[GRASS-SVN] r33046 - in grass/trunk/lib: cairodriver pngdriver
svn_grass at osgeo.org
Sat Aug 23 22:20:30 EDT 2008
Author: glynn
Date: 2008-08-23 22:20:30 -0400 (Sat, 23 Aug 2008)
New Revision: 33046
grass/trunk/lib/cairodriver/Graph.c
grass/trunk/lib/pngdriver/Draw_line.c
grass/trunk/lib/pngdriver/Polygon.c
Fix bug with cairo driver failing to erase background
Fix bug with PNG driver skipping topmost line of polygon
Change PNG driver's line-drawing to use FP throughout
Modified: grass/trunk/lib/cairodriver/Graph.c
--- grass/trunk/lib/cairodriver/Graph.c 2008-08-24 00:42:49 UTC (rev 33045)
+++ grass/trunk/lib/cairodriver/Graph.c 2008-08-24 02:20:30 UTC (rev 33046)
@@ -86,7 +86,7 @@
static void init_file(void)
- int is_vector;
+ int is_vector = 0;
int do_read = 0;
int do_map = 0;
char *p;
Modified: grass/trunk/lib/pngdriver/Draw_line.c
--- grass/trunk/lib/pngdriver/Draw_line.c 2008-08-24 00:42:49 UTC (rev 33045)
+++ grass/trunk/lib/pngdriver/Draw_line.c 2008-08-24 02:20:30 UTC (rev 33046)
@@ -11,102 +11,62 @@
#include "pngdriver.h"
-static void store_xy(int x, int y)
+static void store_xy(double x, double y)
+ int xi = (int) floor(x);
+ int yi = (int) floor(y);
if (x < png.clip_left || x >= png.clip_rite || y < png.clip_top || y >= png.clip_bot)
return;
- png.grid[y * png.width + x] = png.current_color;
+ png.grid[yi * png.width + xi] = png.current_color;
-static void draw_line(int x1, int y1, int x2, int y2)
+static void swap(double *a, double *b)
- int x, y, x_end, y_end;
- int xinc, yinc, error;
- int delta_x, delta_y;
+ double t = *a; *a = *b; *b = t;
- x = x1;
- x_end = x2;
- y = y1;
- y_end = y2;
+static void draw_line(double x1, double y1, double x2, double y2)
+ double x, y;
+ double dx, dy;
- if (x == x_end && y == y_end) {
- store_xy(x, y);
- return;
+ if (fabs(y1 - y2) > fabs(x1 - x2)) {
+ if (y1 > y2) {
+ swap(&y1, &y2);
+ swap(&x1, &x2);
- /* generate equation */
- delta_y = y_end - y;
- delta_x = x_end - x;
+ dy = y2 - y1;
+ dx = x2 - x1;
- /* figure out which way to move x */
- xinc = 1;
- if (delta_x < 0) {
- delta_x = -delta_x;
- xinc = -1;
- /* figure out which way to move y */
- yinc = 1;
- if (delta_y < 0) {
- delta_y = -delta_y;
- yinc = -1;
- if (delta_x > delta_y) {
- /* always move x, decide when to move y */
- /* initialize the error term, and double delta x and delta y */
- delta_y = delta_y * 2;
- error = delta_y - delta_x;
- delta_x = delta_y - (delta_x * 2);
- while (x != x_end) {
+ for (y = floor(y1) + 0.5; y < y2; y++) {
+ x = x1 + (y - y1) * dx / dy;
store_xy(x, y);
- if (error > 0) {
- y += yinc;
- error += delta_x;
- else
- error += delta_y;
- x += xinc;
else {
- /* always move y, decide when to move x */
- delta_x = delta_x * 2;
- error = delta_x - delta_y;
- delta_y = delta_x - (delta_y * 2);
+ if (x1 > x2) {
+ swap(&x1, &x2);
+ swap(&y1, &y2);
- while (y != y_end) {
+ dx = x2 - x1;
+ dy = y2 - y1;
+ for (x = floor(x1) + 0.5; x < x2; x++) {
+ y = y1 + (x - x1) * dy / dx;
store_xy(x, y);
- if (error > 0) {
- x += xinc;
- error += delta_y;
- else
- error += delta_x;
- y += yinc;
- store_xy(x, y);
-void PNG_draw_line(double fx1, double fy1, double fx2, double fy2)
+void PNG_draw_line(double x1, double y1, double x2, double y2)
- int x1 = (int) floor(fx1 + 0.5);
- int y1 = (int) floor(fy1 + 0.5);
- int x2 = (int) floor(fx2 + 0.5);
- int y2 = (int) floor(fy2 + 0.5);
+ double ax[4], ay[4];
+ double k = png.linewidth / 2;
int dx, dy;
- int i;
if (png.linewidth <= 1) {
draw_line(x1, y1, x2, y2);
@@ -114,17 +74,19 @@
return;
- dx = abs(x2 - x1);
- dy = abs(y2 - y1);
- for (i = 0; i < png.linewidth; i++) {
- int k = i - png.linewidth / 2;
- if (dy > dx)
- draw_line(x1 + k, y1, x2 + k, y2);
- else
- draw_line(x1, y1 + k, x2, y2 + k);
+ if (dy > dx) {
+ ax[0] = x1 - k; ay[0] = y1;
+ ax[1] = x1 + k; ay[1] = y1;
+ ax[2] = x2 + k; ay[2] = y2;
+ ax[3] = x2 - k; ay[3] = y2;
+ else {
+ ax[0] = x1; ay[0] = y1 - k;
+ ax[1] = x1; ay[1] = y1 + k;
+ ax[2] = x2; ay[2] = y2 + k;
+ ax[3] = x2; ay[3] = y2 - k;
- png.modified = 1;
+ PNG_Polygon(ax, ay, 4);
Modified: grass/trunk/lib/pngdriver/Polygon.c
--- grass/trunk/lib/pngdriver/Polygon.c 2008-08-24 00:42:49 UTC (rev 33045)
+++ grass/trunk/lib/pngdriver/Polygon.c 2008-08-24 02:20:30 UTC (rev 33046)
@@ -119,10 +119,8 @@
if (y1 > png.clip_bot)
y1 = png.clip_bot;
- y0 = floor(y0 + 0.5) + 0.5;
- for (y = y0; y < y1; y++)
- line(p, n, y + 0.5);
+ for (y = floor(y0 + 0.5) + 0.5; y < y1; y++)
+ line(p, n, y);
void PNG_Polygon(const double *xarray, const double *yarray, int count)
@@ -145,5 +143,7 @@
points[count].y = yarray[0];
poly(points, count);
+ png.modified = 1;
