[GRASS-SVN] r33086 - grass/trunk/vector/v.db.select
Tue Aug 26 05:06:35 EDT 2008
Author: martinl
Date: 2008-08-26 05:06:35 -0400 (Tue, 26 Aug 2008)
New Revision: 33086
   grass/trunk/vector/v.db.select/main.c
v.db.select: add missing ->answer (merge from devbr6, r33085)
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2008-08-26 09:05:11 UTC (rev 33085)
+++ grass/trunk/vector/v.db.select/main.c	2008-08-26 09:06:35 UTC (rev 33086)
@@ -119,7 +119,7 @@
 	G_fatal_error(_("Vector map <%s> not found"), map_opt->answer);
-    if (!r_flag) {
+    if (!r_flag->answer) {
 	Vect_open_old_head(&Map, map_opt->answer, mapset);
     else {
