[GRASS-SVN] r34774 - grass/branches/develbranch_6/lib/gis
svn_grass at osgeo.org
Sun Dec 7 05:22:25 EST 2008
Author: martinl
Date: 2008-12-07 05:22:25 -0500 (Sun, 07 Dec 2008)
New Revision: 34774
grass/branches/develbranch_6/lib/gis/percent.c
G_percent() doxygen string updated
Modified: grass/branches/develbranch_6/lib/gis/percent.c
--- grass/branches/develbranch_6/lib/gis/percent.c 2008-12-07 10:16:21 UTC (rev 34773)
+++ grass/branches/develbranch_6/lib/gis/percent.c 2008-12-07 10:22:25 UTC (rev 34774)
@@ -36,20 +36,29 @@
int nrows;
nrows = 1352; // 1352 is not a special value - example only
- fprintf (stderr, "Percent complete: ");
+ G_message(_("Percent complete..."));
for (row = 0; row < nrows; row++)
- G_percent (row, nrows, 10);
+ G_percent (row+1, nrows, 10);
\endcode
* This will print completion messages at 10% increments; i.e., 10%, 20%, 30%,
* etc., up to 100%. Each message does not appear on a new line, but rather erases
- * the previous message. After 100%, a new line is printed.
+ * the previous message.
+ * G_percent() should stay at the start of the for loop. If the loop takes
+ * a long time to run, 0% should print before the first iteration has begun,
+ * and final 100% message in loop should not be printed before the last
+ * iteration is complete. Otherwise it seems to stall at 99% done, etc.
- * \param[in] n current element
- * \param[in] d total number of elements
- * \param[in] s increment size
+ * \param n current element
+ * \param d total number of elements
+ * \param s increment size
* \return always returns 0
@@ -64,29 +73,15 @@
* This routine prints a percentage complete message to stderr. The
* percentage complete is <i>(<b>n</b>/<b>d</b>)*100</i>, and these are
- * printed only for each <b>s</b> percentage. This is perhaps best
- * explained by example:
-\code
- #include <stdio.h>
- #include <grass/gis.h>
- int row;
- int nrows;
- nrows = 1352; // 1352 is not a special value - example only
- for (row = 0; row < nrows; row++)
-\endcode
- * This will print completion messages at 10% increments; i.e., 10%, 20%, 30%,
- * etc., up to 100%. Each message does not appear on a new line, but rather erases
+ * printed only for each <b>s</b> percentage.
- * \param[in,out] out file to print to
+ * See G_percent() for details.
+ * \param[out] out file to print to
