[GRASS-SVN] r32797 - grass-addons/vector/v.parallel2
Fri Aug 15 18:52:05 EDT 2008
Author: rmatev
Date: 2008-08-15 18:52:05 -0400 (Fri, 15 Aug 2008)
New Revision: 32797
   grass-addons/vector/v.parallel2/dgraph.c
   grass-addons/vector/v.parallel2/e_intersect.c
   grass-addons/vector/v.parallel2/vlib_buffer.c
Modified: grass-addons/vector/v.parallel2/dgraph.c
--- grass-addons/vector/v.parallel2/dgraph.c	2008-08-15 22:51:35 UTC (rev 32796)
+++ grass-addons/vector/v.parallel2/dgraph.c	2008-08-15 22:52:05 UTC (rev 32797)
@@ -183,7 +183,7 @@
     double *x, *y;
     double x1, y1, x2, y2;
     int res, res2;
-    double x1_, y1_, x2_, y2_;
+    double x1_, y1_, x2_, y2_, z1_, z2_;
     struct seg_intersections *si;
     struct seg_intersection_list *il;
     struct intersection_point **sorted;
@@ -204,11 +204,12 @@
         for (j = i+1; j < np-1; j++) {
             G_debug(3, "        checking %d-%d %d-%d", i, i+1, j, j+1);
             res = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
-/*            res = segment_intersection_2d(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2, EPSILON);*/
-/*            res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
-            if (res != res2) {
-                G_debug(0, "res=%d res2=%d", res, res2);
+            /*res2 = segment_intersection_2d(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_, EPSILON);*/
+            res2 = Vect_segment_intersection(x[i], y[i], 0, x[i+1], y[i+1], 0, x[j], y[j], 0, x[j+1], y[j+1], 0, &x1_, &y1_, &z1_, &x2_, &y2_, &z2_, 0);
+            if ((res != res2) /*|| ((res != 0) && (x1!=x1_ || y1!=y1_))*/ ) {
+                G_debug(0, "exact=%d orig=%d", res, res2);
+                segment_intersection_2d_test(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
             G_debug(3, "        intersection type = %d", res);
             if (res == 1) {
Modified: grass-addons/vector/v.parallel2/e_intersect.c
--- grass-addons/vector/v.parallel2/e_intersect.c	2008-08-15 22:51:35 UTC (rev 32796)
+++ grass-addons/vector/v.parallel2/e_intersect.c	2008-08-15 22:52:05 UTC (rev 32797)
@@ -8,6 +8,7 @@
 mpf_t p11, p12, p21, p22, t1, t2;
 mpf_t dd, dda, ddb, delta;
+mpf_t rra, rrb;
 int initialized = 0;
@@ -27,6 +28,9 @@
     mpf_init(ddb);
     mpf_init(delta);
+    mpf_init(rra);
+    mpf_init(rrb);
     initialized = 1;
@@ -162,8 +166,8 @@
-        G_debug(3, "        ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd));
-        G_debug(3, "        sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd));
+        /*G_debug(3, "        ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd));*/
+        /*G_debug(3, "        sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd));*/
         mpf_set_d(delta, ax2 - ax1);
         mpf_mul(t1, dda, delta);
@@ -335,21 +339,21 @@
     d1 = (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2);
     d2 = (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1);
-    G_debug(2, "    d  = %.18f", d);
-    G_debug(2, "    d1 = %.18f", d1);
-    G_debug(2, "    d2 = %.18f", d2);
+    G_debug(2, "    d  = %.18g", d);
+    G_debug(2, "    d1 = %.18g", d1);
+    G_debug(2, "    d2 = %.18g", d2);
     tola = tol/fmax(fabs(ax2-ax1), fabs(ay2-ay1));
     tolb = tol/fmax(fabs(bx2-bx1), fabs(by2-by1));
-    G_debug(2, "    tol  = %.18f", tol);
-    G_debug(2, "    tola = %.18f", tola);
-    G_debug(2, "    tolb = %.18f", tolb);
+    G_debug(2, "    tol  = %.18g", tol);
+    G_debug(2, "    tola = %.18g", tola);
+    G_debug(2, "    tolb = %.18g", tolb);
     if (!FZERO(d, tol)) {
         ra = d1/d;
         rb = d2/d;
-        G_debug(2, "    not parallel/collinear: ra = %.18f", ra);
-        G_debug(2, "                            rb = %.18f", rb);
+        G_debug(2, "    not parallel/collinear: ra = %.18g", ra);
+        G_debug(2, "                            rb = %.18g", rb);
         if ((ra <= -tola) || (ra >= 1+tola) || (rb <= -tolb) || (rb >= 1+tolb)) {
             G_debug(2, "        no intersection");
@@ -563,3 +567,132 @@
     frexp(a-b, &e);
     return (e < ea-N+bits);
+int segment_intersection_2d_test(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2, double *x1, double *y1, double *x2, double *y2) {
+    double t;
+    double max_ax, min_ax, max_ay, min_ay;
+    double max_bx, min_bx, max_by, min_by;
+    int sgn_d, sgn_da, sgn_db;
+    int vertical;
+    int f11, f12, f21, f22;
+    mp_exp_t exp;
+    char *s;
+    double d, da, db, ra, rb;
+    if (!initialized)
+        initialize_mpf_vars();
+    /* TODO: Works for points ? */
+    G_debug(0, "segment_intersection_2d_test()");
+    G_debug(0, "    ax1  = %.18e, ay1  = %.18e", ax1, ay1);
+    G_debug(0, "    ax2  = %.18e, ay2  = %.18e", ax2, ay2);
+    G_debug(0, "    bx1  = %.18e, by1  = %.18e", bx1, by1);
+    G_debug(0, "    bx2  = %.18e, by2  = %.18e", bx2, by2);
+    f11 = ((ax1 == bx1) && (ay1 == by1));
+    f12 = ((ax1 == bx2) && (ay1 == by2));
+    f21 = ((ax2 == bx1) && (ay2 == by1));
+    f22 = ((ax2 == bx2) && (ay2 == by2));
+    /* Check for identical segments */
+    if ((f11 && f22) || (f12 && f21)) {
+        G_debug (0, "    identical segments" );
+        *x1 = ax1; *y1 = ay1;
+        *x2 = ax2; *y2 = ay2;
+        return 5;
+    /* Check for identical endpoints */
+    if (f11 || f12) {
+        G_debug (0, "    connected by endpoints" );
+        return 1;
+    if (f21 || f22) {
+        *x1 = ax2; *y1 = ay2;
+        return 1;
+    if ((fmax(ax1, ax2) < fmin(bx1, bx2)) || (fmax(bx1, bx2) < fmin(ax1, ax2))) {
+        G_debug(0, "    no intersection (disjoint bounding boxes)");
+        return 0;
+    if ((fmax(ay1, ay2) < fmin(by1, by2)) || (fmax(by1, by2) < fmin(ay1, ay2))) {
+        return 0;
+    d  = (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2);
+    da = (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2);
+    db = (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1);
+    det22(dd,  ax2, ax1, bx1, bx2, ay2, ay1, by1, by2);
+    sgn_d = mpf_sgn(dd);
+    s = mpf_get_str(NULL, &exp, 10, 40, dd);
+    G_debug(0, "    dd = %sE%d", (s[0]==0)?"0":s, exp);
+    G_debug(0, "    d = %.18E", d);
+    if (sgn_d != 0) {
+        G_debug(0, "    general position");
+        det22(dda, bx1, ax1, bx1, bx2, by1, ay1, by1, by2);
+        det22(ddb, ax2, ax1, bx1, ax1, ay2, ay1, by1, ay1);
+        sgn_da = mpf_sgn(dda);
+        sgn_db = mpf_sgn(ddb);
+        ra = da/d;
+        rb = db/d;
+        mpf_div(rra, dda, dd);
+        mpf_div(rrb, ddb, dd);
+        s = mpf_get_str(NULL, &exp, 10, 40, rra);
+        G_debug(0, "        rra = %sE%d", (s[0]==0)?"0":s, exp);
+        G_debug(0, "        ra = %.18E", ra);
+        s = mpf_get_str(NULL, &exp, 10, 40, rrb);
+        G_debug(0, "        rrb = %sE%d", (s[0]==0)?"0":s, exp);
+        G_debug(0, "        rb = %.18E", rb);
+        if (sgn_d > 0) {
+            if ((sgn_da < 0) || (mpf_cmp(dda, dd) > 0)) {
+                G_debug(3, "        no intersection");
+                return 0;
+            if ((sgn_db < 0) || (mpf_cmp(ddb, dd) > 0)) {
+                return 0;
+        else { /* if sgn_d < 0 */
+            if ((sgn_da > 0) || (mpf_cmp(dda, dd) < 0)) {
+                return 0;
+            if ((sgn_db > 0) || (mpf_cmp(ddb, dd) < 0)) {
+                return 0;
+        mpf_set_d(delta, ax2 - ax1);
+        mpf_mul(t1, dda, delta);
+        mpf_div(t2, t1, dd);
+        *x1 = ax1 + mpf_get_d(t2);
+        mpf_set_d(delta, ay2 - ay1);
+        *y1 = ay1 + mpf_get_d(t2);
+        G_debug(0, "        intersection at:");
+        G_debug(0, "            xx = %.18e", *x1);
+        G_debug(0, "             x = %.18e", ax1 + ra*(ax2-ax1));
+        G_debug(0, "            yy = %.18e", *y1);
+        G_debug(0, "             y = %.18e", ay1 + ra*(ay2-ay1));
+        return 1;
+    G_debug(0, "    parallel/collinear...");
+    return -1;
\ No newline at end of file
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c	2008-08-15 22:51:35 UTC (rev 32796)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c	2008-08-15 22:52:05 UTC (rev 32797)
@@ -156,7 +156,7 @@
     double phi1, phi2, delta_phi;
     double nsegments, angular_tol, angular_step;
     double cosa, sina, r;
-    int inner_corner, turns180;
+    int inner_corner, turns360;
     G_debug(4, "parallel_line()");
@@ -219,10 +219,10 @@
         else if (delta_phi <= -PI)
             delta_phi += 2*PI;
         /* now delta_phi is in [-pi;pi] */
-        turns180 = (fabs(fabs(delta_phi) - PI) < 1e-15);
-        inner_corner = (side*delta_phi <= 0) && (!turns180);
+        turns360 = (fabs(fabs(delta_phi) - PI) < 1e-15);
+        inner_corner = (side*delta_phi <= 0) && (!turns360);
-        if ((turns180) && (!(caps && round))) {
+        if ((turns360) && (!(caps && round))) {
             if (caps) {
                 norm_vector(0, 0, vx, vy, &tx, &ty);
                 elliptic_tangent(side*tx, side*ty, da, db, dalpha, &tx, &ty);
@@ -305,7 +305,7 @@
     double angle0, angle1;
     G_debug(4, "convolution_line()");
@@ -371,12 +371,12 @@
             delta_phi += 2*PI;
-        /* if <line turns 180> and (<caps> and <not round>) */
-        if (turns180 && caps && (!round)) {
+        /* if <line turns 360> and (<caps> and <not round>) */
+        if (turns360 && caps && (!round)) {
             Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
@@ -385,17 +385,20 @@
             G_debug(4, " append point (c) x=%.16f y=%.16f", nx + tx, ny + ty);
-        if ((!turns180) && (!round) && (!inner_corner)) {
+        if ((!turns360) && (!round) && (!inner_corner)) {
             res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
             if (res == 1) {
                 Vect_append_point(nPoints, rx, ry, 0);
                 G_debug(4, " append point (o) x=%.16f y=%.16f", rx, ry);
+            else if (res == 2) {
+                /* no need to append point in this case */
             else
-                G_fatal_error("unexpected result of line_intersection()");
+                G_fatal_error("unexpected result of line_intersection() res = %d", res);
-        if (round && (!inner_corner)) {
+        if (round && (!inner_corner) && (!turns360 || caps)) {
             /* we should draw elliptical arc for outside corner */
             /* inverse transforms */
