[GRASS-SVN] r34703 -
grass/branches/develbranch_6/scripts/d.split.frame
svn_grass at osgeo.org
Thu Dec 4 04:45:50 EST 2008
Author: hamish
Date: 2008-12-04 04:45:49 -0500 (Thu, 04 Dec 2008)
New Revision: 34703
Added:
grass/branches/develbranch_6/scripts/d.split.frame/d.split.frame
Removed:
grass/branches/develbranch_6/scripts/d.split.frame/d.frame.split
rename
Deleted: grass/branches/develbranch_6/scripts/d.split.frame/d.frame.split
--- grass/branches/develbranch_6/scripts/d.split.frame/d.frame.split 2008-12-04 09:45:17 UTC (rev 34702)
+++ grass/branches/develbranch_6/scripts/d.split.frame/d.frame.split 2008-12-04 09:45:49 UTC (rev 34703)
@@ -1,174 +0,0 @@
-#!/bin/sh
-# MODULE: d.split.frame
-# AUTHOR: M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
-# New Zealand
-# PURPOSE: Split the display into quarter frames, etc
-# (This script is a replacement for d.split from GRASS 5,6)
-# COPYRIGHT: (c) 2007 Hamish Bowman, and the GRASS Development Team
-# This program is free software released to the public domain
-#%Module
-#% description: Split the display into subframes.
-#%End
-#%option
-#% key: frames
-#% type: integer
-#% description: Number of subframes
-#% options: 2,4,6,8,9,12,16
-#% answer: 4
-#%end
-#%flag
-#% key: h
-#% description: Split horizontally not vertically
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
-fi
-# skip parser if no args are given
-if [ "$#" -gt 0 ] ; then
- if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
- fi
-else
- GIS_OPT_FRAMES=4
- GIS_FLAG_H=0
-fi
-if [ `d.mon -p | cut -f1 -d' '` != "Currently" ] ; then
- g.message -e "No monitor currently selected for output"
- exit 1
-fi
-d.erase -f
-if [ $? -ne 0 ] ; then
- g.message -e "Error clearing display monitor"
- exit 1
-fi
-case "$GIS_OPT_FRAMES" in
- 2) if [ $GIS_FLAG_H -eq 0 ] ; then
- #split vert
- d.frame -c frame=uno at=50,100,0,100
- d.frame -c frame=dos at=0,50,0,100
- else
- d.frame -c frame=uno at=0,100,0,50
- d.frame -c frame=dos at=0,100,50,100
- fi
- 4) d.frame -c frame=uno at=50,100,0,50
- d.frame -c frame=dos at=50,100,50,100
- d.frame -c frame=tres at=0,50,0,50
- d.frame -c frame=cuatro at=0,50,50,100
- 6) if [ $GIS_FLAG_H -eq 0 ] ; then
- #split vert
- d.frame -c frame=uno at=66.6667,100,0,50
- d.frame -c frame=dos at=66.6667,100,50,100
- d.frame -c frame=tres at=33.3333,66.6667,0,50
- d.frame -c frame=cuatro at=33.3333,66.6667,50,100
- d.frame -c frame=cinco at=0,33.3333,0,50
- d.frame -c frame=seis at=0,33.3333,50,100
- else
- d.frame -c frame=uno at=50,100,0,33.3333
- d.frame -c frame=dos at=50,100,33.3333,66.6667
- d.frame -c frame=tres at=50,100,66.6667,100
- d.frame -c frame=cuatro at=0,50,0,33.3333
- d.frame -c frame=cinco at=0,50,33.3333,66.6667
- d.frame -c frame=seis at=0,50,66.6667,100
- fi
- 8) if [ $GIS_FLAG_H -eq 0 ] ; then
- #split vert
- d.frame -c frame=uno at=75,100,0,50
- d.frame -c frame=dos at=75,100,50,100
- d.frame -c frame=tres at=50,75,0,50
- d.frame -c frame=cuatro at=50,75,50,100
- d.frame -c frame=cinco at=25,50,0,50
- d.frame -c frame=seis at=25,50,50,100
- d.frame -c frame=siete at=0,25,0,50
- d.frame -c frame=ocho at=0,25,50,100
- else
- d.frame -c frame=uno at=50,100,0,25
- d.frame -c frame=dos at=50,100,25,50
- d.frame -c frame=tres at=50,100,50,75
- d.frame -c frame=cuatro at=50,100,75,100
- d.frame -c frame=cinco at=0,50,0,25
- d.frame -c frame=seis at=0,50,25,50
- d.frame -c frame=siete at=0,50,50,75
- d.frame -c frame=ocho at=0,50,75,100
- fi
- 9) d.frame -c frame=uno at=66.6667,100,0,33.3333
- d.frame -c frame=dos at=66.6667,100,33.3333,66.6667
- d.frame -c frame=tres at=66.6667,100,66.6667,100
- d.frame -c frame=cuatro at=33.3333,66.6667,0,33.3333
- d.frame -c frame=cinco at=33.3333,66.6667,33.3333,66.6667
- d.frame -c frame=seis at=33.3333,66.6667,66.6667,100
- d.frame -c frame=siete at=0,33.3333,0,33.3333
- d.frame -c frame=ocho at=0,33.3333,33.3333,66.6667
- d.frame -c frame=nueve at=0,33.3333,66.6667,100
- 12) if [ $GIS_FLAG_H -eq 0 ] ; then
- #split vert
- d.frame -c frame=uno at=75,100,0,33.3333
- d.frame -c frame=dos at=75,100,33.3333,66.6667
- d.frame -c frame=tres at=75,100,66.6667,100
- d.frame -c frame=cuatro at=50,75,0,33.3333
- d.frame -c frame=cinco at=50,75,33.3333,66.6667
- d.frame -c frame=seis at=50,75,66.6667,100
- d.frame -c frame=siete at=25,50,0,33.3333
- d.frame -c frame=ocho at=25,50,33.3333,66.6667
- d.frame -c frame=nueve at=25,50,66.6667,100
- d.frame -c frame=diez at=0,25,0,33.3333
- d.frame -c frame=once at=0,25,33.3333,66.6667
- d.frame -c frame=doce at=0,25,66.6667,100
- else
- d.frame -c frame=uno at=66.6667,100,0,25
- d.frame -c frame=dos at=66.6667,100,25,50
- d.frame -c frame=tres at=66.6667,100,50,75
- d.frame -c frame=cuatro at=66.6667,100,75,100
- d.frame -c frame=cinco at=33.3333,66.6667,0,25
- d.frame -c frame=seis at=33.3333,66.6667,25,50
- d.frame -c frame=siete at=33.3333,66.6667,50,75
- d.frame -c frame=ocho at=33.3333,66.6667,75,100
- d.frame -c frame=nueve at=0,33.3333,0,25
- d.frame -c frame=diez at=0,33.3333,25,50
- d.frame -c frame=once at=0,33.3333,50,75
- d.frame -c frame=doce at=0,33.3333,75,100
- fi
- 16) d.frame -c frame=uno at=75,100,0,25
- d.frame -c frame=dos at=75,100,25,50
- d.frame -c frame=tres at=75,100,50,75
- d.frame -c frame=cuatro at=75,100,75,100
- d.frame -c frame=cinco at=50,75,0,25
- d.frame -c frame=seis at=50,75,25,50
- d.frame -c frame=siete at=50,75,50,75
- d.frame -c frame=ocho at=50,75,75,100
- d.frame -c frame=nueve at=25,50,0,25
- d.frame -c frame=diez at=25,50,25,50
- d.frame -c frame=once at=25,50,50,75
- d.frame -c frame=doce at=25,50,75,100
- d.frame -c frame=trece at=0,25,0,25
- d.frame -c frame=catorce at=0,25,25,50
- d.frame -c frame=quince at=0,25,50,75
- d.frame -c frame=dieciseis at=0,25,75,100
-esac
-d.frame -s uno
-g.message "Use 'd.erase -f' to clear frames from display monitor."
-exit
Copied: grass/branches/develbranch_6/scripts/d.split.frame/d.split.frame (from rev 34702, grass/branches/develbranch_6/scripts/d.split.frame/d.frame.split)
--- grass/branches/develbranch_6/scripts/d.split.frame/d.split.frame (rev 0)
+++ grass/branches/develbranch_6/scripts/d.split.frame/d.split.frame 2008-12-04 09:45:49 UTC (rev 34703)
@@ -0,0 +1,174 @@
+#!/bin/sh
+# MODULE: d.split.frame
+# AUTHOR: M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
+# New Zealand
+# PURPOSE: Split the display into quarter frames, etc
+# (This script is a replacement for d.split from GRASS 5,6)
+# COPYRIGHT: (c) 2007 Hamish Bowman, and the GRASS Development Team
+# This program is free software released to the public domain
+#%Module
+#% description: Split the display into subframes.
+#%End
+#%option
+#% key: frames
+#% type: integer
+#% description: Number of subframes
+#% options: 2,4,6,8,9,12,16
+#% answer: 4
+#%end
+#%flag
+#% key: h
+#% description: Split horizontally not vertically
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+# skip parser if no args are given
+if [ "$#" -gt 0 ] ; then
+ if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+ fi
+else
+ GIS_OPT_FRAMES=4
+ GIS_FLAG_H=0
+fi
+if [ `d.mon -p | cut -f1 -d' '` != "Currently" ] ; then
+ g.message -e "No monitor currently selected for output"
+ exit 1
+fi
+d.erase -f
+if [ $? -ne 0 ] ; then
+ g.message -e "Error clearing display monitor"
+ exit 1
+fi
+case "$GIS_OPT_FRAMES" in
+ 2) if [ $GIS_FLAG_H -eq 0 ] ; then
+ #split vert
+ d.frame -c frame=uno at=50,100,0,100
+ d.frame -c frame=dos at=0,50,0,100
+ else
+ d.frame -c frame=uno at=0,100,0,50
+ d.frame -c frame=dos at=0,100,50,100
+ fi
+ 4) d.frame -c frame=uno at=50,100,0,50
+ d.frame -c frame=dos at=50,100,50,100
+ d.frame -c frame=tres at=0,50,0,50
+ d.frame -c frame=cuatro at=0,50,50,100
+ 6) if [ $GIS_FLAG_H -eq 0 ] ; then
+ #split vert
+ d.frame -c frame=uno at=66.6667,100,0,50
+ d.frame -c frame=dos at=66.6667,100,50,100
+ d.frame -c frame=tres at=33.3333,66.6667,0,50
+ d.frame -c frame=cuatro at=33.3333,66.6667,50,100
+ d.frame -c frame=cinco at=0,33.3333,0,50
+ d.frame -c frame=seis at=0,33.3333,50,100
+ else
+ d.frame -c frame=uno at=50,100,0,33.3333
+ d.frame -c frame=dos at=50,100,33.3333,66.6667
+ d.frame -c frame=tres at=50,100,66.6667,100
+ d.frame -c frame=cuatro at=0,50,0,33.3333
+ d.frame -c frame=cinco at=0,50,33.3333,66.6667
+ d.frame -c frame=seis at=0,50,66.6667,100
+ fi
+ 8) if [ $GIS_FLAG_H -eq 0 ] ; then
+ #split vert
+ d.frame -c frame=uno at=75,100,0,50
+ d.frame -c frame=dos at=75,100,50,100
+ d.frame -c frame=tres at=50,75,0,50
+ d.frame -c frame=cuatro at=50,75,50,100
+ d.frame -c frame=cinco at=25,50,0,50
+ d.frame -c frame=seis at=25,50,50,100
+ d.frame -c frame=siete at=0,25,0,50
+ d.frame -c frame=ocho at=0,25,50,100
+ else
+ d.frame -c frame=uno at=50,100,0,25
+ d.frame -c frame=dos at=50,100,25,50
+ d.frame -c frame=tres at=50,100,50,75
+ d.frame -c frame=cuatro at=50,100,75,100
+ d.frame -c frame=cinco at=0,50,0,25
+ d.frame -c frame=seis at=0,50,25,50
+ d.frame -c frame=siete at=0,50,50,75
+ d.frame -c frame=ocho at=0,50,75,100
+ fi
+ 9) d.frame -c frame=uno at=66.6667,100,0,33.3333
+ d.frame -c frame=dos at=66.6667,100,33.3333,66.6667
+ d.frame -c frame=tres at=66.6667,100,66.6667,100
+ d.frame -c frame=cuatro at=33.3333,66.6667,0,33.3333
+ d.frame -c frame=cinco at=33.3333,66.6667,33.3333,66.6667
+ d.frame -c frame=seis at=33.3333,66.6667,66.6667,100
+ d.frame -c frame=siete at=0,33.3333,0,33.3333
+ d.frame -c frame=ocho at=0,33.3333,33.3333,66.6667
+ d.frame -c frame=nueve at=0,33.3333,66.6667,100
+ 12) if [ $GIS_FLAG_H -eq 0 ] ; then
+ #split vert
+ d.frame -c frame=uno at=75,100,0,33.3333
+ d.frame -c frame=dos at=75,100,33.3333,66.6667
+ d.frame -c frame=tres at=75,100,66.6667,100
+ d.frame -c frame=cuatro at=50,75,0,33.3333
+ d.frame -c frame=cinco at=50,75,33.3333,66.6667
+ d.frame -c frame=seis at=50,75,66.6667,100
+ d.frame -c frame=siete at=25,50,0,33.3333
+ d.frame -c frame=ocho at=25,50,33.3333,66.6667
+ d.frame -c frame=nueve at=25,50,66.6667,100
+ d.frame -c frame=diez at=0,25,0,33.3333
+ d.frame -c frame=once at=0,25,33.3333,66.6667
+ d.frame -c frame=doce at=0,25,66.6667,100
+ else
+ d.frame -c frame=uno at=66.6667,100,0,25
+ d.frame -c frame=dos at=66.6667,100,25,50
+ d.frame -c frame=tres at=66.6667,100,50,75
+ d.frame -c frame=cuatro at=66.6667,100,75,100
+ d.frame -c frame=cinco at=33.3333,66.6667,0,25
+ d.frame -c frame=seis at=33.3333,66.6667,25,50
+ d.frame -c frame=siete at=33.3333,66.6667,50,75
+ d.frame -c frame=ocho at=33.3333,66.6667,75,100
+ d.frame -c frame=nueve at=0,33.3333,0,25
+ d.frame -c frame=diez at=0,33.3333,25,50
+ d.frame -c frame=once at=0,33.3333,50,75
+ d.frame -c frame=doce at=0,33.3333,75,100
+ fi
+ 16) d.frame -c frame=uno at=75,100,0,25
+ d.frame -c frame=dos at=75,100,25,50
+ d.frame -c frame=tres at=75,100,50,75
+ d.frame -c frame=cuatro at=75,100,75,100
+ d.frame -c frame=cinco at=50,75,0,25
+ d.frame -c frame=seis at=50,75,25,50
+ d.frame -c frame=siete at=50,75,50,75
+ d.frame -c frame=ocho at=50,75,75,100
+ d.frame -c frame=nueve at=25,50,0,25
+ d.frame -c frame=diez at=25,50,25,50
+ d.frame -c frame=once at=25,50,50,75
+ d.frame -c frame=doce at=25,50,75,100
+ d.frame -c frame=trece at=0,25,0,25
+ d.frame -c frame=catorce at=0,25,25,50
+ d.frame -c frame=quince at=0,25,50,75
+ d.frame -c frame=dieciseis at=0,25,75,100
+esac
+d.frame -s uno
+g.message "Use 'd.erase -f' to clear frames from display monitor."
+exit
