[GRASS-SVN] r32789 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Fri Aug 15 16:11:04 EDT 2008
Author: martinl
Date: 2008-08-15 16:11:04 -0400 (Fri, 15 Aug 2008)
New Revision: 32789
Added:
grass/trunk/gui/wxpython/gui_modules/colorrules.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/nviz.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI synchronized with devbr6 (relevant parts)
Added: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -0,0 +1,509 @@
+MODULE: rules.py
+CLASSES:
+ * RulesText
+PURPOSE: Dialog for interactive entry of rules for r.colors,
+ r.reclass, r.recode, and v.reclass
+AUTHORS: The GRASS Development Team
+ Michael Barton (Arizona State University)
+COPYRIGHT: (C) 2007 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+import os
+import sys
+import shutil
+from debug import Debug as Debug
+import wx
+import wx.lib.colourselect as csel
+import wx.lib.scrolledpanel as scrolled
+import gcmd
+import gselect
+import globalvar
+import render
+import utils
+class ColorTable(wx.Frame):
+ def __init__(self, parent, id=wx.ID_ANY, title='',
+ pos=wx.DefaultPosition, size=(-1, -1),
+ style=wx.DEFAULT_FRAME_STYLE|wx.RESIZE_BORDER,
+ **kwargs):
+ wx.Frame.__init__(self, parent, id, title, pos, size, style)
+ Dialog for interactively entering rules
+ for map management commands
+ @param cmd command (given as list)
+ self.CentreOnParent()
+ self.parent = parent
+ self.cmd = kwargs['cmd'] # grass command
+ self.inmap = '' # input map to change
+ self.rastmin = '' # min cat in raster map
+ self.rastmax = '' # max cat in raster map
+ self.old_colrtable = '' # existing color table of raster map
+ self.vals = '' # raster category values for assigning colors
+ self.rgb_string = '' # r:g:b color string for assigning colors to cats
+ self.ruleslines = {} # rules for creating colortable
+ self.overwrite = True
+ self.Map = render.Map() # instance of render.Map to be associated with display
+ self.layer = None # reference to layer with histogram
+ self.mapname = ''
+ # Set the size & cursor
+ self.SetClientSize(size)
+ # set window frame title
+ self.SetTitle('Create new color table for raster map')
+ # top controls
+ self.map_label=wx.StaticText(parent=self, id=wx.ID_ANY, label='Select raster map:')
+ self.selectionInput = gselect.Select(parent=self, id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE,
+ type='cell')
+ self.ovrwrtcheck = wx.CheckBox(parent=self, id=wx.ID_ANY,
+ label=_('replace existing color table'))
+ self.ovrwrtcheck.SetValue(self.overwrite)
+ self.helpbtn = wx.Button(parent=self, id=wx.ID_HELP)
+ # color table and preview window
+ self.cr_label = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label=_('Enter raster cat values or percents'))
+ self.cr_panel = self.__colorrulesPanel()
+ self.InitDisplay() # initialize preview display
+ self.preview = BufferedWindow(self, id = wx.ID_ANY, size=(400,300), Map=self.Map)
+ # bottom controls
+ self.line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(-1,-1),
+ style=wx.LI_HORIZONTAL)
+ cancel_btn = wx.Button(self, wx.ID_CANCEL)
+ apply_btn = wx.Button(self, wx.ID_APPLY)
+ ok_btn = wx.Button(self, wx.ID_OK)
+ ok_btn.SetDefault()
+ self.btnsizer = wx.StdDialogButtonSizer()
+ self.btnsizer.Add(cancel_btn, flag=wx.ALL, border=5)
+ self.btnsizer.Add(apply_btn, flag=wx.ALL, border=5)
+ self.btnsizer.Add(ok_btn, flag=wx.ALL, border=5)
+ self.btnsizer.Realize()
+ self.preview_btn = wx.Button(self, wx.ID_ANY, _("Preview"))
+ # bindings
+ self.Bind(wx.EVT_BUTTON, self.OnHelp, self.helpbtn)
+ self.Bind(wx.EVT_CHECKBOX, self.OnOverwrite, self.ovrwrtcheck)
+ self.selectionInput.Bind(wx.EVT_TEXT, self.OnSelectionInput)
+ self.Bind(wx.EVT_BUTTON, self.OnCancel, cancel_btn)
+ self.Bind(wx.EVT_BUTTON, self.OnApply, apply_btn)
+ self.Bind(wx.EVT_BUTTON, self.OnOK, ok_btn)
+ self.Bind(wx.EVT_BUTTON, self.OnPreview, self.preview_btn)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+ # layout
+ self.__doLayout()
+ self.Show()
+ def __doLayout(self):
+ sizer = wx.GridBagSizer(hgap=5, vgap=5)
+ sizer.AddGrowableCol(2)
+ sizer.AddGrowableRow(4)
+ sizer.Add(self.map_label, pos=(0,0),
+ flag=wx.ALIGN_CENTER_VERTICAL|wx.EXPAND|wx.ALL, border=5)
+ sizer.Add(item=self.selectionInput, pos=(1,0), span=(1,3),
+ flag=wx.ALIGN_CENTER_VERTICAL|wx.EXPAND | wx.ALL, border=5)
+ sizer.Add(item=self.ovrwrtcheck, pos=(2, 0), span=(1,2),
+ flag=wx.ALL, border=5)
+ sizer.Add(item=self.helpbtn, pos=(2,2), flag=wx.ALIGN_RIGHT|wx.ALL, border=5)
+ sizer.Add(item=self.cr_label, pos=(3,0), span=(1,2), flag=wx.ALL, border=5)
+ sizer.Add(item=self.cr_panel, pos=(4,0),
+ flag=wx.EXPAND|wx.LEFT|wx.RIGHT, border=10)
+ sizer.Add(item=self.preview, pos=(4,1), span=(1,2),
+ flag=wx.ALIGN_LEFT|wx.EXPAND|wx.LEFT|wx.RIGHT, border=10)
+ sizer.Add(item=self.line, pos=(5,0), span=(1,3),
+ flag=wx.GROW|wx.EXPAND|wx.ALIGN_CENTER_VERTICAL|
+ wx.TOP|wx.BOTTOM, border=5)
+ sizer.Add(self.btnsizer, pos=(6,0), span=(1,2),
+ flag=wx.ALIGN_CENTER|wx.FIXED_MINSIZE)
+ sizer.Add(self.preview_btn, pos=(6,2),
+ flag=wx.ALIGN_BOTTOM|wx.ALIGN_CENTER|wx.FIXED_MINSIZE|wx.ALL, border=5)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ def __previewPanel(self):
+ preview = wx.Panel(self, -1, pos=(-1,-1), size=(-1,-1), style=wx.SUNKEN_BORDER)
+ preview.SetBackgroundColour(wx.WHITE)
+ #preview.SetAutoLayout(1)
+ return preview
+ def __colorrulesPanel(self):
+ cr_panel = scrolled.ScrolledPanel(self, -1, size=(150,300),
+ style=wx.TAB_TRAVERSAL|wx.SUNKEN_BORDER,
+ name="cr_panel" )
+ cr_sizer = wx.GridBagSizer(vgap=2, hgap=4)
+ for num in range(100):
+ txt_ctrl = wx.TextCtrl(parent=cr_panel, id=num, value='',
+ pos=wx.DefaultPosition, size=(50,-1),
+ style=wx.TE_NOHIDESEL)
+ self.Bind(wx.EVT_TEXT, self.OnVals, txt_ctrl)
+ color_ctrl = csel.ColourSelect(cr_panel, id=num)
+ self.Bind(csel.EVT_COLOURSELECT, self.OnSelectColor, color_ctrl)
+ self.ruleslines[num] = ["","0:0:0"]
+ cr_sizer.Add(item=txt_ctrl, pos=(num,0),
+ flag=wx.ALIGN_CENTER|wx.LEFT, border=10)
+ cr_sizer.Add(item=color_ctrl, pos=(num,1),
+ flag=wx.ALIGN_CENTER|wx.RIGHT, border=10)
+ cr_panel.SetSizer(cr_sizer)
+ cr_panel.SetAutoLayout(1)
+ cr_panel.SetupScrolling()
+ return cr_panel
+ def InitDisplay(self):
+ Initialize preview display, set dimensions and region
+ #self.width, self.height = self.GetClientSize()
+ self.width = self.Map.width = 400
+ self.height = self.Map.height = 300
+ self.Map.geom = self.width, self.height
+ def OnErase(self, event):
+ Erase the histogram display
+ self.PreviewWindow.Draw(self.HistWindow.pdc, pdctype='clear')
+ def OnCloseWindow(self, event):
+ Window closed
+ Also remove associated rendered images
+ #try:
+ # self.propwin.Close(True)
+ #except:
+ # pass
+ self.Map.Clean()
+ self.Destroy()
+ def OnSelectionInput(self, event):
+ self.inmap = event.GetString()
+ try:
+ cmdlist = ['r.info', 'map=%s' % self.inmap, '-r']
+ p = gcmd.Command(cmdlist)
+ output = p.ReadStdOutput()
+ for line in output:
+ line = line.strip('\n ')
+ if 'min' in line:
+ self.rastmin = line.split('=')[1].strip('\n ')
+ if 'max' in line:
+ self.rastmax = line.split('=')[1].strip('\n ')
+ self.cr_label.SetLabel('Enter raster cat values or percents (range = %s-%s)' %
+ (self.rastmin,self.rastmax))
+ except:
+ pass
+ def OnVals(self, event):
+ num = event.GetId()
+ vals = event.GetString().strip()
+ self.ruleslines[num][0] = vals
+ def OnSelectColor(self, event):
+ rgba_color = event.GetValue()
+ rgb_string = str(rgba_color[0]) + ':' + str(rgba_color[1]) + ':' + str(rgba_color[2])
+ self.ruleslines[num][1] = rgb_string
+ def OnApply(self, event):
+ self.CreateColorTable()
+ def OnOK(self, event):
+ self.Destroy()
+ def OnCancel(self, event):
+ self.Destroy()
+ def OnPreview(self, event):
+ # Add layer to the map for preview
+ cmd = ['d.rast', 'map=%s' % self.inmap]
+ self.layer = self.Map.AddLayer(type="command", name='raster', command=cmd,
+ l_active=True, l_hidden=False, l_opacity=1, l_render=False)
+ # Find existing color table and copy to temp file
+ p = gcmd.Command(['g.findfile', 'element=colr', 'file=%s' % self.inmap])
+ if 'file=' in line:
+ old_colrtable = line.split('=')[1].strip("'")
+ try:
+ colrtemp = utils.GetTempfile()
+ shutil.copyfile(old_colrtable,colrtemp)
+ except:
+ return
+ # apply new color table and display preview
+ self.preview.UpdatePreview()
+ shutil.copyfile(colrtemp, old_colrtable)
+ try:
+ os.remove(colrtemp)
+ except:
+ pass
+ def OnHelp(self, event):
+ gcmd.Command(['g.manual',
+ '--quiet',
+ '%s' % self.cmd[0]])
+ def OnOverwrite(self, event):
+ self.overwrite = event.IsChecked()
+ def CreateColorTable(self):
+ rulestxt = ''
+ for num in self.ruleslines:
+ if self.ruleslines[num][0] != "":
+ rulestxt += self.ruleslines[num][0] + ' ' + self.ruleslines[num][1] + '\n'
+ if rulestxt == '': return
+ gtemp = utils.GetTempfile()
+ output = open(gtemp, "w")
+ try:
+ output.write(rulestxt)
+ finally:
+ output.close()
+ cmdlist = ['r.colors', 'map=%s' % self.inmap, 'rules=%s' % gtemp]
+ if self.overwrite == False:
+ cmdlist.append('-w')
+ gcmd.Command(cmdlist)
+class BufferedWindow(wx.Window):
+ A Buffered window class.
+ When the drawing needs to change, you app needs to call the
+ UpdateHist() method. Since the drawing is stored in a bitmap, you
+ can also save the drawing to file by calling the
+ SaveToFile(self,file_name,file_type) method.
+ def __init__(self, parent, id,
+ pos = wx.DefaultPosition,
+ size = wx.DefaultSize,
+ style=wx.NO_FULL_REPAINT_ON_RESIZE,
+ Map=None):
+ wx.Window.__init__(self, parent, id, pos, size, style)
+ self.Map = Map
+ self.mapname = self.parent.mapname
+ # Flags
+ self.render = True # re-render the map from GRASS or just redraw image
+ self.resize = False # indicates whether or not a resize event has taken place
+ self.dragimg = None # initialize variable for map panning
+ self.pen = None # pen for drawing zoom boxes, etc.
+ # Event bindings
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ #self.Bind(wx.EVT_SIZE, self.OnSize)
+ self.Bind(wx.EVT_IDLE, self.OnIdle)
+ # Render output objects
+ self.mapfile = None # image file to be rendered
+ self.img = "" # wx.Image object (self.mapfile)
+ self.imagedict = {} # images and their PseudoDC ID's for painting and dragging
+ self.pdc = wx.PseudoDC()
+ self._Buffer = '' # will store an off screen empty bitmap for saving to file
+ # make sure that extents are updated at init
+ self.Map.region = self.Map.GetRegion()
+ self.Map.SetRegion()
+ self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
+ def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0,0,0,0]):
+ Draws histogram or clears window
+ if drawid == None:
+ if pdctype == 'image' :
+ drawid = imagedict[img]
+ elif pdctype == 'clear':
+ drawid == None
+ else:
+ drawid = wx.NewId()
+ else:
+ pdc.SetId(drawid)
+ pdc.BeginDrawing()
+ Debug.msg (3, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % (drawid, pdctype, coords))
+ if pdctype == 'clear': # erase the display
+ bg = wx.WHITE_BRUSH
+ pdc.SetBackground(bg)
+ pdc.Clear()
+ self.Refresh()
+ pdc.EndDrawing()
+ return
+ if pdctype == 'image':
+ bg = wx.TRANSPARENT_BRUSH
+ bitmap = wx.BitmapFromImage(img)
+ w,h = bitmap.GetSize()
+ pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
+ pdc.SetIdBounds(drawid, (coords[0],coords[1],w,h))
+ pdc.EndDrawing()
+ self.Refresh()
+ def OnPaint(self, event):
+ Draw psuedo DC to buffer
+ self._Buffer = wx.EmptyBitmap(self.Map.width, self.Map.height)
+ dc = wx.BufferedPaintDC(self, self._Buffer)
+ # use PrepareDC to set position correctly
+ self.PrepareDC(dc)
+ # we need to clear the dc BEFORE calling PrepareDC
+ bg = wx.Brush(self.GetBackgroundColour())
+ dc.SetBackground(bg)
+ dc.Clear()
+ # create a clipping rect from our position and size
+ # and the Update Region
+ rgn = self.GetUpdateRegion()
+ r = rgn.GetBox()
+ # draw to the dc using the calculated clipping rect
+ self.pdc.DrawToDCClipped(dc,r)
+ #self.pdc.DrawToDC(dc)
+ def OnSize(self, event):
+ Init image size to match window size
+ # set size of the input image
+ self.Map.width, self.Map.height = self.GetClientSize()
+ # Make new off screen bitmap: this bitmap will always have the
+ # current drawing in it, so it can be used to save the image to
+ # a file, or whatever.
+ # get the image to be rendered
+ self.img = self.GetImage()
+ # update map display
+ if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
+ self.img = self.img.Scale(self.Map.width, self.Map.height)
+ self.render = False
+ self.UpdatePreview()
+ # re-render image on idle
+ self.resize = True
+ def OnIdle(self, event):
+ Only re-render a histogram image from GRASS during
+ idle time instead of multiple times during resizing.
+ if self.resize:
+ event.Skip()
+ def GetImage(self):
+ Converts files to wx.Image
+ if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
+ os.path.getsize(self.Map.mapfile):
+ img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
+ else:
+ img = None
+ self.imagedict[img] = 99 # set image PeudoDC ID
+ return img
+ def UpdatePreview(self, img=None):
+ Update canvas if window changes geometry
+ Debug.msg (2, "BufferedWindow.UpdatePreview(%s): render=%s" % (img, self.render))
+ oldfont = ""
+ oldencoding = ""
+ if self.render:
+ # render new map images
+ self.mapfile = self.Map.Render(force=self.render)
+ if not self.img: return
+ try:
+ id = self.imagedict[self.img]
+ except:
+ return
+ # paint images to PseudoDC
+ self.pdc.Clear()
+ self.pdc.RemoveAll()
+ self.Draw(self.pdc, self.img, drawid=id) # draw map image background
+ # update statusbar
+ # Debug.msg (3, "BufferedWindow.UpdateHist(%s): region=%s" % self.Map.region)
+ def EraseMap(self):
+ Erase the map display
+ self.Draw(self.pdc, pdctype='clear')
Property changes on: grass/trunk/gui/wxpython/gui_modules/colorrules.py
___________________________________________________________________
+ Author Date Id
+ native
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-08-15 20:05:46 UTC (rev 32788)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -44,7 +44,6 @@
- verify option value types
- use DOM instead of SAX
-__version__ ="$Revision$"
import sys
import re
@@ -589,22 +588,7 @@
# icon
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
- # menu
- # menu = wx.Menu()
- # menu.Append(wx.ID_ABOUT, _("&About GrassGUI"),
- # _("Information about GrassGUI") )
- # menu.Append(ID_ABOUT_COMMAND, _("&About %s") % self.task.name,
- # _("Short descripton of GRASS command %s") % self.task.name)
- # menu.AppendSeparator()
- # menu.Append(wx.ID_EXIT, _("E&xit"), _("Terminate the program") )
- # menuBar = wx.MenuBar()
- # menuBar.Append(menu, "&File");
- # self.SetMenuBar(menuBar)
- #wx.EVT_MENU(self, wx.ID_ABOUT, self.OnAbout)
- #wx.EVT_MENU(self, ID_ABOUT_COMMAND, self.OnAboutCommand)
- #wx.EVT_MENU(self, wx.ID_EXIT, self.OnCancel)
guisizer = wx.BoxSizer(wx.VERTICAL)
# set apropriate output window
@@ -857,25 +841,7 @@
self.notebookpanel.OnPageChange(None)
event.Skip()
- def OnAbout(self, event):
- """General 'about' information"""
- dlg = wx.MessageDialog(self, _("This is a sample program for\n"
- "GRASS command interface parsing\n"
- "and automatic GUI building.\n%s") %(__version__),
- _("About wxPython GRASS GUI"), wx.OK | wx.ICON_INFORMATION)
- dlg.ShowModal()
- dlg.Destroy()
- def OnAboutCommand(self, event):
- """About command"""
- self.task.name+": "+self.task.description,
- "About " + self.task.name,
- wx.OK | wx.ICON_INFORMATION)
- dlg.ShowModal()
- dlg.Destroy()
def createCmd(self, ignoreErrors = False):
"""Create command string (python list)"""
return self.notebookpanel.createCmd(ignoreErrors=ignoreErrors)
Property changes on: grass/trunk/gui/wxpython/gui_modules/menuform.py
- Author Date Id Revision
+ Author Date Id
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-08-15 20:05:46 UTC (rev 32788)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -1,13 +1,15 @@
- at package nviz.py
+ at package nviz_mapdisp.py (core)
- at brief 2.5/3D visialization mode for Map Display Window
+ at brief Nviz extension for wxGUI
+This module enables to visualize data in 2.5/3D space.
+Map Display supports standard 2D mode ('mapdisp' module) and
+the 2.5/3D mode ('nviz_mapdisp' module).
List of classes:
- GLWindow
- - NvizToolWindow
- - ViewPositionWindow
- - IsoSurfList
(C) 2008 by the GRASS Development Team
@@ -18,17 +20,9 @@
@author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
-import os
-import sys
-import time
-import copy
+errorMsg = ''
-from threading import Thread
import wx
-import wx.lib.colourselect as csel
-import wx.lib.scrolledpanel as scrolled
-errorMsg = ''
try:
from wx import glcanvas
haveGLCanvas = True
@@ -44,3620 +38,16 @@
errorMsg = e
import globalvar
-import gcmd
-import gselect
-from debug import Debug as Debug
-from mapdisp import MapWindow as MapWindow
-from preferences import globalSettings as UserSettings
try:
- nvizPath = os.path.join(globalvar.ETCWXDIR, "nviz")
- sys.path.append(nvizPath)
- import grass7_wxnviz as wxnviz
+ sys.path.append(os.path.join(globalvar.ETCWXDIR, "nviz"))
+ import grass6_wxnviz as wxnviz
haveNviz = True
except ImportError, e:
haveNviz = False
errorMsg = e
-class GLWindow(MapWindow, glcanvas.GLCanvas):
- """OpenGL canvas for Map Display Window"""
- def __init__(self, parent, id,
- pos=wx.DefaultPosition,
- size=wx.DefaultSize,
- style=wx.NO_FULL_REPAINT_ON_RESIZE,
- Map=None, tree=None, gismgr=None):
+import nviz_mapdisp
+import nviz_tools
- self.parent = parent # MapFrame
- self.Map = Map
- self.tree = tree
- self.gismgr = gismgr
- glcanvas.GLCanvas.__init__(self, parent, id)
- MapWindow.__init__(self, parent, id, pos, size, style,
- Map, tree, gismgr)
- self.init = False
- # render mode
- self.render = { 'quick' : False,
- # do not render vector lines in quick mode
- 'vlines' : False,
- 'vpoints' : False }
- # list of loaded map layers
- self.layers = {}
- for type in ('raster', 'vlines', 'vpoints', '3d-raster'):
- self.layers[type] = {}
- self.layers[type]['name'] = []
- self.layers[type]['id'] = []
- # create nviz instance
- self.nvizClass = wxnviz.Nviz(sys.stderr)
- # set current display
- self.nvizClass.SetDisplay(self)
- # initialize mouse position
- self.lastX = self.x = 30
- self.lastY = self.y = 30
- # default values
- self.view = copy.deepcopy(UserSettings.Get(group='nviz', key='view')) # copy
- self.iview = UserSettings.Get(group='nviz', key='view', internal=True)
- self.update = [] # list of properties to be updated
- self.size = None
- self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
- self.Bind(wx.EVT_SIZE, self.OnSize)
- self.Bind(wx.EVT_PAINT, self.OnPaint)
- self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
- self.Bind(wx.EVT_LEFT_UP, self.OnLeftUp)
- self.Bind(wx.EVT_MOTION, self.OnMouseAction)
- self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouseAction)
- def OnEraseBackground(self, event):
- pass # do nothing, to avoid flashing on MSW
- def OnSize(self, event):
- self.size = self.parent.GetClientSize()
- if self.GetContext():
- Debug.msg(3, "GLCanvas.OnPaint(): w=%d, h=%d" % \
- (self.size.width, self.size.height))
- self.SetCurrent()
- self.nvizClass.ResizeWindow(self.size.width,
- self.size.height)
- event.Skip()
- def OnPaint(self, event):
- Debug.msg(3, "GLCanvas.OnPaint()")
- dc = wx.PaintDC(self)
- self.SetCurrent()
- if not self.init:
- self.nvizClass.InitView()
- self.LoadDataLayers()
- self.ResetView()
- if hasattr(self.parent, "nvizToolWin"):
- self.parent.nvizToolWin.UpdatePage('view')
- layer = self.GetSelectedLayer()
- if layer:
- if layer.type == 'raster':
- self.parent.nvizToolWin.UpdatePage('surface')
- elif layer.type == 'vector':
- self.parent.nvizToolWin.UpdatePage('vector')
- self.parent.nvizToolWin.UpdateSettings()
- # update widgets
- win = self.parent.nvizToolWin.FindWindowById( \
- self.parent.nvizToolWin.win['vector']['lines']['surface'])
- win.SetItems(self.layers['raster']['name'])
- self.init = True
- self.UpdateMap()
- def OnMouseAction(self, event):
- # change position
- if event.Dragging() and event.LeftIsDown():
- self.lastX = self.lastY = self.x = self.y
- self.x, self.y = event.GetPosition()
- self.Refresh(False)
- # change perspective with mouse wheel
- wheel = event.GetWheelRotation()
- if wheel != 0:
- current = event.GetPositionTuple()[:]
- Debug.msg (5, "GLWindow.OnMouseMotion(): wheel=%d" % wheel)
- prev_value = self.view['persp']['value']
- if wheel > 0:
- value = -1 * self.view['persp']['step']
- else:
- value = self.view['persp']['step']
- self.view['persp']['value'] += value
- if self.view['persp']['value'] < 1:
- self.view['persp']['value'] = 1
- elif self.view['persp']['value'] > 100:
- self.view['persp']['value'] = 100
- if prev_value != self.view['persp']['value']:
- self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
- self.iview['height']['value'],
- self.view['persp']['value'],
- self.view['twist']['value'])
- # redraw map
- self.OnPaint(None)
- # update statusbar
- ### self.parent.StatusbarUpdate()
- def OnLeftDown(self, event):
- self.CaptureMouse()
- self.x, self.y = self.lastX, self.lastY = event.GetPosition()
- def OnLeftUp(self, event):
- self.ReleaseMouse()
- def UpdateMap(self, render=True):
- Updates the canvas anytime there is a change to the
- underlaying images or to the geometry of the canvas.
- @param render re-render map composition
- start = time.clock()
- self.resize = False
- # if self.size is None:
- # self.size = self.GetClientSize()
- # w, h = self.size
- # w = float(max(w, 1.0))
- # h = float(max(h, 1.0))
- # d = float(min(w, h))
- # xScale = d / w
- # yScale = d / h
- # print w, h, d, xScale, yScale
- # print self.y, self.lastY, self.x, self.lastX
- # print (self.y - self.lastY) * yScale, (self.x - self.lastX) * xScale
- # print self.x * xScale
- #glRotatef((self.y - self.lastY) * yScale, 1.0, 0.0, 0.0);
- #glRotatef((self.x - self.lastX) * xScale, 0.0, 1.0, 0.0);
- if self.render['quick'] is False:
- self.parent.onRenderGauge.Show()
- self.parent.onRenderGauge.SetRange(2)
- self.parent.onRenderGauge.SetValue(0)
- if 'view' in self.update:
- if 'z-exag' in self.update:
- self.nvizClass.SetZExag(self.view['z-exag']['value'])
- self.update.remove('z-exag')
- self.update.remove('view')
- self.parent.onRenderGauge.SetValue(1)
- wx.Yield()
- self.nvizClass.Draw(False, -1)
- elif self.render['quick'] is True:
- # quick
- mode = wxnviz.DRAW_QUICK_SURFACE | wxnviz.DRAW_QUICK_VOLUME
- if self.render['vlines']:
- mode |= wxnviz.DRAW_QUICK_VLINES
- if self.render['vpoints']:
- mode |= wxnviz.DRAW_QUICK_VPOINTS
- self.nvizClass.Draw(True, mode)
- else: # None -> reuse last rendered image
- pass # TODO
- self.SwapBuffers()
- stop = time.clock()
- self.parent.onRenderGauge.SetValue(2)
- # hide process bar
- self.parent.onRenderGauge.Hide()
- # self.parent.StatusbarUpdate()
- Debug.msg(3, "GLWindow.UpdateMap(): quick=%d, -> time=%g" % \
- (self.render['quick'], (stop-start)))
- # print stop-start
- def EraseMap(self):
- Erase the canvas
- self.nvizClass.EraseMap()
- def IsLoaded(self, item):
- """Check if layer (item) is already loaded
- @param item layer item
- layer = self.tree.GetPyData(item)[0]['maplayer']
- data = self.tree.GetPyData(item)[0]['nviz']
- if not data:
- return 0
- if not data['surface'].has_key('object'):
- return 0
- if not data['vlines'].has_key('object') and \
- not data['points'].has_key('object'):
- return 0
- return 1
- def LoadDataLayers(self):
- """Load raster/vector from current layer tree
- @todo volumes
- listOfItems = []
- # load raster & vector maps
- item = self.tree.GetFirstChild(self.tree.root)[0]
- while item and item.IsOk():
- type = self.tree.GetPyData(item)[0]['type']
- if not item.IsChecked() or \
- type not in ('raster', 'vector', '3d-raster'):
- item = self.tree.GetNextSibling(item)
- continue
- listOfItems.append(item)
- start = time.time()
- while(len(listOfItems) > 0):
- item = listOfItems.pop()
- try:
- if type == 'raster':
- self.LoadRaster(item)
- elif type == '3d-raster':
- self.LoadRaster3d(item)
- except gcmd.NvizError, e:
- print >> sys.stderr, "Nviz:" + e.message
- try:
- if type == 'vector':
- vecType = []
- if data and data.has_key('vector'):
- for v in ('lines', 'points'):
- if data['vector'][v]:
- vecType.append(v)
- self.LoadVector(item, vecType)
- stop = time.time()
- Debug.msg(3, "GLWindow.LoadDataLayers(): time=%f" % (stop-start))
- # print stop - start
- def SetLayerData(self, item, id, nvizType):
- """Set map object properties
- @param id nviz layer id (or -1)
- @param nvizType nviz data type (surface, points, vector)
- type = self.tree.GetPyData(item)[0]['maplayer'].type
- # reference to original layer properties (can be None)
- if data is None:
- # init data structure
- self.tree.GetPyData(item)[0]['nviz'] = {}
- data[nvizType] = {}
- for sec in ('attribute', 'draw', 'mask', 'position'):
- data[nvizType][sec] = {}
- # reset to default properties
- self.SetSurfaceDefaultProp(data[nvizType])
- elif type == 'vector':
- data['vector'] = {}
- for sec in ('lines', 'points'):
- data['vector'][sec] = {}
- # reset to default properties (lines/points)
- self.SetVectorDefaultProp(data['vector'])
- for sec in ('attribute', 'draw', 'position'):
- for sec in ('isosurface', 'slice'):
- data[nvizType][sec] = []
- self.SetVolumeDefaultProp(data[nvizType])
- else:
- # check data
- if not data['vector']['lines']:
- self.SetVectorLinesDefaultProp(data['vector']['lines'])
- if not data['vector']['points']:
- self.SetVectorPointsDefaultProp(data['vector']['points'])
- # set updates
- for sec in data.keys():
- for sec1 in data[sec].keys():
- for sec2 in data[sec][sec1].keys():
- if sec2 not in ('object'):
- self.update.append('%s:%s:%s' % (sec, sec1, sec2))
- # set id
- if id > 0:
- if type in ('raster', '3d-raster'):
- data[nvizType]['object'] = { 'id' : id,
- 'init' : False }
- data['vector'][nvizType]['object'] = { 'id' : id,
- 'init' : False }
- return data
- def LoadRaster(self, item):
- """Load 2d raster map and set surface attributes
- @param layer item
- return self._loadRaster(item)
- def LoadRaster3d(self, item):
- """Load 3d raster map and set surface attributes
- @param layer item
- def _loadRaster(self, item):
- """Load 2d/3d raster map and set its attributes
- @param layer item
- if layer.type not in ('raster', '3d-raster'):
- return
- id = self.nvizClass.LoadSurface(str(layer.name), None, None)
- nvizType = 'surface'
- errorMsg = _("Loading raster map")
- elif layer.type == '3d-raster':
- id = self.nvizClass.LoadVolume(str(layer.name), None, None)
- nvizType = 'volume'
- errorMsg = _("Loading 3d raster map")
- else:
- id = -1
- if id < 0:
- if layer.type in ('raster', '3d-raster'):
- print >> sys.stderr, "Nviz:" + "%s <%s> %s" % (errorMsg, layer.name, _("failed"))
- else:
- print >> sys.stderr, "Nviz:" + _("Unsupported layer type '%s'") % layer.type
- self.layers[layer.type]['name'].append(layer.name)
- self.layers[layer.type]['id'].append(id)
- # set default/workspace layer properties
- data = self.SetLayerData(item, id, nvizType)
- print data
- # update properties
- self.UpdateLayerProperties(item)
- # update tools window
- if hasattr(self.parent, "nvizToolWin") and \
- item == self.GetSelectedLayer(type='item'):
- toolWin = self.parent.nvizToolWin
- win = toolWin.FindWindowById( \
- toolWin.win['vector']['lines']['surface'])
- win.SetItems(self.layers[layer.type]['name'])
- toolWin.UpdatePage(nvizType)
- toolWin.SetPage(nvizType)
- return id
- def UnloadRaster(self, item):
- """Unload 2d raster map
- @param layer item
- return self._unloadRaster(item)
- def UnloadRaster3d(self, item):
- """Unload 3d raster map
- @param layer item
- def _unloadRaster(self, item):
- """Unload 2d/3d raster map
- return
- unloadFn = self.nvizClass.UnloadSurface
- errorMsg = _("Unable to unload raster map")
- successMsg = _("Raster map")
- else:
- unloadFn = self.nvizClass.UnloadVolume
- errorMsg = _("Unable to unload 3d raster map")
- successMsg = _("3d raster map")
- id = data[nvizType]['object']['id']
- if unloadFn(id) == 0:
- print >> sys.stderr, "Nviz:" + "%s <%s>" % (errorMsg, layer.name)
- else:
- print "Nviz:" + "%s <%s> %s" % (successMsg, layer.name, _("unloaded successfully"))
- data[nvizType].pop('object')
- idx = self.layers[layer.type]['id'].index(id)
- del self.layers[layer.type]['name'][idx]
- del self.layers[layer.type]['id'][idx]
- layer.type == 'raster':
- # remove surface page
- if toolWin.notebook.GetSelection() == toolWin.page[nvizType]['id']:
- toolWin.notebook.RemovePage(toolWin.page[nvizType]['id'])
- toolWin.page[nvizType]['id'] = -1
- toolWin.page['settings']['id'] = 1
- def GetSurfaceMode(self, mode, style, shade, string=False):
- """Determine surface draw mode"""
- value = 0
- desc = {}
- if string:
- if mode == 'coarse':
- value |= wxnviz.DM_WIRE
- elif mode == 'fine':
- value |= wxnviz.DM_POLY
- else: # both
- value |= wxnviz.DM_WIRE_POLY
- if style == 'wire':
- value |= wxnviz.DM_GRID_WIRE
- else: # surface
- value |= wxnviz.DM_GRID_SURF
- if shade == 'flat':
- value |= wxnviz.DM_FLAT
- else: # surface
- value |= wxnviz.DM_GOURAUD
- return value
- # -> string is False
- if mode == 0: # coarse
- desc['mode'] = 'coarse'
- elif mode == 1: # fine
- desc['mode'] = 'fine'
- else: # both
- desc['mode'] = 'both'
- if style == 0: # wire
- desc['style'] = 'wire'
- else: # surface
- desc['style'] = 'surface'
- if shade == 0:
- desc['shading'] = 'flat'
- else: # surface
- desc['shading'] = 'gouraud'
- return (value, desc)
- def SetSurfaceDefaultProp(self, data):
- """Set default surface properties"""
- # attributes
- for attrb in ('shine', ):
- data['attribute'][attrb] = {}
- for key, value in UserSettings.Get(group='nviz', key='volume',
- subkey=attrb).iteritems():
- data['attribute'][attrb][key] = value
- self.update.append('surface:attribute:%s' % value)#
- # draw
- data['draw']['all'] = False # apply only for current surface
- for control, value in UserSettings.Get(group='nviz', key='surface', subkey='draw').iteritems():
- if control[:3] == 'res':
- if 'surface:draw:%s' % 'resolution' not in self.update:
- self.update.append('surface:draw:%s' % 'resolution')
- data['draw']['resolution'][control[4:]] = value
- continue
- elif control not in ('style', 'shading'):
- self.update.append('surface:draw:%s' % control)
- if control == 'wire-color':
- value = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
- elif control in ('mode', 'style', 'shading'):
- if not data['draw'].has_key('mode'):
- data['draw']['mode'] = {}
- continue
- data['draw'][control] = { 'value' : value }
- value, desc = self.GetSurfaceMode(UserSettings.Get(group='nviz', key='surface', subkey=['draw', 'mode']),
- UserSettings.Get(group='nviz', key='surface', subkey=['draw', 'style']),
- UserSettings.Get(group='nviz', key='surface', subkey=['draw', 'shading']))
- data['draw']['mode'] = { 'value' : value,
- 'desc' : desc, }
- def LoadVector(self, item, vecType=None):
- """Load 2D or 3D vector map overlay
- @param vecType vector type (lines / points)
- if layer.type != 'vector':
- return
- if vecType is None:
- # load data type by default
- vecType = []
- if UserSettings.Get(group='nviz', key='vector',
- subkey=[v, 'show']):
- vecType.append(v)
- # set default properties
- self.SetLayerData(item, -1, 'lines')
- self.SetLayerData(item, -1, 'points')
- id = -1
- for type in vecType:
- if type == 'lines':
- id = self.nvizClass.LoadVector(str(layer.name), False)
- else:
- id = self.nvizClass.LoadVector(str(layer.name), True)
- if id < 0:
- print >> sys.stderr, "Nviz:" + _("Loading vector map <%(name)s> (%(type)s) failed") % \
- { 'name' : layer.name, 'type' : type }
- continue
- # update layer properties
- self.SetLayerData(item, id, type)
- self.layers['v' + type]['name'].append(layer.name)
- self.layers['v' + type]['id'].append(id)
- toolWin.UpdatePage('vector')
- toolWin.SetPage('vector')
- return id
- def UnloadVector(self, item, vecType=None):
- """Unload vector map overlay
- @param vecType vector type (lines, points)
- data = self.tree.GetPyData(item)[0]['nviz']['vector']
- vecType = []
- vecType.append(v)
- for vtype in vecType:
- if not data[vtype].has_key('object'):
- continue
- id = data[vtype]['object']['id']
- if vtype == 'lines':
- ret = self.nvizClass.UnloadVector(id, False)
- else:
- ret = self.nvizClass.UnloadVector(id, True)
- if ret == 0:
- print >> sys.stderr, "Nviz:" + _("Unable to unload vector map <%(name)s> (%(type)s)") % \
- { 'name': layer.name, 'type' : vtype }
- else:
- print "Nviz:" + _("Vector map <%(name)s> (%(type)s) unloaded successfully") % \
- { 'name' : layer.name, 'type' : vtype }
- data[vtype].pop('object')
- idx = self.layers['v' + vtype]['id'].index(id)
- del self.layers['v' + vtype]['name'][idx]
- del self.layers['v' + vtype]['id'][idx]
- vecType is None:
- if toolWin.notebook.GetSelection() == toolWin.page['surface']['id']:
- toolWin.notebook.RemovePage(toolWin.page['surface']['id'])
- toolWin.page['surface']['id'] = -1
- def SetVectorDefaultProp(self, data):
- """Set default vector properties"""
- self.SetVectorLinesDefaultProp(data['lines'])
- self.SetVectorPointsDefaultProp(data['points'])
- def SetVectorLinesDefaultProp(self, data):
- """Set default vector properties -- lines"""
- # width
- data['width'] = UserSettings.Get(group='nviz', key='vector',
- subkey=['lines', 'width'])
- # color
- value = UserSettings.Get(group='nviz', key='vector',
- subkey=['lines', 'color'])
- color = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
- data['color'] = color
- # mode
- subkey=['lines', 'flat']):
- type = 'flat'
- map = None
- else:
- if len(self.layers['raster']['name']) > 0:
- type = 'surface'
- map = self.layers['raster']['name'][0]
- else:
- type = 'flat'
- map = None
- data['mode'] = {}
- data['mode']['type'] = type
- if map:
- data['mode']['surface'] = map
- # height
- data['height'] = UserSettings.Get(group='nviz', key='vector',
- subkey=['lines', 'height'])
- if data.has_key('object'):
- self.update.append('vector:lines:color')
- self.update.append('vector:lines:width')
- self.update.append('vector:lines:mode')
- self.update.append('vector:lines:height')
- def SetVectorPointsDefaultProp(self, data):
- """Set default vector properties -- points"""
- # size
- data['size'] = UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'size'])
- # width
- subkey=['points', 'width'])
- # marker
- data['marker'] = UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'marker'])
- # color
- subkey=['points', 'color'])
- # mode
- data['mode'] = { 'type' : 'surface',
- 'surface' : '' }
- data['mode']['surface'] = self.layers['raster']['name'][0]
- # height
- subkey=['points', 'height'])
- self.update.append('vector:points:size')
- self.update.append('vector:points:width')
- self.update.append('vector:points:marker')
- self.update.append('vector:points:color')
- self.update.append('vector:points:surface')
- self.update.append('vector:points:height')
- def SetVolumeDefaultProp(self, data):
- """Set default volume properties"""
- # draw
- data['draw']['all'] = False # apply only for current volume set
- for control, value in UserSettings.Get(group='nviz', key='volume', subkey='draw').iteritems():
- if 'volume:draw:%s' % control not in self.update:
- self.update.append('volume:draw:%s' % control)
- # isosurface attributes
- ### self.update.append('volume:attribute:%s' % value)
- def Reset(self):
- """Reset (unload data)"""
- self.nvizClass.Reset()
- self.init = False
- def OnZoomToMap(self, event):
- Set display extents to match selected raster
- or vector map or volume.
- @todo vector, volume
- if layer is None:
- return
- Debug.msg (3, "GLWindow.OnZoomToMap(): layer=%s, type=%s" % \
- (layer.name, layer.type))
- self.nvizClass.SetViewportDefault()
- def ResetView(self):
- """Reset to default view"""
- self.view['z-exag']['value'], \
- self.iview['height']['value'], \
- self.iview['height']['min'], \
- self.iview['height']['max'] = self.nvizClass.SetViewDefault()
- self.view['pos']['x'] = UserSettings.Get(group='nviz', key='view',
- subkey=('pos', 'x'))
- self.view['pos']['y'] = UserSettings.Get(group='nviz', key='view',
- self.view['persp']['value'] = UserSettings.Get(group='nviz', key='view',
- subkey=('persp', 'value'))
- self.view['twist']['value'] = UserSettings.Get(group='nviz', key='view',
- subkey=('twist', 'value'))
- self.update.append('view')
- def UpdateLayerProperties(self, layer=None):
- """Update data layer properties
- @param layer layer item or None (for selected item)
- if not layer:
- mapLayer = self.GetSelectedLayer()
- data = self.GetSelectedLayer(type='nviz')
- else:
- mapLayer = self.tree.GetPyData(layer)[0]['maplayer']
- data = self.tree.GetPyData(layer)[0]['nviz']
- if mapLayer.type == 'raster':
- id = data['surface']['object']['id']
- self.UpdateRasterProperties(id, data['surface'])
- # -> initialized
- data['surface']['object']['init'] = True
- elif mapLayer.type == '3d-raster':
- id = data['volume']['object']['id']
- self.UpdateVolumeProperties(id, data['volume'])
- # -> initialized
- data['volume']['object']['init'] = True
- elif mapLayer.type == 'vector':
- for type in ('lines', 'points'):
- if data['vector'][type].has_key('object'):
- id = data['vector'][type]['object']['id']
- self.UpdateVectorProperties(id, data['vector'], type)
- # -> initialized
- data['vector'][type]['object']['init'] = True
- def UpdateRasterProperties(self, id, data):
- """Update surface layer properties"""
- # surface attributes
- for attrb in ('topo', 'color', 'mask',
- 'transp', 'shine', 'emit'):
- if 'surface:attribute:%s' % attrb in self.update:
- map = data['attribute'][attrb]['map']
- value = data['attribute'][attrb]['value']
- if map is None: # unset
- # only optional attributes
- if attrb == 'mask':
- # TODO: invert mask
- # TODO: broken in NVIZ
- self.nvizClass.UnsetSurfaceMask(id)
- elif attrb == 'transp':
- self.nvizClass.UnsetSurfaceTransp(id)
- elif attrb == 'emit':
- self.nvizClass.UnsetSurfaceEmit(id)
- else:
- if type(value) == type('') and \
- len(value) <= 0: # ignore empty values (TODO: warning)
- continue
- if attrb == 'topo':
- self.nvizClass.SetSurfaceTopo(id, map, str(value))
- elif attrb == 'color':
- self.nvizClass.SetSurfaceColor(id, map, str(value))
- elif attrb == 'mask':
- self.nvizClass.SetSurfaceMask(id, False, str(value))
- self.nvizClass.SetSurfaceTransp(id, map, str(value))
- elif attrb == 'shine':
- self.nvizClass.SetSurfaceShine(id, map, str(value))
- self.nvizClass.SetSurfaceEmit(id, map, str(value))
- self.update.remove('surface:attribute:%s' % attrb)
- # draw res
- if 'surface:draw:resolution' in self.update:
- coarse = data['draw']['resolution']['coarse']
- fine = data['draw']['resolution']['fine']
- if data['draw']['all']:
- self.nvizClass.SetSurfaceRes(-1, fine, coarse)
- else:
- self.nvizClass.SetSurfaceRes(id, fine, coarse)
- self.update.remove('surface:draw:resolution')
- # draw style
- if 'surface:draw:mode' in self.update:
- if data['draw']['mode']['value'] < 0: # need to calculate
- data['draw']['mode']['value'] = \
- self.GetSurfaceMode(mode=data['draw']['mode']['desc']['mode'],
- style=data['draw']['mode']['desc']['style'],
- shade=data['draw']['mode']['desc']['shading'],
- string=True)
- style = data['draw']['mode']['value']
- self.nvizClass.SetSurfaceStyle(-1, style)
- else:
- self.nvizClass.SetSurfaceStyle(id, style)
- self.update.remove('surface:draw:mode')
- # wire color
- if 'surface:draw:wire-color' in self.update:
- color = data['draw']['wire-color']['value']
- self.nvizClass.SetWireColor(-1, str(color))
- else:
- self.nvizClass.SetWireColor(id, str(color))
- self.update.remove('surface:draw:wire-color')
- # position
- if 'surface:position' in self.update:
- x = data['position']['x']
- y = data['position']['y']
- z = data['position']['z']
- self.nvizClass.SetSurfacePosition(id, x, y, z)
- self.update.remove('surface:position')
- """Apply volume layer properties"""
- pass
- def UpdateVectorProperties(self, id, data, type):
- """Update vector layer properties
- @param id layer id
- @param data properties
- @param type lines/points
- if type == 'points':
- self.UpdateVectorPointsProperties(id, data[type])
- else:
- self.UpdateVectorLinesProperties(id, data[type])
- def UpdateVectorLinesProperties(self, id, data):
- """Apply changes for vector line layer"""
- # mode
- if 'vector:lines:color' in self.update or \
- 'vector:lines:width' in self.update or \
- 'vector:lines:mode' in self.update:
- width = data['width']
- color = data['color']
- if data['mode']['type'] == 'flat':
- flat = True
- if data.has_key('surface'):
- data.pop('surface')
- else:
- flat = False
- if not 'vector:lines:surface' in self.update:
- self.update.append('vector:lines:surface')
- self.nvizClass.SetVectorLineMode(id, color,
- width, flat)
- if 'vector:lines:color' in self.update:
- self.update.remove('vector:lines:color')
- if 'vector:lines:width' in self.update:
- self.update.remove('vector:lines:width')
- if 'vector:lines:mode' in self.update:
- self.update.remove('vector:lines:mode')
- # height
- if 'vector:lines:height' in self.update:
- self.nvizClass.SetVectorLineHeight(id,
- data['height'])
- self.update.remove('vector:lines:height')
- # surface
- if 'vector:lines:surface' in self.update:
- idx = self.layers['raster']['name'].index(data['mode']['surface'])
- if idx > -1:
- self.nvizClass.SetVectorLineSurface(id,
- self.layers['raster']['id'][idx])
- self.update.remove('vector:lines:surface')
- def UpdateVectorPointsProperties(self, id, data):
- """Apply changes for vector point layer"""
- if 'vector:points:size' in self.update or \
- 'vector:points:width' in self.update or \
- 'vector:points:marker' in self.update or \
- 'vector:points:color' in self.update:
- ret = self.nvizClass.SetVectorPointMode(id, data['color'],
- data['width'], float(data['size']),
- data['marker'] + 1)
- error = None
- if ret == -1:
- error = _("Vector point layer not found (id=%d)") % id
- elif ret == -2:
- error = _("Unable to set data layer properties (id=%d)") % id
- if error:
- raise gcmd.NvizError(parent=self.parent,
- message=_("Setting data layer properties failed.\n\n%s") % error)
- for prop in ('size', 'width', 'marker', 'color'):
- if 'vector:points:%s' % prop in self.update:
- self.update.remove('vector:points:%s' % prop)
- # height
- if 'vector:points:height' in self.update:
- self.nvizClass.SetVectorPointHeight(id,
- data['height'])
- self.update.remove('vector:points:height')
- # surface
- if 'vector:points:surface' in self.update:
- if idx > -1:
- self.nvizClass.SetVectorPointSurface(id,
- self.update.remove('vector:points:surface')
-class NvizToolWindow(wx.Frame):
- """Experimental window for Nviz tools
- @todo integrate with Map display
- def __init__(self, parent=None, id=wx.ID_ANY, title=_("Nviz tools"),
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_FRAME_STYLE, mapWindow=None):
- self.lmgr = self.parent.gismanager # GMFrame
- self.mapWindow = mapWindow
- wx.Frame.__init__(self, parent, id, title, pos, size, style)
- # icon
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_nviz.ico'), wx.BITMAP_TYPE_ICO))
- # dialog body
- mainSizer = wx.BoxSizer(wx.VERTICAL)
- self.win = {} # window ids
- # notebook
- self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
- self.page = {}
- # view page
- self.__createViewPage()
- self.page['view'] = { 'id' : 0 }
- # surface page
- size = self.__createSurfacePage()
- size = (size[0] + 25, size[0] + 20)
- # vector page
- self.__createVectorPage()
- # volume page
- self.__createVolumePage()
- # settings page
- self.__createSettingsPage()
- self.page['settings'] = { 'id' : 1 }
- self.UpdatePage('settings')
- self.pageChanging = False
- mainSizer.Add(item=self.notebook, proportion=1,
- flag=wx.EXPAND | wx.ALL, border=5)
- # bindings
- self.Bind(wx.EVT_CLOSE, self.OnClose)
- # layout
- self.SetSizer(mainSizer)
- mainSizer.Fit(self)
- self.SetSize(size)
- def __createViewPage(self):
- """Create view settings page"""
- panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
- self.notebook.AddPage(page=panel,
- text=" %s " % _("View"))
- pageSizer = wx.BoxSizer(wx.VERTICAL)
- gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
- self.win['view'] = {}
- # position
- posSizer = wx.GridBagSizer(vgap=3, hgap=3)
- posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("W")),
- pos=(1, 0), flag=wx.ALIGN_CENTER)
- posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("N")),
- pos=(0, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_BOTTOM)
- viewPos = ViewPositionWindow(panel, id=wx.ID_ANY, size=(175, 175),
- mapwindow=self.mapWindow)
- self.win['view']['pos'] = viewPos.GetId()
- posSizer.Add(item=viewPos,
- pos=(1, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_CENTER_VERTICAL)
- posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("S")),
- pos=(2, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_TOP)
- posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("E")),
- pos=(1, 2), flag=wx.ALIGN_CENTER)
- gridSizer.Add(item=posSizer, pos=(0, 0))
- # perspective
- range = UserSettings.Get(group='nviz', key='view', subkey='persp', internal=True)
- self.CreateControl(panel, dict=self.win['view'], name='persp',
- range=(range['min'], range['max']),
- bind=(self.OnViewChange, self.OnViewChanged, self.OnViewChangedSpin))
- gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Perspective:")),
- gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['slider']), pos=(2, 0))
- gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['spin']), pos=(3, 0),
- flag=wx.ALIGN_CENTER)
- # twist
- range = UserSettings.Get(group='nviz', key='view', subkey='twist', internal=True)
- self.CreateControl(panel, dict=self.win['view'], name='twist',
- gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Twist:")),
- pos=(1, 1), flag=wx.ALIGN_CENTER)
- gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['slider']), pos=(2, 1))
- gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['spin']), pos=(3, 1),
- # height + z-exag
- self.CreateControl(panel, dict=self.win['view'], name='height', sliderHor=False,
- range=(0, 1),
- self.CreateControl(panel, dict=self.win['view'], name='z-exag', sliderHor=False,
- range=(0, 1),
- heightSizer = wx.GridBagSizer(vgap=3, hgap=3)
- heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Height:")),
- pos=(0, 0), flag=wx.ALIGN_LEFT, span=(1, 2))
- heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['slider']),
- flag=wx.ALIGN_RIGHT, pos=(1, 0))
- heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['spin']),
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT | wx.TOP |
- wx.BOTTOM | wx.RIGHT, pos=(1, 1))
- heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Z-exag:")),
- pos=(0, 2), flag=wx.ALIGN_LEFT, span=(1, 2))
- heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['slider']),
- flag=wx.ALIGN_RIGHT, pos=(1, 2))
- heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['spin']),
- wx.BOTTOM | wx.RIGHT, pos=(1, 3))
- gridSizer.Add(item=heightSizer, pos=(0, 1), flag=wx.ALIGN_RIGHT)
- # view setup + reset
- viewSizer = wx.BoxSizer(wx.HORIZONTAL)
- viewSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY,
- label=_("Look at:")),
- flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=5)
- viewType = wx.Choice (parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices = [_("top"),
- _("north"),
- _("south"),
- _("east"),
- _("west"),
- _("north-west"),
- _("north-east"),
- _("south-east"),
- _("south-west")])
- viewType.SetSelection(0)
- viewType.Bind(wx.EVT_CHOICE, self.OnLookAt)
- # self.win['lookAt'] = viewType.GetId()
- viewSizer.Add(item=viewType, flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL,
- border=5)
- reset = wx.Button(panel, id=wx.ID_ANY, label=_("Reset"))
- reset.SetToolTipString(_("Reset to default view"))
- # self.win['reset'] = reset.GetId()
- reset.Bind(wx.EVT_BUTTON, self.OnResetView)
- viewSizer.Add(item=reset, proportion=1,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT,
- border=5)
- gridSizer.AddGrowableCol(3)
- gridSizer.Add(item=viewSizer, pos=(4, 0), span=(1, 2),
- flag=wx.EXPAND)
- # body
- pageSizer.Add(item=gridSizer, proportion=1,
- border=5)
- panel.SetSizer(pageSizer)
- return panel.GetBestSize()
- def __createSurfacePage(self):
- self.page['surface'] = {}
- self.page['surface']['id'] = -1
- self.page['surface']['panel'] = panel.GetId()
- # panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY)
- # panel.SetupScrolling(scroll_x=True, scroll_y=True)
- self.win['surface'] = {}
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
- label=" %s " % (_("Surface attributes")))
- boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- # type
- self.win['surface']['attr'] = {}
- row = 0
- for code, attrb in (('topo', _("Topography")),
- ('color', _("Color")),
- ('mask', _("Mask")),
- ('transp', _("Transparency")),
- ('shine', _("Shininess")),
- ('emit', _("Emission"))):
- self.win['surface'][code] = {}
- gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=attrb + ':'),
- pos=(row, 0), flag=wx.ALIGN_CENTER_VERTICAL)
- use = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices = [_("map")])
- if code not in ('topo', 'color', 'shine'):
- use.Insert(item=_("unset"), pos=0)
- self.win['surface'][code]['required'] = False
- else:
- self.win['surface'][code]['required'] = True
- if code != 'mask':
- use.Append(item=_('constant'))
- self.win['surface'][code]['use'] = use.GetId()
- use.Bind(wx.EVT_CHOICE, self.OnMapObjUse)
- gridSizer.Add(item=use, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(row, 1))
- map = gselect.Select(parent=panel, id=wx.ID_ANY,
- # size=globalvar.DIALOG_GSELECT_SIZE,
- size=(200, -1),
- type="raster")
- self.win['surface'][code]['map'] = map.GetId() - 1 # FIXME
- map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
- # changing map topography not allowed
- if code == 'topo':
- map.Enable(False)
- gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(row, 2))
- if code == 'color':
- value = csel.ColourSelect(panel, id=wx.ID_ANY,
- colour=UserSettings.Get(group='nviz', key='surface',
- subkey=['color', 'value']))
- value.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceMap)
- elif code == 'mask':
- value = None
- else:
- value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=0)
- value.SetRange(minVal=-1e9, maxVal=1e9)
- elif code in ('shine', 'transp', 'emit'):
- value.SetRange(minVal=0, maxVal=255)
- else:
- value.SetRange(minVal=0, maxVal=100)
- value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
- if value:
- self.win['surface'][code]['const'] = value.GetId()
- value.Enable(False)
- gridSizer.Add(item=value, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(row, 3))
- else:
- self.win['surface'][code]['const'] = None
- self.SetMapObjUseMap(nvizType='surface',
- attrb=code) # -> enable map / disable constant
- row += 1
- boxSizer.Add(item=gridSizer, proportion=1,
- flag=wx.ALL | wx.EXPAND, border=3)
- pageSizer.Add(item=boxSizer, proportion=0,
- border=5)
- # draw
- self.win['surface']['draw'] = {}
- label=" %s " % (_("Draw")))
- gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
- gridSizer.AddGrowableCol(4)
- # mode
- label=_("Mode:")),
- pos=(0, 0), flag=wx.ALIGN_CENTER_VERTICAL)
- mode = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices = [_("coarse"),
- _("fine"),
- _("both")])
- mode.SetSelection(0)
- mode.SetName("selection")
- mode.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
- self.win['surface']['draw']['mode'] = mode.GetId()
- gridSizer.Add(item=mode, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 1))
- # resolution (mode)
- label=_("Resolution:")),
- pos=(0, 2), flag=wx.ALIGN_CENTER_VERTICAL)
- resSizer = wx.BoxSizer(wx.HORIZONTAL)
- resSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("coarse:")),
- flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=3)
- resC = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=1,
- min=1,
- max=100)
- resC.SetName("value")
- self.win['surface']['draw']['res-coarse'] = resC.GetId()
- resC.Bind(wx.EVT_SPINCTRL, self.OnSurfaceResolution)
- resSizer.Add(item=resC, flag=wx.ALL, border=3)
- label=_("fine:")),
- resF = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=1,
- min=1,
- max=100)
- resF.SetName("value")
- self.win['surface']['draw']['res-fine'] = resF.GetId()
- resF.Bind(wx.EVT_SPINCTRL, self.OnSurfaceResolution)
- resSizer.Add(item=resF, flag=wx.ALL, border=3)
- gridSizer.Add(item=resSizer, pos=(0, 3), span=(1, 2))
- # style
- label=_("Coarse style:")),
- pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL)
- style = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices = [_("wire"),
- _("surface")])
- style.SetName("selection")
- self.win['surface']['draw']['style'] = style.GetId()
- style.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
- gridSizer.Add(item=style, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(1, 1))
- # shading
- label=_("Shading:")),
- pos=(1, 2), flag=wx.ALIGN_CENTER_VERTICAL)
- shade = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices = [_("flat"),
- _("gouraud")])
- shade.SetName("selection")
- self.win['surface']['draw']['shading'] = shade.GetId()
- shade.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
- gridSizer.Add(item=shade, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(1, 3))
- # color
- label=_("Wire color:")),
- pos=(2, 0), flag=wx.ALIGN_CENTER_VERTICAL)
- color = csel.ColourSelect(panel, id=wx.ID_ANY)
- color.SetName("colour")
- color.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceWireColor)
- self.win['surface']['draw']['wire-color'] = color.GetId()
- gridSizer.Add(item=color, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(2, 1))
- flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
- border=5)
- all = wx.Button(panel, id=wx.ID_ANY, label=_("All"))
- all.SetToolTipString(_("Use for all loaded surfaces"))
- all.Bind(wx.EVT_BUTTON, self.OnSurfaceModeAll)
- gridSizer.Add(item=all, flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
- pos=(2, 4))
- # mask
- label=" %s " % (_("Mask")))
- label=_("Mask zeros:")),
- elev = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("by elevation"))
- elev.Enable(False) # TODO: not implemented yet
- gridSizer.Add(item=elev, pos=(0, 1))
- color = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("by color"))
- color.Enable(False) # TODO: not implemented yet
- gridSizer.Add(item=color, pos=(0, 2))
- border=5)
- # position
- self.win['surface']['position'] = {}
- label=" %s " % (_("Position")))
- # position
- axis = wx.Choice (parent=panel, id=wx.ID_ANY, size=(75, -1),
- choices = ["X",
- "Y",
- "Z"])
- axis.SetSelection(0)
- self.win['surface']['position']['axis'] = axis.GetId()
- axis.Bind(wx.EVT_CHOICE, self.OnSurfaceAxis)
- gridSizer.Add(item=axis, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 0))
- value = wx.Slider(parent=panel, id=wx.ID_ANY,
- value=0,
- minValue=-1e4,
- maxValue=1e4,
- style=wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
- wx.SL_TOP | wx.SL_LABELS,
- size=(350, -1))
- self.win['surface']['position']['pos'] = value.GetId()
- value.Bind(wx.EVT_SCROLL, self.OnSurfacePosition)
- pos=(0, 1))
- border=5)
- def __createVectorPage(self):
- self.page['vector'] = {}
- self.page['vector']['id'] = -1
- self.page['vector']['panel'] = panel.GetId()
- self.win['vector'] = {}
- # desc
- desc = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label="")
- self.win['vector']['desc'] = desc.GetId()
- pageSizer.Add(item=desc, proportion=0,
- border=10)
- # vector lines
- self.win['vector']['lines'] = {}
- showLines = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Show vector lines"))
- self.win['vector']['lines']['show'] = showLines.GetId()
- showLines.Bind(wx.EVT_CHECKBOX, self.OnVectorShow)
- pageSizer.Add(item=showLines, proportion=0,
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
- label=" %s " % (_("Vector lines")))
- # width
- label=_("Width:")),
- width = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=1,
- min=1,
- max=100)
- self.win['vector']['lines']['width'] = width.GetId()
- width.Bind(wx.EVT_SPINCTRL, self.OnVectorLines)
- gridSizer.Add(item=width, pos=(0, 1),
- flag=wx.ALIGN_CENTER_VERTICAL)
- gridSizer.AddGrowableCol(2)
- # color
- label=_("Color:")),
- pos=(0, 3), flag=wx.ALIGN_CENTER_VERTICAL)
- color = csel.ColourSelect(panel, id=wx.ID_ANY,
- colour=UserSettings.Get(group='nviz', key='vector',
- subkey=['lines', 'color']))
- self.win['vector']['lines']['color'] = color.GetId()
- color.Bind(csel.EVT_COLOURSELECT, self.OnVectorLines)
- gridSizer.Add(item=color, pos=(0, 4))
- gridSizer.AddGrowableCol(5)
- # display
- label=_("Display:")),
- pos=(0, 6), flag=wx.ALIGN_CENTER_VERTICAL)
- display = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices = [_("on surface"),
- _("flat")])
- self.win['vector']['lines']['flat'] = display.GetId()
- display.Bind(wx.EVT_CHOICE, self.OnVectorDisplay)
- gridSizer.Add(item=display, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 7))
- # hight
- label=_("Hight above surface:")),
- pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL,
- span=(1, 2))
- surface = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(250, -1),
- style=wx.CB_SIMPLE | wx.CB_READONLY,
- choices=[])
- surface.Bind(wx.EVT_COMBOBOX, self.OnVectorSurface)
- self.win['vector']['lines']['surface'] = surface.GetId()
- gridSizer.Add(item=surface,
- pos=(1, 2), span=(1, 6),
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- self.CreateControl(panel, dict=self.win['vector']['lines'], name='height', size=300,
- range=(0, 1000),
- bind=(self.OnVectorHeight, self.OnVectorHeightFull, self.OnVectorHeightSpin))
- gridSizer.Add(item=self.FindWindowById(self.win['vector']['lines']['height']['slider']),
- pos=(2, 2), span=(1, 6))
- gridSizer.Add(item=self.FindWindowById(self.win['vector']['lines']['height']['spin']),
- pos=(3, 4),
- border=5)
- # vector points
- self.win['vector']['points'] = {}
- showPoints = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Show vector points"))
- self.win['vector']['points']['show'] = showPoints.GetId()
- showPoints.Bind(wx.EVT_CHECKBOX, self.OnVectorShow)
- pageSizer.Add(item=showPoints, proportion=0,
- label=" %s " % (_("Vector points")))
- # icon size
- label=_("Icon size:")),
- isize = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=1,
- min=1,
- max=1e6)
- isize.SetName('value')
- self.win['vector']['points']['size'] = isize.GetId()
- isize.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
- gridSizer.Add(item=isize, pos=(0, 1),
- # icon width
- label=_("width:")),
- iwidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=1,
- min=1,
- max=1e6)
- iwidth.SetName('value')
- self.win['vector']['points']['width'] = iwidth.GetId()
- iwidth.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
- gridSizer.Add(item=iwidth, pos=(0, 3),
- # icon symbol
- label=_("symbol:")),
- pos=(0, 4), flag=wx.ALIGN_CENTER_VERTICAL)
- isym = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices=UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'marker'], internal=True))
- isym.SetName("selection")
- self.win['vector']['points']['marker'] = isym.GetId()
- isym.Bind(wx.EVT_CHOICE, self.OnVectorPoints)
- gridSizer.Add(item=isym, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 5))
- # icon color
- label=_("color:")),
- icolor = csel.ColourSelect(panel, id=wx.ID_ANY)
- icolor.SetName("color")
- self.win['vector']['points']['color'] = icolor.GetId()
- icolor.Bind(csel.EVT_COLOURSELECT, self.OnVectorPoints)
- gridSizer.Add(item=icolor, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 7))
- # high
- span=(1, 2))
- choices=[])
- self.win['vector']['points']['surface'] = surface.GetId()
- self.CreateControl(panel, dict=self.win['vector']['points'], name='height', size=300,
- range=(0, 1000),
- gridSizer.Add(item=self.FindWindowById(self.win['vector']['points']['height']['slider']),
- gridSizer.Add(item=self.FindWindowById(self.win['vector']['points']['height']['spin']),
- pos=(3, 4),
- border=5)
- def __createVolumePage(self):
- self.page['volume'] = {}
- self.page['volume']['id'] = -1
- self.page['volume']['panel'] = panel.GetId()
- self.win['volume'] = {}
- # draw
- self.win['volume']['draw'] = {}
- # mode
- mode = wx.Choice (parent=panel, id=wx.ID_ANY, size=(150, -1),
- choices = [_("isosurfaces"),
- _("slides")])
- # mode.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
- self.win['volume']['draw']['mode'] = mode.GetId()
- pos=(0, 1))
- # shading
- _("gouraud")])
- self.win['volume']['draw']['shading'] = shade.GetId()
- shade.Bind(wx.EVT_CHOICE, self.OnVolumeIsosurfMode)
- pos=(0, 3))
- resol = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=1,
- min=1,
- max=100)
- resol.SetName("value")
- self.win['volume']['draw']['resolution'] = resol.GetId()
- resol.Bind(wx.EVT_SPINCTRL, self.OnVolumeIsosurfResolution)
- gridSizer.Add(item=resol, pos=(0, 5))
- border=5)
- # manage isosurfaces
- label=" %s " % (_("List of isosurfaces")))
- # list
- isolevel = IsoSurfList(parent=panel, win=self.win['volume'],
- size=(300, 150))
- self.win['volume']['isosurfs'] = isolevel.GetId()
- gridSizer.Add(item=isolevel, pos=(0, 0), span=(4, 1))
- # buttons (add, delete, move up, move down)
- btnAdd = wx.Button(parent=panel, id=wx.ID_ADD)
- self.win['volume']['btnIsosurfAdd'] = btnAdd.GetId()
- btnAdd.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfAdd)
- gridSizer.Add(item=btnAdd,
- pos=(0, 1))
- btnDelete = wx.Button(parent=panel, id=wx.ID_DELETE)
- self.win['volume']['btnIsosurfDelete'] = btnDelete.GetId()
- btnDelete.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfDelete)
- btnDelete.Enable(False)
- gridSizer.Add(item=btnDelete,
- pos=(1, 1))
- btnMoveUp = wx.Button(parent=panel, id=wx.ID_UP)
- self.win['volume']['btnIsosurfMoveUp'] = btnMoveUp.GetId()
- btnMoveUp.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfMoveUp)
- btnMoveUp.Enable(False)
- gridSizer.Add(item=btnMoveUp,
- pos=(2, 1))
- btnMoveDown = wx.Button(parent=panel, id=wx.ID_DOWN)
- self.win['volume']['btnIsosurfMoveDown'] = btnMoveDown.GetId()
- btnMoveDown.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfMoveDown)
- btnMoveDown.Enable(False)
- gridSizer.Add(item=btnMoveDown,
- pos=(3, 1))
- border=5)
- label=" %s " % (_("Isosurface attributes")))
- self.win['volume']['attr'] = {}
- row = 0
- for code, attrb in (('topo', _("Topography level")),
- self.win['volume'][code] = {}
- # label
- if code != 'topo':
- else:
- use = None
- # check for required properties
- self.win['volume'][code]['required'] = False
- else:
- self.win['volume'][code]['required'] = True
- if use and code != 'mask':
- if use:
- self.win['volume'][code]['use'] = use.GetId()
- pos=(row, 1))
- size=(200, -1),
- type="grid3")
- self.win['volume'][code]['map'] = map.GetId() - 1 # FIXME
- pos=(row, 2))
- else:
- map = None
- colour=UserSettings.Get(group='nviz', key='volume',
- value = None
- else:
- size = (200, -1)
- else:
- size = (65, -1)
- value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=size,
- initial=0)
- else:
- if value:
- self.win['volume'][code]['const'] = value.GetId()
- pos=(row, 2))
- else:
- pos=(row, 3))
- else:
- self.win['volume'][code]['const'] = None
- self.SetMapObjUseMap(nvizType='volume',
- row += 1
- border=5)
- def __createSettingsPage(self):
- """Create settings page"""
- text=" %s " % _("Settings"))
- self.win['settings'] = {}
- # general
- self.win['settings']['general'] = {}
- label=" %s " % (_("General")))
- # background color
- label=_("Background color:")),
- colour=UserSettings.Get(group='nviz', key='settings',
- subkey=['general', 'bgcolor']))
- self.win['settings']['general']['bgcolor'] = color.GetId()
- color.Bind(csel.EVT_COLOURSELECT, self.OnBgColor)
- gridSizer.Add(item=color, pos=(0, 1))
- border=5)
- # view
- self.win['settings']['view'] = {}
- label=" %s " % (_("View")))
- # perspective
- self.win['settings']['view']['persp'] = {}
- pvals = UserSettings.Get(group='nviz', key='view', subkey='persp')
- ipvals = UserSettings.Get(group='nviz', key='view', subkey='persp', internal=True)
- label=_("Perspective:")),
- label=_("(value)")),
- pos=(0, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- pval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=pvals['value'],
- min=ipvals['min'],
- max=ipvals['max'])
- self.win['settings']['view']['persp']['value'] = pval.GetId()
- gridSizer.Add(item=pval, pos=(0, 2),
- label=_("(step)")),
- pos=(0, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- pstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=pvals['step'],
- max=ipvals['max']-1)
- self.win['settings']['view']['persp']['step'] = pstep.GetId()
- gridSizer.Add(item=pstep, pos=(0, 4),
- # position
- self.win['settings']['view']['pos'] = {}
- posvals = UserSettings.Get(group='nviz', key='view', subkey='pos')
- label=_("Position:")),
- label=_("(x)")),
- pos=(1, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- px = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=posvals['x'] * 100,
- min=0,
- max=100)
- self.win['settings']['view']['pos']['x'] = px.GetId()
- gridSizer.Add(item=px, pos=(1, 2),
- label="(y)"),
- pos=(1, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- py = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=posvals['y'] * 100,
- min=0,
- max=100)
- self.win['settings']['view']['pos']['y'] = py.GetId()
- gridSizer.Add(item=py, pos=(1, 4),
- # height
- self.win['settings']['view']['height'] = {}
- hvals = UserSettings.Get(group='nviz', key='view', subkey='height')
- label=_("Height")),
- pos=(2, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- hstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=hvals['step'],
- min=1,
- max=1e6)
- self.win['settings']['view']['height']['step'] = hstep.GetId()
- gridSizer.Add(item=hstep, pos=(2, 2),
- # twist
- self.win['settings']['view']['twist'] = {}
- tvals = UserSettings.Get(group='nviz', key='view', subkey='twist')
- itvals = UserSettings.Get(group='nviz', key='view', subkey='twist', internal=True)
- label=_("Twist")),
- pos=(3, 0), flag=wx.ALIGN_CENTER_VERTICAL)
- pos=(3, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- tval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=tvals['value'],
- min=itvals['min'],
- max=itvals['max'])
- self.win['settings']['view']['twist']['value'] = tval.GetId()
- gridSizer.Add(item=tval, pos=(3, 2),
- pos=(3, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- tstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=tvals['step'],
- max=itvals['max']-1)
- self.win['settings']['view']['twist']['step'] = tstep.GetId()
- gridSizer.Add(item=tstep, pos=(3, 4),
- # z-exag
- self.win['settings']['view']['z-exag'] = {}
- zvals = UserSettings.Get(group='nviz', key='view', subkey='z-exag')
- label=_("Z-exag")),
- pos=(4, 0), flag=wx.ALIGN_CENTER_VERTICAL)
- pos=(4, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- zval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=zvals['value'],
- min=-1e6,
- max=1e6)
- self.win['settings']['view']['z-exag']['value'] = zval.GetId()
- gridSizer.Add(item=zval, pos=(4, 2),
- label=_("(step):")),
- pos=(4, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- zstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=zvals['step'],
- min=-1e6,
- max=1e6)
- self.win['settings']['view']['z-exag']['step'] = zstep.GetId()
- gridSizer.Add(item=zstep, pos=(4, 4),
- border=5)
- # surface
- self.win['settings']['surface'] = {}
- label=" %s " % (_("Surface")))
- border=5)
- # vector lines
- self.win['settings']['vector'] = {}
- self.win['settings']['vector']['lines'] = {}
- # show
- row = 0
- label=_("Show lines"))
- self.win['settings']['vector']['lines']['show'] = showLines.GetId()
- showLines.SetValue(UserSettings.Get(group='nviz', key='vector',
- subkey=['lines', 'show']))
- gridSizer.Add(item=showLines, pos=(row, 0))
- border=5)
- # vector points
- self.win['settings']['vector']['points'] = {}
- gridSizer = wx.GridBagSizer(vgap=3, hgap=5)
- # show
- row = 0
- label=_("Show points"))
- showPoints.SetValue(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'show']))
- self.win['settings']['vector']['points']['show'] = showPoints.GetId()
- gridSizer.Add(item=showPoints, pos=(row, 0), span=(1, 8))
- # icon size
- row += 1
- label=_("Size:")),
- initial=100,
- min=1,
- max=1e6)
- self.win['settings']['vector']['points']['size'] = isize.GetId()
- isize.SetValue(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'size']))
- gridSizer.Add(item=isize, pos=(row, 1),
- # icon width
- label=_("Witdh:")),
- pos=(row, 2), flag=wx.ALIGN_CENTER_VERTICAL)
- initial=2,
- min=1,
- max=1e6)
- self.win['settings']['vector']['points']['width'] = isize.GetId()
- iwidth.SetValue(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'width']))
- gridSizer.Add(item=iwidth, pos=(row, 3),
- # icon symbol
- label=_("Marker:")),
- pos=(row, 4), flag=wx.ALIGN_CENTER_VERTICAL)
- self.win['settings']['vector']['points']['marker'] = isym.GetId()
- isym.SetSelection(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'marker']))
- pos=(row, 5))
- # icon color
- pos=(row, 6), flag=wx.ALIGN_CENTER_VERTICAL)
- self.win['settings']['vector']['points']['color'] = icolor.GetId()
- icolor.SetColour(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'color']))
- pos=(row, 7))
- border=5)
- # buttons
- btnDefault = wx.Button(panel, wx.ID_CANCEL, label=_("Default"))
- btnSave = wx.Button(panel, wx.ID_SAVE)
- btnApply = wx.Button(panel, wx.ID_APPLY)
- btnDefault.Bind(wx.EVT_BUTTON, self.OnDefault)
- btnDefault.SetToolTipString(_("Restore default settings"))
- btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
- btnApply.SetToolTipString(_("Apply changes for the current session"))
- btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
- btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
- btnSave.SetDefault()
- btnSizer = wx.StdDialogButtonSizer()
- btnSizer.AddButton(btnDefault)
- btnSizer.AddButton(btnApply)
- btnSizer.AddButton(btnSave)
- btnSizer.Realize()
- pageSizer.Add(item=btnSizer, proportion=1,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT | wx.ALIGN_BOTTOM,
- border=5)
- def CreateControl(self, parent, dict, name, range, bind, sliderHor=True, size=200):
- """Add control (Slider + SpinCtrl)"""
- dict[name] = {}
- if sliderHor:
- style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
- wx.SL_BOTTOM
- sizeW = (size, -1)
- else:
- style = wx.SL_VERTICAL | wx.SL_AUTOTICKS | \
- wx.SL_BOTTOM | wx.SL_INVERSE
- sizeW = (-1, size)
- try:
- val = self.mapWindow.view[name]['value']
- except KeyError:
- val=-1
- slider = wx.Slider(parent=parent, id=wx.ID_ANY,
- value=val,
- minValue=range[0],
- maxValue=range[1],
- style=style,
- size=sizeW)
- slider.SetName('slider')
- slider.Bind(wx.EVT_SCROLL, bind[0])
- slider.Bind(wx.EVT_SCROLL_CHANGED, bind[1])
- dict[name]['slider'] = slider.GetId()
- spin = wx.SpinCtrl(parent=parent, id=wx.ID_ANY, size=(65, -1),
- initial=val,
- min=range[0],
- max=range[1])
- # spin = wx.SpinButton(parent=parent, id=wx.ID_ANY)
- # spin.SetValue (self.mapWindow.view[name]['value'])
- # spin.SetRange(self.mapWindow.view[name]['min'],
- # self.mapWindow.view[name]['max'])
- # no 'changed' event ... (FIXME)
- spin.SetName('spin')
- spin.Bind(wx.EVT_SPINCTRL, bind[2])
- dict[name]['spin'] = spin.GetId()
- def UpdateSettings(self):
- """Update dialog settings"""
- for control in ('height',
- 'persp',
- 'twist',
- 'z-exag'):
- for win in self.win['view'][control].itervalues():
- if control == 'height':
- value = UserSettings.Get(group='nviz', key='view',
- subkey=['height', 'value'], internal=True)
- else:
- value = self.mapWindow.view[control]['value']
- self.FindWindowById(win).SetValue(value)
- self.FindWindowById(self.win['view']['pos']).Draw()
- self.FindWindowById(self.win['view']['pos']).Refresh(False)
- def __GetWindowName(self, dict, id):
- for name in dict.iterkeys():
- if type(dict[name]) is type({}):
- for win in dict[name].itervalues():
- if win == id:
- return name
- else:
- if dict[name] == id:
- return name
- return None
- def OnViewChange(self, event):
- """Change view, render in quick mode"""
- # find control
- winName = self.__GetWindowName(self.win['view'], event.GetId())
- if not winName:
- return
- if winName == 'height':
- view = self.mapWindow.iview # internal
- else:
- view = self.mapWindow.view
- view[winName]['value'] = event.GetInt()
- for win in self.win['view'][winName].itervalues():
- self.FindWindowById(win).SetValue(view[winName]['value'])
- self.mapWindow.update.append('view')
- if winName == 'z-exag':
- self.mapWindow.update.append('z-exag')
- self.mapWindow.render['quick'] = True
- self.mapWindow.Refresh(False)
- def OnViewChanged(self, event):
- """View changed, render in full resolution"""
- self.mapWindow.render['quick'] = False
- def OnViewChangedSpin(self, event):
- # TODO: use step value instead
- self.OnViewChange(event)
- self.OnViewChanged(None)
- def OnResetView(self, event):
- """Reset to default view (view page)"""
- self.mapWindow.ResetView()
- self.UpdateSettings()
- def OnLookAt(self, event):
- """Look at (view page)"""
- sel = event.GetSelection()
- if sel == 0: # top
- self.mapWindow.view['pos']['x'] = 0.5
- self.mapWindow.view['pos']['y'] = 0.5
- elif sel == 1: # north
- self.mapWindow.view['pos']['y'] = 0.0
- elif sel == 2: # south
- self.mapWindow.view['pos']['y'] = 1.0
- elif sel == 3: # east
- self.mapWindow.view['pos']['x'] = 1.0
- elif sel == 4: # west
- self.mapWindow.view['pos']['x'] = 0.0
- elif sel == 5: # north-west
- elif sel == 6: # north-east
- elif sel == 7: # south-east
- elif sel == 8: # south-west
- def OnDefault(self, event):
- """Restore default settings"""
- settings = copy.deepcopy(UserSettings.GetDefaultSettings()['nviz'])
- UserSettings.Set(group='nviz',
- value=settings)
- for subgroup, key in settings.iteritems(): # view, surface, vector...
- if subgroup != 'view':
- continue
- for subkey, value in key.iteritems():
- for subvalue in value.keys():
- win = self.FindWindowById(self.win['settings'][subgroup][subkey][subvalue])
- val = settings[subgroup][subkey][subvalue]
- if subkey == 'pos':
- val = int(val * 100)
- win.SetValue(val)
- event.Skip()
- def OnApply(self, event):
- """Apply button pressed"""
- if self.notebook.GetSelection() == self.page['settings']['id']:
- self.ApplySettings()
- if event:
- event.Skip()
- def ApplySettings(self):
- """Apply Nviz settings for current session"""
- settings = UserSettings.Get(group='nviz')
- try: # TODO
- except:
- # print 'e', subgroup, subkey, subvalue
- continue
- if win.GetName() == "selection":
- value = win.GetSelection()
- elif win.GetName() == "color":
- value = tuple(win.GetColour())
- else:
- value = win.GetValue()
- value = float(value) / 100
- settings[subgroup][subkey][subvalue] = value
- def OnSave(self, event):
- """OK button pressed
- Apply changes, update map and save settings of selected layer
- # apply changes
- self.OnApply(None)
- fileSettings = {}
- UserSettings.ReadSettingsFile(settings=fileSettings)
- fileSettings['nviz'] = UserSettings.Get(group='nviz')
- file = UserSettings.SaveToFile(fileSettings)
- self.lmgr.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
- def OnBgColor(self, event):
- """Background color changed"""
- color = event.GetValue()
- color = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
- self.mapWindow.nvizClass.SetBgColor(str(color))
- if self.parent.autoRender.IsChecked():
- def OnClose(self, event):
- """Close button pressed
- Close dialog
- self.Hide()
- def OnMapObjUse(self, event):
- """Surface attribute -- use -- map/constant"""
- if not self.mapWindow.init:
- return
- wx.Yield()
- # find attribute row
- attrb = self.__GetWindowName(self.win['surface'], event.GetId())
- if not attrb:
- attrb = self.__GetWindowName(self.win['volume'], event.GetId())
- else:
- selection = event.GetSelection()
- if self.win[nvizType][attrb]['required']: # no 'unset'
- selection += 1
- if selection == 0: # unset
- useMap = None
- value = ''
- elif selection == 1: # map
- useMap = True
- value = self.FindWindowById(self.win[nvizType][attrb]['map']).GetValue()
- elif selection == 2: # constant
- useMap = False
- if attrb == 'color':
- value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetColour()
- else:
- value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetValue()
- self.SetMapObjUseMap(nvizType=nvizType,
- attrb=attrb, map=useMap)
- self.mapWindow.update.append('surface:attribute:%s' % attrb)
- data = self.mapWindow.GetSelectedLayer(type='nviz')
- data[nvizType]['attribute'][attrb] = { 'map' : useMap,
- 'value' : str(value),
- self.mapWindow.UpdateLayerProperties()
- def SetMapObjUseMap(self, nvizType, attrb, map=None):
- if attrb in ('topo', 'color', 'shine'):
- incSel = -1 # decrement selection (no 'unset')
- else:
- incSel = 0
- if map is True: # map
- if attrb != 'topo': # changing map topography not allowed
- # not sure why, but here must be disabled both ids, should be fixed!
- self.FindWindowById(self.win[nvizType][attrb]['map'] + 1).Enable(True)
- if self.win[nvizType][attrb]['const']:
- self.FindWindowById(self.win[nvizType][attrb]['const']).Enable(False)
- self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(1 + incSel)
- elif map is False: # const
- self.FindWindowById(self.win[nvizType][attrb]['map'] + 1).Enable(False)
- self.FindWindowById(self.win[nvizType][attrb]['const']).Enable(True)
- self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(2 + incSel)
- else: # unset
- self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(0)
- def OnSurfaceMap(self, event):
- """Set surface attribute"""
- return
- if not attrb:
- return
- selection = self.FindWindowById(self.win['surface'][attrb]['use']).GetSelection()
- if self.win['surface'][attrb]['required']:
- selection += 1
- map = None
- value = ''
- value = self.FindWindowById(self.win['surface'][attrb]['map']).GetValue()
- map = True
- else: # constant
- value = self.FindWindowById(self.win['surface'][attrb]['const']).GetColour()
- # tuple to string
- else:
- value = self.FindWindowById(self.win['surface'][attrb]['const']).GetValue()
- map = False
- if not self.pageChanging:
- data['surface']['attribute'][attrb] = { 'map' : map,
- def OnSurfaceResolution(self, event):
- """Draw resolution changed"""
- self.SetSurfaceResolution()
- if apply and self.parent.autoRender.IsChecked():
- def SetSurfaceResolution(self):
- """Set draw resolution"""
- coarse = self.FindWindowById(self.win['surface']['draw']['res-coarse']).GetValue()
- fine = self.FindWindowById(self.win['surface']['draw']['res-fine']).GetValue()
- self.mapWindow.update.append('surface:draw:resolution')
- data['surface']['draw']['resolution'] = { 'coarse' : coarse,
- 'fine' : fine }
- def SetSurfaceMode(self):
- """Set draw mode
- @param apply allow auto-rendering
- mode = self.FindWindowById(self.win['surface']['draw']['mode']).GetSelection()
- self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(True)
- self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(False)
- self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(False)
- self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(True)
- else: # both
- style = self.FindWindowById(self.win['surface']['draw']['style']).GetSelection()
- shade = self.FindWindowById(self.win['surface']['draw']['shading']).GetSelection()
- value, desc = self.mapWindow.GetSurfaceMode(mode, style, shade)
- return value, desc
- def OnSurfaceMode(self, event):
- """Set draw mode"""
- value, desc = self.SetSurfaceMode()
- self.mapWindow.update.append('surface:draw:mode')
- data['surface']['draw']['mode'] = { 'value' : value,
- 'desc' : desc }
- def OnSurfaceModeAll(self, event):
- """Set draw mode (including wire color) for all loaded surfaces"""
- self.SetSurfaceMode(all=True)
- self.SetSurfaceResolution(all=True)
- color = self.FindWindowById(self.win['surface']['draw']['wire-color']).GetColour()
- self.SetSurfaceWireColor(color, all=True)
- def SetSurfaceWireColor(self, color, all=False, apply=True):
- """Set wire color"""
- value = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
- def OnSurfaceWireColor(self, event):
- self.SetSurfaceWireColor(event.GetValue())
- self.mapWindow.update.append('surface:draw:wire-color')
- data['surface']['draw']['wire-color'] = { 'value' : value }
- def OnSurfaceAxis(self, event):
- """Surface position, axis changed"""
- mapLayer = self.mapWindow.GetSelectedLayer()
- id = data['object']['id']
- axis = self.FindWindowById(self.win['surface']['position']['axis']).GetSelection()
- win = self.FindWindowById(self.win['surface']['position']['pos'])
- x, y, z = self.mapWindow.nvizClass.GetSurfacePosition(id)
- if axis == 0: # x
- win.SetRange(-1e4, 1e4)
- win.SetValue(x)
- elif axis == 1: # y
- win.SetValue(y)
- else: # z
- win.SetRange(-1e3, 1e3)
- win.SetValue(z)
- def OnSurfacePosition(self, event):
- """Surface position"""
- value = event.GetInt()
- if axis == 0: # x
- x = value
- y = value
- else: # z
- z = value
- self.mapWindow.update.append('surface:position')
- data['surface']['position']['x'] = x
- data['surface']['position']['y'] = y
- data['surface']['position']['z'] = z
- def UpdateVectorShow(self, vecType, enabled):
- """Enable/disable lines/points widgets
- if vecType != 'lines' and vecType != 'points':
- return False
- for win in self.win['vector'][vecType].keys():
- if win == 'show':
- continue
- if type(self.win['vector'][vecType][win]) == type({}):
- for swin in self.win['vector'][vecType][win].keys():
- if enabled:
- self.FindWindowById(self.win['vector'][vecType][win][swin]).Enable(True)
- else:
- self.FindWindowById(self.win['vector'][vecType][win][swin]).Enable(False)
- else:
- if enabled:
- self.FindWindowById(self.win['vector'][vecType][win]).Enable(True)
- else:
- self.FindWindowById(self.win['vector'][vecType][win]).Enable(False)
- return True
- def OnVectorShow(self, event):
- """Show vector lines/points"""
- winId = event.GetId()
- if winId == self.win['vector']['lines']['show']:
- vecType = 'lines'
- else: # points
- vecType = 'points'
- checked = event.IsChecked()
- item = self.mapWindow.GetSelectedLayer(type='item')
- data = self.mapWindow.GetSelectedLayer(type='nviz')['vector']
- if checked:
- self.mapWindow.LoadVector(item, (vecType,))
- else:
- self.mapWindow.UnloadVector(item, (vecType,))
- self.UpdateVectorShow(vecType, checked)
- if checked:
- try:
- id = data[vecType]['object']['id']
- except KeyError:
- id = -1
- if id > 0:
- self.mapWindow.SetLayerData(item, id, vecType)
- self.mapWindow.UpdateLayerProperties(item)
- event.Skip()
- def OnVectorDisplay(self, event):
- """Display vector lines on surface/flat"""
- if event.GetSelection() == 0: # surface
- if len(self.mapWindow.layers['raster']['name']) < 1:
- event.Veto()
- return
- self.FindWindowById(self.win['vector']['lines']['surface']).Enable(True)
- # set first found surface
- data['vector']['lines']['mode']['surface'] = self.mapWindow.layers['raster']['name'][0]
- self.FindWindowById(self.win['vector']['lines']['surface']).SetStringSelection( \
- self.mapWindow.layers['raster']['name'][0])
- else: # flat
- self.FindWindowById(self.win['vector']['lines']['surface']).Enable(False)
- self.OnVectorLines(event)
- event.Skip()
- def OnVectorLines(self, event):
- """Set vector lines mode, apply changes if auto-rendering is enabled"""
- width = self.FindWindowById(self.win['vector']['lines']['width']).GetValue()
- color = self.FindWindowById(self.win['vector']['lines']['color']).GetColour()
- mode = {}
- if self.FindWindowById(self.win['vector']['lines']['flat']).GetSelection() == 0:
- mode['type'] = 'surface'
- mode['surface'] = self.FindWindowById(self.win['vector']['lines']['surface']).GetValue()
- self.mapWindow.update.append('vector:lines:surface')
- else:
- mode['type'] = 'flat'
- self.mapWindow.update.append('vector:lines:width')
- self.mapWindow.update.append('vector:lines:color')
- self.mapWindow.update.append('vector:lines:mode')
- data['vector']['lines']['width'] = width
- data['vector']['lines']['color'] = color
- data['vector']['lines']['mode'] = mode
- def OnVectorHeight(self, event):
- id = event.GetId()
- if id == self.win['vector']['lines']['height']['spin'] or \
- id == self.win['vector']['lines']['height']['slider']:
- vtype = 'lines'
- else:
- vtype = 'points'
- if type(event) == type(wx.ScrollEvent()):
- # slider
- win = self.FindWindowById(self.win['vector'][vtype]['height']['spin'])
- else:
- # spin
- win = self.FindWindowById(self.win['vector'][vtype]['height']['slider'])
- win.SetValue(value)
- self.mapWindow.update.append('vector:%s:height' % vtype)
- data['vector'][vtype]['height'] = value
- self.mapWindow.render['v' + vtype] = True
- def OnVectorHeightFull(self, event):
- """Vector height changed, render in full resolution"""
- vtype = 'lines'
- else:
- vtype = 'points'
- self.mapWindow.render['v' + vtype] = False
- def OnVectorHeightSpin(self, event):
- self.OnVectorHeight(event)
- self.OnVectorHeightFull(event)
- def OnVectorSurface(self, event):
- """Reference surface for vector map (lines/points)"""
- if id == self.win['vector']['lines']['surface']:
- vtype = 'lines'
- else:
- vtype = 'points'
- self.mapWindow.update.append('vector:%s:surface' % vtype)
- data['vector'][vtype]['mode']['surface'] = event.GetValue()
- def OnVectorPoints(self, event):
- """Set vector points mode, apply changes if auto-rendering is enabled"""
- size = self.FindWindowById(self.win['vector']['points']['size']).GetValue()
- width = self.FindWindowById(self.win['vector']['points']['width']).GetValue()
- color = self.FindWindowById(self.win['vector']['points']['color']).GetColour()
- marker = self.FindWindowById(self.win['vector']['points']['marker']).GetSelection()
- self.mapWindow.update.append('vector:points:size')
- self.mapWindow.update.append('vector:points:width')
- self.mapWindow.update.append('vector:points:color')
- self.mapWindow.update.append('vector:points:marker')
- data = self.mapWindow.GetSelectedLayer(type='nviz')['vector']['points']
- data['size'] = size
- data['width'] = width
- data['marker'] = marker
- def UpdateIsosurfButtons(self, list):
- """Enable/disable buttons 'add', 'delete',
- 'move up', 'move down'"""
- nitems = list.GetCount()
- add = self.parent.FindWindowById(self.win['volume']['btnIsosurfAdd'])
- delete = self.parent.FindWindowById(self.win['volume']['btnIsosurfDelete'])
- moveDown = self.parent.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
- moveUp = self.parent.FindWindowById(self.win['volume']['btnIsosurfMoveUp'])
- if nitems >= wxnviz.MAX_ISOSURFS:
- # disable add button on max
- add.Enable(False)
- else:
- add.Enable(True)
- if nitems < 1:
- # disable 'delete' if only one item in the lis
- delete.Enable(False)
- else:
- delete.Enable(True)
- if list.GetSelection() >= nitems - 1:
- # disable 'move-down' if last
- moveDown.Enable(False)
- else:
- moveDown.Enable(True)
- if list.GetSelection() < 1:
- # disable 'move-up' if first
- moveUp.Enable(False)
- else:
- moveUp.Enable(True)
- def OnVolumeIsosurfMode(self, event):
- """Set isosurface draw mode"""
- layer = self.mapWindow.GetSelectedLayer()
- data = self.mapWindow.GetSelectedLayer(type='nviz')['volume']
- mode = 0
- value = event.GetSelection()
- if value == 0:
- mode |= wxnviz.DM_FLAT
- else:
- mode |= wxnviz.DM_GOURAUD
- self.mapWindow.nvizClass.SetIsosurfaceMode(id, mode)
- def OnVolumeIsosurfResolution(self, event):
- """Set isosurface draw resolution"""
- self.mapWindow.nvizClass.SetIsosurfaceRes(id, event.GetInt())
- def OnVolumeIsosurfAdd(self, event):
- """Add new isosurface to the list"""
- list = self.FindWindowById(self.win['volume']['isosurfs'])
- level = self.FindWindowById(self.win['volume']['topo']['const']).GetValue()
- sel = list.GetSelection()
- if sel < 0 or sel >= list.GetCount() - 1:
- item = list.Append(item="%s %s" % (_("Level"), str(level)))
- else:
- list.Insert(item="%s %s" % (_("Level"), str(level)),
- pos=sel+1) # append
- item = sel + 1
- print item
- list.Check(item)
- list.SetSelection(item)
- # collect properties
- isosurfData = {}
- isosurfData[attrb] = {}
- win = self.FindWindowById(self.win['volume'][attrb]['const'])
- isosurfData[attrb]['value'] = win.GetValue()
- else:
- uwin = self.FindWindowById(self.win['volume'][attrb]['use'])
- sel = uwin.GetSelection()
- if self.win['volume'][attrb]['required']:
- sel += 1
- if sel == 0: # unset
- continue
- if sel == 1: # map
- isosurfData[attrb]['map'] = True
- vwin = self.FindWindowById(self.win['volume'][attrb]['map'])
- else: # const
- isosurfData[attrb]['map'] = False
- vwin = self.FindWindowById(self.win['volume'][attrb]['const'])
- isosurfData[attrb]['value'] = vwin.GetValue()
- data['isosurface'].insert(item, isosurfData)
- print '#', data
- # add isosurface
- self.mapWindow.nvizClass.AddIsosurface(id, level)
- self.mapWindow.nvizClass.SetIsosurfaceColor(id, 0, True, str(layer.name))
- # update buttons
- self.UpdateIsosurfButtons(list)
- event.Skip()
- def OnVolumeIsosurfDelete(self, event):
- """Remove isosurface from list"""
- # remove item from list
- isosurfId = list.GetSelection()
- list.Delete(isosurfId)
- # select last item
- if list.GetCount() > 0:
- list.SetSelection(list.GetCount()-1)
- # delete isosurface
- del data['isosurface'][isosurfId]
- print '#', data
- self.mapWindow.nvizClass.DeleteIsosurface(id, isosurfId)
- # update buttons
- event.Skip()
- def OnVolumeIsosurfMoveUp(self, event):
- """Move isosurface up in the list"""
- if sel < 1:
- return # this should not happen
- # move item up
- text = list.GetStringSelection()
- list.Insert(item=text, pos=sel-1)
- list.Check(sel-1)
- list.SetSelection(sel-1)
- list.Delete(sel+1)
- data['isosurface'].insert(sel-1, data['isosurface'][sel])
- del data['isosurface'][sel+1]
- self.mapWindow.nvizClass.MoveIsosurface(id, sel, True)
- print '#', data
- # update buttons
- event.Skip()
- def OnVolumeIsosurfMoveDown(self, event):
- """Move isosurface dowm in the list"""
- if sel >= list.GetCount() - 1:
- # move item up
- list.Insert(item=text, pos=sel+2)
- list.Check(sel+2)
- list.SetSelection(sel+2)
- list.Delete(sel)
- data['isosurface'].insert(sel+2, data['isosurface'][sel])
- del data['isosurface'][sel]
- self.mapWindow.nvizClass.MoveIsosurface(id, sel, False)
- print '#', data
- # update buttons
- event.Skip()
- def UpdatePage(self, pageId):
- """Update dialog (selected page)"""
- self.pageChanging = True
- if pageId == 'view':
- max = self.mapWindow.view['z-exag']['value'] * 10
- hmin = self.mapWindow.iview['height']['min']
- hmax = self.mapWindow.iview['height']['max']
- for control in ('spin', 'slider'):
- self.FindWindowById(self.win['view']['z-exag'][control]).SetRange(1,
- max)
- self.FindWindowById(self.win['view']['height'][control]).SetRange(hmin,
- hmax)
- elif pageId == 'surface':
- if self.notebook.GetSelection() != self.page['surface']['id']:
- for page in ('vector', 'volume'):
- if self.page[page]['id'] > -1:
- self.notebook.RemovePage(self.page[page]['id'])
- self.page[page]['id'] = -1
- self.page['surface']['id'] = 1
- self.page['settings']['id'] = 2
- panel = wx.FindWindowById(self.page['surface']['panel'])
- self.notebook.InsertPage(n=self.page['surface']['id'],
- page=panel,
- text=" %s " % _("Layer properties"),
- select=True)
- self.UpdateSurfacePage(layer, data['surface'])
- elif pageId == 'vector':
- if self.notebook.GetSelection() != self.page['vector']['id']:
- for page in ('surface', 'volume'):
- self.page['vector']['id'] = 1
- panel = wx.FindWindowById(self.page['vector']['panel'])
- self.notebook.InsertPage(n=self.page['vector']['id'],
- page=panel,
- select=True)
- self.UpdateVectorPage(layer, data['vector'])
- elif pageId == 'volume':
- if self.notebook.GetSelection() != self.page['volume']['id']:
- for page in ('surface', 'vector'):
- self.page['volume']['id'] = 1
- panel = wx.FindWindowById(self.page['volume']['panel'])
- self.notebook.InsertPage(n=self.page['volume']['id'],
- page=panel,
- select=True)
- self.UpdateVolumePage(layer, data['volume'])
- def UpdateSurfacePage(self, layer, data):
- # attributes
- for attr in ('topo', 'color'): # required
- if layer and layer.type == 'raster':
- self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
- else:
- self.FindWindowById(self.win['surface'][attr]['map']).SetValue('')
- attrb=attr, map=True) # -> map
- if data['attribute'].has_key('color'):
- value = data['attribute']['color']['value']
- if data['attribute']['color']['map']:
- self.FindWindowById(self.win['surface']['color']['map']).SetValue(value)
- else: # constant
- color = map(int, value.split(':'))
- self.FindWindowById(self.win['surface']['color']['const']).SetColour(color)
- attrb=attr, map=data['attribute']['color']['map'])
- attrb='shine', map=data['attribute']['shine']['map'])
- value = data['attribute']['shine']['value']
- if data['attribute']['shine']['map']:
- self.FindWindowById(self.win['surface']['shine']['map']).SetValue(value)
- else:
- self.FindWindowById(self.win['surface']['shine']['const']).SetValue(value)
- # draw
- for control, dict in data['draw'].iteritems():
- if control == 'all': # skip 'all' property
- continue
- if control == 'resolution':
- self.FindWindowById(self.win['surface']['draw']['res-coarse']).SetValue(dict['coarse'])
- self.FindWindowById(self.win['surface']['draw']['res-fine']).SetValue(dict['fine'])
- continue
- if control == 'mode':
- if dict['desc']['mode'] == 'coarse':
- self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(0)
- elif dict['desc']['mode'] == 'fine':
- self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(1)
- else: # both
- self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(2)
- if dict['desc']['style'] == 'wire':
- self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(0)
- else: # surface
- self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(1)
- if dict['desc']['shading'] == 'flat':
- self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(0)
- else: # gouraud
- self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(1)
- continue
- value = dict['value']
- win = self.FindWindowById(self.win['surface']['draw'][control])
- name = win.GetName()
- if name == "selection":
- win.SetSelection(value)
- elif name == "colour":
- win.SetColour(color)
- else:
- # enable/disable res widget + set draw mode
- self.SetSurfaceMode()
- self.SetSurfaceWireColor(color.GetColour())
- def UpdateVectorPage(self, layer, data):
- vInfo = gcmd.Command(['v.info',
- 'map=%s' % layer.name])
- npoints = nprimitives = 0
- for line in vInfo.ReadStdOutput():
- if 'Map is 3D' in line:
- mapIs3D = int(line.replace('|', '').split(':')[1].strip())
- elif 'Number of points' in line:
- npoints = int(line.replace('|', '').split(':')[1].strip().split(' ')[0])
- nprimitives = npoints
- elif 'Number of lines' in line:
- nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0])
- elif 'Number of boundaries' in line:
- nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0]) # boundaries
- nprimitives += int(line.replace('|', '').split(':')[2].strip()) # faces
- elif 'Number of centroids' in line:
- nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0]) # centroids
- nprimitives += int(line.replace('|', '').split(':')[2].strip()) # kernels
- if mapIs3D:
- desc = _("Vector map <%s> is 3D") % layer.name
- enable = False
- else:
- desc = _("Vector map <%s> is 2D") % layer.name
- enable = True
- desc += " - " + _("%d primitives (%d points)") % (nprimitives, npoints)
- self.FindWindowById(self.win['vector']['lines']['flat']).Enable(enable)
- for v in ('lines', 'points'):
- self.FindWindowById(self.win['vector'][v]['surface']).Enable(enable)
- self.FindWindowById(self.win['vector'][v]['height']['slider']).Enable(enable)
- self.FindWindowById(self.win['vector'][v]['height']['spin']).Enable(enable)
- self.FindWindowById(self.win['vector']['desc']).SetLabel(desc)
- # lines
- showLines = self.FindWindowById(self.win['vector']['lines']['show'])
- if data['lines'].has_key('object'):
- showLines.SetValue(True)
- else:
- showLines.SetValue(False)
- if nprimitives - npoints > 0:
- showLines.Enable(True)
- else:
- showLines.Enable(False)
- self.UpdateVectorShow('lines',
- showLines.IsChecked())
- width.SetValue(data['lines']['width'])
- color.SetValue(map(int, data['lines']['color'].split(':')))
- for vtype in ('lines', 'points'):
- if vtype == 'lines':
- display = self.FindWindowById(self.win['vector']['lines']['flat'])
- if data[vtype]['mode']['type'] == 'flat':
- display.SetSelection(1)
- else:
- display.SetSelection(0)
- if data[vtype]['mode']['type'] == 'surface' and \
- len(self.mapWindow.layers['raster']['name']) > 0:
- surface = self.FindWindowById(self.win['vector'][vtype]['surface'])
- surface.SetItems(self.mapWindow.layers['raster']['name'])
- surface.SetStringSelection(data[vtype]['mode']['surface'])
- for type in ('slider', 'spin'):
- win = self.FindWindowById(self.win['vector']['lines']['height'][type])
- win.SetValue(data['lines']['height'])
- # points
- showPoints = self.FindWindowById(self.win['vector']['points']['show'])
- if data['points'].has_key('object'):
- showPoints.SetValue(True)
- else:
- showPoints.SetValue(False)
- if npoints > 0:
- showPoints.Enable(True)
- else:
- showPoints.Enable(False)
- self.UpdateVectorShow('points',
- showPoints.IsChecked())
- # size, width, marker, color
- win = self.FindWindowById(self.win['vector']['points'][prop])
- if name == 'selection':
- win.SetSelection(data['points'][prop])
- elif name == 'color':
- color = map(int, data['points'][prop].split(':'))
- win.SetValue(color)
- else:
- win.SetValue(data['points'][prop])
- # height
- win = self.FindWindowById(self.win['vector']['points']['height'][type])
- win.SetValue(data['points']['height'])
- def UpdateVolumePage(self, layer, data):
- """Update volume layer properties page"""
- # draw
- continue
- win = self.FindWindowById(self.win['volume']['draw'][control])
- win.SetSelection(dict['value'])
- else:
- win.SetValue(dict['value'])
- #self.SetIsosurfaceMode()
- #self.SetIsosurfaceResolution()
- # isosurface attributes
- for attr in ('color', ): # required
- if layer and layer.type == '3d-raster':
- self.FindWindowById(self.win['volume'][attr]['map']).SetValue(layer.name)
- else:
- self.FindWindowById(self.win['volume'][attr]['map']).SetValue('')
- self.FindWindowById(self.win['volume']['color']['map']).SetValue(value)
- else: # constant
- self.FindWindowById(self.win['volume']['color']['const']).SetColour(color)
- self.FindWindowById(self.win['volume']['shine']['map']).SetValue(value)
- else:
- self.FindWindowById(self.win['volume']['shine']['const']).SetValue(value)
- def SetPage(self, name):
- """Get named page"""
- self.notebook.SetSelection(self.page[name]['id'])
-class ViewPositionWindow(wx.Window):
- """Position control window (for NvizToolWindow)"""
- def __init__(self, parent, id, mapwindow,
- size=wx.DefaultSize):
- self.mapWindow = mapwindow
- wx.Window.__init__(self, parent, id, pos, size)
- self.SetBackgroundColour("WHITE")
- self.pdc = wx.PseudoDC()
- self.pdc.SetBrush(wx.Brush(colour='dark green', style=wx.SOLID))
- self.pdc.SetPen(wx.Pen(colour='dark green', width=2, style=wx.SOLID))
- self.Draw()
- self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x: None)
- self.Bind(wx.EVT_PAINT, self.OnPaint)
- # self.Bind(wx.EVT_MOTION, self.OnMouse)
- self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouse)
- def Draw(self, pos=None):
- w, h = self.GetClientSize()
- if pos is None:
- x = self.mapWindow.view['pos']['x']
- y = self.mapWindow.view['pos']['y']
- x = x * w
- y = y * h
- else:
- x, y = pos
- self.pdc.Clear()
- self.pdc.BeginDrawing()
- self.pdc.DrawLine(w / 2, h / 2, x, y)
- self.pdc.DrawCircle(x, y, 5)
- self.pdc.EndDrawing()
- def OnPaint(self, event):
- dc = wx.BufferedPaintDC(self)
- dc.SetBackground(wx.Brush("White"))
- dc.Clear()
- self.PrepareDC(dc)
- self.pdc.DrawToDC(dc)
- def OnMouse(self, event):
- if event.LeftIsDown():
- x, y = event.GetPosition()
- self.Draw(pos=(x, y))
- self.Refresh(False)
- x = float(x) / w
- y = float(y) / h
- if x >= 0 and x <= 1.0:
- self.mapWindow.view['pos']['x'] = x
- if y >= 0 and y <= 1.0:
- self.mapWindow.view['pos']['y'] = y
- self.mapWindow.Refresh(eraseBackground=False)
- elif event.LeftUp():
- event.Skip()
-class IsoSurfList(wx.CheckListBox):
- """List of loaded volume isosurfaces (volume properties page)"""
- def __init__(self, parent, win, id=wx.ID_ANY, size=wx.DefaultSize):
- self.parent = parent
- self.win = win
- wx.CheckListBox.__init__(self, parent, id, size=size)
- self.Bind(wx.EVT_CHECKLISTBOX, self.OnCheck)
- self.Bind(wx.EVT_LISTBOX, self.OnSelect)
- def OnCheck(self, event):
- """Item checked/unchecked -> load/delete surface"""
- print event.IsChecked()
- def OnSelect(self, event):
- """Item selected"""
- winUp = self.parent.FindWindowById(self.win['btnIsosurfMoveUp'])
- winDown = self.parent.FindWindowById(self.win['btnIsosurfMoveDown'])
- winUp.Enable(False)
- if not winDown.IsEnabled():
- winDown.Enable()
- elif selection == self.GetCount() - 1:
- winDown.Enable(False)
- if not winUp.IsEnabled():
- winUp.Enable()
- else:
- winDown.Enable()
- winUp.Enable()
+GLWindow = nviz_mapdisp.GLWindow
+NvizToolWindow = nviz_tools.NvizToolWindow
Added: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -0,0 +1,1201 @@
+ at package nviz_mapdisp.py (core)
+ at brief Nviz extension for wxGUI
+This module enables to visualize data in 2.5/3D space.
+Map Display supports standard 2D mode ('mapdisp' module) and
+the 2.5/3D mode ('nviz_mapdisp' module).
+List of classes:
+ - GLWindow
+(C) 2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+import os
+import sys
+import time
+import copy
+from threading import Thread
+import wx
+import wx.lib.scrolledpanel as scrolled
+from wx.lib.newevent import NewEvent
+from wx import glcanvas
+import gcmd
+import globalvar
+from debug import Debug as Debug
+from preferences import globalSettings as UserSettings
+from mapdisp import MapWindow as MapWindow
+sys.path.append(os.path.join(globalvar.ETCWXDIR, "nviz"))
+import grass6_wxnviz as wxnviz
+wxUpdateProperties, EVT_UPDATE_PROP = NewEvent()
+class GLWindow(MapWindow, glcanvas.GLCanvas):
+ """OpenGL canvas for Map Display Window"""
+ def __init__(self, parent, id,
+ pos=wx.DefaultPosition,
+ size=wx.DefaultSize,
+ style=wx.NO_FULL_REPAINT_ON_RESIZE,
+ Map=None, tree=None, gismgr=None):
+ self.parent = parent # MapFrame
+ self.Map = Map
+ self.tree = tree
+ self.gismgr = gismgr
+ glcanvas.GLCanvas.__init__(self, parent, id)
+ MapWindow.__init__(self, parent, id, pos, size, style,
+ Map, tree, gismgr)
+ self.update = []
+ self.init = False
+ # render mode
+ self.render = { 'quick' : False,
+ # do not render vector lines in quick mode
+ 'vlines' : False,
+ 'vpoints' : False }
+ # list of loaded map layers
+ self.layers = {}
+ for type in ('raster', 'vlines', 'vpoints', '3d-raster'):
+ self.layers[type] = {}
+ self.layers[type]['name'] = []
+ self.layers[type]['id'] = []
+ # create nviz instance
+ self.nvizClass = wxnviz.Nviz(sys.stderr)
+ # set current display
+ self.nvizClass.SetDisplay(self)
+ # initialize mouse position
+ self.lastX = self.x = 30
+ self.lastY = self.y = 30
+ # default values
+ self.view = copy.deepcopy(UserSettings.Get(group='nviz', key='view')) # copy
+ self.iview = UserSettings.Get(group='nviz', key='view', internal=True)
+ self.size = None
+ self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
+ self.Bind(wx.EVT_LEFT_UP, self.OnLeftUp)
+ self.Bind(wx.EVT_MOTION, self.OnMouseAction)
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouseAction)
+ self.Bind(EVT_UPDATE_PROP, self.UpdateLayerProperties)
+ def OnEraseBackground(self, event):
+ pass # do nothing, to avoid flashing on MSW
+ def OnSize(self, event):
+ self.size = self.parent.GetClientSize()
+ if self.GetContext():
+ Debug.msg(3, "GLCanvas.OnPaint(): w=%d, h=%d" % \
+ (self.size.width, self.size.height))
+ self.SetCurrent()
+ self.nvizClass.ResizeWindow(self.size.width,
+ self.size.height)
+ event.Skip()
+ def OnPaint(self, event):
+ Debug.msg(3, "GLCanvas.OnPaint()")
+ dc = wx.PaintDC(self)
+ self.SetCurrent()
+ if not self.init:
+ self.nvizClass.InitView()
+ self.LoadDataLayers()
+ self.ResetView()
+ if hasattr(self.parent, "nvizToolWin"):
+ self.parent.nvizToolWin.UpdatePage('view')
+ layer = self.GetSelectedLayer()
+ if layer:
+ if layer.type == 'raster':
+ self.parent.nvizToolWin.UpdatePage('surface')
+ elif layer.type == 'vector':
+ self.parent.nvizToolWin.UpdatePage('vector')
+ self.parent.nvizToolWin.UpdateSettings()
+ # update widgets
+ win = self.parent.nvizToolWin.FindWindowById( \
+ self.parent.nvizToolWin.win['vector']['lines']['surface'])
+ win.SetItems(self.layers['raster']['name'])
+ self.init = True
+ self.UpdateMap()
+ def OnMouseAction(self, event):
+ # change position
+ if event.Dragging() and event.LeftIsDown():
+ self.lastX = self.lastY = self.x = self.y
+ self.x, self.y = event.GetPosition()
+ self.Refresh(False)
+ # change perspective with mouse wheel
+ wheel = event.GetWheelRotation()
+ if wheel != 0:
+ current = event.GetPositionTuple()[:]
+ Debug.msg (5, "GLWindow.OnMouseMotion(): wheel=%d" % wheel)
+ prev_value = self.view['persp']['value']
+ if wheel > 0:
+ value = -1 * self.view['persp']['step']
+ else:
+ value = self.view['persp']['step']
+ self.view['persp']['value'] += value
+ if self.view['persp']['value'] < 1:
+ self.view['persp']['value'] = 1
+ elif self.view['persp']['value'] > 100:
+ self.view['persp']['value'] = 100
+ if prev_value != self.view['persp']['value']:
+ self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
+ self.iview['height']['value'],
+ self.view['persp']['value'],
+ self.view['twist']['value'])
+ # redraw map
+ self.OnPaint(None)
+ # update statusbar
+ ### self.parent.StatusbarUpdate()
+ def OnLeftDown(self, event):
+ self.CaptureMouse()
+ self.x, self.y = self.lastX, self.lastY = event.GetPosition()
+ def OnLeftUp(self, event):
+ self.ReleaseMouse()
+ def UpdateMap(self, render=True):
+ Updates the canvas anytime there is a change to the
+ underlaying images or to the geometry of the canvas.
+ @param render re-render map composition
+ start = time.clock()
+ self.resize = False
+ # if self.size is None:
+ # self.size = self.GetClientSize()
+ # w, h = self.size
+ # w = float(max(w, 1.0))
+ # h = float(max(h, 1.0))
+ # d = float(min(w, h))
+ # xScale = d / w
+ # yScale = d / h
+ # print w, h, d, xScale, yScale
+ # print self.y, self.lastY, self.x, self.lastX
+ # print (self.y - self.lastY) * yScale, (self.x - self.lastX) * xScale
+ # print self.x * xScale
+ #glRotatef((self.y - self.lastY) * yScale, 1.0, 0.0, 0.0);
+ #glRotatef((self.x - self.lastX) * xScale, 0.0, 1.0, 0.0);
+ if self.render['quick'] is False:
+ self.parent.onRenderGauge.Show()
+ self.parent.onRenderGauge.SetRange(2)
+ self.parent.onRenderGauge.SetValue(0)
+ if 'view' in self.update:
+ if 'z-exag' in self.update:
+ self.nvizClass.SetZExag(self.view['z-exag']['value'])
+ self.update.remove('z-exag')
+ self.update.remove('view')
+ self.parent.onRenderGauge.SetValue(1)
+ wx.Yield()
+ self.nvizClass.Draw(False, -1)
+ elif self.render['quick'] is True:
+ # quick
+ mode = wxnviz.DRAW_QUICK_SURFACE | wxnviz.DRAW_QUICK_VOLUME
+ if self.render['vlines']:
+ mode |= wxnviz.DRAW_QUICK_VLINES
+ if self.render['vpoints']:
+ mode |= wxnviz.DRAW_QUICK_VPOINTS
+ self.nvizClass.Draw(True, mode)
+ else: # None -> reuse last rendered image
+ pass # TODO
+ self.SwapBuffers()
+ stop = time.clock()
+ self.parent.onRenderGauge.SetValue(2)
+ # hide process bar
+ self.parent.onRenderGauge.Hide()
+ # self.parent.StatusbarUpdate()
+ Debug.msg(3, "GLWindow.UpdateMap(): quick=%d, -> time=%g" % \
+ (self.render['quick'], (stop-start)))
+ # print stop-start
+ def EraseMap(self):
+ Erase the canvas
+ self.nvizClass.EraseMap()
+ def IsLoaded(self, item):
+ """Check if layer (item) is already loaded
+ @param item layer item
+ layer = self.tree.GetPyData(item)[0]['maplayer']
+ data = self.tree.GetPyData(item)[0]['nviz']
+ if not data:
+ return 0
+ if not data['surface'].has_key('object'):
+ return 0
+ if not data['vlines'].has_key('object') and \
+ not data['points'].has_key('object'):
+ return 0
+ return 1
+ def LoadDataLayers(self):
+ """Load raster/vector from current layer tree
+ @todo volumes
+ listOfItems = []
+ # load raster & vector maps
+ item = self.tree.GetFirstChild(self.tree.root)[0]
+ while item and item.IsOk():
+ type = self.tree.GetPyData(item)[0]['type']
+ if not item.IsChecked() or \
+ type not in ('raster', 'vector', '3d-raster'):
+ item = self.tree.GetNextSibling(item)
+ continue
+ listOfItems.append(item)
+ start = time.time()
+ while(len(listOfItems) > 0):
+ item = listOfItems.pop()
+ try:
+ if type == 'raster':
+ self.LoadRaster(item)
+ elif type == '3d-raster':
+ self.LoadRaster3d(item)
+ except gcmd.NvizError, e:
+ print >> sys.stderr, "Nviz:" + e.message
+ try:
+ if type == 'vector':
+ vecType = []
+ if data and data.has_key('vector'):
+ for v in ('lines', 'points'):
+ if data['vector'][v]:
+ vecType.append(v)
+ self.LoadVector(item, vecType)
+ stop = time.time()
+ Debug.msg(3, "GLWindow.LoadDataLayers(): time=%f" % (stop-start))
+ # print stop - start
+ def SetLayerData(self, item, id, nvizType):
+ """Set map object properties
+ @param id nviz layer id (or -1)
+ @param nvizType nviz data type (surface, points, vector)
+ type = self.tree.GetPyData(item)[0]['maplayer'].type
+ # reference to original layer properties (can be None)
+ if data is None:
+ # init data structure
+ self.tree.GetPyData(item)[0]['nviz'] = {}
+ data[nvizType] = {}
+ for sec in ('attribute', 'draw', 'mask', 'position'):
+ data[nvizType][sec] = {}
+ # reset to default properties
+ self.SetSurfaceDefaultProp(data[nvizType])
+ elif type == 'vector':
+ data['vector'] = {}
+ for sec in ('lines', 'points'):
+ data['vector'][sec] = {}
+ # reset to default properties (lines/points)
+ self.SetVectorDefaultProp(data['vector'])
+ for sec in ('attribute', 'draw', 'position'):
+ for sec in ('isosurface', 'slice'):
+ data[nvizType][sec] = []
+ self.SetVolumeDefaultProp(data[nvizType])
+ else:
+ # check data
+ if not data['vector']['lines']:
+ self.SetVectorLinesDefaultProp(data['vector']['lines'])
+ if not data['vector']['points']:
+ self.SetVectorPointsDefaultProp(data['vector']['points'])
+ # set updates
+ for sec in data.keys():
+ for sec1 in data[sec].keys():
+ for sec2 in data[sec][sec1].keys():
+ if sec2 not in ('object'):
+ event = wxUpdateProperties(type='mapobj',
+ data={'nvizType' : sec,
+ 'key' : sec1,
+ 'subkey' : sec2})
+ # set id
+ if id > 0:
+ if type in ('raster', '3d-raster'):
+ data[nvizType]['object'] = { 'id' : id,
+ 'init' : False }
+ data['vector'][nvizType]['object'] = { 'id' : id,
+ 'init' : False }
+ return data
+ def LoadRaster(self, item):
+ """Load 2d raster map and set surface attributes
+ @param layer item
+ return self._loadRaster(item)
+ def LoadRaster3d(self, item):
+ """Load 3d raster map and set surface attributes
+ @param layer item
+ def _loadRaster(self, item):
+ """Load 2d/3d raster map and set its attributes
+ @param layer item
+ if layer.type not in ('raster', '3d-raster'):
+ return
+ id = self.nvizClass.LoadSurface(str(layer.name), None, None)
+ nvizType = 'surface'
+ errorMsg = _("Loading raster map")
+ elif layer.type == '3d-raster':
+ id = self.nvizClass.LoadVolume(str(layer.name), None, None)
+ nvizType = 'volume'
+ errorMsg = _("Loading 3d raster map")
+ else:
+ id = -1
+ if id < 0:
+ if layer.type in ('raster', '3d-raster'):
+ print >> sys.stderr, "Nviz:" + "%s <%s> %s" % (errorMsg, layer.name, _("failed"))
+ else:
+ print >> sys.stderr, "Nviz:" + _("Unsupported layer type '%s'") % layer.type
+ self.layers[layer.type]['name'].append(layer.name)
+ self.layers[layer.type]['id'].append(id)
+ # set default/workspace layer properties
+ data = self.SetLayerData(item, id, nvizType)
+ print data
+ # update properties
+ event = wxUpdateProperties(layer=item)
+ wx.PostEvent(self, event)
+ # update tools window
+ if hasattr(self.parent, "nvizToolWin") and \
+ item == self.GetSelectedLayer(type='item'):
+ toolWin = self.parent.nvizToolWin
+ win = toolWin.FindWindowById( \
+ toolWin.win['vector']['lines']['surface'])
+ win.SetItems(self.layers[layer.type]['name'])
+ toolWin.UpdatePage(nvizType)
+ toolWin.SetPage(nvizType)
+ return id
+ def UnloadRaster(self, item):
+ """Unload 2d raster map
+ @param layer item
+ return self._unloadRaster(item)
+ def UnloadRaster3d(self, item):
+ """Unload 3d raster map
+ @param layer item
+ def _unloadRaster(self, item):
+ """Unload 2d/3d raster map
+ return
+ unloadFn = self.nvizClass.UnloadSurface
+ errorMsg = _("Unable to unload raster map")
+ successMsg = _("Raster map")
+ else:
+ unloadFn = self.nvizClass.UnloadVolume
+ errorMsg = _("Unable to unload 3d raster map")
+ successMsg = _("3d raster map")
+ id = data[nvizType]['object']['id']
+ if unloadFn(id) == 0:
+ print >> sys.stderr, "Nviz:" + "%s <%s>" % (errorMsg, layer.name)
+ else:
+ print "Nviz:" + "%s <%s> %s" % (successMsg, layer.name, _("unloaded successfully"))
+ data[nvizType].pop('object')
+ idx = self.layers[layer.type]['id'].index(id)
+ del self.layers[layer.type]['name'][idx]
+ del self.layers[layer.type]['id'][idx]
+ layer.type == 'raster':
+ # remove surface page
+ if toolWin.notebook.GetSelection() == toolWin.page[nvizType]['id']:
+ toolWin.notebook.RemovePage(toolWin.page[nvizType]['id'])
+ toolWin.page[nvizType]['id'] = -1
+ toolWin.page['settings']['id'] = 1
+ def LoadVector(self, item, vecType=None):
+ """Load 2D or 3D vector map overlay
+ @param vecType vector type (lines / points)
+ if layer.type != 'vector':
+ return
+ if vecType is None:
+ # load data type by default
+ vecType = []
+ if UserSettings.Get(group='nviz', key='vector',
+ subkey=[v, 'show']):
+ vecType.append(v)
+ # set default properties
+ self.SetLayerData(item, -1, 'lines')
+ self.SetLayerData(item, -1, 'points')
+ id = -1
+ for type in vecType:
+ if type == 'lines':
+ id = self.nvizClass.LoadVector(str(layer.name), False)
+ else:
+ id = self.nvizClass.LoadVector(str(layer.name), True)
+ if id < 0:
+ print >> sys.stderr, "Nviz:" + _("Loading vector map <%(name)s> (%(type)s) failed") % \
+ { 'name' : layer.name, 'type' : type }
+ continue
+ # update layer properties
+ self.SetLayerData(item, id, type)
+ self.layers['v' + type]['name'].append(layer.name)
+ self.layers['v' + type]['id'].append(id)
+ toolWin.UpdatePage('vector')
+ toolWin.SetPage('vector')
+ return id
+ def UnloadVector(self, item, vecType=None):
+ """Unload vector map overlay
+ @param vecType vector type (lines, points)
+ data = self.tree.GetPyData(item)[0]['nviz']['vector']
+ vecType = []
+ vecType.append(v)
+ for vtype in vecType:
+ if not data[vtype].has_key('object'):
+ continue
+ id = data[vtype]['object']['id']
+ if vtype == 'lines':
+ ret = self.nvizClass.UnloadVector(id, False)
+ else:
+ ret = self.nvizClass.UnloadVector(id, True)
+ if ret == 0:
+ print >> sys.stderr, "Nviz:" + _("Unable to unload vector map <%(name)s> (%(type)s)") % \
+ { 'name': layer.name, 'type' : vtype }
+ else:
+ print "Nviz:" + _("Vector map <%(name)s> (%(type)s) unloaded successfully") % \
+ { 'name' : layer.name, 'type' : vtype }
+ data[vtype].pop('object')
+ idx = self.layers['v' + vtype]['id'].index(id)
+ del self.layers['v' + vtype]['name'][idx]
+ del self.layers['v' + vtype]['id'][idx]
+ vecType is None:
+ if toolWin.notebook.GetSelection() == toolWin.page['surface']['id']:
+ toolWin.notebook.RemovePage(toolWin.page['surface']['id'])
+ toolWin.page['surface']['id'] = -1
+ def GetDrawMode(self, mode=None, style=None, shade=None, string=False):
+ """Get surface draw mode (value) from description/selection
+ @param mode,style,shade modes
+ @param string if True input parameters are strings otherwise
+ selections
+ value = 0
+ desc = {}
+ if string:
+ if mode is not None:
+ if mode == 'coarse':
+ value |= wxnviz.DM_WIRE
+ elif mode == 'fine':
+ value |= wxnviz.DM_POLY
+ else: # both
+ value |= wxnviz.DM_WIRE_POLY
+ if style is not None:
+ if style == 'wire':
+ value |= wxnviz.DM_GRID_WIRE
+ else: # surface
+ value |= wxnviz.DM_GRID_SURF
+ if shade is not None:
+ if shade == 'flat':
+ value |= wxnviz.DM_FLAT
+ else: # surface
+ value |= wxnviz.DM_GOURAUD
+ return value
+ # -> string is False
+ if mode == 0: # coarse
+ desc['mode'] = 'coarse'
+ elif mode == 1: # fine
+ desc['mode'] = 'fine'
+ else: # both
+ desc['mode'] = 'both'
+ if style == 0: # wire
+ desc['style'] = 'wire'
+ else: # surface
+ desc['style'] = 'surface'
+ if shade == 0:
+ desc['shading'] = 'flat'
+ else: # surface
+ desc['shading'] = 'gouraud'
+ return (value, desc)
+ def SetSurfaceDefaultProp(self, data):
+ """Set default surface properties, add actions to update list"""
+ # attributes
+ for attrb in ('shine', ):
+ data['attribute'][attrb] = {}
+ for key, value in UserSettings.Get(group='nviz', key='volume',
+ subkey=attrb).iteritems():
+ data['attribute'][attrb][key] = value
+ self.update.append('surface:attribute:%s' % attrb)
+ # draw
+ data['draw']['all'] = False # apply only for current surface
+ for control, value in UserSettings.Get(group='nviz', key='surface', subkey='draw').iteritems():
+ if control[:3] == 'res':
+ if not data['draw'].has_key('resolution'):
+ data['draw']['resolution'] = {}
+ if 'surface:draw:%s' % 'resolution' not in self.update:
+ self.update.append('surface:draw:%s' % 'resolution')
+ data['draw']['resolution'][control[4:]] = value
+ continue
+ elif control not in ('style', 'shading'):
+ self.update.append('surface:draw:%s' % control)
+ if control == 'wire-color':
+ value = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
+ elif control in ('mode', 'style', 'shading'):
+ if not data['draw'].has_key('mode'):
+ data['draw']['mode'] = {}
+ continue
+ data['draw'][control] = { 'value' : value }
+ value, desc = self.GetDrawMode(UserSettings.Get(group='nviz', key='surface', subkey=['draw', 'mode']),
+ UserSettings.Get(group='nviz', key='surface', subkey=['draw', 'style']),
+ UserSettings.Get(group='nviz', key='surface', subkey=['draw', 'shading']))
+ data['draw']['mode'] = { 'value' : value,
+ 'desc' : desc, }
+ def SetVolumeDefaultProp(self, data):
+ """Set default volume properties and add actions to update list"""
+ # draw
+ for control, value in UserSettings.Get(group='nviz', key='volume', subkey='draw').iteritems():
+ if control == 'mode':
+ continue
+ if 'volume:draw:%s' % control not in self.update:
+ self.update.append('volume:draw:%s' % control)
+ if control == 'shading':
+ sel = UserSettings.Get(group='nviz', key='surface', subkey=['draw', 'shading'])
+ value, desc = self.GetDrawMode(shade=sel, string=False)
+ data['draw']['shading'] = { 'value' : value,
+ 'desc' : desc['shading'] }
+ elif control == 'mode':
+ sel = UserSettings.Get(group='nviz', key='volume', subkey=['draw', 'mode'])
+ if sel == 0:
+ desc = 'isosurface'
+ else:
+ desc = 'slice'
+ data['draw']['mode'] = { 'value' : sel,
+ 'desc' : desc, }
+ else:
+ # isosurface attributes
+ def SetVectorDefaultProp(self, data):
+ """Set default vector properties, add actions to update list"""
+ self.SetVectorLinesDefaultProp(data['lines'])
+ self.SetVectorPointsDefaultProp(data['points'])
+ def SetVectorLinesDefaultProp(self, data):
+ """Set default vector properties -- lines"""
+ # width
+ data['width'] = UserSettings.Get(group='nviz', key='vector',
+ subkey=['lines', 'width'])
+ # color
+ value = UserSettings.Get(group='nviz', key='vector',
+ subkey=['lines', 'color'])
+ color = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
+ data['color'] = color
+ # mode
+ subkey=['lines', 'flat']):
+ type = 'flat'
+ map = None
+ else:
+ if len(self.layers['raster']['name']) > 0:
+ type = 'surface'
+ map = self.layers['raster']['name'][0]
+ else:
+ type = 'flat'
+ map = None
+ data['mode'] = {}
+ data['mode']['type'] = type
+ if map:
+ data['mode']['surface'] = map
+ # height
+ data['height'] = UserSettings.Get(group='nviz', key='vector',
+ subkey=['lines', 'height'])
+ if data.has_key('object'):
+ self.update.append('vector:lines:color')
+ self.update.append('vector:lines:width')
+ self.update.append('vector:lines:mode')
+ self.update.append('vector:lines:height')
+ def SetVectorPointsDefaultProp(self, data):
+ """Set default vector properties -- points"""
+ # size
+ data['size'] = UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'size'])
+ # width
+ subkey=['points', 'width'])
+ # marker
+ data['marker'] = UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'marker'])
+ # color
+ subkey=['points', 'color'])
+ # mode
+ data['mode'] = { 'type' : 'surface',
+ 'surface' : '' }
+ data['mode']['surface'] = self.layers['raster']['name'][0]
+ # height
+ subkey=['points', 'height'])
+ self.update.append('vector:points:size')
+ self.update.append('vector:points:width')
+ self.update.append('vector:points:marker')
+ self.update.append('vector:points:color')
+ self.update.append('vector:points:surface')
+ self.update.append('vector:points:height')
+ def Reset(self):
+ """Reset (unload data)"""
+ self.nvizClass.Reset()
+ self.init = False
+ def OnZoomToMap(self, event):
+ Set display extents to match selected raster
+ or vector map or volume.
+ @todo vector, volume
+ if layer is None:
+ return
+ Debug.msg (3, "GLWindow.OnZoomToMap(): layer=%s, type=%s" % \
+ (layer.name, layer.type))
+ self.nvizClass.SetViewportDefault()
+ def ResetView(self):
+ """Reset to default view"""
+ self.view['z-exag']['value'], \
+ self.iview['height']['value'], \
+ self.iview['height']['min'], \
+ self.iview['height']['max'] = self.nvizClass.SetViewDefault()
+ self.view['pos']['x'] = UserSettings.Get(group='nviz', key='view',
+ subkey=('pos', 'x'))
+ self.view['pos']['y'] = UserSettings.Get(group='nviz', key='view',
+ self.view['persp']['value'] = UserSettings.Get(group='nviz', key='view',
+ subkey=('persp', 'value'))
+ self.view['twist']['value'] = UserSettings.Get(group='nviz', key='view',
+ subkey=('twist', 'value'))
+ self.update.append('view')
+ def UpdateLayerProperties(self, event):
+ """Update data layer properties"""
+ print self.update
+ if not hasattr(event, "layer"):
+ mapLayer = self.GetSelectedLayer()
+ data = self.GetSelectedLayer(type='nviz')
+ else:
+ mapLayer = self.tree.GetPyData(event.layer)[0]['maplayer']
+ data = self.tree.GetPyData(event.layer)[0]['nviz']
+ if mapLayer.type == 'raster':
+ id = data['surface']['object']['id']
+ self.UpdateSurfaceProperties(id, data['surface'])
+ # -> initialized
+ data['surface']['object']['init'] = True
+ elif mapLayer.type == '3d-raster':
+ id = data['volume']['object']['id']
+ if hasattr(event, "isoSurfId"):
+ self.UpdateVolumeProperties(id, data['volume'], isosurfId)
+ else:
+ self.UpdateVolumeProperties(id, data['volume'])
+ # -> initialized
+ data['volume']['object']['init'] = True
+ elif mapLayer.type == 'vector':
+ for type in ('lines', 'points'):
+ if data['vector'][type].has_key('object'):
+ id = data['vector'][type]['object']['id']
+ self.UpdateVectorProperties(id, data['vector'], type)
+ # -> initialized
+ data['vector'][type]['object']['init'] = True
+ print self.update
+ def UpdateSurfaceProperties(self, id, data):
+ """Update surface layer properties"""
+ # surface attributes
+ for attrb in ('topo', 'color', 'mask',
+ 'transp', 'shine', 'emit'):
+ attrb, 'surface:attribute:%s' % attrb in self.update
+ if 'surface:attribute:%s' % attrb in self.update:
+ map = data['attribute'][attrb]['map']
+ value = data['attribute'][attrb]['value']
+ if map is None: # unset
+ # only optional attributes
+ if attrb == 'mask':
+ # TODO: invert mask
+ # TODO: broken in NVIZ
+ self.nvizClass.UnsetSurfaceMask(id)
+ elif attrb == 'transp':
+ self.nvizClass.UnsetSurfaceTransp(id)
+ elif attrb == 'emit':
+ self.nvizClass.UnsetSurfaceEmit(id)
+ else:
+ if type(value) == type('') and \
+ len(value) <= 0: # ignore empty values (TODO: warning)
+ continue
+ if attrb == 'topo':
+ self.nvizClass.SetSurfaceTopo(id, map, str(value))
+ elif attrb == 'color':
+ self.nvizClass.SetSurfaceColor(id, map, str(value))
+ elif attrb == 'mask':
+ self.nvizClass.SetSurfaceMask(id, False, str(value))
+ self.nvizClass.SetSurfaceTransp(id, map, str(value))
+ elif attrb == 'shine':
+ self.nvizClass.SetSurfaceShine(id, map, str(value))
+ self.nvizClass.SetSurfaceEmit(id, map, str(value))
+ self.update.remove('surface:attribute:%s' % attrb)
+ # draw res
+ if 'surface:draw:resolution' in self.update:
+ coarse = data['draw']['resolution']['coarse']
+ fine = data['draw']['resolution']['fine']
+ if data['draw']['all']:
+ self.nvizClass.SetSurfaceRes(-1, fine, coarse)
+ else:
+ self.nvizClass.SetSurfaceRes(id, fine, coarse)
+ self.update.remove('surface:draw:resolution')
+ # draw style
+ if 'surface:draw:mode' in self.update:
+ if data['draw']['mode']['value'] < 0: # need to calculate
+ data['draw']['mode']['value'] = \
+ self.GetDrawMode(mode=data['draw']['mode']['desc']['mode'],
+ style=data['draw']['mode']['desc']['style'],
+ shade=data['draw']['mode']['desc']['shading'],
+ string=True)
+ style = data['draw']['mode']['value']
+ self.nvizClass.SetSurfaceStyle(-1, style)
+ else:
+ self.nvizClass.SetSurfaceStyle(id, style)
+ self.update.remove('surface:draw:mode')
+ # wire color
+ if 'surface:draw:wire-color' in self.update:
+ color = data['draw']['wire-color']['value']
+ self.nvizClass.SetWireColor(-1, str(color))
+ else:
+ self.nvizClass.SetWireColor(id, str(color))
+ self.update.remove('surface:draw:wire-color')
+ # position
+ if 'surface:position' in self.update:
+ x = data['position']['x']
+ y = data['position']['y']
+ z = data['position']['z']
+ self.nvizClass.SetSurfacePosition(id, x, y, z)
+ self.update.remove('surface:position')
+ def UpdateVolumeProperties(self, id, data, isosurfId=None):
+ """Apply volume layer properties"""
+ # draw
+ if 'volume:draw:resolution' in self.update:
+ self.nvizClass.SetIsosurfaceRes(id, data['draw']['resolution']['value'])
+ self.update.remove('volume:draw:resolution')
+ if 'volume:draw:shading' in self.update:
+ if data['draw']['shading']['value'] < 0: # need to calculate
+ data['draw']['shading']['value'] = \
+ self.GetDrawMode(shade=data['draw']['shading'],
+ string=False)
+ self.update.remove('volume:draw:shading')
+ for attrb in ('color', 'mask',
+ if 'volume:attribute:%s' % attrb in self.update:
+ # self.nvizClass.UnsetSurfaceMask(id)
+ pass
+ # self.nvizClass.UnsetSurfaceTransp(id)
+ pass
+ # self.nvizClass.UnsetSurfaceEmit(id)
+ pass
+ else:
+ continue
+ elif attrb == 'color' and isosurfId:
+ self.nvizClass.SetIsosurfaceColor(id, isosurfId, map, str(value))
+ # self.nvizClass.SetSurfaceMask(id, False, str(value))
+ pass
+ # self.nvizClass.SetSurfaceTransp(id, map, str(value))
+ pass
+ # self.nvizClass.SetSurfaceShine(id, map, str(value))
+ pass
+ # self.nvizClass.SetSurfaceEmit(id, map, str(value))
+ pass
+ self.update.remove('volume:attribute:%s' % attrb)
+ def UpdateVectorProperties(self, id, data, type):
+ """Update vector layer properties
+ @param id layer id
+ @param data properties
+ @param type lines/points
+ if type == 'points':
+ self.UpdateVectorPointsProperties(id, data[type])
+ else:
+ self.UpdateVectorLinesProperties(id, data[type])
+ def UpdateVectorLinesProperties(self, id, data):
+ """Apply changes for vector line layer"""
+ # mode
+ if 'vector:lines:color' in self.update or \
+ 'vector:lines:width' in self.update or \
+ 'vector:lines:mode' in self.update:
+ width = data['width']
+ color = data['color']
+ if data['mode']['type'] == 'flat':
+ flat = True
+ if data.has_key('surface'):
+ data.pop('surface')
+ else:
+ flat = False
+ if not 'vector:lines:surface' in self.update:
+ self.update.append('vector:lines:surface')
+ self.nvizClass.SetVectorLineMode(id, color,
+ width, flat)
+ if 'vector:lines:color' in self.update:
+ self.update.remove('vector:lines:color')
+ if 'vector:lines:width' in self.update:
+ self.update.remove('vector:lines:width')
+ if 'vector:lines:mode' in self.update:
+ self.update.remove('vector:lines:mode')
+ # height
+ if 'vector:lines:height' in self.update:
+ self.nvizClass.SetVectorLineHeight(id,
+ data['height'])
+ self.update.remove('vector:lines:height')
+ # surface
+ if 'vector:lines:surface' in self.update:
+ idx = self.layers['raster']['name'].index(data['mode']['surface'])
+ if idx > -1:
+ self.nvizClass.SetVectorLineSurface(id,
+ self.layers['raster']['id'][idx])
+ self.update.remove('vector:lines:surface')
+ def UpdateVectorPointsProperties(self, id, data):
+ """Apply changes for vector point layer"""
+ if 'vector:points:size' in self.update or \
+ 'vector:points:width' in self.update or \
+ 'vector:points:marker' in self.update or \
+ 'vector:points:color' in self.update:
+ ret = self.nvizClass.SetVectorPointMode(id, data['color'],
+ data['width'], float(data['size']),
+ data['marker'] + 1)
+ error = None
+ if ret == -1:
+ error = _("Vector point layer not found (id=%d)") % id
+ elif ret == -2:
+ error = _("Unable to set data layer properties (id=%d)") % id
+ if error:
+ raise gcmd.NvizError(parent=self.parent,
+ message=_("Setting data layer properties failed.\n\n%s") % error)
+ for prop in ('size', 'width', 'marker', 'color'):
+ if 'vector:points:%s' % prop in self.update:
+ self.update.remove('vector:points:%s' % prop)
+ # height
+ if 'vector:points:height' in self.update:
+ self.nvizClass.SetVectorPointHeight(id,
+ data['height'])
+ self.update.remove('vector:points:height')
+ # surface
+ if 'vector:points:surface' in self.update:
+ if idx > -1:
+ self.nvizClass.SetVectorPointSurface(id,
+ self.update.remove('vector:points:surface')
Property changes on: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
___________________________________________________________________
+ Author Date Id
+ native
Added: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -0,0 +1,2618 @@
+ at package nviz_tools.py
+ at brief Nviz tools window
+Classes:
+ - NvizToolWindow
+ - ViewPositionWindow
+ - IsoSurfList
+for details.
+import os
+import wx
+import wx.lib.colourselect as csel
+import globalvar
+import gselect
+class NvizToolWindow(wx.Frame):
+ """Experimental window for Nviz tools
+ @todo integrate with Map display
+ def __init__(self, parent=None, id=wx.ID_ANY, title=_("Nviz tools"),
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_FRAME_STYLE, mapWindow=None):
+ self.lmgr = self.parent.gismanager # GMFrame
+ self.mapWindow = mapWindow
+ wx.Frame.__init__(self, parent, id, title, pos, size, style)
+ # icon
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_nviz.ico'), wx.BITMAP_TYPE_ICO))
+ # dialog body
+ mainSizer = wx.BoxSizer(wx.VERTICAL)
+ self.win = {} # window ids
+ # notebook
+ self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+ self.page = {}
+ # view page
+ self.__createViewPage()
+ self.page['view'] = { 'id' : 0 }
+ # surface page
+ size = self.__createSurfacePage()
+ size = (size[0] + 25, size[0] + 20)
+ # vector page
+ self.__createVectorPage()
+ # volume page
+ self.__createVolumePage()
+ # settings page
+ self.__createSettingsPage()
+ self.page['settings'] = { 'id' : 1 }
+ self.UpdatePage('settings')
+ self.pageChanging = False
+ mainSizer.Add(item=self.notebook, proportion=1,
+ flag=wx.EXPAND | wx.ALL, border=5)
+ # bindings
+ self.Bind(wx.EVT_CLOSE, self.OnClose)
+ # layout
+ self.SetSizer(mainSizer)
+ mainSizer.Fit(self)
+ self.SetSize(size)
+ def __createViewPage(self):
+ """Create view settings page"""
+ panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
+ self.notebook.AddPage(page=panel,
+ text=" %s " % _("View"))
+ pageSizer = wx.BoxSizer(wx.VERTICAL)
+ gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
+ self.win['view'] = {}
+ # position
+ posSizer = wx.GridBagSizer(vgap=3, hgap=3)
+ posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("W")),
+ pos=(1, 0), flag=wx.ALIGN_CENTER)
+ posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("N")),
+ pos=(0, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_BOTTOM)
+ viewPos = ViewPositionWindow(panel, id=wx.ID_ANY, size=(175, 175),
+ mapwindow=self.mapWindow)
+ self.win['view']['pos'] = viewPos.GetId()
+ posSizer.Add(item=viewPos,
+ pos=(1, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_CENTER_VERTICAL)
+ posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("S")),
+ pos=(2, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_TOP)
+ posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("E")),
+ pos=(1, 2), flag=wx.ALIGN_CENTER)
+ gridSizer.Add(item=posSizer, pos=(0, 0))
+ # perspective
+ range = UserSettings.Get(group='nviz', key='view', subkey='persp', internal=True)
+ self.CreateControl(panel, dict=self.win['view'], name='persp',
+ range=(range['min'], range['max']),
+ bind=(self.OnViewChange, self.OnViewChanged, self.OnViewChangedSpin))
+ gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Perspective:")),
+ gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['slider']), pos=(2, 0))
+ gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['spin']), pos=(3, 0),
+ flag=wx.ALIGN_CENTER)
+ # twist
+ range = UserSettings.Get(group='nviz', key='view', subkey='twist', internal=True)
+ self.CreateControl(panel, dict=self.win['view'], name='twist',
+ gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Twist:")),
+ pos=(1, 1), flag=wx.ALIGN_CENTER)
+ gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['slider']), pos=(2, 1))
+ gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['spin']), pos=(3, 1),
+ # height + z-exag
+ self.CreateControl(panel, dict=self.win['view'], name='height', sliderHor=False,
+ range=(0, 1),
+ self.CreateControl(panel, dict=self.win['view'], name='z-exag', sliderHor=False,
+ range=(0, 1),
+ heightSizer = wx.GridBagSizer(vgap=3, hgap=3)
+ heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Height:")),
+ pos=(0, 0), flag=wx.ALIGN_LEFT, span=(1, 2))
+ heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['slider']),
+ flag=wx.ALIGN_RIGHT, pos=(1, 0))
+ heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['spin']),
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT | wx.TOP |
+ wx.BOTTOM | wx.RIGHT, pos=(1, 1))
+ heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Z-exag:")),
+ pos=(0, 2), flag=wx.ALIGN_LEFT, span=(1, 2))
+ heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['slider']),
+ flag=wx.ALIGN_RIGHT, pos=(1, 2))
+ heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['spin']),
+ wx.BOTTOM | wx.RIGHT, pos=(1, 3))
+ gridSizer.Add(item=heightSizer, pos=(0, 1), flag=wx.ALIGN_RIGHT)
+ # view setup + reset
+ viewSizer = wx.BoxSizer(wx.HORIZONTAL)
+ viewSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY,
+ label=_("Look at:")),
+ flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=5)
+ viewType = wx.Choice (parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices = [_("top"),
+ _("north"),
+ _("south"),
+ _("east"),
+ _("west"),
+ _("north-west"),
+ _("north-east"),
+ _("south-east"),
+ _("south-west")])
+ viewType.SetSelection(0)
+ viewType.Bind(wx.EVT_CHOICE, self.OnLookAt)
+ # self.win['lookAt'] = viewType.GetId()
+ viewSizer.Add(item=viewType, flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL,
+ border=5)
+ reset = wx.Button(panel, id=wx.ID_ANY, label=_("Reset"))
+ reset.SetToolTipString(_("Reset to default view"))
+ # self.win['reset'] = reset.GetId()
+ reset.Bind(wx.EVT_BUTTON, self.OnResetView)
+ viewSizer.Add(item=reset, proportion=1,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT,
+ border=5)
+ gridSizer.AddGrowableCol(3)
+ gridSizer.Add(item=viewSizer, pos=(4, 0), span=(1, 2),
+ flag=wx.EXPAND)
+ # body
+ pageSizer.Add(item=gridSizer, proportion=1,
+ border=5)
+ panel.SetSizer(pageSizer)
+ return panel.GetBestSize()
+ def __createSurfacePage(self):
+ self.page['surface'] = {}
+ self.page['surface']['id'] = -1
+ self.page['surface']['panel'] = panel.GetId()
+ # panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY)
+ # panel.SetupScrolling(scroll_x=True, scroll_y=True)
+ self.win['surface'] = {}
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
+ label=" %s " % (_("Surface attributes")))
+ boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ # type
+ self.win['surface']['attr'] = {}
+ row = 0
+ for code, attrb in (('topo', _("Topography")),
+ ('color', _("Color")),
+ ('mask', _("Mask")),
+ ('transp', _("Transparency")),
+ ('shine', _("Shininess")),
+ ('emit', _("Emission"))):
+ self.win['surface'][code] = {}
+ gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=attrb + ':'),
+ pos=(row, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+ use = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+ choices = [_("map")])
+ if code not in ('topo', 'color', 'shine'):
+ use.Insert(item=_("unset"), pos=0)
+ self.win['surface'][code]['required'] = False
+ else:
+ self.win['surface'][code]['required'] = True
+ if code != 'mask':
+ use.Append(item=_('constant'))
+ self.win['surface'][code]['use'] = use.GetId()
+ use.Bind(wx.EVT_CHOICE, self.OnMapObjUse)
+ gridSizer.Add(item=use, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 1))
+ map = gselect.Select(parent=panel, id=wx.ID_ANY,
+ # size=globalvar.DIALOG_GSELECT_SIZE,
+ size=(200, -1),
+ type="raster")
+ self.win['surface'][code]['map'] = map.GetId() - 1 # FIXME
+ map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+ # changing map topography not allowed
+ if code == 'topo':
+ map.Enable(False)
+ gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 2))
+ if code == 'color':
+ value = csel.ColourSelect(panel, id=wx.ID_ANY,
+ colour=UserSettings.Get(group='nviz', key='surface',
+ subkey=['color', 'value']))
+ value.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceMap)
+ elif code == 'mask':
+ value = None
+ else:
+ value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=0)
+ value.SetRange(minVal=-1e9, maxVal=1e9)
+ elif code in ('shine', 'transp', 'emit'):
+ value.SetRange(minVal=0, maxVal=255)
+ else:
+ value.SetRange(minVal=0, maxVal=100)
+ value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+ if value:
+ self.win['surface'][code]['const'] = value.GetId()
+ value.Enable(False)
+ gridSizer.Add(item=value, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 3))
+ else:
+ self.win['surface'][code]['const'] = None
+ self.SetMapObjUseMap(nvizType='surface',
+ attrb=code) # -> enable map / disable constant
+ row += 1
+ boxSizer.Add(item=gridSizer, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=3)
+ pageSizer.Add(item=boxSizer, proportion=0,
+ border=5)
+ # draw
+ self.win['surface']['draw'] = {}
+ label=" %s " % (_("Draw")))
+ gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
+ gridSizer.AddGrowableCol(4)
+ # mode
+ label=_("Mode:")),
+ pos=(0, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+ mode = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+ choices = [_("coarse"),
+ _("fine"),
+ _("both")])
+ mode.SetSelection(0)
+ mode.SetName("selection")
+ mode.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
+ self.win['surface']['draw']['mode'] = mode.GetId()
+ gridSizer.Add(item=mode, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(0, 1))
+ # resolution (mode)
+ label=_("Resolution:")),
+ pos=(0, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+ resSizer = wx.BoxSizer(wx.HORIZONTAL)
+ resSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("coarse:")),
+ flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=3)
+ resC = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=1,
+ min=1,
+ max=100)
+ resC.SetName("value")
+ self.win['surface']['draw']['res-coarse'] = resC.GetId()
+ resC.Bind(wx.EVT_SPINCTRL, self.OnSurfaceResolution)
+ resSizer.Add(item=resC, flag=wx.ALL, border=3)
+ label=_("fine:")),
+ resF = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=1,
+ min=1,
+ max=100)
+ resF.SetName("value")
+ self.win['surface']['draw']['res-fine'] = resF.GetId()
+ resF.Bind(wx.EVT_SPINCTRL, self.OnSurfaceResolution)
+ resSizer.Add(item=resF, flag=wx.ALL, border=3)
+ gridSizer.Add(item=resSizer, pos=(0, 3), span=(1, 2))
+ # style
+ label=_("Coarse style:")),
+ pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+ style = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+ choices = [_("wire"),
+ _("surface")])
+ style.SetName("selection")
+ self.win['surface']['draw']['style'] = style.GetId()
+ style.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
+ gridSizer.Add(item=style, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(1, 1))
+ # shading
+ label=_("Shading:")),
+ pos=(1, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+ shade = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+ choices = [_("flat"),
+ _("gouraud")])
+ shade.SetName("selection")
+ self.win['surface']['draw']['shading'] = shade.GetId()
+ shade.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
+ gridSizer.Add(item=shade, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(1, 3))
+ # color
+ label=_("Wire color:")),
+ pos=(2, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+ color = csel.ColourSelect(panel, id=wx.ID_ANY)
+ color.SetName("colour")
+ color.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceWireColor)
+ self.win['surface']['draw']['wire-color'] = color.GetId()
+ gridSizer.Add(item=color, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(2, 1))
+ flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
+ border=5)
+ all = wx.Button(panel, id=wx.ID_ANY, label=_("All"))
+ all.SetToolTipString(_("Use for all loaded surfaces"))
+ all.Bind(wx.EVT_BUTTON, self.OnSurfaceModeAll)
+ gridSizer.Add(item=all, flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
+ pos=(2, 4))
+ # mask
+ label=" %s " % (_("Mask")))
+ label=_("Mask zeros:")),
+ elev = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("by elevation"))
+ elev.Enable(False) # TODO: not implemented yet
+ gridSizer.Add(item=elev, pos=(0, 1))
+ color = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("by color"))
+ color.Enable(False) # TODO: not implemented yet
+ gridSizer.Add(item=color, pos=(0, 2))
+ border=5)
+ # position
+ self.win['surface']['position'] = {}
+ label=" %s " % (_("Position")))
+ # position
+ axis = wx.Choice (parent=panel, id=wx.ID_ANY, size=(75, -1),
+ choices = ["X",
+ "Y",
+ "Z"])
+ axis.SetSelection(0)
+ self.win['surface']['position']['axis'] = axis.GetId()
+ axis.Bind(wx.EVT_CHOICE, self.OnSurfaceAxis)
+ gridSizer.Add(item=axis, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(0, 0))
+ value = wx.Slider(parent=panel, id=wx.ID_ANY,
+ value=0,
+ minValue=-1e4,
+ maxValue=1e4,
+ style=wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
+ wx.SL_TOP | wx.SL_LABELS,
+ size=(350, -1))
+ self.win['surface']['position']['pos'] = value.GetId()
+ value.Bind(wx.EVT_SCROLL, self.OnSurfacePosition)
+ pos=(0, 1))
+ border=5)
+ def __createVectorPage(self):
+ self.page['vector'] = {}
+ self.page['vector']['id'] = -1
+ self.page['vector']['panel'] = panel.GetId()
+ self.win['vector'] = {}
+ # desc
+ desc = wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label="")
+ self.win['vector']['desc'] = desc.GetId()
+ pageSizer.Add(item=desc, proportion=0,
+ border=10)
+ # vector lines
+ self.win['vector']['lines'] = {}
+ showLines = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Show vector lines"))
+ self.win['vector']['lines']['show'] = showLines.GetId()
+ showLines.Bind(wx.EVT_CHECKBOX, self.OnVectorShow)
+ pageSizer.Add(item=showLines, proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+ label=" %s " % (_("Vector lines")))
+ # width
+ label=_("Width:")),
+ width = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=1,
+ min=1,
+ max=100)
+ self.win['vector']['lines']['width'] = width.GetId()
+ width.Bind(wx.EVT_SPINCTRL, self.OnVectorLines)
+ gridSizer.Add(item=width, pos=(0, 1),
+ flag=wx.ALIGN_CENTER_VERTICAL)
+ gridSizer.AddGrowableCol(2)
+ # color
+ label=_("Color:")),
+ pos=(0, 3), flag=wx.ALIGN_CENTER_VERTICAL)
+ color = csel.ColourSelect(panel, id=wx.ID_ANY,
+ colour=UserSettings.Get(group='nviz', key='vector',
+ subkey=['lines', 'color']))
+ self.win['vector']['lines']['color'] = color.GetId()
+ color.Bind(csel.EVT_COLOURSELECT, self.OnVectorLines)
+ gridSizer.Add(item=color, pos=(0, 4))
+ gridSizer.AddGrowableCol(5)
+ # display
+ label=_("Display:")),
+ pos=(0, 6), flag=wx.ALIGN_CENTER_VERTICAL)
+ display = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+ choices = [_("on surface"),
+ _("flat")])
+ self.win['vector']['lines']['flat'] = display.GetId()
+ display.Bind(wx.EVT_CHOICE, self.OnVectorDisplay)
+ gridSizer.Add(item=display, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(0, 7))
+ # hight
+ label=_("Hight above surface:")),
+ pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL,
+ span=(1, 2))
+ surface = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(250, -1),
+ style=wx.CB_SIMPLE | wx.CB_READONLY,
+ choices=[])
+ surface.Bind(wx.EVT_COMBOBOX, self.OnVectorSurface)
+ self.win['vector']['lines']['surface'] = surface.GetId()
+ gridSizer.Add(item=surface,
+ pos=(1, 2), span=(1, 6),
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ self.CreateControl(panel, dict=self.win['vector']['lines'], name='height', size=300,
+ range=(0, 1000),
+ bind=(self.OnVectorHeight, self.OnVectorHeightFull, self.OnVectorHeightSpin))
+ gridSizer.Add(item=self.FindWindowById(self.win['vector']['lines']['height']['slider']),
+ pos=(2, 2), span=(1, 6))
+ gridSizer.Add(item=self.FindWindowById(self.win['vector']['lines']['height']['spin']),
+ pos=(3, 4),
+ border=5)
+ # vector points
+ self.win['vector']['points'] = {}
+ showPoints = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Show vector points"))
+ self.win['vector']['points']['show'] = showPoints.GetId()
+ showPoints.Bind(wx.EVT_CHECKBOX, self.OnVectorShow)
+ pageSizer.Add(item=showPoints, proportion=0,
+ label=" %s " % (_("Vector points")))
+ # icon size
+ label=_("Icon size:")),
+ isize = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=1,
+ min=1,
+ max=1e6)
+ isize.SetName('value')
+ self.win['vector']['points']['size'] = isize.GetId()
+ isize.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
+ gridSizer.Add(item=isize, pos=(0, 1),
+ # icon width
+ label=_("width:")),
+ iwidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=1,
+ min=1,
+ max=1e6)
+ iwidth.SetName('value')
+ self.win['vector']['points']['width'] = iwidth.GetId()
+ iwidth.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
+ gridSizer.Add(item=iwidth, pos=(0, 3),
+ # icon symbol
+ label=_("symbol:")),
+ pos=(0, 4), flag=wx.ALIGN_CENTER_VERTICAL)
+ isym = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
+ choices=UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'marker'], internal=True))
+ isym.SetName("selection")
+ self.win['vector']['points']['marker'] = isym.GetId()
+ isym.Bind(wx.EVT_CHOICE, self.OnVectorPoints)
+ gridSizer.Add(item=isym, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(0, 5))
+ # icon color
+ label=_("color:")),
+ icolor = csel.ColourSelect(panel, id=wx.ID_ANY)
+ icolor.SetName("color")
+ self.win['vector']['points']['color'] = icolor.GetId()
+ icolor.Bind(csel.EVT_COLOURSELECT, self.OnVectorPoints)
+ gridSizer.Add(item=icolor, flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(0, 7))
+ # high
+ span=(1, 2))
+ choices=[])
+ self.win['vector']['points']['surface'] = surface.GetId()
+ self.CreateControl(panel, dict=self.win['vector']['points'], name='height', size=300,
+ range=(0, 1000),
+ gridSizer.Add(item=self.FindWindowById(self.win['vector']['points']['height']['slider']),
+ gridSizer.Add(item=self.FindWindowById(self.win['vector']['points']['height']['spin']),
+ pos=(3, 4),
+ border=5)
+ def __createVolumePage(self):
+ self.page['volume'] = {}
+ self.page['volume']['id'] = -1
+ self.page['volume']['panel'] = panel.GetId()
+ self.win['volume'] = {}
+ # draw
+ self.win['volume']['draw'] = {}
+ # mode
+ mode = wx.Choice (parent=panel, id=wx.ID_ANY, size=(150, -1),
+ choices = [_("isosurfaces"),
+ _("slides")])
+ # mode.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
+ self.win['volume']['draw']['mode'] = mode.GetId()
+ pos=(0, 1))
+ # shading
+ _("gouraud")])
+ self.win['volume']['draw']['shading'] = shade.GetId()
+ shade.Bind(wx.EVT_CHOICE, self.OnVolumeIsosurfMode)
+ pos=(0, 3))
+ resol = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=1,
+ min=1,
+ max=100)
+ resol.SetName("value")
+ self.win['volume']['draw']['resolution'] = resol.GetId()
+ resol.Bind(wx.EVT_SPINCTRL, self.OnVolumeIsosurfResolution)
+ gridSizer.Add(item=resol, pos=(0, 5))
+ border=5)
+ # manage isosurfaces
+ label=" %s " % (_("List of isosurfaces")))
+ # list
+ isolevel = IsoSurfList(parent=panel, win=self.win['volume'],
+ size=(300, 150))
+ self.win['volume']['isosurfs'] = isolevel.GetId()
+ gridSizer.Add(item=isolevel, pos=(0, 0), span=(4, 1))
+ # buttons (add, delete, move up, move down)
+ btnAdd = wx.Button(parent=panel, id=wx.ID_ADD)
+ self.win['volume']['btnIsosurfAdd'] = btnAdd.GetId()
+ btnAdd.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfAdd)
+ gridSizer.Add(item=btnAdd,
+ pos=(0, 1))
+ btnDelete = wx.Button(parent=panel, id=wx.ID_DELETE)
+ self.win['volume']['btnIsosurfDelete'] = btnDelete.GetId()
+ btnDelete.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfDelete)
+ btnDelete.Enable(False)
+ gridSizer.Add(item=btnDelete,
+ pos=(1, 1))
+ btnMoveUp = wx.Button(parent=panel, id=wx.ID_UP)
+ self.win['volume']['btnIsosurfMoveUp'] = btnMoveUp.GetId()
+ btnMoveUp.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfMoveUp)
+ btnMoveUp.Enable(False)
+ gridSizer.Add(item=btnMoveUp,
+ pos=(2, 1))
+ btnMoveDown = wx.Button(parent=panel, id=wx.ID_DOWN)
+ self.win['volume']['btnIsosurfMoveDown'] = btnMoveDown.GetId()
+ btnMoveDown.Bind(wx.EVT_BUTTON, self.OnVolumeIsosurfMoveDown)
+ btnMoveDown.Enable(False)
+ gridSizer.Add(item=btnMoveDown,
+ pos=(3, 1))
+ border=5)
+ label=" %s " % (_("Isosurface attributes")))
+ self.win['volume']['attr'] = {}
+ row = 0
+ for code, attrb in (('topo', _("Topography level")),
+ self.win['volume'][code] = {}
+ # label
+ if code != 'topo':
+ else:
+ use = None
+ # check for required properties
+ self.win['volume'][code]['required'] = False
+ else:
+ self.win['volume'][code]['required'] = True
+ if use and code != 'mask':
+ if use:
+ self.win['volume'][code]['use'] = use.GetId()
+ pos=(row, 1))
+ size=(200, -1),
+ type="grid3")
+ self.win['volume'][code]['map'] = map.GetId() - 1 # FIXME
+ map.Bind(wx.EVT_TEXT, self.OnVolumeIsosurfMap)
+ pos=(row, 2))
+ else:
+ map = None
+ colour=UserSettings.Get(group='nviz', key='volume',
+ value.Bind(csel.EVT_COLOURSELECT, self.OnVolumeIsosurfMap)
+ value = None
+ else:
+ size = (200, -1)
+ else:
+ size = (65, -1)
+ value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=size,
+ initial=0)
+ else:
+ if value:
+ self.win['volume'][code]['const'] = value.GetId()
+ pos=(row, 2))
+ else:
+ pos=(row, 3))
+ else:
+ self.win['volume'][code]['const'] = None
+ self.SetMapObjUseMap(nvizType='volume',
+ row += 1
+ border=5)
+ def __createSettingsPage(self):
+ """Create settings page"""
+ text=" %s " % _("Settings"))
+ self.win['settings'] = {}
+ # general
+ self.win['settings']['general'] = {}
+ label=" %s " % (_("General")))
+ # background color
+ label=_("Background color:")),
+ colour=UserSettings.Get(group='nviz', key='settings',
+ subkey=['general', 'bgcolor']))
+ self.win['settings']['general']['bgcolor'] = color.GetId()
+ color.Bind(csel.EVT_COLOURSELECT, self.OnBgColor)
+ gridSizer.Add(item=color, pos=(0, 1))
+ border=5)
+ # view
+ self.win['settings']['view'] = {}
+ label=" %s " % (_("View")))
+ # perspective
+ self.win['settings']['view']['persp'] = {}
+ pvals = UserSettings.Get(group='nviz', key='view', subkey='persp')
+ ipvals = UserSettings.Get(group='nviz', key='view', subkey='persp', internal=True)
+ label=_("Perspective:")),
+ label=_("(value)")),
+ pos=(0, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ pval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=pvals['value'],
+ min=ipvals['min'],
+ max=ipvals['max'])
+ self.win['settings']['view']['persp']['value'] = pval.GetId()
+ gridSizer.Add(item=pval, pos=(0, 2),
+ label=_("(step)")),
+ pos=(0, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ pstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=pvals['step'],
+ max=ipvals['max']-1)
+ self.win['settings']['view']['persp']['step'] = pstep.GetId()
+ gridSizer.Add(item=pstep, pos=(0, 4),
+ # position
+ self.win['settings']['view']['pos'] = {}
+ posvals = UserSettings.Get(group='nviz', key='view', subkey='pos')
+ label=_("Position:")),
+ label=_("(x)")),
+ pos=(1, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ px = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=posvals['x'] * 100,
+ min=0,
+ max=100)
+ self.win['settings']['view']['pos']['x'] = px.GetId()
+ gridSizer.Add(item=px, pos=(1, 2),
+ label="(y)"),
+ pos=(1, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ py = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=posvals['y'] * 100,
+ min=0,
+ max=100)
+ self.win['settings']['view']['pos']['y'] = py.GetId()
+ gridSizer.Add(item=py, pos=(1, 4),
+ # height
+ self.win['settings']['view']['height'] = {}
+ hvals = UserSettings.Get(group='nviz', key='view', subkey='height')
+ label=_("Height")),
+ pos=(2, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ hstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=hvals['step'],
+ min=1,
+ max=1e6)
+ self.win['settings']['view']['height']['step'] = hstep.GetId()
+ gridSizer.Add(item=hstep, pos=(2, 2),
+ # twist
+ self.win['settings']['view']['twist'] = {}
+ tvals = UserSettings.Get(group='nviz', key='view', subkey='twist')
+ itvals = UserSettings.Get(group='nviz', key='view', subkey='twist', internal=True)
+ label=_("Twist")),
+ pos=(3, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+ pos=(3, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ tval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=tvals['value'],
+ min=itvals['min'],
+ max=itvals['max'])
+ self.win['settings']['view']['twist']['value'] = tval.GetId()
+ gridSizer.Add(item=tval, pos=(3, 2),
+ pos=(3, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ tstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=tvals['step'],
+ max=itvals['max']-1)
+ self.win['settings']['view']['twist']['step'] = tstep.GetId()
+ gridSizer.Add(item=tstep, pos=(3, 4),
+ # z-exag
+ self.win['settings']['view']['z-exag'] = {}
+ zvals = UserSettings.Get(group='nviz', key='view', subkey='z-exag')
+ label=_("Z-exag")),
+ pos=(4, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+ pos=(4, 1), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ zval = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=zvals['value'],
+ min=-1e6,
+ max=1e6)
+ self.win['settings']['view']['z-exag']['value'] = zval.GetId()
+ gridSizer.Add(item=zval, pos=(4, 2),
+ label=_("(step):")),
+ pos=(4, 3), flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ zstep = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=zvals['step'],
+ min=-1e6,
+ max=1e6)
+ self.win['settings']['view']['z-exag']['step'] = zstep.GetId()
+ gridSizer.Add(item=zstep, pos=(4, 4),
+ border=5)
+ # surface
+ self.win['settings']['surface'] = {}
+ label=" %s " % (_("Surface")))
+ border=5)
+ # vector lines
+ self.win['settings']['vector'] = {}
+ self.win['settings']['vector']['lines'] = {}
+ # show
+ row = 0
+ label=_("Show lines"))
+ self.win['settings']['vector']['lines']['show'] = showLines.GetId()
+ showLines.SetValue(UserSettings.Get(group='nviz', key='vector',
+ subkey=['lines', 'show']))
+ gridSizer.Add(item=showLines, pos=(row, 0))
+ border=5)
+ # vector points
+ self.win['settings']['vector']['points'] = {}
+ gridSizer = wx.GridBagSizer(vgap=3, hgap=5)
+ # show
+ row = 0
+ label=_("Show points"))
+ showPoints.SetValue(UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'show']))
+ self.win['settings']['vector']['points']['show'] = showPoints.GetId()
+ gridSizer.Add(item=showPoints, pos=(row, 0), span=(1, 8))
+ # icon size
+ row += 1
+ label=_("Size:")),
+ initial=100,
+ min=1,
+ max=1e6)
+ self.win['settings']['vector']['points']['size'] = isize.GetId()
+ isize.SetValue(UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'size']))
+ gridSizer.Add(item=isize, pos=(row, 1),
+ # icon width
+ label=_("Witdh:")),
+ pos=(row, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+ initial=2,
+ min=1,
+ max=1e6)
+ self.win['settings']['vector']['points']['width'] = isize.GetId()
+ iwidth.SetValue(UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'width']))
+ gridSizer.Add(item=iwidth, pos=(row, 3),
+ # icon symbol
+ label=_("Marker:")),
+ pos=(row, 4), flag=wx.ALIGN_CENTER_VERTICAL)
+ self.win['settings']['vector']['points']['marker'] = isym.GetId()
+ isym.SetSelection(UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'marker']))
+ pos=(row, 5))
+ # icon color
+ pos=(row, 6), flag=wx.ALIGN_CENTER_VERTICAL)
+ self.win['settings']['vector']['points']['color'] = icolor.GetId()
+ icolor.SetColour(UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'color']))
+ pos=(row, 7))
+ border=5)
+ # buttons
+ btnDefault = wx.Button(panel, wx.ID_CANCEL, label=_("Default"))
+ btnSave = wx.Button(panel, wx.ID_SAVE)
+ btnApply = wx.Button(panel, wx.ID_APPLY)
+ btnDefault.Bind(wx.EVT_BUTTON, self.OnDefault)
+ btnDefault.SetToolTipString(_("Restore default settings"))
+ btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+ btnApply.SetToolTipString(_("Apply changes for the current session"))
+ btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+ btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
+ btnSave.SetDefault()
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(btnDefault)
+ btnSizer.AddButton(btnApply)
+ btnSizer.AddButton(btnSave)
+ btnSizer.Realize()
+ pageSizer.Add(item=btnSizer, proportion=1,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT | wx.ALIGN_BOTTOM,
+ border=5)
+ def CreateControl(self, parent, dict, name, range, bind, sliderHor=True, size=200):
+ """Add control (Slider + SpinCtrl)"""
+ dict[name] = {}
+ if sliderHor:
+ style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
+ wx.SL_BOTTOM
+ sizeW = (size, -1)
+ else:
+ style = wx.SL_VERTICAL | wx.SL_AUTOTICKS | \
+ wx.SL_BOTTOM | wx.SL_INVERSE
+ sizeW = (-1, size)
+ try:
+ val = self.mapWindow.view[name]['value']
+ except KeyError:
+ val=-1
+ slider = wx.Slider(parent=parent, id=wx.ID_ANY,
+ value=val,
+ minValue=range[0],
+ maxValue=range[1],
+ style=style,
+ size=sizeW)
+ slider.SetName('slider')
+ slider.Bind(wx.EVT_SCROLL, bind[0])
+ slider.Bind(wx.EVT_SCROLL_CHANGED, bind[1])
+ dict[name]['slider'] = slider.GetId()
+ spin = wx.SpinCtrl(parent=parent, id=wx.ID_ANY, size=(65, -1),
+ initial=val,
+ min=range[0],
+ max=range[1])
+ # spin = wx.SpinButton(parent=parent, id=wx.ID_ANY)
+ # spin.SetValue (self.mapWindow.view[name]['value'])
+ # spin.SetRange(self.mapWindow.view[name]['min'],
+ # self.mapWindow.view[name]['max'])
+ # no 'changed' event ... (FIXME)
+ spin.SetName('spin')
+ spin.Bind(wx.EVT_SPINCTRL, bind[2])
+ dict[name]['spin'] = spin.GetId()
+ def UpdateSettings(self):
+ """Update dialog settings"""
+ for control in ('height',
+ 'persp',
+ 'twist',
+ 'z-exag'):
+ for win in self.win['view'][control].itervalues():
+ if control == 'height':
+ value = UserSettings.Get(group='nviz', key='view',
+ subkey=['height', 'value'], internal=True)
+ else:
+ value = self.mapWindow.view[control]['value']
+ self.FindWindowById(win).SetValue(value)
+ self.FindWindowById(self.win['view']['pos']).Draw()
+ self.FindWindowById(self.win['view']['pos']).Refresh(False)
+ def __GetWindowName(self, dict, id):
+ for name in dict.iterkeys():
+ if type(dict[name]) is type({}):
+ for win in dict[name].itervalues():
+ if win == id:
+ return name
+ else:
+ if dict[name] == id:
+ return name
+ return None
+ def OnViewChange(self, event):
+ """Change view, render in quick mode"""
+ # find control
+ winName = self.__GetWindowName(self.win['view'], event.GetId())
+ if not winName:
+ return
+ if winName == 'height':
+ view = self.mapWindow.iview # internal
+ else:
+ view = self.mapWindow.view
+ view[winName]['value'] = event.GetInt()
+ for win in self.win['view'][winName].itervalues():
+ self.FindWindowById(win).SetValue(view[winName]['value'])
+ self.mapWindow.update.append('view')
+ if winName == 'z-exag':
+ self.mapWindow.update.append('z-exag')
+ self.mapWindow.render['quick'] = True
+ self.mapWindow.Refresh(False)
+ def OnViewChanged(self, event):
+ """View changed, render in full resolution"""
+ self.mapWindow.render['quick'] = False
+ def OnViewChangedSpin(self, event):
+ # TODO: use step value instead
+ self.OnViewChange(event)
+ self.OnViewChanged(None)
+ def OnResetView(self, event):
+ """Reset to default view (view page)"""
+ self.mapWindow.ResetView()
+ self.UpdateSettings()
+ def OnLookAt(self, event):
+ """Look at (view page)"""
+ sel = event.GetSelection()
+ if sel == 0: # top
+ self.mapWindow.view['pos']['x'] = 0.5
+ self.mapWindow.view['pos']['y'] = 0.5
+ elif sel == 1: # north
+ self.mapWindow.view['pos']['y'] = 0.0
+ elif sel == 2: # south
+ self.mapWindow.view['pos']['y'] = 1.0
+ elif sel == 3: # east
+ self.mapWindow.view['pos']['x'] = 1.0
+ elif sel == 4: # west
+ self.mapWindow.view['pos']['x'] = 0.0
+ elif sel == 5: # north-west
+ elif sel == 6: # north-east
+ elif sel == 7: # south-east
+ elif sel == 8: # south-west
+ def OnDefault(self, event):
+ """Restore default settings"""
+ settings = copy.deepcopy(UserSettings.GetDefaultSettings()['nviz'])
+ UserSettings.Set(group='nviz',
+ value=settings)
+ for subgroup, key in settings.iteritems(): # view, surface, vector...
+ if subgroup != 'view':
+ continue
+ for subkey, value in key.iteritems():
+ for subvalue in value.keys():
+ win = self.FindWindowById(self.win['settings'][subgroup][subkey][subvalue])
+ val = settings[subgroup][subkey][subvalue]
+ if subkey == 'pos':
+ val = int(val * 100)
+ win.SetValue(val)
+ event.Skip()
+ def OnApply(self, event):
+ """Apply button pressed"""
+ if self.notebook.GetSelection() == self.page['settings']['id']:
+ self.ApplySettings()
+ if event:
+ event.Skip()
+ def ApplySettings(self):
+ """Apply Nviz settings for current session"""
+ settings = UserSettings.Get(group='nviz')
+ try: # TODO
+ except:
+ # print 'e', subgroup, subkey, subvalue
+ continue
+ if win.GetName() == "selection":
+ value = win.GetSelection()
+ elif win.GetName() == "color":
+ value = tuple(win.GetColour())
+ else:
+ value = win.GetValue()
+ value = float(value) / 100
+ settings[subgroup][subkey][subvalue] = value
+ def OnSave(self, event):
+ """OK button pressed
+ Apply changes, update map and save settings of selected layer
+ # apply changes
+ self.OnApply(None)
+ fileSettings = {}
+ UserSettings.ReadSettingsFile(settings=fileSettings)
+ fileSettings['nviz'] = UserSettings.Get(group='nviz')
+ file = UserSettings.SaveToFile(fileSettings)
+ self.lmgr.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
+ def OnBgColor(self, event):
+ """Background color changed"""
+ color = event.GetValue()
+ color = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
+ self.mapWindow.nvizClass.SetBgColor(str(color))
+ if self.parent.autoRender.IsChecked():
+ def OnClose(self, event):
+ """Close button pressed
+ Close dialog
+ self.Hide()
+ def OnMapObjUse(self, event):
+ """Surface attribute -- use -- map/constant"""
+ if not self.mapWindow.init:
+ return
+ wx.Yield()
+ # find attribute row
+ attrb = self.__GetWindowName(self.win['surface'], event.GetId())
+ if not attrb:
+ attrb = self.__GetWindowName(self.win['volume'], event.GetId())
+ else:
+ selection = event.GetSelection()
+ if self.win[nvizType][attrb]['required']: # no 'unset'
+ selection += 1
+ if selection == 0: # unset
+ useMap = None
+ value = ''
+ elif selection == 1: # map
+ useMap = True
+ value = self.FindWindowById(self.win[nvizType][attrb]['map']).GetValue()
+ elif selection == 2: # constant
+ useMap = False
+ if attrb == 'color':
+ value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetColour()
+ value = self._getColorString(value)
+ else:
+ value = self.FindWindowById(self.win[nvizType][attrb]['const']).GetValue()
+ self.SetMapObjUseMap(nvizType=nvizType,
+ attrb=attrb, map=useMap)
+ self.mapWindow.update.append('%s:attribute:%s' % (nvizType, attrb))
+ data = self.mapWindow.GetSelectedLayer(type='nviz')
+ data[nvizType]['attribute'][attrb] = { 'map' : useMap,
+ 'value' : str(value),
+ event = wxUpdateProperties()
+ wx.PostEvent(self.mapWindow, event)
+ def SetMapObjUseMap(self, nvizType, attrb, map=None):
+ if attrb in ('topo', 'color', 'shine'):
+ incSel = -1 # decrement selection (no 'unset')
+ else:
+ incSel = 0
+ if map is True: # map
+ if attrb != 'topo': # changing map topography not allowed
+ # not sure why, but here must be disabled both ids, should be fixed!
+ self.FindWindowById(self.win[nvizType][attrb]['map'] + 1).Enable(True)
+ if self.win[nvizType][attrb]['const']:
+ self.FindWindowById(self.win[nvizType][attrb]['const']).Enable(False)
+ self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(1 + incSel)
+ elif map is False: # const
+ self.FindWindowById(self.win[nvizType][attrb]['map'] + 1).Enable(False)
+ self.FindWindowById(self.win[nvizType][attrb]['const']).Enable(True)
+ self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(2 + incSel)
+ else: # unset
+ self.FindWindowById(self.win[nvizType][attrb]['use']).SetSelection(0)
+ def OnSurfaceMap(self, event):
+ """Set surface attribute"""
+ self.SetMapObjAttrb(nvizType='surface', winId=event.GetId())
+ def SetMapObjAttrb(self, nvizType, winId):
+ """Set map object attrbite"""
+ return
+ attrb = self.__GetWindowName(self.win[nvizType], winId)
+ if not attrb:
+ return
+ selection = self.FindWindowById(self.win[nvizType][attrb]['use']).GetSelection()
+ selection += 1
+ map = None
+ value = ''
+ map = True
+ else: # constant
+ # tuple to string
+ else:
+ map = False
+ if not self.pageChanging:
+ data[nvizType]['attribute'][attrb] = { 'map' : map,
+ def OnSurfaceResolution(self, event):
+ """Draw resolution changed"""
+ self.SetSurfaceResolution()
+ if apply and self.parent.autoRender.IsChecked():
+ def SetSurfaceResolution(self):
+ """Set draw resolution"""
+ coarse = self.FindWindowById(self.win['surface']['draw']['res-coarse']).GetValue()
+ fine = self.FindWindowById(self.win['surface']['draw']['res-fine']).GetValue()
+ self.mapWindow.update.append('surface:draw:resolution')
+ data['surface']['draw']['resolution'] = { 'coarse' : coarse,
+ 'fine' : fine }
+ def SetSurfaceMode(self):
+ """Set draw mode
+ @param apply allow auto-rendering
+ mode = self.FindWindowById(self.win['surface']['draw']['mode']).GetSelection()
+ self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(True)
+ self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(False)
+ self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(False)
+ self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(True)
+ else: # both
+ style = self.FindWindowById(self.win['surface']['draw']['style']).GetSelection()
+ shade = self.FindWindowById(self.win['surface']['draw']['shading']).GetSelection()
+ value, desc = self.mapWindow.GetDrawMode(mode, style, shade)
+ return value, desc
+ def OnSurfaceMode(self, event):
+ """Set draw mode"""
+ value, desc = self.SetSurfaceMode()
+ self.mapWindow.update.append('surface:draw:mode')
+ data['surface']['draw']['mode'] = { 'value' : value,
+ 'desc' : desc }
+ def OnSurfaceModeAll(self, event):
+ """Set draw mode (including wire color) for all loaded surfaces"""
+ self.SetSurfaceMode(all=True)
+ self.SetSurfaceResolution(all=True)
+ ### color = self.FindWindowById(self.win['surface']['draw']['wire-color']).GetColour()
+ def _getColorString(self, color):
+ """Set wire color"""
+ return str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
+ def OnSurfaceWireColor(self, event):
+ self.mapWindow.update.append('surface:draw:wire-color')
+ value = self._getColorString(event.GetValue())
+ data['surface']['draw']['wire-color'] = { 'value' : value }
+ def OnSurfaceAxis(self, event):
+ """Surface position, axis changed"""
+ mapLayer = self.mapWindow.GetSelectedLayer()
+ id = data['object']['id']
+ axis = self.FindWindowById(self.win['surface']['position']['axis']).GetSelection()
+ win = self.FindWindowById(self.win['surface']['position']['pos'])
+ x, y, z = self.mapWindow.nvizClass.GetSurfacePosition(id)
+ if axis == 0: # x
+ win.SetRange(-1e4, 1e4)
+ win.SetValue(x)
+ elif axis == 1: # y
+ win.SetValue(y)
+ else: # z
+ win.SetRange(-1e3, 1e3)
+ win.SetValue(z)
+ def OnSurfacePosition(self, event):
+ """Surface position"""
+ value = event.GetInt()
+ if axis == 0: # x
+ x = value
+ y = value
+ else: # z
+ z = value
+ self.mapWindow.update.append('surface:position')
+ data['surface']['position']['x'] = x
+ data['surface']['position']['y'] = y
+ data['surface']['position']['z'] = z
+ def UpdateVectorShow(self, vecType, enabled):
+ """Enable/disable lines/points widgets
+ if vecType != 'lines' and vecType != 'points':
+ return False
+ for win in self.win['vector'][vecType].keys():
+ if win == 'show':
+ continue
+ if type(self.win['vector'][vecType][win]) == type({}):
+ for swin in self.win['vector'][vecType][win].keys():
+ if enabled:
+ self.FindWindowById(self.win['vector'][vecType][win][swin]).Enable(True)
+ else:
+ self.FindWindowById(self.win['vector'][vecType][win][swin]).Enable(False)
+ else:
+ if enabled:
+ self.FindWindowById(self.win['vector'][vecType][win]).Enable(True)
+ else:
+ self.FindWindowById(self.win['vector'][vecType][win]).Enable(False)
+ return True
+ def OnVectorShow(self, event):
+ """Show vector lines/points"""
+ winId = event.GetId()
+ if winId == self.win['vector']['lines']['show']:
+ vecType = 'lines'
+ else: # points
+ vecType = 'points'
+ checked = event.IsChecked()
+ item = self.mapWindow.GetSelectedLayer(type='item')
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['vector']
+ if checked:
+ self.mapWindow.LoadVector(item, (vecType,))
+ else:
+ self.mapWindow.UnloadVector(item, (vecType,))
+ self.UpdateVectorShow(vecType, checked)
+ if checked:
+ try:
+ id = data[vecType]['object']['id']
+ except KeyError:
+ id = -1
+ if id > 0:
+ self.mapWindow.SetLayerData(item, id, vecType)
+ event.Skip()
+ def OnVectorDisplay(self, event):
+ """Display vector lines on surface/flat"""
+ if event.GetSelection() == 0: # surface
+ if len(self.mapWindow.layers['raster']['name']) < 1:
+ event.Veto()
+ return
+ self.FindWindowById(self.win['vector']['lines']['surface']).Enable(True)
+ # set first found surface
+ data['vector']['lines']['mode']['surface'] = self.mapWindow.layers['raster']['name'][0]
+ self.FindWindowById(self.win['vector']['lines']['surface']).SetStringSelection( \
+ self.mapWindow.layers['raster']['name'][0])
+ else: # flat
+ self.FindWindowById(self.win['vector']['lines']['surface']).Enable(False)
+ self.OnVectorLines(event)
+ event.Skip()
+ def OnVectorLines(self, event):
+ """Set vector lines mode, apply changes if auto-rendering is enabled"""
+ width = self.FindWindowById(self.win['vector']['lines']['width']).GetValue()
+ color = self.FindWindowById(self.win['vector']['lines']['color']).GetColour()
+ mode = {}
+ if self.FindWindowById(self.win['vector']['lines']['flat']).GetSelection() == 0:
+ mode['type'] = 'surface'
+ mode['surface'] = self.FindWindowById(self.win['vector']['lines']['surface']).GetValue()
+ self.mapWindow.update.append('vector:lines:surface')
+ else:
+ mode['type'] = 'flat'
+ self.mapWindow.update.append('vector:lines:width')
+ self.mapWindow.update.append('vector:lines:color')
+ self.mapWindow.update.append('vector:lines:mode')
+ data['vector']['lines']['width'] = width
+ data['vector']['lines']['color'] = color
+ data['vector']['lines']['mode'] = mode
+ def OnVectorHeight(self, event):
+ id = event.GetId()
+ if id == self.win['vector']['lines']['height']['spin'] or \
+ id == self.win['vector']['lines']['height']['slider']:
+ vtype = 'lines'
+ else:
+ vtype = 'points'
+ if type(event) == type(wx.ScrollEvent()):
+ # slider
+ win = self.FindWindowById(self.win['vector'][vtype]['height']['spin'])
+ else:
+ # spin
+ win = self.FindWindowById(self.win['vector'][vtype]['height']['slider'])
+ win.SetValue(value)
+ self.mapWindow.update.append('vector:%s:height' % vtype)
+ data['vector'][vtype]['height'] = value
+ # update properties
+ self.mapWindow.render['v' + vtype] = True
+ def OnVectorHeightFull(self, event):
+ """Vector height changed, render in full resolution"""
+ vtype = 'lines'
+ else:
+ vtype = 'points'
+ self.mapWindow.render['v' + vtype] = False
+ def OnVectorHeightSpin(self, event):
+ self.OnVectorHeight(event)
+ self.OnVectorHeightFull(event)
+ def OnVectorSurface(self, event):
+ """Reference surface for vector map (lines/points)"""
+ if id == self.win['vector']['lines']['surface']:
+ vtype = 'lines'
+ else:
+ vtype = 'points'
+ self.mapWindow.update.append('vector:%s:surface' % vtype)
+ data['vector'][vtype]['mode']['surface'] = event.GetValue()
+ def OnVectorPoints(self, event):
+ """Set vector points mode, apply changes if auto-rendering is enabled"""
+ size = self.FindWindowById(self.win['vector']['points']['size']).GetValue()
+ width = self.FindWindowById(self.win['vector']['points']['width']).GetValue()
+ color = self.FindWindowById(self.win['vector']['points']['color']).GetColour()
+ marker = self.FindWindowById(self.win['vector']['points']['marker']).GetSelection()
+ self.mapWindow.update.append('vector:points:size')
+ self.mapWindow.update.append('vector:points:width')
+ self.mapWindow.update.append('vector:points:color')
+ self.mapWindow.update.append('vector:points:marker')
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['vector']['points']
+ data['size'] = size
+ data['width'] = width
+ data['marker'] = marker
+ def UpdateIsosurfButtons(self, list):
+ """Enable/disable buttons 'add', 'delete',
+ 'move up', 'move down'"""
+ nitems = list.GetCount()
+ add = self.parent.FindWindowById(self.win['volume']['btnIsosurfAdd'])
+ delete = self.parent.FindWindowById(self.win['volume']['btnIsosurfDelete'])
+ moveDown = self.parent.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
+ moveUp = self.parent.FindWindowById(self.win['volume']['btnIsosurfMoveUp'])
+ if nitems >= wxnviz.MAX_ISOSURFS:
+ # disable add button on max
+ add.Enable(False)
+ else:
+ add.Enable(True)
+ if nitems < 1:
+ # disable 'delete' if only one item in the lis
+ delete.Enable(False)
+ else:
+ delete.Enable(True)
+ if list.GetSelection() >= nitems - 1:
+ # disable 'move-down' if last
+ moveDown.Enable(False)
+ else:
+ moveDown.Enable(True)
+ if list.GetSelection() < 1:
+ # disable 'move-up' if first
+ moveUp.Enable(False)
+ else:
+ moveUp.Enable(True)
+ def OnVolumeIsosurfMode(self, event):
+ """Set isosurface draw mode"""
+ self.SetIsosurfaceMode(event.GetSelection())
+ def SetIsosurfaceMode(self, selection):
+ layer = self.mapWindow.GetSelectedLayer()
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['volume']
+ mode = 0
+ mode |= wxnviz.DM_FLAT
+ else:
+ mode |= wxnviz.DM_GOURAUD
+ self.mapWindow.nvizClass.SetIsosurfaceMode(id, mode)
+ def OnVolumeIsosurfResolution(self, event):
+ """Set isosurface draw resolution"""
+ self.SetIsosurfaceResolution(event.GetInt())
+ def SetIsosurfaceResolution(self, res):
+ self.mapWindow.nvizClass.SetIsosurfaceRes(id, res)
+ def OnVolumeIsosurfMap(self, event):
+ def OnVolumeIsosurfAdd(self, event):
+ """Add new isosurface to the list"""
+ list = self.FindWindowById(self.win['volume']['isosurfs'])
+ level = self.FindWindowById(self.win['volume']['topo']['const']).GetValue()
+ sel = list.GetSelection()
+ if sel < 0 or sel >= list.GetCount() - 1:
+ item = list.Append(item="%s %s" % (_("Level"), str(level)))
+ else:
+ list.Insert(item="%s %s" % (_("Level"), str(level)),
+ pos=sel+1) # append
+ item = sel + 1
+ print item
+ list.Check(item)
+ list.SetSelection(item)
+ # collect properties
+ isosurfData = {}
+ isosurfData[attrb] = {}
+ win = self.FindWindowById(self.win['volume'][attrb]['const'])
+ isosurfData[attrb]['value'] = win.GetValue()
+ else:
+ uwin = self.FindWindowById(self.win['volume'][attrb]['use'])
+ sel = uwin.GetSelection()
+ if self.win['volume'][attrb]['required']:
+ sel += 1
+ if sel == 0: # unset
+ continue
+ if sel == 1: # map
+ isosurfData[attrb]['map'] = True
+ vwin = self.FindWindowById(self.win['volume'][attrb]['map'])
+ value = vwin.GetValue()
+ else: # const
+ isosurfData[attrb]['map'] = False
+ vwin = self.FindWindowById(self.win['volume'][attrb]['const'])
+ if vwin.GetName() == "color":
+ value = self._getColorString(vwin.GetValue())
+ else:
+ isosurfData[attrb]['value'] = value
+ data['isosurface'].insert(item, isosurfData)
+ print '#', data
+ # add isosurface
+ self.mapWindow.nvizClass.AddIsosurface(id, level)
+ self.mapWindow.nvizClass.SetIsosurfaceColor(id, 0, True, str(layer.name))
+ # update buttons
+ self.UpdateIsosurfButtons(list)
+ event.Skip()
+ def OnVolumeIsosurfDelete(self, event):
+ """Remove isosurface from list"""
+ # remove item from list
+ isosurfId = list.GetSelection()
+ list.Delete(isosurfId)
+ # select last item
+ if list.GetCount() > 0:
+ list.SetSelection(list.GetCount()-1)
+ # delete isosurface
+ del data['isosurface'][isosurfId]
+ print '#', data
+ self.mapWindow.nvizClass.DeleteIsosurface(id, isosurfId)
+ # update buttons
+ event.Skip()
+ def OnVolumeIsosurfMoveUp(self, event):
+ """Move isosurface up in the list"""
+ if sel < 1:
+ return # this should not happen
+ # move item up
+ text = list.GetStringSelection()
+ list.Insert(item=text, pos=sel-1)
+ list.Check(sel-1)
+ list.SetSelection(sel-1)
+ list.Delete(sel+1)
+ data['isosurface'].insert(sel-1, data['isosurface'][sel])
+ del data['isosurface'][sel+1]
+ self.mapWindow.nvizClass.MoveIsosurface(id, sel, True)
+ print '#', data
+ # update buttons
+ event.Skip()
+ def OnVolumeIsosurfMoveDown(self, event):
+ """Move isosurface dowm in the list"""
+ if sel >= list.GetCount() - 1:
+ # move item up
+ list.Insert(item=text, pos=sel+2)
+ list.Check(sel+2)
+ list.SetSelection(sel+2)
+ list.Delete(sel)
+ data['isosurface'].insert(sel+2, data['isosurface'][sel])
+ del data['isosurface'][sel]
+ self.mapWindow.nvizClass.MoveIsosurface(id, sel, False)
+ print '#', data
+ # update buttons
+ event.Skip()
+ def UpdatePage(self, pageId):
+ """Update dialog (selected page)"""
+ self.pageChanging = True
+ if pageId == 'view':
+ max = self.mapWindow.view['z-exag']['value'] * 10
+ hmin = self.mapWindow.iview['height']['min']
+ hmax = self.mapWindow.iview['height']['max']
+ for control in ('spin', 'slider'):
+ self.FindWindowById(self.win['view']['z-exag'][control]).SetRange(1,
+ max)
+ self.FindWindowById(self.win['view']['height'][control]).SetRange(hmin,
+ hmax)
+ elif pageId == 'surface':
+ if self.notebook.GetSelection() != self.page['surface']['id']:
+ for page in ('vector', 'volume'):
+ if self.page[page]['id'] > -1:
+ self.notebook.RemovePage(self.page[page]['id'])
+ self.page[page]['id'] = -1
+ self.page['surface']['id'] = 1
+ self.page['settings']['id'] = 2
+ panel = wx.FindWindowById(self.page['surface']['panel'])
+ self.notebook.InsertPage(n=self.page['surface']['id'],
+ page=panel,
+ text=" %s " % _("Layer properties"),
+ select=True)
+ self.UpdateSurfacePage(layer, data['surface'])
+ elif pageId == 'vector':
+ if self.notebook.GetSelection() != self.page['vector']['id']:
+ for page in ('surface', 'volume'):
+ self.page['vector']['id'] = 1
+ panel = wx.FindWindowById(self.page['vector']['panel'])
+ self.notebook.InsertPage(n=self.page['vector']['id'],
+ page=panel,
+ select=True)
+ self.UpdateVectorPage(layer, data['vector'])
+ elif pageId == 'volume':
+ if self.notebook.GetSelection() != self.page['volume']['id']:
+ for page in ('surface', 'vector'):
+ self.page['volume']['id'] = 1
+ panel = wx.FindWindowById(self.page['volume']['panel'])
+ self.notebook.InsertPage(n=self.page['volume']['id'],
+ page=panel,
+ select=True)
+ self.UpdateVolumePage(layer, data['volume'])
+ def UpdateSurfacePage(self, layer, data):
+ # attributes
+ for attr in ('topo', 'color'): # required
+ if layer and layer.type == 'raster':
+ self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
+ else:
+ self.FindWindowById(self.win['surface'][attr]['map']).SetValue('')
+ attrb=attr, map=True) # -> map
+ if data['attribute'].has_key('color'):
+ value = data['attribute']['color']['value']
+ if data['attribute']['color']['map']:
+ self.FindWindowById(self.win['surface']['color']['map']).SetValue(value)
+ else: # constant
+ color = map(int, value.split(':'))
+ self.FindWindowById(self.win['surface']['color']['const']).SetColour(color)
+ attrb=attr, map=data['attribute']['color']['map'])
+ attrb='shine', map=data['attribute']['shine']['map'])
+ value = data['attribute']['shine']['value']
+ if data['attribute']['shine']['map']:
+ self.FindWindowById(self.win['surface']['shine']['map']).SetValue(value)
+ else:
+ self.FindWindowById(self.win['surface']['shine']['const']).SetValue(value)
+ # draw
+ for control, dict in data['draw'].iteritems():
+ if control == 'all': # skip 'all' property
+ continue
+ if control == 'resolution':
+ self.FindWindowById(self.win['surface']['draw']['res-coarse']).SetValue(dict['coarse'])
+ self.FindWindowById(self.win['surface']['draw']['res-fine']).SetValue(dict['fine'])
+ continue
+ if control == 'mode':
+ if dict['desc']['mode'] == 'coarse':
+ self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(0)
+ elif dict['desc']['mode'] == 'fine':
+ self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(1)
+ else: # both
+ self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(2)
+ if dict['desc']['style'] == 'wire':
+ self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(0)
+ else: # surface
+ self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(1)
+ if dict['desc']['shading'] == 'flat':
+ self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(0)
+ else: # gouraud
+ self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(1)
+ continue
+ value = dict['value']
+ win = self.FindWindowById(self.win['surface']['draw'][control])
+ name = win.GetName()
+ if name == "selection":
+ win.SetSelection(value)
+ elif name == "colour":
+ win.SetColour(color)
+ else:
+ # enable/disable res widget + set draw mode
+ self.SetSurfaceMode()
+ color = self.FindWindowById(self.win['surface']['draw']['wire-color'])
+ def UpdateVectorPage(self, layer, data):
+ vInfo = gcmd.Command(['v.info',
+ 'map=%s' % layer.name])
+ npoints = nprimitives = 0
+ for line in vInfo.ReadStdOutput():
+ if 'Map is 3D' in line:
+ mapIs3D = int(line.replace('|', '').split(':')[1].strip())
+ elif 'Number of points' in line:
+ npoints = int(line.replace('|', '').split(':')[1].strip().split(' ')[0])
+ nprimitives = npoints
+ elif 'Number of lines' in line:
+ nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0])
+ elif 'Number of boundaries' in line:
+ nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0]) # boundaries
+ nprimitives += int(line.replace('|', '').split(':')[2].strip()) # faces
+ elif 'Number of centroids' in line:
+ nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0]) # centroids
+ nprimitives += int(line.replace('|', '').split(':')[2].strip()) # kernels
+ if mapIs3D:
+ desc = _("Vector map <%s> is 3D") % layer.name
+ enable = False
+ else:
+ desc = _("Vector map <%s> is 2D") % layer.name
+ enable = True
+ desc += " - " + _("%d primitives (%d points)") % (nprimitives, npoints)
+ self.FindWindowById(self.win['vector']['lines']['flat']).Enable(enable)
+ for v in ('lines', 'points'):
+ self.FindWindowById(self.win['vector'][v]['surface']).Enable(enable)
+ self.FindWindowById(self.win['vector'][v]['height']['slider']).Enable(enable)
+ self.FindWindowById(self.win['vector'][v]['height']['spin']).Enable(enable)
+ self.FindWindowById(self.win['vector']['desc']).SetLabel(desc)
+ # lines
+ showLines = self.FindWindowById(self.win['vector']['lines']['show'])
+ if data['lines'].has_key('object'):
+ showLines.SetValue(True)
+ else:
+ showLines.SetValue(False)
+ if nprimitives - npoints > 0:
+ showLines.Enable(True)
+ else:
+ showLines.Enable(False)
+ self.UpdateVectorShow('lines',
+ showLines.IsChecked())
+ width.SetValue(data['lines']['width'])
+ color.SetValue(map(int, data['lines']['color'].split(':')))
+ for vtype in ('lines', 'points'):
+ if vtype == 'lines':
+ display = self.FindWindowById(self.win['vector']['lines']['flat'])
+ if data[vtype]['mode']['type'] == 'flat':
+ display.SetSelection(1)
+ else:
+ display.SetSelection(0)
+ if data[vtype]['mode']['type'] == 'surface' and \
+ len(self.mapWindow.layers['raster']['name']) > 0:
+ surface = self.FindWindowById(self.win['vector'][vtype]['surface'])
+ surface.SetItems(self.mapWindow.layers['raster']['name'])
+ surface.SetStringSelection(data[vtype]['mode']['surface'])
+ for type in ('slider', 'spin'):
+ win = self.FindWindowById(self.win['vector']['lines']['height'][type])
+ win.SetValue(data['lines']['height'])
+ # points
+ showPoints = self.FindWindowById(self.win['vector']['points']['show'])
+ if data['points'].has_key('object'):
+ showPoints.SetValue(True)
+ else:
+ showPoints.SetValue(False)
+ if npoints > 0:
+ showPoints.Enable(True)
+ else:
+ showPoints.Enable(False)
+ self.UpdateVectorShow('points',
+ showPoints.IsChecked())
+ # size, width, marker, color
+ win = self.FindWindowById(self.win['vector']['points'][prop])
+ if name == 'selection':
+ win.SetSelection(data['points'][prop])
+ elif name == 'color':
+ color = map(int, data['points'][prop].split(':'))
+ win.SetValue(color)
+ else:
+ win.SetValue(data['points'][prop])
+ # height
+ win = self.FindWindowById(self.win['vector']['points']['height'][type])
+ win.SetValue(data['points']['height'])
+ def UpdateVolumePage(self, layer, data):
+ """Update volume layer properties page"""
+ # draw
+ continue
+ win = self.FindWindowById(self.win['volume']['draw'][control])
+ if control == 'shading':
+ if data['draw']['shading']['desc'] == 'flat':
+ value = 0
+ else:
+ value = 1
+ else:
+ else:
+ self.SetIsosurfaceMode(data['draw']['shading']['value'])
+ self.SetIsosurfaceResolution(data['draw']['resolution']['value'])
+ # isosurface attributes
+ for attr in ('color', ): # required
+ if layer and layer.type == '3d-raster':
+ self.FindWindowById(self.win['volume'][attr]['map']).SetValue(layer.name)
+ else:
+ self.FindWindowById(self.win['volume'][attr]['map']).SetValue('')
+ self.FindWindowById(self.win['volume']['color']['map']).SetValue(value)
+ else: # constant
+ self.FindWindowById(self.win['volume']['color']['const']).SetColour(color)
+ self.FindWindowById(self.win['volume']['shine']['map']).SetValue(value)
+ else:
+ self.FindWindowById(self.win['volume']['shine']['const']).SetValue(value)
+ def SetPage(self, name):
+ """Get named page"""
+ self.notebook.SetSelection(self.page[name]['id'])
+class ViewPositionWindow(wx.Window):
+ """Position control window (for NvizToolWindow)"""
+ def __init__(self, parent, id, mapwindow,
+ size=wx.DefaultSize):
+ self.mapWindow = mapwindow
+ wx.Window.__init__(self, parent, id, pos, size)
+ self.SetBackgroundColour("WHITE")
+ self.pdc = wx.PseudoDC()
+ self.pdc.SetBrush(wx.Brush(colour='dark green', style=wx.SOLID))
+ self.pdc.SetPen(wx.Pen(colour='dark green', width=2, style=wx.SOLID))
+ self.Draw()
+ self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x: None)
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ # self.Bind(wx.EVT_MOTION, self.OnMouse)
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouse)
+ def Draw(self, pos=None):
+ w, h = self.GetClientSize()
+ if pos is None:
+ x = self.mapWindow.view['pos']['x']
+ y = self.mapWindow.view['pos']['y']
+ x = x * w
+ y = y * h
+ else:
+ x, y = pos
+ self.pdc.Clear()
+ self.pdc.BeginDrawing()
+ self.pdc.DrawLine(w / 2, h / 2, x, y)
+ self.pdc.DrawCircle(x, y, 5)
+ self.pdc.EndDrawing()
+ def OnPaint(self, event):
+ dc = wx.BufferedPaintDC(self)
+ dc.SetBackground(wx.Brush("White"))
+ dc.Clear()
+ self.PrepareDC(dc)
+ self.pdc.DrawToDC(dc)
+ def OnMouse(self, event):
+ if event.LeftIsDown():
+ x, y = event.GetPosition()
+ self.Draw(pos=(x, y))
+ self.Refresh(False)
+ x = float(x) / w
+ y = float(y) / h
+ if x >= 0 and x <= 1.0:
+ self.mapWindow.view['pos']['x'] = x
+ if y >= 0 and y <= 1.0:
+ self.mapWindow.view['pos']['y'] = y
+ self.mapWindow.Refresh(eraseBackground=False)
+ elif event.LeftUp():
+ event.Skip()
+class IsoSurfList(wx.CheckListBox):
+ """List of loaded volume isosurfaces (volume properties page)"""
+ def __init__(self, parent, win, id=wx.ID_ANY, size=wx.DefaultSize):
+ self.parent = parent
+ self.win = win
+ wx.CheckListBox.__init__(self, parent, id, size=size)
+ self.Bind(wx.EVT_CHECKLISTBOX, self.OnCheck)
+ self.Bind(wx.EVT_LISTBOX, self.OnSelect)
+ def OnCheck(self, event):
+ """Item checked/unchecked -> load/delete surface"""
+ print event.IsChecked()
+ def OnSelect(self, event):
+ """Item selected"""
+ winUp = self.parent.FindWindowById(self.win['btnIsosurfMoveUp'])
+ winDown = self.parent.FindWindowById(self.win['btnIsosurfMoveDown'])
+ winUp.Enable(False)
+ if not winDown.IsEnabled():
+ winDown.Enable()
+ elif selection == self.GetCount() - 1:
+ winDown.Enable(False)
+ if not winUp.IsEnabled():
+ winUp.Enable()
+ else:
+ winDown.Enable()
+ winUp.Enable()
Property changes on: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
+ Author Date Id
+ native
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-08-15 20:05:46 UTC (rev 32788)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -1722,7 +1722,7 @@
text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
initial=UserSettings.Get(group='vdigit', key="snapping", subkey='value'),
- min=0, max=1e6)
+ min=-1, max=1e6)
self.snappingValue.Bind(wx.EVT_SPINCTRL, self.OnChangeSnappingValue)
self.snappingUnit = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
choices=["screen pixels", "map units"])
@@ -2073,6 +2073,10 @@
"""Change snapping value - update static text"""
value = self.snappingValue.GetValue()
+ if value < 0:
+ self.snappingInfo.SetLabel(_("No limit for snapping"))
+ return
if self.snappingUnit.GetStringSelection() == "map units":
threshold = value
else:
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-15 20:05:46 UTC (rev 32788)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -344,18 +344,21 @@
"""Set computational region from selected raster/vector map"""
mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
mltype = self.GetPyData(self.layer_selected)[0]['type']
- cmd = ['g.region',
- '-p'] # print by default
+ cmd = ['g.region']
# TODO: other elements
if mltype == 'raster':
cmd.append('rast=%s' % mapLayer.name)
elif mltype == 'vector':
cmd.append('vect=%s' % mapLayer.name)
+ elif mltype == '3d-raster':
+ cmd.append('rast3d=%s' % mapLayer.name)
# print output to command log area
- self.gismgr.goutput.RunCmd(cmd)
+ if len(cmd) > 1:
+ cmd.append('-p')
+ self.gismgr.goutput.RunCmd(cmd)
def OnProfile(self, event):
"""Plot profile of given raster map layer"""
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-08-15 20:05:46 UTC (rev 32788)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-08-15 20:11:04 UTC (rev 32789)
@@ -85,6 +85,7 @@
import gui_modules.workspace as workspace
import gui_modules.goutput as goutput
import gui_modules.gdialogs as gdialogs
+import gui_modules.colorrules as colorrules
from gui_modules.debug import Debug as Debug
from icons.icon import Icons as Icons
@@ -868,6 +869,7 @@
self.disp_idx = 0
self.curr_page = None
def RulesCmd(self, event):
@@ -875,33 +877,32 @@
input and processes rules
command = self.GetMenuCmd(event)
- dlg = rules.RulesText(self, cmd=command)
- if dlg.ShowModal() == wx.ID_OK:
- gtemp = utils.GetTempfile()
- output = open(gtemp, "w")
- try:
- output.write(dlg.rules)
- finally:
- output.close()
- if command[0] == 'r.colors':
+ if command[0] == 'r.colors':
+ ctable = colorrules.ColorTable(self, cmd=command)
+ ctable.Show()
+ else:
+ dlg = rules.RulesText(self, cmd=command)
+ if dlg.ShowModal() == wx.ID_OK:
+ gtemp = utils.GetTempfile()
+ output = open(gtemp, "w")
+ try:
+ output.write(dlg.rules)
+ finally:
+ output.close()
cmdlist = [command[0],
- 'map=%s' % dlg.inmap,
- 'rules=%s' % gtemp]
- else:
- cmdlist = [command[0],
'input=%s' % dlg.inmap,
'output=%s' % dlg.outmap,
'rules=%s' % gtemp]
+ if dlg.overwrite == True:
+ cmdlist.append('--o')
+ dlg.Destroy()
+ self.goutput.RunCmd(cmdlist)
- if dlg.overwrite == True:
- cmdlist.append('--o')
- dlg.Destroy()
- self.goutput.RunCmd(cmdlist)
def OnXTerm(self, event):
Run commands that need interactive xmon
