[GRASS-SVN] r32951 - grass/trunk/vector/v.in.dxf
Wed Aug 20 19:24:56 EDT 2008
Author: martinl
Date: 2008-08-20 19:24:56 -0400 (Wed, 20 Aug 2008)
New Revision: 32951
   grass/trunk/vector/v.in.dxf/main.c
v.in.dxf: cosmetics, more gui sections(merge from devbr6, r32946)
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c	2008-08-20 23:24:51 UTC (rev 32950)
+++ grass/trunk/vector/v.in.dxf/main.c	2008-08-20 23:24:56 UTC (rev 32951)
@@ -69,10 +69,6 @@
     module->description =
 	_("Converts files in DXF format to GRASS vector map format.");
-    flag.list = G_define_flag();
-    flag.list->key = 'l';
-    flag.list->description = _("List available layers and exit");
     flag.extent = G_define_flag();
     flag.extent->key = 'e';
     flag.extent->description = _("Ignore the map extent of DXF file");
@@ -85,19 +81,26 @@
     flag.topo->key = 'b';
     flag.topo->description = _("Do not build topology");
+    flag.frame = G_define_flag();
+    flag.frame->key = 'f';
+    flag.frame->description = _("Import polyface meshes as 3D wire frame");
+    flag.list = G_define_flag();
+    flag.list->key = 'l';
+    flag.list->description = _("List available layers and exit");
+    flag.list->guisection = _("DXF layers");
     flag.invert = G_define_flag();
     flag.invert->key = 'i';
     flag.invert->description =
 	_("Invert selection by layers (don't import layers in list)");
+    flag.invert->guisection = _("DXF layers");
     flag.one_layer = G_define_flag();
     flag.one_layer->key = '1';
     flag.one_layer->description = _("Import all objects into one layer");
+    flag.one_layer->guisection = _("DXF layers");
-    flag.frame = G_define_flag();
-    flag.frame->key = 'f';
-    flag.frame->description = _("Import polyface meshes as 3D wire frame");
     opt.input = G_define_standard_option(G_OPT_F_INPUT);
     opt.input->description = _("Name of input DXF file");
@@ -110,6 +113,7 @@
     opt.layers->required = NO;
     opt.layers->multiple = YES;
     opt.layers->description = _("List of layers to import");
+    opt.layers->guisection = _("DXF layers");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
