[GRASS-SVN] r34758 - in grass/branches/develbranch_6:
gui/wxpython/gui_modules vector/v.distance
svn_grass at osgeo.org
Sat Dec 6 15:34:54 EST 2008
Author: martinl
Date: 2008-12-06 15:34:54 -0500 (Sat, 06 Dec 2008)
New Revision: 34758
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/vector/v.distance/main.c
v.distance: paramaters description cosmetics
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-12-06 19:58:26 UTC (rev 34757)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-12-06 20:34:54 UTC (rev 34758)
@@ -1219,9 +1219,14 @@
win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
win.Bind(wx.EVT_TEXT, self.OnSetValue)
elif p.get('prompt', '') == 'dbtable':
- win = gselect.TableSelect(parent=which_panel)
- p['wxGetValue'] = win.GetStringSelection
- win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+ if p.get('age', 'old_dbtable') == 'old_dbtable':
+ win = gselect.TableSelect(parent=which_panel)
+ p['wxGetValue'] = win.GetStringSelection
+ win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+ else:
+ win = wx.TextCtrl(parent=which_panel, value = p.get('default',''),
+ size=globalvar.DIALOG_TEXTCTRL_SIZE)
+ win.Bind(wx.EVT_TEXT, self.OnSetValue)
elif p.get('prompt', '') == 'dbcolumn':
win = gselect.ColumnSelect(parent=which_panel)
Modified: grass/branches/develbranch_6/vector/v.distance/main.c
--- grass/branches/develbranch_6/vector/v.distance/main.c 2008-12-06 19:58:26 UTC (rev 34757)
+++ grass/branches/develbranch_6/vector/v.distance/main.c 2008-12-06 20:34:54 UTC (rev 34758)
@@ -118,37 +118,37 @@
from_opt = G_define_standard_option(G_OPT_V_INPUT);
from_opt->key = "from";
- from_opt->description = _("Name of existing vector map");
- from_opt->guisection = _("From_map");
+ from_opt->description = _("Name of existing vector map (from)");
+ from_opt->guisection = _("From");
to_opt = G_define_standard_option(G_OPT_V_INPUT);
to_opt->key = "to";
- to_opt->description = _("Name of existing vector map");
- to_opt->guisection = _("To_map");
+ to_opt->description = _("Name of existing vector map (to)");
+ to_opt->guisection = _("To");
from_type_opt = G_define_standard_option(G_OPT_V_TYPE);
from_type_opt->key = "from_type";
from_type_opt->options = "point,centroid";
from_type_opt->answer = "point";
- from_type_opt->label = _("From type");
- from_type_opt->guisection = _("From_map");
+ from_type_opt->label = _("Feature type (from)");
+ from_type_opt->guisection = _("From");
to_type_opt = G_define_standard_option(G_OPT_V_TYPE);
to_type_opt->key = "to_type";
to_type_opt->options = "point,line,boundary,centroid,area";
to_type_opt->answer = "point,line,area";
- to_type_opt->label = _("To type");
- to_type_opt->guisection = _("To_map");
+ to_type_opt->label = _("Feature type (to)");
+ to_type_opt->guisection = _("To");
from_field_opt = G_define_standard_option(G_OPT_V_FIELD);
from_field_opt->key = "from_layer";
- from_field_opt->label = _("From layer");
- from_field_opt->guisection = _("From_map");
+ from_field_opt->label = _("Layer number (from)");
+ from_field_opt->guisection = _("From");
to_field_opt = G_define_standard_option(G_OPT_V_FIELD);
to_field_opt->key = "to_layer";
- to_field_opt->label = _("To layer");
- to_field_opt->guisection = _("To_map");
+ to_field_opt->label = _("Layer number (to)");
+ to_field_opt->guisection = _("To");
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
out_opt->key = "output";
@@ -204,9 +204,10 @@
to_column_opt->key = "to_column";
to_column_opt->description =
_("Column name of nearest feature (used with upload=to_attr)");
- to_column_opt->guisection = _("To_map");
+ to_column_opt->guisection = _("To");
table_opt = G_define_standard_option(G_OPT_TABLE);
+ table_opt->gisprompt = "new_dbtable,dbtable,dbtable";
table_opt->description =
_("Name of table created for output when the distance to all flag is used");
