[GRASS-SVN] r33033 - grass/trunk/vector/v.db.select
svn_grass at osgeo.org
Sat Aug 23 16:40:43 EDT 2008
Author: martinl
Date: 2008-08-23 16:40:40 -0400 (Sat, 23 Aug 2008)
New Revision: 33033
grass/trunk/vector/v.db.select/main.c
grass/trunk/vector/v.db.select/v.db.select.html
v.db.select: flag to print minimal region extent instead of attribures added (used in wxGUI for "Highlight and zoom")
(merge from devbr6, r33032)
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2008-08-23 20:37:32 UTC (rev 33032)
+++ grass/trunk/vector/v.db.select/main.c 2008-08-23 20:40:40 UTC (rev 33033)
@@ -31,7 +31,7 @@
struct GModule *module;
struct Option *map_opt, *field_opt, *fs_opt, *vs_opt, *nv_opt, *col_opt,
*where_opt;
- struct Flag *c_flag, *v_flag;
+ struct Flag *c_flag, *v_flag, *r_flag;
dbDriver *driver;
dbString sql, value_string;
dbCursor cursor;
@@ -43,7 +43,11 @@
struct Map_info Map;
char *mapset;
char query[1024];
+ struct ilist *list_lines;
+ BOUND_BOX *min_box, *line_box;
+ int i, line, area, init_box, cat;
module = G_define_module();
module->keywords = _("vector, database, attribute table");
module->description = _("Prints vector map attributes.");
@@ -57,25 +61,35 @@
fs_opt = G_define_standard_option(G_OPT_F_SEP);
fs_opt->description = _("Output field separator");
+ fs_opt->guisection = _("Format");
vs_opt = G_define_standard_option(G_OPT_F_SEP);
vs_opt->key = "vs";
vs_opt->description = _("Output vertical record separator");
vs_opt->answer = NULL;
+ vs_opt->guisection = _("Format");
nv_opt = G_define_option();
nv_opt->key = "nv";
nv_opt->type = TYPE_STRING;
nv_opt->required = NO;
nv_opt->description = _("Null value indicator");
+ nv_opt->guisection = _("Format");
+ r_flag = G_define_flag();
+ r_flag->key = 'r';
+ r_flag->description =
+ _("Print minimal region extent of selected vector features instead");
c_flag = G_define_flag();
c_flag->key = 'c';
c_flag->description = _("Do not include column names in output");
+ c_flag->guisection = _("Format");
v_flag = G_define_flag();
v_flag->key = 'v';
v_flag->description = _("Vertical output (instead of horizontal)");
+ v_flag->guisection = _("Format");
G_gisinit(argv[0]);
@@ -85,6 +99,18 @@
/* set input vector map name and mapset */
field = atoi(field_opt->answer);
+ if (r_flag->answer) {
+ min_box = (BOUND_BOX *) G_malloc(sizeof(BOUND_BOX));
+ G_zero((void *)min_box, sizeof(BOUND_BOX));
+ line_box = (BOUND_BOX *) G_malloc(sizeof(BOUND_BOX));
+ list_lines = Vect_new_list();
+ else {
+ min_box = line_box = NULL;
+ list_lines = NULL;
db_init_string(&sql);
db_init_string(&value_string);
@@ -93,7 +119,18 @@
G_fatal_error(_("Vector map <%s> not found"), map_opt->answer);
- Vect_open_old_head(&Map, map_opt->answer, mapset);
+ if (!r_flag) {
+ Vect_open_old_head(&Map, map_opt->answer, mapset);
+ else {
+ if (2 > Vect_open_old(&Map, map_opt->answer, mapset)) {
+ Vect_close(&Map);
+ G_fatal_error(_("Unable to open vector map <%s> at topology level. "
+ "Flag '%c' requires topology level."),
+ G_fully_qualified_name(map_opt->answer, mapset),
+ r_flag->key);
if ((Fi = Vect_get_field(&Map, field)) == NULL)
G_fatal_error(_("Database connection not defined for layer %d"),
@@ -128,8 +165,8 @@
table = db_get_cursor_table(&cursor);
ncols = db_get_table_number_of_columns(table);
- /* column names if horizontal output */
- if (!v_flag->answer && !c_flag->answer) {
+ /* column names if horizontal output (ignore for -r) */
+ if (!v_flag->answer && !c_flag->answer && !r_flag->answer) {
for (col = 0; col < ncols; col++) {
column = db_get_table_column(table, col);
if (col)
@@ -139,6 +176,8 @@
fprintf(stdout, "\n");
+ init_box = 1;
/* fetch the data */
while (1) {
if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
@@ -148,9 +187,20 @@
if (!more)
break;
+ cat = -1;
value = db_get_column_value(column);
+ if (cat < 0 && strcmp(Fi->key, db_get_column_name(column)) == 0) {
+ cat = db_get_value_int(value);
+ break;
+ continue;
db_convert_column_value_to_string(column, &value_string);
if (!c_flag->answer && v_flag->answer)
@@ -168,12 +218,57 @@
if (v_flag->answer)
- if (!v_flag->answer)
- fprintf(stdout, "\n");
- else if (vs_opt->answer)
- fprintf(stdout, "%s\n", vs_opt->answer);
+ /* get minimal region extent */
+ Vect_cidx_find_all(&Map, field, -1, cat, list_lines);
+ for (i = 0; i < list_lines->n_values; i++) {
+ line = list_lines->value[i];
+ area = Vect_get_centroid_area(&Map, line);
+ if (area > 0) {
+ if (!Vect_get_area_box(&Map, area, line_box))
+ G_fatal_error(_("Unable to get bounding box of area %d"),
+ area);
+ else {
+ if (!Vect_get_line_box(&Map, line, line_box))
+ G_fatal_error(_("Unable to get bounding box of line %d"),
+ line);
+ if (init_box) {
+ Vect_box_copy(min_box, line_box);
+ init_box = 0;
+ else {
+ Vect_box_extend(min_box, line_box);
+ else {
+ if (!v_flag->answer)
+ fprintf(stdout, "\n");
+ else if (vs_opt->answer)
+ fprintf(stdout, "%s\n", vs_opt->answer);
+ fprintf(stdout, "n=%f\n", min_box->N);
+ fprintf(stdout, "s=%f\n", min_box->S);
+ fprintf(stdout, "w=%f\n", min_box->W);
+ fprintf(stdout, "e=%f\n", min_box->E);
+ if (Vect_is_3d(&Map)) {
+ fprintf(stdout, "t=%f\n", min_box->T);
+ fprintf(stdout, "b=%f\n", min_box->B);
+ fflush(stdout);
+ G_free((void *)min_box);
+ G_free((void *)line_box);
+ Vect_destroy_list(list_lines);
if (!driver)
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Fi->database, Fi->driver);
Modified: grass/trunk/vector/v.db.select/v.db.select.html
--- grass/trunk/vector/v.db.select/v.db.select.html 2008-08-23 20:37:32 UTC (rev 33032)
+++ grass/trunk/vector/v.db.select/v.db.select.html 2008-08-23 20:40:40 UTC (rev 33033)
@@ -3,11 +3,11 @@
<em>v.db.select</em> prints attributes of a vector map from one or several
user selected attribute table columns.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
Select and show entire table:
<div class="code"><pre>
-v.db.select roads
+v.db.select map=roads
cat|label
0|no data
1|interstate
@@ -17,10 +17,10 @@
5|unimproved road
</pre></div>
-<p>
-Select and show single column from table (multiple columns can be specified as comma separated list):
+Select and show single column from table (multiple columns can be
+specified as comma separated list):
-v.db.select roads col=label
+v.db.select map=roads column=label
label
no data
interstate
@@ -30,13 +30,25 @@
unimproved road
</pre></div>
+Print region extent of selected vector features:
+<div class="code"><pre>
+v.db.select -r map=roads where="label ~ 'highway'"
+n=4928063.398015
+s=4914089.153930
+w=589532.054964
+e=609527.210215
+</pre></div>
<h2>SEE ALSO</h2>
<em><a HREF="db.select.html">db.select</a></em>
<h2>AUTHOR</h2>
-Radim Blazek, ITC-Irst, Trento, Italy
+Radim Blazek, ITC-Irst, Trento, Italy<br>
+Minimal region extent added by Martin Landa,
+FBK-irst (formerly ITC-irst), Trento, Italy (2008/08)
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
