[GRASS-SVN] r33095 - grass/trunk/display/d.profile
Tue Aug 26 13:25:49 EDT 2008
Author: glynn
Date: 2008-08-26 13:25:48 -0400 (Tue, 26 Aug 2008)
New Revision: 33095
Removed:
   grass/trunk/display/d.profile/DrawText.c
   grass/trunk/display/d.profile/DumpProfile.c
   grass/trunk/display/d.profile/ExtractProf.c
   grass/trunk/display/d.profile/InitProfile.c
   grass/trunk/display/d.profile/PlotProfile.c
   grass/trunk/display/d.profile/Range.c
   grass/trunk/display/d.profile/What.c
   grass/trunk/display/d.profile/bnw_line.c
   grass/trunk/display/d.profile/profile.h
   grass/trunk/display/d.profile/utils.c
   grass/trunk/display/d.profile/d.profile.html
   grass/trunk/display/d.profile/main.c
Replace d.profile with non-interactive version
Deleted: grass/trunk/display/d.profile/DrawText.c
--- grass/trunk/display/d.profile/DrawText.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/DrawText.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,54 +0,0 @@
-#include <grass/raster.h>
-#include <grass/display.h>
-/* DrawText.c
- * function defined:
- * DrawText(size,row,col,text)
- * int size,            - size of text (percent of window height)
- *     row,             - text row
- *     col;             - text col
- * char *text;          - text string
- * PURPOSE: To display a text string in the currently selected on-screen
- * window, in much the same way that the Dtext program works.  Just like
- * Dtext the text size is expressed as a percentage of the window height.
- * The number of text rows and columns in a window are determined by the
- * text size.
- * NOTES:
- * 1) Assumes that R_open_driver has already been called.
- * 2)
- * Dave Johnson
- * DBA Systems, Inc.
- * 10560 Arrowhead Drive
- * Fairfax, Virginia 22030
-int DrawText(int size, int row, int col, char *text)
-    int b, t, l, r;
-    int tsize;
-    int dots_per_line;
-    int cur_dot_row;
-#ifdef DEBUG
-    fprintf(stdout, "DrawText: %s\n", text);
-#endif
-    D_get_screen_window(&t, &b, &l, &r);
-    dots_per_line = (int)(size / 100.0 * (float)(b - t));
-    tsize = (int)(.8 * (float)dots_per_line);
-    cur_dot_row = t + dots_per_line * row;
-    R_text_size(tsize, tsize);
-    R_move_abs(l + col * tsize, cur_dot_row);
-    R_text(text);
-    return 0;
Deleted: grass/trunk/display/d.profile/DumpProfile.c
--- grass/trunk/display/d.profile/DumpProfile.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/DumpProfile.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,111 +0,0 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <limits.h>
-#include <float.h>
-#include "profile.h"
-#define UCAT_STR_SIZE 50
-char *_fmt_ucat(UCAT *, UCAT *, char *);
-int WriteProfile(char *raster, char *mapset,
-		 char *fname, char letter, struct Profile *profile)
-    int proj;
-    char *buf = G_calloc(UCAT_STR_SIZE, sizeof(char));
-    char *buf2 = G_calloc(UCAT_STR_SIZE, sizeof(char));
-    char *outfile = G_calloc(strlen(fname) + 3, sizeof(char));
-    char coords[4][80];
-    FILE *outFile;
-    struct ProfileNode *ptr;
-    memset(coords[0], 0, 80);
-    memset(coords[1], 0, 80);
-    memset(coords[2], 0, 80);
-    memset(coords[3], 0, 80);
-    /* Something's wrong if all of these are not NULL */
-    if (raster == NULL || mapset == NULL || fname == NULL || profile == NULL)
-	return -1;
-    /* If no profiles were done, do nothing */
-    if (profile->ptr == NULL || profile->count == 0)
-	return 0;
-    /* Each profile has the letter appended to the name */
-    sprintf(outfile, "%s.%c", fname, letter);
-    outFile = fopen(outfile, "w");
-    if (outFile == NULL)
-	return -1;
-    proj = G_projection();
-    /* Do the Header */
-    fprintf(outFile, "# Profile %c of %s@%s\n", letter, raster, mapset);
-    G_format_easting(profile->e1, coords[0], proj);
-    G_format_northing(profile->n1, coords[1], proj);
-    G_format_easting(profile->e2, coords[2], proj);
-    G_format_northing(profile->n2, coords[3], proj);
-    fprintf(outFile, "# From (%s, %s) to (%s, %s)\n",
-	    coords[0], coords[1], coords[2], coords[3]);
-    fprintf(outFile, "# Stats: Count = %ld, Min = %s, Max = %s\n",
-	    profile->count,
-	    _fmt_ucat(&profile->MinCat, &profile->MinCat, buf),
-	    _fmt_ucat(&profile->MaxCat, &profile->MinCat, buf2));
-    fprintf(outFile, "# dist value east north\n");
-    /* Now loop through the nodes, one value per line */
-    for (ptr = profile->ptr; ptr != NULL; ptr = ptr->next) {
-	fprintf(outFile, "%f %s %f %f\n",
-		ptr->dist,
-		_fmt_ucat(&ptr->cat, &profile->MinCat, buf),
-		ptr->east, ptr->north);
-    G_free(buf);
-    G_free(buf2);
-    G_free(outfile);
-    fclose(outFile);
-    return 0;
-}				/* WriteProfile() */
-/* Pointer should have space for at least 20 chars.
- * First UCAT is the value we're formatting.
- * Second UCAT is a minimum value (use it if NULL)
- * The char *s in is the same that goes out
-char *_fmt_ucat(UCAT * c, UCAT * min, char *s)
-    memset(s, 0, UCAT_STR_SIZE);
-    switch (c->type) {
-    case CELL_TYPE:
-	if (c->val.c == INT_MIN)
-	    sprintf(s, "%d", min->val.c);
-	else
-	    sprintf(s, "%d", c->val.c);
-	break;
-    case FCELL_TYPE:
-	if (c->val.f == FLT_MIN)
-	    sprintf(s, "%f", min->val.f);
-	else
-	    sprintf(s, "%f", c->val.f);
-	break;
-    case DCELL_TYPE:
-	if (c->val.d == DBL_MIN)
-	    sprintf(s, "%lf", min->val.d);
-	else
-	    sprintf(s, "%lf", c->val.d);
-	break;
-    default:			/* Shouldn't happen */
-	*s = '\0';
-    return s;
-/* vim: set softtabstop=4 shiftwidth=4 expandtab: */
Deleted: grass/trunk/display/d.profile/ExtractProf.c
--- grass/trunk/display/d.profile/ExtractProf.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/ExtractProf.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,357 +0,0 @@
-/* ExtractProfile.c
- * ExtractProfile(profile,name,mapset)
- *  struct Profile *profile;    - pointer in initialized profile struct
- *  char   *name,               - cell-file map name
- *         *mapset;             - mapset name
- * PURPOSE: To extract a profile from a cell-file.  A profile is a list
- * of all the cell-values along a given line drawn across a cell-file.
- * The number of cell-values is determined by the end-points of the line
- * and the current window definition.
- * NOTES:
- * 1) Assumes that profile is a pointer to a profile structure that has
- *    been initialized through a call to the routine InitProfile.  The
- *    profile structure is defined in profile.h.
- * 2) ExtractProfile returns 0 upon successful completion, or a negative
- *    value if an error is encountered:
- *       -1   profile end-point outside the current window
- *       -2   unable to open cell-file
- *       -3   error reading from cell-file
- *       -4   profile's window does not match current window
- * Dave Johnson
-#include <float.h>
-#include <grass/glocale.h>
-void ucat_max(UCAT *, UCAT *);
-void ucat_min(UCAT *, UCAT *);
-int ExtractProfile(struct Profile *profile, char *name, char *mapset)
-    int fd;			/* cell-file desciptor */
-    struct Cell_head window;	/* current GIS window */
-    RASTER_MAP_PTR buf;		/* storage for one cell-file row */
-    UCAT theCell;		/* storage of the current cell of interest - for NULL fix */
-    struct ProfileNode *ptr = NULL;
-    int stop;
-    int row1, col1;
-    int row2, col2;
-    int row, col;		/* keep track of profile line position */
-    float slope;		/* for profile line equation */
-    int incr;
-    G_get_set_window(&window);
-    /* make sure profile`s window matches currently set window */
-    if (profile->window.north != window.north ||
-	profile->window.south != window.south ||
-	profile->window.east != window.east ||
-	profile->window.west != window.west ||
-	profile->window.ew_res != window.ew_res ||
-	profile->window.ns_res != window.ns_res)
-	return (-4);
-    /* make sure profile's end-points are not outside the current window */
-    if (profile->n1 > window.north || profile->n1 < window.south ||
-	profile->e1 > window.east || profile->e1 < window.west ||
-	profile->n2 > window.north || profile->n2 < window.south ||
-	profile->e2 > window.east || profile->e2 < window.west)
-	return (-1);
-    /* figure row and column coords. of end-points */
-    row1 = (profile->window.north - profile->n1) / profile->window.ns_res;
-    col1 = (profile->e1 - profile->window.west) / profile->window.ew_res;
-    row2 = (profile->window.north - profile->n2) / profile->window.ns_res;
-    col2 = (profile->e2 - profile->window.west) / profile->window.ew_res;
-#ifdef DEBUG
-    fprintf(stdout, "ExtractProfile: from (%d,%d) to ", row1, col1);
-    fprintf(stdout, "(%d,%d)\n", row2, col2);
-#endif
-    /* open the cel file, return -2 if problem */
-    fd = G_open_cell_old(name, mapset);
-    if (fd < 0) {
-	G_warning(_("Unable to open raster map <%s>"), name);
-	return (-2);
-    theCell.type = buf.type = G_get_raster_map_type(fd);
-    buf.data.v = G_allocate_raster_buf(buf.type);
-     * this section loops through a line between (row1,col1) and (row2,col2)
-     * adding category values along line to linked-list that represents
-     * the profile
-     * two cases:
-     * 1) line crosses more rows than columns.
-     * 2) line crosses more columns than rows.
-    /* CASE 1: line crosses more rows than columns. */
-    if ((row1 != row2) && (abs(row1 - row2) > abs(col1 - col2))) {
-	if (row2 < row1)
-	    incr = -1;		/* line goes "up" */
-	else
-	    incr = 1;		/* line goes "down" */
-	if (row1 == row2)
-	    slope = (float)0.0;	/* line is horizontal */
-	else
-	    slope = (float)((float)(col2 - col1) / (float)(row2 - row1));
-#  ifdef DEBUG
-	fprintf(stdout, "CASE 1: slope=%f\n", slope);
-#  endif
-	/* LOOP through profile line by rows */
-	stop = row2 + incr;
-	for (row = row1; row != stop; row += incr) {
-	    profile->count++;
-	    col = (int)(slope * (float)(row - row1) + col1);
-	    if (G_get_raster_row(fd, buf.data.v, row, buf.type) < 0)
-		return (-3);
-	    /* Test if NULL, if so set to the minimum value */
-	    if (is_null_value(&buf, col)) {
-		switch (buf.type) {
-		case CELL_TYPE:
-		    theCell.val.c = INT_MIN;
-		    break;
-		case FCELL_TYPE:
-		    theCell.val.f = FLT_MIN;
-		    break;
-		case DCELL_TYPE:
-		    theCell.val.d = DBL_MIN;
-		    break;
-	    else {
-		case CELL_TYPE:
-		    theCell.val.c = buf.data.c[col];
-		    break;
-		case FCELL_TYPE:
-		    theCell.val.f = buf.data.f[col];
-		    break;
-		case DCELL_TYPE:
-		    theCell.val.d = buf.data.d[col];
-		    break;
-	    /* set mins and maxes */
-	    if (row == row1) {
-		profile->MaxCat = theCell;
-		profile->MinCat = theCell;
-	    else {
-		ucat_max(&profile->MaxCat, &theCell);
-		ucat_min(&profile->MinCat, &theCell);
-	    /* add to linked list */
-	    if (profile->ptr == NULL) {	/* add to linked list */
-		/* first in list */
-		profile->ptr = (struct ProfileNode *)
-		    G_malloc(sizeof(struct ProfileNode));
-		profile->ptr->cat = theCell;
-		profile->ptr->next = NULL;
-		/* Start info for Plotfile output */
-		profile->ptr->east = G_col_to_easting((double)0.5 + col,
-						      &profile->window);
-		profile->ptr->north = G_row_to_northing((double)0.5 + row,
-		profile->ptr->dist = (double)0.0;
-		ptr = profile->ptr;
-	    else {
-		/* not first in list */
-		ptr->next = (struct ProfileNode *)
-		ptr->next->cat = theCell;
-		/* Do row/cell conversion for coordinates, Add .5 to get center */
-		ptr->next->north = G_row_to_northing((double)0.5 + row,
-		ptr->next->east = G_col_to_easting((double)0.5 + col,
-		G_begin_distance_calculations();
-		ptr->next->dist =
-		    G_distance(profile->ptr->east, profile->ptr->north,
-		ptr->next->next = NULL;
-		ptr = ptr->next;
-    /* CASE 2: line crosses more columns than rows */
-    else {
-	if (col2 < col1)
-	    incr = -1;		/* line goes "left" */
-	else
-	    incr = 1;		/* line goes "right" */
-	if (col1 == col2)
-	    slope = (float)0.0;	/* line is vertical */
-	else
-	    slope = (float)((float)(row2 - row1) / (float)(col2 - col1));
-#  ifdef DEBUG
-	fprintf(stdout, "CASE 2: slope=%f\n", slope);
-#  endif
-	/* LOOP through profile line by columns */
-	stop = col2 + incr;
-	for (col = col1; col != stop; col += incr) {
-	    profile->count++;
-	    row = (int)(slope * (float)(col - col1) + row1);
-		return (-3);
-		case CELL_TYPE:
-		    break;
-		case FCELL_TYPE:
-		    break;
-		case DCELL_TYPE:
-		    break;
-	    else {
-		case CELL_TYPE:
-		    break;
-		case FCELL_TYPE:
-		    break;
-		case DCELL_TYPE:
-		    break;
-	    else {
-	    else {
-		ptr->next->dist =
-		ptr = ptr->next;
-#ifdef DEBUG
-    fprintf(stdout, "\n");
-#endif
-    G_unopen_cell(fd);
-    return (0);
-void ucat_max(UCAT * to, UCAT * from)
-    switch (to->type) {
-    case CELL_TYPE:
-	if (to->val.c == INT_MIN)
-	    to->val.c = from->val.c;
-	else if (from->val.c > to->val.c)
-	break;
-    case FCELL_TYPE:
-	if (to->val.f == FLT_MIN)
-	    to->val.f = from->val.f;
-	else if (from->val.f > to->val.f)
-	break;
-    case DCELL_TYPE:
-	if (to->val.d == DBL_MIN)
-	    to->val.d = from->val.d;
-	else if (from->val.d > to->val.d)
-	break;
-void ucat_min(UCAT * to, UCAT * from)
-    switch (from->type) {
-    case CELL_TYPE:
-	if (from->val.c != INT_MIN && from->val.c < to->val.c)
-	break;
-    case FCELL_TYPE:
-	if (from->val.f != FLT_MIN && from->val.f < to->val.f)
-	break;
-    case DCELL_TYPE:
-	if (from->val.d != DBL_MIN && from->val.d < to->val.d)
-	break;
Deleted: grass/trunk/display/d.profile/InitProfile.c
--- grass/trunk/display/d.profile/InitProfile.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/InitProfile.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,51 +0,0 @@
-/* InitProfile.c
- * InitProfile(profile,window,north1,east1,north2,east2)
- * struct Profile   *profile;   - pointer to profile structure
- * struct Cell_head window;     - current window definition
- * double           north1,     - coords. of point #1
- *                  east1,
- *                  north2,     - coords. of point #2
- *                  east2;
- * PURPOSE: To initialize a profile structure with profile-line
- * end-points and the current window definition.
- * NOTES:
- * 1) The profile structure is defined in the file profile.h.
- * 2)
- * Dave Johnson
-int
-InitProfile(struct Profile *profile, struct Cell_head window, double north1,
-	    double east1, double north2, double east2)
-    profile->window.north = window.north;
-    profile->window.south = window.south;
-    profile->window.west = window.west;
-    profile->window.east = window.east;
-    profile->window.ew_res = window.ew_res;
-    profile->window.ns_res = window.ns_res;
-    profile->n1 = north1;
-    profile->e1 = east1;
-    profile->n2 = north2;
-    profile->e2 = east2;
-    profile->count = 0;
-    profile->ptr = NULL;
-    return 0;
Deleted: grass/trunk/display/d.profile/PlotProfile.c
--- grass/trunk/display/d.profile/PlotProfile.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/PlotProfile.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,166 +0,0 @@
-/* PlotProfile.c
- * PlotProfile(profile,letter,min,max)
- * struct Profile profile;      - profile structure
- * int min,                     - min cell-file value
- *     max;                     - max cell-file calue
- * PURPOSE: To plot a profile in the currently chosen on-screen window.
- * The profile's length is scaled to fit along the x-axis.  The profile
- * is scaled to fit the maximum and minimum cell-file values (instead of
- * the maximum and minimum profile values) on the y-axis.
- * NOTES:
- * 1) assumes that R_open_driver has already been called.
- * 2) assumes that the profile structure has been both initialized by
- * a call to InitProfile, and filled with data by a call to ExtractProfile.
- * Dave Johnson
-#define ORIGIN_X	0.13
-#define ORIGIN_Y	0.07
-#define YAXIS_END	0.77
-#define XAXIS_END	0.95
-#define TEXT_HEIGHT	0.11
-#define TEXT_COLUMN    	0.07
-double _get_cat(UCAT *, int);
-int PlotProfile(struct Profile profile, char *letter, int min, int max)
-    char txt_buf[512];
-    int done;
-    int text_width,
-	text_height,
-	i, t, b, l, r, tt, tb, tl, tr, height, width, x_line[3], y_line[3];
-    double yoffset, xoffset, xscale, yscale;
-    /* get current graphics window coordinates */
-    R_set_window(t, b, l, r);
-    /* erase current graphics window to black */
-    D_use_color(D_translate_color(DEFAULT_BG_COLOR));
-    D_erase_window();
-    /* create axis lines */
-    height = b - t;
-    width = r - l;
-    x_line[0] = x_line[1] = l + (int)(ORIGIN_X * width);
-    x_line[2] = l + (int)(XAXIS_END * width);
-    y_line[0] = b - (int)(YAXIS_END * height);
-    y_line[1] = y_line[2] = b - (int)(ORIGIN_Y * height);
-    D_use_color(D_translate_color(DEFAULT_FG_COLOR));
-    /* figure scaling factors and offsets for profile line */
-    xscale = ((double)(x_line[2] - x_line[1]) / ((double)profile.count));
-    yscale = ((double)(y_line[1] - y_line[0])) / ((double)(max - min));
-    yoffset = (double)(y_line[1]);
-    xoffset = (double)x_line[1];
-    /* plot profile */
-    ptr = profile.ptr;
-    R_move_abs((int)xoffset, (int)yoffset);
-    for (i = 0; i <= profile.count; i++) {
-	if (ptr == NULL)
-	    break;
-	if (xscale > 1) {
-	    R_cont_abs((int)(xoffset + xscale * i),
-		       (int)(yoffset - yscale * _get_cat(&ptr->cat, min)));
-	    R_cont_abs((int)(xoffset + xscale * (i + 1.0)),
-	else
-	ptr = ptr->next;
-    D_use_color(D_translate_color("red"));
-    R_polyline_abs(x_line, y_line, 3);
-    /* loop until coordinate text is sized correctly to fit in window */
-    text_height = TEXT_HEIGHT * (b - t);
-    text_width = text_height * 0.8;
-    sprintf(txt_buf, "%s: From (%10.2f,%10.2f) to (%10.2f,%10.2f)",
-	    letter, profile.e1, profile.n1, profile.e2, profile.n2);
-    done = 0;
-    do {
-	R_get_text_box(txt_buf, &tt, &tb, &tl, &tr);
-	if ((tr - tl) >= (r - l)) {
-	    text_height *= 0.95;
-	    text_width *= 0.95;
-	    R_text_size(text_width, text_height);
-	else
-	    done = 1;
-    while (!done);
-    R_move_abs((int)(l + 0.5 * (r - l) - .5 * (tr - tl)),
-	       (int)(t + .12 * (b - t)));
-    R_text(txt_buf);
-    /* set text size for y-axis labels */
-    /* plot y-axis label (bottom) */
-    sprintf(txt_buf, "%d", min);
-    R_move_abs((int)(l + TEXT_COLUMN * (r - l) - .5 * (tr - tl)),
-	       (int)(yoffset + .5 * (tb - tt)));
-    R_text(txt_buf);
-    /* plot y-axis label (top) */
-    sprintf(txt_buf, "%d", max);
-	       (int)(y_line[0] + .5 * (tb - tt)));
-    R_text(txt_buf);
-    R_flush();
-    return 0;
-double _get_cat(UCAT * theCat, int min)
-    switch (theCat->type) {
-    case CELL_TYPE:
-	if (theCat->val.c >= min)
-	    return (double)(theCat->val.c - (double)min);
-	else
-	    return (double)0.0;
-    case FCELL_TYPE:
-	if (theCat->val.f >= min)
-	    return (double)(theCat->val.f - (double)min);
-	else
-    case DCELL_TYPE:
-	if (theCat->val.d >= min)
-	    return (theCat->val.d - (double)min);
-	else
Deleted: grass/trunk/display/d.profile/Range.c
--- grass/trunk/display/d.profile/Range.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/Range.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,109 +0,0 @@
-#include <stdio.h>
-#include <grass/gis.h>
-int WindowRange(char *name, char *mapset, long *min, long *max)
-    char inbuf[512];		/* input buffer for reading stats */
-    int done = 0;
-    char stats_cmd[512];	/* string for r.stats command */
-    char *temp_fname;		/* temp file name */
-    FILE *temp_file;		/* temp file pointer */
-    long int cat;		/* a category value */
-    long int stat;		/* a category stat value */
-    int first;
-    /* write stats to a temp file */
-    temp_fname = G_tempfile();
-    sprintf(stats_cmd, "r.stats -ci %s > %s\n", name, temp_fname);
-    system(stats_cmd);
-    /* open temp file and read the stats into a linked list */
-    temp_file = fopen(temp_fname, "r");
-    first = 1;
-    while (!done) {
-	if (fgets(inbuf, 1024, temp_file) != NULL) {
-	    if (sscanf(inbuf, "%ld %ld", &cat, &stat) == 2) {
-		if (first) {
-		    *max = cat;
-		    *min = cat;
-		    first = 0;
-		else {
-		    if (cat > *max)
-			*max = cat;
-		    if (cat < *min)
-			*min = cat;
-	    else
-		done = 1;
-	else
-	    done = 1;
-    return 0;
-int quick_range(char *name, char *mapset, long *min, long *max)
-    struct Range range;
-    struct FPRange fprange;
-    CELL xmin, xmax;
-    DCELL fpxmin, fpxmax;
-    switch (G_raster_map_type(name, mapset)) {
-    case CELL_TYPE:
-	if (G_read_range(name, mapset, &range) <= 0)
-	    return 0;
-	G_get_range_min_max(&range, &xmin, &xmax);
-	*max = xmax;
-	*min = xmin;
-	break;
-    default:
-	if (G_read_fp_range(name, mapset, &fprange) <= 0)
-	    return 0;
-	G_get_fp_range_min_max(&fprange, &fpxmin, &fpxmax);
-	*max = (long)fpxmax;
-	*min = (long)fpxmin;
-	break;
-    return 1;
-int slow_range(char *name, char *mapset, long *min, long *max)
-    FILE *fd;
-    int first;
-    long n;
-    int ok;
-    char buf[512];
-    *min = *max = 0;
-    G_message(_("one moment ..."));
-    sprintf(buf, "Gdescribe -r -1 '%s in %s'", name, mapset);
-    fd = popen(buf, "r");
-    if (fd == NULL)
-	return 0;
-    ok = 1;
-    first = 1;
-    while (ok && fgets(buf, sizeof(buf), fd)) {
-	ok = (sscanf(buf, "%ld", &n) == 1);
-	if (!ok)
-	    break;
-	if (n == 0)
-	    continue;
-	*max = n;
-	if (first)
-	    *min = n;
-	first = 0;
-    pclose(fd);
-    if (!ok)
-	*min = *max = 0;
-    return ok;
Deleted: grass/trunk/display/d.profile/What.c
--- grass/trunk/display/d.profile/What.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/What.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,52 +0,0 @@
-#include <stdio.h>
-int What(char *name,
-	 char *mapset, struct Cell_head window, double east, double north)
-    struct Categories cat;
-    int NoCatStrings = 0, row, col, fd;
-    CELL *buf;
-    char txt_buf[1024];
-    row = (window.north - north) / window.ns_res;
-    col = (east - window.west) / window.ew_res;
-    buf = G_allocate_cell_buf();
-    if (fd < 0)
-	G_fatal_error(_("Unable to open raster map <%s>"), name);
-    if (G_read_cats(name, mapset, &cat) < 0)
-	NoCatStrings = 1;
-    if (G_get_map_row(fd, buf, row) < 0)
-	G_fatal_error(_("Error reading raster map"));
-    else {
-	D_erase_window();
-	R_flush();
-	sprintf(txt_buf, "%s in mapset %s", name, mapset);
-	DrawText(22, 1, 1, txt_buf);
-	sprintf(txt_buf, "EAST: %10.2f", east);
-	DrawText(22, 2, 1, txt_buf);
-	sprintf(txt_buf, "NORTH: %10.2f", north);
-	DrawText(22, 3, 1, txt_buf);
-	if (NoCatStrings)
-	    sprintf(txt_buf, "(%d)", buf[col]);
-	else
-	    sprintf(txt_buf, "(%d) %s", buf[col], G_get_cat(buf[col], &cat));
-	DrawText(22, 4, 1, txt_buf);
-	R_flush();
-    return 0;
Deleted: grass/trunk/display/d.profile/bnw_line.c
--- grass/trunk/display/d.profile/bnw_line.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/bnw_line.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,24 +0,0 @@
-int black_and_white_line(int screen_x, int screen_y,
-			 int cur_screen_x, int cur_screen_y)
-    R_move_abs(cur_screen_x, cur_screen_y);
-    R_cont_abs(screen_x, screen_y);
-    if (abs(screen_y - cur_screen_y) <= abs(screen_x - cur_screen_x)) {
-	R_move_abs(cur_screen_x, cur_screen_y - 1);
-	R_cont_abs(screen_x, screen_y - 1);
-    else {
-	R_move_abs(cur_screen_x + 1, cur_screen_y);
-	R_cont_abs(screen_x + 1, screen_y);
-    R_flush();
-    return 0;
Modified: grass/trunk/display/d.profile/d.profile.html
--- grass/trunk/display/d.profile/d.profile.html	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/d.profile.html	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,194 +1,16 @@
 <H2>DESCRIPTION</H2>
-This command works only interactively. It clears the entire
-graphics screen and provides a graphical interaction
-allowing the selection of transects for which profiles are
-then generated. Input parameters can be specified on the command line
-for quicker start-up.
+This command displays the profile for a specified transect.
-<H2>USER PROMPTS</H2>
-First, you will be presented with a prompt asking you to
-choose a raster map layer to be profiled. Then you will be
-prompted for an optional display raster.  The optional display raster
-will be shown rather than the profiled raster.  This is useful
-to be able to more easily see ground features, such as might be visible
-in an aerial photo or satellite image. Finally, you will
-be prompted for the name prefix for output file(s) containing the profile
-data. This is an optional feature.
-<P>
-After parameters are given, the raster layer will be
-displayed in the left half of the graphics monitor, and the
-right half will be divided into four
-frames. There will also be two frames along the top of the
-monitor: a mouse-button menu frame on the left, and a
-status frame on the right.
-<P>
-The mouse-button menu initially offers you three options:
-<DL>
-<DD>
-Mouse Buttons: <BR>
-Left: Where am I? <BR>
-Middle: Mark FIRST Point of Profile Line. <BR>
-Right: QUIT this. <BR>
-</DL>
-You may query the displayed raster map layer by indicating
-points with the left mouse-button. The coordinates and
-category value of each point that you indicate will be
-displayed on in the status frame.  If you mark the first
-point of the profile line you will be presented with the
-following mouse-button menu:
-<DL>
-<DD>
-Middle: Mark SECOND Point of Profile Line. <BR>
-</DL>
-Once you mark the second point of the profile line, the
-profile line will be labeled (with a letter from A to D)
-and displayed in one of the four display frames on the
-right hand side of the screen. You will then be presented
-with a third mouse-button menu:
-<DL>
-<DD>
-Left: DO ANOTHER <BR>
-Middle: CLEAR DISPLAY <BR>
-</DL>
-If you would like to view another profile, click on the
-left mouse-button.  If you would like to redisplay the
-raster map layer and clear out the four profile frames,
-click on the middle mouse-button. If you would like to
-quit, then click on the right button.
-<P>
-If you selected the <B>plotfile</B> option, you will have up to
-four files starting with the <EM>name</EM> and followed by a suffix
-of the plot letter <EM>A, B, C,</EM> or <EM>D</EM>.  The plots that
-are written to these files reflect the last of each plot done with that
-letter (i.e. They will match what's in the display when you quit).
-<P>
-The format of the plot files is not geared toward any particular software,
-but should be easy to coax into a number of other programs.  The first
-three lines contain some header information about the plot, each prefixed
-with a <TT>#</TT> sign to denote a comment.  A fourth comment line describes
-the data that follows.  It consists of the distance (always in meters),
-the cell value (in whatever units it is in), the easting in decimal format,
-and the northing in decimal format.
-The number of values will vary depending on the length of the profile, cell
-resolution and the slope angle of the profile line.  Below is an example
-of a plotfile:
-<P>
-<TT>
-# Profile A of elev.ft at snows<BR>
-# From (702879.29679757, 4287317.55920185) to (702722.40973589, 4287061.72632285)<BR>
-# Stats: Count = 644, Min = 2424.658936, Max = 2513.246094<BR>
-# dist value east north<BR>
-0.000000 2513.246094 702879.102364 4287317.516912<BR>
-0.000000 2513.246094 702878.713496 4287317.118970<BR>
-0.556395 2513.246094 702878.324629 4287316.721029<BR>
-1.112790 2513.246094 702878.324629 4287316.323088<BR>
-...<P>
-</TT>
-<H2>NOTES</H2>
-You might notice the first two 'dist' values in the profile output above are
-both zero.  This is due to the fact the cell resolution for this file is
-less than one meter, and so the function that calculates the distance
-considers the distance between the first cell and the second to be zero.
-You might also notice, the coordinates given in the header and displayed on
-screen are slightly different from the first and last coordinates given in
-the profile data output.  This is because the profile data output finds the
-eastings and northings for the center of the cells while the coordinate
-transformations from mouse clicks might yield slightly different coordinates
-which still fall within the same cell boundaries.  The difference should
-always be less than the distance between the center and any corner (not
-edge!) of the cell at the resolution of the profiled raster.
-<P>
-Only four output plotfiles can be made.  Each time a new profile is run, the
-plotfile is immediately written to the file <EM>name</EM>.<EM>letter</EM>.
-One can take advantage of this fact to create an unlimited number of
-plotfiles simply by renaming the output files before running more profiles.
-This may not always be the case, but it is at the time of this writing.
-<P>
-Useful enhancements to <EM>d.profile</EM> would include:
-<OL>
-<LI>Adding an option to display profiles using category
-colors, like a bar-chart.
-<LI>Allowing profile lines to be defined by a series of
-points, not just two.
-<LI>Allowing profiles to be saved in a file, for later
-viewing by GRASS.
-<LI>Allowing the user to enter profile line points by
-typing coordinates.
-</OL>
-<H3>Perl Script to convert output to a site_list</H3>
-The script below will convert the <B>plotfile</B> output to the site_list format.
-It probably won't work 100% for lat/lon datasets.
-<P>
-<TT>
-<B>#! /usr/bin/perl -w</B><BR>
-# prof2sites.pl: converts the output of d.profile to a site_list
-<P>
-<B>my</B> (<EM>$dist</EM>, <EM>$elev</EM>, <EM>$east</EM>, <EM>$north</EM>);
-<P>
-<B>while</B> (&lt;<B>STDIN</B>&gt;)<BR>
-{<BR>
-&nbsp;&nbsp;<B>if</B> (m/^#/)<BR>
-&nbsp;&nbsp;{<BR>
-&nbsp;&nbsp;&nbsp;&nbsp;<B>print</B> "<EM>$_</EM>";<BR>
-&nbsp;&nbsp;}<BR>
-&nbsp;&nbsp;<B>else</B><BR>
-&nbsp;&nbsp;{<BR>
-&nbsp;&nbsp;&nbsp;&nbsp;<B>chomp</B>;<BR>
-&nbsp;&nbsp;&nbsp;&nbsp;(<EM>$dist</EM>, <EM>$elev</EM>, <EM>$east</EM>, <EM>$north</EM>) = <B>split</B> / /;<BR>
-&nbsp;&nbsp;&nbsp;&nbsp;<B>print</B> "<EM>$east</EM>|<EM>$north</EM>|<EM>$elev</EM>|#1 \%<EM>$dist</EM> \@Profile\n";<BR>
-&nbsp;&nbsp;}<BR>
-}<BR>
-</TT>
 <H2>BUGS</H2>
 None known.
 <H2>AUTHOR</H2>
-Dave Johnson
-<BR> DBA Systems, Inc. <BR>
-10560 Arrowhead Drive <BR>
-Fairfax, Virginia 22030
+Glynn Clements
-<P>
-Modified by Eric G. Miller for profile output, support of
-floating point rasters, and optional display raster (02-Dec-2000).
+This program has been completely re-written for 7.0. It bears no
+relation to the interactive d.profile module in previous versions.
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/main.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -19,8 +19,6 @@
-#define DEBUG
-#define USE_OLD_CODE		/* Frame set-up still needs old code ATM. */
 #include <stdio.h>
 #include <stdlib.h>
 #include <math.h>
@@ -28,439 +26,287 @@
-struct windows windows[] = {
-    {"mou", 85, 100, 0, 50},
-    {"sta", 85, 100, 50, 100},
-    {"map", 0, 85, 0, 50},
-    {"orig", 0, 100, 0, 1009}
+static char *mapname;
+static double min, max;
-struct windows profiles[] = {
-    {"pro1", 64, 85, 50, 100},
-    {"pro2", 43, 64, 50, 100},
-    {"pro3", 22, 43, 50, 100},
-    {"pro4", 0, 22, 50, 100}
+struct point
+    double x, y;
+    double d;
-struct Profile profile;
-void myDcell(char *name, char *mapset, int overlay);
-int main(int argc, char **argv)
+static void get_region_range(int fd)
-    char *old_mapset, *old_mapname, *d_mapset, *d_mapname;
-    double cur_ux, cur_uy;
-    double ux, uy;
-    char ltr[10];
-    int text_width, text_height;
-    int err, doplot;
-    int button;
-    int cur_screen_x, cur_screen_y;
-    int screen_x, screen_y;
-    int t, b, l, r;
-    int i, CurrentWin = 0;
-    long min, max;
-    struct Option *map, *dmap, *plotfile;
-    struct GModule *module;
+    DCELL *buf = G_allocate_d_raster_buf();
+    int nrows = G_window_rows();
+    int ncols = G_window_cols();
+    int row, col;
-    /* Initialize the GIS calls */
-    G_gisinit(argv[0]);
+    min = 1e300;
+    max = -1e300;
-    /* Set description */
-    module = G_define_module();
-    module->keywords = _("display");
-    module->description =
-	_("Interactive profile plotting utility with optional output.");
+    for (row = 0; row < nrows; row++) {
+	G_get_d_raster_row(fd, buf, row);
+	for (col = 0; col < ncols; col++) {
+	    if (min > buf[col])
+		min = buf[col];
+	    if (max < buf[col])
+		max = buf[col];
-    /* set up command line */
-    map = G_define_option();
-    map->key = "rast";
-    map->type = TYPE_STRING;
-    map->required = YES;
-    map->gisprompt = "old,cell,raster";
-    map->description = _("Raster map to be profiled");
+static void get_map_range(void)
+    if (G_raster_map_type(mapname, "") == CELL_TYPE) {
+	struct Range range;
+	CELL xmin, xmax;
-    dmap = G_define_option();
-    dmap->key = "drast";
-    dmap->type = TYPE_STRING;
-    dmap->required = NO;
-    dmap->gisprompt = "old,cell,raster";
-    dmap->description = _("Optional display raster");
+	if (G_read_range(mapname, "", &range) <= 0)
+	    G_fatal_error(_("Unable to read range for %s"), mapname);
-    plotfile = G_define_option();
-    plotfile->key = "plotfile";
-    plotfile->type = TYPE_STRING;
-    plotfile->required = NO;
-    plotfile->description =
-	_("Output profile data to file(s) with prefix 'name'");
+	G_get_range_min_max(&range, &xmin, &xmax);
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
+	max = xmax;
+	min = xmin;
+    else {
+	struct FPRange fprange;
-    old_mapname = map->answer;
+	if (G_read_fp_range(mapname, "", &fprange) <= 0)
+	    G_fatal_error(_("Unable to read FP range for %s"), mapname);
-    old_mapset = G_find_cell2(old_mapname, "");
-    if (old_mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), old_mapname);
+	G_get_fp_range_min_max(&fprange, &min, &max);
-    if (plotfile->answer != NULL)
-	doplot = 1;
-    else
-	doplot = 0;
+static void plot_axes(void)
+    char str[64];
+    double scale;
+    double t, b, l, r;
-    /* If the user wants to display a different raster */
-    if (dmap->answer != NULL) {
-	d_mapname = dmap->answer;
-	d_mapset = G_find_cell2(d_mapname, "");
-	if (d_mapset == NULL) {
-	    G_warning(_("Display raster [%s] not found. Using profile raster."),
-		      d_mapname);
-	    d_mapname = old_mapname;
-	    d_mapset = old_mapset;
-    else {
+    D_use_color(D_translate_color("red"));
-    /* get cell-file range */
-    WindowRange(old_mapname, old_mapset, &min, &max);
+    D_move_abs(0, 1);
+    D_cont_abs(0, 0);
+    D_cont_abs(1, 0);
-    /* the following code should not be used to get fp range correctly.
-       if (!quick_range(old_mapname,old_mapset,&min,&max))
-       if (!slow_range(old_mapname,old_mapset,&min,&max))
-       G_fatal_error(_("Unable to read from cell-file"));
-       if (min > 0) min = 0;
-       if (max < 0) max = 0;
+    D_use_color(D_translate_color(DEFAULT_FG_COLOR));
-    G_message(_("\n\nUse mouse to choose action"));
+    /* set text size for y-axis labels */
+    scale = fabs(D_get_u_to_d_yconv());
+    R_text_size(scale * 0.04, scale * 0.05);
-    /* establish connection with graphics driver */
-    if (R_open_driver() != 0)
-	G_fatal_error(_("No graphics device selected"));
+    /* plot y-axis label (bottom) */
+    sprintf(str, "%.1f", min);
+    D_get_text_box(str, &t, &b, &l, &r);
+    D_move_abs(-0.02 - (r - l), 0 - (t - b) / 2);
+    R_text(str);
-    /* Make sure screen is clear */
-    D_remove_windows();
-    R_erase();
+    /* plot y-axis label (top) */
+    sprintf(str, "%.1f", max);
+    D_move_abs(-0.02 - (r - l), 1 - (t - b) / 2);
+    R_text(str);
-    /* Establish windows on screen */
-#ifdef USE_OLD_CODE
-    D_new_window_percent(MOU.name, MOU.bot, MOU.top, MOU.left, MOU.right);
-    D_new_window_percent(STA.name, STA.bot, STA.top, STA.left, STA.right);
-    D_new_window_percent(MAP.name, MAP.bot, MAP.top, MAP.left, MAP.right);
-    D_new_window_percent(ORIG.name, ORIG.bot, ORIG.top, ORIG.left,
-			 ORIG.right);
-    for (i = 0; i <= 3; i++)
-	D_new_window_percent(profiles[i].name, profiles[i].bot,
-			     profiles[i].top, profiles[i].left,
-			     profiles[i].right);
-#else
-    /* This operates different than above, expect real world coords ? */
-    D_new_window(MOU.name, MOU.top, MOU.bot, MOU.left, MOU.right);
-    D_new_window(STA.name, STA.top, STA.bot, STA.left, STA.right);
-    D_new_window(MAP.name, MAP.top, MAP.bot, MAP.left, MAP.right);
-    D_new_window(ORIG.name, ORIG.top, ORIG.bot, ORIG.left, ORIG.right);
-    for (i = 0; i < 4; i++)
-	D_new_window(profiles[i].name, profiles[i].top,
-		     profiles[i].bot, profiles[i].left, profiles[i].right);
-#endif
+static int get_cell(DCELL *result, int fd, double x, double y)
+    static DCELL *row1, *row2;
+    static int cur_row = -1;
+    static int row, col;
+    DCELL *tmp;
-    /* Plot cell-file in map window */
-    D_set_cur_wind(MAP.name);
-    myDcell(d_mapname, d_mapset, 1);
+    if (!row1) {
+	row1 = G_allocate_d_raster_buf();
+	row2 = G_allocate_d_raster_buf();
+    col = (int)floor(x - 0.5);
+    row = (int)floor(y - 0.5);
+    x -= col + 0.5;
+    y -= row + 0.5;
-    /* loop until user wants to quit */
-    for (;;) {
-	/* display mouse-menu in mouse-menu window */
-	D_set_cur_wind(MOU.name);
-	D_erase_window();
-	DrawText(25, 1, 1, "GRASS PROGRAM: profile");
-	DrawText(15, 3, 1, "MOUSE   | Left:   Where am I?");
-	DrawText(15, 4, 1, "BUTTON  | Middle: Set FIRST point");
-	DrawText(15, 5, 1, "MENU    | Right:  Quit this\n");
-	R_flush();
+    if (row < 0 || row + 1 >= G_window_rows() ||
+	col < 0 || col + 1 >= G_window_cols()) {
+	G_set_d_null_value(result, 1);
+	return 0;
-	/* LOOP to get first point of line */
-	do {
+    if (cur_row != row) {
+	if (cur_row == row + 1) {
+	    tmp = row1; row1 = row2; row2 = tmp;
+	    G_get_d_raster_row(fd, row1, row);
+	else if (cur_row == row - 1) {
+	    G_get_d_raster_row(fd, row2, row + 1);
+	else {
+	cur_row = row;
-	    /* choose map window and set up conversion factors */
-	    screen_y = (t + b) / 2;
-	    screen_x = (l + r) / 2;
-	    D_do_conversions(&window, t, b, l, r);
+    if (G_is_d_null_value(&row1[col]) || G_is_d_null_value(&row1[col+1]) ||
+	G_is_d_null_value(&row2[col]) || G_is_d_null_value(&row2[col+1])) {
+	return 0;
-	    /* get a point from the mouse */
-	    R_get_location_with_pointer(&screen_x, &screen_y, &button);
+    *result = G_interp_bilinear(x, y,
+				row1[col], row1[col+1],
+				row2[col], row2[col+1]);
-	    /* exit if user hit left mouse button */
-	    if (button == 3) {
-		D_set_cur_wind(ORIG.name);
-		G_message(_("Use 'd.frame -e' to remove left over frames"));
-		exit(EXIT_SUCCESS);
+    return 1;
-	    /* convert to (easting,northing) coordinates */
-	    cur_uy = D_d_to_u_row((double)screen_y);
-	    cur_ux = D_d_to_u_col((double)screen_x);
+int main(int argc, char **argv)
+    struct GModule *module;
+    struct Option *map, *profile;
+    struct Flag *stored;
+    struct Cell_head window;
+    struct point *points = NULL;
+    int num_points, max_points = 0;
+    double length;
+    int fd;
+    int i;
+    double sx;
+    int last;
-	    if (cur_ux > window.east || cur_ux < window.west ||
-		cur_uy > window.north || cur_uy < window.south) {
-		D_set_cur_wind(STA.name);
-		D_erase_window();
-		DrawText(25, 1, 1, "OUTSIDE CURRENT WINDOW");
-		R_flush();
-		button = 1;
-	    else {
-		/* print "earth" coords. and category info. in status window */
-		What(old_mapname, old_mapset, window, cur_ux, cur_uy);
+    /* Initialize the GIS calls */
+    G_gisinit(argv[0]);
-	} while (button != 2);
+    /* Set description */
+    module = G_define_module();
+    module->keywords = _("display");
+    module->description = _("Plots profile of a transect.");
-	D_erase_window();
-	DrawText(15, 4, 1, "BUTTON  | Middle: Set SECOND point");
-	R_flush();
+    /* set up command line */
+    map = G_define_standard_option(G_OPT_R_INPUT);
+    map->description = _("Raster map to be profiled");
-	/* move graphics position to first point chosen */
-	R_move_abs(screen_x, screen_y);
-	cur_screen_x = screen_x;
-	cur_screen_y = screen_y;
+    profile = G_define_option();
+    profile->key = "profile";
+    profile->type = TYPE_DOUBLE;
+    profile->required = YES;
+    profile->multiple = YES;
+    profile->key_desc = "east,north";
+    profile->description = _("Profile coordinate pairs");
-	/* LOOP to get second point of line */
-	do {
-	    G_get_window(&window);
+    stored = G_define_flag();
+    stored->key = 'r';
+    stored->description = _("Use map's range recorded range");
-	    R_get_location_with_line(cur_screen_x, cur_screen_y,
-				     &screen_x, &screen_y, &button);
-	    uy = D_d_to_u_row((double)screen_y);
-	    ux = D_d_to_u_col((double)screen_x);
-	    if (ux > window.east || ux < window.west ||
-		uy > window.north || uy < window.south) {
-		D_erase_window();
-		button = 1;
-	    else {
-		if (button == 1) {
-		    What(old_mapname, old_mapset, window, ux, uy);
-		else if (button == 2) {
-		    /* get profile data */
-		    InitProfile(&profile, window, cur_uy, cur_ux, uy, ux);
-		    if ((err =
-			 ExtractProfile(&profile, old_mapname,
-					old_mapset)) == -1) {
-			D_erase_window();
-			DrawText(25, 1, 1, "ERROR: end-point outside");
-			DrawText(25, 2, 1, "       of current window");
-		    else if (err == -2)
-			G_fatal_error(_("Error opening cell-file"));
-		    else if (err == -3)
-			G_fatal_error(_("Error reading from cell-file"));
-		    else if (err == -4)
-			G_fatal_error(_("Mysterious window inconsistancy error"));
-		    else {
-			/* draw profile line on cell-file */
-			black_and_white_line(screen_x, screen_y, cur_screen_x,
-					     cur_screen_y);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
-			/* select letter for current profile label */
-			switch (CurrentWin) {
-			case 0:
-			    ltr[0] = 'A';
-			    ltr[1] = 0;
-			    break;
-			case 1:
-			    ltr[0] = 'B';
-			    ltr[1] = 0;
-			    break;
-			case 2:
-			    ltr[0] = 'C';
-			    ltr[1] = 0;
-			    break;
-			case 3:
-			    ltr[0] = 'D';
-			    ltr[1] = 0;
-			    break;
-			default:
-			    ltr[0] = '?';
-			    ltr[1] = 0;
-			    break;
+    mapname = map->answer;
-			/* plot label in black */
-			text_height = (int)(0.03 * (b - t));
-			text_width = (int)(0.03 * (r - l));
-			if (screen_x <= cur_screen_x &&
-			    screen_y >= cur_screen_y)
-			    R_move_rel(-(text_width + 2), (text_height + 2));
-			else if (screen_x < cur_screen_x &&
-				 screen_y <= cur_screen_y)
-			    R_move_rel(-(text_width + 2), 2);
-			else if (screen_x > cur_screen_x)
-			    R_move_rel(3, 0);
-			R_text(ltr);
+    fd = G_open_cell_old(mapname, "");
+    if (fd < 0)
+	G_fatal_error(_("Unable to open raster map <%s>"), mapname);
-			/* plot label in white */
-			    R_move_rel(3, 0);
-			R_move_rel(1, 1);
-			R_text(ltr);
+    if (stored->answer)
+	get_map_range();
+    else
+	get_region_range(fd);
-			/*length = hypot(cur_ux - ux, cur_uy - uy); */
+    G_get_window(&window);
-			/* tell user about profile being plotted */
-			D_erase_window();
-			DrawText(25, 1, 1, "PLOTTING PROFILE");
+    num_points = 0;
+    length = 0;
+    for (i = 0; profile->answers[i]; i += 2) {
+	struct point *p;
+	double x, y;
-			/* plot profile data in profile window */
-			D_set_cur_wind(profiles[CurrentWin++].name);
-			/* dump profile if requested */
-			if (doplot)
-			    WriteProfile(old_mapname, old_mapset,
-					 plotfile->answer, ltr[0], &profile);
-			PlotProfile(profile, ltr, min, max);
-			if (CurrentWin > 3)
-			    CurrentWin = 0;
+	if (num_points >= max_points) {
+	    max_points = num_points + 100;
+	    points = G_realloc(points, max_points * sizeof(struct point));
-			cur_ux = ux;
-			cur_uy = uy;
-	    R_flush();
-	} while (button != 3 && button != 2);
+	p = &points[num_points];
-	D_erase_window();
-	DrawText(15, 3, 1, "MOUSE   | Left:   DO ANOTHER");
-	DrawText(15, 4, 1, "BUTTON  | Middle: CLEAR DISPLAY");
-	DrawText(15, 5, 1, "MENU    | Right:  QUIT");
-	R_flush();
+	G_scan_easting( profile->answers[i+0], &x, G_projection());
+	G_scan_northing(profile->answers[i+1], &y, G_projection());
+	p->x = G_easting_to_col (x, &window);
+	p->y = G_northing_to_row(y, &window);
+	if (num_points > 0) {
+	    const struct point *prev = &points[num_points-1];
+	    double dx = fabs(p->x - prev->x);
+	    double dy = fabs(p->y - prev->y);
+	    double d = sqrt(dx * dx + dy * dy);
+	    length += d;
+	    p->d = length;
-	    D_erase(DEFAULT_BG_COLOR);
-	    for (i = 0; i <= 3; i++) {
-		D_set_cur_wind(profiles[i].name);
-	    CurrentWin = 0;
-	else {
-	    G_free(profile.ptr);
+	num_points++;
+    points[0].d = 0;
+    if (num_points < 2)
+	G_fatal_error(_("At least two points are required"));
-    int fd, i, code;
-    CELL *cell;
-    struct Colors clr;
+    /* establish connection with graphics driver */
+    if (R_open_driver() != 0)
+	G_fatal_error(_("No graphics device selected"));
-    D_setup(!overlay);
-    D_set_overlay_mode(overlay);
+    D_setup2(1, 0, 1.05, -0.05, -0.15, 1.05);
-    cell = G_allocate_c_raster_buf();
+    plot_axes();
-    if ((fd = G_open_cell_old(name, mapset)) < 0)
-	G_fatal_error(_("%s: Couldn't open raster <%s@%s>"),
-		      G_program_name(), name, mapset);
-    if (G_read_colors(name, mapset, &clr) < 0)
-	G_fatal_error(_("%s: Couldn't read color table for <%s@%s>"),
+    D_get_src(&t, &b, &l, &r);
+    t -= 0.1 * (t - b);
+    b += 0.1 * (t - b);
+    l += 0.1 * (r - l);
+    r -= 0.1 * (r - l);
-    D_cell_draw_begin();
-    for (i = 0; i >= 0;) {
-	code = G_get_c_raster_row(fd, cell, i);
-	if (code < 0)
-	    break;
-	else if (code == 0) {
+    i = 0;
+    last = 0;
+    for (sx = 0; sx < 1; sx += D_get_d_to_u_xconv()) {
+	double d = length * (sx - l);
+	const struct point *p, *next;
+	double k, sy, x, y;
+	DCELL v;
+	for (;;) {
+	    p = &points[i];
+	    next = &points[i + 1];
+	    k = (d - p->d) / (next->d - p->d);
+	    if (k < 1)
+		break;
 	    i++;
+	x = p->x * (1 - k) + next->x * k;
+	y = p->y * (1 - k) + next->y * k;
+	if (!get_cell(&v, fd, x, y)) {
+	    last = 0;
 	    continue;
-	i = D_draw_cell(i, cell, &clr);
+	sy = (v - min) / (max - min);
+	if (last)
+	    D_cont_abs(sx, sy);
+	else
+	    D_move_abs(sx, sy);
+	last = 1;
-    D_cell_draw_end();
-    /* Only one cell, always set the name */
-    D_set_cell_name(G_fully_qualified_name(name, mapset));
+    R_close_driver();
-    G_close_cell(fd);
-    G_free(cell);
+    exit(EXIT_SUCCESS);
Deleted: grass/trunk/display/d.profile/profile.h
--- grass/trunk/display/d.profile/profile.h	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/profile.h	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,91 +0,0 @@
-#include <grass/config.h>
-typedef struct _ucat
-    RASTER_MAP_TYPE type;
-    union
-	CELL c;
-	FCELL f;
-	DCELL d;
-    } val;
-} UCAT;
-typedef union _raster_ptr
-    void *v;
-    CELL *c;
-    FCELL *f;
-    DCELL *d;
-} RASTER_PTR;
-typedef struct _raster_map_ptr
-    RASTER_PTR data;
-} RASTER_MAP_PTR;
-struct windows
-    char *name;
-    float bot, top, left, right;
-struct ProfileNode
-    double north, east, dist;
-    UCAT cat;
-    struct ProfileNode *next;
-struct Profile
-    double n1, e1, n2, e2;
-    long int count;
-    UCAT MinCat, MaxCat;
-extern struct windows windows[];
-extern struct windows profiles[];
-#define MOU     windows[0]
-#define STA     windows[1]
-#define MAP     windows[2]
-#define ORIG     windows[3]
-/* DrawText.c */
-int DrawText(int, int, int, char *);
-/* DumpProfile.c */
-int WriteProfile(char *, char *, char *, char, struct Profile *);
-/* ExtractProf.c */
-int ExtractProfile(struct Profile *, char *, char *);
-/* InitProfile.c */
-int InitProfile(struct Profile *, struct Cell_head, double, double, double,
-		double);
-/* PlotProfile.c */
-int PlotProfile(struct Profile, char *, int, int);
-/* Range.c */
-int WindowRange(char *, char *, long *, long *);
-int quick_range(char *, char *, long *, long *);
-int slow_range(char *, char *, long *, long *);
-/* What.c */
-int What(char *, char *, struct Cell_head, double, double);
-/* bnw_line.c */
-int black_and_white_line(int, int, int, int);
-/* show.c */
-int show_cat(int, char *, int, char *);
-int show_utm(double, double);
-int show_mouse(void);
-/* utils.c */
-int is_null_value(RASTER_MAP_PTR *, int);
Deleted: grass/trunk/display/d.profile/utils.c
--- grass/trunk/display/d.profile/utils.c	2008-08-26 15:43:43 UTC (rev 33094)
+++ grass/trunk/display/d.profile/utils.c	2008-08-26 17:25:48 UTC (rev 33095)
@@ -1,29 +0,0 @@
-int is_null_value(RASTER_MAP_PTR * ptr, int col)
-    if (ptr == NULL)
-	G_fatal_error(_("%s: 'is_null_value()' got NULL pointer!"),
-		      G_program_name());
-    if (col < 0)
-	G_fatal_error(_("%s: 'is_null_value()' got negative column index"),
-    switch (ptr->type) {
-    case CELL_TYPE:
-	return G_is_c_null_value(&ptr->data.c[col]);
-    case FCELL_TYPE:
-	return G_is_f_null_value(&ptr->data.f[col]);
-    case DCELL_TYPE:
-	return G_is_d_null_value(&ptr->data.d[col]);
-    default:
-	G_fatal_error(_("%s: 'is_null_value()' Unknown "
-			"RASTER_MAP_TYPE '%d'"), G_program_name(), ptr->type);
-    return 0;
