[GRASS-SVN] r33040 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sat Aug 23 18:59:24 EDT 2008
Author: martinl
Date: 2008-08-23 18:59:24 -0400 (Sat, 23 Aug 2008)
New Revision: 33040
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
wxGUI: fix attribute table manager "highlight selected and zoom" (v.db.select -r)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-08-23 22:11:40 UTC (rev 33039)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-08-23 22:59:24 UTC (rev 33040)
@@ -87,8 +87,8 @@
         self.mapDBInfo = mapDBInfo
         self.layer   = layer
-        self.columns              = {} # <- LoadData()
+        self.columns = {} # <- LoadData()
         # self.selectedCats         = []
         # self.lastTurnSelectedCats = [] # just temporary, for comparation
@@ -137,94 +137,110 @@
         self.LoadData(self.layer)
-    def LoadData(self, layer, sql=None):
+    def LoadData(self, layer, columns=None, where=None):
         """Load data into list
         @param layer layer number
-        @param sql SQL select statement (if None 'SELECT * FROM table)
+        @param columns list of columns for output
+        @param where where statement
         @return id of key column
         @return -1 if key column is not displayed
         self.log.write(_("Loading data..."))
+        tableName    = self.mapDBInfo.layers[layer]['table']
+        keyColumn    = self.mapDBInfo.layers[layer]['key']
+        self.columns = self.mapDBInfo.tables[tableName]
+        cmd = ["v.db.select",
+               "-c", "--q",
+               "map=%s" % self.mapDBInfo.map,
+               "layer=%d" % layer]
+        if not columns:
+            columns = self.mapDBInfo.GetColumns(tableName)
+        else:
+            all = self.mapDBInfo.GetColumns(tableName)
+            cmd.append("columns=%s" % ','.join(columns))
+            for col in columns:
+                if col not in all:
+                    wx.MessageBox(parent=self,
+                                  message=_("Column <%(column)s> not found in "
+                                            "in the table <%(table)s>.") % \
+                                      { 'column' : col, 'table' : tableName },
+                                  caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+                    return
+        if where:
+            cmd.append("where=%s" % where)
+        try:
+            # for maps connected via v.external
+            keyId = columns.index(keyColumn)
+        except:
+            keyId = -1
+        # read data
+        # FIXME: Max. number of rows, while the GUI is still usable
+        # stdout can be very large, do not use PIPE, redirect to temp file
+        # TODO: more effective way should be implemented...
+        outFile = tempfile.NamedTemporaryFile(mode='w+b')
+        selectCommand = gcmd.Command(cmd,
+                                     stdout=outFile)
         # These two should probably be passed to init more cleanly
         # setting the numbers of items = number of elements in the dictionary
         self.itemDataMap  = {}
         self.itemIndexMap = []
         self.itemCatsMap  = {}
         self.DeleteAllItems()
         # self.ClearAll()
         for i in range(self.GetColumnCount()):
             self.DeleteColumn(0)
-        tableName    = self.mapDBInfo.layers[layer]['table']
-        keyColumn    = self.mapDBInfo.layers[layer]['key']
-        self.columns = self.mapDBInfo.tables[tableName]
-        if sql is None:
-            sql = "SELECT * FROM %s" % tableName
-        if sql[7] != '*':
-            columnNames = sql[7:].split(' ')[0].split(',')
-        else:
-            columnNames = self.mapDBInfo.GetColumns(tableName)
-        try:
-            # for maps connected via v.external
-            keyId = columnNames.index(keyColumn)
-        except:
-            keyId = -1
         i = 0
         info = wx.ListItem()
         info.m_mask = wx.LIST_MASK_TEXT | wx.LIST_MASK_IMAGE | wx.LIST_MASK_FORMAT
         info.m_image = -1
         info.m_format = 0
-        for column in columnNames:
+        for column in columns:
             info.m_text = column
             self.InsertColumnInfo(i, info)
             i += 1
             if i >= 256:
                 self.log.write(_("Can display only 256 columns."))
-        # read data
-        # FIXME: Max. number of rows, while the GUI is still usable
-        # stdout can be very large, do not use PIPE, redirect to temp file
-        # TODO: more effective way should be implemented...
-        outFile = tempfile.NamedTemporaryFile(mode='w+b')
-        selectCommand = gcmd.Command(["db.select", "-c", "--q",
-                                      "sql=%s" % sql,
-                                      "database=%s" % self.mapDBInfo.layers[layer]["database"],
-                                      "driver=%s"   % self.mapDBInfo.layers[layer]["driver"],
-                                      "fs=|"],
-                                     stdout=outFile)
         i = 0
         outFile.seek(0)
         while True:
             # os.linesep doesn't work here (MSYS)
             record = outFile.readline().replace('\n', '')
             if not record:
                 break
             self.itemDataMap[i] = []
             j = 0
             for value in record.split('|'):
                 # casting ...
                 try:
-                    self.itemDataMap[i].append(self.columns[columnNames[j]]['ctype'] (value))
+                    self.itemDataMap[i].append(self.columns[columns[j]]['ctype'] (value))
                 except:
                     self.itemDataMap[i].append('')
                 if keyId > -1 and keyId == j:
                     try:
-                        cat = self.columns[columnNames[j]]['ctype'] (value)
+                        cat = self.columns[columns[j]]['ctype'] (value)
                     except ValueError, e:
                         cat = -1
@@ -255,9 +271,9 @@
                 break
         self.SetItemCount(i)
         i = 0
-        for col in columnNames:
             width = self.columns[col]['length'] * 6 # FIXME
             if width < 60:
                 width = 60
@@ -1032,27 +1048,57 @@
         """Highlight selected features"""
         if not self.map or not self.mapdisplay:
             return
+        list = self.FindWindowById(self.layerPage[self.layer]['data'])
+        cats = map(int, list.GetSelectedItems())
         digitToolbar = self.mapdisplay.toolbars['vdigit']
         if digitToolbar and \
                 digitToolbar.GetLayer().GetName() == self.vectmap:
-            list = self.FindWindowById(self.layerPage[self.layer]['data'])
-            cats = map(int, list.GetSelectedItems())
             self.mapdisplay.digit.driver.SetSelected(cats, cats=True)
             if zoom:
                 n, s, w, e = self.mapdisplay.digit.driver.GetRegionSelected()
                 self.mapdisplay.Map.GetRegion(n=n, s=s, w=w, e=e,
                                               update=True)
-                self.mapdisplay.Map.AdjustRegion() # resolution
-                self.mapdisplay.MapWindow.UpdateMap(render=True, renderVector=True)
-            else:
-                self.mapdisplay.MapWindow.UpdateMap(render=False, renderVector=True)
         else:
             # add map layer with higlighted vector features
             self.AddQueryMapLayer()
-            self.mapdisplay.MapWindow.UpdateMap(render=False, renderVector=False,
-                                                zoom=zoom)
+            if zoom:
+                keyColumn = self.mapDBInfo.layers[self.layer]['key']
+                where = ''
+                for range in utils.ListOfCatsToRange(cats).split(','):
+                    if '-' in range:
+                        min, max = range.split('-')
+                        where += '%s >= %d and %s <= %d or ' % \
+                            (keyColumn, int(min),
+                             keyColumn, int(max))
+                    else:
+                        where += '%s = %d or ' % (keyColumn, int(range))
+                where = where.rstrip('or ')
+                cmd = gcmd.Command(["v.db.select",
+                                    "-r", "--q",
+                                    "layer=%d" % self.layer,
+                                    "where=%s" % where])
+                region = {}
+                for line in cmd.ReadStdOutput():
+                    key, value = line.split('=')
+                    region[key] = float(value)
+                self.mapdisplay.Map.GetRegion(n=region['n'], s=region['s'],
+                                              w=region['w'], e=region['e'],
+                                              update=True)
+        if zoom:
+            self.mapdisplay.Map.AdjustRegion() # adjust resolution
+            self.mapdisplay.Map.AlignExtentFromDisplay() # adjust extent
+            self.mapdisplay.MapWindow.UpdateMap(render=True, renderVector=True)
+        else:
+            self.mapdisplay.MapWindow.UpdateMap(render=False, renderVector=True)
     def OnDataDrawSelected(self, event):
         """Reload table description"""
         self._drawSelected(zoom=False)
@@ -1576,44 +1622,38 @@
             where = self.FindWindowById(self.layerPage[self.layer]['where']).GetValue().strip()
             try:
                 if len(where) > 0:
-                    sql = "SELECT * FROM %s WHERE %s" % (self.mapDBInfo.layers[self.layer]['table'],
-                                                         where)
-                    keyColumn = listWin.LoadData(self.layer, sql=sql)
+                    keyColumn = listWin.LoadData(self.layer, where=where)
                 else:
                     keyColumn = listWin.LoadData(self.layer)
-            except gcmd.CmdError:
+            except gcmd.CmdError, e:
-                              message=_("Loading attribute data failed. "
-                                        "Invalid SQL 'select' statement.\n\n"
-                                        "'%s'") % sql,
+                              message=_("Loading attribute data failed.\n\n%s") % e.message,
-                keyColumn = listWin.LoadData(self.layer)
                 self.FindWindowById(self.layerPage[self.layer]['where']).SetValue('')
         else:
             # advanced sql statement
-            # valid, cols, where = \
-            #    self.ValidateSelectStatement( \
-            #    self.FindWindowById(self.layerPage[self.layer]['statement']).GetValue().strip())
-            #Debug.msg(4, "AttributeManager.OnApplySqlStatament(): valid=%s, cols=%s, where=%s" %
-            #          (valid, cols, where))
-            sql = self.FindWindowById(self.layerPage[self.layer]['statement']).GetValue()
+            win = self.FindWindowById(self.layerPage[self.layer]['statement'])
             try:
-                # if valid is True:
-                                             sql=sql)
-                # else:
-                # raise gcmd.GException('')
+                cols, where = self.ValidateSelectStatement(win.GetValue())
+            except TypeError:
-                                        "'%s'") % sql,
+                              message=_("Loading attribute data failed.\n"
+                                        "Invalid SQL select statement.\n\n%s") % win.GetValue(),
-                self.FindWindowById(self.layerPage[self.layer]['statement']).\
-                    SetValue("SELECT * FROM %s" % self.mapDBInfo.layers[self.layer]['table'])
+                win.SetValue("SELECT * FROM %s" % self.mapDBInfo.layers[self.layer]['table'])
+                cols = None
+                where = None
+            print cols, where
+            if cols or where:
+                try:
+                    keyColumn = listWin.LoadData(self.layer, columns=cols,
+                                                 where=where)
         # sort by key column
         if keyColumn > -1:
             listWin.SortListItems(col=keyColumn, ascending=True)
@@ -1625,18 +1665,14 @@
                            self.FindWindowById(self.layerPage[self.layer]['data']).GetItemCount())
     def ValidateSelectStatement(self, statement):
-        """Validate Select SQL statement
+        """Validate SQL select statement
-        TODO: check list of columns and where statement
-        Return True if valid, False if not
-        Return list of columns (or '*' for all columns)
-        Return where statement
+        @return (columns, where)
+        @return None on error
         if statement[0:7].lower() != 'select ':
-            return (False, '', '')
+            return None
         cols = ''
         index = 7
         for c in statement[index:]:
@@ -1644,25 +1680,29 @@
                 break
             cols += c
             index += 1
+        if cols == '*':
+            cols = None
+        else:
+            cols = cols.split(',')
         tablelen = len(self.mapDBInfo.layers[self.layer]['table'])
         if statement[index+1:index+6].lower() != 'from ' or \
                 statement[index+6:index+6+tablelen] != '%s' % \
                 (self.mapDBInfo.layers[self.layer]['table']):
+            return None
         if len(statement[index+7+tablelen:]) > 0:
             index = statement.lower().find('where ')
             if index > -1:
                 where = statement[index+6:]
             else:
-                where = ''
+                return None
         else:
-            where = ''
-        return (True, cols, where)
+            where = None
+        return (cols, where)
     def OnInfoPaneChanged(self, event):
         """Collapse database connection info box"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-23 22:11:40 UTC (rev 33039)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-23 22:59:24 UTC (rev 33040)
@@ -612,14 +612,13 @@
         return img
-    def UpdateMap(self, render=True, renderVector=True, zoom=False):
+    def UpdateMap(self, render=True, renderVector=True):
         Updates the canvas anytime there is a change to the
         underlaying images or to the geometry of the canvas.
         @param render re-render map composition
         @param renderVector re-render vector map layer enabled for editing (used for digitizer)
-        @param zoom zoom to region given by 'd.vect -r'
         start = time.clock()
@@ -658,10 +657,9 @@
                 # use computation region resolution for rendering
                 windres = True
             self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
-                                           windres=windres, zoom=zoom)
+                                           windres=windres)
         else:
-            self.mapfile = self.Map.Render(force=False, mapWindow=self.parent,
-                                           zoom=zoom)
+            self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
         self.img = self.GetImage() # id=99
@@ -2188,7 +2186,7 @@
         # selected layer must be a valid map
         if layer.type in ('raster', 'rgb', 'his', 'shaded', 'arrow'):
             if layer.type == 'raster':
-                self.Map.region = self.Map.GetRegion(rast="%s" % layer.name, zoom=zoom)
+                self.Map.region = self.Map.GetRegion(rast="%s" % layer.name)
             else:
         elif layer.type in ('vector', 'thememap', 'themechart'):
@@ -3416,7 +3414,6 @@
         str(color[2])
         cmd = ["d.vect",
-               #               "-r", # print minimal region extent
                "map=%s" % name,
                "color=%s" % colorStr,
                "fcolor=%s" % colorStr,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2008-08-23 22:11:40 UTC (rev 33039)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2008-08-23 22:59:24 UTC (rev 33040)
@@ -97,11 +97,9 @@
         Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
                    (self.name, self.GetCmd(string=True)))
-    def Render(self, zoom):
+    def Render(self):
         """Render layer to image
-        @param zoom if True zoom to extent given by 'd.vect -r'
         @return rendered image filename
@@ -150,12 +148,6 @@
             runcmd = gcmd.Command(cmd=self.cmdlist + ['--q'],
                                   stderr=None)
-            if zoom:
-                self._region = {}
-                for line in runcmd.ReadStdOutput():
-                    key, value = line.split('=')
-                    self._region[key] = float(value)
             if runcmd.returncode != 0:
                 #clean up after probley
                 try:
@@ -809,7 +801,7 @@
         return selected
-    def _renderLayers(self, force, zoom, mapWindow, maps, masks, opacities):
+    def _renderLayers(self, force, mapWindow, maps, masks, opacities):
         # render map layers
         ilayer = 1
         for layer in self.layers + self.overlays:
@@ -822,18 +814,9 @@
                layer.force_render or \
                layer.mapfile == None or \
                (not os.path.isfile(layer.mapfile) or not os.path.getsize(layer.mapfile)):
-                if not layer.Render(zoom):
+                if not layer.Render():
                     continue
-            zoomToRegion = layer.GetRegion()
-            if zoomToRegion:
-                self.GetRegion(n=zoomToRegion['n'], s=zoomToRegion['s'],
-                               w=zoomToRegion['w'], e=zoomToRegion['e'],
-                               update=True)
-                self.AdjustRegion() # resolution
-                print self.region
-                return False
             # update progress bar
             wx.SafeYield(mapWindow)
             event = wxUpdateProgressBar(value=ilayer)
@@ -850,7 +833,7 @@
         return True
-    def Render(self, force=False, mapWindow=None, windres=False, zoom=False):
+    def Render(self, force=False, mapWindow=None, windres=False):
         Creates final image composite
@@ -860,7 +843,6 @@
         @param force force rendering
         @param reference for MapFrame instance (for progress bar)
         @param windres use region resolution (True) otherwise display resolution
         @return name of file with rendered image or None
@@ -886,7 +868,7 @@
             os.environ["GRASS_TRUECOLOR"] = "TRUE"
             os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
-        if not self._renderLayers(force, zoom, mapWindow, maps, masks, opacities):
+        if not self._renderLayers(force, mapWindow, maps, masks, opacities):
             os.environ["GRASS_REGION"] = self.SetRegion(windres)
             self._renderLayers(True, False, mapWindow, maps, masks, opacities)
