[GRASS-SVN] r33080 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Aug 26 04:11:18 EDT 2008
Author: martinl
Date: 2008-08-26 04:11:18 -0400 (Tue, 26 Aug 2008)
New Revision: 33080
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
wxGUI: update r33077, don't duplicate code, use inheritance instead
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-08-26 06:43:33 UTC (rev 33079)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-08-26 08:11:18 UTC (rev 33080)
@@ -54,6 +54,7 @@
import gcmd
import utils
import gdialogs
+import gselect
from debug import Debug as Debug
from preferences import globalSettings as UserSettings
@@ -3125,105 +3126,12 @@
return True
-class VectorDBInfo:
+class VectorDBInfo(gselect.VectorDBInfo):
"""Class providing information about attribute tables
linked to the vector map"""
def __init__(self, map):
- self.map = map
- # {layer number : {table, database, driver})
- self.layers = {}
- # {table : {column name : type, length, values, ids}}
- self.tables = {}
- if not self.__CheckDBConnection(): # -> self.layers
- return
- self.__DescribeTables() # -> self.tables
- def __CheckDBConnection(self):
- """Check DB connection"""
- layerCommand = gcmd.Command(cmd=["v.db.connect",
- "-g", "--q",
- "map=%s" % self.map],
- rerr=None, stderr=None)
- if layerCommand.returncode != 0:
- return False
- # list of available layers & (table, database, driver)
- for line in layerCommand.ReadStdOutput():
- lineList = line.split(' ')
- layer = lineList[0]
- if '/' in layer:
- layer, layer_name = lineList[0].split('/')
- else:
- layer_name = None
- # database can contain ' ' in it's path
- if len(lineList) > 5:
- database = ''.join(lineList[3:-1])
- else:
- database = lineList[3]
- self.layers[int(layer)] = {
- "name" : layer_name,
- "table" : lineList[1],
- "key" : lineList[2],
- "database" : database,
- "driver" : lineList[-1]
- if (len(self.layers.keys()) == 0):
- return False
- return True
- def __DescribeTables(self):
- """Describe linked tables"""
- for layer in self.layers.keys():
- # determine column names and types
- table = self.layers[layer]["table"]
- columnsCommand = gcmd.Command (cmd=["db.describe",
- "-c", "--q",
- "table=%s" % self.layers[layer]["table"],
- "driver=%s" % self.layers[layer]["driver"],
- "database=%s" % self.layers[layer]["database"]])
- columns = {} # {name: {type, length, [values], [ids]}}
- if columnsCommand.returncode == 0:
- # skip nrows and ncols
- i = 0
- for line in columnsCommand.ReadStdOutput()[2:]:
- num, name, type, length = line.strip().split(':')
- # FIXME: support more datatypes
- if type.lower() == "integer":
- ctype = int
- elif type.lower() == "double precision":
- ctype = float
- else:
- ctype = str
- columns[name.strip()] = { 'index' : i,
- 'type' : type.lower(),
- 'ctype' : ctype,
- 'length' : int(length),
- 'values' : [],
- 'ids' : []}
- i += 1
- else:
- return False
- # check for key column
- # v.db.connect -g/p returns always key column name lowercase
- if self.layers[layer]["key"] not in columns.keys():
- for col in columns.keys():
- if col.lower() == self.layers[layer]["key"]:
- self.layers[layer]["key"] = col.upper()
- break
- self.tables[table] = columns
- return True
+ gselect.VectorDBInfo.__init__(self, map)
def GetColumns(self, table):
"""Return list of columns names (based on their index)"""
names = [''] * len(self.tables[table].keys())
@@ -3308,15 +3216,6 @@
return nselected
- def Reset(self):
- """Reset"""
- for layer in self.layers:
- table = self.layers[layer]["table"] # get table desc
- columns = self.tables[table]
- for name in self.tables[table].keys():
- self.tables[table][name]['values'] = []
- self.tables[table][name]['ids'] = []
class ModifyTableRecord(wx.Dialog):
"""Dialog for inserting/updating table record"""
def __init__(self, parent, id, title, data, keyEditable=(-1, True),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-08-26 06:43:33 UTC (rev 33079)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2008-08-26 08:11:18 UTC (rev 33080)
@@ -1,18 +1,21 @@
-MODULE: gselect
+ at package gselect
+ at brief Custom control that selects GRASS GIS elements
CLASSES:
- * Select
- * TreeCrtlComboPopup
+ - Select
+ - TreeCrtlComboPopup
+ - VectorDBInfo
+ - LayerSelect
+ - ColumnSelect
-PURPOSE: Custon control that selects GRASS GIS elements
+(C) 2007-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
-AUTHORS: The GRASS Development Team. Michael Barton & Martin Landa
-COPYRIGHT: (C) 2007 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+ at author Michael Barton, Martin Landa
import os
