[GRASS-SVN] r32990 - grass/trunk/tools/g.html2man
svn_grass at osgeo.org
Thu Aug 21 22:02:44 EDT 2008
Author: glynn
Date: 2008-08-21 22:02:44 -0400 (Thu, 21 Aug 2008)
New Revision: 32990
grass/trunk/tools/g.html2man/g.html2man.py
Better support for tables, lists, pre-formatted sections
Modified: grass/trunk/tools/g.html2man/g.html2man.py
--- grass/trunk/tools/g.html2man/g.html2man.py 2008-08-22 02:01:53 UTC (rev 32989)
+++ grass/trunk/tools/g.html2man/g.html2man.py 2008-08-22 02:02:44 UTC (rev 32990)
@@ -145,51 +145,84 @@
excluded = setify(excluded)
-formats = {
+styles = {
'b': "\\fB@\\fR",
'i': "\\fI@\\fR",
'em': "\\fI@\\fR",
'code': "\\fC@\\fR",
'span': "\\fC@\\fR",
'sup': "\\u@\\d",
+ 'hr': ""
+formats = {
'br': "\n.br\n",
- 'hr': "",
'h2': "\n.SH @",
'h3': "\n.SS @",
'h4': "\n.SS @",
'dt': ("\n.IP \"@\" 4m", 'no_nl'),
'dd': "\n.br\n@",
- 'ul': ("\n.RS\n@\n.RE\n", 'in_ul'),
- 'menu': ("\n.RS\n@\n.RE\n", 'in_ul'),
- 'dir': ("\n.RS\n@\n.RE\n", 'in_ul'),
- 'ol': ("\n..IP\n@\n.PP\n", 'index'),
+ 'ul': ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+ 'menu': ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+ 'dir': ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+ 'ol': ("\n.IP\n@\n.PP\n", 'index'),
'p': "\n.PP\n@",
- 'pre': ("\n\\fC\n.DS\n@\n.DE\n\\fR\n", 'preformat'),
- 'tr': ("@\n.br\n", 'no_nl'),
- 'td': "@\t"
+ 'pre': ("\n.br\n.nf\n\\fC\n@\n\\fR\n.fi\n", 'preformat')
+formats.update(styles)
+def is_string(x):
+ return isinstance(x, types.StringType)
+def is_tuple(x):
+ return isinstance(x, types.TupleType)
+def is_list(x):
+ return isinstance(x, types.ListType)
+def is_blank(s):
+ return is_string(s) and s.strip() == ""
+def clean(content):
+ return [item for item in content if not is_blank(item)]
class Formatter:
def __init__(self, stream = sys.stdout):
self.stream = stream
- self.style = dict(preformat = False, in_ul = False, no_nl = False, index = [])
+ self.style = dict(preformat = False,
+ in_ul = False,
+ no_nl = False,
+ in_table = False,
+ in_tr = False,
+ index = [])
self.stack = []
self.strip_re = re.compile("\n[ \t]+")
+ def warning(self, msg):
+ sys.stderr.write(msg + '\n')
def set(self, var, val):
self.style[var] = val
def get(self, var):
return self.style[var]
+ def push(self, **kwargs):
+ self.stack.append(self.style.copy())
+ self.style.update(**kwargs)
+ def pop(self):
+ self.style = self.stack.pop()
def show(self, s):
self.stream.write(s)
def pp_with(self, content, var, val):
- self.stack.append(self.style.copy())
+ self.push()
self.set(var, val)
self.pp(content)
- self.style = self.stack.pop()
+ self.pop()
def fmt(self, format, content, var = None):
(pre,sep,post) = format.partition("@")
@@ -209,7 +242,7 @@
def pp_li(self, content):
if self.get('in_ul'):
- self.fmt("\n.IP\n@", content)
+ self.fmt("\n.IP \(bu 4n\n@", content)
else:
idx = self.get('index')
idx[-1] += 1
@@ -225,14 +258,80 @@
version +
"\" \"Grass User's Manual\"")
+ def pp_tr(self, content):
+ content = clean(content)
+ self.push(in_tr = True)
+ col = 0
+ for item in content:
+ if not is_tuple(item):
+ self.warning("invalid item in table row: %s" % str(item))
+ continue
+ (tag, tail) = item
+ if tag not in ['td', 'th']:
+ self.warning("invalid tag in table row: %s" % tag)
+ continue
+ if col > 0:
+ self.show("\t \t")
+ self.show("T{\n")
+ self.pp(tail)
+ self.show("\nT}")
+ col += 1
+ self.show("\n")
+ self.pop()
+ def pp_tbody(self, content):
+ if is_tuple(item):
+ if tag in ['thead', 'tbody', 'tfoot']:
+ self.pp_tbody(tail)
+ elif tag == 'tr':
+ self.pp_tr(tail)
+ self.show(".sp 1\n")
+ def count_cols(self, content):
+ cols = 0
+ n = 0
+ if is_blank(item):
+ pass
+ elif is_tuple(item):
+ n = self.count_cols(tail)
+ elif tag == 'tr':
+ n = len(clean(tail))
+ cols = max(cols, n)
+ else:
+ self.warning("invalid item in table: %s" % str(item))
+ return cols
+ def pp_table(self, content):
+ cols = self.count_cols(content)
+ if cols == 0:
+ return
+ self.show("\n.TS\nexpand;\n")
+ self.show(" lw1 ".join(["lw60" for i in range(cols)]) + ".\n")
+ self.pp_tbody(content)
+ self.show("\n.TE\n")
def pp_tag(self, tag, content):
- if tag in formats:
+ if self.get('in_tr') and tag not in styles:
+ self.pp(content)
+ elif tag in formats:
spec = formats[tag]
- if isinstance(spec, types.StringType):
+ if is_string(spec):
self.fmt(spec, content)
else:
(fmt, var) = spec
self.fmt(fmt, content, var)
+ elif tag == 'table':
+ if self.get('in_table'):
+ self.warning("cannot handle nested tables")
+ return
+ self.push(in_table = True)
+ self.pp_table(content)
+ self.pop()
elif tag == 'li':
self.pp_li(content)
elif tag == 'title':
@@ -253,10 +352,7 @@
def pp_text(self, content):
if content != "":
if self.get('preformat'):
- for line in content.splitlines(True):
- self.pp_string(line)
- if line.endswith("\n"):
- self.show("\n.br\n")
+ self.pp_string(content)
else:
s = self.strip_re.sub('\n', content)
self.pp_string(s)
@@ -266,12 +362,12 @@
self.pp(item)
def pp(self, content):
- if isinstance(content, types.ListType):
+ if is_list(content):
self.pp_list(content)
- elif isinstance(content, types.TupleType):
+ elif is_tuple(content):
(head, tail) = content
self.pp_tag(head, tail)
- elif isinstance(content, types.StringType):
+ elif is_string(content):
self.pp_text(content)
class MyHTMLParser(HTMLParser):
