[GRASS-SVN] r33092 - in grass/trunk: display/d.his
display/d.profile display/d.rast display/d.rgb include lib/display
svn_grass at osgeo.org
Tue Aug 26 09:34:11 EDT 2008
Author: glynn
Date: 2008-08-26 09:34:11 -0400 (Tue, 26 Aug 2008)
New Revision: 33092
grass/trunk/display/d.his/main.c
grass/trunk/display/d.profile/main.c
grass/trunk/display/d.rast/display.c
grass/trunk/display/d.rgb/main.c
grass/trunk/include/display.h
grass/trunk/lib/display/raster.c
Replace D_cell_draw_setup() with D_cell_draw_begin()
Modified: grass/trunk/display/d.his/main.c
--- grass/trunk/display/d.his/main.c 2008-08-26 13:33:17 UTC (rev 33091)
+++ grass/trunk/display/d.his/main.c 2008-08-26 13:34:11 UTC (rev 33092)
@@ -54,7 +54,6 @@
struct GModule *module;
struct Option *opt_h, *opt_i, *opt_s, *brighten;
struct Flag *nulldraw;
- double t, b, l, r;
double bright_mult;
@@ -117,9 +116,7 @@
/* Prepare the raster cell drawing functions */
D_setup(0);
- D_get_dst(&t, &b, &l, &r);
D_set_overlay_mode(nulldraw->answer ? 1 : 0);
- D_cell_draw_setup(t, b, l, r);
/* Get name of layer to be used for hue */
name_h = opt_h->answer;
@@ -202,6 +199,8 @@
intensity = 255; /* default is to not change intensity */
saturation = 255; /* default is to not change saturation */
+ D_cell_draw_begin();
next_row = 0;
for (atrow = 0; atrow < window.rows;) {
G_percent(atrow, window.rows, 2);
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c 2008-08-26 13:33:17 UTC (rev 33091)
+++ grass/trunk/display/d.profile/main.c 2008-08-26 13:34:11 UTC (rev 33092)
@@ -426,16 +426,12 @@
void myDcell(char *name, char *mapset, int overlay)
- int fd, i, t, b, l, r, code;
+ int fd, i, code;
CELL *cell;
struct Colors clr;
D_setup(!overlay);
- D_get_screen_window(&t, &b, &l, &r);
D_set_overlay_mode(overlay);
cell = G_allocate_c_raster_buf();
@@ -447,6 +443,7 @@
G_fatal_error(_("%s: Couldn't read color table for <%s@%s>"),
G_program_name(), name, mapset);
for (i = 0; i >= 0;) {
code = G_get_c_raster_row(fd, cell, i);
if (code < 0)
Modified: grass/trunk/display/d.rast/display.c
--- grass/trunk/display/d.rast/display.c 2008-08-26 13:33:17 UTC (rev 33091)
+++ grass/trunk/display/d.rast/display.c 2008-08-26 13:34:11 UTC (rev 33092)
@@ -51,17 +51,14 @@
int cellfile;
void *xarray;
int cur_A_row;
int ncols, nrows;
ncols = G_window_cols();
nrows = G_window_rows();
/* Set up the screen, conversions, and graphics */
+ D_setup(0);
- if (D_cell_draw_setup(t, b, l, r))
- G_fatal_error(_("Cannot use current window"));
/* Make sure map is available */
if ((cellfile = G_open_cell_old(name, mapset)) == -1)
@@ -70,6 +67,8 @@
/* Allocate space for cell buffer */
xarray = G_allocate_raster_buf(data_type);
/* loop for array rows */
for (cur_A_row = 0; cur_A_row != -1;) {
G_percent(cur_A_row, nrows, 2);
Modified: grass/trunk/display/d.rgb/main.c
--- grass/trunk/display/d.rgb/main.c 2008-08-26 13:33:17 UTC (rev 33091)
+++ grass/trunk/display/d.rgb/main.c 2008-08-26 13:34:11 UTC (rev 33092)
@@ -45,7 +45,6 @@
struct Cell_head window;
struct Flag *flag_o;
int i;
G_gisinit(argv[0]);
@@ -84,9 +83,7 @@
G_fatal_error(_("No graphics device selected"));
D_setup(0);
D_set_overlay_mode(flag_o->answer);
for (i = 0; i < 3; i++) {
/* Get name of layer to be used */
@@ -112,6 +109,8 @@
/* read in current window */
G_get_window(&window);
next_row = 0;
for (row = 0; row < window.rows;) {
G_percent(row, window.rows, 5);
Modified: grass/trunk/include/display.h
--- grass/trunk/include/display.h 2008-08-26 13:33:17 UTC (rev 33091)
+++ grass/trunk/include/display.h 2008-08-26 13:34:11 UTC (rev 33092)
@@ -124,7 +124,7 @@
int D_draw_f_raster(int, const FCELL *, struct Colors *);
int D_draw_c_raster(int, const CELL *, struct Colors *);
int D_draw_cell(int, const CELL *, struct Colors *);
-int D_cell_draw_setup(double, double, double, double);
+void D_cell_draw_begin(void);
int D_draw_raster_RGB(int, const void *, const void *, const void *,
struct Colors *, struct Colors *, struct Colors *,
RASTER_MAP_TYPE, RASTER_MAP_TYPE, RASTER_MAP_TYPE);
Modified: grass/trunk/lib/display/raster.c
--- grass/trunk/lib/display/raster.c 2008-08-26 13:33:17 UTC (rev 33091)
+++ grass/trunk/lib/display/raster.c 2008-08-26 13:34:11 UTC (rev 33092)
@@ -130,22 +130,12 @@
* \return int
-int D_cell_draw_setup(double t, double b, double l, double r)
- struct Cell_head window;
- if (G_get_set_window(&window) == -1)
- G_fatal_error("Current window not available");
- D_do_conversions(&window, t, b, l, r);
/* Set up the screen for drawing map */
D_get_a(src);
D_get_d(dst);
R_begin_scaled_raster(D__overlay_mode, src, dst);
- return 0;
int D_draw_raster_RGB(int A_row,
