[GRASS-SVN] r33024 - in grass/trunk/gui: scripts wxpython/gui_modules
Sat Aug 23 09:37:39 EDT 2008
Author: martinl
Date: 2008-08-23 09:37:38 -0400 (Sat, 23 Aug 2008)
New Revision: 33024
Added:
   grass/trunk/gui/scripts/v.type.py
   grass/trunk/gui/wxpython/gui_modules/menudata.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: use v.type.py instead of v.type.sh
(merge from devbr6, r33023(
Copied: grass/trunk/gui/scripts/v.type.py (from rev 33023, grass/branches/develbranch_6/gui/scripts/v.type.py)
--- grass/trunk/gui/scripts/v.type.py	                        (rev 0)
+++ grass/trunk/gui/scripts/v.type.py	2008-08-23 13:37:38 UTC (rev 33024)
@@ -0,0 +1,91 @@
+#!/usr/bin/env python
+# MODULE:       v.type.py (v.type wrapper script)
+# AUTHOR(S):    Hamish Bowman  (Otago University, New Zealand)
+#               (original contributor, v.type.sh)
+#               Pythonized by Martin Landa <landa.martin gmail.com> (2008/08)
+# PURPOSE:      Supply v.type options in a GUI compatible way
+# COPYRIGHT:    (C) 2007-2008 by Hamish Bowman, and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%module
+#% description: Change the type of geometry elements.
+#% keywords: vector, geometry
+#%end
+#%option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%end
+#%option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output vector map
+#% gisprompt: new,vector,vector
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: no
+#% multiple: no
+#% options: point to centroid,point to kernel,centroid to point,centroid to kernel,kernel to point,kernel to centroid,line to boundary,line to face,boundary to line,boundary to face,face to line,face to boundary
+#% description: Conversion
+#% answer: boundary to line
+#%end
+import grass
+import sys
+def main():
+    if options['type'] == "point to centroid":
+        type_cnv = "point,centroid"
+    elif options['type'] == "point to kernel":
+        type_cnv = "point,kernel"
+    elif options['type'] == "centroid to point":
+        type_cnv = "centroid,point"
+    elif options['type'] == "centroid to kernel":
+        type_cnv = "centroid,kernel"
+    elif options['type'] == "kernel to point":
+        type_cnv = "kernel,point"
+    elif options['type'] == "kernel to centroid":
+        type_cnv = "kernel,centroid"
+    elif options['type'] == "line to boundary":
+        type_cnv = "line,boundary"
+    elif options['type'] == "line to face":
+        type_cnv = "line,face"
+    elif options['type'] == "boundary to line":
+        type_cnv = "boundary,line"
+    elif options['type'] == "boundary to face":
+        type_cnv = "boundary,face"
+    elif options['type'] == "face to line":
+        type_cnv = "face,line"
+    elif options['type'] == "face to boundary":
+        type_cnv = "face,boundary"
+    options.pop('type')
+    grass.exec_command("v.type", type = type_cnv, **options)
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-08-23 13:35:52 UTC (rev 33023)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-08-23 13:37:38 UTC (rev 33024)
@@ -1223,7 +1223,7 @@
                                 (_("Convert object types"),
                                  _("Change the type of geometry elements."),
                                  "self.OnMenuCmd",
-                                 "v.type.sh"),
+                                 "v.type.py"),
                                 (_("Add centroids"),
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-08-23 13:35:52 UTC (rev 33023)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-08-23 13:37:38 UTC (rev 33024)
@@ -573,7 +573,7 @@
         self.parent = parent # LayerTree | None
         # module name + keywords
-        title = self.task.name
+        title = self.task.name.rstrip('.py').rstrip('.sh')
         try:
             title +=  " [" + ', '.join( self.task.keywords ) + "]"
         except ValueError:
