[GRASS-SVN] r34822 - in grass/trunk: general/g.mlist raster/r.patch
raster/r.series scripts/v.dissolve
svn_grass at osgeo.org
Wed Dec 10 18:39:46 EST 2008
Author: hamish
Date: 2008-12-10 18:39:46 -0500 (Wed, 10 Dec 2008)
New Revision: 34822
grass/trunk/general/g.mlist/g.mlist.html
grass/trunk/general/g.mlist/main.c
grass/trunk/raster/r.patch/r.patch.html
grass/trunk/raster/r.series/r.series.html
grass/trunk/scripts/v.dissolve/v.dissolve.html
revert r34818, separator= is preferred
Modified: grass/trunk/general/g.mlist/g.mlist.html
--- grass/trunk/general/g.mlist/g.mlist.html 2008-12-10 15:13:06 UTC (rev 34821)
+++ grass/trunk/general/g.mlist/g.mlist.html 2008-12-10 23:39:46 UTC (rev 34822)
@@ -66,7 +66,7 @@
Print out "tmp0" ..."tmp9" if corresponding vector map exists (each map name comma separated):
<div class="code"><pre>
- g.mlist -r type=vect fs=, pattern='^tmp[0-9]$'
+ g.mlist -r type=vect separator=, pattern='^tmp[0-9]$'
</pre></div>
This may be useful for other programs' parameter input
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2008-12-10 15:13:06 UTC (rev 34821)
+++ grass/trunk/general/g.mlist/main.c 2008-12-10 23:39:46 UTC (rev 34822)
@@ -103,10 +103,14 @@
opt.exclude->multiple = NO;
opt.exclude->description = _("Map name exclusion pattern (default: none)");
- opt.separator = G_define_standard_option(G_OPT_F_SEP);
+ opt.separator = G_define_option();
+ opt.separator->key = "separator";
+ opt.separator->type = TYPE_STRING;
+ opt.separator->required = NO;
+ opt.separator->multiple = NO;
opt.separator->answer = "newline";
opt.separator->description =
- _("One-character output field separator, newline, comma, space, or tab");
+ _("One-character output separator, newline, comma, space, or tab");
opt.mapset = G_define_option();
opt.mapset->key = "mapset";
Modified: grass/trunk/raster/r.patch/r.patch.html
--- grass/trunk/raster/r.patch/r.patch.html 2008-12-10 15:13:06 UTC (rev 34821)
+++ grass/trunk/raster/r.patch/r.patch.html 2008-12-10 23:39:46 UTC (rev 34822)
@@ -89,7 +89,7 @@
used in the order listed.
-MAPS=`g.mlist type=rast fs=, pat="map_*"`
+MAPS=`g.mlist type=rast sep=, pat="map_*"`
g.region rast=$MAPS
r.patch in=$MAPS out=mosaic
</pre></div>
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html 2008-12-10 15:13:06 UTC (rev 34821)
+++ grass/trunk/raster/r.series/r.series.html 2008-12-10 23:39:46 UTC (rev 34822)
@@ -55,7 +55,7 @@
Using <em>r.series</em> with wildcards:
<br>
-r.series input="`g.mlist pattern='insitu_data.*' fs=,`"
+r.series input="`g.mlist pattern='insitu_data.*' sep=,`"
output=insitu_data.stddev method=stddev
</pre></div>
<p>
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.html
--- grass/trunk/scripts/v.dissolve/v.dissolve.html 2008-12-10 15:13:06 UTC (rev 34821)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.html 2008-12-10 23:39:46 UTC (rev 34822)
@@ -52,7 +52,7 @@
# patch tiles after import:
-v.patch -e `g.mlist type=vect pat="clc2000_*" fs=,` out=clc2000_patched
+v.patch -e `g.mlist type=vect pat="clc2000_*" sep=,` out=clc2000_patched
# remove duplicated tile boundaries:
v.clean clc2000_patched out=clc2000_clean tool=snap,break,rmdupl thresh=.01
