[GRASS-SVN] r33036 - in grass/branches/develbranch_6/gui: scripts
wxpython/gui_modules
svn_grass at osgeo.org
Sat Aug 23 17:02:08 EDT 2008
Author: martinl
Date: 2008-08-23 17:02:08 -0400 (Sat, 23 Aug 2008)
New Revision: 33036
Added:
grass/branches/develbranch_6/gui/scripts/v.type.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py
Update r33034, r33035: use v.type.py only in wxGUI
Added: grass/branches/develbranch_6/gui/scripts/v.type.py
--- grass/branches/develbranch_6/gui/scripts/v.type.py (rev 0)
+++ grass/branches/develbranch_6/gui/scripts/v.type.py 2008-08-23 21:02:08 UTC (rev 33036)
@@ -0,0 +1,91 @@
+#!/usr/bin/env python
+# MODULE: v.type.py (v.type wrapper script)
+# AUTHOR(S): Hamish Bowman (Otago University, New Zealand)
+# (original contributor, v.type.sh)
+# Pythonized by Martin Landa <landa.martin gmail.com> (2008/08)
+# PURPOSE: Supply v.type options in a GUI compatible way
+# COPYRIGHT: (C) 2007-2008 by Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Change the type of geometry elements.
+#% keywords: vector, geometry
+#%end
+#%option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%end
+#%option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output vector map
+#% gisprompt: new,vector,vector
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: no
+#% multiple: no
+#% options: point to centroid,point to kernel,centroid to point,centroid to kernel,kernel to point,kernel to centroid,line to boundary,line to face,boundary to line,boundary to face,face to line,face to boundary
+#% description: Conversion
+#% answer: boundary to line
+#%end
+import grass
+import sys
+def main():
+ if options['type'] == "point to centroid":
+ type_cnv = "point,centroid"
+ elif options['type'] == "point to kernel":
+ type_cnv = "point,kernel"
+ elif options['type'] == "centroid to point":
+ type_cnv = "centroid,point"
+ elif options['type'] == "centroid to kernel":
+ type_cnv = "centroid,kernel"
+ elif options['type'] == "kernel to point":
+ type_cnv = "kernel,point"
+ elif options['type'] == "kernel to centroid":
+ type_cnv = "kernel,centroid"
+ elif options['type'] == "line to boundary":
+ type_cnv = "line,boundary"
+ elif options['type'] == "line to face":
+ type_cnv = "line,face"
+ elif options['type'] == "boundary to line":
+ type_cnv = "boundary,line"
+ elif options['type'] == "boundary to face":
+ type_cnv = "boundary,face"
+ elif options['type'] == "face to line":
+ type_cnv = "face,line"
+ elif options['type'] == "face to boundary":
+ type_cnv = "face,boundary"
+ options.pop('type')
+ grass.exec_command("v.type", type = type_cnv, **options)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass/branches/develbranch_6/gui/scripts/v.type.py
___________________________________________________________________
+ text/x-python
+ Author Date Id
+ native
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py 2008-08-23 20:55:55 UTC (rev 33035)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py 2008-08-23 21:02:08 UTC (rev 33036)
@@ -1223,7 +1223,7 @@
(_("Convert object types"),
_("Change the type of geometry elements."),
"self.OnMenuCmd",
- "v.type.sh"),
+ "v.type.py"),
(_("Add centroids"),
