[GRASS-SVN] r33148 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Aug 29 03:10:14 EDT 2008
Author: martinl
Date: 2008-08-29 03:10:14 -0400 (Fri, 29 Aug 2008)
New Revision: 33148
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: fix trac #268 - the "command layer" in wxGUI does not work
(merge from devbr6, r33147)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-29 07:06:44 UTC (rev 33147)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-08-29 07:10:14 UTC (rev 33148)
@@ -75,8 +75,6 @@
self.active = active
self.hidden = hidden
self.opacity = opacity
- self._region = None # produced by `d.vect -r`
self.force_render = True
@@ -103,19 +101,16 @@
@return rendered image filename
@return None on error
- self._region = None # reset region
if len(self.cmdlist) == 0:
return None
# ignore in 2D
if self.type == '3d-raster':
return None
Debug.msg (3, "Layer.Render(): type=%s, name=%s" % \
(self.type, self.name))
# prepare command for each layer
@@ -124,7 +119,7 @@
'grid', 'geodesic', 'rhumb', 'labels',
'command',
'overlay']
if self.type not in layertypes:
raise gcmd.GStdError(_("<%(name)s>: layer type <%(type)s> is not supported yet.") % \
{'type' : self.type, 'name' : self.name})
@@ -141,7 +136,7 @@
try:
runcmd = gcmd.Command(cmd=self.cmdlist + ['--q'],
stderr=None)
if runcmd.returncode != 0:
#clean up after probley
try:
@@ -152,7 +147,7 @@
pass
self.mapfile = None
self.maskfile = None
except gcmd.CmdError, e:
print >> sys.stderr, e
# clean up after problems
@@ -164,16 +159,16 @@
pass
self.mapfile = None
# stop monitor
os.unsetenv("GRASS_PNGFILE")
self.force_render = False
return self.mapfile
def GetCmd(self, string=False):
Get GRASS command as list of string.
@@ -263,11 +258,7 @@
# for re-rendering
- def GetRegion(self):
- """Get layer region or None"""
- return self._region
class MapLayer(Layer):
"""Represents map layer in the map canvas"""
def __init__(self, type, cmd, name=None,
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-29 07:06:44 UTC (rev 33147)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-08-29 07:10:14 UTC (rev 33148)
@@ -949,8 +949,7 @@
"""Change command string"""
ctrl = event.GetEventObject().GetId()
cmd = event.GetString()
- layer = None
layer = self.GetFirstVisibleItem()
while layer and layer.IsOk():
@@ -960,15 +959,8 @@
layer = self.GetNextVisible(layer)
# change parameters for item in layers list in render.Map
- if layer == False:
- self.ChangeLayer(layer)
- self.GetPyData(layer)[0]['cmd'] = cmd.split(' ')
- maplayer = self.GetPyData(layer)[0]['maplayer']
- for option in maplayer.GetCmd():
- if 'map=' in option:
- mapname = option.split('=')[1]
- self.Map.ChangeLayerName(maplayer, mapname)
+ self.ChangeLayer(layer)
event.Skip()
def OnChangeSel(self, event):
