[GRASS-SVN] r33150 - in grass/trunk/gui/wxpython: . gui_modules
vdigit
svn_grass at osgeo.org
Fri Aug 29 04:05:52 EDT 2008
Author: martinl
Date: 2008-08-29 04:05:52 -0400 (Fri, 29 Aug 2008)
New Revision: 33150
Added:
grass/trunk/gui/wxpython/vdigit/message.cpp
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/gui_modules/utils.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/digit.cpp
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/driver.h
grass/trunk/gui/wxpython/vdigit/line.cpp
grass/trunk/gui/wxpython/vdigit/select.cpp
grass/trunk/gui/wxpython/vdigit/undo.cpp
grass/trunk/gui/wxpython/vdigit/vertex.cpp
grass/trunk/gui/wxpython/wxgui.py
wxGUI: better error message handling in vdigit
initial support for copy categories/attributes in vdigit
some wxGUI fixes
(merge from devbr6, r33149)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-08-29 08:05:52 UTC (rev 33150)
@@ -443,6 +443,9 @@
def GetError(self):
"""Get error message or ''"""
+ if not self.cmdThread.module:
+ return _("Unable to exectute command: '%s'") % ' '.join(self.cmd)
for type, msg in self.__ProcessStdErr():
if type == 'ERROR':
return msg
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-08-29 08:05:52 UTC (rev 33150)
@@ -1119,7 +1119,8 @@
else:
point = False
- digitClass.AddPoint(map, point, east, north)
+ if digitClass.AddPoint(map, point, east, north) < 0:
+ return
self.UpdateMap(render=False) # redraw map
@@ -1741,8 +1742,9 @@
if len(self.polycoords) < 2: # ignore 'one-point' lines
return
- digitClass.AddLine(map, line, self.polycoords)
+ if digitClass.AddLine(map, line, self.polycoords) < 0:
+ return
position = self.Cell2Pixel(self.polycoords[-1])
self.polycoords = []
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-08-29 08:05:52 UTC (rev 33150)
@@ -436,11 +436,7 @@
# toogle to pointer by default
self.OnTool(None)
- if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vdigit':
- self.toolbar[0].EnableTool(self.copyCats, False) # not implemented (TODO)
- self.toolbar[0].SetToolShortHelp(self.copyCats, _("Not implemented yet"))
def ToolbarData(self, row=None):
Toolbar data
@@ -502,7 +498,7 @@
self.OnDisplayCats),
(self.copyCats, "digCopyCats", Icons["digCopyCats"].GetBitmap(),
wx.ITEM_CHECK, Icons["digCopyCats"].GetLabel(), Icons["digCopyCats"].GetDesc(),
- self.OnCopyCats),
+ self.OnCopyCA),
(self.displayAttr, "digDispAttr", Icons["digDispAttr"].GetBitmap(),
wx.ITEM_CHECK, Icons["digDispAttr"].GetLabel(), Icons["digDispAttr"].GetDesc(),
self.OnDisplayAttr),
@@ -671,13 +667,60 @@
'id' : self.displayAttr }
self.parent.MapWindow.mouse['box'] = 'point'
+ def OnCopyCA(self, event):
+ """Copy categories/attributes menu"""
+ point = wx.GetMousePosition()
+ toolMenu = wx.Menu()
+ # Add items to the menu
+ cats = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Copy categories'),
+ kind=wx.ITEM_CHECK)
+ toolMenu.AppendItem(cats)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyCats, cats)
+ if self.action['desc'] == "copyCats":
+ cats.Check(True)
+ attrb = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+ text=_('Duplicate attributes'),
+ toolMenu.AppendItem(attrb)
+ self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyAttrb, attrb)
+ if self.action['desc'] == "copyAttrs":
+ attrb.Check(True)
+ # Popup the menu. If an item is selected then its handler
+ # will be called before PopupMenu returns.
+ self.parent.MapWindow.PopupMenu(toolMenu)
+ toolMenu.Destroy()
+ if self.action['desc'] == "addPoint":
+ self.toolbar[0].ToggleTool(self.copyCats, False)
def OnCopyCats(self, event):
"""Copy categories"""
+ if self.action['desc'] == 'copyCats': # select previous action
+ self.toolbar[0].ToggleTool(self.addPoint, True)
+ self.OnAddPoint(event)
+ return
Debug.msg(2, "Digittoolbar.OnCopyCats():")
self.action = { 'desc' : "copyCats",
'id' : self.copyCats }
+ def OnCopyAttrb(self, event):
+ if self.action['desc'] == 'copyAttrs': # select previous action
+ return
+ Debug.msg(2, "Digittoolbar.OnCopyAttrb():")
+ self.action = { 'desc' : "copyAttrs",
+ 'id' : self.copyCats }
+ self.parent.MapWindow.mouse['box'] = 'point'
def OnUndo(self, event):
"""Undo previous changes"""
self.parent.digit.Undo()
@@ -795,12 +838,13 @@
toolMenu.Destroy()
if self.action['desc'] == 'addPoint':
- self.toolbar[0].ToggleTool(self.additionalTools, True)
+ self.toolbar[0].ToggleTool(self.additionalTools, False)
def OnCopy(self, event):
"""Copy selected features from (background) vector map"""
if self.action['desc'] == 'copyLine': # select previous action
return
@@ -813,6 +857,7 @@
"""Flip selected lines/boundaries"""
if self.action['desc'] == 'flipLine': # select previous action
return
@@ -825,6 +870,7 @@
"""Merge selected lines/boundaries"""
if self.action['desc'] == 'mergeLine': # select previous action
return
@@ -837,6 +883,7 @@
"""Break selected lines/boundaries"""
if self.action['desc'] == 'breakLine': # select previous action
return
@@ -849,6 +896,7 @@
"""Snap selected features"""
if self.action['desc'] == 'snapLine': # select previous action
return
@@ -861,6 +909,7 @@
"""Connect selected lines/boundaries"""
if self.action['desc'] == 'connectLine': # select previous action
return
@@ -873,6 +922,7 @@
"""Query selected lines/boundaries"""
if self.action['desc'] == 'queryLine': # select previous action
return
@@ -886,6 +936,7 @@
"""Z bulk-labeling selected lines/boundaries"""
if self.action['desc'] == 'zbulkLine': # select previous action
return
@@ -903,6 +954,7 @@
if self.action['desc'] == 'typeConv': # select previous action
return
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2008-08-29 08:05:52 UTC (rev 33150)
@@ -98,7 +98,11 @@
break
if idx < len(dcmd):
- mapname = dcmd[idx].split('=')[1]
+ try:
+ mapname = dcmd[idx].split('=')[1]
+ except IndexError:
+ return ''
if fullyQualified and '@' not in mapname:
if layerType in ('raster', 'vector', '3d-raster'):
try:
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-08-29 08:05:52 UTC (rev 33150)
@@ -37,6 +37,8 @@
import string
import copy
+from threading import Thread
import wx
import wx.lib.colourselect as csel
import wx.lib.mixins.listctrl as listmix
@@ -686,6 +688,7 @@
return False
# collect cats
+ # FIXME: currently layer is ignored...
gcmd.Command(['v.edit',
'--q',
'map=%s' % self.map,
@@ -789,7 +792,8 @@
AbstractDigit.__init__(self, mapwindow)
try:
- self.digit = wxvdigit.Digit(self.driver.GetDevice())
+ self.digit = wxvdigit.Digit(self.driver.GetDevice(),
+ mapwindow)
except (ImportError, NameError):
self.digit = None
@@ -823,15 +827,15 @@
if z:
ret = self.digit.AddLine(type, [x, y, z], layer, cat,
- str(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value')), snap, thresh)
+ str(UserSettings.Get(group='vdigit', key="backgroundMap",
+ subkey='value')), snap, thresh)
else:
ret = self.digit.AddLine(type, [x, y], layer, cat,
+ self.toolbar.EnableUndo()
- if ret == -1:
- raise gcmd.DigitError, _("Adding new feature to vector map <%s> failed.") % map
- self.toolbar.EnableUndo()
+ return ret
def AddLine (self, map, line, coords):
"""Add line/boundary
@@ -864,12 +868,11 @@
ret = self.digit.AddLine(type, listCoords, layer, cat,
- if ret == -1:
+ return ret
def DeleteSelectedLines(self):
"""Delete selected features
@@ -1090,19 +1093,19 @@
return ret
- def CopyCats(self, cats, ids):
+ def CopyCats(self, fromId, toId):
"""Copy given categories to objects with id listed in ids
- @param cats list of cats to be copied
- @param ids ids of lines to be modified
+ @param cats ids of 'from' feature
+ @param ids ids of 'to' feature(s)
@return number of modified features
@return -1 on error
- if len(cats) == 0 or len(ids) == 0:
+ if len(fromId) == 0 or len(toId) == 0:
return 0
- ret = self.digit.CopyCats(cats, ids)
+ ret = self.digit.CopyCats(fromId, toId)
if ret > 0:
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-08-29 08:05:52 UTC (rev 33150)
@@ -35,6 +35,7 @@
if (!display->mapInfo) {
+ DisplayMsg();
return -1;
@@ -158,10 +159,12 @@
struct field_info *fi;
+ DisplayMsg();
return lc;
if (line_id == -1 && display->selected.values->n_values < 1) {
+ GetLineCatsMsg(line_id);
return lc;
@@ -171,6 +174,7 @@
if (!Vect_line_alive(display->mapInfo, line)) {
+ DeadLineMsg(line);
return lc;
@@ -178,6 +182,7 @@
if (Vect_read_line(display->mapInfo, NULL, Cats, line) < 0) {
Vect_destroy_cats_struct(Cats);
+ ReadLineMsg(line);
return lc;
@@ -186,6 +191,7 @@
for (int dblink = 0; dblink < n_dblinks; dblink++) {
fi = Vect_get_dblink(display->mapInfo, dblink);
if (fi == NULL) {
+ DblinkMsg(dblink+1);
continue;
std::vector<int> cats;
@@ -219,10 +225,12 @@
struct line_cats *Cats;
+ DisplayMsg();
return -1;
return -1;
@@ -232,6 +240,7 @@
return -1;
@@ -241,6 +250,7 @@
if (type < 0) {
Vect_destroy_line_struct(Points);
return -1;
@@ -284,15 +294,68 @@
\brief Copy categories from one vector feature to other
- \param cats list of layer/category to be copied
- \param ids list of line ids where to copy categories
+ \param fromId list of 'from' feature ids
+ \param toId list of 'to' feature ids
\return number of modified features
\return -1 on error
-int Digit::CopyCats(std::vector<std::vector<int> > cats, std::vector<int> ids)
+int Digit::CopyCats(std::vector<int> fromId, std::vector<int> toId)
- /* TODO */
+ int fline, tline, nlines, type;
+ bool error;
+ struct line_pnts *Points;
+ struct line_cats *Cats_from, *Cats_to;
- return 0;
+ Points = Vect_new_line_struct();
+ Cats_from = Vect_new_cats_struct();
+ Cats_to = Vect_new_cats_struct();
+ nlines = 0;
+ error = false;
+ for (std::vector<int>::const_iterator fi = fromId.begin(), fe = fromId.end();
+ fi != fe && !error; ++fi) {
+ fline = *fi;
+ if (!Vect_line_alive(display->mapInfo, fline))
+ continue;
+ type = Vect_read_line(display->mapInfo, NULL, Cats_from, fline);
+ if (type < 0) {
+ nlines = -1;
+ error = true;
+ for(std::vector<int>::const_iterator ti = toId.begin(), te = toId.end();
+ ti != te && !error; ++ti) {
+ tline = *ti;
+ if (!Vect_line_alive(display->mapInfo, tline))
+ continue;
+ type = Vect_read_line(display->mapInfo, Points, Cats_to, tline);
+ if (type < 0) {
+ nlines = -1;
+ error = true;
+ for (int i = 0; Cats_from->n_cats; i++) {
+ if (Vect_cat_set(Cats_to, Cats_from->field[i], Cats_from->field[i]) < 1) {
+ nlines = -1;
+ error = true;
+ if (Vect_rewrite_line(display->mapInfo, tline, type, Points, Cats_to) < 0) {
+ nlines = -1;
+ error = true;
+ nlines++;
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats_from);
+ Vect_destroy_cats_struct(Cats_to);
+ return nlines;
Modified: grass/trunk/gui/wxpython/vdigit/digit.cpp
--- grass/trunk/gui/wxpython/vdigit/digit.cpp 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/digit.cpp 2008-08-29 08:05:52 UTC (rev 33150)
@@ -21,10 +21,12 @@
\brief Initialize digit interface used by SWIG
\param driver display driver instance
+ \param window parent window for message dialog
-Digit::Digit(DisplayDriver *ddriver)
+Digit::Digit(DisplayDriver *ddriver, void *window)
display = ddriver;
+ parentWin = (wxWindow *) window;
if (display->mapInfo) {
InitCats();
@@ -33,6 +35,8 @@
changesetCurrent = -2; // initial value for undo/redo
changesetDead = -1;
+ msgCaption = _("Digitization error");
// avoid GUI crash
// Vect_set_fatal_error(GV_FATAL_PRINT);
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-08-29 08:05:52 UTC (rev 33150)
@@ -13,7 +13,8 @@
std::map<int, int> cats;
DisplayDriver *display;
+ wxWindow *parentWin;
int SetCategory(int, int);
struct Map_info** OpenBackgroundVectorMap(const char *);
@@ -42,8 +43,22 @@
void FreeChangeset(int);
int RemoveActionFromChangeset(int, action_type, int);
+ /* message dialogs */
+ wxString msgCaption;
+ void DisplayMsg(void);
+ void Only2DMsg(void);
+ void ReadLineMsg(int);
+ void DeadLineMsg(int);
+ void WriteLineMsg(void);
+ void BackgroundMapMsg(const char *);
+ void DblinkMsg(int);
+ void DbDriverMsg(const char *);
+ void DbDatabaseMsg(const char *, const char *);
+ void DbExecuteMsg(const char *);
+ void GetLineCatsMsg(int);
public:
- Digit(DisplayDriver *);
+ Digit(DisplayDriver *, void *);
~Digit();
int InitCats();
@@ -79,7 +94,7 @@
double, double, double, bool,
int, int, double);
- int CopyCats(std::vector<std::vector<int> >, std::vector<int>);
+ int CopyCats(std::vector<int>, std::vector<int>);
int GetCategory(int);
std::map<int, std::vector<int> > GetLineCats(int);
int SetLineCats(int, int, std::vector<int>, bool);
@@ -92,4 +107,3 @@
#endif /* WXVDIGIT_DIGIT_H */
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/driver.h 2008-08-29 08:05:52 UTC (rev 33150)
@@ -20,6 +20,7 @@
#include <wx/dc.h>
#include <wx/list.h>
+#include <wx/string.h>
#include <Python.h>
#include <wx/wxPython/pseudodc.h>
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-08-29 08:05:52 UTC (rev 33150)
@@ -50,11 +50,17 @@
int nbgmaps; /* number of registrated background maps */
+ DisplayMsg();
return -1;
npoints = coords.size() / (Vect_is_3d(display->mapInfo) ? 3 : 2);
if (coords.size() != npoints * (Vect_is_3d(display->mapInfo) ? 3 : 2)) {
+ wxString msg;
+ msg.Printf(_("Incorrent number of points (%d)"), coords.size());
+ wxMessageDialog dlg(parentWin, msg,
+ msgCaption, wxOK | wxICON_ERROR | wxCENTRE);
+ dlg.ShowModal();
return -1;
@@ -63,6 +69,7 @@
/* TODO: 3D */
if (!(type & (GV_POINTS | GV_LINES))) {
+ Only2DMsg();
return -1;
@@ -71,6 +78,7 @@
if (bgmap && strlen(bgmap) > 0) {
BgMap = OpenBackgroundVectorMap(bgmap);
if (!BgMap) {
+ BackgroundMapMsg(bgmap);
return -1;
else {
@@ -121,6 +129,7 @@
newline = Vect_write_line(display->mapInfo, type, Points, Cats);
if (newline < 0) {
+ WriteLineMsg();
return -1;
@@ -204,11 +213,13 @@
+ DisplayMsg();
return -1;
/* line alive ? */
+ WriteLineMsg();
return -1;
@@ -217,6 +228,7 @@
if (!BgMap) {
return -1;
else {
@@ -301,6 +313,7 @@
struct ilist *list;
+ DisplayMsg();
return -1;
point = Vect_new_line_struct();
@@ -344,22 +357,21 @@
// struct ilist *List;
+ DisplayMsg();
return -1;
n_dblinks = Vect_get_num_dblinks(display->mapInfo);
Cats_del = NULL;
- // List = NULL;
/* collect categories if needed */
if (delete_records) {
Cats = Vect_new_cats_struct();
- // List = Vect_new_list();
Cats_del = Vect_new_cats_struct();
for (int i = 0; i < display->selected.values->n_values; i++) {
if (Vect_read_line(display->mapInfo, NULL, Cats, display->selected.values->value[i]) < 0) {
Vect_destroy_cats_struct(Cats_del);
- //Vect_destroy_list(List);
+ ReadLineMsg(display->selected.values->value[i]);
return -1;
for (int j = 0; j < Cats->n_cats; j++) {
@@ -403,17 +415,20 @@
if (fi == NULL) {
return -1;
driver = db_start_driver(fi->driver);
if (driver == NULL) {
+ DbDriverMsg(fi->driver);
return -1;
db_init_handle (&handle);
db_set_handle (&handle, fi->database, NULL);
if (db_open_database(driver, &handle) != DB_OK) {
+ DbDatabaseMsg(fi->driver, fi->database);
return -1;
@@ -437,6 +452,7 @@
if (n_cats &&
db_execute_immediate (driver, &stmt) != DB_OK ) {
+ DbExecuteMsg(db_get_string(&stmt));
return -1;
@@ -451,12 +467,7 @@
if (Cats_del) {
- if(List) {
- Vect_destroy_list(List);
return ret;
@@ -481,6 +492,7 @@
+ DisplayMsg();
return -1;
BgMap = NULL;
@@ -488,6 +500,7 @@
if (!BgMap) {
return -1;
else {
@@ -535,6 +548,7 @@
long int nlines;
+ DisplayMsg();
return -1;
@@ -570,6 +584,7 @@
int ret, changeset, line;
+ DisplayMsg();
return -1;
@@ -616,6 +631,7 @@
+ DisplayMsg();
return -1;
@@ -663,6 +679,7 @@
int Digit::SnapLines(double thresh)
+ DisplayMsg();
return -1;
@@ -684,6 +701,7 @@
long int nlines_diff;
+ DisplayMsg();
return -1;
@@ -731,6 +749,7 @@
int ret;
+ DisplayMsg();
return -1;
@@ -760,6 +779,7 @@
list = NULL;
+ DisplayMsg();
return -1;
@@ -873,6 +893,7 @@
int changeset, nlines_diff;
+ DisplayMsg();
return -1;
Copied: grass/trunk/gui/wxpython/vdigit/message.cpp (from rev 33149, grass/branches/develbranch_6/gui/wxpython/vdigit/message.cpp)
--- grass/trunk/gui/wxpython/vdigit/message.cpp (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/message.cpp 2008-08-29 08:05:52 UTC (rev 33150)
@@ -0,0 +1,186 @@
+ \file message.cpp
+ \brief Error message dialogs
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ (C) 2008 by The GRASS development team
+ \author Martin Landa <landa.martin gmail.com>
+ \date 2008
+#include "driver.h"
+#include "digit.h"
+ \brief Error message - no display driver available
+void Digit::DisplayMsg(void)
+ wxMessageDialog dlg(parentWin, _("Display driver not available."),
+ dlg.ShowModal();
+ return;
+ \brief Error message - cannot edit 3d features
+void Digit::Only2DMsg(void)
+ wxMessageDialog dlg(parentWin, _("3D vector features are not currently supported."),
+ dlg.ShowModal();
+ return;
+ \brief Error message - unable to write line
+void Digit::WriteLineMsg(void)
+ wxMessageDialog dlg(parentWin, _("Unable to write new line"),
+ dlg.ShowModal();
+ return;
+ \brief Error message - unable to read line
+ \param line line id
+void Digit::ReadLineMsg(int line)
+ wxString msg;
+ msg.Printf(_("Unable to read line %d"), line);
+ dlg.ShowModal();
+ return;
+ \brief Error message - trying to read dead line
+void Digit::DeadLineMsg(int line)
+ wxString msg;
+ msg.Printf(_("Unable to read line %d, line is dead"), line);
+ dlg.ShowModal();
+ return;
+ \brief Error message - unable to open background map
+ \param bgmap map name
+void Digit::BackgroundMapMsg(const char *bgmap)
+ wxString msg;
+ msg.Printf(_("Unable to open background vector map <%s>. "
+ "Please check digitizer settings."),
+ wxString (bgmap, wxConvUTF8).c_str());
+ dlg.ShowModal();
+ return;
+ \brief Error message - dblink not defined
+ \param layer layer id
+void Digit::DblinkMsg(int layer)
+ wxString msg;
+ msg.Printf(_("Database connection not defined for layer %d"), layer);
+ dlg.ShowModal();
+ return;
+ \brief Error message - unable to start driver
+ \param driver driver name
+void Digit::DbDriverMsg(const char *driver)
+ wxString msg;
+ msg.Printf(_("Unable to start driver <%s>"), driver);
+ dlg.ShowModal();
+ return;
+ \brief Error message - unable to open database
+ \param database database name
+void Digit::DbDatabaseMsg(const char *driver, const char *database)
+ wxString msg;
+ msg.Printf(_("Unable to open database <%s> by driver <%s>"),
+ database, driver);
+ dlg.ShowModal();
+ return;
+ \brief Error message - unable to execute SQL command
+ \param sql sql command
+void Digit::DbExecuteMsg(const char *sql)
+ wxString msg;
+ msg.Printf(_("Unable to execute: '%s'"), sql);
+ dlg.ShowModal();
+ return;
+ wxString msg;
+ \brief Error message - unable to get line categories
+void Digit::GetLineCatsMsg(int line)
+ msg.Printf(_("Unable to get feature categories"), line);
+ dlg.ShowModal();
+ return;
Modified: grass/trunk/gui/wxpython/vdigit/select.cpp
--- grass/trunk/gui/wxpython/vdigit/select.cpp 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/select.cpp 2008-08-29 08:05:52 UTC (rev 33150)
@@ -49,6 +49,7 @@
struct line_pnts *bbox;
+ DisplayDriver();
return ids;
Modified: grass/trunk/gui/wxpython/vdigit/undo.cpp
--- grass/trunk/gui/wxpython/vdigit/undo.cpp 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/undo.cpp 2008-08-29 08:05:52 UTC (rev 33150)
@@ -163,6 +163,7 @@
+ DisplayMsg();
return -1;
@@ -171,6 +172,7 @@
/* do copy */
return -1;
ltype = Vect_read_line(display->mapInfo, Points, Cats, line);
Modified: grass/trunk/gui/wxpython/vdigit/vertex.cpp
--- grass/trunk/gui/wxpython/vdigit/vertex.cpp 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/vdigit/vertex.cpp 2008-08-29 08:05:52 UTC (rev 33150)
@@ -44,8 +44,10 @@
struct Map_info **BgMap; /* backgroud vector maps */
- if (!display->mapInfo)
+ if (!display->mapInfo) {
+ DisplayMsg();
return -1;
if (display->selected.values->n_values != 1)
return 0;
@@ -55,6 +57,7 @@
if (!BgMap) {
return -1;
else {
@@ -111,8 +114,10 @@
int ret;
struct line_pnts *point;
+ DisplayMsg();
return -1;
return 0;
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-08-29 08:02:58 UTC (rev 33149)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-08-29 08:05:52 UTC (rev 33150)
@@ -962,8 +962,8 @@
Init histogram display canvas and tools
self.histogram = histogram.HistFrame(self,
- id=wx.ID_ANY, pos=wx.DefaultPosition, size=(400,300),
- style=wx.DEFAULT_FRAME_STYLE)
+ id=wx.ID_ANY, pos=wx.DefaultPosition, size=(400,300),
+ style=wx.DEFAULT_FRAME_STYLE)
#show new display
self.histogram.Show()
