[GRASS-SVN] r32970 - in grass-addons/gipe: i.latitude i.lmf
svn_grass at osgeo.org
Thu Aug 21 09:32:52 EDT 2008
Author: ychemin
Date: 2008-08-21 09:32:52 -0400 (Thu, 21 Aug 2008)
New Revision: 32970
grass-addons/gipe/i.latitude/main.c
grass-addons/gipe/i.lmf/fitting.c
grass-addons/gipe/i.lmf/lmf.c
grass-addons/gipe/i.lmf/main.c
grass-addons/gipe/i.lmf/make_matrix.c
code cleaning, upgrade, standardization
Modified: grass-addons/gipe/i.latitude/main.c
--- grass-addons/gipe/i.latitude/main.c 2008-08-21 13:07:01 UTC (rev 32969)
+++ grass-addons/gipe/i.latitude/main.c 2008-08-21 13:32:52 UTC (rev 32970)
@@ -21,25 +21,25 @@
int main(int argc, char *argv[])
- struct Cell_head cellhd; //region+header info
- char *mapset; // mapset name
+ struct Cell_head cellhd; /*region+header info*/
+ char *mapset; /*mapset name*/
int nrows, ncols;
int row,col;
- int not_ll=0;//if proj is not lat/long, it will be 1.
+ int not_ll=0;/*if proj is not lat/long, it will be 1.*/
struct GModule *module;
struct Option *input1, *output1;
struct Flag *flag1;
- struct History history; //metadata
+ struct History history; /*metadata*/
struct pj_info iproj;
struct pj_info oproj;
/* FMEO Declarations*****************/
- char *name; // input raster name
- char *result1; //output raster name
- //File Descriptors
+ char *name; /*input raster name*/
+ char *result1; /*output raster name*/
+ /*File Descriptors*/
int infd;
int outfd1;
@@ -52,7 +52,7 @@
double latitude, longitude;
void *inrast;
- unsigned char *outrast1;
+ DCELL *outrast1;
RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
RASTER_MAP_TYPE data_type_inrast;
@@ -64,15 +64,10 @@
/* Define the different options */
input1 = G_define_standard_option(G_OPT_R_INPUT) ;
- input1->key = _("input");
input1->description=_("Name of the input map");
- input1->answer =_("input");
output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
- output1->key =_("latitude");
output1->description=_("Name of the output latitude layer");
- output1->answer =_("latitude");
if (G_parser(argc, argv))
exit (EXIT_FAILURE);
@@ -104,7 +99,7 @@
nrows = G_window_rows();
ncols = G_window_cols();
- //Shamelessly stolen from r.sun !!!!
+ /* Shamelessly stolen from r.sun !!!! */
/* Set up parameters for projection to lat/long if necessary */
if ((G_projection() != PROJECTION_LL)) {
not_ll=1;
@@ -123,7 +118,7 @@
sprintf(oproj.proj, "ll");
if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
G_fatal_error(_("Unable to set up lat/long projection parameters"));
- }//End of stolen from r.sun :P
+ }/* End of stolen from r.sun :P*/
outrast1 = G_allocate_raster_buf(data_type_output);
if ( (outfd1 = G_open_raster_new (result1,data_type_output)) < 0)
@@ -144,10 +139,10 @@
G_fatal_error(_("Error in pj_do_proj"));
}else{
- //Do nothing
+ /*Do nothing*/
d_lat = latitude;
- ((DCELL *) outrast1)[col] = d_lat;
+ outrast1[col] = d_lat;
if (G_put_raster_row (outfd1, outrast1, data_type_output) < 0)
G_fatal_error(_("Cannot write to output raster file"));
Modified: grass-addons/gipe/i.lmf/fitting.c
--- grass-addons/gipe/i.lmf/fitting.c 2008-08-21 13:07:01 UTC (rev 32969)
+++ grass-addons/gipe/i.lmf/fitting.c 2008-08-21 13:32:52 UTC (rev 32970)
@@ -18,14 +18,14 @@
nn=nfunc*2+2;
- //Value Initialization
+ /*Value Initialization*/
for(i=0;i<nn;i++){
c[i]=0.0;
for(i=0;i<npoint;i++){
vfit[i]=0.0;
- //Matrix Initialization
+ /*Matrix Initialization*/
for(i=0;i<nn;i++){
for(j=0;j<nn;j++){
tf[i][j]=0.0;
@@ -33,7 +33,7 @@
vec[i]=0.0;
- //Making Matrix
+ /*Making Matrix*/
if(idx1[i]==1){
for(k1=0;k1<nn;k1++){
@@ -44,7 +44,7 @@
- //Matrix Copy and Inversion
+ /*Matrix Copy and Inversion*/
for(i=0;i<nn;i++){
for(j=i;j<nn;j++){
tfij=tf[i][j];
@@ -53,7 +53,7 @@
invert_matrix(tinv,nn);
- //Calculation of Coefficients
+ /*Calculation of Coefficients*/
for(i=0;i<nn;i++){
sum=0.0;
for(j=0;j<nn;j++){
@@ -61,7 +61,7 @@
c[i]=sum;
- //Calculating theoretical value
+ /*Calculating theoretical value*/
sum=0.0;
for(k=0;k<nn;k++){
Modified: grass-addons/gipe/i.lmf/lmf.c
--- grass-addons/gipe/i.lmf/lmf.c 2008-08-21 13:07:01 UTC (rev 32969)
+++ grass-addons/gipe/i.lmf/lmf.c 2008-08-21 13:32:52 UTC (rev 32970)
@@ -32,17 +32,17 @@
double tcld,thh,thl;
double vaic,delta;
int idx1[NMAX];
- //for fitting
+ /*for fitting*/
double dat[NMAX];
double f[NMAX][MAXF],c[MAXF];
double vfit[NMAX];
double ipoint[MAXB];
- //for iteration
+ /*for iteration*/
double dat0[NMAX],c0[MAXF];
double dat1[NMAX];
- //for Matrix Inversion
+ /*for Matrix Inversion*/
int numk[MAXF]={ 1,2,3,4,6,12,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 };
- //Set Defaults
+ /*Set Defaults*/
nfunc=6;
for(i=0;i<NMAX;i++){
for(j=0;j<MAXF;j++){
@@ -52,30 +52,30 @@
make_matrix(nbands,npoint,nfunc,numk,f);
nwin=3;
mmsw=1;
- //nds=npoint;
+ /*nds=npoint;*/
nds=2*nfunc+2;
- //LMF Process
- //Checking Pixel Value
+ /*LMF Process*/
+ /*Checking Pixel Value*/
fitsw=1;
- //fitting method
+ /*fitting method*/
tcld=0.15;
fitmd=2;
- //FITMD0----
+ /*FITMD0----*/
if(fitmd==0){
thh=tcld*2.0;
thl=-tcld;
- //FITMD1----
+ /*FITMD1----*/
if(fitmd==1){
thh=tcld;
thl=-tcld*2.0;
- //FITMD2----
+ /*FITMD2----*/
if(fitmd==2){
thh=tcld;
thl=-tcld;
- //initialize arrays
+ /*initialize arrays*/
for(k=0;k<nbands;k++){
dat0[k]=0.0;
outpix[k]=0.0;
@@ -98,13 +98,13 @@
dat0[k]=inpix[k];
dat[k]=dat0[k];
- //Minimax Filter
+ /*Minimax Filter*/
if(mmsw>=1&&fitmd==0){
minmax(nbands,nwin,dat);
}else if(mmsw>=1&&fitmd==1){
maxmin(nbands,nwin,dat);
- //Fitting
+ /*Fitting*/
fitting(nbands,3,dat,idx1,f,c,vfit);
outpix[k]=vfit[k];
Modified: grass-addons/gipe/i.lmf/main.c
--- grass-addons/gipe/i.lmf/main.c 2008-08-21 13:07:01 UTC (rev 32969)
+++ grass-addons/gipe/i.lmf/main.c 2008-08-21 13:32:52 UTC (rev 32970)
@@ -44,20 +44,20 @@
int
- struct Cell_head cellhd;//region+header info
- char *mapset; //mapset name
+ struct Cell_head cellhd;/*region+header info*/
int nrows, ncols;
int row,col;
struct Option *input,*ndate,*output;
- char *name; //input raster name
- char *result[MAXFILES]; //output raster name
+ char *result[MAXFILES]; /*output raster name*/
int nfiles;
int infd[MAXFILES];
int outfd[MAXFILES];
@@ -75,10 +75,6 @@
RASTER_MAP_TYPE in_data_type[MAXFILES]; /* 0=numbers 1=text */
RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
- char *fileName;
-#define fileNameLe 8
-#define fileNamePosition 3
int ndates;
double inpix[MAXFILES]={0.0};
double outpix[MAXFILES]={0.0};
@@ -93,8 +89,7 @@
- input = G_define_standard_option(G_OPT_R_INPUT) ;
- input->multiple = YES;
+ input = G_define_standard_option(G_OPT_R_INPUTS) ;
input->description= _("Names of input layers");
ndate = G_define_option();
Modified: grass-addons/gipe/i.lmf/make_matrix.c
--- grass-addons/gipe/i.lmf/make_matrix.c 2008-08-21 13:07:01 UTC (rev 32969)
+++ grass-addons/gipe/i.lmf/make_matrix.c 2008-08-21 13:32:52 UTC (rev 32970)
@@ -1,7 +1,5 @@
-// Making Triangular Function Matrix/Vector
+/* Making Triangular Function Matrix/Vector*/
-// double f[NMAX][MAXF];
#include<stdio.h>
#include<stdlib.h>
#include<math.h>
@@ -17,20 +15,18 @@
int i,j,j1,j2;
double di,dk;
-// printf("make_matrix: n=%d\tnpoint=%d\tnfunc=%d\n",n,npoint,nfunc);
nn=2*nfunc+2;
-// printf("make_matrix: nn=%d\n",nn);
eps=1.0;
- //Set Constants
+ /*Set Constants*/
vn= (double) npoint;
angle=2.0*PI/vn;
- //Matrix Clear
+ /*Matrix Clear*/
for(i=0;i<n;i++){
for(j=0;j<nn;j++){
f[i][j]=0.0;
- //Making Matrix
+ /*Making Matrix*/
for(i=0;i<n;i++){
di= (double) (i+1);
for(j=0;j<nfunc;j++){
