[GRASS-SVN] r33005 - grass/branches/develbranch_6/vector/v.label.sa
svn_grass at osgeo.org
Fri Aug 22 11:54:05 EDT 2008
Author: martinl
Date: 2008-08-22 11:54:05 -0400 (Fri, 22 Aug 2008)
New Revision: 33005
grass/branches/develbranch_6/vector/v.label.sa/Makefile
grass/branches/develbranch_6/vector/v.label.sa/annealing.c
grass/branches/develbranch_6/vector/v.label.sa/main.c
glynn: Don't use C++/C99 comments in GRASS
(merge from devbr6, r33004)
Modified: grass/branches/develbranch_6/vector/v.label.sa/Makefile
--- grass/branches/develbranch_6/vector/v.label.sa/Makefile 2008-08-22 15:48:53 UTC (rev 33004)
+++ grass/branches/develbranch_6/vector/v.label.sa/Makefile 2008-08-22 15:54:05 UTC (rev 33005)
@@ -6,7 +6,7 @@
LIBES = $(DISPLAYLIB) $(RASTERLIB) $(VECTLIB) $(GISLIB) $(FTLIB)
DEPENDENCIES= $(DISPLAYDEP) $(RASTERDEP) $(VECTDEP) $(GISDEP)
EXTRA_INC = $(VECT_INC) $(FTINC)
-EXTRA_CFLAGS = $(VECT_CFLAGS) -Wall -Wmissing-prototypes -std=c99
+EXTRA_CFLAGS = $(VECT_CFLAGS)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/branches/develbranch_6/vector/v.label.sa/annealing.c
--- grass/branches/develbranch_6/vector/v.label.sa/annealing.c 2008-08-22 15:48:53 UTC (rev 33004)
+++ grass/branches/develbranch_6/vector/v.label.sa/annealing.c 2008-08-22 15:54:05 UTC (rev 33005)
@@ -197,7 +197,7 @@
if (ol->current_candidate == oc) {
ol->current_score -= LABEL_OVERLAP_WEIGHT;
label->current_score -= LABEL_OVERLAP_WEIGHT;
- // ol->candidates[oc].score -= LABEL_OVERLAP_WEIGHT;
+ /* ol->candidates[oc].score -= LABEL_OVERLAP_WEIGHT; */
overlaps_removed++;
@@ -212,7 +212,7 @@
ol->current_score += LABEL_OVERLAP_WEIGHT;
label->current_score += LABEL_OVERLAP_WEIGHT;
- // ol->candidates[oc]->score += 40;
+ /* ol->candidates[oc]->score += 40; */
overlaps_created++;
Modified: grass/branches/develbranch_6/vector/v.label.sa/main.c
--- grass/branches/develbranch_6/vector/v.label.sa/main.c 2008-08-22 15:48:53 UTC (rev 33004)
+++ grass/branches/develbranch_6/vector/v.label.sa/main.c 2008-08-22 15:54:05 UTC (rev 33005)
@@ -46,7 +46,6 @@
module->description =
_("Create optimally placed labels for vector map(s)");
- // fprintf(stderr, "Parsing options and flags\n");
/* parse options and flags */
parse_args(argc, argv, &p);
@@ -245,8 +244,8 @@
fprintf(labelf, "east: %lf\n", label->candidates[cc].point.x);
fprintf(labelf, "north: %lf\n", label->candidates[cc].point.y);
- fprintf(labelf, "xoffset: %lf\n", 0.0); // * (size));
- fprintf(labelf, "yoffset: %lf\n", 0.0); // * (size));
+ fprintf(labelf, "xoffset: %lf\n", 0.0); /* * (size)); */
+ fprintf(labelf, "yoffset: %lf\n", 0.0); /* * (size)); */
fprintf(labelf, "ref: %s\n", "bottom left");
fprintf(labelf, "font: %s\n", p->font->answer);
