[GRASS-SVN] r34788 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Mon Dec 8 01:36:10 EST 2008
Author: glynn
Date: 2008-12-08 01:36:09 -0500 (Mon, 08 Dec 2008)
New Revision: 34788
grass/trunk/gui/wxpython/
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/gui_modules/menudata.py
Generate dummy Python file containing menu strings for translation
Property changes on: grass/trunk/gui/wxpython
___________________________________________________________________
+ menustrings.py
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2008-12-07 19:41:20 UTC (rev 34787)
+++ grass/trunk/gui/wxpython/Makefile 2008-12-08 06:36:09 UTC (rev 34788)
@@ -17,6 +17,7 @@
if [ ! -d $(ETCDIR)/$$dir ] ; then $(MKDIR) $(ETCDIR)/$$dir ; fi ; \
done
$(MAKE) $(DSTFILES)
+ $(MAKE) menustrings.py
$(ETCDIR)/scripts/wxgui: wxgui
$(INSTALL) $< $@
@@ -27,3 +28,5 @@
$(ETCDIR)/%: %
$(INSTALL_DATA) $< $@
+menustrings.py: gui_modules/menudata.py xml/menudata.xml
+ python $< > $@
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-12-07 19:41:20 UTC (rev 34787)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-12-08 06:36:09 UTC (rev 34788)
@@ -25,6 +25,9 @@
class Data:
'''Data object that returns menu descriptions to be used in wxgui.py.'''
+ def __init__(self):
+ filename = os.getenv('GISBASE') + '/etc/wxpython/xml/menudata.xml'
+ self.tree = etree.parse(filename)
def getMenuItem(self, mi):
if mi.tag == 'separator':
@@ -56,6 +59,15 @@
return list(map(self.getMenuBar, md.findall('menubar')))
def GetMenu(self):
- filename = os.getenv('GISBASE') + '/etc/wxpython/xml/menudata.xml'
- tree = etree.parse(filename)
- return self.getMenuData(tree.getroot())
+ return self.getMenuData(self.tree.getroot())
+ def PrintStrings(self, fh):
+ fh.write('menustrings = [\n')
+ for node in self.tree.getiterator():
+ if node.tag in ['label', 'help']:
+ fh.write(' _(%r),\n' % node.text)
+ fh.write(' \'\']\n')
+if __name__ == "__main__":
+ import sys
+ Data().PrintStrings(sys.stdout)
