, if there were two filters driving the algorithm
-and weight=1.0, 2.0 was given in the command line: The second filter would
-be twice as important as the first filter. If no weight values are given,
-each filter will be just as important as the other filters defining the
-random field. If weight values exist, there must be a weight value for each
-filter of the random field.
-<dt><b>high</b>
-<dd>Input value [default 255]: Specifies the high end of the range of cell
-values in the output map(s). Specifying a very large high value will
-minimize the "errors" caused by the random surface's
-discretization. The word errors is in quotes because errors in
-discretization are often going to cancel each other out and the spatial
-statistics are far more sensitive to the initial independent random deviates
-than any potential discretization errors.
-<dt><b>seed</b>
-<dd>Input value(s) [default random]: Specifies the random seed(s), one for
-each map, that <em>r.random.surface</em> will use to generate the initial
-set of random values that the resulting map is based on. If the random seed
-is not given, <em>r.random.surface</em> will get a seed from the process ID
-number.
-</dl>
-<h2>NOTES</h2>
-While most literature uses the term random field instead of random surface,
-this algorithm always generates a surface. Thus, its use of random surface.
-<p>
-<em>r.random.surface</em> builds the random surface using a filter algorithm
-smoothing a map of independent random deviates. The size of the filter is
-determined by the largest distance of spatial dependence. The shape of the
-filter is determined by the distance decay exponent(s), and the various
-weights if different sets of spatial parameters are used. The map of
-independent random deviates will be as large as the current region PLUS the
-extent of the filter. This will eliminate edge effects caused by the
-reduction of degrees of freedom. The map of independent random deviates will
-ignore the current mask for the same reason.
-<p>
-One of the most important uses for <em>r.random.surface</em> is to determine
-how the error inherent in raster maps might effect the analyses done with
-those maps. If you wanted to check to see how sensitive your analysis is to
-the errors in the DEMs in your study area, see:
-<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/CGFinal/paper.htm">Visualizing Spatial Data Uncertainty Using Animation (final draft)</a>," by Charles R. Ehlschlaeger, Ashton M. Shortridge, and Michael F. Goodchild. Submitted to Computers in GeoSciences in September, 1996, accepted October, 1996 for publication in June, 1997.
-<p>
-"<a href="http://www.geo.hunter.cuny.edu/~chuck/SDH96/paper.html">Modeling Uncertainty in Elevation Data for Geographical Analysis</a>", by Charles R. Ehlschlaeger, and Ashton M. Shortridge. Proceedings of the 7th International Symposium on Spatial Data Handling, Delft, Netherlands, August 1996. </p>
-<p>
-"<a href="http://www.geo.hunter.cuny.edu/~chuck/acm/paper.html">Dealing with Uncertainty in Categorical Coverage Maps: Defining, Visualizing, and Managing Data Errors</a>", by Charles Ehlschlaeger and Michael Goodchild. Proceedings, Workshop on Geographic Information Systems at the Conference on Information and Knowledge Management, Gaithersburg MD, 1994.
-<p>
-"<a href="http://www.geo.hunter.cuny.edu/~chuck/gislis/gislis.html>Uncertainty in Spatial Data: Defining, Visualizing, and Managing Data Errors</a>", by Charles Ehlschlaeger and Michael Goodchild. Proceedings, GIS/LIS'94, pp. 246-253, Phoenix AZ,
-1994.
-<p>
-If you are interested in creating potential realizations of categorical
-coverage maps, see <em>r.random.model</em>.
-<h2>SEE ALSO</h2>
-<em><a href="r.random.html">r.random</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>
-</em>
-use: </p>
-<p>"<a href="../../CGFinal/paper.htm">Visualizing Spatial Data
-<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/paper.html">Modeling Uncertainty in Elevation Data for
-<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/acm/paper.html">Dealing with Uncertainty in
-<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/gislis/gislis.html">Uncertainty in Spatial Data:
-<h2>AUTHORS</h2>
-Charles Ehlschlaeger, Michael Goodchild, and Chih-chang Lin; National Center
-for Geographic Information and Analysis, University of California, Santa
-Barbara.
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.random.surface/r.random.surface.html (from rev 32770, grass/trunk/raster/r.random.surface/description.html)
--- grass/trunk/raster/r.random.surface/r.random.surface.html (rev 0)
+++ grass/trunk/raster/r.random.surface/r.random.surface.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,174 @@
+<em>r.random.surface</em> generates a spatially dependent random surface.
+The random surface is composed of values representing the deviation from the
+mean of the initial random values driving the algorithm. The initial random
+values are independent Gaussian random deviates with a mean of 0 and
+standard deviation of 1. The initial values are spread over each output map
+using filter(s) of diameter distance. The influence of each random value on
+nearby cells is determined by a distance decay function based on exponent.
+If multiple filters are passed over the output maps, each filter is given a
+weight based on the weight inputs. The resulting random surface can have
+"any" mean and variance, but the theoretical mean of an infinitely
+large map is 0.0 and a variance of 1.0. Description of the algorithm is in
+the <b>NOTES</b> section.
+<p>
+The random surface generated are composed of floating point numbers, and
+saved in the category description files of the output map(s). Cell values
+are uniformly or normally distributed between 1 and high values inclusive
+(determined by whether the <em>-u</em> flag is used). The category names
+indicate the average floating point value and the range of floating point
+values that each cell value represents.
+<p>
+<em>r.random.surface's</em> original goal is to generate random fields for
+spatial error modeling. A procedure to use <em>r.random.surface</em> in
+spatial error modeling is given in the <b>NOTES</b> section.
+<h3>Parameters:</h3>
+<dl>
+<dt><b>output</b>
+<dd>Output map(s): Random surface(s). The cell values are a random
+distribution between the low and high values inclusive. The category values
+of the output map(s) are in the form "#.# #.# to #.#" where each
+#.# is a floating point number. The first number is the average of the
+random values the cell value represents. The other two numbers are the range
+of random values for that cell value. The "average" mean value of
+generated <tt>output</tt> map(s) is 0. The "average"
+variance of map(s) generated is 1. The random values represent the standard
+deviation from the mean of that random surface.
+<dt><b>distance</b>
+<dd>Input value(s) [default 0.0]: distance determines the spatial dependence
+of the output map(s). The distance value indicates the minimum distance at
+which two map cells have no relationship to each other. A distance value of
+0.0 indicates that there is no spatial dependence (i.e., adjacent cell
+values have no relationship to each other). As the distance value increases,
+adjacent cell values will have values closer to each other. But the range
+and distribution of cell values over the output map(s) will remain the same.
+Visually, the clumps of lower and higher values gets larger as distance
+increases. If multiple values are given, each output map will have multiple
+filters, one for each set of distance, exponent, and weight values.
+<dt><b>exponent</b>
+<dd>Input value(s) [default 1.0]: exponent determines the distance decay
+exponent for a particular filter. The exponent value(s) have the property of
+determining the "texture" of the random surface. Texture will
+decrease as the exponent value(s) get closer to 1.0. Normally, exponent will
+be 1.0 or less. If there are no exponent values given, each filter will be
+given an exponent value of 1.0. If there is at least one exponent value
+given, there must be one exponent value for each distance value.
+<dt><b>flat</b>
+<dd>Input value(s) [default 0.0]: flat determines the distance at which the
+filter
+<dt><b>weight</b>
+<dd>Input value(s) [default 1.0]: weight determines the relative importance
+of each filter. For example, if there were two filters driving the algorithm
+and weight=1.0, 2.0 was given in the command line: The second filter would
+be twice as important as the first filter. If no weight values are given,
+each filter will be just as important as the other filters defining the
+random field. If weight values exist, there must be a weight value for each
+filter of the random field.
+<dt><b>high</b>
+<dd>Input value [default 255]: Specifies the high end of the range of cell
+values in the output map(s). Specifying a very large high value will
+minimize the "errors" caused by the random surface's
+discretization. The word errors is in quotes because errors in
+discretization are often going to cancel each other out and the spatial
+statistics are far more sensitive to the initial independent random deviates
+than any potential discretization errors.
+<dt><b>seed</b>
+<dd>Input value(s) [default random]: Specifies the random seed(s), one for
+each map, that <em>r.random.surface</em> will use to generate the initial
+set of random values that the resulting map is based on. If the random seed
+is not given, <em>r.random.surface</em> will get a seed from the process ID
+number.
+</dl>
+<h2>NOTES</h2>
+While most literature uses the term random field instead of random surface,
+this algorithm always generates a surface. Thus, its use of random surface.
+<p>
+<em>r.random.surface</em> builds the random surface using a filter algorithm
+smoothing a map of independent random deviates. The size of the filter is
+determined by the largest distance of spatial dependence. The shape of the
+filter is determined by the distance decay exponent(s), and the various
+weights if different sets of spatial parameters are used. The map of
+independent random deviates will be as large as the current region PLUS the
+extent of the filter. This will eliminate edge effects caused by the
+reduction of degrees of freedom. The map of independent random deviates will
+ignore the current mask for the same reason.
+<p>
+One of the most important uses for <em>r.random.surface</em> is to determine
+how the error inherent in raster maps might effect the analyses done with
+those maps. If you wanted to check to see how sensitive your analysis is to
+the errors in the DEMs in your study area, see:
+<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/CGFinal/paper.htm">Visualizing Spatial Data Uncertainty Using Animation (final draft)</a>," by Charles R. Ehlschlaeger, Ashton M. Shortridge, and Michael F. Goodchild. Submitted to Computers in GeoSciences in September, 1996, accepted October, 1996 for publication in June, 1997.
+<p>
+"<a href="http://www.geo.hunter.cuny.edu/~chuck/SDH96/paper.html">Modeling Uncertainty in Elevation Data for Geographical Analysis</a>", by Charles R. Ehlschlaeger, and Ashton M. Shortridge. Proceedings of the 7th International Symposium on Spatial Data Handling, Delft, Netherlands, August 1996. </p>
+<p>
+"<a href="http://www.geo.hunter.cuny.edu/~chuck/acm/paper.html">Dealing with Uncertainty in Categorical Coverage Maps: Defining, Visualizing, and Managing Data Errors</a>", by Charles Ehlschlaeger and Michael Goodchild. Proceedings, Workshop on Geographic Information Systems at the Conference on Information and Knowledge Management, Gaithersburg MD, 1994.
+<p>
+"<a href="http://www.geo.hunter.cuny.edu/~chuck/gislis/gislis.html>Uncertainty in Spatial Data: Defining, Visualizing, and Managing Data Errors</a>", by Charles Ehlschlaeger and Michael Goodchild. Proceedings, GIS/LIS'94, pp. 246-253, Phoenix AZ,
+1994.
+<p>
+If you are interested in creating potential realizations of categorical
+coverage maps, see <em>r.random.model</em>.
+<h2>SEE ALSO</h2>
+<em><a href="r.random.html">r.random</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>
+</em>
+use: </p>
+<p>"<a href="../../CGFinal/paper.htm">Visualizing Spatial Data
+<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/paper.html">Modeling Uncertainty in Elevation Data for
+<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/acm/paper.html">Dealing with Uncertainty in
+<p>"<a href="http://www.geo.hunter.cuny.edu/~chuck/gislis/gislis.html">Uncertainty in Spatial Data:
+<h2>AUTHORS</h2>
+Charles Ehlschlaeger, Michael Goodchild, and Chih-chang Lin; National Center
+for Geographic Information and Analysis, University of California, Santa
+Barbara.
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.reclass/description.html
--- grass/trunk/raster/r.reclass/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.reclass/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,291 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.reclass</em> creates an <em>output</em> map layer
-based on an <em>input</em> raster map layer. The output
-map layer will be a reclassification of the input map layer
-based on reclass rules input to <em>r.reclass</em>, and can
-be treated in much the same way that raster maps are
-treated. A <em>TITLE</em> for the output map layer may be
-(optionally) specified by the user.
-<p>
-The reclass rules are read from standard input (i.e., from
-the keyboard, redirected from a file, or piped through
-another program).
-<p>
-Before using <em>r.reclass</em> the user must know the following:
-<ol>
-<li>The new categories desired; and, which old categories fit into
-which new categories.
-<li>The names of the new categories.
-</ol>
-<h2>INTERACTIVE PROGRAM USE: EXAMPLE</h2>
-Suppose we want to reclassify the raster map layer
-<em>roads</em>, consisting of five categories, into the
-three new categories: paved roads, unpaved roads, and
-railroad tracks. The user is asked whether the reclass
-table is to be established with each category value
-initially set to 0, or with each category value initially
-set to its own value. A screen like that shown below then
-appears, listing the categories of the <em>roads</em>
-raster map layer to be reclassified and prompting the user
-for the new category values to be assigned them.
-<p>
-<pre>
- ENTER NEW CATEGORY NUMBERS FOR THESE CATEGORIES
- OLD CATEGORY NAME OLD NEW
- NUM NUM
- no data 0 0___
- Hard Surface, 2 lanes 1 0___
- Loose Surface, 1 lane 2 0___
- Improved Dirt 3 0___
- Unimproved Dirt Trail 4 0___
- Railroad, single track 5 0___
- AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
- (OR <Ctrl-C> TO CANCEL)
-</pre>
-In the following screen the new category values have been
-entered beside the appropriate old category names. Cells
-assigned category values 2, 3, and 4 in the old raster map
-layer are now assigned the new category value 2 in the
-reclassed map; cell data formerly assigned to category
-value 5 in the old raster map map are now assigned the new
-category value 3 in the reclassed map.
-<pre>
- NUM NUM
- no data 0 0___
- Hard Surface, 2 lanes 1 1___
- Loose Surface, 1 lane 2 2___
- Improved Dirt 3 2___
- Unimproved Dirt Trail 4 2___
- Railroad, single track 5 3___
-</pre>
-Hitting the escape key <ESC> will bring up the
-following screen, which prompts the user to enter a new
-TITLE and category label for the newly <b>reclassed</b>
-categories.
-<pre>
- ENTER NEW CATEGORY NAMES FOR THESE CATEGORIES
- TITLE: Roads Reclassified
- CAT NEW CATEGORY NAME
- NUM
- 0 no data
- 1 Paved Roads
- 2 Unpaved Roads
- 3 Railroad, single track
-</pre>
-Based upon the information supplied by the user in the above sample screens,
-the new output map, supporting category, color, history, and header files
-are created.
-<h2>NON-INTERACTIVE PROGRAM USE: RECLASS RULES</h2>
-In non-interactive program use, the names of an input map, output map,
-and output map TITLE are given on the command line.
-However, the reclass rules are still read from standard input
-(i.e., from the keyboard, redirected
-from a file, or piped through another program).
-<p>
-Once the user has specified an input raster map layer,
-output map layer name, and (optionally) output map layer
-TITLE by typing
-<dl>
-<dd>
-<b>r.reclass input=</b><em>name </em><b>output=</b><em>name </em>[<b>TITLE=</b><em>name</em>]
-</dl>
-Each line of input must have the following format:
-<dl>
-<dd><b>input_categories=</b><em>output_category </em>[<em>label</em>]
-</dl>
-<p>
-where the input lines specify the category values in the
-input raster map layer to be reclassified to the new
-<em>output_category</em> category value. Specification of
-a <em>label</em> to be associated with the new output map
-layer category is optional. If specified, it is recorded
-as the category label for the new category value. The
-equal sign = is required. The <em>input_category(ies)</em>
-may consist of single category values or a range of such
-values in the format "<em>low</em> thru <em>high</em>." The
-word "thru" must be present.
-<p>
-To include all (remaining) values the asterix "*" can be used. This
-rule has to be set as last rule. No further rules are accepted after
-setting this rule.
-<p>
-No data have to be spcified with NULL.
-<p>
-A line containing only the word <b>end</b> terminates the
-input.
-<h2>NON-INTERACTIVE PROGRAM USE: EXAMPLES</h2>
-The following examples may help clarify the reclass rules.
-<p>
-<dt>
-<dd>1. This example reclassifies categories 1, 2 and 3 in the input raster
-map layer "roads" to category 1 with category label "good quality" in the output map
-layer, and reclassifies input raster map layer categories 4 and 5 to
-category 2 with the label "poor quality" in the output map layer.
-<pre>
- 1 2 3 = 1 good quality
- 4 5 = 2 poor quality
-</pre>
-<p>
-<dd>2. This example reclassifies input raster map layer categories 1 thru 10 to output
-map layer category 1, input map layer categories 11 thru 20 to output map layer
-category 2, and input map layer categories 21 thru 30 to output map layer
-category 3, all without labels. The range from 30 to 40 is reclassified as
-NULL.
-<pre>
- 1 thru 10 = 1
- 11 thru 20 = 2
- 21 thru 30 = 3
- 30 thru 40 = NULL
-</pre>
-<dd>3. Subsequent rules override previous rules. Therefore, the below example
-reclassifies input raster map layer categories 1 thru 19 and 51 thru 100
-to category 1 in the output map layer,
-input raster map layer categories 20 thru 24 and 26 thru 50 to
-the output map layer category 2, and input raster map layer category 25
-to the output category 3.
-<pre>
- 1 thru 100 = 1 poor quality
- 20 thru 50 = 2 medium quality
- 25 = 3 good quality
-</pre>
-<dd>4. This example reclassifies categories 1, 3 and 5 in the input raster map layer to category 1 with category label "poor quality" in the output map layer,
-and reclassifies input raster map layer categories 2, 4, and 6
-to category 2 with the label "good quality" in the output map layer.
-All other values are reclassified to NULL.
-<pre>
- 1 3 5 = 1 poor quality
- 2 4 6 = 2 good quality
- * = NULL
-</pre>
-<p>
-<dd>5. The previous example could also have been entered as:
-<pre>
- 1 thru 19 51 thru 100 = 1 poor quality
- 20 thru 24 26 thru 50 = 2 medium quality
-</pre>
-or as:
-<pre>
- 1 thru 19 = 1 poor quality
- 51 thru 100 = 1
- 20 thru 24 = 2
- 26 thru 50 = 2 medium quality
-</pre>
-</dd>
-<p>
-The final example was given to show how the labels are handled. If a new
-category value appears in more than one rule (as is the case with new
-category values 1 and 2),
-the last label which was specified becomes the label for that category.
-In this case the labels are assigned exactly as in the two previous examples.
-<h2>NOTES</h2>
-In fact, the <em>r.reclass</em> program does <em>not</em> generate any new
-raster map layers (in the interests of disk space conservation). Instead, a
-<b>reclass table</b> is stored which will be used to reclassify the
-original raster map layer each time the new (reclassed) map name
-is requested. As far as the user (and programmer) is concerned, that
-raster map has been created.
-Also note that although the user can generate a <em>r.reclass</em> map
-which is based on another <em>r.reclass</em> map,
-the new <em>r.reclass</em> map map will be stored in GRASS as a reclass
-of the <em>original</em> raster map on which the first reclassed map was
-based. Therefore, while GRASS allows the user to provide <em>r.reclass</em>
-map layer information which is based on an already reclassified map
-(for the user's convenience), no <em>r.reclass</em> map layer
-(i.e., <em>reclass table</em>) will ever be <em>stored</em>
-as a <em>r.reclass</em> of a <em>r.reclass</em>.
-<p>
-To convert a reclass map to a regular raster map layer, set your
-geographic region settings to match the settings in the header for the
-reclass map (an ASCII file found under the <em>cellhd</em> directory, or
-viewable by running <em><a href="r.support.html">r.support</a></em>) and then run <em><a href="r.resample.html">r.resample</a></em>.
-<p>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em> can be used to convert
-a reclass map to a regular raster map layer:
-<div class="code"><pre>
- r.mapcalc raster_map=reclass_map
-</pre></div>
-<p>
-where <em>raster_map</em> is the name to be given to the new raster map,
-and <em>reclass_map</em> is an existing reclass map.
-<h2>BEWARE</h2>
-Because <em>r.reclass</em> generates a table referencing some original
-raster map layer rather than creating a reclassed raster map layer,
-a <em>r.reclass</em> map layer will no longer be accessible if
-the original raster map layer upon which it was based is later removed.
-<p>
-A <em>r.reclass</em> map is not a true raster map layer.
-Rather, it is a table of reclassification values which reference the
-input raster map layer. Therefore, users who wish to retain reclassified
-map layers must also save the original input raster map layers
-from which they were generated. Alternatively r.recode can be used.
-<p>
-Category values which are not explicitly reclassified to a new value
-by the user will be reclassified to NULL.
-<h2>SEE ALSO</h2>
-<em><a href="r.resample.html">r.resample</a></em>,
-<em><a href="r.rescale.html">r.rescale</a></em>,
-<em><a href="r.recode.html">r.recode</a></em>
-<h2>AUTHORS</h2>
-James Westervelt,
-<br>
-Michael Shapiro,
-<br>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.reclass/r.reclass.html (from rev 32770, grass/trunk/raster/r.reclass/description.html)
--- grass/trunk/raster/r.reclass/r.reclass.html (rev 0)
+++ grass/trunk/raster/r.reclass/r.reclass.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,291 @@
+<em>r.reclass</em> creates an <em>output</em> map layer
+based on an <em>input</em> raster map layer. The output
+map layer will be a reclassification of the input map layer
+based on reclass rules input to <em>r.reclass</em>, and can
+be treated in much the same way that raster maps are
+treated. A <em>TITLE</em> for the output map layer may be
+(optionally) specified by the user.
+<p>
+The reclass rules are read from standard input (i.e., from
+the keyboard, redirected from a file, or piped through
+another program).
+<p>
+Before using <em>r.reclass</em> the user must know the following:
+<ol>
+<li>The new categories desired; and, which old categories fit into
+which new categories.
+<li>The names of the new categories.
+</ol>
+<h2>INTERACTIVE PROGRAM USE: EXAMPLE</h2>
+Suppose we want to reclassify the raster map layer
+<em>roads</em>, consisting of five categories, into the
+three new categories: paved roads, unpaved roads, and
+railroad tracks. The user is asked whether the reclass
+table is to be established with each category value
+initially set to 0, or with each category value initially
+set to its own value. A screen like that shown below then
+appears, listing the categories of the <em>roads</em>
+raster map layer to be reclassified and prompting the user
+for the new category values to be assigned them.
+<p>
+<pre>
+ ENTER NEW CATEGORY NUMBERS FOR THESE CATEGORIES
+ OLD CATEGORY NAME OLD NEW
+ NUM NUM
+ no data 0 0___
+ Hard Surface, 2 lanes 1 0___
+ Loose Surface, 1 lane 2 0___
+ Improved Dirt 3 0___
+ Unimproved Dirt Trail 4 0___
+ Railroad, single track 5 0___
+ AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
+ (OR <Ctrl-C> TO CANCEL)
+</pre>
+In the following screen the new category values have been
+entered beside the appropriate old category names. Cells
+assigned category values 2, 3, and 4 in the old raster map
+layer are now assigned the new category value 2 in the
+reclassed map; cell data formerly assigned to category
+value 5 in the old raster map map are now assigned the new
+category value 3 in the reclassed map.
+<pre>
+ NUM NUM
+ no data 0 0___
+ Hard Surface, 2 lanes 1 1___
+ Loose Surface, 1 lane 2 2___
+ Improved Dirt 3 2___
+ Unimproved Dirt Trail 4 2___
+ Railroad, single track 5 3___
+</pre>
+Hitting the escape key <ESC> will bring up the
+following screen, which prompts the user to enter a new
+TITLE and category label for the newly <b>reclassed</b>
+categories.
+<pre>
+ ENTER NEW CATEGORY NAMES FOR THESE CATEGORIES
+ TITLE: Roads Reclassified
+ CAT NEW CATEGORY NAME
+ NUM
+ 0 no data
+ 1 Paved Roads
+ 2 Unpaved Roads
+ 3 Railroad, single track
+</pre>
+Based upon the information supplied by the user in the above sample screens,
+the new output map, supporting category, color, history, and header files
+are created.
+<h2>NON-INTERACTIVE PROGRAM USE: RECLASS RULES</h2>
+In non-interactive program use, the names of an input map, output map,
+and output map TITLE are given on the command line.
+However, the reclass rules are still read from standard input
+(i.e., from the keyboard, redirected
+from a file, or piped through another program).
+<p>
+Once the user has specified an input raster map layer,
+output map layer name, and (optionally) output map layer
+TITLE by typing
+<dl>
+<dd>
+<b>r.reclass input=</b><em>name </em><b>output=</b><em>name </em>[<b>TITLE=</b><em>name</em>]
+</dl>
+Each line of input must have the following format:
+<dl>
+<dd><b>input_categories=</b><em>output_category </em>[<em>label</em>]
+</dl>
+<p>
+where the input lines specify the category values in the
+input raster map layer to be reclassified to the new
+<em>output_category</em> category value. Specification of
+a <em>label</em> to be associated with the new output map
+layer category is optional. If specified, it is recorded
+as the category label for the new category value. The
+equal sign = is required. The <em>input_category(ies)</em>
+may consist of single category values or a range of such
+values in the format "<em>low</em> thru <em>high</em>." The
+word "thru" must be present.
+<p>
+To include all (remaining) values the asterix "*" can be used. This
+rule has to be set as last rule. No further rules are accepted after
+setting this rule.
+<p>
+No data have to be spcified with NULL.
+<p>
+A line containing only the word <b>end</b> terminates the
+input.
+<h2>NON-INTERACTIVE PROGRAM USE: EXAMPLES</h2>
+The following examples may help clarify the reclass rules.
+<p>
+<dt>
+<dd>1. This example reclassifies categories 1, 2 and 3 in the input raster
+map layer "roads" to category 1 with category label "good quality" in the output map
+layer, and reclassifies input raster map layer categories 4 and 5 to
+category 2 with the label "poor quality" in the output map layer.
+<pre>
+ 1 2 3 = 1 good quality
+ 4 5 = 2 poor quality
+</pre>
+<p>
+<dd>2. This example reclassifies input raster map layer categories 1 thru 10 to output
+map layer category 1, input map layer categories 11 thru 20 to output map layer
+category 2, and input map layer categories 21 thru 30 to output map layer
+category 3, all without labels. The range from 30 to 40 is reclassified as
+NULL.
+<pre>
+ 1 thru 10 = 1
+ 11 thru 20 = 2
+ 21 thru 30 = 3
+ 30 thru 40 = NULL
+</pre>
+<dd>3. Subsequent rules override previous rules. Therefore, the below example
+reclassifies input raster map layer categories 1 thru 19 and 51 thru 100
+to category 1 in the output map layer,
+input raster map layer categories 20 thru 24 and 26 thru 50 to
+the output map layer category 2, and input raster map layer category 25
+to the output category 3.
+<pre>
+ 1 thru 100 = 1 poor quality
+ 20 thru 50 = 2 medium quality
+ 25 = 3 good quality
+</pre>
+<dd>4. This example reclassifies categories 1, 3 and 5 in the input raster map layer to category 1 with category label "poor quality" in the output map layer,
+and reclassifies input raster map layer categories 2, 4, and 6
+to category 2 with the label "good quality" in the output map layer.
+All other values are reclassified to NULL.
+<pre>
+ 1 3 5 = 1 poor quality
+ 2 4 6 = 2 good quality
+ * = NULL
+</pre>
+<p>
+<dd>5. The previous example could also have been entered as:
+<pre>
+ 1 thru 19 51 thru 100 = 1 poor quality
+ 20 thru 24 26 thru 50 = 2 medium quality
+</pre>
+or as:
+<pre>
+ 1 thru 19 = 1 poor quality
+ 51 thru 100 = 1
+ 20 thru 24 = 2
+ 26 thru 50 = 2 medium quality
+</pre>
+</dd>
+<p>
+The final example was given to show how the labels are handled. If a new
+category value appears in more than one rule (as is the case with new
+category values 1 and 2),
+the last label which was specified becomes the label for that category.
+In this case the labels are assigned exactly as in the two previous examples.
+<h2>NOTES</h2>
+In fact, the <em>r.reclass</em> program does <em>not</em> generate any new
+raster map layers (in the interests of disk space conservation). Instead, a
+<b>reclass table</b> is stored which will be used to reclassify the
+original raster map layer each time the new (reclassed) map name
+is requested. As far as the user (and programmer) is concerned, that
+raster map has been created.
+Also note that although the user can generate a <em>r.reclass</em> map
+which is based on another <em>r.reclass</em> map,
+the new <em>r.reclass</em> map map will be stored in GRASS as a reclass
+of the <em>original</em> raster map on which the first reclassed map was
+based. Therefore, while GRASS allows the user to provide <em>r.reclass</em>
+map layer information which is based on an already reclassified map
+(for the user's convenience), no <em>r.reclass</em> map layer
+(i.e., <em>reclass table</em>) will ever be <em>stored</em>
+as a <em>r.reclass</em> of a <em>r.reclass</em>.
+<p>
+To convert a reclass map to a regular raster map layer, set your
+geographic region settings to match the settings in the header for the
+reclass map (an ASCII file found under the <em>cellhd</em> directory, or
+viewable by running <em><a href="r.support.html">r.support</a></em>) and then run <em><a href="r.resample.html">r.resample</a></em>.
+<p>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em> can be used to convert
+a reclass map to a regular raster map layer:
+<div class="code"><pre>
+ r.mapcalc raster_map=reclass_map
+</pre></div>
+<p>
+where <em>raster_map</em> is the name to be given to the new raster map,
+and <em>reclass_map</em> is an existing reclass map.
+<h2>BEWARE</h2>
+Because <em>r.reclass</em> generates a table referencing some original
+raster map layer rather than creating a reclassed raster map layer,
+a <em>r.reclass</em> map layer will no longer be accessible if
+the original raster map layer upon which it was based is later removed.
+<p>
+A <em>r.reclass</em> map is not a true raster map layer.
+Rather, it is a table of reclassification values which reference the
+input raster map layer. Therefore, users who wish to retain reclassified
+map layers must also save the original input raster map layers
+from which they were generated. Alternatively r.recode can be used.
+<p>
+Category values which are not explicitly reclassified to a new value
+by the user will be reclassified to NULL.
+<h2>SEE ALSO</h2>
+<em><a href="r.resample.html">r.resample</a></em>,
+<em><a href="r.rescale.html">r.rescale</a></em>,
+<em><a href="r.recode.html">r.recode</a></em>
+<h2>AUTHORS</h2>
+James Westervelt,
+<br>
+Michael Shapiro,
+<br>
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.recode/description.html
--- grass/trunk/raster/r.recode/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.recode/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,78 +0,0 @@
-<em>r.recode</em> creates an output map layer based on an input raster map
-layer. The output map layer will be a recoding of the input map layer based
-on recode rules input to <em>r.recode</em>. A <em>title</em> for the output
-map layer may be (optionally) specified by the user.<p>
-The recode rules are read from standard input (i.e., from the keyboard,
-redirected from a file, or piped through another program).<p>
-The program will be run non-interactively if the user specifies the name of
-the raster map layer to be recoded, the <em>name</em> of an output layer to
-hold recoded map, and (optionally) the name of a title for the output map.
-Rules are defined in one of these formats:
-<pre>
- old_low:old_high:new_low:new_high
- old_low:old_high:new_val (i.e. new_high == new_low)
- *:old_val:new_val (interval [inf, old_val])
- old_val:*:new_val (interval [old_val, inf])
-</pre>
-<em>r.recode</em> is loosely based on r.reclass and uses the GRASS reclass
-library to convert the rasters. It has routines for converting to every
-possible combination of raster (eg. int to double, double to float, etc).
-Standard floating point raster precision is float, with <em>-d</em> double
-precision will be written.<br>
-There are four basic routines that it accepts:
-<ol>
-<li>old-low to old-high is reclassed to new-low to new high , where the
-user provides all four values. The program figures on the fly what type of
-raster should be created.
-<li>old-low to old-high is reclassed to a single new value. Anything outside
-the range is null.
-<li> * to old-high will reclass everything less than old-high to a single
-new value.
-<li> old-low to * will reclass everything greater than old-low to a single
-new value.
-</ol>
-These four sets of arguments can be given on the command line, or piped via
-stdin or a file. More than one set of arguments is accepted.
-<h2>EXAMPLES</h2>
-<b>Map type conversion</b><br>
-To simply convert a raster between formats (eg. int to float) the user would
-use the first argument. For example <br>
-<tt>10:1500:0.1:15.0</tt><br>
- would convert an old raster with range between 10 and 1500 to a float
-raster with range bewteen 0.1 and 15.0. <p>
-<b>Value replacement</b><br>
-r.recode can be used to replace existing cell values by others. The
-formatting is as described above. In following example the values 1, 2 and
-3 are replaced by 1.1, 7.5 resp. 0.4:<br>
-<pre>
- r.recode in=oldmap out=newmap << EOF
- 1:1:1.1:1.1
- 2:2:7.5:7.5
- 3:3:0.4:0.4
- EOF
-</pre>
-<h2>AUTHOR</h2>
-CERL
Copied: grass/trunk/raster/r.recode/r.recode.html (from rev 32770, grass/trunk/raster/r.recode/description.html)
--- grass/trunk/raster/r.recode/r.recode.html (rev 0)
+++ grass/trunk/raster/r.recode/r.recode.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,78 @@
+<em>r.recode</em> creates an output map layer based on an input raster map
+layer. The output map layer will be a recoding of the input map layer based
+on recode rules input to <em>r.recode</em>. A <em>title</em> for the output
+map layer may be (optionally) specified by the user.<p>
+The recode rules are read from standard input (i.e., from the keyboard,
+redirected from a file, or piped through another program).<p>
+The program will be run non-interactively if the user specifies the name of
+the raster map layer to be recoded, the <em>name</em> of an output layer to
+hold recoded map, and (optionally) the name of a title for the output map.
+Rules are defined in one of these formats:
+<pre>
+ old_low:old_high:new_low:new_high
+ old_low:old_high:new_val (i.e. new_high == new_low)
+ *:old_val:new_val (interval [inf, old_val])
+ old_val:*:new_val (interval [old_val, inf])
+</pre>
+<em>r.recode</em> is loosely based on r.reclass and uses the GRASS reclass
+library to convert the rasters. It has routines for converting to every
+possible combination of raster (eg. int to double, double to float, etc).
+Standard floating point raster precision is float, with <em>-d</em> double
+precision will be written.<br>
+There are four basic routines that it accepts:
+<ol>
+<li>old-low to old-high is reclassed to new-low to new high , where the
+user provides all four values. The program figures on the fly what type of
+raster should be created.
+<li>old-low to old-high is reclassed to a single new value. Anything outside
+the range is null.
+<li> * to old-high will reclass everything less than old-high to a single
+new value.
+<li> old-low to * will reclass everything greater than old-low to a single
+new value.
+</ol>
+These four sets of arguments can be given on the command line, or piped via
+stdin or a file. More than one set of arguments is accepted.
+<h2>EXAMPLES</h2>
+<b>Map type conversion</b><br>
+To simply convert a raster between formats (eg. int to float) the user would
+use the first argument. For example <br>
+<tt>10:1500:0.1:15.0</tt><br>
+ would convert an old raster with range between 10 and 1500 to a float
+raster with range bewteen 0.1 and 15.0. <p>
+<b>Value replacement</b><br>
+r.recode can be used to replace existing cell values by others. The
+formatting is as described above. In following example the values 1, 2 and
+3 are replaced by 1.1, 7.5 resp. 0.4:<br>
+<pre>
+ r.recode in=oldmap out=newmap << EOF
+ 1:1:1.1:1.1
+ 2:2:7.5:7.5
+ 3:3:0.4:0.4
+ EOF
+</pre>
+<h2>AUTHOR</h2>
+CERL
Deleted: grass/trunk/raster/r.region/description.html
--- grass/trunk/raster/r.region/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.region/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,35 +0,0 @@
-The <em>r.region</em> program allows the user to manage the boundaries
-of a raster map. These boundaries can be set by the user directly
-and/or set from a region definition file (stored under the
-<kbd>windows</kbd> directory in the user's current mapset), a raster
-or vector map, or a 3dview file.
-<p>
-The <b>align</b> parameter allows to set the current resolution equal to
-that of the named raster map, and align the boundaries to a row and column
-edge in the named map. Alignment only moves the existing boundaries outward
-to the edges of the next nearest cell in the named raster map -- not to the
-named map's edges. To perform the latter function, use the
-<b>raster=</b><em>name</em> option.
-<h2>NOTE</h2>
-After all updates have been applied, the raster map's resolution
-settings are recomputed from the boundaries and the number of rows and
-columns in the raster map.
-<h2>SEE ALSO</h2>
-<em><a href="r.support.html">r.support</a></em><br>
-<em><a href="g.region.html">g.region</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements
-<br>
-Based upon g.region
Copied: grass/trunk/raster/r.region/r.region.html (from rev 32770, grass/trunk/raster/r.region/description.html)
--- grass/trunk/raster/r.region/r.region.html (rev 0)
+++ grass/trunk/raster/r.region/r.region.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,35 @@
+<h2>DESCRIPTION</h2>
+The <em>r.region</em> program allows the user to manage the boundaries
+of a raster map. These boundaries can be set by the user directly
+and/or set from a region definition file (stored under the
+<kbd>windows</kbd> directory in the user's current mapset), a raster
+or vector map, or a 3dview file.
+<p>
+The <b>align</b> parameter allows to set the current resolution equal to
+that of the named raster map, and align the boundaries to a row and column
+edge in the named map. Alignment only moves the existing boundaries outward
+to the edges of the next nearest cell in the named raster map -- not to the
+named map's edges. To perform the latter function, use the
+<b>raster=</b><em>name</em> option.
+<h2>NOTE</h2>
+After all updates have been applied, the raster map's resolution
+settings are recomputed from the boundaries and the number of rows and
+columns in the raster map.
+<h2>SEE ALSO</h2>
+<em><a href="r.support.html">r.support</a></em><br>
+<em><a href="g.region.html">g.region</a></em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<br>
+Based upon g.region
Deleted: grass/trunk/raster/r.report/description.html
--- grass/trunk/raster/r.report/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.report/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,98 +0,0 @@
-<em>r.report</em> allows the user to set up a series of report parameters to
-be applied to a raster map layer, and creates a report. If invoked with
-command line arguments, the report will print out to the screen only.
-However, output may be redirected to a file or another program using the
-UNIX redirection mechanism. If invoked without command line arguments, the
-user is given the option of printing out each report and/or saving output to
-a file.
-<p>
-The report itself consists of two parts, a header section and the main body
-of the report.
-<p>
-The header section of the report identifies the raster map layer(s) (by map
-layer name and TITLE), location, mapset, report date, and the region of
-interest. The area of interest is described in two parts: the user's current
-geographic region is presented, and the mask is presented (if any is used).
-<p>
-The main body of the report consists of from one to three tables which
-present the statistics for each category and the totals for each unit
-column.
-<p>
-Note that, unlike <em><a href="r.stats.html">r.stats</a></em>,
-<em>r.report</em> allows the user to select the specific units of measure in
-which statistics will be reported.
-<p>
-Following is the result of a <em>r.report</em> run on the raster map layer
-<em>geology</em> (located in the Spearfish, SD sample data base), with the
-units expressed in square miles and acres. Here, <em>r.report</em> output is
-directed into the file <em>report.file</em>.
-<h2>EXAMPLE:</h2>
-<dl>
-<dd>
-<b>r.report map=</b><em>geology</em> <b>units=</b><em>miles,acres</em> > <em>report.file </em>
-</dl>
-<pre>
- ____________________________________________________________
-| RASTER MAP CATEGORY REPORT |
-|____________________________________________________________|
-| north: 4928000.00 east: 609000.00 |
-| REGION: south: 4914000.00 west: 590000.00 |
-| res: 100.00 res: 100.00 |
-| MASK: none |
-| MAP: geology in PERMANENT |
-| Category Information | Acres Square |
-| # description | Miles |
-|________|_________________________|_________________________|
-| 0 | no data | 415.13| 0.65 |
-| 1 | metamorphic | 2597.02| 4.06 |
-| 2 | transition | 32.12| 0.05 |
-| 3 | igneous | 8117.24| 12.68 |
-| 4 | sandstone | 16691.60| 26.08 |
-| 5 | limestone | 13681.93| 21.38 |
-| 6 | shale | 10304.07| 16.10 |
-| 7 | sandy shale | 2517.95| 3.93 |
-| 8 | claysand | 3229.60| 5.05 |
-| 9 | sand | 8141.95| 12.72 |
-|__________________________________|___________|_____________|
-| TOTAL | 65728.60| 102.70 |
-</pre>
-<h2>NOTES</h2>
-If the user runs <em>r.report</em> interactively and saves the report output
-in a file, this file will be placed into the user's current working
-directory.
-<p>
-If the user runs <em>r.report</em> non-interactively, report output can be
-saved by redirecting it to a file or a printer using the UNIX redirection
-mechanism.
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a>,
-<a href="r.coin.html">r.coin</a>,
-<a href="r.describe.html">r.describe</a>,
-<a href="r.info.html">r.info</a>,
-<a href="r.stats.html">r.stats</a>,
-<a href="r.univar.html">r.univar</a>
-</em>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.report/r.report.html (from rev 32770, grass/trunk/raster/r.report/description.html)
--- grass/trunk/raster/r.report/r.report.html (rev 0)
+++ grass/trunk/raster/r.report/r.report.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,98 @@
+<em>r.report</em> allows the user to set up a series of report parameters to
+be applied to a raster map layer, and creates a report. If invoked with
+command line arguments, the report will print out to the screen only.
+However, output may be redirected to a file or another program using the
+UNIX redirection mechanism. If invoked without command line arguments, the
+user is given the option of printing out each report and/or saving output to
+a file.
+<p>
+The report itself consists of two parts, a header section and the main body
+of the report.
+<p>
+The header section of the report identifies the raster map layer(s) (by map
+layer name and TITLE), location, mapset, report date, and the region of
+interest. The area of interest is described in two parts: the user's current
+geographic region is presented, and the mask is presented (if any is used).
+<p>
+The main body of the report consists of from one to three tables which
+present the statistics for each category and the totals for each unit
+column.
+<p>
+Note that, unlike <em><a href="r.stats.html">r.stats</a></em>,
+<em>r.report</em> allows the user to select the specific units of measure in
+which statistics will be reported.
+<p>
+Following is the result of a <em>r.report</em> run on the raster map layer
+<em>geology</em> (located in the Spearfish, SD sample data base), with the
+units expressed in square miles and acres. Here, <em>r.report</em> output is
+directed into the file <em>report.file</em>.
+<h2>EXAMPLE:</h2>
+<dl>
+<dd>
+<b>r.report map=</b><em>geology</em> <b>units=</b><em>miles,acres</em> > <em>report.file </em>
+</dl>
+<pre>
+ ____________________________________________________________
+| RASTER MAP CATEGORY REPORT |
+| LOCATION: spearfish Fri Sep 2 09:20:09|
+|____________________________________________________________|
+| north: 4928000.00 east: 609000.00 |
+| REGION: south: 4914000.00 west: 590000.00 |
+| res: 100.00 res: 100.00 |
+| MASK: none |
+| MAP: geology in PERMANENT |
+| Category Information | Acres Square |
+| # description | Miles |
+|________|_________________________|_________________________|
+| 0 | no data | 415.13| 0.65 |
+| 1 | metamorphic | 2597.02| 4.06 |
+| 2 | transition | 32.12| 0.05 |
+| 3 | igneous | 8117.24| 12.68 |
+| 4 | sandstone | 16691.60| 26.08 |
+| 5 | limestone | 13681.93| 21.38 |
+| 6 | shale | 10304.07| 16.10 |
+| 7 | sandy shale | 2517.95| 3.93 |
+| 8 | claysand | 3229.60| 5.05 |
+| 9 | sand | 8141.95| 12.72 |
+|__________________________________|___________|_____________|
+| TOTAL | 65728.60| 102.70 |
+</pre>
+<h2>NOTES</h2>
+If the user runs <em>r.report</em> interactively and saves the report output
+in a file, this file will be placed into the user's current working
+directory.
+<p>
+If the user runs <em>r.report</em> non-interactively, report output can be
+saved by redirecting it to a file or a printer using the UNIX redirection
+mechanism.
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a>,
+<a href="r.coin.html">r.coin</a>,
+<a href="r.describe.html">r.describe</a>,
+<a href="r.info.html">r.info</a>,
+<a href="r.stats.html">r.stats</a>,
+<a href="r.univar.html">r.univar</a>
+</em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.resamp.interp/description.html
--- grass/trunk/raster/r.resamp.interp/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.resamp.interp/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,50 +0,0 @@
-<em>r.resamp.interp</em> resamples an input raster map by interpolating between
-the neighboring cells via a selectable resampling algorithm. All cells
-present in the neighborhood of the input raster cell must be non-null to
-generate a non-null cell in the output raster map. A choice of three
-interpolation methods is available; each uses the weighted values of a different
-number of adjacent cells in the input map to determine the value of each
-cell in the output map as follows:
-<ul>
-<li>nearest neighbour (1 cell)</li>
-<li>bilinear (4 cells)</li>
-<li>bicubic (16 cells)</li>
-</ul>
-This module is intended for reinterpolation of continuous data
-to a different resolution rather than for interpolation from scattered data
-(use the <em>v.surf.*</em> modules for that purpose).
-</p>
-<p>
-Note that for bilinear and bicubic interpolation,
-cells of the output raster that cannot be bounded by the appropriate number
-of input cell centers are set to NULL (NULL propagation). This could occur
-due to the input cells being outside the current region, being NULL or MASKed.
-</p>
-<h2>NOTES</h2>
-<p>
-For longitude-latitude databases, the interpolation algorithm is based on
-degree fractions, not on the absolute distances between cell centers. Any
-attempt to implement the latter would violate the integrity of the
-interpolation method.
-</p>
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.resamp.rst.html">r.resamp.rst</a></em>
-<em><a href="r.resamp.stats.html">r.resamp.stats</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements
Copied: grass/trunk/raster/r.resamp.interp/r.resamp.interp.html (from rev 32770, grass/trunk/raster/r.resamp.interp/description.html)
--- grass/trunk/raster/r.resamp.interp/r.resamp.interp.html (rev 0)
+++ grass/trunk/raster/r.resamp.interp/r.resamp.interp.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,50 @@
+<em>r.resamp.interp</em> resamples an input raster map by interpolating between
+the neighboring cells via a selectable resampling algorithm. All cells
+present in the neighborhood of the input raster cell must be non-null to
+generate a non-null cell in the output raster map. A choice of three
+interpolation methods is available; each uses the weighted values of a different
+number of adjacent cells in the input map to determine the value of each
+cell in the output map as follows:
+<ul>
+<li>nearest neighbour (1 cell)</li>
+<li>bilinear (4 cells)</li>
+<li>bicubic (16 cells)</li>
+</ul>
+This module is intended for reinterpolation of continuous data
+to a different resolution rather than for interpolation from scattered data
+(use the <em>v.surf.*</em> modules for that purpose).
+</p>
+<p>
+Note that for bilinear and bicubic interpolation,
+cells of the output raster that cannot be bounded by the appropriate number
+of input cell centers are set to NULL (NULL propagation). This could occur
+due to the input cells being outside the current region, being NULL or MASKed.
+</p>
+<h2>NOTES</h2>
+<p>
+For longitude-latitude databases, the interpolation algorithm is based on
+degree fractions, not on the absolute distances between cell centers. Any
+attempt to implement the latter would violate the integrity of the
+interpolation method.
+</p>
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.resamp.rst.html">r.resamp.rst</a></em>
+<em><a href="r.resamp.stats.html">r.resamp.stats</a></em>
+<h2>AUTHOR</h2>
+Glynn Clements
Deleted: grass/trunk/raster/r.resamp.rst/description.html
--- grass/trunk/raster/r.resamp.rst/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.resamp.rst/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,148 +0,0 @@
-<i>r.resamp.rst</i> reinterpolates the values a from given raster map (named
-<i>input</i>) to a new raster map (named <i>elev</i>).
-Reinterpolation (resampling) is done to higher, same or lower resolution
-specified by the <i>ew_res</i> and <i>ns_res</i> parameters.
-<p>
-All resulting raster maps are created using the settings of the current
-region (which may be different from that of the <i>input</i> raster map).
-<p>
-Optionally, and simultaneously with interpolation, topographic parameters
-are computed from an input raster map containing z-values of elevation/depth: slope,
-aspect, profile curvature (measured in the direction of steepest
-slope), tangential curvature (measured in the direction of a tangent to
-contour line) and/or mean curvature are computed from and saved as raster maps
-as specified by the options <i>slope, aspect, pcurv, tcurv, mcurv</i> respectively.
-<p>
-If the <i>-d</i> flag is set the program outputs partial derivatives fx, fy,
-fxx, fxy, and fyy instead of slope, aspect and curvatures.
-<p>
-For noisy data it is possible to define spatially variable smoothing
-by providing a raster map named by the <i>smooth</i> option containing
-smoothing parameters.
-With the smoothing parameter set to zero (<i>smooth</i> is not given or
-contains zero data), the resulting surface passes exactly through the data
-points.
-<p>
-The user can also define a raster map (named with <i>maskmap</i>) which will
-be used as a mask. The interpolation is skipped for cells which have zero
-or NULL value in the mask.
-<p>
-Zero values will be assigned to these cells in all output raster maps.
-<!-- is this still true???? -->
-<p>
-The <i>zmult</i> parameter allows the user to rescale the z-values which may
-be useful, e.g., for transformation of elevations given in feet to meters,
-so that the proper values of slopes and curvatures can be computed.
-The default value is 1.
-<p>
-A regularized spline with tension method is used for the interpolation.
-The <i>tension</i> parameter tunes the character of the resulting surface
-from thin plate to membrane. Higher values of tension parameter reduce the
-overshoots that can appear in surfaces with rapid change of gradient.
-<p>
-The <i>-t</i> flag can be set to use "dnorm independent tension".
-<!-- but what is "dnorm independent tension" ??? -->
-<p>
-The interpolation is performed for overlapping rectangular segments.
-The user can define the width of overlap (in number of cells) with
-the <i>overlap</i> option. The default value is 3.
-<br>
-<h2>NOTES</h2>
-<i>r.resamp.rst</i> uses regularized spline with tension for interpolation
-(as described in Mitasova and Mitas, 1993).
-<p>
-The region is temporarily changed while writing output files with desired
-resolution. Topographic parameters are computed in the same way as in
-the <i>v.surf.rst</i> module. (See also Mitasova and Hofierka, 1993)
-<p>
-The raster map used with the <i>smooth</i> option should contain variable
-smoothing parameters. These can be derived from errors, slope, etc. using
-the <i>r.mapcalc</i> module.
-<p>
-The program gives warning when significant overshoots appear and higher
-tension should be used. However, with tension set too high the resulting surface
-changes its behavior to a membrane (rubber sheet stretched over the data
-points resulting in a peak or pit in each given point and everywhere else
-the surface goes rapidly to trend). Smoothing can be used to reduce
-the overshoots. When overshoots occur the resulting <i>elev</i> file will
-have white color in the locations of overshoots since the color table for
-the output file is the same as colortable for raster input file.
-<p>
-The program checks the numerical stability of the algorithm by computation
-of values at given points, and prints the maximum difference found into the
-history file of raster map <i>elev</i> (view with <i>r.info</i>).
-An increase in tension is suggested if the difference is unacceptable.
-For computations with smoothing set to 0 this difference should be 0.
-With a smoothing parameter greater than zero the surface will not pass through
-the data points exactly, and the higher the parameter the closer the surface
-will be to the trend.
-<p>
-The program writes the values of parameters used in computation into
-the comment part of the <i>elev</i> map history file. Additionally the
-following values are also written to assist in the evaluation of results
-and choosing of suitable parameters:
-<ul>
-<li>minimum and maximum z values in the data file (zmin_data, zmax_data) and
-in the interpolated raster map (zmin_int, zmax_int),</li>
-<li>maximum difference between the given and interpolated z value at a given
-point (errtotal),</li>
-<li>rescaling parameter used for normalization (dnorm), which influences the
-tension.</li>
-</ul>
-<p>
-The program gives a warning when the user wants to interpolate outside
-the region given by the <i>input</i> raster map's header data. Zooming into the
-area where the points are is suggested in this case.
-<p>
-When a mask is used, the program uses all points in the given region for
-interpolation, including those in the area which is masked out, to ensure
-proper interpolation along the border of the mask. It therefore does not
-mask out the data points; if this is desirable, it must be done outside
-<i>r.resamp.rst</i> before processing.
-<h2>SEE ALSO</h2>
-<a href="g.region.html">g.region</a>,
-<a href="r.resample.html">r.resample</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.surf.contour.html">r.surf.contour</a>,
-<a href="v.surf.rst.html">v.surf.rst</a>
-<h2>AUTHORS</h2>
-<i>Original version of program (in FORTRAN):</i>
-<br>Lubos Mitas, NCSA, University of Illinois at Urbana Champaign, Il
-<br>Helena Mitasova, US Army CERL, Champaign, Illinois
-<p><i>Modified program (translated to C, adapted for GRASS , segmentation
-procedure):</i>
-<br>Irina Kosinovsky, US Army CERL.
-<br>Dave Gerdes, US Army CERL.
-<h2>REFERENCES</h2>
-Mitas, L., Mitasova, H., 1999, Spatial Interpolation. In: P.Longley, M.F.
-Goodchild, D.J. Maguire, D.W.Rhind (Eds.), Geographical Information Systems:
-Principles, Techniques, Management and Applications, Wiley, 481-492.
-<p>Mitasova, H. and Mitas, L., 1993. Interpolation by regularized spline
-with tension: I. Theory and implementation, Mathematical Geology No.25
-p.641-656.
-<p>Mitasova, H. and Hofierka, L., 1993. Interpolation by regularized spline
-with tension: II. Application to terrain modeling and surface geometry
-analysis, Mathematical Geology No.25 p.657-667.
-<p>Talmi, A. and Gilat, G., 1977. Method for smooth approximation
-of data, Journal of Computational Physics , 23, pp 93-123.
-<p>Wahba, G., 1990. Spline models for observational data, CNMS-NSF Regional
-Conference series in applied mathematics, 59, SIAM, Philadelphia, Pennsylvania.
Copied: grass/trunk/raster/r.resamp.rst/r.resamp.rst.html (from rev 32770, grass/trunk/raster/r.resamp.rst/description.html)
--- grass/trunk/raster/r.resamp.rst/r.resamp.rst.html (rev 0)
+++ grass/trunk/raster/r.resamp.rst/r.resamp.rst.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,148 @@
+<i>r.resamp.rst</i> reinterpolates the values a from given raster map (named
+<i>input</i>) to a new raster map (named <i>elev</i>).
+Reinterpolation (resampling) is done to higher, same or lower resolution
+specified by the <i>ew_res</i> and <i>ns_res</i> parameters.
+<p>
+All resulting raster maps are created using the settings of the current
+region (which may be different from that of the <i>input</i> raster map).
+<p>
+Optionally, and simultaneously with interpolation, topographic parameters
+are computed from an input raster map containing z-values of elevation/depth: slope,
+aspect, profile curvature (measured in the direction of steepest
+slope), tangential curvature (measured in the direction of a tangent to
+contour line) and/or mean curvature are computed from and saved as raster maps
+as specified by the options <i>slope, aspect, pcurv, tcurv, mcurv</i> respectively.
+<p>
+If the <i>-d</i> flag is set the program outputs partial derivatives fx, fy,
+fxx, fxy, and fyy instead of slope, aspect and curvatures.
+<p>
+For noisy data it is possible to define spatially variable smoothing
+by providing a raster map named by the <i>smooth</i> option containing
+smoothing parameters.
+With the smoothing parameter set to zero (<i>smooth</i> is not given or
+contains zero data), the resulting surface passes exactly through the data
+points.
+<p>
+The user can also define a raster map (named with <i>maskmap</i>) which will
+be used as a mask. The interpolation is skipped for cells which have zero
+or NULL value in the mask.
+<p>
+Zero values will be assigned to these cells in all output raster maps.
+<!-- is this still true???? -->
+<p>
+The <i>zmult</i> parameter allows the user to rescale the z-values which may
+be useful, e.g., for transformation of elevations given in feet to meters,
+so that the proper values of slopes and curvatures can be computed.
+The default value is 1.
+<p>
+A regularized spline with tension method is used for the interpolation.
+The <i>tension</i> parameter tunes the character of the resulting surface
+from thin plate to membrane. Higher values of tension parameter reduce the
+overshoots that can appear in surfaces with rapid change of gradient.
+<p>
+The <i>-t</i> flag can be set to use "dnorm independent tension".
+<!-- but what is "dnorm independent tension" ??? -->
+<p>
+The interpolation is performed for overlapping rectangular segments.
+The user can define the width of overlap (in number of cells) with
+the <i>overlap</i> option. The default value is 3.
+<br>
+<h2>NOTES</h2>
+<i>r.resamp.rst</i> uses regularized spline with tension for interpolation
+(as described in Mitasova and Mitas, 1993).
+<p>
+The region is temporarily changed while writing output files with desired
+resolution. Topographic parameters are computed in the same way as in
+the <i>v.surf.rst</i> module. (See also Mitasova and Hofierka, 1993)
+<p>
+The raster map used with the <i>smooth</i> option should contain variable
+smoothing parameters. These can be derived from errors, slope, etc. using
+the <i>r.mapcalc</i> module.
+<p>
+The program gives warning when significant overshoots appear and higher
+tension should be used. However, with tension set too high the resulting surface
+changes its behavior to a membrane (rubber sheet stretched over the data
+points resulting in a peak or pit in each given point and everywhere else
+the surface goes rapidly to trend). Smoothing can be used to reduce
+the overshoots. When overshoots occur the resulting <i>elev</i> file will
+have white color in the locations of overshoots since the color table for
+the output file is the same as colortable for raster input file.
+<p>
+The program checks the numerical stability of the algorithm by computation
+of values at given points, and prints the maximum difference found into the
+history file of raster map <i>elev</i> (view with <i>r.info</i>).
+An increase in tension is suggested if the difference is unacceptable.
+For computations with smoothing set to 0 this difference should be 0.
+With a smoothing parameter greater than zero the surface will not pass through
+the data points exactly, and the higher the parameter the closer the surface
+will be to the trend.
+<p>
+The program writes the values of parameters used in computation into
+the comment part of the <i>elev</i> map history file. Additionally the
+following values are also written to assist in the evaluation of results
+and choosing of suitable parameters:
+<ul>
+<li>minimum and maximum z values in the data file (zmin_data, zmax_data) and
+in the interpolated raster map (zmin_int, zmax_int),</li>
+<li>maximum difference between the given and interpolated z value at a given
+point (errtotal),</li>
+<li>rescaling parameter used for normalization (dnorm), which influences the
+tension.</li>
+</ul>
+<p>
+The program gives a warning when the user wants to interpolate outside
+the region given by the <i>input</i> raster map's header data. Zooming into the
+area where the points are is suggested in this case.
+<p>
+When a mask is used, the program uses all points in the given region for
+interpolation, including those in the area which is masked out, to ensure
+proper interpolation along the border of the mask. It therefore does not
+mask out the data points; if this is desirable, it must be done outside
+<i>r.resamp.rst</i> before processing.
+<h2>SEE ALSO</h2>
+<a href="g.region.html">g.region</a>,
+<a href="r.resample.html">r.resample</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.surf.contour.html">r.surf.contour</a>,
+<a href="v.surf.rst.html">v.surf.rst</a>
+<h2>AUTHORS</h2>
+<i>Original version of program (in FORTRAN):</i>
+<br>Lubos Mitas, NCSA, University of Illinois at Urbana Champaign, Il
+<br>Helena Mitasova, US Army CERL, Champaign, Illinois
+<p><i>Modified program (translated to C, adapted for GRASS , segmentation
+procedure):</i>
+<br>Irina Kosinovsky, US Army CERL.
+<br>Dave Gerdes, US Army CERL.
+<h2>REFERENCES</h2>
+Mitas, L., Mitasova, H., 1999, Spatial Interpolation. In: P.Longley, M.F.
+Goodchild, D.J. Maguire, D.W.Rhind (Eds.), Geographical Information Systems:
+Principles, Techniques, Management and Applications, Wiley, 481-492.
+<p>Mitasova, H. and Mitas, L., 1993. Interpolation by regularized spline
+with tension: I. Theory and implementation, Mathematical Geology No.25
+p.641-656.
+<p>Mitasova, H. and Hofierka, L., 1993. Interpolation by regularized spline
+with tension: II. Application to terrain modeling and surface geometry
+analysis, Mathematical Geology No.25 p.657-667.
+<p>Talmi, A. and Gilat, G., 1977. Method for smooth approximation
+of data, Journal of Computational Physics , 23, pp 93-123.
+<p>Wahba, G., 1990. Spline models for observational data, CNMS-NSF Regional
+Conference series in applied mathematics, 59, SIAM, Philadelphia, Pennsylvania.
Deleted: grass/trunk/raster/r.resamp.stats/description.html
--- grass/trunk/raster/r.resamp.stats/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.resamp.stats/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,32 +0,0 @@
-<p>
-<em>r.resamp.stats</em> fills a grid cell (raster) matrix with
-aggregated values generated from a set of input layer data points.
-</p>
-<p>
-Without the <em>-w</em> switch, the aggregate is computed over all of
-the input cells whose centers lie within the output cell.
-</p>
-<p>
-With the <em>-w</em> switch, the aggregate uses the values from all
-input cells which intersect the output cell, weighted according to the
-proportion of the source cell which lies inside the output cell. This
-is slower, but produces a more accurate result.
-</p>
-<h2>NOTES</h2>
-<h2>SEE ALSO</h2>
-<em><a href="r.resamp.interp.html">r.resamp.interp</a></em>
-<h2>AUTHOR</h2>
-Glynn Clements
-<p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.resamp.stats/r.resamp.stats.html (from rev 32770, grass/trunk/raster/r.resamp.stats/description.html)
--- grass/trunk/raster/r.resamp.stats/r.resamp.stats.html (rev 0)
+++ grass/trunk/raster/r.resamp.stats/r.resamp.stats.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,32 @@
+<p>
+<em>r.resamp.stats</em> fills a grid cell (raster) matrix with
+aggregated values generated from a set of input layer data points.
+</p>
+<p>
+Without the <em>-w</em> switch, the aggregate is computed over all of
+the input cells whose centers lie within the output cell.
+</p>
+<p>
+With the <em>-w</em> switch, the aggregate uses the values from all
+input cells which intersect the output cell, weighted according to the
+proportion of the source cell which lies inside the output cell. This
+is slower, but produces a more accurate result.
+</p>
+<h2>NOTES</h2>
+<h2>SEE ALSO</h2>
+<em><a href="r.resamp.interp.html">r.resamp.interp</a></em>
+<h2>AUTHOR</h2>
+Glynn Clements
Deleted: grass/trunk/raster/r.resample/description.html
--- grass/trunk/raster/r.resample/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.resample/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,49 +0,0 @@
-<em>r.resample</em> resamples the data values in a user-specified raster
-input map layer <em>name</em> (bounded by the current geographic region
-and masked by the current mask), and produces a new raster output map layer
-<em>name</em> containing the results of the resampling.
-The category values in the new raster output map layer will be the same
-as those in the original, except that the resolution and extent of the
-new raster output map layer will match those of the current geographic region
-settings (see <em><a href="g.region.html">g.region</a></em>).
-<em>r.resample</em> is intended for reinterpolation of continuous data
-<h2>NOTES</h2>
-The method by which resampling is conducted is "nearest neighbor"
-(see <em><a href="r.neighbors.html">r.neighbors</a></em>).
-The resulting raster map layer will have the same
-resolution as the resolution of the current geographic region
-(set using <em><a href="g.region.html">g.region</a></em>).
-<p>
-The resulting raster map layer may be identical to the original raster
-map layer. The <em>r.resample</em> program will copy the color table
-and history file associated with the original raster map
-layer for the resulting raster map layer and will create a modified
-category file which contains description of only those categories
-which appear in resampled file.
-<p>
-When the user resamples a GRASS <em>reclass</em> file, a true raster map
-is created by <em>r.resample</em>.
-<h2>SEE ALSO</h2>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.mfilter.html">r.mfilter</a></em>,
-<em><a href="r.neighbors.html">r.neighbors</a></em>,
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S.Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.resample/r.resample.html (from rev 32770, grass/trunk/raster/r.resample/description.html)
--- grass/trunk/raster/r.resample/r.resample.html (rev 0)
+++ grass/trunk/raster/r.resample/r.resample.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,49 @@
+<em>r.resample</em> resamples the data values in a user-specified raster
+input map layer <em>name</em> (bounded by the current geographic region
+and masked by the current mask), and produces a new raster output map layer
+<em>name</em> containing the results of the resampling.
+The category values in the new raster output map layer will be the same
+as those in the original, except that the resolution and extent of the
+new raster output map layer will match those of the current geographic region
+settings (see <em><a href="g.region.html">g.region</a></em>).
+<em>r.resample</em> is intended for reinterpolation of continuous data
+<h2>NOTES</h2>
+The method by which resampling is conducted is "nearest neighbor"
+(see <em><a href="r.neighbors.html">r.neighbors</a></em>).
+The resulting raster map layer will have the same
+resolution as the resolution of the current geographic region
+(set using <em><a href="g.region.html">g.region</a></em>).
+<p>
+The resulting raster map layer may be identical to the original raster
+map layer. The <em>r.resample</em> program will copy the color table
+and history file associated with the original raster map
+layer for the resulting raster map layer and will create a modified
+category file which contains description of only those categories
+which appear in resampled file.
+<p>
+When the user resamples a GRASS <em>reclass</em> file, a true raster map
+is created by <em>r.resample</em>.
+<h2>SEE ALSO</h2>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a href="r.mfilter.html">r.mfilter</a></em>,
+<em><a href="r.neighbors.html">r.neighbors</a></em>,
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S.Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.rescale/description.html
--- grass/trunk/raster/r.rescale/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.rescale/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,60 +0,0 @@
-The <em>r.rescale</em> program rescales the range of
-category values appearing in a raster map layer. A new
-raster map layer, and an appropriate category file and
-color table based upon the original raster map layer, are
-generated with category labels that reflect the original
-category values that produced each category. This command
-is useful for producing representations with a reduced
-number of categories from a raster map layer with a large
-range of category values (e.g., elevation).
-<em>Rescaled</em> map layers are appropriate for use in
-such GRASS programs as
-<em><a href="r.stats.html">r.stats</a></em>,
-<em><a href="r.report.html">r.report</a></em>, and
-<em><a href="r.coin.html">r.coin</a></em>.
-<h2>EXAMPLE</h2>
-To rescale an elevation raster map layer with category
-values ranging from 1090 meters to 1800 meters into the
-range 0-255, the following command line could be used:
-<dl>
-<dd>
-<b>r.rescale input=</b>elevation <b>from=</b>1090,1800 <b>output=</b>elevation.255 <b>to=</b>0,255
-</dl>
-<h2>NOTES</h2>
-Category values that fall beyond the input range will
-become NULL. This allows the user to select a subset of
-the full category value range for rescaling if desired.
-This also means that the user should know the category
-value range for the input raster map layer. The user can
-request the </b><em>r.rescale</em> program to determine
-this range, or can obtain it using the
-<em><a href="r.describe.html">r.describe</a></em> or <em><a href="r.info.html">r.info</a></em>
-command. If the category value range is determined using
-<em>r.rescale</em>, the input raster map layer is examined,
-and the minimum and maximum non-NULL category values are
-selected as the input range.
-<h2>SEE ALSO</h2>
-<em><a href="r.coin.html">r.coin</a></em>,
-<em><a href="r.describe.html">r.describe</a></em>,
-<em><a href="r.info.html">r.info</a></em>,
-<em><a href="r.reclass.html">r.reclass</a></em>,
-<h2>AUTHOR</h2>
-Michael Shapiro,
Copied: grass/trunk/raster/r.rescale/r.rescale.html (from rev 32770, grass/trunk/raster/r.rescale/description.html)
--- grass/trunk/raster/r.rescale/r.rescale.html (rev 0)
+++ grass/trunk/raster/r.rescale/r.rescale.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,60 @@
+The <em>r.rescale</em> program rescales the range of
+category values appearing in a raster map layer. A new
+raster map layer, and an appropriate category file and
+color table based upon the original raster map layer, are
+generated with category labels that reflect the original
+category values that produced each category. This command
+is useful for producing representations with a reduced
+number of categories from a raster map layer with a large
+range of category values (e.g., elevation).
+<em>Rescaled</em> map layers are appropriate for use in
+such GRASS programs as
+<em><a href="r.stats.html">r.stats</a></em>,
+<em><a href="r.report.html">r.report</a></em>, and
+<em><a href="r.coin.html">r.coin</a></em>.
+<h2>EXAMPLE</h2>
+To rescale an elevation raster map layer with category
+values ranging from 1090 meters to 1800 meters into the
+range 0-255, the following command line could be used:
+<dl>
+<dd>
+<b>r.rescale input=</b>elevation <b>from=</b>1090,1800 <b>output=</b>elevation.255 <b>to=</b>0,255
+</dl>
+<h2>NOTES</h2>
+Category values that fall beyond the input range will
+become NULL. This allows the user to select a subset of
+the full category value range for rescaling if desired.
+This also means that the user should know the category
+value range for the input raster map layer. The user can
+request the </b><em>r.rescale</em> program to determine
+this range, or can obtain it using the
+<em><a href="r.describe.html">r.describe</a></em> or <em><a href="r.info.html">r.info</a></em>
+command. If the category value range is determined using
+<em>r.rescale</em>, the input raster map layer is examined,
+and the minimum and maximum non-NULL category values are
+selected as the input range.
+<h2>SEE ALSO</h2>
+<em><a href="r.coin.html">r.coin</a></em>,
+<em><a href="r.describe.html">r.describe</a></em>,
+<em><a href="r.info.html">r.info</a></em>,
+<em><a href="r.reclass.html">r.reclass</a></em>,
+<h2>AUTHOR</h2>
+Michael Shapiro,
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.rescale.eq/description.html
--- grass/trunk/raster/r.rescale.eq/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.rescale.eq/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,61 +0,0 @@
-<h2>DESCRIPTION</h2>
-The <em>r.rescale.eq</em> program rescales the range of
-category values appearing in a raster map layer with equalized histogram.
-A new raster map layer, and an appropriate category file and
-<h2>EXAMPLE</h2>
-<dl>
-<dd>
-<b>r.rescale.eq input=</b>elevation <b>from=</b>1090,1800 <b>output=</b>elevation.255 <b>to=</b>0,255
-</dl>
-<h2>NOTES</h2>
-request the </b><em>r.rescale.eq</em> program to determine
-<em>r.rescale.eq</em>, the input raster map layer is examined,
-<h2>SEE ALSO</h2>
-<h2>AUTHOR</h2>
-Michael Shapiro,
Copied: grass/trunk/raster/r.rescale.eq/r.rescale.eq.html (from rev 32770, grass/trunk/raster/r.rescale.eq/description.html)
--- grass/trunk/raster/r.rescale.eq/r.rescale.eq.html (rev 0)
+++ grass/trunk/raster/r.rescale.eq/r.rescale.eq.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,61 @@
+The <em>r.rescale.eq</em> program rescales the range of
+category values appearing in a raster map layer with equalized histogram.
+A new raster map layer, and an appropriate category file and
+<h2>EXAMPLE</h2>
+<dl>
+<dd>
+<b>r.rescale.eq input=</b>elevation <b>from=</b>1090,1800 <b>output=</b>elevation.255 <b>to=</b>0,255
+</dl>
+<h2>NOTES</h2>
+request the </b><em>r.rescale.eq</em> program to determine
+<em>r.rescale.eq</em>, the input raster map layer is examined,
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Michael Shapiro,
Deleted: grass/trunk/raster/r.series/description.html
--- grass/trunk/raster/r.series/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.series/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,66 +0,0 @@
-<em>r.series</em> makes each output cell value a function of the values
-assigned to the corresponding cells in the input raster map layers.
-Following methods are available:
-<ul>
- <li>average: average value
- <li>count: count of non-NULL cells
- <li>median: median value
- <li>mode: most frequently occuring value
- <li>minimum: lowest value
- <li>maximum: highest value
- <li>range: range of values (max - min)
- <li>stddev: standard deviation
- <li>sum: sum of values
- <li>variance: statistical variance
- <li>diversity: number of different values
- <li>slope: linear regression slope
- <li>offset: linear regression offset
- <li>detcoeff: linear regression coefficient of determination
- <li>min_raster: raster map number with the minimum time-series value
- <li>max_raster: raster map number with the maximum time-series value
- </ul>
-<h2>NOTES</h2>
-With <em>-n</em> flag, any cell for which any of the corresponding input cells are
-NULL is automatically set to NULL (NULL propagation). The aggregate function is not
-called, so all methods behave this way with respect to the <em>-n</em> flag.
-<p>
-Without <em>-n</em> flag, the complete list of inputs for each cell (including
-NULLs) is passed to the aggregate function. Individual aggregates can
-handle data as they choose. Mostly, they just compute the aggregate
-over the non-NULL values, producing a NULL result only if all inputs
-are NULL.
-<p>
-The <em>min_raster</em> and <em>max_raster</em> methods generate a map with the
-number of the raster map that holds the minimum/maximum value of the
-time-series. The numbering starts at <em>0</em> up to <em>n</em> for the
-first and the last raster listed in <em>input=</em>, respectively.
-<h2>EXAMPLE</h2>
-Using <em>r.series</em> with wildcards:
-<br>
-<tt>r.series input="`g.mlist pattern='insitu_data.*' sep=,`"
- output=insitu_data.stddev method=stddev</tt>
-<p>
-Note the <em>g.mlist</em> script also supports regular expressions for
-selecting map names.
-<h2>SEE ALSO</h2>
-<em><a href="g.mlist.html">g.mlist</a></em>,
-<h2>AUTHOR</h2>
-Glynn Clements
Copied: grass/trunk/raster/r.series/r.series.html (from rev 32770, grass/trunk/raster/r.series/description.html)
--- grass/trunk/raster/r.series/r.series.html (rev 0)
+++ grass/trunk/raster/r.series/r.series.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,66 @@
+<em>r.series</em> makes each output cell value a function of the values
+assigned to the corresponding cells in the input raster map layers.
+Following methods are available:
+<ul>
+ <li>average: average value
+ <li>count: count of non-NULL cells
+ <li>median: median value
+ <li>mode: most frequently occuring value
+ <li>minimum: lowest value
+ <li>maximum: highest value
+ <li>range: range of values (max - min)
+ <li>stddev: standard deviation
+ <li>sum: sum of values
+ <li>variance: statistical variance
+ <li>diversity: number of different values
+ <li>slope: linear regression slope
+ <li>offset: linear regression offset
+ <li>detcoeff: linear regression coefficient of determination
+ <li>min_raster: raster map number with the minimum time-series value
+ <li>max_raster: raster map number with the maximum time-series value
+ </ul>
+<h2>NOTES</h2>
+With <em>-n</em> flag, any cell for which any of the corresponding input cells are
+NULL is automatically set to NULL (NULL propagation). The aggregate function is not
+called, so all methods behave this way with respect to the <em>-n</em> flag.
+<p>
+Without <em>-n</em> flag, the complete list of inputs for each cell (including
+NULLs) is passed to the aggregate function. Individual aggregates can
+handle data as they choose. Mostly, they just compute the aggregate
+over the non-NULL values, producing a NULL result only if all inputs
+are NULL.
+<p>
+The <em>min_raster</em> and <em>max_raster</em> methods generate a map with the
+number of the raster map that holds the minimum/maximum value of the
+time-series. The numbering starts at <em>0</em> up to <em>n</em> for the
+first and the last raster listed in <em>input=</em>, respectively.
+<h2>EXAMPLE</h2>
+Using <em>r.series</em> with wildcards:
+<br>
+<tt>r.series input="`g.mlist pattern='insitu_data.*' sep=,`"
+ output=insitu_data.stddev method=stddev</tt>
+<p>
+Note the <em>g.mlist</em> script also supports regular expressions for
+selecting map names.
+<h2>SEE ALSO</h2>
+<em><a href="g.mlist.html">g.mlist</a></em>,
+<h2>AUTHOR</h2>
+Glynn Clements
Deleted: grass/trunk/raster/r.slope.aspect/description.html
--- grass/trunk/raster/r.slope.aspect/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.slope.aspect/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,174 +0,0 @@
-<b>r.slope.aspect </b>generates raster maps of slope, aspect, curvatures and
-first and second order partial derivatives from a raster map of true
-elevation values. The user must specify the input <i>elevation</i> file name
-and at least one output file name. The user can also specify the
-<i>format</i> for slope (degrees, percent; default=degrees), and the
-<i>zfactor</i>: multiplicative factor to convert elevation units to meters;
-(default 1.0).
-<p>
-The <i>elevation</i> input raster map specified by the user must contain true
-elevation values, <b>not</b> rescaled or categorized data. If the elevation
-values are in feet or other units than meters (with a conversion factor
-<i>meters:</i>, defined in PROJ_UNITS), they must be converted to meters using
-the parameter <i>zfactor</i>.
-<p>
-The <i>aspect</i> output raster map indicates the direction that slopes are
-facing. The aspect categories represent the number degrees of east. Category
-and color table files are also generated for the aspect map layer. The aspect
-categories represent the number degrees of east and they increase
-counterclockwise: 90deg is North, 180 is West, 270 is South 360 is East. The
-aspect value 0 is used to indicate undefined aspect in flat areas with slope=0.
-<p>
-The <i>slope</i> output raster map contains slope values, stated in degrees of
-inclination from the horizontal if <i>format</i>=degrees option (the default)
-is chosen, and in percent rise if <i>format</i>=percent option is chosen.
-Category and color table files are generated.
-<p>
-Profile and tangential curvatures are the curvatures in the direction of
-steepest slope and in the direction of the contour tangent respectively. The
-curvatures are expressed as 1/metres, e.g. a curvature of 0.05 corresponds to a
-radius of curvature of 20m.
-<p>
-<table width="100%" border="0">
- <tr valign="baseline">
- <td>
- <div align="center">
- <img src="dem.png" border="1">
- <P>
- Example DEM
- <BR><BR>
- </div>
- </td>
- <td>
- </td>
- </tr>
- <td>
- <img src="slope.png" border="1">
- <P>
- Slope (degree) from example DEM
- <BR><BR>
- </div>
- </td>
- <td>
- <img src="aspect.png" border="1">
- <P>
- Aspect (degree) from example DEM
- <BR><BR>
- </div>
- </td>
- </tr>
- <td>
- <img src="tcurv.png" border="1">
- <P>
- Tangential curvature (m<sup>-1</sup>) from example DEM
- <BR><BR>
- </div>
- </td>
- <td>
- <img src="pcurv.png" border="1">
- <P>
- Profile curvature (m<sup>-1</sup>) from example DEM
- <BR><BR>
- </div>
- </td>
- <td>
- </td>
- </tr>
-</table>
-<p>
-For some applications, the user will wish to use a reclassified raster map
-of slope that groups slope values into ranges of slope. This can be done using
-<i><a href="r.reclass.html">r.reclass</a></i>. An example of a useful
-reclassification is given below:
-<div class="code"><pre> category range category labels
- (in degrees) (in percent)
- 1 0- 1 0- 2%
- 2 2- 3 3- 5%
- 3 4- 5 6- 10%
- 4 6- 8 11- 15%
- 5 9- 11 16- 20%
- 6 12- 14 21- 25%
- 7 15- 90 26% and higher
- The following color table works well with the above
- reclassification.
- category red green blue
- 0 179 179 179
- 1 0 102 0
- 2 0 153 0
- 3 128 153 0
- 4 204 179 0
- 5 128 51 51
- 6 255 0 0
- 7 0 0 0</pre></div>
-<h2>NOTES</h2>
-To ensure that the raster elevation map layer is not inappropriately resampled,
-the settings for the current region are modified slightly (for the execution
-of the program only): the resolution is set to match the resolution of
-the elevation map and the edges of the region (i.e. the north, south, east
-and west) are shifted, if necessary, to line up along edges of the nearest
-cells in the elevation map. If the user really wants the elevation map
-resampled to the current region resolution, the -a flag should be specified.
-<p>
-The current mask is ignored.
-<p>
-The algorithm used to determine slope and aspect uses a 3x3 neighborhood
-around each cell in the elevation file. Thus, it is not possible to determine
-slope and aspect for the cells adjacent to the edges in the elevation map
-layer. These cells are assigned a "zero slope" value (category 0) in both
-the slope and aspect raster map layers.
-<p>
-Horn's formula is used to find the derivatives in x and y directions.
-<p>
-Only when using integer elevation models, the aspect is biased in 0,
-45, 90, 180, 225, 270, 315, and 360 directions; i.e., the distribution
-of aspect categories is very uneven, with peaks at 0, 45,..., 360 categories.
-When working with floating point elevation models, no such aspect bias occurs.
-<p>
-Because most cells with a very small slope end up having category 0,
-45, ..., 360, it is sometimes possible to reduce the bias in these directions
-by filtering out the aspect in areas where the terrain is almost flat. A new
-option <i>min_slp_allowed</i> was added to specify the minimum slope for which
-aspect is computed. The aspect for all cells with slope <
-<i>min_slp_allowed</i> is set to <b>null</b>.
-<h2>REFERENCE</h2>
-Horn, B. K. P. (1981). Hill Shading and the Reflectance Map, Proceedings
-of the IEEE, 69(1):14-47.
-<h2>SEE ALSO</h2>
-<em><a href="r.rescale.html">r.rescale</a></em>
-<h2>AUTHORS</h2>
-Michael Shapiro, U.S.Army Construction Engineering Research Laboratory<BR>
-Olga Waupotitsch, U.S.Army Construction Engineering Research Laboratory
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.slope.aspect/r.slope.aspect.html (from rev 32770, grass/trunk/raster/r.slope.aspect/description.html)
--- grass/trunk/raster/r.slope.aspect/r.slope.aspect.html (rev 0)
+++ grass/trunk/raster/r.slope.aspect/r.slope.aspect.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,174 @@
+<b>r.slope.aspect </b>generates raster maps of slope, aspect, curvatures and
+first and second order partial derivatives from a raster map of true
+elevation values. The user must specify the input <i>elevation</i> file name
+and at least one output file name. The user can also specify the
+<i>format</i> for slope (degrees, percent; default=degrees), and the
+<i>zfactor</i>: multiplicative factor to convert elevation units to meters;
+(default 1.0).
+<p>
+The <i>elevation</i> input raster map specified by the user must contain true
+elevation values, <b>not</b> rescaled or categorized data. If the elevation
+values are in feet or other units than meters (with a conversion factor
+<i>meters:</i>, defined in PROJ_UNITS), they must be converted to meters using
+the parameter <i>zfactor</i>.
+<p>
+The <i>aspect</i> output raster map indicates the direction that slopes are
+facing. The aspect categories represent the number degrees of east. Category
+and color table files are also generated for the aspect map layer. The aspect
+categories represent the number degrees of east and they increase
+counterclockwise: 90deg is North, 180 is West, 270 is South 360 is East. The
+aspect value 0 is used to indicate undefined aspect in flat areas with slope=0.
+<p>
+The <i>slope</i> output raster map contains slope values, stated in degrees of
+inclination from the horizontal if <i>format</i>=degrees option (the default)
+is chosen, and in percent rise if <i>format</i>=percent option is chosen.
+Category and color table files are generated.
+<p>
+Profile and tangential curvatures are the curvatures in the direction of
+steepest slope and in the direction of the contour tangent respectively. The
+curvatures are expressed as 1/metres, e.g. a curvature of 0.05 corresponds to a
+radius of curvature of 20m.
+<p>
+<table width="100%" border="0">
+ <tr valign="baseline">
+ <td>
+ <div align="center">
+ <img src="dem.png" border="1">
+ <P>
+ Example DEM
+ <BR><BR>
+ </div>
+ </td>
+ <td>
+ </td>
+ </tr>
+ <td>
+ <img src="slope.png" border="1">
+ <P>
+ Slope (degree) from example DEM
+ <BR><BR>
+ </div>
+ </td>
+ <td>
+ <img src="aspect.png" border="1">
+ <P>
+ Aspect (degree) from example DEM
+ <BR><BR>
+ </div>
+ </td>
+ </tr>
+ <td>
+ <img src="tcurv.png" border="1">
+ <P>
+ Tangential curvature (m<sup>-1</sup>) from example DEM
+ <BR><BR>
+ </div>
+ </td>
+ <td>
+ <img src="pcurv.png" border="1">
+ <P>
+ Profile curvature (m<sup>-1</sup>) from example DEM
+ <BR><BR>
+ </div>
+ </td>
+ <td>
+ </td>
+ </tr>
+</table>
+<p>
+For some applications, the user will wish to use a reclassified raster map
+of slope that groups slope values into ranges of slope. This can be done using
+<i><a href="r.reclass.html">r.reclass</a></i>. An example of a useful
+reclassification is given below:
+<div class="code"><pre> category range category labels
+ (in degrees) (in percent)
+ 1 0- 1 0- 2%
+ 2 2- 3 3- 5%
+ 3 4- 5 6- 10%
+ 4 6- 8 11- 15%
+ 5 9- 11 16- 20%
+ 6 12- 14 21- 25%
+ 7 15- 90 26% and higher
+ The following color table works well with the above
+ reclassification.
+ category red green blue
+ 0 179 179 179
+ 1 0 102 0
+ 2 0 153 0
+ 3 128 153 0
+ 4 204 179 0
+ 5 128 51 51
+ 6 255 0 0
+ 7 0 0 0</pre></div>
+<h2>NOTES</h2>
+To ensure that the raster elevation map layer is not inappropriately resampled,
+the settings for the current region are modified slightly (for the execution
+of the program only): the resolution is set to match the resolution of
+the elevation map and the edges of the region (i.e. the north, south, east
+and west) are shifted, if necessary, to line up along edges of the nearest
+cells in the elevation map. If the user really wants the elevation map
+resampled to the current region resolution, the -a flag should be specified.
+<p>
+The current mask is ignored.
+<p>
+The algorithm used to determine slope and aspect uses a 3x3 neighborhood
+around each cell in the elevation file. Thus, it is not possible to determine
+slope and aspect for the cells adjacent to the edges in the elevation map
+layer. These cells are assigned a "zero slope" value (category 0) in both
+the slope and aspect raster map layers.
+<p>
+Horn's formula is used to find the derivatives in x and y directions.
+<p>
+Only when using integer elevation models, the aspect is biased in 0,
+45, 90, 180, 225, 270, 315, and 360 directions; i.e., the distribution
+of aspect categories is very uneven, with peaks at 0, 45,..., 360 categories.
+When working with floating point elevation models, no such aspect bias occurs.
+<p>
+Because most cells with a very small slope end up having category 0,
+45, ..., 360, it is sometimes possible to reduce the bias in these directions
+by filtering out the aspect in areas where the terrain is almost flat. A new
+option <i>min_slp_allowed</i> was added to specify the minimum slope for which
+aspect is computed. The aspect for all cells with slope <
+<i>min_slp_allowed</i> is set to <b>null</b>.
+<h2>REFERENCE</h2>
+Horn, B. K. P. (1981). Hill Shading and the Reflectance Map, Proceedings
+of the IEEE, 69(1):14-47.
+<h2>SEE ALSO</h2>
+<em><a href="r.rescale.html">r.rescale</a></em>
+<h2>AUTHORS</h2>
+Michael Shapiro, U.S.Army Construction Engineering Research Laboratory<BR>
+Olga Waupotitsch, U.S.Army Construction Engineering Research Laboratory
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.statistics/description.html
--- grass/trunk/raster/r.statistics/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.statistics/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,98 +0,0 @@
-<em>r.statistics</em> is a tool to analyse exploratory statistics of a "cover
-layer" according to how it intersects with objects in a "base layer". A
-variety of standard statistical measures are possible (called "zonal statistics"
-in some GIS).
-All cells in the base layer are considered one object for the analysis. For
-some applications, one will first want to prepare the input data so that
-all areas of contiguous cell category values in the base layer are uniquely
-identified, which can be done with <em>r.clump</em>.
-<br>
-The available methods are the following (english - german):
-<ul>
-<li>distribution - Verteilung in Prozent</li>
-<li>average - Durchschnitt</li>
-<li>mode - Modalwert</li>
-<li>median - Median</li>
-<li>average deviation - Durchschnittliche Abweichung</li>
-<li>standard deviation - Standardabweichung</li>
-<li>variance - Varianz</li>
-<li>skewness - Schiefe der Verteilung</li>
-<li>kurtosis - Relative Abflachung (-) oder Zuspitzung (+)</li>
-<li>minimum - Minimum</li>
-<li>maximum - Maximum</li>
-<li>sum - Summe</li>
-</ul>
-The calculations will be performed on each area of data of the
-cover layers which fall within each unique value, or category, of the base layer.
-<p>
-Setting the <em>-c</em> flag the category lables of the covering raster
-layer will be used. This is nice to avoid the GRASS limitation to interger
-in raster maps because using category values floating point numbers can be
-stored.
-<p>
-All calculations except "distribution" create an output layer. The output
-layer is a reclassified version of the base layer with identical
-category values, but modified category labels - the results of the calculations
-are stored in the category labels of the output layer.
-<p>
-For distributions, the output is printed to the user interface (stdout).
-If an output file name was specified, it will be ignored. The result will
-be a text table with three columns.
-In the first column are the category values of the base layer (a), in the second
-column the associated value of the cover layers (b), and in the third column the
-percentage of area in that base layer category (a) that falls into that row's
-value in the cover layer(b). Example:
-1 124 23
-1 201 47
-1 273 30
-2 101 5
-2 152 16
-2 167 60
-2 187 19
-</pre></div>
-So for the first line in the output above, we see that 23% of the cells of the
-base layer category 1 have a value of 124 in the cover layer.
-To transfer the values stored as category labels into cell values,
-<em>r.mapcalc</em> can be used ('@' operator).
-<h2>EXAMPLES</h2>
-Calculation of average elevation of each field in the Spearfish region:
-r.statistics base=fields cover=elevation.dem out=elevstats method=average
-r.category elevstats
-r.mapcalc "fieldelev=@elevstats"
-r.univar fieldelev
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.average.html">r.average</a>,
-<a href="r.clump.html">r.clump</a>,
-<a href="r.mode.html">r.mode</a>,
-<a href="r.median.html">r.median</a>,
-<a href="r.neighbors.html">r.neighbors</a>,
-<a href="r.category.html">r.category</a>
-</em>
-<h2>AUTHOR</h2>
-Martin Schroeder, Geographisches Institut Heidelberg, Germany
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/raster/r.statistics/r.statistics.html (from rev 32770, grass/trunk/raster/r.statistics/description.html)
--- grass/trunk/raster/r.statistics/r.statistics.html (rev 0)
+++ grass/trunk/raster/r.statistics/r.statistics.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,98 @@
+<em>r.statistics</em> is a tool to analyse exploratory statistics of a "cover
+layer" according to how it intersects with objects in a "base layer". A
+variety of standard statistical measures are possible (called "zonal statistics"
+in some GIS).
+All cells in the base layer are considered one object for the analysis. For
+some applications, one will first want to prepare the input data so that
+all areas of contiguous cell category values in the base layer are uniquely
+identified, which can be done with <em>r.clump</em>.
+<br>
+The available methods are the following (english - german):
+<ul>
+<li>distribution - Verteilung in Prozent</li>
+<li>average - Durchschnitt</li>
+<li>mode - Modalwert</li>
+<li>median - Median</li>
+<li>average deviation - Durchschnittliche Abweichung</li>
+<li>standard deviation - Standardabweichung</li>
+<li>variance - Varianz</li>
+<li>skewness - Schiefe der Verteilung</li>
+<li>kurtosis - Relative Abflachung (-) oder Zuspitzung (+)</li>
+<li>minimum - Minimum</li>
+<li>maximum - Maximum</li>
+<li>sum - Summe</li>
+</ul>
+The calculations will be performed on each area of data of the
+cover layers which fall within each unique value, or category, of the base layer.
+<p>
+Setting the <em>-c</em> flag the category lables of the covering raster
+layer will be used. This is nice to avoid the GRASS limitation to interger
+in raster maps because using category values floating point numbers can be
+stored.
+<p>
+All calculations except "distribution" create an output layer. The output
+layer is a reclassified version of the base layer with identical
+category values, but modified category labels - the results of the calculations
+are stored in the category labels of the output layer.
+<p>
+For distributions, the output is printed to the user interface (stdout).
+If an output file name was specified, it will be ignored. The result will
+be a text table with three columns.
+In the first column are the category values of the base layer (a), in the second
+column the associated value of the cover layers (b), and in the third column the
+percentage of area in that base layer category (a) that falls into that row's
+value in the cover layer(b). Example:
+1 124 23
+1 201 47
+1 273 30
+2 101 5
+2 152 16
+2 167 60
+2 187 19
+</pre></div>
+So for the first line in the output above, we see that 23% of the cells of the
+base layer category 1 have a value of 124 in the cover layer.
+To transfer the values stored as category labels into cell values,
+<em>r.mapcalc</em> can be used ('@' operator).
+<h2>EXAMPLES</h2>
+Calculation of average elevation of each field in the Spearfish region:
+r.statistics base=fields cover=elevation.dem out=elevstats method=average
+r.category elevstats
+r.mapcalc "fieldelev=@elevstats"
+r.univar fieldelev
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.average.html">r.average</a>,
+<a href="r.clump.html">r.clump</a>,
+<a href="r.mode.html">r.mode</a>,
+<a href="r.median.html">r.median</a>,
+<a href="r.neighbors.html">r.neighbors</a>,
+<a href="r.category.html">r.category</a>
+</em>
+<h2>AUTHOR</h2>
+Martin Schroeder, Geographisches Institut Heidelberg, Germany
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/raster/r.stats/description.html
--- grass/trunk/raster/r.stats/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.stats/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,89 +0,0 @@
-<em>r.stats</em> calculates the area present in each of the categories of
-user-selected raster map layer(s). Area statistics are given in units of
-square meters and/or cell counts. This analysis uses the current geographic
-region and mask settings. Output can be sent to a file in the user's current
-working directory.
-If a single map layer is specified on the command line, a list of areas in
-square meters (assuming the map's coordinate system is in meters) for each
-category in the raster map layer will be printed. (If the <em>-c</em> option
-is chosen, areas will be stated in number of cells.) If multiple raster map
-layers are specified on the command line, a cross-tabulation table of areas
-for each combination of categories in the map layers will be printed.
-<p>
-For example, if one raster map layer were specified, the output would look like:
-<pre>
- 1:1350000.00
- 2:4940000.00
- 3:8870000.00
-</pre>
-If three raster map layers <em>a, b</em>, and <em>c</em>, were specified,
-the output would look like:
-<pre>
- 0:0:0:8027500.00
- 0:1:0:1152500.00
- 1:0:0:164227500.00
- 1:0:1:2177500.00
- 1:1:0:140092500.00
- 1:1:1:3355000.00
- 2:0:0:31277500.00
- 2:0:1:2490000.00
- 2:1:0:24207500.00
- 2:1:1:1752500.00
- 3:0:0:17140000.00
- 3:1:0:11270000.00
- 3:1:1:2500.00
-</pre>
-Within each grouping, the first field represents the category value of map
-layer <em>a</em>, the second represents the category values associated with
-map layer <em>b</em>, the third represents category values for map layer
-<em>c</em>, and the last field gives the area in square meters for the
-particular combination of these three map layers' categories. For example,
-above, combination 3,1,1 covered 2500 square meters. Fields are separated by
-colons.
-<h2>NOTES</h2>
-<em>r.stats</em> works in the current geographic region with the current mask.
-<p>
-If a nicely formatted output is desired, pipe the output into a command
-which can create columnar output. For example, the command:
-<p>
- <b>r.stats input=</b>a,b,c | pr -3 | cat -s
-<p>
-will create a three-column output
-<pre>
-1:4:4:10000.00 2:1:5:290000.00 2:4:5:2090000.00
-1:4:5:1340000.00 2:2:5:350000.00 3:1:2:450000.00
-2:1:1:1090000.00 2:4:1:700000.00 3:1:3:5280000.00
-2:1:3:410000.00 2:4:3:10000.00 3:1:5:3140000.00
-</pre>
-The output from <em>r.stats</em> on more than one map layer is sorted.
-<p>
-Note that the user has only the option of printing out cell statistics in
-terms of cell counts and/or area totals. Users wishing to use different
-units than are available here should use the GRASS program
-<em><a href="r.report.html">r.report</a></em>.
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.report.html">r.report</a>,
-<a href="r.statistics.html">r.statistics</a>,
-</em>
-<h2>AUTHOR</h2>
-Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.stats/r.stats.html (from rev 32770, grass/trunk/raster/r.stats/description.html)
--- grass/trunk/raster/r.stats/r.stats.html (rev 0)
+++ grass/trunk/raster/r.stats/r.stats.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,89 @@
+<h2>DESCRIPTION</h2>
+<em>r.stats</em> calculates the area present in each of the categories of
+user-selected raster map layer(s). Area statistics are given in units of
+square meters and/or cell counts. This analysis uses the current geographic
+region and mask settings. Output can be sent to a file in the user's current
+working directory.
+If a single map layer is specified on the command line, a list of areas in
+square meters (assuming the map's coordinate system is in meters) for each
+category in the raster map layer will be printed. (If the <em>-c</em> option
+is chosen, areas will be stated in number of cells.) If multiple raster map
+layers are specified on the command line, a cross-tabulation table of areas
+for each combination of categories in the map layers will be printed.
+<p>
+For example, if one raster map layer were specified, the output would look like:
+<pre>
+ 1:1350000.00
+ 2:4940000.00
+ 3:8870000.00
+</pre>
+If three raster map layers <em>a, b</em>, and <em>c</em>, were specified,
+the output would look like:
+<pre>
+ 0:0:0:8027500.00
+ 0:1:0:1152500.00
+ 1:0:0:164227500.00
+ 1:0:1:2177500.00
+ 1:1:0:140092500.00
+ 1:1:1:3355000.00
+ 2:0:0:31277500.00
+ 2:0:1:2490000.00
+ 2:1:0:24207500.00
+ 2:1:1:1752500.00
+ 3:0:0:17140000.00
+ 3:1:0:11270000.00
+ 3:1:1:2500.00
+</pre>
+Within each grouping, the first field represents the category value of map
+layer <em>a</em>, the second represents the category values associated with
+map layer <em>b</em>, the third represents category values for map layer
+<em>c</em>, and the last field gives the area in square meters for the
+particular combination of these three map layers' categories. For example,
+above, combination 3,1,1 covered 2500 square meters. Fields are separated by
+colons.
+<h2>NOTES</h2>
+<em>r.stats</em> works in the current geographic region with the current mask.
+<p>
+If a nicely formatted output is desired, pipe the output into a command
+which can create columnar output. For example, the command:
+<p>
+ <b>r.stats input=</b>a,b,c | pr -3 | cat -s
+<p>
+will create a three-column output
+<pre>
+1:4:4:10000.00 2:1:5:290000.00 2:4:5:2090000.00
+1:4:5:1340000.00 2:2:5:350000.00 3:1:2:450000.00
+2:1:1:1090000.00 2:4:1:700000.00 3:1:3:5280000.00
+2:1:3:410000.00 2:4:3:10000.00 3:1:5:3140000.00
+</pre>
+The output from <em>r.stats</em> on more than one map layer is sorted.
+<p>
+Note that the user has only the option of printing out cell statistics in
+terms of cell counts and/or area totals. Users wishing to use different
+units than are available here should use the GRASS program
+<em><a href="r.report.html">r.report</a></em>.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.report.html">r.report</a>,
+<a href="r.statistics.html">r.statistics</a>,
+</em>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.sum/description.html
--- grass/trunk/raster/r.sum/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.sum/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,14 +0,0 @@
-<b><em>r.sum</em></b> sums up the raster cell values.
-For example, it can be used to summarize the population
-of a country. Using a raster MASK, raster areas can be
-easily selected for the summary.
-<h2>SEE ALSO</h2>
-<em><a href="r.surf.area.html">r.surf.area</a></em>
-<h2>AUTHOR</h2>
-<a href=mailto:brown at gis.uiuc.edu>Bill Brown</a>, UIUC GIS Laboratory
Copied: grass/trunk/raster/r.sum/r.sum.html (from rev 32770, grass/trunk/raster/r.sum/description.html)
--- grass/trunk/raster/r.sum/r.sum.html (rev 0)
+++ grass/trunk/raster/r.sum/r.sum.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,14 @@
+<b><em>r.sum</em></b> sums up the raster cell values.
+For example, it can be used to summarize the population
+of a country. Using a raster MASK, raster areas can be
+easily selected for the summary.
+<h2>SEE ALSO</h2>
+<em><a href="r.surf.area.html">r.surf.area</a></em>
+<h2>AUTHOR</h2>
+<a href=mailto:brown at gis.uiuc.edu>Bill Brown</a>, UIUC GIS Laboratory
Deleted: grass/trunk/raster/r.sun/description.html
--- grass/trunk/raster/r.sun/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.sun/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,272 +0,0 @@
-<b>r.sun</b> computes beam (direct), diffuse and ground reflected solar
-irradiation raster maps for given day, latitude, surface and atmospheric
-conditions. Solar parameters (e.g. time of sunrise and sunset, declination,
-extraterrestrial irradiance, daylight length) are stored in the resultant maps'
-history files. Alternatively, the local time can be specified to compute solar
-incidence angle and/or irradiance raster maps. The shadowing effect of the
-topography is optionally incorporated, a correction factor for shadowing to account
-for the earth curvature is internally calucated.<br>
-The units of the parameters are specified in brackets, a hyphen in the brackets
-explains that the parameter has no units.
-<p>
-For latitude-longitude coordinates it requires that the elevation map is in meters.
-The rules are:
-<ul>
-<li> lat/lon coordinates: elevation in meters;
-<li> Other coordinates: elevation in the same unit as the easting-northing coordinates.
-</ul>
-<p>
-The solar geometry of the model is based on the works of Krcho (1990), later
-improved by Jenco (1992). The equations describing Sun – Earth position as
-well as an interaction of the solar radiation with atmosphere were originally
-based on the formulas suggested by Kitler and Mikler (1986). This component
-was considerably updated by the results and suggestions of the working group
-co-ordinated by Scharmer and Greif (2000) (this algorithm might be replaced
-by SOLPOS algorithm-library included in GRASS within <a href="r.sunmask.html">
-r.sunmask</a>
- command). The model computes all three components of global radiation (beam,
-diffuse and reflected) for the clear sky conditions, i.e. not taking into
-consideration the spatial and temporal variation of clouds. The extent and
-spatial resolution of the modelled area, as well as integration over time,
-are limited only by the memory and data storage resources. The model is built
-to fulfil user needs in various fields of science (hydrology, climatology,
-ecology and environmental sciences, photovoltaics, engineering, etc.) for
-continental, regional up to the landscape scales.
-<p>As an option the model considers a shadowing effect of the local topography.
-The r.sun program works in two modes. In the first mode it calculates for the set
-local time a solar incidence angle [degrees] and solar irradiance values [W.m-2].
-In the second mode daily sums of solar radiation [Wh.m-2.day-1] are computed
-within a set day. By a scripting the two modes can be used separately or
-in a combination to provide estimates for any desired time interval. The
-model accounts for sky obstruction by local relief features. Several solar
-parameters are saved in the resultant maps' history files, which may be viewed
-with the <a href="r.info.html">r.info</a> command.
-</p>
-<p>The solar incidence angle raster map <i>incidout</i> is computed specifying
-elevation raster map <i>elevin</i>, aspect raster map <i>aspin</i>, slope
-steepness raster map <i>slopin,</i> given the day <i>day</i> and local time
-<i>time</i>. There is no need to define latitude for locations with known
-and defined projection/coordinate system (check it with the <a href="g.proj.html">
-g.proj</a>
- command). If you have undefined projection, (x,y) system, etc. then the latitude
-can be defined explicitely for large areas by input raster map <i>latin</i>
- with interpolated latitude values or, for smaller areas, a single region
-latitude value <i>lat</i> can be used instead. All input raster maps must
-be floating point (FCELL) raster maps. Null data in maps are excluded from
-the computation (and also speeding-up the computation), so each output raster
-map will contain null data in cells according to all input raster maps. The
-user can use <a href="r.null.html">r.null</a>
- command to create/reset null file for your input raster maps. <br>
-The specified day <i>day</i> is the number of the day of the general year
-where January 1 is day no.1 and December 31 is 365. Time <i>time</i> must
-be a local (solar) time (i.e. NOT a zone time, e.g. GMT, CET) in decimal system,
-e.g. 7.5 (= 7h 30m A.M.), 16.1 = 4h 6m P.M.. </p>
-<p>Setting the solar declination <i>declin</i> by user is an option to override
-the value computed by the internal routine for the day of the year. The value
-of geographical latitude can be set as a constant for the whole computed
-region or, as an option, a grid representing spatially distributed values
-over a large region. The geographical latitude must be also in decimal system
-with positive values for northern hemisphere and negative for southern one.
-In similar principle the Linke turbidity factor (<i>linkein</i>, <i>lin</i>
-) and ground albedo (<i>albedo</i>, <i>alb</i>) can be set. </p>
-<p>Besides clear-sky radiations, user can compute a real-sky radiation (beam,
-diffuse) using <i>coefbh</i> and <i>coefdh </i>input raster maps defining
-the fraction of the respective clear-sky radiations reduced by atmospheric
-factors (e.g. cloudiness). The value is between 0-1. Usually these
-coefficients can be obtained from a long-terms meteorological measurements.</p>
-<p>The solar irradiation or irradiance raster maps <i>beam_rad</i>, <i>diff_rad</i>
-, <i>refl_rad</i> are computed for a given day <i>day,</i> latitude <i>lat
-(latin), </i>elevation <i>elevin</i>, slope <i>slopein</i> and aspect <i>
-aspin</i> raster maps. The program uses the Linke atmosphere turbidity factor
-and ground albedo coefficient. A default, single value of Linke factor is
-<i>lin</i>=3.0 and is near the annual average for rural-city areas. The Linke
-factor for an absolutely clear atmosphere is <i>lin</i>=1.0. See notes below
-to learn more about this factor. The incidence solar angle is the angle between
-horizon and solar beam vector. The solar radiation maps for given day are
-computed integrating the relevant irradiance between sunrise and sunset times
-for given day. The user can set finer or coarser time step <i>step</i> used
-for all-day radiation calculations. A default value of <i>step</i> is 0.5
-hour. Larger steps (e.g. 1.0-2.0) can speed-up calculations but produce less
-reliable results. The output units are in Wh per squared meter per given
-day [Wh/(m*m)/day]. The incidence angle and irradiance/irradiation maps can
-be computed without shadowing influence of relief by default or they can
-be computed with this influence using the flag <i>-s</i>. In mountainous areas
-this can lead to very different results! The user should be aware that taken
-into account the shadowing effect of relief can slow
-down the speed of computing especially when the sun altitude is low.
- When considering shadowing effect (flag <i>-s</i>) speed and precision computing
-can be controlled by a parameter <i>dist</i> which defines the sampling density
-at which the visibility of a grid cell is computed in the direction of a
-path of the solar flow. It also defines the method by which the obstacle's
-altitude is computed. When choosing <i>dist</i> less than 1.0 (i.e. sampling
-points will be computed at <i>dist</i> * cellsize distance), r.sun takes
-altitude from the nearest grid point. Values above 1.0 will use the maximum
-altitude value found in the nearest 4 surrounding grid points. The default
-value <i>dist</i>=1.0 should give reasonable results for most cases (e.g.
-on DEM). <i>Dist</i> value defines a multiplying coefficient for sampling
-distance. This basic sampling distance equals to the arithmetic average of
-both cell sizes. The reasonable values are in the range 0.5-1.5. The values
-below 0.5 will decrease and values above 1.0 will increase the computing
-speed. Values greater than 2.0 may produce estimates with lower accuracy
-in highly dissected relief. The fully shadowed areas are written to the ouput
-maps as zero values. Areas with NULL data are considered as no barrier with
-shadowing effect .</p>
-<p>The maps' history files are generated containing the following listed
-parameters used in the computation: <br>
-- Solar constant 1367 W.m-2 <br>
-- Extraterrestrial irradiance on a plane perpendicular to the solar beam
-[W.m-2] <br>
-- Day of the year <br>
-- Declination [radians] <br>
-- Decimal hour (Alternative 1 only) <br>
-- Sunrise and sunset (min-max) over a horizontal plane <br>
-- Daylight lengths <br>
-- Geographical latitude (min-max) <br>
-- Linke turbidity factor (min-max) <br>
-- Ground albedo (min-max) </p>
-<p>The user can use a nice shellcript with variable
-day to compute radiation for some time interval within the year (e.g. vegetation
-or winter period). Elevation, aspect and slope input values should not be
-reclassified into coarser categories. This could lead to incorrect results.
-</p>
-<h2> OPTIONS</h2>
-<p>Currently, there are two modes of r.sun.
-In the first mode it calculates solar incidence angle and solar irradiance
-raster maps using the set local time. In the second mode daily sums of solar
-irradiation [Wh.m-2.day-1] are computed for a specified day.</p>
-<h2>
-NOTES</h2>
-Solar energy is an important input parameter in different models concerning
-energy industry, landscape, vegetation, evapotranspiration, snowmelt or remote
-sensing. Solar rays incidence angle maps can be effectively used in radiometric
-and topographic corrections in mountainous and hilly terrain where very accurate
-investigations should be performed.
-<p>
-The clear-sky solar radiation model applied in the r.sun is based on the
-work undertaken for development of European Solar Radiation Atlas (Scharmer
-and Greif 2000, Page et al. 2001, Rigollier 2001). The clear sky model estimates
-the global radiation from the sum of its beam, diffuse and reflected components.
-The main difference between solar radiation models for inclined surfaces
-in Europe is the treatment of the diffuse component. In the European climate
-this component is often the largest source of estimation error. Taking into
-consideration the existing models and their limitation the European Solar
-Radiation Atlas team selected the Muneer (1990) model as it has a sound theoretical
-basis and thus more potential for later improvement. </p>
-<p>
-Details of underlying equations used in this program can be found in the
-reference literature cited below or book published by Neteler and Mitasova:
-Open Source GIS: A GRASS GIS Approach (published in Kluwer Academic Publishers
-in 2002). </p>
-<p>
-Average monthly values of the Linke turbidity coefficient for a mild climate
-(see reference literature for your study area): </p>
-<pre>
-Month Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec annual<br>
-mountains 1.5 1.6 1.8 1.9 2.0 2.3 2.3 2.3 2.1 1.8 1.6 1.5 1.90 <br>
-rural 2.1 2.2 2.5 2.9 3.2 3.4 3.5 3.3 2.9 2.6 2.3 2.2 2.75 <br>
-city 3.1 3.2 3.5 4.0 4.2 4.3 4.4 4.3 4.0 3.6 3.3 3.1 3.75 <br>
-industrial 4.1 4.3 4.7 5.3 5.5 5.7 5.8 5.7 5.3 4.9 4.5 4.2 5.00
-</pre>
-<p>
-Planned improvements include the use of the SOLPOS algorithm for solar
-geometry calculations and internal computation of aspect and slope.
-<h3>Shadow maps</h3>
-A map of shadows can be extracted from the solar incidence angle map
-(incidout). Areas with zero values are shadowed. The <em>-s</em> flag
-has to be used.
-<h2>EXAMPLE</h2>
-Nice looking maps can be created with the model's output as follows:
-g.region rast=elevation.dem
-r.sun -s elev=elevation.dem slop=slope asp=aspect beam=beam_map day=180
-r.colors beam_map col=grey
-d.his i_map=beam_map h_map=elevation.dem
-</pre></div>
-<h2>SEE ALSO</h2>
-<a href="r.slope.aspect.html">r.slope.aspect</a>,
-<a href="r.sunmask.html">r.sunmask</a>,
-<a href="g.proj.html">g.proj</a>,
-<a href="r.null.html">r.null</a>,
-<a href="v.surf.rst.html">v.surf.rst</a>
-<h2>REFERENCES</h2>
-Hofierka, J., Suri, M. (2002): The solar radiation model for Open source
-GIS: implementation and applications. Manuscript submitted to the International
-GRASS users conference in Trento, Italy, September 2002.
-<p>
-Hofierka, J. (1997). Direct solar radiation modelling within an open GIS
-environment. Proceedings of JEC-GI'97 conference in Vienna, Austria, IOS
-Press Amsterdam, 575-584. </p>
-<p>
-Jenco, M. (1992). Distribution of direct solar radiation on georelief and
-its modelling by means of complex digital model of terrain (in Slovak). Geograficky
-casopis, 44, 342-355. </p>
-<p>
-Kasten, F. (1996). The Linke turbidity factor based on improved values of
-the integral Rayleigh optical thickness. Solar Energy, 56 (3), 239-244. </p>
-<p>
-Kasten, F., Young, A. T. (1989). Revised optical air mass tables and approximation
-formula. Applied Optics, 28, 4735-4738. </p>
-<p>
-Kittler, R., Mikler, J. (1986): Basis of the utilization of solar radiation
-(in Slovak). VEDA, Bratislava, p. 150. </p>
-<p>
-Krcho, J. (1990). Morfometrická analza a digitálne modely georeliéfu
-(Morphometric analysis and digital models of georelief, in Slovak).
-VEDA, Bratislava.</p>
-<p>
-Muneer, T. (1990). Solar radiation model for Europe. Building services engineering
-research and technology, 11, 4, 153-163. </p>
-<p>
-Neteler, M., Mitasova, H. (2002): Open Source GIS: A GRASS GIS Approach, Kluwer
-Academic Publishers. </p>
-<p>
-Page, J. ed. (1986). Prediction of solar radiation on inclined surfaces. Solar
-energy R&D in the European Community, series F – Solar radiation data,
-Dordrecht (D. Reidel), 3, 71, 81-83. </p>
-<p>
-Page, J., Albuisson, M., Wald, L. (2001). The European solar radiation atlas:
-a valuable digital tool. Solar Energy, 71, 81-83. </p>
-<p>
-Rigollier, Ch., Bauer, O., Wald, L. (2000). On the clear sky model of the
-ESRA - European Solar radiation Atlas - with respect to the Heliosat method.
-Solar energy, 68, 33-48. </p>
-<p>
-Scharmer, K., Greif, J., eds., (2000). The European solar radiation atlas,
-Vol. 2: Database and exploitation software. Paris (Les Presses de l’ École
-des Mines). </p>
-<p>Joint Research Centre: <a href="http://re.jrc.ec.europa.eu/pvgis/">GIS solar radiation database for Europe</a> and
-<a href="http://re.jrc.ec.europa.eu/pvgis/solres/solmod3.htm">Solar radiation and GIS</a>
-</p>
-<h2>AUTHORS</h2>
-Jaroslav Hofierka, GeoModel, s.r.o. Bratislava, Slovakia <br>
-Marcel Suri, GeoModel, s.r.o. Bratislava, Slovakia <br>
-Thomas Huld, JRC, Italy <br>
-© 2002, Jaroslav Hofierka, Marcel Suri
-<address>
-<a href="MAILTO:hofi at geomodel.sk">hofierka at geomodel.sk</a>
-<a href="MAILTO:suri at geomodel.sk">suri at geomodel.sk</a>
-</address>
-<p><i>Last changed: $Date$</i> </p>
Copied: grass/trunk/raster/r.sun/r.sun.html (from rev 32770, grass/trunk/raster/r.sun/description.html)
--- grass/trunk/raster/r.sun/r.sun.html (rev 0)
+++ grass/trunk/raster/r.sun/r.sun.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,272 @@
+<b>r.sun</b> computes beam (direct), diffuse and ground reflected solar
+irradiation raster maps for given day, latitude, surface and atmospheric
+conditions. Solar parameters (e.g. time of sunrise and sunset, declination,
+extraterrestrial irradiance, daylight length) are stored in the resultant maps'
+history files. Alternatively, the local time can be specified to compute solar
+incidence angle and/or irradiance raster maps. The shadowing effect of the
+topography is optionally incorporated, a correction factor for shadowing to account
+for the earth curvature is internally calucated.<br>
+The units of the parameters are specified in brackets, a hyphen in the brackets
+explains that the parameter has no units.
+<p>
+For latitude-longitude coordinates it requires that the elevation map is in meters.
+The rules are:
+<ul>
+<li> lat/lon coordinates: elevation in meters;
+<li> Other coordinates: elevation in the same unit as the easting-northing coordinates.
+</ul>
+<p>
+The solar geometry of the model is based on the works of Krcho (1990), later
+improved by Jenco (1992). The equations describing Sun – Earth position as
+well as an interaction of the solar radiation with atmosphere were originally
+based on the formulas suggested by Kitler and Mikler (1986). This component
+was considerably updated by the results and suggestions of the working group
+co-ordinated by Scharmer and Greif (2000) (this algorithm might be replaced
+by SOLPOS algorithm-library included in GRASS within <a href="r.sunmask.html">
+r.sunmask</a>
+ command). The model computes all three components of global radiation (beam,
+diffuse and reflected) for the clear sky conditions, i.e. not taking into
+consideration the spatial and temporal variation of clouds. The extent and
+spatial resolution of the modelled area, as well as integration over time,
+are limited only by the memory and data storage resources. The model is built
+to fulfil user needs in various fields of science (hydrology, climatology,
+ecology and environmental sciences, photovoltaics, engineering, etc.) for
+continental, regional up to the landscape scales.
+<p>As an option the model considers a shadowing effect of the local topography.
+The r.sun program works in two modes. In the first mode it calculates for the set
+local time a solar incidence angle [degrees] and solar irradiance values [W.m-2].
+In the second mode daily sums of solar radiation [Wh.m-2.day-1] are computed
+within a set day. By a scripting the two modes can be used separately or
+in a combination to provide estimates for any desired time interval. The
+model accounts for sky obstruction by local relief features. Several solar
+parameters are saved in the resultant maps' history files, which may be viewed
+with the <a href="r.info.html">r.info</a> command.
+</p>
+<p>The solar incidence angle raster map <i>incidout</i> is computed specifying
+elevation raster map <i>elevin</i>, aspect raster map <i>aspin</i>, slope
+steepness raster map <i>slopin,</i> given the day <i>day</i> and local time
+<i>time</i>. There is no need to define latitude for locations with known
+and defined projection/coordinate system (check it with the <a href="g.proj.html">
+g.proj</a>
+ command). If you have undefined projection, (x,y) system, etc. then the latitude
+can be defined explicitely for large areas by input raster map <i>latin</i>
+ with interpolated latitude values or, for smaller areas, a single region
+latitude value <i>lat</i> can be used instead. All input raster maps must
+be floating point (FCELL) raster maps. Null data in maps are excluded from
+the computation (and also speeding-up the computation), so each output raster
+map will contain null data in cells according to all input raster maps. The
+user can use <a href="r.null.html">r.null</a>
+ command to create/reset null file for your input raster maps. <br>
+The specified day <i>day</i> is the number of the day of the general year
+where January 1 is day no.1 and December 31 is 365. Time <i>time</i> must
+be a local (solar) time (i.e. NOT a zone time, e.g. GMT, CET) in decimal system,
+e.g. 7.5 (= 7h 30m A.M.), 16.1 = 4h 6m P.M.. </p>
+<p>Setting the solar declination <i>declin</i> by user is an option to override
+the value computed by the internal routine for the day of the year. The value
+of geographical latitude can be set as a constant for the whole computed
+region or, as an option, a grid representing spatially distributed values
+over a large region. The geographical latitude must be also in decimal system
+with positive values for northern hemisphere and negative for southern one.
+In similar principle the Linke turbidity factor (<i>linkein</i>, <i>lin</i>
+) and ground albedo (<i>albedo</i>, <i>alb</i>) can be set. </p>
+<p>Besides clear-sky radiations, user can compute a real-sky radiation (beam,
+diffuse) using <i>coefbh</i> and <i>coefdh </i>input raster maps defining
+the fraction of the respective clear-sky radiations reduced by atmospheric
+factors (e.g. cloudiness). The value is between 0-1. Usually these
+coefficients can be obtained from a long-terms meteorological measurements.</p>
+<p>The solar irradiation or irradiance raster maps <i>beam_rad</i>, <i>diff_rad</i>
+, <i>refl_rad</i> are computed for a given day <i>day,</i> latitude <i>lat
+(latin), </i>elevation <i>elevin</i>, slope <i>slopein</i> and aspect <i>
+aspin</i> raster maps. The program uses the Linke atmosphere turbidity factor
+and ground albedo coefficient. A default, single value of Linke factor is
+<i>lin</i>=3.0 and is near the annual average for rural-city areas. The Linke
+factor for an absolutely clear atmosphere is <i>lin</i>=1.0. See notes below
+to learn more about this factor. The incidence solar angle is the angle between
+horizon and solar beam vector. The solar radiation maps for given day are
+computed integrating the relevant irradiance between sunrise and sunset times
+for given day. The user can set finer or coarser time step <i>step</i> used
+for all-day radiation calculations. A default value of <i>step</i> is 0.5
+hour. Larger steps (e.g. 1.0-2.0) can speed-up calculations but produce less
+reliable results. The output units are in Wh per squared meter per given
+day [Wh/(m*m)/day]. The incidence angle and irradiance/irradiation maps can
+be computed without shadowing influence of relief by default or they can
+be computed with this influence using the flag <i>-s</i>. In mountainous areas
+this can lead to very different results! The user should be aware that taken
+into account the shadowing effect of relief can slow
+down the speed of computing especially when the sun altitude is low.
+ When considering shadowing effect (flag <i>-s</i>) speed and precision computing
+can be controlled by a parameter <i>dist</i> which defines the sampling density
+at which the visibility of a grid cell is computed in the direction of a
+path of the solar flow. It also defines the method by which the obstacle's
+altitude is computed. When choosing <i>dist</i> less than 1.0 (i.e. sampling
+points will be computed at <i>dist</i> * cellsize distance), r.sun takes
+altitude from the nearest grid point. Values above 1.0 will use the maximum
+altitude value found in the nearest 4 surrounding grid points. The default
+value <i>dist</i>=1.0 should give reasonable results for most cases (e.g.
+on DEM). <i>Dist</i> value defines a multiplying coefficient for sampling
+distance. This basic sampling distance equals to the arithmetic average of
+both cell sizes. The reasonable values are in the range 0.5-1.5. The values
+below 0.5 will decrease and values above 1.0 will increase the computing
+speed. Values greater than 2.0 may produce estimates with lower accuracy
+in highly dissected relief. The fully shadowed areas are written to the ouput
+maps as zero values. Areas with NULL data are considered as no barrier with
+shadowing effect .</p>
+<p>The maps' history files are generated containing the following listed
+parameters used in the computation: <br>
+- Solar constant 1367 W.m-2 <br>
+- Extraterrestrial irradiance on a plane perpendicular to the solar beam
+[W.m-2] <br>
+- Day of the year <br>
+- Declination [radians] <br>
+- Decimal hour (Alternative 1 only) <br>
+- Sunrise and sunset (min-max) over a horizontal plane <br>
+- Daylight lengths <br>
+- Geographical latitude (min-max) <br>
+- Linke turbidity factor (min-max) <br>
+- Ground albedo (min-max) </p>
+<p>The user can use a nice shellcript with variable
+day to compute radiation for some time interval within the year (e.g. vegetation
+or winter period). Elevation, aspect and slope input values should not be
+reclassified into coarser categories. This could lead to incorrect results.
+</p>
+<h2> OPTIONS</h2>
+<p>Currently, there are two modes of r.sun.
+In the first mode it calculates solar incidence angle and solar irradiance
+raster maps using the set local time. In the second mode daily sums of solar
+irradiation [Wh.m-2.day-1] are computed for a specified day.</p>
+<h2>
+NOTES</h2>
+Solar energy is an important input parameter in different models concerning
+energy industry, landscape, vegetation, evapotranspiration, snowmelt or remote
+sensing. Solar rays incidence angle maps can be effectively used in radiometric
+and topographic corrections in mountainous and hilly terrain where very accurate
+investigations should be performed.
+<p>
+The clear-sky solar radiation model applied in the r.sun is based on the
+work undertaken for development of European Solar Radiation Atlas (Scharmer
+and Greif 2000, Page et al. 2001, Rigollier 2001). The clear sky model estimates
+the global radiation from the sum of its beam, diffuse and reflected components.
+The main difference between solar radiation models for inclined surfaces
+in Europe is the treatment of the diffuse component. In the European climate
+this component is often the largest source of estimation error. Taking into
+consideration the existing models and their limitation the European Solar
+Radiation Atlas team selected the Muneer (1990) model as it has a sound theoretical
+basis and thus more potential for later improvement. </p>
+<p>
+Details of underlying equations used in this program can be found in the
+reference literature cited below or book published by Neteler and Mitasova:
+Open Source GIS: A GRASS GIS Approach (published in Kluwer Academic Publishers
+in 2002). </p>
+<p>
+Average monthly values of the Linke turbidity coefficient for a mild climate
+(see reference literature for your study area): </p>
+<pre>
+Month Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec annual<br>
+mountains 1.5 1.6 1.8 1.9 2.0 2.3 2.3 2.3 2.1 1.8 1.6 1.5 1.90 <br>
+rural 2.1 2.2 2.5 2.9 3.2 3.4 3.5 3.3 2.9 2.6 2.3 2.2 2.75 <br>
+city 3.1 3.2 3.5 4.0 4.2 4.3 4.4 4.3 4.0 3.6 3.3 3.1 3.75 <br>
+industrial 4.1 4.3 4.7 5.3 5.5 5.7 5.8 5.7 5.3 4.9 4.5 4.2 5.00
+</pre>
+<p>
+Planned improvements include the use of the SOLPOS algorithm for solar
+geometry calculations and internal computation of aspect and slope.
+<h3>Shadow maps</h3>
+A map of shadows can be extracted from the solar incidence angle map
+(incidout). Areas with zero values are shadowed. The <em>-s</em> flag
+has to be used.
+<h2>EXAMPLE</h2>
+Nice looking maps can be created with the model's output as follows:
+g.region rast=elevation.dem
+r.sun -s elev=elevation.dem slop=slope asp=aspect beam=beam_map day=180
+r.colors beam_map col=grey
+d.his i_map=beam_map h_map=elevation.dem
+</pre></div>
+<h2>SEE ALSO</h2>
+<a href="r.slope.aspect.html">r.slope.aspect</a>,
+<a href="r.sunmask.html">r.sunmask</a>,
+<a href="g.proj.html">g.proj</a>,
+<a href="r.null.html">r.null</a>,
+<a href="v.surf.rst.html">v.surf.rst</a>
+<h2>REFERENCES</h2>
+Hofierka, J., Suri, M. (2002): The solar radiation model for Open source
+GIS: implementation and applications. Manuscript submitted to the International
+GRASS users conference in Trento, Italy, September 2002.
+<p>
+Hofierka, J. (1997). Direct solar radiation modelling within an open GIS
+environment. Proceedings of JEC-GI'97 conference in Vienna, Austria, IOS
+Press Amsterdam, 575-584. </p>
+<p>
+Jenco, M. (1992). Distribution of direct solar radiation on georelief and
+its modelling by means of complex digital model of terrain (in Slovak). Geograficky
+casopis, 44, 342-355. </p>
+<p>
+Kasten, F. (1996). The Linke turbidity factor based on improved values of
+the integral Rayleigh optical thickness. Solar Energy, 56 (3), 239-244. </p>
+<p>
+Kasten, F., Young, A. T. (1989). Revised optical air mass tables and approximation
+formula. Applied Optics, 28, 4735-4738. </p>
+<p>
+Kittler, R., Mikler, J. (1986): Basis of the utilization of solar radiation
+(in Slovak). VEDA, Bratislava, p. 150. </p>
+<p>
+Krcho, J. (1990). Morfometrická analza a digitálne modely georeliéfu
+(Morphometric analysis and digital models of georelief, in Slovak).
+VEDA, Bratislava.</p>
+<p>
+Muneer, T. (1990). Solar radiation model for Europe. Building services engineering
+research and technology, 11, 4, 153-163. </p>
+<p>
+Neteler, M., Mitasova, H. (2002): Open Source GIS: A GRASS GIS Approach, Kluwer
+Academic Publishers. </p>
+<p>
+Page, J. ed. (1986). Prediction of solar radiation on inclined surfaces. Solar
+energy R&D in the European Community, series F – Solar radiation data,
+Dordrecht (D. Reidel), 3, 71, 81-83. </p>
+<p>
+Page, J., Albuisson, M., Wald, L. (2001). The European solar radiation atlas:
+a valuable digital tool. Solar Energy, 71, 81-83. </p>
+<p>
+Rigollier, Ch., Bauer, O., Wald, L. (2000). On the clear sky model of the
+ESRA - European Solar radiation Atlas - with respect to the Heliosat method.
+Solar energy, 68, 33-48. </p>
+<p>
+Scharmer, K., Greif, J., eds., (2000). The European solar radiation atlas,
+Vol. 2: Database and exploitation software. Paris (Les Presses de l’ École
+des Mines). </p>
+<p>Joint Research Centre: <a href="http://re.jrc.ec.europa.eu/pvgis/">GIS solar radiation database for Europe</a> and
+<a href="http://re.jrc.ec.europa.eu/pvgis/solres/solmod3.htm">Solar radiation and GIS</a>
+</p>
+<h2>AUTHORS</h2>
+Jaroslav Hofierka, GeoModel, s.r.o. Bratislava, Slovakia <br>
+Marcel Suri, GeoModel, s.r.o. Bratislava, Slovakia <br>
+Thomas Huld, JRC, Italy <br>
+© 2002, Jaroslav Hofierka, Marcel Suri
+<address>
+<a href="MAILTO:hofi at geomodel.sk">hofierka at geomodel.sk</a>
+<a href="MAILTO:suri at geomodel.sk">suri at geomodel.sk</a>
+</address>
+<p><i>Last changed: $Date$</i> </p>
Deleted: grass/trunk/raster/r.sunmask/description.html
--- grass/trunk/raster/r.sunmask/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.sunmask/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,74 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.sunmask</em> creates an output map layer based on an input elevation
-raster map layer and the sun position. The output map layer contains the
-cast shadow areas arising from sun shine and elevations. The user can define
-the sun position either directly or the module calculates it from given
-location and date/time parameters using the
-<a href=http://rredc.nrel.gov/>NREL</a> sun position algorithm. So either
-"A:"-parameters to specify the exact known sun position or "B:-parameters"
-to specify date/time for sun position calculation by r.sunmask itself have
-to be used.
-<p>
-The module performs sunset/sunrise checks and refraction correction for sun
-position calculation. Local coordinate systems are internally transformed to
-latitude/longitude for the SOLPOS algorithm. The elevation is not considered
-in the sunset/sunrise calculations.
-<h2>Notes</h2>
-r.sunmask and daylight savings: Rather than convert time to GMT, the solpos
-algorithm uses what is called Local Standard Time, which is generally
-defined politically as an offset from GMT. So the key is the offset from
-GMT, which the solpos Time Zone parameter. If the user specifies clock time
-(different for winter and summer), he/she would have to change the Time Zone
-parameter seasonally in r.sunmask (timezone parameter).
-<p>
-Note: In latitude/longitude locations the position coordinates pair
-(east/west) has to be specified in decimal degree (not D:M:S). If
-not specified, the map center's coordinates will be used.
-Also <em>g.region -l</em> displays the map center's coordinates.
-<p>
-Note for module usage with <em>-g</em> flag and calculations
-close to sunset/sunrise:
-<pre>
- sunangleabovehorizont=0.434240
- sunrise=07:59:19
- sunset=16:25:17
- Time (07:59:02) is before sunrise (07:59:19)!
- WARNING: Nothing to calculate. Please verify settings.
- No map calculation requested. Finished.
-</pre>
-In above calculation appears to be a mistake as
-the program indicates that we are before sunrise while
-the <i>sun angle above horizon</i> is already positive.
-The reason is that <i>sun angle above horizon</i> is
-calculated with correction for atmosphere refraction while
-<i>sunrise</i> and <i>sunset</i> are calculated <b>without</b>
-correction for atmosphere refraction. The output without
-<em>-g</em> flag contains related indications.
-<h2>Acknowledgements</h2>
-Acknowledgements: National Renewable Energy Laboratory for their <a href=http://rredc.nrel.gov/solar/codes_algs/solpos/>SOLPOS 2.0</a> sun position
-algorithm.
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="r.sun.html">r.sun</a>,
-</em>
-<h2>AUTHOR</h2>
-Janne Soimasuo, Finland 1994<br>
-update to FP by Huidae Cho 2001<br>
-added solpos algorithm feature by Markus Neteler 2001
Copied: grass/trunk/raster/r.sunmask/r.sunmask.html (from rev 32770, grass/trunk/raster/r.sunmask/description.html)
--- grass/trunk/raster/r.sunmask/r.sunmask.html (rev 0)
+++ grass/trunk/raster/r.sunmask/r.sunmask.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,74 @@
+<em>r.sunmask</em> creates an output map layer based on an input elevation
+raster map layer and the sun position. The output map layer contains the
+cast shadow areas arising from sun shine and elevations. The user can define
+the sun position either directly or the module calculates it from given
+location and date/time parameters using the
+<a href=http://rredc.nrel.gov/>NREL</a> sun position algorithm. So either
+"A:"-parameters to specify the exact known sun position or "B:-parameters"
+to specify date/time for sun position calculation by r.sunmask itself have
+to be used.
+<p>
+The module performs sunset/sunrise checks and refraction correction for sun
+position calculation. Local coordinate systems are internally transformed to
+latitude/longitude for the SOLPOS algorithm. The elevation is not considered
+in the sunset/sunrise calculations.
+<h2>Notes</h2>
+r.sunmask and daylight savings: Rather than convert time to GMT, the solpos
+algorithm uses what is called Local Standard Time, which is generally
+defined politically as an offset from GMT. So the key is the offset from
+GMT, which the solpos Time Zone parameter. If the user specifies clock time
+(different for winter and summer), he/she would have to change the Time Zone
+parameter seasonally in r.sunmask (timezone parameter).
+<p>
+Note: In latitude/longitude locations the position coordinates pair
+(east/west) has to be specified in decimal degree (not D:M:S). If
+not specified, the map center's coordinates will be used.
+Also <em>g.region -l</em> displays the map center's coordinates.
+<p>
+Note for module usage with <em>-g</em> flag and calculations
+close to sunset/sunrise:
+<pre>
+ sunangleabovehorizont=0.434240
+ sunrise=07:59:19
+ sunset=16:25:17
+ Time (07:59:02) is before sunrise (07:59:19)!
+ WARNING: Nothing to calculate. Please verify settings.
+ No map calculation requested. Finished.
+</pre>
+In above calculation appears to be a mistake as
+the program indicates that we are before sunrise while
+the <i>sun angle above horizon</i> is already positive.
+The reason is that <i>sun angle above horizon</i> is
+calculated with correction for atmosphere refraction while
+<i>sunrise</i> and <i>sunset</i> are calculated <b>without</b>
+correction for atmosphere refraction. The output without
+<em>-g</em> flag contains related indications.
+<h2>Acknowledgements</h2>
+Acknowledgements: National Renewable Energy Laboratory for their <a href=http://rredc.nrel.gov/solar/codes_algs/solpos/>SOLPOS 2.0</a> sun position
+algorithm.
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.sun.html">r.sun</a>,
+</em>
+<h2>AUTHOR</h2>
+Janne Soimasuo, Finland 1994<br>
+update to FP by Huidae Cho 2001<br>
+added solpos algorithm feature by Markus Neteler 2001
Deleted: grass/trunk/raster/r.support/description.html
--- grass/trunk/raster/r.support/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.support/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,42 +0,0 @@
-<b>r.support</b> allows the user to create and/or edit raster map support
-information. Editing of raster map color tables, category labels, header,
-history, and title is supported. Category labels can also be copied from
-another raster map.
-<h2>NOTES</h2>
-If metadata options such as <b>title</b> or <b>history</b> are given the
-module will run non-interactively. If only the map name is given
-<em>r.support</em> will run interactively within a terminal shell and the
-user with be prompted for input.
-<p>
-Freeform metadata information is stored in a "<tt>hist</tt>" file which may be
-appended to by using the <b>history</b> option. Currently this is limited to
-50 lines of text with a maximum line length of 78 characters. Any input
-larger than this will be wrapped to the next line.
-All other metadata strings available as standard options are limited to
-79 characters.
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.category.html">r.category</a>,
-<a href="r.describe.html">r.describe</a>,
-<a href="r.info.html">r.info</a>,
-<a href="r.region.html">r.region</a>,
-<a href="r.timestamp.html">r.timestamp</a>
-</em>
-<h2>AUTHORS</h2>
-Micharl Shapiro, CERL: Original author<br>
-<a href="MAILTO:rez at touchofmadness.com">Brad Douglas</a>: GRASS 6 Port<br>
-M. Hamish Bowman: command line enhancements<br>
-Markus Neteler: category copy from other map
-<p>
-</p>
Copied: grass/trunk/raster/r.support/r.support.html (from rev 32770, grass/trunk/raster/r.support/description.html)
--- grass/trunk/raster/r.support/r.support.html (rev 0)
+++ grass/trunk/raster/r.support/r.support.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,42 @@
+<b>r.support</b> allows the user to create and/or edit raster map support
+information. Editing of raster map color tables, category labels, header,
+history, and title is supported. Category labels can also be copied from
+another raster map.
+<h2>NOTES</h2>
+If metadata options such as <b>title</b> or <b>history</b> are given the
+module will run non-interactively. If only the map name is given
+<em>r.support</em> will run interactively within a terminal shell and the
+user with be prompted for input.
+<p>
+Freeform metadata information is stored in a "<tt>hist</tt>" file which may be
+appended to by using the <b>history</b> option. Currently this is limited to
+50 lines of text with a maximum line length of 78 characters. Any input
+larger than this will be wrapped to the next line.
+All other metadata strings available as standard options are limited to
+79 characters.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.category.html">r.category</a>,
+<a href="r.describe.html">r.describe</a>,
+<a href="r.info.html">r.info</a>,
+<a href="r.region.html">r.region</a>,
+<a href="r.timestamp.html">r.timestamp</a>
+</em>
+<h2>AUTHORS</h2>
+Micharl Shapiro, CERL: Original author<br>
+<a href="MAILTO:rez at touchofmadness.com">Brad Douglas</a>: GRASS 6 Port<br>
+M. Hamish Bowman: command line enhancements<br>
+Markus Neteler: category copy from other map
+<p>
+</p>
Deleted: grass/trunk/raster/r.support.stats/description.html
--- grass/trunk/raster/r.support.stats/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.support.stats/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,22 +0,0 @@
-<b>r.support.stats</b> allows the user to update raster map statistics
-information.
-<h2>NOTES</h2>
-None
-<h2>SEE ALSO</h2>
-<a href="r.support.html">r.support</a>,
-<h2>AUTHORS</h2>
Copied: grass/trunk/raster/r.support.stats/r.support.stats.html (from rev 32770, grass/trunk/raster/r.support.stats/description.html)
--- grass/trunk/raster/r.support.stats/r.support.stats.html (rev 0)
+++ grass/trunk/raster/r.support.stats/r.support.stats.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,22 @@
+<b>r.support.stats</b> allows the user to update raster map statistics
+information.
+<h2>NOTES</h2>
+None
+<h2>SEE ALSO</h2>
+<a href="r.support.html">r.support</a>,
+<h2>AUTHORS</h2>
Deleted: grass/trunk/raster/r.surf.area/description.html
--- grass/trunk/raster/r.surf.area/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.surf.area/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,66 +0,0 @@
-<em>r.surf.area</em> Calculates area of regular 3D triangulated points
-(centers of cells) in current region by adding areas of triangles.
-Therefore, area of a flat surface will be reported as
-(rows + cols -1)*(area of cell) less than area of
-flat region due to a half row and half column missing around the
-perimeter.
-<h2>NOTE</h2>
-This calculation is heavily dependent on
-data resolution (think of it as a fractal shoreline problem, the more
-resolution the more detail, the more area, etc). This program uses the
-<em>CURRENT GRASS REGION</em>, not the resolution of the map. This is
-especially important for surfaces with <tt>NULL</tt> values and highly
-irregular edges. The program does not [currently] attempt to correct for
-the error introduced by this <em>edge effect</em>.
-<p>
-This version actually calculates area twice for each triangle pair,
-keeping a running minimum and maximum area depending on the
-direction of the diagonal used.
-<p>
-<ol>
-<lh>Reported totals are:
-<li>"Plan" area of <tt>NULL</tt> values within the current GRASS region
-<li>"Plan" area within calculation region (rows-1 * cols-1 * cellarea)
-<li>Average of the minimum and maximum calculated 3d triangle area
-within this region
-<li>"Plan" area within current GRASS region (rows * cols * cellarea)
-<li>Scaling of calculated area to current GRASS region (see
-<a href="#note">NOTE</a>)
-</ol>
-<h2>NOTES</h2>
-<em>r.surf.area</em> works best when the surface being evaluated extends
-to the edges of the current GRASS region and the cell resolution is small.
-Surfaces which are especially long and thin and have highly irregular
-boudaries will tend to have underestimated surface areas. Setting a
-high cell resolution (small area) will greatly reduce this impact, but will
-cause longer processing times.
-<h2>SEE ALSO</h2>
-<em><a href="r.sum.html">r.sum</a></em>,
-<em><a href="r.surf.idw.html">r.surf.idw</a></em>,
-<em><a href="r.surf.idw2.html">r.surf.idw2</a></em>,
-<em><a href="r.surf.fractal.html">r.surf.fractal</a></em>,
-<em><a href="r.surf.gauss.html">r.surf.gauss</a></em>,
-<em><a href="r.volume.html">r.volume</a></em>,
-<em><a href="v.to.rast.html">v.to.rast</a></em>,
-<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>,
-<em><a href="g.region.html">g.region</a></em>
-<h2>AUTHOR</h2>
-Bill Brown, USACERL December 21, 1994
-<p>
-Modified for floating point rasters and <tt>NULL</tt> values by
-Eric G. Miller (October 17, 2000)
Copied: grass/trunk/raster/r.surf.area/r.surf.area.html (from rev 32770, grass/trunk/raster/r.surf.area/description.html)
--- grass/trunk/raster/r.surf.area/r.surf.area.html (rev 0)
+++ grass/trunk/raster/r.surf.area/r.surf.area.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,66 @@
+<em>r.surf.area</em> Calculates area of regular 3D triangulated points
+(centers of cells) in current region by adding areas of triangles.
+Therefore, area of a flat surface will be reported as
+(rows + cols -1)*(area of cell) less than area of
+flat region due to a half row and half column missing around the
+perimeter.
+<h2>NOTE</h2>
+This calculation is heavily dependent on
+data resolution (think of it as a fractal shoreline problem, the more
+resolution the more detail, the more area, etc). This program uses the
+<em>CURRENT GRASS REGION</em>, not the resolution of the map. This is
+especially important for surfaces with <tt>NULL</tt> values and highly
+irregular edges. The program does not [currently] attempt to correct for
+the error introduced by this <em>edge effect</em>.
+<p>
+This version actually calculates area twice for each triangle pair,
+keeping a running minimum and maximum area depending on the
+direction of the diagonal used.
+<p>
+<ol>
+<lh>Reported totals are:
+<li>"Plan" area of <tt>NULL</tt> values within the current GRASS region
+<li>"Plan" area within calculation region (rows-1 * cols-1 * cellarea)
+<li>Average of the minimum and maximum calculated 3d triangle area
+within this region
+<li>"Plan" area within current GRASS region (rows * cols * cellarea)
+<li>Scaling of calculated area to current GRASS region (see
+<a href="#note">NOTE</a>)
+</ol>
+<h2>NOTES</h2>
+<em>r.surf.area</em> works best when the surface being evaluated extends
+to the edges of the current GRASS region and the cell resolution is small.
+Surfaces which are especially long and thin and have highly irregular
+boudaries will tend to have underestimated surface areas. Setting a
+high cell resolution (small area) will greatly reduce this impact, but will
+cause longer processing times.
+<h2>SEE ALSO</h2>
+<em><a href="r.sum.html">r.sum</a></em>,
+<em><a href="r.surf.idw.html">r.surf.idw</a></em>,
+<em><a href="r.surf.idw2.html">r.surf.idw2</a></em>,
+<em><a href="r.surf.fractal.html">r.surf.fractal</a></em>,
+<em><a href="r.surf.gauss.html">r.surf.gauss</a></em>,
+<em><a href="r.volume.html">r.volume</a></em>,
+<em><a href="v.to.rast.html">v.to.rast</a></em>,
+<em><a href="r.slope.aspect.html">r.slope.aspect</a></em>,
+<em><a href="g.region.html">g.region</a></em>
+<h2>AUTHOR</h2>
+Bill Brown, USACERL December 21, 1994
+<p>
+Modified for floating point rasters and <tt>NULL</tt> values by
+Eric G. Miller (October 17, 2000)
Deleted: grass/trunk/raster/r.surf.contour/description.html
--- grass/trunk/raster/r.surf.contour/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.surf.contour/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,101 +0,0 @@
-<em>r.surf.contour</em> creates a raster elevation map from a rasterized
-contour map. Elevation values are determined using procedures similar
-to a manual methods.
-To determine the elevation of a point on a contour map, an individual
-might interpolate its value from those of the two nearest contour lines
-(uphill and downhill).
-<p>
-<em>r.surf.contour</em> works in a similar way. Initially, a vector map of
-the contour lines is made with the elevation of each line as an attribute.
-When the program <em><a href="v.to.rast.html">v.to.rast</a></em>
-is run on the vector map, continuous "lines" of rasters containing the
-contour line values will be the input for <em>r.surf.contour</em>. For each
-cell in the input map, either the cell is a contour line cell (which is
-given that value), or a flood fill is generated from that spot until the
-fill comes to two unique values. So the <em>r.surf.contour</em> algorithm
-<strong>linearly interpolates</strong> between contour lines. The flood fill
-is not allowed to cross over
-the rasterized contour lines, thus ensuring that an uphill and downhill
-contour value will be the two values chosen. <em>r.surf.contour</em>
-interpolates from the uphill and downhill values by the true distance.
-<h3>Parameters:</h3>
-<dl>
-<dt><b>input=</b><em>name</em>
-<dd>Name of an existing raster map that contains a set of
-initial category values (i.e., some cells contain known elevation
-values (denoting contours) while the rest contain NULL values or zeros (0)).
-<dt><b>output=</b><em>name</em>
-<dd>Name to be assigned to new output raster map that represents
-a smooth (e.g., elevation) surface generated from
-the known category values in the input raster map layer.
-</dl>
-<h2>NOTES</h2>
-<em>r.surf.contour</em> works well under the following circumstances:
-1) the contour lines extend to the the edge of the current region,
-2) the program is run at the same resolution as that of the input map,
-3) there are no disjointed contour lines,
-and 4) no spot elevation data BETWEEN contour lines exist. Spot elevations at
-the tops of hills and the bottoms of depressions, on the other hand, improve
-the output greatly.
-Violating these constraints will cause non-intuitive anomalies to appear in
-the output map. Run <em> <a href="r.slope.aspect.html">r.slope.aspect</a>
-</em> on <em>r.surf.contour</em> results to locate potential anomalies.
-<p>
-The running of <em>r.surf.contour</em> is very sensitive to the resolution of
-rasterized vector map. If multiple contour lines go through the same raster,
-slight anomalies may occur. The speed of <em>r.surf.contour</em> is dependent
-on how far "apart" the contour lines are from each other (as measured in
-raster cells). Since a flood fill algorithm is used, the program's running
-time will grow exponentially with the distance between contour lines.
-<h2>BUGS</h2>
-<em>r.surf.contour</em> has not been fully updated for NULL support and still
-considers a value of "<tt>0</tt>" to be NULL. Thus any contour lines at 0
-elevation (e.g. the coastline) will be ignored. In such cases converting any
-0 values in the input map to -1 with <em>r.mapcalc</em> may be a suitable
-work-around.
-<p>
-Currently <em>r.surf.contour</em> will only produce CELL (integer) map output.
-If you would like a finer grade output map (i.e. floating point) it is
-recommended to multiply the <b>input</b> map by 1000 (for example) using
-<em>r.mapcalc</em>, then divide the resultant <em>r.surf.contour</em>
-<b>output</b> map by 1000.0, again with <em>r.mapcalc</em>.
-<p>
-Volunteers are sought to remedy both these issues.
-<h2>SEE ALSO</h2>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="v.digit.html">v.digit</a></em>,
-<em><a href="v.surf.idw.html">v.surf.idw</a></em>,
-<em><a href="v.surf.rst.html">v.surf.rst</a></em>,
-<h2>AUTHOR</h2>
-Chuck Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.surf.contour/r.surf.contour.html (from rev 32770, grass/trunk/raster/r.surf.contour/description.html)
--- grass/trunk/raster/r.surf.contour/r.surf.contour.html (rev 0)
+++ grass/trunk/raster/r.surf.contour/r.surf.contour.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,101 @@
+<em>r.surf.contour</em> creates a raster elevation map from a rasterized
+contour map. Elevation values are determined using procedures similar
+to a manual methods.
+To determine the elevation of a point on a contour map, an individual
+might interpolate its value from those of the two nearest contour lines
+(uphill and downhill).
+<p>
+<em>r.surf.contour</em> works in a similar way. Initially, a vector map of
+the contour lines is made with the elevation of each line as an attribute.
+When the program <em><a href="v.to.rast.html">v.to.rast</a></em>
+is run on the vector map, continuous "lines" of rasters containing the
+contour line values will be the input for <em>r.surf.contour</em>. For each
+cell in the input map, either the cell is a contour line cell (which is
+given that value), or a flood fill is generated from that spot until the
+fill comes to two unique values. So the <em>r.surf.contour</em> algorithm
+<strong>linearly interpolates</strong> between contour lines. The flood fill
+is not allowed to cross over
+the rasterized contour lines, thus ensuring that an uphill and downhill
+contour value will be the two values chosen. <em>r.surf.contour</em>
+interpolates from the uphill and downhill values by the true distance.
+<h3>Parameters:</h3>
+<dl>
+<dt><b>input=</b><em>name</em>
+<dd>Name of an existing raster map that contains a set of
+initial category values (i.e., some cells contain known elevation
+values (denoting contours) while the rest contain NULL values or zeros (0)).
+<dt><b>output=</b><em>name</em>
+<dd>Name to be assigned to new output raster map that represents
+a smooth (e.g., elevation) surface generated from
+the known category values in the input raster map layer.
+</dl>
+<h2>NOTES</h2>
+<em>r.surf.contour</em> works well under the following circumstances:
+1) the contour lines extend to the the edge of the current region,
+2) the program is run at the same resolution as that of the input map,
+3) there are no disjointed contour lines,
+and 4) no spot elevation data BETWEEN contour lines exist. Spot elevations at
+the tops of hills and the bottoms of depressions, on the other hand, improve
+the output greatly.
+Violating these constraints will cause non-intuitive anomalies to appear in
+the output map. Run <em> <a href="r.slope.aspect.html">r.slope.aspect</a>
+</em> on <em>r.surf.contour</em> results to locate potential anomalies.
+<p>
+The running of <em>r.surf.contour</em> is very sensitive to the resolution of
+rasterized vector map. If multiple contour lines go through the same raster,
+slight anomalies may occur. The speed of <em>r.surf.contour</em> is dependent
+on how far "apart" the contour lines are from each other (as measured in
+raster cells). Since a flood fill algorithm is used, the program's running
+time will grow exponentially with the distance between contour lines.
+<h2>BUGS</h2>
+<em>r.surf.contour</em> has not been fully updated for NULL support and still
+considers a value of "<tt>0</tt>" to be NULL. Thus any contour lines at 0
+elevation (e.g. the coastline) will be ignored. In such cases converting any
+0 values in the input map to -1 with <em>r.mapcalc</em> may be a suitable
+work-around.
+<p>
+Currently <em>r.surf.contour</em> will only produce CELL (integer) map output.
+If you would like a finer grade output map (i.e. floating point) it is
+recommended to multiply the <b>input</b> map by 1000 (for example) using
+<em>r.mapcalc</em>, then divide the resultant <em>r.surf.contour</em>
+<b>output</b> map by 1000.0, again with <em>r.mapcalc</em>.
+<p>
+Volunteers are sought to remedy both these issues.
+<h2>SEE ALSO</h2>
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a href="v.digit.html">v.digit</a></em>,
+<em><a href="v.surf.idw.html">v.surf.idw</a></em>,
+<em><a href="v.surf.rst.html">v.surf.rst</a></em>,
+<h2>AUTHOR</h2>
+Chuck Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.surf.fractal/description.html
--- grass/trunk/raster/r.surf.fractal/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.surf.fractal/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,41 +0,0 @@
-<b>r.surf.fractal</b> creates a fractal surface of a given fractal
-dimension. Uses spectral synthesis method. Can create intermediate layers
-showing the build up of different spectral coefficients (see Saupe,
-pp.106-107 for an example of this).
-<p>
-Use this module to generate naturally looking synthetical elevation models
-(DEM).
-<h2>NOTE</h2>
-This module requires the <a href="http://www.fftw.org">FFTW library</a>
-for computing Discrete Fourier Transforms.
-<h2>REFERENCE</h2>
- Saupe, D. (1988) Algorithms for random fractals, in Barnsley M.,
- Devaney R., Mandelbrot B., Peitgen, H-O., Saupe D., and Voss R.
- (1988) The Science of Fractal Images, Ch. 2, pp.71-136. London:
- Springer-Verlag.
-<h2>SEE ALSO</h2>
-<em><a href="r.surf.contour.html">r.surf.contour</a></em>,
-<em><a href="r.surf.random.html">r.surf.random</a></em>,
-<address>
-<a href="MAILTO:jwo at le.ac.uk">jwo at le.ac.uk</a></address>
-<br><a href="http://www.geog.le.ac.uk/assist/index.html">ASSIST's home</a>
-<p>
Copied: grass/trunk/raster/r.surf.fractal/r.surf.fractal.html (from rev 32770, grass/trunk/raster/r.surf.fractal/description.html)
--- grass/trunk/raster/r.surf.fractal/r.surf.fractal.html (rev 0)
+++ grass/trunk/raster/r.surf.fractal/r.surf.fractal.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,41 @@
+<b>r.surf.fractal</b> creates a fractal surface of a given fractal
+dimension. Uses spectral synthesis method. Can create intermediate layers
+showing the build up of different spectral coefficients (see Saupe,
+pp.106-107 for an example of this).
+<p>
+Use this module to generate naturally looking synthetical elevation models
+(DEM).
+<h2>NOTE</h2>
+This module requires the <a href="http://www.fftw.org">FFTW library</a>
+for computing Discrete Fourier Transforms.
+<h2>REFERENCE</h2>
+ Saupe, D. (1988) Algorithms for random fractals, in Barnsley M.,
+ Devaney R., Mandelbrot B., Peitgen, H-O., Saupe D., and Voss R.
+ (1988) The Science of Fractal Images, Ch. 2, pp.71-136. London:
+ Springer-Verlag.
+<h2>SEE ALSO</h2>
+<em><a href="r.surf.contour.html">r.surf.contour</a></em>,
+<em><a href="r.surf.random.html">r.surf.random</a></em>,
+<address>
+<a href="MAILTO:jwo at le.ac.uk">jwo at le.ac.uk</a></address>
+<br><a href="http://www.geog.le.ac.uk/assist/index.html">ASSIST's home</a>
+<p>
Deleted: grass/trunk/raster/r.surf.gauss/description.html
--- grass/trunk/raster/r.surf.gauss/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.surf.gauss/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,27 +0,0 @@
-<b>r.surf.gauss</b> produces a raster map layer of Gaussian deviates whose
-mean and standard deviation can be expressed by the user. It uses a Gaussian
-random number generator. It is essentialy the same as <em>r.surf.random</em>,
-but uses a Gaussian random number generator instead.
-<p>
-<center>
-<img src="r_surf_gauss_hist.png" alt="r.surf.gauss map histogram"><br>
-<i>Histogram of map generated with r.surf.gauss (mean=0, sigma=10)</i>
-</center>
-<h2>SEE ALSO</h2>
-<h2>AUTHOR</h2>
-Jo Wood
Copied: grass/trunk/raster/r.surf.gauss/r.surf.gauss.html (from rev 32770, grass/trunk/raster/r.surf.gauss/description.html)
--- grass/trunk/raster/r.surf.gauss/r.surf.gauss.html (rev 0)
+++ grass/trunk/raster/r.surf.gauss/r.surf.gauss.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,27 @@
+<h2>DESCRIPTION</h2>
+<b>r.surf.gauss</b> produces a raster map layer of Gaussian deviates whose
+mean and standard deviation can be expressed by the user. It uses a Gaussian
+random number generator. It is essentialy the same as <em>r.surf.random</em>,
+but uses a Gaussian random number generator instead.
+<p>
+<center>
+<img src="r_surf_gauss_hist.png" alt="r.surf.gauss map histogram"><br>
+<i>Histogram of map generated with r.surf.gauss (mean=0, sigma=10)</i>
+</center>
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Jo Wood
Deleted: grass/trunk/raster/r.surf.idw/description.html
--- grass/trunk/raster/r.surf.idw/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.surf.idw/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,110 +0,0 @@
-<em>r.surf.idw</em> fills a grid cell (raster) matrix with
-interpolated values generated from a set of input layer
-data points. It uses a numerical approximation technique
-based on distance squared weighting of the values of
-nearest data points. The number of nearest data points used
-to determined the interpolated value of a cell can be
-specified by the user (default: 12 nearest data points).
-<p>
-If there is a current working mask, it applies to the output
-raster map. Only those cells falling within the mask will be
-assigned interpolated values. The search procedure for the
-selection of nearest neighboring points will consider all
-input data, without regard to the mask.
-The <b>-e</b> flag is the error analysis option that interpolates values
-only for those cells of the input raster map which have non-zero values and
-outputs the difference (see <a href="#minuse.html">NOTES</a> below).
-<p>
-The <b>npoints</b> parameter defines the number of nearest data points used
-to determine the interpolated value of an output raster cell.
-<A NAME="notes.html"><h2>NOTES</h2></a>
-<em>r.surf.idw</em> is a surface generation utility which
-uses inverse distance squared weighting (as described in
-<b>Applied Geostatistics</b> by E. H. Isaaks and R. M.
-Srivastava, Oxford University Press, 1989) to assign
-interpolated values. The implementation includes a
-customized data structure somewhat akin to a sparse matrix
-which enhances the efficiency with which nearest data
-points are selected. For latitude/longitude projections,
-distances are calculated from point to point along a
-geodesic.
-<p>
-Unlike <em><a href="r.surf.idw2.html">r.surf.idw2</a></em>, which processes
-all input data points in each interpolation cycle, <em>r.surf.idw</em>
-attempts to minimize the number of input data for which distances must be
-calculated. Execution speed is therefore a function of the search effort,
-and does not increase appreciably with the number of input data points.
-<p>
-<em>r.surf.idw</em> will generally outperform <em><A
-HREF="r.surf.idw2.html">r.surf.idw2</a></em> except when the input data
-layer contains few non-zero data, i.e. when the cost of the search exceeds
-the cost of the additional distance calculations performed by <em><A
-HREF="r.surf.idw2.html">r.surf.idw2</a></em>. The relative performance of
-these utilities will depend on the comparative speed of boolean, integer and
-floating point operations on a particular platform.
-<p>
-Worst case search performance by <em>r.surf.idw</em> occurs
-when the interpolated cell is located outside of the region
-in which input data are distributed. It therefore behooves
-the user to employ a mask when geographic region boundaries
-include large areas outside the general extent of the input
-data.
-<p>
-The degree of smoothing produced by the interpolation will
-increase relative to the number of nearest data points
-considered. The utility may be used with regularly or
-irregularly spaced input data. However, the output result
-for the former may include unacceptable nonconformities in
-the surface pattern.
-<p>
-The <A NAME="minuse.html"><b>-e</b></a> flag option provides a standard
-surface-generation error analysis facility. It produces an output raster map
-of the difference of interpolated values minus input values for those cells
-whose input data are non-zero. For each interpolation cycle, the known value
-of the cell under consideration is ignored, and the remaining input values
-are used to interpolate a result. The output raster map may be compared to
-the input raster map to analyze the distribution of interpolation error.
-This procedure may be helpful in choosing the number of nearest neighbors
-considered for surface generation.
-<h2>SEE ALSO</h2>
-<h2>AUTHOR</h2>
-Greg Koerper
-<br>
-Global Climate Research Project
-<br>
-U.S. EPA Environmental Research Laboratory
-<br>
-200 S.W. 35th Street, JSB
-<br>
-Corvallis, OR 97333
Copied: grass/trunk/raster/r.surf.idw/r.surf.idw.html (from rev 32770, grass/trunk/raster/r.surf.idw/description.html)
--- grass/trunk/raster/r.surf.idw/r.surf.idw.html (rev 0)
+++ grass/trunk/raster/r.surf.idw/r.surf.idw.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,110 @@
+<em>r.surf.idw</em> fills a grid cell (raster) matrix with
+interpolated values generated from a set of input layer
+data points. It uses a numerical approximation technique
+based on distance squared weighting of the values of
+nearest data points. The number of nearest data points used
+to determined the interpolated value of a cell can be
+specified by the user (default: 12 nearest data points).
+<p>
+If there is a current working mask, it applies to the output
+raster map. Only those cells falling within the mask will be
+assigned interpolated values. The search procedure for the
+selection of nearest neighboring points will consider all
+input data, without regard to the mask.
+The <b>-e</b> flag is the error analysis option that interpolates values
+only for those cells of the input raster map which have non-zero values and
+outputs the difference (see <a href="#minuse.html">NOTES</a> below).
+<p>
+The <b>npoints</b> parameter defines the number of nearest data points used
+to determine the interpolated value of an output raster cell.
+<A NAME="notes.html"><h2>NOTES</h2></a>
+<em>r.surf.idw</em> is a surface generation utility which
+uses inverse distance squared weighting (as described in
+<b>Applied Geostatistics</b> by E. H. Isaaks and R. M.
+Srivastava, Oxford University Press, 1989) to assign
+interpolated values. The implementation includes a
+customized data structure somewhat akin to a sparse matrix
+which enhances the efficiency with which nearest data
+points are selected. For latitude/longitude projections,
+distances are calculated from point to point along a
+geodesic.
+<p>
+Unlike <em><a href="r.surf.idw2.html">r.surf.idw2</a></em>, which processes
+all input data points in each interpolation cycle, <em>r.surf.idw</em>
+attempts to minimize the number of input data for which distances must be
+calculated. Execution speed is therefore a function of the search effort,
+and does not increase appreciably with the number of input data points.
+<p>
+<em>r.surf.idw</em> will generally outperform <em><A
+HREF="r.surf.idw2.html">r.surf.idw2</a></em> except when the input data
+layer contains few non-zero data, i.e. when the cost of the search exceeds
+the cost of the additional distance calculations performed by <em><A
+HREF="r.surf.idw2.html">r.surf.idw2</a></em>. The relative performance of
+these utilities will depend on the comparative speed of boolean, integer and
+floating point operations on a particular platform.
+<p>
+Worst case search performance by <em>r.surf.idw</em> occurs
+when the interpolated cell is located outside of the region
+in which input data are distributed. It therefore behooves
+the user to employ a mask when geographic region boundaries
+include large areas outside the general extent of the input
+data.
+<p>
+The degree of smoothing produced by the interpolation will
+increase relative to the number of nearest data points
+considered. The utility may be used with regularly or
+irregularly spaced input data. However, the output result
+for the former may include unacceptable nonconformities in
+the surface pattern.
+<p>
+The <A NAME="minuse.html"><b>-e</b></a> flag option provides a standard
+surface-generation error analysis facility. It produces an output raster map
+of the difference of interpolated values minus input values for those cells
+whose input data are non-zero. For each interpolation cycle, the known value
+of the cell under consideration is ignored, and the remaining input values
+are used to interpolate a result. The output raster map may be compared to
+the input raster map to analyze the distribution of interpolation error.
+This procedure may be helpful in choosing the number of nearest neighbors
+considered for surface generation.
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Greg Koerper
+<br>
+Global Climate Research Project
+<br>
+U.S. EPA Environmental Research Laboratory
+<br>
+200 S.W. 35th Street, JSB
+<br>
+Corvallis, OR 97333
Deleted: grass/trunk/raster/r.surf.idw2/description.html
--- grass/trunk/raster/r.surf.idw2/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.surf.idw2/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,68 +0,0 @@
-<em>r.surf.idw2</em> fills a raster matrix with
-interpolated values generated from a set of irregularly
-spaced data points using numerical approximation (weighted
-averaging) techniques. The interpolated value of a cell is
-determined by values of nearby data points and the distance
-of the cell from those input points. In comparison with
-other methods, numerical approximation allows
-representation of more complex surfaces (particularly those
-with anomalous features), restricts the spatial influence
-of any errors, and generates the interpolated surface from
-the data points. It is the most appropriate method to
-apply to most spatial data.
-The <b>npoints</b> parameter defines the number of points to use for
-interpolation. The default is to use the 12 nearest points when
-interpolating the value for a particular cell.
-<h2>NOTES</h2>
-The amount of memory used by this program is related to the
-number of non-zero data values in the input map layer. If
-the input raster map layer is very dense (i.e., contains
-many non-zero data points), the program may not be able to
-get all the memory it needs from the system. The time
-required to execute increases with the number of input data
-points.
-<p>
-If the user has a mask set, then interpolation is only done
-for those cells that fall within the mask. However, all
-non-zero data points in the input layer are used even if
-they fall outside the mask.
-<p>
-This program does not work with latitude/longitude data
-bases. Another surface generation program, named
-should be used with latitude/longitude data bases.
-<p>
-The user should refer to the manual entries for <br>
-<em><a href="r.surf.idw.html">r.surf.idw</a></em><br>
-<em><a href="r.surf.contour.html">r.surf.contour</a></em><br>
-<em><a href="v.surf.rst.html">v.surf.rst</a></em> <br>to
-compare this surface generation program with others available in GRASS.
-<h2>SEE ALSO</h2>
-<h2>AUTHOR</h2>
-Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.surf.idw2/r.surf.idw2.html (from rev 32770, grass/trunk/raster/r.surf.idw2/description.html)
--- grass/trunk/raster/r.surf.idw2/r.surf.idw2.html (rev 0)
+++ grass/trunk/raster/r.surf.idw2/r.surf.idw2.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,68 @@
+<em>r.surf.idw2</em> fills a raster matrix with
+interpolated values generated from a set of irregularly
+spaced data points using numerical approximation (weighted
+averaging) techniques. The interpolated value of a cell is
+determined by values of nearby data points and the distance
+of the cell from those input points. In comparison with
+other methods, numerical approximation allows
+representation of more complex surfaces (particularly those
+with anomalous features), restricts the spatial influence
+of any errors, and generates the interpolated surface from
+the data points. It is the most appropriate method to
+apply to most spatial data.
+The <b>npoints</b> parameter defines the number of points to use for
+interpolation. The default is to use the 12 nearest points when
+interpolating the value for a particular cell.
+<h2>NOTES</h2>
+The amount of memory used by this program is related to the
+number of non-zero data values in the input map layer. If
+the input raster map layer is very dense (i.e., contains
+many non-zero data points), the program may not be able to
+get all the memory it needs from the system. The time
+required to execute increases with the number of input data
+points.
+<p>
+If the user has a mask set, then interpolation is only done
+for those cells that fall within the mask. However, all
+non-zero data points in the input layer are used even if
+they fall outside the mask.
+<p>
+This program does not work with latitude/longitude data
+bases. Another surface generation program, named
+should be used with latitude/longitude data bases.
+<p>
+The user should refer to the manual entries for <br>
+<em><a href="r.surf.idw.html">r.surf.idw</a></em><br>
+<em><a href="r.surf.contour.html">r.surf.contour</a></em><br>
+<em><a href="v.surf.rst.html">v.surf.rst</a></em> <br>to
+compare this surface generation program with others available in GRASS.
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.surf.random/description.html
--- grass/trunk/raster/r.surf.random/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.surf.random/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,41 +0,0 @@
-<b>r.surf.random</b> produces a raster map layer of uniform random deviates
-whose range can be expressed by the user. It is essentialy the same as
-<em>r.surf.gauss</em>, but uses a linear random number generator instead.
-It uses the random number generator drand48() or rand()<!-- cite? -->,
-depending on the user's platform.
-<p>
-<center>
-<img src="r_surf_random_hist.png" alt="r.surf.random map histogram"><br>
-<i>Histogram of map generated with r.surf.random</i>
-</center>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.surf.contour.html">r.surf.contour</a>,
-<a href="r.surf.fractal.html">r.surf.fractal</a>,
-<a href="r.surf.gauss.html">r.surf.gauss</a>,
-<a href="r.surf.idw.html">r.surf.idw</a>,
-<a href="r.surf.idw2.html">r.surf.idw2</a>,
-</em>
-<h2>AUTHOR</h2>
-Jo Wood<br>
-Midlands Regional Research Laboratory (ASSIST)<br>
-University of Leicester<br>
-<i>October 1991</i>
-<br>
-<!-- almost certainly no longer valid
-<address>jwo at le.ac.uk</address>
-<p>
Copied: grass/trunk/raster/r.surf.random/r.surf.random.html (from rev 32770, grass/trunk/raster/r.surf.random/description.html)
--- grass/trunk/raster/r.surf.random/r.surf.random.html (rev 0)
+++ grass/trunk/raster/r.surf.random/r.surf.random.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,41 @@
+<b>r.surf.random</b> produces a raster map layer of uniform random deviates
+whose range can be expressed by the user. It is essentialy the same as
+<em>r.surf.gauss</em>, but uses a linear random number generator instead.
+It uses the random number generator drand48() or rand()<!-- cite? -->,
+depending on the user's platform.
+<p>
+<center>
+<img src="r_surf_random_hist.png" alt="r.surf.random map histogram"><br>
+<i>Histogram of map generated with r.surf.random</i>
+</center>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.surf.contour.html">r.surf.contour</a>,
+<a href="r.surf.fractal.html">r.surf.fractal</a>,
+<a href="r.surf.gauss.html">r.surf.gauss</a>,
+<a href="r.surf.idw.html">r.surf.idw</a>,
+<a href="r.surf.idw2.html">r.surf.idw2</a>,
+</em>
+<h2>AUTHOR</h2>
+Jo Wood<br>
+Midlands Regional Research Laboratory (ASSIST)<br>
+University of Leicester<br>
+<i>October 1991</i>
+<br>
+<!-- almost certainly no longer valid
+<address>jwo at le.ac.uk</address>
+<p>
Deleted: grass/trunk/raster/r.terraflow/description.html
--- grass/trunk/raster/r.terraflow/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.terraflow/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,249 +0,0 @@
-<p><em>r.terraflow</em> takes as input a raster digital elevation
-model (DEM) and computes the flow direction raster and the flow
-accumulation raster, as well as the flooded elevation raster,
-sink-watershed raster (partition into watersheds around sinks) and tci
-(topographic convergence index) raster.
-<p><em>r.terraflow</em> computes these rasters using well-known
-approaches, with the difference that its emphasis is on the
-computational complexity of the algorithms, rather than on modeling
-realistic flow. <em>r.terraflow</em> emerged from the necessity of
-having scalable software able to process efficiently very large
-terrains. It is based on theoretically optimal algorithms developed
-in the framework of I/O-efficient algorithms. <em>r.terraflow</em>
-was designed and optimized especially for massive grids and is able to
-process terrains which were impractical with similar functions
-existing in other GIS systems.
-<p>Flow directions are computed using either the MFD (Multiple Flow
-Direction) model or the SFD (Single Flow Direction, or D8) model,
-illustrated below. Both methods compute downslope flow directions by
-inspecting the 3-by-3 window around the current cell. The SFD method
-assigns a unique flow direction towards the steepest downslope
-neighbor. The MFD method assigns multiple flow directions towards all
-downslope neighbors.
-<p>
-<table width=80% align=center>
- <tr>
- <th><img src="rterraflow_dir2.png" alt="[SFD]" border=0></th>
- <th><img src="rterraflow_dir3.png" alt="[SFD]" border=0></th>
- </tr>
- <tr>
- <th>Flow direction to steepest<br> downslope neighbor (SFD).</th>
- <th>Flow direction to all<br> downslope neighbors (MFD).</th>
- </tr>
-</table>
-<p>The SFD and the MFD method cannot compute flow directions for
-cells which have the same height as all their neighbors (flat areas)
-or cells which do not have downslope neighbors (one-cell pits).
-<ul>
- <li>On plateaus (flat areas that spill out) <em>r.terraflow</em>
-routes flow so that globally the flow goes towards the spill cells of
-the plateaus.
- <li>On sinks (flat areas that do not spill out, including one-cell
-pits) <em>r.terraflow</em> assigns flow by flooding the terrain until
-all the sinks are filled and assigning flow directions on the filled
-terrain.
-</ul>
-<p>
-In order to flood the terrain, <em>r.terraflow</em> identifies all
-sinks and partitions the terrain into sink-watersheds (a
-sink-watershed contains all the cells that flow into that sink),
-builds a graph representing the adjacency information of the
-sink-watersheds, and uses this sink-watershed graph to merge
-watersheds into each other along their lowest common boundary until
-all watersheds have a flow path outside the terrain. Flooding produces
-a sink-less terrain in which every cell has a downslope flow path
-leading outside the terrain and therefore every cell in the terrain
-can be assigned SFD/MFD flow directions as above.
-<p>
-Once flow directions are computed for every cell in the terrain,
-<em>r.terraflow</em> computes flow accumulation by routing water using
-the flow directions and keeping track of how much water flows through
-each cell.
-<p>
-If flow accumulation of a cell is larger than the value given by the
-<b>d8cut</b> option, then
-the flow of this cell is routed to its neighbors using the SFD (D8)
-model. This option affects only the flow accumulation raster and is
-meaningfull only for MFD flow (i.e. if the -s flag is not used); If
-this option is used for SFD flow it is ignored. The default value of
-<b>d8cut</b> is <i>infinity</i>.
-<p>
-<em>r.terraflow</em> also computes the tci raster (topographic convergence
-index, defined as the logarithm of the ratio of flow accumulation and
-local slope).
-<p>
-For more details on the algorithms see [1,2,3] below.
-<h2>NOTES</h2>
-One of the techniques used by <em>r.terraflow</em> is the
-space-time trade-off. In particular, in order to avoid searches, which
-are I/O-expensive, <em>r.terraflow</em> computes and works with an
-augmented elevation raster in which each cell stores relevant
-information about its 8 neighbors, in total up to 80B per cell. As a
-result <em>r.terraflow</em> works with intermediate temporary files
-that may be up to 80N bytes, where N is the number of cells (rows x
-columns) in the elevation raster (more precisely, 80K bytes, where K
-is the number of valid (not no-data) cells in the input elevation
-raster).
-<p>
-All these intermediate temporary files are stored in the path specified
-by the <b>STREAM_DIR</b> option. Note: <b>STREAM_DIR</b> must contain
-enough free disk space in order to store up to 2 x 80N bytes.
-<p>
-The <b>memory</b> option can be used to set the maximum amount of main
-memory (RAM) the module will use during processing. In practice its
-<i>value</i> should be an underestimate of the amount of available
-(free) main memory on the machine. <em>r.terraflow</em> will use at
-all times at most this much memory, and the virtual memory system
-(swap space) will never be used. The default value is 300 MB.
-<p>
-The internal type used by <em>r.terraflow</em> to store elevations
-can be defined at compile-time. By default, <em>r.terraflow</em> is
-compiled to store elevations internally as floats.
-A version which is compiled to store elevations internally as
-shorts is available as <em>r.terraflow.short</em>. Other versions can
-be created by the user if needed.
-<p>
-<em>r.terraflow.short</em> uses less space (up to 60B per cell, up
-to 60N intermediate file) and therefore is more space and time
-efficient. <em>r.terraflow</em> is intended for use with floating
-point raster data (FCELL), and <em>r.terraflow.short</em> with integer
-raster data (CELL) in which the maximum elevation does not exceed the
-value of a short SHRT_MAX=32767 (this is not a constraint for any
-terrain data of the Earth, if elevation is stored in meters).
-<p>
-Both <em>r.terraflow</em> and <em>r.terraflow.short</em> work with
-input elevation rasters which can be either integer, floating point or
-double (CELL, FCELL, DCELL). If the input raster contains a value that
-exceeds the allowed internal range (short for
-<em>r.terraflow.short</em>, float for <em>r.terraflow</em>), the
-program exits with a warning message. Otherwise, if all values in the
-input elevation raster are in range, they will be converted
-(truncated) to the internal elevation type (short for
-<em>r.terraflow.short</em>, float for <em>r.terraflow</em>). In this
-case precision may be lost and artificial flat areas may be created.
-<p>
-For instance, if <em>r.terraflow.short</em> is used with floating
-point raster data (FCELL or DCELL), the values of the elevation will
-be truncated as shorts. This may create artificial flat areas, and the
-outpus of <em>r.terraflow.short</em> may be less realistic than those
-of <em>r.terraflow</em> on floating point raster data.
-The outputs of <em>r.terraflow.short</em> and <em>r.terraflow</em> are
-identical for integer raster data (CELL maps).
-<p>
-The <b>stats</b> option defines the name of the file that contains the
-statistics (stats) of the run. The default name is <tt>stats.out</tt>
-(in the current directory).
-<h2>EXAMPLES</h2>
-<div class="code"><pre>
- r.terraflow elev=spearfish filled=spearfish-filled \
- dir=spearfish-mfdir swatershed=spearfish-watershed \
- accumulation=spearfish-accu tci=spearfish-tci
-</pre></div>
- accumulation=spearfish-accu tci=spearfish-tci d8cut=500 memory=800 \
- STREAM-DIR=/var/tmp/ stats=spearfish-stats.txt
-</pre></div>
-<h2>SEE ALSO</h2>
-<ul>
- <li>The <a
-href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project at Duke University
- <li><a href=r.flow.html>r.flow</a>,
- <a href="r.basins.fill.html">r.basins.fill</a>,
- <a href="r.drain.html">r.drain</a>,
- <a href="r.topidx.html">r.topidx</a>,
- <a href="r.topmodel.html">r.topmodel</a>,
- <a href="r.water.outlet.html">r.water.outlet</a>,
- <a href="r.watershed.html">r.watershed</a>
-</ul>
-<h2>AUTHORS</h2>
-<dl>
- <dt>Original version of program: The <a
- href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project,
- 1999, Duke University.
- <dd><a href="http://www.cs.duke.edu/~large/">Lars Arge</a>,
- <a href="http://www.cs.duke.edu/~chase/">Jeff Chase</a>,
- <a href="http://www.env.duke.edu/faculty/bios/halpin.html">Pat Halpin</a>,
- <a href="http://www.cs.duke.edu/~laura/">Laura Toma</a>,
- <a href="http://www.env.duke.edu/faculty/bios/urban.html">Dean Urban</a>,
- <a href="http://www.cs.duke.edu/~jsv/">Jeff Vitter</a>,
- <a href="http://www.cs.duke.edu/~rajiv/">Rajiv Wickremesinghe</a>.
- <dt>Porting for GRASS, 2002:
- <dd> <a href="http://www.cs.duke.edu/~large/">Lars Arge</a>,
- <a href="http://skagit.meas.ncsu.edu/~helena/index.html">Helena Mitasova,</a>
- <a href="http://www.cs.duke.edu/~laura/">Laura Toma</a>.
- <dt>Contact: <a href="mailto:laura at cs.duke.edu"> Laura Toma</a></dt>
-</dl>
-<h2>REFERENCES</h2>
-<ol>
- <li><A NAME="arge:drainage"
- HREF="http://www.cs.duke.edu/geo*/terraflow/papers/alenex00_drainage.ps.gz">
- I/O-efficient algorithms for problems on grid-based
- terrains</a>. Lars Arge, Laura Toma, and Jeffrey S. Vitter. In
- <em>Proc. Workshop on Algorithm Engineering and Experimentation</em>,
- 2000. To appear in <em>Journal of Experimental Algorithms</em>.
- <li><A NAME="terraflow:acmgis01"
- HREF="http://www.cs.duke.edu/geo*/terraflow/papers/acmgis01_terraflow.pdf">
- Flow computation on massive grids</a>.
- Lars Arge, Jeffrey S. Chase, Patrick N. Halpin, Laura Toma,
- Jeffrey S. Vitter, Dean Urban and Rajiv Wickremesinghe. In
- <em>Proc. ACM Symposium on Advances in Geographic Information
- Systems</em>, 2001.
- <li><A NAME="terraflow:geoinformatica"
- HREF="http://www.cs.duke.edu/geo*/terraflow/papers/journal_terraflow.pdf">
- Flow computation on massive grid terrains</a>.
- To appear in <em>GeoInformatica, International Journal on
- Advances of Computer Science for Geographic Information
- Systems</em>.
-</ol>
-<p>
Copied: grass/trunk/raster/r.terraflow/r.terraflow.html (from rev 32770, grass/trunk/raster/r.terraflow/description.html)
--- grass/trunk/raster/r.terraflow/r.terraflow.html (rev 0)
+++ grass/trunk/raster/r.terraflow/r.terraflow.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,249 @@
+<p><em>r.terraflow</em> takes as input a raster digital elevation
+model (DEM) and computes the flow direction raster and the flow
+accumulation raster, as well as the flooded elevation raster,
+sink-watershed raster (partition into watersheds around sinks) and tci
+(topographic convergence index) raster.
+<p><em>r.terraflow</em> computes these rasters using well-known
+approaches, with the difference that its emphasis is on the
+computational complexity of the algorithms, rather than on modeling
+realistic flow. <em>r.terraflow</em> emerged from the necessity of
+having scalable software able to process efficiently very large
+terrains. It is based on theoretically optimal algorithms developed
+in the framework of I/O-efficient algorithms. <em>r.terraflow</em>
+was designed and optimized especially for massive grids and is able to
+process terrains which were impractical with similar functions
+existing in other GIS systems.
+<p>Flow directions are computed using either the MFD (Multiple Flow
+Direction) model or the SFD (Single Flow Direction, or D8) model,
+illustrated below. Both methods compute downslope flow directions by
+inspecting the 3-by-3 window around the current cell. The SFD method
+assigns a unique flow direction towards the steepest downslope
+neighbor. The MFD method assigns multiple flow directions towards all
+downslope neighbors.
+<p>
+<table width=80% align=center>
+ <tr>
+ <th><img src="rterraflow_dir2.png" alt="[SFD]" border=0></th>
+ <th><img src="rterraflow_dir3.png" alt="[SFD]" border=0></th>
+ </tr>
+ <tr>
+ <th>Flow direction to steepest<br> downslope neighbor (SFD).</th>
+ <th>Flow direction to all<br> downslope neighbors (MFD).</th>
+ </tr>
+</table>
+<p>The SFD and the MFD method cannot compute flow directions for
+cells which have the same height as all their neighbors (flat areas)
+or cells which do not have downslope neighbors (one-cell pits).
+<ul>
+ <li>On plateaus (flat areas that spill out) <em>r.terraflow</em>
+routes flow so that globally the flow goes towards the spill cells of
+the plateaus.
+ <li>On sinks (flat areas that do not spill out, including one-cell
+pits) <em>r.terraflow</em> assigns flow by flooding the terrain until
+all the sinks are filled and assigning flow directions on the filled
+terrain.
+</ul>
+<p>
+In order to flood the terrain, <em>r.terraflow</em> identifies all
+sinks and partitions the terrain into sink-watersheds (a
+sink-watershed contains all the cells that flow into that sink),
+builds a graph representing the adjacency information of the
+sink-watersheds, and uses this sink-watershed graph to merge
+watersheds into each other along their lowest common boundary until
+all watersheds have a flow path outside the terrain. Flooding produces
+a sink-less terrain in which every cell has a downslope flow path
+leading outside the terrain and therefore every cell in the terrain
+can be assigned SFD/MFD flow directions as above.
+<p>
+Once flow directions are computed for every cell in the terrain,
+<em>r.terraflow</em> computes flow accumulation by routing water using
+the flow directions and keeping track of how much water flows through
+each cell.
+<p>
+If flow accumulation of a cell is larger than the value given by the
+<b>d8cut</b> option, then
+the flow of this cell is routed to its neighbors using the SFD (D8)
+model. This option affects only the flow accumulation raster and is
+meaningfull only for MFD flow (i.e. if the -s flag is not used); If
+this option is used for SFD flow it is ignored. The default value of
+<b>d8cut</b> is <i>infinity</i>.
+<p>
+<em>r.terraflow</em> also computes the tci raster (topographic convergence
+index, defined as the logarithm of the ratio of flow accumulation and
+local slope).
+<p>
+For more details on the algorithms see [1,2,3] below.
+<h2>NOTES</h2>
+One of the techniques used by <em>r.terraflow</em> is the
+space-time trade-off. In particular, in order to avoid searches, which
+are I/O-expensive, <em>r.terraflow</em> computes and works with an
+augmented elevation raster in which each cell stores relevant
+information about its 8 neighbors, in total up to 80B per cell. As a
+result <em>r.terraflow</em> works with intermediate temporary files
+that may be up to 80N bytes, where N is the number of cells (rows x
+columns) in the elevation raster (more precisely, 80K bytes, where K
+is the number of valid (not no-data) cells in the input elevation
+raster).
+<p>
+All these intermediate temporary files are stored in the path specified
+by the <b>STREAM_DIR</b> option. Note: <b>STREAM_DIR</b> must contain
+enough free disk space in order to store up to 2 x 80N bytes.
+<p>
+The <b>memory</b> option can be used to set the maximum amount of main
+memory (RAM) the module will use during processing. In practice its
+<i>value</i> should be an underestimate of the amount of available
+(free) main memory on the machine. <em>r.terraflow</em> will use at
+all times at most this much memory, and the virtual memory system
+(swap space) will never be used. The default value is 300 MB.
+<p>
+The internal type used by <em>r.terraflow</em> to store elevations
+can be defined at compile-time. By default, <em>r.terraflow</em> is
+compiled to store elevations internally as floats.
+A version which is compiled to store elevations internally as
+shorts is available as <em>r.terraflow.short</em>. Other versions can
+be created by the user if needed.
+<p>
+<em>r.terraflow.short</em> uses less space (up to 60B per cell, up
+to 60N intermediate file) and therefore is more space and time
+efficient. <em>r.terraflow</em> is intended for use with floating
+point raster data (FCELL), and <em>r.terraflow.short</em> with integer
+raster data (CELL) in which the maximum elevation does not exceed the
+value of a short SHRT_MAX=32767 (this is not a constraint for any
+terrain data of the Earth, if elevation is stored in meters).
+<p>
+Both <em>r.terraflow</em> and <em>r.terraflow.short</em> work with
+input elevation rasters which can be either integer, floating point or
+double (CELL, FCELL, DCELL). If the input raster contains a value that
+exceeds the allowed internal range (short for
+<em>r.terraflow.short</em>, float for <em>r.terraflow</em>), the
+program exits with a warning message. Otherwise, if all values in the
+input elevation raster are in range, they will be converted
+(truncated) to the internal elevation type (short for
+<em>r.terraflow.short</em>, float for <em>r.terraflow</em>). In this
+case precision may be lost and artificial flat areas may be created.
+<p>
+For instance, if <em>r.terraflow.short</em> is used with floating
+point raster data (FCELL or DCELL), the values of the elevation will
+be truncated as shorts. This may create artificial flat areas, and the
+outpus of <em>r.terraflow.short</em> may be less realistic than those
+of <em>r.terraflow</em> on floating point raster data.
+The outputs of <em>r.terraflow.short</em> and <em>r.terraflow</em> are
+identical for integer raster data (CELL maps).
+<p>
+The <b>stats</b> option defines the name of the file that contains the
+statistics (stats) of the run. The default name is <tt>stats.out</tt>
+(in the current directory).
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+ r.terraflow elev=spearfish filled=spearfish-filled \
+ dir=spearfish-mfdir swatershed=spearfish-watershed \
+ accumulation=spearfish-accu tci=spearfish-tci
+</pre></div>
+ accumulation=spearfish-accu tci=spearfish-tci d8cut=500 memory=800 \
+ STREAM-DIR=/var/tmp/ stats=spearfish-stats.txt
+</pre></div>
+<h2>SEE ALSO</h2>
+<ul>
+ <li>The <a
+href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project at Duke University
+ <li><a href=r.flow.html>r.flow</a>,
+ <a href="r.basins.fill.html">r.basins.fill</a>,
+ <a href="r.drain.html">r.drain</a>,
+ <a href="r.topidx.html">r.topidx</a>,
+ <a href="r.topmodel.html">r.topmodel</a>,
+ <a href="r.water.outlet.html">r.water.outlet</a>,
+ <a href="r.watershed.html">r.watershed</a>
+</ul>
+<h2>AUTHORS</h2>
+<dl>
+ <dt>Original version of program: The <a
+ href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project,
+ 1999, Duke University.
+ <dd><a href="http://www.cs.duke.edu/~large/">Lars Arge</a>,
+ <a href="http://www.cs.duke.edu/~chase/">Jeff Chase</a>,
+ <a href="http://www.env.duke.edu/faculty/bios/halpin.html">Pat Halpin</a>,
+ <a href="http://www.cs.duke.edu/~laura/">Laura Toma</a>,
+ <a href="http://www.env.duke.edu/faculty/bios/urban.html">Dean Urban</a>,
+ <a href="http://www.cs.duke.edu/~jsv/">Jeff Vitter</a>,
+ <a href="http://www.cs.duke.edu/~rajiv/">Rajiv Wickremesinghe</a>.
+ <dt>Porting for GRASS, 2002:
+ <dd> <a href="http://www.cs.duke.edu/~large/">Lars Arge</a>,
+ <a href="http://skagit.meas.ncsu.edu/~helena/index.html">Helena Mitasova,</a>
+ <a href="http://www.cs.duke.edu/~laura/">Laura Toma</a>.
+ <dt>Contact: <a href="mailto:laura at cs.duke.edu"> Laura Toma</a></dt>
+</dl>
+<h2>REFERENCES</h2>
+<ol>
+ <li><A NAME="arge:drainage"
+ HREF="http://www.cs.duke.edu/geo*/terraflow/papers/alenex00_drainage.ps.gz">
+ I/O-efficient algorithms for problems on grid-based
+ terrains</a>. Lars Arge, Laura Toma, and Jeffrey S. Vitter. In
+ <em>Proc. Workshop on Algorithm Engineering and Experimentation</em>,
+ 2000. To appear in <em>Journal of Experimental Algorithms</em>.
+ <li><A NAME="terraflow:acmgis01"
+ HREF="http://www.cs.duke.edu/geo*/terraflow/papers/acmgis01_terraflow.pdf">
+ Flow computation on massive grids</a>.
+ Lars Arge, Jeffrey S. Chase, Patrick N. Halpin, Laura Toma,
+ Jeffrey S. Vitter, Dean Urban and Rajiv Wickremesinghe. In
+ <em>Proc. ACM Symposium on Advances in Geographic Information
+ Systems</em>, 2001.
+ <li><A NAME="terraflow:geoinformatica"
+ HREF="http://www.cs.duke.edu/geo*/terraflow/papers/journal_terraflow.pdf">
+ Flow computation on massive grid terrains</a>.
+ To appear in <em>GeoInformatica, International Journal on
+ Advances of Computer Science for Geographic Information
+ Systems</em>.
+</ol>
+<p>
Deleted: grass/trunk/raster/r.texture/description.html
--- grass/trunk/raster/r.texture/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.texture/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,98 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.texture</em> - Creates map raster with textural features for
-user-specified raster map layer. The module calculates textural features
-based on spatial dependence matrices at 0, 45, 90, and 135
-degrees for a <em>distance</em> (default = 1).
-<p>
-<em>r.texture</em> uses the algorithms of <a href="i.texture.html">i.texture</a>.
-<em>r.texture</em> reads a GRASS raster map as input and calculates textural
-features based on spatial
-dependence matrices for north-south, east-west, northwest, and southwest
-directions using a side by side neighborhood (i.e., a distance of 1). Be
-sure to carefully set your resolution (using
-<a href="g.region.html">g.region</a>) before running this program, or else your
-computer could run out of memory. Also, make sure that your raster map has
-no more than 255 categories. The output consists into four images for each
-textural feature, one for every direction.</p>
-<p>
-A commonly used texture model is based on the so-called grey level co-occurrence
-matrix. This matrix is a two-dimensional histogram of grey levels
-for a pair of pixels which are separated by a fixed spatial relationship.
-The matrix approximates the joint probability distribution of a pair of pixels.
-Several texture measures are directly computed from the grey level co-occurrence
-matrix.
-<p>
-The following are brief explanations of texture measures:
-<p>
-<ul>
-<li> Angular Second Moment:
-This is a measure of local homogeneity and the opposite of Entropy.
-It is high when the local window a few pixels with high values; low,
-when the pixels are almost equal.
-<li> Contrast:
-This measure considers the amount of local variation and is the opposite of Homogeneity
-(when high pixel values concentrate along the diagonal).
-<li> Correlation:
-This measure analyses the linear dependency of grey levels of neighboring
-pixels. Typically high, when the scale of local texture is larger than the
-<em>distance</em>.
-<li> Entropy:
-This measure is high when the values of the local window have similar values.
-It is low when the values are close to either 0 or 1 (i.e. when the
-pixels in the local window are uniform).
-</ul>
-<h2>NOTES</h2>
-Algorithm taken from:<br>
-Haralick, R.M., K. Shanmugam, and I. Dinstein. 1973. Textural features for
- image classification. <em>IEEE Transactions on Systems, Man, and
- Cybernetics</em>, SMC-3(6):610-621.
-<p>The code was taken by permission from <em>pgmtexture</em>, part of
- PBMPLUS (Copyright 1991, Jef Poskanser and Texas Agricultural Experiment
- Station, employer for hire of James Darrell McCauley). <br>
- Man page of <a href="http://netpbm.sourceforge.net/doc/pgmtexture.html">pgmtexture</a></p>
-<h2>BUGS</h2>
-- The program can run incredibly slow for large raster maps.
-<p>
-- The method for finding the maximal correlation coefficient, which
- requires finding the second largest eigenvalue of a matrix Q, does not
- always converge.
-<b>Haralick, R.M., K. Shanmugam, and I. Dinstein</b> (1973). Textural features for
-<p>
-<b>Bouman C. A., Shapiro M.</b>,(March
- 1994).A Multiscale Random Field Model for Bayesian Image
- Segmentation, IEEE Trans. on Image Processing, vol. 3, no.2.
-<p>
-<b>Haralick R.</b>, (May 1979). <i>Statistical and structural approaches to texture</i>,
- Proceedings of the IEEE, vol. 67, No.5, pp. 786-804</p>
-<h2>SEE ALSO</h2>
-<em><a href="i.smap.html">i.smap</a></em>,
-<em><a href="i.gensigset.html">i.gensigset</a></em>,
-<em><a href="i.pca.html">i.pca</a></em>,
-<em><a href="r.digit.html">r.digit</a></em>,
-<em><a href="i.group.html">i.group</a></em>
-<!-- <em><a href="i.texture.html">i.texture</a></em> -->
-<h2>AUTHOR</h2>
-<a href="mailto:antoniol at ieee.org">G. Antoniol</a> - RCOST (Research Centre on Software Technology - Viale Traiano - 82100 Benevento)<br>
-<a href="mailto:basco at unisannio.it">C. Basco</a> - RCOST (Research Centre on Software Technology - Viale Traiano - 82100 Benevento)<br>
-<a href="mailto:ceccarelli at unisannio.it">M. Ceccarelli</a> - Facolta di Scienze, Universita del Sannio, Benevento
-<p><i>Last changed: $Date$</i></p>
Copied: grass/trunk/raster/r.texture/r.texture.html (from rev 32770, grass/trunk/raster/r.texture/description.html)
--- grass/trunk/raster/r.texture/r.texture.html (rev 0)
+++ grass/trunk/raster/r.texture/r.texture.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,98 @@
+<em>r.texture</em> - Creates map raster with textural features for
+user-specified raster map layer. The module calculates textural features
+based on spatial dependence matrices at 0, 45, 90, and 135
+degrees for a <em>distance</em> (default = 1).
+<p>
+<em>r.texture</em> uses the algorithms of <a href="i.texture.html">i.texture</a>.
+<em>r.texture</em> reads a GRASS raster map as input and calculates textural
+features based on spatial
+dependence matrices for north-south, east-west, northwest, and southwest
+directions using a side by side neighborhood (i.e., a distance of 1). Be
+sure to carefully set your resolution (using
+<a href="g.region.html">g.region</a>) before running this program, or else your
+computer could run out of memory. Also, make sure that your raster map has
+no more than 255 categories. The output consists into four images for each
+textural feature, one for every direction.</p>
+<p>
+A commonly used texture model is based on the so-called grey level co-occurrence
+matrix. This matrix is a two-dimensional histogram of grey levels
+for a pair of pixels which are separated by a fixed spatial relationship.
+The matrix approximates the joint probability distribution of a pair of pixels.
+Several texture measures are directly computed from the grey level co-occurrence
+matrix.
+<p>
+The following are brief explanations of texture measures:
+<p>
+<ul>
+<li> Angular Second Moment:
+This is a measure of local homogeneity and the opposite of Entropy.
+It is high when the local window a few pixels with high values; low,
+when the pixels are almost equal.
+<li> Contrast:
+This measure considers the amount of local variation and is the opposite of Homogeneity
+(when high pixel values concentrate along the diagonal).
+<li> Correlation:
+This measure analyses the linear dependency of grey levels of neighboring
+pixels. Typically high, when the scale of local texture is larger than the
+<em>distance</em>.
+<li> Entropy:
+This measure is high when the values of the local window have similar values.
+It is low when the values are close to either 0 or 1 (i.e. when the
+pixels in the local window are uniform).
+</ul>
+<h2>NOTES</h2>
+Algorithm taken from:<br>
+Haralick, R.M., K. Shanmugam, and I. Dinstein. 1973. Textural features for
+ image classification. <em>IEEE Transactions on Systems, Man, and
+ Cybernetics</em>, SMC-3(6):610-621.
+<p>The code was taken by permission from <em>pgmtexture</em>, part of
+ PBMPLUS (Copyright 1991, Jef Poskanser and Texas Agricultural Experiment
+ Station, employer for hire of James Darrell McCauley). <br>
+ Man page of <a href="http://netpbm.sourceforge.net/doc/pgmtexture.html">pgmtexture</a></p>
+<h2>BUGS</h2>
+- The program can run incredibly slow for large raster maps.
+<p>
+- The method for finding the maximal correlation coefficient, which
+ requires finding the second largest eigenvalue of a matrix Q, does not
+ always converge.
+<b>Haralick, R.M., K. Shanmugam, and I. Dinstein</b> (1973). Textural features for
+<p>
+<b>Bouman C. A., Shapiro M.</b>,(March
+ 1994).A Multiscale Random Field Model for Bayesian Image
+ Segmentation, IEEE Trans. on Image Processing, vol. 3, no.2.
+<p>
+<b>Haralick R.</b>, (May 1979). <i>Statistical and structural approaches to texture</i>,
+ Proceedings of the IEEE, vol. 67, No.5, pp. 786-804</p>
+<h2>SEE ALSO</h2>
+<em><a href="i.smap.html">i.smap</a></em>,
+<em><a href="i.gensigset.html">i.gensigset</a></em>,
+<em><a href="i.pca.html">i.pca</a></em>,
+<em><a href="r.digit.html">r.digit</a></em>,
+<em><a href="i.group.html">i.group</a></em>
+<!-- <em><a href="i.texture.html">i.texture</a></em> -->
+<h2>AUTHOR</h2>
+<a href="mailto:antoniol at ieee.org">G. Antoniol</a> - RCOST (Research Centre on Software Technology - Viale Traiano - 82100 Benevento)<br>
+<a href="mailto:basco at unisannio.it">C. Basco</a> - RCOST (Research Centre on Software Technology - Viale Traiano - 82100 Benevento)<br>
+<a href="mailto:ceccarelli at unisannio.it">M. Ceccarelli</a> - Facolta di Scienze, Universita del Sannio, Benevento
+<p><i>Last changed: $Date$</i></p>
Deleted: grass/trunk/raster/r.thin/description.html
--- grass/trunk/raster/r.thin/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.thin/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,84 +0,0 @@
-<em>r.thin</em> scans the named <em>input</em> raster map
-layer and thins non-zero cells that denote linear features
-into linear features having a single cell width.
-<p>
-<em>r.thin</em> will thin only the non-zero cells of the
-named <em>input</em> raster map layer within the current
-geographic region settings. The cell width of the thinned
-<em>output</em> raster map layer will be equal to the cell
-resolution of the currently set geographic region. All of
-the thinned linear features will have the width of a single
-cell.
-<p>
-<em>r.thin</em> will create a new <em>output</em> raster
-data file containing the thinned linear features.
-<em>r.thin</em> assumes that linear features are encoded
-with positive values on a background of 0's in the
-<em>input</em> raster data file.
-<h2>NOTE</h2>
-<em>r.thin</em> only creates raster map layers. You will need to run
-<em><a href="r.to.vect.html">r.to.vect</a></em>
-on the resultant raster map to create a vector
-(<em><a href="v.digit.html">v.digit</a></em>) map layer.
-<p>
-<em>r.thin</em> may create small spurs or "dangling lines"
-during the thinning process. These spurs may be removed
-(after creating a vector map layer) by
-<em><a href="v.clean.html">v.clean</a></em>.
-<p>
-<em>r.thin</em> creates a 0/1 output map.
-<h2>NOTE</h2>
-This code implements the thinning algorithm described in
-"Analysis of Thinning Algorithms Using Mathematical
-Morphology" by Ben-Kwei Jang and Ronlad T. Chin in
-<em>Transactions on Pattern Analysis and Machine
-Intelligence</em>, vol. 12, No. 6, June 1990. The
-definition Jang and Chin give of the thinning process is
-"successive removal of outer layers of pixels from an
-object while retaining any pixels whose removal would alter
-the connectivity or shorten the legs of the sceleton."
-<p>
-The sceleton is finally thinned when the thinning process
-converges; i.e., "no further pixels can be removed without
-altering the connectivity or shortening the sceleton legs"
-(p. 541). The authors prove that the thinning process
-described always converges and produces one-pixel thick
-sceletons. The number of iterations depends on the
-original thickness of the object. Each iteration peels off
-the outside pixels from the object. Therefore, if the
-object is <= n pixels thick, the algorithm should
-converge in <= iterations.
-<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.to.vect.html">r.to.vect</a></em>,
-<em><a href="v.clean.html">v.clean</a></em>,
-<em><a href="v.build.html">v.build</a></em>
-<h2>AUTHOR</h2>
-Olga Waupotitsch, U.S.Army Construction Engineering Research Laboratory
-<p>
-The code for finding the bounding box as well as input/output code
-was written by Mike Baba (DBA Systems, 1990) and Jean Ezell (USACERL, 1988).
Copied: grass/trunk/raster/r.thin/r.thin.html (from rev 32770, grass/trunk/raster/r.thin/description.html)
--- grass/trunk/raster/r.thin/r.thin.html (rev 0)
+++ grass/trunk/raster/r.thin/r.thin.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,84 @@
+<em>r.thin</em> scans the named <em>input</em> raster map
+layer and thins non-zero cells that denote linear features
+into linear features having a single cell width.
+<p>
+<em>r.thin</em> will thin only the non-zero cells of the
+named <em>input</em> raster map layer within the current
+geographic region settings. The cell width of the thinned
+<em>output</em> raster map layer will be equal to the cell
+resolution of the currently set geographic region. All of
+the thinned linear features will have the width of a single
+cell.
+<p>
+<em>r.thin</em> will create a new <em>output</em> raster
+data file containing the thinned linear features.
+<em>r.thin</em> assumes that linear features are encoded
+with positive values on a background of 0's in the
+<em>input</em> raster data file.
+<h2>NOTE</h2>
+<em>r.thin</em> only creates raster map layers. You will need to run
+<em><a href="r.to.vect.html">r.to.vect</a></em>
+on the resultant raster map to create a vector
+(<em><a href="v.digit.html">v.digit</a></em>) map layer.
+<p>
+<em>r.thin</em> may create small spurs or "dangling lines"
+during the thinning process. These spurs may be removed
+(after creating a vector map layer) by
+<em><a href="v.clean.html">v.clean</a></em>.
+<p>
+<em>r.thin</em> creates a 0/1 output map.
+<h2>NOTE</h2>
+This code implements the thinning algorithm described in
+"Analysis of Thinning Algorithms Using Mathematical
+Morphology" by Ben-Kwei Jang and Ronlad T. Chin in
+<em>Transactions on Pattern Analysis and Machine
+Intelligence</em>, vol. 12, No. 6, June 1990. The
+definition Jang and Chin give of the thinning process is
+"successive removal of outer layers of pixels from an
+object while retaining any pixels whose removal would alter
+the connectivity or shorten the legs of the sceleton."
+<p>
+The sceleton is finally thinned when the thinning process
+converges; i.e., "no further pixels can be removed without
+altering the connectivity or shortening the sceleton legs"
+(p. 541). The authors prove that the thinning process
+described always converges and produces one-pixel thick
+sceletons. The number of iterations depends on the
+original thickness of the object. Each iteration peels off
+the outside pixels from the object. Therefore, if the
+object is <= n pixels thick, the algorithm should
+converge in <= iterations.
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em>,
+<em><a href="r.to.vect.html">r.to.vect</a></em>,
+<em><a href="v.clean.html">v.clean</a></em>,
+<em><a href="v.build.html">v.build</a></em>
+<h2>AUTHOR</h2>
+Olga Waupotitsch, U.S.Army Construction Engineering Research Laboratory
+<p>
+The code for finding the bounding box as well as input/output code
+was written by Mike Baba (DBA Systems, 1990) and Jean Ezell (USACERL, 1988).
Deleted: grass/trunk/raster/r.timestamp/description.html
--- grass/trunk/raster/r.timestamp/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.timestamp/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,109 +0,0 @@
-This command has 2 modes of operation. If no date argument is supplied, then
-the current timestamp for the raster map is printed. If a date argument is
-specified, then the timestamp for the raster map is set to the specified
-date(s). See EXAMPLES below.
-<h2>NOTES</h2>
-Strings containing spaces should be quoted. For specifying a range
-of time, the two timestamps should be separated by a forward slash.
-To remove the timestamp from a raster map, use <b>date=</b><em>none</em>.
-<h2>EXAMPLES</h2>
- <b>r.timestamp map=soils</b><br>
- Prints the timestamp for the "soils" raster map. If
- there is no timestamp for soils, nothing is printed. If
- there is a timestamp, one or two time strings are printed,
- depending on if the timestamp for the map consists of a
- single date or two dates (ie start and end dates).
-<p>
-<b> r.timestamp map=soils date='15 sep 1987'</b><br>
- Sets the timestamp for "soils" to the single date<br>
- "15 sep 1987"
-<p>
-<b> r.timestamp map=soils date='15 sep 1987/20 feb 1988'</b><br>
- Sets the timestamp for "soils" to have the start date<br>
- "15 sep 1987" and the end date "20 feb 1988"
-<p>
-<b> r.timestamp map=soils date=none</b><br>
- Removes the timestamp for the "soils" raster map
-<h2>TIMESTAMP FORMAT</h2>
- The timestamp values must use the format as described in the
- GRASS datetime library. The source tree for this library
- should have a description of the format. For convience, the
- formats as of Feb, 1996 are reproduced here:
-<p>
- There are two types of datetime values: absolute and
- relative. Absolute values specify exact dates and/or times.
- Relative values specify a span of time. Some examples will
- help clarify:
-<p>
-<b>Absolute</b><p>
- The general format for absolute values is:
-<p><tt>
- day month year [bc] hour:minute:seconds timezone
-<p>
- day is 1-31<br>
- month is jan,feb,...,dec<br>
- year is 4 digit year<br>
- [bc] if present, indicates dates is BC<br>
- hour is 0-23 (24 hour clock)<br>
- mintue is 0-59<br>
- second is 0-59.9999 (fractions of second allowed)<br>
- timezone is +hhmm or -hhmm (eg, -0600)<br>
-<p>
- parts can be missing
-<p>
- 1994 [bc]<br>
- Jan 1994 [bc]<br>
- 15 jan 1000 [bc]<br>
- 15 jan 1994 [bc] 10 [+0000]<br>
- 15 jan 1994 [bc] 10:00 [+0100]<br>
- 15 jan 1994 [bc] 10:00:23.34 [-0500]<br>
-<p>
-</tt>
-<b>Relative</b><p>
- There are two types of relative datetime values, year-
- month and day-second. The formats are:
-<p><tt>
- [-] # years # months<br>
- [-] # days # hours # minutes # seconds
-</tt><p>
- The words years, months, days, hours, minutes, seconds
- are literal words, and the # are the numeric values.<br>
- Examples:<p>
-<tt>
- 2 years<br>
- 5 months<br>
- 2 years 5 months<br>
- 100 days<br>
- 15 hours 25 minutes 35.34 seconds<br>
- 100 days 25 minutes<br>
- 1000 hours 35.34 seconds
-</tt><p>
- The following are <i>illegal</i> because it mixes year-month
- and day-second (because the number of days in a month
- or in a year vary):<p>
-<tt>
- 3 months 15 days<br>
- 3 years 10 days
-</tt>
-<h2>SEE ALSO</h2>
-<em><a HREF="v.timestamp.html">v.timestamp</a></em>
-<h2>BUGS</h2>
-Spaces in the timestamp value are required.
-<h2>AUTHOR</h2>
-Michael Shapiro, <br>
-U.S.Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.timestamp/r.timestamp.html (from rev 32770, grass/trunk/raster/r.timestamp/description.html)
--- grass/trunk/raster/r.timestamp/r.timestamp.html (rev 0)
+++ grass/trunk/raster/r.timestamp/r.timestamp.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,109 @@
+This command has 2 modes of operation. If no date argument is supplied, then
+the current timestamp for the raster map is printed. If a date argument is
+specified, then the timestamp for the raster map is set to the specified
+date(s). See EXAMPLES below.
+<h2>NOTES</h2>
+Strings containing spaces should be quoted. For specifying a range
+of time, the two timestamps should be separated by a forward slash.
+To remove the timestamp from a raster map, use <b>date=</b><em>none</em>.
+<h2>EXAMPLES</h2>
+ <b>r.timestamp map=soils</b><br>
+ Prints the timestamp for the "soils" raster map. If
+ there is no timestamp for soils, nothing is printed. If
+ there is a timestamp, one or two time strings are printed,
+ depending on if the timestamp for the map consists of a
+ single date or two dates (ie start and end dates).
+<p>
+<b> r.timestamp map=soils date='15 sep 1987'</b><br>
+ Sets the timestamp for "soils" to the single date<br>
+ "15 sep 1987"
+<p>
+<b> r.timestamp map=soils date='15 sep 1987/20 feb 1988'</b><br>
+ Sets the timestamp for "soils" to have the start date<br>
+ "15 sep 1987" and the end date "20 feb 1988"
+<p>
+<b> r.timestamp map=soils date=none</b><br>
+ Removes the timestamp for the "soils" raster map
+<h2>TIMESTAMP FORMAT</h2>
+ The timestamp values must use the format as described in the
+ GRASS datetime library. The source tree for this library
+ should have a description of the format. For convience, the
+ formats as of Feb, 1996 are reproduced here:
+<p>
+ There are two types of datetime values: absolute and
+ relative. Absolute values specify exact dates and/or times.
+ Relative values specify a span of time. Some examples will
+ help clarify:
+<p>
+<b>Absolute</b><p>
+ The general format for absolute values is:
+<p><tt>
+ day month year [bc] hour:minute:seconds timezone
+<p>
+ day is 1-31<br>
+ month is jan,feb,...,dec<br>
+ year is 4 digit year<br>
+ [bc] if present, indicates dates is BC<br>
+ hour is 0-23 (24 hour clock)<br>
+ mintue is 0-59<br>
+ second is 0-59.9999 (fractions of second allowed)<br>
+ timezone is +hhmm or -hhmm (eg, -0600)<br>
+<p>
+ parts can be missing
+<p>
+ 1994 [bc]<br>
+ Jan 1994 [bc]<br>
+ 15 jan 1000 [bc]<br>
+ 15 jan 1994 [bc] 10 [+0000]<br>
+ 15 jan 1994 [bc] 10:00 [+0100]<br>
+ 15 jan 1994 [bc] 10:00:23.34 [-0500]<br>
+<p>
+</tt>
+<b>Relative</b><p>
+ There are two types of relative datetime values, year-
+ month and day-second. The formats are:
+<p><tt>
+ [-] # years # months<br>
+ [-] # days # hours # minutes # seconds
+</tt><p>
+ The words years, months, days, hours, minutes, seconds
+ are literal words, and the # are the numeric values.<br>
+ Examples:<p>
+<tt>
+ 2 years<br>
+ 5 months<br>
+ 2 years 5 months<br>
+ 100 days<br>
+ 15 hours 25 minutes 35.34 seconds<br>
+ 100 days 25 minutes<br>
+ 1000 hours 35.34 seconds
+</tt><p>
+ The following are <i>illegal</i> because it mixes year-month
+ and day-second (because the number of days in a month
+ or in a year vary):<p>
+<tt>
+ 3 months 15 days<br>
+ 3 years 10 days
+</tt>
+<h2>SEE ALSO</h2>
+<em><a HREF="v.timestamp.html">v.timestamp</a></em>
+<h2>BUGS</h2>
+Spaces in the timestamp value are required.
+<h2>AUTHOR</h2>
+Michael Shapiro, <br>
+U.S.Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.to.rast3/description.html
--- grass/trunk/raster/r.to.rast3/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.to.rast3/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,56 +0,0 @@
-Converts 2D raster map(s) into one G3D raster map.
-If the 2d and 3d region settings are different,
-the 2d resolution will be adjust to the 3d resolution.
-<center>
-<img src=r.to.rast3.png border=0><br>
-<table border=0 width=700>
-<tr><td><center>
-<i>How r.to.rast3 works</i>
-</center></td></tr>
-</table>
-</center>
-<h2>NOTES</h2>
-Every 2D raster map is copied as one slice to the G3D raster map. Slices
-are counted from bottom to the top, so the bottom slice has to be number 1.
-<br><br>
-If fewer 2D raster maps are provided than depths, the last give 2D map is
-used to fill up the G3D slices to the top.
-<h2>EXAMPLES</h2>
-<h3>EXAMPLE 1</h3>
-This example shows how to convert 6 maps into one 3d map with 6 layers.
-<br>
-# Mapset data in Location slovakia3d
-r.to.rast3 input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=new_3dmap
-</pre></div>
-<h3>EXAMPLE 2</h3>
-This example shows how to convert 3 maps into one 3d map with 6 layers.
-<br>
-r.to.rast3 input=prec_1,prec_2,prec_3 output=new_3dmap
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="r3.to.rast.html">r3.to.rast</a>,
-<a href="r.to.rast3elev.html">r.to.rast3elev</a>
-</em>
-<h2>AUTHOR</h2>
-Soeren Gebbert
Copied: grass/trunk/raster/r.to.rast3/r.to.rast3.html (from rev 32770, grass/trunk/raster/r.to.rast3/description.html)
--- grass/trunk/raster/r.to.rast3/r.to.rast3.html (rev 0)
+++ grass/trunk/raster/r.to.rast3/r.to.rast3.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,56 @@
+<h2>DESCRIPTION</h2>
+Converts 2D raster map(s) into one G3D raster map.
+If the 2d and 3d region settings are different,
+the 2d resolution will be adjust to the 3d resolution.
+<center>
+<img src=r.to.rast3.png border=0><br>
+<table border=0 width=700>
+<tr><td><center>
+<i>How r.to.rast3 works</i>
+</center></td></tr>
+</table>
+</center>
+<h2>NOTES</h2>
+Every 2D raster map is copied as one slice to the G3D raster map. Slices
+are counted from bottom to the top, so the bottom slice has to be number 1.
+<br><br>
+If fewer 2D raster maps are provided than depths, the last give 2D map is
+used to fill up the G3D slices to the top.
+<h2>EXAMPLES</h2>
+<h3>EXAMPLE 1</h3>
+This example shows how to convert 6 maps into one 3d map with 6 layers.
+<br>
+# Mapset data in Location slovakia3d
+r.to.rast3 input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 output=new_3dmap
+</pre></div>
+<h3>EXAMPLE 2</h3>
+This example shows how to convert 3 maps into one 3d map with 6 layers.
+<br>
+r.to.rast3 input=prec_1,prec_2,prec_3 output=new_3dmap
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r3.to.rast.html">r3.to.rast</a>,
+<a href="r.to.rast3elev.html">r.to.rast3elev</a>
+</em>
+<h2>AUTHOR</h2>
+Soeren Gebbert
Deleted: grass/trunk/raster/r.to.rast3elev/description.html
--- grass/trunk/raster/r.to.rast3elev/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.to.rast3elev/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,58 +0,0 @@
-Creates a 3D volume map based on 2D elevation and value raster maps.
-<center>
-<img src=r.to.rast3elev.png border=0><br>
-<tr><td><center>
-<i>How r.to.rast3elev works</i>
-</table>
-</center>
-<h2>NOTES</h2>
-The hight of the 2D elevation maps will be used to verify the position
-within the 3D region. If the cell value of the elevation raster maps is located within the 3d region, the
-cell value of the appropriate 2D input raster maps will be written to the associated 3d cell.
-There are flags and options to fill the upper and lower 3D cells with a specific value, or the
-input raster maps values.
-<h2>Example</h2>
-Simple Spearfish example
-g.region -d
-g.region res=200 res3=200 t=5000 b=0 tbres=100
-# Write the values of raster map soils based on the elevation of elevation.10m
-# to the 3D map volev
-r.elev.to.rast3 in=soils elev=elevation.10m out=volev
-# Write the values of map soils based on the elevation of elevation.10m
-# to the 3D map volev_l and fill the lower cells with the soils map values
-r.elev.to.rast3 in=soils elev=elevation.10m out=volev_l -l
-# to the 3D map volev_u and fill the upper cells with the soils map values
-r.elev.to.rast3 in=soils elev=elevation.10m out=volev_u -u
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="r.to.rast3.html">r.to.rast3</a></em><br>
-<em><a href="r3.cross.rast.html">r3.cross.rast</a></em><br>
-<em><a href="g.region.html">g.region</a></em><br>
-<h2>AUTHOR</h2>
-Soeren Gebbert
Copied: grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html (from rev 32770, grass/trunk/raster/r.to.rast3elev/description.html)
--- grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html (rev 0)
+++ grass/trunk/raster/r.to.rast3elev/r.to.rast3elev.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,58 @@
+Creates a 3D volume map based on 2D elevation and value raster maps.
+<center>
+<img src=r.to.rast3elev.png border=0><br>
+<tr><td><center>
+<i>How r.to.rast3elev works</i>
+</table>
+</center>
+<h2>NOTES</h2>
+The hight of the 2D elevation maps will be used to verify the position
+within the 3D region. If the cell value of the elevation raster maps is located within the 3d region, the
+cell value of the appropriate 2D input raster maps will be written to the associated 3d cell.
+There are flags and options to fill the upper and lower 3D cells with a specific value, or the
+input raster maps values.
+<h2>Example</h2>
+Simple Spearfish example
+g.region -d
+g.region res=200 res3=200 t=5000 b=0 tbres=100
+# Write the values of raster map soils based on the elevation of elevation.10m
+# to the 3D map volev
+r.elev.to.rast3 in=soils elev=elevation.10m out=volev
+# Write the values of map soils based on the elevation of elevation.10m
+# to the 3D map volev_l and fill the lower cells with the soils map values
+r.elev.to.rast3 in=soils elev=elevation.10m out=volev_l -l
+# to the 3D map volev_u and fill the upper cells with the soils map values
+r.elev.to.rast3 in=soils elev=elevation.10m out=volev_u -u
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="r.to.rast3.html">r.to.rast3</a></em><br>
+<em><a href="r3.cross.rast.html">r3.cross.rast</a></em><br>
+<em><a href="g.region.html">g.region</a></em><br>
+<h2>AUTHOR</h2>
+Soeren Gebbert
Deleted: grass/trunk/raster/r.to.vect/description.html
--- grass/trunk/raster/r.to.vect/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.to.vect/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,103 +0,0 @@
-<em>r.to.vect</em> scans the named <b>input</b> raster map
-layer, extracts points, lines or area edge features from it, converts data
-to GRASS vector format.
-<h3>Points</h3>
-The <em>r.to.vect</em> program extracts data from a GRASS raster map layer and stores output
-in a new GRASS <em>vector</em> file.
-<h3>Lines</h3>
-<em>r.to.vect</em> assumes that the <em>input</em> map has been thinned
-using <em><a href="r.thin.html">r.thin</a></em>.
-<p>
-<em>r.to.vect</em> extracts vectors (aka, "arcs") from a
-raster map. These arcs may represent linear features
-(like roads or streams), or may represent area edge
-features (like political boundaries, or soil mapping
-units).
-<p>
-<em><a href="r.thin.html">r.thin</a></em> and <em>r.to.vect</em>
-may create excessive nodes at every junction, and may create small spurs
-or "dangling lines" during the thinning and vectorization process.
-These excessive nodes and spurs may be removed using
-<h3>Areas</h3>
-<em>r.to.vect</em> first traces the perimeter of each unique
-area in the raster map layer and creates vector data to
-represent it. The cell category values for the raster map
-layer will be used to create attribute information for the
-resultant vector area edge data.
-<p>
-A true vector tracing of the area edges might appear
-blocky, since the vectors outline the edges of raster data
-that are stored in rectangular cells. To produce a
-better-looking vector map, <em>r.to.vect</em> smoothes the
-corners of the vector data as they are being extracted. At
-each change in direction (i.e., each corner), the two
-midpoints of the corner cell (half the cell's height and
-width) are taken, and the line segment connecting them is
-used to outline this corner in the resultant vector map.
-(The cell's cornermost node is ignored.) Because vectors
-are smoothed by this program, the resulting vector map will
-not be "true" to the raster map from which it was created.
-The user should check the resolution of the geographic
-region (and the original data) to estimate the possible
-error introduced by smoothing.
-<p>
-<em>r.to.vect</em> extracts only area edges from the named raster input file.
-If the raster map contains other data (i.e., line edges, or point data) the
-output may be wrong.
-<h2>BUGS</h2>
-For feature=line the input raster map MUST be thinned by
-<em><a href="r.thin.html">r.thin</a></em>;
-if not, <em>r.to.vect</em> may crash.
-<h2>AUTHOR</h2>
-<b>Points</b><br>
-Bill Brown<br>
-<br>
-<b>Lines</b><br>
-Mike Baba<br>
-DBA Systems, Inc.<br>
-10560 Arrowhead Drive<br>
-Fairfax, Virginia 22030<br>
-<br>
-<b>Areas</b><br>
-<em>Original</em> version of <em>r.poly</em>:
-<br>
-Jean Ezell and Andrew Heekin,
-<br>
-U.S. Army Construction Engineering
-Research Laboratory
-<p>
-<em>Modified</em> program for smoothed lines:
-<br>
-David Satnik,
-Central Washington University
-<br>
-Updated 2001 by Andrea Aime, Modena, Italy<br>
-<br>
-<b>Update</b><br>
-Original r.to.sites, r.line and r.poly merged and updated to 5.7 by Radim Blazek
Copied: grass/trunk/raster/r.to.vect/r.to.vect.html (from rev 32770, grass/trunk/raster/r.to.vect/description.html)
--- grass/trunk/raster/r.to.vect/r.to.vect.html (rev 0)
+++ grass/trunk/raster/r.to.vect/r.to.vect.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,103 @@
+<em>r.to.vect</em> scans the named <b>input</b> raster map
+layer, extracts points, lines or area edge features from it, converts data
+to GRASS vector format.
+<h3>Points</h3>
+The <em>r.to.vect</em> program extracts data from a GRASS raster map layer and stores output
+in a new GRASS <em>vector</em> file.
+<h3>Lines</h3>
+<em>r.to.vect</em> assumes that the <em>input</em> map has been thinned
+using <em><a href="r.thin.html">r.thin</a></em>.
+<p>
+<em>r.to.vect</em> extracts vectors (aka, "arcs") from a
+raster map. These arcs may represent linear features
+(like roads or streams), or may represent area edge
+features (like political boundaries, or soil mapping
+units).
+<p>
+<em><a href="r.thin.html">r.thin</a></em> and <em>r.to.vect</em>
+may create excessive nodes at every junction, and may create small spurs
+or "dangling lines" during the thinning and vectorization process.
+These excessive nodes and spurs may be removed using
+<h3>Areas</h3>
+<em>r.to.vect</em> first traces the perimeter of each unique
+area in the raster map layer and creates vector data to
+represent it. The cell category values for the raster map
+layer will be used to create attribute information for the
+resultant vector area edge data.
+<p>
+A true vector tracing of the area edges might appear
+blocky, since the vectors outline the edges of raster data
+that are stored in rectangular cells. To produce a
+better-looking vector map, <em>r.to.vect</em> smoothes the
+corners of the vector data as they are being extracted. At
+each change in direction (i.e., each corner), the two
+midpoints of the corner cell (half the cell's height and
+width) are taken, and the line segment connecting them is
+used to outline this corner in the resultant vector map.
+(The cell's cornermost node is ignored.) Because vectors
+are smoothed by this program, the resulting vector map will
+not be "true" to the raster map from which it was created.
+The user should check the resolution of the geographic
+region (and the original data) to estimate the possible
+error introduced by smoothing.
+<p>
+<em>r.to.vect</em> extracts only area edges from the named raster input file.
+If the raster map contains other data (i.e., line edges, or point data) the
+output may be wrong.
+<h2>BUGS</h2>
+For feature=line the input raster map MUST be thinned by
+<em><a href="r.thin.html">r.thin</a></em>;
+if not, <em>r.to.vect</em> may crash.
+<h2>AUTHOR</h2>
+<b>Points</b><br>
+Bill Brown<br>
+<br>
+<b>Lines</b><br>
+Mike Baba<br>
+DBA Systems, Inc.<br>
+10560 Arrowhead Drive<br>
+Fairfax, Virginia 22030<br>
+<br>
+<b>Areas</b><br>
+<em>Original</em> version of <em>r.poly</em>:
+<br>
+Jean Ezell and Andrew Heekin,
+<br>
+U.S. Army Construction Engineering
+Research Laboratory
+<p>
+<em>Modified</em> program for smoothed lines:
+<br>
+David Satnik,
+Central Washington University
+<br>
+Updated 2001 by Andrea Aime, Modena, Italy<br>
+<br>
+<b>Update</b><br>
+Original r.to.sites, r.line and r.poly merged and updated to 5.7 by Radim Blazek
Deleted: grass/trunk/raster/r.topidx/description.html
--- grass/trunk/raster/r.topidx/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.topidx/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,42 +0,0 @@
-<em>r.topidx</em> creates topographic index (wetness index), ln(a/tan(beta)), map from
-elevation map
-<p>
-where
-<dl>
-<dd>a: the area of the hillslope per unit contour length that drains through any point,
-<p>
-<dd>tan(beta): the local surface topographic slope (delta vertical) / (delta horizontal).
-</dl>
-<p>
-Input maps may have NULL values. For example, if you have a MASK for
-a watershed (basin map from <em>r.water.outlet</em>), the
-following command will create a masked elevation map (belev):
-r.mapcalc "belev = if(isnull(basin), basin, elev)"
-</pre></div>
-<p>
-<em>r.stats -Anc</em> prints out averaged statistics for topographic index.
-<h2>SEE ALSO</h2>
-<em><a href="r.topmodel.html">r.topmodel</a></em>,
-<em><a href="r.water.outlet.html">r.water.outlet</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>
-<h2>REFERENCE</h2>
-Moore, I.D., R.B. Grayson, and A.R. Ladson, 1991. Digital terrain
-modeling: A review of hydrological, geomorphological, and biological
-applications. Hydrol. Processes 5:3-30.
-<h2>AUTHORS</h2>
-Main algorithm sources are rewritten from GRIDATB.FOR.
-<br>
-Thanks to Keith Beven.
-<p>
-GRASS port by <a href=mailto:grass4u gmail com>Huidae Cho</a><br>
-Hydro Laboratory, Kyungpook National University, South Korea
Copied: grass/trunk/raster/r.topidx/r.topidx.html (from rev 32770, grass/trunk/raster/r.topidx/description.html)
--- grass/trunk/raster/r.topidx/r.topidx.html (rev 0)
+++ grass/trunk/raster/r.topidx/r.topidx.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,42 @@
+<em>r.topidx</em> creates topographic index (wetness index), ln(a/tan(beta)), map from
+elevation map
+<p>
+where
+<dl>
+<dd>a: the area of the hillslope per unit contour length that drains through any point,
+<p>
+<dd>tan(beta): the local surface topographic slope (delta vertical) / (delta horizontal).
+</dl>
+<p>
+Input maps may have NULL values. For example, if you have a MASK for
+a watershed (basin map from <em>r.water.outlet</em>), the
+following command will create a masked elevation map (belev):
+r.mapcalc "belev = if(isnull(basin), basin, elev)"
+</pre></div>
+<p>
+<em>r.stats -Anc</em> prints out averaged statistics for topographic index.
+<h2>SEE ALSO</h2>
+<em><a href="r.topmodel.html">r.topmodel</a></em>,
+<em><a href="r.water.outlet.html">r.water.outlet</a></em>,
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>
+<h2>REFERENCE</h2>
+Moore, I.D., R.B. Grayson, and A.R. Ladson, 1991. Digital terrain
+modeling: A review of hydrological, geomorphological, and biological
+applications. Hydrol. Processes 5:3-30.
+<h2>AUTHORS</h2>
+Main algorithm sources are rewritten from GRIDATB.FOR.
+<br>
+Thanks to Keith Beven.
+<p>
+GRASS port by <a href=mailto:grass4u gmail com>Huidae Cho</a><br>
+Hydro Laboratory, Kyungpook National University, South Korea
Deleted: grass/trunk/raster/r.topmodel/description.html
--- grass/trunk/raster/r.topmodel/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.topmodel/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,60 +0,0 @@
-<b><em>r.topmodel</em></b> simulates TOPMODEL which is a physically based
-hydrologic model.
-<p>
-Note: (i) means input; (o) means output; (o/i) means input or output
-<p>
-The <b>-i</b> flag indicates that input data are given for (o/i). Without this
-flag, all inputs (i) and intermediate outputs (o/i) should be given. For
-example, [belevation] map will be created from [elevation] and [basin] in every
-run. However, given the same [elevation] and [basin], [belevation] output will
-be the same all the time, so r.topmodel can directly take [belevation] as an
-input with this flag to save time.
-<p>
-<h3>Selected Parameters:</h3>
-<dl>
-<dt><b>depressionless</b> map is created as follows:</dt>
-<dd><div class="code"><pre>
-r.fill.dir input=elevation elev=depressionless dir=direction type=grass
-</pre></div>
-This option can be omitted if [elevation] map is already depressionless.
-</dd>
-<p>
-<dt><b>belevation</b> map is created from [elevation] with [basin] mask applied:</dt>
-r.mapcalc "belevation = if(basin == 0 || isnull(basin), null(), elevation)"
-</pre></div></dd>
-<p>
-<dt><b>topidx</b> map is created as follows:</dt>
-r.topidx input=elevation output=topidx
-</pre></div></dd>
-<p>
-<dt><b>Qobs</b></dt>
-<dd>Compare simulated flows with observed flows and calculate model
-efficiency.
-</dd>
-<p>
-</dl>
-<h2>SEE ALSO</h2>
-<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.topidx.html">r.topidx</a></em>,
-<em><a href="http://geni.ath.cx/r.topmodel.html">How to run r.topmodel</a></em>
-<h2>AUTHORS</h2>
-Main algorithm sources are rewritten in C based on TMOD9502.FOR.
-<br>
-<p>
Copied: grass/trunk/raster/r.topmodel/r.topmodel.html (from rev 32770, grass/trunk/raster/r.topmodel/description.html)
--- grass/trunk/raster/r.topmodel/r.topmodel.html (rev 0)
+++ grass/trunk/raster/r.topmodel/r.topmodel.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,60 @@
+<b><em>r.topmodel</em></b> simulates TOPMODEL which is a physically based
+hydrologic model.
+<p>
+Note: (i) means input; (o) means output; (o/i) means input or output
+<p>
+The <b>-i</b> flag indicates that input data are given for (o/i). Without this
+flag, all inputs (i) and intermediate outputs (o/i) should be given. For
+example, [belevation] map will be created from [elevation] and [basin] in every
+run. However, given the same [elevation] and [basin], [belevation] output will
+be the same all the time, so r.topmodel can directly take [belevation] as an
+input with this flag to save time.
+<p>
+<h3>Selected Parameters:</h3>
+<dl>
+<dt><b>depressionless</b> map is created as follows:</dt>
+<dd><div class="code"><pre>
+r.fill.dir input=elevation elev=depressionless dir=direction type=grass
+</pre></div>
+This option can be omitted if [elevation] map is already depressionless.
+</dd>
+<p>
+<dt><b>belevation</b> map is created from [elevation] with [basin] mask applied:</dt>
+r.mapcalc "belevation = if(basin == 0 || isnull(basin), null(), elevation)"
+</pre></div></dd>
+<p>
+<dt><b>topidx</b> map is created as follows:</dt>
+r.topidx input=elevation output=topidx
+</pre></div></dd>
+<p>
+<dt><b>Qobs</b></dt>
+<dd>Compare simulated flows with observed flows and calculate model
+efficiency.
+</dd>
+<p>
+</dl>
+<h2>SEE ALSO</h2>
+<em><a href="r.fill.dir.html">r.fill.dir</a></em>,
+<em><a href="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a href="r.topidx.html">r.topidx</a></em>,
+<em><a href="http://geni.ath.cx/r.topmodel.html">How to run r.topmodel</a></em>
+<h2>AUTHORS</h2>
+Main algorithm sources are rewritten in C based on TMOD9502.FOR.
+<br>
+<p>
Deleted: grass/trunk/raster/r.transect/description.html
--- grass/trunk/raster/r.transect/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.transect/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,46 +0,0 @@
-This program outputs, in ASCII, the values in a raster map
-which lie along one or more user-defined transect lines.
-The transects are described by their starting coordinates,
-azimuth, and distance.
-<!-- The transects may be single-cell
- wide lines, or multiple-cell wide lines. The output, for
- each transect, may be the values at each of the cells, or a
- single aggregate value (e.g., average or median value). -->
-<p>
-The <b>line</b> parameter is a definition of (each) transect line,
-specified by the geographic coordinates of its starting point (<em>easting,
-northing</em>), the angle and direction of its travel (<em>azimuth</em>),
-and its distance (<em>distance</em>).
-<p>
-The <em>azimuth</em> is an angle, in degrees, measured to
-the east of north. The <em>distance</em> is in map units
-(meters for a metered database, like UTM).
-<p>
-The <b>null</b> parameter can optionally be set to change the character
-string representing null values.
-<h2>NOTES</h2>
-This program is a front-end to the <em>
-<a href="r.profile.html">r.profile</a></em> program. It simply converts the
-azimuth and distance to an ending coordinate and then runs <em>
-<a href="r.profile.html">r.profile</a></em>.
-There once were <b>width=</b> and <b>result=</b><em>raw|median|average</em>
- options which are not currently implemented.
-<h2>SEE ALSO</h2>
-<em><a href="r.profile.html">r.profile</a></em>,
-<em><a href="gm_profile.html">gis.m: PROFILE TOOL</a></em>
-<h2>AUTHOR</h2>
-Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.transect/r.transect.html (from rev 32770, grass/trunk/raster/r.transect/description.html)
--- grass/trunk/raster/r.transect/r.transect.html (rev 0)
+++ grass/trunk/raster/r.transect/r.transect.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,46 @@
+This program outputs, in ASCII, the values in a raster map
+which lie along one or more user-defined transect lines.
+The transects are described by their starting coordinates,
+azimuth, and distance.
+<!-- The transects may be single-cell
+ wide lines, or multiple-cell wide lines. The output, for
+ each transect, may be the values at each of the cells, or a
+ single aggregate value (e.g., average or median value). -->
+<p>
+The <b>line</b> parameter is a definition of (each) transect line,
+specified by the geographic coordinates of its starting point (<em>easting,
+northing</em>), the angle and direction of its travel (<em>azimuth</em>),
+and its distance (<em>distance</em>).
+<p>
+The <em>azimuth</em> is an angle, in degrees, measured to
+the east of north. The <em>distance</em> is in map units
+(meters for a metered database, like UTM).
+<p>
+The <b>null</b> parameter can optionally be set to change the character
+string representing null values.
+<h2>NOTES</h2>
+This program is a front-end to the <em>
+<a href="r.profile.html">r.profile</a></em> program. It simply converts the
+azimuth and distance to an ending coordinate and then runs <em>
+<a href="r.profile.html">r.profile</a></em>.
+There once were <b>width=</b> and <b>result=</b><em>raw|median|average</em>
+ options which are not currently implemented.
+<h2>SEE ALSO</h2>
+<em><a href="r.profile.html">r.profile</a></em>,
+<em><a href="gm_profile.html">gis.m: PROFILE TOOL</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.volume/description.html
--- grass/trunk/raster/r.volume/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.volume/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,108 +0,0 @@
-<em>r.volume</em> is a tool for summing cell values within clumps
-and calculating volumes and centroids of patches or clumps.
-<p>
-<em>r.volume</em> generates a table containing the sum of all cells from
-a data_map layer sorted by category on a clump map, and optionally
-generates a vector points map of the centroids for each clump. If a
-clump map is not specified, the current MASK is used.
-The sum is multiplied by the area of a cell to give the volume
-occupied by that cell. See below for an example of the output
-table.
-<!-- The table is placed in the user's home directory in the
-file Gvol.report. (or not???)
-NOTE: I can't find any evidence of this in the source code, and I have tested
-the module out as of Jan 10, 2008. I'll leave the above comment about
-automatic report generation commented out from the manpage for now, unless I get
-notification otherwise. - EP
-<h2>NOTES</h2>
-<p>
-If a clump map is not given and a MASK not set, the program exits
-with an error message.
-<p>
-<em>r.volume</em> works in the current region and respects the current MASK.
-<p>
-<h2>EXAMPLE</h2>
-The following report was generated by the command:
-(spearfish data base; fields.only is the fields layer without the
-National Forest category)
-<p>
-r.volume data=elevation clump=fields.only centroids=field.centers
-<p>
-<pre><tt>
-Volume report on data from elevation using clumps on fields.only map
- Cat Average Data # Cells Centroid Total
-Number in clump Total in clump Easting Northing Volume
- 1 1181.09 75590 64 595500.00 4927700.00 755900000.00
- 2 1163.50 69810 60 597100.00 4927700.00 698100000.00
- 3 1146.83 34405 30 598300.00 4927700.00 344050000.00
- 4 1193.20 366311 307 599400.00 4927300.00 3663110000.00
- 60 1260.08 351563 279 603100.00 4921000.00 3515630000.00
- 61 1213.93 35204 29 603700.00 4921500.00 352040000.00
- 62 1207.71 33816 28 604100.00 4921500.00 338160000.00
- Total Volume = 67226740000.00
-</tt></pre>
-The Data Total column is the sum of the elevations for each
-in each of the fields. The Total Volume is the sum multiplied
-by the e-w resolution times the n-s resolution. Note that
-the units on the volume may be difficult if the units of cell
-values on the data_map layer and the resolution units differ.
-<p>
-<h3>CENTROIDS</h3>
-The centroid coordinates are the same as those stored in the sites
-file (if one was requested). They are guaranteed to fall on a cell
-of the appropriate category, thus they are not always the true,
-mathematical centroid. They will always fall at a cell center.
-<h3>FORMAT OF CENTROIDS table<br></h3>
-For each line of above table the vector points table contains
-these columns:
-<tt>
-easting,
-northing,
-cat,
-volume,
-average,
-sum,
-count
-</tt>
-<p>
-This can be converted directly to a raster map with each point
-a separate category using <em>v.to.rast</em>.
-<p>
-<!-- As far as I can tell, no attributes are written to a table in Grass 6.3
-(Jan 2008), as this program hasn't been updated to use the Grass 6 vector library. - EP
-<h3>APPLICATIONS</h3>
-By preprocessing the elevation layer with <em>r.mapcalc</em> and using
-suitable masking or clump maps, very interesting applications can
-be done with <em>r.volume</em>. Such as, calculating the volume of rock
-in a potential quarry; calculating cut/fill volumes for roads;
-finding water volumes in potential reservoirs. Data layers of
-other measures of real values.
-<h2>AUTHOR</h2>
-Dr. James Hinthorne, Central Washington University GIS Laboratory<br>
-December 1988.
Copied: grass/trunk/raster/r.volume/r.volume.html (from rev 32770, grass/trunk/raster/r.volume/description.html)
--- grass/trunk/raster/r.volume/r.volume.html (rev 0)
+++ grass/trunk/raster/r.volume/r.volume.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,108 @@
+<em>r.volume</em> is a tool for summing cell values within clumps
+and calculating volumes and centroids of patches or clumps.
+<p>
+<em>r.volume</em> generates a table containing the sum of all cells from
+a data_map layer sorted by category on a clump map, and optionally
+generates a vector points map of the centroids for each clump. If a
+clump map is not specified, the current MASK is used.
+The sum is multiplied by the area of a cell to give the volume
+occupied by that cell. See below for an example of the output
+table.
+<!-- The table is placed in the user's home directory in the
+file Gvol.report. (or not???)
+NOTE: I can't find any evidence of this in the source code, and I have tested
+the module out as of Jan 10, 2008. I'll leave the above comment about
+automatic report generation commented out from the manpage for now, unless I get
+notification otherwise. - EP
+<h2>NOTES</h2>
+<p>
+If a clump map is not given and a MASK not set, the program exits
+with an error message.
+<p>
+<em>r.volume</em> works in the current region and respects the current MASK.
+<p>
+<h2>EXAMPLE</h2>
+The following report was generated by the command:
+(spearfish data base; fields.only is the fields layer without the
+National Forest category)
+<p>
+r.volume data=elevation clump=fields.only centroids=field.centers
+<p>
+<pre><tt>
+Volume report on data from elevation using clumps on fields.only map
+ Cat Average Data # Cells Centroid Total
+Number in clump Total in clump Easting Northing Volume
+ 1 1181.09 75590 64 595500.00 4927700.00 755900000.00
+ 2 1163.50 69810 60 597100.00 4927700.00 698100000.00
+ 3 1146.83 34405 30 598300.00 4927700.00 344050000.00
+ 4 1193.20 366311 307 599400.00 4927300.00 3663110000.00
+ 60 1260.08 351563 279 603100.00 4921000.00 3515630000.00
+ 61 1213.93 35204 29 603700.00 4921500.00 352040000.00
+ 62 1207.71 33816 28 604100.00 4921500.00 338160000.00
+ Total Volume = 67226740000.00
+</tt></pre>
+The Data Total column is the sum of the elevations for each
+in each of the fields. The Total Volume is the sum multiplied
+by the e-w resolution times the n-s resolution. Note that
+the units on the volume may be difficult if the units of cell
+values on the data_map layer and the resolution units differ.
+<p>
+<h3>CENTROIDS</h3>
+The centroid coordinates are the same as those stored in the sites
+file (if one was requested). They are guaranteed to fall on a cell
+of the appropriate category, thus they are not always the true,
+mathematical centroid. They will always fall at a cell center.
+<h3>FORMAT OF CENTROIDS table<br></h3>
+For each line of above table the vector points table contains
+these columns:
+<tt>
+easting,
+northing,
+cat,
+volume,
+average,
+sum,
+count
+</tt>
+<p>
+This can be converted directly to a raster map with each point
+a separate category using <em>v.to.rast</em>.
+<p>
+<!-- As far as I can tell, no attributes are written to a table in Grass 6.3
+(Jan 2008), as this program hasn't been updated to use the Grass 6 vector library. - EP
+<h3>APPLICATIONS</h3>
+By preprocessing the elevation layer with <em>r.mapcalc</em> and using
+suitable masking or clump maps, very interesting applications can
+be done with <em>r.volume</em>. Such as, calculating the volume of rock
+in a potential quarry; calculating cut/fill volumes for roads;
+finding water volumes in potential reservoirs. Data layers of
+other measures of real values.
+<h2>AUTHOR</h2>
+Dr. James Hinthorne, Central Washington University GIS Laboratory<br>
+December 1988.
Deleted: grass/trunk/raster/r.walk/description.html
--- grass/trunk/raster/r.walk/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.walk/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,133 +0,0 @@
-<em>r.walk</em> outputs a raster map layer showing the lowest
-cumulative cost of moving between each cell and the user-specified
-starting points. It uses an input elevation raster map layer whose
-cell category values represent elevation, combined with a second input
-raster map layer whose cell values represent friction costs.
-This function is similar to <em>r.cost</em>, but in addiction to a
-friction map, it considers an anisotropic travel time due to the
-different walking speed associated with downhill and uphill movements.
-<p>
-The formula from Aitken 1977/Langmuir 1984 (based on Naismith's rule
-for walking times) has been used to estimate the cost parameters of
-specific slope intervals:
-<p>
-T= [(a)*(Delta S)] + [(b)*(Delta H uphill)] + [(c)*(Delta H moderate downhill)] + [(d)*(Delta H steep downhill)]
-<p>
-where:<br>
-T is time of movement in seconds,<br>
-Delta S is the distance covered in meters,<br>
-Delta H is the altitude difference in meter.
-<p>
-The a, b, c, d parameters take in account movement speed in the different
-conditions and are linked to:
-<ul>
- <li>a: underfoot condition (a=1/walking_speed)</li>
- <li>b: underfoot condition and cost associated to movement uphill</li>
- <li>c: underfoot condition and cost associated to movement moderate downhill</li>
- <li>d: underfoot condition and cost associated to movement steep downhill</li>
-</ul>
-It has been proved that moving downhill is favourable up to a specific
-slope value threshold, after that it becomes unfavourable. The default
-slope value threshold (slope factor) is -0.2125, corresponding to
-tan(-12), calibrated on human behaviour (>5 and <12
-degrees: moderate downhill; >12 degrees: steep downhill). The
-default values for a, b, c, d are those proposed by Langmuir (0.72, 6.0,
-1.9998, -1.9998), based on man walking effort in standard
-conditions.<p>
-The lambda parameter of the linear equation combining movement and
-friction costs:<br>
-total cost = movement time cost + (lambda) * friction costs<br>
-must be set in the option section of <em>r.walk</em>.
-<p>
-For a more accurate result, the "knight's move" option can be used
-(although it is more time consuming). In the diagram below, the center
-location (O) represents a grid cell from which cumulative distances
-are calculated. Those neighbours marked with an x are always
-considered for cumulative cost updates. With the "knight's move"
-option, the neighbours marked with a K are also considered.
-<div class="code"><pre>
- K K
-K x x x K
- x O x
-K x x x K
- K K
-</pre></div>
-<p>
-The minimum cumulative costs are computed using Dijkstra's
-algorithm, that find an optimum solution (for more details see
-<em>r.cost</em>, that uses the same algorithm).
-<p>
-Once <em>r.walk</em> computes the cumulative cost map as a linear
-combination of friction cost (from friction map) and the altitude and
-distance covered (from the digital elevation model), <em>r.drain</em>
-can be used to find the minimum cost path.
-<h2>SEE ALSO</h2>
-<em><a href="r.cost.html">r.cost</a></em>,
-<em><a href="r.drain.html">r.drain</a></em>,
-<em><a href="r.in.ascii.html">r.in.ascii</a></em>,
-<em><a href="r.out.ascii.html">r.out.ascii</a></em>
-<h2>REFERENCES</h2>
-<ul>
-<li>Aitken, R. 1977. Wilderness areas in Scotland. Unpublished Ph.D. thesis.
- University of Aberdeen.
-<li> Steno Fontanari, University of Trento, Italy, Ingegneria per l'Ambiente e
- il Territorio, 2000-2001.
- Svilluppo di metodologie GIS per la determinazione dell'accessibilità
- territoriale come supporto alle decisioni nella gestione ambientale.
-<li>Langmuir, E. 1984. Mountaincraft and leadership. The Scottish
- Sports Council/MLTB. Cordee, Leicester.
-</ul>
-<h2>AUTHORS</h2>
-<b>Based on r.cost written by :</b>
-<p>
-Antony Awaida,<br>
-Intelligent Engineering<br>
-Systems Laboratory,<br>
-M.I.T.<br>
-<br>
-James Westervelt,<br>
-<p>Updated for Grass 5<br>
-Pierre de Mouveaux (pmx at audiovu.com)
-<p>
-<b>Initial version of r.walk:</b>
-<p>
-Steno Fontanari, 2002
-<p>
-<b>Current version of r.walk:</b>
-<p>
-Franceschetti Simone, Sorrentino Diego, Mussi Fabiano and Pasolli Mattia<br>
-Correction by: Fontanari Steno, Napolitano Maurizio and Flor Roberto<br>
-In collaboration with: Franchi Matteo, Vaglia Beatrice, Bartucca Luisa, Fava Valentina and Tolotti Mathias, 2004
-<p>
-<b>Updated for Grass 6.1</b>
-<p>
-Roberto Flor and Markus Neteler
Copied: grass/trunk/raster/r.walk/r.walk.html (from rev 32770, grass/trunk/raster/r.walk/description.html)
--- grass/trunk/raster/r.walk/r.walk.html (rev 0)
+++ grass/trunk/raster/r.walk/r.walk.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,133 @@
+<em>r.walk</em> outputs a raster map layer showing the lowest
+cumulative cost of moving between each cell and the user-specified
+starting points. It uses an input elevation raster map layer whose
+cell category values represent elevation, combined with a second input
+raster map layer whose cell values represent friction costs.
+This function is similar to <em>r.cost</em>, but in addiction to a
+friction map, it considers an anisotropic travel time due to the
+different walking speed associated with downhill and uphill movements.
+<p>
+The formula from Aitken 1977/Langmuir 1984 (based on Naismith's rule
+for walking times) has been used to estimate the cost parameters of
+specific slope intervals:
+<p>
+T= [(a)*(Delta S)] + [(b)*(Delta H uphill)] + [(c)*(Delta H moderate downhill)] + [(d)*(Delta H steep downhill)]
+<p>
+where:<br>
+T is time of movement in seconds,<br>
+Delta S is the distance covered in meters,<br>
+Delta H is the altitude difference in meter.
+<p>
+The a, b, c, d parameters take in account movement speed in the different
+conditions and are linked to:
+<ul>
+ <li>a: underfoot condition (a=1/walking_speed)</li>
+ <li>b: underfoot condition and cost associated to movement uphill</li>
+ <li>c: underfoot condition and cost associated to movement moderate downhill</li>
+ <li>d: underfoot condition and cost associated to movement steep downhill</li>
+</ul>
+It has been proved that moving downhill is favourable up to a specific
+slope value threshold, after that it becomes unfavourable. The default
+slope value threshold (slope factor) is -0.2125, corresponding to
+tan(-12), calibrated on human behaviour (>5 and <12
+degrees: moderate downhill; >12 degrees: steep downhill). The
+default values for a, b, c, d are those proposed by Langmuir (0.72, 6.0,
+1.9998, -1.9998), based on man walking effort in standard
+conditions.<p>
+The lambda parameter of the linear equation combining movement and
+friction costs:<br>
+total cost = movement time cost + (lambda) * friction costs<br>
+must be set in the option section of <em>r.walk</em>.
+<p>
+For a more accurate result, the "knight's move" option can be used
+(although it is more time consuming). In the diagram below, the center
+location (O) represents a grid cell from which cumulative distances
+are calculated. Those neighbours marked with an x are always
+considered for cumulative cost updates. With the "knight's move"
+option, the neighbours marked with a K are also considered.
+<div class="code"><pre>
+ K K
+K x x x K
+ x O x
+K x x x K
+ K K
+</pre></div>
+<p>
+The minimum cumulative costs are computed using Dijkstra's
+algorithm, that find an optimum solution (for more details see
+<em>r.cost</em>, that uses the same algorithm).
+<p>
+Once <em>r.walk</em> computes the cumulative cost map as a linear
+combination of friction cost (from friction map) and the altitude and
+distance covered (from the digital elevation model), <em>r.drain</em>
+can be used to find the minimum cost path.
+<h2>SEE ALSO</h2>
+<em><a href="r.cost.html">r.cost</a></em>,
+<em><a href="r.drain.html">r.drain</a></em>,
+<em><a href="r.in.ascii.html">r.in.ascii</a></em>,
+<em><a href="r.out.ascii.html">r.out.ascii</a></em>
+<h2>REFERENCES</h2>
+<ul>
+<li>Aitken, R. 1977. Wilderness areas in Scotland. Unpublished Ph.D. thesis.
+ University of Aberdeen.
+<li> Steno Fontanari, University of Trento, Italy, Ingegneria per l'Ambiente e
+ il Territorio, 2000-2001.
+ Svilluppo di metodologie GIS per la determinazione dell'accessibilità
+ territoriale come supporto alle decisioni nella gestione ambientale.
+<li>Langmuir, E. 1984. Mountaincraft and leadership. The Scottish
+ Sports Council/MLTB. Cordee, Leicester.
+</ul>
+<h2>AUTHORS</h2>
+<b>Based on r.cost written by :</b>
+<p>
+Antony Awaida,<br>
+Intelligent Engineering<br>
+Systems Laboratory,<br>
+M.I.T.<br>
+<br>
+James Westervelt,<br>
+<p>Updated for Grass 5<br>
+Pierre de Mouveaux (pmx at audiovu.com)
+<p>
+<b>Initial version of r.walk:</b>
+<p>
+Steno Fontanari, 2002
+<p>
+<b>Current version of r.walk:</b>
+<p>
+Franceschetti Simone, Sorrentino Diego, Mussi Fabiano and Pasolli Mattia<br>
+Correction by: Fontanari Steno, Napolitano Maurizio and Flor Roberto<br>
+In collaboration with: Franchi Matteo, Vaglia Beatrice, Bartucca Luisa, Fava Valentina and Tolotti Mathias, 2004
+<p>
+<b>Updated for Grass 6.1</b>
+<p>
+Roberto Flor and Markus Neteler
Deleted: grass/trunk/raster/r.water.outlet/description.html
--- grass/trunk/raster/r.water.outlet/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.water.outlet/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,57 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.water.outlet</em> generates a watershed basin from a drainage
-direction map (from <em><a href="r.watershed.html">r.watershed</a></em>) and
-a set of coordinates representing the outlet point of watershed.
-<h3>Selected Parameters</h3>
-<dl>
-<dt><b>drainage=</b><em>name</em>
-<dd>Input map: drainage direction. Indicates the "aspect" for each
-cell. Multiplying positive values by 45 will give the direction in
-degrees that the surface runoff will travel from that cell. The
-value -1 indicates that the cell is a depression area.
-Other negative values indicate that
-surface runoff is leaving the boundaries of the current geographic
-region. The absolute value of these negative cells indicates the
-direction of flow. This map is generated from
-<em><a href="r.watershed.html">r.watershed</a></em>.
-<dt><b>basin=</b><em>name</em>
-<dd>Output map: Values of one (1) indicate the watershed
-basin. Values of zero are not in the watershed basin.
-<dt><b>easting=</b><em>value</em>
-<dd>Input value: Easting value of outlet point.
-<dt><b>northing=</b><em>value</em>
-<dd>Input value: Northing value of outlet point.
-</dl>
-<h2>NOTES</h2>
-In the context of this program, a watershed basin is the
-region upstream of an outlet point. Thus, if the user
-chooses an outlet point on a hill slope, the resulting map
-will be a thin silver of land representing the overland
-slope uphill of the point.
-<h2>SEE ALSO</h2>
-<em>
-<a href="d.where.html">d.where</a>,
-<a href="r.watershed.html">r.watershed</a>,
-<a href="r.topidx.html">r.topidx</a>
-</em>
-<h2>AUTHOR</h2>
-Charles Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
Copied: grass/trunk/raster/r.water.outlet/r.water.outlet.html (from rev 32770, grass/trunk/raster/r.water.outlet/description.html)
--- grass/trunk/raster/r.water.outlet/r.water.outlet.html (rev 0)
+++ grass/trunk/raster/r.water.outlet/r.water.outlet.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,57 @@
+<em>r.water.outlet</em> generates a watershed basin from a drainage
+direction map (from <em><a href="r.watershed.html">r.watershed</a></em>) and
+a set of coordinates representing the outlet point of watershed.
+<h3>Selected Parameters</h3>
+<dl>
+<dt><b>drainage=</b><em>name</em>
+<dd>Input map: drainage direction. Indicates the "aspect" for each
+cell. Multiplying positive values by 45 will give the direction in
+degrees that the surface runoff will travel from that cell. The
+value -1 indicates that the cell is a depression area.
+Other negative values indicate that
+surface runoff is leaving the boundaries of the current geographic
+region. The absolute value of these negative cells indicates the
+direction of flow. This map is generated from
+<em><a href="r.watershed.html">r.watershed</a></em>.
+<dt><b>basin=</b><em>name</em>
+<dd>Output map: Values of one (1) indicate the watershed
+basin. Values of zero are not in the watershed basin.
+<dt><b>easting=</b><em>value</em>
+<dd>Input value: Easting value of outlet point.
+<dt><b>northing=</b><em>value</em>
+<dd>Input value: Northing value of outlet point.
+</dl>
+<h2>NOTES</h2>
+In the context of this program, a watershed basin is the
+region upstream of an outlet point. Thus, if the user
+chooses an outlet point on a hill slope, the resulting map
+will be a thin silver of land representing the overland
+slope uphill of the point.
+<h2>SEE ALSO</h2>
+<em>
+<a href="d.where.html">d.where</a>,
+<a href="r.watershed.html">r.watershed</a>,
+<a href="r.topidx.html">r.topidx</a>
+</em>
+<h2>AUTHOR</h2>
+Charles Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
Deleted: grass/trunk/raster/r.watershed/front/description.html
--- grass/trunk/raster/r.watershed/front/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.watershed/front/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,426 +0,0 @@
-<em>r.watershed</em> generates a set of maps indicating:
-1) the location of watershed basins, and
-2) the LS and S factors of the Revised Universal Soil Loss Equation (RUSLE).
-<p>
-<!-- Interactive mode not activated in GRASS 6.
-<em>r.watershed</em> can be run either interactively or non-interactively.
-If the user types <tt>r.watershed</tt>
-on the command line without program arguments, the program will prompt the user
-with a verbose description of the input maps. The interactive version of
-<em>r.watershed</em> can prepare inputs to lumped-parameter hydrologic models.
-After a verbose interactive session, <em>r.watershed</em> will query the user
-for a number of
-map layers. Each map layer's values will be tabulated by watershed basin and sent
-to an output file. This output file is organized to ease data entry into a
-lumped-parameter hydrologic model program. The non-interactive version of
-<em>r.watershed</em> cannot create this file.
-<p>
-The user can run the program non-interactively, by specifying input map names
-on the command line. Parameter names may be specified by their
-full names, or by any initial string that distinguish them from other parameter names.
-In <em>r.watershed</em>'s case, the first two letters of each name sufficiently
-distinguishes parameter names.
-For example, the two expressions below are equivalent inputs to <em>r.watershed</em>:
-<p>
-<pre>
- el=elev.map th=100 st=stream.map ba=basin.map
- elevation=elev.map threshold=100 stream=stream.map basin=basin.map
-</pre>
-<h2>OPTIONS</h2>
-<dl>
-<dt><em>-m</em>
-<dd>Without this flag set, the entire analysis is run in memory
-maintained by the operating system. This can be limiting, but is
-relatively fast. Setting the flag causes the program to manage memory
-on disk which allows larger maps to be processes but is considerably
-slower.
-<dt><em>-4</em>
-<dd>Allow only horizontal and vertical flow of water.
-Stream and slope lengths are approximately the same as outputs from default surface
-flow (allows horizontal, vertical, and diagonal flow of water).
-This flag will also make the drainage basins look more homogeneous.
-<dt><em>elevation</em>
-<dd>Input map: Elevation on which entire analysis is based.
-<dt><em>depression</em>
-<dd>Input map: Map layer of actual depressions or sinkholes in the
-landscape that are large enough to slow and store surface runoff from
-a storm event. Any non-zero values indicate depressions.
-<dt><em>flow</em>
-<dd>Input map: amount of overland flow per cell. This map indicates the
-amount of overland flow units that each cell will contribute to the
-watershed basin model. Overland flow units represent the amount of
-overland flow each cell contributes to surface flow. If omitted, a
-value of one (1) is assumed. The algorithm is D8 flow accumulation.
-<dt><em>disturbed.land</em>
-<dd>Raster map input layer or value containing the percent of disturbed
-land (i.e., croplands, and construction sites) where the raster or input
-value of 17 equals 17%. If no map or value is given, <em>r.watershed</em>
-assumes no disturbed land. This input is used for the RUSLE calculations.
-<dt><em>blocking</em>
-<dd>Input map: terrain that will block overland surface flow. Terrain
-that will block overland surface flow and restart the slope length
-for the RUSLE. Any non-zero values indicate blocking terrain.
-<dt><em>threshold</em>
-<dd>The minimum size of an exterior watershed basin in cells, if no flow
-map is input, or overland flow units when a flow map is given.
-Warning: low threshold values will dramactically increase run time and
-generate difficult too read basin and half.basin results.
-This parameter also controls the level of detail in the <em>stream</em>
-segments map.
-<dt><em>max.slope.length</em>
-<dd>Input value indicating the maximum length of overland surface flow
-in meters. If overland flow travels greater than the maximum length,
-the program assumes the maximum length (it assumes that landscape
-characteristics not discernible in the digital elevation model exist
-that maximize the slope length). This input is used for the RUSLE calculations
-and is a sensitive parameter.
-<dt><em>accumulation</em>
-<dd>Output map: The absolute value of each cell in this output map layer is
-the amount of overland flow that traverses the cell. This value will be
-the number of upland cells plus one if no overland flow map is given. If
-the overland flow map is given, the value will be in overland flow units.
-Negative numbers indicate that those cells possibly have surface runoff
-from outside of the current geographic region. Thus, any cells with
-negative values cannot have their surface runoff and sedimentation yields
-calculated accurately.
-<dt><em>drainage</em>
-<dd>Output map: drainage direction. Provides the "aspect" for each
-value -1 indicates that the cell is a depression area (defined by
-the depression input map). Other negative values indicate that
-direction of flow.
-<dt><em>basin</em>
-<dd>Output map: Unique label for each watershed basin. Each basin will
-be given a unique positive even integer. Areas along edges may not
-be large enough to create an exterior watershed basin. 0 values
-indicate that the cell is not part of a complete watershed basin
-in the current geographic region.
-<dt><em>stream</em>
-<dd>Output map: stream segments. Values correspond to the watershed
-basin values.
-<dt><em>half.basin</em>
-<dd>Output map: each half-basin is given a unique value. Watershed
-basins are divided into left and right sides. The right-hand side
-cell of the watershed basin (looking upstream) are given even values
-corresponding to the values in basin. The left-hand side
-cells of the watershed basin are given odd values which are one less
-than the value of the watershed basin.
-<dt><em>visual</em>
-<dd>Output map: useful for visual display of results.
-Surface runoff accumulation with the values
-modified to provide for easy display. All negative accumulation values
-are changed to zero. All positive values above the basin threshold
-are given the value of the <em>threshold</em> parameter.
-<dt><em>length.slope</em>
-<dd>Output map: slope length and steepness (LS) factor. Contains the LS
-factor for the Revised Universal Soil Loss Equation. Equations taken
-from <em>Revised Universal Soil Loss Equation for Western Rangelands</em>
-(Weltz et al. 1987).
-Since the LS factor is a small number, it is multiplied by 100 for the
-GRASS output map.
-<dt><em>slope.steepness</em>
-<dd>Output map: slope steepness (S) factor for RUSLE.
-Contains the revised S factor for the Universal Soil
-Loss Equation. Equations taken from article entitled
-<em>Revised Slope Steepness Factor for the Universal Soil
-Loss Equation</em> (McCool et al. 1987). Since the S factor
-is a small number (usually less than one), it is multiplied
-by 100 for the GRASS output map layer.
-</dd>
-</dl>
-<h2>NOTES</h2>
-<em>r.watershed</em> uses an algorithm designed to minimize the impact of
-DEM data errors. This algorithm works slower than <em>r.terraflow</em> but
-provides more accurate results in areas of low slope as well as DEMs
-constructed with techniques that mistake canopy tops as the ground elevation.
-Kinner et al. (2005), for example, used SRTM and IFSAR DEMs to compare
-<em>r.watershed</em> against <em>r.terraflow</em> results in Panama.
-<em>r.terraflow</em> was unable to replicate stream locations in the larger
-valleys while <em>r.watershed</em> performed much better. Thus, if forest
-canopy exists in valleys, SRTM, IFSAR, and similar data products will cause
-major errors in <em>r.terraflow</em> stream output. Under similar conditions,
-<em>r.watershed</em> will generate better <b>stream</b> and <b>half.basin</b>
-results. If watershed divides contain flat to low slope, <em>r.watershed</em>
-will generate better basin results than <em>r.terraflow</em>.
-(<em>r.terraflow</em> uses the same type of algorithm as ESRI's ArcGIS
-watershed software which fails under these conditions.) Also, if watershed
-divides contain forest canopy mixed with uncanopied areas using SRTM, IFSAR,
-and similar data products, <em>r.watershed</em> will generate better basin
-results than <em>r.terraflow</em>.
-<p>
-There are two versions of this program: <em>ram</em> and <em>seg</em>.
-Which is version is run depends on whether the <em>-m</em> flag is set.
-<br>
-The <em>ram</em> version uses virtual memory managed by the operating
-system to store all the data structures and is faster than the <em>seg</em>
-version;
-<em>seg</em> uses the GRASS segmentation library which manages data in disk
-files. Thus <em>seg</em> uses much less system memory (RAM) allowing other
-processes to operate on the same CPU, even when the current geographic
-region is huge.
-<br>
-Due to memory requirements of both programs, it is quite easy to run out of
-memory when working with huge map regions. If the <em>ram</em> version runs
-out of memory and the resolution size of the current geographic region
-cannot be increased, either more memory needs to be added to the computer,
-or the swap space size needs to be increased. If <em>seg</em> runs out of
-memory, additional disk space needs to be freed up for the program to run.
-<p>
-Both versions use the A<sup>T</sup> least-cost search algorithm to determine
-the flow of water over the landscape (see <a href="#seealso">SEE ALSO</a>
-section).
-The algorithm produces results similar to those obtained when running
-<em><a href="r.cost.html">r.cost</a></em> and
-<em><a href="r.drain.html">r.drain</a></em> on every cell on the map.
-<p>
-In many situations, the elevation data will be too finely detailed for
-the amount of time or memory available. Running <em>r.watershed</em> may
-require use of a coarser resolution. To make the results more closely
-resemble the finer terrain data, create a map layer containing the
-lowest elevation values at the coarser resolution. This is done by:
-1) Setting the current geographic region equal to the elevation map
-layer with <em>g.region</em>, and 2) Use the <em>r.neighbors</em> or
-<em>r.resamp.stats</em> command to find the lowest value for an area
-equal in size to the desired resolution. For example, if the resolution
-of the elevation data is 30 meters and the resolution of the geographic
-region for <em>r.watershed</em> will be 90 meters: use the minimum
-function for a 3 by 3 neighborhood. After changing to the resolution at
-which <em>r.watershed</em> will be run, <em>r.watershed</em> should be run
-using the values from the <em>neighborhood</em> output map layer that
-represents the minimum elevation within the region of the coarser cell.
-<p>
-The minimum size of drainage basins, defined by the <em>threshold</em>
-parameter, is only relevant for those watersheds with a single stream
-having at least the <em>threshold</em> of cells flowing into it.
-(These watersheds are called exterior basins.)
-Interior drainage basins contain stream segments below multiple tributaries.
-Interior drainage basins can be of any size because the length of
-an interior stream segment is determined by the distance between the
-tributaries flowing into it.
-<p>
-The <em>r.watershed</em> program does not require the user to have the
-current geographic region filled with elevation values. Areas without
-elevation data MUST be masked out, by creating a raster map (or raster
-reclassification) named <tt>MASK</tt>. Areas
-masked out will be treated as if they are off the edge of the region.
-MASKs will reduce the memory necessary to run the program. Masking out
-unimportant areas can significantly reduce processing time if the watersheds
-of interest occupy a small percentage of the overall area.
-<p>
-Zero data values will be treated as elevation data (not no_data).
-<p>
-To isolate an individual river network using the output of this module,
-a number of approaches may be considered.
-<ol>
-<li>Use a resample of the basins catchment raster map as a MASK.<br>
- The equivalent vector map method is similar using <em>v.select</em> or
- <em>v.overlay</em>.
-<li>Use the <em>r.cost</em> module with a point in the river as a starting
- point.
-<li>Use the <em>v.net.iso</em> module with a node in the river as a
- starting point.
-</ol>
-<p>
-To create <i>river mile</i> segmentation from a vectorized streams map,
-try the <em>v.net.iso</em> or <em>v.lrs.segment</em> modules.
-<h2>EXAMPLES</h2>
-<i>These examples use the Spearfish sample dataset.</i>
-<p>
-Convert <em>r.watershed</em> streams map output to a vector layer.
-<p>
-If you want a detailed stream network, set the threshold option
-small to create lots of catchment basins, as only one stream is
-presented per catchment. The r.to.vect -v flag preserves the
-catchment ID as the vector category number.
- r.watershed elev=elevation.dem stream=rwater.stream
- r.to.vect -v in=rwater.stream out=rwater_stream
-</pre></div>
-<br>
-<p>
-Set a nice color table for the accumulation map:
- MAP=rwater.accum
- r.watershed elev=elevation.dem accum=$MAP
- eval `r.univar -g "$MAP"`
- stddev_x_2=`echo $stddev | awk '{print $1 * 2}'`
- stddev_div_2=`echo $stddev | awk '{print $1 / 2}'`
- r.colors $MAP col=rules << EOF
- 0% red
- -$stddev_x_2 red
- -$stddev yellow
- -$stddev_div_2 cyan
- -$mean_of_abs blue
- 0 white
- $mean_of_abs blue
- $stddev_div_2 cyan
- $stddev yellow
- $stddev_x_2 red
- 100% red
- EOF
-</pre></div>
-<br>
-<p>
-Create a more detailed stream map using the accumulation map and convert
-it to a vector output map. The accumulation cut-off, and therefore fractal
-dimension, is arbitrary; in this example we use the map's mean number of
-upstream catchment cells (calculated in the above example by <em>r.univar</em>)
-as the cut-off value.
- r.watershed elev=elevation.dem accum=rwater.accum
- r.mapcalc 'MASK = if(!isnull(elevation.dem))'
- r.mapcalc "rwater.course = \
- if( abs(rwater.accum) > $mean_of_abs, \
- abs(rwater.accum), \
- null() )"
- r.colors -g rwater.course col=bcyr
- g.remove MASK
- # <i>Thinning is required before converting raster lines to vector</i>
- r.thin in=rwater.course out=rwater.course.Thin
- r.colors -gn rwater.course.Thin color=grey
- r.to.vect in=rwater.course.Thin out=rwater_course feature=line
- v.db.dropcol map=rwater_course column=label
-</pre></div>
-<!-- can't set line attribute to catchment it is in as v.what.rast and
- v.distance only work for point features. Could create endpoint node
- points map and upload to that ?? -->
-<!-- Note value column containing accumulation cells in output vector
- may not necessarily reference the downstream end of the line! drop it? -->
-<br>
-<p>
-Create watershed basins map and convert to a vector polygon map
- r.watershed elev=elevation.dem basin=rwater.basin thresh=15000
- r.to.vect -s in=rwater.basin out=rwater_basins feature=area
- v.db.dropcol map=rwater_basins column=label
- v.db.renamecol map=rwater_basins column=value,catchment
-</pre></div>
-<br>
-<p>
-Display output in a nice way
- r.shaded.relief map=elevation.dem
- d.shadedmap rel=elevation.dem.shade drape=rwater.basin bright=40
- d.vect rwater_course color=orange
-</pre></div>
-<br>
-<a name="references"></a>
-Ehlschlaeger, C. (1989). <i>Using the A<sup>T</sup> Search Algorithm
-to Develop Hydrologic Models from Digital Elevation Data</i>,
-<b>Proceedings of International Geographic Information Systems (IGIS)
-Symposium '89</b>, pp 275-281 (Baltimore, MD, 18-19 March 1989).<br>
-URL: <a href="http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html">
-http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html</a>
-<p>
-Kinner D., H. Mitasova, R. Harmon, L. Toma, R., Stallard. (2005).
-<i>GIS-based Stream Network Analysis for The Chagres River Basin,
-Republic of Panama</i>. <b>The Rio Chagres: A Multidisciplinary Profile of
-a Tropical Watershed</b>, R. Harmon (Ed.), Springer/Kluwer, p.83-95.<br>
-URL: <a href="http://skagit.meas.ncsu.edu/%7Ehelena/measwork/panama/panama.html">
-http://skagit.meas.ncsu.edu/~helena/measwork/panama/panama.html</a>
-<p>
-McCool et al. (1987). <i>Revised Slope Steepness Factor for the Universal
-Soil Loss Equation</i>, <b>Transactions of the ASAE</b> Vol 30(5).
-<p>
-Weltz M. A., K. G. Renard, J. R. Simanton (1987). <i>Revised Universal Soil
-Loss Equation for Western Rangelands</i>, <b>U.S.A./Mexico Symposium of
-Strategies for Classification and Management of Native Vegetation for
-Food Production In Arid Zones</b> (Tucson, AZ, 12-16 Oct. 1987).
-<a name="seealso"></a>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.cost.html">r.cost</a>,
-<a href="r.drain.html">r.drain</a>,
-<a href="r.flow.html">r.flow</a>,
-<!-- <a href="r.flowmd.html">r.flowmd</a>, -->
-<a href="r.neighbors.html">r.neighbors</a>,
-<a href="r.param.scale.html">r.param.scale</a>,
-<a href="r.resamp.interp.html">r.resamp.interp</a>,
-<a href="r.terraflow.html">r.terraflow</a>,
-<a href="r.topidx.html">r.topidx</a>,
-<a href="r.water.outlet.html">r.water.outlet</a>
-</em>
-<h2>AUTHOR</h2>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/raster/r.watershed/front/r.watershed.html (from rev 32770, grass/trunk/raster/r.watershed/front/description.html)
--- grass/trunk/raster/r.watershed/front/r.watershed.html (rev 0)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -0,0 +1,426 @@
+<h2>DESCRIPTION</h2>
+<em>r.watershed</em> generates a set of maps indicating:
+1) the location of watershed basins, and
+2) the LS and S factors of the Revised Universal Soil Loss Equation (RUSLE).
+<p>
+<!-- Interactive mode not activated in GRASS 6.
+<em>r.watershed</em> can be run either interactively or non-interactively.
+If the user types <tt>r.watershed</tt>
+on the command line without program arguments, the program will prompt the user
+with a verbose description of the input maps. The interactive version of
+<em>r.watershed</em> can prepare inputs to lumped-parameter hydrologic models.
+After a verbose interactive session, <em>r.watershed</em> will query the user
+for a number of
+map layers. Each map layer's values will be tabulated by watershed basin and sent
+to an output file. This output file is organized to ease data entry into a
+lumped-parameter hydrologic model program. The non-interactive version of
+<em>r.watershed</em> cannot create this file.
+<p>
+The user can run the program non-interactively, by specifying input map names
+on the command line. Parameter names may be specified by their
+full names, or by any initial string that distinguish them from other parameter names.
+In <em>r.watershed</em>'s case, the first two letters of each name sufficiently
+distinguishes parameter names.
+For example, the two expressions below are equivalent inputs to <em>r.watershed</em>:
+<p>
+<pre>
+ el=elev.map th=100 st=stream.map ba=basin.map
+ elevation=elev.map threshold=100 stream=stream.map basin=basin.map
+</pre>
+<h2>OPTIONS</h2>
+<dl>
+<dt><em>-m</em>
+<dd>Without this flag set, the entire analysis is run in memory
+maintained by the operating system. This can be limiting, but is
+relatively fast. Setting the flag causes the program to manage memory
+on disk which allows larger maps to be processes but is considerably
+slower.
+<dt><em>-4</em>
+<dd>Allow only horizontal and vertical flow of water.
+Stream and slope lengths are approximately the same as outputs from default surface
+flow (allows horizontal, vertical, and diagonal flow of water).
+This flag will also make the drainage basins look more homogeneous.
+<dt><em>elevation</em>
+<dd>Input map: Elevation on which entire analysis is based.
+<dt><em>depression</em>
+<dd>Input map: Map layer of actual depressions or sinkholes in the
+landscape that are large enough to slow and store surface runoff from
+a storm event. Any non-zero values indicate depressions.
+<dt><em>flow</em>
+<dd>Input map: amount of overland flow per cell. This map indicates the
+amount of overland flow units that each cell will contribute to the
+watershed basin model. Overland flow units represent the amount of
+overland flow each cell contributes to surface flow. If omitted, a
+value of one (1) is assumed. The algorithm is D8 flow accumulation.
+<dt><em>disturbed.land</em>
+<dd>Raster map input layer or value containing the percent of disturbed
+land (i.e., croplands, and construction sites) where the raster or input
+value of 17 equals 17%. If no map or value is given, <em>r.watershed</em>
+assumes no disturbed land. This input is used for the RUSLE calculations.
+<dt><em>blocking</em>
+<dd>Input map: terrain that will block overland surface flow. Terrain
+that will block overland surface flow and restart the slope length
+for the RUSLE. Any non-zero values indicate blocking terrain.
+<dt><em>threshold</em>
+<dd>The minimum size of an exterior watershed basin in cells, if no flow
+map is input, or overland flow units when a flow map is given.
+Warning: low threshold values will dramactically increase run time and
+generate difficult too read basin and half.basin results.
+This parameter also controls the level of detail in the <em>stream</em>
+segments map.
+<dt><em>max.slope.length</em>
+<dd>Input value indicating the maximum length of overland surface flow
+in meters. If overland flow travels greater than the maximum length,
+the program assumes the maximum length (it assumes that landscape
+characteristics not discernible in the digital elevation model exist
+that maximize the slope length). This input is used for the RUSLE calculations
+and is a sensitive parameter.
+<dt><em>accumulation</em>
+<dd>Output map: The absolute value of each cell in this output map layer is
+the amount of overland flow that traverses the cell. This value will be
+the number of upland cells plus one if no overland flow map is given. If
+the overland flow map is given, the value will be in overland flow units.
+Negative numbers indicate that those cells possibly have surface runoff
+from outside of the current geographic region. Thus, any cells with
+negative values cannot have their surface runoff and sedimentation yields
+calculated accurately.
+<dt><em>drainage</em>
+<dd>Output map: drainage direction. Provides the "aspect" for each
+value -1 indicates that the cell is a depression area (defined by
+the depression input map). Other negative values indicate that
+direction of flow.
+<dt><em>basin</em>
+<dd>Output map: Unique label for each watershed basin. Each basin will
+be given a unique positive even integer. Areas along edges may not
+be large enough to create an exterior watershed basin. 0 values
+indicate that the cell is not part of a complete watershed basin
+in the current geographic region.
+<dt><em>stream</em>
+<dd>Output map: stream segments. Values correspond to the watershed
+basin values.
+<dt><em>half.basin</em>
+<dd>Output map: each half-basin is given a unique value. Watershed
+basins are divided into left and right sides. The right-hand side
+cell of the watershed basin (looking upstream) are given even values
+corresponding to the values in basin. The left-hand side
+cells of the watershed basin are given odd values which are one less
+than the value of the watershed basin.
+<dt><em>visual</em>
+<dd>Output map: useful for visual display of results.
+Surface runoff accumulation with the values
+modified to provide for easy display. All negative accumulation values
+are changed to zero. All positive values above the basin threshold
+are given the value of the <em>threshold</em> parameter.
+<dt><em>length.slope</em>
+<dd>Output map: slope length and steepness (LS) factor. Contains the LS
+factor for the Revised Universal Soil Loss Equation. Equations taken
+from <em>Revised Universal Soil Loss Equation for Western Rangelands</em>
+(Weltz et al. 1987).
+Since the LS factor is a small number, it is multiplied by 100 for the
+GRASS output map.
+<dt><em>slope.steepness</em>
+<dd>Output map: slope steepness (S) factor for RUSLE.
+Contains the revised S factor for the Universal Soil
+Loss Equation. Equations taken from article entitled
+<em>Revised Slope Steepness Factor for the Universal Soil
+Loss Equation</em> (McCool et al. 1987). Since the S factor
+is a small number (usually less than one), it is multiplied
+by 100 for the GRASS output map layer.
+</dd>
+</dl>
+<h2>NOTES</h2>
+<em>r.watershed</em> uses an algorithm designed to minimize the impact of
+DEM data errors. This algorithm works slower than <em>r.terraflow</em> but
+provides more accurate results in areas of low slope as well as DEMs
+constructed with techniques that mistake canopy tops as the ground elevation.
+Kinner et al. (2005), for example, used SRTM and IFSAR DEMs to compare
+<em>r.watershed</em> against <em>r.terraflow</em> results in Panama.
+<em>r.terraflow</em> was unable to replicate stream locations in the larger
+valleys while <em>r.watershed</em> performed much better. Thus, if forest
+canopy exists in valleys, SRTM, IFSAR, and similar data products will cause
+major errors in <em>r.terraflow</em> stream output. Under similar conditions,
+<em>r.watershed</em> will generate better <b>stream</b> and <b>half.basin</b>
+results. If watershed divides contain flat to low slope, <em>r.watershed</em>
+will generate better basin results than <em>r.terraflow</em>.
+(<em>r.terraflow</em> uses the same type of algorithm as ESRI's ArcGIS
+watershed software which fails under these conditions.) Also, if watershed
+divides contain forest canopy mixed with uncanopied areas using SRTM, IFSAR,
+and similar data products, <em>r.watershed</em> will generate better basin
+results than <em>r.terraflow</em>.
+<p>
+There are two versions of this program: <em>ram</em> and <em>seg</em>.
+Which is version is run depends on whether the <em>-m</em> flag is set.
+<br>
+The <em>ram</em> version uses virtual memory managed by the operating
+system to store all the data structures and is faster than the <em>seg</em>
+version;
+<em>seg</em> uses the GRASS segmentation library which manages data in disk
+files. Thus <em>seg</em> uses much less system memory (RAM) allowing other
+processes to operate on the same CPU, even when the current geographic
+region is huge.
+<br>
+Due to memory requirements of both programs, it is quite easy to run out of
+memory when working with huge map regions. If the <em>ram</em> version runs
+out of memory and the resolution size of the current geographic region
+cannot be increased, either more memory needs to be added to the computer,
+or the swap space size needs to be increased. If <em>seg</em> runs out of
+memory, additional disk space needs to be freed up for the program to run.
+<p>
+Both versions use the A<sup>T</sup> least-cost search algorithm to determine
+the flow of water over the landscape (see <a href="#seealso">SEE ALSO</a>
+section).
+The algorithm produces results similar to those obtained when running
+<em><a href="r.cost.html">r.cost</a></em> and
+<em><a href="r.drain.html">r.drain</a></em> on every cell on the map.
+<p>
+In many situations, the elevation data will be too finely detailed for
+the amount of time or memory available. Running <em>r.watershed</em> may
+require use of a coarser resolution. To make the results more closely
+resemble the finer terrain data, create a map layer containing the
+lowest elevation values at the coarser resolution. This is done by:
+1) Setting the current geographic region equal to the elevation map
+layer with <em>g.region</em>, and 2) Use the <em>r.neighbors</em> or
+<em>r.resamp.stats</em> command to find the lowest value for an area
+equal in size to the desired resolution. For example, if the resolution
+of the elevation data is 30 meters and the resolution of the geographic
+region for <em>r.watershed</em> will be 90 meters: use the minimum
+function for a 3 by 3 neighborhood. After changing to the resolution at
+which <em>r.watershed</em> will be run, <em>r.watershed</em> should be run
+using the values from the <em>neighborhood</em> output map layer that
+represents the minimum elevation within the region of the coarser cell.
+<p>
+The minimum size of drainage basins, defined by the <em>threshold</em>
+parameter, is only relevant for those watersheds with a single stream
+having at least the <em>threshold</em> of cells flowing into it.
+(These watersheds are called exterior basins.)
+Interior drainage basins contain stream segments below multiple tributaries.
+Interior drainage basins can be of any size because the length of
+an interior stream segment is determined by the distance between the
+tributaries flowing into it.
+<p>
+The <em>r.watershed</em> program does not require the user to have the
+current geographic region filled with elevation values. Areas without
+elevation data MUST be masked out, by creating a raster map (or raster
+reclassification) named <tt>MASK</tt>. Areas
+masked out will be treated as if they are off the edge of the region.
+MASKs will reduce the memory necessary to run the program. Masking out
+unimportant areas can significantly reduce processing time if the watersheds
+of interest occupy a small percentage of the overall area.
+<p>
+Zero data values will be treated as elevation data (not no_data).
+<p>
+To isolate an individual river network using the output of this module,
+a number of approaches may be considered.
+<ol>
+<li>Use a resample of the basins catchment raster map as a MASK.<br>
+ The equivalent vector map method is similar using <em>v.select</em> or
+ <em>v.overlay</em>.
+<li>Use the <em>r.cost</em> module with a point in the river as a starting
+ point.
+<li>Use the <em>v.net.iso</em> module with a node in the river as a
+ starting point.
+</ol>
+<p>
+To create <i>river mile</i> segmentation from a vectorized streams map,
+try the <em>v.net.iso</em> or <em>v.lrs.segment</em> modules.
+<h2>EXAMPLES</h2>
+<i>These examples use the Spearfish sample dataset.</i>
+<p>
+Convert <em>r.watershed</em> streams map output to a vector layer.
+<p>
+If you want a detailed stream network, set the threshold option
+small to create lots of catchment basins, as only one stream is
+presented per catchment. The r.to.vect -v flag preserves the
+catchment ID as the vector category number.
+ r.watershed elev=elevation.dem stream=rwater.stream
+ r.to.vect -v in=rwater.stream out=rwater_stream
+</pre></div>
+<br>
+<p>
+Set a nice color table for the accumulation map:
+ MAP=rwater.accum
+ r.watershed elev=elevation.dem accum=$MAP
+ eval `r.univar -g "$MAP"`
+ stddev_x_2=`echo $stddev | awk '{print $1 * 2}'`
+ stddev_div_2=`echo $stddev | awk '{print $1 / 2}'`
+ r.colors $MAP col=rules << EOF
+ 0% red
+ -$stddev_x_2 red
+ -$stddev yellow
+ -$stddev_div_2 cyan
+ -$mean_of_abs blue
+ 0 white
+ $mean_of_abs blue
+ $stddev_div_2 cyan
+ $stddev yellow
+ $stddev_x_2 red
+ 100% red
+ EOF
+</pre></div>
+<br>
+<p>
+Create a more detailed stream map using the accumulation map and convert
+it to a vector output map. The accumulation cut-off, and therefore fractal
+dimension, is arbitrary; in this example we use the map's mean number of
+upstream catchment cells (calculated in the above example by <em>r.univar</em>)
+as the cut-off value.
+ r.watershed elev=elevation.dem accum=rwater.accum
+ r.mapcalc 'MASK = if(!isnull(elevation.dem))'
+ r.mapcalc "rwater.course = \
+ if( abs(rwater.accum) > $mean_of_abs, \
+ abs(rwater.accum), \
+ null() )"
+ r.colors -g rwater.course col=bcyr
+ g.remove MASK
+ # <i>Thinning is required before converting raster lines to vector</i>
+ r.thin in=rwater.course out=rwater.course.Thin
+ r.colors -gn rwater.course.Thin color=grey
+ r.to.vect in=rwater.course.Thin out=rwater_course feature=line
+ v.db.dropcol map=rwater_course column=label
+</pre></div>
+<!-- can't set line attribute to catchment it is in as v.what.rast and
+ v.distance only work for point features. Could create endpoint node
+ points map and upload to that ?? -->
+<!-- Note value column containing accumulation cells in output vector
+ may not necessarily reference the downstream end of the line! drop it? -->
+<br>
+<p>
+Create watershed basins map and convert to a vector polygon map
+ r.watershed elev=elevation.dem basin=rwater.basin thresh=15000
+ r.to.vect -s in=rwater.basin out=rwater_basins feature=area
+ v.db.dropcol map=rwater_basins column=label
+ v.db.renamecol map=rwater_basins column=value,catchment
+</pre></div>
+<br>
+<p>
+Display output in a nice way
+ r.shaded.relief map=elevation.dem
+ d.shadedmap rel=elevation.dem.shade drape=rwater.basin bright=40
+ d.vect rwater_course color=orange
+</pre></div>
+<br>
+<a name="references"></a>
+Ehlschlaeger, C. (1989). <i>Using the A<sup>T</sup> Search Algorithm
+to Develop Hydrologic Models from Digital Elevation Data</i>,
+<b>Proceedings of International Geographic Information Systems (IGIS)
+Symposium '89</b>, pp 275-281 (Baltimore, MD, 18-19 March 1989).<br>
+URL: <a href="http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html">
+http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html</a>
+<p>
+Kinner D., H. Mitasova, R. Harmon, L. Toma, R., Stallard. (2005).
+<i>GIS-based Stream Network Analysis for The Chagres River Basin,
+Republic of Panama</i>. <b>The Rio Chagres: A Multidisciplinary Profile of
+a Tropical Watershed</b>, R. Harmon (Ed.), Springer/Kluwer, p.83-95.<br>
+URL: <a href="http://skagit.meas.ncsu.edu/%7Ehelena/measwork/panama/panama.html">
+http://skagit.meas.ncsu.edu/~helena/measwork/panama/panama.html</a>
+<p>
+McCool et al. (1987). <i>Revised Slope Steepness Factor for the Universal
+Soil Loss Equation</i>, <b>Transactions of the ASAE</b> Vol 30(5).
+<p>
+Weltz M. A., K. G. Renard, J. R. Simanton (1987). <i>Revised Universal Soil
+Loss Equation for Western Rangelands</i>, <b>U.S.A./Mexico Symposium of
+Strategies for Classification and Management of Native Vegetation for
+Food Production In Arid Zones</b> (Tucson, AZ, 12-16 Oct. 1987).
+<a name="seealso"></a>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.cost.html">r.cost</a>,
+<a href="r.drain.html">r.drain</a>,
+<a href="r.flow.html">r.flow</a>,
+<!-- <a href="r.flowmd.html">r.flowmd</a>, -->
+<a href="r.neighbors.html">r.neighbors</a>,
+<a href="r.param.scale.html">r.param.scale</a>,
+<a href="r.resamp.interp.html">r.resamp.interp</a>,
+<a href="r.terraflow.html">r.terraflow</a>,
+<a href="r.topidx.html">r.topidx</a>,
+<a href="r.water.outlet.html">r.water.outlet</a>
+</em>
+<h2>AUTHOR</h2>
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.what/description.html
--- grass/trunk/raster/r.what/description.html 2008-08-15 03:16:41 UTC (rev 32771)
+++ grass/trunk/raster/r.what/description.html 2008-08-15 06:16:42 UTC (rev 32772)
@@ -1,145 +0,0 @@
-<em>r.what</em> outputs the category values and (optionally) the category
-labels associated with user-specified locations on raster input map(s).
-Locations are specified as geographic x,y coordinate pairs (i.e., pair of
-eastings and northings); the user can also (optionally) associate a label
-with each location.
-<p>
-The input coordinates can be entered directly on the command line, or
-redirected via <tt>stdin</tt> from an input text file, script, or piped from
-another program (like <em><a href="d.where.html">d.where</a></em>).
-<p>
-If none of the above input methods are used and the module is run from the
-terminal prompt, the program will interactively query the user for point
-locations and labels.
-<p>
-Each line of the input consists of an easting, a northing, and an optional
-label, which are separated by spaces. In interactive mode, the word
-"<tt>end</tt>" must be typed after the last pair of input coordinates.
-<p>
-<em>r.what</em> output consists of the input geographic location and label,
-and, for each user-named raster map layer, the category value, and (if
-the <b>-f</b> label flag is
