[GRASS-SVN] r32858 - in grass/trunk: raster/r.in.xyz vector/v.surf.rst vector/v.vol.rst
Mon Aug 18 13:19:28 EDT 2008
Author: neteler
Date: 2008-08-18 13:19:28 -0400 (Mon, 18 Aug 2008)
New Revision: 32858
   grass/trunk/raster/r.in.xyz/r.in.xyz.html
   grass/trunk/vector/v.surf.rst/v.surf.rst.html
   grass/trunk/vector/v.vol.rst/v.vol.rst.html
url updated
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html	2008-08-18 15:58:53 UTC (rev 32857)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html	2008-08-18 17:19:28 UTC (rev 32858)
@@ -152,7 +152,7 @@
 <h2>EXAMPLE</h2>
-Import the <a href="http://mpa.itc.it/grasstutor/data_menu2nd.phtml">Jockey's
+Import the <a href="http://www.grassbook.org/data_menu2nd.phtml">Jockey's
 Ridge, NC, LIDAR dataset</a>, and process into a clean DEM:
 <div class="code"><pre>
Modified: grass/trunk/vector/v.surf.rst/v.surf.rst.html
--- grass/trunk/vector/v.surf.rst/v.surf.rst.html	2008-08-18 15:58:53 UTC (rev 32857)
+++ grass/trunk/vector/v.surf.rst/v.surf.rst.html	2008-08-18 17:19:28 UTC (rev 32858)
@@ -342,7 +342,7 @@
 </p>
 <p>
-<a href="http://mpa.itc.it/grasstutor/">
+<a href="http://www.grassbook.org">
 Neteler, M. and Mitasova, H., 2004, Open Source GIS: A GRASS GIS Approach, Second Edition, </a>
 Kluwer International Series in Engineering and Computer Science, 773, Kluwer Academic Press / Springer,
 Boston, Dordrecht, 424 pages.
Modified: grass/trunk/vector/v.vol.rst/v.vol.rst.html
--- grass/trunk/vector/v.vol.rst/v.vol.rst.html	2008-08-18 15:58:53 UTC (rev 32857)
+++ grass/trunk/vector/v.vol.rst/v.vol.rst.html	2008-08-18 17:19:28 UTC (rev 32858)
@@ -140,7 +140,7 @@
 <P>
 <i>Example
- (based on <a href="http://mpa.itc.it/grasstutor/data_menu2nd.phtml">Slovakia3d dataset</a>):</i>
+ (based on <a href="http://www.grassbook.org/data_menu2nd.phtml">Slovakia3d dataset</a>):</i>
 <P>
 v.info -c precip3d
