[GRASS-SVN] r34813 -
grass/branches/develbranch_6/scripts/v.db.addcol
svn_grass at osgeo.org
Tue Dec 9 07:45:07 EST 2008
Author: neteler
Date: 2008-12-09 07:45:06 -0500 (Tue, 09 Dec 2008)
New Revision: 34813
grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
reverted r34809
Modified: grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
--- grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2008-12-09 11:38:19 UTC (rev 34812)
+++ grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2008-12-09 12:45:06 UTC (rev 34813)
@@ -99,15 +99,7 @@
while [ "$n" -le "$colnum" ]
do
col=`echo $GIS_OPT_COLUMNS | cut -d',' -f$n`
- # trap odd column definitions
- COLPAIRS=`echo $col | tr ',' '\n' | wc -l | awk '{print $1 * 2}'`
- TOKENS=`echo $col | tr ' ' '\n' | wc -l | awk '{print $1}'`
- if [ $COLPAIRS -ne $TOKENS ] ; then
- g.message -e 'Column definitions are not comma separated or incorrect'
- exit 1
- fi
if [ -z "$col" ] ; then
g.message -e 'There is an empty column! Did you leave a trailing comma?'
exit 1
