[GRASS-SVN] r34824 - grass-addons/raster/r.viewshed
svn_grass at osgeo.org
Thu Dec 11 03:07:02 EST 2008
Author: hamish
Date: 2008-12-11 03:07:02 -0500 (Thu, 11 Dec 2008)
New Revision: 34824
grass-addons/raster/r.viewshed/grass.cc
grass-addons/raster/r.viewshed/main.cc
G_fatal_error() calls exit
Modified: grass-addons/raster/r.viewshed/grass.cc
--- grass-addons/raster/r.viewshed/grass.cc 2008-12-11 07:54:59 UTC (rev 34823)
+++ grass-addons/raster/r.viewshed/grass.cc 2008-12-11 08:07:02 UTC (rev 34824)
@@ -99,25 +99,24 @@
hd->nrows = (dimensionType) nrows;
hd->ncols = (dimensionType) ncols;
- else {
- G_fatal_error(_("grid dimension too big for current precision"));
- exit(EXIT_FAILURE);
+ else
+ G_fatal_error(_("Grid dimension too big for current precision"));
/*fill in rest of header */
hd->xllcorner = G_col_to_easting(0, region);
hd->yllcorner = G_row_to_northing(0, region);
/*Cell_head stores 2 resolutions, while GridHeader only stores 1
//make sure the two Cell_head resolutions are equal */
if (fabs(region->ew_res - region->ns_res) > .001) {
- G_warning(_("east-west resolution does not equal north-south resolutio. The viewshed computation assumes the cells are square, so in this case this may result in innacuracies."));
+ G_warning(_("East-west resolution does not equal north-south resolutio. The viewshed computation assumes the cells are square, so in this case this may result in innacuracies."));
// exit(EXIT_FAILURE);
hd->cellsize = (float) region->ew_res;
//store the null value of the map
G_set_f_null_value(& (hd->nodata_value), 1);
- printf("nodata value set to %f\n", hd->nodata_value);
+ G_message("Nodata value set to %f", hd->nodata_value);
return hd;
@@ -125,9 +124,6 @@
/* input: an array capable to hold the max number of events, a raster
name, a viewpoint and the viewOptions; action: figure out all events
@@ -154,17 +150,13 @@
/*get the mapset name */
char *mapset;
mapset = G_find_cell(rastName, "");
- if (mapset == NULL) {
- G_fatal_error(_("raster map [%s] not found"), rastName);
+ if (mapset == NULL)
+ G_fatal_error(_("Raster map [%s] not found"), rastName);
/*open map */
int infd;
- if ((infd = G_open_cell_old(rastName, mapset)) < 0) {
+ if ((infd = G_open_cell_old(rastName, mapset)) < 0)
G_fatal_error(_("Cannot open raster file [%s]"), rastName);
/*get the data_type */
RASTER_MAP_TYPE data_type;
@@ -192,10 +184,8 @@
for (i = 0; i < G_window_rows(); i++) {
/*read in the raster row */
int rasterRowResult = G_get_raster_row(infd, inrast, i, data_type);
- if (rasterRowResult <= 0) {
- G_fatal_error(_("coord not read from row %d of %s"), i, rastName);
+ if (rasterRowResult <= 0)
+ G_fatal_error(_("Coord not read from row %d of <%s>"), i, rastName);
/*fill event list with events from this row */
for (j = 0; j < G_window_cols(); j++) {
@@ -231,7 +221,7 @@
set_viewpoint_elev(vp, e.elev + viewOptions.obsElev);
if (isnull) {
/*what to do when viewpoint is NODATA ? */
- G_message(_("WARNING: viewpoint is NODATA. "));
+ G_warning(_("Viewpoint is NODATA."));
G_message(_("Will assume its elevation is = %f"), vp->elev);
continue;
@@ -316,17 +306,14 @@
/*determine which mapset we are in */
char *mapset;
/*open map */
int infd;
data_type = G_raster_map_type(rastName, mapset);
void *inrast;
@@ -345,10 +332,9 @@
- if (G_get_raster_row(infd, inrast, i, data_type) <= 0) {
+ if (G_get_raster_row(infd, inrast, i, data_type) <= 0)
+ G_fatal_error(_("Coord not read from row %d of %s"), i, rastName);
@@ -386,8 +372,8 @@
/*what to do when viewpoint is NODATA */
if (is_nodata(hd, e.elev)) {
- printf("WARNING: viewpoint is NODATA. ");
- printf("Will assume its elevation is %.f\n", e.elev);
+ G_warning("Viewpoint is NODATA.");
+ G_message("Will assume its elevation is %.f", e.elev);
@@ -431,11 +417,10 @@
G_message(_("...done creating event list\n"));
G_close_cell(infd);
- printf("nbEvents = %lu\n", (unsigned long)eventList->stream_len());
- printf("Event stream length: %lu x %dB (%lu MB)\n",
- (unsigned long)eventList->stream_len(), (int)sizeof(AEvent),
- (unsigned
- long)(((long long)(eventList->stream_len() *
+ G_message("nbEvents = %lu", (unsigned long)eventList->stream_len());
+ G_message("Event stream length: %lu x %dB (%lu MB)",
+ (unsigned long)eventList->stream_len(), (int)sizeof(AEvent),
+ (unsigned long)(((long long)(eventList->stream_len() *
sizeof(AEvent))) >> 20));
fflush(stdout);
return eventList;
@@ -453,7 +438,7 @@
save_grid_to_GRASS(Grid* grid, char* filename, RASTER_MAP_TYPE type,
float(*fun)(float)) {
- G_message(_("saving grid to %s"), filename);
+ G_message(_("Saving grid to <%s>"), filename);
assert(grid && filename);
/*open the new raster */
@@ -503,22 +488,19 @@
save_vis_elev_to_GRASS(Grid* visgrid, char* elevfname, char* visfname,
float vp_elev) {
- G_message(_("saving grid to %s"), visfname);
+ G_message(_("Saving grid to <%s>"), visfname);
assert(visgrid && elevfname && visfname);
char *mapset;
mapset = G_find_cell(elevfname, "");
- G_fatal_error(_("raster map [%s] not found"), elevfname);
+ G_fatal_error(_("Raster map [%s] not found"), elevfname);
/*open elevation map */
int elevfd;
- if ((elevfd = G_open_cell_old(elevfname, mapset)) < 0) {
+ if ((elevfd = G_open_cell_old(elevfname, mapset)) < 0)
G_fatal_error(_("Cannot open raster file [%s]"), elevfname);
/*get elevation data_type */
RASTER_MAP_TYPE elev_data_type;
@@ -540,9 +522,9 @@
double elev=0, viewshed_value;
/* get the row from elevation */
- if (G_get_raster_row(elevfd, elevrast, i, elev_data_type) <= 0) {
- G_fatal_error(_("save_vis_elev_to_GRASS: could not read row %d"), i);
+ if (G_get_raster_row(elevfd, elevrast, i, elev_data_type) <= 0)
+ G_fatal_error(_("save_vis_elev_to_GRASS: could not read row %d"), i);
/* read the current elevation value */
@@ -608,7 +590,7 @@
((DCELL *) bufrast)[j] = (DCELL) x;
break;
default:
- G_fatal_error(_("unknown type"));
+ G_fatal_error(_("Unknown data type"));
@@ -625,8 +607,7 @@
G_set_d_null_value(& ((DCELL *) bufrast)[j], 1);
break;
default:
@@ -637,10 +618,11 @@
for each value x it writes to grass fun(x) */
void
save_io_visibilitygrid_to_GRASS(IOVisibilityGrid * visgrid,
- char* fname, RASTER_MAP_TYPE type,
- float (*fun)(float)) {
+ char* fname, RASTER_MAP_TYPE type,
+ float (*fun)(float))
- G_message(_("saving grid to %s"), fname);
+ G_message(_("Saving grid to <%s>"), fname);
assert(fname && visgrid);
/* open the output raster and set up its row buffer */
@@ -708,25 +690,22 @@
(i,j) order. */
void
save_io_vis_and_elev_to_GRASS(IOVisibilityGrid * visgrid, char* elevfname,
- char* visfname, float vp_elev) {
+ char* visfname, float vp_elev)
assert(visfname && visgrid);
/*get mapset name and data type */
char *mapset;
- G_fatal_error(_("opening %s: cannot find raster"), elevfname);
+ G_fatal_error(_("Opening <%s>: cannot find raster"), elevfname);
int elevfd;
@@ -764,10 +743,8 @@
- G_fatal_error(_("could not read row %d"), i);
+ G_fatal_error(_("Could not read row %d"), i);
Modified: grass-addons/raster/r.viewshed/main.cc
--- grass-addons/raster/r.viewshed/main.cc 2008-12-11 07:54:59 UTC (rev 34823)
+++ grass-addons/raster/r.viewshed/main.cc 2008-12-11 08:07:02 UTC (rev 34824)
@@ -133,10 +133,8 @@
module->description = _("IO-efficient viewshed algorithm");
struct Cell_head region;
- if (G_get_set_window(®ion) == -1) {
- G_fatal_error("error getting current region");
+ if (G_get_set_window(®ion) == -1)
+ G_fatal_error("Error getting current region");
#endif
@@ -192,10 +190,9 @@
the algorithm will work correctly in theory. But this
requires some changes. To do.*/
if (!(vp.row < hd->nrows && vp.col < hd->ncols)) {
- G_fatal_error(_("Viewpoint outside grid"));
- G_fatal_error(_("viewpont: (row=%d, col=%d)"), vp.row, vp.col);
+ G_warning(_("Viewpoint outside grid"));
+ G_warning(_("viewpont: (row=%d, col=%d)"), vp.row, vp.col);
G_fatal_error(_("grid: (rows=%d, cols=%d)"), hd->nrows, hd->ncols);
#else
/*open file input file and read grid header from grid ascii file */
@@ -575,8 +572,7 @@
viewOptions->maxDist = atof(maxDistOpt->answer);
if (viewOptions->maxDist < 0 &&
viewOptions->maxDist!= INFINITY_DISTANCE) {
- G_fatal_error(_("negative max distance value is not valid"));
+ G_fatal_error(_("Negative max distance value is not valid"));
@@ -716,10 +712,6 @@
/*print the timings for the internal memory method of computing the
viewshed */
