[GRASS-SVN] r32874 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Aug 19 02:03:25 EDT 2008
Author: cmbarton
Date: 2008-08-19 02:03:25 -0400 (Tue, 19 Aug 2008)
New Revision: 32874
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
Greatly speed up auto-rendering and make it nearly unbreakable even when rapidly doing drag and drop of layers.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-08-18 22:26:11 UTC (rev 32873)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-08-19 06:03:25 UTC (rev 32874)
@@ -643,6 +643,8 @@
# render background image if needed
+ self.tree.ReorderLayers()
if render:
# update display size
self.Map.ChangeMapSize(self.GetClientSize())
@@ -2817,7 +2819,7 @@
Re-render map composition (each map layer)
- # detele tmp map layers (queries)
+ # delete tmp map layers (queries)
qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
for layer in qlayer:
self.Map.DeleteLayer(layer)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-08-18 22:26:11 UTC (rev 32873)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-08-19 06:03:25 UTC (rev 32874)
@@ -831,11 +831,11 @@
if not layer.Render():
continue
- # update process bar
+ # update progress bar
if mapWindow is not None:
mapWindow.onRenderCounter += 1
- wx.SafeYield(self.window)
+ #wx.SafeYield(self.window)
# add image to compositing list
if layer.type != "overlay":
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-18 22:26:11 UTC (rev 32873)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-19 06:03:25 UTC (rev 32874)
@@ -91,6 +91,7 @@
self.notebook = kargs['notebook'] # GIS Manager notebook for layer tree
self.treepg = parent # notebook page holding layer tree
self.auimgr = kargs['auimgr'] # aui manager
+ self.rerender = False # layer change requires a reordering and rerendering (if auto render)
# init associated map display
self.mapdisplay = mapdisp.MapFrame(self,
@@ -188,7 +189,21 @@
#self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnChangeLayerName)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
# self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+ self.Bind(wx.EVT_IDLE, self.OnIdle)
+ def OnIdle(self, event):
+ Only re-order and re-render a composite map image from GRASS during
+ idle time instead of multiple times during layer changing.
+ if self.rerender:
+ if self.mapdisplay.autoRender.GetValue():
+ self.mapdisplay.MapWindow.UpdateMap(render=True)
+ event.Skip()
def OnKeyUp(self, event):
"""Key pressed"""
key = event.GetKeyCode()
@@ -479,8 +494,10 @@
layerbase + ' (opacity: ' + str(opacity_pct) + '%)')
# redraw map if auto-rendering is enabled
- if self.mapdisplay.autoRender.GetValue():
- self.mapdisplay.OnRender(None)
+ self.rerender = True
+ #if self.mapdisplay.autoRender.GetValue():
+ # print "*** Opacity OnRender *****"
+ # self.mapdisplay.OnRender(None)
def OnNvizProperties(self, event):
"""Nviz-related properties (raster/vector/volume)
@@ -843,8 +860,10 @@
pass
+ # print "*** Delete OnRender *****"
if self.mapdisplay.toolbars['vdigit']:
self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers (updateTool=True)
@@ -918,8 +937,10 @@
self.mapdisplay.SetStatusText("", 0)
+ # print "*** Checked OnRender *****"
def OnCmdChanged(self, event):
"""Change command string"""
@@ -1048,11 +1069,13 @@
pass
# reorder layers in render.Map to match new order after drag and drop
- self.ReorderLayers()
+ #self.ReorderLayers()
+ # print "*** Drop OnRender *****"
# select new item
self.SelectItem(newItem)
@@ -1069,13 +1092,11 @@
image = self.GetItemImage(dragItem, 0)
text = self.GetItemText(dragItem)
if self.GetPyData(dragItem)[0]['ctrl']:
- # recreate spin/text control for layer
+ # recreate data layer
btnbmp = Icons["layeropts"].GetBitmap((16,16))
newctrl = buttons.GenBitmapButton(self, id=wx.ID_ANY, bitmap=btnbmp, size=(24, 24))
newctrl.SetToolTipString(_("Click to edit layer settings"))
self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, newctrl)
- opacity = self.GetPyData(dragItem)[0]['maplayer'].GetOpacity()
- windval = self.GetPyData(dragItem)[0]['maplayer'].GetOpacity()
data = self.GetPyData(dragItem)
elif self.GetPyData(dragItem)[0]['type'] == 'command':
@@ -1090,13 +1111,11 @@
pass
newctrl.Bind(wx.EVT_TEXT_ENTER, self.OnCmdChanged)
newctrl.Bind(wx.EVT_TEXT, self.OnCmdChanged)
elif self.GetPyData(dragItem)[0]['type'] == 'group':
- #recreate group
+ # recreate group
newctrl = None
- windval = None
data = None
# decide where to put recreated item
@@ -1139,7 +1158,7 @@
else:
self.GetPyData(newItem)[0]['ctrl'] = None
- self.CheckItem(newItem, checked=checked)
+ self.CheckItem(newItem, checked=checked) # causes a new render
# newItem.SetHeight(TREE_ITEM_HEIGHT)
@@ -1228,7 +1247,7 @@
else:
vislayer = self.GetNextVisible(vislayer)
- Debug.msg (4, "LayerTree.ReoderLayers(): items=%s" % \
+ Debug.msg (4, "LayerTree.ReorderLayers(): items=%s" % \
(itemList))
# reorder map layers
@@ -1268,8 +1287,10 @@
self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers(updateTool=True)
+ # print "*** Change OnRender *****"
# item.SetHeight(TREE_ITEM_HEIGHT)
