[GRASS-SVN] r34670 - in grass/trunk: lib/gis vector/v.category
svn_grass at osgeo.org
Tue Dec 2 11:50:15 EST 2008
Author: martinl
Date: 2008-12-02 11:50:15 -0500 (Tue, 02 Dec 2008)
New Revision: 34670
grass/trunk/lib/gis/parser.c
grass/trunk/vector/v.category/main.c
v.category: more guisections
sipmlify G_OPT_TYPE description
(merge from devbr6, r34669)
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2008-12-02 16:44:48 UTC (rev 34669)
+++ grass/trunk/lib/gis/parser.c 2008-12-02 16:50:15 UTC (rev 34670)
@@ -595,8 +595,7 @@
Opt->multiple = YES;
Opt->answer = "point,line,boundary,centroid,area";
Opt->options = "point,line,boundary,centroid,area";
- Opt->label = _("Type");
- Opt->description = _("Feature type(s)");
+ Opt->description = _("Feature type");
break;
case G_OPT_V_FIELD:
Opt->key = "layer";
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2008-12-02 16:44:48 UTC (rev 34669)
+++ grass/trunk/vector/v.category/main.c 2008-12-02 16:50:15 UTC (rev 34670)
@@ -69,9 +69,9 @@
_("Attach, delete or report vector categories to map geometry.");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
out_opt->required = NO;
- type_opt = G_define_standard_option(G_OPT_V_TYPE);
option_opt = G_define_option();
option_opt->key = "option";
@@ -88,15 +88,24 @@
"report;print report (statistics), in shell style: layer type count min max;"
"print;print category values, more cats in the same layer are separated by '/'");
- cat_opt = G_define_standard_option(G_OPT_V_CAT);
- cat_opt->answer = "1";
- cat_opt->guisection = _("Selection");
+ type_opt = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt->guisection = _("Selection");
field_opt = G_define_standard_option(G_OPT_V_FIELD);
field_opt->answer = "1";
field_opt->multiple = YES;
field_opt->guisection = _("Selection");
+ id_opt = G_define_standard_option(G_OPT_V_CAT);
+ id_opt->multiple = YES;
+ id_opt->label = _("Feature id(s)");
+ id_opt->description = _("By default all ids are processed");
+ id_opt->key = "id";
+ id_opt->guisection = _("Selection");
+ cat_opt = G_define_standard_option(G_OPT_V_CAT);
+ cat_opt->answer = "1";
step_opt = G_define_option();
step_opt->key = "step";
step_opt->type = TYPE_INTEGER;
@@ -105,12 +114,6 @@
step_opt->answer = "1";
step_opt->description = _("Category increment");
- id_opt = G_define_standard_option(G_OPT_V_CAT);
- id_opt->multiple = YES;
- id_opt->label = _("Feature id(s)");
- id_opt->description = _("By default all ids are processed");
- id_opt->key = "id";
shell = G_define_flag();
shell->key = 'g';
shell->label = _("Shell script style, currently only for report");
