[GRASS-SVN] r34740 - in grass/trunk: lib/gis raster/r.external
	raster/r.in.gdal
    svn_grass at osgeo.org
    Fri Dec  5 04:50:00 EST 2008
Author: glynn
Date: 2008-12-05 04:49:59 -0500 (Fri, 05 Dec 2008)
New Revision: 34740
   grass/trunk/lib/gis/G.h
   grass/trunk/lib/gis/gdal.c
   grass/trunk/lib/gis/get_row.c
   grass/trunk/raster/r.external/main.c
   grass/trunk/raster/r.in.gdal/main.c
Better handling of flipped/rotated maps
Modified: grass/trunk/lib/gis/G.h
--- grass/trunk/lib/gis/G.h	2008-12-05 09:36:49 UTC (rev 34739)
+++ grass/trunk/lib/gis/G.h	2008-12-05 09:49:59 UTC (rev 34740)
@@ -23,6 +23,8 @@
     char *filename;
     int band_num;
     DCELL null_val;
+    int hflip;
+    int vflip;
 #ifdef HAVE_GDAL
     GDALDatasetH data;
     GDALRasterBandH band;
Modified: grass/trunk/lib/gis/gdal.c
--- grass/trunk/lib/gis/gdal.c	2008-12-05 09:36:49 UTC (rev 34739)
+++ grass/trunk/lib/gis/gdal.c	2008-12-05 09:49:59 UTC (rev 34740)
@@ -150,6 +150,7 @@
     struct Key_Value *key_val;
     const char *p;
     DCELL null_val;
+    int hflip, vflip;
     if (!G_find_cell2(name, mapset))
 	return NULL;
@@ -186,6 +187,9 @@
     else
 	null_val = atof(p);
+    hflip = G_find_key_value("hflip", key_val) ? 1 : 0;
+    vflip = G_find_key_value("vflip", key_val) ? 1 : 0;
 #ifdef GDAL_LINK
     p = G_find_key_value("type", key_val);
     if (!p)
@@ -231,6 +235,8 @@
     gdal->filename = G_store(filename);
     gdal->band_num = band_num;
     gdal->null_val = null_val;
+    gdal->hflip = hflip;
+    gdal->vflip = vflip;
 #ifdef GDAL_LINK
     gdal->data = data;
     gdal->band = band;
Modified: grass/trunk/lib/gis/get_row.c
--- grass/trunk/lib/gis/get_row.c	2008-12-05 09:36:49 UTC (rev 34739)
+++ grass/trunk/lib/gis/get_row.c	2008-12-05 09:49:59 UTC (rev 34740)
@@ -208,14 +208,32 @@
 static int read_data_gdal(int fd, int row, unsigned char *data_buf, int *nbytes)
     struct fileinfo *fcb = &G__.fileinfo[fd];
+    unsigned char *buf;
     CPLErr err;
     *nbytes = fcb->nbytes;
+    if (fcb->gdal->vflip)
+	row = fcb->cellhd.rows - 1 - row;
+    buf = fcb->gdal->hflip
+	? G__alloca(fcb->cellhd.cols * fcb->cur_nbytes)
+	: data_buf;
     err = G_gdal_raster_IO(
-	fcb->gdal->band, GF_Read, 0, row, fcb->cellhd.cols, 1, data_buf,
+	fcb->gdal->band, GF_Read, 0, row, fcb->cellhd.cols, 1, buf,
 	fcb->cellhd.cols, 1, fcb->gdal->type, 0, 0);
+    if (fcb->gdal->hflip) {
+	int i;
+	for (i = 0; i < fcb->cellhd.cols; i++)
+	    memcpy(data_buf + i * fcb->cur_nbytes,
+		   buf + (fcb->cellhd.cols - 1 - i) * fcb->cur_nbytes,
+		   fcb->cur_nbytes);
+	G__freea(buf);
     return err == CE_None ? 0 : -1;
 #endif
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c	2008-12-05 09:36:49 UTC (rev 34739)
+++ grass/trunk/raster/r.external/main.c	2008-12-05 09:49:59 UTC (rev 34740)
@@ -42,6 +42,11 @@
     struct Colors colors;
+enum flip {
+    FLIP_H = 1,
+    FLIP_V = 2,
 static void list_formats(void)
@@ -183,7 +188,7 @@
-static void setup_window(struct Cell_head *cellhd, GDALDatasetH hDS)
+static void setup_window(struct Cell_head *cellhd, GDALDatasetH hDS, int *flip)
     /*      Set up the window representing the data we have.                */
@@ -196,19 +201,26 @@
     cellhd->cols = GDALGetRasterXSize(hDS);
     cellhd->cols3 = GDALGetRasterXSize(hDS);
-    if (GDALGetGeoTransform(hDS, adfGeoTransform) == CE_None &&
-	adfGeoTransform[5] < 0.0) {
+    if (GDALGetGeoTransform(hDS, adfGeoTransform) == CE_None) {
 	if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0)
 	    G_fatal_error(_("Input raster map is rotated - cannot import. "
 			    "You may use 'gdalwarp' to transform the map to North-up."));
+	if (adfGeoTransform[1] <= 0.0) {
+	    G_message(_("Applying horizontal flip"));
+	    *flip |= FLIP_H;
+	if (adfGeoTransform[5] >= 0.0) {
+	    G_message(_("Applying vertical flip"));
+	    *flip |= FLIP_V;
 	cellhd->north = adfGeoTransform[3];
 	cellhd->ns_res = fabs(adfGeoTransform[5]);
 	cellhd->ns_res3 = fabs(adfGeoTransform[5]);
 	cellhd->south = cellhd->north - cellhd->ns_res * cellhd->rows;
 	cellhd->west = adfGeoTransform[0];
-	cellhd->ew_res = adfGeoTransform[1];
-	cellhd->ew_res3 = adfGeoTransform[1];
+	cellhd->ew_res = fabs(adfGeoTransform[1]);
+	cellhd->ew_res3 = fabs(adfGeoTransform[1]);
 	cellhd->east = cellhd->west + cellhd->cols * cellhd->ew_res;
 	cellhd->top = 1.;
 	cellhd->bottom = 0.;
@@ -365,7 +377,7 @@
 static void make_link(const char *input, const char *output, int band,
-		      const struct band_info *info)
+		      const struct band_info *info, int flip)
     struct Key_Value *key_val = G_create_key_value();
     char null_str[256], type_str[8], band_str[8];
@@ -388,6 +400,10 @@
     G_set_key_value("band", band_str, key_val);
     G_set_key_value("null", null_str, key_val);
     G_set_key_value("type", type_str, key_val);
+    if (flip & FLIP_H)
+	G_set_key_value("hflip", "yes", key_val);
+    if (flip & FLIP_V)
+	G_set_key_value("vflip", "yes", key_val);
     fp = G_fopen_new_misc("cell_misc", "gdal", output);
     if (!fp)
@@ -440,7 +456,7 @@
 static void create_map(const char *input, int band, const char *output,
 		       struct Cell_head *cellhd, struct band_info *info,
-		       const char *title)
+		       const char *title, int flip)
     struct History history;
@@ -448,7 +464,7 @@
     make_cell(output, info);
-    make_link(input, output, band, info);
+    make_link(input, output, band, info, flip);
     if (info->data_type == CELL_TYPE) {
 	struct Range range;
@@ -495,9 +511,10 @@
     struct {
 	struct Option *input, *source, *output, *band, *title;
     } parm;
-    struct Flag *flag_o, *flag_f, *flag_e, *flag_r;
+    struct Flag *flag_o, *flag_f, *flag_e, *flag_r, *flag_h, *flag_v;
     int band;
     struct band_info info;
+    int flip;
     G_gisinit(argv[0]);
@@ -554,6 +571,14 @@
     flag_f->description = _("List supported formats and exit");
     flag_f->guisection = _("Print");
+    flag_h = G_define_flag();
+    flag_h->key = 'h';
+    flag_h->description = _("Flip horizontally");
+    flag_v = G_define_flag();
+    flag_v->key = 'v';
+    flag_v->description = _("Flip vertically");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -568,6 +593,12 @@
     source = parm.source->answer;
     output = parm.output->answer;
+    flip = 0;
+    if (flag_h->answer)
+	flip |= FLIP_H;
+    if (flag_v->answer)
+	flip |= FLIP_V;
     if (parm.title->answer) {
 	title = G_store(parm.title->answer);
 	G_strip(title);
@@ -604,7 +635,7 @@
     if (hDS == NULL)
 	return 1;
-    setup_window(&cellhd, hDS);
+    setup_window(&cellhd, hDS, &flip);
     check_projection(&cellhd, hDS, flag_o->answer);
@@ -619,7 +650,7 @@
 	G_fatal_error(_("Unable to set window"));
     query_band(hBand, output, flag_r->answer, &cellhd, &info);
-    create_map(input, band, output, &cellhd, &info, title);
+    create_map(input, band, output, &cellhd, &info, title, flip);
     if (flag_e->answer)
 	update_default_window(&cellhd);
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2008-12-05 09:36:49 UTC (rev 34739)
+++ grass/trunk/raster/r.in.gdal/main.c	2008-12-05 09:49:59 UTC (rev 34740)
@@ -237,19 +237,18 @@
     cellhd.cols = GDALGetRasterXSize(hDS);
     cellhd.cols3 = GDALGetRasterXSize(hDS);
-	&& adfGeoTransform[5] < 0.0) {
-	if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0)
-	    G_fatal_error(_("Input raster map is rotated - cannot import. "
+	if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0 ||
+	    adfGeoTransform[1] <= 0.0 || adfGeoTransform[5] >= 0.0)
+	    G_fatal_error(_("Input raster map is flipped or rotated - cannot import. "
 	cellhd.north = adfGeoTransform[3];
 	cellhd.ns_res = fabs(adfGeoTransform[5]);
 	cellhd.ns_res3 = fabs(adfGeoTransform[5]);
 	cellhd.south = cellhd.north - cellhd.ns_res * cellhd.rows;
 	cellhd.west = adfGeoTransform[0];
-	cellhd.ew_res = adfGeoTransform[1];
-	cellhd.ew_res3 = adfGeoTransform[1];
+	cellhd.ew_res = fabs(adfGeoTransform[1]);
+	cellhd.ew_res3 = fabs(adfGeoTransform[1]);
 	cellhd.east = cellhd.west + cellhd.cols * cellhd.ew_res;
 	cellhd.top = 1.;
 	cellhd.bottom = 0.;
