[GRASS-SVN] r32849 - in grass/trunk/gui/wxpython: gui_modules nviz
svn_grass at osgeo.org
Sun Aug 17 17:51:16 EDT 2008
Author: martinl
Date: 2008-08-17 17:51:15 -0400 (Sun, 17 Aug 2008)
New Revision: 32849
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/nviz/nviz.h
grass/trunk/gui/wxpython/nviz/volume.cpp
wxGUI/nviz2: better isosurface draw mode support, added methods to change isosurface attributes
(merge from devbr6, r32848)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2008-08-17 21:39:32 UTC (rev 32848)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2008-08-17 21:51:15 UTC (rev 32849)
@@ -400,7 +400,7 @@
for sec in data.keys():
for sec1 in data[sec].keys():
for sec2 in data[sec][sec1].keys():
- if sec2 not in ('object'):
+ if sec2 not in ('object', 'all'):
data[sec][sec1][sec2]['update'] = None
event = wxUpdateProperties(data=data)
@@ -1059,14 +1059,11 @@
if attrb == 'mask':
# TODO: invert mask
# TODO: broken in NVIZ
- # self.nvizClass.UnsetSurfaceMask(id)
- pass
+ self.nvizClass.UnsetIsosurfaceMask(id, isosurfId)
elif attrb == 'transp':
- # self.nvizClass.UnsetSurfaceTransp(id)
- pass
+ self.nvizClass.UnsetIsosurfaceTransp(id, isosurfId)
elif attrb == 'emit':
- # self.nvizClass.UnsetSurfaceEmit(id)
- pass
+ self.nvizClass.UnsetIsosurfaceEmit(id, isosurfId)
else:
if type(value) == type('') and \
len(value) <= 0: # ignore empty values (TODO: warning)
@@ -1076,17 +1073,13 @@
elif attrb == 'mask':
# TODO: invert mask
- # self.nvizClass.SetSurfaceMask(id, False, str(value))
- pass
+ self.nvizClass.SetIsosurfaceMask(id, isosurfId, False, str(value))
- # self.nvizClass.SetSurfaceTransp(id, map, str(value))
- pass
+ self.nvizClass.SetIsosurfaceTransp(id, isosurfId, map, str(value))
elif attrb == 'shine':
- # self.nvizClass.SetSurfaceShine(id, map, str(value))
- pass
+ self.nvizClass.SetIsosurfaceShine(id, isosurfId, map, str(value))
- # self.nvizClass.SetSurfaceEmit(id, map, str(value))
- pass
+ self.nvizClass.SetIsosurfaceEmit(id, isosurfId, map, str(value))
isosurf[attrb].pop('update')
isosurfId += 1
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-08-17 21:39:32 UTC (rev 32848)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-08-17 21:51:15 UTC (rev 32849)
@@ -6,7 +6,6 @@
Classes:
- NvizToolWindow
- ViewPositionWindow
- - IsoSurfList
(C) 2008 by the GRASS Development Team
@@ -797,8 +796,11 @@
gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
# list
- isolevel = IsoSurfList(parent=panel, win=self.win['volume'],
- size=(300, 150))
+ isolevel = wx.CheckListBox(parent=panel, id=wx.ID_ANY,
+ size=(300, 150))
+ self.Bind(wx.EVT_CHECKLISTBOX, self.OnVolumeIsosurfCheck, isolevel)
+ self.Bind(wx.EVT_LISTBOX, self.OnVolumeIsosurfSelect, isolevel)
self.win['volume']['isosurfs'] = isolevel.GetId()
gridSizer.Add(item=isolevel, pos=(0, 0), span=(4, 1))
@@ -905,8 +907,8 @@
value.SetRange(minVal=0, maxVal=255)
else:
value.SetRange(minVal=0, maxVal=100)
- value.Bind(wx.EVT_SPINCTRL, self.OnSurfaceMap)
- value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+ value.Bind(wx.EVT_SPINCTRL, self.OnVolumeIsosurfMap)
+ value.Bind(wx.EVT_TEXT, self.OnVolumeIsosurfMap)
if value:
self.win['volume'][code]['const'] = value.GetId()
@@ -1613,6 +1615,9 @@
if not attrb:
return
+ if nvizType == 'volume' and attrb == 'topo':
+ return
selection = self.FindWindowById(self.win[nvizType][attrb]['use']).GetSelection()
if self.win[nvizType][attrb]['required']:
selection += 1
@@ -2063,7 +2068,50 @@
def OnVolumeIsosurfMap(self, event):
"""Set surface attribute"""
self.SetMapObjAttrb(nvizType='volume', winId=event.GetId())
+ def OnVolumeIsosurfCheck(self, event):
+ """Isosurface checked (->load) or unchecked (->unload)"""
+ index = event.GetSelection()
+ list = self.FindWindowById(self.win['volume']['isosurfs'])
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['volume']
+ id = data['object']['id']
+ isosurfId = event.GetSelection()
+ if list.IsChecked(index):
+ self.mapWindow.nvizClass.SetIsosurfaceTransp(id, isosurfId, False, "0")
+ else:
+ # disable -> make transparent
+ self.mapWindow.nvizClass.SetIsosurfaceTransp(id, isosurfId, False, "255")
+ if self.parent.autoRender.IsChecked():
+ self.mapWindow.Refresh(False)
+ def OnVolumeIsosurfSelect(self, event):
+ """Isosurface item selected"""
+ winUp = self.FindWindowById(self.win['volume']['btnIsosurfMoveUp'])
+ winDown = self.FindWindowById(self.win['volume']['btnIsosurfMoveDown'])
+ selection = event.GetSelection()
+ if selection == 0:
+ winUp.Enable(False)
+ if not winDown.IsEnabled():
+ winDown.Enable()
+ elif selection == self.FindWindowById(event.GetId()).GetCount() - 1:
+ winDown.Enable(False)
+ if not winUp.IsEnabled():
+ winUp.Enable()
+ else:
+ winDown.Enable()
+ winUp.Enable()
+ # update dialog
+ layer = self.mapWindow.GetSelectedLayer()
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['volume']['isosurface'][selection]
+ self.UpdateVolumeIsosurfPage(layer, data)
def OnVolumeIsosurfAdd(self, event):
"""Add new isosurface to the list"""
@@ -2499,36 +2547,50 @@
self.SetIsosurfaceMode(data['draw']['shading']['value'])
self.SetIsosurfaceResolution(data['draw']['resolution']['value'])
+ self.UpdateVolumeIsosurfPage(layer, data['attribute'])
+ def UpdateVolumeIsosurfPage(self, layer, data):
+ """Update dialog -- isosurface attributes"""
# isosurface attributes
- for attr in ('color', ): # required
- if layer and layer.type == '3d-raster':
- self.FindWindowById(self.win['volume'][attr]['map']).SetValue(layer.name)
+ for attrb in ('topo', 'color', 'mask',
+ 'transp', 'shine', 'emit'):
+ # check required first
+ if attrb == 'topo':
+ self.FindWindowById(self.win['volume'][attrb]['const']).SetValue(0)
+ continue
+ if attrb == 'color':
+ if layer and layer.type == '3d-raster':
+ self.FindWindowById(self.win['volume'][attrb]['map']).SetValue(layer.name)
+ else:
+ self.FindWindowById(self.win['volume'][attrb]['map']).SetValue('')
+ self.SetMapObjUseMap(nvizType='volume',
+ attrb=attrb, map=True) # -> map
+ continue
+ # skip empty attributes
+ if not data.has_key(attrb):
+ continue
+ value = data[attrb]['value']
+ if data[attrb]['map']:
+ self.FindWindowById(self.win['volume'][attrb]['map']).SetValue(value)
+ else: # constant
+ color = map(int, value.split(':'))
+ self.FindWindowById(self.win['volume'][attrb]['const']).SetColour(color)
else:
- self.FindWindowById(self.win['volume'][attr]['map']).SetValue('')
+ win = self.FindWindowById(self.win['volume'][attrb]['map'])
+ else:
+ win = self.FindWindowById(self.win['volume'][attrb]['const'])
+ win.SetValue(value)
- attrb=attr, map=True) # -> map
- if data['attribute'].has_key('color'):
- value = data['attribute']['color']['value']
- if data['attribute']['color']['map']:
- self.FindWindowById(self.win['volume']['color']['map']).SetValue(value)
- else: # constant
- color = map(int, value.split(':'))
- self.FindWindowById(self.win['volume']['color']['const']).SetColour(color)
- self.SetMapObjUseMap(nvizType='volume',
- attrb=attr, map=data['attribute']['color']['map'])
- attrb='shine', map=data['attribute']['shine']['map'])
- value = data['attribute']['shine']['value']
- if data['attribute']['shine']['map']:
- self.FindWindowById(self.win['volume']['shine']['map']).SetValue(value)
- else:
- self.FindWindowById(self.win['volume']['shine']['const']).SetValue(value)
+ attrb=attrb, map=data[attrb]['map'])
def SetPage(self, name):
"""Get named page"""
self.notebook.SetSelection(self.page[name]['id'])
@@ -2604,37 +2666,4 @@
self.mapWindow.Refresh(eraseBackground=False)
event.Skip()
-class IsoSurfList(wx.CheckListBox):
- """List of loaded volume isosurfaces (volume properties page)"""
- def __init__(self, parent, win, id=wx.ID_ANY, size=wx.DefaultSize):
- self.parent = parent
- self.win = win
- wx.CheckListBox.__init__(self, parent, id, size=size)
- self.Bind(wx.EVT_CHECKLISTBOX, self.OnCheck)
- self.Bind(wx.EVT_LISTBOX, self.OnSelect)
- def OnCheck(self, event):
- """Item checked/unchecked -> load/delete surface"""
- # event.IsChecked()
- def OnSelect(self, event):
- """Item selected"""
- winUp = self.parent.FindWindowById(self.win['btnIsosurfMoveUp'])
- winDown = self.parent.FindWindowById(self.win['btnIsosurfMoveDown'])
- selection = event.GetSelection()
- if selection == 0:
- winUp.Enable(False)
- if not winDown.IsEnabled():
- winDown.Enable()
- elif selection == self.GetCount() - 1:
- winDown.Enable(False)
- if not winUp.IsEnabled():
- winUp.Enable()
- else:
- winDown.Enable()
- winUp.Enable()
Modified: grass/trunk/gui/wxpython/nviz/nviz.h
--- grass/trunk/gui/wxpython/nviz/nviz.h 2008-08-17 21:39:32 UTC (rev 32848)
+++ grass/trunk/gui/wxpython/nviz/nviz.h 2008-08-17 21:51:15 UTC (rev 32849)
@@ -104,6 +104,13 @@
int DeleteIsosurface(int, int);
int MoveIsosurface(int, int, bool);
int SetIsosurfaceColor(int, int, bool, const char *);
+ int SetIsosurfaceMask(int, int, bool, const char *);
+ int SetIsosurfaceTransp(int, int, bool, const char *);
+ int SetIsosurfaceShine(int, int, bool, const char *);
+ int SetIsosurfaceEmit(int, int, bool, const char *);
+ int UnsetIsosurfaceMask(int, int);
+ int UnsetIsosurfaceTransp(int, int);
+ int UnsetIsosurfaceEmit(int, int);
int SetIsosurfaceMode(int, int);
int SetIsosurfaceRes(int, int);
Modified: grass/trunk/gui/wxpython/nviz/volume.cpp
--- grass/trunk/gui/wxpython/nviz/volume.cpp 2008-08-17 21:39:32 UTC (rev 32848)
+++ grass/trunk/gui/wxpython/nviz/volume.cpp 2008-08-17 21:51:15 UTC (rev 32849)
@@ -103,9 +103,9 @@
- \brief Set surface color
+ \brief Set isosurface color
- \param id surface id
+ \param id volume id
\param isosurf_id isosurface id (0 - MAX_ISOSURFS)
\param map if true use map otherwise constant
\param value map name of value
@@ -113,7 +113,7 @@
\return 1 on success
\return -1 volume not found
\return -2 isosurface not found
- \return -3 setting attributes failed
+ \return -3 on failure
int Nviz::SetIsosurfaceColor(int id, int isosurf_id,
bool map, const char *value)
@@ -122,6 +122,84 @@
+ \brief Set isosurface mask
+ @todo invert
+ \param isosurf_id isosurface id (0 - MAX_ISOSURFS)
+ \param invert true for invert mask
+ \param value map name to be used for mask
+ \return 1 on success
+ \return -1 volume not found
+ \return -2 isosurface not found
+int Nviz::SetIsosurfaceMask(int id, int isosurf_id,
+ bool invert, const char *value)
+ return SetIsosurfaceAttr(id, isosurf_id, ATT_MASK, true, value);
+ \brief Set isosurface transparency
+ \param map if true use map otherwise constant
+ \param value map name of value
+int Nviz::SetIsosurfaceTransp(int id, int isosurf_id,
+ bool map, const char *value)
+ return SetIsosurfaceAttr(id, isosurf_id, ATT_TRANSP, map, value);
+ \brief Set isosurface shininess
+int Nviz::SetIsosurfaceShine(int id, int isosurf_id,
+ return SetIsosurfaceAttr(id, isosurf_id, ATT_SHINE, map, value);
+ \brief Set isosurface emission
+int Nviz::SetIsosurfaceEmit(int id, int isosurf_id,
+ return SetIsosurfaceAttr(id, isosurf_id, ATT_EMIT, map, value);
\brief Set isosurface attribute
\param id volume id
@@ -171,6 +249,54 @@
+ \brief Unset isosurface mask
+ \return -3 setting attributes failed
+int Nviz::UnsetIsosurfaceMask(int id, int isosurf_id)
+ return UnsetIsosurfaceAttr(id, isosurf_id, ATT_MASK);
+ \brief Unset isosurface transparency
+int Nviz::UnsetIsosurfaceTransp(int id, int isosurf_id)
+ return UnsetIsosurfaceAttr(id, isosurf_id, ATT_TRANSP);
+ \brief Unset isosurface emission
+int Nviz::UnsetIsosurfaceEmit(int id, int isosurf_id)
+ return UnsetIsosurfaceAttr(id, isosurf_id, ATT_EMIT);
\brief Unset surface attribute
