[GRASS-SVN] r32979 - grass-addons/gipe/i.vi.mpi
svn_grass at osgeo.org
Thu Aug 21 10:35:03 EDT 2008
Author: ychemin
Date: 2008-08-21 10:35:03 -0400 (Thu, 21 Aug 2008)
New Revision: 32979
grass-addons/gipe/i.vi.mpi/main.c
code cleaning, upgrade, standardization
Modified: grass-addons/gipe/i.vi.mpi/main.c
--- grass-addons/gipe/i.vi.mpi/main.c 2008-08-21 14:26:48 UTC (rev 32978)
+++ grass-addons/gipe/i.vi.mpi/main.c 2008-08-21 14:35:03 UTC (rev 32979)
@@ -40,27 +40,23 @@
MPI_Comm_size(MPI_COMM_WORLD,&NUM_HOSTS);
MPI_Comm_rank(MPI_COMM_WORLD,&me);
- //printf("rank =%d\n",me);
if(!me)
- // printf("I am Master\n");
- struct Cell_head cellhd; //region+header info
- char *mapset; // mapset name
+ struct Cell_head cellhd; /*region+header info*/
+ char *mapset; /*mapset name*/
int row,col,row_n;
- int verbose=1;
- char *viflag;// Switch for particular index
+ char *viflag;/*Switch for particular index*/
struct GModule *module;
struct Option *input1, *input2,*input3,*input4,*input5,*input6,*input7,*input8, *output;
struct Flag *flag1;
- struct History history; //metadata
+ struct History history; /*metadata*/
/* FMEO Declarations*****************/
- char *name; // input raster name
- char *result; //output raster name
- //File Descriptors
+ char *name; /*input raster name*/
+ char *result; /*output raster name*/
+ /*File Descriptors*/
int infd_redchan, infd_nirchan, infd_greenchan, infd_bluechan, infd_chan5chan, infd_chan7chan;
int outfd;
@@ -69,7 +65,7 @@
int i=0,j=0,temp;
void *inrast_redchan, *inrast_nirchan, *inrast_greenchan, *inrast_bluechan, *inrast_chan5chan, *inrast_chan7chan;
- unsigned char *outrast;
+ DCELL *outrast;
RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
RASTER_MAP_TYPE data_type_redchan;
@@ -83,7 +79,7 @@
G_gisinit(argv[0]);
module = G_define_module();
- //module->keywords = _("vegetation index, biophysical parameters");
+ module->keywords = _("vegetation index, biophysical parameters");
module->description = _("13 types of vegetation indices from red and nir, and only some requiring additional bands");
/* Define the different options */
@@ -95,53 +91,33 @@
input1->description=_("Name of VI: sr,ndvi,ipvi,dvi,pvi,wdvi,savi,msavi,msavi2,gemi,arvi,gvi,gari.");
input1->answer =_("ndvi");
- input2 = G_define_option() ;
+ input2 = G_define_standard_option(G_OPT_R_INPUT) ;
input2->key = _("red");
- input2->type = TYPE_STRING;
- input2->required = YES;
- input2->gisprompt =_("old,cell,raster") ;
input2->description=_("Name of the RED Channel surface reflectance map [0.0;1.0]");
- input2->answer =_("redchan");
- input3 = G_define_option() ;
+ input3 = G_define_standard_option(G_OPT_R_INPUT) ;
input3->key =_("nir");
- input3->type = TYPE_STRING;
- input3->required = YES;
- input3->gisprompt =_("old,cell,raster");
input3->description=_("Name of the NIR Channel surface reflectance map [0.0;1.0]");
- input3->answer =_("nirchan");
- input4 = G_define_option() ;
+ input4 = G_define_standard_option(G_OPT_R_INPUT) ;
input4->key =_("green");
- input4->type = TYPE_STRING;
input4->required = NO;
- input4->gisprompt =_("old,cell,raster");
input4->description=_("Name of the GREEN Channel surface reflectance map [0.0;1.0]");
- // input4->answer =_("greenchan");
- input5 = G_define_option() ;
+ input5 = G_define_standard_option(G_OPT_R_INPUT) ;
input5->key =_("blue");
- input5->type = TYPE_STRING;
input5->required = NO;
- input5->gisprompt =_("old,cell,raster");
input5->description=_("Name of the BLUE Channel surface reflectance map [0.0;1.0]");
- // input5->answer =_("bluechan");
- input6 = G_define_option() ;
+ input6 = G_define_standard_option(G_OPT_R_INPUT) ;
input6->key =_("chan5");
- input6->type = TYPE_STRING;
input6->required = NO;
- input6->gisprompt =_("old,cell,raster");
input6->description=_("Name of the CHAN5 Channel surface reflectance map [0.0;1.0]");
- // input6->answer =_("chan5chan");
- input7 = G_define_option() ;
+ input7 = G_define_standard_option(G_OPT_R_INPUT) ;
input7->key =_("chan7");
- input7->type = TYPE_STRING;
input7->required = NO;
- input7->gisprompt =_("old,cell,raster");
input7->description=_("Name of the CHAN7 Channel surface reflectance map [0.0;1.0]");
- // input7->answer =_("chan7chan");
input8 = G_define_option() ;
input8->key =_("tmp");
@@ -149,21 +125,10 @@
input8->required = NO;
input8->gisprompt =_("no of operation value");
input8->description=_("User input for number of operation");
- // input8->answer =_("1");
- output= G_define_option() ;
- output->key =_("vi");
- output->type = TYPE_STRING;
- output->required = YES;
- output->gisprompt =_("new,cell,raster");
+ output= G_define_standard_option(G_OPT_R_OUTPUT) ;
output->description=_("Name of the output vi layer");
- output->answer =_("vi");
- flag1 = G_define_flag();
- flag1->key = 'q';
- flag1->description = _("Quiet");
if (G_parser(argc, argv))
exit (EXIT_FAILURE);
@@ -177,7 +142,6 @@
temp = atoi(input8->answer);
result = output->answer;
- verbose = (!flag1->answer);
mapset = G_find_cell2(redchan, "");
if (mapset == NULL) {
@@ -260,7 +224,6 @@
G_debug(3, "number of rows %d",cellhd.rows);
nrows = G_window_rows();
ncols = G_window_cols();
- //nrows=9;
outrast = G_allocate_raster_buf(data_type_output);
/* Create New raster files */
@@ -271,7 +234,7 @@
int I[ncols+1];
host_n=1;
- printf("%d", temp);
+ G_message("tmp=%d", temp);
for(i=1;i<NUM_HOSTS;i++){
MPI_Send(&temp,1,MPI_INT,i,1,MPI_COMM_WORLD);
@@ -296,10 +259,8 @@
DCELL d_nirchan;
DCELL d_chan5chan;
DCELL d_chan7chan;
- if(verbose)
- G_percent(row,nrows,2);
- //printf("r=%d, k=%d, row=%d\n",r,k,row);
- /* read soil input maps */
+ G_percent(row,nrows,2);
+ /* read input maps */
if(G_get_raster_row(infd_redchan,inrast_redchan,row,data_type_redchan)<0)
G_fatal_error(_("Could not read from <%s>"),redchan);
if(G_get_raster_row(infd_nirchan,inrast_nirchan,row,data_type_nirchan)<0)
@@ -407,7 +368,6 @@
db[5][col]= d_chan7chan;
- // to change to multiple to output files.
if(G_is_d_null_value(&d_redchan)){
i=0;
}else if(G_is_d_null_value(&d_nirchan)){
@@ -476,13 +436,13 @@
I[col]=i;
- }//else
+ }/*else*/
- }//col
- //printf("Row data has genareted\n");
+ }/*col*/
+ /*printf("Row data has genareted\n");*/
row_n=k-1;
I[ncols]=row_n;
- //MPI_Send(&row_n,1,MPI_INT,k,1,MPI_COMM_WORLD);
+ /*MPI_Send(&row_n,1,MPI_INT,k,1,MPI_COMM_WORLD);*/
MPI_Send(I,ncols+1,MPI_INT,k,1,MPI_COMM_WORLD);
MPI_Send(db,6*ncols,MPI_DOUBLE,k,1,MPI_COMM_WORLD);
/*MPI_Send(db1,ncols,MPI_DOUBLE,k,1,MPI_COMM_WORLD);
@@ -492,9 +452,9 @@
MPI_Send(db5,ncols,MPI_DOUBLE,k,1,MPI_COMM_WORLD);
- }//k
+ }/*k*/
for(k=1;k<NUM_HOSTS;k++){
- //MPI_Recv(&row_n,1,MPI_INT,k,1,MPI_COMM_WORLD,&status);
+ /*MPI_Recv(&row_n,1,MPI_INT,k,1,MPI_COMM_WORLD,&status);*/
MPI_Recv(R,ncols+1,MPI_DOUBLE,k,1,MPI_COMM_WORLD,&status);
row_n=R[ncols];
for (cn=0;cn<ncols;cn++)
@@ -504,31 +464,26 @@
for(k=0;k<(NUM_HOSTS-1);k++)
for(j=0;j<ncols;j++)
- ((DCELL *) outrast)[j] = outputImage[k][j];
+ outrast[j] = outputImage[k][j];
if (G_put_raster_row (outfd, outrast, data_type_output) < 0)
G_fatal_error(_("Cannot write to output raster file"));
- }//r
+ }/*r*/
k=1;
int lm=0;
for(r=row+1;r<nrows;r++)
- // printf("row %d, node %d\n",r,k);
+ /* printf("row %d, node %d\n",r,k);*/
DCELL d_bluechan;
DCELL d_greenchan;
DCELL d_redchan;
DCELL d_nirchan;
DCELL d_chan5chan;
DCELL d_chan7chan;
- if(verbose)
if(G_get_raster_row(infd_redchan,inrast_redchan,r,data_type_redchan)<0)
if(G_get_raster_row(infd_nirchan,inrast_nirchan,r,data_type_nirchan)<0)
@@ -637,8 +592,6 @@
db[4][col]= d_chan5chan;
i=0;
@@ -708,10 +661,10 @@
I[col]=i;
- }//col
+ }/*col*/
row_n=k-1;
I[ncols]=row_n;
@@ -722,11 +675,11 @@
k++;
lm=1;
- }//r
+ }/*r */
if(lm)
for(nh=1;nh<k;nh++){
- // MPI_Recv(&row_n,1,MPI_INT,nh,1,MPI_COMM_WORLD,&status);
+ /* MPI_Recv(&row_n,1,MPI_INT,nh,1,MPI_COMM_WORLD,&status);*/
MPI_Recv(R,ncols+1,MPI_DOUBLE,nh,1,MPI_COMM_WORLD,&status);
row_n=R[ncols];
@@ -736,15 +689,12 @@
for(nh=0;nh<(k-1);nh++)
- ((DCELL *) outrast)[j] = outputImage[nh][j];
+ outrast[j] = outputImage[nh][j];
MPI_Finalize();
G_free(inrast_redchan);
G_close_cell(infd_redchan);
@@ -769,23 +719,23 @@
G_free(outrast);
G_close_cell(outfd);
- //G_short_history(result, "raster", &history);
- //G_command_history(&history);
- //G_write_history(result,&history);
+ G_short_history(result, "raster", &history);
+ G_command_history(&history);
+ G_write_history(result,&history);
exit(EXIT_SUCCESS);
- }//if end
+ }/*if end*/
else if(me){
int col,n_rows,i,row_n,modv,nrows,ncols,t,temp;
int *I;
double *a, *b, *c, *d, *e, *f, *r;
- //double *r;
+ /*double *r;*/
MPI_Recv(&temp,1,MPI_INT,0,1,MPI_COMM_WORLD,&status);
MPI_Recv(&nrows,1,MPI_INT,0,1,MPI_COMM_WORLD,&status);
MPI_Recv(&ncols,1,MPI_INT,0,1,MPI_COMM_WORLD,&status);
- //printf("Slave->%d: nrows=%d, ncols=%d \n",me,nrows,ncols);
+ /*printf("Slave->%d: nrows=%d, ncols=%d \n",me,nrows,ncols);*/
I=(int *)malloc((ncols+2)*sizeof(int));
a=(double *)malloc((ncols+1)*sizeof(double));
@@ -799,16 +749,16 @@
double db[6][ncols];
n_rows=nrows/(NUM_HOSTS-1);
modv=nrows%(NUM_HOSTS-1);
- //temp=10;
- //printf("%d\n",temp);
+ /*temp=10;*/
+ /*printf("%d\n",temp);*/
- //int temp;
+ /*int temp; */
if(modv>=me)
n_rows++;
for(i=0;i<n_rows;i++)
- //MPI_Recv(&row_n,1,MPI_INT,0,1,MPI_COMM_WORLD,&status);
+ /*MPI_Recv(&row_n,1,MPI_INT,0,1,MPI_COMM_WORLD,&status);*/
MPI_Recv(I,ncols+1,MPI_INT,0,1,MPI_COMM_WORLD,&status);
MPI_Recv(db,6*ncols,MPI_DOUBLE,0,1,MPI_COMM_WORLD,&status);
/* MPI_Recv(a,ncols,MPI_DOUBLE,0,1,MPI_COMM_WORLD,&status);
@@ -833,7 +783,7 @@
if (I[col]==0) r[col]=-999.99;
else if (I[col]==1){
- //sr
+ /*sr*/
if( a[col] == 0.0 ){
r[col] = -1.0;
} else {
@@ -841,7 +791,7 @@
else if (I[col]==2){
- //ndvi
+ /*ndvi*/
if( ( b[col] + a[col] ) == 0.0 ){
r[col] = -1.0;
} else {
@@ -849,7 +799,7 @@
else if (I[col]==3){
- //ipvi
+ /*ipvi*/
r[col] = -1.0;
@@ -859,7 +809,7 @@
else if (I[col]==4){
- //dvi
+ /*dvi*/
r[col] = -1.0;
} else {
@@ -867,7 +817,7 @@
else if (I[col]==5){
- //pvi
+ /*pvi*/
r[col] = -1.0;
} else {
@@ -875,8 +825,8 @@
else if (I[col]==6){
- //wdvi
- double slope=1;//slope of soil line //
+ /*wdvi*/
+ double slope=1;/*slope of soil line */
r[col] = -1.0;
} else {
@@ -884,7 +834,7 @@
else if (I[col]==7){
- //savi
+ /*savi*/
r[col] = -1.0;
} else {
@@ -892,7 +842,7 @@
else if (I[col]==8){
- //msavi
+ /*msavi*/
r[col] = -1.0;
} else {
@@ -900,7 +850,7 @@
else if (I[col]==9){
- //msavi2
+ /*msavi2*/
r[col] = -1.0;
} else {
@@ -908,7 +858,7 @@
else if (I[col]==10){
- //gemi
+ /*gemi*/
r[col] = -1.0;
} else {
@@ -916,7 +866,7 @@
else if (I[col]==11){
- //arvi
+ /*arvi*/
r[col] = -1.0;
} else {
@@ -924,7 +874,7 @@
else if (I[col]==12){
- //gvi
+ /*gvi*/
r[col] = -1.0;
} else {
@@ -932,18 +882,18 @@
else if (I[col]==13){
- //gari
+ /*gari*/
r[col] = ( b[col] - (c[col]-(d[col] - a[col]))) / ( b[col] + (c[col]-(d[col] - a[col]))) ;
- } //for temp
+ } /*for temp*/
- }// col end
+ }/*col end*/
r[ncols]=I[ncols];
- //MPI_Send(&row_n,1,MPI_INT,0,1,MPI_COMM_WORLD);
+ /*MPI_Send(&row_n,1,MPI_INT,0,1,MPI_COMM_WORLD);*/
MPI_Send(r,ncols+1,MPI_DOUBLE,0,1,MPI_COMM_WORLD);
- }//row end
+ }/*row end*/
free(I);
free(a);
@@ -955,6 +905,6 @@
free(r);
MPI_Finalize();
- }//if end
-}//main end
+ }/*if end*/
+}/*main end*/
