[GRASS-SVN] r34817 - in grass/trunk: raster/r.clump
raster/r.surf.idw scripts/r.reclass.area
svn_grass at osgeo.org
Tue Dec 9 11:55:00 EST 2008
Author: martinl
Date: 2008-12-09 11:55:00 -0500 (Tue, 09 Dec 2008)
New Revision: 34817
grass/trunk/raster/r.clump/clump.c
grass/trunk/raster/r.clump/main.c
grass/trunk/raster/r.surf.idw/main.c
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
message standardization
(merge from devbr6, r34816)
Modified: grass/trunk/raster/r.clump/clump.c
--- grass/trunk/raster/r.clump/clump.c 2008-12-09 16:43:52 UTC (rev 34816)
+++ grass/trunk/raster/r.clump/clump.c 2008-12-09 16:55:00 UTC (rev 34817)
@@ -18,8 +18,8 @@
#include <time.h>
#include <grass/gis.h>
+#include <grass/glocale.h>
#include "local_proto.h"
-#include <grass/glocale.h>
#define INCR 1024
@@ -95,13 +95,13 @@
/* initialize clump labels */
label = 0;
- G_message(_("CLUMP PASS %d ... "), pass);
- fflush(stderr);
+ G_message(_("Pass %d..."), pass);
for (row = 0; row < nrows; row++) {
if (G_get_map_row(in_fd, cur_in + 1, row) < 0)
- G_fatal_error(_("Unable to properly read input raster map"));
- G_percent(row, nrows, 2);
+ G_fatal_error(_("Unable to read raster map row %d "),
+ row);
+ G_percent(row+1, nrows, 2);
X = 0;
for (col = 1; col <= ncols; col++) {
LEFT = X;
@@ -235,7 +235,8 @@
G_set_null_value(&out_cell[column], 1, CELL_TYPE);
if (G_put_raster_row(out_fd, out_cell, CELL_TYPE) < 0)
- G_fatal_error(_("Unable to properly write output raster map"));
+ G_fatal_error(_("Failed writing raster map row %d"),
+ row);
/* switch the buffers so that the current buffer becomes the previous */
@@ -247,9 +248,8 @@
cur_clump = prev_clump;
prev_clump = temp_clump;
print_time(&cur_time);
return 0;
@@ -269,11 +269,11 @@
seconds = seconds % 60;
if (hours)
- G_message("%2d:%02d:%02d", hours, minutes, seconds);
+ G_verbose_message("%2d:%02d:%02d", hours, minutes, seconds);
else if (minutes)
- G_message("%d:%02d", minutes, seconds);
+ G_verbose_message("%d:%02d", minutes, seconds);
else
- G_message("%d seconds", seconds);
+ G_verbose_message("%d seconds", seconds);
return 0;
Modified: grass/trunk/raster/r.clump/main.c
--- grass/trunk/raster/r.clump/main.c 2008-12-09 16:43:52 UTC (rev 34816)
+++ grass/trunk/raster/r.clump/main.c 2008-12-09 16:55:00 UTC (rev 34817)
@@ -8,7 +8,7 @@
* PURPOSE: Recategorizes data in a raster map layer by grouping cells
* that form physically discrete areas into unique categories.
- * COPYRIGHT: (C) 2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -19,10 +19,9 @@
#include <stdlib.h>
#include <string.h>
int main(int argc, char *argv[])
struct Colors colr;
@@ -43,9 +42,9 @@
/* Define the different options */
module = G_define_module();
- module->keywords = _("raster");
+ module->keywords = _("raster, statistics, reclass");
module->description =
- _("Recategorizes data in a raster map layer by grouping cells "
+ _("Recategorizes data in a raster map by grouping cells "
"that form physically discrete areas into unique categories.");
opt_in = G_define_standard_option(G_OPT_R_INPUT);
@@ -77,7 +76,7 @@
clump(in_fd, out_fd);
- G_message(_("Creating support files..."));
+ G_debug(1, "Creating support files...");
G_close_cell(in_fd);
G_close_cell(out_fd);
@@ -87,14 +86,15 @@
if (opt_title->answer != NULL)
strcpy(title, opt_title->answer);
else
- sprintf(title, "clump of %s", name);
+ sprintf(title, "clump of <%s@%s>", name, mapset);
G_put_cell_title(OUTPUT, title);
G_read_range(OUTPUT, G_mapset(), &range);
G_get_range_min_max(&range, &min, &max);
G_make_random_colors(&colr, min, max);
G_write_colors(OUTPUT, G_mapset(), &colr);
- G_message(_("%d clumps"), range.max);
+ G_done_msg(_("%d clumps."), range.max);
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.surf.idw/main.c
--- grass/trunk/raster/r.surf.idw/main.c 2008-12-09 16:43:52 UTC (rev 34816)
+++ grass/trunk/raster/r.surf.idw/main.c 2008-12-09 16:55:00 UTC (rev 34817)
@@ -13,7 +13,7 @@
* Radim Blazek <radim.blazek gmail.com>
* PURPOSE: spatial interpolation based on distance squared weighting of
* the values of nearest irregularly spaced data points
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
@@ -36,7 +36,6 @@
#include <math.h>
#include "main.h"
struct Cell_head window;
@@ -100,9 +99,9 @@
G_gisinit(argv[0]);
+ module->keywords = _("raster, interpolation");
- _("Surface interpolation utility for raster map layers.");
+ _("Surface interpolation utility for raster map.");
parm.input = G_define_standard_option(G_OPT_R_INPUT);
@@ -123,7 +122,7 @@
exit(EXIT_FAILURE);
if (sscanf(parm.npoints->answer, "%d", &n) != 1 || n <= 0)
- G_fatal_error(_("%s=%s - illegal value"), parm.npoints->key,
+ G_fatal_error(_("Illegal value for '%s' (%s)"), parm.npoints->key,
parm.npoints->answer);
npoints = n;
@@ -184,7 +183,8 @@
G_command_history(&history);
G_write_history(output, &history);
- G_done_msg("");
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
@@ -252,11 +252,11 @@
nbr_head->searchptr = &(nbr_head->Mptr); /* see replace_neighbor */
#endif
- G_message(_("Interpolating raster map <%s>... %d rows... "), output,
+ G_message(_("Interpolating raster map <%s> (%d rows)..."), output,
nrows);
for (row = 0; row < nrows; row++) { /* loop over rows */
/* if mask occurs, read current row of the mask */
if (mask && G_get_map_row(maskfd, mask, row) < 0)
@@ -704,12 +704,13 @@
/* enter data by allocation of individual matrix elements */
*npts = 0;
- fprintf(stderr, "Reading %s...", input);
+ G_message(_("Reading raster map <%s>..."), input);
for (row = 0, Rptr = rowlist; row < rows; row++) {
- G_percent(row, rows, 1);
+ G_percent(row+1, rows, 2);
if (G_get_map_row_nomask(fd, cell, row) < 0)
- G_fatal_error(_("Cannot read row"));
+ G_fatal_error(_("Unable to read raster map row %d"),
+ row);
for (col = 0; col < cols; col++) {
if (cell[col] != 0) {
@@ -728,7 +729,7 @@
if (Rptr->prior != Rptr) /* non-zero input data in this row */
Rptr++->y = row;
} /* loop over rows */
endlist = Rptr; /* point to element after last valid row list dummy */
/* add final link to complete doubly-linked lists */
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2008-12-09 16:43:52 UTC (rev 34816)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2008-12-09 16:55:00 UTC (rev 34817)
@@ -21,33 +21,36 @@
# 1998 from NRCS, slightly modified for GRASS 4.2.1
#%Module
-#% description: Reclasses a raster map greater or less than user specified area size (in hectares)
+#% description: Reclasses a raster map greater or less than user specified area size (in hectares).
#% keywords: raster, statistics, aggregation
#%End
#%option
#% key: input
#% type: string
#% gisprompt: old,cell,raster
-#% description: raster input map
+#% description: Name of input raster map
#% required : yes
#%END
#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Name for output raster map
+#% required : yes
+#%END
+#%option
#% key: lesser
#% type: double
-#% description: lesser val option that sets the <= area size limit [hectares]
+#% description: Lesser value option that sets the <= area size limit [hectares]
#%END
#%option
#% key: greater
#% type: double
-#% description: greater val option that sets the >= area size limit [hectares]
+#% description: Greater value option that sets the >= area size limit [hectares]
#%END
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% description: reclass raster output map
-#% required : yes
-#%END
import sys
import os
@@ -63,11 +66,11 @@
kv = grass.parse_key_val(s, sep = ':')
s = kv['projection'].strip().split()
if s == '0':
- grass.fatal("xy-locations are not supported.")
- grass.fatal("Need projected data with grids in meters.")
+ grass.fatal("xy-locations are not supported")
+ grass.fatal("Need projected data with grids in meters")
if not lesser and not greater:
- grass.fatal("you have to specify either lesser= or greater=")
+ grass.fatal("You have to specify either lesser= or greater=")
if lesser and greater:
grass.fatal("lesser= and greater= are mutually exclusive")
if lesser:
@@ -76,21 +79,21 @@
limit = float(greater)
if not grass.find_file(infile)['name']:
- grass.fatal("Raster map <%s> does not exist." % infile)
+ grass.fatal("Raster map <%s> not found" % infile)
clumpfile = "%s.clump.%s" % (infile.split('@')[0], outfile)
if not grass.overwrite():
if grass.find_file(clumpfile)['name']:
- grass.fatal("Temporary raster map <%s> exists." % clumpfile)
+ grass.fatal("Temporary raster map <%s> exists" % clumpfile)
grass.message("Generating a clumped raster file ...")
grass.run_command('r.clump', input = infile, output = clumpfile)
if lesser:
- grass.message("Generating a reclass map with area size less than or equal to %f hectares" % limit)
+ grass.message("Generating a reclass map with area size less than or equal to %f hectares..." % limit)
else:
- grass.message("Generating a reclass map with area size greater than or equal to %f hectares" % limit)
+ grass.message("Generating a reclass map with area size greater than or equal to %f hectares..." % limit)
recfile = outfile + '.recl'
@@ -111,7 +114,7 @@
p2.stdin.close()
p2.wait()
- grass.message("Written: %s" % outfile)
+ grass.message("Generating output raster map <$outfile>..." % outfile)
grass.mapcalc("$outfile = $recfile", outfile = outfile, recfile = recfile)
grass.run_command('g.remove', rast = [recfile, clumpfile], quiet = True)
