[GRASS-SVN] r32866 - in grass/trunk: display/d.erase display/d.info include lib/cairodriver lib/display lib/driver lib/htmldriver lib/pngdriver lib/psdriver lib/raster
Mon Aug 18 16:24:15 EDT 2008
Author: glynn
Date: 2008-08-18 16:24:15 -0400 (Mon, 18 Aug 2008)
New Revision: 32866
Added:
   grass/trunk/lib/pngdriver/Polygon.c
Removed:
   grass/trunk/lib/display/list.c
   grass/trunk/display/d.erase/main.c
   grass/trunk/display/d.info/main.c
   grass/trunk/include/display.h
   grass/trunk/include/raster.h
   grass/trunk/lib/cairodriver/Graph.c
   grass/trunk/lib/display/setup.c
   grass/trunk/lib/display/window.c
   grass/trunk/lib/driver/Erase.c
   grass/trunk/lib/driver/Polygon.c
   grass/trunk/lib/driver/Returns.c
   grass/trunk/lib/driver/Set_window.c
   grass/trunk/lib/driver/driver.h
   grass/trunk/lib/driver/init.c
   grass/trunk/lib/driver/text3.c
   grass/trunk/lib/htmldriver/Graph_Clse.c
   grass/trunk/lib/htmldriver/Graph_Set.c
   grass/trunk/lib/pngdriver/Driver.c
   grass/trunk/lib/pngdriver/Graph_set.c
   grass/trunk/lib/pngdriver/Makefile
   grass/trunk/lib/pngdriver/Set_window.c
   grass/trunk/lib/pngdriver/pngdriver.h
   grass/trunk/lib/psdriver/Erase.c
   grass/trunk/lib/psdriver/Graph_set.c
   grass/trunk/lib/psdriver/Set_window.c
   grass/trunk/lib/psdriver/psdriver.h
   grass/trunk/lib/raster/raster.c
Replace screen_{left,right,top,bottom} with screen_{width,height}
Replace R_screen_{left,rite,top,bot} with R_get_window()
Move polygon filler into PNG driver
Add GRASS_{LINE_WIDTH,TEXT_SIZE,FRAME} env variables
Remove unused functions from lib/display
Modified: grass/trunk/display/d.erase/main.c
--- grass/trunk/display/d.erase/main.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/display/d.erase/main.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -52,9 +52,8 @@
     D_erase(color->answer);
-    if (eraseframe->answer) {
-	D_full_screen();
+    if (eraseframe->answer)
+	R_erase();
     R_close_driver();
Modified: grass/trunk/display/d.info/main.c
--- grass/trunk/display/d.info/main.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/display/d.info/main.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -71,12 +71,8 @@
     if (R_open_driver() != 0)
 	G_fatal_error(_("No graphics device selected"));
-    if (rflag->answer || dflag->answer) {
-	l = R_screen_left();
-	r = R_screen_rite();
-	t = R_screen_top();
-	b = R_screen_bot();
+    if (rflag->answer || dflag->answer)
+	R_get_window(&t, &b, &l, &r);
     if (rflag->answer)
 	fprintf(stdout, "rectangle: %f %f %f %f\n", l, r, t, b);
Modified: grass/trunk/include/display.h
--- grass/trunk/include/display.h	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/include/display.h	2008-08-18 20:24:15 UTC (rev 32866)
@@ -72,11 +72,6 @@
 /* icon.c */
 void D_plot_icon(double, double, int, double, double);
-/* list.c */
-void D_clear_window(void);
-void D_set_erase_color(const char *);
-void D_get_erase_color(char *);
 /* raster.c */
 int D_draw_raster(int, const void *, struct Colors *, RASTER_MAP_TYPE);
 int D_draw_d_raster(int, const DCELL *, struct Colors *);
@@ -98,7 +93,7 @@
 int D_color_of_type(const void *, struct Colors *, RASTER_MAP_TYPE);
 /* setup.c */
-int D_setup(int);
+void D_setup(int);
 /* symbol.c */
 void D_symbol(const SYMBOL *, double, double, const RGBA_Color *,
@@ -115,16 +110,9 @@
 int D_color_number_to_RGB(int, int *, int *, int *);
 /* window.c */
-void D_new_window(char *, double, double, double, double);
-void D_new_window_percent(char *, double, double, double, double);
-void D_show_window(int);
-int D_get_screen_window(double *, double *, double *, double *);
+void D_set_window(double, double, double, double);
+void D_get_screen_window(double *, double *, double *, double *);
 void D_check_map_window(struct Cell_head *);
-void D_reset_screen_window(double, double, double, double);
-void D_remove_window(void);
-void D_erase_window(void);
 void D_erase(const char *);
-void D_remove_windows(void);
-void D_full_screen(void);
 #endif /* GRASS_DISPLAY_H */
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/include/raster.h	2008-08-18 20:24:15 UTC (rev 32866)
@@ -5,12 +5,9 @@
 int R_open_driver(void);
 void R_close_driver(void);
-double R_screen_left(void);
-double R_screen_rite(void);
-double R_screen_bot(void);
-double R_screen_top(void);
 int R_get_num_colors(void);
+void R_set_window(double, double, double, double);
+void R_get_window(double *, double *, double *, double *);
 void R_standard_color(int);
 void R_RGB_color(int, int, int);
@@ -33,7 +30,6 @@
 void R_text_size(double, double);
 void R_text_rotation(double);
-void R_set_window(double, double, double, double);
 void R_text(const char *);
 void R_get_text_box(const char *, double *, double *, double *, double *);
Modified: grass/trunk/lib/cairodriver/Graph.c
--- grass/trunk/lib/cairodriver/Graph.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/cairodriver/Graph.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -104,8 +104,8 @@
     char *p;
     /* set image properties */
-    width = screen_right - screen_left;
-    height = screen_bottom - screen_top;
+    width = screen_width;
+    height = screen_height;
     stride = width * 4;
     /* get file name */
Deleted: grass/trunk/lib/display/list.c
--- grass/trunk/lib/display/list.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/display/list.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -1,48 +0,0 @@
-/*  Routines to manage the graphics window contents list
- * D_set_erase_color(color)
- *     sets the color name of the current erase color for the window
- * D_get_erase_color(color)
- *     returns the current erase color name for window
-#include <string.h>
-#include <stdio.h>
-#include <grass/display.h>
-#include <grass/raster.h>
- * \brief clears information about current frame
- * Removes all information about the current frame. This includes the map region and the
- * frame content lists.
- *  \param ~
- *  \return int
-static char *erase_color;
-void D_set_erase_color(const char *colorname)
-    if (erase_color)
-	G_free(erase_color);
-    erase_color = G_store(colorname);
-void D_get_erase_color(char *colorname)
-    if (!erase_color)
-	erase_color = G_store(DEFAULT_BG_COLOR);
-    strcpy(colorname, erase_color);
Modified: grass/trunk/lib/display/setup.c
--- grass/trunk/lib/display/setup.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/display/setup.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -56,25 +56,16 @@
  *  \return int
-int D_setup(int clear)
+void D_setup(int clear)
     struct Cell_head region;
     double t, b, l, r;
-    D_new_window("full_screen", t, b, l, r);
     D_get_screen_window(&t, &b, &l, &r);
     /* clear the frame, if requested to do so */
-    if (clear) {
-	D_clear_window();
-	R_standard_color(D_translate_color(DEFAULT_BG_COLOR));
-	R_box_abs(l, t, r, b);
+    if (clear)
+	D_erase(DEFAULT_BG_COLOR);
     /* Set the map region associated with graphics frame */
     G_get_set_window(&region);
@@ -88,7 +79,4 @@
     /* set text clipping, for good measure */
     R_set_window(t, b, l, r);
-    R_move_abs(0, 0);
-    D_move_abs(0, 0);
-    return 0;
Modified: grass/trunk/lib/display/window.c
--- grass/trunk/lib/display/window.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/display/window.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -4,9 +4,6 @@
  *   if "name" is an empty string, the routine returns a unique
  *   string in "name"
- * D_reset_screen_window(t, b, l, r)
- *   resets the edges of the current window
  * D_show_window(color)
  *   outlines current window in color (from ../colors.h)
@@ -19,9 +16,6 @@
  *   else
  *       struct "wind" is written to map window (m_win)
- * D_remove_window()
- *   remove any trace of window
  * D_erase_window()
  *   Erases the window on scree.  Does not affect window contents list.
@@ -40,13 +34,14 @@
 static struct Cell_head map_window;
 static int map_window_set;
-static void D_set_window(double t, double b, double l, double r)
+void D_set_window(double t, double b, double l, double r)
     screen_window.t = t;
     screen_window.b = b;
     screen_window.l = l;
     screen_window.r = r;
     screen_window_set = 1;
+    R_set_window(t, b, l, r);
@@ -62,14 +57,12 @@
  *  \return int
-int D_get_screen_window(double *t, double *b, double *l, double *r)
+void D_get_screen_window(double *t, double *b, double *l, double *r)
-    if (!screen_window_set)
-	screen_window.t = R_screen_top();
-	screen_window.b = R_screen_bot();
-	screen_window.l = R_screen_left();
-	screen_window.r = R_screen_rite();
+    if (!screen_window_set) {
+	R_get_window(
+	    &screen_window.t, &screen_window.b,
+	    &screen_window.l, &screen_window.r);
@@ -77,105 +70,10 @@
     *b = screen_window.b;
     *l = screen_window.l;
     *r = screen_window.r;
-    return 0;
- * \brief create new graphics frame
- * Creates a new frame <b>name</b> with
- * coordinates <b>top, bottom, left</b>, and <b>right.</b> If <b>name</b>
- * is the empty string '''' (i.e., *<b>name</b> = = 0), the routine returns a
- * unique string in <b>name.</b>
- *  \param name
- *  \param top
- *  \param bottom
- *  \param left
- *  \param right
- *  \return void
-void D_new_window(char *name, double t, double b, double l, double r)
-    screen_window_set = 0;
-    map_window_set = 0;
-    D_set_window(t, b, l, r);
- * \brief create new graphics frame, with coordinates in percent
- * Creates a new frame <b>name</b> with coordinates <b>top, bottom,
- * left</b>, and <b>right</b> as percentages of the screen size.
- * If <b>name</b> is the empty string "" (i.e., *<b>name</b> == 0),
- * the routine returns a unique string in <b>name.</b>
- *  \param name
- *  \param bottom
- *  \param top
- *  \param left
- *  \param right
- *  \return void
-void D_new_window_percent(char *name, double b, double t, double l, double r)
-    double scr_t = R_screen_top();
-    double scr_b = R_screen_bot();
-    double scr_l = R_screen_left();
-    double scr_r = R_screen_rite();
-    double win_t = 0.5 + scr_t + (scr_b - scr_t) * (100. - t) / 100.0;
-    double win_b = 0.5 + scr_t + (scr_b - scr_t) * (100. - b) / 100.0;
-    double win_l = 0.5 + scr_l + (scr_r - scr_l) * l / 100.0;
-    double win_r = 0.5 + scr_l + (scr_r - scr_l) * r / 100.0;
-    if (win_t < scr_t)
-	win_t = scr_t;
-    if (win_b > scr_b)
-	win_b = scr_b;
-    if (win_l < scr_l)
-	win_l = scr_l;
-    if (win_r > scr_r)
-	win_r = scr_r;
-    D_new_window(name, win_t, win_b, win_l, win_r);
- * \brief outlines current frame
- * Outlines
- * current frame in <b>color.</b> Appropriate colors are found in
- * $GISBASE/src/D/libes/colors.h\remarks{$GISBASE is the directory where GRASS
- * is installed. See UNIX_Environment for details.} and are spelled
- * with lowercase letters.
- *  \param color
- *  \return void
-void D_show_window(int color)
-    double t, b, l, r;
-    D_get_screen_window(&t, &b, &l, &r);
-    R_standard_color(color);
-    R_move_abs(l, b);
-    R_cont_abs(l, t);
-    R_cont_abs(r, t);
-    R_cont_abs(r, b);
-    R_cont_abs(l, b);
  * \brief assign/retrieve current map region
  * Graphics frames can have GRASS map regions associated with
@@ -200,41 +98,7 @@
- * \brief resets current frame position
- * Re-establishes the screen position of a
- * frame at the location specified by <b>top, bottom, left, and right.</b>
- *  \param top
- *  \param bottom
- *  \param left
- *  \param right
- *  \return void
-void D_reset_screen_window(double t, double b, double l, double r)
- * \brief remove a frame
- * Removes any trace of the
- * current frame.
- *  \param ~
  * \brief erase current frame
  * Erases the frame on the
@@ -243,22 +107,12 @@
  *  \param ~
-    R_flush();
 void D_erase(const char *color)
     double t, b, l, r;
     int colorindex;
-    D_clear_window();
     /* Parse and select background color */
     colorindex = D_parse_color(color, 0);
@@ -266,24 +120,5 @@
     /* Do the plotting */
-    /* Add erase item to the pad */
-    D_set_erase_color(color);
-    D_remove_windows();
-    D_new_window_percent("full_screen", 0.0, 100.0, 0.0, 100.0);
-    R_erase();
Modified: grass/trunk/lib/driver/Erase.c
--- grass/trunk/lib/driver/Erase.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/driver/Erase.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -10,10 +10,7 @@
 	return;
-    top  = COM_Screen_top();
-    bot  = COM_Screen_bot();
-    rite = COM_Screen_rite();
-    left = COM_Screen_left();
+    COM_Get_window(&top, &bot, &left, &rite);
     COM_Box_abs(left, top, rite, bot);
Modified: grass/trunk/lib/driver/Polygon.c
--- grass/trunk/lib/driver/Polygon.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/driver/Polygon.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -3,133 +3,10 @@
 #include "driver.h"
 #include "driverlib.h"
-struct point
-    double x, y;
-static int cmp_double(const void *aa, const void *bb)
-    const double *a = aa;
-    const double *b = bb;
-    return
-	*a > *b ?  1 :
-	*a < *b ? -1 :
-	0;
-static void fill(double x0, double x1, double y)
-    COM_Box_abs(x0, y, x1, y + 1);
-static void line(const struct point *p, int n, double y)
-    static double *xs;
-    static double max_x;
-    int num_x = 0;
-    int i;
-    for (i = 0; i < n; i++) {
-	const struct point *p0 = &p[i];
-	const struct point *p1 = &p[i + 1];
-	const struct point *tmp;
-	double fx;
-	long x;
-	if (p0->y == p1->y)
-	    continue;
-	if (p0->y > p1->y)
-	    tmp = p0, p0 = p1, p1 = tmp;
-	if (p0->y > y)
-	    continue;
-	if (p1->y <= y)
-	    continue;
-	fx = (double)p1->x * (y - p0->y) + (double)p0->x * (p1->y - y);
-	fx /= p1->y - p0->y;
-	x = fx < -0x7fffffff ? -0x7fffffff :
-	    fx > 0x7fffffff ? 0x7fffffff : (long)fx;
-	if (num_x >= max_x) {
-	    max_x += 20;
-	    xs = G_realloc(xs, max_x * sizeof(double));
-	xs[num_x++] = x;
-    qsort(xs, num_x, sizeof(double), cmp_double);
-    for (i = 0; i + 1 < num_x; i += 2)
-	fill(xs[i], xs[i + 1], y);
-static void poly(const struct point *p, int n)
-    double y0, y1, y;
-    int i;
-    if (n < 3)
-	return;
-    y0 = y1 = p[0].y;
-    for (i = 1; i < n; i++) {
-	if (y0 > p[i].y)
-	    y0 = p[i].y;
-	if (y1 < p[i].y)
-	    y1 = p[i].y;
-    if (y0 > screen_bottom || y1 < screen_top)
-	return;
-    if (y0 < screen_top)
-	y0 = screen_top;
-    if (y1 > screen_bottom)
-	y1 = screen_bottom;
-    for (y = y0; y < y1; y++)
-	line(p, n, y);
-static void fill_polygon(const double *xarray, const double *yarray, int count)
-    static struct point *points;
-    static int max_points;
-    int i;
-    if (max_points < count + 1) {
-	max_points = count + 1;
-	points = G_realloc(points, sizeof(struct point) * max_points);
-    for (i = 0; i < count; i++) {
-	points[i].x = xarray[i];
-	points[i].y = yarray[i];
-    points[count].x = xarray[0];
-    points[count].y = yarray[0];
-    poly(points, count);
 void COM_Polygon_abs(const double *xarray, const double *yarray, int number)
-    if (driver->Polygon) {
+    if (driver->Polygon)
 	(*driver->Polygon) (xarray, yarray, number);
-	return;
-    fill_polygon(xarray, yarray, number);
 void COM_Polygon_rel(const double *xarray, const double *yarray, int number)
Modified: grass/trunk/lib/driver/Returns.c
--- grass/trunk/lib/driver/Returns.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/driver/Returns.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -1,26 +1,6 @@
 #include "driver.h"
-double COM_Screen_left(void)
-    return screen_left;
-double COM_Screen_rite(void)
-    return screen_right;
-double COM_Screen_bot(void)
-    return screen_bottom;
-double COM_Screen_top(void)
-    return screen_top;
 int COM_Number_of_colors(void)
     return NCOLORS;
Modified: grass/trunk/lib/driver/Set_window.c
--- grass/trunk/lib/driver/Set_window.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/driver/Set_window.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -1,8 +1,25 @@
 #include "driver.h"
+static struct {
+    double t, b, l, r;
+} window;
 void COM_Set_window(double t, double b, double l, double r)
+    window.t = t;
+    window.b = b;
+    window.l = l;
+    window.r = r;
     if (driver->Set_window)
 	(*driver->Set_window) (t, b, l, r);
+void COM_Get_window(double *t, double *b, double *l, double *r)
+    *t = window.t;
+    *b = window.b;
+    *l = window.l;
+    *r = window.r;
Modified: grass/trunk/lib/driver/driver.h
--- grass/trunk/lib/driver/driver.h	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/driver/driver.h	2008-08-18 20:24:15 UTC (rev 32866)
@@ -6,10 +6,8 @@
 extern int NCOLORS;
-extern int screen_left;
-extern int screen_right;
-extern int screen_bottom;
-extern int screen_top;
+extern int screen_width;
+extern int screen_height;
 extern double cur_x;
 extern double cur_y;
@@ -56,7 +54,7 @@
 /* Library Functions */
 /* init.c */
-extern int LIB_init(const struct driver *drv);
+extern void LIB_init(const struct driver *drv);
 /* Commands */
@@ -121,14 +119,11 @@
 extern void COM_Respond(void);
 /* Returns.c */
-extern double COM_Screen_left(void);
-extern double COM_Screen_rite(void);
-extern double COM_Screen_bot(void);
-extern double COM_Screen_top(void);
 extern int COM_Number_of_colors(void);
 /* Set_window.c */
 extern void COM_Set_window(double, double, double, double);
+extern void COM_Get_window(double *, double *, double *, double *);
 /* Text.c */
 extern void COM_Text(const char *);
Modified: grass/trunk/lib/driver/init.c
--- grass/trunk/lib/driver/init.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/driver/init.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -28,10 +28,8 @@
 int NCOLORS;
-int screen_left;
-int screen_right;
-int screen_bottom;
-int screen_top;
+int screen_width;
+int screen_height;
 double cur_x;
 double cur_y;
@@ -41,7 +39,7 @@
 double text_rotation;
 int matrix_valid;
-int LIB_init(const struct driver *drv)
+void LIB_init(const struct driver *drv)
     const char *p;
@@ -51,15 +49,13 @@
     /* initialize graphics */
     p = getenv("GRASS_WIDTH");
-    screen_left = 0;
-    screen_right = (p && atoi(p)) ? atoi(p) : DEF_WIDTH;
+    screen_width = (p && atoi(p)) ? atoi(p) : DEF_WIDTH;
     p = getenv("GRASS_HEIGHT");
-    screen_top = 0;
-    screen_bottom = (p && atoi(p)) ? atoi(p) : DEF_HEIGHT;
+    screen_height = (p && atoi(p)) ? atoi(p) : DEF_HEIGHT;
     if (COM_Graph_set() < 0)
 	exit(1);
-    return 0;
+    COM_Set_window(0, screen_height, 0, screen_width);
Modified: grass/trunk/lib/driver/text3.c
--- grass/trunk/lib/driver/text3.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/driver/text3.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -111,7 +111,7 @@
     /* init point */
     pen.x = x * 64;
     /* pen.y = 0; */
-    pen.y = (screen_bottom - y) * 64;
+    pen.y = (screen_height - y) * 64;
     /* convert string to:shift-jis from:encoding */
     outlen = convert_str(encoding, string, &out);
@@ -207,10 +207,10 @@
 	/* draw bitmap */
 	if (!fdont_draw)
 	    draw_bitmap(&slot->bitmap, slot->bitmap_left,
-			screen_bottom - slot->bitmap_top);
+			screen_height - slot->bitmap_top);
 	else
 	    set_text_box(&slot->bitmap, slot->bitmap_left,
 	/* increment pen position */
 	pen->x += slot->advance.x;
Modified: grass/trunk/lib/htmldriver/Graph_Clse.c
--- grass/trunk/lib/htmldriver/Graph_Clse.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/htmldriver/Graph_Clse.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -147,7 +147,7 @@
     case CLIENT:
 	fprintf(output,
 		"<AREA SHAPE=\"RECT\" NOHREF COORDS=\"%d,%d %d,%d\">\n",
-		screen_left, screen_top, screen_right, screen_bottom);
+		0, 0, screen_width, screen_height);
 	fprintf(output, "</MAP>\n");
 	break;
Modified: grass/trunk/lib/htmldriver/Graph_Set.c
--- grass/trunk/lib/htmldriver/Graph_Set.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/htmldriver/Graph_Set.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -105,7 +105,7 @@
     G_message("HTMLMAP: collecting to file: %s\n width = %d, height = %d, ",
-	      file_name, screen_right, screen_bottom);
+	      file_name, screen_width, screen_height);
      * check type of map wanted
Modified: grass/trunk/lib/pngdriver/Driver.c
--- grass/trunk/lib/pngdriver/Driver.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/pngdriver/Driver.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -34,7 +34,7 @@
     drv.Line_width = PNG_Line_width;
     drv.Polydots = NULL;
     drv.Polyline = NULL;
-    drv.Polygon = NULL;
+    drv.Polygon = PNG_Polygon;
     drv.Set_window = PNG_Set_window;
     drv.Begin_scaled_raster = PNG_begin_scaled_raster;
     drv.Scaled_raster = PNG_scaled_raster;
Modified: grass/trunk/lib/pngdriver/Graph_set.c
--- grass/trunk/lib/pngdriver/Graph_set.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/pngdriver/Graph_set.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -30,7 +30,7 @@
 int has_alpha;
 int mapped;
-int clip_top, clip_bot, clip_left, clip_rite;
+double clip_top, clip_bot, clip_left, clip_rite;
 int width, height;
 void *image;
 unsigned int *grid;
@@ -103,13 +103,13 @@
     if (do_read && access(file_name, 0) != 0)
 	do_read = 0;
-    clip_top = screen_top;
-    clip_bot = screen_bottom;
-    clip_left = screen_left;
-    clip_rite = screen_right;
+    clip_top = 0;
+    clip_bot = height;
+    clip_left = 0;
+    clip_rite = width;
     p = getenv("GRASS_TRANSPARENT");
     has_alpha = p && strcmp(p, "TRUE") == 0;
Modified: grass/trunk/lib/pngdriver/Makefile
--- grass/trunk/lib/pngdriver/Makefile	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/pngdriver/Makefile	2008-08-18 20:24:15 UTC (rev 32866)
@@ -20,6 +20,7 @@
 	Graph_close.o		\
 	Graph_set.o		\
 	Line_width.o		\
+	Polygon.o		\
 	Raster.o		\
 	Respond.o		\
 	Set_window.o		\
Added: grass/trunk/lib/pngdriver/Polygon.c
--- grass/trunk/lib/pngdriver/Polygon.c	                        (rev 0)
+++ grass/trunk/lib/pngdriver/Polygon.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -0,0 +1,147 @@
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include "pngdriver.h"
+struct point
+    double x, y;
+static int cmp_double(const void *aa, const void *bb)
+    const double *a = aa;
+    const double *b = bb;
+    return
+	*a > *b ?  1 :
+	*a < *b ? -1 :
+	0;
+static void fill(double x0, double x1, double y)
+    int yi = (int) floor(y);
+    int xi0 = (int) floor(x0 + 0.5);
+    int xi1 = (int) floor(x1 + 0.5);
+    unsigned int *p = &grid[yi * width + xi1];
+    int x;
+    if (yi < clip_bot || yi >= clip_top)
+	return;
+    if (xi0 > clip_rite)
+	return;
+    if (xi1 < clip_left)
+	return;
+    if (xi0 < clip_left)
+	xi0 = clip_left;
+    if (xi1 > clip_rite)
+	xi1 = clip_rite;
+    p = &grid[yi * width + xi1];
+    for (x = xi0; x < xi1; x++)
+	*p++ = currentColor;
+static void line(const struct point *p, int n, double y)
+    static double *xs;
+    static double max_x;
+    int num_x = 0;
+    int i;
+    for (i = 0; i < n; i++) {
+	const struct point *p0 = &p[i];
+	const struct point *p1 = &p[i + 1];
+	const struct point *tmp;
+	double x;
+	if (p0->y == p1->y)
+	    continue;
+	if (p0->y > p1->y)
+	    tmp = p0, p0 = p1, p1 = tmp;
+	if (p0->y > y)
+	    continue;
+	if (p1->y <= y)
+	    continue;
+	x = p1->x * (y - p0->y) + p0->x * (p1->y - y);
+	x /= p1->y - p0->y;
+	if (num_x >= max_x) {
+	    max_x += 20;
+	    xs = G_realloc(xs, max_x * sizeof(double));
+	xs[num_x++] = x;
+    qsort(xs, num_x, sizeof(double), cmp_double);
+    for (i = 0; i + 1 < num_x; i += 2)
+	fill(xs[i], xs[i + 1], y);
+static void poly(const struct point *p, int n)
+    double y0, y1, y;
+    int i;
+    if (n < 3)
+	return;
+    y0 = y1 = p[0].y;
+    for (i = 1; i < n; i++) {
+	if (y0 > p[i].y)
+	    y0 = p[i].y;
+	if (y1 < p[i].y)
+	    y1 = p[i].y;
+    if (y0 > clip_bot || y1 < clip_top)
+	return;
+    if (y0 < clip_top)
+	y0 = clip_top;
+    if (y1 > clip_bot)
+	y1 = clip_bot;
+    for (y = y0; y < y1; y++)
+	line(p, n, y + 0.5);
+void PNG_Polygon(const double *xarray, const double *yarray, int count)
+    static struct point *points;
+    static int max_points;
+    int i;
+    if (max_points < count + 1) {
+	max_points = count + 1;
+	points = G_realloc(points, sizeof(struct point) * max_points);
+    for (i = 0; i < count; i++) {
+	points[i].x = xarray[i];
+	points[i].y = yarray[i];
+    points[count].x = xarray[0];
+    points[count].y = yarray[0];
+    poly(points, count);
Modified: grass/trunk/lib/pngdriver/Set_window.c
--- grass/trunk/lib/pngdriver/Set_window.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/pngdriver/Set_window.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -20,15 +20,11 @@
 #include <math.h>
-void PNG_Set_window(double ft, double fb, double fl, double fr)
+void PNG_Set_window(double t, double b, double l, double r)
-    int t = (int) floor(ft + 0.5);
-    int b = (int) floor(fb + 0.5);
-    int l = (int) floor(fl + 0.5);
-    int r = (int) floor(fr + 0.5);
-    clip_top  = t > screen_top    ? t : screen_top;
-    clip_bot  = b < screen_bottom ? b : screen_bottom;
-    clip_left = l > screen_left   ? l : screen_left;
-    clip_rite = r < screen_right  ? r : screen_right;
+    clip_top  = t > 0      ? t : 0;
+    clip_bot  = b < height ? b : height;
+    clip_left = l > 0      ? l : 0;
+    clip_rite = r < width  ? r : width;
Modified: grass/trunk/lib/pngdriver/pngdriver.h
--- grass/trunk/lib/pngdriver/pngdriver.h	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/pngdriver/pngdriver.h	2008-08-18 20:24:15 UTC (rev 32866)
@@ -17,7 +17,7 @@
 extern int has_alpha;
 extern int mapped;
-extern int clip_top, clip_bot, clip_left, clip_rite;
+extern double clip_top, clip_bot, clip_left, clip_rite;
 extern int width, height;
 extern unsigned int *grid;
 extern unsigned char png_palette[256][4];
@@ -50,6 +50,7 @@
 extern void PNG_Graph_close(void);
 extern int PNG_Graph_set(void);
 extern void PNG_Line_width(double);
+extern void PNG_Polygon(const double *, const double *, int);
 extern void PNG_begin_scaled_raster(int, int[2][2], double[2][2]);
 extern int PNG_scaled_raster(int, int, const unsigned char *,
 			     const unsigned char *, const unsigned char *,
Modified: grass/trunk/lib/psdriver/Erase.c
--- grass/trunk/lib/psdriver/Erase.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/psdriver/Erase.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -3,8 +3,7 @@
 void PS_Erase(void)
     if (encapsulated)
-	output("%d %d %d %d BOX\n", screen_left, screen_top, screen_right,
-	       screen_bottom);
+	output("%d %d %d %d BOX\n", left, top, right, bot);
     else
 	output("ERASE\n");
Modified: grass/trunk/lib/psdriver/Graph_set.c
--- grass/trunk/lib/psdriver/Graph_set.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/psdriver/Graph_set.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -14,6 +14,7 @@
 #include <stdlib.h>
 #include <stdarg.h>
 #include <time.h>
+#include <math.h>
 #include "psdriver.h"
@@ -23,12 +24,12 @@
 const char *file_name;
 FILE *outfp;
 int true_color;
-int width, height;
 int encapsulated;
 int no_header, no_trailer;
+double left, right, bot, top;
+static double width, height;
 static int landscape;
-static int left, right, bot, top;
 struct paper
@@ -76,7 +77,9 @@
     output("%%%%Title: %s\n", file_name);
     output("%%%%For: %s\n", G_whoami());
     output("%%%%Orientation: %s\n", landscape ? "Landscape" : "Portrait");
-    output("%%%%BoundingBox: %d %d %d %d\n", left, bot, right, top);
+    output("%%%%BoundingBox: %d %d %d %d\n",
+	   (int)floor(left), (int)floor(bot),
+	   (int)ceil(right), (int)ceil(top));
     output("%%%%CreationDate: %s\n", date_str);
     output("%%%%EndComments\n");
@@ -98,27 +101,27 @@
     output("%%%%BeginSetup\n");
-    output("%d %d translate\n", left, bot);
+    output("%.1f %.1f translate\n", left, bot);
     if (landscape)
 	output("90 rotate 0 1 -1 scale\n");
     else
-	output("0 %d translate 1 -1 scale\n", height);
+	output("0 %.1f translate 1 -1 scale\n", height);
-    output("%d %d BEGIN\n", width, height);
+    output("%.1f %.1f BEGIN\n", width, height);
     output("%%%%EndSetup\n");
     output("%%%%Page: 1 1\n");
-static int in2pt(double x)
+static double in2pt(double x)
-    return (int)(x * 72);
+    return x * 72;
-static void swap(int *x, int *y)
+static void swap(double *x, double *y)
-    int tmp = *x;
+    double tmp = *x;
     *x = *y;
     *y = tmp;
@@ -130,8 +133,8 @@
     const struct paper *paper;
     int i;
     left = 0;
     right = width;
@@ -165,8 +168,8 @@
     if (landscape)
 	swap(&width, &height);
-    screen_right = screen_left + width;
-    screen_bottom = screen_top + height;
+    right = left + width;
+    bot = top + height;
 int PS_Graph_set(void)
@@ -212,8 +215,8 @@
 	write_setup();
-    G_message
-	("PS: collecting to file: %s,\n     GRASS_WIDTH=%d, GRASS_HEIGHT=%d",
+    G_message(
+	"PS: collecting to file: %s,\nGRASS_WIDTH=%.1f, GRASS_HEIGHT=%.1f",
 	 file_name, width, height);
     fflush(outfp);
Modified: grass/trunk/lib/psdriver/Set_window.c
--- grass/trunk/lib/psdriver/Set_window.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/psdriver/Set_window.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -21,6 +21,6 @@
 void PS_Set_window(double t, double b, double l, double r)
-    output("%f %f %f %f %s\n", t, b, l, r,
+    output("%.1f %.1f %.1f %.1f %s\n", t, b, l, r,
 	   encapsulated ? "EPSWINDOW" : "WINDOW");
Modified: grass/trunk/lib/psdriver/psdriver.h
--- grass/trunk/lib/psdriver/psdriver.h	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/psdriver/psdriver.h	2008-08-18 20:24:15 UTC (rev 32866)
@@ -11,9 +11,9 @@
 extern const char *file_name;
 extern FILE *outfp;
 extern int true_color;
-extern int width, height;
 extern int encapsulated;
 extern int no_header, no_trailer;
+extern double left, right, bot, top;
 extern void output(const char *, ...);
Modified: grass/trunk/lib/raster/raster.c
--- grass/trunk/lib/raster/raster.c	2008-08-18 20:19:33 UTC (rev 32865)
+++ grass/trunk/lib/raster/raster.c	2008-08-18 20:24:15 UTC (rev 32866)
@@ -26,17 +26,28 @@
     const char *fenc = getenv("GRASS_ENCODING");
     const char *font = getenv("GRASS_FONT");
-    int t = R_screen_top();
-    int b = R_screen_bot();
-    int l = R_screen_left();
-    int r = R_screen_rite();
+    const char *line_width = getenv("GRASS_LINE_WIDTH");
+    const char *text_size = getenv("GRASS_TEXT_SIZE");
+    const char *frame = getenv("GRASS_FRAME");
     R_font(font ? font : "romans");
     if (fenc)
 	R_encoding(fenc);
-    R_set_window(t, b, l, r);
+    if (line_width)
+	R_line_width(atof(line_width));
+    if (text_size) {
+	double s = atof(text_size);
+	R_text_size(s, s);
+    if (frame) {
+	sscanf(frame, "%lf,%lf,%lf,%lf", &t, &b, &l, &r);
@@ -76,63 +87,6 @@
 	system(cmd);
- * \brief screen left edge
- * Returns the coordinate of the left edge of the screen.
- *  \param void
- *  \return double
-    return COM_Screen_left();
- * \brief screen right edge
- * Returns the coordinate of the right edge of the screen.
- *  \param void
- *  \return double
-    return COM_Screen_rite();
- * \brief bottom of screen
- * Returns the coordinate of the bottom of the screen.
- *  \param void
- *  \return double
-    return COM_Screen_bot();
- * \brief top of screen
- * Returns the coordinate of the top of the screen.
- *  \param void
- *  \return double
-    return COM_Screen_top();
     return COM_Number_of_colors();
@@ -454,10 +408,10 @@
- * \brief set text clipping frame
+ * \brief set clipping frame
- * Subsequent calls to <i>R_text</i> will have text strings
- * clipped to the screen frame defined by <b>top, bottom, left, right.</b>
+ * Subsequent drawing operations will be clipped to the screen frame
+ * defined by <b>top, bottom, left, right.</b>
  *  \param t top
  *  \param b bottom
@@ -472,6 +426,23 @@
+ * \brief get clipping frame
+ * Retrieve clipping frame
+ *  \param t top
+ *  \param b bottom
+ *  \param l left
+ *  \param r right
+ *  \return void
+void R_get_window(double *t, double *b, double *l, double *r)
+    return COM_Get_window(t, b, l, r);
  * \brief write text
  * Writes <b>text</b> in the current color and font, at the current text
