[GRASS-SVN] r34847 - grass-addons/raster/r.pack
svn_grass at osgeo.org
Sat Dec 13 05:52:00 EST 2008
Author: hamish
Date: 2008-12-13 05:51:59 -0500 (Sat, 13 Dec 2008)
New Revision: 34847
Added:
grass-addons/raster/r.pack/r.pack2
new version of r.pack copying elements instead of using r.out.mat
Added: grass-addons/raster/r.pack/r.pack2
--- grass-addons/raster/r.pack/r.pack2 (rev 0)
+++ grass-addons/raster/r.pack/r.pack2 2008-12-13 10:51:59 UTC (rev 34847)
@@ -0,0 +1,133 @@
+#!/bin/sh
+# r.pack -- pack up a raster map:
+# collect raster map elements => gzip
+# (c) 2004-2008 GRASS Development Team
+# AUTHOR: Hamish Bowman, Otago University, New Zealand
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Packs up a raster map and support files for copying
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Name of an existing raster map
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,output
+#% description: Name for output file (default is input-map.pack)
+#% required : no
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+# check for tar (is there a better way?)
+if [ -z "`which tar`" ] ; then
+ echo "ERROR: tar must be installed to use this program."
+ exit 1
+fi
+# check for gzip
+if [ -z "`which gzip`" ] ; then
+ echo "ERROR: gzip must be installed to use this program."
+ exit 1
+fi
+if [ -n "$GIS_OPT_OUTPUT" ] ; then
+ outfile="$GIS_OPT_OUTPUT"
+else
+ outfile="$GIS_OPT_INPUT.pack"
+fi
+#be overly helpful
+outfile="`basename "$outfile" .pack`.pack"
+eval `g.findfile elem=cell file="$GIS_OPT_INPUT"`
+if [ -z "$name" ] ; then
+ g.message -e "Map not found"
+ exit 1
+fi
+# create temporary directory to hold bits
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+ g.message -e "Unable to create temporary files"
+fi
+rm -f "$TMP"
+mkdir "$TMP"
+TMP_DIR="$TMP/$name"
+mkdir "$TMP_DIR"
+if [ ! -d "$TMP_DIR" ] ; then
+ g.message -e "Unable to create temporary directory"
+ exit 1
+fi
+BASEDIR=`echo "$file" | sed -e 's+/cell/.*$++'`
+OLDDIR=`pwd`
+for ELEMENT in cats cell cellhd colr fcell grid3 hist ; do
+ if [ -e "$BASEDIR/$ELEMENT/$GIS_OPT_INPUT" ] ; then
+ cp "$BASEDIR/$ELEMENT/$name" "$TMP_DIR/$ELEMENT"
+ fi
+done
+if [ -d "$BASEDIR/cell_misc/$GIS_OPT_INPUT/" ] ; then
+ mkdir "$TMP_DIR/cell_misc/"
+ cp "$BASEDIR/cell_misc/$name/"* "$TMP_DIR/cell_misc/"
+fi
+if [ -z "`ls $TMP_DIR`" ] ; then
+ g.message -e "No map components found"
+ exit 1
+fi
+# copy projection info
+# (would prefer to use g.proj*, but this way is 5.3 and 5.7 compat)
+eval `g.gisenv`
+for SUPPORT in INFO UNITS ; do
+ if [ -e "$GISDBASE/$LOCATION_NAME/PERMANENT/PROJ_$SUPPORT" ] ; then
+ cp "$GISDBASE/$LOCATION_NAME/PERMANENT/PROJ_$SUPPORT" "$TMP_DIR"
+ fi
+done
+# pack it all up
+cd "$TMP"
+tar czf "$outfile" *
+# clean up
+mv "$outfile" "$OLDDIR/"
+if [ $? -ne 0 ] ; then
+ g.message -e "Saving file to <$OLDDIR/$outfile>"
+ rm -rf "$TMP"
+ exit 1
+fi
+cd "$OLD_DIR"
+rm -rf "$TMP"
+g.message -v "Done. Map saved to <$OLDDIR/$outfile>"
+exit 0
Property changes on: grass-addons/raster/r.pack/r.pack2
___________________________________________________________________
+ text/x-sh
+ native
