[GRASS-SVN] r32779 - in grass-addons/raster/r.rast4d: . globals
svn_grass at osgeo.org
Fri Aug 15 09:06:14 EDT 2008
Author: neteler
Date: 2008-08-15 09:06:14 -0400 (Fri, 15 Aug 2008)
New Revision: 32779
grass-addons/raster/r.rast4d/globals/defines.sh
grass-addons/raster/r.rast4d/r.rast4d.init
(commented) postgresql support
Modified: grass-addons/raster/r.rast4d/globals/defines.sh
--- grass-addons/raster/r.rast4d/globals/defines.sh 2008-08-15 13:05:07 UTC (rev 32778)
+++ grass-addons/raster/r.rast4d/globals/defines.sh 2008-08-15 13:06:14 UTC (rev 32779)
@@ -9,13 +9,18 @@
export GRAST4D_BASE=${GISDBASE}/${LOCATION_NAME}/${MAPSET}
export GRAST4D_DB_DIR="$GRAST4D_BASE/rast4d_db"
-##############################à
export GRAST4D_BIN_DIR="${GISBASE}/etc/r.rast4d/bin"
export GRAST4D_LIB_DIR="${GISBASE}/etc/r.rast4d/lib"
export GRAST4D_SQL_DIR="${GISBASE}/etc/r.rast4d/sql"
+export PATH=$GRAST4D_BIN_DIR:$PATH
+# SQLite:
export GRAST4D_DATABASE=$GRAST4D_DB_DIR/database.sqlite
-export PATH=$GRAST4D_BIN_DIR:$PATH
export GRAST4D_DBM="sqlite3"
+# PostgreSQL:
+#export PGDB=rast4d_database
+#export GRAST4D_DATABASE="-h localhost -p 5432 -U $USER $PGDB"
+#export GRAST4D_DBM="psql"
# Table name definitions
export GRASTER_VIEW_NAME="raster_view"
Modified: grass-addons/raster/r.rast4d/r.rast4d.init
--- grass-addons/raster/r.rast4d/r.rast4d.init 2008-08-15 13:05:07 UTC (rev 32778)
+++ grass-addons/raster/r.rast4d/r.rast4d.init 2008-08-15 13:06:14 UTC (rev 32779)
@@ -11,10 +11,25 @@
source ${GISBASE}/etc/r.rast4d/globals/defines.sh
-if [ ! -f $GRAST4D_DATABASE ]
- then
- if [ ! -d ./db/ ]; then mkdir ./db/ ; fi
- ${GISBASE}/etc/r.rast4d/bin/init_db.sh
+if [ "$GRAST4D_DBM" = "sqlite3" ] ; then
+ if [ ! -f $GRAST4D_DATABASE ] ; then
+ if [ ! -d ./db/ ]; then mkdir ./db/ ; fi
+ echo "Initializing SQLite db..."
+ ${GISBASE}/etc/r.rast4d/bin/init_db.sh
+ else
+ echo "$GRAST4D_DATABASE already exists. Doing nothing. Remove that DB file to start over"
+ fi
else
- echo "$GRAST4D_DATABASE already exists. Doing nothing. Remove that DB file to start over"
+ psql -l | grep $PGDB > /dev/null
+ if [ $? -ne 0 ] ; then
+ # TODO: implement psql magic to call 'createdb'
+ echo "ERROR: PostgreSQL database <$PGDB> does not exist. Run 'createdb $PGDB' as appropriate."
+ exit 1
+ else
+ echo "Initializing PostgreSQL database..."
+ fi
fi
+echo "Done. Now you can use the tg.* commands."
+exit 0
