[GRASS-SVN] r32882 - in grass-addons/gipe: . i.albedo i.evapo.time_integration
Tue Aug 19 06:43:14 EDT 2008
Author: ychemin
Date: 2008-08-19 06:43:10 -0400 (Tue, 19 Aug 2008)
New Revision: 32882
Added:
   grass-addons/gipe/i.evapo.time_integration/
   grass-addons/gipe/i.evapo.time_integration/Makefile
   grass-addons/gipe/i.evapo.time_integration/description.html
   grass-addons/gipe/i.evapo.time_integration/main.c
   grass-addons/gipe/Makefile.imagery
   grass-addons/gipe/gmmenu.tcl
   grass-addons/gipe/i.albedo/description.html
   grass-addons/gipe/i.albedo/main.c
   grass-addons/gipe/menudata.py
added i.evapo.time_integration
Modified: grass-addons/gipe/Makefile.imagery
--- grass-addons/gipe/Makefile.imagery	2008-08-19 10:14:07 UTC (rev 32881)
+++ grass-addons/gipe/Makefile.imagery	2008-08-19 10:43:10 UTC (rev 32882)
@@ -34,6 +34,7 @@
 	i.evapo.potrad \
 	i.evapo.PT \
 	i.evapo.SENAY \
+	i.evapo.time_integration \
 	i.evapo.TSA \
 	i.qc.modis \
 	i.latitude \
Modified: grass-addons/gipe/gmmenu.tcl
--- grass-addons/gipe/gmmenu.tcl	2008-08-19 10:14:07 UTC (rev 32881)
+++ grass-addons/gipe/gmmenu.tcl	2008-08-19 10:43:10 UTC (rev 32882)
@@ -600,6 +600,8 @@
 				{command {[G_msg "Actual ET (SEBAL)"]} {} "i.eb.eta" {} -command {execute i.eb.eta }}
 				{command {[G_msg "Actual ET (SENAY)"]} {} "i.evapo.SENAY" {} -command {execute i.evapo.SENAY }}
 				{command {[G_msg "Actual ET (TSA)"]} {} "i.evapo.TSA" {} -command {execute i.evapo.TSA }}
+				{separator}
+				{command {[G_msg "Actual ET Temporal Integration"]} {} "i.evapo.time_integration" {} -command {execute i.evapo.time_integration }}
 		{cascad {[G_msg "Energy Balance"]} {} "" $tmenu {
 				{command {[G_msg "Surface roughness (generic)"]} {} "i.eb.z0m0" {} -command {execute i.eb.z0m0 }}
Modified: grass-addons/gipe/i.albedo/description.html
--- grass-addons/gipe/i.albedo/description.html	2008-08-19 10:14:07 UTC (rev 32881)
+++ grass-addons/gipe/i.albedo/description.html	2008-08-19 10:43:10 UTC (rev 32882)
@@ -17,7 +17,7 @@
 <H2>AUTHORS</H2>
-Yann Chemin, AIT, Thailand<BR>
+Yann Chemin, International Rice Research Institute, The Philippines<BR>
 <p>
Modified: grass-addons/gipe/i.albedo/main.c
--- grass-addons/gipe/i.albedo/main.c	2008-08-19 10:14:07 UTC (rev 32881)
+++ grass-addons/gipe/i.albedo/main.c	2008-08-19 10:43:10 UTC (rev 32882)
@@ -134,6 +134,13 @@
 	landsat = (flag3->answer);
 	aster 	= (flag4->answer);
+	if (G_legal_filename (result) < 0)
+		G_fatal_error (_("[%s] is an illegal name"), result);
 	for (; *ptr != NULL; ptr++)
 		if (nfiles >= MAXFILES)
@@ -146,11 +153,6 @@
 			G_fatal_error (_("cell file [%s] not found"), name);
 			ok = 0;
-		if (G_legal_filename (result) < 0)
-			G_fatal_error (_("[%s] is an illegal name"), result);
-			ok = 0;
 		if (!ok){
 			continue;
Added: grass-addons/gipe/i.evapo.time_integration/Makefile
--- grass-addons/gipe/i.evapo.time_integration/Makefile	                        (rev 0)
+++ grass-addons/gipe/i.evapo.time_integration/Makefile	2008-08-19 10:43:10 UTC (rev 32882)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM = i.evapo.time_integration
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/i.evapo.time_integration/description.html
--- grass-addons/gipe/i.evapo.time_integration/description.html	                        (rev 0)
+++ grass-addons/gipe/i.evapo.time_integration/description.html	2008-08-19 10:43:10 UTC (rev 32882)
@@ -0,0 +1,58 @@
+<H2>DESCRIPTION</H2>
+<EM>i.evapo.time_integration</EM> integrates ETa in time following a reference ET (typically) from a set of meteorological stations dataset.
+Inputs:
+- ETa images
+- ETa images DOY (Day of Year)
+- ETo images
+- ETo DOYmin as a single value
+Method:
+1 - each ETa pixel is divided by the same day ETo and become ETrF
+2 - each ETrF pixel is multiplied by the ETo sum for the representative days
+3 - Sum all n temporal [ETrF*ETo_sum] pixels to make a summed(ET) in [DOYmin;DOYmax]
+representative days calculation:
+let assume i belongs to range [DOYmin;DOYmax]
+DOYbeforeETa[i] = ( DOYofETa[i] - DOYofETa[i-1] ) / 2
+DOYafterETa[i] = ( DOYofETa[i+1] - DOYofETa[i] ) / 2
+<H2>NOTES</H2>
+ETo images preparation:
+If you only have one meteorological station data, the easiest way is:
+n=0
+for ETo_val in Eto[1] Eto[2] ...
+do
+	r.mapcalc eto$n=$ETo_val
+	`expr n = n + 1'
+done
+with Eto[1], Eto[2], etc being a simple copy and paste from your data file of all ETo values separated by an empty space from each other.
+If you have several meteorological stations data, then you need to grid them, Thiessen polygons or interpolation for each day.
+For multi-year calculations, just continue incrementing DOY values above 366, it will continue working, up to maximum input of 400 satellite images.
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.eb.eta.html">i.eb.eta</A><br>
+<A HREF="i.evapo.potrad.html">i.evapo.potrad</A><br>
+<A HREF="i.evapo.SENAY.html">i.evapo.SENAY</A><br>
+<A HREF="r.surf.idw.html">r.surf.idw</A><br>
+<A HREF="r.surf.idw2.html">r.surf.idw2</A><br>
+<A HREF="r.bilinear.html">r.bilinear</A><br>
+</em>
+<H2>AUTHORS</H2>
+<p>
+<i>Last changed: $Date: 2008/08/25 06:17:43 $</i>
Added: grass-addons/gipe/i.evapo.time_integration/main.c
--- grass-addons/gipe/i.evapo.time_integration/main.c	                        (rev 0)
+++ grass-addons/gipe/i.evapo.time_integration/main.c	2008-08-19 10:43:10 UTC (rev 32882)
@@ -0,0 +1,398 @@
+ * MODULE:       i.evapo.time_integration
+ * AUTHOR(S):    Yann Chemin - ychemin at gmail.com
+ * PURPOSE:      Integrate in time the evapotranspiration from satellite,
+ *		 following a daily pattern from meteorological ETo.
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU Lesser General Public
+ *   	    	 License. Read the file COPYING that comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#define MAXFILES 400
+int
+main(int argc, char *argv[])
+	struct Cell_head cellhd;//region+header info
+	char *mapset; //mapset name
+	int nrows, ncols;
+	int row,col;
+	struct GModule *module;
+	struct Option *input, *input1, *input2, *input3, *output;
+	struct History history; //metadata
+	struct Colors colors; //Color rules
+	/* FMEO Declarations*****************/
+	char *name,*name1,*name2; //input raster name
+	char *result; //output raster name
+	//File Descriptors
+	int nfiles, nfiles1, nfiles2;
+	int infd[MAXFILES], infd1[MAXFILES], infd2[MAXFILES];
+	int outfd;
+	/* Pointers for file names 		*/
+	char **names;
+	char **ptr;
+	char **names1;
+	char **ptr1;
+	char **names2;
+	char **ptr2;
+	double DOYbeforeETa[MAXFILES],DOYafterETa[MAXFILES];
+	int bfr,aft;
+	int ok;
+	int i=0,j=0;
+	double etodoy; /*minimum ETo DOY*/
+	void *inrast[MAXFILES], *inrast1[MAXFILES], *inrast2[MAXFILES];
+	DCELL *outrast;
+	int data_format; /* 0=double  1=float  2=32bit signed int  5=8bit unsigned int (ie text) */
+	RASTER_MAP_TYPE in_data_type[MAXFILES]; /* ETa */
+	RASTER_MAP_TYPE in_data_type1[MAXFILES]; /* DOY of ETa */
+	RASTER_MAP_TYPE in_data_type2[MAXFILES]; /* ETo */
+	RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("evapotranspiration,temporal,integration");
+	module->description =
+		_("Temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)\n");
+	/* Define the different options */
+	input = G_define_standard_option(G_OPT_R_INPUT) ;
+	input->key        =_("eta");
+	input->multiple   = YES;
+	input->description= _("Names of satellite ETa layers [mm/d or cm/d]");
+	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input1->key        =_("eta_doy");
+	input1->multiple   = YES;
+	input1->description= _("Names of satellite ETa Day of Year (DOY) layers [0-400] [-]");
+	input2 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input2->key        =_("eto");
+	input2->multiple   = YES;
+	input2->description= _("Names of meteorological station ETo layers [0-400] [mm/d or cm/d]");
+	input3 = G_define_option() ;
+	input3->key        =_("eto_doy_min");
+	input3->type       = TYPE_DOUBLE;
+	input3->required   = YES;
+	input3->description =_("Value of DOY for ETo first day");
+	output = G_define_standard_option(G_OPT_R_OUTPUT) ;
+	output->description= _("Name of the output temporally integrated ETa layer");
+	/* FMEO init nfiles */
+	nfiles = 1;
+	nfiles1 = 1;
+	nfiles2 = 1;
+	if (G_parser(argc, argv))
+		exit (-1);
+	ok = 1;
+	names	= input->answers;
+	ptr	= input->answers;
+	names1	= input1->answers;
+	ptr1	= input1->answers;
+	names2	= input2->answers;
+	ptr2	= input2->answers;
+	etodoy	= atof(input3->answer);
+	result	= output->answer;
+		ok = 0;
+	for (; *ptr != NULL; ptr++)
+		if (nfiles > MAXFILES)
+			G_fatal_error (_("%s - too many ETa files. Only %d allowed"), G_program_name(), MAXFILES);
+		name = *ptr;
+		/* find map in mapset */
+		mapset = G_find_cell2 (name, "");
+	        if (mapset == NULL)
+			G_fatal_error (_("cell file [%s] not found"), name);
+			ok = 0;
+		if (!ok){
+			continue;
+		infd[nfiles] = G_open_cell_old (name, mapset);
+		if (infd[nfiles] < 0)
+			ok = 0;
+			continue;
+		/* Allocate input buffer */
+		in_data_type[nfiles] = G_raster_map_type(name, mapset);
+		if( (infd[nfiles] = G_open_cell_old(name,mapset)) < 0){
+			G_fatal_error(_("Cannot open cell file [%s]"), name);
+		if( (G_get_cellhd(name,mapset,&cellhd)) < 0){
+			G_fatal_error(_("Cannot read file header of [%s]"), name);
+		inrast[nfiles] = G_allocate_raster_buf(in_data_type[nfiles]);
+		nfiles++;
+	nfiles--;
+	if (nfiles <= 1){
+		G_fatal_error(_("The min specified input map is two"));
+	ok=1;
+	for (; *ptr1 != NULL; ptr1++)
+		if (nfiles1 > MAXFILES)
+		name1 = *ptr1;
+		mapset = G_find_cell2 (name1, "");
+			G_fatal_error (_("cell file [%s] not found"), name1);
+			ok = 0;
+		if (!ok){
+			continue;
+		infd1[nfiles] = G_open_cell_old (name1, mapset);
+		if (infd1[nfiles] < 0)
+			ok = 0;
+			continue;
+		in_data_type1[nfiles] = G_raster_map_type(name1, mapset);
+		if( (infd1[nfiles] = G_open_cell_old(name1,mapset)) < 0){
+			G_fatal_error(_("Cannot open cell file [%s]"), name1);
+		if( (G_get_cellhd(name1,mapset,&cellhd)) < 0){
+			G_fatal_error(_("Cannot read file header of [%s]"), name1);
+		inrast1[nfiles] = G_allocate_raster_buf(in_data_type[nfiles1]);
+		nfiles1++;
+	nfiles1--;
+	if (nfiles1 <= 1){
+	if(nfiles!=nfiles1)
+		G_fatal_error (_("ETa and ETa_DOY file numbers are not equal!"));
+	ok=1;
+	for (; *ptr2 != NULL; ptr2++)
+		name2 = *ptr2;
+		mapset = G_find_cell2 (name2, "");
+			G_fatal_error (_("cell file [%s] not found"), name2);
+			ok = 0;
+		if (!ok){
+			continue;
+		infd2[nfiles2] = G_open_cell_old (name2, mapset);
+		if (infd2[nfiles2] < 0)
+			ok = 0;
+			continue;
+		in_data_type2[nfiles2] = G_raster_map_type(name2, mapset);
+		if( (infd2[nfiles2] = G_open_cell_old(name2,mapset)) < 0){
+			G_fatal_error(_("Cannot open cell file [%s]"), name2);
+		if( (G_get_cellhd(name2,mapset,&cellhd)) < 0){
+			G_fatal_error(_("Cannot read file header of [%s]"), name2);
+		inrast2[nfiles2] = G_allocate_raster_buf(in_data_type2[nfiles2]);
+		nfiles2++;
+	nfiles2--;
+	if (nfiles2 <= 1){
+	/* Allocate output buffer, use input map data_type */
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	outrast = G_allocate_raster_buf(out_data_type);
+	/* Create New raster files */
+	if ( (outfd = G_open_raster_new (result,1)) < 0){
+		G_fatal_error (_("Could not open <%s>"),result);
+	/* Process pixels */
+	double doy[MAXFILES];
+	double sum[MAXFILES];
+	for (row = 0; row < nrows; row++)
+		DCELL d_out;
+		DCELL d_ETrF[MAXFILES];
+		DCELL d[MAXFILES];
+		DCELL d1[MAXFILES];
+		DCELL d2[MAXFILES];
+		G_percent (row, nrows, 2);
+		/* read input map */
+		for (i=1;i<=nfiles;i++)
+			if( (G_get_raster_row(infd[i],inrast[i],row,in_data_type[i])) < 0){
+				G_fatal_error (_("Could not read from <%s>"),name);
+		for (i=1;i<=nfiles1;i++)
+			if( (G_get_raster_row(infd1[i],inrast1[i],row,in_data_type1[i])) < 0){
+				G_fatal_error (_("Could not read from <%s>"),name1);
+		for (i=1;i<=nfiles2;i++)
+			if( (G_get_raster_row(infd2[i],inrast2[i],row,in_data_type2[i])) < 0){
+				G_fatal_error (_("Could not read from <%s>"),name2);
+		/*process the data */
+		for (col=0; col < ncols; col++)
+			for(i=1;i<=nfiles;i++)
+				switch(in_data_type[i])
+					case CELL_TYPE:
+						d[i] = (double) ((CELL *) inrast[i])[col];
+						break;
+					case FCELL_TYPE:
+						d[i] = (double) ((FCELL *) inrast[i])[col];
+						break;
+					case DCELL_TYPE:
+						d[i] = (double) ((DCELL *) inrast[i])[col];
+						break;
+			for(i=1;i<=nfiles1;i++)
+				switch(in_data_type1[i])
+					case CELL_TYPE:
+						d1[i] = (double) ((CELL *) inrast1[i])[col];
+						break;
+					case FCELL_TYPE:
+						d1[i] = (double) ((FCELL *) inrast1[i])[col];
+						break;
+					case DCELL_TYPE:
+						d1[i] = (double) ((DCELL *) inrast1[i])[col];
+						break;
+			for(i=1;i<=nfiles2;i++)
+				switch(in_data_type2[i])
+					case CELL_TYPE:
+						d2[i] = (double) ((CELL *) inrast2[i])[col];
+						break;
+					case FCELL_TYPE:
+						d2[i] = (double) ((FCELL *) inrast2[i])[col];
+						break;
+					case DCELL_TYPE:
+						d2[i] = (double) ((DCELL *) inrast2[i])[col];
+						break;
+			/* Find out the DOY of the eto image	*/
+			/* DOY_eto_index = ModisDOY - etodoymin	*/
+				doy[i] = d1[i] - etodoy;
+				d_ETrF[i]=d[i]/d2[(int)doy[i]];
+				if(i==1)
+					DOYbeforeETa[i]=etodoy;
+				else
+					DOYbeforeETa[i]=(d[i]-d[i-1])/2.0;
+				if(i==nfiles1)
+					DOYafterETa[i]=etodoy+nfiles2;
+				else
+					DOYafterETa[i]=(d[i+1]-d[i])/2.0;
+			sum[MAXFILES]=0.0;
+				bfr = (int) DOYbeforeETa[i];
+				aft = (int) DOYafterETa[i];
+				for(j=bfr;j<aft;j++)
+					sum[i]+=d2[j];
+			d_out = 0.0;
+				d_out += d_ETrF[i]*sum[i];
+			outrast[col] = d_out;
+		if (G_put_raster_row (outfd, outrast, out_data_type) < 0)
+			G_fatal_error (_("Cannot write to <%s>"),result);
+		G_free (inrast[i]);
+		G_close_cell (infd[i]);
+		G_free (inrast1[i]);
+		G_close_cell (infd1[i]);
+		G_free (inrast2[i]);
+		G_close_cell (infd2[i]);
+	G_free (outrast);
+	G_close_cell (outfd);
+	/* Color table from 0.0 to 1.0 */
+	G_init_colors(&colors);
+	G_add_color_rule(0.0,0,0,0,10.0,255,255,255,&colors);
+	/* Metadata */
+	G_short_history(result,"raster",&history);
+	G_command_history(&history);
+	G_write_history(result,&history);
+	exit(EXIT_SUCCESS);
Modified: grass-addons/gipe/menudata.py
--- grass-addons/gipe/menudata.py	2008-08-19 10:14:07 UTC (rev 32881)
+++ grass-addons/gipe/menudata.py	2008-08-19 10:43:10 UTC (rev 32882)
@@ -1510,6 +1510,11 @@
                            _("Actual ET (TSA) NOT WORKING YET"),
                            "self.RunMenuCmd",
                            "i.evapo.TSA"),
+                          (_("Actual ET Time Integration"),
+                           _("Temporal Integration of Actual ET using daily ETo"),
+                           "self.RunMenuCmd",
+                           "i.evapo.time_integration"),
                          (_("Energy Balance"), (
