[GRASS-SVN] r34654 - in grass/trunk: db/drivers/sqlite display/d.thematic.area display/d.vect display/d.vect.chart lib/rst/interp_float lib/sites raster/r.random vector/lidar/v.surf.bspline vector/v.convert vector/v.in.dwg vector/v.in.ogr vector/v.info vector/v.net.path vector/v.surf.rst vector/v.to.points
Mon Dec 1 11:45:58 EST 2008
Author: martinl
Date: 2008-12-01 11:45:58 -0500 (Mon, 01 Dec 2008)
New Revision: 34654
   grass/trunk/db/drivers/sqlite/db.c
   grass/trunk/display/d.thematic.area/plot1.c
   grass/trunk/display/d.vect.chart/plot.c
   grass/trunk/display/d.vect/area.c
   grass/trunk/display/d.vect/attr.c
   grass/trunk/display/d.vect/plot1.c
   grass/trunk/lib/rst/interp_float/vinput2d.c
   grass/trunk/lib/sites/sites.c
   grass/trunk/raster/r.random/random.c
   grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
   grass/trunk/vector/v.convert/att.c
   grass/trunk/vector/v.in.dwg/main.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.info/main.c
   grass/trunk/vector/v.net.path/path.c
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.to.points/main.c
message standardization, i18n
	(merge from devbr6, r34653)
Modified: grass/trunk/db/drivers/sqlite/db.c
--- grass/trunk/db/drivers/sqlite/db.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/db/drivers/sqlite/db.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -1,8 +1,7 @@
  * \file db.c
- * \brief Low Level SQLite databse driver.
+ * \brief DBMI - Low Level SQLite database driver.
  * This program is free software under the GNU General Public License
  * (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -16,19 +15,19 @@
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/dbmi.h>
+#include <grass/glocale.h>
 #include "globals.h"
 #include "proto.h"
- * \fn int db__driver_open_database (dbHandle *handle)
  * \brief Open SQLite database.
  * \param[in,out] handle database handle
- * \return int DB_FAILED on error; DB_OK on success
+ * \return DB_FAILED on error
+ * \return DB_OK on success
 int db__driver_open_database(dbHandle * handle)
     char name2[2000];
@@ -82,7 +81,7 @@
     G_debug(2, "name2 = '%s'", name2);
     if (sqlite3_open(name2, &sqlite) != SQLITE_OK) {
-	append_error("Cannot open database: ");
+	append_error(_("Unable to open database: "));
 	append_error((char *)sqlite3_errmsg(sqlite));
 	report_error();
 	return DB_FAILED;
@@ -93,11 +92,9 @@
- * \fn int db__driver_close_database (void)
  * \brief Close SQLite database.
- * \return int always returns DB_OK
+ * \return always returns DB_OK
 int db__driver_close_database(void)
Modified: grass/trunk/display/d.thematic.area/plot1.c
--- grass/trunk/display/d.thematic.area/plot1.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/display/d.thematic.area/plot1.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -102,12 +102,13 @@
     if (open_db) {
 	fi = Vect_get_field(Map, (Clist->field > 0 ? Clist->field : 1));
 	if (fi == NULL) {
-	    G_fatal_error(_("Cannot read field info"));
+	    G_fatal_error(_("Database connection not defined for layer %d"),
+			  (Clist->field > 0 ? Clist->field : 1));
 	driver = db_start_driver_open_database(fi->driver, fi->database);
 	if (driver == NULL)
-	    G_fatal_error(_("Cannot open database %s by driver %s"),
+	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			  fi->database, fi->driver);
@@ -115,7 +116,7 @@
 	/* for reading RRR:GGG:BBB color strings from table */
 	if (rgb_column == NULL || *rgb_column == '\0')
-	    G_fatal_error(_("Color definition column not specified."));
+	    G_fatal_error(_("Color definition column not specified"));
 	db_CatValArray_init(&cvarr_rgb);
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/display/d.vect/area.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -51,12 +51,13 @@
 	if (fi == NULL) {
 	if (driver == NULL)
Modified: grass/trunk/display/d.vect/attr.c
--- grass/trunk/display/d.vect/attr.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/display/d.vect/attr.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -41,7 +41,8 @@
     if (driver == NULL)
-	G_fatal_error(_("Cannot open database %s by driver %s"), fi->database,
+		      fi->database,
 		      fi->driver);
     Vect_rewind(Map);
@@ -109,7 +110,7 @@
 		if (db_open_select_cursor
 		    (driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
-		    G_fatal_error(_("Cannot select attributes: %s"),
+		    G_fatal_error(_("Unable to open select cursor: '%s'"),
 				  db_get_string(&stmt));
 		nrows = db_get_num_rows(&cursor);
Modified: grass/trunk/display/d.vect/plot1.c
--- grass/trunk/display/d.vect/plot1.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/display/d.vect/plot1.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -103,12 +103,13 @@
     if (open_db) {
 	if (fi == NULL) {
 	if (driver == NULL)
Modified: grass/trunk/display/d.vect.chart/plot.c
--- grass/trunk/display/d.vect.chart/plot.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/display/d.vect.chart/plot.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -4,6 +4,8 @@
 #include <grass/display.h>
 #include <grass/raster.h>
 #include <grass/symbol.h>
 #include "global.h"
 /* Returns 0 - ok , 1 - error */
@@ -33,13 +35,14 @@
     Fi = Vect_get_field(Map, field);
     if (Fi == NULL)
-	G_fatal_error("No database table defined for selected field <%d>",
 		      field);
     /* Open driver */
     driver = db_start_driver_open_database(Fi->driver, Fi->database);
     if (driver == NULL) {
-	G_warning("Cannot open database %s by driver %s", Fi->database,
+	G_warning(_("Unable to open database <%s> by driver <%s>"),
+		  Fi->database,
 		  Fi->driver);
 	return 1;
@@ -79,7 +82,8 @@
 	if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) !=
 	    DB_OK) {
-	    G_warning("Cannot open select cursor: %s", buf);
+	    G_warning(_("Unable to open select cursor: '%s'"),
+		      buf);
 	    return 1;
Modified: grass/trunk/lib/rst/interp_float/vinput2d.c
--- grass/trunk/lib/rst/interp_float/vinput2d.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/lib/rst/interp_float/vinput2d.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -76,7 +76,8 @@
 	G_message(_("Loading data from attribute table ..."));
 	if (Fi == NULL)
-	    G_fatal_error(_("Cannot get layer info"));
+			  field);
 	G_debug(3, "  driver = %s database = %s table = %s", Fi->driver,
 		Fi->database, Fi->table);
 	db_init_handle(&handle);
@@ -84,7 +85,8 @@
 	driver = db_start_driver(Fi->driver);
 	db_set_handle(&handle, Fi->database, NULL);
 	if (db_open_database(driver, &handle) != DB_OK)
-	    G_fatal_error(_("Cannot open database %s"), Fi->database);
+			  Fi->database, Fi->driver);
 	zctype = db_column_Ctype(driver, Fi->table, zcol);
 	G_debug(3, " zcol C type = %d", zctype);
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/lib/sites/sites.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -317,7 +317,8 @@
     if (driver == NULL)
+		      fi->database,
 		      fi->driver);
     db_init_string(&stmt);
@@ -325,7 +326,8 @@
     db_append_string(&stmt, fi->table);
     if (db_open_select_cursor(driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
-	G_fatal_error(_("Cannot select attributes"));
+		      db_get_string(&stmt));
     G_debug(1, "%d rows selected from vector attribute table", nrows);
Modified: grass/trunk/raster/r.random/random.c
--- grass/trunk/raster/r.random/random.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/raster/r.random/random.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -38,10 +38,11 @@
     /* open the data files, input raster should be set-up already */
     if ((infd = theState->fd_old) < 0)
-	G_fatal_error(_("Cannot open raster map <%s>"), theState->inraster);
+	G_fatal_error(_("Unable to open raster map <%s>"),
+		      theState->inraster);
     if (theState->docover == 1) {
 	if ((cinfd = theState->fd_cold) < 0)
-	    G_fatal_error(_("Cannot open cover raster map <%s>"),
 			  theState->inrcover);
@@ -51,7 +52,7 @@
 	else
 	    type = theState->buf.type;
 	if ((outfd = G_open_raster_new(theState->outraster, type)) < 0)
-	    G_fatal_error(_("Cannot create raster map <%s>"),
+	    G_fatal_error(_("Unable to create raster map <%s>"),
 			  theState->outraster);
 	theState->fd_new = outfd;
@@ -70,7 +71,7 @@
 					  Vect_subst_var(fi->database, &Out));
 	if (!driver)
-	    G_fatal_error(_("Cannot open database <%s> by driver <%s>"),
 			  Vect_subst_var(fi->database, &Out), fi->driver);
 	Vect_map_add_dblink(&Out, 1, NULL, fi->table, "cat", fi->database,
Modified: grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -73,7 +73,7 @@
     ndata = Vect_get_num_lines(Map);
     if (ndata > NDATA_MAX)
-	G_warning(_("CrossCorrelation: %d are too many points. "
+	G_warning(_("%d are too many points. "
 		    "The cross validation would take too much time."), ndata);
     /*points = Vect_new_line_struct (); */
@@ -82,11 +82,11 @@
     /* Current region is read and points recorded into observ */
     observ = P_Read_Vector_Region_Map(Map, &region, &ndata, 1024, 1);
     G_debug(5, "CrossCorrelation: %d points read in region. ", ndata);
-    fprintf(stdout, _("CrossCorrelation: %d points read in region.\n"),
-	    ndata);
+    G_verbose_message(_("%d points read in region"),
+		      ndata);
     if (ndata > 50)
-	G_warning(_("CrossCorrelation: Maybe, it takes too long. "
+	G_warning(_("Maybe, it takes too long. "
 		    "It will depend on how many points you are considering."));
     else
 	G_debug(5, "CrossCorrelation: It shouldn't take too long.");
@@ -110,7 +110,8 @@
 	    Fi = Vect_get_field(Map, bspline_field);
 	    if (Fi == NULL)
-		G_fatal_error(_("CrossCorrelation: Cannot read field info"));
+			    bspline_field);
 	    driver_cats =
@@ -118,7 +119,7 @@
 		    Fi->database);
 	    if (driver_cats == NULL)
-		G_fatal_error(_("CrossCorrelation: Cannot open database %s by driver %s"),
 	    nrec =
@@ -128,13 +129,14 @@
 	    ctype = cvarr.ctype;
 	    if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
-		G_fatal_error(_("CrossCorrelation: Column type not supported"));
+		G_fatal_error(_("Column type not supported"));
 	    if (nrec < 0)
-		G_fatal_error(_("CrossCorrelation: Cannot select data from table"));
+		G_fatal_error(_("No records selected from table <%s> "),
+			      Fi->table);
-	    G_message(_("CrossCorrelation: %d records selected from table"),
-		      nrec);
+	    G_debug(1, "%d records selected from table",
+		    nrec);
 	    db_close_database_shutdown_driver(driver_cats);
@@ -145,7 +147,7 @@
 	nparam_spl = nsplx * nsply;	/* Total number of splines */
 	if (nparam_spl > 22900)
-	    G_fatal_error(_("CrossCorrelation: Too many splines (%d x %d). "
+	    G_fatal_error(_("Too many splines (%d x %d). "
 			    "Consider changing spline steps \"sie=\" \"sin=\"."),
 			  nsplx, nsply);
@@ -163,10 +165,9 @@
 	for (lbd = 0; lbd < PARAM_LAMBDA; lbd++) {	/* For each lambda value */
-	    fprintf(stdout,
-		    _("CrossCorrelation: Begining cross validation with "
-		      "lambda_i=%.4f ...\n"), lambda[lbd]);
+	    G_message(_("Begining cross validation with "
+			"lambda_i=%.4f..."), lambda[lbd]);
 	       How cross correlation algorithm is done:
 	       For each cicle, only the first ndata-1 "observ" elements are considered for the
@@ -214,7 +215,7 @@
 			    obs_mean[i] = dval;
 			if (ret != DB_OK) {
-			    G_warning(_("CrossCorrelation: No record for point (cat = %d)"),
+			    G_warning(_("No record for point (cat = %d)"),
 				      cat);
 			    continue;
@@ -284,12 +285,9 @@
 	    stdev[lbd] =
 		calc_standard_deviation(stat_vect.error, stat_vect.n_points);
-	    fprintf(stdout, _("CrossCorrelation: Mean = %.5lf\n"), mean[lbd]);
-	    fprintf(stdout,
-		    _("CrossCorrelation: Root Means Square (RMS) = %.5lf\n"),
-		    rms[lbd]);
-	    fprintf(stdout,
-		    "\n---------------------o-o-------------------\n\n");
+	    G_message(_("Mean = %.5lf"), mean[lbd]);
+	    G_message(_("Root Means Square (RMS) = %.5lf"),
+		      rms[lbd]);
 	}			/* ENDFOR each lambda value */
 	G_free_matrix(N);
@@ -304,31 +302,28 @@
 	stdev_min = find_minimum(stdev, &lbd_min);
 	/* Writing some output */
-	fprintf(stdout,
-		_("CrossCorrelation: Different number of splines and lambda_i values have "
-		 "been taken for the cross correlation\n"));
-	fprintf(stdout,
-		_("CrossCorrelation: The minimum value for the test (rms=%lf) was obtained with:\n"),
-		rms_min);
-	fprintf(stdout, _("CrossCorrelation: lambda_i = %.3f\n"),
-		lambda[lbd_min]);
+	G_message(_("Different number of splines and lambda_i values have "
+		    "been taken for the cross correlation"));
+	G_message(_("The minimum value for the test (rms=%lf) was "
+		    "obtained with: lambda_i = %.3f"),
+		  rms_min,
+		  lambda[lbd_min]);
 	*lambda_min = lambda[lbd_min];
 #endif
-	fprintf(stdout, _("Now, the results into a table:\n"));
-	fprintf(stdout, _(" lambda    | mean        | rms         |\n"));
+	G_message(_("Results into a table:"));
+	G_message(_(" lambda    | mean        | rms         |"));
-	    fprintf(stdout, _(" %-10.5f| %-12.4f| %-12.4f|\n"), lambda[lbd],
-		    mean[lbd], rms[lbd]);
+	    G_message(_(" %-10.5f| %-12.4f| %-12.4f|"), lambda[lbd],
+		      mean[lbd], rms[lbd]);
-	fprintf(stdout, _("\nResults are over.\n"));
 	G_free_vector(mean);
 	G_free_vector(rms);
     }				/* ENDIF (ndata > 0) */
     else
-	G_warning(_("CrossCorrelation: No point lies into the current region"));
+	G_warning(_("No point lies into the current region"));
     G_free(observ);
     return TRUE;
Modified: grass/trunk/vector/v.convert/att.c
--- grass/trunk/vector/v.convert/att.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/v.convert/att.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -27,18 +27,18 @@
     /* Find vector mapset */
     if (NULL == (mapset = G_find_file("dig", in, ""))) {
-	G_warning(_("Input vector was not found."));	/* Should not happen */
+	G_warning(_("Vector map <%s> not found"), in);	/* Should not happen */
 	return 0;
     /* Find dig_cats if exists */
     if (NULL == G_find_file("dig_cats", in, mapset)) {
-	G_message(_("No category labels (dig_cats) found, no table created.\n"));
+	G_message(_("No category labels (dig_cats) found, no table created"));
 	return 0;
     if (G_read_vector_cats(in, mapset, &Cats) == -1) {
-	G_warning(_("Cannot open dig_cats file."));
+	G_warning(_("Unable to open dig_cats file"));
 	return -1;
@@ -64,26 +64,31 @@
     driver = db_start_driver(fi->driver);
     if (driver == NULL)
-	G_fatal_error("Cannot open driver %s", fi->driver);
+	G_fatal_error(_("Unable to open driver <%s>"),
+		      fi->driver);
     db_set_handle(&handle, Vect_subst_var(fi->database, Out), NULL);
     if (db_open_database(driver, &handle) != DB_OK) {
 	db_shutdown_driver(driver);
-	G_fatal_error(_("Cannot open database %s"), fi->database);
+	G_fatal_error(_("Unable to open database <%s>"),
+		      fi->database);
     if (db_execute_immediate(driver, &sql) != DB_OK) {
 	db_close_database(driver);
-	G_fatal_error(_("Cannot create table: %s"), db_get_string(&sql));
+	G_fatal_error(_("Unable to create table: '%s'"),
+		      db_get_string(&sql));
     if (db_create_index2(driver, fi->table, "cat") != DB_OK)
-	G_warning("Cannot create index");
+	G_warning(_("Unable to create index for table <%s>, key <%s>"),
+		  fi->table, "cat");
     if (db_grant_on_table
 	(driver, fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
-	G_fatal_error("Cannot grant privileges on table %s", fi->table);
+	G_fatal_error(_("Unable to grant privileges on table <%s>"),
+		      fi->table);
     G_debug(1, "ncats = %d", Cats.ncats);
@@ -102,7 +107,7 @@
-	    G_fatal_error(_("Cannot insert into table: %s"),
+	    G_fatal_error(_("Unable to insert new record: '%s'"),
 	count++;
Modified: grass/trunk/vector/v.in.dwg/main.c
--- grass/trunk/vector/v.in.dwg/main.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/v.in.dwg/main.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -6,7 +6,7 @@
  *  PURPOSE:      Import of DWG/DXF files
- *  COPYRIGHT:    (C) 2001 by the GRASS Development Team
+ *  COPYRIGHT:    (C) 2001-2008 by the GRASS Development Team
  *                GNU General Public License (>=v2).
@@ -80,14 +80,10 @@
     module = G_define_module();
     module->keywords = _("vector, import");
-    module->description = "Convert DWG/DXF to GRASS vector map";
+    module->description = _("Converts DWG/DXF to GRASS vector map");
-    in_opt = G_define_option();
-    in_opt->key = "input";
-    in_opt->type = TYPE_STRING;
-    in_opt->required = YES;
-    in_opt->description = "DWG or DXF file";
-    in_opt->gisprompt = "old_file,file,input";
+    in_opt = G_define_standard_option(G_OPT_F_INPUT);
+    in_opt->description = _("Name of DWG or DXF file");
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
     out_opt->required = YES;
@@ -97,28 +93,28 @@
     layers_opt->type = TYPE_STRING;
     layers_opt->required = NO;
     layers_opt->multiple = YES;
-    layers_opt->description = "List of layers to import";
+    layers_opt->description = _("List of layers to import");
     invert_flag = G_define_flag();
     invert_flag->key = 'i';
     invert_flag->description =
-	"Invert selection by layers (don't import layers in list)";
+	_("Invert selection by layers (don't import layers in list)");
     z_flag = G_define_flag();
     z_flag->key = 'z';
-    z_flag->description = "Create 3D vector";
+    z_flag->description = _("Create 3D vector map");
     circle_flag = G_define_flag();
     circle_flag->key = 'c';
-    circle_flag->description = "Write circles as points (centre)";
+    circle_flag->description = _("Write circles as points (centre)");
     l_flag = G_define_flag();
     l_flag->key = 'l';
-    l_flag->description = "List available layers and exit";
+    l_flag->description = _("List available layers and exit");
     int_flag = G_define_flag();
     int_flag->key = 'n';
-    int_flag->description = "Use numeric type for attribute \"layer\"";
+    int_flag->description = _("Use numeric type for attribute \"layer\"");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -138,10 +134,10 @@
     /* Init OpenDWG */
     sprintf(path, "%s/etc/adinit.dat", G_gisbase());
     if (!adInitAd2(path, &initerror)) {
-	sprintf(buf, "Unable to initialize OpenDWG Toolkit, error: %d: %s.",
+	sprintf(buf, _("Unable to initialize OpenDWG Toolkit, error: %d: %s."),
 		initerror, adErrorStr(initerror));
 	if (initerror == AD_UNABLE_TO_OPEN_INIT_FILE)
-	    sprintf(buf, "%s Cannot open %s", buf, path);
+	    sprintf(buf, _("%s Cannot open %s"), buf, path);
 	G_fatal_error(buf);
     adSetupDwgRead();
@@ -149,7 +145,8 @@
     /* Open input file */
     if ((dwghandle = adLoadFile(in_opt->answer, AD_PRELOAD_ALL, 1)) == NULL) {
-	G_fatal_error("Cannot open input file. Error %d: %s", adError(),
+	G_fatal_error(_("Unable to open input file <%s>. Error %d: %s"),
+		      in_opt->answer, adError(),
 		      adErrorStr(adError()));
@@ -211,7 +208,7 @@
 				      Vect_subst_var(Fi->database, &Map));
-	G_fatal_error("Cannot open database %s by driver %s",
 		      Vect_subst_var(Fi->database, &Map), Fi->driver);
     db_begin_transaction(driver);
@@ -236,15 +233,17 @@
-	G_fatal_error("Cannot create table: %s", db_get_string(&sql));
+	G_fatal_error(_("Unable to create table: '%s'", db_get_string(&sql));
     if (db_create_index2(driver, Fi->table, "cat") != DB_OK)
+		  Fi->table, "cat");
 	(driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
-	G_fatal_error("Cannot grant privileges on table %s", Fi->table);
+		      Fi->table);
     cat = 1;
     n_elements = n_skipped = 0;
@@ -271,11 +270,6 @@
-    G_message(_("%d elements processed"), n_elements);
-    if (n_skipped > 0)
-	G_message(_("%d elements skipped (layer name was not in list)"),
-		  n_skipped);
     db_commit_transaction(driver);
     db_close_database_shutdown_driver(driver);
@@ -284,6 +278,12 @@
     Vect_build(&Map, stderr);
     Vect_close(&Map);
+    if (n_skipped > 0)
+	G_message(_("%d elements skipped (layer name was not in list)"),
+		  n_skipped);
+    G_done_msg(_("%d elements processed"), n_elements);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/v.in.ogr/main.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -750,24 +750,25 @@
 							     &Map));
+		G_fatal_error(_("Unable open database <%s> by driver <%s>"),
 	    if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
-		G_warning(_("Cannot create index"));
+			  Fi->table, cat_col_name);
-		G_fatal_error(_("Cannot grant privileges on table %s"),
 			      Fi->table);
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/v.info/main.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -62,9 +62,9 @@
     G_gisinit(argv[0]);
-    module->keywords = _("vector");
+    module->keywords = _("vector, metadata, history");
-	_("Outputs basic information about a user-specified vector map layer.");
+	_("Outputs basic information about a user-specified vector map.");
     /* get G_OPT_ from include/gis.h */
     in_opt = G_define_standard_option(G_OPT_V_MAP);
@@ -74,23 +74,28 @@
     histf = G_define_flag();
     histf->key = 'h';
     histf->description = _("Print vector history instead of info");
+    histf->guisection = _("Print");
     columns = G_define_flag();
     columns->key = 'c';
     columns->description =
 	_("Print types/names of table columns for specified layer instead of info");
+    columns->guisection = _("Print");
     gflag = G_define_flag();
     gflag->key = 'g';
     gflag->description = _("Print map region only");
+    gflag->guisection = _("Print");
     mflag = G_define_flag();
     mflag->key = 'm';
     mflag->description = _("Print map title only");
+    mflag->guisection = _("Print");
     tflag = G_define_flag();
     tflag->key = 't';
     tflag->description = _("Print topology information only");
+    tflag->guisection = _("Print");
 	exit(EXIT_FAILURE);
@@ -193,18 +198,22 @@
 		G_message(_("Displaying column types/names for database connection of layer %d:"),
 			  field);
 		if ((fi = Vect_get_field(&Map, field)) == NULL)
-		    G_fatal_error("Database connection not defined");
+				  field);
 		if (driver == NULL)
+				  fi->driver);
 		db_set_handle(&handle, fi->database, NULL);
-		    G_fatal_error("Cannot open database <%s>", fi->database);
+			fi->database, fi->driver);
 		db_init_string(&table_name);
 		db_set_string(&table_name, fi->table);
 		if (db_describe_table(driver, &table_name, &table) != DB_OK)
-		    G_fatal_error("Cannot open table <%s>", fi->table);
+		    G_fatal_error(_("Unable to describe table <%s>"),
+				  fi->table);
 		ncols = db_get_table_number_of_columns(table);
 		for (col = 0; col < ncols; col++)
Modified: grass/trunk/vector/v.net.path/path.c
--- grass/trunk/vector/v.net.path/path.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/v.net.path/path.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -93,7 +93,7 @@
     if (driver == NULL)
     sprintf(buf,
@@ -106,7 +106,7 @@
+	G_fatal_error(_("Unable to create table: '%s'"), db_get_string(&sql));
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/v.surf.rst/main.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -540,13 +540,14 @@
 	G_debug(1, db_get_string(&sql2));
 	driver2 = db_start_driver_open_database(ff->driver, ff->database);
 	if (driver2 == NULL)
 			  ff->database, ff->driver);
 	if (db_execute_immediate(driver2, &sql2) != DB_OK) {
 	    db_close_database(driver2);
 	    db_shutdown_driver(driver2);
-	    G_fatal_error(_("Cannot create table: %s"), db_get_string(&sql2));
+			  db_get_string(&sql2));
 	count = 1;
Modified: grass/trunk/vector/v.to.points/main.c
--- grass/trunk/vector/v.to.points/main.c	2008-12-01 16:42:44 UTC (rev 34653)
+++ grass/trunk/vector/v.to.points/main.c	2008-12-01 16:45:58 UTC (rev 34654)
@@ -60,7 +60,7 @@
 	db_append_string(&stmt, buf);
 	if (db_execute_immediate(driver, &stmt) != DB_OK) {
-	    G_warning(_("Cannot insert new record: %s"),
+	    G_warning(_("Unable to insert new record: '%s'"),
@@ -265,7 +265,8 @@
 							   &Out), Fi->table);
 	    if (ret == DB_FAILED) {
-		G_fatal_error(_("Cannot copy table"));
+		G_fatal_error(_("Unable to copy table <%s>"),
+			      Fin->table);
@@ -276,7 +277,7 @@
 	/* Open driver */
 	if (driver == NULL)
 	sprintf(buf,
@@ -286,16 +287,18 @@
-	    G_fatal_error(_("Cannot create table: %s"), db_get_string(&stmt));
-	    G_fatal_error(_("Cannot grant privileges on table <%s>"),
 			  Fi->table);
