[GRASS-SVN] r33055 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Mon Aug 25 06:12:13 EDT 2008
Author: pkelly
Date: 2008-08-25 06:12:12 -0400 (Mon, 25 Aug 2008)
New Revision: 33055
grass/trunk/general/g.proj/g.proj.html
grass/trunk/general/g.proj/input.c
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
grass/trunk/general/g.proj/output.c
Compile with reduced functionality if HAVE_OGR not defined.
Update documentation to reflect removal of interactivity.
Allow only one output format at a time.
Modified: grass/trunk/general/g.proj/g.proj.html
--- grass/trunk/general/g.proj/g.proj.html 2008-08-25 00:24:22 UTC (rev 33054)
+++ grass/trunk/general/g.proj/g.proj.html 2008-08-25 10:12:12 UTC (rev 33055)
@@ -2,13 +2,18 @@
<P><em>g.proj</em> provides a means of converting a co-ordinate system
description (i.e. projection information) between various formats.
-It requires <A HREF="http://www.gdal.org/ogr/">OGR</A> to compile. The basic
-functionality of the module is to report the projection information for the
-current location, either in conventional GRASS (-p flag) or PROJ.4 (-j flag)
-format.</P>
+If compiled without <A HREF="http://www.gdal.org/ogr/">OGR</A> present, the
+functionality is limited to:
+<ul>
+<li>Reporting the projection information for the current location,
+either in conventional GRASS (-p flag) or PROJ.4 (-j flag) format</li>
+<li>Reporting and modifying the datum transformation parameters for
+the current location</li>
+</ul>
+</P>
-<P>Projection information may also be output in the Well-Known Text (WKT)
-format popularised
+<P>When compiled with OGR, functionality is increased and allows output of
+the projection information in the Well-Known Text (WKT) format popularised
by proprietary GIS. In addition, if one of the parameters <em>georef</em>,
<em>wkt</em>, <em>proj4</em> or <em>epsg</em> is specified, rather than the
projection information being read from the current location it is imported
@@ -54,8 +59,7 @@
DEFAULT_WIND) based on the imported information. If the <em>location</em>
parameter is specified in addition to -c, then a new location will be created.
Otherwise the projection information files in the current location will be
-overwritten. The program will warn before doing this only if command-line
-interactive mode (<em>-i</em> flag) is selected.</P>
+overwritten. The program will <strong>not</strong> warn before doing this.</P>
<P>The final mode of operation of g.proj is to report on the datum
information and datum transformation parameters associated with the
@@ -77,14 +81,11 @@
<strong>Any other number less than or equal to the number of parameter sets
available for this datum:</strong> Choose this parameter set and add it to the
co-ordinate system description.<br>
-If the module is being used from the command-line through an interactive
-terminal, the <em>-i</em> flag can be specified to enable interactive
-selection of the parameter set, and the value of <em>datumtrans</em> (if
-specified) is ignored.<br>
If the <em>-t</em> flag is specified, the module will attempt to change the
datum transformation parameters using one of the above two methods
<strong>even if</strong> a valid parameter set is already specified in the
-input co-ordinate system.</P>
+input co-ordinate system. This can be useful to change the datum information
+for an existing location.</P>
<P>Output is simply based on the input projection information. g.proj does
<strong>not</strong> attempt to verify that the co-ordinate system thus
@@ -155,18 +156,17 @@
<p>
Create a new location with the same co-ordinate system as the current
+location, but forcing a change to datum transformation parameter set no. 1:<br>
<div class="code"><pre>
-g.proj -c location=newloc
+g.proj -c location=newloc -t datumtrans=1
</pre></div>
<p>
-Interactively change/update the datum transformation parameters for the
-current location:<br>
+List the possible datum transformation parameters for the current location:<br>
-g.proj -itc
+g.proj -t datumtrans=-1
</pre></div>
<p>
Modified: grass/trunk/general/g.proj/input.c
--- grass/trunk/general/g.proj/input.c 2008-08-25 00:24:22 UTC (rev 33054)
+++ grass/trunk/general/g.proj/input.c 2008-08-25 10:12:12 UTC (rev 33055)
@@ -22,15 +22,22 @@
#include <grass/gis.h>
#include <grass/gprojects.h>
#include <grass/glocale.h>
-#include <gdal.h>
-#include <ogr_api.h>
-#include <cpl_csv.h>
+#include <grass/config.h>
+#ifdef HAVE_OGR
+# include <gdal.h>
+# include <ogr_api.h>
+# include <cpl_csv.h>
+#endif
#include "local_proto.h"
static void set_default_region(void);
+#ifdef HAVE_OGR
static void set_gdal_region(GDALDatasetH);
static void set_ogr_region(OGRLayerH);
+#endif
* \brief Read projection and region information from current location
@@ -50,6 +57,8 @@
return;
+#ifdef HAVE_OGR
* \brief Read projection information in WKT format from stdin or a file
@@ -254,6 +263,7 @@
return ret;
+#endif /* HAVE_OGR */
* \brief Populates global cellhd with "default" region settings
@@ -283,6 +293,8 @@
return;
+#ifdef HAVE_OGR
* \brief Populates global cellhd with region settings based on
* georeferencing information in a GDAL dataset
@@ -365,3 +377,4 @@
return;
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2008-08-25 00:24:22 UTC (rev 33054)
+++ grass/trunk/general/g.proj/local_proto.h 2008-08-25 10:12:12 UTC (rev 33055)
@@ -1,3 +1,5 @@
extern struct Key_Value *projinfo, *projunits;
extern struct Cell_head cellhd;
@@ -3,14 +5,18 @@
/* input.c */
void input_currloc(void);
+#ifdef HAVE_OGR
int input_wkt(char *);
int input_proj4(char *);
int input_epsg(int);
int input_georef(char *);
+#endif
/* output.c */
void print_projinfo(void);
void print_datuminfo(void);
void print_proj4(int);
+#ifdef HAVE_OGR
void print_wkt(int, int);
+#endif
void create_location(char *);
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2008-08-25 00:24:22 UTC (rev 33054)
+++ grass/trunk/general/g.proj/main.c 2008-08-25 10:12:12 UTC (rev 33055)
@@ -18,6 +18,7 @@
#include <string.h>
@@ -44,7 +45,7 @@
* GDAL or OGR */
struct GModule *module;
- int importformats;
+ int formats;
G_set_program_name(argv[0]);
G_no_gisinit(); /* We don't call G_gisinit() here because it validates the
@@ -54,9 +55,13 @@
module = G_define_module();
module->keywords = _("general");
module->description =
+#ifdef HAVE_OGR
_("Converts co-ordinate system descriptions (i.e. projection "
"information) between various formats (including GRASS format). "
"Can also be used to create GRASS locations.");
+#else
+ _("Prints and manipulates GRASS projection information files.");
+#endif
printinfo = G_define_flag();
printinfo->key = 'p';
@@ -76,6 +81,17 @@
printproj4->description =
_("Print projection information in PROJ.4 format");
+ dontprettify = G_define_flag();
+ dontprettify->key = 'f';
+ dontprettify->guisection = "Printed_Output";
+ dontprettify->description =
+ _("Print 'flat' output with no linebreaks (applies to "
+#ifdef HAVE_OGR
+ "WKT and "
+#endif
+ "PROJ.4 output)");
+#ifdef HAVE_OGR
printwkt = G_define_flag();
printwkt->key = 'w';
printwkt->guisection = "Printed_Output";
@@ -87,13 +103,6 @@
esristyle->description =
_("Use ESRI-style format (applies to WKT output only)");
- dontprettify = G_define_flag();
- dontprettify->key = 'f';
- dontprettify->guisection = "Printed_Output";
- dontprettify->description =
- _("Print 'flat' output with no linebreaks (applies to WKT and "
- "PROJ.4 output)");
ingeo = G_define_option();
ingeo->key = "georef";
ingeo->type = TYPE_STRING;
@@ -127,6 +136,7 @@
inepsg->options = "1-1000000";
inepsg->guisection = "Input";
inepsg->description = _("EPSG projection code");
+#endif
dtrans = G_define_option();
dtrans->key = "datumtrans";
@@ -166,25 +176,25 @@
/* Initialisation & Validation */
+#ifdef HAVE_OGR
/* -e implies -w */
if (esristyle->answer && !printwkt->answer)
printwkt->answer = 1;
- projinfo = NULL;
- projunits = NULL;
- importformats = ((ingeo->answer ? 1 : 0) + (inwkt->answer ? 1 : 0) +
- (inproj4->answer ? 1 : 0) + (inepsg->answer ? 1 : 0));
- if (importformats > 1)
+ formats = ((ingeo->answer ? 1 : 0) + (inwkt->answer ? 1 : 0) +
+ (inproj4->answer ? 1 : 0) + (inepsg->answer ? 1 : 0));
+ if (formats > 1)
G_fatal_error(_("Only one of '%s', '%s', '%s' or '%s' options may be specified"),
ingeo->key, inwkt->key, inproj4->key, inepsg->key);
/* Input */
/* We can only have one input source, hence if..else construct */
- if (importformats == 0)
+ if (formats == 0)
+#endif
/* Input is projection of current location */
input_currloc();
+#ifdef HAVE_OGR
else if (inwkt->answer)
/* Input in WKT format */
input_wkt(inwkt->answer);
@@ -197,8 +207,8 @@
else
/* Input from georeferenced file */
input_georef(ingeo->answer);
+#endif
/* Consistency Check */
if ((cellhd.proj != PROJECTION_XY)
@@ -210,23 +220,39 @@
/* Output */
- /* We can output the same information in multiple formats if
- * necessary, hence multiple if statements */
+ /* Only allow one output format at a time, to reduce confusion */
+ formats = ((printinfo->answer ? 1 : 0) + (datuminfo->answer ? 1 : 0) +
+ (printproj4->answer ? 1 : 0) +
+#ifdef HAVE_OGR
+ (printwkt->answer ? 1 : 0) +
+#endif
+ (create->answer ? 1 : 0));
+ if (formats > 1)
+ G_fatal_error(_("Only one of -%c, -%c, -%c"
+#ifdef HAVE_OGR
+ ", -%c"
+#endif
+ " or -%c flags may be specified"),
+ printinfo->key, datuminfo->key, printproj4->key,
+#ifdef HAVE_OGR
+ printwkt->key,
+#endif
+ create->key);
if (printinfo->answer)
print_projinfo();
- if (datuminfo->answer)
+ else if (datuminfo->answer)
print_datuminfo();
- if (printproj4->answer)
+ else if (printproj4->answer)
print_proj4(dontprettify->answer);
- if (printwkt->answer)
+#ifdef HAVE_OGR
+ else if (printwkt->answer)
print_wkt(esristyle->answer, dontprettify->answer);
- if (create->answer)
+#endif
+ else if (create->answer)
create_location(location->answer);
+ else
+ G_warning(_("No output! Please specify an output option."));
/* Tidy Up */
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c 2008-08-25 00:24:22 UTC (rev 33054)
+++ grass/trunk/general/g.proj/output.c 2008-08-25 10:12:12 UTC (rev 33055)
@@ -20,6 +20,7 @@
@@ -124,6 +125,7 @@
return;
+#ifdef HAVE_OGR
void print_wkt(int esristyle, int dontprettify)
char *outwkt;
@@ -142,6 +144,7 @@
return;
+#endif
void create_location(char *location)
