[GRASS-SVN] r34728 - grass/trunk/vector/v.category
svn_grass at osgeo.org
Thu Dec 4 15:20:07 EST 2008
Author: martinl
Date: 2008-12-04 15:20:07 -0500 (Thu, 04 Dec 2008)
New Revision: 34728
grass/trunk/vector/v.category/main.c
v.category: '0' is valid category number
(merge from devbr6, r34727)
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2008-12-04 20:18:08 UTC (rev 34727)
+++ grass/trunk/vector/v.category/main.c 2008-12-04 20:20:07 UTC (rev 34728)
@@ -53,7 +53,7 @@
struct field_info *Fi;
struct cat_list *Clist;
int i, j, ret, option, otype, type, with_z, step, id;
- int n_areas, centr, new_centr;
+ int n_areas, centr, new_centr, nmodified;
double x, y;
int cat, ocat, *fields, nfields, field;
struct GModule *module;
@@ -82,7 +82,7 @@
option_opt->answer = "add";
option_opt->description = _("Action to be done");
option_opt->descriptions = _("add;add a new category;"
- "del;delete category;"
+ "del;delete category (-1 to delete all categories of given layer);"
"chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);"
"sum;add the value specified by cat option to the current category value;"
"report;print report (statistics), in shell style: layer type count min max;"
@@ -149,6 +149,10 @@
step = atoi(step_opt->answer);
otype = Vect_option_to_types(type_opt);
+ if (cat < 0 && option == O_ADD)
+ G_fatal_error(_("Invalid category number (must be equal to or greater than 0). "
+ "Normally category number starts at 1."));
/* collect ids */
if (id_opt->answer) {
Clist = Vect_new_cat_list();
@@ -214,6 +218,13 @@
id = 0;
+ nmodified = 0;
+ if (option == O_ADD || option == O_DEL || option == O_CHFIELD ||
+ option == O_SUM) {
+ G_message(_("Processing features..."));
switch (option) {
case (O_ADD):
/* Lines */
@@ -223,8 +234,12 @@
(Clist &&
Vect_cat_in_cat_list(id, Clist) == TRUE))) {
if ((Vect_cat_get(Cats, fields[0], &ocat)) == 0) {
- Vect_cat_set(Cats, fields[0], cat);
- cat += step;
+ if (ocat < 0) {
+ if (Vect_cat_set(Cats, fields[0], cat) > 0) {
+ nmodified++;
+ cat += step;
Vect_write_line(&Out, type, Points, Cats);
@@ -245,7 +260,9 @@
Vect_reset_line(Points);
Vect_reset_cats(Cats);
Vect_append_point(Points, x, y, 0.0);
+ nmodified++;
cat += step;
Vect_write_line(&Out, GV_CENTROID, Points, Cats);
new_centr++;
@@ -260,7 +277,10 @@
if (type & otype && (!Clist ||
(Clist &&
- ret = Vect_cat_del(Cats, fields[0]);
+ ret = Vect_field_cat_del(Cats, fields[0], cat);
+ if (ret == 1) {
+ nmodified++;
@@ -277,6 +297,7 @@
Cats->field[i] = fields[1];
+ nmodified++;
@@ -293,6 +314,7 @@
Cats->cat[i] += cat;
+ nmodified++;
@@ -344,6 +366,10 @@
fld = nfreps - 1;
freps[fld] = (FREPORT *) G_calloc(1, sizeof(FREPORT));
freps[fld]->field = field;
+ for (j = 0; j < FRTYPES; j++) {
+ /* cat '0' is valid category number */
+ freps[fld]->min[j] = -1;
if ((Fi = Vect_get_field(&In, field)) != NULL) {
freps[fld]->table = G_store(Fi->table);
@@ -355,7 +381,7 @@
freps[fld]->count[rtype]++;
freps[fld]->count[FR_ALL]++;
- if ((freps[fld]->min[rtype] == 0) ||
+ if (freps[fld]->min[rtype] == -1 ||
freps[fld]->min[rtype] > cat)
freps[fld]->min[rtype] = cat;
@@ -363,7 +389,7 @@
freps[fld]->max[rtype] < cat)
freps[fld]->max[rtype] = cat;
- if ((freps[fld]->min[FR_ALL] == 0) ||
+ if (freps[fld]->min[FR_ALL] == -1 ||
freps[fld]->min[FR_ALL] > cat)
freps[fld]->min[FR_ALL] = cat;
@@ -377,33 +403,37 @@
if (freps[i]->count[FR_POINT] > 0)
fprintf(stdout, "%d point %d %d %d\n", freps[i]->field,
freps[i]->count[FR_POINT],
- freps[i]->min[FR_POINT], freps[i]->max[FR_POINT]);
+ (freps[i]->min[FR_POINT] < 0 ? 0 : freps[i]->min[FR_POINT]),
+ freps[i]->max[FR_POINT]);
if (freps[i]->count[FR_LINE] > 0)
fprintf(stdout, "%d line %d %d %d\n", freps[i]->field,
- freps[i]->count[FR_LINE], freps[i]->min[FR_LINE],
+ freps[i]->count[FR_LINE],
+ (freps[i]->min[FR_LINE] < 0 ? 0 : freps[i]->min[FR_LINE]),
freps[i]->max[FR_LINE]);
if (freps[i]->count[FR_BOUNDARY] > 0)
fprintf(stdout, "%d boundary %d %d %d\n", freps[i]->field,
freps[i]->count[FR_BOUNDARY],
- freps[i]->min[FR_BOUNDARY],
+ (freps[i]->min[FR_BOUNDARY] < 0 ? 0 : freps[i]->min[FR_BOUNDARY]),
freps[i]->max[FR_BOUNDARY]);
if (freps[i]->count[FR_CENTROID] > 0)
fprintf(stdout, "%d centroid %d %d %d\n", freps[i]->field,
freps[i]->count[FR_CENTROID],
- freps[i]->min[FR_CENTROID],
freps[i]->max[FR_CENTROID]);
if (freps[i]->count[FR_AREA] > 0)
fprintf(stdout, "%d area %d %d %d\n", freps[i]->field,
- freps[i]->count[FR_AREA], freps[i]->min[FR_AREA],
+ freps[i]->count[FR_AREA],
+ (freps[i]->min[FR_AREA] < 0 ? 0 : freps[i]->min[FR_AREA]),
freps[i]->max[FR_AREA]);
if (freps[i]->count[FR_ALL] > 0)
fprintf(stdout, "%d all %d %d %d\n", freps[i]->field,
- freps[i]->count[FR_ALL], freps[i]->min[FR_ALL],
+ freps[i]->count[FR_ALL],
+ (freps[i]->min[FR_ALL] < 0 ? 0 : freps[i]->min[FR_ALL]),
freps[i]->max[FR_ALL]);
else {
@@ -414,27 +444,31 @@
else {
fprintf(stdout, "%s: %d\n", _("Layer"), freps[i]->field);
- fprintf(stdout, "type count min max\n");
- fprintf(stdout, "point %7d %10d %10d\n",
+ fprintf(stdout, _("type count min max\n"));
+ fprintf(stdout, "%s %7d %10d %10d\n", _("point"),
- fprintf(stdout, "line %7d %10d %10d\n",
+ (freps[i]->min[FR_POINT] < 0) ? 0 : freps[i]->min[FR_POINT],
+ fprintf(stdout, "%s %7d %10d %10d\n", _("line"),
- freps[i]->min[FR_LINE], freps[i]->max[FR_LINE]);
- fprintf(stdout, "boundary %7d %10d %10d\n",
+ (freps[i]->min[FR_LINE] < 0) ? 0 : freps[i]->min[FR_LINE],
+ freps[i]->max[FR_LINE]);
+ fprintf(stdout, "%s %7d %10d %10d\n", _("boundary"),
+ (freps[i]->min[FR_BOUNDARY] < 0) ? 0 : freps[i]->min[FR_BOUNDARY],
- fprintf(stdout, "centroid %7d %10d %10d\n",
+ fprintf(stdout, "%s %7d %10d %10d\n", _("centroid"),
+ (freps[i]->min[FR_CENTROID] < 0) ? 0 : freps[i]->min[FR_CENTROID],
- fprintf(stdout, "area %7d %10d %10d\n",
+ fprintf(stdout, "%s %7d %10d %10d\n", _("area"),
- freps[i]->min[FR_AREA], freps[i]->max[FR_AREA]);
- fprintf(stdout, "all %7d %10d %10d\n",
+ (freps[i]->min[FR_AREA] < 0) ? 0 : freps[i]->min[FR_AREA],
+ freps[i]->max[FR_AREA]);
+ fprintf(stdout, "%s %7d %10d %10d\n", _("all"),
- freps[i]->min[FR_ALL], freps[i]->max[FR_ALL]);
+ (freps[i]->min[FR_ALL] < 0) ? 0 : freps[i]->min[FR_ALL],
+ freps[i]->max[FR_ALL]);
break;
@@ -484,10 +518,13 @@
option == O_SUM) {
+ G_message(_("Copying attribute table(s)..."));
if (Vect_copy_tables(&In, &Out, 0))
G_warning(_("Failed to copy attribute table to output map"));
Vect_build(&Out);
Vect_close(&Out);
+ G_done_msg(_("%d features modified"), nmodified);
Vect_close(&In);
