[GRASS-SVN] r34831 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Dec 11 14:10:39 EST 2008
Author: martinl
Date: 2008-12-11 14:10:39 -0500 (Thu, 11 Dec 2008)
New Revision: 34831
grass/trunk/gui/wxpython/gui_modules/dbm.py
wxGUI: add optionally records for each category on add layer
(merge from devbr6, r34830)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-12-11 19:05:56 UTC (rev 34830)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-12-11 19:10:39 UTC (rev 34831)
@@ -1609,7 +1609,10 @@
if event.GetSelection() == 0 and id:
win = self.FindWindowById(id)
- self.log.write(_("Number of loaded records: %d") % win.GetItemCount())
+ if win:
+ self.log.write(_("Number of loaded records: %d") % win.GetItemCount())
+ else:
+ self.log.write("")
else:
self.log.write("")
@@ -2160,7 +2163,12 @@
(wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
label='%s:' % _("Key column")),
wx.Choice(parent=self.addPanel, id=wx.ID_ANY, size=(200, -1),
- choices=self.defaultColumns))}
+ choices=self.defaultColumns)),
+ 'addCat':
+ (wx.CheckBox(parent=self.addPanel, id=wx.ID_ANY,
+ label=_("Insert record for each category into table")),
+ None),
# set default values for widgets
self.addLayerWidgets['driver'][1].SetStringSelection(self.defaultConnect['driver'])
@@ -2172,6 +2180,9 @@
self.addLayerWidgets['database'][1].Bind(wx.EVT_TEXT_ENTER, self.OnDatabaseChanged)
self.addLayerWidgets['table'][1].Bind(wx.EVT_CHOICE, self.OnTableChanged)
+ # tooltips
+ self.addLayerWidgets['addCat'][0].SetToolTipString(_("You need to add categories "
+ "by v.category module."))
# list of table widgets
@@ -2215,19 +2226,33 @@
layerSizer = wx.StaticBoxSizer(layerBox, wx.VERTICAL)
# data area
- dataSizer = wx.FlexGridSizer(cols=2, hgap=5, vgap=5)
+ dataSizer = wx.GridBagSizer(hgap=5, vgap=5)
dataSizer.AddGrowableCol(1)
- for key in ('layer', 'driver', 'database', 'table', 'key'):
+ row = 0
+ for key in ('layer', 'driver', 'database', 'table', 'key', 'addCat'):
label, value = self.addLayerWidgets[key]
+ if not value:
+ span = (1, 2)
+ else:
+ span = (1, 1)
dataSizer.Add(item=label,
- flag=wx.ALIGN_CENTER_VERTICAL)
+ flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0),
+ span=span)
+ if not value:
+ row += 1
+ continue
if label.GetLabel() == "Layer:":
- dataSizer.Add(item=value,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
+ style = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT
else:
- flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+ style = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND
+ dataSizer.Add(item=value,
+ flag=style, pos=(row, 1))
+ row += 1
layerSizer.Add(item=dataSizer,
proportion=1,
flag=wx.ALL | wx.EXPAND,
@@ -2239,7 +2264,7 @@
flag=wx.ALL | wx.ALIGN_LEFT,
border=5)
- btnSizer.Add(item=(5,5),
+ btnSizer.Add(item=(5, 5),
proportion=1,
border=5)
@@ -2283,12 +2308,12 @@
pageSizer.Add(item=layerSizer,
- proportion=1,
+ proportion=3,
border=5)
pageSizer.Add(item=tableSizer,
- proportion=1,
+ proportion=2,
border=5)
@@ -2297,7 +2322,7 @@
def __createDeletePage(self):
"""Delete layer"""
self.deletePanel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.AddPage(page=self.deletePanel, text=_("Delete selected layer"))
+ self.AddPage(page=self.deletePanel, text=_("Delete layer"))
label = wx.StaticText(parent=self.deletePanel, id=wx.ID_ANY,
label='%s:' % _("Layer to detele"))
@@ -2365,7 +2390,7 @@
def __createModifyPage(self):
"""Modify layer"""
self.modifyPanel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.AddPage(page=self.modifyPanel, text=_("Modify selected layer"))
+ self.AddPage(page=self.modifyPanel, text=_("Modify layer"))
# list of layer widgets (label, value)
@@ -2626,6 +2651,7 @@
caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
return
+ # add new layer
connectCmd = gcmd.Command(['v.db.connect',
'--q',
'map=%s' % self.mapDBInfo.map,
@@ -2635,6 +2661,16 @@
'key=%s' % key,
'layer=%d' % layer])
+ # insert records into table if required
+ if self.addLayerWidgets['addCat'][0].IsChecked():
+ gcmd.Command(['v.to.db',
+ '--q',
+ 'map=%s' % self.mapDBInfo.map,
+ 'layer=%d' % layer,
+ 'qlayer=%d' % layer,
+ 'option=cat',
+ 'columns=%s' % key])
if connectCmd.returncode == 0:
# update dialog (only for new layer)
self.parentDialog.UpdateDialog(layer=layer)
@@ -2652,7 +2688,6 @@
def OnDeleteLayer(self, event):
"""Delete layer"""
try:
layer = int(self.deleteLayer.GetValue())
except:
@@ -2676,6 +2711,11 @@
'database=%s' % database],
stdin=sql)
+ # update list of tables
+ tableList = self.addLayerWidgets['table'][1]
+ tableList.SetItems(self.__getTables(driver, database))
+ tableList.SetStringSelection(table)
# update dialog
# update db info
