[GRASS-SVN] r32832 - grass/trunk/gui/wxpython/gui_modules
Sun Aug 17 01:46:17 EDT 2008
Author: cmbarton
Date: 2008-08-17 01:46:17 -0400 (Sun, 17 Aug 2008)
New Revision: 32832
   grass/trunk/gui/wxpython/gui_modules/render.py
Backport from develbranch_6. Bug fix for layering rendering problem.
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2008-08-17 05:43:51 UTC (rev 32831)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2008-08-17 05:46:17 UTC (rev 32832)
@@ -30,6 +30,7 @@
     compatPath = os.path.join(globalvar.ETCWXDIR, "compat")
     sys.path.append(compatPath)
     import subprocess
+import tempfile
 import wx
@@ -80,8 +81,15 @@
                         self.opacity, self.hidden))
         # generated file for layer
-        self.gtemp = utils.GetTempfile()
+        #self.gtemp = utils.GetTempfile()
+        #self.gtemp = os.tmpfile()
+        #self.maskfile = self.gtemp + ".pgm"
+        self.gtemp = tempfile.mkstemp()[1]
+        if self.type == 'overlay':
+            self.mapfile  = self.gtemp + ".png"
+        else:
+            self.mapfile  = self.gtemp + ".ppm"
     def __del__(self):
         Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
@@ -106,13 +114,14 @@
         # to be sure, set temporary file with layer and mask
-        if not self.gtemp:
-            gtemp = utils.GetTempfile()
-            self.maskfile = gtemp + ".pgm"
-            if self.type == 'overlay':
-                self.mapfile  = gtemp + ".png"
-            else:
-                self.mapfile  = gtemp + ".ppm"
+        #if not self.gtemp:
+        #gtemp = utils.GetTempfile()
+        #gtemp = tempfile.mkstemp()[1]
+        #self.maskfile = gtemp + ".pgm"
+        #if self.type == 'overlay':
+        #    self.mapfile  = gtemp + ".png"
+        #else:
+        #    self.mapfile  = gtemp + ".ppm"
         # prepare command for each layer
@@ -138,7 +147,7 @@
         else:
             if self.mapfile:
                 os.environ["GRASS_PNGFILE"] = self.mapfile
         # execute command
@@ -274,7 +283,7 @@
         Layer.__init__(self, type, cmd, name,
                        active, hidden, opacity)
-        self.mapfile = self.gtemp + ".ppm"
+        #self.mapfile = self.gtemp + ".ppm"
     def GetMapset(self):
@@ -308,7 +317,7 @@
         self.id = id
-        self.mapfile = self.gtemp + ".png"
+        #self.mapfile = self.gtemp + ".png"
 class Map(object):
@@ -838,31 +847,31 @@
             Debug.msg (3, "Map.Render() type=%s, layer=%s " % (layer.type, layer.name))
-	# ugly hack for MSYS
-	if not subprocess.mswindows:
-	    mapstr = ",".join(maps)
-	    maskstr = ",".join(masks)
+        # ugly hack for MSYS
+        if not subprocess.mswindows:
+            mapstr = ",".join(maps)
+            maskstr = ",".join(masks)
             mapoutstr = self.mapfile
-	else:
-	    mapstr = ""
-	    for item in maps:
+        else:
+            mapstr = ""
+            for item in maps:
                 mapstr += item.replace('\\', '/')
-	    mapstr = mapstr.rstrip(',')
-	    maskstr = ""
+            mapstr = mapstr.rstrip(',')
+            maskstr = ""
             for item in masks:
-		maskstr += item.replace('\\', '/')
-	    maskstr = maskstr.rstrip(',')
-	    mapoutstr = self.mapfile.replace('\\', '/')
+                maskstr += item.replace('\\', '/')
+            maskstr = maskstr.rstrip(',')
+            mapoutstr = self.mapfile.replace('\\', '/')
         # compose command
         complist = ["g.pnmcomp",
-                   "in=%s" % ",".join(maps),
-	           "mask=%s" % ",".join(masks),
-                   "opacity=%s" % ",".join(opacities),
-                   "background=255:255:255",
-                   "width=%s" % str(self.width),
-                   "height=%s" % str(self.height),
-                   "output=%s" % self.mapfile]
+                    "in=%s" % ",".join(maps),
+                    "mask=%s" % ",".join(masks),
+                    "opacity=%s" % ",".join(opacities),
+                    "background=255:255:255",
+                    "width=%s" % str(self.width),
+                    "height=%s" % str(self.height),
+                    "output=%s" % self.mapfile]
         # render overlays
