[GRASS-SVN] r33102 - grass/branches/develbranch_6/vector/v.extrude
Tue Aug 26 17:58:45 EDT 2008
Author: martinl
Date: 2008-08-26 17:58:44 -0400 (Tue, 26 Aug 2008)
New Revision: 33102
   grass/branches/develbranch_6/vector/v.extrude/main.c
v.extrude cosmetics; fix progress messages
Modified: grass/branches/develbranch_6/vector/v.extrude/main.c
--- grass/branches/develbranch_6/vector/v.extrude/main.c	2008-08-26 21:40:12 UTC (rev 33101)
+++ grass/branches/develbranch_6/vector/v.extrude/main.c	2008-08-26 21:58:44 UTC (rev 33102)
@@ -189,7 +189,7 @@
 	nelements = Vect_get_num_areas(&In);
 	G_debug(2, "n_areas = %d", nelements);
 	if (nelements > 0)
-	    G_verbose_message(_("Extruding areas..."));
+	    G_message(_("Extruding areas..."));
 	for (areanum = 1; areanum <= nelements; areanum++) {
 	    G_debug(3, "area = %d", areanum);
@@ -242,7 +242,7 @@
 		    fdrast, trace, objheight, voffset, window, GV_AREA,
 		    centroid);
-	    G_percent(areanum, nelements, 1);
+	    G_percent(areanum, nelements, 2);
 	}			/* foreach area */
@@ -253,7 +253,7 @@
 	i = 1;
 	/* loop through each line in the dataset */
 	nelements = Vect_get_num_lines(&In);
-	G_verbose_message(_("Extruding basic vector objects..."));
+	G_message(_("Extruding vector primitives..."));
 	for (line = 1; line <= nelements; line++) {
 	    /* read line */
@@ -321,13 +321,11 @@
 		    fdrast, trace, objheight, voffset, window, type, -1);
 	    /* progress feedback */
-	    G_percent(line, nelements, 1);
+	    G_percent(line, nelements, 2);
 	}			/* for each line */
     }				/* else if area */
-    G_percent(1, 1, 1);
     if (driver) {
 	db_close_database(driver);
 	db_shutdown_driver(driver);
