[GRASS-SVN] r32855 - grass/trunk/lib/python
Mon Aug 18 11:33:02 EDT 2008
Author: glynn
Date: 2008-08-18 11:33:02 -0400 (Mon, 18 Aug 2008)
New Revision: 32855
   grass/trunk/lib/python/grass.py
Add exec_command
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py	2008-08-18 13:38:03 UTC (rev 32854)
+++ grass/trunk/lib/python/grass.py	2008-08-18 15:33:02 UTC (rev 32855)
@@ -58,6 +58,12 @@
     ps = pipe_command(*args, **kwargs)
     return ps.communicate()[0]
+def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
+    args = make_command(prog, flags, overwrite, quiet, verbose, **kwargs)
+    if env == None:
+	env = os.environ
+    os.execvpe(prog, args, env)
 # interface to g.message
 def message(msg, flag = None):
