[GRASS-SVN] r34712 - grass/trunk/scripts/v.colors
svn_grass at osgeo.org
Thu Dec 4 05:19:02 EST 2008
Author: hamish
Date: 2008-12-04 05:19:02 -0500 (Thu, 04 Dec 2008)
New Revision: 34712
grass/trunk/scripts/v.colors/v.colors
echo to g.message (merge from devbr6)
Modified: grass/trunk/scripts/v.colors/v.colors
--- grass/trunk/scripts/v.colors/v.colors 2008-12-04 10:17:47 UTC (rev 34711)
+++ grass/trunk/scripts/v.colors/v.colors 2008-12-04 10:19:02 UTC (rev 34712)
@@ -202,14 +202,14 @@
g.message -e "Column <$GIS_OPT_COLUMN> is not numeric"
exit 1
fi
-#echo "column <$GIS_OPT_COLUMN> is type [$NCOLUMN_TYPE]"
+#g.message "column <$GIS_OPT_COLUMN> is type [$NCOLUMN_TYPE]"
# check if GRASSRGB column exists, make it if it doesn't
TABLE=`v.db.connect -g map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" fs=";" | cut -f2 -d';'`
COLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep -i "|$GIS_OPT_RGB_COLUMN$" | cut -f1 -d'|'`
if [ -z "$COLUMN_TYPE" ] ; then
# RGB Column not found, create it
- echo "Creating column <$GIS_OPT_RGB_COLUMN> ..."
+ g.message "Creating column <$GIS_OPT_RGB_COLUMN> ..."
v.db.addcol map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" column="$GIS_OPT_RGB_COLUMN varchar(11)"
if [ $? -ne 0 ] ; then
g.message -e "Creating color column"
@@ -233,11 +233,11 @@
MINVAL=`echo "$GIS_OPT_RANGE" | grep '[[:digit:]]' | grep ',' | cut -f1 -d','`
MAXVAL=`echo "$GIS_OPT_RANGE" | grep '[[:digit:]]' | grep ',' | cut -f2 -d','`
else
- echo "Scanning values ..."
+ g.message "Scanning values ..."
MINVAL=`v.db.select map="$GIS_OPT_MAP" column="$GIS_OPT_COLUMN" layer="$GIS_OPT_LAYER" | sort -n | grep '^[-0-9]' | head -n 1`
MAXVAL=`v.db.select map="$GIS_OPT_MAP" column="$GIS_OPT_COLUMN" layer="$GIS_OPT_LAYER" | sort -n | grep '^[-0-9]' | tail -n 1`
fi
-echo " min=[$MINVAL] max=[$MAXVAL]"
+g.message " min=[$MINVAL] max=[$MAXVAL]"
if [ -z "$MINVAL" ] || [ -z "$MAXVAL" ] ; then
g.message -e "Scanning data range"
exit 1
@@ -283,12 +283,12 @@
# calculate colors and write SQL command file
-echo "Looking up colors ..."
+g.message "Looking up colors ..."
v.db.select map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" column="$GIS_OPT_COLUMN" | \
sort -n | grep '^[-0-9]' | uniq | \
r.what.color -i in="tmp_colr_$$" | sed -e 's/: /|/' | grep -v '|\*$' | \
( while read LINE ; do
- #echo "LINE=[$LINE]"
+ #g.message "LINE=[$LINE]"
VALUE=`echo $LINE | cut -f1 -d'|'`
COLR=`echo $LINE | cut -f2 -d'|'`
echo "UPDATE $TABLE SET $GIS_OPT_RGB_COLUMN = '$COLR' WHERE $GIS_OPT_COLUMN = $VALUE;" >> "${TMP}_vcol.sql"
@@ -303,7 +303,7 @@
# apply SQL commands to update the table with values
NUM_RULES=`wc -l < "${TMP}_vcol.sql"`
-echo "Writing $NUM_RULES colors ..."
+g.message "Writing $NUM_RULES colors ..."
#less "$TMP"
db.execute input="${TMP}_vcol.sql"
@@ -315,7 +315,7 @@
if [ $GIS_FLAG_S -eq 1 ] ; then
g.rename rast="tmp_colr_$$","vcolors_$$"
- echo "Raster map containing color rules saved to <vcolors_$$>"
+ g.message "Raster map containing color rules saved to <vcolors_$$>"
# TODO save full v.colors command line history
r.support map="vcolors_$$" history="" \
source1="vector map=$GIS_OPT_MAP" \
