[GRASS-SVN] r33105 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Aug 26 21:10:09 EDT 2008
Author: glynn
Date: 2008-08-26 21:10:09 -0400 (Tue, 26 Aug 2008)
New Revision: 33105
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/render.py
Remove references to d.mon
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-08-27 01:07:05 UTC (rev 33104)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-08-27 01:10:09 UTC (rev 33105)
@@ -3865,9 +3865,6 @@
grassenv.GetGRASSVariable("LOCATION_NAME"))
gm_map.MainLoop()
- if grassenv.env.has_key("MONITOR"):
- os.system("d.mon sel=%s" % grassenv.GetGRASSVariable("MONITOR"))
os.remove(cmdfilename)
os.system("""g.gisenv set="GRASS_PYCMDFILE" """)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-27 01:07:05 UTC (rev 33104)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-27 01:10:09 UTC (rev 33105)
@@ -132,14 +132,8 @@
# start monitor
- if UserSettings.Get(group='display', key='driver', subkey='type') == 'cairo':
- os.environ["GRASS_CAIROFILE"] = self.mapfile
- if 'cairo' not in gcmd.Command(['d.mon', '-p']).ReadStdOutput()[0]:
- gcmd.Command(['d.mon',
- 'start=cairo'], stderr=None)
- else:
- if self.mapfile:
- os.environ["GRASS_PNGFILE"] = self.mapfile
+ if self.mapfile:
+ os.environ["GRASS_PNGFILE"] = self.mapfile
# execute command
@@ -174,12 +168,7 @@
# stop monitor
- 'stop=cairo'], stderr=None)
- os.unsetenv("GRASS_CAIROFILE")
- else:
- os.unsetenv("GRASS_PNGFILE")
+ os.unsetenv("GRASS_PNGFILE")
self.force_render = False
@@ -857,14 +846,10 @@
os.environ["GRASS_REGION"] = self.SetRegion(windres)
os.environ["GRASS_WIDTH"] = str(self.width)
os.environ["GRASS_HEIGHT"] = str(self.height)
- os.environ["GRASS_AUTO_WRITE"] = "TRUE"
- os.unsetenv("GRASS_RENDER_IMMEDIATE")
- else:
- os.environ["GRASS_PNG_AUTO_WRITE"] = "TRUE"
- os.environ["GRASS_COMPRESSION"] = "0"
- os.environ["GRASS_TRUECOLOR"] = "TRUE"
- os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
+ os.environ["GRASS_PNG_AUTO_WRITE"] = "TRUE"
+ os.environ["GRASS_COMPRESSION"] = "0"
+ os.environ["GRASS_TRUECOLOR"] = "TRUE"
+ os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
self._renderLayers(force, mapWindow, maps, masks, opacities)
