[GRASS-SVN] r34833 - in grass/trunk/raster/r.watershed: ram seg
Fri Dec 12 08:22:44 EST 2008
Author: glynn
Date: 2008-12-12 08:22:43 -0500 (Fri, 12 Dec 2008)
New Revision: 34833
   grass/trunk/raster/r.watershed/ram/do_cum.c
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster/r.watershed/seg/do_cum.c
   grass/trunk/raster/r.watershed/seg/init_vars.c
Patch from Markus Metz (ticket #398)
Modified: grass/trunk/raster/r.watershed/ram/do_cum.c
--- grass/trunk/raster/r.watershed/ram/do_cum.c	2008-12-11 20:41:24 UTC (rev 34832)
+++ grass/trunk/raster/r.watershed/ram/do_cum.c	2008-12-12 13:22:43 UTC (rev 34833)
@@ -87,12 +87,13 @@
     DCELL value, valued;
     int killer, threshold, count;
-    int mfd_cells, astar_not_set;
+    /* MFD */
+    int mfd_cells, stream_cells, swale_cells, astar_not_set;
     double *dist_to_nbr, *weight, sum_weight, max_weight;
-    int r_nbr, c_nbr, ct_dir, np_side, in_val;
+    int r_nbr, c_nbr, r_max, c_max, r_swale, c_swale, ct_dir, np_side;
     double dx, dy;
-    CELL ele, ele_nbr;
-    double prop;
+    CELL ele, ele_nbr, aspect, is_worked;
+    double prop, max_acc, max_swale;
     int workedon;
     G_message(_("SECTION 3: Accumulating Surface Flow with MFD"));
@@ -135,10 +136,6 @@
 	    value = wat[SEG_INDEX(wat_seg, r, c)];
 	    valued = wat[SEG_INDEX(wat_seg, dr, dc)];
-	    /* disabled for MFD */
-	    /* if (ABS(value) > threshold)
-	       FLAG_SET(swale, r, c); */
 	    /* start MFD */
 	    /* get weights */
@@ -157,8 +154,8 @@
 		/* check that neighbour is within region */
 		if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 &&
 		    c_nbr < ncols) {
-		    in_val = FLAG_GET(worked, r_nbr, c_nbr);
-		    if (in_val == 0) {
+		    is_worked = FLAG_GET(worked, r_nbr, c_nbr);
+		    if (is_worked == 0) {
 			ele_nbr = alt[SEG_INDEX(alt_seg, r_nbr, c_nbr)];
 			if (ele_nbr < ele) {
 			    weight[ct_dir] =
@@ -202,6 +199,15 @@
 	    /* set flow accumulation for neighbours */
+	    stream_cells = 0;
+	    swale_cells = 0;
+	    max_acc = -1;
+	    max_swale = -1;
+	    r_max = dr;
+	    c_max = dc;
+	    r_swale = dr;
+	    c_swale = dc;
 	    if (mfd_cells > 1) {
 		prop = 0.0;
 		for (ct_dir = 0; ct_dir < sides; ct_dir++) {
@@ -212,8 +218,9 @@
 			c_nbr < ncols && weight[ct_dir] > -0.5) {
+			is_swale = FLAG_GET(swale, r_nbr, c_nbr);
 			    weight[ct_dir] = weight[ct_dir] / sum_weight;
 			    prop += weight[ct_dir];	/* check everything sums up to 1.0 */
@@ -232,10 +239,26 @@
 				    valued = value * weight[ct_dir] - valued;
 			    wat[SEG_INDEX(wat_seg, r_nbr, c_nbr)] = valued;
+			    if ((ABS(valued) + 0.5) >= threshold)
+				stream_cells++;
+			    if (ABS(valued) > max_acc) {
+				max_acc = ABS(valued);
+				r_max = r_nbr;
+				c_max = c_nbr;
+			    /* assist in stream merging */
+			    if (is_swale && ABS(valued) > max_swale) {
+				max_swale = ABS(valued);
+				r_swale = r_nbr;
+				c_swale = c_nbr;
 			else if (ct_dir == np_side) {
 			    workedon++;	/* check for consistency with A * path */
+			if (is_swale)
+			    swale_cells++;
 		if (ABS(prop - 1.0) > 5E-6f) {
@@ -243,6 +266,10 @@
 			      prop);
+		if (max_swale > -0.5) {
+		    r_max = r_swale;
+		    c_max = c_swale;
 	    if (mfd_cells < 2) {
@@ -264,15 +291,28 @@
 	    /* MFD finished */
 	    valued = ABS(valued) + 0.5;
 	    is_swale = FLAG_GET(swale, r, c);
-	    if (is_swale || ((int)valued) >= threshold) {
+	    /* start new stream: only works with A * path */
+	    if (!is_swale && (int)valued >= threshold && stream_cells < 2 &&
+		swale_cells < 1) {
 		FLAG_SET(swale, dr, dc);
+	    /* continue stream */
+	    if (is_swale) {
+		FLAG_SET(swale, r_max, c_max);
 	    else {
 		if (er_flag && !is_swale)
-		    slope_length(r, c, dr, dc);
+		    slope_length(r, c, r_max, c_max);
+	    /* update asp */
+	    if (dr != r_max || dc != c_max) {
+		aspect = drain[r - r_max + 1][c - c_max + 1];
+		if (asp[SEG_INDEX(asp_seg, r, c)] < 0)
+		    aspect = -aspect;
+		asp[SEG_INDEX(asp_seg, r, c)] = aspect;
 	    FLAG_SET(worked, r, c);
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c	2008-12-11 20:41:24 UTC (rev 34832)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c	2008-12-12 13:22:43 UTC (rev 34833)
@@ -129,11 +129,19 @@
 	G_fatal_error(_("unable to open elevation map layer"));
+    swale = flag_create(nrows, ncols);
+    in_list = flag_create(nrows, ncols);
+    worked = flag_create(nrows, ncols);
     for (r = 0; r < nrows; r++) {
 	G_get_c_raster_row(fd, buf, r);
 	for (c = 0; c < ncols; c++) {
 	    index = SEG_INDEX(alt_seg, r, c);
 	    alt[index] = r_h[index] = buf[c];
+	    /* all flags need to be manually set to zero */
+	    flag_unset(swale, r, c);
+	    flag_unset(in_list, r, c);
+	    flag_unset(worked, r, c);
     G_close_cell(fd);
@@ -176,7 +184,7 @@
 	G_close_cell(fd);
-    swale = flag_create(nrows, ncols);
     if (ob_flag) {
 	fd = G_open_cell_old(ob_name, "");
 	if (fd < 0) {
@@ -197,8 +205,7 @@
 	    G_fatal_error(_("unable to open rill map layer"));
-    in_list = flag_create(nrows, ncols);
-    worked = flag_create(nrows, ncols);
     MASK_flag = 0;
     do_points = nrows * ncols;
     if (NULL != G_find_file("cell", "MASK", G_mapset())) {
@@ -237,7 +244,7 @@
 			       sizeof(double));
-    /* heap_index will track astar_pts in the binary min-heap */
+    /* heap_index will track astar_pts in ternary min-heap */
     /* heap_index is one-based */
     heap_index = (int *)G_malloc((do_points + 1) * sizeof(int));
Modified: grass/trunk/raster/r.watershed/seg/do_cum.c
--- grass/trunk/raster/r.watershed/seg/do_cum.c	2008-12-11 20:41:24 UTC (rev 34832)
+++ grass/trunk/raster/r.watershed/seg/do_cum.c	2008-12-12 13:22:43 UTC (rev 34833)
@@ -92,12 +92,13 @@
     POINT point;
+    /* MFD */
     double dx, dy;
-    double prop;
+    CELL ele, ele_nbr, aspect, asp_val, is_worked;
     int workedon;
     G_message(_("SECTION 3: Accumulating Surface Flow with MFD."));
@@ -168,8 +169,8 @@
 		    c_nbr < ncols) {
-		    bseg_get(&worked, &in_val, r_nbr, c_nbr);
+		    bseg_get(&worked, &is_worked, r_nbr, c_nbr);
 			cseg_get(&alt, &ele_nbr, r_nbr, c_nbr);
 			    weight[ct_dir] =
@@ -213,6 +214,15 @@
+	    stream_cells = 0;
+	    swale_cells = 0;
+	    max_acc = -1;
+	    max_swale = -1;
+	    r_max = dr;
+	    c_max = dc;
+	    r_swale = dr;
+	    c_swale = dc;
 		prop = 0.0;
@@ -223,8 +233,9 @@
+			bseg_get(&swale, &is_swale, r_nbr, c_nbr);
@@ -243,6 +254,20 @@
 			    dseg_put(&wat, &valued, r_nbr, c_nbr);
+				stream_cells++;
+				r_max = r_nbr;
+				c_max = c_nbr;
+				r_swale = r_nbr;
+				c_swale = c_nbr;
@@ -254,6 +279,10 @@
 			      prop);
 		dseg_get(&wat, &valued, dr, dc);
+		    r_max = r_swale;
+		    c_max = c_swale;
@@ -275,15 +304,29 @@
 	    /* MFD finished */
 	    bseg_get(&swale, &is_swale, r, c);
-	    if (is_swale || (int)valued >= threshold) {
 		bseg_put(&swale, &one, dr, dc);
+	    if (is_swale) {
+		bseg_put(&swale, &one, r_max, c_max);
 	    else {
+	    /* update asp */
+		cseg_get(&asp, &asp_val, r, c);
+		if (asp_val < 0)
+		    aspect = -aspect;
+		cseg_put(&asp, &aspect, r, c);
 	    bseg_put(&worked, &one, r, c);
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c	2008-12-11 20:41:24 UTC (rev 34832)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c	2008-12-12 13:22:43 UTC (rev 34833)
@@ -240,7 +240,7 @@
     seg_open(&astar_pts, 1, do_points, 1, seg_rows * seg_cols,
 	     num_open_segs, sizeof(POINT));
     seg_open(&heap_index, 1, do_points + 1, 1, seg_rows * seg_cols,
 	     num_open_segs, sizeof(HEAP));
