[GRASS-SVN] r34800 - grass/trunk/imagery/i.maxlik
svn_grass at osgeo.org
Mon Dec 8 07:32:04 EST 2008
Author: martinl
Date: 2008-12-08 07:32:03 -0500 (Mon, 08 Dec 2008)
New Revision: 34800
grass/trunk/imagery/i.maxlik/invert.c
grass/trunk/imagery/i.maxlik/main.c
grass/trunk/imagery/i.maxlik/open.c
i.maxlik: message standardization
(merge from devbr6, r34799)
Modified: grass/trunk/imagery/i.maxlik/invert.c
--- grass/trunk/imagery/i.maxlik/invert.c 2008-12-08 12:29:36 UTC (rev 34799)
+++ grass/trunk/imagery/i.maxlik/invert.c 2008-12-08 12:32:03 UTC (rev 34800)
@@ -25,10 +25,10 @@
stat = invert(s = &S.sig[c], S.nbands, ik, jk, &det);
if (stat != 1) {
if (stat)
- G_warning(_("signature %d is not valid (ill-conditioned) - ignored."),
+ G_warning(_("Signature %d is not valid (ill-conditioned) - ignored"),
c + 1);
else
- G_warning(_("signature %d is not valid (singular) - ignored."),
+ G_warning(_("Signature %d is not valid (singular) - ignored"),
c + 1);
bad = 1;
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c 2008-12-08 12:29:36 UTC (rev 34799)
+++ grass/trunk/imagery/i.maxlik/main.c 2008-12-08 12:32:03 UTC (rev 34800)
@@ -11,7 +11,7 @@
* Glynn Clements <glynn gclements.plus.com>,
* Jan-Oliver Wagner <jan intevation.de>
* PURPOSE: maximum likelihood classification of image groups
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -60,7 +60,7 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("imagery");
+ module->keywords = _("imagery, classification");
module->label =
_("Classifies the cell spectral reflectances in imagery data.");
module->description =
@@ -68,33 +68,29 @@
"generated by either i.cluster, i.class, or i.gensig.");
parm.group = G_define_standard_option(G_OPT_I_GROUP);
- parm.group->description = _("Imagery group to be classified");
parm.subgroup = G_define_option();
parm.subgroup->key = "subgroup";
parm.subgroup->type = TYPE_STRING;
parm.subgroup->required = YES;
- parm.subgroup->description =
- _("Subgroup containing image files to be classified");
+ parm.subgroup->description = _("Name of subgroup in the above group");
- parm.sigfile = G_define_option();
+ parm.sigfile = G_define_standard_option(G_OPT_F_INPUT);
parm.sigfile->key = "sigfile";
- parm.sigfile->type = TYPE_STRING;
parm.sigfile->required = YES;
- parm.sigfile->description = _("Signatures to use for classification");
+ parm.sigfile->label = _("Name of file containing signatures");
+ parm.sigfile->description = _("Generated by either i.cluster, i.class, or i.gensig");
- parm.class = G_define_option();
+ parm.class = G_define_standard_option(G_OPT_R_OUTPUT);
parm.class->key = "class";
- parm.class->type = TYPE_STRING;
parm.class->required = YES;
- parm.class->description = _("Raster map to hold classification results");
+ parm.class->description = _("Name for raster map holding classification results");
- parm.reject = G_define_option();
+ parm.reject = G_define_standard_option(G_OPT_R_OUTPUT);
parm.reject->key = "reject";
- parm.reject->type = TYPE_STRING;
parm.reject->required = NO;
parm.reject->description =
- _("Raster map to hold reject threshold results");
+ _("Name for raster map holding reject threshold results");
flag.quiet = G_define_flag();
flag.quiet->key = 'q';
@@ -115,25 +111,20 @@
nrows = G_window_rows();
ncols = G_window_cols();
- if (!flag.quiet->answer)
- fprintf(stderr, "%s ... ", G_program_name());
for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
+ G_percent(row+1, nrows, 2);
for (band = 0; band < Ref.nfiles; band++)
- if (G_get_d_raster_row(cellfd[band], cell[band], row) < 0) /*fixed 11/99 */
- exit(EXIT_FAILURE);
+ if (G_get_d_raster_row(cellfd[band], cell[band], row) < 0)
+ G_fatal_error(_("Unable to read raster map row %d"),
+ row);
classify(class_cell, reject_cell, ncols);
G_put_raster_row(class_fd, class_cell, CELL_TYPE);
if (reject_fd > 0)
G_put_raster_row(reject_fd, reject_cell, CELL_TYPE);
G_close_cell(class_fd);
if (reject_fd > 0)
G_close_cell(reject_fd);
@@ -191,6 +182,5 @@
I_put_group_ref(group, &group_ref);
make_history(class_name, group, subgroup, sigfile);
exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.maxlik/open.c
--- grass/trunk/imagery/i.maxlik/open.c 2008-12-08 12:29:36 UTC (rev 34799)
+++ grass/trunk/imagery/i.maxlik/open.c 2008-12-08 12:32:03 UTC (rev 34800)
@@ -13,21 +13,21 @@
I_init_group_ref(&Ref);
if (!I_find_group(group))
- G_fatal_error(_("group=[%s] - not found."), group);
+ G_fatal_error(_("Group <%s> not found"), group);
if (!I_find_subgroup(group, subgroup))
- G_fatal_error(_("subgroup=[%s] (of group [%s]) - not found."),
+ G_fatal_error(_("Subgroup <%s> in group <%s> not found"),
subgroup, group);
I_get_subgroup_ref(group, subgroup, &Ref);
if (Ref.nfiles <= 1) {
if (Ref.nfiles <= 0)
- G_fatal_error(_("Subgroup [%s] of group [%s] doesn't have any files.\n"
- "The subgroup must have at least 2 files."));
+ G_fatal_error(_("Subgroup <%s> of group <%s> doesn't have any raster maps. "
+ "The subgroup must have at least 2 raster maps."));
else
- G_fatal_error(_("Subgroup [%s] of group [%s] only has 1 file.\n"
+ G_fatal_error(_("Subgroup <%s> of group <%s> only has 1 raster map. "
cell = (DCELL **) G_malloc(Ref.nfiles * sizeof(DCELL *));
@@ -38,21 +38,25 @@
name = Ref.file[n].name;
mapset = Ref.file[n].mapset;
if ((cellfd[n] = G_open_cell_old(name, mapset)) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"),
+ G_fully_qualified_name(name, mapset));
I_init_signatures(&S, Ref.nfiles);
fd = I_fopen_signature_file_old(group, subgroup, sigfile);
if (fd == NULL)
+ G_fatal_error(_("Unable to open signature file <%s>"),
+ sigfile);
n = I_read_signatures(fd, &S);
fclose(fd);
if (n < 0)
- G_fatal_error(_("Can't read signature file [%s]."), sigfile);
+ G_fatal_error(_("Unable to read signature file <%s>"),
+ sigfile);
if (S.nsigs > 255)
- G_fatal_error(_("[%s] has more than 255 signatures."), sigfile);
+ G_fatal_error(_("<%s> has too many signatures (limit is 255)"),
+ sigfile);
B = (double *)G_malloc(S.nsigs * sizeof(double));
invert_signatures();
@@ -67,7 +71,7 @@
if (reject_name) {
reject_fd = G_open_cell_new(reject_name);
if (reject_fd < 0)
- G_fatal_error(_("Unable to create reject layer [%s]."),
+ G_fatal_error(_("Unable to create raster map <%s>"),
reject_name);
else
reject_cell = G_allocate_cell_buf();
